[U-Boot] [PATCH] The _config target is not present anymore, mention _defconfig instead
The _config part is gone for sure, the _defconfig target could at least work. I have not verified this for all targets though. --- README | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/README b/README index f704eb3..5dce2c2 100644 --- a/README +++ b/README @@ -252,15 +252,15 @@ Selection of Processor Architecture and Board Type: ---------------------------------------------------
For all supported boards there are ready-to-use default -configurations available; just type "make <board_name>_config". +configurations available; just type "make <board_name>_defconfig".
Example: For a TQM823L module type:
cd u-boot - make TQM823L_config + make TQM823L_defconfig
For the Cogent platform, you need to specify the CPU type as well; -e.g. "make cogent_mpc8xx_config". And also configure the cogent +e.g. "make cogent_mpc8xx_defconfig". And also configure the cogent directory according to the instructions in cogent/README.
@@ -4840,9 +4840,9 @@ U-Boot is intended to be simple to build. After installing the sources you must configure U-Boot for one specific board type. This is done by typing:
- make NAME_config + make NAME_defconfig
-where "NAME_config" is the name of one of the existing configu- +where "NAME_defconfig" is the name of one of the existing configu- rations; see boards.cfg for supported names.
Note: for some board special configuration names may exist; check if @@ -4851,10 +4851,10 @@ Note: for some board special configuration names may exist; check if or with LCD support. You can select such additional "features" when choosing the configuration, i. e.
- make TQM823L_config + make TQM823L_defconfig - will configure for a plain TQM823L, i. e. no LCD support
- make TQM823L_LCD_config + make TQM823L_LCD_defconfig - will configure for a TQM823L with U-Boot console on LCD
etc. @@ -4874,14 +4874,14 @@ this behavior and build U-Boot to some external directory: 1. Add O= to the make command line invocations:
make O=/tmp/build distclean - make O=/tmp/build NAME_config + make O=/tmp/build NAME_defconfig make O=/tmp/build all
2. Set environment variable BUILD_DIR to point to the desired location:
export BUILD_DIR=/tmp/build make distclean - make NAME_config + make NAME_defconfig make all
Note that the command line "O=" setting overrides the BUILD_DIR environment @@ -4907,7 +4907,7 @@ steps: your board 3. If you're porting U-Boot to a new CPU, then also create a new directory to hold your CPU specific code. Add any files you need. -4. Run "make <board>_config" with your new name. +4. Run "make <board>_defconfig" with your new name. 5. Type "make", and you should get a working "u-boot.srec" file to be installed on your target system. 6. Debug and solve any problems that might arise. @@ -5487,7 +5487,7 @@ which was introduced for our predecessor project PPCBoot and uses a
Example:
- make TQM850L_config + make TQM850L_defconfig make oldconfig make dep make uImage
Holger Hans Peter Freyther
