[U-Boot] [PATCH] env: remove duplicated env_get_char_spec()
env_fat and env_remote have an implementation of env_get_char_spec() function that is not different than the default. Remove the duplicated code.
Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- common/env_fat.c | 5 ----- common/env_remote.c | 5 ----- 2 files changed, 0 insertions(+), 10 deletions(-)
diff --git a/common/env_fat.c b/common/env_fat.c index bad92aa..ca76967 100644 --- a/common/env_fat.c +++ b/common/env_fat.c @@ -40,11 +40,6 @@ env_t *env_ptr;
DECLARE_GLOBAL_DATA_PTR;
-uchar env_get_char_spec(int index) -{ - return *((uchar *)(gd->env_addr + index)); -} - int env_init(void) { /* use default */ diff --git a/common/env_remote.c b/common/env_remote.c index 3bf0f95..87af1936 100644 --- a/common/env_remote.c +++ b/common/env_remote.c @@ -41,11 +41,6 @@ DECLARE_GLOBAL_DATA_PTR; #define CONFIG_ENV_OFFSET 0 #endif
-uchar env_get_char_spec(int index) -{ - return *((uchar *)(gd->env_addr + index)); -} - int env_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) {
Igor Grinberg
