[U-Boot] [PATCH 00/20] spi/sf: Kconfig updates
Kconfig additions for spi/sf related drivers.
thanks! Jagan.
Jagan Teki (20): sf: dataflash: Rename to CONFIG_SPI_FLASH_DATAFLASH README: Add CONFIG_SPI_FLASH_DATAFLASH description sf: Add Kconfig menu entry common: Add CMD_SF Kconfig entry sf: Kconfig: Update SPI_FLASH entry sf: Kconfig: Add SPI_FLASH_MTD entry sf: Kconfig: Add SPI_FLASH_DATAFLASH entry spi: Add Kconfig menu entry spi: Kconfig: Add XILINX_SPI entry spi: Kconfig: Add TI_QSPI entry spi: Makefile: Use object file alphabetic order spi: Kconfig: Show dm-spi drivers if DM_SPI set spi: Kconfig: Add FSL_DSPI entry spi: Kconfig: Add FSL_ESPI entry spi: Kconfig: Add FSL_QSPI entry spi: Kconfig: Add EXYNOS_SPI entry spi: Kconfig: Add ICH_SPI entry spi: Kconfig: Add TEGRA114_SPI entry spi: Kconfig: Add TEGRA20_SFLASH entry spi: Kconfig: Add TEGRA20_SLINK entry
README | 5 ++ common/Kconfig | 5 ++ drivers/mtd/spi/Kconfig | 41 +++++++++++++---- drivers/mtd/spi/Makefile | 2 +- drivers/spi/Kconfig | 106 +++++++++++++++++++++++++++++++++++++------ drivers/spi/Makefile | 10 ++-- include/configs/ls1021aqds.h | 2 +- 7 files changed, 143 insertions(+), 28 deletions(-)
Rename CONFIG_SF_DATAFLASH into CONFIG_SPI_FLASH_DATAFLASH as it follows the naming convention same as remaining configs.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/Makefile | 2 +- include/configs/ls1021aqds.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index ed46648..ff48b25 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -15,9 +15,9 @@ endif #ifndef CONFIG_DM_SPI obj-$(CONFIG_SPI_FLASH) += sf_probe.o #endif -obj-$(CONFIG_SF_DATAFLASH) += sf_dataflash.o obj-$(CONFIG_CMD_SF) += sf.o obj-$(CONFIG_SPI_FLASH) += sf_ops.o sf_params.o +obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o obj-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 973454b..75b9ccb 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -423,7 +423,7 @@ unsigned long get_board_ddr_clk(void); #if defined(CONFIG_FSL_DSPI) || defined(CONFIG_FSL_QSPI) #define CONFIG_CMD_SF #define CONFIG_DM_SPI_FLASH -#define CONFIG_SF_DATAFLASH +#define CONFIG_SPI_FLASH_DATAFLASH #endif #endif
This patch adds CONFIG_SPI_FLASH_DATAFLASH descrition on README file for more readble for users.
Signed-off-by: Jagan Teki jteki@openedev.com --- README | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/README b/README index 168d824..c49af74 100644 --- a/README +++ b/README @@ -3099,6 +3099,11 @@ CBFS (Coreboot Filesystem) support is needed for subsystems like UBI which can only operate on top of the MTD layer.
+ CONFIG_SPI_FLASH_DATAFLASH SPI based Dataflash + + Define this option to access AT45xxx Dataflash chips support + using spi flash interface. + - SystemACE Support: CONFIG_SYSTEMACE
Added Kconfig menu ... endmenu enties for spi flash suppor
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 40a7981..aa3468b 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -1,3 +1,5 @@ +menu "SPI Flash Support" + config SPI_FLASH bool "Enable SPI Flash support" help @@ -31,3 +33,5 @@ config SPI_FLASH_SANDBOX bus (see CONFIG_SANDBOX_SPI) and SPI traffic will be routed to this device. Typically the contents of the emulated SPI flash device is stored in a file on the host filesystem. + +endmenu # menu "SPI Flash Support"
Added Kconfig entry for CMD_SF.
Signed-off-by: Jagan Teki jteki@openedev.com --- common/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/Kconfig b/common/Kconfig index 2976cd7..40cd69e 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -311,6 +311,11 @@ config CMD_NAND help NAND support.
+config CMD_SF + bool "sf" + help + SPI Flash support + config CMD_SPI bool "sspi" help
Updated SPI_FLASH entry on Kconfig with depends on and along with config help description.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/Kconfig | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index aa3468b..9536aac 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -1,14 +1,5 @@ menu "SPI Flash Support"
-config SPI_FLASH - bool "Enable SPI Flash support" - help - Enable the legacy SPI flash support. This will include basic - standard support for things like probing, read / write, and - erasing through the MTD layer. - - If unsure, say N - config DM_SPI_FLASH bool "Enable Driver Model for SPI flash" depends on DM && DM_SPI @@ -34,4 +25,14 @@ config SPI_FLASH_SANDBOX device. Typically the contents of the emulated SPI flash device is stored in a file on the host filesystem.
+config SPI_FLASH + bool "Legacy SPI Flash Interface support" + depends on CMD_SF + help + Enable the legacy SPI flash support. This will include basic + standard support for things like probing, read / write, and + erasing through cmd_sf interface. + + If unsure, say N + endmenu # menu "SPI Flash Support"
Added SPI_FLASH_MTD entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Heiko Schocher hs@denx.de --- drivers/mtd/spi/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 9536aac..217e4d7 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -35,4 +35,16 @@ config SPI_FLASH
If unsure, say N
+config SPI_FLASH_MTD + bool "SPI Flash MTD support" + depends on SPI_FLASH + help + Enable the MTD support for spi flash layer, this adapter is for + translating mtd_read/mtd_write commands into spi_flash_read/write + commands. It is not intended to use it within sf_cmd or the SPI + flash subsystem. Such an adapter is needed for subsystems like + UBI which can only operate on top of the MTD layer. + + If unsure, say N + endmenu # menu "SPI Flash Support"
2015-06-27 20:13 GMT+02:00 Jagan Teki jteki@openedev.com:
If unsure, say N
help
If unsure, say N
1.9.1
looks good. Maybe you also should remove that help text from the README file.
Acked-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
On 29 June 2015 at 21:25, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
If unsure, say N
help
If unsure, say N
1.9.1
Thought the same, will send the patch.
thanks!
Added SPI_FLASH_DATAFLASH entry on Kconfig with help description
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Haikun Wang haikun.wang@freescale.com Cc: Simon Glass sjg@chromium.org --- drivers/mtd/spi/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 217e4d7..6b38ffc 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -35,6 +35,14 @@ config SPI_FLASH
If unsure, say N
+config SPI_FLASH_DATAFLASH + bool "AT45xxx DataFlash support" + depends on SPI_FLASH && DM_SPI_FLASH + help + Enable the access for SPI Flash based AT45xxx DataFlash chips. + + If unsure, say N + config SPI_FLASH_MTD bool "SPI Flash MTD support" depends on SPI_FLASH
Hi Jagan,
If unsure, say N
help
nit: SPI-flash-based
You could talk a little more about the chips capabilities? Normally we try to have 4 lines here.
If unsure, say N
config SPI_FLASH_MTD bool "SPI Flash MTD support" depends on SPI_FLASH -- 1.9.1
On 1 July 2015 at 01:18, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
If unsure, say N
help
If unsure, say N
Applied to u-boot-spi/master
thanks!
Added Kconfig menu ... endmenu enties for spi support.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index fbff707..913951f 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -1,3 +1,5 @@ +menu "SPI Support" + config DM_SPI bool "Enable Driver Model for SPI drivers" depends on DM @@ -59,3 +61,5 @@ config ZYNQ_SPI Enable the Zynq SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Zynq SPI IP core. + +endmenu # menu "SPI Support"
Added XILINX_SPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Michal Simek michal.simek@xilinx.com --- drivers/spi/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 913951f..452dd4d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -54,6 +54,15 @@ config CADENCE_QSPI used to access the SPI NOR flash on platforms embedding this Cadence IP core.
+config XILINX_SPI + bool "Xilinx SPI driver" + depends on DM_SPI + help + Enable the Xilinx SPI driver from the Xilinx EDK. This SPI + controller support 8 bit SPI transfers only, with or w/o FIFO. + For more info on Xilinx SPI Register Definitions and Overview + see driver file - drivers/spi/xilinx_spi.c + config ZYNQ_SPI bool "Zynq SPI driver" depends on DM_SPI && (ARCH_ZYNQ || TARGET_XILINX_ZYNQMP)
Added TI_QSPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 452dd4d..218657e 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -54,6 +54,12 @@ config CADENCE_QSPI used to access the SPI NOR flash on platforms embedding this Cadence IP core.
+config TI_QSPI + bool "TI QSPI driver" + help + Enable the TI Quad-SPI (QSPI) driver for DRA7xx and AM43xx evms. + This driver support spi flash single, quad and memory reads. + config XILINX_SPI bool "Xilinx SPI driver" depends on DM_SPI
Use object files as incresing alphabetic order, so-that it's easy for readability.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 507c315..ee88aa1 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -15,7 +15,6 @@ obj-y += spi.o obj-$(CONFIG_SOFT_SPI) += soft_spi_legacy.o endif
-obj-$(CONFIG_EP93XX_SPI) += ep93xx_spi.o obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o @@ -27,7 +26,11 @@ obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o +obj-$(CONFIG_EP93XX_SPI) += ep93xx_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o +obj-$(CONFIG_FSL_DSPI) += fsl_dspi.o +obj-$(CONFIG_FSL_ESPI) += fsl_espi.o +obj-$(CONFIG_FSL_QSPI) += fsl_qspi.o obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_LPC32XX_SSP) += lpc32xx_ssp.o @@ -39,12 +42,9 @@ obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o obj-$(CONFIG_SH_SPI) += sh_spi.o obj-$(CONFIG_SH_QSPI) += sh_qspi.o -obj-$(CONFIG_FSL_ESPI) += fsl_espi.o +obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o -obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o -obj-$(CONFIG_FSL_QSPI) += fsl_qspi.o -obj-$(CONFIG_FSL_DSPI) += fsl_dspi.o
DM supported spi drivers are enbled only when DM_SPI enabled, so added DM_SPI if condition in Kconfig to show thoese only when it enabled.
Also re-order the config items as incresing alphabetic order.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/Kconfig | 51 ++++++++++++++++++++++++++------------------------- 1 file changed, 26 insertions(+), 25 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 218657e..7277bbd 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -13,6 +13,22 @@ config DM_SPI typically use driver-private data instead of extending the spi_slave structure.
+if DM_SPI + +config CADENCE_QSPI + bool "Cadence QSPI driver" + help + Enable the Cadence Quad-SPI (QSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + Cadence IP core. + +config DESIGNWARE_SPI + bool "Designware SPI driver" + help + Enable the Designware SPI driver. This driver can be used to + access the SPI NOR flash on platforms embedding this Designware + IP core. + config SANDBOX_SPI bool "Sandbox SPI driver" depends on SANDBOX && DM @@ -36,33 +52,10 @@ config SANDBOX_SPI spi-max-frequency = <40000000>; sandbox,filename = "spi.bin"; }; - }; - -config DESIGNWARE_SPI - bool "Designware SPI driver" - depends on DM_SPI - help - Enable the Designware SPI driver. This driver can be used to - access the SPI NOR flash on platforms embedding this Designware - IP core. - -config CADENCE_QSPI - bool "Cadence QSPI driver" - depends on DM_SPI - help - Enable the Cadence Quad-SPI (QSPI) driver. This driver can be - used to access the SPI NOR flash on platforms embedding this - Cadence IP core. - -config TI_QSPI - bool "TI QSPI driver" - help - Enable the TI Quad-SPI (QSPI) driver for DRA7xx and AM43xx evms. - This driver support spi flash single, quad and memory reads. + };
config XILINX_SPI bool "Xilinx SPI driver" - depends on DM_SPI help Enable the Xilinx SPI driver from the Xilinx EDK. This SPI controller support 8 bit SPI transfers only, with or w/o FIFO. @@ -71,10 +64,18 @@ config XILINX_SPI
config ZYNQ_SPI bool "Zynq SPI driver" - depends on DM_SPI && (ARCH_ZYNQ || TARGET_XILINX_ZYNQMP) + depends on ARCH_ZYNQ || TARGET_XILINX_ZYNQMP help Enable the Zynq SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Zynq SPI IP core.
+endif # if DM_SPI + +config TI_QSPI + bool "TI QSPI driver" + help + Enable the TI Quad-SPI (QSPI) driver for DRA7xx and AM43xx evms. + This driver support spi flash single, quad and memory reads. + endmenu # menu "SPI Support"
Added FSL_DSPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Haikun Wang haikun.wang@freescale.com --- drivers/spi/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 7277bbd..9c6c5d5 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -29,6 +29,14 @@ config DESIGNWARE_SPI access the SPI NOR flash on platforms embedding this Designware IP core.
+config FSL_DSPI + bool "Freescale DSPI driver" + help + Enable the Freescale DSPI driver. This driver can be used to + access the SPI NOR flash and SPI Data flash on platforms embedding + this Freescale DSPI IP core. LS102xA and Colibri VF50/VF61 platforms + use this driver. + config SANDBOX_SPI bool "Sandbox SPI driver" depends on SANDBOX && DM
Added FSL_ESPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Haikun Wang haikun.wang@freescale.com --- drivers/spi/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 9c6c5d5..2c0046d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -80,6 +80,13 @@ config ZYNQ_SPI
endif # if DM_SPI
+config FSL_ESPI + bool "Freescale eSPI driver" + help + Enable the Freescale eSPI driver. This driver can be used to + access the SPI interface and SPI NOR flash on platforms embedding + this Freescale eSPI IP core. + config TI_QSPI bool "TI QSPI driver" help
Added FSL_QSPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Peng Fan Peng.Fan@freescale.com Cc: Haikun Wang haikun.wang@freescale.com --- drivers/spi/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 2c0046d..e4a90e8 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -37,6 +37,13 @@ config FSL_DSPI this Freescale DSPI IP core. LS102xA and Colibri VF50/VF61 platforms use this driver.
+config FSL_QSPI + bool "Freescale QSPI driver" + help + Enable the Freescale Quad-SPI (QSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + Freescale IP core. + config SANDBOX_SPI bool "Sandbox SPI driver" depends on SANDBOX && DM
Added EXYNOS_SPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org --- drivers/spi/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index e4a90e8..d5e6881 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -29,6 +29,13 @@ config DESIGNWARE_SPI access the SPI NOR flash on platforms embedding this Designware IP core.
+config EXYNOS_SPI + bool "Samsung Exynos SPI driver" + help + Enable the Samsung Exynos SPI driver. This driver can be used to + access the SPI NOR flash on platforms embedding this Samsung + Exynos IP core. + config FSL_DSPI bool "Freescale DSPI driver" help
Reviewed-by: Simon Glass sjg@chromium.org _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
thanks!
Added ICH_SPI entry on Kconfig with help description.
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index d5e6881..43f9fac 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -51,6 +51,13 @@ config FSL_QSPI used to access the SPI NOR flash on platforms embedding this Freescale IP core.
+config ICH_SPI + bool "Intel ICH SPI driver" + help + Enable the Intel ICH SPI driver. This driver can be used to + access the SPI NOR flash on platforms embedding this Intel + ICH IP core. + config SANDBOX_SPI bool "Sandbox SPI driver" depends on SANDBOX && DM
+config ICH_SPI
help
ICH IP core.
config SANDBOX_SPI bool "Sandbox SPI driver" depends on SANDBOX && DM --
thanks!
Added TEGRA114_SPI entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Tom Warren twarren@nvidia.com Cc: Stephen Warren swarren@nvidia.com Cc: Simon Glass sjg@chromium.org --- drivers/spi/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 43f9fac..16dce77 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -83,6 +83,16 @@ config SANDBOX_SPI }; };
+config TEGRA114_SPI + bool "nVidia Tegra114 SPI driver" + help + Enable the nVidia Tegra114 SPI driver. This driver can be used to + access the SPI NOR flash on platforms embedding this nVidia Tegra114 + IP core. + + This controller is different than the older SoCs SPI controller and + also register interface get changed with this controller. + config XILINX_SPI bool "Xilinx SPI driver" help
thanks!
Added TEGRA20_SFLASH entry on Kconfig with help description.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Tom Warren twarren@nvidia.com Cc: Stephen Warren swarren@nvidia.com Cc: Simon Glass sjg@chromium.org --- drivers/spi/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 16dce77..8ffb3c4 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -93,6 +93,13 @@ config TEGRA114_SPI This controller is different than the older SoCs SPI controller and also register interface get changed with this controller.
+config TEGRA20_SFLASH + bool "nVidia Tegra20 Serial Flash controller driver" + help + Enable the nVidia Tegra20 Serial Flash controller driver. This driver + can be used to access the SPI NOR flash on platforms embedding this + nVidia Tegra20 IP core. + config XILINX_SPI bool "Xilinx SPI driver" help
thanks!
Added TEGRA20_SLINK entry on Kconfig with help description.
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 8ffb3c4..c84a7b7 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -100,6 +100,13 @@ config TEGRA20_SFLASH can be used to access the SPI NOR flash on platforms embedding this nVidia Tegra20 IP core.
+config TEGRA20_SLINK + bool "nVidia Tegra20/Tegra30 SLINK driver" + help + Enable the nVidia Tegra20/Tegra30 SLINK driver. This driver can + be used to access the SPI NOR flash on platforms embedding this + nVidia Tegra20/Tegra30 IP cores. + config XILINX_SPI bool "Xilinx SPI driver" help
thanks!
thanks! Jagan.
thanks!
participants (5)
Bin Meng
Daniel Schwierzeck
Jagan Teki
