[U-Boot] [PATCH 1/2] board/spear/common: move code to arch/arm/cpu/arm926ejs/spear/
The code in board/spear/common/ is not board-specific but SoC-specific. Therefore, boards from other vendors than "spear" may want to re-use this code, which is currently difficult with the code being placed in board/spear/common/.
Since this code really is SoC-specific, this commit moves it to arch/arm/cpu/arm926ejs/spear/, with the rest of the SPEAr related code.
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com --- arch/arm/cpu/arm926ejs/spear/Makefile | 2 ++ .../arm/cpu/arm926ejs/spear}/spr_lowlevel_init.S | 0 .../common => arch/arm/cpu/arm926ejs/spear}/spr_misc.c | 0 board/spear/common/Makefile | 14 -------------- 4 files changed, 2 insertions(+), 14 deletions(-) rename {board/spear/common => arch/arm/cpu/arm926ejs/spear}/spr_lowlevel_init.S (100%) rename {board/spear/common => arch/arm/cpu/arm926ejs/spear}/spr_misc.c (100%) delete mode 100644 board/spear/common/Makefile
diff --git a/arch/arm/cpu/arm926ejs/spear/Makefile b/arch/arm/cpu/arm926ejs/spear/Makefile index 7b15d4e..3992401 100644 --- a/arch/arm/cpu/arm926ejs/spear/Makefile +++ b/arch/arm/cpu/arm926ejs/spear/Makefile @@ -16,6 +16,8 @@ obj-$(CONFIG_DDR_MT47H64M16) += spr600_mt47h64m16_3_333_cl5_psync.o obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_333_cl5_psync.o obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_37e_166_cl4_sync.o obj-$(CONFIG_DDR_MT47H128M8) += spr600_mt47h128m8_3_266_cl5_async.o +else +obj-y += spr_misc.o spr_lowlevel_init.o endif
extra-$(CONFIG_SPL_BUILD) := start.o diff --git a/board/spear/common/spr_lowlevel_init.S b/arch/arm/cpu/arm926ejs/spear/spr_lowlevel_init.S similarity index 100% rename from board/spear/common/spr_lowlevel_init.S rename to arch/arm/cpu/arm926ejs/spear/spr_lowlevel_init.S diff --git a/board/spear/common/spr_misc.c b/arch/arm/cpu/arm926ejs/spear/spr_misc.c similarity index 100% rename from board/spear/common/spr_misc.c rename to arch/arm/cpu/arm926ejs/spear/spr_misc.c diff --git a/board/spear/common/Makefile b/board/spear/common/Makefile deleted file mode 100644 index b0ba320..0000000 --- a/board/spear/common/Makefile +++ /dev/null @@ -1,14 +0,0 @@ -# -# (C) Copyright 2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -ifdef CONFIG_SPL_BUILD -# necessary to create built-in.o -obj- := __dummy__.o -else -obj-y := spr_misc.o -obj-y += spr_lowlevel_init.o -endif
do_switch_ecc() calls fsmc_nand_switch_ecc(), which is a direct function call into drivers/mtd/nand/fsmc_nand.c. However, this function is not guarded by CONFIG_NAND_FSMC, which results to a build failure if CONFIG_NAND_FSMC is disabled.
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com --- arch/arm/cpu/arm926ejs/spear/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/spear/cpu.c b/arch/arm/cpu/arm926ejs/spear/cpu.c index be0d14f..7b9dc65 100644 --- a/arch/arm/cpu/arm926ejs/spear/cpu.c +++ b/arch/arm/cpu/arm926ejs/spear/cpu.c @@ -84,7 +84,7 @@ int print_cpuinfo(void) } #endif
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_NAND_ECC_BCH) +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_NAND_ECC_BCH) && defined(CONFIG_NAND_FSMC) static int do_switch_ecc(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) {
So, I asked Stefan to do some cleanups related to SPEAr a while ago, but he's been unable to find the time I believe. Would you have interest in being perhaps co-maintainer of these platforms? Otherwise I fear they need dropping due to lack of Kconfig migration. Thanks!
Hello,
I'm not sure I'll have a long term interest in SPEAr, so that probably doesn't justify me being a co-maintainer. However, if you can list what needs to be done in terms of cleanup/Kconfig migration, I can try to find some time to look into that.
Thanks!
Thomas
On Sat, Aug 19, 2017 at 12:06:35PM +0200, Thomas Petazzoni wrote:
Hello,
Everything that shows up under 'grep SPEAR scripts/config_whitelist.txt' needs to be migrated (or if it makes sense, moved out of CONFIG namespace instead). Thanks!
Thomas Petazzoni
