[U-Boot] [PATCH] mx6cuboxi: add support for detecting Revision 1.5 SoMs
Solid Run have a rev 1.5 SoM with different a different WiFi/BT module and some other changes. Their downstream commit 99e18b7f14 adds support for detecting this new SoM revision. This adds that support and sets up the new device tree naming that landed in the linux 4.16 kernel.
Tested on a Hummingboard2 Gate.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 30 +++++++++++++++++++++++++++--- include/configs/mx6cuboxi.h | 12 ++++++------ 2 files changed, 33 insertions(+), 9 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index ee9e4f7c01..bea6275b78 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -79,9 +79,11 @@ static iomux_v3_cfg_t const usdhc2_pads[] = { };
static iomux_v3_cfg_t const hb_cbi_sense[] = { - /* These pins are for sensing if it is a CuBox-i or a HummingBoard */ - IOMUX_PADS(PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA4__GPIO3_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), + /* These pins are for sensing if it is a CuBox-i, HummingBoard(2) and SoM rev */ + IOMUX_PADS(PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA4__GPIO3_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT14__GPIO6_IO00 | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT18__GPIO6_IO04 | MUX_PAD_CTRL(UART_PAD_CTRL)), };
static iomux_v3_cfg_t const usb_pads[] = { @@ -390,6 +392,25 @@ static bool is_hummingboard2(void) return false; }
+static bool is_som_rev15(void) +{ + int val1; + int val2; + + SETUP_IOMUX_PADS(hb_cbi_sense); + + gpio_direction_input(IMX_GPIO_NR(6, 0)); + gpio_direction_input(IMX_GPIO_NR(6, 4)); + + val1 = gpio_get_value(IMX_GPIO_NR(6, 0)); + val2 = gpio_get_value(IMX_GPIO_NR(6, 4)); + + if (val1 == 1 && val2 == 0) + return true; + else + return false; +} + int checkboard(void) { if (is_hummingboard2()) @@ -412,6 +433,9 @@ int board_late_init(void) else env_set("board_name", "CUBOXI");
+ if (is_som_rev15()) + env_set("som_rev", "-som-v15"); + if (is_mx6dq()) env_set("board_rev", "MX6Q"); else diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 0e1d18cad8..076fd2c40e 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -104,17 +104,17 @@ "fi\0" \ "findfdt="\ "if test $board_name = HUMMINGBOARD2 && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-hummingboard2.dtb; fi; " \ + "setenv fdtfile imx6q-hummingboard2${som_rev}.dtb; fi; " \ "if test $board_name = HUMMINGBOARD2 && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-hummingboard2.dtb; fi; " \ + "setenv fdtfile imx6dl-hummingboard2${som_rev}.dtb; fi; " \ "if test $board_name = HUMMINGBOARD && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-hummingboard.dtb; fi; " \ + "setenv fdtfile imx6q-hummingboard${som_rev}.dtb; fi; " \ "if test $board_name = HUMMINGBOARD && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-hummingboard.dtb; fi; " \ + "setenv fdtfile imx6dl-hummingboard${som_rev}.dtb; fi; " \ "if test $board_name = CUBOXI && test $board_rev = MX6Q ; then " \ - "setenv fdtfile imx6q-cubox-i.dtb; fi; " \ + "setenv fdtfile imx6q-cubox-i${som_rev}.dtb; fi; " \ "if test $board_name = CUBOXI && test $board_rev = MX6DL ; then " \ - "setenv fdtfile imx6dl-cubox-i.dtb; fi; " \ + "setenv fdtfile imx6dl-cubox-i${som_rev}.dtb; fi; " \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine dtb to use; fi; \0" \ BOOTENV
Hi Peter,
[Adding Jon and Baruch]
Shouldn't we use Jon's recent board version detection implementation instead? https://github.com/SolidRun/u-boot/commit/5d9cf6d848bb33aa3933ce10a3defdaee6...
Thanks
int val1;
int val2;
return true;
else
return false;
if (is_som_rev15())
-- 2.14.3
On Sun, Mar 4, 2018 at 2:49 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Peter,
Possibly, I didn't know if it was better to use the upstream or downstream way of doing things, they're quite a bit different and this was the least change.
int val1;
int val2;
return true;
else
return false;
if (is_som_rev15())
-- 2.14.3
Fabio Estevam
Peter Robinson
