[U-Boot] [PATCH] Fix defines needed to enable command sha1sum
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum.
Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum.
Signed-off-by: Alexander Holler holler@ahsoftware.de --- README | 2 +- common/cmd_mem.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/README b/README index 8e1a9ff..755d17c 100644 --- a/README +++ b/README @@ -675,7 +675,7 @@ The following options need to be configured: (requires CONFIG_CMD_I2C) CONFIG_CMD_SETGETDCR Support for DCR Register access (4xx only) - CONFIG_CMD_SHA1 print sha1 memory digest + CONFIG_CMD_SHA1SUM print sha1 memory digest (requires CONFIG_CMD_MEMORY) CONFIG_CMD_SOURCE "source" command Support CONFIG_CMD_SPI * SPI serial bus support diff --git a/common/cmd_mem.c b/common/cmd_mem.c index f03233c..ccf420a 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -1184,7 +1184,7 @@ int do_md5sum(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif
-#ifdef CONFIG_CMD_SHA1 +#ifdef CONFIG_CMD_SHA1SUM int do_sha1sum(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned long addr, len; @@ -1343,7 +1343,7 @@ U_BOOT_CMD( "compute SHA1 message digest", "address count" ); -#endif /* CONFIG_CMD_SHA1 */ +#endif /* CONFIG_CMD_SHA1SUM */
#ifdef CONFIG_CMD_UNZIP U_BOOT_CMD(
Dear Alexander Holler,
Applied, thanks.
Alexander Holler
