[U-Boot] [WIP PATCH] dts: Generate binaries for all relevant platforms
(sent for the benefit of the Kbuild series - this does not apply as is)
Similar targets can use the same u-boot binary with different device trees. It is convenient to have all similar device trees compiled and published when u-boot is made: it allows for later easy repackaging without the need to re-run the make file.
This follows the Linux kernel suite, which also compiles all similar device tree targets at once.
For the purposes of exynos u-boot, as of now similar targets are those which have the same device tree file prefix (before the first '-').
This change modifies the dts makefile to allow concurrent processing of multiple device trees. As previously, one device tree is still published at 'u-boot.dtb', this is a copy of the compiled default device tree.
The problem with some DTC compiler versions generating stderr output even when there is no compilation errors has been also addressed: all DTC output is collected in a file, and only in case of error is the file sent to stderr.
Chrome OS tests: . emerge-{link|daisy} chromeos-u-boot - both succeed
. to verify that all device tres get compiled run the following commands (the doit script below configures and builds u-boot for the target passed through TARGET='):
$ rm -rf /tmp/u-* $ for t in link peach daisy; do USE_STDINT=1 U_BOOT_ROOT=$(pwd) TARGET=$t doit done $ find /tmp/u-* -name '*.dtb' /tmp/u-daisy/u-boot.dtb /tmp/u-daisy/dts/exynos5250-snow.dtb /tmp/u-daisy/dts/exynos5250-smdk5250.dtb /tmp/u-daisy/dts/exynos5250-spring.dtb /tmp/u-link/u-boot.dtb /tmp/u-link/dts/link.dtb /tmp/u-peach/u-boot.dtb /tmp/u-peach/dts/exynos5420-smdk5420.dtb /tmp/u-peach/dts/exynos5420-peach_pit.dtb /tmp/u-peach/dts/exynos5420-peach-pit-adv.dtb
. to verify that dt.o still builds when required run the following commands
$ find /tmp/u-peach/ -name 'dt.o' $ CONFIG_OF_EMBED=y TARGET=peach USE_STDINT=1 U_BOOT_ROOT=$(pwd) doit $ find /tmp/u-peach/ -name 'dt.o' /tmp/u-peach/dts/dt.o
. to verify that corrupting device tree still stops the build, add a syntax error to exynos5420-peach_pit.dts and rerun the build:
$ TARGET=peach USE_STDINT=1 U_BOOT_ROOT=$(pwd) doit Building in /tmp/u-peach DTC: dts->dtb on file "/tmp/u-peach/dts/exynos5420-peach_pit.dtb.in" FATAL ERROR: Unable to parse input tree Error: /tmp/u-peach/dts/exynos5420-peach_pit.dtb.in:6.1-4 syntax error make[1]: *** [/tmp/u-peach/dts/exynos5420-peach_pit.dtb] Error 1 make[1]: Target 'binary' not remade because of errors. make: *** [/tmp/u-peach/u-boot.dtb] Error 2 make: Target `all' not remade because of errors. END
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- dts/Makefile | 49 ++++++++++++++++++++++++++++++------------------- 1 file changed, 30 insertions(+), 19 deletions(-)
diff --git a/dts/Makefile b/dts/Makefile index 684ead3..a024b6a 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -30,7 +30,12 @@ LIB = $(obj)libdts.o ifeq ($(DEVICE_TREE),) $(if $(CONFIG_DEFAULT_DEVICE_TREE),,\ $(error Please define CONFIG_DEFAULT_DEVICE_TREE in your board header file)) -DEVICE_TREE = $(subst ",,$(CONFIG_DEFAULT_DEVICE_TREE)) +# This gets rid both of the double quotes and a possible suffix. +DEV_TREE_BASE := $(shell echo $(CONFIG_DEFAULT_DEVICE_TREE) | sed 's/-.*//') +DEFAULT_TREE := $(subst ",,$(obj)$(CONFIG_DEFAULT_DEVICE_TREE).dtb) +else +DEV_TREE_BASE := $(DEVICE_TREE) +DEFAULT_TREE := $(obj)$(DEVICE_TREE).dtb) endif
$(if $(CONFIG_ARCH_DEVICE_TREE),,\ @@ -52,14 +57,12 @@ DTS_FLAGS := $(shell if ! dtc -i 2>&1 | grep -q "invalid option"; then \ # Undefine 'linux' since it might be used in device tree files DTS_CPPFLAGS := -x assembler-with-cpp -Ulinux \ -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" \ - -DBOARD_DTS="$(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts/$(DEVICE_TREE).dts" \ -D__ASSEMBLY__ -I$(OBJTREE)/include -I$(SRCTREE)/include \ -I$(OBJTREE)/include2 \ -I$(SRCTREE)/board/$(VENDOR)/dts -I$(SRCTREE)/arch/$(ARCH)/dts \ -include $(OBJTREE)/include/config.h
-DTS_TMP := $(OBJTREE)/include/generated/$(DEVICE_TREE).dts.in -DTS_SRC := board/$(VENDOR)/dts/$(DEVICE_TREE).dts +DTS_DIR := $(TOPDIR)/board/$(VENDOR)/dts
all: $(obj).depend $(LIB)
@@ -68,20 +71,28 @@ all: $(obj).depend $(LIB) # the filename. DT_BIN := $(obj)dt.dtb
-DTC_CMD := $(DTC) -R 4 -p 0x1000 -O dtb -o ${DT_BIN} $(DTS_FLAGS) $(DTS_TMP) - -$(DT_BIN): $(TOPDIR)/$(DTS_SRC) - rc=$$( \ - cat $< | $(CPP) -P $(DTS_CPPFLAGS) - > $(DTS_TMP); \ - { { $(DTC_CMD) 2>&1 ; \ - echo $$? >&3 ; } | \ - grep -v '^DTC: dts->dtb on file' ; \ - } 3>&1 1>&2 ) ; \ - if [ $$rc != 0 ]; then \ - echo "Source file is $(DTS_SRC)"; \ - echo "Compiler: $(DTC_CMD)"; \ - fi; \ - exit $$rc +DT_SOURCES := $(notdir $(wildcard $(DTS_DIR)/$(DEV_TREE_BASE)-*)) +DT_BINS := $(addprefix $(obj),$(addsuffix .dtb,$(basename $(DT_SOURCES)))) \ + $(DT_BIN) + +$(obj)dt.dtb: $(DEFAULT_TREE) + cp $< $@ + +# Get preprocessed version of the tree. +$(obj)%.dts.in : $(DTS_DIR)/%.dts + $(CPP) -P $(DTS_CPPFLAGS) -DBOARD_DTS=$< $< -o $@ + +# Compile the preprocessed device tree. Some DTC versions insist on sending +# output to stderr even when everything is fine, which wrecs havoc on +# automated testing tools watching for stderr output. +# +# To address this issue collect all DTC output in a file and send the file to +# stderr only if there has been a DTC error. '&& false' enforces a make error. +# +$(obj)%.dtb : $(obj)%.dts.in + $(DTC) -R 4 -p 0x1000 -O dtb $(DTS_FLAGS) -o $@ $< > $@.errmsg 2>&1 || \ + (export rc=$$? && cat $@.errmsg >&2 && exit $$rc) + rm -f $@.errmsg
process_lds = \ $(1) | sed -r -n 's/^OUTPUT_$(2)[ ("]*([^")]*).*/\1/p' @@ -122,7 +133,7 @@ COBJS := $(OBJS-y)
OBJS := $(addprefix $(obj),$(COBJS))
-binary: $(DT_BIN) +binary: $(DT_BINS)
$(LIB): $(OBJS) $(DTB) $(call cmd_link_o_target, $(OBJS))
