[U-Boot] [PATCH] mtd: nand: zynq: Add support for the NAND lock/unlock operation
Zynq NAND driver is not support for NAND lock or unlock operation. Hence, accidentally write into the critical NAND region might cause data corruption to occur.
This commit is to add NAND lock/unlock command into NAND SMC register set for NAND lock/unlock operaion.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Keng Soon Cheah keng.soon.cheah@ni.com Cc: Chen Yee Chew chen.yee.chew@ni.com Cc: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Cc: Michal Simek michal.simek@xilinx.com Cc: Scott Wood oss@buserror.net Signed-off-by: Wilson Lee wilson.lee@ni.com ---
drivers/mtd/nand/zynq_nand.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/mtd/nand/zynq_nand.c b/drivers/mtd/nand/zynq_nand.c index 948f059..484f1bb 100644 --- a/drivers/mtd/nand/zynq_nand.c +++ b/drivers/mtd/nand/zynq_nand.c @@ -81,6 +81,13 @@ #define ZYNQ_NAND_ECC_BUSY (1 << 6) /* ECC block is busy */ #define ZYNQ_NAND_ECC_MASK 0x00FFFFFF /* ECC value mask */
+#ifndef NAND_CMD_LOCK_TIGHT +#define NAND_CMD_LOCK_TIGHT 0x2c +#endif + +#ifndef NAND_CMD_LOCK_STATUS +#define NAND_CMD_LOCK_STATUS 0x7a +#endif
/* SMC register set */ struct zynq_nand_smc_regs { @@ -141,6 +148,11 @@ static const struct zynq_nand_command_format zynq_nand_commands[] = { {NAND_CMD_PARAM, NAND_CMD_NONE, 1, 0}, {NAND_CMD_GET_FEATURES, NAND_CMD_NONE, 1, 0}, {NAND_CMD_SET_FEATURES, NAND_CMD_NONE, 1, 0}, + {NAND_CMD_LOCK, NAND_CMD_NONE, 0, 0}, + {NAND_CMD_LOCK_TIGHT, NAND_CMD_NONE, 0, 0}, + {NAND_CMD_UNLOCK1, NAND_CMD_NONE, 3, 0}, + {NAND_CMD_UNLOCK2, NAND_CMD_NONE, 3, 0}, + {NAND_CMD_LOCK_STATUS, NAND_CMD_NONE, 3, 0}, {NAND_CMD_NONE, NAND_CMD_NONE, 0, 0}, /* Add all the flash commands supported by the flash device */ };
Wilson Lee
