Re: [PATCH v3] clk: meson: add Hardware Clock measure driver
Hi Sean,
On 18/12/2023 10:47, Neil Armstrong via groups.io wrote:
Amlogic SoCs embeds an hardware clock measure block, port it from Linux and implement it as a UCLK_CLK with only the dump op and fail-only xlate.
Based on the Linux driver introduced in [1].
[1] commit 2b45ebef39a2 ("soc: amlogic: Add Meson Clock Measure driver").
Reviewed-by: Sean Anderson seanga2@gmail.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org
Should I take this via the amlogic tree ?
Thanks, Neil
<snip>
On 1/10/24 04:23, Neil Armstrong wrote:
Hi Sean,
If you like.
I will be doing a PR sometime before the merge window ends.
--Sean
Hi Sean,
If you like.
If you're making a PR, I won't except for this, so please take it then!
Neil
--Sean
Neil Armstrong
Sean Anderson
