[U-Boot] [PATCH 6/9] ARM: mvebu: add support for boot from SATA
Add the required Kconfig and macro definitions to allow boot from SATA on Armada 38x systems.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/mach-mvebu/Kconfig | 5 +++++ arch/arm/mach-mvebu/Makefile | 3 +++ arch/arm/mach-mvebu/include/mach/soc.h | 2 ++ arch/arm/mach-mvebu/spl.c | 5 +++++ 4 files changed, 15 insertions(+)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 495c48e6c749..fdd39685b75d 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -239,6 +239,11 @@ config MVEBU_SPL_BOOT_DEVICE_MMC bool "SDIO/MMC card" select SPL_LIBDISK_SUPPORT
+config MVEBU_SPL_BOOT_DEVICE_SATA + bool "SATA" + select SPL_SATA_SUPPORT + select SPL_LIBDISK_SUPPORT + config MVEBU_SPL_BOOT_DEVICE_UART bool "UART"
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 02d3ce27ee74..8228a17972f9 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -37,6 +37,9 @@ endif ifneq ($(CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC),) KWB_CFG_BOOT_FROM=sdio endif +ifneq ($(CONFIG_MVEBU_SPL_BOOT_DEVICE_SATA),) + KWB_CFG_BOOT_FROM=sata +endif ifneq ($(CONFIG_MVEBU_SPL_BOOT_DEVICE_UART),) KWB_CFG_BOOT_FROM=uart endif diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index f666ee24243b..acb9257c90fe 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -159,7 +159,9 @@ #define BOOT_DEV_SEL_MASK (0x3f << BOOT_DEV_SEL_OFFS)
#define BOOT_FROM_NAND 0x0A +#define BOOT_FROM_SATA 0x22 #define BOOT_FROM_UART 0x28 +#define BOOT_FROM_SATA_ALT 0x2A #define BOOT_FROM_UART_ALT 0x3f #define BOOT_FROM_SPI 0x32 #define BOOT_FROM_MMC 0x30 diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 530b98c1aa31..d54de5195624 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -59,6 +59,11 @@ static u32 get_boot_device(void) case BOOT_FROM_UART_ALT: #endif return BOOT_DEVICE_UART; +#ifdef BOOT_FROM_SATA + case BOOT_FROM_SATA: + case BOOT_FROM_SATA_ALT: + return BOOT_DEVICE_SATA; +#endif case BOOT_FROM_SPI: default: return BOOT_DEVICE_SPI;
Hi u-boot list, Stefan,
Please ignore this patch and the next. The patch series starts at the 0/9 cover letter.
Sorry for the spam.
baruch
- bool "SATA"
- select SPL_SATA_SUPPORT
- select SPL_LIBDISK_SUPPORT
- KWB_CFG_BOOT_FROM=sata
- case BOOT_FROM_SATA:
- case BOOT_FROM_SATA_ALT:
Baruch Siach
