[U-Boot] [PATCH] Fix bitmap offsets for non 8-bit LCDs
Currently bitmap logos don't interpret the X coordinate correctly if the bpp is anything other than 8.
Signed-off-by: Andre Renaud andre@bluewatersys.com --- common/lcd.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 66d4f94..ee47712 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -589,15 +589,16 @@ void bitmap_plot(int x, int y) immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; cpm8xx_t *cp = &(immr->im_cpm); #endif + unsigned bpix = NBITS(panel_info.vl_bpix);
debug("Logo: width %d height %d colors %d cmap %d\n", BMP_LOGO_WIDTH, BMP_LOGO_HEIGHT, BMP_LOGO_COLORS, ARRAY_SIZE(bmp_logo_palette));
bmap = &bmp_logo_bitmap[0]; - fb = (uchar *)(lcd_base + y * lcd_line_length + x); + fb = (uchar *)(lcd_base + y * lcd_line_length + x * bpix / 8);
- if (NBITS(panel_info.vl_bpix) < 12) { + if (bpix < 12) { /* Leave room for default color map * default case: generic system with no cmap (most likely 16bpp) * cmap was set to the source palette, so no change is done. @@ -648,7 +649,7 @@ void bitmap_plot(int x, int y) } else { /* true color mode */ u16 col16; - fb16 = (ushort *)(lcd_base + y * lcd_line_length + x); + fb16 = (ushort *)fb; for (i = 0; i < BMP_LOGO_HEIGHT; ++i) { for (j = 0; j < BMP_LOGO_WIDTH; j++) { col16 = bmp_logo_palette[(bmap[j]-16)];
Hello,
On Thu, 14 Feb 2013 16:48:00 +1300 Andre Renaud andre@bluewatersys.com wrote:
applied, thanks!
Anatolij
Anatolij Gustschin
Andre Renaud
