[U-Boot] [PATCH] dts: re-write dts/Makefile more simply with Kbuild
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code.
We do not need to parse a linker script to get output format and arch.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
This patch uses my Kbuild series as a prerequisite. "Switch over to real Kbuild" series must be applied beforehand.
.gitignore | 1 - Makefile | 16 +++++----- arch/arm/lib/board.c | 2 +- arch/microblaze/lib/board.c | 2 +- arch/x86/lib/init_helpers.c | 2 +- common/board_f.c | 2 +- dts/.gitignore | 2 ++ dts/Makefile | 72 +++++++++++++-------------------------------- include/common.h | 2 +- scripts/Makefile.lib | 12 ++++---- 10 files changed, 41 insertions(+), 72 deletions(-) create mode 100644 dts/.gitignore
diff --git a/.gitignore b/.gitignore index 24019b3..5882ff5 100644 --- a/.gitignore +++ b/.gitignore @@ -48,7 +48,6 @@ /u-boot.lds /u-boot.ubl /u-boot.ais -/u-boot.dtb /u-boot.sb
# diff --git a/Makefile b/Makefile index 3bf759a..ab82ed4 100644 --- a/Makefile +++ b/Makefile @@ -743,7 +743,7 @@ ALL-$(CONFIG_RAMBOOT_PBL) += u-boot.pbl ALL-$(CONFIG_SPL) += spl/u-boot-spl.bin ALL-$(CONFIG_SPL_FRAMEWORK) += u-boot.img ALL-$(CONFIG_TPL) += tpl/u-boot-tpl.bin -ALL-$(CONFIG_OF_SEPARATE) += u-boot.dtb u-boot-dtb.bin +ALL-$(CONFIG_OF_SEPARATE) += u-boot-dtb.bin ifneq ($(CONFIG_SPL_TARGET),) ALL-$(CONFIG_SPL) += $(CONFIG_SPL_TARGET:"%"=%) endif @@ -767,11 +767,11 @@ endif
all: $(ALL-y)
-u-boot.dtb: checkdtc u-boot - $(MAKE) $(build)=dts binary - mv dts/dt.dtb $@ +PHONY += dtbs +dtbs dts/dt.dtb: checkdtc u-boot + $(Q)$(MAKE) $(build)=dts dtbs
-u-boot-dtb.bin: u-boot.bin u-boot.dtb +u-boot-dtb.bin: u-boot.bin dts/dt.dtb cat $^ >$@
u-boot.hex: u-boot @@ -898,8 +898,8 @@ u-boot-nodtb-tegra.bin: spl/u-boot-spl.bin u-boot.bin rm spl/u-boot-spl-pad.bin
ifeq ($(CONFIG_OF_SEPARATE),y) -u-boot-dtb-tegra.bin: u-boot-nodtb-tegra.bin u-boot.dtb - cat u-boot-nodtb-tegra.bin u-boot.dtb > $@ +u-boot-dtb-tegra.bin: u-boot-nodtb-tegra.bin dts/dt.dtb + cat $^ > $@ endif endif
@@ -1184,7 +1184,7 @@ CLOBBER_DIRS += tpl \ $(shell ls -1 --file-type spl 2>/dev/null)))) CLOBBER_FILES += u-boot u-boot.elf u-boot.hex u-boot.img \ u-boot.kwb u-boot.pbl u-boot.ldr \ - u-boot.ubl u-boot.ais u-boot.dtb \ + u-boot.ubl u-boot.ais \ u-boot.sb u-boot.spr MLO MLO.byteswap SPL \ $(patsubst %,spl/%, $(filter-out Makefile %/, \ $(shell ls -1 --file-type spl 2>/dev/null))) \ diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index b770e25..c8cb049 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -280,7 +280,7 @@ void board_init_f(ulong bootflag) gd->mon_len = _bss_end_ofs; #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_db_begin #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (void *)(_end_ofs + _TEXT_BASE); diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index 896e73a..0f10c88 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -76,7 +76,7 @@ void board_init_f(ulong not_used)
#ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (void *)__end; diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index 582c0ff..b5d937f 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -92,7 +92,7 @@ int find_fdt(void) { #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ gd->fdt_blob = (ulong *)&_end; diff --git a/common/board_f.c b/common/board_f.c index aa70c3e..d0ee6f7 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -360,7 +360,7 @@ static int setup_fdt(void) { #ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ - gd->fdt_blob = _binary_dt_dtb_start; + gd->fdt_blob = __dtb_dt_begin; #elif defined CONFIG_OF_SEPARATE /* FDT is at end of image */ # ifdef CONFIG_SYS_SYM_OFFSETS diff --git a/dts/.gitignore b/dts/.gitignore new file mode 100644 index 0000000..1b37180 --- /dev/null +++ b/dts/.gitignore @@ -0,0 +1,2 @@ +*.dtb +*.dtb.S diff --git a/dts/Makefile b/dts/Makefile index 1e7609a..c47fba7 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -7,64 +7,32 @@ # This Makefile builds the internal U-Boot fdt if CONFIG_OF_CONTROL is # enabled. See doc/README.fdt-control for more details.
-DTS_INCDIRS = $(SRCTREE)/board/$(VENDOR)/$(BOARD)/dts -DTS_INCDIRS += $(SRCTREE)/board/$(VENDOR)/dts -DTS_INCDIRS += $(SRCTREE)/arch/$(ARCH)/dts +DEVICE_TREE ?= $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%) +ifeq ($(DEVICE_TREE),) +DEVICE_TREE := notfound +endif
-DTS_CPPFLAGS := -x assembler-with-cpp -undef -D__DTS__ \ - -nostdinc $(addprefix -I,$(DTS_INCDIRS)) +DTS := $(srctree)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts
-DTC_FLAGS := -R 4 -p 0x1000 \ - $(addprefix -i ,$(DTS_INCDIRS)) +DTC_FLAGS += -i $(srctree)/arch/$(ARCH)/dts -R 4 -p 0x1000
-# Use a constant name for this so we can access it from C code. -# objcopy doesn't seem to allow us to set the symbol name independently of -# the filename. -DT_BIN := $(obj)/dt.dtb +$(obj)/dt.dtb: $(DTS) FORCE + $(call if_changed_dep,dtc)
-DEVICE_TREE ?= $(CONFIG_DEFAULT_DEVICE_TREE:"%"=%) -ifeq ($(DEVICE_TREE),) -$(DT_BIN): FORCE - echo >&2 "Please define CONFIG_DEFAULT_DEVICE_TREE in your board header file" -else -$(DT_BIN): $(TOPDIR)/board/$(VENDOR)/dts/$(DEVICE_TREE).dts - $(CPP) $(DTS_CPPFLAGS) $< -o $(DT_BIN).dts.tmp - $(DTC) $(DTC_FLAGS) -O dtb -o ${DT_BIN} $(DT_BIN).dts.tmp -endif +targets += dt.dtb
-process_lds = \ - $(1) | sed -r -n 's/^OUTPUT_$(2)[ ("]*([^")]*).*/\1/p' +$(DTS): + @echo >&2 + @echo >&2 "Device Tree Source is not specified." + @echo >&2 "Please define 'CONFIG_DEFAULT_DEVICE_TREE'" + @echo >&2 "or build with 'DEVICE_TREE=<dts-file-name>' argument" + @/bin/false
-# Run the compiler and get the link script from the linker -GET_LDS = $(CC) $(c_flags) $(ld_flags) -Wl,--verbose 2>&1 +.SECONDARY: $(obj)/dt.dtb.S
-$(obj)/dt.o: $(DT_BIN) - # We want the output format and arch. - # We also hope to win a prize for ugliest Makefile / shell interaction - # We look in the LDSCRIPT first. - # Then try the linker which should give us the answer. - # Then check it worked. - [ -n "$(LDSCRIPT)" ] && \ - oformat=`$(call process_lds,cat $(LDSCRIPT),FORMAT)` && \ - oarch=`$(call process_lds,cat $(LDSCRIPT),ARCH)` ;\ - \ - [ -z $${oformat} ] && \ - oformat=`$(call process_lds,$(GET_LDS),FORMAT)` ;\ - [ -z $${oarch} ] && \ - oarch=`$(call process_lds,$(GET_LDS),ARCH)` ;\ - \ - [ -z $${oformat} ] && \ - echo "Cannot read OUTPUT_FORMAT from lds file $(LDSCRIPT)" && \ - exit 1 || true ;\ - [ -z $${oarch} ] && \ - echo "Cannot read OUTPUT_ARCH from lds file $(LDSCRIPT)" && \ - exit 1 || true ;\ - \ - cd $(dir ${DT_BIN}) && \ - $(OBJCOPY) -I binary -O $${oformat} -B $${oarch} \ - $(notdir ${DT_BIN}) $(notdir $@) - rm $(DT_BIN) +obj-$(CONFIG_OF_EMBED) := dt.dtb.o
-obj-$(CONFIG_OF_EMBED) := dt.o +dtbs: $(obj)/dt.dtb + @:
-binary: $(DT_BIN) +clean-files := dt.dtb.S diff --git a/include/common.h b/include/common.h index c15e5a4..b590f3a 100644 --- a/include/common.h +++ b/include/common.h @@ -302,7 +302,7 @@ int checkdram (void); int last_stage_init(void); extern ulong monitor_flash_len; int mac_read_from_eeprom(void); -extern u8 _binary_dt_dtb_start[]; /* embedded device tree blob */ +extern u8 __dtb_dt_begin[]; /* embedded device tree blob */ int set_cpu_clk_info(void); int print_cpuinfo(void); int update_flash_size(int flash_size); diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index d4b5cb5..ee3ceac 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -151,9 +151,10 @@ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \
ld_flags = $(LDFLAGS) $(ldflags-y)
+# Modified for U-Boot dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ - -I$(srctree)/arch/$(SRCARCH)/boot/dts \ - -I$(srctree)/arch/$(SRCARCH)/boot/dts/include \ + -I$(srctree)/board/$(VENDOR)/dts/ \ + -I$(srctree)/arch/$(ARCH)/dts \ -undef -D__DTS__
# Finds the multi-part object the current object will be linked into @@ -247,25 +248,24 @@ cmd_gzip = (cat $(filter-out FORCE,$^) | gzip -n -f -9 > $@) || \
# Generate an assembly file to wrap the output of the device tree compiler quiet_cmd_dt_S_dtb= DTB $@ +# Modified for U-Boot cmd_dt_S_dtb= \ ( \ - echo '#include <asm-generic/vmlinux.lds.h>'; \ echo '.section .dtb.init.rodata,"a"'; \ - echo '.balign STRUCT_ALIGNMENT'; \ echo '.global __dtb_$(*F)_begin'; \ echo '__dtb_$(*F)_begin:'; \ echo '.incbin "$<" '; \ echo '__dtb_$(*F)_end:'; \ echo '.global __dtb_$(*F)_end'; \ - echo '.balign STRUCT_ALIGNMENT'; \ ) > $@
$(obj)/%.dtb.S: $(obj)/%.dtb $(call cmd,dt_S_dtb)
quiet_cmd_dtc = DTC $@ +# Modified for U-Boot cmd_dtc = $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ - $(objtree)/scripts/dtc/dtc -O dtb -o $@ -b 0 \ + dtc -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \ cat $(depfile).pre.tmp $(depfile).dtc.tmp > $(depfile)
Hi Masahiro,
Great, another benefit from the Kbuild changes!
I think we should still generate this file in the root directory, since some build systems will need to use it.
Ultimately we should support generating multiple .dtbs with the U-Boot build system. I will see if I have a patch for that somewhere...
/u-boot.sb
all: $(ALL-y)
mv dts/dt.dtb $@
cat $^ > $@
endif endif
Needs ; on the end I think.
-process_lds = \
+$(DTS):
@echo >&2
@/bin/false
exit 1 || true ;\
exit 1 || true ;\
rm $(DT_BIN)
echo '\#include <asm-generic/vmlinux.lds.h>'; \ echo '.section .dtb.init.rodata,"a"'; \
-- 1.8.3.2
Hello Simon,
I saw the patch you posted http://patchwork.ozlabs.org/patch/315846/ and I understood what you want to do. (But I don't like to search similar device trees with file name prefixes.)
Do you like ARM Linux style? dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ exynos5420-smdk5420.dtb
Please check v2.
I vote for removal of ./u-boot.dts because I do not want to have many copies.
If we adopt multiple DTBs generation, we will have three copies: - arch/arm/dts/exynosXXX.dtb - dts/dt.dtb - ./u-boot.dtb
But, if you really need a DTB at the top directory, I can revive u-boot.dtb at version 3.
Good catch! I fixed it at v2. Thanks.
Best Regards Masahiro Yamada
Hi Masahiro,
On 4 February 2014 03:00, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon,
Please check v2.
Agreed, I don't like the prefix idea either.
u-boot.dtb you mean?
This is the correct one
- dts/dt.dtb
This is a temporary file, probably deleted during the build. I'm not even sure if it is created when you are building multiple files. Perhaps it use just used for CONFIG_OF_EMBED?
- ./u-boot.dtb
For now I think there is a 'default' .dtb for each board config. After all U-Boot does not have a way to select between several of them at runtime. So it makes sense for this one to be made available as it currently is I think. Perhaps it could be a symlink to the real one?
Hello Simon,
- dts/dt.dtb
No. It is a temporary file, but it must not be deleted during the build. Otherwise, dts/dt.dtb will be re-generated at every build even when it shouldn't.
My patch is using dts/dt.dtb for both CONFIG_OF_EMBED and CONFIG_OF_SEPARTE.
If you don't want to generate dts/dt.dtb at all, most of lines in dts/Makefile must be moved to the top Makefile, which leads we get the top Makefile fatter and dirtier.
- ./u-boot.dtb
Creating a symbolic link during the build is generally troublesome and a bad idea, I think.
Masahiro Yamada
