[U-Boot] [PATCH] include/net.h: add max_speed member in struct eth_pdata
This will be used for getting max speed mode of Ethernet interface that a particular MAC supports from Device Tree blob and later being used for phy configuration.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Joe Hershberger joe.hershberger@ni.com --- include/net.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/net.h b/include/net.h index ebed29a..7dbba09 100644 --- a/include/net.h +++ b/include/net.h @@ -86,11 +86,13 @@ enum eth_state_t { * @iobase: The base address of the hardware registers * @enetaddr: The Ethernet MAC address that is loaded from EEPROM or env * @phy_interface: PHY interface to use - see PHY_INTERFACE_MODE_... + * @max_speed: Maximum speed of Ethernet connection supported by MAC */ struct eth_pdata { phys_addr_t iobase; unsigned char enetaddr[6]; int phy_interface; + int max_speed; };
enum eth_recv_flags {
Hi Joe,
- @iobase: The base address of the hardware registers
- @enetaddr: The Ethernet MAC address that is loaded from EEPROM or env
- @phy_interface: PHY interface to use - see PHY_INTERFACE_MODE_...
- @max_speed: Maximum speed of Ethernet connection supported by MAC
- int max_speed;
Any chance for this one to be applied?
-Alexey
Alexey Brodkin
