[PATCH] board: phytec: phycore_imx8mp.env fix netboot issues
The "run netargs" command should come later in the "netboot" command order when using dhcp since it sets the server and client ip addresses. The previous order led to misconfigured kernel boot params and thus kernel panic when serverip was not manually set. Further, following Linux FHS 3.0, change the nfsroot default directory to /srv/nfs.
Fixes: 60f64bec414e ("board: phytec: phycore_imx8mp: Add fec support") Signed-off-by: Yannic Moog y.moog@phytec.de --- Depends on [1] which is on next already. [1] https://lore.kernel.org/u-boot/20240312085957.902398-1-l.anderweit@phytec.de... --- board/phytec/phycore_imx8mp/phycore_imx8mp.env | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/phytec/phycore_imx8mp/phycore_imx8mp.env b/board/phytec/phycore_imx8mp/phycore_imx8mp.env index fae3e992654..7f6c5fd2c76 100644 --- a/board/phytec/phycore_imx8mp/phycore_imx8mp.env +++ b/board/phytec/phycore_imx8mp/phycore_imx8mp.env @@ -46,17 +46,17 @@ netargs= nfsroot=${serverip}:${nfsroot},v3,tcp netboot= echo Booting from net ...; - run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${loadaddr} ${image}; + run netargs; if ${get_cmd} ${fdt_addr} ${fdt_file}; then booti ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi; -nfsroot=/nfs +nfsroot=/srv/nfs sd_dev=1
--- base-commit: 86b79cf131b64eadae023a127921893d30503093 change-id: 20240322-phycore_mx8mp_netboot_fixes-337ceb4ba0cc
Applied to u-boot-imx/next, thanks.
Fabio Estevam
Yannic Moog
