[PATCH v1] rockchip: video: rk_edp: add more rk3288 edp node options
The rk3288 DT synced from Linux contains some different properties in the edp node then origanal used in U-boot. Allow both options to be backwards compatible and to be able to handle recent rk3288.dtsi files.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Fix for rk3288.dtsi sync from Linux. Not tested with hardware. --- drivers/video/rockchip/rk_edp.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/video/rockchip/rk_edp.c b/drivers/video/rockchip/rk_edp.c index 0ddf5e02..3697d582 100644 --- a/drivers/video/rockchip/rk_edp.c +++ b/drivers/video/rockchip/rk_edp.c @@ -1070,8 +1070,11 @@ static int rk_edp_probe(struct udevice *dev)
ret = reset_get_by_name(dev, "dp", &dp_rst); if (ret) { - dev_err(dev, "failed to get dp reset (ret=%d)\n", ret); - return ret; + ret = reset_get_by_name(dev, "edp", &dp_rst); + if (ret) { + dev_err(dev, "failed to get dp reset (ret=%d)\n", ret); + return ret; + } }
ret = reset_assert(&dp_rst); @@ -1156,6 +1159,7 @@ static const struct rockchip_dp_data rk3288_dp = { };
static const struct udevice_id rockchip_dp_ids[] = { + { .compatible = "rockchip,rk3288-dp", .data = (ulong)&rk3288_dp }, { .compatible = "rockchip,rk3288-edp", .data = (ulong)&rk3288_dp }, { .compatible = "rockchip,rk3399-edp", .data = (ulong)&rk3399_edp }, { }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
return ret;
if (ret) {
return ret;
- { .compatible = "rockchip,rk3288-dp", .data = (ulong)&rk3288_dp }, { .compatible = "rockchip,rk3288-edp", .data = (ulong)&rk3288_dp }, { .compatible = "rockchip,rk3399-edp", .data = (ulong)&rk3399_edp }, { }
Johan Jonker
Kever Yang
