[U-Boot] [Patch v2 0/3] Enable network support on at91sam9n12ek board
This patch set based on the following patch set: - arm: at91: add at91sam9n12ek board support - http://patchwork.ozlabs.org/patch/237184/
And implement the following things - add ignore for network block comment style checking - add ks8851_16mll ethernet driver - Enable network support on at91sam9n12ek board.
Bo Shen (2): checkpatch: add ignore for network block comment style checking ARM: at91sam9n12: add network support with ksz8851_16mll
Roberto Cerati (1): net: ks8851_mll: add ethernet support
.checkpatch.conf | 3 + board/atmel/at91sam9n12ek/at91sam9n12ek.c | 36 ++ drivers/net/Makefile | 1 + drivers/net/ks8851_mll.c | 645 +++++++++++++++++++++++++++++ drivers/net/ks8851_mll.h | 357 ++++++++++++++++ include/configs/at91sam9n12ek.h | 4 + include/netdev.h | 1 + 7 files changed, 1047 insertions(+) create mode 100644 drivers/net/ks8851_mll.c create mode 100644 drivers/net/ks8851_mll.h
When use checkpatch.pl to check network related patch, it will report --->8--- WARNING: networking block comments don't use an empty /* line, use /* Comment... ---<8---
So, add --ignore NETWORKING_BLOCK_COMMENT_STYLE into .checkpatch.conf This will help to keep all driver include network related driver use the same comment style
Signed-off-by: Bo Shen voice.shen@atmel.com --- Change in v2 New patch added --- .checkpatch.conf | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/.checkpatch.conf b/.checkpatch.conf index d88af57..35167e1 100644 --- a/.checkpatch.conf +++ b/.checkpatch.conf @@ -18,3 +18,6 @@
# Not Linux, so we don't recommend usleep_range() over udelay() --ignore USLEEP_RANGE + +# Ignore networking block comment style +--ignore NETWORKING_BLOCK_COMMENT_STYLE
The device interface is 16 bits wide. All the available packets are read from the incoming fifo.
Signed-off-by: Roberto Cerati roberto.cerati@bticino.it Signed-off-by: Raffaele Recalcati raffaele.recalcati@bticino.it [voice.shen@atmel.com: address comments from review results] [voice.shen@atmel.com: clean up for submit] Signed-off-by: Bo Shen voice.shen@atmel.com --- Change in v2 - keep the comment style the same with other drivers - remove tab between #define and micro --- drivers/net/Makefile | 1 + drivers/net/ks8851_mll.c | 645 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ks8851_mll.h | 357 +++++++++++++++++++++++++ include/netdev.h | 1 + 4 files changed, 1004 insertions(+) create mode 100644 drivers/net/ks8851_mll.c create mode 100644 drivers/net/ks8851_mll.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 786a656..f4cc072 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -50,6 +50,7 @@ COBJS-$(CONFIG_FTMAC100) += ftmac100.o COBJS-$(CONFIG_GRETH) += greth.o COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o +COBJS-$(CONFIG_KS8851_MLL) += ks8851_mll.o COBJS-$(CONFIG_LAN91C96) += lan91c96.o COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o diff --git a/drivers/net/ks8851_mll.c b/drivers/net/ks8851_mll.c new file mode 100644 index 0000000..b02d59a --- /dev/null +++ b/drivers/net/ks8851_mll.c @@ -0,0 +1,645 @@ +/* + * Micrel KS8851_MLL 16bit Network driver + * Copyright (c) 2011 Roberto Cerati roberto.cerati@bticino.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <net.h> +#include <miiphy.h> + +#include "ks8851_mll.h" + +#define DRIVERNAME "ks8851_mll" + +#define MAX_RECV_FRAMES 32 +#define MAX_BUF_SIZE 2048 +#define TX_BUF_SIZE 2000 +#define RX_BUF_SIZE 2000 + +static const struct chip_id chip_ids[] = { + {CIDER_ID, "KSZ8851"}, + {0, NULL}, +}; + +/* + * union ks_tx_hdr - tx header data + * @txb: The header as bytes + * @txw: The header as 16bit, little-endian words + * + * A dual representation of the tx header data to allow + * access to individual bytes, and to allow 16bit accesses + * with 16bit alignment. + */ +union ks_tx_hdr { + u8 txb[4]; + __le16 txw[2]; +}; + +/* + * struct ks_net - KS8851 driver private data + * @net_device : The network device we're bound to + * @txh : temporaly buffer to save status/length. + * @frame_head_info : frame header information for multi-pkt rx. + * @statelock : Lock on this structure for tx list. + * @msg_enable : The message flags controlling driver output (see ethtool). + * @frame_cnt : number of frames received. + * @bus_width : i/o bus width. + * @irq : irq number assigned to this device. + * @rc_rxqcr : Cached copy of KS_RXQCR. + * @rc_txcr : Cached copy of KS_TXCR. + * @rc_ier : Cached copy of KS_IER. + * @sharedbus : Multipex(addr and data bus) mode indicator. + * @cmd_reg_cache : command register cached. + * @cmd_reg_cache_int : command register cached. Used in the irq handler. + * @promiscuous : promiscuous mode indicator. + * @all_mcast : mutlicast indicator. + * @mcast_lst_size : size of multicast list. + * @mcast_lst : multicast list. + * @mcast_bits : multicast enabed. + * @mac_addr : MAC address assigned to this device. + * @fid : frame id. + * @extra_byte : number of extra byte prepended rx pkt. + * @enabled : indicator this device works. + */ + +/* Receive multiplex framer header info */ +struct type_frame_head { + u16 sts; /* Frame status */ + u16 len; /* Byte count */ +} fr_h_i[MAX_RECV_FRAMES]; + +struct ks_net { + struct net_device *netdev; + union ks_tx_hdr txh; + struct type_frame_head *frame_head_info; + u32 msg_enable; + u32 frame_cnt; + int bus_width; + int irq; + u16 rc_rxqcr; + u16 rc_txcr; + u16 rc_ier; + u16 sharedbus; + u16 cmd_reg_cache; + u16 cmd_reg_cache_int; + u16 promiscuous; + u16 all_mcast; + u16 mcast_lst_size; + u8 mcast_lst[MAX_MCAST_LST][MAC_ADDR_LEN]; + u8 mcast_bits[HW_MCAST_SIZE]; + u8 mac_addr[6]; + u8 fid; + u8 extra_byte; + u8 enabled; +} ks_str, *ks; + +#define BE3 0x8000 /* Byte Enable 3 */ +#define BE2 0x4000 /* Byte Enable 2 */ +#define BE1 0x2000 /* Byte Enable 1 */ +#define BE0 0x1000 /* Byte Enable 0 */ + +static u8 ks_rdreg8(struct eth_device *dev, u16 offset) +{ + u8 shift_bit = offset & 0x03; + u8 shift_data = (offset & 1) << 3; + + writew(offset | (BE0 << shift_bit), dev->iobase + 2); + + return (u8)(readw(dev->iobase) >> shift_data); +} + +static u16 ks_rdreg16(struct eth_device *dev, u16 offset) +{ + writew(offset | ((BE1 | BE0) << (offset & 0x02)), dev->iobase + 2); + + return readw(dev->iobase); +} + +static void ks_wrreg8(struct eth_device *dev, u16 offset, u8 val) +{ + u8 shift_bit = (offset & 0x03); + u16 value_write = (u16)(val << ((offset & 1) << 3)); + + writew(offset | (BE0 << shift_bit), dev->iobase + 2); + writew(value_write, dev->iobase); +} + +static void ks_wrreg16(struct eth_device *dev, u16 offset, u16 val) +{ + writew(offset | ((BE1 | BE0) << (offset & 0x02)), dev->iobase + 2); + writew(val, dev->iobase); +} + +/* + * ks_inblk - read a block of data from QMU. This is called after sudo DMA mode + * enabled. + * @ks: The chip state + * @wptr: buffer address to save data + * @len: length in byte to read + */ +static inline void ks_inblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + len >>= 1; + + while (len--) + *wptr++ = readw(dev->iobase); +} + +/* + * ks_outblk - write data to QMU. This is called after sudo DMA mode enabled. + * @ks: The chip information + * @wptr: buffer address + * @len: length in byte to write + */ +static inline void ks_outblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + len >>= 1; + + while (len--) + writew(*wptr++, dev->iobase); +} + +static void ks_enable_int(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_IER, ks->rc_ier); +} + +static void ks_set_powermode(struct eth_device *dev, unsigned pwrmode) +{ + unsigned pmecr; + + ks_rdreg16(dev, KS_GRR); + pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_PM_MASK; + pmecr |= pwrmode; + + ks_wrreg16(dev, KS_PMECR, pmecr); +} + +/* + * ks_read_config - read chip configuration of bus width. + * @ks: The chip information + */ +static void ks_read_config(struct eth_device *dev) +{ + u16 reg_data = 0; + + /* Regardless of bus width, 8 bit read should always work. */ + reg_data = ks_rdreg8(dev, KS_CCR) & 0x00FF; + reg_data |= ks_rdreg8(dev, KS_CCR + 1) << 8; + + /* addr/data bus are multiplexed */ + ks->sharedbus = (reg_data & CCR_SHARED) == CCR_SHARED; + + /* + * There are garbage data when reading data from QMU, + * depending on bus-width. + */ + if (reg_data & CCR_8BIT) { + ks->bus_width = ENUM_BUS_8BIT; + ks->extra_byte = 1; + } else if (reg_data & CCR_16BIT) { + ks->bus_width = ENUM_BUS_16BIT; + ks->extra_byte = 2; + } else { + ks->bus_width = ENUM_BUS_32BIT; + ks->extra_byte = 4; + } +} + +/* + * ks_soft_reset - issue one of the soft reset to the device + * @ks: The device state. + * @op: The bit(s) to set in the GRR + * + * Issue the relevant soft-reset command to the device's GRR register + * specified by @op. + * + * Note, the delays are in there as a caution to ensure that the reset + * has time to take effect and then complete. Since the datasheet does + * not currently specify the exact sequence, we have chosen something + * that seems to work with our device. + */ +static void ks_soft_reset(struct eth_device *dev, unsigned op) +{ + /* Disable interrupt first */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_GRR, op); + mdelay(10); /* wait a short time to effect reset */ + ks_wrreg16(dev, KS_GRR, 0); + mdelay(1); /* wait for condition to clear */ +} + +void ks_enable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Enables QMU Transmit (TXCR). */ + ks_wrreg16(dev, KS_TXCR, w | TXCR_TXE); + + /* Enable RX Frame Count Threshold and Auto-Dequeue RXQ Frame */ + w = ks_rdreg16(dev, KS_RXQCR); + ks_wrreg16(dev, KS_RXQCR, w | RXQCR_RXFCTE); + + /* Enables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + ks_wrreg16(dev, KS_RXCR1, w | RXCR1_RXE); +} + +static void ks_disable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Disables QMU Transmit (TXCR). */ + w &= ~TXCR_TXE; + ks_wrreg16(dev, KS_TXCR, w); + + /* Disables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + w &= ~RXCR1_RXE; + ks_wrreg16(dev, KS_RXCR1, w); +} + +static inline void ks_read_qmu(struct eth_device *dev, u16 *buf, u32 len) +{ + u32 r = ks->extra_byte & 0x1; + u32 w = ks->extra_byte - r; + + /* 1. set sudo DMA mode */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + + /* + * 2. read prepend data + * + * read 4 + extra bytes and discard them. + * extra bytes for dummy, 2 for status, 2 for len + */ + + if (r) + ks_rdreg8(dev, 0); + + ks_inblk(dev, buf, w + 2 + 2); + + /* 3. read pkt data */ + ks_inblk(dev, buf, ALIGN(len, 4)); + + /* 4. reset sudo DMA Mode */ + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr & ~RXQCR_SDA) & 0xff); +} + +static void ks_rcv(struct eth_device *dev, uchar **pv_data) +{ + struct type_frame_head *frame_hdr = ks->frame_head_info; + int i; + + ks->frame_cnt = ks_rdreg16(dev, KS_RXFCTR) >> 8; + + /* read all header information */ + for (i = 0; i < ks->frame_cnt; i++) { + /* Checking Received packet status */ + frame_hdr->sts = ks_rdreg16(dev, KS_RXFHSR); + /* Get packet len from hardware */ + frame_hdr->len = ks_rdreg16(dev, KS_RXFHBCR); + frame_hdr++; + } + + frame_hdr = ks->frame_head_info; + while (ks->frame_cnt--) { + if ((frame_hdr->sts & RXFSHR_RXFV) && + (frame_hdr->len < RX_BUF_SIZE) && + frame_hdr->len) { + /* read data block including CRC 4 bytes */ + ks_read_qmu(dev, (u16 *)(*pv_data), frame_hdr->len); + + /* NetRxPackets buffer size is ok (*pv_data pointer) */ + NetReceive(*pv_data, frame_hdr->len); + pv_data++; + } else { + ks_wrreg16(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_RRXEF)); + printf(DRIVERNAME ": bad packet\n"); + } + frame_hdr++; + } +} + +/* + * ks_read_selftest - read the selftest memory info. + * @ks: The device state + * + * Read and check the TX/RX memory selftest information. + */ +static int ks_read_selftest(struct eth_device *dev) +{ + u16 both_done = MBIR_TXMBF | MBIR_RXMBF; + u16 mbir; + int ret = 0; + + mbir = ks_rdreg16(dev, KS_MBIR); + + if ((mbir & both_done) != both_done) { + printf(DRIVERNAME ": Memory selftest not finished\n"); + return 0; + } + + if (mbir & MBIR_TXMBFA) { + printf(DRIVERNAME ": TX memory selftest fails\n"); + ret |= 1; + } + + if (mbir & MBIR_RXMBFA) { + printf(DRIVERNAME ": RX memory selftest fails\n"); + ret |= 2; + } + + debug(DRIVERNAME ": the selftest passes\n"); + + return ret; +} + +static void ks_setup(struct eth_device *dev) +{ + u16 w; + + /* Setup Transmit Frame Data Pointer Auto-Increment (TXFDPR) */ + ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI); + + /* Setup Receive Frame Data Pointer Auto-Increment */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + + /* Setup Receive Frame Threshold - 1 frame (RXFCTFC) */ + ks_wrreg16(dev, KS_RXFCTR, 1 & RXFCTR_THRESHOLD_MASK); + + /* Setup RxQ Command Control (RXQCR) */ + ks->rc_rxqcr = RXQCR_CMD_CNTL; + ks_wrreg16(dev, KS_RXQCR, ks->rc_rxqcr); + + /* + * set the force mode to half duplex, default is full duplex + * because if the auto-negotiation fails, most switch uses + * half-duplex. + */ + w = ks_rdreg16(dev, KS_P1MBCR); + w &= ~P1MBCR_FORCE_FDX; + ks_wrreg16(dev, KS_P1MBCR, w); + + w = TXCR_TXFCE | TXCR_TXPE | TXCR_TXCRC | TXCR_TCGIP; + ks_wrreg16(dev, KS_TXCR, w); + + w = RXCR1_RXFCE | RXCR1_RXBE | RXCR1_RXUE | RXCR1_RXME | RXCR1_RXIPFCC; + + /* Normal mode */ + w |= RXCR1_RXPAFMA; + + ks_wrreg16(dev, KS_RXCR1, w); +} + +static void ks_setup_int(struct eth_device *dev) +{ + ks->rc_ier = 0x00; + + /* Clear the interrupts status of the hardware. */ + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* Enables the interrupts of the hardware. */ + ks->rc_ier = (IRQ_LCI | IRQ_TXI | IRQ_RXI); +} + +static int ks8851_mll_detect_chip(struct eth_device *dev) +{ + unsigned short val, i; + + ks_read_config(dev); + + val = ks_rdreg16(dev, KS_CIDER); + + if (val == 0xffff) { + /* Special case -- no chip present */ + printf(DRIVERNAME ": is chip mounted ?\n"); + return -1; + } else if ((val & 0xfff0) != CIDER_ID) { + printf(DRIVERNAME ": Invalid chip id 0x%04x\n", val); + return -1; + } + + debug("Read back KS8851 id 0x%x\n", val); + + /* only one entry in the table */ + val &= 0xfff0; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) + break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04x\n", val); + return -1; + } + + dev->priv = (void *)&chip_ids[i]; + + return 0; +} + +static void ks8851_mll_reset(struct eth_device *dev) +{ + /* wake up powermode to normal mode */ + ks_set_powermode(dev, PMECR_PM_NORMAL); + mdelay(1); /* wait for normal mode to take effect */ + + /* Disable interrupt and reset */ + ks_soft_reset(dev, GRR_GSR); + + /* turn off the IRQs and ack any outstanding */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* shutdown RX/TX QMU */ + ks_disable_qmu(dev); +} + +static void ks8851_mll_phy_configure(struct eth_device *dev) +{ + u16 data; + + ks_setup(dev); + ks_setup_int(dev); + + /* Probing the phy */ + data = ks_rdreg16(dev, KS_OBCR); + ks_wrreg16(dev, KS_OBCR, data | OBCR_ODS_16MA); + + debug(DRIVERNAME ": phy initialized\n"); +} + +static void ks8851_mll_enable(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_ISR, 0xffff); + ks_enable_int(dev); + ks_enable_qmu(dev); +} + +static int ks8851_mll_init(struct eth_device *dev, bd_t *bd) +{ + struct chip_id *id = dev->priv; + + debug(DRIVERNAME ": detected %s controller\n", id->name); + + if (ks_read_selftest(dev)) { + printf(DRIVERNAME ": Selftest failed\n"); + return -1; + } + + ks8851_mll_reset(dev); + + /* Configure the PHY, initialize the link state */ + ks8851_mll_phy_configure(dev); + + /* static allocation of private informations */ + ks->frame_head_info = fr_h_i; + + /* Turn on Tx + Rx */ + ks8851_mll_enable(dev); + + return 0; +} + +static void ks_write_qmu(struct eth_device *dev, u8 *pdata, u16 len) +{ + /* start header at txb[0] to align txw entries */ + ks->txh.txw[0] = 0; + ks->txh.txw[1] = cpu_to_le16(len); + + /* 1. set sudo-DMA mode */ + ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI); + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + /* 2. write status/lenth info */ + ks_outblk(dev, ks->txh.txw, 4); + /* 3. write pkt data */ + ks_outblk(dev, (u16 *)pdata, ALIGN(len, 4)); + /* 4. reset sudo-DMA mode */ + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr & ~RXQCR_SDA) & 0xff); + /* 5. Enqueue Tx(move the pkt from TX buffer into TXQ) */ + ks_wrreg16(dev, KS_TXQCR, TXQCR_METFE); + /* 6. wait until TXQCR_METFE is auto-cleared */ + do { } while (ks_rdreg16(dev, KS_TXQCR) & TXQCR_METFE); +} + +static int ks8851_mll_send(struct eth_device *dev, void *packet, int length) +{ + u8 *data = (u8 *)packet; + u16 tmplen = (u16)length; + u16 retv; + + /* + * Extra space are required: + * 4 byte for alignment, 4 for status/length, 4 for CRC + */ + retv = ks_rdreg16(dev, KS_TXMIR) & 0x1fff; + if (retv >= tmplen + 12) { + ks_write_qmu(dev, data, tmplen); + return 0; + } else { + printf(DRIVERNAME ": failed to send packet: No buffer\n"); + return -1; + } +} + +static void ks8851_mll_halt(struct eth_device *dev) +{ + ks8851_mll_reset(dev); +} + +/* + * Maximum receive ring size; that is, the number of packets + * we can buffer before overflow happens. Basically, this just + * needs to be enough to prevent a packet being discarded while + * we are processing the previous one. + */ +static int ks8851_mll_recv(struct eth_device *dev) +{ + u16 status; + + status = ks_rdreg16(dev, KS_ISR); + + ks_wrreg16(dev, KS_ISR, status); + + if ((status & IRQ_RXI)) + ks_rcv(dev, (uchar **)NetRxPackets); + + if ((status & IRQ_LDI)) { + u16 pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_WKEVT_MASK; + ks_wrreg16(dev, KS_PMECR, pmecr | PMECR_WKEVT_LINK); + } + + return 0; +} + +static int ks8851_mll_write_hwaddr(struct eth_device *dev) +{ + u16 addrl, addrm, addrh; + + addrh = (dev->enetaddr[0] << 8) | dev->enetaddr[1]; + addrm = (dev->enetaddr[2] << 8) | dev->enetaddr[3]; + addrl = (dev->enetaddr[4] << 8) | dev->enetaddr[5]; + + ks_wrreg16(dev, KS_MARH, addrh); + ks_wrreg16(dev, KS_MARM, addrm); + ks_wrreg16(dev, KS_MARL, addrl); + + return 0; +} + +int ks8851_mll_initialize(u8 dev_num, int base_addr) +{ + struct eth_device *dev; + + dev = malloc(sizeof(*dev)); + if (!dev) { + printf("Error: Failed to allocate memory\n"); + return -1; + } + memset(dev, 0, sizeof(*dev)); + + dev->iobase = base_addr; + + ks = &ks_str; + + /* Try to detect chip. Will fail if not present. */ + if (ks8851_mll_detect_chip(dev)) { + free(dev); + return -1; + } + + dev->init = ks8851_mll_init; + dev->halt = ks8851_mll_halt; + dev->send = ks8851_mll_send; + dev->recv = ks8851_mll_recv; + dev->write_hwaddr = ks8851_mll_write_hwaddr; + sprintf(dev->name, "%s-%hu", DRIVERNAME, dev_num); + + eth_register(dev); + + return 0; +} diff --git a/drivers/net/ks8851_mll.h b/drivers/net/ks8851_mll.h new file mode 100644 index 0000000..7f90ae4 --- /dev/null +++ b/drivers/net/ks8851_mll.h @@ -0,0 +1,357 @@ +/* + * drivers/net/ks8851_mll.c + * + * Supports: + * KS8851 16bit MLL chip from Micrel Inc. + * + * Copyright (c) 2009 Micrel Inc. + * + * modified by + * (c) 2011 Bticino s.p.a, Roberto Cerati roberto.cerati@bticino.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#ifndef _KS8851_MLL_H_ +#define _KS8851_MLL_H_ + +#include <linux/types.h> + +#define KS_CCR 0x08 +#define CCR_EEPROM (1 << 9) +#define CCR_SPI (1 << 8) +#define CCR_8BIT (1 << 7) +#define CCR_16BIT (1 << 6) +#define CCR_32BIT (1 << 5) +#define CCR_SHARED (1 << 4) +#define CCR_32PIN (1 << 0) + +/* MAC address registers */ +#define KS_MARL 0x10 +#define KS_MARM 0x12 +#define KS_MARH 0x14 + +#define KS_OBCR 0x20 +#define OBCR_ODS_16MA (1 << 6) + +#define KS_EEPCR 0x22 +#define EEPCR_EESA (1 << 4) +#define EEPCR_EESB (1 << 3) +#define EEPCR_EEDO (1 << 2) +#define EEPCR_EESCK (1 << 1) +#define EEPCR_EECS (1 << 0) + +#define KS_MBIR 0x24 +#define MBIR_TXMBF (1 << 12) +#define MBIR_TXMBFA (1 << 11) +#define MBIR_RXMBF (1 << 4) +#define MBIR_RXMBFA (1 << 3) + +#define KS_GRR 0x26 +#define GRR_QMU (1 << 1) +#define GRR_GSR (1 << 0) + +#define KS_WFCR 0x2A +#define WFCR_MPRXE (1 << 7) +#define WFCR_WF3E (1 << 3) +#define WFCR_WF2E (1 << 2) +#define WFCR_WF1E (1 << 1) +#define WFCR_WF0E (1 << 0) + +#define KS_WF0CRC0 0x30 +#define KS_WF0CRC1 0x32 +#define KS_WF0BM0 0x34 +#define KS_WF0BM1 0x36 +#define KS_WF0BM2 0x38 +#define KS_WF0BM3 0x3A + +#define KS_WF1CRC0 0x40 +#define KS_WF1CRC1 0x42 +#define KS_WF1BM0 0x44 +#define KS_WF1BM1 0x46 +#define KS_WF1BM2 0x48 +#define KS_WF1BM3 0x4A + +#define KS_WF2CRC0 0x50 +#define KS_WF2CRC1 0x52 +#define KS_WF2BM0 0x54 +#define KS_WF2BM1 0x56 +#define KS_WF2BM2 0x58 +#define KS_WF2BM3 0x5A + +#define KS_WF3CRC0 0x60 +#define KS_WF3CRC1 0x62 +#define KS_WF3BM0 0x64 +#define KS_WF3BM1 0x66 +#define KS_WF3BM2 0x68 +#define KS_WF3BM3 0x6A + +#define KS_TXCR 0x70 +#define TXCR_TCGICMP (1 << 8) +#define TXCR_TCGUDP (1 << 7) +#define TXCR_TCGTCP (1 << 6) +#define TXCR_TCGIP (1 << 5) +#define TXCR_FTXQ (1 << 4) +#define TXCR_TXFCE (1 << 3) +#define TXCR_TXPE (1 << 2) +#define TXCR_TXCRC (1 << 1) +#define TXCR_TXE (1 << 0) + +#define KS_TXSR 0x72 +#define TXSR_TXLC (1 << 13) +#define TXSR_TXMC (1 << 12) +#define TXSR_TXFID_MASK (0x3f << 0) +#define TXSR_TXFID_SHIFT (0) +#define TXSR_TXFID_GET(_v) (((_v) >> 0) & 0x3f) + + +#define KS_RXCR1 0x74 +#define RXCR1_FRXQ (1 << 15) +#define RXCR1_RXUDPFCC (1 << 14) +#define RXCR1_RXTCPFCC (1 << 13) +#define RXCR1_RXIPFCC (1 << 12) +#define RXCR1_RXPAFMA (1 << 11) +#define RXCR1_RXFCE (1 << 10) +#define RXCR1_RXEFE (1 << 9) +#define RXCR1_RXMAFMA (1 << 8) +#define RXCR1_RXBE (1 << 7) +#define RXCR1_RXME (1 << 6) +#define RXCR1_RXUE (1 << 5) +#define RXCR1_RXAE (1 << 4) +#define RXCR1_RXINVF (1 << 1) +#define RXCR1_RXE (1 << 0) +#define RXCR1_FILTER_MASK (RXCR1_RXINVF | RXCR1_RXAE | \ + RXCR1_RXMAFMA | RXCR1_RXPAFMA) + +#define KS_RXCR2 0x76 +#define RXCR2_SRDBL_MASK (0x7 << 5) +#define RXCR2_SRDBL_SHIFT (5) +#define RXCR2_SRDBL_4B (0x0 << 5) +#define RXCR2_SRDBL_8B (0x1 << 5) +#define RXCR2_SRDBL_16B (0x2 << 5) +#define RXCR2_SRDBL_32B (0x3 << 5) +/* #define RXCR2_SRDBL_FRAME (0x4 << 5) */ +#define RXCR2_IUFFP (1 << 4) +#define RXCR2_RXIUFCEZ (1 << 3) +#define RXCR2_UDPLFE (1 << 2) +#define RXCR2_RXICMPFCC (1 << 1) +#define RXCR2_RXSAF (1 << 0) + +#define KS_TXMIR 0x78 + +#define KS_RXFHSR 0x7C +#define RXFSHR_RXFV (1 << 15) +#define RXFSHR_RXICMPFCS (1 << 13) +#define RXFSHR_RXIPFCS (1 << 12) +#define RXFSHR_RXTCPFCS (1 << 11) +#define RXFSHR_RXUDPFCS (1 << 10) +#define RXFSHR_RXBF (1 << 7) +#define RXFSHR_RXMF (1 << 6) +#define RXFSHR_RXUF (1 << 5) +#define RXFSHR_RXMR (1 << 4) +#define RXFSHR_RXFT (1 << 3) +#define RXFSHR_RXFTL (1 << 2) +#define RXFSHR_RXRF (1 << 1) +#define RXFSHR_RXCE (1 << 0) +#define RXFSHR_ERR (RXFSHR_RXCE | RXFSHR_RXRF |\ + RXFSHR_RXFTL | RXFSHR_RXMR |\ + RXFSHR_RXICMPFCS | RXFSHR_RXIPFCS |\ + RXFSHR_RXTCPFCS) +#define KS_RXFHBCR 0x7E +#define RXFHBCR_CNT_MASK 0x0FFF + +#define KS_TXQCR 0x80 +#define TXQCR_AETFE (1 << 2) +#define TXQCR_TXQMAM (1 << 1) +#define TXQCR_METFE (1 << 0) + +#define KS_RXQCR 0x82 +#define RXQCR_RXDTTS (1 << 12) +#define RXQCR_RXDBCTS (1 << 11) +#define RXQCR_RXFCTS (1 << 10) +#define RXQCR_RXIPHTOE (1 << 9) +#define RXQCR_RXDTTE (1 << 7) +#define RXQCR_RXDBCTE (1 << 6) +#define RXQCR_RXFCTE (1 << 5) +#define RXQCR_ADRFE (1 << 4) +#define RXQCR_SDA (1 << 3) +#define RXQCR_RRXEF (1 << 0) +#define RXQCR_CMD_CNTL (RXQCR_RXFCTE|RXQCR_ADRFE) + +#define KS_TXFDPR 0x84 +#define TXFDPR_TXFPAI (1 << 14) +#define TXFDPR_TXFP_MASK (0x7ff << 0) +#define TXFDPR_TXFP_SHIFT (0) + +#define KS_RXFDPR 0x86 +#define RXFDPR_RXFPAI (1 << 14) + +#define KS_RXDTTR 0x8C +#define KS_RXDBCTR 0x8E + +#define KS_IER 0x90 +#define KS_ISR 0x92 +#define IRQ_LCI (1 << 15) +#define IRQ_TXI (1 << 14) +#define IRQ_RXI (1 << 13) +#define IRQ_RXOI (1 << 11) +#define IRQ_TXPSI (1 << 9) +#define IRQ_RXPSI (1 << 8) +#define IRQ_TXSAI (1 << 6) +#define IRQ_RXWFDI (1 << 5) +#define IRQ_RXMPDI (1 << 4) +#define IRQ_LDI (1 << 3) +#define IRQ_EDI (1 << 2) +#define IRQ_SPIBEI (1 << 1) +#define IRQ_DEDI (1 << 0) + +#define KS_RXFCTR 0x9C +#define RXFCTR_THRESHOLD_MASK 0x00FF + +#define KS_RXFC 0x9D +#define RXFCTR_RXFC_MASK (0xff << 8) +#define RXFCTR_RXFC_SHIFT (8) +#define RXFCTR_RXFC_GET(_v) (((_v) >> 8) & 0xff) +#define RXFCTR_RXFCT_MASK (0xff << 0) +#define RXFCTR_RXFCT_SHIFT (0) + +#define KS_TXNTFSR 0x9E + +#define KS_MAHTR0 0xA0 +#define KS_MAHTR1 0xA2 +#define KS_MAHTR2 0xA4 +#define KS_MAHTR3 0xA6 + +#define KS_FCLWR 0xB0 +#define KS_FCHWR 0xB2 +#define KS_FCOWR 0xB4 + +#define KS_CIDER 0xC0 +#define CIDER_ID 0x8870 +#define CIDER_REV_MASK (0x7 << 1) +#define CIDER_REV_SHIFT (1) +#define CIDER_REV_GET(_v) (((_v) >> 1) & 0x7) + +#define KS_CGCR 0xC6 +#define KS_IACR 0xC8 +#define IACR_RDEN (1 << 12) +#define IACR_TSEL_MASK (0x3 << 10) +#define IACR_TSEL_SHIFT (10) +#define IACR_TSEL_MIB (0x3 << 10) +#define IACR_ADDR_MASK (0x1f << 0) +#define IACR_ADDR_SHIFT (0) + +#define KS_IADLR 0xD0 +#define KS_IAHDR 0xD2 + +#define KS_PMECR 0xD4 +#define PMECR_PME_DELAY (1 << 14) +#define PMECR_PME_POL (1 << 12) +#define PMECR_WOL_WAKEUP (1 << 11) +#define PMECR_WOL_MAGICPKT (1 << 10) +#define PMECR_WOL_LINKUP (1 << 9) +#define PMECR_WOL_ENERGY (1 << 8) +#define PMECR_AUTO_WAKE_EN (1 << 7) +#define PMECR_WAKEUP_NORMAL (1 << 6) +#define PMECR_WKEVT_MASK (0xf << 2) +#define PMECR_WKEVT_SHIFT (2) +#define PMECR_WKEVT_GET(_v) (((_v) >> 2) & 0xf) +#define PMECR_WKEVT_ENERGY (0x1 << 2) +#define PMECR_WKEVT_LINK (0x2 << 2) +#define PMECR_WKEVT_MAGICPKT (0x4 << 2) +#define PMECR_WKEVT_FRAME (0x8 << 2) +#define PMECR_PM_MASK (0x3 << 0) +#define PMECR_PM_SHIFT (0) +#define PMECR_PM_NORMAL (0x0 << 0) +#define PMECR_PM_ENERGY (0x1 << 0) +#define PMECR_PM_SOFTDOWN (0x2 << 0) +#define PMECR_PM_POWERSAVE (0x3 << 0) + +/* Standard MII PHY data */ +#define KS_P1MBCR 0xE4 +#define P1MBCR_FORCE_FDX (1 << 8) + +#define KS_P1MBSR 0xE6 +#define P1MBSR_AN_COMPLETE (1 << 5) +#define P1MBSR_AN_CAPABLE (1 << 3) +#define P1MBSR_LINK_UP (1 << 2) + +#define KS_PHY1ILR 0xE8 +#define KS_PHY1IHR 0xEA +#define KS_P1ANAR 0xEC +#define KS_P1ANLPR 0xEE + +#define KS_P1SCLMD 0xF4 +#define P1SCLMD_LEDOFF (1 << 15) +#define P1SCLMD_TXIDS (1 << 14) +#define P1SCLMD_RESTARTAN (1 << 13) +#define P1SCLMD_DISAUTOMDIX (1 << 10) +#define P1SCLMD_FORCEMDIX (1 << 9) +#define P1SCLMD_AUTONEGEN (1 << 7) +#define P1SCLMD_FORCE100 (1 << 6) +#define P1SCLMD_FORCEFDX (1 << 5) +#define P1SCLMD_ADV_FLOW (1 << 4) +#define P1SCLMD_ADV_100BT_FDX (1 << 3) +#define P1SCLMD_ADV_100BT_HDX (1 << 2) +#define P1SCLMD_ADV_10BT_FDX (1 << 1) +#define P1SCLMD_ADV_10BT_HDX (1 << 0) + +#define KS_P1CR 0xF6 +#define P1CR_HP_MDIX (1 << 15) +#define P1CR_REV_POL (1 << 13) +#define P1CR_OP_100M (1 << 10) +#define P1CR_OP_FDX (1 << 9) +#define P1CR_OP_MDI (1 << 7) +#define P1CR_AN_DONE (1 << 6) +#define P1CR_LINK_GOOD (1 << 5) +#define P1CR_PNTR_FLOW (1 << 4) +#define P1CR_PNTR_100BT_FDX (1 << 3) +#define P1CR_PNTR_100BT_HDX (1 << 2) +#define P1CR_PNTR_10BT_FDX (1 << 1) +#define P1CR_PNTR_10BT_HDX (1 << 0) + +/* TX Frame control */ +#define TXFR_TXIC (1 << 15) +#define TXFR_TXFID_MASK (0x3f << 0) +#define TXFR_TXFID_SHIFT (0) + +#define KS_P1SR 0xF8 +#define P1SR_HP_MDIX (1 << 15) +#define P1SR_REV_POL (1 << 13) +#define P1SR_OP_100M (1 << 10) +#define P1SR_OP_FDX (1 << 9) +#define P1SR_OP_MDI (1 << 7) +#define P1SR_AN_DONE (1 << 6) +#define P1SR_LINK_GOOD (1 << 5) +#define P1SR_PNTR_FLOW (1 << 4) +#define P1SR_PNTR_100BT_FDX (1 << 3) +#define P1SR_PNTR_100BT_HDX (1 << 2) +#define P1SR_PNTR_10BT_FDX (1 << 1) +#define P1SR_PNTR_10BT_HDX (1 << 0) + +#define ENUM_BUS_NONE 0 +#define ENUM_BUS_8BIT 1 +#define ENUM_BUS_16BIT 2 +#define ENUM_BUS_32BIT 3 + +#define MAX_MCAST_LST 32 +#define HW_MCAST_SIZE 8 +#define MAC_ADDR_LEN 6 + +/* Chip ID values */ +struct chip_id { + u16 id; + char *name; +}; + +#endif diff --git a/include/netdev.h b/include/netdev.h index fd3e243..7c2aacb 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -71,6 +71,7 @@ int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); int ks8695_eth_initialize(void); +int ks8851_mll_initialize(u8 dev_num, int base_addr); int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis);
Hi Bo,
Change in v2
- Micrel KS8851_MLL 16bit Network driver
- Copyright (c) 2011 Roberto Cerati roberto.cerati@bticino.it
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- {CIDER_ID, "KSZ8851"},
- {0, NULL},
- union ks_tx_hdr - tx header data
- @txb: The header as bytes
- @txw: The header as 16bit, little-endian words
- A dual representation of the tx header data to allow
- access to individual bytes, and to allow 16bit accesses
- with 16bit alignment.
+union ks_tx_hdr {
- u8 txb[4];
- __le16 txw[2];
- struct ks_net - KS8851 driver private data
- @net_device : The network device we're bound to
- @txh : temporaly buffer to save status/length.
- @frame_head_info : frame header information for multi-pkt rx.
- @statelock : Lock on this structure for tx list.
- @msg_enable : The message flags controlling driver output (see ethtool).
- @frame_cnt : number of frames received.
- @bus_width : i/o bus width.
- @irq : irq number assigned to this device.
- @rc_rxqcr : Cached copy of KS_RXQCR.
- @rc_txcr : Cached copy of KS_TXCR.
- @rc_ier : Cached copy of KS_IER.
- @sharedbus : Multipex(addr and data bus) mode indicator.
- @cmd_reg_cache : command register cached.
- @cmd_reg_cache_int : command register cached. Used in the irq handler.
- @promiscuous : promiscuous mode indicator.
- @all_mcast : mutlicast indicator.
- @mcast_lst_size : size of multicast list.
- @mcast_lst : multicast list.
- @mcast_bits : multicast enabed.
- @mac_addr : MAC address assigned to this device.
- @fid : frame id.
- @extra_byte : number of extra byte prepended rx pkt.
- @enabled : indicator this device works.
- u16 sts; /* Frame status */
- u16 len; /* Byte count */
+struct ks_net {
- struct net_device *netdev;
- union ks_tx_hdr txh;
- struct type_frame_head *frame_head_info;
- u32 msg_enable;
- u32 frame_cnt;
- int bus_width;
- int irq;
- u16 rc_rxqcr;
- u16 rc_txcr;
- u16 rc_ier;
- u16 sharedbus;
- u16 cmd_reg_cache;
- u16 cmd_reg_cache_int;
- u16 promiscuous;
- u16 all_mcast;
- u16 mcast_lst_size;
- u8 mcast_lst[MAX_MCAST_LST][MAC_ADDR_LEN];
- u8 mcast_bits[HW_MCAST_SIZE];
- u8 mac_addr[6];
- u8 fid;
- u8 extra_byte;
- u8 enabled;
+} ks_str, *ks;
- u8 shift_bit = offset & 0x03;
- u8 shift_data = (offset & 1) << 3;
- writew(offset | (BE0 << shift_bit), dev->iobase + 2);
- return (u8)(readw(dev->iobase) >> shift_data);
- writew(offset | ((BE1 | BE0) << (offset & 0x02)), dev->iobase + 2);
- return readw(dev->iobase);
- u8 shift_bit = (offset & 0x03);
- u16 value_write = (u16)(val << ((offset & 1) << 3));
- writew(value_write, dev->iobase);
- writew(val, dev->iobase);
- ks_inblk - read a block of data from QMU. This is called after sudo DMA mode
- enabled.
- @ks: The chip state
- @wptr: buffer address to save data
- @len: length in byte to read
- len >>= 1;
- while (len--)
- *wptr++ = readw(dev->iobase);
- ks_outblk - write data to QMU. This is called after sudo DMA mode enabled.
- @ks: The chip information
- @len: length in byte to write
- len >>= 1;
- while (len--)
- writew(*wptr++, dev->iobase);
- ks_wrreg16(dev, KS_IER, ks->rc_ier);
- unsigned pmecr;
- ks_rdreg16(dev, KS_GRR);
- pmecr = ks_rdreg16(dev, KS_PMECR);
- pmecr &= ~PMECR_PM_MASK;
- pmecr |= pwrmode;
- ks_wrreg16(dev, KS_PMECR, pmecr);
- ks_read_config - read chip configuration of bus width.
- u16 reg_data = 0;
- /* Regardless of bus width, 8 bit read should always work. */
- reg_data = ks_rdreg8(dev, KS_CCR) & 0x00FF;
- reg_data |= ks_rdreg8(dev, KS_CCR + 1) << 8;
- /* addr/data bus are multiplexed */
- ks->sharedbus = (reg_data & CCR_SHARED) == CCR_SHARED;
- There are garbage data when reading data from QMU,
- depending on bus-width.
- if (reg_data & CCR_8BIT) {
- ks->bus_width = ENUM_BUS_8BIT;
- ks->extra_byte = 1;
- } else if (reg_data & CCR_16BIT) {
- ks->bus_width = ENUM_BUS_16BIT;
- ks->extra_byte = 2;
- } else {
- ks->bus_width = ENUM_BUS_32BIT;
- ks->extra_byte = 4;
- ks_soft_reset - issue one of the soft reset to the device
- @ks: The device state.
- @op: The bit(s) to set in the GRR
- Issue the relevant soft-reset command to the device's GRR register
- specified by @op.
- Note, the delays are in there as a caution to ensure that the reset
- has time to take effect and then complete. Since the datasheet does
- not currently specify the exact sequence, we have chosen something
- that seems to work with our device.
- /* Disable interrupt first */
- ks_wrreg16(dev, KS_IER, 0x0000);
- ks_wrreg16(dev, KS_GRR, op);
- mdelay(10); /* wait a short time to effect reset */
- ks_wrreg16(dev, KS_GRR, 0);
- mdelay(1); /* wait for condition to clear */
- u16 w;
- w = ks_rdreg16(dev, KS_TXCR);
- /* Enables QMU Transmit (TXCR). */
- ks_wrreg16(dev, KS_TXCR, w | TXCR_TXE);
- /* Enable RX Frame Count Threshold and Auto-Dequeue RXQ Frame */
- w = ks_rdreg16(dev, KS_RXQCR);
- ks_wrreg16(dev, KS_RXQCR, w | RXQCR_RXFCTE);
- /* Enables QMU Receive (RXCR1). */
- w = ks_rdreg16(dev, KS_RXCR1);
- ks_wrreg16(dev, KS_RXCR1, w | RXCR1_RXE);
- u16 w;
- /* Disables QMU Transmit (TXCR). */
- w &= ~TXCR_TXE;
- ks_wrreg16(dev, KS_TXCR, w);
- /* Disables QMU Receive (RXCR1). */
- w &= ~RXCR1_RXE;
- ks_wrreg16(dev, KS_RXCR1, w);
- u32 r = ks->extra_byte & 0x1;
- u32 w = ks->extra_byte - r;
- /* 1. set sudo DMA mode */
- ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI);
- ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff);
- read prepend data
- read 4 + extra bytes and discard them.
- extra bytes for dummy, 2 for status, 2 for len
- if (r)
- ks_rdreg8(dev, 0);
- ks_inblk(dev, buf, w + 2 + 2);
- /* 3. read pkt data */
- ks_inblk(dev, buf, ALIGN(len, 4));
- /* 4. reset sudo DMA Mode */
- ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr & ~RXQCR_SDA) & 0xff);
- struct type_frame_head *frame_hdr = ks->frame_head_info;
- int i;
- ks->frame_cnt = ks_rdreg16(dev, KS_RXFCTR) >> 8;
- /* read all header information */
- for (i = 0; i < ks->frame_cnt; i++) {
- /* Checking Received packet status */
- frame_hdr->sts = ks_rdreg16(dev, KS_RXFHSR);
- /* Get packet len from hardware */
- frame_hdr->len = ks_rdreg16(dev, KS_RXFHBCR);
- frame_hdr++;
- frame_hdr = ks->frame_head_info;
- while (ks->frame_cnt--) {
- if ((frame_hdr->sts & RXFSHR_RXFV) &&
frame_hdr->len) {
- /* read data block including CRC 4 bytes */
- ks_read_qmu(dev, (u16 *)(*pv_data), frame_hdr->len);
- /* NetRxPackets buffer size is ok (*pv_data pointer) */
- NetReceive(*pv_data, frame_hdr->len);
- pv_data++;
- } else {
- ks_wrreg16(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_RRXEF));
- printf(DRIVERNAME ": bad packet\n");
- frame_hdr++;
- ks_read_selftest - read the selftest memory info.
- Read and check the TX/RX memory selftest information.
- u16 both_done = MBIR_TXMBF | MBIR_RXMBF;
- u16 mbir;
- int ret = 0;
- mbir = ks_rdreg16(dev, KS_MBIR);
- if ((mbir & both_done) != both_done) {
- printf(DRIVERNAME ": Memory selftest not finished\n");
- if (mbir & MBIR_TXMBFA) {
- printf(DRIVERNAME ": TX memory selftest fails\n");
- ret |= 1;
- if (mbir & MBIR_RXMBFA) {
- printf(DRIVERNAME ": RX memory selftest fails\n");
- ret |= 2;
- debug(DRIVERNAME ": the selftest passes\n");
- return ret;
- u16 w;
- /* Setup Transmit Frame Data Pointer Auto-Increment (TXFDPR) */
- ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI);
- /* Setup Receive Frame Data Pointer Auto-Increment */
- /* Setup Receive Frame Threshold - 1 frame (RXFCTFC) */
- ks_wrreg16(dev, KS_RXFCTR, 1 & RXFCTR_THRESHOLD_MASK);
- /* Setup RxQ Command Control (RXQCR) */
- ks->rc_rxqcr = RXQCR_CMD_CNTL;
- ks_wrreg16(dev, KS_RXQCR, ks->rc_rxqcr);
- set the force mode to half duplex, default is full duplex
- because if the auto-negotiation fails, most switch uses
- half-duplex.
- w = ks_rdreg16(dev, KS_P1MBCR);
- w &= ~P1MBCR_FORCE_FDX;
- ks_wrreg16(dev, KS_P1MBCR, w);
- w = TXCR_TXFCE | TXCR_TXPE | TXCR_TXCRC | TXCR_TCGIP;
- w = RXCR1_RXFCE | RXCR1_RXBE | RXCR1_RXUE | RXCR1_RXME | RXCR1_RXIPFCC;
- /* Normal mode */
- w |= RXCR1_RXPAFMA;
- ks->rc_ier = 0x00;
- /* Clear the interrupts status of the hardware. */
- ks_wrreg16(dev, KS_ISR, 0xffff);
- /* Enables the interrupts of the hardware. */
- ks->rc_ier = (IRQ_LCI | IRQ_TXI | IRQ_RXI);
- unsigned short val, i;
- ks_read_config(dev);
- val = ks_rdreg16(dev, KS_CIDER);
- if (val == 0xffff) {
- /* Special case -- no chip present */
- printf(DRIVERNAME ": is chip mounted ?\n");
- return -1;
- } else if ((val & 0xfff0) != CIDER_ID) {
- printf(DRIVERNAME ": Invalid chip id 0x%04x\n", val);
- return -1;
- debug("Read back KS8851 id 0x%x\n", val);
- /* only one entry in the table */
- val &= 0xfff0;
- for (i = 0; chip_ids[i].id != 0; i++) {
- if (chip_ids[i].id == val)
- break;
- if (!chip_ids[i].id) {
- printf(DRIVERNAME ": Unknown chip ID %04x\n", val);
- return -1;
- dev->priv = (void *)&chip_ids[i];
- /* wake up powermode to normal mode */
- ks_set_powermode(dev, PMECR_PM_NORMAL);
- mdelay(1); /* wait for normal mode to take effect */
- /* Disable interrupt and reset */
- ks_soft_reset(dev, GRR_GSR);
- /* turn off the IRQs and ack any outstanding */
- /* shutdown RX/TX QMU */
- ks_disable_qmu(dev);
- u16 data;
- ks_setup(dev);
- ks_setup_int(dev);
- /* Probing the phy */
- data = ks_rdreg16(dev, KS_OBCR);
- ks_wrreg16(dev, KS_OBCR, data | OBCR_ODS_16MA);
- debug(DRIVERNAME ": phy initialized\n");
- ks_enable_int(dev);
- ks_enable_qmu(dev);
- struct chip_id *id = dev->priv;
- debug(DRIVERNAME ": detected %s controller\n", id->name);
- if (ks_read_selftest(dev)) {
- printf(DRIVERNAME ": Selftest failed\n");
- return -1;
- ks8851_mll_reset(dev);
- /* Configure the PHY, initialize the link state */
- ks8851_mll_phy_configure(dev);
- /* static allocation of private informations */
- ks->frame_head_info = fr_h_i;
- /* Turn on Tx + Rx */
- ks8851_mll_enable(dev);
- /* start header at txb[0] to align txw entries */
- ks->txh.txw[0] = 0;
- ks->txh.txw[1] = cpu_to_le16(len);
- /* 1. set sudo-DMA mode */
- /* 2. write status/lenth info */
- ks_outblk(dev, ks->txh.txw, 4);
- /* 3. write pkt data */
- ks_outblk(dev, (u16 *)pdata, ALIGN(len, 4));
- /* 4. reset sudo-DMA mode */
- /* 5. Enqueue Tx(move the pkt from TX buffer into TXQ) */
- ks_wrreg16(dev, KS_TXQCR, TXQCR_METFE);
- /* 6. wait until TXQCR_METFE is auto-cleared */
- do { } while (ks_rdreg16(dev, KS_TXQCR) & TXQCR_METFE);
- u8 *data = (u8 *)packet;
- u16 tmplen = (u16)length;
- u16 retv;
- Extra space are required:
- 4 byte for alignment, 4 for status/length, 4 for CRC
- retv = ks_rdreg16(dev, KS_TXMIR) & 0x1fff;
- if (retv >= tmplen + 12) {
- ks_write_qmu(dev, data, tmplen);
- } else {
- printf(DRIVERNAME ": failed to send packet: No buffer\n");
- return -1;
- Maximum receive ring size; that is, the number of packets
- we can buffer before overflow happens. Basically, this just
- needs to be enough to prevent a packet being discarded while
- we are processing the previous one.
- u16 status;
- status = ks_rdreg16(dev, KS_ISR);
- ks_wrreg16(dev, KS_ISR, status);
- if ((status & IRQ_RXI))
- ks_rcv(dev, (uchar **)NetRxPackets);
- if ((status & IRQ_LDI)) {
- u16 pmecr = ks_rdreg16(dev, KS_PMECR);
- pmecr &= ~PMECR_WKEVT_MASK;
- ks_wrreg16(dev, KS_PMECR, pmecr | PMECR_WKEVT_LINK);
- u16 addrl, addrm, addrh;
- addrh = (dev->enetaddr[0] << 8) | dev->enetaddr[1];
- addrm = (dev->enetaddr[2] << 8) | dev->enetaddr[3];
- addrl = (dev->enetaddr[4] << 8) | dev->enetaddr[5];
- ks_wrreg16(dev, KS_MARH, addrh);
- ks_wrreg16(dev, KS_MARM, addrm);
- ks_wrreg16(dev, KS_MARL, addrl);
- struct eth_device *dev;
- dev = malloc(sizeof(*dev));
- if (!dev) {
- printf("Error: Failed to allocate memory\n");
- return -1;
- memset(dev, 0, sizeof(*dev));
- dev->iobase = base_addr;
- ks = &ks_str;
- /* Try to detect chip. Will fail if not present. */
- if (ks8851_mll_detect_chip(dev)) {
- free(dev);
- return -1;
- dev->init = ks8851_mll_init;
- dev->halt = ks8851_mll_halt;
- dev->send = ks8851_mll_send;
- dev->recv = ks8851_mll_recv;
- dev->write_hwaddr = ks8851_mll_write_hwaddr;
- sprintf(dev->name, "%s-%hu", DRIVERNAME, dev_num);
- eth_register(dev);
- drivers/net/ks8851_mll.c
- Supports:
- KS8851 16bit MLL chip from Micrel Inc.
- Copyright (c) 2009 Micrel Inc.
- modified by
- (c) 2011 Bticino s.p.a, Roberto Cerati roberto.cerati@bticino.it
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
RXFSHR_RXTCPFCS)
- u16 id;
- char *name;
+#endif diff --git a/include/netdev.h b/include/netdev.h index fd3e243..7c2aacb 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -71,6 +71,7 @@ int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); int ks8695_eth_initialize(void); +int ks8851_mll_initialize(u8 dev_num, int base_addr); int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis); -- 1.7.9.5
Tested-by: Raffaele Recalcati raffaele.recalcati@bticino.it
Testing it on my customized u-boot based on the following
commit 3786a942b5892441982f5d8908303f360bac9f8c Author: Stephen Warren swarren@nvidia.com Date: Mon Nov 5 13:22:00 2012 +0000
tegra: use generic fs commands in BOOTCOMMAND
Modify tegra-common-post.h's BOOTCOMMAND definition to use the generic filesystem command load rather than separate fatload and ext2load. This removes the need to iterate over supported filesystem types in the boot command.
This requires editing all board config headers to enable the new commands. The now-unused commands are left enabled to assue backwards compatibility with any user scripts. Boards (all from Avionic Design) which define custom BOOTCOMMAND values are not affected.
Signed-off-by: Stephen Warren swarren@nvidia.com tegra generic fs cmds fixup Signed-off-by: Tom Warren twarren@nvidia.com
add network support with ksz8851_16mll on at91sam9n12ek board
Signed-off-by: Bo Shen voice.shen@atmel.com --- Change in v2 No change --- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 36 +++++++++++++++++++++++++++++ include/configs/at91sam9n12ek.h | 4 ++++ 2 files changed, 40 insertions(+)
diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 8752794..3013a42 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -33,6 +33,7 @@ #include <lcd.h> #include <atmel_hlcdc.h> #include <atmel_mci.h> +#include <netdev.h>
#ifdef CONFIG_LCD_INFO #include <nand.h> @@ -190,6 +191,30 @@ int board_mmc_init(bd_t *bd) } #endif
+#ifdef CONFIG_KS8851_MLL +void at91sam9n12ek_ks8851_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[2].setup); + writel(AT91_SMC_PULSE_NWE(7) | AT91_SMC_PULSE_NCS_WR(7) | + AT91_SMC_PULSE_NRD(7) | AT91_SMC_PULSE_NCS_RD(7), + &smc->cs[2].pulse); + writel(AT91_SMC_CYCLE_NWE(9) | AT91_SMC_CYCLE_NRD(9), + &smc->cs[2].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_BAT | AT91_SMC_MODE_DBW_16 | + AT91_SMC_MODE_TDF_CYCLE(1), + &smc->cs[2].mode); + + /* Configure NCS2 PIN */ + at91_set_b_periph(AT91_PIO_PORTD, 19, 0); +} +#endif + int board_early_init_f(void) { /* Enable clocks for all PIOs */ @@ -217,9 +242,20 @@ int board_init(void) at91_lcd_hw_init(); #endif
+#ifdef CONFIG_KS8851_MLL + at91sam9n12ek_ks8851_hw_init(); +#endif + return 0; }
+#ifdef CONFIG_KS8851_MLL +int board_eth_init(bd_t *bis) +{ + return ks8851_mll_initialize(0, CONFIG_KS8851_MLL_BASEADDR); +} +#endif + int dram_init(void) { gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 8d2673d..b4b1c31 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -167,6 +167,10 @@ #define CONFIG_DOS_PARTITION #endif
+/* Ethernet */ +#define CONFIG_KS8851_MLL +#define CONFIG_KS8851_MLL_BASEADDR 0x30000000 /* use NCS2 */ + #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE
Dear Bo Shen,
Acked-by: Andreas Bießmann andreas.devel@googlemail.com
Applied series, Thanks. -Joe
Andreas Bießmann
Bo Shen
Joe Hershberger
Raffaele Recalcati
