[U-Boot] [PATCH v4 0/2] arm: ppc: Share DPAA1 fixups between ARCHs
- Support DPAA1 QBMan device tree fixups in a shared location for both arm and ppc architectures - cleanup a define from header files and add as Kconfig with auto selection based on SOC
Changes in v4: - Update function name setup_portals() to setup_qbman_portals() in files that were missed the first time - Added QBMan support in Kconfig auto select for B4420 and T4160 SOCs
Changes in v3: - Add freescale old copyright in new file since it is a modified copy - Add ifdef QBMAN guard around get_qman_freq() - Return freq_qman instead of freq_systembus. More readable and robust - Add white space before return line in get_qman_freq()
Changes in v2: - Add get_qman_freq() to replace get_sys_info() for readability - Correct the copyright year in new files - Replace !ARM with PPC to wall off PowerPC SOCs specific qman setup - Rename portals.c -> fsl_portals.c for clarity
Ahmed Mansour (2): drivers/misc: Share qbman init between archs Move SYS_DPAA_QBMAN to Kconfig
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 4 + arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 9 + .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 14 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 29 ++ arch/arm/include/asm/arch-fsl-layerscape/speed.h | 3 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 3 +- arch/powerpc/cpu/mpc85xx/fdt.c | 1 + arch/powerpc/cpu/mpc85xx/portals.c | 281 ------------------- arch/powerpc/include/asm/fsl_liodn.h | 7 +- arch/powerpc/include/asm/fsl_portals.h | 4 - arch/powerpc/include/asm/immap_85xx.h | 60 ---- board/freescale/p1023rdb/p1023rdb.c | 2 +- board/keymile/kmp204x/kmp204x.c | 2 +- board/varisys/cyrus/cyrus.c | 2 +- drivers/misc/Makefile | 1 + drivers/misc/fsl_portals.c | 305 +++++++++++++++++++++ drivers/net/Kconfig | 24 ++ include/configs/B4860QDS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/ls1046a_common.h | 4 - include/fsl_qbman.h | 75 +++++ 32 files changed, 475 insertions(+), 368 deletions(-) create mode 100644 drivers/misc/fsl_portals.c create mode 100644 include/fsl_qbman.h
This patch adds changes necessary to move functionality present in PowerPC folders with ARM architectures that have DPAA1 QBMan hardware
- Create new board/freescale/common/fsl_portals.c to house shared device tree fixups for DPAA1 devices with ARM and PowerPC cores - Add new header file to top includes directory to allow files in both architectures to grab the function prototypes - Port inhibit_portals() from PowerPC to ARM. This function is used in setup to disable interrupts on all QMan and BMan portals. It is needed because the interrupts are enabled by default for all portals including unused/uninitialised portals. When the kernel attempts to go to deep sleep the unused portals prevent it from doing so
Signed-off-by: Ahmed Mansour ahmed.mansour@nxp.com
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 4 + arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 9 + .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 14 + .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 29 ++ arch/arm/include/asm/arch-fsl-layerscape/speed.h | 3 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 3 +- arch/powerpc/cpu/mpc85xx/fdt.c | 1 + arch/powerpc/cpu/mpc85xx/portals.c | 281 ------------------- arch/powerpc/include/asm/fsl_liodn.h | 7 +- arch/powerpc/include/asm/fsl_portals.h | 4 - arch/powerpc/include/asm/immap_85xx.h | 60 ---- board/freescale/p1023rdb/p1023rdb.c | 2 +- board/keymile/kmp204x/kmp204x.c | 2 +- board/varisys/cyrus/cyrus.c | 2 +- drivers/misc/Makefile | 1 + drivers/misc/fsl_portals.c | 305 +++++++++++++++++++++ include/configs/ls1043a_common.h | 2 + include/fsl_qbman.h | 75 +++++ 18 files changed, 453 insertions(+), 351 deletions(-) create mode 100644 drivers/misc/fsl_portals.c create mode 100644 include/fsl_qbman.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index d082629..3fd352f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -30,6 +30,7 @@ #endif #include <asm/arch/clock.h> #include <hwconfig.h> +#include <fsl_qbman.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -565,6 +566,9 @@ int arch_early_init_r(void) #ifdef CONFIG_FMAN_ENET fman_enet_init(); #endif +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_qbman_portals(); +#endif return 0; }
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index cae59da..382bf3d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -26,6 +26,8 @@ #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #include <asm/armv8/sec_firmware.h> #endif +#include <asm/arch/speed.h> +#include <fsl_qbman.h>
int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) { @@ -415,6 +417,13 @@ void ft_cpu_setup(void *blob, bd_t *bd) fdt_fixup_esdhc(blob, bd); #endif
+#ifdef CONFIG_SYS_DPAA_QBMAN + fdt_fixup_bportals(blob); + fdt_fixup_qportals(blob); + do_fixup_by_compat_u32(blob, "fsl,qman", + "clock-frequency", get_qman_freq(), 1); +#endif + #ifdef CONFIG_SYS_DPAA_FMAN fdt_fixup_fman_firmware(blob); #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 2d7775e..5f23aad 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -155,8 +155,22 @@ void get_sys_info(struct sys_info *sys_info) sys_info->freq_localbus = sys_info->freq_systembus / CONFIG_SYS_FSL_IFC_CLK_DIV; #endif +#ifdef CONFIG_SYS_DPAA_QBMAN + sys_info->freq_qman = sys_info->freq_systembus; +#endif }
+#ifdef CONFIG_SYS_DPAA_QBMAN +unsigned long get_qman_freq(void) +{ + struct sys_info sys_info; + + get_sys_info(&sys_info); + + return sys_info.freq_qman; +} +#endif + int get_clocks(void) { struct sys_info sys_info; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 2561ead..1ff5cac 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -23,6 +23,8 @@ #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00ee00b0) #define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) +#define CONFIG_SYS_FSL_BMAN_ADDR (CONFIG_SYS_IMMR + 0x00890000) +#define CONFIG_SYS_FSL_QMAN_ADDR (CONFIG_SYS_IMMR + 0x00880000) #define CONFIG_SYS_FSL_FMAN_ADDR (CONFIG_SYS_IMMR + 0x00a00000) #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_DCFG_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) @@ -41,6 +43,33 @@ #define CONFIG_SYS_SEC_MON_ADDR (CONFIG_SYS_IMMR + 0xe90000) #define CONFIG_SYS_SFP_ADDR (CONFIG_SYS_IMMR + 0xe80200)
+#define CONFIG_SYS_BMAN_NUM_PORTALS 10 +#define CONFIG_SYS_BMAN_MEM_BASE 0x508000000 +#define CONFIG_SYS_BMAN_MEM_PHYS (0xf00000000ull + \ + CONFIG_SYS_BMAN_MEM_BASE) +#define CONFIG_SYS_BMAN_MEM_SIZE 0x08000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x10000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x10000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0x3E80 +#define CONFIG_SYS_QMAN_NUM_PORTALS 10 +#define CONFIG_SYS_QMAN_MEM_BASE 0x500000000 +#define CONFIG_SYS_QMAN_MEM_PHYS (0xf00000000ull + \ + CONFIG_SYS_QMAN_MEM_BASE) +#define CONFIG_SYS_QMAN_MEM_SIZE 0x08000000 +#define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x10000 +#define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x10000 +#define CONFIG_SYS_QMAN_CENA_BASE CONFIG_SYS_QMAN_MEM_BASE +#define CONFIG_SYS_QMAN_CENA_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_CINH_BASE (CONFIG_SYS_QMAN_MEM_BASE + \ + CONFIG_SYS_QMAN_CENA_SIZE) +#define CONFIG_SYS_QMAN_CINH_SIZE (CONFIG_SYS_QMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_QMAN_SWP_ISDR_REG 0x3680 + #define CONFIG_SYS_FSL_TIMER_ADDR 0x02b00000
#define I2C1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01180000) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/speed.h b/arch/arm/include/asm/arch-fsl-layerscape/speed.h index de795f6..e94fe8e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/speed.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/speed.h @@ -7,4 +7,7 @@ #ifndef _FSL_LAYERSCAPE_SPEED_H #define _FSL_LAYERSCAPE_SPEED_H void get_sys_info(struct sys_info *sys_info); +#ifdef CONFIG_SYS_DPAA_QBMAN +unsigned long get_qman_freq(void); +#endif #endif /* _FSL_LAYERSCAPE_SPEED_H */ diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index ea46e49..b350bfe 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -26,6 +26,7 @@ #ifdef CONFIG_FSL_CORENET #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h> +#include <fsl_qbman.h> #endif #include <fsl_usb.h> #include <hwconfig.h> @@ -804,7 +805,7 @@ int cpu_init_r(void) #ifdef CONFIG_FSL_CORENET set_liodns(); #ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); + setup_qbman_portals(); #endif #endif
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 297dc4a..1159f06 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -15,6 +15,7 @@ #include <asm/io.h> #include <asm/fsl_fdt.h> #include <asm/fsl_portals.h> +#include <fsl_qbman.h> #include <hwconfig.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 3777c6f..b298d11 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -14,75 +14,6 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h>
-#define MAX_BPORTALS (CONFIG_SYS_BMAN_CINH_SIZE / CONFIG_SYS_BMAN_SP_CINH_SIZE) -#define MAX_QPORTALS (CONFIG_SYS_QMAN_CINH_SIZE / CONFIG_SYS_QMAN_SP_CINH_SIZE) -static void inhibit_portals(void __iomem *addr, int max_portals, - int arch_max_portals, int portal_cinh_size) -{ - uint32_t val; - int i; - - /* arch_max_portals is the maximum based on memory size. This includes - * the reserved memory in the SoC. max_portals the number of physical - * portals in the SoC */ - if (max_portals > arch_max_portals) { - printf("ERROR: portal config error\n"); - max_portals = arch_max_portals; - } - - for (i = 0; i < max_portals; i++) { - out_be32(addr, -1); - val = in_be32(addr); - if (!val) { - printf("ERROR: Stopped after %d portals\n", i); - goto done; - } - addr += portal_cinh_size; - } -#ifdef DEBUG - printf("Cleared %d portals\n", i); -#endif -done: - - return; -} - -void setup_portals(void) -{ - ccsr_qman_t *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; - void __iomem *bpaddr = (void *)CONFIG_SYS_BMAN_CINH_BASE + - CONFIG_SYS_BMAN_SWP_ISDR_REG; - void __iomem *qpaddr = (void *)CONFIG_SYS_QMAN_CINH_BASE + - CONFIG_SYS_QMAN_SWP_ISDR_REG; -#ifdef CONFIG_FSL_CORENET - int i; - - for (i = 0; i < CONFIG_SYS_QMAN_NUM_PORTALS; i++) { - u8 sdest = qp_info[i].sdest; - u16 fliodn = qp_info[i].fliodn; - u16 dliodn = qp_info[i].dliodn; - u16 liodn_off = qp_info[i].liodn_offset; - - out_be32(&qman->qcsp[i].qcsp_lio_cfg, (liodn_off << 16) | - dliodn); - /* set frame liodn */ - out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | fliodn); - } -#endif - - /* Set the Qman initiator BAR to match the LAW (for DQRR stashing) */ -#ifdef CONFIG_PHYS_64BIT - out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); -#endif - out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); - - /* Change default state of BMan ISDR portals to all 1s */ - inhibit_portals(bpaddr, CONFIG_SYS_BMAN_NUM_PORTALS, MAX_BPORTALS, - CONFIG_SYS_BMAN_SP_CINH_SIZE); - inhibit_portals(qpaddr, CONFIG_SYS_QMAN_NUM_PORTALS, MAX_QPORTALS, - CONFIG_SYS_QMAN_SP_CINH_SIZE); -} - /* Update portal containter to match LAW setup of portal in phy map */ void fdt_portal(void *blob, const char *compat, const char *container, u64 addr, u32 size) @@ -142,215 +73,3 @@ void fdt_portal(void *blob, const char *compat, const char *container,
printf("ERROR: %s isn't in a container. Not supported\n", compat); } - -static int fdt_qportal(void *blob, int off, int id, char *name, - enum fsl_dpaa_dev dev, int create) -{ - int childoff, dev_off, ret = 0; - uint32_t dev_handle; -#ifdef CONFIG_FSL_CORENET - int num; - u32 liodns[2]; -#endif - - childoff = fdt_subnode_offset(blob, off, name); - if (create) { - char handle[64], *p; - - strncpy(handle, name, sizeof(handle)); - p = strchr(handle, '@'); - if (!strncmp(name, "fman", 4)) { - *p = *(p + 1); - p++; - } - *p = '\0'; - - dev_off = fdt_path_offset(blob, handle); - /* skip this node if alias is not found */ - if (dev_off == -FDT_ERR_BADPATH) - return 0; - if (dev_off < 0) - return dev_off; - - if (childoff <= 0) - childoff = fdt_add_subnode(blob, off, name); - - /* need to update the dev_off after adding a subnode */ - dev_off = fdt_path_offset(blob, handle); - if (dev_off < 0) - return dev_off; - - if (childoff > 0) { - dev_handle = fdt_get_phandle(blob, dev_off); - if (dev_handle <= 0) { - dev_handle = fdt_alloc_phandle(blob); - ret = fdt_set_phandle(blob, dev_off, - dev_handle); - if (ret < 0) - return ret; - } - - ret = fdt_setprop(blob, childoff, "dev-handle", - &dev_handle, sizeof(dev_handle)); - if (ret < 0) - return ret; - -#ifdef CONFIG_FSL_CORENET - num = get_dpaa_liodn(dev, &liodns[0], id); - ret = fdt_setprop(blob, childoff, "fsl,liodn", - &liodns[0], sizeof(u32) * num); - if (!strncmp(name, "pme", 3)) { - u32 pme_rev1, pme_rev2; - ccsr_pme_t *pme_regs = - (void *)CONFIG_SYS_FSL_CORENET_PME_ADDR; - - pme_rev1 = in_be32(&pme_regs->pm_ip_rev_1); - pme_rev2 = in_be32(&pme_regs->pm_ip_rev_2); - ret = fdt_setprop(blob, childoff, - "fsl,pme-rev1", &pme_rev1, sizeof(u32)); - if (ret < 0) - return ret; - ret = fdt_setprop(blob, childoff, - "fsl,pme-rev2", &pme_rev2, sizeof(u32)); - } -#endif - } else { - return childoff; - } - } else { - if (childoff > 0) - ret = fdt_del_node(blob, childoff); - } - - return ret; -} - -void fdt_fixup_qportals(void *blob) -{ - int off, err; - unsigned int maj, min; - unsigned int ip_cfg; - ccsr_qman_t *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; - u32 rev_1 = in_be32(&qman->ip_rev_1); - u32 rev_2 = in_be32(&qman->ip_rev_2); - char compat[64]; - int compat_len; - - maj = (rev_1 >> 8) & 0xff; - min = rev_1 & 0xff; - ip_cfg = rev_2 & 0xff; - - compat_len = sprintf(compat, "fsl,qman-portal-%u.%u.%u", - maj, min, ip_cfg) + 1; - compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1; - - off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); - while (off != -FDT_ERR_NOTFOUND) { -#ifdef CONFIG_FSL_CORENET - u32 liodns[2]; -#endif - const int *ci = fdt_getprop(blob, off, "cell-index", &err); - int i; - - if (!ci) - goto err; - - i = *ci; -#ifdef CONFIG_SYS_DPAA_FMAN - int j; -#endif - - err = fdt_setprop(blob, off, "compatible", compat, compat_len); - if (err < 0) - goto err; - -#ifdef CONFIG_FSL_CORENET - liodns[0] = qp_info[i].dliodn; - liodns[1] = qp_info[i].fliodn; - - err = fdt_setprop(blob, off, "fsl,liodn", - &liodns, sizeof(u32) * 2); - if (err < 0) - goto err; -#endif - - i++; - - err = fdt_qportal(blob, off, i, "crypto@0", FSL_HW_PORTAL_SEC, - IS_E_PROCESSOR(get_svr())); - if (err < 0) - goto err; - -#ifdef CONFIG_FSL_CORENET -#ifdef CONFIG_SYS_DPAA_PME - err = fdt_qportal(blob, off, i, "pme@0", FSL_HW_PORTAL_PME, 1); - if (err < 0) - goto err; -#else - fdt_qportal(blob, off, i, "pme@0", FSL_HW_PORTAL_PME, 0); -#endif -#endif - -#ifdef CONFIG_SYS_DPAA_FMAN - for (j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { - char name[] = "fman@0"; - - name[sizeof(name) - 2] = '0' + j; - err = fdt_qportal(blob, off, i, name, - FSL_HW_PORTAL_FMAN1 + j, 1); - if (err < 0) - goto err; - } -#endif -#ifdef CONFIG_SYS_DPAA_RMAN - err = fdt_qportal(blob, off, i, "rman@0", - FSL_HW_PORTAL_RMAN, 1); - if (err < 0) - goto err; -#endif - -err: - if (err < 0) { - printf("ERROR: unable to create props for %s: %s\n", - fdt_get_name(blob, off, NULL), fdt_strerror(err)); - return; - } - - off = fdt_node_offset_by_compatible(blob, off, "fsl,qman-portal"); - } -} - -void fdt_fixup_bportals(void *blob) -{ - int off, err; - unsigned int maj, min; - unsigned int ip_cfg; - ccsr_bman_t *bman = (void *)CONFIG_SYS_FSL_BMAN_ADDR; - u32 rev_1 = in_be32(&bman->ip_rev_1); - u32 rev_2 = in_be32(&bman->ip_rev_2); - char compat[64]; - int compat_len; - - maj = (rev_1 >> 8) & 0xff; - min = rev_1 & 0xff; - - ip_cfg = rev_2 & 0xff; - - compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u", - maj, min, ip_cfg) + 1; - compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1; - - off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal"); - while (off != -FDT_ERR_NOTFOUND) { - err = fdt_setprop(blob, off, "compatible", compat, compat_len); - if (err < 0) { - printf("ERROR: unable to create props for %s: %s\n", - fdt_get_name(blob, off, NULL), - fdt_strerror(err)); - return; - } - - off = fdt_node_offset_by_compatible(blob, off, "fsl,bman-portal"); - } - -} diff --git a/arch/powerpc/include/asm/fsl_liodn.h b/arch/powerpc/include/asm/fsl_liodn.h index 8c91e72..0ccb79c 100644 --- a/arch/powerpc/include/asm/fsl_liodn.h +++ b/arch/powerpc/include/asm/fsl_liodn.h @@ -8,6 +8,7 @@ #define _FSL_LIODN_H_
#include <asm/types.h> +#include <fsl_qbman.h>
struct srio_liodn_id_table { u32 id[2]; @@ -128,12 +129,14 @@ extern void fdt_fixup_liodn(void *blob); CONFIG_SYS_MPC85xx_TDM_OFFSET)
#define SET_QMAN_LIODN(liodn) \ - SET_LIODN_ENTRY_1("fsl,qman", liodn, offsetof(ccsr_qman_t, liodnr) + \ + SET_LIODN_ENTRY_1("fsl,qman", liodn, \ + offsetof(struct ccsr_qman, liodnr) + \ CONFIG_SYS_FSL_QMAN_OFFSET, \ CONFIG_SYS_FSL_QMAN_OFFSET)
#define SET_BMAN_LIODN(liodn) \ - SET_LIODN_ENTRY_1("fsl,bman", liodn, offsetof(ccsr_bman_t, liodnr) + \ + SET_LIODN_ENTRY_1("fsl,bman", liodn, \ + offsetof(struct ccsr_bman, liodnr) + \ CONFIG_SYS_FSL_BMAN_OFFSET, \ CONFIG_SYS_FSL_BMAN_OFFSET)
diff --git a/arch/powerpc/include/asm/fsl_portals.h b/arch/powerpc/include/asm/fsl_portals.h index f13ba14..10d459e 100644 --- a/arch/powerpc/include/asm/fsl_portals.h +++ b/arch/powerpc/include/asm/fsl_portals.h @@ -41,10 +41,6 @@ struct qportal_info {
extern int get_dpaa_liodn(enum fsl_dpaa_dev dpaa_dev, u32 *liodns, int liodn_offset); -extern void setup_portals(void); -extern void fdt_fixup_qportals(void *blob); -extern void fdt_fixup_bportals(void *blob); - extern struct qportal_info qp_info[]; extern void fdt_portal(void *blob, const char *compat, const char *container, u64 addr, u32 size); diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index ee537f4..841f3d9 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2702,66 +2702,6 @@ enum { FSL_SRDS_B3_LANE_D = 23, };
-typedef struct ccsr_qman { -#ifdef CONFIG_SYS_FSL_QMAN_V3 - u8 res0[0x200]; -#else - struct { - u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ - u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ - u32 res; - u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg */ - } qcsp[32]; -#endif - /* Not actually reserved, but irrelevant to u-boot */ - u8 res[0xbf8 - 0x200]; - u32 ip_rev_1; - u32 ip_rev_2; - u32 fqd_bare; /* FQD Extended Base Addr Register */ - u32 fqd_bar; /* FQD Base Addr Register */ - u8 res1[0x8]; - u32 fqd_ar; /* FQD Attributes Register */ - u8 res2[0xc]; - u32 pfdr_bare; /* PFDR Extended Base Addr Register */ - u32 pfdr_bar; /* PFDR Base Addr Register */ - u8 res3[0x8]; - u32 pfdr_ar; /* PFDR Attributes Register */ - u8 res4[0x4c]; - u32 qcsp_bare; /* QCSP Extended Base Addr Register */ - u32 qcsp_bar; /* QCSP Base Addr Register */ - u8 res5[0x78]; - u32 ci_sched_cfg; /* Initiator Scheduling Configuration */ - u32 srcidr; /* Source ID Register */ - u32 liodnr; /* LIODN Register */ - u8 res6[4]; - u32 ci_rlm_cfg; /* Initiator Read Latency Monitor Cfg */ - u32 ci_rlm_avg; /* Initiator Read Latency Monitor Avg */ - u8 res7[0x2e8]; -#ifdef CONFIG_SYS_FSL_QMAN_V3 - struct { - u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ - u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ - u32 res; - u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg*/ - } qcsp[50]; -#endif -} ccsr_qman_t; - -typedef struct ccsr_bman { - /* Not actually reserved, but irrelevant to u-boot */ - u8 res[0xbf8]; - u32 ip_rev_1; - u32 ip_rev_2; - u32 fbpr_bare; /* FBPR Extended Base Addr Register */ - u32 fbpr_bar; /* FBPR Base Addr Register */ - u8 res1[0x8]; - u32 fbpr_ar; /* FBPR Attributes Register */ - u8 res2[0xf0]; - u32 srcidr; /* Source ID Register */ - u32 liodnr; /* LIODN Register */ - u8 res7[0x2f4]; -} ccsr_bman_t; - typedef struct ccsr_pme { u8 res0[0x804]; u32 liodnbr; /* LIODN Base Register */ diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c index ccda824..e950d18 100644 --- a/board/freescale/p1023rdb/p1023rdb.c +++ b/board/freescale/p1023rdb/p1023rdb.c @@ -81,7 +81,7 @@ int board_early_init_r(void) MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, flash_esel, BOOKE_PAGESZ_256M, 1);
return 0; } diff --git a/board/keymile/kmp204x/kmp204x.c b/board/keymile/kmp204x/kmp204x.c index 8c9d6b1..d70b1d1 100644 --- a/board/keymile/kmp204x/kmp204x.c +++ b/board/keymile/kmp204x/kmp204x.c @@ -126,7 +126,7 @@ int board_early_init_r(void) invalidate_icache();
set_liodns(); - setup_portals(); + setup_qbman_portals();
ret = trigger_fpga_config(); if (ret) diff --git a/board/varisys/cyrus/cyrus.c b/board/varisys/cyrus/cyrus.c index 30f518a..f458627 100644 --- a/board/varisys/cyrus/cyrus.c +++ b/board/varisys/cyrus/cyrus.c @@ -69,7 +69,7 @@ int board_early_init_r(void) set_liodns();
#ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); + setup_qbman_portals(); #endif print_lbc_regs(); return 0; diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index ada7624..e8d598c 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -53,3 +53,4 @@ obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o obj-$(CONFIG_STM32_RCC) += stm32_rcc.o +obj-$(CONFIG_SYS_DPAA_QBMAN) += fsl_portals.o diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c new file mode 100644 index 0000000..3b3dd02 --- /dev/null +++ b/drivers/misc/fsl_portals.c @@ -0,0 +1,305 @@ +/* + * Copyright 2008-2011 Freescale Semiconductor, Inc. + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <libfdt.h> +#include <fdt_support.h> + +#include <asm/processor.h> +#include <asm/io.h> +#ifdef CONFIG_PPC +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#endif +#include <fsl_qbman.h> + +#define MAX_BPORTALS (CONFIG_SYS_BMAN_CINH_SIZE / CONFIG_SYS_BMAN_SP_CINH_SIZE) +#define MAX_QPORTALS (CONFIG_SYS_QMAN_CINH_SIZE / CONFIG_SYS_QMAN_SP_CINH_SIZE) +void setup_qbman_portals(void) +{ + void __iomem *bpaddr = (void *)CONFIG_SYS_BMAN_CINH_BASE + + CONFIG_SYS_BMAN_SWP_ISDR_REG; + void __iomem *qpaddr = (void *)CONFIG_SYS_QMAN_CINH_BASE + + CONFIG_SYS_QMAN_SWP_ISDR_REG; +#ifdef CONFIG_PPC + struct ccsr_qman *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; + + /* Set the Qman initiator BAR to match the LAW (for DQRR stashing) */ +#ifdef CONFIG_PHYS_64BIT + out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); +#endif + out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); +#endif +#ifdef CONFIG_FSL_CORENET + int i; + + for (i = 0; i < CONFIG_SYS_QMAN_NUM_PORTALS; i++) { + u8 sdest = qp_info[i].sdest; + u16 fliodn = qp_info[i].fliodn; + u16 dliodn = qp_info[i].dliodn; + u16 liodn_off = qp_info[i].liodn_offset; + + out_be32(&qman->qcsp[i].qcsp_lio_cfg, (liodn_off << 16) | + dliodn); + /* set frame liodn */ + out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | fliodn); + } +#endif + + /* Change default state of BMan ISDR portals to all 1s */ + inhibit_portals(bpaddr, CONFIG_SYS_BMAN_NUM_PORTALS, MAX_BPORTALS, + CONFIG_SYS_BMAN_SP_CINH_SIZE); + inhibit_portals(qpaddr, CONFIG_SYS_QMAN_NUM_PORTALS, MAX_QPORTALS, + CONFIG_SYS_QMAN_SP_CINH_SIZE); +} + +void inhibit_portals(void __iomem *addr, int max_portals, + int arch_max_portals, int portal_cinh_size) +{ + u32 val; + int i; + + /* arch_max_portals is the maximum based on memory size. This includes + * the reserved memory in the SoC. max_portals the number of physical + * portals in the SoC + */ + if (max_portals > arch_max_portals) { + printf("ERROR: portal config error\n"); + max_portals = arch_max_portals; + } + + for (i = 0; i < max_portals; i++) { + out_be32(addr, -1); + val = in_be32(addr); + if (!val) { + printf("ERROR: Stopped after %d portals\n", i); + return; + } + addr += portal_cinh_size; + } + debug("Cleared %d portals\n", i); +} + +#ifdef CONFIG_PPC +static int fdt_qportal(void *blob, int off, int id, char *name, + enum fsl_dpaa_dev dev, int create) +{ + int childoff, dev_off, ret = 0; + u32 dev_handle; +#ifdef CONFIG_FSL_CORENET + int num; + u32 liodns[2]; +#endif + + childoff = fdt_subnode_offset(blob, off, name); + if (create) { + char handle[64], *p; + + strncpy(handle, name, sizeof(handle)); + p = strchr(handle, '@'); + if (!strncmp(name, "fman", 4)) { + *p = *(p + 1); + p++; + } + *p = '\0'; + + dev_off = fdt_path_offset(blob, handle); + /* skip this node if alias is not found */ + if (dev_off == -FDT_ERR_BADPATH) + return 0; + if (dev_off < 0) + return dev_off; + + if (childoff <= 0) + childoff = fdt_add_subnode(blob, off, name); + + /* need to update the dev_off after adding a subnode */ + dev_off = fdt_path_offset(blob, handle); + if (dev_off < 0) + return dev_off; + + if (childoff > 0) { + dev_handle = fdt_get_phandle(blob, dev_off); + if (dev_handle <= 0) { + dev_handle = fdt_alloc_phandle(blob); + ret = fdt_set_phandle(blob, dev_off, + dev_handle); + if (ret < 0) + return ret; + } + + ret = fdt_setprop(blob, childoff, "dev-handle", + &dev_handle, sizeof(dev_handle)); + if (ret < 0) + return ret; + +#ifdef CONFIG_FSL_CORENET + num = get_dpaa_liodn(dev, &liodns[0], id); + ret = fdt_setprop(blob, childoff, "fsl,liodn", + &liodns[0], sizeof(u32) * num); + if (!strncmp(name, "pme", 3)) { + u32 pme_rev1, pme_rev2; + ccsr_pme_t *pme_regs = + (void *)CONFIG_SYS_FSL_CORENET_PME_ADDR; + + pme_rev1 = in_be32(&pme_regs->pm_ip_rev_1); + pme_rev2 = in_be32(&pme_regs->pm_ip_rev_2); + ret = fdt_setprop(blob, childoff, + "fsl,pme-rev1", &pme_rev1, + sizeof(u32)); + if (ret < 0) + return ret; + ret = fdt_setprop(blob, childoff, + "fsl,pme-rev2", &pme_rev2, + sizeof(u32)); + } +#endif + } else { + return childoff; + } + } else { + if (childoff > 0) + ret = fdt_del_node(blob, childoff); + } + + return ret; +} +#endif /* CONFIG_PPC */ + +void fdt_fixup_qportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + struct ccsr_qman *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; + u32 rev_1 = in_be32(&qman->ip_rev_1); + u32 rev_2 = in_be32(&qman->ip_rev_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,qman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,qman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); + while (off != -FDT_ERR_NOTFOUND) { +#ifdef CONFIG_PPC +#ifdef CONFIG_FSL_CORENET + u32 liodns[2]; +#endif + const int *ci = fdt_getprop(blob, off, "cell-index", &err); + int i; + + if (!ci) + goto err; + + i = *ci; +#ifdef CONFIG_SYS_DPAA_FMAN + int j; +#endif + +#endif /* CONFIG_PPC */ + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) + goto err; +#ifdef CONFIG_PPC +#ifdef CONFIG_FSL_CORENET + liodns[0] = qp_info[i].dliodn; + liodns[1] = qp_info[i].fliodn; + err = fdt_setprop(blob, off, "fsl,liodn", + &liodns, sizeof(u32) * 2); + if (err < 0) + goto err; +#endif + + i++; + + err = fdt_qportal(blob, off, i, "crypto@0", FSL_HW_PORTAL_SEC, + IS_E_PROCESSOR(get_svr())); + if (err < 0) + goto err; + +#ifdef CONFIG_FSL_CORENET +#ifdef CONFIG_SYS_DPAA_PME + err = fdt_qportal(blob, off, i, "pme@0", FSL_HW_PORTAL_PME, 1); + if (err < 0) + goto err; +#else + fdt_qportal(blob, off, i, "pme@0", FSL_HW_PORTAL_PME, 0); +#endif +#endif + +#ifdef CONFIG_SYS_DPAA_FMAN + for (j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { + char name[] = "fman@0"; + + name[sizeof(name) - 2] = '0' + j; + err = fdt_qportal(blob, off, i, name, + FSL_HW_PORTAL_FMAN1 + j, 1); + if (err < 0) + goto err; + } +#endif +#ifdef CONFIG_SYS_DPAA_RMAN + err = fdt_qportal(blob, off, i, "rman@0", + FSL_HW_PORTAL_RMAN, 1); + if (err < 0) + goto err; +#endif +#endif /* CONFIG_PPC */ + +err: + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + + off = fdt_node_offset_by_compatible(blob, off, + "fsl,qman-portal"); + } +} + +void fdt_fixup_bportals(void *blob) +{ + int off, err; + unsigned int maj, min; + unsigned int ip_cfg; + struct ccsr_bman *bman = (void *)CONFIG_SYS_FSL_BMAN_ADDR; + u32 rev_1 = in_be32(&bman->ip_rev_1); + u32 rev_2 = in_be32(&bman->ip_rev_2); + char compat[64]; + int compat_len; + + maj = (rev_1 >> 8) & 0xff; + min = rev_1 & 0xff; + + ip_cfg = rev_2 & 0xff; + + compat_len = sprintf(compat, "fsl,bman-portal-%u.%u.%u", + maj, min, ip_cfg) + 1; + compat_len += sprintf(compat + compat_len, "fsl,bman-portal") + 1; + + off = fdt_node_offset_by_compatible(blob, -1, "fsl,bman-portal"); + while (off != -FDT_ERR_NOTFOUND) { + err = fdt_setprop(blob, off, "compatible", compat, compat_len); + if (err < 0) { + printf("ERROR: unable to create props for %s: %s\n", + fdt_get_name(blob, off, NULL), + fdt_strerror(err)); + return; + } + + off = fdt_node_offset_by_compatible(blob, off, + "fsl,bman-portal"); + } +} diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 67b5ea7..1a7ff56 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -194,6 +194,8 @@ #endif #endif
+#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ + /* FMan ucode */ #ifndef SPL_NO_FMAN #define CONFIG_SYS_DPAA_FMAN diff --git a/include/fsl_qbman.h b/include/fsl_qbman.h new file mode 100644 index 0000000..06262ec --- /dev/null +++ b/include/fsl_qbman.h @@ -0,0 +1,75 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_QBMAN_H__ +#define __FSL_QBMAN_H__ +void fdt_fixup_qportals(void *blob); +void fdt_fixup_bportals(void *blob); +void inhibit_portals(void __iomem *addr, int max_portals, + int arch_max_portals, int portal_cinh_size); +void setup_qbman_portals(void); + +struct ccsr_qman { +#ifdef CONFIG_SYS_FSL_QMAN_V3 + u8 res0[0x200]; +#else + struct { + u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ + u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ + u32 res; + u32 qcsp_dd_cfg; /* 0xc - SW Portal Dynamic Debug cfg */ + } qcsp[32]; +#endif + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8 - 0x200]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fqd_bare; /* FQD Extended Base Addr Register */ + u32 fqd_bar; /* FQD Base Addr Register */ + u8 res1[0x8]; + u32 fqd_ar; /* FQD Attributes Register */ + u8 res2[0xc]; + u32 pfdr_bare; /* PFDR Extended Base Addr Register */ + u32 pfdr_bar; /* PFDR Base Addr Register */ + u8 res3[0x8]; + u32 pfdr_ar; /* PFDR Attributes Register */ + u8 res4[0x4c]; + u32 qcsp_bare; /* QCSP Extended Base Addr Register */ + u32 qcsp_bar; /* QCSP Base Addr Register */ + u8 res5[0x78]; + u32 ci_sched_cfg; /* Initiator Scheduling Configuration */ + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res6[4]; + u32 ci_rlm_cfg; /* Initiator Read Latency Monitor Cfg */ + u32 ci_rlm_avg; /* Initiator Read Latency Monitor Avg */ + u8 res7[0x2e8]; +#ifdef CONFIG_SYS_FSL_QMAN_V3 + struct { + u32 qcsp_lio_cfg; /* 0x0 - SW Portal n LIO cfg */ + u32 qcsp_io_cfg; /* 0x4 - SW Portal n IO cfg */ + u32 res; + u32 qcsp_dd_cfg; /* 0xc - SW Portal n Dynamic Debug cfg*/ + } qcsp[50]; +#endif +}; + +struct ccsr_bman { + /* Not actually reserved, but irrelevant to u-boot */ + u8 res[0xbf8]; + u32 ip_rev_1; + u32 ip_rev_2; + u32 fbpr_bare; /* FBPR Extended Base Addr Register */ + u32 fbpr_bar; /* FBPR Base Addr Register */ + u8 res1[0x8]; + u32 fbpr_ar; /* FBPR Attributes Register */ + u8 res2[0xf0]; + u32 srcidr; /* Source ID Register */ + u32 liodnr; /* LIODN Register */ + u8 res7[0x2f4]; +}; + +#endif /* __FSL_QBMAN_H__ */
Changes in v4:
You still have a problem with P1023RDB. Please use buildman to test all mpc85xx boards before you send another version.
York
The CONFIG_SYS_DPAA_QBMAN define is used by DPAA1 freescale SOCs to add device tree fixups that allow deep sleep in Linux. The define was placed in header files included by a number of boards, but was not explicitly documented in any of the Kconfigs. A description was added to the drivers/networking menuconfig and default selection for current SOCs that have this part
Changes in v4: - Added QBMan support in Kconfig auto select for B4420 and T4160 SOCs
drivers/net/Kconfig | 24 ++++++++++++++++++++++++ include/configs/B4860QDS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/ls1043a_common.h | 2 -- include/configs/ls1046a_common.h | 4 ---- 16 files changed, 24 insertions(+), 19 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 52555da..49f78fc 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -365,4 +365,28 @@ config FEC2_PHY_NORXERR The PHY does not have a RXERR line (RMII only). (so program the FEC to ignore it).
+config SYS_DPAA_QBMAN + bool "Device tree fixup for QBMan on freescale SOCs" + depends on (ARM || PPC) && !SPL_BUILD + default y if ARCH_B4860 || \ + ARCH_B4420 || \ + ARCH_P1023 || \ + ARCH_P2041 || \ + ARCH_T1023 || \ + ARCH_T1024 || \ + ARCH_T1040 || \ + ARCH_T1042 || \ + ARCH_T2080 || \ + ARCH_T2081 || \ + ARCH_T4240 || \ + ARCH_T4160 || \ + ARCH_P4080 || \ + ARCH_P3041 || \ + ARCH_P5040 || \ + ARCH_P5020 || \ + ARCH_LS1043A || \ + ARCH_LS1046A + help + QBman fixups to allow deep sleep in DPAA 1 SOCs + endif # NETDEVICES diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 661bc8b..7f9482d 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -572,7 +572,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 25 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 1b78a4f..56e3f48 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -272,7 +272,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_LOADADDR 1000000
/* Qman/Bman */ -#define CONFIG_SYS_DPAA_QBMAN /* support Q/Bman */ #define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 #define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 917e5d5..aa89405 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -438,7 +438,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */
/* Qman/Bman */ -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index ed6df53..181ec42 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -642,7 +642,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 7dee2f0..e1f2196 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -649,7 +649,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index bc5c0d2..220eddc 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -532,7 +532,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 2b9c77f..5219b4f 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -642,7 +642,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 43fcc6f..bdff61a 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -584,7 +584,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 18 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index e1c57de..85bda94 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -522,7 +522,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 18 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 099e9e1..73e91bc 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -381,7 +381,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 50 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 98f8f4f..ead8a83 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -543,7 +543,6 @@ unsigned long get_board_ddr_clk(void);
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 50 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index d0e8bfb..88cf179 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -454,7 +454,6 @@ #define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
/* Qman/Bman */ -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 4fea53b..4b81bcf 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -317,7 +317,6 @@ #define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
/* Qman/Bman */ -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 10 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 1a7ff56..67b5ea7 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -194,8 +194,6 @@ #endif #endif
-#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ - /* FMan ucode */ #ifndef SPL_NO_FMAN #define CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index e208f7d..5c2ad69 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -155,10 +155,6 @@ #endif #endif
-#ifndef SPL_NO_QBMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ -#endif - /* FMan ucode */ #ifndef SPL_NO_FMAN #define CONFIG_SYS_DPAA_FMAN
Changes in v4:
You still have problems with kmlion1 kmcoge4 T1024QDS_DDR4. Please test all mpc85xx boards before sending another version.
York
Ahmed Mansour
York Sun
