Re: [DNX#2006040142000124] [U-Boot-Users] Re: MPC8272ADS Hangs with gcc 4.0.0 [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000124] was created:
<snip>
Thank you Wolfgang
Your advice was very useful. I got the board working! I would want to submit a patch, but I'm not sure about what my modification can do in the whole code. I suspect that there are other part(s) of the code that suffer with new GCC 4 optimizations.
I started debugging with BDI2000. After a lot of steps, I found where the board hanged. In fact, the processor resets in line 33 of cpu/mpc8260.c, function m8260_cpm_reset()
line 33 : gd->dp_alloc_base = CPM_DATAONLY_BASE;
The gd variable was appointing to a wrong address. gd is a "register volatile", as it is defined in include/asm-ppc/global_data.h:
#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r29")
Inspecting assembler generated code, I've found that before this funcion, r29 should be initiated with the correct value. This should be done in function cpu_init_f(), but no assembler code was generated from the line that initialized gd:
void cpu_init_f (volatile immap_t * immr) { DECLARE_GLOBAL_DATA_PTR; //register volatile gd_t *gd asm ("r29");
#if !defined(CONFIG_COGENT) /* done in start.S for the cogent */ uint sccr; #endif volatile memctl8260_t *memctl = &immr->im_memctl; extern void m8260_cpm_reset (void);
/* Pointer is writable since we allocated a register for it */ gd = (gd_t *) (CFG_INIT_RAM_ADDR + CFG_GBL_DATA_OFFSET);
/* Clear initial global data */ memset ((void *) gd, 0, sizeof (gd_t));
So, I searched the web and found someone that was working with u-boot and posted a possible GCC "optimization bug":
http://gcc.gnu.org/ml/gcc-bugs/2005-08/msg01984.html
And, in the end, a solution was given:
http://gcc.gnu.org/ml/gcc-bugs/2005-08/msg02003.html
This way, I modified the definition of DECLARE_GLOBAL_DATA_PTR to:
#define DECLARE_GLOBAL_DATA_PTR register gd_t*volatile gd asm ("r29");
Now I compile the code and the board runs! But, for my surprise, a lot of warnings are produced, like this:
cpu_init.c: In function 'cpu_init_f': cpu_init.c:99: warning: volatile register variables don't work as you might wish
I know my new declaration can be wrong. But the old one seems to be wrong too.
Any idea?
Best Regards, Addison Baldwin
On 2/2/06, Ron Kellam ronkbox-news@yahoo.com wrote:
If anyone had this problem, or if anyone have such a configuration working (GCC 4 and U-Boot 1.1.4 with this board), any help will be very appreciated.
I have a custom board very similar to the MPC8272ADS, but without the BCSR FPGA.
My board also hangs with u-boot 1.1.4 compiled with ELDK4.0's gcc 4, so the problem is not just the BCSR accesses.
For now I'm sticking with my ELDK3.1.1 compiled u-boot, as I don't have time to debug u-boot when I have a working one.
Could you please post your findings if you get to the bottom of it.
Regards, Ron Kellam
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&da... _______________________________________________ U-Boot-Users mailing list
</snip>
Your U-Boot support team
DENX Support System
