[U-Boot] bug report: the 8378 can not boot up when we enable the debug log
I test the mpc8378 board when I enable the DEBUG macro in common.h file Log is below: ------ U-Boot 2010.12 (Jan 15 2011 - 11:40:03) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c4, MPC8378E, Rev: 2.1 at 297 MHz, CSB: 198 MHz Board: Freescale MPC837xEMDS I2C: Requested speed:400000, i2c_clk:66000000 FDR:0x24, div:320, ga:0x4, gb:0x1, a:10, b:32, speed:206250 Tr <= 348 ns FDR:0x21, div:192, ga:0x5, gb:0x0, a:12, b:16, speed:343750 Tr <= 106 ns divider:165, est_div:192, DFSR:3 FDR:0x21, speed:343750 Requested speed:400000, i2c_clk:198000000 FDR:0x28, div:640, ga:0x4, gb:0x2, a:10, b:64, speed:309375 Tr <= 186 ns FDR:0x27, div:512, ga:0x7, gb:0x1, a:16, b:32, speed:386718 Tr <= 25 ns divider:495, est_div:512, DFSR:9 FDR:0x27, speed:386718 ready DRAM: 512 MiB (DDR2, 64-bit, ECC off, 198 MHz) Top of RAM usable for U-Boot at: 20000000 Reserving 545k for U-Boot at: 1ff77000 Reserving 520k for malloc() at: 1fef5000 Reserving 68 Bytes for Board Info at: 1fef4fbc Reserving 152 Bytes for Global Data at: 1fef4f24 Stack Pointer at: 1fef4f08 New Stack Pointer is: 1fef4f08 Now running in RAM - U-Boot at: 1ff77000 i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK i2c_wait: No RXACK PCI 32bit bus on PMC1 & PMC2 &PMC3 FLASH: flash detect cfi fwc addr fe000000 cmd f0 f0 8bit x 8 bit fwc addr fe000000 cmd ff ff 8bit x 8 bit fwc addr fe000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fe000010 is= 0 51 fwc addr fe000000 cmd f0 f0f0 16bit x 8 bit fwc addr fe000000 cmd ff ffff 16bit x 8 bit fwc addr fe0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 0051 5151 fwc addr fe000aaa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr fe000020 is= 0051 5151 fwc addr fe000000 cmd f0 00f0 16bit x 16 bit fwc addr fe000000 cmd ff 00ff 16bit x 16 bit fwc addr fe0000aa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr fe000020 is= 0051 0051 is= cmd 52(R) addr fe000022 is= 0052 0052 is= cmd 59(Y) addr fe000024 is= 0059 0059 device interface is 2 found port 2 chip 2 port 16 bits chip 16 bits 00 : 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 07 QRY..@.....'6... 10 : 07 0a 00 03 05 04 00 18 02 00 05 00 01 7f 00 00 ................ 20 : 02 00 00 00 00 00 00 00 00 00 00 00 00 fb ce 28 ...............( fwc addr fe000000 cmd f0 00f0 16bit x 16 bit fwc addr fe000aaa cmd aa 00aa 16bit x 16 bit fwc addr fe000554 cmd 55 0055 16bit x 16 bit fwc addr fe000aaa cmd 90 0090 16bit x 16 bit fwc addr fe000000 cmd f0 00f0 16bit x 16 bit fwc addr fe0000aa cmd 98 0098 16bit x 16 bit manufacturer is 2 manufacturer id is 0x1 device id is 0x227e device id2 is 0x0 cfi version is 0x3133 size_ratio 1 port 16 bits chip 16 bits found 1 erase regions erase region 0: 0x0200007f erase_region_count = 128 erase_region_size = 131072 fwc addr fe000000 cmd f0 00f0 16bit x 16 bit flash_protect ON: from 0xFE000000 to 0xFE051FFF flash_is_busy: 0 protect on 0 flash_is_busy: 0 protect on 1 flash_is_busy: 0 protect on 2 flash_protect ON: from 0xFE060000 to 0xFE07FFFF flash_is_busy: 0 protect on 3 16 MiB NAND: No NAND device found!!! 0 MiB MMC: * Warning - bad CRC, using default environment
Destroy Hash Table: 1ffca978 table = (null) Create Hash Table: N=172 INSERT: table 1ffca978, filled 1/173 rv 1fef57b8 ==> name="bootcmd" value="setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr" Bad trap at PC: 10820010, SR: 1000, vector=2000000 NIP: 10820010 XER: 00000000 LR: 10480030 REGS: 00000001 TRAP: 2000000 DAR: 08000200 MSR: 00001000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 00990080 00000100 00800040 00000100 00820000 04000800 20080010 10000000 GPR08: 00800000 02001100 30E00000 40000000 004A0000 80000200 21020000 00000000 GPR16: 00010020 2A000000 300C0000 08000200 002B0000 00001000 00100070 3B005000 GPR24: 00000001 00000100 20520000 00004100 001A0000 41000000 01000000 40000900 Call backtrace: 60000000 Exception in kernel pc 10820010 signal 0 Resetting the board.
Leo Liu
