[U-Boot] [PATCH] video: ipu_disp: wait for DP SF end irq when disabling sync BG flows
Instead of waiting for DC triple buffer to be cleared, this patch changes to wait for a relevant DP sync flow end interrupt to come when disabling sync BG flows. In this way, we align the implement to the freescale internal IPUv3 driver. After applying this patch, an uboot hang up issue at the arch_preboot_os() stage, where we disable a relevant ipu display channel, is not observed any more on some MX6DL platforms.
Signed-off-by: Liu Ying Ying.Liu@freescale.com --- drivers/video/ipu.h | 8 ++++++++ drivers/video/ipu_disp.c | 27 ++++++++------------------- drivers/video/ipu_regs.h | 3 +++ 3 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/drivers/video/ipu.h b/drivers/video/ipu.h index 3d2741f..091b58f 100644 --- a/drivers/video/ipu.h +++ b/drivers/video/ipu.h @@ -176,6 +176,14 @@ typedef union { } ipu_channel_params_t;
/* + * Enumeration of IPU interrupts. + */ +enum ipu_irq_line { + IPU_IRQ_DP_SF_END = 448 + 3, + IPU_IRQ_DC_FC_1 = 448 + 9, +}; + +/* * Bitfield of Display Interface signal polarities. */ typedef struct { diff --git a/drivers/video/ipu_disp.c b/drivers/video/ipu_disp.c index cefd2dc..bf39a51 100644 --- a/drivers/video/ipu_disp.c +++ b/drivers/video/ipu_disp.c @@ -666,13 +666,16 @@ void ipu_dp_dc_disable(ipu_channel_t channel, unsigned char swap) uint32_t csc; uint32_t dc_chan = 0; int timeout = 50; + int irq = 0;
dc_swap = swap;
if (channel == MEM_DC_SYNC) { dc_chan = 1; + irq = IPU_IRQ_DC_FC_1; } else if (channel == MEM_BG_SYNC) { dc_chan = 5; + irq = IPU_IRQ_DP_SF_END; } else if (channel == MEM_FG_SYNC) { /* Disable FG channel */ dc_chan = 5; @@ -723,25 +726,11 @@ void ipu_dp_dc_disable(ipu_channel_t channel, unsigned char swap) reg ^= DC_WR_CH_CONF_PROG_DI_ID; __raw_writel(reg, DC_WR_CH_CONF(dc_chan)); } else { - timeout = 50; - - /* Wait for DC triple buffer to empty */ - if (g_dc_di_assignment[dc_chan] == 0) - while ((__raw_readl(DC_STAT) & 0x00000002) - != 0x00000002) { - udelay(2000); - timeout -= 2; - if (timeout <= 0) - break; - } - else if (g_dc_di_assignment[dc_chan] == 1) - while ((__raw_readl(DC_STAT) & 0x00000020) - != 0x00000020) { - udelay(2000); - timeout -= 2; - if (timeout <= 0) - break; - } + /* Make sure that we leave at the irq starting edge */ + __raw_writel(IPUIRQ_2_MASK(irq), IPUIRQ_2_STATREG(irq)); + do { + reg = __raw_readl(IPUIRQ_2_STATREG(irq)); + } while (!(reg & IPUIRQ_2_MASK(irq)));
reg = __raw_readl(DC_WR_CH_CONF(dc_chan)); reg &= ~DC_WR_CH_CONF_PROG_TYPE_MASK; diff --git a/drivers/video/ipu_regs.h b/drivers/video/ipu_regs.h index 21e9c99..c2c134a 100644 --- a/drivers/video/ipu_regs.h +++ b/drivers/video/ipu_regs.h @@ -313,9 +313,12 @@ struct ipu_dmfc {
#define IPU_STAT ((struct ipu_stat *)(IPU_CTRL_BASE_ADDR + \ IPU_STAT_REG_BASE)) +#define IPU_INT_STAT(n) (&IPU_STAT->int_stat[(n) - 1]) #define IPU_CHA_CUR_BUF(ch) (&IPU_STAT->cur_buf[ch / 32]) #define IPU_CHA_BUF0_RDY(ch) (&IPU_STAT->ch_buf0_rdy[ch / 32]) #define IPU_CHA_BUF1_RDY(ch) (&IPU_STAT->ch_buf1_rdy[ch / 32]) +#define IPUIRQ_2_STATREG(irq) (IPU_INT_STAT(1) + ((irq) / 32)) +#define IPUIRQ_2_MASK(irq) (1UL << ((irq) & 0x1F))
#define IPU_INT_CTRL(n) (&IPU_CM_REG->int_ctrl[(n) - 1])
applied to u-boot-video/master. Thanks!
Anatolij
Anatolij Gustschin
Liu Ying
