Ok i hope i turned the irritating HTML of, now!
The thing i missed is which cfg_ the U-Boot has to have. Should i put my sram address as CFG_SDRAM_BASE and underline CFG_SRAM_BASE?
-- Måns Brorsson
In message 9e45f2180601310654x4c786877ma82c04368e2002af@mail.gmail.com you wrote:
Yes, thanks!
CFG_SRAM_BASE is not really used anywhere in U-Boot; it's just passed to the Linux kernel on some boards.
CFG_SDRAM_BASE is more important.
Hi Mans,
I'm assuming you're using Nios II ... in which case the code doesn't really care about SDRAM ... since the SDRAM controller is configured when you create the Nios II system module, not a run time. So yes, you can set CFG_SDRAM_BASE to point to your SRAM base address. And just set CFG_SRAM_BASE/SIZE to zero.
Also, there are several patches for the Nios II code that haven't made it into the source tree yet -- if you run into problems, just let me know & I'll send you the patches directly.
Regards, --Scott
Måns Brorsson
Scott McNutt
