[U-Boot-Users] u-boot 1.1.1 and USB mass storage devices
Hello,
We are using u-boot on a Samsung S3C2410 based board and have USB mostly working using the arm920t USB driver. I say mostly working as some mass storage devices work fine, but most do not.
Typically the behavior we see when they don't work is a "usb reset" reports the correct number of devices, a "usb tree" will return the correct device tree but "usb scan" will typically return a lot of CLI:TIMEOUT errors and seemingly never return. Sometimes it is able to find the storage device, but reading from it (it has a FAT16 filesystem) will return similar errors.
I'm curious if these are known problems or likely to be something in the way we have (or have not) set up usb? Might anyone have some recommendations as to where to start looking?
Thanks for any help!
Shannon
This is normal. Use the working tdevices, and throw away the rest.
There are many, many USB devices out there which are out of spec, or where controller/firmware problems get fixed in the windows drivers provided by the vendor (either directly or through M$). Typically such devices will not work under Linux, or only with special quirks. U-Boot does not implement any such quirks, which makes it a bit picky.
Using USB 2.0 spec'ed devices usually increases the chance that they will work with U-Boot.
Does anyone have recommendations as to devices that are known to work? We've tried four to date, the only one that works is a two year old USB 1.1 drive that I haven't been able to find more of (yet). We've tried another 1.1 device, along with two USB 2.0 devices (one being a Sandisk, the other being a "generic" el-cheapo model) - buying and trying at random is starting to get expensive!
Thanks!
Shannon
Do these devices fail enumeration? If so, you may want to look at the change going into the kernel. I have several devices that failed on linux that now work.
See:
http://marc.theaimsgroup.com/?l=linux-usb-devel&m=109725370016614&w=...
Kyle.
They generally do enumerate, but I will take a look at the change anyway as it might well be useful.
Thanks!
Shannon
See:
This was marked as open issue on my list. I think we can close it now. It should have been fixed with the latest rework of the USB code in U-Boot, see:
commit 9c998aa83148c75cd734a18958218926313bd54c tree c6d523801214c37337d3995dd1c405a7c329b37d parent f530187dbd69b0534e84b553f9a9803b16ed4999 author Wolfgang Denk wd@castor.denx.de Thu, 21 Jul 2005 11:57:57 +0200 committer Wolfgang Denk wd@castor.denx.de Thu, 21 Jul 2005 11:57:57 +0200
Fix low-level OHCI transfers for ARM920t and MPC5xxx
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
Feedback appreciated!
rest.
something in
some
spec, or
windows drivers
Typically
special quirks.
it a bit
picky.
that they
Thanks!
Shannon
I ported the OHCI driver over to our 8245 based board and don't have a problem with any (6) devices we have tried. I did encounter a usb memory stick that worked in u-boot but did not work with the kernel. Maybe your driver is the culprit...
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal Use IT products in your business? Tell us what you think of them. Give us Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
__________________________________ Do you Yahoo!? Yahoo! Mail Address AutoComplete - You start. We finish. http://promotions.yahoo.com/new_mail
Was your port based on the ohci driver in the arm920t cpu port?
All of the devices I've tried so far have worked under 2.6.8/2.6.9 (on our board), so it would certainly seem to point at either a driver problem or some special casing that's been done under the newer versions of linux.
Thanks!
Shannon
Shannon,
We used PNY Attache USB flash drives and they worked fine under u-boot and Linux. Link is the following : http://www.pny.com/products/usbflashdrive/
Hope this helps,
Laurent Mohin ACTERNA
u-boot-users-admin@lists.sourceforge.net wrote on 20/10/2004 00:24:47:
Thanks!
Shannon
us
more
participants (5)
Frank
Kyle Harris
Laurent Mohin
Shannon Holland
