[U-Boot] Pull request: u-boot-spi/sunxi
Hi Tom,
These are the pending patches, from u-boot-sunxi/next.
Will send sunxi PR on top of u-boot-sunxi repo once I get the access, meanwhile please take this PR.
Hans, Let me know if I miss any patches from next.
thanks! Jagan.
The following changes since commit fc127d184aea293ec415dd66e3282dba0b66c5f3:
colibri_pxa270: drop edit, elf, fpga, hush, regex et al. for space reason (2016-11-23 13:53:20 +0100)
git://git.denx.de/u-boot-spi.git sunxi
for you to fetch changes up to e68a831cacc85ea1da274f3c8d19bb98c1141a97:
nand: sunxi: Add options for the SPL NAND configuration (2016-11-24 19:40:49 +0530)
---------------------------------------------------------------- Boris Brezillon (1): mtd: nand: add support for the TC58NVG2S0H chip
Chen-Yu Tsai (9): ARM: PSCI: Set ARMV7_PSCI_NR_CPUS default to 8 for sun9i/A80 sunxi: Add CCI-400 and CPUCFG registers base address for sun9i/A80 sunxi: Add base address of secure SRAM B for sun9i/A80 sunxi: Use secure SRAM B for secure RAM for sun9i/A80 sunxi: Add PRCM register definition for sun9i/A80 sunxi: Add CPUCFG register definitions for sun9i/A80 sunxi: Add support for TZPC on sun9i/A80 sunxi: Add basic PSCI implementation for A80 sunxi: Enable PSCI on sun9i/A80
Emmanuel Vadot (1): sunxi: mmc: Set CONFIG_SYS_MMC_MAX_DEVICE
Hans de Goede (1): sunxi: Mele_M5_defconfig: Drop non existing STATUSLED setting
Jelle van der Waa (1): sunxi: Use the available Kconfig option for AHCI
Marcel Ziswiler (1): colibri_pxa270: transition to driver model for serial
Maxime Ripard (3): sunxi: Sync GR8 DTS and AXP209 with the kernel tools: sunxi: Add spl image builder nand: sunxi: Add options for the SPL NAND configuration
Yann E. MORIN (1): arm: sunxi: do not force USB for arch-sunxi
arch/arm/Kconfig | 10 +- arch/arm/cpu/armv7/Kconfig | 1 + arch/arm/cpu/armv7/sunxi/Makefile | 5 + arch/arm/cpu/armv7/sunxi/psci-mcpm.c | 234 +++++ arch/arm/cpu/armv7/sunxi/tzpc.c | 6 + arch/arm/dts/Makefile | 1 + arch/arm/dts/axp209.dtsi | 6 + arch/arm/dts/ntc-gr8-chip-pro.dts | 266 ++++++ arch/arm/dts/ntc-gr8.dtsi | 1132 ++++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/cpu_sun9i.h | 5 + arch/arm/include/asm/arch-sunxi/cpucfg_sun9i.h | 51 ++ arch/arm/include/asm/arch-sunxi/prcm_sun9i.h | 55 ++ arch/arm/include/asm/arch-sunxi/tzpc.h | 4 + arch/arm/mach-sunxi/board.c | 3 +- board/sunxi/Kconfig | 4 + board/toradex/colibri_pxa270/colibri_pxa270.c | 18 +- configs/A10-OLinuXino-Lime_defconfig | 3 +- configs/A20-OLinuXino-Lime2_defconfig | 3 +- configs/A20-OLinuXino-Lime_defconfig | 3 +- configs/A20-OLinuXino_MICRO_defconfig | 3 +- configs/A20-Olimex-SOM-EVB_defconfig | 3 +- configs/Bananapi_defconfig | 3 +- configs/Bananapro_defconfig | 3 +- configs/Cubieboard2_defconfig | 3 +- configs/Cubieboard_defconfig | 3 +- configs/Cubietruck_defconfig | 3 +- configs/Itead_Ibox_A20_defconfig | 3 +- configs/Lamobo_R1_defconfig | 3 +- configs/Linksprite_pcDuino3_Nano_defconfig | 3 +- configs/Linksprite_pcDuino3_defconfig | 3 +- configs/Marsboard_A10_defconfig | 3 +- configs/Mele_A1000_defconfig | 3 +- configs/Mele_M5_defconfig | 3 +- configs/Orangepi_defconfig | 3 +- configs/Orangepi_mini_defconfig | 3 +- configs/Wits_Pro_A20_DKT_defconfig | 3 +- configs/colibri_pxa270_defconfig | 2 + drivers/mtd/nand/Kconfig | 16 + drivers/mtd/nand/nand_ids.c | 3 + include/configs/colibri_pxa270.h | 2 - include/configs/sun9i.h | 4 + include/configs/sunxi-common.h | 1 + scripts/config_whitelist.txt | 1 - tools/.gitignore | 1 + tools/Makefile | 1 + tools/sunxi-spl-image-builder.c | 1117 +++++++++++++++++++++++ 46 files changed, 2978 insertions(+), 31 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/psci-mcpm.c create mode 100644 arch/arm/dts/ntc-gr8-chip-pro.dts create mode 100644 arch/arm/dts/ntc-gr8.dtsi create mode 100644 arch/arm/include/asm/arch-sunxi/cpucfg_sun9i.h create mode 100644 arch/arm/include/asm/arch-sunxi/prcm_sun9i.h create mode 100644 tools/sunxi-spl-image-builder.c
On Thu, Nov 24, 2016 at 08:05:55PM +0530, Jagan Teki wrote:
Hi Tom,
thanks! Jagan.
Hmmm, I'm not sure why it's in though.
I sent an update version of those since the first iteration had issues.
Maxime
Hi Tom,
thanks! Jagan.
Probably my bad, I put this in u-boot-sunxi/next before I stepped down as maintainer. Which of these 3 patches need to be dropped exactly?
Otherwise this pull-req looks good. Jagan, thank you for your work on this!
Regards,
Hans
Hi Tom,
thanks! Jagan.
OK, couldn't see Maxime latest series. Will remove these 3 and send the PR.
thanks!
Hans de Goede
Jagan Teki
Maxime Ripard
