[U-Boot] [PATCH] arm: ti: Add missing "=" from previous fix
While the original patch to fix a regression in distro boot for mmc on these platforms had the correct syntax, I broke the change while applying. Add back in the missing "=" here so that the syntax is correct.
Reported-by: Andre Heider a.heider@gmail.com Fixes: 27e0f3bcf075 ("arm: ti: Fix regression in distro boot for mmc") Signed-off-by: Tom Rini trini@konsulko.com --- include/environment/ti/mmc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/environment/ti/mmc.h b/include/environment/ti/mmc.h index ef053766088b..bb4af0a3d54b 100644 --- a/include/environment/ti/mmc.h +++ b/include/environment/ti/mmc.h @@ -56,7 +56,7 @@ "bootz; " \ "fi;\0" \ "mmcboot=mmc dev ${mmcdev}; " \ - "devnum ${mmcdev}; " \ + "devnum=${mmcdev}; " \ "setenv devtype mmc; " \ "if mmc rescan; then " \ "echo SD/MMC found on device ${mmcdev};" \
