[U-Boot] [PATCH u-boot sunxi 0/4] sun4i support on top of Ian's patches
Hi All,
Here is a patch-set adding sun4i support on top of Ian's recent 1st attempt to get sun7i upstream patch-set.
Note I've had to drop the raising of the cpu core clock, without matching axp209 changes this causes issues on sun4i.
I've been thinking about how to best move forward with this patch-set, and I think it would be best to first complete the job of splitting up what we've in u-boot-sunxi now (at least most of it), keeping this based on v2014.01 so that we can easily diff. And then once we've everything split up, use the split-up patch-set as a base and start working on addressing any review comments there, which will break easy diffs against u-boot-sunxi, but at that point we no longer need them.
We can even paralellize things. I can stick with Ian's v1 patchset for now, adding patches on top adding what is missing in piecemeal patches, and Ian can start working on making his initial series ready to go upstream.
Ian, does that sound like a plan ?
Regards,
Hans
We should not be raising the cpu core frequency until we have pmic support in place.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- board/sunxi/board.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 5dbcf2a..cc3083c 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -75,7 +75,6 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_SPL_BUILD void sunxi_board_init(void) { - int power_failed = 0; unsigned long ramsize;
printf("DRAM:"); @@ -91,14 +90,5 @@ void sunxi_board_init(void) printf(" %lu MiB\n", ramsize >> 20); if (!ramsize) hang(); - - /* - * Only clock up the CPU to full speed if we are reasonably - * assured it's being powered with suitable core voltage - */ - if (!power_failed) - clock_set_pll1(912000000); - else - printf("Failed to set core voltage! Can't set CPU frequency\n"); } #endif
mctl_ddr3_reset() should not be called here for sun7i, at least the u-boot-sunxi sources don't do this.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/dram.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/sunxi/dram.c b/arch/arm/cpu/armv7/sunxi/dram.c index 81b1f50..c34322d 100644 --- a/arch/arm/cpu/armv7/sunxi/dram.c +++ b/arch/arm/cpu/armv7/sunxi/dram.c @@ -373,7 +373,6 @@ unsigned long dramc_init(struct dram_para *para) mctl_setup_dram_clock(para->clock);
/* reset external DRAM */ - mctl_ddr3_reset(); mctl_set_drive();
/* dram clock off */
oops, I misread an ifndef. I'll fold in, thanks.
Ian.
There is no way to reset the cpu, so use the watchdog for this.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 7 +++++++ arch/arm/include/asm/arch-sunxi/timer.h | 4 ++++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 98cad43..2668d52 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -70,6 +70,13 @@ int gpio_init(void)
void reset_cpu(ulong addr) { + static const struct sunxi_wdog *wdog = + &((struct sunxi_timer_reg *)SUNXI_TIMER_BASE)->wdog; + + /* Set the watchdog for its shortest interval (.5s) and wait */ + writel(WDT_MODE_RESET_EN | WDT_MODE_EN, &wdog->mode); + writel(WDT_CTRL_RESTART, &wdog->ctl); + while (1); }
/* do some early init */ diff --git a/arch/arm/include/asm/arch-sunxi/timer.h b/arch/arm/include/asm/arch-sunxi/timer.h index f9d4f4f..1489b2e 100644 --- a/arch/arm/include/asm/arch-sunxi/timer.h +++ b/arch/arm/include/asm/arch-sunxi/timer.h @@ -27,6 +27,10 @@ #ifndef _SUNXI_TIMER_H_ #define _SUNXI_TIMER_H_
+#define WDT_CTRL_RESTART (0x1 << 0) +#define WDT_MODE_EN (0x1 << 0) +#define WDT_MODE_RESET_EN (0x1 << 1) + #ifndef __ASSEMBLY__
#include <linux/types.h>
The sunxi.git tree does this by calling watchdog_set(0). I think it would be better to introduce the generic watchdog support and the add this a patch to use it for reset. Unless we don't plan to upstream the watchdog stuff for some reason?
Not sure why cmd_watchdog.c is sunxi, seems like in principal it could be generic.
Ian.
- static const struct sunxi_wdog *wdog =
- /* Set the watchdog for its shortest interval (.5s) and wait */
- writel(WDT_MODE_RESET_EN | WDT_MODE_EN, &wdog->mode);
- writel(WDT_CTRL_RESTART, &wdog->ctl);
- while (1);
sön 2014-03-16 klockan 18:38 +0000 skrev Ian Campbell:
In principal it could, but there is no common API for setting the watchdog timer, and no common API for disabling the watchdog once armed.
Regards Henrik
sön 2014-03-16 klockan 14:53 +0100 skrev Hans de Goede:
- while (1);
This code is incomplete and do not reload the watchdog if already running. wdog->ctl is locked by a magic key. Should use
writel(WDT_CTRL_KEY | WDT_CTRL_RESTART, &wdog->ctl);
where
#define WDT_CTRL_KEY (0x0a57 << 1)
Unfortunatley Allwinner kindly omitted this little detail from the User Manual.
Found out while trying to use the watchdog as a watchdog and not only reset. Asked Tom while he still was at Allwinner and got clarification on how to use the watchdog control register.
Regards Henrik
- while (1);
where
Thanks, I'm currently working on v2 of this series and I've included this fix.
Regards,
Hans
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 2 +- arch/arm/cpu/armv7/sunxi/clock.c | 2 + arch/arm/cpu/armv7/sunxi/cpu_info.c | 7 ++ arch/arm/cpu/armv7/sunxi/dram.c | 129 ++++++++++++++++++++++++++++++++++++ board/sunxi/Makefile | 3 +- board/sunxi/dram_a10_olinuxino_l.c | 31 +++++++++ boards.cfg | 1 + drivers/mmc/sunxi_mmc.c | 10 +++ include/configs/sun4i.h | 40 +++++++++++ 9 files changed, 223 insertions(+), 2 deletions(-) create mode 100644 board/sunxi/dram_a10_olinuxino_l.c create mode 100644 include/configs/sun4i.h
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index 2668d52..2225e31 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -82,7 +82,7 @@ void reset_cpu(ulong addr) /* do some early init */ void s_init(void) { -#if !defined CONFIG_SPL_BUILD +#if !defined CONFIG_SPL_BUILD && defined CONFIG_SUN7I /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ asm volatile( "mrc p15, 0, r0, c1, c0, 1\n" diff --git a/arch/arm/cpu/armv7/sunxi/clock.c b/arch/arm/cpu/armv7/sunxi/clock.c index e3abaf0..f685dda 100644 --- a/arch/arm/cpu/armv7/sunxi/clock.c +++ b/arch/arm/cpu/armv7/sunxi/clock.c @@ -43,8 +43,10 @@ static void clock_init_safe(void) sdelay(200); writel(AXI_DIV_1 << 0 | AHB_DIV_2 << 4 | APB0_DIV_1 << 8 | CPU_CLK_SRC_PLL1 << 16, &ccm->cpu_ahb_apb0_cfg); +#ifdef CONFIG_SUN7I writel(0x1 << 6 | readl(&ccm->ahb_gate0), &ccm->ahb_gate0); writel(0x1 << 31 | readl(&ccm->pll6_cfg), &ccm->pll6_cfg); +#endif } #endif
diff --git a/arch/arm/cpu/armv7/sunxi/cpu_info.c b/arch/arm/cpu/armv7/sunxi/cpu_info.c index 14093dd..31c9f96 100644 --- a/arch/arm/cpu/armv7/sunxi/cpu_info.c +++ b/arch/arm/cpu/armv7/sunxi/cpu_info.c @@ -29,7 +29,14 @@ #ifdef CONFIG_DISPLAY_CPUINFO int print_cpuinfo(void) { +#ifdef CONFIG_SUN4I + puts("CPU: Allwinner A10 (SUN4I)\n"); +#elif defined CONFIG_SUN7I puts("CPU: Allwinner A20 (SUN7I)\n"); +#else +#warning Please update cpu_info.c with correct CPU information + puts("CPU: SUNXI Family\n"); +#endif return 0; } #endif diff --git a/arch/arm/cpu/armv7/sunxi/dram.c b/arch/arm/cpu/armv7/sunxi/dram.c index c34322d..08db987 100644 --- a/arch/arm/cpu/armv7/sunxi/dram.c +++ b/arch/arm/cpu/armv7/sunxi/dram.c @@ -49,6 +49,21 @@ static void mctl_ddr3_reset(void) struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
+#ifdef CONFIG_SUN4I + struct sunxi_timer_reg *timer = + (struct sunxi_timer_reg *)SUNXI_TIMER_BASE; + u32 reg_val; + + writel(0, &timer->cpu_cfg); + reg_val = readl(&timer->cpu_cfg); + + if ((reg_val & CPU_CFG_CHIP_VER_MASK) != + CPU_CFG_CHIP_VER(CPU_CFG_CHIP_REV_A)) { + setbits_le32(&dram->mcr, DRAM_MCR_RESET); + udelay(2); + clrbits_le32(&dram->mcr, DRAM_MCR_RESET); + } else +#endif { clrbits_le32(&dram->mcr, DRAM_MCR_RESET); udelay(2); @@ -60,7 +75,11 @@ static void mctl_set_drive(void) { struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
+#ifdef CONFIG_SUN7I clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3) | (0x3 << 28), +#else + clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3), +#endif DRAM_MCR_MODE_EN(0x3) | 0xffc); } @@ -112,7 +131,11 @@ static void mctl_enable_dllx(u32 phase) n = DRAM_DCR_NR_DLLCR_16BIT;
for (i = 1; i < n; i++) { +#ifdef CONFIG_SUN7I clrsetbits_le32(&dram->dllcr[i], 0xf << 14, +#else + clrsetbits_le32(&dram->dllcr[i], 0x4 << 14, +#endif (phase & 0xf) << 14); clrsetbits_le32(&dram->dllcr[i], DRAM_DLLCR_NRESET, DRAM_DLLCR_DISABLE); @@ -132,6 +155,17 @@ static void mctl_enable_dllx(u32 phase) }
static u32 hpcr_value[32] = { +#ifdef CONFIG_SUN4I + 0x0301, 0x0301, 0x0301, 0x0301, + 0x0301, 0x0301, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0x1031, 0x1031, 0x0735, 0x1035, + 0x1035, 0x0731, 0x1031, 0x0735, + 0x1035, 0x1031, 0x0731, 0x1035, + 0x1031, 0x0301, 0x0301, 0x0731 +#endif +#ifdef CONFIG_SUN7I 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0x0301, 0, 0, 0, 0, @@ -145,6 +179,7 @@ static u32 hpcr_value[32] = { * but boot0 code skips #28 and #30, and sets #29 and #31 to the * value from #28 entry (0x1031) */ +#endif };
static void mctl_configure_hostport(void) @@ -186,20 +221,34 @@ static void mctl_setup_dram_clock(u32 clk)
/* setup MBUS clock */ reg_val = CCM_MBUS_CTRL_GATE | +#if defined(CONFIG_SUN7I) CCM_MBUS_CTRL_CLK_SRC(CCM_MBUS_CTRL_CLK_SRC_PLL6) | CCM_MBUS_CTRL_N(CCM_MBUS_CTRL_N_X(2)) | CCM_MBUS_CTRL_M(CCM_MBUS_CTRL_M_X(2)); +#else /* defined(CONFIG_SUN7I) */ + CCM_MBUS_CTRL_CLK_SRC(CCM_MBUS_CTRL_CLK_SRC_PLL5) | + CCM_MBUS_CTRL_N(CCM_MBUS_CTRL_N_X(1)) | + CCM_MBUS_CTRL_M(CCM_MBUS_CTRL_M_X(2)); +#endif writel(reg_val, &ccm->mbus_clk_cfg);
/* * open DRAMC AHB & DLL register clock * close it first */ +#if defined(CONFIG_SUN7I) clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM | CCM_AHB_GATE_DLL); +#else + clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM); +#endif udelay(22);
/* then open it */ +#if defined(CONFIG_SUN7I) setbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM | CCM_AHB_GATE_DLL); +#else + setbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM); +#endif udelay(22); }
@@ -209,7 +258,9 @@ static int dramc_scan_readpipe(void) u32 reg_val;
/* data training trigger */ +#ifdef CONFIG_SUN7I clrbits_le32(&dram->csr, DRAM_CSR_FAILED); +#endif setbits_le32(&dram->ccr, DRAM_CCR_DATA_TRAINING);
/* check whether data training process has completed */ @@ -336,15 +387,51 @@ fail:
static void dramc_clock_output_en(u32 on) { +#if defined(CONFIG_SUN7I) struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
if (on) setbits_le32(&dram->mcr, DRAM_MCR_DCLK_OUT); else clrbits_le32(&dram->mcr, DRAM_MCR_DCLK_OUT); +#endif +#ifdef CONFIG_SUN4I + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + if (on) + setbits_le32(&ccm->dram_clk_cfg, CCM_DRAM_CTRL_DCLK_OUT); + else + clrbits_le32(&ccm->dram_clk_cfg, CCM_DRAM_CTRL_DCLK_OUT); +#endif }
+#ifdef CONFIG_SUN4I +static void dramc_set_autorefresh_cycle(u32 clk) +{ + struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE; + u32 reg_val; + u32 tmp_val; + u32 reg_dcr; + + if (clk < 600) { + reg_dcr = readl(&dram->dcr); + if ((reg_dcr & DRAM_DCR_CHIP_DENSITY_MASK) <= + DRAM_DCR_CHIP_DENSITY(DRAM_DCR_CHIP_DENSITY_1024M)) + reg_val = (131 * clk) >> 10; + else + reg_val = (336 * clk) >> 10; + + tmp_val = (7987 * clk) >> 10; + tmp_val = tmp_val * 9 - 200; + reg_val |= tmp_val << 8; + reg_val |= 0x8 << 24; + writel(reg_val, &dram->drr); + } else { + writel(0x0, &dram->drr); + } +} +#endif /* SUN4I */
+#if defined(CONFIG_SUN7I) static void dramc_set_autorefresh_cycle(u32 clk) { struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE; @@ -358,6 +445,7 @@ static void dramc_set_autorefresh_cycle(u32 clk) reg_val |= 0x8 << 24; writel(reg_val, &dram->drr); } +#endif /* SUN7I */
unsigned long dramc_init(struct dram_para *para) { @@ -373,11 +461,19 @@ unsigned long dramc_init(struct dram_para *para) mctl_setup_dram_clock(para->clock);
/* reset external DRAM */ +#ifndef CONFIG_SUN7I + mctl_ddr3_reset(); +#endif mctl_set_drive();
/* dram clock off */ dramc_clock_output_en(0);
+#ifdef CONFIG_SUN4I + /* select dram controller 1 */ + writel(DRAM_CSEL_MAGIC, &dram->csel); +#endif + mctl_itm_disable(); mctl_enable_dll0(para->tpr3);
@@ -408,24 +504,35 @@ unsigned long dramc_init(struct dram_para *para) reg_val |= DRAM_DCR_MODE(DRAM_DCR_MODE_INTERLEAVE); writel(reg_val, &dram->dcr);
+#ifdef CONFIG_SUN7I setbits_le32(&dram->zqcr1, (0x1 << 24) | (0x1 << 1)); if (para->tpr4 & 0x2) clrsetbits_le32(&dram->zqcr1, (0x1 << 24), (0x1 << 1)); dramc_clock_output_en(1); +#endif
+#ifdef CONFIG_SUN7I /* set odt impendance divide ratio */ reg_val = ((para->zq) >> 8) & 0xfffff; reg_val |= ((para->zq) & 0xff) << 20; reg_val |= (para->zq) & 0xf0000000; writel(reg_val, &dram->zqcr0); +#endif
+#ifdef CONFIG_SUN7I /* Set CKE Delay to about 1ms */ setbits_le32(&dram->idcr, 0x1ffff); +#endif
+#ifdef CONFIG_SUN7I if ((readl(&dram->ppwrsctl) & 0x1) != 0x1) mctl_ddr3_reset(); else setbits_le32(&dram->mcr, DRAM_MCR_RESET); +#else + /* dram clock on */ + dramc_clock_output_en(1); +#endif
udelay(1);
@@ -433,6 +540,22 @@ unsigned long dramc_init(struct dram_para *para)
mctl_enable_dllx(para->tpr3);
+#ifdef CONFIG_SUN4I + /* set odt impendance divide ratio */ + reg_val = ((para->zq) >> 8) & 0xfffff; + reg_val |= ((para->zq) & 0xff) << 20; + reg_val |= (para->zq) & 0xf0000000; + writel(reg_val, &dram->zqcr0); +#endif + +#ifdef CONFIG_SUN4I + /* set I/O configure register */ + reg_val = 0x00cc0000; + reg_val |= (para->odt_en) & 0x3; + reg_val |= ((para->odt_en) & 0x3) << 30; + writel(reg_val, &dram->iocr); +#endif + /* set refresh period */ dramc_set_autorefresh_cycle(para->clock);
@@ -443,7 +566,9 @@ unsigned long dramc_init(struct dram_para *para)
if (para->type == DRAM_MEMORY_TYPE_DDR3) { reg_val = DRAM_MR_BURST_LENGTH(0x0); +#if defined(CONFIG_SUN7I) reg_val |= DRAM_MR_POWER_DOWN; +#endif reg_val |= DRAM_MR_CAS_LAT(para->cas - 4); reg_val |= DRAM_MR_WRITE_RECOVERY(0x5); } else if (para->type == DRAM_MEMORY_TYPE_DDR2) { @@ -460,13 +585,16 @@ unsigned long dramc_init(struct dram_para *para) /* set DQS window mode */ clrsetbits_le32(&dram->ccr, DRAM_CCR_DQS_DRIFT_COMP, DRAM_CCR_DQS_GATE);
+#ifdef CONFIG_SUN7I /* Command rate timing mode 2T & 1T */ if (para->tpr4 & 0x1) setbits_le32(&dram->ccr, DRAM_CCR_COMMAND_RATE_1T); +#endif /* reset external DRAM */ setbits_le32(&dram->ccr, DRAM_CCR_INIT); while (readl(&dram->ccr) & DRAM_CCR_INIT);
+#ifdef CONFIG_SUN7I /* setup zq calibration manual */ reg_val = readl(&dram->ppwrsctl); if ((reg_val & 0x1) == 1) { @@ -502,6 +630,7 @@ unsigned long dramc_init(struct dram_para *para)
udelay(2); } +#endif
/* scan read pipe value */ mctl_itm_enable(); diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index 180adc9..2ebcd8a 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -26,4 +26,5 @@ #
obj-y += board.o -obj-y += dram_cubietruck.o +obj-$(CONFIG_A10_OLINUXINO_L) += dram_a10_olinuxino_l.o +obj-$(CONFIG_CUBIETRUCK) += dram_cubietruck.o diff --git a/board/sunxi/dram_a10_olinuxino_l.c b/board/sunxi/dram_a10_olinuxino_l.c new file mode 100644 index 0000000..24a1bd9 --- /dev/null +++ b/board/sunxi/dram_a10_olinuxino_l.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 480, + .type = 3, + .rank_num = 1, + .density = 4096, + .io_width = 16, + .bus_width = 16, + .cas = 6, + .zq = 123, + .odt_en = 0, + .size = 512, + .tpr0 = 0x30926692, + .tpr1 = 0x1090, + .tpr2 = 0x1a0c8, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0x4, + .emr2 = 0, + .emr3 = 0, +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/boards.cfg b/boards.cfg index a513376..07dd65a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -353,6 +353,7 @@ Active arm armv7 rmobile renesas koelsch Active arm armv7 s5pc1xx samsung goni s5p_goni - Mateusz Zalega m.zalega@samsung.com Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - +Active arm armv7 sunxi - sunxi A10-OLinuXino-Lime sun4i:A10_OLINUXINO_L,SPL - Active arm armv7 sunxi - sunxi Cubietruck sun7i:CUBIETRUCK,SPL - Active arm armv7 sunxi - sunxi Cubietruck_FEL sun7i:CUBIETRUCK,SPL_FEL - Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 13eba76..be5f301 100755 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -87,10 +87,20 @@ struct sunxi_mmc_des { u32 reserved1_2:24; u32 card_err_sum:1; /* transfer error flag */ u32 own:1; /* des owner:1-idma owns it, 0-host owns it */ +#ifdef CONFIG_SUN4I +#define SDXC_DES_NUM_SHIFT 13 +#define SDXC_DES_BUFFER_MAX_LEN (1 << SDXC_DES_NUM_SHIFT) + u32 data_buf1_sz:13; + u32 data_buf2_sz:13; + u32 reserverd2_1:6; +#elif defined(CONFIG_SUN5I) || defined(CONFIG_SUN7I) #define SDXC_DES_NUM_SHIFT 16 #define SDXC_DES_BUFFER_MAX_LEN (1 << SDXC_DES_NUM_SHIFT) u32 data_buf1_sz:16; u32 data_buf2_sz:16; +#else +#error ">>>> Wrong Platform for MMC <<<<" +#endif u32 buf_addr_ptr1; u32 buf_addr_ptr2; }; diff --git a/include/configs/sun4i.h b/include/configs/sun4i.h new file mode 100644 index 0000000..4f37372 --- /dev/null +++ b/include/configs/sun4i.h @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net + * + * Configuration settings for the Allwinner A10 (sun4i) CPU + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * A10 specific configuration + */ +#define CONFIG_SUN4I /* sun4i SoC generation */ + +#define CONFIG_SYS_PROMPT "sun4i# " + +/* + * Include common sunxi configuration where most the settings are + */ +#include <configs/sunxi-common.h> + +#endif /* __CONFIG_H */
On 03/16/2014 02:53 PM, Hans de Goede wrote:
Woops I forgot to add a commit msg here, I've jut fixed this locally:
Based linux-sunxi#sunxi commit d854c4de2f57 "arm: Handle .gnu.hash section in ldscripts" vs v2014.01.
As well as the following signed-off-by the sunxi branch shows commits to the new sun4i dram bits by:
Berg Xing bergxing@allwinnertech.com Tom Cubie tangliang@allwinnertech.com
Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com
Regards,
Hans
- puts("CPU: Allwinner A10 (SUN4I)\n");
- puts("CPU: SUNXI Family\n");
- struct sunxi_timer_reg *timer =
- u32 reg_val;
- writel(0, &timer->cpu_cfg);
- reg_val = readl(&timer->cpu_cfg);
- if ((reg_val & CPU_CFG_CHIP_VER_MASK) !=
udelay(2);
- } else
- clrsetbits_le32(&dram->mcr, DRAM_MCR_MODE_NORM(0x3),
- 0x0301, 0x0301, 0x0301, 0x0301,
- 0x0301, 0x0301, 0, 0,
- 0, 0, 0, 0,
- 0, 0, 0, 0,
- 0x1031, 0x1031, 0x0735, 0x1035,
- 0x1035, 0x0731, 0x1031, 0x0735,
- 0x1035, 0x1031, 0x0731, 0x1035,
- 0x1031, 0x0301, 0x0301, 0x0731
- clrbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM);
+#endif udelay(22);
- setbits_le32(&ccm->ahb_gate0, CCM_AHB_GATE_SDRAM);
- struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
- if (on)
- else
+#endif }
- struct sunxi_dram_reg *dram = (struct sunxi_dram_reg *)SUNXI_DRAMC_BASE;
- u32 reg_val;
- u32 tmp_val;
- u32 reg_dcr;
- if (clk < 600) {
else
- } else {
- /* select dram controller 1 */
- writel(DRAM_CSEL_MAGIC, &dram->csel);
- mctl_itm_disable(); mctl_enable_dll0(para->tpr3);
- /* dram clock on */
- dramc_clock_output_en(1);
udelay(1);
- /* set odt impendance divide ratio */
- reg_val = ((para->zq) >> 8) & 0xfffff;
- reg_val |= ((para->zq) & 0xff) << 20;
- reg_val |= (para->zq) & 0xf0000000;
- writel(reg_val, &dram->zqcr0);
- /* set I/O configure register */
- reg_val = 0x00cc0000;
- reg_val |= (para->odt_en) & 0x3;
- reg_val |= ((para->odt_en) & 0x3) << 30;
- writel(reg_val, &dram->iocr);
- /* set refresh period */ dramc_set_autorefresh_cycle(para->clock);
udelay(2);
} +#endif
- .clock = 480,
- .type = 3,
- .rank_num = 1,
- .density = 4096,
- .io_width = 16,
- .bus_width = 16,
- .cas = 6,
- .zq = 123,
- .odt_en = 0,
- .size = 512,
- .tpr0 = 0x30926692,
- .tpr1 = 0x1090,
- .tpr2 = 0x1a0c8,
- .tpr3 = 0,
- .tpr4 = 0,
- .tpr5 = 0,
- .emr1 = 0x4,
- .emr2 = 0,
- .emr3 = 0,
- return dramc_init(&dram_para);
- u32 data_buf1_sz:13;
- u32 data_buf2_sz:13;
- u32 reserverd2_1:6;
- (C) Copyright 2012-2013 Henrik Nordstrom henrik@henriknordstrom.net
- Configuration settings for the Allwinner A10 (sun4i) CPU
- project.
- MA 02111-1307 USA
- A10 specific configuration
- Include common sunxi configuration where most the settings are
Wow, nice.
For tracking / merging can you split this part up into 1/2 "add SUN7I test around ..." so that Ian can pick it up into his series in the next go-round? Thanks!
Wow, nice.
Done, see the next patch-set I'm about to send.
Regards,
Hans
Hi All,
Yes, I was going to drop this from the base series based on the feedback so far.
I was actually planning to ask if we could merge up to at least v2014.04-rc2, in general it is easier to upstream the closer we are starting from.
In particular between v2014.01 and v2014.04.rc the following are going to be relevant for upstreaming: * Switch to Kbuild has made the Makefile stuff very different * Based on Wens' feedback it looked like there are changes to the designware stuff upstream which will need integrating * The generic distro stuff which Dennis asked for isn't in v2014.01 AFAIK.
The merge up doesn't seem too bad, I've got it mostly done locally. Not sure what the best way to send it out is -- probably as a git pull request?
I've also got a small series which addresses the initial upstream review feedback in sunxi.git which I hope to send out soon.
I'd prefer this approach to tacking your patches onto the end of my series and managing them myself.
Ian.
Hi All,
Ack, the "FIXUP" marked patched in my series are intented to get squashed into your patches.
You mean merging u-boot-sunxi's sunxi branch to v2014.04-rc2 right? That sounds fine to me. Ultimately its HNO call to make though. HNO if you're ok with this I can test Ian's merge on sun4i and sun5i and then push it to u-boot-sunxi's sunxi branch.
Yes a git pull is probably best. You can use either github's pull-req interface or just send one to the linux-sunxi list.
Sounds good.
Ok, so lets split up our efforts for now then, you work on getting the basic sun7i support upstream and I'll work on adding missing bits, like sun4i, sun5i and axp support.
Regards,
Hans
p.s.
For those reading along, I've just finished adding sun5i support, testing that is next on my todo list, then adding axp support. I'll send a second patch-set with what I've tonight to avoid others doing double work. In general my latest work on this can be found here: https://github.com/jwrdegoede/u-boot-sunxi/tree/v2014.01-sunxi
Hi All,
Thanks, will do.
Correct.
I've been trying to avoid registering with github so I'll send a request to the list.
Sounds good.
Agreed.
Great!
Ian.
Hans de Goede
Henrik Nordström
Ian Campbell
