[PATCH 1/2] ARM: imx8mm: verdin-imx8mm: Rework board_early_init()
Rename board_early_init_f() to board_early_init(), since this function has nothing to do with actual board_early_init_f() as used throughout U-Boot. The board_early_init() is function local to this board used to configure UART and WDT pinmux. Wrap init_uart_clk() into this function so that early UART init would be all in one place. Turn the function into __weak one, so it could be overridden in case custom carrier board uses different UART or needs custom IOMUX settings.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/toradex/verdin-imx8mm/spl.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/board/toradex/verdin-imx8mm/spl.c b/board/toradex/verdin-imx8mm/spl.c index 97d6a31da15..4e6128c3314 100644 --- a/board/toradex/verdin-imx8mm/spl.c +++ b/board/toradex/verdin-imx8mm/spl.c @@ -88,17 +88,17 @@ static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), };
-int board_early_init_f(void) +__weak void board_early_init(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
+ init_uart_clk(0); + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads));
set_wdog_reset(wdog);
imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - - return 0; }
int power_init_board(void) @@ -140,9 +140,7 @@ void board_init_f(ulong dummy)
arch_cpu_init();
- init_uart_clk(0); - - board_early_init_f(); + board_early_init();
timer_init();
Add new board based on the Toradex Verdin iMX8M Mini SoM, the MX8Menlo. The board is a compatible replacement for i.MX53 M53Menlo and features USB, multiple UARTs, ethernet, LEDs, SD and eMMC.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mm-mx8menlo-u-boot.dtsi | 38 +++ arch/arm/dts/imx8mm-mx8menlo.dts | 325 +++++++++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 8 + board/menlo/mx8menlo/Kconfig | 39 +++ board/menlo/mx8menlo/MAINTAINERS | 7 + board/menlo/mx8menlo/Makefile | 25 ++ board/menlo/mx8menlo/mx8menlo.c | 56 ++++ configs/imx8mm-mx8menlo_defconfig | 120 +++++++++ include/configs/imx8mm-mx8menlo.h | 36 +++ 10 files changed, 655 insertions(+) create mode 100644 arch/arm/dts/imx8mm-mx8menlo-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-mx8menlo.dts create mode 100644 board/menlo/mx8menlo/Kconfig create mode 100644 board/menlo/mx8menlo/MAINTAINERS create mode 100644 board/menlo/mx8menlo/Makefile create mode 100644 board/menlo/mx8menlo/mx8menlo.c create mode 100644 configs/imx8mm-mx8menlo_defconfig create mode 100644 include/configs/imx8mm-mx8menlo.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cd9a820f956..d80ebc4f26c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -905,6 +905,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-kontron-n801x-s.dtb \ imx8mm-kontron-n801x-s-lvds.dtb \ + imx8mm-mx8menlo.dtb \ imx8mm-venice.dtb \ imx8mm-venice-gw71xx-0x.dtb \ imx8mm-venice-gw72xx-0x.dtb \ diff --git a/arch/arm/dts/imx8mm-mx8menlo-u-boot.dtsi b/arch/arm/dts/imx8mm-mx8menlo-u-boot.dtsi new file mode 100644 index 00000000000..b87cef9bf99 --- /dev/null +++ b/arch/arm/dts/imx8mm-mx8menlo-u-boot.dtsi @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright 2021-2022 Marek Vasut marex@denx.de + */ +#include "imx8mm-verdin-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart2; + }; + + aliases { + /delete-property/ eeprom1; + /delete-property/ eeprom2; + usbphy0 = &usbphynop1; + usbphy1 = &usbphynop2; + }; +}; + +&i2c4 { + /delete-node/ codec@1a; +}; + +&pinctrl_uart1 { + /delete-property/ u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&uart1 { + /delete-property/ u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-mx8menlo.dts b/arch/arm/dts/imx8mm-mx8menlo.dts new file mode 100644 index 00000000000..adfd8fd8cb6 --- /dev/null +++ b/arch/arm/dts/imx8mm-mx8menlo.dts @@ -0,0 +1,325 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright 2021-2022 Marek Vasut marex@denx.de + */ + +#include "imx8mm-verdin.dts" + +/ { + model = "MENLO MX8MM EMBEDDED DEVICE"; + compatible = "menlo,mx8menlo", + "toradex,verdin-imx8mm", + "fsl,imx8mm"; + + /delete-node/ gpio-keys; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led>; + + user1 { + label = "TestLed601"; + gpios = <&gpio4 18 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + + user2 { + label = "TestLed602"; + gpios = <&gpio4 10 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + beeper { + compatible = "gpio-beeper"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_beeper>; + gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; + }; +}; + +&ecspi1 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>; + status = "okay"; + + /* CAN controller on the baseboard */ + canfd: can@0 { + compatible = "microchip,mcp2518fd"; + clocks = <&clk20m>; + gpio-controller; + interrupt-parent = <&gpio1>; + interrupts = <8 IRQ_TYPE_EDGE_FALLING>; + reg = <0>; + spi-max-frequency = <2000000>; + status = "okay"; + }; + +}; + +&ecspi2 { + pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_gpio1>; + cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>, <&gpio3 4 GPIO_ACTIVE_LOW>; + status = "disabled"; +}; + +ðphy0 { + max-speed = <100>; +}; + +&fec1 { + status = "okay"; +}; + +&flexspi { + status = "okay"; + + flash@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <66000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + }; +}; + +&gpio1 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpio2 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpio3 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "DISP_reset", "KBD_intI", + "", "", "", "", + "", "", "", ""; +}; + +&gpio4 { + /* + * CPLD_D[n] is ARM_CPLD[n] in schematic + * CPLD_int is SA_INTERRUPT in schematic + * CPLD_reset is RESET_SOFT in schematic + */ + gpio-line-names = + "CPLD_D[1]", "CPLD_int", "CPLD_reset", "", + "", "CPLD_D[0]", "", "", + "", "", "", "CPLD_D[2]", + "CPLD_D[3]", "CPLD_D[4]", "CPLD_D[5]", "CPLD_D[6]", + "CPLD_D[7]", "", "", "", + "", "", "", "", + "", "", "", "KBD_intK", + "", "", "", ""; +}; + +&gpio5 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpio_expander_21 { + status = "okay"; +}; + +&i2c1 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <100000>; +}; + +&i2c2 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <100000>; +}; + +&i2c3 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <100000>; + status = "okay"; +}; + +&i2c4 { + /* IMX8MM ERRATA e7805 -- I2C is limited to 384 kHz due to SoC bug */ + clock-frequency = <100000>; + /delete-node/ bridge@2c; + /delete-node/ hwmon@40; + /delete-node/ hdmi@48; + /delete-node/ touch@4a; + /delete-node/ hwmontemp@4f; + /delete-node/ eeprom@50; + /delete-node/ eeprom@57; +}; + +&iomuxc { + pinctrl-0 = <&pinctrl_gpio7>, <&pinctrl_gpio_hog1>, + <&pinctrl_gpio_hog2>, <&pinctrl_gpio_hog3>; + + pinctrl_beeper: beepergrp { + fsl,pins = < + MX8MM_IOMUXC_SPDIF_TX_GPIO5_IO3 0x1c4 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX8MM_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x4 + MX8MM_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x4 + MX8MM_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x1c4 + MX8MM_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x1c4 + >; + }; + + pinctrl_led: ledgrp { + fsl,pins = < + MX8MM_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x1c4 + MX8MM_IOMUXC_SAI1_TXFS_GPIO4_IO10 0x1c4 + >; + }; + + pinctrl_uart4_rts: uart4rtsgrp { + fsl,pins = < + /* SODIMM 222 */ + MX8MM_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x184 + >; + }; +}; + +&pinctrl_gpio1 { + fsl,pins = < + /* SODIMM 206 */ + MX8MM_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x1c4 + >; +}; + +&pinctrl_gpio_hog1 { + fsl,pins = < + /* SODIMM 88 */ + MX8MM_IOMUXC_SAI1_MCLK_GPIO4_IO20 0x1c4 + /* CPLD_int */ + MX8MM_IOMUXC_SAI1_RXC_GPIO4_IO1 0x1c4 + /* CPLD_reset */ + MX8MM_IOMUXC_SAI1_RXD0_GPIO4_IO2 0x1c4 + /* SODIMM 94 */ + MX8MM_IOMUXC_SAI1_RXD1_GPIO4_IO3 0x1c4 + /* SODIMM 96 */ + MX8MM_IOMUXC_SAI1_RXD2_GPIO4_IO4 0x1c4 + /* CPLD_D[7] */ + MX8MM_IOMUXC_SAI1_RXD3_GPIO4_IO5 0x1c4 + /* CPLD_D[6] */ + MX8MM_IOMUXC_SAI1_RXFS_GPIO4_IO0 0x1c4 + /* CPLD_D[5] */ + MX8MM_IOMUXC_SAI1_TXC_GPIO4_IO11 0x1c4 + /* CPLD_D[4] */ + MX8MM_IOMUXC_SAI1_TXD0_GPIO4_IO12 0x1c4 + /* CPLD_D[3] */ + MX8MM_IOMUXC_SAI1_TXD1_GPIO4_IO13 0x1c4 + /* CPLD_D[2] */ + MX8MM_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x1c4 + /* CPLD_D[1] */ + MX8MM_IOMUXC_SAI1_TXD3_GPIO4_IO15 0x1c4 + /* CPLD_D[0] */ + MX8MM_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x1c4 + /* KBD_intK */ + MX8MM_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x1c4 + /* DISP_reset */ + MX8MM_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x1c4 + /* KBD_intI */ + MX8MM_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x1c4 + /* SODIMM 46 */ + MX8MM_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x1c4 + >; +}; + +&pinctrl_uart1 { + fsl,pins = < + /* SODIMM 149 */ + MX8MM_IOMUXC_SAI2_RXFS_UART1_DCE_TX 0x1c4 + /* SODIMM 147 */ + MX8MM_IOMUXC_SAI2_RXC_UART1_DCE_RX 0x1c4 + /* SODIMM 210 */ + MX8MM_IOMUXC_UART3_RXD_UART1_DTE_RTS_B 0x1c4 + /* SODIMM 212 */ + MX8MM_IOMUXC_UART3_TXD_UART1_DTE_CTS_B 0x1c4 + >; +}; + +®_usb_otg1_vbus { + /delete-property/ enable-active-high; + gpio = <&gpio1 12 GPIO_ACTIVE_LOW>; +}; + +®_usb_otg2_vbus { + /delete-property/ enable-active-high; + gpio = <&gpio1 14 GPIO_ACTIVE_LOW>; +}; + +&sai2 { + status = "disabled"; +}; + +&uart1 { + uart-has-rtscts; + status = "okay"; +}; + +&uart2 { + uart-has-rtscts; + status = "okay"; +}; + +&uart4 { + pinctrl-0 = <&pinctrl_uart4 &pinctrl_uart4_rts>; + linux,rs485-enabled-at-boot-time; + rts-gpios = <&gpio1 9 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "gadget"; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc2 { + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index fae70499953..2b3c7bb9afd 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -71,6 +71,13 @@ config TARGET_IMX8MM_ICORE_MX8MM * i.Core MX8M Mini needs to mount on top of this Carrier board for creating complete i.Core MX8M Mini C.TOUCH 2.0 board.
+config TARGET_IMX8MM_MX8MENLO + bool "Support i.MX8M Mini MX8Menlo board based on Toradex Verdin SoM" + select BINMAN + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_IMX8MM_VENICE bool "Support Gateworks Venice iMX8M Mini module" select BINMAN @@ -218,6 +225,7 @@ source "board/gateworks/venice/Kconfig" source "board/google/imx8mq_phanbell/Kconfig" source "board/kontron/pitx_imx8m/Kconfig" source "board/kontron/sl-mx8mm/Kconfig" +source "board/menlo/mx8menlo/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/ronetix/imx8mq-cm/Kconfig" diff --git a/board/menlo/mx8menlo/Kconfig b/board/menlo/mx8menlo/Kconfig new file mode 100644 index 00000000000..51d0ee355eb --- /dev/null +++ b/board/menlo/mx8menlo/Kconfig @@ -0,0 +1,39 @@ +if TARGET_IMX8MM_MX8MENLO + +config SYS_BOARD + default "mx8menlo" + +config SYS_VENDOR + default "menlo" + +config SYS_CONFIG_NAME + default "imx8mm-mx8menlo" + +config TDX_CFG_BLOCK + default y + +config TDX_CFG_BLOCK_EXTRA + default y + +config TDX_HAVE_MMC + default y + +config TDX_HAVE_EEPROM_EXTRA + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_PART + default "1" + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +config IMX_CONFIG + default "board/toradex/verdin-imx8mm/imximage.cfg" + +source "board/toradex/common/Kconfig" + +endif diff --git a/board/menlo/mx8menlo/MAINTAINERS b/board/menlo/mx8menlo/MAINTAINERS new file mode 100644 index 00000000000..09e6aef6c3e --- /dev/null +++ b/board/menlo/mx8menlo/MAINTAINERS @@ -0,0 +1,7 @@ +MX8MENLO BOARD +M: Marek Vasut marex@denx.de +M: Olaf Mandel o.mandel@menlosystems.com +S: Maintained +F: board/menlo/mx8menlo/ +F: include/configs/imx8mm-mx8menlo.h +F: configs/imx8mm-mx8menlo_defconfig diff --git a/board/menlo/mx8menlo/Makefile b/board/menlo/mx8menlo/Makefile new file mode 100644 index 00000000000..fd5ec826336 --- /dev/null +++ b/board/menlo/mx8menlo/Makefile @@ -0,0 +1,25 @@ +# +# Menlosystems MX8Menlo +# Copyright (C) 2021-2022 Marek Vasut marex@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx8menlo.o + +obj-y += ../../toradex/verdin-imx8mm/verdin-imx8mm.o + +ifdef CONFIG_SPL_BUILD +obj-y += ../../toradex/verdin-imx8mm/spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += ../../toradex/verdin-imx8mm/lpddr4_timing.o +endif + +# Common for all Toradex modules +ifeq ($(CONFIG_SPL_BUILD),y) +# Necessary to create built-in.o +obj- := __dummy__.o +else +obj-$(CONFIG_TDX_CFG_BLOCK) += ../../toradex/common/tdx-cfg-block.o +obj-y += ../../toradex/common/tdx-common.o +obj-y += ../../toradex/common/tdx-eeprom.o +endif diff --git a/board/menlo/mx8menlo/mx8menlo.c b/board/menlo/mx8menlo/mx8menlo.c new file mode 100644 index 00000000000..a4d0becdcc8 --- /dev/null +++ b/board/menlo/mx8menlo/mx8menlo.c @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021-2022 Marek Vasut marex@denx.de + */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <spl.h> + +#define UART_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_PE | PAD_CTL_DSE4) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +/* Verdin UART_3, Console/Debug UART */ +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MM_PAD_SAI3_TXFS_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MM_PAD_SAI3_TXC_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +#define SNVS_BASE_ADDR 0x30370000 +#define SNVS_LPSR 0x4c +#define SNVS_LPLVDR 0x64 +#define SNVS_LPPGDR_INIT 0x41736166 + +static void setup_snvs(void) +{ + /* Enable SNVS clock */ + clock_enable(CCGR_SNVS, 1); + /* Initialize glitch detect */ + writel(SNVS_LPPGDR_INIT, SNVS_BASE_ADDR + SNVS_LPLVDR); + /* Clear interrupt status */ + writel(0xffffffff, SNVS_BASE_ADDR + SNVS_LPSR); +} + +void board_early_init(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + init_uart_clk(1); + + setup_snvs(); +} diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig new file mode 100644 index 00000000000..22ae1b39799 --- /dev/null +++ b/configs/imx8mm-mx8menlo_defconfig @@ -0,0 +1,120 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-mx8menlo" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_MX8MENLO=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_BOOTCOUNT_BOOTLIMIT=3 +CONFIG_SYS_BOOTCOUNT_ADDR=0x30370090 +CONFIG_SPL=y +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_ENV_OFFSET_REDUND=0xFFFFDE00 +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SYS_MEMTEST_START=0x40000000 +CONFIG_SYS_MEMTEST_END=0x80000000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="mmc partconf 0 distro_bootpart && load ${devtype} ${devnum}:${distro_bootpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" +CONFIG_DEFAULT_FDT_FILE="imx8mm-mx8menlo.dtb" +CONFIG_LOG=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="Verdin iMX8MM # " +# CONFIG_BOOTM_NETBSD is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_UUID=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_BTRFS=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="FEC" +CONFIG_VERSION_VARIABLE=y +CONFIG_IP_DEFRAG=y +CONFIG_TFTP_BLOCKSIZE=4096 +CONFIG_SPL_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_SYS_BOOTCOUNT_MAGIC=0xB0C40000 +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_GPIO_HOG=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_IMX_WATCHDOG=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/imx8mm-mx8menlo.h b/include/configs/imx8mm-mx8menlo.h new file mode 100644 index 00000000000..fd1831622f0 --- /dev/null +++ b/include/configs/imx8mm-mx8menlo.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021-2022 Marek Vasut marex@denx.de + */ + +#ifndef __IMX8MM_MX8MENLO_H +#define __IMX8MM_MX8MENLO_H + +#include <configs/verdin-imx8mm.h> + +/* Custom initial environment variables */ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "devtype=mmc\0" \ + "devnum=1\0" \ + "distro_bootpart=1\0" \ + "altbootcmd=" \ + "mmc partconf 0 mmcpart ; " \ + "if test ${mmcpart} -eq 1 ; then " \ + "mmc partconf 0 1 2 0 ; " \ + "else " \ + "mmc partconf 0 1 1 0 ; " \ + "fi ; " \ + "boot\0" \ + "boot_file=fitImage\0" \ + "console=ttymxc1\0" \ + "fdt_addr=0x43000000\0" \ + "initrd_addr=0x43800000\0" \ + "kernel_image=fitImage\0" + +#undef CONFIG_MXC_UART_BASE +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +#endif /* __IMX8MM_MX8MENLO_H */
Add new board based on the Toradex Verdin iMX8M Mini SoM, the MX8Menlo. The board is a compatible replacement for i.MX53 M53Menlo and features USB, multiple UARTs, ethernet, LEDs, SD and eMMC. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Rename board_early_init_f() to board_early_init(), since this function has nothing to do with actual board_early_init_f() as used throughout U-Boot. The board_early_init() is function local to this board used to configure UART and WDT pinmux. Wrap init_uart_clk() into this function so that early UART init would be all in one place. Turn the function into __weak one, so it could be overridden in case custom carrier board uses different UART or needs custom IOMUX settings. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
sbabic@denx.de
