[PATCH 0/7] rockchip: Add GMAC support for RK3568 and RK3588
This series adds a glue driver, dwc_eth_qos_rockchip, to support GMAC on RK356x and RK3588.
rk_gmac_ops used in this series has been ported from mainline linux.
Patch 1-3 does some minor cleanup in dwc_eth_qos driver. Patch 4 add glue driver with RK3568 support. Patch 5 add support for RK3588 to glue driver. Patch 6-7 update defconfigs to enable use of the new driver.
Dependencies: - "pinctrl: rockchip: Fix drive and input schmitt on RK3568" [1] - "clk: rockchip: rk3568: Add dummy support for GMAC speed clocks" [2] - "net: phy: motorcomm: Add support for YT8511 PHY" [3] - "rockchip: Port IO-domain driver for RK3568 from linux" [4]
dhcp and ping commands has been tested on the followin devices: - RK3566: Quartz64 Model A and SOQuartz on Blade - RK3568: ROCK 3 Model A - RK3588: ROCK 5 Model A
This series can also be found at [5].
[1] https://patchwork.ozlabs.org/patch/1816600/ [2] https://patchwork.ozlabs.org/patch/1816856/ [3] https://patchwork.ozlabs.org/patch/1817295/ [4] https://patchwork.ozlabs.org/cover/1817469/ [5] https://github.com/Kwiboo/u-boot-rockchip/commits/rk35xx-gmac-v1
Jonas Karlman (7): net: dwc_eth_qos: Drop unused rx_pkt from eqos_priv net: dwc_eth_qos: Return error code when start fails net: dwc_eth_qos: Stop spam of RX packet not available message net: dwc_eth_qos: Add glue driver for GMAC on Rockchip RK3568 net: dwc_eth_qos_rockchip: Add support for RK3588 configs: rockchip: Enable ethernet driver on RK356x boards configs: rockchip: Enable ethernet driver on RK3588 boards
configs/evb-rk3568_defconfig | 5 +- configs/evb-rk3588_defconfig | 5 +- configs/nanopi-r5s-rk3568_defconfig | 3 + configs/neu6a-io-rk3588_defconfig | 2 - configs/neu6b-io-rk3588_defconfig | 2 - configs/odroid-m1-rk3568_defconfig | 3 + configs/quartz64-a-rk3566_defconfig | 3 + configs/quartz64-b-rk3566_defconfig | 3 + configs/radxa-cm3-io-rk3566_defconfig | 6 +- configs/rock-3a-rk3568_defconfig | 5 +- configs/rock5a-rk3588s_defconfig | 6 +- configs/soquartz-blade-rk3566_defconfig | 3 + configs/soquartz-cm4-rk3566_defconfig | 3 + configs/soquartz-model-a-rk3566_defconfig | 3 + drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/dwc_eth_qos.c | 33 +- drivers/net/dwc_eth_qos.h | 3 +- drivers/net/dwc_eth_qos_rockchip.c | 522 ++++++++++++++++++++++ 19 files changed, 585 insertions(+), 34 deletions(-) create mode 100644 drivers/net/dwc_eth_qos_rockchip.c
rx_pkt is allocated and not used for anything, remove it.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/net/dwc_eth_qos.c | 11 ----------- drivers/net/dwc_eth_qos.h | 1 - 2 files changed, 12 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 1e92bd9ca9c0..555eaee3bbc3 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1314,22 +1314,12 @@ static int eqos_probe_resources_core(struct udevice *dev) } debug("%s: rx_dma_buf=%p\n", __func__, eqos->rx_dma_buf);
- eqos->rx_pkt = malloc(EQOS_MAX_PACKET_SIZE); - if (!eqos->rx_pkt) { - debug("%s: malloc(rx_pkt) failed\n", __func__); - ret = -ENOMEM; - goto err_free_rx_dma_buf; - } - debug("%s: rx_pkt=%p\n", __func__, eqos->rx_pkt); - eqos->config->ops->eqos_inval_buffer(eqos->rx_dma_buf, EQOS_MAX_PACKET_SIZE * EQOS_DESCRIPTORS_RX);
debug("%s: OK\n", __func__); return 0;
-err_free_rx_dma_buf: - free(eqos->rx_dma_buf); err_free_tx_dma_buf: free(eqos->tx_dma_buf); err_free_descs: @@ -1348,7 +1338,6 @@ static int eqos_remove_resources_core(struct udevice *dev)
debug("%s(dev=%p):\n", __func__, dev);
- free(eqos->rx_pkt); free(eqos->rx_dma_buf); free(eqos->tx_dma_buf); eqos_free_descs(eqos->rx_descs); diff --git a/drivers/net/dwc_eth_qos.h b/drivers/net/dwc_eth_qos.h index a6b719af809f..06a082da72ef 100644 --- a/drivers/net/dwc_eth_qos.h +++ b/drivers/net/dwc_eth_qos.h @@ -273,7 +273,6 @@ struct eqos_priv { unsigned int desc_per_cacheline; void *tx_dma_buf; void *rx_dma_buf; - void *rx_pkt; bool started; bool reg_access_ok; bool clk_ck_enabled;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
ret = -ENOMEM;
Return error code when phy_connect fails or no link can be established.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/net/dwc_eth_qos.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 555eaee3bbc3..7565e716823a 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -811,6 +811,7 @@ static int eqos_start(struct udevice *dev)
if (!eqos->phy) { pr_err("phy_connect() failed"); + ret = -ENODEV; goto err_stop_resets; }
@@ -838,6 +839,7 @@ static int eqos_start(struct udevice *dev)
if (!eqos->phy->link) { pr_err("No link"); + ret = -EAGAIN; goto err_shutdown_phy; }
Thanks, - Kever
}ret = -ENODEV; goto err_stop_resets;
goto err_shutdown_phy; }ret = -EAGAIN;
Remove spam of RX packet not available debug messages when waiting to receive a packet.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/net/dwc_eth_qos.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 7565e716823a..24fb3fac1f12 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1193,14 +1193,12 @@ static int eqos_recv(struct udevice *dev, int flags, uchar **packetp) struct eqos_desc *rx_desc; int length;
- debug("%s(dev=%p, flags=%x):\n", __func__, dev, flags); - rx_desc = eqos_get_desc(eqos, eqos->rx_desc_idx, true); eqos->config->ops->eqos_inval_desc(rx_desc); - if (rx_desc->des3 & EQOS_DESC3_OWN) { - debug("%s: RX packet not available\n", __func__); + if (rx_desc->des3 & EQOS_DESC3_OWN) return -EAGAIN; - } + + debug("%s(dev=%p, flags=%x):\n", __func__, dev, flags);
*packetp = eqos->rx_dma_buf + (eqos->rx_desc_idx * EQOS_MAX_PACKET_SIZE);
Thanks, - Kever
- if (rx_desc->des3 & EQOS_DESC3_OWN) return -EAGAIN;
Add a new glue driver for Rockchip SoCs, i.e RK3568, with a GMAC based on Synopsys DWC Ethernet QoS IP.
rk_gmac_ops was ported from linux commit: 3bb3d6b1c195 ("net: stmmac: Add RK3566/RK3568 SoC support")
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Cc: David Wu david.wu@rock-chips.com Cc: Ezequiel Garcia ezequiel@collabora.com --- drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/dwc_eth_qos.c | 8 +- drivers/net/dwc_eth_qos.h | 2 + drivers/net/dwc_eth_qos_rockchip.c | 348 +++++++++++++++++++++++++++++ 5 files changed, 365 insertions(+), 2 deletions(-) create mode 100644 drivers/net/dwc_eth_qos_rockchip.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 0ed39a61e4de..29304fd77759 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -225,6 +225,14 @@ config DWC_ETH_QOS_IMX The Synopsys Designware Ethernet QOS IP block with the specific configuration used in IMX soc.
+config DWC_ETH_QOS_ROCKCHIP + bool "Synopsys DWC Ethernet QOS device support for Rockchip SoCs" + depends on DWC_ETH_QOS + select DM_ETH_PHY + help + The Synopsys Designware Ethernet QOS IP block with specific + configuration used in Rockchip SoCs. + config DWC_ETH_QOS_STM32 bool "Synopsys DWC Ethernet QOS device support for STM32" depends on DWC_ETH_QOS diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d4af253b6f28..1d444f5b4a69 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o obj-$(CONFIG_DSA_SANDBOX) += dsa_sandbox.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_DWC_ETH_QOS_IMX) += dwc_eth_qos_imx.o +obj-$(CONFIG_DWC_ETH_QOS_ROCKCHIP) += dwc_eth_qos_rockchip.o obj-$(CONFIG_DWC_ETH_QOS_QCOM) += dwc_eth_qos_qcom.o obj-$(CONFIG_DWC_ETH_QOS_STARFIVE) += dwc_eth_qos_starfive.o obj-$(CONFIG_E1000) += e1000.o diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 24fb3fac1f12..9fb98a2c3c74 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1707,7 +1707,12 @@ static const struct udevice_id eqos_ids[] = { .data = (ulong)&eqos_imx_config }, #endif - +#if IS_ENABLED(CONFIG_DWC_ETH_QOS_ROCKCHIP) + { + .compatible = "rockchip,rk3568-gmac", + .data = (ulong)&eqos_rockchip_config + }, +#endif #if IS_ENABLED(CONFIG_DWC_ETH_QOS_QCOM) { .compatible = "qcom,qcs404-ethqos", @@ -1720,7 +1725,6 @@ static const struct udevice_id eqos_ids[] = { .data = (ulong)&eqos_jh7110_config }, #endif - { } };
diff --git a/drivers/net/dwc_eth_qos.h b/drivers/net/dwc_eth_qos.h index 06a082da72ef..e3222e1e17e5 100644 --- a/drivers/net/dwc_eth_qos.h +++ b/drivers/net/dwc_eth_qos.h @@ -82,6 +82,7 @@ struct eqos_mac_regs { #define EQOS_MAC_MDIO_ADDRESS_PA_SHIFT 21 #define EQOS_MAC_MDIO_ADDRESS_RDA_SHIFT 16 #define EQOS_MAC_MDIO_ADDRESS_CR_SHIFT 8 +#define EQOS_MAC_MDIO_ADDRESS_CR_100_150 1 #define EQOS_MAC_MDIO_ADDRESS_CR_20_35 2 #define EQOS_MAC_MDIO_ADDRESS_CR_250_300 5 #define EQOS_MAC_MDIO_ADDRESS_SKAP BIT(4) @@ -287,5 +288,6 @@ void eqos_flush_buffer_generic(void *buf, size_t size); int eqos_null_ops(struct udevice *dev);
extern struct eqos_config eqos_imx_config; +extern struct eqos_config eqos_rockchip_config; extern struct eqos_config eqos_qcom_config; extern struct eqos_config eqos_jh7110_config; diff --git a/drivers/net/dwc_eth_qos_rockchip.c b/drivers/net/dwc_eth_qos_rockchip.c new file mode 100644 index 000000000000..c8abe351fc3e --- /dev/null +++ b/drivers/net/dwc_eth_qos_rockchip.c @@ -0,0 +1,348 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <net.h> +#include <phy.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <asm/gpio.h> +#include <linux/delay.h> + +#include "dwc_eth_qos.h" + +struct rk_gmac_ops { + const char *compatible; + int (*set_to_rgmii)(struct udevice *dev, + int tx_delay, int rx_delay); + int (*set_to_rmii)(struct udevice *dev); + int (*set_gmac_speed)(struct udevice *dev); + u32 regs[3]; +}; + +struct rockchip_platform_data { + struct reset_ctl_bulk resets; + const struct rk_gmac_ops *ops; + int id; + struct regmap *grf; +}; + +#define HIWORD_UPDATE(val, mask, shift) \ + ((val) << (shift) | (mask) << ((shift) + 16)) + +#define GRF_BIT(nr) (BIT(nr) | BIT((nr) + 16)) +#define GRF_CLR_BIT(nr) (BIT((nr) + 16)) + +#define RK3568_GRF_GMAC0_CON0 0x0380 +#define RK3568_GRF_GMAC0_CON1 0x0384 +#define RK3568_GRF_GMAC1_CON0 0x0388 +#define RK3568_GRF_GMAC1_CON1 0x038c + +/* RK3568_GRF_GMAC0_CON1 && RK3568_GRF_GMAC1_CON1 */ +#define RK3568_GMAC_PHY_INTF_SEL_RGMII \ + (GRF_BIT(4) | GRF_CLR_BIT(5) | GRF_CLR_BIT(6)) +#define RK3568_GMAC_PHY_INTF_SEL_RMII \ + (GRF_CLR_BIT(4) | GRF_CLR_BIT(5) | GRF_BIT(6)) +#define RK3568_GMAC_FLOW_CTRL GRF_BIT(3) +#define RK3568_GMAC_FLOW_CTRL_CLR GRF_CLR_BIT(3) +#define RK3568_GMAC_RXCLK_DLY_ENABLE GRF_BIT(1) +#define RK3568_GMAC_RXCLK_DLY_DISABLE GRF_CLR_BIT(1) +#define RK3568_GMAC_TXCLK_DLY_ENABLE GRF_BIT(0) +#define RK3568_GMAC_TXCLK_DLY_DISABLE GRF_CLR_BIT(0) + +/* RK3568_GRF_GMAC0_CON0 && RK3568_GRF_GMAC1_CON0 */ +#define RK3568_GMAC_CLK_RX_DL_CFG(val) HIWORD_UPDATE(val, 0x7F, 8) +#define RK3568_GMAC_CLK_TX_DL_CFG(val) HIWORD_UPDATE(val, 0x7F, 0) + +static int rk3568_set_to_rgmii(struct udevice *dev, + int tx_delay, int rx_delay) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + u32 con0, con1; + + con0 = (data->id == 1) ? RK3568_GRF_GMAC1_CON0 : + RK3568_GRF_GMAC0_CON0; + con1 = (data->id == 1) ? RK3568_GRF_GMAC1_CON1 : + RK3568_GRF_GMAC0_CON1; + + regmap_write(data->grf, con0, + RK3568_GMAC_CLK_RX_DL_CFG(rx_delay) | + RK3568_GMAC_CLK_TX_DL_CFG(tx_delay)); + + regmap_write(data->grf, con1, + RK3568_GMAC_PHY_INTF_SEL_RGMII | + RK3568_GMAC_RXCLK_DLY_ENABLE | + RK3568_GMAC_TXCLK_DLY_ENABLE); + + return 0; +} + +static int rk3568_set_to_rmii(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + u32 con1; + + con1 = (data->id == 1) ? RK3568_GRF_GMAC1_CON1 : + RK3568_GRF_GMAC0_CON1; + regmap_write(data->grf, con1, RK3568_GMAC_PHY_INTF_SEL_RMII); + + return 0; +} + +static int rk3568_set_gmac_speed(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + ulong rate; + int ret; + + switch (eqos->phy->speed) { + case SPEED_10: + rate = 2500000; + break; + case SPEED_100: + rate = 25000000; + break; + case SPEED_1000: + rate = 125000000; + break; + default: + return -EINVAL; + } + + ret = clk_set_rate(&eqos->clk_tx, rate); + if (ret < 0) + return ret; + + return 0; +} + +static const struct rk_gmac_ops rk_gmac_ops[] = { + { + .compatible = "rockchip,rk3568-gmac", + .set_to_rgmii = rk3568_set_to_rgmii, + .set_to_rmii = rk3568_set_to_rmii, + .set_gmac_speed = rk3568_set_gmac_speed, + .regs = { + 0xfe2a0000, /* gmac0 */ + 0xfe010000, /* gmac1 */ + 0x0, /* sentinel */ + }, + }, + { } +}; + +static const struct rk_gmac_ops *get_rk_gmac_ops(struct udevice *dev) +{ + const struct rk_gmac_ops *ops = rk_gmac_ops; + + while (ops->compatible) { + if (device_is_compatible(dev, ops->compatible)) + return ops; + ops++; + } + + return NULL; +} + +static int eqos_probe_resources_rk(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data; + int reset_flags = GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE; + int ret; + + data = calloc(1, sizeof(struct rockchip_platform_data)); + if (!data) + return -ENOMEM; + + data->ops = get_rk_gmac_ops(dev); + if (!data->ops) { + ret = -EINVAL; + goto err_free; + } + + for (int i = 0; data->ops->regs[i]; i++) { + if (data->ops->regs[i] == (u32)eqos->regs) { + data->id = i; + break; + } + } + + pdata->priv_pdata = data; + pdata->phy_interface = eqos->config->interface(dev); + pdata->max_speed = eqos->max_speed; + + if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) { + pr_err("Invalid PHY interface\n"); + ret = -EINVAL; + goto err_free; + } + + data->grf = syscon_regmap_lookup_by_phandle(dev, "rockchip,grf"); + if (IS_ERR(data->grf)) { + dev_err(dev, "Missing rockchip,grf property\n"); + ret = -EINVAL; + goto err_free; + } + + ret = reset_get_bulk(dev, &data->resets); + if (ret < 0) + goto err_free; + + reset_assert_bulk(&data->resets); + + ret = clk_get_by_name(dev, "stmmaceth", &eqos->clk_master_bus); + if (ret) { + dev_dbg(dev, "clk_get_by_name(stmmaceth) failed: %d", ret); + goto err_release_resets; + } + + ret = clk_get_by_name(dev, "clk_mac_speed", &eqos->clk_tx); + if (ret) { + dev_dbg(dev, "clk_get_by_name(clk_mac_speed) failed: %d", ret); + goto err_free_clk_master_bus; + } + + if (dev_read_bool(dev, "snps,reset-active-low")) + reset_flags |= GPIOD_ACTIVE_LOW; + + dev_read_u32_array(dev, "snps,reset-delays-us", eqos->reset_delays, 3); + + gpio_request_by_name(dev, "snps,reset-gpio", 0, + &eqos->phy_reset_gpio, reset_flags); + + return 0; + +err_free_clk_master_bus: + clk_free(&eqos->clk_master_bus); +err_release_resets: + reset_release_bulk(&data->resets); +err_free: + free(data); + + return ret; +} + +static int eqos_remove_resources_rk(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + if (dm_gpio_is_valid(&eqos->phy_reset_gpio)) + dm_gpio_free(dev, &eqos->phy_reset_gpio); + + clk_free(&eqos->clk_tx); + clk_free(&eqos->clk_master_bus); + reset_release_bulk(&data->resets); + free(data); + + return 0; +} + +static int eqos_stop_resets_rk(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + return reset_assert_bulk(&data->resets); +} + +static int eqos_start_resets_rk(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + return reset_deassert_bulk(&data->resets); +} + +static int eqos_stop_clks_rk(struct udevice *dev) +{ + return 0; +} + +static int eqos_start_clks_rk(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + int tx_delay, rx_delay, ret; + + if (dm_gpio_is_valid(&eqos->phy_reset_gpio)) { + udelay(eqos->reset_delays[1]); + + ret = dm_gpio_set_value(&eqos->phy_reset_gpio, 0); + if (ret < 0) + return ret; + + udelay(eqos->reset_delays[2]); + } + + tx_delay = dev_read_u32_default(dev, "tx_delay", 0x30); + rx_delay = dev_read_u32_default(dev, "rx_delay", 0x10); + + switch (pdata->phy_interface) { + case PHY_INTERFACE_MODE_RGMII: + return data->ops->set_to_rgmii(dev, tx_delay, rx_delay); + case PHY_INTERFACE_MODE_RGMII_ID: + return data->ops->set_to_rgmii(dev, 0, 0); + case PHY_INTERFACE_MODE_RGMII_RXID: + return data->ops->set_to_rgmii(dev, tx_delay, 0); + case PHY_INTERFACE_MODE_RGMII_TXID: + return data->ops->set_to_rgmii(dev, 0, rx_delay); + case PHY_INTERFACE_MODE_RMII: + return data->ops->set_to_rmii(dev); + } + + return -EINVAL; +} + +static int eqos_set_tx_clk_speed_rk(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + return data->ops->set_gmac_speed(dev); +} + +static ulong eqos_get_tick_clk_rate_rk(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + + return clk_get_rate(&eqos->clk_master_bus); +} + +static struct eqos_ops eqos_rockchip_ops = { + .eqos_inval_desc = eqos_inval_desc_generic, + .eqos_flush_desc = eqos_flush_desc_generic, + .eqos_inval_buffer = eqos_inval_buffer_generic, + .eqos_flush_buffer = eqos_flush_buffer_generic, + .eqos_probe_resources = eqos_probe_resources_rk, + .eqos_remove_resources = eqos_remove_resources_rk, + .eqos_stop_resets = eqos_stop_resets_rk, + .eqos_start_resets = eqos_start_resets_rk, + .eqos_stop_clks = eqos_stop_clks_rk, + .eqos_start_clks = eqos_start_clks_rk, + .eqos_calibrate_pads = eqos_null_ops, + .eqos_disable_calibration = eqos_null_ops, + .eqos_set_tx_clk_speed = eqos_set_tx_clk_speed_rk, + .eqos_get_enetaddr = eqos_null_ops, + .eqos_get_tick_clk_rate = eqos_get_tick_clk_rate_rk, +}; + +struct eqos_config eqos_rockchip_config = { + .reg_access_always_ok = false, + .mdio_wait = 10, + .swr_wait = 50, + .config_mac = EQOS_MAC_RXQ_CTRL0_RXQ0EN_ENABLED_DCB, + .config_mac_mdio = EQOS_MAC_MDIO_ADDRESS_CR_100_150, + .axi_bus_width = EQOS_AXI_WIDTH_64, + .interface = dev_read_phy_mode, + .ops = &eqos_rockchip_ops, +};
Hi Jonas,
Thank you for your work,
- bool "Synopsys DWC Ethernet QOS device support for Rockchip SoCs"
- depends on DWC_ETH_QOS
- select DM_ETH_PHY
- help
- config DWC_ETH_QOS_STM32 bool "Synopsys DWC Ethernet QOS device support for STM32" depends on DWC_ETH_QOS
Unintended change ?
- const char *compatible;
- int (*set_to_rgmii)(struct udevice *dev,
- int (*set_to_rmii)(struct udevice *dev);
- int (*set_gmac_speed)(struct udevice *dev);
- u32 regs[3];
Can't these be somehow const and point to a dedicated array for a specific SoC ?
Also I believe the naming 'regs' is a bit unfortunate, as it does not hold the usual regmap, rather an array of addresses hardcoded used to figure out which of the GMAC instances we are referring to.
- struct reset_ctl_bulk resets;
- const struct rk_gmac_ops *ops;
- int id;
- struct regmap *grf;
can't you use rk_clrsetreg and friends? it should already do this
Can you add these as a struct in
arch/arm/include/asm/arch-rockchip/grf_rk3568.h
(e.g. I got this from downstream Uboot for 3588 : https://gitlab.collabora.com/hardware-enablement/rockchip-3588/u-boot/-/blob... )
- struct eth_pdata *pdata = dev_get_plat(dev);
- struct rockchip_platform_data *data = pdata->priv_pdata;
- u32 con0, con1;
- con0 = (data->id == 1) ? RK3568_GRF_GMAC1_CON0 :
- con1 = (data->id == 1) ? RK3568_GRF_GMAC1_CON1 :
- regmap_write(data->grf, con0,
- regmap_write(data->grf, con1,
Shouldn't you set RK3568_GMAC_TXCLK_DLY_DISABLE here in case the delays are 0 ?
- u32 con1;
- regmap_write(data->grf, con1, RK3568_GMAC_PHY_INTF_SEL_RMII);
- struct eqos_priv *eqos = dev_get_priv(dev);
- ulong rate;
- int ret;
- switch (eqos->phy->speed) {
- case SPEED_10:
rate = 2500000;
break;
- case SPEED_100:
rate = 25000000;
break;
- case SPEED_1000:
rate = 125000000;
break;
- default:
return -EINVAL;
- ret = clk_set_rate(&eqos->clk_tx, rate);
- if (ret < 0)
return ret;
.regs = {
0x0, /* sentinel */
Can these be referenced to a const struct ?
- const struct rk_gmac_ops *ops = rk_gmac_ops;
- while (ops->compatible) {
return ops;
ops++;
- return NULL;
- struct rockchip_platform_data *data;
- int reset_flags = GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE;
- int ret;
- data = calloc(1, sizeof(struct rockchip_platform_data));
- if (!data)
return -ENOMEM;
- data->ops = get_rk_gmac_ops(dev);
- if (!data->ops) {
ret = -EINVAL;
goto err_free;
- for (int i = 0; data->ops->regs[i]; i++) {
data->id = i;
break;
- pdata->priv_pdata = data;
- pdata->phy_interface = eqos->config->interface(dev);
- pdata->max_speed = eqos->max_speed;
- if (pdata->phy_interface == PHY_INTERFACE_MODE_NA) {
ret = -EINVAL;
goto err_free;
- data->grf = syscon_regmap_lookup_by_phandle(dev, "rockchip,grf");
- if (IS_ERR(data->grf)) {
ret = -EINVAL;
goto err_free;
From my read of the binding, rockchip,grf is not mandatory. Is it possible to just ignore the grf if the property is missing ?
- ret = reset_get_bulk(dev, &data->resets);
- if (ret < 0)
goto err_free;
- reset_assert_bulk(&data->resets);
The same goes for the clocks below, the binding specifies min clocks is 5, and maximum clocks is 8, but not which are the 5 minimum required clocks. So , can we not stop if some of the clocks are missing ?
- ret = clk_get_by_name(dev, "stmmaceth", &eqos->clk_master_bus);
- if (ret) {
- ret = clk_get_by_name(dev, "clk_mac_speed", &eqos->clk_tx);
- if (ret) {
- if (dev_read_bool(dev, "snps,reset-active-low"))
- dev_read_u32_array(dev, "snps,reset-delays-us", eqos->reset_delays, 3);
- gpio_request_by_name(dev, "snps,reset-gpio", 0,
reset-gpio appears to be deprecated according to the binding, also, you do not check the error code and assume the property exists ?
Greetings, Eugen
- clk_free(&eqos->clk_master_bus);
- reset_release_bulk(&data->resets);
+err_free:
- free(data);
- return ret;
- if (dm_gpio_is_valid(&eqos->phy_reset_gpio))
- clk_free(&eqos->clk_tx);
- free(data);
- return reset_assert_bulk(&data->resets);
- return reset_deassert_bulk(&data->resets);
- int tx_delay, rx_delay, ret;
- if (dm_gpio_is_valid(&eqos->phy_reset_gpio)) {
if (ret < 0)
return ret;
- tx_delay = dev_read_u32_default(dev, "tx_delay", 0x30);
- rx_delay = dev_read_u32_default(dev, "rx_delay", 0x10);
- switch (pdata->phy_interface) {
- case PHY_INTERFACE_MODE_RGMII:
- case PHY_INTERFACE_MODE_RGMII_ID:
- case PHY_INTERFACE_MODE_RGMII_RXID:
- case PHY_INTERFACE_MODE_RGMII_TXID:
- case PHY_INTERFACE_MODE_RMII:
- return -EINVAL;
- return data->ops->set_gmac_speed(dev);
- return clk_get_rate(&eqos->clk_master_bus);
- .eqos_inval_desc = eqos_inval_desc_generic,
- .eqos_flush_desc = eqos_flush_desc_generic,
- .eqos_inval_buffer = eqos_inval_buffer_generic,
- .eqos_flush_buffer = eqos_flush_buffer_generic,
- .eqos_probe_resources = eqos_probe_resources_rk,
- .eqos_remove_resources = eqos_remove_resources_rk,
- .eqos_stop_resets = eqos_stop_resets_rk,
- .eqos_start_resets = eqos_start_resets_rk,
- .eqos_stop_clks = eqos_stop_clks_rk,
- .eqos_start_clks = eqos_start_clks_rk,
- .eqos_calibrate_pads = eqos_null_ops,
- .eqos_disable_calibration = eqos_null_ops,
- .eqos_set_tx_clk_speed = eqos_set_tx_clk_speed_rk,
- .eqos_get_enetaddr = eqos_null_ops,
- .eqos_get_tick_clk_rate = eqos_get_tick_clk_rate_rk,
- .reg_access_always_ok = false,
- .mdio_wait = 10,
- .swr_wait = 50,
- .config_mac = EQOS_MAC_RXQ_CTRL0_RXQ0EN_ENABLED_DCB,
- .config_mac_mdio = EQOS_MAC_MDIO_ADDRESS_CR_100_150,
- .axi_bus_width = EQOS_AXI_WIDTH_64,
- .interface = dev_read_phy_mode,
- .ops = &eqos_rockchip_ops,
Hi Eugen,
On 2023-08-07 16:41, Eugen Hristev wrote:
Hi Jonas,
Thanks!
- select DM_ETH_PHY
- help
Unintended change ?
A change to have it consistent without blank lines as remaining if/endif blocks.
- u32 regs[3];
I agree that it is an unfortunate naming, but would prefer to keep this in sync with mainline linux as much as possible to ease porting any fix merged in linux.
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
- int id;
Same here, would like to keep this in sync with linux driver. I only did absolute minimal change, wrap nr and add space, to please checkpatch.pl
- u32 con0, con1;
I did this in my original work, but opted to just import all rk_gmac_ops as close to 1:1 from mainline linux as possible in the end. Or we may end up with network working differently in linux and U-Boot. But if this is a bug, it should be fixed in both.
- u32 con1;
- ulong rate;
- int ret;
- case SPEED_10:
rate = 2500000;
break;
- case SPEED_100:
rate = 25000000;
break;
- case SPEED_1000:
rate = 125000000;
break;
- default:
return -EINVAL;
- if (ret < 0)
return ret;
.regs = {
0x0, /* sentinel */
return ops;
ops++;
- return NULL;
- int ret;
- if (!data)
return -ENOMEM;
- if (!data->ops) {
ret = -EINVAL;
goto err_free;
data->id = i;
break;
ret = -EINVAL;
goto err_free;
ret = -EINVAL;
goto err_free;
This code and the linux driver require this property or it cannot locate grf, would like to avoid falling back on the hack we have in U-Boot to locate grf. And without having regmap of grf we cannot configure the gmac in rgmii/rmii mode.
The linux driver does a check if grf is valid in the individual set_to_grmii/rmii functions, I thoutht it was better to fail earlier at probe time.
- if (ret < 0)
goto err_free;
I do not really see any reason for that, the clock drivers for rk35xx in U-Boot do not implement set_enable/disable, so auto gating or default state is required for gmac to work in U-Boot.
We only need the following clock refs to get the rate or to set the gmac speed in rk3568 case. Also we just follow linux driver here:
return dev_err_probe(dev, ret, "Cannot get stmmaceth clock\n");
So the stmmaceth clock is mandatory, and clk_mac_speed for rk3568 or we cannot change link speed.
- if (ret) {
- if (ret) {
Yes this was intentional, should probably add a comment about it.
This tries very minimum to support reset using the deprecated binding. If the properties exists, gpio pin will be asserted here and then in start_clks we wait, deassert pin, wait again. If they do not exists we silently continue.
With reset-gpios in phy node, the Ethernet Generic PHY driver will propertly assert pin, wait, deassert pin, wait again.
However, some boards still use the deprecated binding because reset-gpios in phy node does not work properly. Linux does not issue an proper assert deassert cycle in a way that one would expect, and instead treats it like a reset signal.
There there is also a chicken-and-egg problem in linux: - phy needs to be reset or phy_id read back as 0xffffffff on mdio bus - phy device is not created because a valid phy_id is not read back - phy device needs to be created before it can be reset
Please see more details of what I discovered in this linux thread: https://lore.kernel.org/linux-rockchip/47d55aca-bee6-810f-379f-9431649fefa6@...
Regards, Jonas
Greetings, Eugen
+err_free:
- free(data);
- return ret;
- free(data);
if (ret < 0)
return ret;
- return -EINVAL;
- .mdio_wait = 10,
- .swr_wait = 50,
Hi Jonas,
Thank you for your help.
在 2023/8/7 08:08, Jonas Karlman 写道:
- select DM_ETH_PHY
- help
If this compatible could move to dwc_eth_qos_rockchip.c, it is better, we have other SoCs that also use this driver in the feature, and it must increase this array all the time for new SoCs later, it will be better only change dwc_eth_qos_rockchip.c, we don't need to change the current file.
- u32 regs[3];
- int id;
- u32 con0, con1;
- u32 con1;
- ulong rate;
- int ret;
- case SPEED_10:
rate = 2500000;
break;
- case SPEED_100:
rate = 25000000;
break;
- case SPEED_1000:
rate = 125000000;
break;
- default:
return -EINVAL;
- if (ret < 0)
return ret;
.regs = {
0x0, /* sentinel */
return ops;
ops++;
- return NULL;
- int ret;
- if (!data)
return -ENOMEM;
- if (!data->ops) {
ret = -EINVAL;
goto err_free;
data->id = i;
break;
ret = -EINVAL;
goto err_free;
ret = -EINVAL;
goto err_free;
- if (ret < 0)
goto err_free;
- if (ret) {
- if (ret) {
+err_free:
- free(data);
- return ret;
- free(data);
if (ret < 0)
return ret;
- return -EINVAL;
- .mdio_wait = 10,
- .swr_wait = 50,
Hi David,
On 2023-08-15 15:12, David Wu wrote:
Hi Jonas,
- select DM_ETH_PHY
- help
Agree that this could be improved, not sure how we should/could do it, and is something that can be done in a follow-up series.
Will leave as-is for v2.
Regards, Jonas
- u32 regs[3];
- int id;
- u32 con0, con1;
- u32 con1;
- ulong rate;
- int ret;
- case SPEED_10:
rate = 2500000;
break;
- case SPEED_100:
rate = 25000000;
break;
- case SPEED_1000:
rate = 125000000;
break;
- default:
return -EINVAL;
- if (ret < 0)
return ret;
.regs = {
0x0, /* sentinel */
return ops;
ops++;
- return NULL;
- int ret;
- if (!data)
return -ENOMEM;
- if (!data->ops) {
ret = -EINVAL;
goto err_free;
data->id = i;
break;
ret = -EINVAL;
goto err_free;
ret = -EINVAL;
goto err_free;
- if (ret < 0)
goto err_free;
- if (ret) {
- if (ret) {
+err_free:
- free(data);
- return ret;
- free(data);
if (ret < 0)
return ret;
- return -EINVAL;
- .mdio_wait = 10,
- .swr_wait = 50,
Thanks, - Kever
- select DM_ETH_PHY
- help
- u32 regs[3];
- int id;
- u32 con0, con1;
- u32 con1;
- ulong rate;
- int ret;
- case SPEED_10:
rate = 2500000;
break;
- case SPEED_100:
rate = 25000000;
break;
- case SPEED_1000:
rate = 125000000;
break;
- default:
return -EINVAL;
- if (ret < 0)
return ret;
.regs = {
0x0, /* sentinel */
return ops;
ops++;
- return NULL;
- int ret;
- if (!data)
return -ENOMEM;
- if (!data->ops) {
ret = -EINVAL;
goto err_free;
data->id = i;
break;
ret = -EINVAL;
goto err_free;
ret = -EINVAL;
goto err_free;
- if (ret < 0)
goto err_free;
- if (ret) {
- if (ret) {
+err_free:
- free(data);
- return ret;
- free(data);
if (ret < 0)
return ret;
- return -EINVAL;
- .mdio_wait = 10,
- .swr_wait = 50,
Add rk_gmac_ops and other special handling that is needed for GMAC to work on RK3588.
rk_gmac_ops was ported from linux commits: 2f2b60a0ec28 ("net: ethernet: stmmac: dwmac-rk: Add gmac support for rk3588") 88619e77b33d ("net: stmmac: rk3588: Allow multiple gmac controller")
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Cc: David Wu david.wu@rock-chips.com Cc: Sebastian Reichel sebastian.reichel@collabora.com Cc: Benjamin Gaignard benjamin.gaignard@collabora.com --- drivers/net/dwc_eth_qos.c | 4 + drivers/net/dwc_eth_qos_rockchip.c | 182 ++++++++++++++++++++++++++++- 2 files changed, 182 insertions(+), 4 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index 9fb98a2c3c74..dc04416865dd 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1712,6 +1712,10 @@ static const struct udevice_id eqos_ids[] = { .compatible = "rockchip,rk3568-gmac", .data = (ulong)&eqos_rockchip_config }, + { + .compatible = "rockchip,rk3588-gmac", + .data = (ulong)&eqos_rockchip_config + }, #endif #if IS_ENABLED(CONFIG_DWC_ETH_QOS_QCOM) { diff --git a/drivers/net/dwc_eth_qos_rockchip.c b/drivers/net/dwc_eth_qos_rockchip.c index c8abe351fc3e..34020496bde6 100644 --- a/drivers/net/dwc_eth_qos_rockchip.c +++ b/drivers/net/dwc_eth_qos_rockchip.c @@ -20,6 +20,7 @@ struct rk_gmac_ops { int tx_delay, int rx_delay); int (*set_to_rmii)(struct udevice *dev); int (*set_gmac_speed)(struct udevice *dev); + void (*set_clock_selection)(struct udevice *dev, bool enable); u32 regs[3]; };
@@ -27,7 +28,9 @@ struct rockchip_platform_data { struct reset_ctl_bulk resets; const struct rk_gmac_ops *ops; int id; + bool clock_input; struct regmap *grf; + struct regmap *php_grf; };
#define HIWORD_UPDATE(val, mask, shift) \ @@ -121,6 +124,137 @@ static int rk3568_set_gmac_speed(struct udevice *dev) return 0; }
+/* sys_grf */ +#define RK3588_GRF_GMAC_CON7 0x031c +#define RK3588_GRF_GMAC_CON8 0x0320 +#define RK3588_GRF_GMAC_CON9 0x0324 + +#define RK3588_GMAC_RXCLK_DLY_ENABLE(id) GRF_BIT(2 * (id) + 3) +#define RK3588_GMAC_RXCLK_DLY_DISABLE(id) GRF_CLR_BIT(2 * (id) + 3) +#define RK3588_GMAC_TXCLK_DLY_ENABLE(id) GRF_BIT(2 * (id) + 2) +#define RK3588_GMAC_TXCLK_DLY_DISABLE(id) GRF_CLR_BIT(2 * (id) + 2) + +#define RK3588_GMAC_CLK_RX_DL_CFG(val) HIWORD_UPDATE(val, 0xFF, 8) +#define RK3588_GMAC_CLK_TX_DL_CFG(val) HIWORD_UPDATE(val, 0xFF, 0) + +/* php_grf */ +#define RK3588_GRF_GMAC_CON0 0x0008 +#define RK3588_GRF_CLK_CON1 0x0070 + +#define RK3588_GMAC_PHY_INTF_SEL_RGMII(id) \ + (GRF_BIT(3 + (id) * 6) | GRF_CLR_BIT(4 + (id) * 6) | GRF_CLR_BIT(5 + (id) * 6)) +#define RK3588_GMAC_PHY_INTF_SEL_RMII(id) \ + (GRF_CLR_BIT(3 + (id) * 6) | GRF_CLR_BIT(4 + (id) * 6) | GRF_BIT(5 + (id) * 6)) + +#define RK3588_GMAC_CLK_RMII_MODE(id) GRF_BIT(5 * (id)) +#define RK3588_GMAC_CLK_RGMII_MODE(id) GRF_CLR_BIT(5 * (id)) + +#define RK3588_GMAC_CLK_SELET_CRU(id) GRF_BIT(5 * (id) + 4) +#define RK3588_GMAC_CLK_SELET_IO(id) GRF_CLR_BIT(5 * (id) + 4) + +#define RK3588_GMAC_CLK_RMII_DIV2(id) GRF_BIT(5 * (id) + 2) +#define RK3588_GMAC_CLK_RMII_DIV20(id) GRF_CLR_BIT(5 * (id) + 2) + +#define RK3588_GMAC_CLK_RGMII_DIV1(id) \ + (GRF_CLR_BIT(5 * (id) + 2) | GRF_CLR_BIT(5 * (id) + 3)) +#define RK3588_GMAC_CLK_RGMII_DIV5(id) \ + (GRF_BIT(5 * (id) + 2) | GRF_BIT(5 * (id) + 3)) +#define RK3588_GMAC_CLK_RGMII_DIV50(id) \ + (GRF_CLR_BIT(5 * (id) + 2) | GRF_BIT(5 * (id) + 3)) + +#define RK3588_GMAC_CLK_RMII_GATE(id) GRF_BIT(5 * (id) + 1) +#define RK3588_GMAC_CLK_RMII_NOGATE(id) GRF_CLR_BIT(5 * (id) + 1) + +static int rk3588_set_to_rgmii(struct udevice *dev, + int tx_delay, int rx_delay) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + u32 offset_con, id = data->id; + + offset_con = data->id == 1 ? RK3588_GRF_GMAC_CON9 : + RK3588_GRF_GMAC_CON8; + + regmap_write(data->php_grf, RK3588_GRF_GMAC_CON0, + RK3588_GMAC_PHY_INTF_SEL_RGMII(id)); + + regmap_write(data->php_grf, RK3588_GRF_CLK_CON1, + RK3588_GMAC_CLK_RGMII_MODE(id)); + + regmap_write(data->grf, RK3588_GRF_GMAC_CON7, + RK3588_GMAC_RXCLK_DLY_ENABLE(id) | + RK3588_GMAC_TXCLK_DLY_ENABLE(id)); + + regmap_write(data->grf, offset_con, + RK3588_GMAC_CLK_RX_DL_CFG(rx_delay) | + RK3588_GMAC_CLK_TX_DL_CFG(tx_delay)); + + return 0; +} + +static int rk3588_set_to_rmii(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + regmap_write(data->php_grf, RK3588_GRF_GMAC_CON0, + RK3588_GMAC_PHY_INTF_SEL_RMII(data->id)); + + regmap_write(data->php_grf, RK3588_GRF_CLK_CON1, + RK3588_GMAC_CLK_RMII_MODE(data->id)); + + return 0; +} + +static int rk3588_set_gmac_speed(struct udevice *dev) +{ + struct eqos_priv *eqos = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + u32 val = 0, id = data->id; + + switch (eqos->phy->speed) { + case SPEED_10: + if (pdata->phy_interface == PHY_INTERFACE_MODE_RMII) + val = RK3588_GMAC_CLK_RMII_DIV20(id); + else + val = RK3588_GMAC_CLK_RGMII_DIV50(id); + break; + case SPEED_100: + if (pdata->phy_interface == PHY_INTERFACE_MODE_RMII) + val = RK3588_GMAC_CLK_RMII_DIV2(id); + else + val = RK3588_GMAC_CLK_RGMII_DIV5(id); + break; + case SPEED_1000: + if (pdata->phy_interface != PHY_INTERFACE_MODE_RMII) + val = RK3588_GMAC_CLK_RGMII_DIV1(id); + else + return -EINVAL; + break; + default: + return -EINVAL; + } + + regmap_write(data->php_grf, RK3588_GRF_CLK_CON1, val); + + return 0; +} + +static void rk3588_set_clock_selection(struct udevice *dev, bool enable) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + u32 val = data->clock_input ? RK3588_GMAC_CLK_SELET_IO(data->id) : + RK3588_GMAC_CLK_SELET_CRU(data->id); + + val |= enable ? RK3588_GMAC_CLK_RMII_NOGATE(data->id) : + RK3588_GMAC_CLK_RMII_GATE(data->id); + + regmap_write(data->php_grf, RK3588_GRF_CLK_CON1, val); +} + static const struct rk_gmac_ops rk_gmac_ops[] = { { .compatible = "rockchip,rk3568-gmac", @@ -133,6 +267,18 @@ static const struct rk_gmac_ops rk_gmac_ops[] = { 0x0, /* sentinel */ }, }, + { + .compatible = "rockchip,rk3588-gmac", + .set_to_rgmii = rk3588_set_to_rgmii, + .set_to_rmii = rk3588_set_to_rmii, + .set_gmac_speed = rk3588_set_gmac_speed, + .set_clock_selection = rk3588_set_clock_selection, + .regs = { + 0xfe1b0000, /* gmac0 */ + 0xfe1c0000, /* gmac1 */ + 0x0, /* sentinel */ + }, + }, { } };
@@ -154,6 +300,7 @@ static int eqos_probe_resources_rk(struct udevice *dev) struct eqos_priv *eqos = dev_get_priv(dev); struct eth_pdata *pdata = dev_get_plat(dev); struct rockchip_platform_data *data; + const char *clock_in_out; int reset_flags = GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE; int ret;
@@ -191,6 +338,16 @@ static int eqos_probe_resources_rk(struct udevice *dev) goto err_free; }
+ if (device_is_compatible(dev, "rockchip,rk3588-gmac")) { + data->php_grf = + syscon_regmap_lookup_by_phandle(dev, "rockchip,php-grf"); + if (IS_ERR(data->php_grf)) { + dev_err(dev, "Missing rockchip,php-grf property\n"); + ret = -EINVAL; + goto err_free; + } + } + ret = reset_get_bulk(dev, &data->resets); if (ret < 0) goto err_free; @@ -203,12 +360,20 @@ static int eqos_probe_resources_rk(struct udevice *dev) goto err_release_resets; }
- ret = clk_get_by_name(dev, "clk_mac_speed", &eqos->clk_tx); - if (ret) { - dev_dbg(dev, "clk_get_by_name(clk_mac_speed) failed: %d", ret); - goto err_free_clk_master_bus; + if (device_is_compatible(dev, "rockchip,rk3568-gmac")) { + ret = clk_get_by_name(dev, "clk_mac_speed", &eqos->clk_tx); + if (ret) { + dev_dbg(dev, "clk_get_by_name(clk_mac_speed) failed: %d", ret); + goto err_free_clk_master_bus; + } }
+ clock_in_out = dev_read_string(dev, "clock_in_out"); + if (clock_in_out && !strcmp(clock_in_out, "input")) + data->clock_input = true; + else + data->clock_input = false; + if (dev_read_bool(dev, "snps,reset-active-low")) reset_flags |= GPIOD_ACTIVE_LOW;
@@ -264,6 +429,12 @@ static int eqos_start_resets_rk(struct udevice *dev)
static int eqos_stop_clks_rk(struct udevice *dev) { + struct eth_pdata *pdata = dev_get_plat(dev); + struct rockchip_platform_data *data = pdata->priv_pdata; + + if (data->ops->set_clock_selection) + data->ops->set_clock_selection(dev, false); + return 0; }
@@ -284,6 +455,9 @@ static int eqos_start_clks_rk(struct udevice *dev) udelay(eqos->reset_delays[2]); }
+ if (data->ops->set_clock_selection) + data->ops->set_clock_selection(dev, true); + tx_delay = dev_read_u32_default(dev, "tx_delay", 0x30); rx_delay = dev_read_u32_default(dev, "rx_delay", 0x10);
Thanks, - Kever
- }, #endif #if IS_ENABLED(CONFIG_DWC_ETH_QOS_QCOM) {
- void (*set_clock_selection)(struct udevice *dev, bool enable); u32 regs[3]; };
- (GRF_BIT(3 + (id) * 6) | GRF_CLR_BIT(4 + (id) * 6) | GRF_CLR_BIT(5 + (id) * 6))
- (GRF_CLR_BIT(3 + (id) * 6) | GRF_CLR_BIT(4 + (id) * 6) | GRF_BIT(5 + (id) * 6))
- u32 offset_con, id = data->id;
- offset_con = data->id == 1 ? RK3588_GRF_GMAC_CON9 :
- regmap_write(data->php_grf, RK3588_GRF_GMAC_CON0,
- regmap_write(data->php_grf, RK3588_GRF_CLK_CON1,
- regmap_write(data->grf, RK3588_GRF_GMAC_CON7,
- regmap_write(data->grf, offset_con,
- u32 val = 0, id = data->id;
- case SPEED_10:
else
break;
- case SPEED_100:
else
break;
- case SPEED_1000:
else
return -EINVAL;
break;
- default:
return -EINVAL;
- regmap_write(data->php_grf, RK3588_GRF_CLK_CON1, val);
- u32 val = data->clock_input ? RK3588_GMAC_CLK_SELET_IO(data->id) :
- val |= enable ? RK3588_GMAC_CLK_RMII_NOGATE(data->id) :
- static const struct rk_gmac_ops rk_gmac_ops[] = { { .compatible = "rockchip,rk3568-gmac",
.regs = {
0x0, /* sentinel */
- const char *clock_in_out; int reset_flags = GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE; int ret;
- if (device_is_compatible(dev, "rockchip,rk3588-gmac")) {
data->php_grf =
ret = -EINVAL;
goto err_free;
- ret = reset_get_bulk(dev, &data->resets); if (ret < 0) goto err_free;
- if (ret) {
if (ret) {
else
- if (data->ops->set_clock_selection)
- return 0; }
- tx_delay = dev_read_u32_default(dev, "tx_delay", 0x30); rx_delay = dev_read_u32_default(dev, "rx_delay", 0x10);
FWIW it's also
Reviewed-by: sebastian.reichel@collabora.com
-- Sebastian
Thanks,
- Kever
- bool clock_input; struct regmap *grf;
- struct regmap *php_grf; }; #define HIWORD_UPDATE(val, mask, shift) \
@@ -121,6 +124,137 @@ static int rk3568_set_gmac_speed(struct udevice *dev) return 0; } +/* sys_grf */ +#define RK3588_GRF_GMAC_CON7 0x031c +#define RK3588_GRF_GMAC_CON8 0x0320 +#define RK3588_GRF_GMAC_CON9 0x0324
- case SPEED_10:
else
break;
- case SPEED_100:
else
break;
- case SPEED_1000:
else
return -EINVAL;
break;
- default:
return -EINVAL;
.regs = {
0x0, /* sentinel */
data->php_grf =
ret = -EINVAL;
goto err_free;
- if (ret) {
- if (device_is_compatible(dev, "rockchip,rk3568-gmac")) {
if (ret) {
- clock_in_out = dev_read_string(dev, "clock_in_out");
- if (clock_in_out && !strcmp(clock_in_out, "input"))
- else
- if (dev_read_bool(dev, "snps,reset-active-low")) reset_flags |= GPIOD_ACTIVE_LOW;
@@ -264,6 +429,12 @@ static int eqos_start_resets_rk(struct udevice *dev) static int eqos_stop_clks_rk(struct udevice *dev) {
- return 0; }
Tested to work (DHCP, ping) on RK3588 QuartzPro64 (DTS coming soon!), thanks!
Tested-by: Tom Fitzhenry tom@tom-fitzhenry.me.uk
Enable DWC_ETH_QOS_ROCKCHIP and related PHY driver on RK356x boards that have an enabled gmac node.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- configs/evb-rk3568_defconfig | 5 +++-- configs/nanopi-r5s-rk3568_defconfig | 3 +++ configs/odroid-m1-rk3568_defconfig | 3 +++ configs/quartz64-a-rk3566_defconfig | 3 +++ configs/quartz64-b-rk3566_defconfig | 3 +++ configs/radxa-cm3-io-rk3566_defconfig | 6 ++++-- configs/rock-3a-rk3568_defconfig | 5 +++-- configs/soquartz-blade-rk3566_defconfig | 3 +++ configs/soquartz-cm4-rk3566_defconfig | 3 +++ configs/soquartz-model-a-rk3566_defconfig | 3 +++ 10 files changed, 31 insertions(+), 6 deletions(-)
diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index 5f3fab7304c2..43431ecdfed6 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -58,8 +58,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y diff --git a/configs/nanopi-r5s-rk3568_defconfig b/configs/nanopi-r5s-rk3568_defconfig index c278ce083d9a..2736d382a352 100644 --- a/configs/nanopi-r5s-rk3568_defconfig +++ b/configs/nanopi-r5s-rk3568_defconfig @@ -65,6 +65,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_RTL8169=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y diff --git a/configs/odroid-m1-rk3568_defconfig b/configs/odroid-m1-rk3568_defconfig index 3dda5c1f9170..96b4e9ecdaff 100644 --- a/configs/odroid-m1-rk3568_defconfig +++ b/configs/odroid-m1-rk3568_defconfig @@ -82,6 +82,9 @@ CONFIG_SF_DEFAULT_BUS=4 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/quartz64-a-rk3566_defconfig b/configs/quartz64-a-rk3566_defconfig index 6853cd6c44b4..bf4d4cd2b8ed 100644 --- a/configs/quartz64-a-rk3566_defconfig +++ b/configs/quartz64-a-rk3566_defconfig @@ -81,6 +81,9 @@ CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/quartz64-b-rk3566_defconfig b/configs/quartz64-b-rk3566_defconfig index aa29fff14643..358687ab5d7f 100644 --- a/configs/quartz64-b-rk3566_defconfig +++ b/configs/quartz64-b-rk3566_defconfig @@ -79,6 +79,9 @@ CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index f89777184ceb..4b606dcb8e94 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -59,8 +60,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y CONFIG_SPL_PINCTRL=y diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 409aa95acf06..28d157dbd7a7 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -77,8 +77,9 @@ CONFIG_SF_DEFAULT_BUS=4 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_XTX=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/soquartz-blade-rk3566_defconfig b/configs/soquartz-blade-rk3566_defconfig index 181c284e73e9..1d993a5b71b0 100644 --- a/configs/soquartz-blade-rk3566_defconfig +++ b/configs/soquartz-blade-rk3566_defconfig @@ -67,6 +67,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/soquartz-cm4-rk3566_defconfig b/configs/soquartz-cm4-rk3566_defconfig index 7e290351477e..f01aa7269a1c 100644 --- a/configs/soquartz-cm4-rk3566_defconfig +++ b/configs/soquartz-cm4-rk3566_defconfig @@ -67,6 +67,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y diff --git a/configs/soquartz-model-a-rk3566_defconfig b/configs/soquartz-model-a-rk3566_defconfig index a0884a797d58..2f3145745d58 100644 --- a/configs/soquartz-model-a-rk3566_defconfig +++ b/configs/soquartz-model-a-rk3566_defconfig @@ -68,6 +68,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y
Thanks, - Kever
Enable DWC_ETH_QOS_ROCKCHIP and related PHY driver on RK3588 boards that have an enabled gmac node and drop ETH_DESIGNWARE and GMAC_ROCKCHIP for remaining RK3588 boards.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- configs/evb-rk3588_defconfig | 5 +++-- configs/neu6a-io-rk3588_defconfig | 2 -- configs/neu6b-io-rk3588_defconfig | 2 -- configs/rock5a-rk3588s_defconfig | 6 +++--- 4 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig index f49c2ca686a8..0b7b4f2f627a 100644 --- a/configs/evb-rk3588_defconfig +++ b/configs/evb-rk3588_defconfig @@ -58,8 +58,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index 09729a0ea429..d5301c630b2a 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -53,8 +53,6 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y diff --git a/configs/neu6b-io-rk3588_defconfig b/configs/neu6b-io-rk3588_defconfig index c7bc3b1965f0..b13c9b5db1b0 100644 --- a/configs/neu6b-io-rk3588_defconfig +++ b/configs/neu6b-io-rk3588_defconfig @@ -53,8 +53,6 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y diff --git a/configs/rock5a-rk3588s_defconfig b/configs/rock5a-rk3588s_defconfig index 6cbd9817c528..bccdb1e3ecd6 100644 --- a/configs/rock5a-rk3588s_defconfig +++ b/configs/rock5a-rk3588s_defconfig @@ -11,7 +11,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588s-rock-5a" CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y -CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x1000000 CONFIG_TARGET_ROCK5A_RK3588=y @@ -59,8 +58,9 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y -CONFIG_ETH_DESIGNWARE=y -CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_SPL_PINCTRL=y CONFIG_REGULATOR_PWM=y CONFIG_PWM_ROCKCHIP=y
Thanks, - Kever
Add David,
Hi David,
Please help to review this patch set for dwc_eth_qos for rk3568/rk3588.
Thanks,
- Kever
Dependencies:
participants (6)
David Wu
Eugen Hristev
Jonas Karlman
Kever Yang
Sebastian Reichel
Tom Fitzhenry
