[U-Boot] [PATCH 1/2] ARM: imx6: DHCOM i.MX6 PDK: use Kconfig for inclusion of DDR calibration
The four x16 DDR3 are wired in T-topology. From NXP AN4467: 'Although not required, T-Topologies may also benefit from performing Write Leveling as there are package delays on both the processor and DDR devices that can be de-skewed by performing Write Leveling. Therefore, Freescale recommends determining Write Leveling calibration parameters for all boards, regardless of topology used.' That is why write level calibration is also done.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 32 +++++++++++++++++++++++++------ 1 file changed, 26 insertions(+), 6 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index 04e9eab272a..bbd2dc26828 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -482,6 +482,29 @@ static void setup_iomux_usb(void) SETUP_IOMUX_PADS(usb_pads); }
+/* Perform DDR DRAM calibration */ +static int spl_dram_perform_cal(struct mx6_ddr_sysinfo const *sysinfo) +{ + int ret = 0; + +#ifdef CONFIG_MX6_DDRCAL + udelay(100); + ret = mmdc_do_write_level_calibration(sysinfo); + if (ret) { + printf("DDR3: Write level calibration error [%d]\n", ret); + return ret; + } + + ret = mmdc_do_dqs_calibration(sysinfo); + if (ret) { + printf("DDR3: DQS calibration error [%d]\n", ret); + return ret; + } +#endif /* CONFIG_MX6_DDRCAL */ + + return ret; +} +
/* DRAM */ static void dhcom_spl_dram_init(void) @@ -509,8 +532,7 @@ static void dhcom_spl_dram_init(void) }
/* Perform DDR DRAM calibration */ - udelay(100); - mmdc_do_dqs_calibration(&dhcom_ddr_64bit); + spl_dram_perform_cal(&dhcom_ddr_64bit);
} else if (is_cpu_type(MXC_CPU_MX6DL)) { mx6sdl_dram_iocfg(64, &dhcom6sdl_ddr_ioregs, @@ -528,8 +550,7 @@ static void dhcom_spl_dram_init(void) }
} else if (is_cpu_type(MXC_CPU_MX6SOLO)) { mx6sdl_dram_iocfg(32, &dhcom6sdl_ddr_ioregs, @@ -552,8 +573,7 @@ static void dhcom_spl_dram_init(void) }
/* Perform DDR DRAM calibration */ - udelay(100); - mmdc_do_dqs_calibration(&dhcom_ddr_32bit); + spl_dram_perform_cal(&dhcom_ddr_32bit); } }
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index bbd2dc26828..2939389de39 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -161,18 +161,18 @@ static const struct mx6_mmdc_calibration dhcom_mmdc_calib_2x4g_800 = { };
static const struct mx6_mmdc_calibration dhcom_mmdc_calib_4x2g_1066 = { - .p0_mpwldectrl0 = 0x0011000E, - .p0_mpwldectrl1 = 0x000E001B, - .p1_mpwldectrl0 = 0x00190015, - .p1_mpwldectrl1 = 0x00070018, - .p0_mpdgctrl0 = 0x42720306, - .p0_mpdgctrl1 = 0x026F0266, - .p1_mpdgctrl0 = 0x4273030A, - .p1_mpdgctrl1 = 0x02740240, - .p0_mprddlctl = 0x45393B3E, - .p1_mprddlctl = 0x403A3747, - .p0_mpwrdlctl = 0x40434541, - .p1_mpwrdlctl = 0x473E4A3B, + .p0_mpwldectrl0 = 0x001a001a, + .p0_mpwldectrl1 = 0x00260015, + .p0_mpdgctrl0 = 0x030c0320, + .p0_mpdgctrl1 = 0x03100304, + .p0_mprddlctl = 0x432e3538, + .p0_mpwrdlctl = 0x363f423d, + .p1_mpwldectrl0 = 0x0006001e, + .p1_mpwldectrl1 = 0x00050015, + .p1_mpdgctrl0 = 0x031c0324, + .p1_mpdgctrl1 = 0x030c0258, + .p1_mprddlctl = 0x3834313f, + .p1_mpwrdlctl = 0x47374a42, };
static const struct mx6_mmdc_calibration dhcom_mmdc_calib_4x2g_800 = {
On 4/12/19 1:29 PM, Ludwig Zenz wrote:
Commit message is missing , please fix.
- .p0_mpwldectrl0 = 0x001a001a,
- .p0_mpwldectrl1 = 0x00260015,
- .p0_mpdgctrl0 = 0x030c0320,
- .p0_mpdgctrl1 = 0x03100304,
- .p0_mprddlctl = 0x432e3538,
- .p0_mpwrdlctl = 0x363f423d,
- .p1_mpwldectrl0 = 0x0006001e,
- .p1_mpwldectrl1 = 0x00050015,
- .p1_mpdgctrl0 = 0x031c0324,
- .p1_mpdgctrl1 = 0x030c0258,
- .p1_mprddlctl = 0x3834313f,
- .p1_mpwrdlctl = 0x47374a42,
- int ret = 0;
- udelay(100);
- ret = mmdc_do_write_level_calibration(sysinfo);
- if (ret) {
return ret;
- ret = mmdc_do_dqs_calibration(sysinfo);
- if (ret) {
return ret;
- return ret;
udelay(100);
udelay(100);
udelay(100);
}spl_dram_perform_cal(&dhcom_ddr_32bit);
Ludwig Zenz
