[U-Boot] [PATCH] efi_loader: Rename EFI_RUNTIME_{TEXT, DATA} to __efi_runtime{, _data}
Compiler attributes are more commonly __foo style tags rather than big upper case eye sores like EFI_RUNTIME_TEXT.
Simon Glass felt quite strongly about this, so this patch converts our existing defines over to more eye friendly ones.
Signed-off-by: Alexander Graf agraf@suse.de --- arch/arm/cpu/armv8/fwcall.c | 12 ++++++------ include/efi_loader.h | 12 ++++++------ lib/efi_loader/efi_boottime.c | 6 +++--- lib/efi_loader/efi_runtime.c | 20 ++++++++++---------- 4 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/arch/arm/cpu/armv8/fwcall.c b/arch/arm/cpu/armv8/fwcall.c index 64539f9..7dfd270 100644 --- a/arch/arm/cpu/armv8/fwcall.c +++ b/arch/arm/cpu/armv8/fwcall.c @@ -18,7 +18,7 @@ * x0~x7: input arguments * x0~x3: output arguments */ -static void EFI_RUNTIME_TEXT hvc_call(struct pt_regs *args) +static void __efi_runtime hvc_call(struct pt_regs *args) { asm volatile( "ldr x0, %0\n" @@ -52,7 +52,7 @@ static void EFI_RUNTIME_TEXT hvc_call(struct pt_regs *args) * x0~x3: output arguments */
-void EFI_RUNTIME_TEXT smc_call(struct pt_regs *args) +void __efi_runtime smc_call(struct pt_regs *args) { asm volatile( "ldr x0, %0\n" @@ -82,9 +82,9 @@ void EFI_RUNTIME_TEXT smc_call(struct pt_regs *args) * use PSCI on U-Boot running below a hypervisor, please detect * this and set the flag accordingly. */ -static const EFI_RUNTIME_DATA bool use_smc_for_psci = true; +static const __efi_runtime_data bool use_smc_for_psci = true;
-void __noreturn EFI_RUNTIME_TEXT psci_system_reset(void) +void __noreturn __efi_runtime psci_system_reset(void) { struct pt_regs regs;
@@ -99,7 +99,7 @@ void __noreturn EFI_RUNTIME_TEXT psci_system_reset(void) ; }
-void __noreturn EFI_RUNTIME_TEXT psci_system_off(void) +void __noreturn __efi_runtime psci_system_off(void) { struct pt_regs regs;
@@ -121,7 +121,7 @@ void reset_misc(void) }
#ifdef CONFIG_EFI_LOADER -void EFI_RUNTIME_TEXT EFIAPI efi_reset_system( +void __efi_runtime EFIAPI efi_reset_system( enum efi_reset_type reset_type, efi_status_t reset_status, unsigned long data_size, void *reset_data) diff --git a/include/efi_loader.h b/include/efi_loader.h index 871499f..35b3fe2 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -156,8 +156,8 @@ static inline void ascii2unicode(u16 *unicode, const char *ascii) * Use these to indicate that your code / data should go into the EFI runtime * section and thus still be available when the OS is running */ -#define EFI_RUNTIME_DATA __attribute__ ((section ("efi_runtime_data"))) -#define EFI_RUNTIME_TEXT __attribute__ ((section ("efi_runtime_text"))) +#define __efi_runtime_data __attribute__ ((section ("efi_runtime_data"))) +#define __efi_runtime __attribute__ ((section ("efi_runtime_text")))
/* Call this with mmio_ptr as the _pointer_ to a pointer to an MMIO region * to make it available at runtime */ @@ -165,13 +165,13 @@ void efi_add_runtime_mmio(void *mmio_ptr, u64 len);
/* Boards may provide the functions below to implement RTS functionality */
-void EFI_RUNTIME_TEXT EFIAPI efi_reset_system( +void __efi_runtime EFIAPI efi_reset_system( enum efi_reset_type reset_type, efi_status_t reset_status, unsigned long data_size, void *reset_data); void efi_reset_system_init(void);
-efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_get_time( +efi_status_t __efi_runtime EFIAPI efi_get_time( struct efi_time *time, struct efi_time_cap *capabilities); void efi_get_time_init(void); @@ -179,8 +179,8 @@ void efi_get_time_init(void); #else /* defined(EFI_LOADER) && !defined(CONFIG_SPL_BUILD) */
/* Without CONFIG_EFI_LOADER we don't have a runtime section, stub it out */ -#define EFI_RUNTIME_DATA -#define EFI_RUNTIME_TEXT +#define __efi_runtime_data +#define __efi_runtime static inline void efi_add_runtime_mmio(void **mmio_ptr, u64 len) { }
/* No loader configured, stub out EFI_ENTRY */ diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 476ef1b..1fdddf4 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -37,7 +37,7 @@ static bool efi_is_direct_boot = true; * In most cases we want to pass an FDT to the payload, so reserve one slot of * config table space for it. The pointer gets populated by do_bootefi_exec(). */ -static struct efi_configuration_table EFI_RUNTIME_DATA efi_conf_table[2]; +static struct efi_configuration_table __efi_runtime_data efi_conf_table[2];
#ifdef CONFIG_ARM /* @@ -790,10 +790,10 @@ static const struct efi_boot_services efi_boot_services = { };
-static uint16_t EFI_RUNTIME_DATA firmware_vendor[] = +static uint16_t __efi_runtime_data firmware_vendor[] = { 'D','a','s',' ','U','-','b','o','o','t',0 };
-struct efi_system_table EFI_RUNTIME_DATA systab = { +struct efi_system_table __efi_runtime_data systab = { .hdr = { .signature = EFI_SYSTEM_TABLE_SIGNATURE, .revision = 0x20005, /* 2.5 */ diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index f007ca6..dd52755 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -26,9 +26,9 @@ struct efi_runtime_mmio_list { /* This list contains all runtime available mmio regions */ LIST_HEAD(efi_runtime_mmio);
-static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_unimplemented(void); -static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_device_error(void); -static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_invalid_parameter(void); +static efi_status_t __efi_runtime EFIAPI efi_unimplemented(void); +static efi_status_t __efi_runtime EFIAPI efi_device_error(void); +static efi_status_t __efi_runtime EFIAPI efi_invalid_parameter(void);
#ifdef CONFIG_SYS_CACHELINE_SIZE #define EFI_CACHELINE_SIZE CONFIG_SYS_CACHELINE_SIZE @@ -125,7 +125,7 @@ static efi_status_t EFIAPI efi_get_time_boottime(
/* Boards may override the helpers below to implement RTS functionality */
-void __weak EFI_RUNTIME_TEXT EFIAPI efi_reset_system( +void __weak __efi_runtime EFIAPI efi_reset_system( enum efi_reset_type reset_type, efi_status_t reset_status, unsigned long data_size, void *reset_data) @@ -138,7 +138,7 @@ void __weak efi_reset_system_init(void) { }
-efi_status_t __weak EFI_RUNTIME_TEXT EFIAPI efi_get_time( +efi_status_t __weak __efi_runtime EFIAPI efi_get_time( struct efi_time *time, struct efi_time_cap *capabilities) { @@ -346,7 +346,7 @@ void efi_add_runtime_mmio(void *mmio_ptr, u64 len) * function or variable below this line. * * Please keep everything fully self-contained and annotated with - * EFI_RUNTIME_TEXT and EFI_RUNTIME_DATA markers. + * __efi_runtime and __efi_runtime_data markers. */
/* @@ -355,22 +355,22 @@ void efi_add_runtime_mmio(void *mmio_ptr, u64 len) * address map calls. */
-static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_unimplemented(void) +static efi_status_t __efi_runtime EFIAPI efi_unimplemented(void) { return EFI_UNSUPPORTED; }
-static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_device_error(void) +static efi_status_t __efi_runtime EFIAPI efi_device_error(void) { return EFI_DEVICE_ERROR; }
-static efi_status_t EFI_RUNTIME_TEXT EFIAPI efi_invalid_parameter(void) +static efi_status_t __efi_runtime EFIAPI efi_invalid_parameter(void) { return EFI_INVALID_PARAMETER; }
-struct efi_runtime_services EFI_RUNTIME_DATA efi_runtime_services = { +struct efi_runtime_services __efi_runtime_data efi_runtime_services = { .hdr = { .signature = EFI_RUNTIME_SERVICES_SIGNATURE, .revision = EFI_RUNTIME_SERVICES_REVISION,
Signed-off-by: Alexander Graf agraf@suse.de Reviewed-by: Simon Glass sjg@chromium.org
Thanks, applied to efi-next
Alexander Graf
