[U-Boot] [PATCH] powerpc/85xx: Change timebase divisor to be defined per processor
Introduce new CONFIG_SYS_FSL_TBCLK_DIV on 85xx platforms because different SoCs have different divisor amounts. All the PQ3 parts are /8, the P4080/P4080 is /16, and P2040/P3041/P5020 are /32.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cpu.c | 11 ++++++----- arch/powerpc/include/asm/config_mpc85xx.h | 6 ++++++ 2 files changed, 12 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index f5b39c0..f863f4a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -234,13 +234,14 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* * Get timebase clock frequency */ +#ifndef CONFIG_SYS_FSL_TBCLK_DIV +#define CONFIG_SYS_FSL_TBCLK_DIV 8 +#endif unsigned long get_tbclk (void) { -#ifdef CONFIG_FSL_CORENET - return (gd->bus_clk + 8) / 16; -#else - return (gd->bus_clk + 4UL)/8UL; -#endif + unsigned long tbclk_div = CONFIG_SYS_FSL_TBCLK_DIV; + + return (gd->bus_clk + (tbclk_div >> 1)) / tbclk_div; }
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index da2e998..d71c3fc 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -264,6 +264,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 5 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -278,6 +279,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -288,6 +290,7 @@ #define CONFIG_SYS_FSL_NUM_LAWS 32 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 16
#elif defined(CONFIG_PPC_P4080) #define CONFIG_MAX_CPUS 8 @@ -301,6 +304,7 @@ #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 16 #define CONFIG_SYS_FSL_ERRATUM_CPC_A002 #define CONFIG_SYS_FSL_ERRATUM_CPC_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 @@ -323,6 +327,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -337,6 +342,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 +#define CONFIG_SYS_FSL_TBCLK_DIV 32 #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
Shouldn't there also be a README update to document this option?
- unsigned long tbclk_div = CONFIG_SYS_FSL_TBCLK_DIV;
- return (gd->bus_clk + (tbclk_div >> 1)) / tbclk_div;
Why not just:
return (gd->bus_clk + (CONFIG_SYS_FSL_TBCLK_DIV / 2)) / CONFIG_SYS_FSL_TBCLK_DIV;
I think its self evident what it is.
Why not just:
It was done this way to deal w/line wrapping.
- k
On Fri, 22 Apr 2011 08:26:55 -0500 Kumar Gala galak@kernel.crashing.org wrote:
Without commenting on whether this one is or isn't self-explanatory, there are enough CONFIG symbols that are used without documentation that are not self-explanatory (sometimes the purpose is clear, but the exact semantics aren't), that it's better to just document all of them.
-Scott
I have to disagree. Without reading the patch description, it's hard to know what value to choose for this macro. Besides, Wolfgang is already annoyed with the number of CONFIG_ options that are not documented, so I can't imagine he would accept another one.
Dear Kumar Gala,
In message 54CE1181-5449-4FBF-9402-DF5D4E99E4CE@kernel.crashing.org you wrote:
Please fix it.
Why not just:
Now this is really a _very_ strange argument. Please fix as well.
On Apr 23, 2011, at 1:45 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Please fix it.
Why not just:
I consider it more readable as it stands. I'm not changing this.
- k
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Added README update
README | 7 +++++++ arch/powerpc/cpu/mpc85xx/cpu.c | 11 ++++++----- arch/powerpc/include/asm/config_mpc85xx.h | 6 ++++++ 3 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/README b/README index 157cc9e..2754d1e 100644 --- a/README +++ b/README @@ -356,6 +356,13 @@ The following options need to be configured: Define this option if you want to enable the ICache only when Code runs from RAM.
+- 85xx CPU Options: + CONFIG_SYS_FSL_TBCLK_DIV + + Defines the core time base clock divider ratio compared to the + system clock. On most PQ3 devices this is 8, on newer QorIQ + devices it can be 16 or 32. The ratio varies from SoC to Soc. + - Intel Monahans options: CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO
- Added README update
applied to 85xx
- k
Kumar Gala
Scott Wood
Tabi Timur-B04825
