[U-Boot] [U-boot] [Patch 0/2] keystone: nand: add additional nand ecclayout
This series adds a nand ecclayout command to davinci nand that allows the ecclayout of the current nand device to be changed during run time. This feature is useful when using u-boot to write something to nand flash that will be read by other applications, such as ROM bootloader, that expects a different ECC layout. In that case, change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Based on u-boot.git/master
WingMan Kwok (2): common: cmd_nand: add nand ecclayout command mtd: nand: davinci: allow to change ecclayout by ecclayout command
common/cmd_nand.c | 115 +++++++++++++++++++++++++++++++++++++++- drivers/mtd/nand/davinci_nand.c | 101 +++++++++++++++++++++++++++++++++++ include/nand.h | 10 ++++ 3 files changed, 225 insertions(+), 1 deletion(-)
This commit adds a nand ecclayout command that allows the ecclayout of the current nand device to be changed during run time. This feature is useful when using u-boot to write something to nand flash that will be read by other applications, such as ROM bootloader, that expects a different ECC layout. In that case, change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Signed-off-by: WingMan Kwok w-kwok2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- common/cmd_nand.c | 115 +++++++++++++++++++++++++++++++++++++++++++++++++++++- include/nand.h | 10 +++++ 2 files changed, 124 insertions(+), 1 deletion(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 04ab0f1..7cbe6fc 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -462,6 +462,53 @@ static void adjust_size_for_badblocks(loff_t *size, loff_t offset, int dev) } }
+#ifdef CONFIG_CMD_NAND_ECCLAYOUT +static void nand_print_ecclayout_info(struct nand_ecclayout *p) +{ + int i; + struct nand_oobfree *oobfree; + + if (!p) + return; + + printf(" num ecc bytes: %d\n", p->eccbytes); + puts(" ecc pos:\n "); + + for (i = 0; i < p->eccbytes; i++) { + if (i && !(i % 9)) + printf("\n "); + + printf("%2d ", p->eccpos[i]); + } + + puts("\n oobfree:\n"); + puts(" offset length\n"); + + oobfree = p->oobfree; + for (i = 0; oobfree->length && i < MTD_MAX_OOBFREE_ENTRIES_LARGE; i++) { + printf(" %2d %2d\n", oobfree->offset, oobfree->length); + oobfree++; + } +} + +static void nand_print_device_ecclayout(int dev) +{ + int idx; + nand_info_t *nand = &nand_info[dev]; + struct nand_chip *chip = nand->priv; + + idx = board_nand_ecclayout_get_idx(chip, chip->ecc.layout); + + if (idx < 0) { + puts("no ecc layout\n"); + return; + } + + printf("\necc layout %d:\n", idx); + nand_print_ecclayout_info(chip->ecc.layout); +} +#endif + static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret = 0; @@ -506,8 +553,12 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) putc('\n'); if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE) puts("no devices available\n"); - else + else { nand_print_and_set_info(dev); +#ifdef CONFIG_CMD_NAND_ECCLAYOUT + nand_print_device_ecclayout(dev); +#endif + } return 0; }
@@ -836,6 +887,60 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif
+#ifdef CONFIG_CMD_NAND_ECCLAYOUT + if (strcmp(cmd, "ecclayout") == 0) { + int idx; + struct nand_ecclayout *p; + nand_info_t *nand = &nand_info[dev]; + struct nand_chip *chip = nand->priv; + + if (argc < 3) { + puts("Current device ecclayout:\n"); + nand_print_device_ecclayout(dev); + return 0; + } + + if (!strcmp(argv[2], "set")) { + if (argc < 4) + return 1; + + idx = (int)simple_strtoul(argv[3], NULL, 10); + if (!board_nand_ecclayout_set(chip, idx)) { + p = chip->ecc.layout; + p->oobavail = 0; + for (i = 0; p->oobfree[i].length && + i < ARRAY_SIZE(p->oobfree); i++) + p->oobavail += p->oobfree[i].length; + + nand->oobavail = p->oobavail; + } else { + printf("Setting current device" + " to ecc layout %d FAILED!\n", idx); + } + + return 0; + } + + if (strcmp(argv[2], "all") != 0) + return 1; + + /* show all available ecc layouts */ + puts("Available ecc layouts:\n"); + + idx = 0; + while (1) { + p = board_nand_ecclayout_get_layout(chip, idx); + if (!p) + break; + + printf("\n ecc layout %d:\n", idx++); + nand_print_ecclayout_info(p); + } + + return 0; + } +#endif + usage: return CMD_RET_USAGE; } @@ -890,6 +995,14 @@ static char nand_help_text[] = "nand env.oob set off|partition - set enviromnent offset\n" "nand env.oob get - get environment offset" #endif +#ifdef CONFIG_CMD_NAND_ECCLAYOUT + "\n" + "nand ecclayout <set <idx>|all> - show or set ecclayout" + " of current device\n" + " 'all' shows all available ecc layouts for setting" + " to current device\n" + " 'set' sets current device ecc layout to layout indexed by idx\n" +#endif ""; #endif
diff --git a/include/nand.h b/include/nand.h index fc735d1..0e8a093 100644 --- a/include/nand.h +++ b/include/nand.h @@ -155,6 +155,16 @@ void nand_deselect(void); void board_nand_select_device(struct nand_chip *nand, int chip); #endif
+#ifdef CONFIG_CMD_NAND_ECCLAYOUT +int board_nand_ecclayout_get_idx(struct nand_chip *nand, + struct nand_ecclayout *p); + +struct nand_ecclayout *board_nand_ecclayout_get_layout(struct nand_chip *nand, + int idx); + +int board_nand_ecclayout_set(struct nand_chip *nand, int idx); +#endif + __attribute__((noreturn)) void nand_boot(void);
#endif
- int i;
- struct nand_oobfree *oobfree;
- if (!p)
return;
- printf(" num ecc bytes: %d\n", p->eccbytes);
- puts(" ecc pos:\n ");
- for (i = 0; i < p->eccbytes; i++) {
if (i && !(i % 9))
printf("\n ");
Why 9?
- puts("\n oobfree:\n");
- puts(" offset length\n");
- oobfree = p->oobfree;
- for (i = 0; oobfree->length && i < MTD_MAX_OOBFREE_ENTRIES_LARGE; i++) {
oobfree++;
- int idx;
- nand_info_t *nand = &nand_info[dev];
- struct nand_chip *chip = nand->priv;
- idx = board_nand_ecclayout_get_idx(chip, chip->ecc.layout);
- if (idx < 0) {
return;
- printf("\necc layout %d:\n", idx);
- nand_print_ecclayout_info(chip->ecc.layout);
+} +#endif
else
}} return 0;
Braces are needed on both sides of if/else if used on one side.
It would be better to provide an inline no-op stub when CONFIG_CMD_NAND_ECCLAYOUT, than ifdeffing at the call site.
Does it really make sense to dump this information here, when the user could use the ecclayout command instead?
- if (strcmp(cmd, "ecclayout") == 0) {
int idx;
if (argc < 3) {
if (argc < 4)
return 1;
p->oobavail = 0;
Shouldn't board_nand_ecclayout_set() take care of this? Possibly via common helper functions, but not here.
} else {
Don't wrap user-visible strings (checkpatch should have warned you about this).
return 1;
idx = 0;
while (1) {
if (!p)
break;
Please use a for loop rather than hiding the increment in the loop body.
- "\n"
- "nand ecclayout <set <idx>|all> - show or set ecclayout"
- " of current device\n"
- " 'all' shows all available ecc layouts for setting"
- " to current device\n"
- " 'set' sets current device ecc layout to layout indexed by idx\n"
This help text doesn't include the plain "nand ecclayout" to show the current layout.
int idx);
Don't ifdef prototypes.
-Scott
- int i;
- if (!p)
return;
if (i && !(i % 9))
printf("\n ");
Why 9?
It's to print a new line on every 9th character position. I'll add a comment.
oobfree++;
- int idx;
- if (idx < 0) {
return;
+} +#endif
- static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret = 0;
else
}} return 0;
Yes.
Yes. It's better.
Yes. Seems it's redundant. I'll better delete it.
int idx;
if (argc < 3) {
if (argc < 4)
return 1;
p->oobavail = 0;
Yes, It should be moved to board_nand_ecclayout_set()
} else {
For user's eyes it's not wrapped.
return 1;
idx = 0;
while (1) {
if (!p)
break;
Ok.
- usage: return CMD_RET_USAGE; }
- "\n"
Yes.
int idx);
Ok. Thanks! I will repost soon.
-Scott
if (i && !(i % 9))
printf("\n ");
Why 9?
OK, Scott, breath... I got this one. It'll be OK...
Ivan, I am confident Scott understood that a newline would be generated every ninth-character. We all get that. I think what Scott was asking was why the value 9 was chosen? Why not 10? Or 8? Or 145? Was it to fit some arbitrary line length or screen size? Would it make more sense to use something familiar like a base 10 or half of base-16?
Thanks, jdl
if (i && !(i % 9))
printf("\n ");
Why 9?
More specifically, it neither avoids a division (as a power of two would) nor does it seem to match the ecc size of the layouts used by the davinci driver (which is the only user of this so far), nor is it anywhere near 80 columns.
Also, why is the field width two characters, when ecc positions can exceed 100?
-Scott
if (i && !(i % 9))
printf("\n ");
Why 9?
-Scott
Ok, I'll try to correct as you proposed. I dislike it also ... Thanks.
} else {
That's not the point. Wrapping it in the source means the user can't grep for the string. Checkpatch should have issued a warning about this. This is an exception to the 80 column rule.
-Scott
} else {
-Scott
Ok.
This patch adds opportunity to change ecclayout of current nand device during runtime. So we can change the current nand device ecclayout using the "nand ecclayout set" command before writing the data to nand flash.
Signed-off-by: Hao Zhang hzhang@ti.com Signed-off-by: WingMan Kwok w-kwok2@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- drivers/mtd/nand/davinci_nand.c | 101 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 101 insertions(+)
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index 75b03a7..b33de0d 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -306,6 +306,103 @@ static struct nand_ecclayout nand_davinci_4bit_layout_oobfirst = { #endif };
+#if defined(CONFIG_CMD_NAND_ECCLAYOUT) +#if defined(CONFIG_SYS_NAND_PAGE_2K) +static struct nand_ecclayout nand_keystone_rbl_4bit_layout_oobfirst = { + .eccbytes = 40, + .eccpos = { + 6, 7, + 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, + 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, + 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, + 56, 57, 58, 59, 60, 61, 62, 63, + }, + .oobfree = { + {.offset = 2, .length = 4, }, + {.offset = 16, .length = 6, }, + {.offset = 32, .length = 6, }, + {.offset = 48, .length = 6, }, + }, +}; +#elif defined(CONFIG_SYS_NAND_PAGE_4K) +static struct nand_ecclayout nand_keystone_rbl_4bit_layout_oobfirst = { + .eccbytes = 80, + .eccpos = { + 6, 7, + 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, + 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, + 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, + 56, 57, 58, 59, 60, 61, 62, 63, + 70, 71, + 72, 73, 74, 75, 76, 77, 78, 79, + 86, 87, + 88, 89, 90, 91, 92, 93, 94, 95, + 102, 103, + 104, 105, 106, 107, 108, 109, 110, 111, + 118, 119, + 120, 121, 122, 123, 124, 125, 126, 127, + }, + .oobfree = { + {.offset = 2, .length = 4, }, + {.offset = 16, .length = 6, }, + {.offset = 32, .length = 6, }, + {.offset = 48, .length = 6, }, + {.offset = 64, .length = 6, }, + {.offset = 80, .length = 6, }, + {.offset = 96, .length = 6, }, + {.offset = 112, .length = 6, }, + }, +}; +#endif + +#define NAND_ECCLAYOUT_NUM 2 + +struct nand_ecclayout *davinci_nand_ecclayouts[NAND_ECCLAYOUT_NUM] = { + &nand_davinci_4bit_layout_oobfirst, + &nand_keystone_rbl_4bit_layout_oobfirst, +}; + +int board_nand_ecclayout_get_idx(struct nand_chip *nand, + struct nand_ecclayout *p) +{ + int i; + + if (!p) + return -1; + + for (i = 0; i < NAND_ECCLAYOUT_NUM; i++) + if (davinci_nand_ecclayouts[i] == p) + return i; + + return -1; +} + +struct nand_ecclayout *board_nand_ecclayout_get_layout(struct nand_chip *nand, + int idx) +{ + if ((idx >= 0) && (idx < NAND_ECCLAYOUT_NUM)) + return davinci_nand_ecclayouts[idx]; + else + return NULL; +} + +int board_nand_ecclayout_set(struct nand_chip *nand, int idx) +{ + if (idx < 0 || idx >= NAND_ECCLAYOUT_NUM) + return -1; + + nand->ecc.layout = davinci_nand_ecclayouts[idx]; + + return 0; +} +#endif + static void nand_davinci_4bit_enable_hwecc(struct mtd_info *mtd, int mode) { u32 val; @@ -631,7 +728,11 @@ void davinci_nand_init(struct nand_chip *nand) nand->ecc.calculate = nand_davinci_4bit_calculate_ecc; nand->ecc.correct = nand_davinci_4bit_correct_data; nand->ecc.hwctl = nand_davinci_4bit_enable_hwecc; +#ifndef CONFIG_CMD_NAND_ECCLAYOUT nand->ecc.layout = &nand_davinci_4bit_layout_oobfirst; +#else + nand->ecc.layout = &nand_keystone_rbl_4bit_layout_oobfirst; +#endif #endif /* Set address of hardware control function */ nand->cmd_ctrl = nand_davinci_hwcontrol;
Undocumented CONFIG symbol (yes, I know it's not new)... Also redundant with CONFIG_SYS_NAND_PAGE_SIZE (though that's only documented in the context of SPL).
- .eccbytes = 40,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
Why the odd 2/8 pattern?
- .oobfree = {
- .eccbytes = 80,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
70, 71,
86, 87,
102, 103,
118, 119,
- .oobfree = {
+}; +#endif
- &nand_davinci_4bit_layout_oobfirst,
- &nand_keystone_rbl_4bit_layout_oobfirst,
- int i;
- if (!p)
return -1;
- for (i = 0; i < NAND_ECCLAYOUT_NUM; i++)
return i;
- return -1;
Use ARRAY_SIZE().
int idx)
- if ((idx >= 0) && (idx < NAND_ECCLAYOUT_NUM))
- else
return NULL;
- if (idx < 0 || idx >= NAND_ECCLAYOUT_NUM)
return -1;
- nand->ecc.layout = davinci_nand_ecclayouts[idx];
+} +#endif
Put a comment on this indicating what condition the #endif is ending.
- nand->ecc.layout = &nand_keystone_rbl_4bit_layout_oobfirst;
Use "ifdef/else" rather than "ifndef/else".
Why does enabling layout selection change the default layout? Nothing in the changelog suggests that.
-Scott
- .eccbytes = 40,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
...I'll align.
- .oobfree = {
- .eccbytes = 80,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
70, 71,
86, 87,
102, 103,
118, 119,
- .oobfree = {
+}; +#endif
- int i;
- if (!p)
return -1;
return i;
- return -1;
Use ARRAY_SIZE().
Ok.
int idx)
- else
return NULL;
return -1;
+} +#endif
Ok.
It's not correct. I will move it to board code. I'll better do smth like the following:
In board config: #define CONFIG_SYS_NAND_SELF_INIT in board config:
In nand davinci header: #define NAND_DAVINCI_4BIT_LAYOUT 0 #define NAND_KEYSTONE_RBL_4BIT_LAYOUT 1
In board file: int board_nand_init(struct nand_chip *chip) { davinci_nand_init(chip); chip->ecc.layout = board_nand_ecclayout_get_layout(NAND_KEYSTONE_RBL_4BIT_LAYOUT);
return 0; }
-Scott
Thanks a lot Scott, I will send the new series soon.
- .eccbytes = 40,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
...I'll align.
- .oobfree = {
- .eccbytes = 80,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
70, 71,
86, 87,
102, 103,
118, 119,
- .oobfree = {
+}; +#endif
- int i;
- if (!p)
return -1;
return i;
- return -1;
Use ARRAY_SIZE().
Ok.
int idx)
- else
return NULL;
return -1;
+} +#endif
Ok.
What does CONFIG_SYS_NAND_SELF_INIT have to do with this? Note that with that set, board_nand_init does not take an argument.
"board_nand_ecclayout_get_layout" is a bit long -- how about just "board_nand_get_ecclayout"?
-Scott
- .eccbytes = 40,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
...I'll align.
- .oobfree = {
- .eccbytes = 80,
- .eccpos = {
6, 7,
22, 23,
38, 39,
54, 55,
70, 71,
86, 87,
102, 103,
118, 119,
- .oobfree = {
+}; +#endif
- int i;
- if (!p)
return -1;
return i;
- return -1;
Use ARRAY_SIZE().
Ok.
int idx)
- else
return NULL;
return -1;
+} +#endif
Ok.
Yes. Just seeing this while implementing...It's not needed.
I will rename to board_nand_get_ecclayout
Ivan Khoronzhuk
Jon Loeliger
Scott Wood
