RE: [U-Boot-Users] 2 flash sizes, starting at different addresses in the same u-boot binary?
Do you know by heart the name of any of these systems?
Thanks and Best Regards
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] In message E7E846FF4F1FE947AABFF850350820780CBFC4@PTLISI051MSX.PT001.SIEMENS.NET you wrote:
I needed to have u-boot support 2 versions of the same hardware, in which the only difference is the flash size. I'm using the
CFI
driver. If in both versions of the hardware the flash started at the same address, the CFI driver would take care of it. However, they don't start at the same address (they must end at the same address). Does anyone has a clue if there is an easy way to have u-boot support these 2 versions in the same binary?
U-Boot does this in a couple of systems. It's not difficult to support such a setup.
Joao, Nuno (ext)
