[U-Boot] [PATCH] board: engicam: Remove bogus check for mmc for imx6ul isiot
imx6ul-isiot-mmc.dts was removed in uboot version v2018.03 and from then onwards IMX6UL isiot uses imx6ul-isiot-emmc.dts for mmc, so remove unnecessary check for mmc.
Signed-off-by: Shyam Saini shyam.saini@amarulasolutions.com --- board/engicam/common/board.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index 7486f0ac2d..567b9f63e5 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -53,8 +53,6 @@ static void setenv_fdt_file(void) env_set("fdt_file", "imx6dl-icore-rqs.dtb"); } else if (!strcmp(cmp_dtb, "imx6ul-geam")) env_set("fdt_file", "imx6ul-geam.dtb"); - else if (!strcmp(cmp_dtb, "imx6ul-isiot-mmc")) - env_set("fdt_file", "imx6ul-isiot-emmc.dtb"); else if (!strcmp(cmp_dtb, "imx6ul-isiot-emmc")) env_set("fdt_file", "imx6ul-isiot-emmc.dtb"); else if (!strcmp(cmp_dtb, "imx6ul-isiot-nand"))
imx6ul-isiot-mmc.dts was removed in uboot version v2018.03 and from then onwards IMX6UL isiot uses imx6ul-isiot-emmc.dts for mmc, so remove unnecessary check for mmc. Signed-off-by: Shyam Saini shyam.saini@amarulasolutions.com
Best regards, Stefano Babic
sbabic@denx.de
Shyam Saini
