[U-Boot-Users] Ebony (440GP) fails to bootp in Linux after U-Boot...
I've been using the the IBM booter that comes with the Ebony and successfully booted my Linux kernel (2.6.8.1 based) on the Ebony. This includes the IBM booter doing tftp, then the kernel running bootp/dhcp and mounting the nfs smoothly.
Lately I've been trying to move to u-boot. Although installation of u-boot to the flash and booting u-boot went quite fine, I'm unable to finish the kernel boot process.
First I generated a kernel for the IBM booter using the make and tftp-loaded zImage.ebony. Everything works fine. Then switched to the u-boot flash (using U46 SW1). Then I generated the linux kernel using "make uImage", using "tftpbootm 0x500000 /somewhere/uImage ; bootm 0x50000". (IBM booter used same 0x500000 address).
It loads nicely then just keeps trying to "BOOTP". Configuring the IP by hand just moves the problem later to the NFS mounting process since no ethernet traffic exists.
I did notice that the kernel doesn't automatically load the u-boot MAC address correctly (kernel originally showed MAC is ff:ff:ff:ff:ff:ff on u-boot), so for the time being I patched the source of the MAC and inserted it by hand into the kernel code (now the kernel shows the correct MAC when booting). Again, this runs fine on the IBM booter.
However, after I boot using u-boot, there doesn't seem to be any traffic coming from the kernel (monitored using ethereal). I turned on some debugging features in the 440GP EMAC driver, and it seems that the EMAC driver gets request to transmit the BOOTP request, but nothing comes in or out.
Anyone have any solutions for this?!?
Please help me out.
Many thanks, Rani Glaser ranig <at> go-wlan.com
In message 699F7BBB368A10479166148511F524173D7149@gn-ex01.Go80211.com you wrote:
Did you modify your kernel to work with U-Boot (i. e. did you include ppcboot.h in your board header file) ?
This probably means that your kernel does not pick up the arguments passed by U-Boot. This is a FAQ (see http://www.denx.de/twiki/bin/view/DULG/LinuxHangsAfterUncompressingKernel)
RTFM ?
Rani Glaser
