[PATCH 0/1] imx8mm-cl-iot-gate: Remove redundant board_fix_fdt()
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Previously there's no implementation of board_fix_fdt(). But recently there's one in arch/arm/mach-imx/imx8m/soc.c. Since the board_fix_fdt() in imx8mm-cl-iot-gate is empty, we should remove it and use the one from soc.c.
Ying-Chun Liu (PaulLiu) (1): imx8mm-cl-iot-gate: Remove redundant board_fix_fdt()
board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 5 ----- 1 file changed, 5 deletions(-)
In arch/arm/mach-imx/imx8m/soc.c there's an implementation of board_fix_fdt(). Remove the redundant one to avoid FTBFS.
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com --- board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c index e6021a4566..3d7fff34d2 100644 --- a/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c +++ b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c @@ -335,11 +335,6 @@ static int iot_gate_imx8_update_ext_ied(void) return 0; }
-int board_fix_fdt(void *rw_fdt_blob) -{ - return 0; -} - int extension_board_scan(struct list_head *extension_list) { struct extension *extension = NULL;
Hi Paul,
Please mention that commit 35bb60787b88 ("imx: imx8mp: disable fused IP for UltraLite") was the one that introduced board_fix_fdt() in arch/arm/mach-imx/imx8m/soc.c.
Sorry, what does FTBFS mean?
Fabio Estevam
Ying-Chun Liu
