[U-Boot] [PATCH] usb: musb: add virtual root hub control support
For MUSB devices that do not support multipoint (hubs), we have to emulate a root hub so that we can support core operations like resetting ports.
Signed-off-by: Bryan Wu bryan.wu@analog.com Signed-off-by: Cliff Cai cliff.cai@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/usb/musb/musb_hcd.c | 429 ++++++++++++++++++++++++++++++++++++++++++- drivers/usb/musb/musb_hcd.h | 55 ++++++ 2 files changed, 482 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index adb8c38..dd2aa7f 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -35,6 +35,106 @@ static struct musb_epinfo epinfo[3] = { {MUSB_INTR_EP, 0, 64} /* EP2 - Interrupt IN - 64 Bytes */ };
+/* --- Virtual Root Hub ---------------------------------------------------- */ +#ifdef MUSB_NO_MULTIPOINT +static int rh_devnum; +static u32 port_status; + +/* Device descriptor */ +static u8 root_hub_dev_des[] = { + 0x12, /* __u8 bLength; */ + 0x01, /* __u8 bDescriptorType; Device */ + 0x00, /* __u16 bcdUSB; v1.1 */ + 0x02, + 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ + 0x00, /* __u8 bDeviceSubClass; */ + 0x00, /* __u8 bDeviceProtocol; */ + 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ + 0x00, /* __u16 idVendor; */ + 0x00, + 0x00, /* __u16 idProduct; */ + 0x00, + 0x00, /* __u16 bcdDevice; */ + 0x00, + 0x00, /* __u8 iManufacturer; */ + 0x01, /* __u8 iProduct; */ + 0x00, /* __u8 iSerialNumber; */ + 0x01 /* __u8 bNumConfigurations; */ +}; + +/* Configuration descriptor */ +static u8 root_hub_config_des[] = { + 0x09, /* __u8 bLength; */ + 0x02, /* __u8 bDescriptorType; Configuration */ + 0x19, /* __u16 wTotalLength; */ + 0x00, + 0x01, /* __u8 bNumInterfaces; */ + 0x01, /* __u8 bConfigurationValue; */ + 0x00, /* __u8 iConfiguration; */ + 0x40, /* __u8 bmAttributes; + Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ + 0x00, /* __u8 MaxPower; */ + + /* interface */ + 0x09, /* __u8 if_bLength; */ + 0x04, /* __u8 if_bDescriptorType; Interface */ + 0x00, /* __u8 if_bInterfaceNumber; */ + 0x00, /* __u8 if_bAlternateSetting; */ + 0x01, /* __u8 if_bNumEndpoints; */ + 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ + 0x00, /* __u8 if_bInterfaceSubClass; */ + 0x00, /* __u8 if_bInterfaceProtocol; */ + 0x00, /* __u8 if_iInterface; */ + + /* endpoint */ + 0x07, /* __u8 ep_bLength; */ + 0x05, /* __u8 ep_bDescriptorType; Endpoint */ + 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ + 0x03, /* __u8 ep_bmAttributes; Interrupt */ + 0x00, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ + 0x02, + 0xff /* __u8 ep_bInterval; 255 ms */ +}; + +static unsigned char root_hub_str_index0[] = { + 0x04, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 0x09, /* __u8 lang ID */ + 0x04, /* __u8 lang ID */ +}; + +static unsigned char root_hub_str_index1[] = { + 0x1c, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 'M', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'U', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'S', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'B', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'R', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 't', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'H', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'u', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'b', /* __u8 Unicode */ + 0, /* __u8 Unicode */ +}; +#endif + /* * This function writes the data toggle value. */ @@ -411,18 +511,341 @@ static void config_hub_port(struct usb_device *dev, u8 ep) #endif }
+#ifdef MUSB_NO_MULTIPOINT + +static void musb_port_reset(int do_reset) +{ + u8 power = readb(&musbr->power); + + if (do_reset) { + power &= 0xf0; + writeb(power | MUSB_POWER_RESET, &musbr->power); + port_status |= USB_PORT_STAT_RESET; + port_status &= ~USB_PORT_STAT_ENABLE; + udelay(30000); + } else { + writeb(power & ~MUSB_POWER_RESET, &musbr->power); + + power = readb(&musbr->power); + if (power & MUSB_POWER_HSMODE) + port_status |= USB_PORT_STAT_HIGH_SPEED; + + port_status &= ~(USB_PORT_STAT_RESET | (USB_PORT_STAT_C_CONNECTION << 16)); + port_status |= USB_PORT_STAT_ENABLE + | (USB_PORT_STAT_C_RESET << 16) + | (USB_PORT_STAT_C_ENABLE << 16); + } +} + +/* + * root hub control + */ +static int musb_submit_rh_msg(struct usb_device *dev, unsigned long pipe, + void *buffer, int transfer_len, + struct devrequest *cmd) +{ + int leni = transfer_len; + int len = 0; + int stat = 0; + u32 datab[4]; + u8 *data_buf = (u8 *) datab; + u16 bmRType_bReq; + u16 wValue; + u16 wIndex; + u16 wLength; + u16 int_usb; + + if ((pipe & PIPE_INTERRUPT) == PIPE_INTERRUPT) { + debug("Root-Hub submit IRQ: NOT implemented\n"); + return 0; + } + + bmRType_bReq = cmd->requesttype | (cmd->request << 8); + wValue = swap_16(cmd->value); + wIndex = swap_16(cmd->index); + wLength = swap_16(cmd->length); + + debug("--- HUB ----------------------------------------\n"); + debug("submit rh urb, req=%x val=%#x index=%#x len=%d\n", + bmRType_bReq, wValue, wIndex, wLength); + debug("------------------------------------------------\n"); + + switch (bmRType_bReq) { + case RH_GET_STATUS: + debug("RH_GET_STATUS\n"); + + *(__u16 *) data_buf = swap_16(1); + len = 2; + break; + + case RH_GET_STATUS | RH_INTERFACE: + debug("RH_GET_STATUS | RH_INTERFACE\n"); + + *(__u16 *) data_buf = swap_16(0); + len = 2; + break; + + case RH_GET_STATUS | RH_ENDPOINT: + debug("RH_GET_STATUS | RH_ENDPOINT\n"); + + *(__u16 *) data_buf = swap_16(0); + len = 2; + break; + + case RH_GET_STATUS | RH_CLASS: + debug("RH_GET_STATUS | RH_CLASS\n"); + + *(__u32 *) data_buf = swap_32(0); + len = 4; + break; + + case RH_GET_STATUS | RH_OTHER | RH_CLASS: + debug("RH_GET_STATUS | RH_OTHER | RH_CLASS\n"); + + int_usb = readw(&musbr->intrusb); + if (int_usb & MUSB_INTR_CONNECT) { + port_status |= USB_PORT_STAT_CONNECTION + | (USB_PORT_STAT_C_CONNECTION << 16); + port_status |= USB_PORT_STAT_HIGH_SPEED + | USB_PORT_STAT_ENABLE; + } + + if (port_status & USB_PORT_STAT_RESET) + musb_port_reset(0); + + *(__u32 *) data_buf = swap_32(port_status); + len = 4; + break; + + case RH_CLEAR_FEATURE | RH_ENDPOINT: + debug("RH_CLEAR_FEATURE | RH_ENDPOINT\n"); + + switch (wValue) { + case RH_ENDPOINT_STALL: + debug("C_HUB_ENDPOINT_STALL\n"); + len = 0; + break; + } + port_status &= ~(1 << wValue); + break; + + case RH_CLEAR_FEATURE | RH_CLASS: + debug("RH_CLEAR_FEATURE | RH_CLASS\n"); + + switch (wValue) { + case RH_C_HUB_LOCAL_POWER: + debug("C_HUB_LOCAL_POWER\n"); + len = 0; + break; + + case RH_C_HUB_OVER_CURRENT: + debug("C_HUB_OVER_CURRENT\n"); + len = 0; + break; + } + port_status &= ~(1 << wValue); + break; + + case RH_CLEAR_FEATURE | RH_OTHER | RH_CLASS: + debug("RH_CLEAR_FEATURE | RH_OTHER | RH_CLASS\n"); + + switch (wValue) { + case RH_PORT_ENABLE: + len = 0; + break; + + case RH_PORT_SUSPEND: + len = 0; + break; + + case RH_PORT_POWER: + len = 0; + break; + + case RH_C_PORT_CONNECTION: + len = 0; + break; + + case RH_C_PORT_ENABLE: + len = 0; + break; + + case RH_C_PORT_SUSPEND: + len = 0; + break; + + case RH_C_PORT_OVER_CURRENT: + len = 0; + break; + + case RH_C_PORT_RESET: + len = 0; + break; + + default: + debug("invalid wValue\n"); + stat = USB_ST_STALLED; + } + + port_status &= ~(1 << wValue); + break; + + case RH_SET_FEATURE | RH_OTHER | RH_CLASS: + debug("RH_SET_FEATURE | RH_OTHER | RH_CLASS\n"); + + switch (wValue) { + case RH_PORT_SUSPEND: + len = 0; + break; + + case RH_PORT_RESET: + musb_port_reset(1); + len = 0; + break; + + case RH_PORT_POWER: + len = 0; + break; + + case RH_PORT_ENABLE: + len = 0; + break; + + default: + debug("invalid wValue\n"); + stat = USB_ST_STALLED; + } + + port_status |= 1 << wValue; + break; + + case RH_SET_ADDRESS: + debug("RH_SET_ADDRESS\n"); + + rh_devnum = wValue; + len = 0; + break; + + case RH_GET_DESCRIPTOR: + debug("RH_GET_DESCRIPTOR: %x, %d\n", wValue, wLength); + + switch (wValue) { + case (USB_DT_DEVICE << 8): /* device descriptor */ + len = min_t(unsigned int, + leni, min_t(unsigned int, + sizeof(root_hub_dev_des), + wLength)); + data_buf = root_hub_dev_des; + break; + + case (USB_DT_CONFIG << 8): /* configuration descriptor */ + len = min_t(unsigned int, + leni, min_t(unsigned int, + sizeof(root_hub_config_des), + wLength)); + data_buf = root_hub_config_des; + break; + + case ((USB_DT_STRING << 8) | 0x00): /* string 0 descriptors */ + len = min_t(unsigned int, + leni, min_t(unsigned int, + sizeof(root_hub_str_index0), + wLength)); + data_buf = root_hub_str_index0; + break; + + case ((USB_DT_STRING << 8) | 0x01): /* string 1 descriptors */ + len = min_t(unsigned int, + leni, min_t(unsigned int, + sizeof(root_hub_str_index1), + wLength)); + data_buf = root_hub_str_index1; + break; + + default: + debug("invalid wValue\n"); + stat = USB_ST_STALLED; + } + + break; + + case RH_GET_DESCRIPTOR | RH_CLASS: + debug("RH_GET_DESCRIPTOR | RH_CLASS\n"); + + data_buf[0] = 0x09; /* min length; */ + data_buf[1] = 0x29; + data_buf[2] = 0x1; /* 1 port */ + data_buf[3] = 0x01; /* per-port power switching */ + data_buf[3] |= 0x10; /* no overcurrent reporting */ + + /* Corresponds to data_buf[4-7] */ + data_buf[4] = 0; + data_buf[5] = 5; + data_buf[6] = 0; + data_buf[7] = 0x02; + data_buf[8] = 0xff; + + len = min_t(unsigned int, leni, + min_t(unsigned int, data_buf[0], wLength)); + break; + + case RH_GET_CONFIGURATION: + debug("RH_GET_CONFIGURATION\n"); + + *(__u8 *) data_buf = 0x01; + len = 1; + break; + + case RH_SET_CONFIGURATION: + debug("RH_SET_CONFIGURATION\n"); + + len = 0; + break; + + default: + debug("*** *** *** unsupported root hub command *** *** ***\n"); + stat = USB_ST_STALLED; + } + + len = min_t(int, len, leni); + if (buffer != data_buf) + memcpy(buffer, data_buf, len); + + dev->act_len = len; + dev->status = stat; + debug("dev act_len %d, status %d\n", dev->act_len, dev->status); + + return stat; +} + +static void musb_rh_init(void) +{ + rh_devnum = 0; + port_status = 0; +} + +#else + +static void musb_rh_init(void) {} + +#endif + /* * do a control transfer */ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, int len, struct devrequest *setup) { -#ifndef MUSB_NO_MULTIPOINT int devnum = usb_pipedevice(pipe); -#endif u16 csr; u8 devspeed;
+#ifdef MUSB_NO_MULTIPOINT + /* Control message is for the HUB? */ + if (devnum == rh_devnum) + return musb_submit_rh_msg(dev, pipe, buffer, len, setup); +#endif + /* select control endpoint */ writeb(MUSB_CONTROL_EP, &musbr->index); csr = readw(&musbr->txcsr); @@ -649,6 +1072,8 @@ int usb_lowlevel_init(void) u8 power; u32 timeout;
+ musb_rh_init(); + if (musb_platform_init() == -1) return -1;
diff --git a/drivers/usb/musb/musb_hcd.h b/drivers/usb/musb/musb_hcd.h index a437985..dde7d37 100644 --- a/drivers/usb/musb/musb_hcd.h +++ b/drivers/usb/musb/musb_hcd.h @@ -50,6 +50,61 @@ extern unsigned char new[]; ((readb(&musbr->power) & MUSB_POWER_HSMODE) \ >> MUSB_POWER_HSMODE_SHIFT)
+#define min_t(type, x, y) \ + ({ type __x = (x); type __y = (y); __x < __y ? __x : __y; }) + +/* USB HUB CONSTANTS (not OHCI-specific; see hub.h) */ + +/* destination of request */ +#define RH_INTERFACE 0x01 +#define RH_ENDPOINT 0x02 +#define RH_OTHER 0x03 + +#define RH_CLASS 0x20 +#define RH_VENDOR 0x40 + +/* Requests: bRequest << 8 | bmRequestType */ +#define RH_GET_STATUS 0x0080 +#define RH_CLEAR_FEATURE 0x0100 +#define RH_SET_FEATURE 0x0300 +#define RH_SET_ADDRESS 0x0500 +#define RH_GET_DESCRIPTOR 0x0680 +#define RH_SET_DESCRIPTOR 0x0700 +#define RH_GET_CONFIGURATION 0x0880 +#define RH_SET_CONFIGURATION 0x0900 +#define RH_GET_STATE 0x0280 +#define RH_GET_INTERFACE 0x0A80 +#define RH_SET_INTERFACE 0x0B00 +#define RH_SYNC_FRAME 0x0C80 +/* Our Vendor Specific Request */ +#define RH_SET_EP 0x2000 + +/* Hub port features */ +#define RH_PORT_CONNECTION 0x00 +#define RH_PORT_ENABLE 0x01 +#define RH_PORT_SUSPEND 0x02 +#define RH_PORT_OVER_CURRENT 0x03 +#define RH_PORT_RESET 0x04 +#define RH_PORT_POWER 0x08 +#define RH_PORT_LOW_SPEED 0x09 + +#define RH_C_PORT_CONNECTION 0x10 +#define RH_C_PORT_ENABLE 0x11 +#define RH_C_PORT_SUSPEND 0x12 +#define RH_C_PORT_OVER_CURRENT 0x13 +#define RH_C_PORT_RESET 0x14 + +/* Hub features */ +#define RH_C_HUB_LOCAL_POWER 0x00 +#define RH_C_HUB_OVER_CURRENT 0x01 + +#define RH_DEVICE_REMOTE_WAKEUP 0x00 +#define RH_ENDPOINT_STALL 0x01 + +#define RH_ACK 0x01 +#define RH_REQ_ERR -1 +#define RH_NACK 0x00 + /* extern functions */ extern int musb_platform_init(void); extern void musb_platform_deinit(void);
2010/1/9 Mike Frysinger vapier@gentoo.org:
Applied to u-boot-usb Thanks.
Remy
Mike Frysinger
Remy Bohmer
