[PATCH 00/18] Add USB on SAM9X60, SAMA7G5 and SAMA5D2 boards
This series of patches is meant to add support for USB Mass Storage on SAM9X60, SAMA7G5 and SAMA5D2 boards and register ohci-at91 driver into Driver Model. In order for this to be achieved, the respective DT nodes have been added, the USB clock has been registered into CCF and the required defconfigs have been added to the boards' defconfig. What is more, in order for the VBUS to stay enabled, a `child_pre_probe` method has been added to overcome the DM core disabling it in `usb_scan_device`: when the generic `device_probe` method is called, the pinctrl is processed once again, undoing whatever changes have been made in our driver's probe method. In order to enable USB on SAMA7G5 the addition of RSTC and USB 2.0 PHY drivers were required.
Cristian Birsan (2): ARM: at91: add sama7 SFR definitions usb: ohci-at91: Add `ohci_t` field in `ohci_at91_priv`
Sergiu Moga (16): ARM: dts: sam9x60ek: Add OHCI and EHCI DT nodes clk: at91: Add support for sam9x60 USB clock clk: at91: sam9x60: Register the required clocks for USB clk: at91: sam9x60: Add initial setup of UPLL and USBCK rates usb: ohci-at91: Enable OHCI functionality and register into DM configs: at91: sam9x60ek: Add required configs for the USB command dt-bindings: reset: add sama7g5 definitions dt-bindings: clk: at91: Define additional UTMI related clocks ARM: dts: at91: sama7: Add USB related DT nodes reset: at91: Add reset driver for basic assert/deassert operations phy: at91: Add support for the USB 2.0 PHY's of SAMA7 usb: ohci-at91: Add USB PHY functionality configs: at91: sama7: Enable USB and RESET functionality ARM: dts: at91: sama5d2_icp: Add pinctrl nodes for USB related DT nodes ARM: dts: at91: sama5d27_wlsom1_ek: Add pinctrl nodes for USB DT nodes configs: at91: sama5d2: Enable OHCI/EHCI related configs
arch/arm/dts/at91-sama5d27_wlsom1_ek.dts | 25 ++ arch/arm/dts/at91-sama5d2_icp.dts | 22 ++ arch/arm/dts/at91-sama7g5ek.dts | 34 +++ arch/arm/dts/sam9x60.dtsi | 18 ++ arch/arm/dts/sam9x60ek.dts | 21 ++ arch/arm/dts/sama7g5.dtsi | 73 ++++++ arch/arm/mach-at91/include/mach/sama7-sfr.h | 59 +++++ configs/sam9x60ek_mmc_defconfig | 10 + configs/sam9x60ek_nandflash_defconfig | 10 + configs/sam9x60ek_qspiflash_defconfig | 10 + configs/sama5d27_som1_ek_mmc1_defconfig | 5 + configs/sama5d27_som1_ek_mmc_defconfig | 5 + configs/sama5d27_som1_ek_qspiflash_defconfig | 5 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 6 + .../sama5d27_wlsom1_ek_qspiflash_defconfig | 5 + configs/sama5d2_icp_mmc_defconfig | 9 + configs/sama5d2_icp_qspiflash_defconfig | 9 + configs/sama5d2_ptc_ek_mmc_defconfig | 5 + configs/sama5d2_ptc_ek_nandflash_defconfig | 5 + configs/sama5d2_xplained_emmc_defconfig | 5 + configs/sama5d2_xplained_mmc_defconfig | 5 + configs/sama5d2_xplained_qspiflash_defconfig | 5 + configs/sama5d2_xplained_spiflash_defconfig | 5 + configs/sama7g5ek_mmc1_defconfig | 13 ++ configs/sama7g5ek_mmc_defconfig | 13 ++ drivers/clk/at91/Kconfig | 7 + drivers/clk/at91/Makefile | 1 + drivers/clk/at91/clk-sam9x60-usb.c | 156 +++++++++++++ drivers/clk/at91/pmc.h | 11 + drivers/clk/at91/sam9x60.c | 99 +++++++- drivers/phy/Kconfig | 10 + drivers/phy/Makefile | 1 + drivers/phy/phy-sama7-usb.c | 92 ++++++++ drivers/phy/phy-sama7-utmi-clk.c | 202 +++++++++++++++++ drivers/reset/Kconfig | 8 + drivers/reset/Makefile | 1 + drivers/reset/reset-at91.c | 143 ++++++++++++ drivers/sysreset/sysreset_at91.c | 10 +- drivers/usb/host/ohci-at91.c | 214 ++++++++++++++++++ include/dt-bindings/clk/at91.h | 5 + include/dt-bindings/reset/sama7g5-reset.h | 10 + 41 files changed, 1342 insertions(+), 10 deletions(-) create mode 100644 arch/arm/mach-at91/include/mach/sama7-sfr.h create mode 100644 drivers/clk/at91/clk-sam9x60-usb.c create mode 100644 drivers/phy/phy-sama7-usb.c create mode 100644 drivers/phy/phy-sama7-utmi-clk.c create mode 100644 drivers/reset/reset-at91.c create mode 100644 include/dt-bindings/reset/sama7g5-reset.h
Add the OHCI and EHCI DT nodes for the sam9x60 board.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- arch/arm/dts/sam9x60.dtsi | 18 ++++++++++++++++++ arch/arm/dts/sam9x60ek.dts | 21 +++++++++++++++++++++ 2 files changed, 39 insertions(+)
diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index 17224ef771..e36a540f78 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -69,6 +69,24 @@ #size-cells = <1>; ranges;
+ usb1: ohci@600000 { + compatible = "atmel,at91rm9200-ohci", "usb-ohci"; + reg = <0x00600000 0x100000>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 22>, <&pmc PMC_TYPE_PERIPHERAL 22>, <&pmc PMC_TYPE_SYSTEM 21>; + clock-names = "ohci_clk", "hclk", "uhpck"; + status = "disabled"; + }; + + usb2: ehci@700000 { + compatible = "atmel,at91sam9g45-ehci", "usb-ehci"; + reg = <0x00700000 0x100000>; + clocks = <&pmc PMC_TYPE_CORE 8>, <&pmc PMC_TYPE_PERIPHERAL 22>; + clock-names = "usb_clk", "ehci_clk"; + assigned-clocks = <&pmc PMC_TYPE_CORE 8>; + assigned-clock-rates = <480000000>; + status = "disabled"; + }; + ebi: ebi@10000000 { compatible = "microchip,sam9x60-ebi"; #address-cells = <2>; diff --git a/arch/arm/dts/sam9x60ek.dts b/arch/arm/dts/sam9x60ek.dts index 1a02e2cb79..45e2f4cc40 100644 --- a/arch/arm/dts/sam9x60ek.dts +++ b/arch/arm/dts/sam9x60ek.dts @@ -139,6 +139,13 @@ <AT91_PIOD 14 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; };
+ usb1 { + pinctrl_usb_default: usb_default { + atmel,pins = <AT91_PIOD 15 AT91_PERIPH_GPIO AT91_PINCTRL_NONE + AT91_PIOD 16 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; + }; + }; + }; }; }; @@ -213,3 +220,17 @@ phy-mode = "rmii"; status = "okay"; }; + +&usb1 { + num-ports = <3>; + atmel,vbus-gpio = <0 + &pioD 15 GPIO_ACTIVE_HIGH + &pioD 16 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + status = "okay"; +}; + +&usb2 { + status = "okay"; +};
Implement sam9x60 USB clock driver. This clock has three parents: PLLA, UPLL and MAINXTAL. The driver is aware of the three possible parents with the help of the two mux tables provied to the driver during the registration of the clock.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- drivers/clk/at91/Kconfig | 7 ++ drivers/clk/at91/Makefile | 1 + drivers/clk/at91/clk-sam9x60-usb.c | 156 +++++++++++++++++++++++++++++ drivers/clk/at91/pmc.h | 11 ++ 4 files changed, 175 insertions(+) create mode 100644 drivers/clk/at91/clk-sam9x60-usb.c
diff --git a/drivers/clk/at91/Kconfig b/drivers/clk/at91/Kconfig index 4abc8026b4..4563892647 100644 --- a/drivers/clk/at91/Kconfig +++ b/drivers/clk/at91/Kconfig @@ -61,3 +61,10 @@ config AT91_SAM9X60_PLL help This option is used to enable the AT91 SAM9X60's PLL clock driver. + +config AT91_SAM9X60_USB + bool "USB Clock support for SAM9X60 SoCs" + depends on CLK_AT91 + help + This option is used to enable the AT91 SAM9X60's USB clock + driver. diff --git a/drivers/clk/at91/Makefile b/drivers/clk/at91/Makefile index 580b406d7b..e53dcb4ca7 100644 --- a/drivers/clk/at91/Makefile +++ b/drivers/clk/at91/Makefile @@ -9,6 +9,7 @@ obj-y += clk-peripheral.o obj-$(CONFIG_AT91_GENERIC_CLK) += clk-generic.o obj-$(CONFIG_AT91_UTMI) += clk-utmi.o obj-$(CONFIG_AT91_SAM9X60_PLL) += clk-sam9x60-pll.o +obj-$(CONFIG_AT91_SAM9X60_USB) += clk-sam9x60-usb.o obj-$(CONFIG_SAMA7G5) += sama7g5.o obj-$(CONFIG_SAM9X60) += sam9x60.o else diff --git a/drivers/clk/at91/clk-sam9x60-usb.c b/drivers/clk/at91/clk-sam9x60-usb.c new file mode 100644 index 0000000000..0ccdc1494d --- /dev/null +++ b/drivers/clk/at91/clk-sam9x60-usb.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SAM9X60's USB Clock support. + * + * Copyright (C) 2022 Microchip Technology Inc. and its subsidiaries + * + * Author: Sergiu Moga sergiu.moga@microchip.com + */ + +#include <clk-uclass.h> +#include <dm.h> +#include <linux/clk-provider.h> + +#include "pmc.h" + +#define UBOOT_DM_CLK_AT91_SAM9X60_USB "at91-sam9x60-usb-clk" + +struct sam9x60_usb { + const struct clk_usbck_layout *layout; + void __iomem *base; + struct clk clk; + const u32 *clk_mux_table; + const u32 *mux_table; + const char * const *parent_names; + u32 num_parents; + u8 id; +}; + +#define to_sam9x60_usb(_clk) container_of(_clk, struct sam9x60_usb, clk) +#define USB_MAX_DIV 15 + +static int sam9x60_usb_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct sam9x60_usb *usb = to_sam9x60_usb(clk); + u32 val, index; + + index = at91_clk_mux_val_to_index(usb->clk_mux_table, usb->num_parents, + parent->id); + if (index < 0) + return index; + + index = at91_clk_mux_index_to_val(usb->mux_table, usb->num_parents, + index); + if (index < 0) + return index; + + pmc_read(usb->base, usb->layout->offset, &val); + val &= ~usb->layout->usbs_mask; + val |= index << (ffs(usb->layout->usbs_mask - 1)); + pmc_write(usb->base, usb->layout->offset, val); + + return 0; +} + +static ulong sam9x60_usb_clk_get_rate(struct clk *clk) +{ + struct sam9x60_usb *usb = to_sam9x60_usb(clk); + ulong parent_rate = clk_get_parent_rate(clk); + u32 val, usbdiv; + + if (!parent_rate) + return 0; + + pmc_read(usb->base, usb->layout->offset, &val); + usbdiv = (val & usb->layout->usbdiv_mask) >> + (ffs(usb->layout->usbdiv_mask) - 1); + return parent_rate / (usbdiv + 1); +} + +static ulong sam9x60_usb_clk_set_rate(struct clk *clk, ulong rate) +{ + struct sam9x60_usb *usb = to_sam9x60_usb(clk); + ulong parent_rate = clk_get_parent_rate(clk); + u32 usbdiv, val; + + if (!parent_rate) + return 0; + + usbdiv = DIV_ROUND_CLOSEST(parent_rate, rate); + if (usbdiv > USB_MAX_DIV + 1 || !usbdiv) + return 0; + + pmc_read(usb->base, usb->layout->offset, &val); + val &= usb->layout->usbdiv_mask; + val |= (usbdiv - 1) << (ffs(usb->layout->usbdiv_mask) - 1); + pmc_write(usb->base, usb->layout->offset, val); + + return parent_rate / usbdiv; +} + +static const struct clk_ops sam9x60_usb_ops = { + .set_parent = sam9x60_usb_clk_set_parent, + .set_rate = sam9x60_usb_clk_set_rate, + .get_rate = sam9x60_usb_clk_get_rate, +}; + +struct clk * +sam9x60_clk_register_usb(void __iomem *base, const char *name, + const char * const *parent_names, u8 num_parents, + const struct clk_usbck_layout *usbck_layout, + const u32 *clk_mux_table, const u32 *mux_table, u8 id) +{ + struct sam9x60_usb *usb; + struct clk *clk; + int ret; + u32 val, index; + + if (!base || !name || !parent_names || !num_parents || + !clk_mux_table || !mux_table) + return ERR_PTR(-EINVAL); + + usb = kzalloc(sizeof(*usb), GFP_KERNEL); + if (!usb) + return ERR_PTR(-ENOMEM); + + usb->id = id; + usb->base = base; + usb->layout = usbck_layout; + usb->parent_names = parent_names; + usb->num_parents = num_parents; + usb->clk_mux_table = clk_mux_table; + usb->mux_table = mux_table; + + clk = &usb->clk; + clk->flags = CLK_SET_RATE_GATE | CLK_SET_PARENT_GATE | + CLK_SET_RATE_PARENT; + + pmc_read(usb->base, usb->layout->offset, &val); + + val = (val & usb->layout->usbs_mask) >> + (ffs(usb->layout->usbs_mask) - 1); + + index = at91_clk_mux_val_to_index(usb->mux_table, usb->num_parents, + val); + + if (index < 0) { + kfree(usb); + return ERR_PTR(index); + } + + ret = clk_register(clk, UBOOT_DM_CLK_AT91_SAM9X60_USB, name, + parent_names[index]); + if (ret) { + kfree(usb); + clk = ERR_PTR(ret); + } + + return clk; +} + +U_BOOT_DRIVER(at91_sam9x60_usb_clk) = { + .name = UBOOT_DM_CLK_AT91_SAM9X60_USB, + .id = UCLASS_CLK, + .ops = &sam9x60_usb_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/at91/pmc.h b/drivers/clk/at91/pmc.h index 2b4dd9a3d9..17793b8802 100644 --- a/drivers/clk/at91/pmc.h +++ b/drivers/clk/at91/pmc.h @@ -71,6 +71,12 @@ struct clk_pcr_layout { u32 pid_mask; };
+struct clk_usbck_layout { + u32 offset; + u32 usbs_mask; + u32 usbdiv_mask; +}; + extern const struct clk_programmable_layout at91rm9200_programmable_layout; extern const struct clk_programmable_layout at91sam9g45_programmable_layout; extern const struct clk_programmable_layout at91sam9x5_programmable_layout; @@ -87,6 +93,11 @@ struct clk *at91_clk_sam9x5_main(void __iomem *reg, const char *name, const char * const *parent_names, int num_parents, const u32 *mux_table, int type); struct clk * +sam9x60_clk_register_usb(void __iomem *base, const char *name, + const char * const *parent_names, u8 num_parents, + const struct clk_usbck_layout *usbck_layout, + const u32 *clk_mux_table, const u32 *mux_table, u8 id); +struct clk * sam9x60_clk_register_div_pll(void __iomem *base, const char *name, const char *parent_name, u8 id, const struct clk_pll_characteristics *characteristics,
Register into DM the clocks required to properly enable USB functionality within the bootloader.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- drivers/clk/at91/sam9x60.c | 37 +++++++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+)
diff --git a/drivers/clk/at91/sam9x60.c b/drivers/clk/at91/sam9x60.c index 6b5486c6c9..eaf70c4668 100644 --- a/drivers/clk/at91/sam9x60.c +++ b/drivers/clk/at91/sam9x60.c @@ -76,6 +76,8 @@ enum pmc_clk_ids { ID_QSPI = 18,
ID_MCK_PRES = 19, + ID_USBCK = 20, + ID_UHPCK = 21,
ID_MAX, }; @@ -99,6 +101,7 @@ static const char *clk_names[] = { [ID_PLL_A_DIV] = "plla_divpmcck", [ID_MCK_PRES] = "mck_pres", [ID_MCK_DIV] = "mck_div", + [ID_USBCK] = "usbck", };
/* Fractional PLL output range. */ @@ -171,6 +174,15 @@ static const struct clk_pcr_layout pcr_layout = { .pid_mask = GENMASK(6, 0), };
+#if CONFIG_IS_ENABLED(AT91_SAM9X60_USB) +/* USB clock layout */ +static const struct clk_usbck_layout usbck_layout = { + .offset = 0x38, + .usbs_mask = GENMASK(1, 0), + .usbdiv_mask = GENMASK(11, 8), +}; +#endif + /** * PLL clocks description * @n: clock name @@ -266,6 +278,7 @@ static const struct { u8 cid; } sam9x60_systemck[] = { { .n = "ddrck", .p = "mck_div", .id = 2, .cid = ID_DDR, }, + { .n = "uhpck", .p = "usbck", .id = 6, .cid = ID_UHPCK }, { .n = "pck0", .p = "prog0", .id = 8, .cid = ID_PCK0, }, { .n = "pck1", .p = "prog1", .id = 9, .cid = ID_PCK1, }, { .n = "qspick", .p = "mck_div", .id = 19, .cid = ID_QSPI, }, @@ -543,6 +556,30 @@ static int sam9x60_clk_probe(struct udevice *dev) } clk_dm(AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_MCK_DIV), c);
+#if CONFIG_IS_ENABLED(AT91_SAM9X60_USB) + /* Register usbck. */ + p[0] = clk_names[ID_PLL_A_DIV]; + p[1] = clk_names[ID_PLL_U_DIV]; + p[2] = clk_names[ID_MAIN_XTAL]; + m[0] = 0; + m[1] = 1; + m[2] = 2; + cm[0] = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_PLL_A_DIV); + cm[1] = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_PLL_U_DIV); + cm[2] = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_MAIN_XTAL); + prepare_mux_table(clkmuxallocs, clkmuxallocindex, tmpclkmux, cm, + 3, fail); + prepare_mux_table(muxallocs, muxallocindex, tmpmux, m, 3, fail); + c = sam9x60_clk_register_usb(base, clk_names[ID_USBCK], p, 3, + &usbck_layout, tmpclkmux, tmpmux, + ID_USBCK); + if (IS_ERR(c)) { + ret = PTR_ERR(c); + goto fail; + } + clk_dm(AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_USBCK), c); +#endif + /* Register programmable clocks. */ p[0] = clk_names[ID_MD_SLCK]; p[1] = clk_names[ID_TD_SLCK];
In order for some of the functionalities, such as the USB clocks, to work properly we need some clocks to be properly initialised at the very beginning of booting.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- drivers/clk/at91/sam9x60.c | 62 +++++++++++++++++++++++++++++++++++++- 1 file changed, 61 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/at91/sam9x60.c b/drivers/clk/at91/sam9x60.c index eaf70c4668..4336148f73 100644 --- a/drivers/clk/at91/sam9x60.c +++ b/drivers/clk/at91/sam9x60.c @@ -380,6 +380,36 @@ static const struct { { .n = "dbgu_gclk", .id = 47, }, };
+/** + * Clock setup description + * @cid: clock id corresponding to clock subsystem + * @pid: parent clock id corresponding to clock subsystem + * @rate: clock rate + * @prate: parent rate + */ +static const struct pmc_clk_setup { + unsigned int cid; + unsigned int pid; + unsigned long rate; + unsigned long prate; +} sam9x60_clk_setup[] = { + { + .cid = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_PLL_U_FRAC), + .rate = 960000000, + }, + + { + .cid = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_PLL_U_DIV), + .rate = 480000000, + }, + + { + .cid = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_USBCK), + .pid = AT91_TO_CLK_ID(PMC_TYPE_CORE, ID_PLL_U_DIV), + .rate = 48000000, + }, +}; + #define prepare_mux_table(_allocs, _index, _dst, _src, _num, _label) \ do { \ int _i; \ @@ -399,7 +429,7 @@ static int sam9x60_clk_probe(struct udevice *dev) unsigned int *clkmuxallocs[64], *muxallocs[64]; const char *p[10]; unsigned int cm[10], m[10], *tmpclkmux, *tmpmux; - struct clk clk, *c; + struct clk clk, *c, *parent; int ret, muxallocindex = 0, clkmuxallocindex = 0, i; static const struct clk_range r = { 0, 0 };
@@ -672,6 +702,36 @@ static int sam9x60_clk_probe(struct udevice *dev) clk_dm(AT91_TO_CLK_ID(PMC_TYPE_GCK, sam9x60_gck[i].id), c); }
+ /* Setup clocks. */ + for (i = 0; i < ARRAY_SIZE(sam9x60_clk_setup); i++) { + ret = clk_get_by_id(sam9x60_clk_setup[i].cid, &c); + if (ret) + goto fail; + + if (sam9x60_clk_setup[i].pid) { + ret = clk_get_by_id(sam9x60_clk_setup[i].pid, &parent); + if (ret) + goto fail; + + ret = clk_set_parent(c, parent); + if (ret) + goto fail; + + if (sam9x60_clk_setup[i].prate) { + ret = clk_set_rate(parent, + sam9x60_clk_setup[i].prate); + if (ret < 0) + goto fail; + } + } + + if (sam9x60_clk_setup[i].rate) { + ret = clk_set_rate(c, sam9x60_clk_setup[i].rate); + if (ret < 0) + goto fail; + } + } + return 0;
fail:
Register the OHCI driver into DM by properly initializing the required clocks and pins required by the DT node of OHCI. In order for the VBUS to stay enabled, a `child_pre_probe` method has been added to overcome the DM core disabling it in `usb_scan_device`: when the generic `device_probe` method is called, the pinctrl is processed once again, undoing whatever changes have been made in our driver's probe method.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- drivers/usb/host/ohci-at91.c | 182 +++++++++++++++++++++++++++++++++++ 1 file changed, 182 insertions(+)
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 9b955c1bd6..362ab01c3d 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -7,6 +7,8 @@ #include <common.h> #include <asm/arch/clk.h>
+#if !(CONFIG_IS_ENABLED(DM_USB)) + int usb_cpu_init(void) { #ifdef CONFIG_USB_ATMEL_CLK_SEL_PLLB @@ -62,3 +64,183 @@ int usb_cpu_init_fail(void) { return usb_cpu_stop(); } + +#elif CONFIG_IS_ENABLED(DM_GPIO) + +#include <clk.h> +#include <dm.h> +#include <asm/gpio.h> +#include <usb.h> +#include "ohci.h" + +#define AT91_MAX_USBH_PORTS 3 + +#define at91_for_each_port(index) \ + for ((index) = 0; (index) < AT91_MAX_USBH_PORTS; (index)++) + +struct at91_usbh_data { + enum usb_init_type init_type; + struct gpio_desc vbus_pin[AT91_MAX_USBH_PORTS]; + u8 ports; /* number of ports on root hub */ +}; + +struct ohci_at91_priv { + struct clk *iclk; + struct clk *fclk; + struct clk *hclk; + bool clocked; +}; + +static void at91_start_clock(struct ohci_at91_priv *ohci_at91) +{ + if (ohci_at91->clocked) + return; + + clk_set_rate(ohci_at91->fclk, 48000000); + clk_prepare_enable(ohci_at91->hclk); + clk_prepare_enable(ohci_at91->iclk); + clk_prepare_enable(ohci_at91->fclk); + ohci_at91->clocked = true; +} + +static void at91_stop_clock(struct ohci_at91_priv *ohci_at91) +{ + if (!ohci_at91->clocked) + return; + + clk_disable_unprepare(ohci_at91->fclk); + clk_disable_unprepare(ohci_at91->iclk); + clk_disable_unprepare(ohci_at91->hclk); + ohci_at91->clocked = false; +} + +static void ohci_at91_set_power(struct at91_usbh_data *pdata, int port, + bool enable) +{ + if (!dm_gpio_is_valid(&pdata->vbus_pin[port])) + return; + + if (enable) + dm_gpio_set_dir_flags(&pdata->vbus_pin[port], + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + else + dm_gpio_set_dir_flags(&pdata->vbus_pin[port], 0); +} + +static void at91_start_hc(struct udevice *dev) +{ + struct ohci_at91_priv *ohci_at91 = dev_get_priv(dev); + + at91_start_clock(ohci_at91); +} + +static void at91_stop_hc(struct udevice *dev) +{ + struct ohci_at91_priv *ohci_at91 = dev_get_priv(dev); + + at91_stop_clock(ohci_at91); +} + +static int ohci_atmel_deregister(struct udevice *dev) +{ + struct at91_usbh_data *pdata = dev_get_plat(dev); + int i; + + at91_stop_hc(dev); + + at91_for_each_port(i) { + if (i >= pdata->ports) + break; + + ohci_at91_set_power(pdata, i, false); + } + + return ohci_deregister(dev); +} + +static int ohci_atmel_child_pre_probe(struct udevice *dev) +{ + struct udevice *ohci_controller = dev_get_parent(dev); + struct at91_usbh_data *pdata = dev_get_plat(ohci_controller); + int i; + + at91_for_each_port(i) { + if (i >= pdata->ports) + break; + + ohci_at91_set_power(pdata, i, true); + } + + return 0; +} + +static int ohci_atmel_probe(struct udevice *dev) +{ + struct at91_usbh_data *pdata = dev_get_plat(dev); + struct ohci_at91_priv *ohci_at91 = dev_get_priv(dev); + int i; + int ret; + u32 ports; + struct ohci_regs *regs = (struct ohci_regs *)dev_read_addr(dev); + + if (!dev_read_u32(dev, "num-ports", &ports)) + pdata->ports = ports; + + at91_for_each_port(i) { + if (i >= pdata->ports) + break; + + gpio_request_by_name(dev, "atmel,vbus-gpio", i, + &pdata->vbus_pin[i], GPIOD_IS_OUT | + GPIOD_IS_OUT_ACTIVE); + } + + ohci_at91->iclk = devm_clk_get(dev, "ohci_clk"); + if (IS_ERR(ohci_at91->iclk)) { + ret = PTR_ERR(ohci_at91->iclk); + goto fail; + } + + ohci_at91->fclk = devm_clk_get(dev, "uhpck"); + if (IS_ERR(ohci_at91->fclk)) { + ret = PTR_ERR(ohci_at91->fclk); + goto fail; + } + + ohci_at91->hclk = devm_clk_get(dev, "hclk"); + if (IS_ERR(ohci_at91->hclk)) { + ret = PTR_ERR(ohci_at91->hclk); + goto fail; + } + + at91_start_hc(dev); + + return ohci_register(dev, regs); + +fail: + at91_for_each_port(i) + if (&pdata->vbus_pin[i]) + gpio_free(pdata->vbus_pin[i].offset); + + return ret; +} + +static const struct udevice_id ohci_usb_ids[] = { + { .compatible = "atmel,at91rm9200-ohci", }, + { } +}; + +U_BOOT_DRIVER(ohci_atmel) = { + .name = "ohci_atmel", + .id = UCLASS_USB, + .of_match = ohci_usb_ids, + .probe = ohci_atmel_probe, + .remove = ohci_atmel_deregister, + .child_pre_probe = ohci_atmel_child_pre_probe, + .ops = &ohci_usb_ops, + .plat_auto = sizeof(struct at91_usbh_data), + .priv_auto = sizeof(struct ohci_at91_priv), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; + +#endif /* CONFIG_IS_ENABLED(DM_USB) && CONFIG_IS_ENABLED(DM_GPIO) */
Add the configs required to use the USB-related functionalities within the bootloader.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- configs/sam9x60ek_mmc_defconfig | 10 ++++++++++ configs/sam9x60ek_nandflash_defconfig | 10 ++++++++++ configs/sam9x60ek_qspiflash_defconfig | 10 ++++++++++ 3 files changed, 30 insertions(+)
diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index 268a485456..79780b6689 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -59,6 +59,7 @@ CONFIG_CLK_CCF=y CONFIG_CLK_AT91=y CONFIG_AT91_GENERIC_CLK=y CONFIG_AT91_SAM9X60_PLL=y +CONFIG_AT91_SAM9X60_USB=y CONFIG_CPU=y CONFIG_AT91_GPIO=y CONFIG_DM_I2C=y @@ -100,3 +101,12 @@ CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_DS24XXX=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sam9x60ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 +CONFIG_USB_ATMEL=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index a9cbb6e953..13774f0764 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -61,6 +61,7 @@ CONFIG_CLK_CCF=y CONFIG_CLK_AT91=y CONFIG_AT91_GENERIC_CLK=y CONFIG_AT91_SAM9X60_PLL=y +CONFIG_AT91_SAM9X60_USB=y CONFIG_CPU=y CONFIG_AT91_GPIO=y CONFIG_DM_I2C=y @@ -102,3 +103,12 @@ CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_DS24XXX=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sam9x60ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 +CONFIG_USB_ATMEL=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index 72f08f1375..587d0da20f 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -61,6 +61,7 @@ CONFIG_CLK_CCF=y CONFIG_CLK_AT91=y CONFIG_AT91_GENERIC_CLK=y CONFIG_AT91_SAM9X60_PLL=y +CONFIG_AT91_SAM9X60_USB=y CONFIG_CPU=y CONFIG_AT91_GPIO=y CONFIG_DM_I2C=y @@ -101,3 +102,12 @@ CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_DS24XXX=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sam9x60ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 +CONFIG_USB_ATMEL=y
Upstream linux commit 5994f58977e0.
Add reset bindings for SAMA7G5. At the moment only USB PHYs are included.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- include/dt-bindings/reset/sama7g5-reset.h | 10 ++++++++++ 1 file changed, 10 insertions(+) create mode 100644 include/dt-bindings/reset/sama7g5-reset.h
diff --git a/include/dt-bindings/reset/sama7g5-reset.h b/include/dt-bindings/reset/sama7g5-reset.h new file mode 100644 index 0000000000..2116f41d04 --- /dev/null +++ b/include/dt-bindings/reset/sama7g5-reset.h @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ + +#ifndef __DT_BINDINGS_RESET_SAMA7G5_H +#define __DT_BINDINGS_RESET_SAMA7G5_H + +#define SAMA7G5_RESET_USB_PHY1 4 +#define SAMA7G5_RESET_USB_PHY2 5 +#define SAMA7G5_RESET_USB_PHY3 6 + +#endif /* __DT_BINDINGS_RESET_SAMA7G5_H */
Add definitions for an additional main UTMI clock as well as its respective subclocks.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- include/dt-bindings/clk/at91.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/dt-bindings/clk/at91.h b/include/dt-bindings/clk/at91.h index e30756b280..386f01cf31 100644 --- a/include/dt-bindings/clk/at91.h +++ b/include/dt-bindings/clk/at91.h @@ -18,5 +18,10 @@ #define PMC_TYPE_PERIPHERAL 3 #define PMC_TYPE_GCK 4 #define PMC_TYPE_SLOW 5 +#define UTMI 6 + +#define UTMI1 0 +#define UTMI2 1 +#define UTMI3 2
#endif
Add the USB related DT nodes for the sama7g5ek board.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- arch/arm/dts/at91-sama7g5ek.dts | 34 +++++++++++++++ arch/arm/dts/sama7g5.dtsi | 73 +++++++++++++++++++++++++++++++++ 2 files changed, 107 insertions(+)
diff --git a/arch/arm/dts/at91-sama7g5ek.dts b/arch/arm/dts/at91-sama7g5ek.dts index 9b247fcaf6..31adc4d3e7 100644 --- a/arch/arm/dts/at91-sama7g5ek.dts +++ b/arch/arm/dts/at91-sama7g5ek.dts @@ -761,6 +761,11 @@ pinmux = <PIN_PB1__SPDIF_TX>; bias-disable; }; + + pinctrl_usb_default: usb_default { + pinmux = <PIN_PC6__GPIO>; + bias-disable; + }; };
&pwm { @@ -837,6 +842,35 @@ status = "okay"; };
+&usb2 { + num-ports = <3>; + atmel,vbus-gpio = <0 + 0 + &pioA PIN_PC6 GPIO_ACTIVE_HIGH + >; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + phys = <&usb_phy2>; + phy-names = "usb"; + status = "okay"; +}; + +&usb3 { + status = "okay"; +}; + +&usb_phy0 { + status = "okay"; +}; + +&usb_phy1 { + status = "okay"; +}; + +&usb_phy2 { + status = "okay"; +}; + &vddout25 { vin-supply = <&vdd_3v3>; status = "okay"; diff --git a/arch/arm/dts/sama7g5.dtsi b/arch/arm/dts/sama7g5.dtsi index 6388a60e53..a6521aaa82 100644 --- a/arch/arm/dts/sama7g5.dtsi +++ b/arch/arm/dts/sama7g5.dtsi @@ -16,6 +16,8 @@ #include <dt-bindings/dma/at91.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/mfd/at91-usart.h> +#include <dt-bindings/reset/sama7g5-reset.h> +#include <dt-bindings/clock/at91.h>
/ { model = "Microchip SAMA7G5 family SoC"; @@ -103,6 +105,54 @@ }; };
+ utmi_clk: utmi-clk { + compatible = "microchip,sama7g5-utmi-clk"; + sfr-phandle = <&sfr>; + #clock-cells = <1>; + clocks = <&pmc PMC_TYPE_CORE 27>; + clock-names = "utmi_clk"; + resets = <&reset_controller SAMA7G5_RESET_USB_PHY1>, + <&reset_controller SAMA7G5_RESET_USB_PHY2>, + <&reset_controller SAMA7G5_RESET_USB_PHY3>; + reset-names = "usb0_reset", "usb1_reset", "usb2_reset"; + }; + + utmi { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + usb_phy0: phy@0 { + compatible = "microchip,sama7g5-usb-phy"; + sfr-phandle = <&sfr>; + reg = <0>; + clocks = <&utmi_clk UTMI1>; + clock-names = "utmi_clk"; + status = "disabled"; + #phy-cells = <0>; + }; + + usb_phy1: phy@1 { + compatible = "microchip,sama7g5-usb-phy"; + sfr-phandle = <&sfr>; + reg = <1>; + clocks = <&utmi_clk UTMI2>; + clock-names = "utmi_clk"; + status = "disabled"; + #phy-cells = <0>; + }; + + usb_phy2: phy@2 { + compatible = "microchip,sama7g5-usb-phy"; + sfr-phandle = <&sfr>; + reg = <2>; + clocks = <&utmi_clk UTMI3>; + clock-names = "utmi_clk"; + status = "disabled"; + #phy-cells = <0>; + }; + }; + vddout25: fixed-regulator-vddout25 { compatible = "regulator-fixed";
@@ -127,6 +177,24 @@ #size-cells = <1>; ranges;
+ usb2: ohci@400000 { + compatible = "microchip,sama7g5-ohci", "usb-ohci"; + reg = <0x00400000 0x100000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 106>, <&utmi_clk UTMI1>, <&usb_clk>; + clock-names = "ohci_clk", "hclk", "uhpck"; + status = "disabled"; + }; + + usb3: ehci@500000 { + compatible = "atmel,at91sam9g45-ehci", "usb-ehci"; + reg = <0x00500000 0x100000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>, <&pmc PMC_TYPE_PERIPHERAL 106>; + clock-names = "usb_clk", "ehci_clk"; + status = "disabled"; + }; + nfc_sram: sram@600000 { compatible = "mmio-sram"; no-memory-wc; @@ -559,6 +627,11 @@ status = "disabled"; };
+ sfr: sfr@e1624000 { + compatible = "microchip,sama7g5-sfr", "syscon"; + reg = <0xe1624000 0x4000>; + }; + eic: interrupt-controller@e1628000 { compatible = "microchip,sama7g5-eic"; reg = <0xe1628000 0xec>;
From: Cristian Birsan cristian.birsan@microchip.com
Special Function Registers(SFR) definitions for SAMA7 product family.
Signed-off-by: Cristian Birsan cristian.birsan@microchip.com Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- arch/arm/mach-at91/include/mach/sama7-sfr.h | 59 +++++++++++++++++++++ 1 file changed, 59 insertions(+) create mode 100644 arch/arm/mach-at91/include/mach/sama7-sfr.h
diff --git a/arch/arm/mach-at91/include/mach/sama7-sfr.h b/arch/arm/mach-at91/include/mach/sama7-sfr.h new file mode 100644 index 0000000000..a987ff5465 --- /dev/null +++ b/arch/arm/mach-at91/include/mach/sama7-sfr.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Microchip SFR (Special Function Registers) registers for SAMA7 family. + * + * Copyright (C) 2022 Microchip Technology Inc. and its subsidiaries + * + * Author: Cristian Birsan cristian.birsan@microchip.com + */ + +#ifndef _LINUX_MFD_SYSCON_AT91_SAMA7_SFR_H +#define _LINUX_MFD_SYSCON_AT91_SAMA7_SFR_H + +#define SAMA7_SFR_OHCIICR 0x00 /* OHCI INT Configuration Register */ +#define SAMA7_SFR_OHCIISR 0x04 /* OHCI INT Status Register */ +/* 0x08 ~ 0xe3: Reserved */ +#define SAMA7_SFR_WPMR 0xe4 /* Write Protection Mode Register */ +#define SAMA7_SFR_WPSR 0xe4 /* Write Protection Status Register */ +/* 0xec ~ 0x200b: Reserved */ +#define SAMA7_SFR_DEBUG 0x200c /* Debug Register */ + +/* 0x2010 ~ 0x2027: Reserved */ +#define SAMA7_SFR_EHCIOHCI 0x2020 /* EHCI OHCI Clock Configuration Reg */ + +#define SAMA7_SFR_HSS_AXI_QOS 0x2028 /* HSS AXI QOS Register */ +#define SAMA7_SFR_UDDRC 0x202c /* UDDRC Register */ +#define SAMA7_SFR_CAN_SRAM_SEL 0x2030 /* CAN SRAM Select. Register */ +/* 0x2034 ~ 0x203f: Reserved */ + +#define SAMA7_SFR_UTMI0 0x2040 +#define SAMA7_SFR_UTMI0R(x) (SAMA7_SFR_UTMI0 + 4 * (x)) + +#define SAMA7_SFR_UTMI0R0 0x2040 /* UTMI0 Configuration Register */ +#define SAMA7_SFR_UTMI0R1 0x2044 /* UTMI1 Configuration Register */ +#define SAMA7_SFR_UTMI0R2 0x2048 /* UTMI2 Configuration Register */ + +/* Field definitions */ +#define SAMA7_SFR_OHCIICR_ARIE BIT(0) +#define SAMA7_SFR_OHCIICR_APPSTART BIT(1) +#define SAMA7_SFR_OHCIICR_USB_SUSP(x) BIT(8 + (x)) +#define SAMA7_SFR_OHCIICR_USB_SUSPEND GENMASK(10, 8) + +#define SAMA7_SFR_OHCIISR_RIS(x) BIT(x) + +#define SAMA7_SFR_WPMR_WPEN BIT(0) +#define SAMA7_SFR_WPMR_KEY 0x53465200 /* SFR in ASCII*/ +#define SAMA7_SFR_WPMR_WPKEY_MASK GENMASK(31, 8) + +#define SAMA7_SFR_WPSR_WPSRC_MASK GENMASK(23, 8) +#define SAMA7_SFR_WPSR_WPVS_MASK BIT(0) + +#define SAMA7_SFR_CAN_SRAM_UPPER(x) BIT(x) + +#define SAMA7_SFR_UTMI_RX_VBUS BIT(25) /* VBUS Valid bit */ +#define SAMA7_SFR_UTMI_RX_TX_PREEM_AMP_TUNE_1X BIT(23) /* TXPREEMPAMPTUNE 1x */ +#define SAMA7_SFR_UTMI_COMMONON BIT(3) /* PLL Common ON bit */ + +#define SAMA7_SFR_EHCIOHCI_PHYCLK BIT(1) /* Alternate PHY Clk */ + +#endif /* _LINUX_MFD_SYSCON_AT91_SAMA7_SFR_H */
Add support for at91 reset controller's basic assert/deassert operations. Since this driver conflicts with the SYSRESET driver because they both bind to the same RSTC node, implement a custom bind hook that would manually bind the sysreset driver, if enabled, to the same RSTC DT node. Furthermore, delete the no longer needed compatibles from the SYSRESET driver and rename it to make sure than any possible conflicts are avoided.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com Tested-by: Mihai Sain mihai.sain@microchip.com --- drivers/reset/Kconfig | 8 ++ drivers/reset/Makefile | 1 + drivers/reset/reset-at91.c | 143 +++++++++++++++++++++++++++++++ drivers/sysreset/sysreset_at91.c | 10 +-- 4 files changed, 153 insertions(+), 9 deletions(-) create mode 100644 drivers/reset/reset-at91.c
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 4cb0ba0850..e4039d7474 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -211,4 +211,12 @@ config RESET_DRA7 help Support for TI DRA7-RESET subsystem. Basic Assert/Deassert is supported. + +config RESET_AT91 + bool "Enable support for Microchip/Atmel Reset Controller driver" + depends on DM_RESET && ARCH_AT91 + help + This enables the Reset Controller driver support for Microchip/Atmel + SoCs. Mainly used to expose assert/deassert methods to other drivers + that require it. endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 0620b62809..6c8b45ecba 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -31,3 +31,4 @@ obj-$(CONFIG_RESET_RASPBERRYPI) += reset-raspberrypi.o obj-$(CONFIG_RESET_SCMI) += reset-scmi.o obj-$(CONFIG_RESET_ZYNQMP) += reset-zynqmp.o obj-$(CONFIG_RESET_DRA7) += reset-dra7.o +obj-$(CONFIG_RESET_AT91) += reset-at91.o diff --git a/drivers/reset/reset-at91.c b/drivers/reset/reset-at91.c new file mode 100644 index 0000000000..ee035a8934 --- /dev/null +++ b/drivers/reset/reset-at91.c @@ -0,0 +1,143 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Support for Atmel/Microchip Reset Controller. + * + * Copyright (C) 2022 Microchip Technology Inc. and its subsidiaries + * + * Author: Sergiu Moga sergiu.moga@microchip.com + */ + +#include <clk.h> +#include <asm/io.h> +#include <dm.h> +#include <dm/lists.h> +#include <reset-uclass.h> +#include <asm/arch/at91_rstc.h> +#include <dt-bindings/reset/sama7g5-reset.h> + +struct at91_reset { + void __iomem *dev_base; + struct at91_reset_data *data; +}; + +struct at91_reset_data { + u32 n_device_reset; + u8 device_reset_min_id; + u8 device_reset_max_id; +}; + +static const struct at91_reset_data sama7g5_data = { + .n_device_reset = 3, + .device_reset_min_id = SAMA7G5_RESET_USB_PHY1, + .device_reset_max_id = SAMA7G5_RESET_USB_PHY3, +}; + +static int at91_rst_update(struct at91_reset *reset, unsigned long id, + bool assert) +{ + u32 val; + + if (!reset->dev_base) + return 0; + + val = readl(reset->dev_base); + if (assert) + val |= BIT(id); + else + val &= ~BIT(id); + writel(val, reset->dev_base); + + return 0; +} + +static int at91_reset_of_xlate(struct reset_ctl *reset_ctl, + struct ofnode_phandle_args *args) +{ + struct at91_reset *reset = dev_get_priv(reset_ctl->dev); + + if (!reset->data->n_device_reset || + args->args[0] < reset->data->device_reset_min_id || + args->args[0] > reset->data->device_reset_max_id) + return -EINVAL; + + reset_ctl->id = args->args[0]; + + return 0; +} + +static int at91_rst_assert(struct reset_ctl *reset_ctl) +{ + struct at91_reset *reset = dev_get_priv(reset_ctl->dev); + + return at91_rst_update(reset, reset_ctl->id, true); +} + +static int at91_rst_deassert(struct reset_ctl *reset_ctl) +{ + struct at91_reset *reset = dev_get_priv(reset_ctl->dev); + + return at91_rst_update(reset, reset_ctl->id, false); +} + +struct reset_ops at91_reset_ops = { + .of_xlate = at91_reset_of_xlate, + .rst_assert = at91_rst_assert, + .rst_deassert = at91_rst_deassert, +}; + +static int at91_reset_probe(struct udevice *dev) +{ + struct at91_reset *reset = dev_get_priv(dev); + struct clk sclk; + int ret; + + reset->data = (struct at91_reset_data *)dev_get_driver_data(dev); + reset->dev_base = dev_remap_addr_index(dev, 1); + if (reset->data && reset->data->n_device_reset && !reset->dev_base) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &sclk); + if (ret) + return ret; + + ret = clk_prepare_enable(&sclk); + + return ret; +} + +static int at91_reset_bind(struct udevice *dev) +{ + struct udevice *at91_sysreset; + + if (CONFIG_IS_ENABLED(SYSRESET_AT91)) + return device_bind_driver_to_node(dev, "at91_sysreset", + "at91_sysreset", + dev_ofnode(dev), + &at91_sysreset); + + return 0; +} + +static const struct udevice_id at91_reset_ids[] = { + { + .compatible = "microchip,sama7g5-rstc", + .data = (ulong)&sama7g5_data, + }, + { + .compatible = "atmel,sama5d3-rstc", + }, + { + .compatible = "microchip,sam9x60-rstc", + }, + { } +}; + +U_BOOT_DRIVER(at91_reset) = { + .name = "at91_reset", + .id = UCLASS_RESET, + .of_match = at91_reset_ids, + .bind = at91_reset_bind, + .probe = at91_reset_probe, + .priv_auto = sizeof(struct at91_reset), + .ops = &at91_reset_ops, +}; diff --git a/drivers/sysreset/sysreset_at91.c b/drivers/sysreset/sysreset_at91.c index 6119a29927..fc85f31ebf 100644 --- a/drivers/sysreset/sysreset_at91.c +++ b/drivers/sysreset/sysreset_at91.c @@ -56,17 +56,9 @@ static struct sysreset_ops at91_sysreset = { .request = at91_sysreset_request, };
-static const struct udevice_id a91_sysreset_ids[] = { - { .compatible = "atmel,sama5d3-rstc" }, - { .compatible = "microchip,sam9x60-rstc" }, - { .compatible = "microchip,sama7g5-rstc" }, - { } -}; - U_BOOT_DRIVER(sysreset_at91) = { .id = UCLASS_SYSRESET, - .name = "at91_reset", + .name = "at91_sysreset", .ops = &at91_sysreset, .probe = at91_sysreset_probe, - .of_match = a91_sysreset_ids, };
In order to have USB functionality, drivers for SAMA7's USB 2.0 PHY's have been added. There is one driver for UTMI clock's SFR and RESET required functionalities and one for its three possible subclocks of the phy's themselves. In order for this layout to properly work in conjunction with CCF and DT, the former driver will also act as a clock provider for the three phy's with the help of a custom hook into the driver's of_xlate method.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com Tested-by: Mihai Sain mihai.sain@microchip.com --- drivers/phy/Kconfig | 10 ++ drivers/phy/Makefile | 1 + drivers/phy/phy-sama7-usb.c | 92 ++++++++++++++ drivers/phy/phy-sama7-utmi-clk.c | 202 +++++++++++++++++++++++++++++++ 4 files changed, 305 insertions(+) create mode 100644 drivers/phy/phy-sama7-usb.c create mode 100644 drivers/phy/phy-sama7-utmi-clk.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index cf4d5908d7..9fbb956783 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -281,6 +281,16 @@ config PHY_XILINX_ZYNQMP Enable this to support ZynqMP High Speed Gigabit Transceiver that is part of ZynqMP SoC.
+config PHY_MICROCHIP_SAMA7_USB + tristate "Microchip SAMA7 USB 2.0 PHY" + depends on PHY && ARCH_AT91 + help + Enable this to support SAMA7 USB 2.0 PHY. + + The USB 2.0 PHY integrates high-speed, full-speed and low-speed + termination and signal switching. With a single resistor, it + requires minimal external components. + source "drivers/phy/rockchip/Kconfig" source "drivers/phy/cadence/Kconfig" source "drivers/phy/ti/Kconfig" diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index a3b9f3c5b1..9d50affd47 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o obj-$(CONFIG_PHY_NPCM_USB) += phy-npcm-usb.o obj-$(CONFIG_PHY_IMX8MQ_USB) += phy-imx8mq-usb.o obj-$(CONFIG_PHY_XILINX_ZYNQMP) += phy-zynqmp.o +obj-$(CONFIG_PHY_MICROCHIP_SAMA7_USB) += phy-sama7-utmi-clk.o phy-sama7-usb.o obj-y += cadence/ obj-y += ti/ obj-y += qcom/ diff --git a/drivers/phy/phy-sama7-usb.c b/drivers/phy/phy-sama7-usb.c new file mode 100644 index 0000000000..b6fe40ecc1 --- /dev/null +++ b/drivers/phy/phy-sama7-usb.c @@ -0,0 +1,92 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Support for Atmel/Microchip USB PHY's. + * + * Copyright (C) 2022 Microchip Technology Inc. and its subsidiaries + * + * Author: Sergiu Moga sergiu.moga@microchip.com + */ + +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <syscon.h> +#include <regmap.h> +#include <mach/sama7-sfr.h> + +struct sama7_usb_phy { + struct clk *uclk; + struct regmap *sfr; + int port; +}; + +int sama7_usb_phy_init(struct phy *phy) +{ + struct sama7_usb_phy *sama7_phy = dev_get_priv(phy->dev); + int port = sama7_phy->port; + + regmap_update_bits(sama7_phy->sfr, SAMA7_SFR_UTMI0R(port), + SAMA7_SFR_UTMI_RX_TX_PREEM_AMP_TUNE_1X, + SAMA7_SFR_UTMI_RX_TX_PREEM_AMP_TUNE_1X); + + regmap_update_bits(sama7_phy->sfr, SAMA7_SFR_UTMI0R(port), + SAMA7_SFR_UTMI_RX_VBUS, + SAMA7_SFR_UTMI_RX_VBUS); + + return 0; +} + +int sama7_phy_power_on(struct phy *phy) +{ + struct sama7_usb_phy *sama7_phy = dev_get_priv(phy->dev); + + clk_prepare_enable(sama7_phy->uclk); + + return 0; +} + +int sama7_phy_power_off(struct phy *phy) +{ + struct sama7_usb_phy *sama7_phy = dev_get_priv(phy->dev); + + clk_disable_unprepare(sama7_phy->uclk); + + return 0; +} + +int sama7_usb_phy_probe(struct udevice *dev) +{ + struct sama7_usb_phy *sama7_phy = dev_get_priv(dev); + + sama7_phy->uclk = devm_clk_get(dev, "utmi_clk"); + if (IS_ERR(sama7_phy->uclk)) + return PTR_ERR(sama7_phy->uclk); + + sama7_phy->sfr = syscon_regmap_lookup_by_phandle(dev, "sfr-phandle"); + if (IS_ERR(sama7_phy->sfr)) { + sama7_phy->sfr = NULL; + return PTR_ERR(sama7_phy->sfr); + } + + return dev_read_u32(dev, "reg", &sama7_phy->port); +} + +static const struct phy_ops sama7_usb_phy_ops = { + .init = sama7_usb_phy_init, + .power_on = sama7_phy_power_on, + .power_off = sama7_phy_power_off, +}; + +static const struct udevice_id sama7_usb_phy_of_match[] = { + { .compatible = "microchip,sama7g5-usb-phy", }, + { }, +}; + +U_BOOT_DRIVER(sama7_usb_phy_driver) = { + .name = "sama7-usb-phy", + .id = UCLASS_PHY, + .of_match = sama7_usb_phy_of_match, + .ops = &sama7_usb_phy_ops, + .probe = sama7_usb_phy_probe, + .priv_auto = sizeof(struct sama7_usb_phy), +}; diff --git a/drivers/phy/phy-sama7-utmi-clk.c b/drivers/phy/phy-sama7-utmi-clk.c new file mode 100644 index 0000000000..ab9fddccf6 --- /dev/null +++ b/drivers/phy/phy-sama7-utmi-clk.c @@ -0,0 +1,202 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Support for Atmel/Microchip USB PHY's. + * + * Copyright (C) 2022 Microchip Technology Inc. and its subsidiaries + * + * Author: Sergiu Moga sergiu.moga@microchip.com + */ + +#include <dm.h> +#include <linux/clk-provider.h> +#include <syscon.h> +#include <regmap.h> +#include <mach/sama7-sfr.h> +#include <reset.h> +#include <dt-bindings/clk/at91.h> + +struct sama7_utmi_clk { + struct clk uclk; + struct regmap *regmap_sfr; + struct reset_ctl *reset; + u8 id; +}; + +#define to_sama7_utmi_clk(_c) container_of(_c, struct sama7_utmi_clk, uclk) + +#define UBOOT_DM_CLK_MICROCHIP_SAMA7G5_UTMI "sama7-utmi-clk" +#define UBOOT_DM_MICROCHIP_SAMA7G5_UTMI "sama7-utmi" + +#define AT91_TO_CLK_ID(_t, _i) (((_t) << 8) | ((_i) & 0xff)) + +/* + * UTMI clock description + * @n: clock name + * @p: clock parent name + * @id: clock id in RSTC_GRSTR + */ +static struct { + const char *n; + const char *p; + u8 id; +} sama7_utmick[] = { + { .n = "utmi1", .p = "utmick", .id = 0, }, + { .n = "utmi2", .p = "utmi1", .id = 1, }, + { .n = "utmi3", .p = "utmi1", .id = 2, }, +}; + +static int sama7_utmi_clk_enable(struct clk *clk) +{ + int ret; + + struct sama7_utmi_clk *utmi = to_sama7_utmi_clk(clk); + u8 id = utmi->id; + + ret = reset_assert(utmi->reset); + if (ret) + return ret; + + ret = regmap_update_bits(utmi->regmap_sfr, SAMA7_SFR_UTMI0R(id), + SAMA7_SFR_UTMI_COMMONON, 0); + if (ret < 0) + return ret; + + ret = reset_deassert(utmi->reset); + if (ret) + return ret; + + /* Datasheet states a minimum of 45 us before any USB operation */ + udelay(50); + + return 0; +} + +static int sama7_utmi_clk_disable(struct clk *clk) +{ + int ret; + struct sama7_utmi_clk *utmi = to_sama7_utmi_clk(clk); + u8 id = utmi->id; + + ret = reset_assert(utmi->reset); + if (ret) + return ret; + + regmap_update_bits(utmi->regmap_sfr, SAMA7_SFR_UTMI0R(id), + SAMA7_SFR_UTMI_COMMONON, SAMA7_SFR_UTMI_COMMONON); + + return 0; +} + +static ulong sama7_utmi_clk_get_rate(struct clk *clk) +{ + /* Return utmick's rate: 480MHz */ + return clk_get_parent_rate(clk); +} + +static const struct clk_ops sama7_utmi_clk_ops = { + .enable = sama7_utmi_clk_enable, + .disable = sama7_utmi_clk_disable, + .get_rate = sama7_utmi_clk_get_rate, +}; + +static struct clk* +sama7_utmi_clk_register(struct regmap *regmap_sfr, struct reset_ctl *reset, + const char *name, const char *parent_name, u8 id) +{ + struct clk *clk; + struct sama7_utmi_clk *utmi_clk; + int ret; + + if (!regmap_sfr || !reset || !name || !parent_name) + return ERR_PTR(-EINVAL); + + utmi_clk = kzalloc(sizeof(*utmi_clk), GFP_KERNEL); + if (!utmi_clk) + return ERR_PTR(-ENOMEM); + + utmi_clk->reset = reset; + utmi_clk->regmap_sfr = regmap_sfr; + utmi_clk->id = id; + + clk = &utmi_clk->uclk; + ret = clk_register(clk, UBOOT_DM_CLK_MICROCHIP_SAMA7G5_UTMI, + name, parent_name); + if (ret) { + kfree(utmi_clk); + clk = ERR_PTR(ret); + } + + clk_dm(AT91_TO_CLK_ID(UTMI, utmi_clk->id), clk); + + return clk; +} + +static int sama7_utmi_probe(struct udevice *dev) +{ + struct clk *utmi_parent_clk, *utmi_clk; + struct regmap *regmap_sfr; + struct reset_ctl *phy_reset; + int i; + char name[16]; + + utmi_parent_clk = devm_clk_get(dev, "utmi_clk"); + if (IS_ERR(utmi_parent_clk)) + return PTR_ERR(utmi_parent_clk); + + regmap_sfr = syscon_regmap_lookup_by_phandle(dev, "sfr-phandle"); + if (IS_ERR(regmap_sfr)) + return PTR_ERR(regmap_sfr); + + for (i = 0; i < ARRAY_SIZE(sama7_utmick); i++) { + snprintf(name, sizeof(name), "usb%d_reset", i); + phy_reset = devm_reset_control_get(dev, name); + if (IS_ERR(phy_reset)) + return PTR_ERR(phy_reset); + + utmi_clk = sama7_utmi_clk_register(regmap_sfr, phy_reset, + sama7_utmick[i].n, + sama7_utmick[i].p, + sama7_utmick[i].id); + if (IS_ERR(utmi_clk)) + return PTR_ERR(utmi_clk); + } + + return 0; +}; + +static const struct udevice_id sama7_utmi_clk_dt_ids[] = { + { .compatible = "microchip,sama7g5-utmi-clk", }, + { /* sentinel */}, +}; + +static int utmi_clk_of_xlate(struct clk *clk, struct ofnode_phandle_args *args) +{ + if (args->args_count != 1) { + debug("UTMI: clk: Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + clk->id = AT91_TO_CLK_ID(UTMI, args->args[0]); + + return 0; +} + +static const struct clk_ops sama7_utmi_ops = { + .of_xlate = utmi_clk_of_xlate, + .enable = ccf_clk_enable, + .disable = ccf_clk_disable, +}; + +U_BOOT_DRIVER(microhip_sama7g5_utmi_clk) = { + .name = UBOOT_DM_CLK_MICROCHIP_SAMA7G5_UTMI, + .id = UCLASS_CLK, + .ops = &sama7_utmi_clk_ops, +}; + +U_BOOT_DRIVER(microhip_sama7g5_utmi) = { + .name = UBOOT_DM_MICROCHIP_SAMA7G5_UTMI, + .of_match = sama7_utmi_clk_dt_ids, + .id = UCLASS_CLK, + .ops = &sama7_utmi_ops, + .probe = sama7_utmi_probe, +};
Add the ability to enable/disable whatever USB PHY's are passed to the AT91 OHCI driver through DT.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com Tested-by: Mihai Sain mihai.sain@microchip.com --- drivers/usb/host/ohci-at91.c | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 362ab01c3d..43d3ed3bde 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -73,6 +73,10 @@ int usb_cpu_init_fail(void) #include <usb.h> #include "ohci.h"
+#if CONFIG_IS_ENABLED(PHY_MICROCHIP_SAMA7_USB) +#include <generic-phy.h> +#endif + #define AT91_MAX_USBH_PORTS 3
#define at91_for_each_port(index) \ @@ -89,6 +93,10 @@ struct ohci_at91_priv { struct clk *fclk; struct clk *hclk; bool clocked; + +#if CONFIG_IS_ENABLED(PHY_MICROCHIP_SAMA7_USB) + struct phy phy[AT91_MAX_USBH_PORTS]; +#endif };
static void at91_start_clock(struct ohci_at91_priv *ohci_at91) @@ -96,6 +104,13 @@ static void at91_start_clock(struct ohci_at91_priv *ohci_at91) if (ohci_at91->clocked) return;
+#if CONFIG_IS_ENABLED(PHY_MICROCHIP_SAMA7_USB) + int i; + + at91_for_each_port(i) + generic_phy_power_on(&ohci_at91->phy[i]); +#endif + clk_set_rate(ohci_at91->fclk, 48000000); clk_prepare_enable(ohci_at91->hclk); clk_prepare_enable(ohci_at91->iclk); @@ -108,6 +123,13 @@ static void at91_stop_clock(struct ohci_at91_priv *ohci_at91) if (!ohci_at91->clocked) return;
+#if CONFIG_IS_ENABLED(PHY_MICROCHIP_SAMA7_USB) + int i; + + at91_for_each_port(i) + generic_phy_power_off(&ohci_at91->phy[i]); +#endif + clk_disable_unprepare(ohci_at91->fclk); clk_disable_unprepare(ohci_at91->iclk); clk_disable_unprepare(ohci_at91->hclk); @@ -213,6 +235,14 @@ static int ohci_atmel_probe(struct udevice *dev) goto fail; }
+#if CONFIG_IS_ENABLED(PHY_MICROCHIP_SAMA7_USB) + at91_for_each_port(i) { + generic_phy_get_by_index(dev, i, &ohci_at91->phy[i]); + generic_phy_init(&ohci_at91->phy[i]); + generic_phy_configure(&ohci_at91->phy[i], NULL); + } +#endif + at91_start_hc(dev);
return ohci_register(dev, regs); @@ -227,6 +257,7 @@ fail:
static const struct udevice_id ohci_usb_ids[] = { { .compatible = "atmel,at91rm9200-ohci", }, + { .compatible = "microchip,sama7g5-ohci", }, { } };
Enable USB and RESET functionality. In order for USB to work properly on SAMA7, the driver needs to be able to have access to PHY's, which, in turn, need to have access to the RSTC driver's assert/deassert functionalities.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com Tested-by: Mihai Sain mihai.sain@microchip.com --- configs/sama7g5ek_mmc1_defconfig | 13 +++++++++++++ configs/sama7g5ek_mmc_defconfig | 13 +++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/configs/sama7g5ek_mmc1_defconfig b/configs/sama7g5ek_mmc1_defconfig index f004e44803..afe7676d90 100644 --- a/configs/sama7g5ek_mmc1_defconfig +++ b/configs/sama7g5ek_mmc1_defconfig @@ -78,4 +78,17 @@ CONFIG_SYSRESET_AT91=y CONFIG_TIMER=y CONFIG_MCHP_PIT64B_TIMER=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama7g5ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y +CONFIG_PHY=y +CONFIG_PHY_MICROCHIP_SAMA7_USB=y +CONFIG_DM_RESET=y +CONFIG_RESET_AT91=y # CONFIG_EFI_LOADER_HII is not set diff --git a/configs/sama7g5ek_mmc_defconfig b/configs/sama7g5ek_mmc_defconfig index 5b42fc63f3..9865b070be 100644 --- a/configs/sama7g5ek_mmc_defconfig +++ b/configs/sama7g5ek_mmc_defconfig @@ -78,4 +78,17 @@ CONFIG_SYSRESET_AT91=y CONFIG_TIMER=y CONFIG_MCHP_PIT64B_TIMER=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama7g5ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y +CONFIG_PHY=y +CONFIG_PHY_MICROCHIP_SAMA7_USB=y +CONFIG_DM_RESET=y +CONFIG_RESET_AT91=y # CONFIG_EFI_LOADER_HII is not set
Add the pinctrl subnodes required by the USB related DT nodes.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- arch/arm/dts/at91-sama5d2_icp.dts | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/at91-sama5d2_icp.dts b/arch/arm/dts/at91-sama5d2_icp.dts index 2dffae9c5c..4f796c6c94 100644 --- a/arch/arm/dts/at91-sama5d2_icp.dts +++ b/arch/arm/dts/at91-sama5d2_icp.dts @@ -154,7 +154,29 @@ <PIN_PA13__SDMMC0_CD>; bias-disable; }; + + pinctrl_usb_default: usb_default { + pinmux = <PIN_PC17__GPIO>; + bias-disable; + }; + + pinctrl_usba_vbus: usba_vbus { + pinmux = <PIN_PD23__GPIO>; + bias-disable; + }; }; }; }; }; + +&usb1 { + num-ports = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + status = "okay"; +}; + +&usb2 { + phy_type = "hsic"; + status = "okay"; +};
Add the pinctrl nodes required by the USB related DT nodes.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- arch/arm/dts/at91-sama5d27_wlsom1_ek.dts | 25 ++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts b/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts index eec183d5de..6d4b35ea96 100644 --- a/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts +++ b/arch/arm/dts/at91-sama5d27_wlsom1_ek.dts @@ -143,7 +143,32 @@ pinmux = <PIN_PC9__GPIO>; bias-pull-up; }; + + pinctrl_usb_default: usb_default { + pinmux = <PIN_PA10__GPIO>; + bias-disable; + }; + + pinctrl_usba_vbus: usba_vbus { + pinmux = <PIN_PA16__GPIO>; + bias-disable; + }; }; }; }; }; + +&usb1 { + num-ports = <3>; + atmel,vbus-gpio = <0 + &pioA PIN_PA10 GPIO_ACTIVE_HIGH + 0 + >; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_default>; + status = "okay"; +}; + +&usb2 { + status = "okay"; +};
Enable the OHCI and EHCI related configs required in order to be able to use the USB command properly.
Signed-off-by: Sergiu Moga sergiu.moga@microchip.com --- configs/sama5d27_som1_ek_mmc1_defconfig | 5 +++++ configs/sama5d27_som1_ek_mmc_defconfig | 5 +++++ configs/sama5d27_som1_ek_qspiflash_defconfig | 5 +++++ configs/sama5d27_wlsom1_ek_mmc_defconfig | 6 ++++++ configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 5 +++++ configs/sama5d2_icp_mmc_defconfig | 9 +++++++++ configs/sama5d2_icp_qspiflash_defconfig | 9 +++++++++ configs/sama5d2_ptc_ek_mmc_defconfig | 5 +++++ configs/sama5d2_ptc_ek_nandflash_defconfig | 5 +++++ configs/sama5d2_xplained_emmc_defconfig | 5 +++++ configs/sama5d2_xplained_mmc_defconfig | 5 +++++ configs/sama5d2_xplained_qspiflash_defconfig | 5 +++++ configs/sama5d2_xplained_spiflash_defconfig | 5 +++++ 13 files changed, 74 insertions(+)
diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 93ae714b62..935afd633f 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -108,6 +108,11 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_SPL_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_USB_ATMEL=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d27_som1_ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 5096366de7..c52ce7e8a3 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -109,6 +109,11 @@ CONFIG_SPL_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_USB_ATMEL=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d27_som1_ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index d7c7f42c93..9385e7bd96 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -108,6 +108,11 @@ CONFIG_SPL_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d27_som1_ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 7634a6c68f..c0d5d2d165 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -114,6 +114,12 @@ CONFIG_SPL_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d27_wlsom1_ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index bb018d4c69..d581b0e389 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -118,6 +118,11 @@ CONFIG_SPL_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d27_wlsom1_ek" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 51f7104b35..cf72910e0c 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -111,4 +111,13 @@ CONFIG_SPL_TIMER=y CONFIG_ATMEL_TCB_TIMER=y CONFIG_SPL_ATMEL_TCB_TIMER=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_CMD_USB=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_icp" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=4 +CONFIG_USB_ATMEL=y # CONFIG_EFI_LOADER_HII is not set diff --git a/configs/sama5d2_icp_qspiflash_defconfig b/configs/sama5d2_icp_qspiflash_defconfig index ab7308848f..e8181b1a0c 100644 --- a/configs/sama5d2_icp_qspiflash_defconfig +++ b/configs/sama5d2_icp_qspiflash_defconfig @@ -96,6 +96,15 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_CMD_USB=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_icp" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=4 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 8ae20d5a76..5464a7cbd6 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -78,6 +78,11 @@ CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_ptc" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_W1=y CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index f987278101..36d45521be 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -78,6 +78,11 @@ CONFIG_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_ptc" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_W1=y CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 9509091c4e..94a554b4a0 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -108,6 +108,11 @@ CONFIG_SPL_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_xplained" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index fe267f33e2..3889efdc5e 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -110,6 +110,11 @@ CONFIG_SPL_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_xplained" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index 7fc5dad631..32741f2265 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -110,6 +110,11 @@ CONFIG_SPL_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_xplained" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 95e2b449f9..7b2e4c06a9 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -114,6 +114,11 @@ CONFIG_SPL_ATMEL_TCB_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_USB_OHCI_HCD=y +CONFIG_DM_USB=y +CONFIG_SYS_USB_OHCI_SLOT_NAME="sama5d2_xplained" +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=1 +CONFIG_USB_ATMEL=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_VIDEO=y
The `ohci_register` function expects that the OHCI driver's priv is a struct whose first field is of type `ohci_t`. The original conversion to DM did not have it and this inconsistency revealed itself whenever U-Boot required multiple memory allocations resulting in a memory overwrite of where this field would supposedly be.
Thus, add this missing field and automatically increase the implicit size of the driver's priv to avoid whatever future memory allocations may take place from overwriting it.
Fixes: de1cf0a9c6 ("drivers: usb: ohci-at91: Enable OHCI functionality and register into DM") Signed-off-by: Cristian Birsan cristian.birsan@microchip.com Signed-off-by: Sergiu Moga sergiu.moga@microchip.com Tested-by: Mihai Sain mihai.sain@microchip.com --- drivers/usb/host/ohci-at91.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 43d3ed3bde..b53d80e3f5 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -89,6 +89,7 @@ struct at91_usbh_data { };
struct ohci_at91_priv { + ohci_t ohci; struct clk *iclk; struct clk *fclk; struct clk *hclk;
On 12/7/22 15:14, Sergiu Moga wrote:
This series of patches is meant to add support for USB Mass Storage on SAM9X60, SAMA7G5 and SAMA5D2 boards and register ohci-at91 driver into Driver Model. In order for this to be achieved, the respective DT nodes have been added, the USB clock has been registered into CCF and the required defconfigs have been added to the boards' defconfig. What is more, in order for the VBUS to stay enabled, a `child_pre_probe` method has been added to overcome the DM core disabling it in `usb_scan_device`: when the generic `device_probe` method is called, the pinctrl is processed once again, undoing whatever changes have been made in our driver's probe method. In order to enable USB on SAMA7G5 the addition of RSTC and USB 2.0 PHY drivers were required.
Cristian Birsan (2): ARM: at91: add sama7 SFR definitions usb: ohci-at91: Add `ohci_t` field in `ohci_at91_priv`
Sergiu Moga (16): ARM: dts: sam9x60ek: Add OHCI and EHCI DT nodes clk: at91: Add support for sam9x60 USB clock clk: at91: sam9x60: Register the required clocks for USB clk: at91: sam9x60: Add initial setup of UPLL and USBCK rates usb: ohci-at91: Enable OHCI functionality and register into DM configs: at91: sam9x60ek: Add required configs for the USB command dt-bindings: reset: add sama7g5 definitions dt-bindings: clk: at91: Define additional UTMI related clocks ARM: dts: at91: sama7: Add USB related DT nodes reset: at91: Add reset driver for basic assert/deassert operations phy: at91: Add support for the USB 2.0 PHY's of SAMA7 usb: ohci-at91: Add USB PHY functionality configs: at91: sama7: Enable USB and RESET functionality ARM: dts: at91: sama5d2_icp: Add pinctrl nodes for USB related DT nodes ARM: dts: at91: sama5d27_wlsom1_ek: Add pinctrl nodes for USB DT nodes configs: at91: sama5d2: Enable OHCI/EHCI related configs
arch/arm/dts/at91-sama5d27_wlsom1_ek.dts | 25 ++ arch/arm/dts/at91-sama5d2_icp.dts | 22 ++ arch/arm/dts/at91-sama7g5ek.dts | 34 +++ arch/arm/dts/sam9x60.dtsi | 18 ++ arch/arm/dts/sam9x60ek.dts | 21 ++ arch/arm/dts/sama7g5.dtsi | 73 ++++++ arch/arm/mach-at91/include/mach/sama7-sfr.h | 59 +++++ configs/sam9x60ek_mmc_defconfig | 10 + configs/sam9x60ek_nandflash_defconfig | 10 + configs/sam9x60ek_qspiflash_defconfig | 10 + configs/sama5d27_som1_ek_mmc1_defconfig | 5 + configs/sama5d27_som1_ek_mmc_defconfig | 5 + configs/sama5d27_som1_ek_qspiflash_defconfig | 5 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 6 + .../sama5d27_wlsom1_ek_qspiflash_defconfig | 5 + configs/sama5d2_icp_mmc_defconfig | 9 + configs/sama5d2_icp_qspiflash_defconfig | 9 + configs/sama5d2_ptc_ek_mmc_defconfig | 5 + configs/sama5d2_ptc_ek_nandflash_defconfig | 5 + configs/sama5d2_xplained_emmc_defconfig | 5 + configs/sama5d2_xplained_mmc_defconfig | 5 + configs/sama5d2_xplained_qspiflash_defconfig | 5 + configs/sama5d2_xplained_spiflash_defconfig | 5 + configs/sama7g5ek_mmc1_defconfig | 13 ++ configs/sama7g5ek_mmc_defconfig | 13 ++ drivers/clk/at91/Kconfig | 7 + drivers/clk/at91/Makefile | 1 + drivers/clk/at91/clk-sam9x60-usb.c | 156 +++++++++++++ drivers/clk/at91/pmc.h | 11 + drivers/clk/at91/sam9x60.c | 99 +++++++- drivers/phy/Kconfig | 10 + drivers/phy/Makefile | 1 + drivers/phy/phy-sama7-usb.c | 92 ++++++++ drivers/phy/phy-sama7-utmi-clk.c | 202 +++++++++++++++++ drivers/reset/Kconfig | 8 + drivers/reset/Makefile | 1 + drivers/reset/reset-at91.c | 143 ++++++++++++ drivers/sysreset/sysreset_at91.c | 10 +- drivers/usb/host/ohci-at91.c | 214 ++++++++++++++++++ include/dt-bindings/clk/at91.h | 5 + include/dt-bindings/reset/sama7g5-reset.h | 10 + 41 files changed, 1342 insertions(+), 10 deletions(-) create mode 100644 arch/arm/mach-at91/include/mach/sama7-sfr.h create mode 100644 drivers/clk/at91/clk-sam9x60-usb.c create mode 100644 drivers/phy/phy-sama7-usb.c create mode 100644 drivers/phy/phy-sama7-utmi-clk.c create mode 100644 drivers/reset/reset-at91.c create mode 100644 include/dt-bindings/reset/sama7g5-reset.h
Hi Sergiu,
When enabling the configs, I get plenty of errors like this in lots of boards:
./arch/arm/include/asm/arch/clk.h: In function ‘get_h32mxdiv’: ./arch/arm/include/asm/arch/clk.h:65:9: warning: implicit declaration of function ‘readl’ [-Wimplicit-function-declaration] 65 | return readl(&pmc->mckr) & AT91_PMC_MCKR_H32MXDIV; | ^~~~~
This commit causes the problem : configs: at91: sama5d2: Enable OHCI/EHCI related config
But I assume there is a problem with the driver since the commit only enables it to be built.
Can you have a look please ?
Eugen
Eugen.Hristev@microchip.com
Sergiu Moga
