[U-Boot] Error while Readin Flash Info(flinfo) in U-boot - Help
Hi Stefan,
I am Balaji. am using IMX6 base custom board. In my board am using S29GL01G NOR Flash to store u-boot and kernel. I understand from the data sheet this NOR Flash is CFI supported one. So i have added Configurations for CFI Flash driver. Currently am loading the U-boot into DDR3 and able to excute U-boot test commands. When i put flinfo , am getting "missing or unknow flash type" and while loading the u-boot it is printing as " Unknown flash on BANK 1 - Size - 0MB". So am not sure what am missing here or i have to add anything extra in the config file. Please request you to check and provide your suggestion.
Thanks , ShivBalaji ________________________________________ From: u-boot-bounces@lists.denx.de [u-boot-bounces@lists.denx.de] On Behalf Of u-boot-request@lists.denx.de [u-boot-request@lists.denx.de] Sent: Saturday, March 10, 2012 4:30 PM To: u-boot@lists.denx.de Subject: U-Boot Digest, Vol 46, Issue 17
Send U-Boot mailing list submissions to u-boot@lists.denx.de
To subscribe or unsubscribe via the World Wide Web, visit http://lists.denx.de/mailman/listinfo/u-boot or, via email, send a message with subject or body 'help' to u-boot-request@lists.denx.de
You can reach the person managing the list at u-boot-owner@lists.denx.de
When replying, please edit your Subject line so it is more specific than "Re: Contents of U-Boot digest..."
Today's Topics:
1. Re: [PATCH v8] usb: align buffers at cacheline (Marek Vasut) 2. Re: [PATCH] PowerPC: enable the SATA for p1/p2 rdb-pc platform (Tabi Timur-B04825) 3. Re: [PATCH 4/7] i.MX28: Enable additional DRAM address bits (Stefano Babic) 4. Re: AVR32 status (Wolfgang Denk) 5. Re: (no subject) (Simon Glass) 6. Re: ubifsmount reports "Error reading superblock", but linux can mount FS (Wolfgang Denk) 7. A few things for the release? (Simon Glass) 8. adding new command in u-boot (Haneef hawk21) 9. Re: adding new command in u-boot (Anatolij Gustschin) 10. [PATCH 2/2] omap3: fix NAND for tam3517 boards (Stefano Babic) 11. [PATCH 1/2] omap3: fix NAND for mcx board (Stefano Babic) 12. Re: [PATCH 1/2] omap3: fix NAND for mcx board (Tom Rini) 13. Re: [PATCH 1/2] omap3: fix NAND for mcx board (Stefano Babic) 14. Re: [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards (Stephen Warren) 15. Re: A few things for the release? (Dirk Behme) 16. Re: ubifsmount reports "Error reading superblock", but linux can mount FS (Alex Zeffertt) 17. Re: [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards (Simon Glass) 18. Re: [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards (Simon Glass) 19. [PATCH v2 1/4] ns16550: Add function to drain serial output (Simon Glass) 20. [PATCH v2 2/4] Enable printf() console if pre-console putc() is available (Simon Glass) 21. [PATCH v2 3/4] tegra: Implement pre-console putc() for fdt warning (Simon Glass) 22. [PATCH v2 4/4] tegra: Enable pre-console putc() for Tegra boards (Simon Glass) 23. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Tom Warren) 24. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Stephen Warren) 25. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Simon Glass) 26. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Tom Warren) 27. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Simon Glass) 28. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Stephen Warren) 29. pull request for u-boot-tegra/master (Tom Warren) 30. Re: DEVELOPER's MEETING (Fabio Estevam) 31. Re: [PATCH resend] ARMV7/Vexpress: add missing get_ticks() and get_tbclk() (Matt Waddel) 32. Re: [PATCH v2 3/4] tegra: Implement pre-console putc() for fdt warning (Wolfgang Denk) 33. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Wolfgang Denk) 34. Re: [PATCH v2 1/4] ns16550: Add function to drain serial output (Wolfgang Denk) 35. Re: pull request for u-boot-tegra/master (Wolfgang Denk) 36. Re: DEVELOPER's MEETING (Wolfgang Denk) 37. Re: [PATCH] arm: Don't use printf() in SPL builds (Sughosh Ganu) 38. Re: Does U-boot supports Spansion S29GL512P NOR Flash? (Balaji Sivakumar)
Message: 1 Date: Fri, 9 Mar 2012 13:03:31 +0100 From: Marek Vasut marex@denx.de Subject: Re: [U-Boot] [PATCH v8] usb: align buffers at cacheline To: puneets puneets@nvidia.com Cc: "u-boot@lists.denx.de" u-boot@lists.denx.de, Tom Warren TWarren@nvidia.com, "trini@ti.com" trini@ti.com Message-ID: 201203091303.31631.marex@denx.de Content-Type: Text/Plain; charset="us-ascii"
Dear puneets,
Hi Marek,
On Thursday 08 March 2012 07:42 PM, Marek Vasut wrote:
Dear puneets,
Hi Marek,
On Thursday 08 March 2012 03:36 AM, Marek Vasut wrote:
Dear puneets,
Hi Mike,
On Tuesday 06 March 2012 08:37 AM, Mike Frysinger wrote:
- PGP Signed by an unknown key
On Monday 05 March 2012 09:46:21 Puneet Saxena wrote: > As DMA expects the buffers to be equal and larger then > cache lines, This aligns buffers at cacheline.
i don't think this statement is true. DMA doesn't care about alignment (well, some do, but it's not related to cache lines but rather some other restriction in the peripheral DMA itself). what does matter is that cache operations operate on cache lines and not individual bytes. hence the core arm code was updated to warn when someone told it to invalidate X bytes but the hardware literally could not, so it had to invalidate X + Y bytes.
Agreed, Will update the commit message in next patchset.
> --- a/drivers/usb/host/ehci-hcd.c > +++ b/drivers/usb/host/ehci-hcd.c > > static void flush_invalidate(u32 addr, int size, int flush) > { > > + /* > + * Size is the bytes actually moved during transaction, > + * which may not equal to the cache line. This results > + * stop address passed for invalidating cache may not be
aligned.
> + * Therfore making size as multiple of cache line size. > + */ > + size = ALIGN(size, ARCH_DMA_MINALIGN); > + > > if (flush) > > flush_dcache_range(addr, addr + size); > > else
i think this is wrong and merely hides the errors from higher up instead of fixing them. the point of the warning was to tell you that the code was invalidating *too many* bytes. this code still invalidates too many bytes without any justification as for why it's OK to do here. further, this code path only matters to the invalidation logic, not the flush logic. -mike
The sole purpose of this patch to remove the warnings as start/stop address sent for invalidating is unaligned. Without this patch code works fine but with lots of spew...Which we don't want and discussed in earlier thread which Simon posted. Please have a look on following link.
As I understood, you agree that we need to align start/stop buffer address and also agree that to align stop address we need to align size as start address is already aligned. Now, "why its OK to do here"? We could have aligned the size in two places, cache_qtd() and cache_qh() but then we need to place alignment check at all the places where size is passed. So I thought better Aligning at flush_invalidate() and "ALIGN" macro does not increase the size if size is already aligned.
Actually I have to agree with Mike here. Can you please remove that ALIGN() (and all others you might have added)? If it does spew, that's ok and it tells us something is wrong in the USB core subsystem. Such stuff can be fixed in subsequent patch.
Sorry, I could not understand "(and all others you might have added)". Do you want me remove any HACK in the patch which is using ALIGN or making stop address
No, only such hacks where it's certain they will either invalidate or flush some areas that weren't allocated for them, like this ALIGN you did here. This can cause trouble that will be very hard to find.
aligned? The patch has only the above line to make stop address align and rest of the code makes start address align. Just to confirm, you are fine with the start address alignment code in the patch?
The start address alignment you do also aligns the end to the cacheline, doesn't it? (at least that's what I believe the macro is supposed to do).
Yes, start address alignment also aligns start address at the cache line. So, removing stop address alignment code as depicted above, should make this patch acceptable?
Puneet, it's not a problem of acceptability, it's a problem of breaking uboot ;-) Acceptability goes only after it we are sure doesn't break anything. The cache stuff is really fragile so we need to be very careful, please understand and let's figure this out together, I feel we're really close.
And yes, I believe removing such dangerous ALIGN() calls will be the last fix necessary, unless something other pops up.
Best regards, Marek Vasut
Message: 2 Date: Fri, 9 Mar 2012 12:40:35 +0000 From: Tabi Timur-B04825 B04825@freescale.com Subject: Re: [U-Boot] [PATCH] PowerPC: enable the SATA for p1/p2 rdb-pc platform To: Huang Changming-R66093 r66093@freescale.com Cc: "u-boot@lists.denx.de" u-boot@lists.denx.de, Andy Fleming afleming@gmail.com Message-ID: CAOZdJXWKdgCPW_UDqP1qhBxVBikfR_2Uqkufu2_Q_f_0qnH9SQ@mail.gmail.com Content-Type: text/plain; charset="iso-8859-1"
On Fri, Mar 9, 2012 at 1:54 AM, Chang-Ming.Huang@freescale.com wrote:
-#define CONFIG_SATA_SIL3114 +#define CONFIG_SATA_SIL
This is not "enabling" SATA. This is choosing the correct driver. You can only use the word "enable" if the feature was intentionally disabled before, e.g. because the driver did not exist yet.
Your patch description is fine. The subject line, however, is wrong.
-- Timur Tabi Linux kernel developer at Freescale
Message: 3 Date: Fri, 09 Mar 2012 14:39:29 +0100 From: Stefano Babic sbabic@denx.de Subject: Re: [U-Boot] [PATCH 4/7] i.MX28: Enable additional DRAM address bits To: Marek Vasut marex@denx.de Cc: u-boot@lists.denx.de Message-ID: 4F5A0811.8090506@denx.de Content-Type: text/plain; charset=ISO-8859-1
On 26/02/2012 23:15, Marek Vasut wrote:
Signed-off-by: Marek Vasut marex@denx.de
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
-- ===================================================================== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de =====================================================================
Message: 4 Date: Fri, 09 Mar 2012 14:47:49 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] AVR32 status To: Andreas Bie?mann andreas.devel@googlemail.com Cc: u-boot@lists.denx.de Message-ID: 20120309134749.CAAF9202D70@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Andreas,
In message 4F59BA55.9050306@googlemail.com you wrote:
There are two patches pending from Sven Schnelle since October last year: http://patchwork.ozlabs.org/patch/120993/ http://patchwork.ozlabs.org/patch/120992/
Both are working and could go in 2012.0{3,4}. Wolfgang are you willing to grab them for this release?
Yes, that's perfectly fine with me.
Both of them are delegated to Reinhard on patchwork. Could I take them directly or is some administrative interaction necessary to mark them as accepted?
You can reassign to yourself, or just apply directly. Patchwork does not really care about assignments...
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The universe does not have laws - it has habits, and habits can be broken.
Message: 5 Date: Fri, 9 Mar 2012 05:59:53 -0800 From: Simon Glass sjg@chromium.org Subject: Re: [U-Boot] (no subject) To: Wolfgang Denk wd@denx.de Cc: u-boot@lists.denx.de Message-ID: CAPnjgZ1Drbv8uDWjeDkXsaujPMNnwKMtb7JpCiEHArYOB6y=zQ@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
Hi Wolfgang,
On Thu, Mar 8, 2012 at 12:16 AM, Wolfgang Denk wd@denx.de wrote:
Dear Simon Glass,
In message CAPnjgZ2tGqTRfFOaKyySUrQxMO3_4qfX7ewg-XFUcuqZtP=6Ew@mail.gmail.com you wrote:
?01/10 Simon Glass ? ? ? ?[U-Boot] [PATCH v2 8/8] sandbox: Add > basic command line parsing http://article.gmane.org/gmane.comp.boot-loaders.u-boot/122324
Mike expanded this one significantly - I just acked it. Might stretch the definition of 'inside merge window'?
Initial patch was within merge window; we usually accapt updates, so why not here.
OK. It will be good to have this in.
Yes I just cleaned up mine...it would be nice if you could select multiple patches at the top level and perform actions on them.
See the "Create bundle" function - eventually this is what you are looking for?
Yes I can create a bundle, just not sure how I can then mark everything in the bundle as 'archived' or change its state.
-- DENX Software Engineering GmbH, ? ? MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A modem is a baudy house.
Message: 6 Date: Fri, 09 Mar 2012 15:02:16 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] ubifsmount reports "Error reading superblock", but linux can mount FS To: Alex Zeffertt azeffertt@cambridgesys.com Cc: u-boot@lists.denx.de, Stefan Roese sr@denx.de Message-ID: 20120309140216.E2949202D70@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Alex,
In message CANNiwJKREXiOBfiA_1v_-QGMoV_A59Ce0ADcVfK1xLMFkReFgw@mail.gmail.com you wrote:
Can you please try out and test what happens when you increase the size of the malloc arena? "include/configs/openrd.h" includes "include/configs/mv-common.h" which sets CONFIG_SYS_MALLOC_LEN to 1 MiB - try changing it to 4 MiB.
Thanks Wolfgang, that worked! Is there any reason why you would not set this variable to the maximum possible. ...
Define "maximum possible". The more memory we reserve here, the less will be available for loading Linux and root filesystem images and such. So it's always a compromize: make it as big as needed, but not (much) bigger.
... For example, is this
memory available to the kernel after it is booted? ...
When the kernel boots, all of U-Boot is gone. The kernel has no idea of how U-Boot used the memory; all such information is gone, too.
... How do you know
how big this might need to be in order to mount a filesystem that "needs recovery"?
I don't know of ways to determine this in advance. Eventually all we can do is thry what you did: increase the malloc arena when it turns out to be too small.
If you are willing to invest a little more time, it would be interesting to test how much memory is actually needed on your system.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de In the realm of scientific observation, luck is granted only to those who are prepared. - Louis Pasteur
Message: 7 Date: Fri, 9 Mar 2012 06:32:44 -0800 From: Simon Glass sjg@chromium.org Subject: [U-Boot] A few things for the release? To: U-Boot Mailing List u-boot@lists.denx.de Message-ID: CAPnjgZ3J2Tpfa9=ftH_wS50jDsZdK404StC0aYMEfwqYuK3+gg@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
I have a few more series that I hope will go in this time.
1. I think bootstage is ready
http://patchwork.ozlabs.org/bundle/sjg/bootstage/
2. The generic board init series needs some updates to create asm/sections.h for each architecture. This changes quite a few patches, plus there is one that I can drop since Mike fixed s520_timer already. So I will resend the whole series today. The is enabled only by a config option.
3. For generic relocation, there is the issue of creating lib/membasic.c (which is safe I think, but changes things for everyone) versus using -ffunction-sections and possibly breaking some boards. The latter solution is probably preferred in the long term, but I'm not sure if Albert is keep on this happening now. See here for details:
http://patchwork.ozlabs.org/patch/142216/
Albert, can you please take a look?
4. I have created a bundle for the ARM link-script series as it is today:
http://patchwork.ozlabs.org/bundle/sjg/lds/
Albert you had some comments, the latest of which I answered here:
http://patchwork.ozlabs.org/patch/142254/
Regadrs, Simon
Message: 8 Date: Fri, 9 Mar 2012 19:29:03 +0530 From: Haneef hawk21 haneef.hawk21@gmail.com Subject: [U-Boot] adding new command in u-boot To: u-boot@lists.denx.de Message-ID: CAEwP+aEx15aZh2i2ye1C4gdsZKES_OBTitr6HoCbghUxV0EdKg@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
I am trying to create a new command that would be used to do custom tests like mm, md, mtest all at once by calling their do_** function.
So I tried to create a simple command initially to print some message and print bdinfo in the hush: I did the following
created a file in common/cmd_myprint.c the file looks like this #include <command.h> #include <common.h>
int do_myprint(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { printf("U-Boot Test"); do_bdinfo(NULL, 0, 0, NULL); return 0; }
U_BOOT_CMD( myprint, 1, 1, do_myprint, "print message", "" );
then i added this in makefile as COBJS-y += cmd_myprint.o
this got compiled without any problem and even got the hush prompt but when i gave help command i did not see my command listed there. please help me in solving this issue.
Thanks, haneef
Message: 9 Date: Fri, 9 Mar 2012 16:19:51 +0100 From: Anatolij Gustschin agust@denx.de Subject: Re: [U-Boot] adding new command in u-boot To: Haneef hawk21 haneef.hawk21@gmail.com Cc: u-boot@lists.denx.de Message-ID: 20120309161951.3fd9362c@wker Content-Type: text/plain; charset=US-ASCII
On Fri, 9 Mar 2012 19:29:03 +0530 Haneef hawk21 haneef.hawk21@gmail.com wrote:
Can't you just put needed commands in a script and run it?
Try to pass a help string as the sixth argument of U_BOOT_CMD().
BR, Anatolij
Message: 10 Date: Fri, 9 Mar 2012 16:58:41 +0100 From: Stefano Babic sbabic@denx.de Subject: [U-Boot] [PATCH 2/2] omap3: fix NAND for tam3517 boards To: u-boot@lists.denx.de Message-ID: 1331308721-20849-2-git-send-email-sbabic@denx.de
commit 4fee6c2f295f932b8febdc7ce8731ba045695fa5 nand: make 1-bit software ECC configurable
breaks boards using Software ECC and requires that CONFIG_MTD_ECC_SOFT is set to have the previous behavior. Fix for tam3517 based boards.
Signed-off-by: Stefano Babic sbabic@denx.de Tom Rini trini@ti.com --- include/configs/tam3517-common.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 4c4321d..aaf9afe 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -293,6 +293,7 @@ #define CONFIG_MTD_PARTITIONS #define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_ECC_SOFT
/* Setup MTD for NAND on the SOM */ #define MTDIDS_DEFAULT "nand0=omap2-nand.0" -- 1.7.5.4
Message: 11 Date: Fri, 9 Mar 2012 16:58:40 +0100 From: Stefano Babic sbabic@denx.de Subject: [U-Boot] [PATCH 1/2] omap3: fix NAND for mcx board To: u-boot@lists.denx.de Message-ID: 1331308721-20849-1-git-send-email-sbabic@denx.de
breaks boards using Software ECC and requires that CONFIG_MTD_ECC_SOFT is set to have the previous behavior. Fix for mcx board.
Signed-off-by: Stefano Babic sbabic@denx.de Tom Rini trini@ti.com --- include/configs/mcx.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 1315c3c..d9bb700 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -140,6 +140,7 @@ #define CONFIG_MTD_PARTITIONS #define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_ECC_SOFT
#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ -- 1.7.5.4
Message: 12 Date: Fri, 9 Mar 2012 09:09:54 -0700 From: Tom Rini trini@ti.com Subject: Re: [U-Boot] [PATCH 1/2] omap3: fix NAND for mcx board To: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de Message-ID: 20120309160954.GB11879@bill-the-cat Content-Type: text/plain; charset=us-ascii
The generic NAND commit has been reverted for some time now, please re-test your boards against current mainline. Thanks!
-- Tom
Message: 13 Date: Fri, 09 Mar 2012 17:19:22 +0100 From: Stefano Babic sbabic@denx.de Subject: Re: [U-Boot] [PATCH 1/2] omap3: fix NAND for mcx board To: Tom Rini trini@ti.com Cc: u-boot@lists.denx.de Message-ID: 4F5A2D8A.2040503@denx.de Content-Type: text/plain; charset=ISO-8859-1
Thanks Tom ! Please drop my patches, they are not necessary.
Stefano
Message: 14 Date: Fri, 09 Mar 2012 09:57:06 -0700 From: Stephen Warren swarren@wwwdotorg.org Subject: Re: [U-Boot] [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards To: Simon Glass sjg@chromium.org Cc: linux-tegra@vger.kernel.org, U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: 4F5A3662.3040009@wwwdotorg.org Content-Type: text/plain; charset=ISO-8859-1
On 03/08/2012 07:52 PM, Simon Glass wrote:
This is used to display panic messages before the console is active.
Signed-off-by: Simon Glass sjg@chromium.org
I applied both these patches on top of u-boot-tegra/master, built for Ventana, and loaded/ran u-boot.bin, and don't see any useful serial output; there's a bit of periodic binary spew. u-boot-dtb.bin works as expected.
So, these patches don't appear to solve the problem.
Message: 15 Date: Fri, 09 Mar 2012 18:35:27 +0100 From: Dirk Behme dirk.behme@googlemail.com Subject: Re: [U-Boot] A few things for the release? To: u-boot@lists.denx.de Message-ID: 4F5A3F5F.7020508@googlemail.com Content-Type: text/plain; charset=ISO-8859-1; format=flowed
- I think bootstage is ready
- The generic board init series needs some updates to create
- For generic relocation, there is the issue of creating
- I have created a bundle for the ARM link-script series as it is today:
Using the nice subject ;)
5. I'm still hoping that we could get
http://patchwork.ozlabs.org/patch/136789/
into 2012.0{3,4}.
Best regards
Dirk
Message: 16 Date: Fri, 9 Mar 2012 18:10:04 +0000 From: Alex Zeffertt azeffertt@cambridgesys.com Subject: Re: [U-Boot] ubifsmount reports "Error reading superblock", but linux can mount FS To: Wolfgang Denk wd@denx.de, u-boot@lists.denx.de Message-ID: CANNiwJLjE1vzPPCPC_-mJE_fZKKKSrrN=6f5YTC7cW51ZNiFPg@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?... ?How do you know how big this might need to be in order to mount a filesystem that "needs recovery"?
I don't know of ways to determine this in advance. ?Eventually all we can do is thry what you did: increase the malloc arena when it turns out to be too small.
I know that 1MiB was too little and 4MiB was enough. However, I don't know whether a filesystem corruption could occur that caused ubifsmount to require more than 4MiB. For that reason I made the malloc area 64MiB. This is half my total RAM, which leaves the other half for downloading images.
Regards,
Alex
Message: 17 Date: Fri, 9 Mar 2012 10:24:41 -0800 From: Simon Glass sjg@chromium.org Subject: Re: [U-Boot] [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards To: Stephen Warren swarren@wwwdotorg.org Cc: linux-tegra@vger.kernel.org, U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: CAPnjgZ2CnV8LjOJQx3Y-5fP=+xBPa7eAiikBNnJypDq7r1JLWg@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
Hi Stephen,
I don't have a ventana but I think Seaboard is equivalent. I will test on that and figure out what piece is missing.
They do in our tree, but I will take a look.
Message: 18 Date: Fri, 9 Mar 2012 12:32:04 -0800 From: Simon Glass sjg@chromium.org Subject: Re: [U-Boot] [PATCH 2/2] tegra: Enable pre-console putc() for Tegra boards To: Stephen Warren swarren@wwwdotorg.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: CAPnjgZ2nAgGTYvanYSUHBzXYBqHY_1j12ApToqGgUbHzQ1Oy3Q@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
-linux-tegra
Hi Stephen,
You are seeing the output, but since it resets the ns16550 on every character we are just emitting garbage. I should have pushed back on just having a board_pre_console_panic() as it would be easier. Anyway, given that this is what we have, we need a function to drain the FIFO.
Also printf() is silently skipped without a console, so we need to stop that happening as well.
I will send a new series with those two new patches and dealing with Mike's comments. It seems to work fine for me on Seaboard.
Message: 19 Date: Fri, 9 Mar 2012 12:32:55 -0800 From: Simon Glass sjg@chromium.org Subject: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Warren twarren@nvidia.com Message-ID: 1331325178-14634-1-git-send-email-sjg@chromium.org
Sometimes we want to be sure that the output FIFO has fully drained (e.g. because we are about to reset or the port or reset the board). Add a function for this.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add function to drain the ns16550's FIFO
drivers/serial/ns16550.c | 11 +++++++++++ include/ns16550.h | 3 +++ 2 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 0c23955..a082112 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -6,6 +6,7 @@
#include <config.h> #include <ns16550.h> +#include <common.h> #include <watchdog.h> #include <linux/types.h> #include <asm/io.h> @@ -115,4 +116,14 @@ int NS16550_tstc(NS16550_t com_port) return (serial_in(&com_port->lsr) & UART_LSR_DR) != 0; }
+/* Wait for the UART's output buffer and holding register to drain */ +void NS16550_drain(NS16550_t regs) +{ + u32 mask = UART_LSR_TEMT | UART_LSR_THRE; + + /* Wait for the UART to finish sending */ + while ((serial_in(®s->lsr) & mask) != mask) + udelay(100); +} + #endif /* CONFIG_NS16550_MIN_FUNCTIONS */ diff --git a/include/ns16550.h b/include/ns16550.h index e9d2eda..16b3828 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -166,4 +166,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor); void NS16550_putc(NS16550_t com_port, char c); char NS16550_getc(NS16550_t com_port); int NS16550_tstc(NS16550_t com_port); + +/* Wait for the UART's output buffer and holding register to drain */ +void NS16550_drain(NS16550_t regs); void NS16550_reinit(NS16550_t com_port, int baud_divisor); -- 1.7.7.3
Message: 20 Date: Fri, 9 Mar 2012 12:32:56 -0800 From: Simon Glass sjg@chromium.org Subject: [U-Boot] [PATCH v2 2/4] Enable printf() console if pre-console putc() is available To: U-Boot Mailing List u-boot@lists.denx.de Cc: Tom Warren twarren@nvidia.com Message-ID: 1331325178-14634-2-git-send-email-sjg@chromium.org
At present we skip printf() if there is no hope of it making it to the console. But this check ignores CONFIG_PRE_CONSOLE_PUTC at present. Add a check for that also.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Allow printf() output to make it to pre-console putc()
common/console.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/console.c b/common/console.c index 1d9fd7f..38d7094 100644 --- a/common/console.c +++ b/common/console.c @@ -447,7 +447,7 @@ int vprintf(const char *fmt, va_list args) uint i; char printbuffer[CONFIG_SYS_PBSIZE];
-#ifndef CONFIG_PRE_CONSOLE_BUFFER +#if !defined(CONFIG_PRE_CONSOLE_BUFFER) && !defined(CONFIG_PRE_CONSOLE_PUTC) if (!gd->have_console) return 0; #endif -- 1.7.7.3
Message: 21 Date: Fri, 9 Mar 2012 12:32:57 -0800 From: Simon Glass sjg@chromium.org Subject: [U-Boot] [PATCH v2 3/4] tegra: Implement pre-console putc() for fdt warning To: U-Boot Mailing List u-boot@lists.denx.de Cc: Stephen Warren swarren@nvidia.com, Tom Warren twarren@nvidia.com Message-ID: 1331325178-14634-3-git-send-email-sjg@chromium.org
When there is not device tree file available to U-Boot, we panic. Implement board_pre_console_putc() so that this panic will be displayed on the serial console.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Tidy up casting in board_pre_console_putc() - Use 'const' for uart_reg_addr
arch/arm/cpu/armv7/tegra2/board.c | 61 +++++++++++++++++++++++++++++++++++++ 1 files changed, 61 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/board.c b/arch/arm/cpu/armv7/tegra2/board.c index 77a627d..0517d72 100644 --- a/arch/arm/cpu/armv7/tegra2/board.c +++ b/arch/arm/cpu/armv7/tegra2/board.c @@ -23,9 +23,11 @@
#include <common.h> #include <asm/io.h> +#include <ns16550.h> #include "ap20.h" #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> +#include <asm/arch/gpio.h> #include <asm/arch/sys_proto.h> #include <asm/arch/tegra2.h> #include <asm/arch/pmc.h> @@ -37,6 +39,7 @@ enum { UARTA = 1 << 0, UARTB = 1 << 1, UARTD = 1 << 3, + UART_ALL = 0xf, UART_COUNT = 4, };
@@ -149,3 +152,61 @@ void enable_caches(void) dcache_enable(); } #endif + + +/* + * Possible UART locations: we ignore UARTC at 0x70006200 and UARTE at + * 0x70006400, since we don't have code to init them + */ +static const u32 uart_reg_addr[] = { + NV_PA_APB_UARTA_BASE, + NV_PA_APB_UARTB_BASE, + NV_PA_APB_UARTD_BASE, + 0 +}; + +#ifdef CONFIG_PRE_CONSOLE_PUTC +/* + * This is called when we have no console. About the only reason that this + * happen is if we don't have a valid fdt. So we don't know what kind of + * Tegra board we are. We blindly try to print a message every which way we + * know. + */ +void board_pre_console_putc(int ch) +{ + int uart_ids = UART_ALL; /* turn it all on! */ + const u32 *uart_addr; + int clock_freq, multiplier, baudrate, divisor; + + /* Try to enable all possible UARTs */ + setup_uarts(uart_ids); + + /* + * Seaboard has a UART switch on PI3. We might be a Seaboard, + * so flip it! + */ +#ifdef CONFIG_SPI_UART_SWITCH + gpio_direction_output(GPIO_PI3, 0); +#endif + + /* + * Now send the string out all the Tegra UARTs. We don't try all + * possible configurations, but this could be added if required. + */ + clock_freq = CONFIG_DEFAULT_NS16550_CLK; + multiplier = CONFIG_DEFAULT_NS16550_MULT; + baudrate = CONFIG_BAUDRATE; + divisor = (clock_freq + (baudrate * (multiplier / 2))) / + (multiplier * baudrate); + + for (uart_addr = uart_reg_addr; *uart_addr; uart_addr++) { + NS16550_t regs = (NS16550_t)*uart_addr; + + NS16550_init(regs, divisor); + NS16550_putc(regs, ch); + if (ch == '\n') + NS16550_putc(regs, '\r'); + NS16550_drain(regs); + } +} +#endif -- 1.7.7.3
Message: 22 Date: Fri, 9 Mar 2012 12:32:58 -0800 From: Simon Glass sjg@chromium.org Subject: [U-Boot] [PATCH v2 4/4] tegra: Enable pre-console putc() for Tegra boards To: U-Boot Mailing List u-boot@lists.denx.de Cc: Stephen Warren swarren@nvidia.com, Tom Warren twarren@nvidia.com Message-ID: 1331325178-14634-4-git-send-email-sjg@chromium.org
include/configs/tegra2-common.h | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/include/configs/tegra2-common.h b/include/configs/tegra2-common.h index 837f859..368f3eb 100644 --- a/include/configs/tegra2-common.h +++ b/include/configs/tegra2-common.h @@ -68,11 +68,18 @@ */ #define V_NS16550_CLK 216000000 /* 216MHz (pllp_out0) */
+/* Default serial clock and multiplier */ +#define CONFIG_DEFAULT_NS16550_CLK V_NS16550_CLK +#define CONFIG_DEFAULT_NS16550_MULT 16 + #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK
+/* We use this for a warning message when no device tree is present */ +#define CONFIG_PRE_CONSOLE_PUTC + /* * select serial console configuration */ -- 1.7.7.3
Message: 23 Date: Fri, 9 Mar 2012 12:59:38 -0800 From: Tom Warren TWarren@nvidia.com Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Simon Glass sjg@chromium.org, U-Boot Mailing List u-boot@lists.denx.de Message-ID: 5FBF8E85CA34454794F0F7ECBA79798F37971BC0CD@HQMAIL04.nvidia.com Content-Type: text/plain; charset="us-ascii"
Simon,
-----Original Message----- From: Simon Glass [mailto:sjg@chromium.org] Sent: Friday, March 09, 2012 1:33 PM To: U-Boot Mailing List Cc: Tom Warren; Stephen Warren; Simon Glass Subject: [PATCH v2 1/4] ns16550: Add function to drain serial output
This patch series (v2, 1-4) works for me on my Seaboard - I get a message about 'No valid fdt found', etc.
So: Tested-by: Tom Warren twarren@nvidia.com Acked-by: Tom Warren twarren@nvidia.com
If no one objects, I'll apply this series, and Stephen's 'Makefile: fdt: Make the final build result be u-boot.bin' patch (which also works OK, BTW) to my previous pull request and resend to Albert.
Tom
-- nvpublic
Changes in v2:
+/* Wait for the UART's output buffer and holding register to drain */ +void NS16550_drain(NS16550_t regs) {
udelay(100);
Message: 24 Date: Fri, 09 Mar 2012 14:00:56 -0700 From: Stephen Warren swarren@wwwdotorg.org Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Simon Glass sjg@chromium.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: 4F5A6F88.6020503@wwwdotorg.org Content-Type: text/plain; charset=ISO-8859-1
The series,
Tested-by: Stephen Warren swarren@wwwdotorg.org
Tom,
I'm OK with you adding these patches to u-boot-tegra/master and sending a pull request for that. Just please put these patches before any that actually enable CONFIG_OF_CONTROL for any boards, so there's never a window of broken commits.
I think it'd be nice at this stage to also drop the commit that turns Ventana into a DT board, since re-using the Seaboard .dts file for Ventana isn't correct. However, IIRC that commit was added to WAR some build issue with Simon's patch series? If that's still a problem, then I'm OK with converting Ventana if we have to, but we'll need to be very careful that tegra-seaboard.dts doesn't add stuff that'll fail on, or damage, Ventana.
Message: 25 Date: Fri, 9 Mar 2012 13:08:33 -0800 From: Simon Glass sjg@chromium.org Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Stephen Warren swarren@wwwdotorg.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: CAPnjgZ2U_Aobrj4YGTFzJVJ2xRhaZ9E9Jo0tj7Whnb7ECnZL1A@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
The series,
Tom,
A few points:
1. Yes you can drop the Ventana commit and I agree it is a good idea. We should have a real Ventana .dts file I think. Ventana should built ok without a device tree now. The problem was in my clock.c patch.
2. I have held off responding to Stephen's patch on the ML to see what other say. My view is that it is controversial since it changes the so-far accepted meaning of u-boot.bin and the behaviour of the U-Boot Makefile. Plus it is not really necessary as a means of informing the user since we put the pre-console putc() for exactly this problem. So I would rather leave Stephen's patch out at until people have time to decide that I am wrong about it. We already have CONFIG_OF_EMBED to build the fdt into u-boot.bin. Grant Likely had big reservations about this feature - let's not bring it in by stealth.
Message: 26 Date: Fri, 9 Mar 2012 13:23:31 -0800 From: Tom Warren TWarren@nvidia.com Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Simon Glass sjg@chromium.org, Stephen Warren swarren@wwwdotorg.org Cc: U-Boot Mailing List u-boot@lists.denx.de Message-ID: 5FBF8E85CA34454794F0F7ECBA79798F37971BC0D6@HQMAIL04.nvidia.com Content-Type: text/plain; charset="us-ascii"
Simon/Stephen,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, March 09, 2012 2:09 PM To: Stephen Warren Cc: U-Boot Mailing List; Tom Warren Subject: Re: [PATCH v2 1/4] ns16550: Add function to drain serial output
The series,
Tom,
A few points:
- Yes you can drop the Ventana commit and I agree it is a good idea.
- I have held off responding to Stephen's patch on the ML to see what other
I see now why it's so hard to find custodians for the U-Boot repos. :/
I've done as Stephen requested and re-ordered the commits so his Makefile fix comes before the config file changes to add CONFIG_OF_CONTROL to Seaboard and Ventana.
I've left the Ventana change that uses the Seaboard .dts file in, as I think it can easily be edited to use a Ventana-specific dts file just as soon as one of you finds one and submits a patch for it. For now, the Seaboard .dts just works.
I've pushed my latest changes to u-boot-tegra/master, and I'm going to let it percolate over the weekend. I'd have liked to get a pull request in to Albert today, before the ARM HEAD moves again, but I'm not going sweat to it since there doesn't seem to be a consensus on how to proceed here. IMO, I see no problem with putting these patches in as they stand, since I've tested them to work OK on Seaboard and Ventana, other (non-DT) Tegra2 boards build fine, and anything here that needs to change can always be edited with a future patch. But I'm going to head out early (it's my birthday today), and pick this up again next week.
Tom
-- nvpublic
Message: 27 Date: Fri, 9 Mar 2012 13:29:16 -0800 From: Simon Glass sjg@chromium.org Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Tom Warren TWarren@nvidia.com Cc: U-Boot Mailing List u-boot@lists.denx.de Message-ID: CAPnjgZ34SjYWv1A-yZ9Y5BaXPZs3hY8W6OCuLtux5hpqkVykvQ@mail.gmail.com Content-Type: text/plain; charset=ISO-8859-1
Hi Stephen,
On Fri, Mar 9, 2012 at 1:23 PM, Tom Warren TWarren@nvidia.com wrote:
Simon/Stephen,
The series,
Tom,
A few points:
Happy Birthday Tom!
Stephen, what you do you about leaving out your Makefile patch for now? It is (I think) the only controversial part of this, and is not needed to make all this work...
Tom
-- nvpublic
Message: 28 Date: Fri, 09 Mar 2012 14:40:17 -0700 From: Stephen Warren swarren@wwwdotorg.org Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Simon Glass sjg@chromium.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Tom Warren TWarren@nvidia.com Message-ID: 4F5A78C1.1030405@wwwdotorg.org Content-Type: text/plain; charset=ISO-8859-1
sjg@google.com wrote at Friday, March 09, 2012 2:09 PM:
I don't quite see how this is bringing the feature in by stealth; the exact same set of files (one with and without appended DTB already in place) is still available, just under filenames that are likely to cause less surprise to the user.
Yes, I'm happy with that. The issue I had was the surprising result of U-Boot hanging without giving any clues why, and that's addressed by the messages that are now printed with your latest patches.
While I still like the patch to rename the files in the top-level Makefile, I do agree that including it in a pull request without more widespread discussion and agreement is not a good idea.
BTW, happy birthday Tom.
Message: 29 Date: Fri, 9 Mar 2012 14:39:00 -0800 From: Tom Warren TWarren@nvidia.com Subject: [U-Boot] pull request for u-boot-tegra/master To: Albert ARIBAUD albert.u.boot@aribaud.net Cc: U-Boot Mailing List u-boot@lists.denx.de, Stephen Warren swarren@nvidia.com Message-ID: 5FBF8E85CA34454794F0F7ECBA79798F37971BC102@HQMAIL04.nvidia.com Content-Type: text/plain; charset="us-ascii"
Albert,
Please pull u-boot-tegra/master into arm master. Thanks!
The following changes since commit 32ec258f829808dd7cf74fd83ba999fdaaeab715:
IXP: Fix GPIO_INT_ACT_LOW_SET() (2012-03-08 08:11:45 +0100)
are available in the git repository at: git://git.denx.de/u-boot-tegra master
Simon Glass (26): fdt: Add fdtdec_find_aliases() to deal with alias nodes fdt: Add tests for fdtdec fdt: Tidy up a few fdtdec problems fdt: Add functions to access phandles, arrays and bools fdt: Add basic support for decoding GPIO definitions arm: fdt: Add skeleton device tree file from kernel tegra: fdt: Add Tegra2x device tree file from kernel tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel fdt: Add staging area for device tree binding documentation fdt: Add tegra-usb bindings file from linux tegra: fdt: Add additional USB binding tegra: fdt: Add clock bindings tegra: fdt: Add clock bindings for Tegra2 Seaboard tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard usb: Add support for txfifo threshold tegra: fdt: Add function to return peripheral/clock ID tegra: usb: Add support for Tegra USB peripheral tegra: usb: Add USB support to nvidia boards tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Enable USB on Seaboard tegra: fdt: Enable FDT support for Seaboard ns16550: Add function to drain serial output Enable printf() console if pre-console putc() is available tegra: Implement pre-console putc() for fdt warning tegra: Enable pre-console putc() for Tegra boards
Tom Warren (2): arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load tegra: fdt: Enable FDT support for Ventana
README | 3 + arch/arm/cpu/armv7/tegra2/Makefile | 4 +- arch/arm/cpu/armv7/tegra2/ap20.c | 10 +- arch/arm/cpu/armv7/tegra2/board.c | 61 +++ arch/arm/cpu/armv7/tegra2/clock.c | 58 +++ arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/cpu/armv7/tegra2/usb.c | 460 ++++++++++++++++++++ arch/arm/dts/skeleton.dtsi | 13 + arch/arm/dts/tegra20.dtsi | 188 ++++++++ arch/arm/include/asm/arch-tegra2/clock.h | 13 + arch/arm/include/asm/arch-tegra2/tegra2.h | 2 + arch/arm/include/asm/arch-tegra2/usb.h | 252 +++++++++++ board/nvidia/common/board.c | 12 + board/nvidia/common/board.h | 6 + board/nvidia/dts/tegra2-seaboard.dts | 74 ++++ board/nvidia/seaboard/seaboard.c | 6 + common/console.c | 2 +- doc/device-tree-bindings/README | 17 + .../clock/nvidia,tegra20-car.txt | 207 +++++++++ doc/device-tree-bindings/usb/tegra-usb.txt | 25 + drivers/serial/ns16550.c | 11 + drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-hcd.c | 7 + drivers/usb/host/ehci-tegra.c | 62 +++ drivers/usb/host/ehci.h | 6 +- include/configs/seaboard.h | 12 + include/configs/tegra2-common.h | 17 + include/configs/ventana.h | 5 + include/fdtdec.h | 155 +++++++- include/ns16550.h | 3 + lib/Makefile | 1 + lib/fdtdec.c | 285 ++++++++++++- lib/fdtdec_test.c | 226 ++++++++++ 33 files changed, 2188 insertions(+), 18 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/usb.c create mode 100644 arch/arm/dts/skeleton.dtsi create mode 100644 arch/arm/dts/tegra20.dtsi create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 board/nvidia/dts/tegra2-seaboard.dts create mode 100644 doc/device-tree-bindings/README create mode 100644 doc/device-tree-bindings/clock/nvidia,tegra20-car.txt create mode 100644 doc/device-tree-bindings/usb/tegra-usb.txt create mode 100644 drivers/usb/host/ehci-tegra.c create mode 100644 lib/fdtdec_test.c
nvpublic
Message: 30 Date: Fri, 9 Mar 2012 20:33:05 -0300 From: Fabio Estevam festevam@gmail.com Subject: Re: [U-Boot] DEVELOPER's MEETING To: Wolfgang Denk wd@denx.de Cc: u-boot@lists.denx.de Message-ID: CAOMZO5BgTUYSH9MFSbFkZf4Dx8O-VeiUW46WErQgLa07_gGZHw@mail.gmail.com Content-Type: text/plain; charset=UTF-8
Hi Wolfgang,
On Thu, Mar 8, 2012 at 9:16 AM, Wolfgang Denk wd@denx.de wrote:
I was just thinking if this year's Libre Software Meeting (LSM - from 7th to 12th July in Geneva, Switzerland) would be a suitable event to arrange a meeting of some U-Boot developers?
What about arranging the U-boot meeting at ELCE ? https://events.linuxfoundation.org/events/embedded-linux-conference-europe
Regards,
Fabio Estevam
Message: 31 Date: Fri, 09 Mar 2012 17:11:00 -0700 From: Matt Waddel matt.waddel@linaro.org Subject: Re: [U-Boot] [PATCH resend] ARMV7/Vexpress: add missing get_ticks() and get_tbclk() To: u-boot@lists.denx.de Message-ID: 4F5A9C14.5000004@linaro.org Content-Type: text/plain; charset=ISO-8859-1
On 02/22/2012 07:56 AM, walimis wrote:
commit f31a911fe (arm, post: add missing post_time_ms for arm) enables get_ticks and get_tbclk for all arm based boards, arm/vexpress also needs these functions to work.
Signed-off-by: Liming Wang walimisdev@gmail.com
Acked-by: Matt.Waddel@linaro.org
board/armltd/vexpress/ca9x4_ct_vxp.c | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/board/armltd/vexpress/ca9x4_ct_vxp.c b/board/armltd/vexpress/ca9x4_ct_vxp.c index da6f14d..0b36d12 100644 --- a/board/armltd/vexpress/ca9x4_ct_vxp.c +++ b/board/armltd/vexpress/ca9x4_ct_vxp.c @@ -226,3 +226,13 @@ void lowlevel_init(void) ulong get_board_rev(void){ return readl((u32 *)SYS_ID); }
+unsigned long long get_ticks(void) +{
return get_timer(0);
+ulong get_tbclk (void) +{
return (ulong)CONFIG_SYS_HZ;
Message: 32 Date: Sat, 10 Mar 2012 09:16:20 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] [PATCH v2 3/4] tegra: Implement pre-console putc() for fdt warning To: Simon Glass sjg@chromium.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Stephen Warren swarren@nvidia.com, Tom Warren twarren@nvidia.com Message-ID: 20120310081620.CB434202C07@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Simon Glass,
if (ch == '\n')
Why is this needed for every output character?
Actually, why is it needed at all?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de All a hacker needs is a tight PUSHJ, a loose pair of UUOs, and a warm place to shift.
Message: 33 Date: Sat, 10 Mar 2012 09:19:23 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Simon Glass sjg@chromium.org Cc: U-Boot Mailing List u-boot@lists.denx.de, Tom Warren twarren@nvidia.com Message-ID: 20120310081923.BB158202C07@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Simon Glass,
Seems there is one unintentional "or".
function for this.
Changes in v2:
I dislike this. This is mostly dead code, enabled for eveybody where it just increases the memory footprint for no use.
Also I do not understand why it would be needed at all. We did not have such a requirement for any system before, so I feel you must be doing something wrong, or at least very exotic.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Extreme feminine beauty is always disturbing. -- Spock, "The Cloud Minders", stardate 5818.4
Message: 34 Date: Sat, 10 Mar 2012 09:20:28 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] [PATCH v2 1/4] ns16550: Add function to drain serial output To: Tom Warren TWarren@nvidia.com Cc: U-Boot Mailing List u-boot@lists.denx.de Message-ID: 20120310082028.0F896202C07@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Tom Warren,
In message 5FBF8E85CA34454794F0F7ECBA79798F37971BC0CD@HQMAIL04.nvidia.com you wrote:
I do object. This affects common code.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "On two occasions I have been asked [by members of Parliament!], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question." - Charles Babbage
Message: 35 Date: Sat, 10 Mar 2012 09:25:33 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] pull request for u-boot-tegra/master To: Albert ARIBAUD albert.u.boot@aribaud.net Cc: U-Boot Mailing List u-boot@lists.denx.de, Stephen Warren swarren@nvidia.com, Tom Warren TWarren@nvidia.com Message-ID: 20120310082533.D3252202C07@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Albert,
In message 5FBF8E85CA34454794F0F7ECBA79798F37971BC102@HQMAIL04.nvidia.com Tom Warren wrote:
Please do NOT pull this.
I'm not OK with these patches yet. Also, they affect common code.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Never underestimate the power of human stupidity when it comes to using technology they don't understand.
Message: 36 Date: Sat, 10 Mar 2012 09:31:44 +0100 From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] DEVELOPER's MEETING To: Fabio Estevam festevam@gmail.com Cc: u-boot@lists.denx.de Message-ID: 20120310083144.A54B8202C07@gemini.denx.de Content-Type: text/plain; charset=UTF-8
Dear Fabio,
In message CAOMZO5BgTUYSH9MFSbFkZf4Dx8O-VeiUW46WErQgLa07_gGZHw@mail.gmail.com you wrote:
There were a number of reasons that made me looking at this: Geneva is pretty much central in Europe and easy to reach, and there are no other interesting (at least to me) events around this time.
ELCE always manages to fall close to other events like trade shows. For example this autumn's ELCE (November 5-7) kind of collides with electronica 2012 in Munich (Nov 13-16).
But I'm open to suggestions / opinions.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The software required `Windows 95 or better', so I installed Linux.
Message: 37 Date: Sat, 10 Mar 2012 14:03:45 +0530 From: Sughosh Ganu urwithsughosh@gmail.com Subject: Re: [U-Boot] [PATCH] arm: Don't use printf() in SPL builds To: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com, U-Boot Mailing List u-boot@lists.denx.de, Heiko Schocher hs@denx.de, Christian Riesch christian.riesch@omicron.at Message-ID: 20120310083345.GA6861@Hardy Content-Type: text/plain; charset="us-ascii"
hi Simon,
On Sat Mar 03, 2012 at 12:33:15PM -0800, Simon Glass wrote:
raise() likes to call printf() if it is available, but in SPL builds it either is not available, or adds a large chunk to the resulting image size.
So don't call it even if it is available.
This change reduces SPL size from 10KB to 6.3KB on hawkboard, for example, using generic relocation.
arch/arm/lib/eabi_compat.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/arch/arm/lib/eabi_compat.c b/arch/arm/lib/eabi_compat.c index 2028dbd..44eebe0 100644 --- a/arch/arm/lib/eabi_compat.c +++ b/arch/arm/lib/eabi_compat.c @@ -13,7 +13,8 @@
int raise (int signum) { -#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT)
/* Even if printf() is available, it's large. Punt it for SPL builds */
+#if !defined(CONFIG_SPL_BUILD) printf("raise: Signal # %d caught\n", signum); #endif
I tested with this change on hawkboard, and after applying this change, the spl size increase is 412 bytes against the 4k increase that we get with libcommon changes introduced. So this patch works fine.
Can you please check if libcommon support is needed for the cam_enc_4xx board -- your relocation patch series did not add CONFIG_SPL_LIBCOMMON_SUPPORT to this board. This will affect my patch to initialise gd and bd objects for hawkboard. Please let me know, and i will spin a patch accordingly.
-sughosh
Message: 38 Date: Sat, 10 Mar 2012 10:47:35 +0000 (UTC) From: Balaji Sivakumar balajisk@hcl.com Subject: Re: [U-Boot] Does U-boot supports Spansion S29GL512P NOR Flash? To: u-boot@lists.denx.de Message-ID: loom.20120310T113930-255@post.gmane.org Content-Type: text/plain; charset=us-ascii
Stefan Roese <sr <at> denx.de> writes:
Hi Prakash,
On Friday 09 April 2010 07:26:37 prakash bedge wrote:
In U-boot I am not seeing the support for Spansion S29GL512P NOR flash.
This chip is CFI compliant so I believe the common CFI driver should work with this chip.
Does U-boot supports S29GL512P NOR flash or I have to implement the functionality to support S29GL512P?
If anyone has tried with S29GL512P NOR flash please share the experiecne.
This chip is currently supported by the common CFI NOR FLASH driver. So it should just work for your board as well.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office <at> denx.de
Hi Stefan,
I am Balaji. am using IMX6 base custom board. In my board am using S29GL01G NOR Flash to srore u-boot and kernel. I understand from the data sheet this NOR Flash is CFI based on. So i have added Configurations for CFI Flash driver.
Currently am loading the U-boot into DDR3 and able to excute U-boot test commands. When i put flinfo , am getting "missing or unknow flash type" and while loading the u-boot it is printing as " Unknown flash on BANK 1 - Size - 0MB". So am not sure what am missing here or i have to add anything extra in teh config file. Please request you to check and provide your suggestion.
Thanks, Balaji S
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
End of U-Boot Digest, Vol 46, Issue 17 **************************************
::DISCLAIMER:: -----------------------------------------------------------------------------------------------------------------------
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or HCL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of HCL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect.
Balaji Sivakumar, ERS, HCLTech
