[PATCH] dm: core: Add address translation in fdt_get_resource
Today of_address_to_resource() is called only in ofnode_read_resource() for livetree support and fdt_get_resource() is called when livetree is not supported.
The fdt_get_resource() doesn't do the address translation so when it is required, but the address translation is done by ofnode_read_resource() caller, for example in drivers/firmware/scmi/smt.c::scmi_dt_get_smt_buffer() { ... ret = ofnode_read_resource(args.node, 0, &resource); if (ret) return ret;
faddr = cpu_to_fdt32(resource.start); paddr = ofnode_translate_address(args.node, &faddr); ...
The both behavior should be aligned and the address translation must be called in fdt_get_resource() and removed for each caller.
Fixes: a44810123f9e ("dm: core: Add dev_read_resource() to read device resources") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
This patch allows to remove the workaround in smci/smt.c introduced by [1].
But it impact with all user of - ofnode_read_resource - ofnode_read_resource_byname - dev_read_resource - dev_read_resource_byname
After my first check, the only impacts are in drivers/net/mscc_eswitch => I remove the unnecessary translate after code review, this patch need to be verify on real hardware
I proposed to merge the workaround [1] as soon as possible to avoid issue on stm32mp1 platform and this patch can be merged when it will be acked by mscc_eswitch maintainers and other API users.
[1] "scmi: translate the resource only when livetree is not activated" http://patchwork.ozlabs.org/project/uboot/list/?series=236526&state=*
drivers/firmware/scmi/smt.c | 12 +----------- drivers/net/mscc_eswitch/jr2_switch.c | 4 +--- drivers/net/mscc_eswitch/ocelot_switch.c | 4 +--- drivers/net/mscc_eswitch/serval_switch.c | 4 +--- drivers/net/mscc_eswitch/servalt_switch.c | 4 +--- lib/fdtdec.c | 6 +++++- 6 files changed, 10 insertions(+), 24 deletions(-)
diff --git a/drivers/firmware/scmi/smt.c b/drivers/firmware/scmi/smt.c index f1915c0074..e60c2aebc8 100644 --- a/drivers/firmware/scmi/smt.c +++ b/drivers/firmware/scmi/smt.c @@ -30,8 +30,6 @@ int scmi_dt_get_smt_buffer(struct udevice *dev, struct scmi_smt *smt) int ret; struct ofnode_phandle_args args; struct resource resource; - fdt32_t faddr; - phys_addr_t paddr;
ret = dev_read_phandle_with_args(dev, "shmem", NULL, 0, 0, &args); if (ret) @@ -41,21 +39,13 @@ int scmi_dt_get_smt_buffer(struct udevice *dev, struct scmi_smt *smt) if (ret) return ret;
- /* TEMP workaround for ofnode_read_resource translation issue */ - if (of_live_active()) { - paddr = resource.start; - } else { - faddr = cpu_to_fdt32(resource.start); - paddr = ofnode_translate_address(args.node, &faddr); - } - smt->size = resource_size(&resource); if (smt->size < sizeof(struct scmi_smt_header)) { dev_err(dev, "Shared memory buffer too small\n"); return -EINVAL; }
- smt->buf = devm_ioremap(dev, paddr, smt->size); + smt->buf = devm_ioremap(dev, resource.start, smt->size); if (!smt->buf) return -ENOMEM;
diff --git a/drivers/net/mscc_eswitch/jr2_switch.c b/drivers/net/mscc_eswitch/jr2_switch.c index 128d7f21ce..bf3e9b56ec 100644 --- a/drivers/net/mscc_eswitch/jr2_switch.c +++ b/drivers/net/mscc_eswitch/jr2_switch.c @@ -842,7 +842,6 @@ static int jr2_probe(struct udevice *dev) int i; int ret; struct resource res; - fdt32_t faddr; phys_addr_t addr_base; unsigned long addr_size; ofnode eth_node, node, mdio_node; @@ -893,9 +892,8 @@ static int jr2_probe(struct udevice *dev)
if (ofnode_read_resource(mdio_node, 0, &res)) return -ENOMEM; - faddr = cpu_to_fdt32(res.start);
- addr_base = ofnode_translate_address(mdio_node, &faddr); + addr_base = res.start; addr_size = res.end - res.start;
/* If the bus is new then create a new bus */ diff --git a/drivers/net/mscc_eswitch/ocelot_switch.c b/drivers/net/mscc_eswitch/ocelot_switch.c index 19e725c6f9..d1d0a489ab 100644 --- a/drivers/net/mscc_eswitch/ocelot_switch.c +++ b/drivers/net/mscc_eswitch/ocelot_switch.c @@ -530,7 +530,6 @@ static int ocelot_probe(struct udevice *dev) struct ocelot_private *priv = dev_get_priv(dev); int i, ret; struct resource res; - fdt32_t faddr; phys_addr_t addr_base; unsigned long addr_size; ofnode eth_node, node, mdio_node; @@ -578,9 +577,8 @@ static int ocelot_probe(struct udevice *dev)
/* If the bus is new then create a new bus */ diff --git a/drivers/net/mscc_eswitch/serval_switch.c b/drivers/net/mscc_eswitch/serval_switch.c index 09ce33452d..c4b81f7529 100644 --- a/drivers/net/mscc_eswitch/serval_switch.c +++ b/drivers/net/mscc_eswitch/serval_switch.c @@ -482,7 +482,6 @@ static int serval_probe(struct udevice *dev) struct serval_private *priv = dev_get_priv(dev); int i, ret; struct resource res; - fdt32_t faddr; phys_addr_t addr_base; unsigned long addr_size; ofnode eth_node, node, mdio_node; @@ -533,9 +532,8 @@ static int serval_probe(struct udevice *dev)
/* If the bus is new then create a new bus */ diff --git a/drivers/net/mscc_eswitch/servalt_switch.c b/drivers/net/mscc_eswitch/servalt_switch.c index 4a4e9e4054..f114086ece 100644 --- a/drivers/net/mscc_eswitch/servalt_switch.c +++ b/drivers/net/mscc_eswitch/servalt_switch.c @@ -412,7 +412,6 @@ static int servalt_probe(struct udevice *dev) struct servalt_private *priv = dev_get_priv(dev); int i; struct resource res; - fdt32_t faddr; phys_addr_t addr_base; unsigned long addr_size; ofnode eth_node, node, mdio_node; @@ -461,9 +460,8 @@ static int servalt_probe(struct udevice *dev)
/* If the bus is new then create a new bus */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 864589193b..4b097fb588 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -942,7 +942,11 @@ int fdt_get_resource(const void *fdt, int node, const char *property,
while (ptr + na + ns <= end) { if (i == index) { - res->start = fdtdec_get_number(ptr, na); + if (CONFIG_IS_ENABLED(OF_TRANSLATE)) + res->start = fdt_translate_address(fdt, node, ptr); + else + res->start = fdtdec_get_number(ptr, na); + res->end = res->start; res->end += fdtdec_get_number(&ptr[na], ns) - 1; return 0;
On Tue, 6 Apr 2021 at 09:38, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
Acked-by: Etienne Carriere etienne.carriere@linaro.org
Regards, Etienne
- dev_read_resource
fdt32_t faddr;
phys_addr_t paddr; ret = dev_read_phandle_with_args(dev, "shmem", NULL, 0, 0, &args); if (ret)
} else {
addr_base = res.start; addr_size = res.end - res.start; /* If the bus is new then create a new bus */
else
-- 2.17.1
The 04/06/2021 09:38, Patrick Delaunay wrote:
Hi Patrick,
I have applied your patches and I have done a basic test on jr2_switch. It seems to work fine. I got some warnings from the function '__of_translate_address' which I need to figure out.
But one more important thing is that also luton_switch should be updated.
- dev_read_resource
fdt32_t faddr;
} else {
else
-- 2.17.1
Hi Horatiu,
Hi Patrick,
Thanks for the tests
I miss 'luton_switch' impact, I will add it in V2.
for information:
I check again all the user:
$> grep -r ofnode_read_resource * | cut -f 1 -d: | xargs
$> grep translate
I don't found any other driver which use translate and get ressource.
Regards
Patrick
Etienne Carriere
Horatiu Vultur
Patrick DELAUNAY
Patrick Delaunay
