[U-Boot] [PATCH v3 00/15] imx6: Engicam i.CoreM6/Is.IoT eMMC boot support
Changes for v3: - Update IMX6_BMODE_* shift macros with real number instead of bitops - %s/IMX6_BMODE_SERIAL/IMX6_BMODE_SERIAL_ROM - Assign enums with numbers so-that it can easy to see same in RM - Update board MAINTAINERS file with imx6ul-isiot-emmc.dts file
Changes for v2: - Rebase on master - Add Is.IoT eMMC boot patches - Add few mmc env patches on board
Jagan Teki (15): imx6: Add imx6_src_get_boot_mode imx: spl: Update NAND bootmode detection bit imx: Use IMX6_BMODE_* macros instead of numericals imx6: Add src_base structure define macro imx6: isiotmx6ul: Update SPL board boot order for eMMC i.MX6UL: isiot: Add eMMC boot support i.MX6UL: isiot: Add modeboot env via board_late_init i.MX6UL: isiot: Add mmc_late_init i.MX6UL: isiot: Switch the mmc env based on devno arm: dts: imx6qdl-icore-rqs: Add eMMC node imx6: icorem6_rqs: Update SPL board boot order for eMMC imx6: icorem6_rqs: Add eMMC boot support i.MX6Q: icorem6_rqs: Add modeboot env via board_late_init i.MX6Q: icorem6_rqs: Add mmc_late_init i.MX6Q: isiot: Switch the mmc env based on devno
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6qdl-icore-rqs.dtsi | 22 ++++++ arch/arm/dts/imx6ul-isiot-emmc.dts | 77 +++++++++++++++++++++ arch/arm/imx-common/init.c | 10 +++ arch/arm/imx-common/spl.c | 50 ++++++++------ arch/arm/include/asm/arch-mx6/imx-regs.h | 2 + arch/arm/include/asm/imx-common/sys_proto.h | 46 +++++++++++++ board/engicam/icorem6_rqs/icorem6_rqs.c | 96 +++++++++++++++++++++++++- board/engicam/isiotmx6ul/MAINTAINERS | 2 + board/engicam/isiotmx6ul/isiotmx6ul.c | 101 +++++++++++++++++++++++++++- configs/imx6dl_icore_rqs_mmc_defconfig | 1 + configs/imx6q_icore_rqs_mmc_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 40 +++++++++++ configs/imx6ul_isiot_mmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + include/configs/imx6qdl_icore_rqs.h | 36 +++++----- include/configs/imx6ul_isiot.h | 40 +++++------ 17 files changed, 461 insertions(+), 66 deletions(-) create mode 100644 arch/arm/dts/imx6ul-isiot-emmc.dts create mode 100644 configs/imx6ul_isiot_emmc_defconfig
For i.MX6, the bootmode determine code is part of spl_boot_device, but there is might be a possibility for other part the code need to check the desired boot mode for adding new functionalities like modeboot env variable, or changing boot order etc.
So introduced imx6_src_get_boot_mode which actually reading the boot mode register for desired modes.
More cleanup will be add in future patches.
Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@openedev.com --- arch/arm/imx-common/init.c | 12 ++++++++++++ arch/arm/imx-common/spl.c | 6 +++--- arch/arm/include/asm/imx-common/sys_proto.h | 14 ++++++++++++++ 3 files changed, 29 insertions(+), 3 deletions(-)
diff --git a/arch/arm/imx-common/init.c b/arch/arm/imx-common/init.c index e5dbd93..036ebb2 100644 --- a/arch/arm/imx-common/init.c +++ b/arch/arm/imx-common/init.c @@ -115,3 +115,15 @@ void boot_mode_apply(unsigned cfg_val) writel(reg, &psrc->gpr10); } #endif + +#if defined(CONFIG_MX6) +u32 imx6_src_get_boot_mode(void) +{ + struct src *psrc = (struct src *)SRC_BASE_ADDR; + + if (imx6_is_bmode_from_gpr9()) + return readl(&psrc->gpr9); + else + return readl(&psrc->sbmr1); +} +#endif diff --git a/arch/arm/imx-common/spl.c b/arch/arm/imx-common/spl.c index 60c4adf..a7f9705 100644 --- a/arch/arm/imx-common/spl.c +++ b/arch/arm/imx-common/spl.c @@ -10,6 +10,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> #include <asm/spl.h> #include <spl.h> #include <asm/imx-common/hab.h> @@ -19,16 +20,15 @@ u32 spl_boot_device(void) { struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned int gpr10_boot = readl(&psrc->gpr10) & (1 << 28); - unsigned reg = gpr10_boot ? readl(&psrc->gpr9) : readl(&psrc->sbmr1); unsigned int bmode = readl(&psrc->sbmr2); + u32 reg = imx6_src_get_boot_mode();
/* * Check for BMODE if serial downloader is enabled * BOOT_MODE - see IMX6DQRM Table 8-1 */ if ((((bmode >> 24) & 0x03) == 0x01) || /* Serial Downloader */ - (gpr10_boot && (reg == 1))) + (imx6_is_bmode_from_gpr9() && (reg == 1))) return BOOT_DEVICE_UART; /* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ switch ((reg & 0x000000FF) >> 4) { diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index 539d34b..99e3869 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -8,6 +8,7 @@ #ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_
+#include <asm/io.h> #include <asm/imx-common/regs-common.h> #include <common.h> #include "../arch-imx/cpu.h" @@ -38,6 +39,19 @@ #define is_mx6ull() (is_cpu_type(MXC_CPU_MX6ULL)) #define is_mx6sll() (is_cpu_type(MXC_CPU_MX6SLL))
+#ifdef CONFIG_MX6 +#define IMX6_SRC_GPR10_BMODE BIT(28) + +static inline u8 imx6_is_bmode_from_gpr9(void) +{ + struct src *psrc = (struct src *)SRC_BASE_ADDR; + + return readl(&psrc->gpr10) & IMX6_SRC_GPR10_BMODE; +} + +u32 imx6_src_get_boot_mode(void); +#endif /* CONFIG_MX6 */ + u32 get_nr_cpus(void); u32 get_cpu_rev(void); u32 get_cpu_speed_grade_hz(void);
Hi Jagan,
This restores the old behavior before commit:
commit ac0a93fd21b815166c54b991659377f951d4d203 Author: Stefan Agner stefan.agner@toradex.com Date: Tue Dec 27 17:01:42 2016 +0100
imx_common: check for bmode Serial Downloader
It was reported by Stefan that the unreserved value (not documented) causes issue and boards cannot boot. I agree on your patch to cleanup code, but it should not change the current behaviour or the reported issue will come up again
Best regards, Stefano Babic
- struct src *psrc = (struct src *)SRC_BASE_ADDR;
- if (imx6_is_bmode_from_gpr9())
- else
- Check for BMODE if serial downloader is enabled
- BOOT_MODE - see IMX6DQRM Table 8-1
return BOOT_DEVICE_UART; /* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ switch ((reg & 0x000000FF) >> 4) {(imx6_is_bmode_from_gpr9() && (reg == 1)))
- return readl(&psrc->gpr10) & IMX6_SRC_GPR10_BMODE;
BOOT_CFG1[7:4] the NAND boot mode selection is done only when BOOT_CFG1[7] is 1 hence update the NAND boot mode detection bit case. This information available on Table 8-11. NAND Boot eFUSE Descriptions, from IMX6DQRM.
Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Signed-off-by: Jagan Teki jagan@openedev.com --- arch/arm/imx-common/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/imx-common/spl.c b/arch/arm/imx-common/spl.c index a7f9705..fc3704b 100644 --- a/arch/arm/imx-common/spl.c +++ b/arch/arm/imx-common/spl.c @@ -61,8 +61,8 @@ u32 spl_boot_device(void) case 0x6: case 0x7: return BOOT_DEVICE_MMC1; - /* NAND Flash: 8.5.2 */ - case 0x8 ... 0xf: + /* NAND Flash: 8.5.2, Table 8-10 */ + case 0x8: return BOOT_DEVICE_NAND; } return BOOT_DEVICE_NONE;
- case 0x8 ... 0xf:
- /* NAND Flash: 8.5.2, Table 8-10 */
- case 0x8: return BOOT_DEVICE_NAND; } return BOOT_DEVICE_NONE;
Reviewed by : Stefano Babic |sbabic@denx.de>
Use meaningful macros IMX6_BMODE_*, instead of numerical number in boot mode detection code.
Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Signed-off-by: Jagan Teki jagan@openedev.com --- Changes for v3: - Update IMX6_BMODE_* shift macros with real number instead of bitops - %s/IMX6_BMODE_SERIAL/IMX6_BMODE_SERIAL_ROM - Assign enums with numbers so-that it can easy to see same in RM
arch/arm/imx-common/spl.c | 39 ++++++++++++++++++----------- arch/arm/include/asm/imx-common/sys_proto.h | 34 +++++++++++++++++++++++++ 2 files changed, 58 insertions(+), 15 deletions(-)
diff --git a/arch/arm/imx-common/spl.c b/arch/arm/imx-common/spl.c index fc3704b..acf268d 100644 --- a/arch/arm/imx-common/spl.c +++ b/arch/arm/imx-common/spl.c @@ -30,39 +30,48 @@ u32 spl_boot_device(void) if ((((bmode >> 24) & 0x03) == 0x01) || /* Serial Downloader */ (imx6_is_bmode_from_gpr9() && (reg == 1))) return BOOT_DEVICE_UART; + /* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ - switch ((reg & 0x000000FF) >> 4) { + switch ((reg & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { /* EIM: See 8.5.1, Table 8-9 */ - case 0x0: + case IMX6_BMODE_EMI: /* BOOT_CFG1[3]: NOR/OneNAND Selection */ - if ((reg & 0x00000008) >> 3) + switch ((reg & IMX6_BMODE_EMI_MASK) >> IMX6_BMODE_EMI_SHIFT) { + case IMX6_BMODE_ONENAND: return BOOT_DEVICE_ONENAND; - else + case IMX6_BMODE_NOR: return BOOT_DEVICE_NOR; - break; + } /* SATA: See 8.5.4, Table 8-20 */ - case 0x2: + case IMX6_BMODE_SATA: return BOOT_DEVICE_SATA; /* Serial ROM: See 8.5.5.1, Table 8-22 */ - case 0x3: + case IMX6_BMODE_SERIAL_ROM: /* BOOT_CFG4[2:0] */ - switch ((reg & 0x07000000) >> 24) { - case 0x0 ... 0x4: + switch ((reg & IMX6_BMODE_SERIAL_ROM_MASK) >> + IMX6_BMODE_SERIAL_ROM_SHIFT) { + case IMX6_BMODE_ECSPI1: + case IMX6_BMODE_ECSPI2: + case IMX6_BMODE_ECSPI3: + case IMX6_BMODE_ECSPI4: + case IMX6_BMODE_ECSPI5: return BOOT_DEVICE_SPI; - case 0x5 ... 0x7: + case IMX6_BMODE_I2C1: + case IMX6_BMODE_I2C2: + case IMX6_BMODE_I2C3: return BOOT_DEVICE_I2C; } break; /* SD/eSD: 8.5.3, Table 8-15 */ - case 0x4: - case 0x5: + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: return BOOT_DEVICE_MMC1; /* MMC/eMMC: 8.5.3 */ - case 0x6: - case 0x7: + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: return BOOT_DEVICE_MMC1; /* NAND Flash: 8.5.2, Table 8-10 */ - case 0x8: + case IMX6_BMODE_NAND: return BOOT_DEVICE_NAND; } return BOOT_DEVICE_NONE; diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index 99e3869..ba95641 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -42,6 +42,40 @@ #ifdef CONFIG_MX6 #define IMX6_SRC_GPR10_BMODE BIT(28)
+#define IMX6_BMODE_MASK GENMASK(7, 0) +#define IMX6_BMODE_SHIFT 4 +#define IMX6_BMODE_EMI_MASK BIT(3) +#define IMX6_BMODE_EMI_SHIFT 3 +#define IMX6_BMODE_SERIAL_ROM_MASK GENMASK(26, 24) +#define IMX6_BMODE_SERIAL_ROM_SHIFT 24 + +enum imx6_bmode_serial_rom { + IMX6_BMODE_ECSPI1, + IMX6_BMODE_ECSPI2, + IMX6_BMODE_ECSPI3, + IMX6_BMODE_ECSPI4, + IMX6_BMODE_ECSPI5, + IMX6_BMODE_I2C1, + IMX6_BMODE_I2C2, + IMX6_BMODE_I2C3, +}; + +enum imx6_bmode_emi { + IMX6_BMODE_ONENAND, + IMX6_BMODE_NOR, +}; + +enum imx6_bmode { + IMX6_BMODE_EMI = 0x0, + IMX6_BMODE_SATA = 0x2, + IMX6_BMODE_SERIAL_ROM = 0x3, + IMX6_BMODE_SD = 0x4, + IMX6_BMODE_ESD = 0x5, + IMX6_BMODE_MMC = 0x6, + IMX6_BMODE_EMMC = 0x7, + IMX6_BMODE_NAND = 0x8, +}; + static inline u8 imx6_is_bmode_from_gpr9(void) { struct src *psrc = (struct src *)SRC_BASE_ADDR;
Changes for v3:
- /* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */
- switch ((reg & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { /* EIM: See 8.5.1, Table 8-9 */
- case 0x0:
- case IMX6_BMODE_EMI: /* BOOT_CFG1[3]: NOR/OneNAND Selection */
else
break;
/* SATA: See 8.5.4, Table 8-20 */}
- case 0x2:
- case IMX6_BMODE_SATA: return BOOT_DEVICE_SATA; /* Serial ROM: See 8.5.5.1, Table 8-22 */
- case 0x3:
- case IMX6_BMODE_SERIAL_ROM: /* BOOT_CFG4[2:0] */
case 0x0 ... 0x4:
case 0x5 ... 0x7:
} break; /* SD/eSD: 8.5.3, Table 8-15 */case IMX6_BMODE_I2C3: return BOOT_DEVICE_I2C;
- case 0x4:
- case 0x5:
- case IMX6_BMODE_SD:
- case IMX6_BMODE_ESD: return BOOT_DEVICE_MMC1; /* MMC/eMMC: 8.5.3 */
- case 0x6:
- case 0x7:
- case IMX6_BMODE_MMC:
- case IMX6_BMODE_EMMC: return BOOT_DEVICE_MMC1; /* NAND Flash: 8.5.2, Table 8-10 */
- case 0x8:
- case IMX6_BMODE_NAND: return BOOT_DEVICE_NAND; } return BOOT_DEVICE_NONE;
- IMX6_BMODE_ECSPI1,
- IMX6_BMODE_ECSPI2,
- IMX6_BMODE_ECSPI3,
- IMX6_BMODE_ECSPI4,
- IMX6_BMODE_ECSPI5,
- IMX6_BMODE_I2C1,
- IMX6_BMODE_I2C2,
- IMX6_BMODE_I2C3,
- IMX6_BMODE_ONENAND,
- IMX6_BMODE_NOR,
+enum imx6_bmode {
- IMX6_BMODE_EMI = 0x0,
- IMX6_BMODE_SATA = 0x2,
- IMX6_BMODE_SERIAL_ROM = 0x3,
- IMX6_BMODE_SD = 0x4,
- IMX6_BMODE_ESD = 0x5,
- IMX6_BMODE_MMC = 0x6,
- IMX6_BMODE_EMMC = 0x7,
- IMX6_BMODE_NAND = 0x8,
Fully agree to get rid of hex code !
Acked by : Stefano Babic |sbabic@denx.de>
Instead of initializing 'struct src' to SRC_BASE_ADDR on every function better to have global define macro.
Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jagan Teki jagan@openedev.com --- arch/arm/imx-common/init.c | 6 ++---- arch/arm/imx-common/spl.c | 3 +-- arch/arm/include/asm/arch-mx6/imx-regs.h | 2 ++ arch/arm/include/asm/imx-common/sys_proto.h | 4 +--- 4 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/arch/arm/imx-common/init.c b/arch/arm/imx-common/init.c index 036ebb2..5b4f828 100644 --- a/arch/arm/imx-common/init.c +++ b/arch/arm/imx-common/init.c @@ -119,11 +119,9 @@ void boot_mode_apply(unsigned cfg_val) #if defined(CONFIG_MX6) u32 imx6_src_get_boot_mode(void) { - struct src *psrc = (struct src *)SRC_BASE_ADDR; - if (imx6_is_bmode_from_gpr9()) - return readl(&psrc->gpr9); + return readl(&src_base->gpr9); else - return readl(&psrc->sbmr1); + return readl(&src_base->sbmr1); } #endif diff --git a/arch/arm/imx-common/spl.c b/arch/arm/imx-common/spl.c index acf268d..c8723bb 100644 --- a/arch/arm/imx-common/spl.c +++ b/arch/arm/imx-common/spl.c @@ -19,8 +19,7 @@ /* determine boot device from SRC_SBMR1 (BOOT_CFG[4:1]) or SRC_GPR9 register */ u32 spl_boot_device(void) { - struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned int bmode = readl(&psrc->sbmr2); + unsigned int bmode = readl(&src_base->sbmr2); u32 reg = imx6_src_get_boot_mode();
/* diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 6727c56..646013d 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -473,6 +473,8 @@ struct src { u32 gpr10; };
+#define src_base ((struct src *)SRC_BASE_ADDR) + #define SRC_SCR_M4_ENABLE_OFFSET 22 #define SRC_SCR_M4_ENABLE_MASK (1 << 22) #define SRC_SCR_M4C_NON_SCLR_RST_OFFSET 4 diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index ba95641..673527a 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -78,9 +78,7 @@ enum imx6_bmode {
static inline u8 imx6_is_bmode_from_gpr9(void) { - struct src *psrc = (struct src *)SRC_BASE_ADDR; - - return readl(&psrc->gpr10) & IMX6_SRC_GPR10_BMODE; + return readl(&src_base->gpr10) & IMX6_SRC_GPR10_BMODE; }
elsereturn readl(&src_base->gpr9);
- return readl(&src_base->gpr10) & IMX6_SRC_GPR10_BMODE;
SPL mmc device index is get based on the boot device, like - BOOT_DEVICE_MMC1 for mmc device 0 - BOOT_DEVICE_MMC2 for mmc device 1
Currently BOOT_DEVICE_MMC1 is setting both SD/eSD and MMC/eMMC boot devices in i.MX, So u-boot is loading from mmc device 0 even "if the board booting from SD/eSD or MMC/eMMC"
So, this patch set BOOT_DEVICE_MMC2 for MMC/eMMC so for MMC/eMMC the u-boot is loading from mmc device 1 and the board file need to take care if the board have different mmc device order intialization.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 20c8aa7..07dd501 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -205,6 +205,32 @@ int board_mmc_init(bd_t *bis)
return 0; } + +#ifdef CONFIG_ENV_IS_IN_MMC +void board_boot_order(u32 *spl_boot_list) +{ + u32 bmode = imx6_src_get_boot_mode(); + u8 boot_dev = BOOT_DEVICE_MMC1; + + switch ((bmode & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + /* SD/eSD - BOOT_DEVICE_MMC1 */ + break; + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + /* MMC/eMMC */ + boot_dev = BOOT_DEVICE_MMC2; + break; + default: + /* Default - BOOT_DEVICE_MMC1 */ + printf("Wrong board boot order\n"); + break; + } + + spl_boot_list[0] = boot_dev; +} +#endif #endif /* CONFIG_FSL_ESDHC */
static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = {
return 0; }
- u32 bmode = imx6_src_get_boot_mode();
- u8 boot_dev = BOOT_DEVICE_MMC1;
- switch ((bmode & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) {
break;
/* MMC/eMMC */
break;
- default:
break;
- spl_boot_list[0] = boot_dev;
Boot from eMMC: -------------- U-Boot SPL 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27) Trying to boot from MMC2
U-Boot 2017.01-00314-gd0cd9cd-dirty (Jan 25 2017 - 13:25:27 +0100)
CPU: Freescale i.MX6UL rev1.1 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 36C Reset cause: POR Model: Engicam Is.IoT MX6UL eMMC Starterkit DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial switch to partitions #0, OK mmc1(part 0) is current device
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - Update board MAINTAINERS file with arch/arm/dts/imx6ul-isiot-emmc.dts
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6ul-isiot-emmc.dts | 77 +++++++++++++++++++++++++++++++++++ board/engicam/isiotmx6ul/MAINTAINERS | 2 + board/engicam/isiotmx6ul/isiotmx6ul.c | 26 +++++++++++- configs/imx6ul_isiot_emmc_defconfig | 39 ++++++++++++++++++ include/configs/imx6ul_isiot.h | 2 +- 6 files changed, 145 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx6ul-isiot-emmc.dts create mode 100644 configs/imx6ul_isiot_emmc_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 09e3bdb..cde7f41 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -314,6 +314,7 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6q-icore.dtb \ imx6q-icore-rqs.dtb \ imx6ul-geam-kit.dtb \ + imx6ul-isiot-emmc.dtb \ imx6ul-isiot-mmc.dtb \ imx6ul-isiot-nand.dtb
diff --git a/arch/arm/dts/imx6ul-isiot-emmc.dts b/arch/arm/dts/imx6ul-isiot-emmc.dts new file mode 100644 index 0000000..677de96 --- /dev/null +++ b/arch/arm/dts/imx6ul-isiot-emmc.dts @@ -0,0 +1,77 @@ +/* + * Copyright (C) 2016 Amarula Solutions B.V. + * Copyright (C) 2016 Engicam S.r.l. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This file is distributed in the hope that it will be useful + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6ul-isiot.dtsi" + +/ { + model = "Engicam Is.IoT MX6UL eMMC Starterkit"; + compatible = "engicam,imx6ul-isiot", "fsl,imx6ul"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + cd-gpios = <&gpio4 5 GPIO_ACTIVE_LOW>; + bus-width = <8>; + no-1-8-v; + status = "okay"; +}; + +&iomuxc { + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x17070 + MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x10070 + MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17070 + MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17070 + MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17070 + MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17070 + MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x17070 + MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x17070 + MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x17070 + MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x17070 + MX6UL_PAD_NAND_ALE__USDHC2_RESET_B 0x17070 + >; + }; +}; diff --git a/board/engicam/isiotmx6ul/MAINTAINERS b/board/engicam/isiotmx6ul/MAINTAINERS index f4dcfbd..c30cfe7 100644 --- a/board/engicam/isiotmx6ul/MAINTAINERS +++ b/board/engicam/isiotmx6ul/MAINTAINERS @@ -4,7 +4,9 @@ S: Maintained F: board/engicam/isiotmx6ul F: include/configs/imx6ul_isiot.h F: configs/imx6ul_isiot_mmc_defconfig +F: configs/imx6ul_isiot_emmc_defconfig F: configs/imx6ul_isiot_nand_defconfig F: arch/arm/dts/imx6ul-isiot.dtsi F: arch/arm/dts/imx6ul-isiot-mmc.dts +F: arch/arm/dts/imx6ul-isiot-emmc.dts F: arch/arm/dts/imx6ul-isiot-nand.dts diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 07dd501..1b5f74e 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -153,10 +153,24 @@ static iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_GPIO1_IO09__GPIO1_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), };
+static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA00__USDHC2_DATA0| MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA04__USDHC2_DATA4| MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + #define USDHC1_CD_GPIO IMX_GPIO_NR(1, 19) +#define USDHC2_CD_GPIO IMX_GPIO_NR(4, 5)
-struct fsl_esdhc_cfg usdhc_cfg[1] = { +struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC1_BASE_ADDR, 0, 4}, + {USDHC2_BASE_ADDR, 0, 8}, };
int board_mmc_getcd(struct mmc *mmc) @@ -168,6 +182,9 @@ int board_mmc_getcd(struct mmc *mmc) case USDHC1_BASE_ADDR: ret = !gpio_get_value(USDHC1_CD_GPIO); break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; }
return ret; @@ -181,6 +198,7 @@ int board_mmc_init(bd_t *bis) * According to the board_mmc_init() the following map is done: * (U-boot device node) (Physical Port) * mmc0 USDHC1 + * mmc1 USDHC2 */ for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { @@ -190,6 +208,12 @@ int board_mmc_init(bd_t *bis) gpio_direction_input(USDHC1_CD_GPIO); usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc2_pads)); + gpio_direction_input(USDHC2_CD_GPIO); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; default: printf("Warning - USDHC%d controller not supporting\n", i + 1); diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig new file mode 100644 index 0000000..94fe808 --- /dev/null +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -0,0 +1,39 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6UL_ISIOT=y +CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_BOOTDELAY=3 +CONFIG_DEFAULT_FDT_FILE="imx6ul-isiot-emmc.dtb" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SYS_PROMPT="isiotmx6ul> " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_BLK is not set +# CONFIG_DM_MMC_OPS is not set +CONFIG_FEC_MXC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index 10311d0..1b0e436 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -145,7 +145,7 @@ /* MMC */ #ifdef CONFIG_FSL_USDHC # define CONFIG_SYS_MMC_ENV_DEV 0 -# define CONFIG_SYS_FSL_USDHC_NUM 1 +# define CONFIG_SYS_FSL_USDHC_NUM 2 # define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
Boot from eMMC:
Changes for v3:
- imx6ul-isiot-emmc.dtb \ imx6ul-isiot-mmc.dtb \ imx6ul-isiot-nand.dtb
- Copyright (C) 2016 Amarula Solutions B.V.
- Copyright (C) 2016 Engicam S.r.l.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively
- b) Permission is hereby granted, free of charge, to any person
conditions:
+/dts-v1/;
- model = "Engicam Is.IoT MX6UL eMMC Starterkit";
- compatible = "engicam,imx6ul-isiot", "fsl,imx6ul";
+&usdhc2 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_usdhc2>;
- cd-gpios = <&gpio4 5 GPIO_ACTIVE_LOW>;
- bus-width = <8>;
- no-1-8-v;
- status = "okay";
+&iomuxc {
- pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
- MX6_PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA00__USDHC2_DATA0| MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA04__USDHC2_DATA4| MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- {USDHC2_BASE_ADDR, 0, 8},
break;
return ret;
- According to the board_mmc_init() the following map is done:
- (U-boot device node) (Physical Port)
- mmc0 USDHC1
- mmc1 USDHC2
case 1:
default: printf("Warning - USDHC%d controller not supporting\n", i + 1);break;
Add runtime, modeboot env which is setting mmcboot, or nandboot based on the bootdevice so-that conditional macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should be avoided in config files.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 21 ++++++++++++++++++++ configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_mmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + include/configs/imx6ul_isiot.h | 36 ++++++++++++++++------------------- 5 files changed, 40 insertions(+), 20 deletions(-)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 1b5f74e..fa91956 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -103,6 +103,27 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
+int board_late_init(void) +{ + switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> + IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + setenv("modeboot", "mmcboot"); + break; + case IMX6_BMODE_NAND: + setenv("modeboot", "nandboot"); + break; + default: + setenv("modeboot", ""); + break; + } + + return 0; +} + int board_init(void) { /* Address of boot parameters */ diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 94fe808..4c3664f 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -37,3 +37,4 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig index 8ecdd8e..ea2d378 100644 --- a/configs/imx6ul_isiot_mmc_defconfig +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -39,3 +39,4 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 6f1a054..f02a2ac 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -40,3 +40,4 @@ CONFIG_PINCTRL_IMX6=y CONFIG_SYS_I2C_MXC=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_BOARD_LATE_INIT=y diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index 1b0e436..7258fed 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -64,8 +64,7 @@ "fitboot=echo Booting FIT image from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ + "_mmcboot=run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ @@ -79,6 +78,20 @@ "else " \ "bootm; " \ "fi\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadfit; then " \ + "run fitboot; " \ + "else " \ + "if run loadimage; then " \ + "run _mmcboot; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi\0" \ "nandboot=echo Booting from nand ...; " \ "if mtdparts; then " \ "echo Starting nand boot ...; " \ @@ -90,24 +103,7 @@ "nand read ${fdt_addr} dtb 0x100000; " \ "bootm ${loadaddr} - ${fdt_addr}\0"
-#ifdef CONFIG_NAND_MXS -# define CONFIG_BOOTCOMMAND "run nandboot" -#else -# define CONFIG_BOOTCOMMAND \ - "if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadfit; then " \ - "run fitboot; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "fi; " \ - "fi; " \ - "fi; " \ - "fi" -#endif +#define CONFIG_BOOTCOMMAND "run $modeboot"
/* Miscellaneous configurable options */ #define CONFIG_SYS_MEMTEST_START 0x80000000
- switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >>
IMX6_BMODE_SHIFT) {
break;
break;
- default:
break;
"run mmcargs; " \
- "_mmcboot=run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \
"else " \
"run fitboot; " \
"else " \
"run _mmcboot; " \
"fi; " \
"fi; " \
"fi; " \
"nandboot=echo Booting from nand ...; " \ "if mtdparts; then " \ "echo Starting nand boot ...; " \"fi\0" \
"else " \
"run fitboot; " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
"fi; " \
- "fi"
Let the runtime code can set the mmcdev and mmcroot based on the devno using mmc_get_env_dev instead of defining separately in build-time configs using mmc_late_init func.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 22 ++++++++++++++++++++++ include/configs/imx6ul_isiot.h | 2 -- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index fa91956..18989d8 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <mmc.h>
#include <asm/io.h> #include <asm/gpio.h> @@ -103,6 +104,24 @@ static void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
+#ifdef CONFIG_ENV_IS_IN_MMC +static void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} +#endif + int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> @@ -111,6 +130,9 @@ int board_late_init(void) case IMX6_BMODE_ESD: case IMX6_BMODE_MMC: case IMX6_BMODE_EMMC: +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif setenv("modeboot", "mmcboot"); break; case IMX6_BMODE_NAND: diff --git a/include/configs/imx6ul_isiot.h b/include/configs/imx6ul_isiot.h index 7258fed..4009648 100644 --- a/include/configs/imx6ul_isiot.h +++ b/include/configs/imx6ul_isiot.h @@ -45,9 +45,7 @@ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x87800000\0" \ "boot_fdt=try\0" \ - "mmcdev=0\0" \ "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ "nandroot=ubi0:rootfs rootfstype=ubifs\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \
- char cmd[32];
- char mmcblk[32];
- u32 dev_no = mmc_get_env_dev();
- setenv_ulong("mmcdev", dev_no);
- /* Set mmcblk env */
- sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no);
- setenv("mmcroot", mmcblk);
- sprintf(cmd, "mmc dev %d", dev_no);
- run_command(cmd, 0);
+} +#endif
mmc_late_init();
Add board_mmc_get_env_dev
Switch the mmc env based on the mmc devno, instead of separately defining a config item in include/configs using board_mmc_get_env_dev - devno 0: sd/esd - devno 1: mmc/emmc
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/isiotmx6ul/isiotmx6ul.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 18989d8..fde122d 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -105,6 +105,12 @@ static void setup_gpmi_nand(void) #endif /* CONFIG_NAND_MXS */
#ifdef CONFIG_ENV_IS_IN_MMC +int board_mmc_get_env_dev(int devno) +{ + /* dev 0 for SD/eSD, dev 1 for MMC/eMMC */ + return (devno == 0) ? 0 : 1; +} + static void mmc_late_init(void) { char cmd[32];
Add usdhc4 node, which is eMMC for Engicam i.CoreM6 RQS modules.
eMMC Log: -------- icorem6qdl-rqs> mmc dev 1 switch to partitions #0, OK mmc1(part 0) is current device icorem6qdl-rqs> mmcinfo Device: FSL_SDHC Manufacturer ID: fe OEM: 14e Name: MMC04 Tran Speed: 52000000 Rd Block Len: 512 MMC version 4.4.1 High Capacity: Yes Capacity: 3.5 GiB Bus Width: 4-bit Erase Group Size: 512 KiB HC WP Group Size: 4 MiB User Capacity: 3.5 GiB Boot Capacity: 16 MiB ENH RPMB Capacity: 128 KiB ENH
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6qdl-icore-rqs.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-icore-rqs.dtsi b/arch/arm/dts/imx6qdl-icore-rqs.dtsi index 750229b..8b9d5b4 100644 --- a/arch/arm/dts/imx6qdl-icore-rqs.dtsi +++ b/arch/arm/dts/imx6qdl-icore-rqs.dtsi @@ -107,6 +107,13 @@ status = "okay"; };
+&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + no-1-8-v; + status = "okay"; +}; + &iomuxc { pinctrl_enet: enetgrp { fsl,pins = < @@ -167,4 +174,19 @@ MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17070 >; }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x17070 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x10070 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x17070 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x17070 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x17070 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x17070 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x17070 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x17070 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x17070 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17070 + >; + }; };
eMMC Log:
+&usdhc4 {
- pinctrl-0 = <&pinctrl_usdhc4>;
- no-1-8-v;
- status = "okay";
- pinctrl_usdhc4: usdhc4grp {
fsl,pins = <
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6_rqs/icorem6_rqs.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 2769177..e3c520f 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -125,6 +125,32 @@ int board_mmc_init(bd_t *bis)
return 0; }
break;
/* MMC/eMMC */
break;
- default:
break;
+} +#endif #endif
Boot from eMMC: -------------- U-Boot SPL 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21) Trying to boot from MMC2
U-Boot 2017.01-00318-g8e243f8 (Jan 26 2017 - 11:53:21 +0100)
CPU: Freescale i.MX6D rev1.2 at 792 MHz Reset cause: POR Model: Engicam i.CoreM6 Quad/Dual RQS Starter Kit DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial switch to partitions #0, OK mmc1(part 0) is current device Net: No ethernet found. Hit any key to stop autoboot: 0 Booting from mmc ... switch to partitions #0, OK mmc1(part 0) is current device
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6_rqs/icorem6_rqs.c | 24 ++++++++++++++++++++++-- include/configs/imx6qdl_icore_rqs.h | 2 +- 2 files changed, 23 insertions(+), 3 deletions(-)
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index e3c520f..66cf487 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -77,8 +77,22 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), };
-struct fsl_esdhc_cfg usdhc_cfg[1] = { +static iomux_v3_cfg_t const usdhc4_pads[] = { + IOMUX_PADS(PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), +}; + +struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR, 1, 4}, + {USDHC4_BASE_ADDR, 1, 8}, };
int board_mmc_getcd(struct mmc *mmc) @@ -88,6 +102,7 @@ int board_mmc_getcd(struct mmc *mmc)
switch (cfg->esdhc_base) { case USDHC3_BASE_ADDR: + case USDHC4_BASE_ADDR: ret = 1; break; } @@ -102,7 +117,8 @@ int board_mmc_init(bd_t *bis) /* * According to the board_mmc_init() the following map is done: * (U-boot device node) (Physical Port) - * mmc0 USDHC3 + * mmc0 USDHC3 + * mmc1 USDHC4 */ for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { @@ -110,6 +126,10 @@ int board_mmc_init(bd_t *bis) SETUP_IOMUX_PADS(usdhc3_pads); usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); break; + case 1: + SETUP_IOMUX_PADS(usdhc4_pads); + usdhc_cfg[i].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + break; default: printf("Warning - USDHC%d controller not supporting\n", i + 1); diff --git a/include/configs/imx6qdl_icore_rqs.h b/include/configs/imx6qdl_icore_rqs.h index 6f7195d..cd94c5f 100644 --- a/include/configs/imx6qdl_icore_rqs.h +++ b/include/configs/imx6qdl_icore_rqs.h @@ -124,7 +124,7 @@ /* MMC */ #ifdef CONFIG_FSL_USDHC # define CONFIG_SYS_MMC_ENV_DEV 0 -# define CONFIG_SYS_FSL_USDHC_NUM 1 +# define CONFIG_SYS_FSL_USDHC_NUM 2 # define CONFIG_SYS_FSL_ESDHC_ADDR 0 #endif
Add runtime, modeboot env which is setting mmcboot based on the bootdevice so-that conditional macros for MMC via CONFIG_BOOTCOMMAND should be avoided in config files.
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6_rqs/icorem6_rqs.c | 18 ++++++++++++++++++ configs/imx6dl_icore_rqs_mmc_defconfig | 1 + configs/imx6q_icore_rqs_mmc_defconfig | 1 + include/configs/imx6qdl_icore_rqs.h | 32 ++++++++++++++++---------------- 4 files changed, 36 insertions(+), 16 deletions(-)
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 66cf487..4bb43d1 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -45,6 +45,24 @@ int board_init(void) return 0; }
+int board_late_init(void) +{ + switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> + IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + setenv("modeboot", "mmcboot"); + break; + default: + setenv("modeboot", ""); + break; + } + + return 0; +} + int dram_init(void) { gd->ram_size = imx_ddr_size(); diff --git a/configs/imx6dl_icore_rqs_mmc_defconfig b/configs/imx6dl_icore_rqs_mmc_defconfig index 3b10e99..b15fcb2 100644 --- a/configs/imx6dl_icore_rqs_mmc_defconfig +++ b/configs/imx6dl_icore_rqs_mmc_defconfig @@ -38,3 +38,4 @@ CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y +CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx6q_icore_rqs_mmc_defconfig b/configs/imx6q_icore_rqs_mmc_defconfig index 8df4ef0..987fdf7 100644 --- a/configs/imx6q_icore_rqs_mmc_defconfig +++ b/configs/imx6q_icore_rqs_mmc_defconfig @@ -38,3 +38,4 @@ CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y +CONFIG_BOARD_LATE_INIT=y diff --git a/include/configs/imx6qdl_icore_rqs.h b/include/configs/imx6qdl_icore_rqs.h index cd94c5f..c62c1d4 100644 --- a/include/configs/imx6qdl_icore_rqs.h +++ b/include/configs/imx6qdl_icore_rqs.h @@ -56,8 +56,7 @@ "fitboot=echo Booting FIT image from mmc ...; " \ "run mmcargs; " \ "bootm ${loadaddr}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ + "_mmcboot=run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ @@ -70,23 +69,24 @@ "fi; " \ "else " \ "bootm; " \ - "fi\0" - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev};" \ - "if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loadfit; then " \ - "run fitboot; " \ + "fi\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "mmc dev ${mmcdev};" \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ + "if run loadfit; then " \ + "run fitboot; " \ + "else " \ + "if run loadimage; then " \ + "run _mmcboot; " \ + "fi; " \ "fi; " \ "fi; " \ - "fi; " \ - "fi" + "fi\0" + +#define CONFIG_BOOTCOMMAND "run $modeboot"
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6_rqs/icorem6_rqs.c | 22 ++++++++++++++++++++++ include/configs/imx6qdl_icore_rqs.h | 2 -- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 4bb43d1..f289e91 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -7,6 +7,7 @@ */
#include <asm/io.h> #include <asm/gpio.h> @@ -45,6 +46,24 @@ int board_init(void) return 0; }
+#ifdef CONFIG_ENV_IS_IN_MMC +static void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} +#endif + int board_late_init(void) { switch ((imx6_src_get_boot_mode() & IMX6_BMODE_MASK) >> @@ -53,6 +72,9 @@ int board_late_init(void) case IMX6_BMODE_ESD: case IMX6_BMODE_MMC: case IMX6_BMODE_EMMC: +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif setenv("modeboot", "mmcboot"); break; default: diff --git a/include/configs/imx6qdl_icore_rqs.h b/include/configs/imx6qdl_icore_rqs.h index c62c1d4..3358320 100644 --- a/include/configs/imx6qdl_icore_rqs.h +++ b/include/configs/imx6qdl_icore_rqs.h @@ -40,9 +40,7 @@ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ - "mmcdev=0\0" \ "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console},${baudrate} " \ "root=${mmcroot}\0" \
Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/icorem6_rqs/icorem6_rqs.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index f289e91..d2f9309 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -47,6 +47,12 @@ int board_init(void) }
#ifdef CONFIG_ENV_IS_IN_MMC +int board_mmc_get_env_dev(int devno) +{ + /* dev 0 for SD/eSD, dev 1 for MMC/eMMC */ + return (devno == 3) ? 1 : 0; +} + static void mmc_late_init(void) { char cmd[32];
- devno 0: sd/esd
- devno 1: mmc/emmc
- /* dev 0 for SD/eSD, dev 1 for MMC/eMMC */
- return (devno == 3) ? 1 : 0;
IMHO just patch 1 has an issue - could you resubmit just that patch ? I will merge then the whole patchset.
Thanks!
Stefano
- devno 0: sd/esd
- devno 1: mmc/emmc
look like there are few other patches have merge issue, will resolve and send the two series again, will it be OK?
thanks!
- devno 0: sd/esd
- devno 1: mmc/emmc
Absolutely, thanks !
Hi Stefano,
On Thu, Feb 2, 2017 at 8:25 PM, Jagan Teki jagan@openedev.com wrote:
Changes for v3:
Changes for v2:
- Rebase on master
Ping
thanks!
Jagan Teki
Stefano Babic
