[PATCH 0/6] arm64: zynqmp: DT syncup patches
this series is trying to clean and sync DTS files. At the end we want to have all these files be in sync with the Linux kernel based on DT binding available in the Linux kernel.
Thanks, Michal
Michal Simek (6): arm64: zynqmp: Remove additional header from zc1232 DT arm64: zynqmp: Add maximum-speed property for dwc3 nodes arm64: zynqmp: Remove addition newline from zc1751 dc1 arm64: zynqmp: Remove unused dp_aclk clock arm64: zynqmp: Sync dp port location on zc1751 dc4 arm64: zynqmp: Sync psgtr location on zcu100/zcu106
arch/arm/dts/zynqmp-clk-ccf.dtsi | 7 ------- arch/arm/dts/zynqmp-zc1232-revA.dts | 1 - arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 2 +- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 16 ++++++++-------- arch/arm/dts/zynqmp-zcu100-revC.dts | 14 +++++++------- arch/arm/dts/zynqmp-zcu106-revA.dts | 15 ++++++++------- arch/arm/dts/zynqmp-zcu111-revA.dts | 1 + arch/arm/dts/zynqmp-zcu208-revA.dts | 1 + arch/arm/dts/zynqmp-zcu216-revA.dts | 1 + 9 files changed, 27 insertions(+), 31 deletions(-)
Remove unused phy.h from zc1232 DTS.
arch/arm/dts/zynqmp-zc1232-revA.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zc1232-revA.dts b/arch/arm/dts/zynqmp-zc1232-revA.dts index 65dd4e1f3a5d..7543855c9fda 100644 --- a/arch/arm/dts/zynqmp-zc1232-revA.dts +++ b/arch/arm/dts/zynqmp-zc1232-revA.dts @@ -11,7 +11,6 @@
#include "zynqmp.dtsi" #include "zynqmp-clk-ccf.dtsi" -#include <dt-bindings/phy/phy.h>
/ { model = "ZynqMP ZC1232 RevA";
dwc3 can be used only for higher speeds than super-speed that's why explicitly set it up. This is also aligned with other ZynqMP dts files.
arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 1 + arch/arm/dts/zynqmp-zcu106-revA.dts | 1 + arch/arm/dts/zynqmp-zcu111-revA.dts | 1 + arch/arm/dts/zynqmp-zcu208-revA.dts | 1 + arch/arm/dts/zynqmp-zcu216-revA.dts | 1 + 5 files changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index 0c6a2a92dfe5..b0506c08418e 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -433,6 +433,7 @@ snps,usb3_lpm_capable; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; + maximum-speed = "super-speed"; };
&zynqmp_dpdma { diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index 4da7a3edf548..d7140fc950ee 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -1040,6 +1040,7 @@ snps,usb3_lpm_capable; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; + maximum-speed = "super-speed"; };
&watchdog0 { diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index 85821065dd43..223bb8a61462 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -861,6 +861,7 @@ snps,usb3_lpm_capable; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; + maximum-speed = "super-speed"; };
&zynqmp_dpdma { diff --git a/arch/arm/dts/zynqmp-zcu208-revA.dts b/arch/arm/dts/zynqmp-zcu208-revA.dts index 03c84ae21acb..7607098ac077 100644 --- a/arch/arm/dts/zynqmp-zcu208-revA.dts +++ b/arch/arm/dts/zynqmp-zcu208-revA.dts @@ -701,4 +701,5 @@ snps,usb3_lpm_capable; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; + maximum-speed = "super-speed"; }; diff --git a/arch/arm/dts/zynqmp-zcu216-revA.dts b/arch/arm/dts/zynqmp-zcu216-revA.dts index fd1d9bfbd199..7ba60da131f1 100644 --- a/arch/arm/dts/zynqmp-zcu216-revA.dts +++ b/arch/arm/dts/zynqmp-zcu216-revA.dts @@ -705,4 +705,5 @@ snps,usb3_lpm_capable; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; + maximum-speed = "super-speed"; };
Trivial patch.
arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts index b0506c08418e..8f361e47bda1 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts @@ -443,4 +443,3 @@ &zynqmp_dpsub { status = "okay"; }; -
dp_aclk is not used anywhere that's why remove it.
arch/arm/dts/zynqmp-clk-ccf.dtsi | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/arch/arm/dts/zynqmp-clk-ccf.dtsi b/arch/arm/dts/zynqmp-clk-ccf.dtsi index 987792e5c511..5ee7aa244552 100644 --- a/arch/arm/dts/zynqmp-clk-ccf.dtsi +++ b/arch/arm/dts/zynqmp-clk-ccf.dtsi @@ -67,13 +67,6 @@ #clock-cells = <0>; clock-frequency = <27000000>; }; - - dp_aclk: dp_aclk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <100000000>; - clock-accuracy = <100>; - }; };
&zynqmp_firmware {
Historically dpdma and dpsub are placed at the end of files. Move nodes there for easier comparison among dts files.
arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts index aadda179c323..e7fbf1c4b70c 100644 --- a/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts +++ b/arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts @@ -115,14 +115,6 @@ status = "okay"; };
-&zynqmp_dpsub { - status = "okay"; -}; - -&zynqmp_dpdma { - status = "okay"; -}; - &gem0 { status = "okay"; phy-mode = "rgmii-id"; @@ -221,3 +213,11 @@ &watchdog0 { status = "okay"; }; + +&zynqmp_dpdma { + status = "okay"; +}; + +&zynqmp_dpsub { + status = "okay"; +};
psgtr node should be below pinctrl for easier comparion among dts files. That's why move that nodes to different location.
arch/arm/dts/zynqmp-zcu100-revC.dts | 14 +++++++------- arch/arm/dts/zynqmp-zcu106-revA.dts | 14 +++++++------- 2 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu100-revC.dts b/arch/arm/dts/zynqmp-zcu100-revC.dts index cad1a23e9539..45dd7da7179b 100644 --- a/arch/arm/dts/zynqmp-zcu100-revC.dts +++ b/arch/arm/dts/zynqmp-zcu100-revC.dts @@ -483,6 +483,13 @@ }; };
+&psgtr { + status = "okay"; + /* usb3, dp */ + clocks = <&si5335_0>, <&si5335_1>; + clock-names = "ref0", "ref1"; +}; + &rtc { status = "okay"; }; @@ -518,13 +525,6 @@ }; };
-&psgtr { - status = "okay"; - /* usb3, dp */ - clocks = <&si5335_0>, <&si5335_1>; - clock-names = "ref0", "ref1"; -}; - &spi0 { /* Low Speed connector */ status = "okay"; label = "LS-SPI0"; diff --git a/arch/arm/dts/zynqmp-zcu106-revA.dts b/arch/arm/dts/zynqmp-zcu106-revA.dts index d7140fc950ee..2b1255dc5f32 100644 --- a/arch/arm/dts/zynqmp-zcu106-revA.dts +++ b/arch/arm/dts/zynqmp-zcu106-revA.dts @@ -947,6 +947,13 @@ }; };
+&psgtr { + status = "okay"; + /* nc, sata, usb3, dp */ + clocks = <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; + clock-names = "ref1", "ref2", "ref3"; +}; + &qspi { status = "okay"; is-dual = <1>; @@ -977,13 +984,6 @@ }; };
-&psgtr { - status = "okay"; - /* nc, sata, usb3, dp */ - clocks = <&si5341 0 3>, <&si5341 0 2>, <&si5341 0 0>; - clock-names = "ref1", "ref2", "ref3"; -}; - &rtc { status = "okay"; };
čt 3. 6. 2021 v 10:11 odesílatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.31.1
Applied. M
Michal Simek
Michal Simek
