[U-Boot] [PATCH 1/2 v3] x86: Add DFI BT700 BayTrail board support
This patch adds support for the DFI BayTrail BT700 QSeven SoM installed on the DFI Q7X-151 baseboard. The baseboard is equipped with the Nuvoton NCT6102D Super IO chip providing the UART as console.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com --- v3: - Change comment Winbond > Nuvoton - Remove unneeded compatible property in HS-UART DTS node
v2: - Added missing text to Kconfig entry
arch/x86/Kconfig | 4 + arch/x86/dts/Makefile | 1 + arch/x86/dts/dfi-bt700-q7x-151.dts | 22 +++ arch/x86/dts/dfi-bt700.dtsi | 308 ++++++++++++++++++++++++++++++ board/dfi/Kconfig | 29 +++ board/dfi/dfi-bt700/Kconfig | 28 +++ board/dfi/dfi-bt700/MAINTAINERS | 8 + board/dfi/dfi-bt700/Makefile | 8 + board/dfi/dfi-bt700/acpi/mainboard.asl | 13 ++ board/dfi/dfi-bt700/dfi-bt700.c | 30 +++ board/dfi/dfi-bt700/dsdt.asl | 14 ++ board/dfi/dfi-bt700/start.S | 9 + configs/dfi-bt700-internal-uart_defconfig | 61 ++++++ configs/dfi-bt700-q7x-151_defconfig | 63 ++++++ include/configs/dfi-bt700.h | 74 +++++++ 15 files changed, 672 insertions(+) create mode 100644 arch/x86/dts/dfi-bt700-q7x-151.dts create mode 100644 arch/x86/dts/dfi-bt700.dtsi create mode 100644 board/dfi/Kconfig create mode 100644 board/dfi/dfi-bt700/Kconfig create mode 100644 board/dfi/dfi-bt700/MAINTAINERS create mode 100644 board/dfi/dfi-bt700/Makefile create mode 100644 board/dfi/dfi-bt700/acpi/mainboard.asl create mode 100644 board/dfi/dfi-bt700/dfi-bt700.c create mode 100644 board/dfi/dfi-bt700/dsdt.asl create mode 100644 board/dfi/dfi-bt700/start.S create mode 100644 configs/dfi-bt700-internal-uart_defconfig create mode 100644 configs/dfi-bt700-q7x-151_defconfig create mode 100644 include/configs/dfi-bt700.h
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 29d1120..5193ee7 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -17,6 +17,9 @@ config VENDOR_CONGATEC config VENDOR_COREBOOT bool "coreboot"
+config VENDOR_DFI + bool "dfi" + config VENDOR_EFI bool "efi"
@@ -35,6 +38,7 @@ endchoice source "board/advantech/Kconfig" source "board/congatec/Kconfig" source "board/coreboot/Kconfig" +source "board/dfi/Kconfig" source "board/efi/Kconfig" source "board/emulation/Kconfig" source "board/google/Kconfig" diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile index 4f07f41..ca086bd 100644 --- a/arch/x86/dts/Makefile +++ b/arch/x86/dts/Makefile @@ -9,6 +9,7 @@ dtb-y += bayleybay.dtb \ conga-qeval20-qa3-e3845.dtb \ cougarcanyon2.dtb \ crownbay.dtb \ + dfi-bt700-q7x-151.dtb \ efi.dtb \ galileo.dtb \ minnowmax.dtb \ diff --git a/arch/x86/dts/dfi-bt700-q7x-151.dts b/arch/x86/dts/dfi-bt700-q7x-151.dts new file mode 100644 index 0000000..31d9679 --- /dev/null +++ b/arch/x86/dts/dfi-bt700-q7x-151.dts @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "dfi-bt700.dtsi" + +#include "serial.dtsi" + +/ { + model = "DFI-BT700"; + compatible = "dfi,bt700", "intel,baytrail"; + + aliases { + serial0 = &serial; + spi0 = &spi; + }; +}; diff --git a/arch/x86/dts/dfi-bt700.dtsi b/arch/x86/dts/dfi-bt700.dtsi new file mode 100644 index 0000000..75ee6ad --- /dev/null +++ b/arch/x86/dts/dfi-bt700.dtsi @@ -0,0 +1,308 @@ +/* + * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/gpio/x86-gpio.h> +#include <dt-bindings/interrupt-router/intel-irq.h> + +#include "skeleton.dtsi" +#include "rtc.dtsi" +#include "tsc_timer.dtsi" + +/ { + config { + silent_console = <0>; + }; + + pch_pinctrl { + compatible = "intel,x86-pinctrl"; + reg = <0 0>; + + /* Add UART1 PAD configuration (SIO HS-UART) */ + uart1_txd@0 { + pad-offset = <0x10>; + mode-func = <1>; + }; + + uart1_rxd@0 { + pad-offset = <0x20>; + mode-func = <1>; + }; + + /* + * As of today, the latest version FSP (gold4) for BayTrail + * misses the PAD configuration of the SD controller's Card + * Detect signal. The default PAD value for the CD pin sets + * the pin to work in GPIO mode, which causes card detect + * status cannot be reflected by the Present State register + * in the SD controller (bit 16 & bit 18 are always zero). + * + * Configure this pin to function 1 (SD controller). + */ + sdmmc3_cd@0 { + pad-offset = <0x3a0>; + mode-func = <1>; + }; + }; + + chosen { + stdout-path = "/serial"; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <0>; + intel,apic-id = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <1>; + intel,apic-id = <2>; + }; + + cpu@2 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <2>; + intel,apic-id = <4>; + }; + + cpu@3 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <3>; + intel,apic-id = <6>; + }; + }; + + pci { + compatible = "intel,pci-baytrail", "pci-x86"; + #address-cells = <3>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0x80000000 0x80000000 0 0x40000000 + 0x42000000 0x0 0xc0000000 0xc0000000 0 0x20000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>; + + pciuart0: uart@1e,3 { + compatible = "pci8086,0f0a.00", + "pci8086,0f0a", + "pciclass,070002", + "pciclass,0700", + "ns16550"; + u-boot,dm-pre-reloc; + reg = <0x0200f310 0x0 0x0 0x0 0x0>; + reg-shift = <2>; + clock-frequency = <58982400>; + current-speed = <115200>; + }; + + pch@1f,0 { + reg = <0x0000f800 0 0 0 0>; + compatible = "pci8086,0f1c", "intel,pch9"; + #address-cells = <1>; + #size-cells = <1>; + + irq-router { + compatible = "intel,irq-router"; + intel,pirq-config = "ibase"; + intel,ibase-offset = <0x50>; + intel,actl-addr = <0>; + intel,pirq-link = <8 8>; + intel,pirq-mask = <0xdee0>; + intel,pirq-routing = < + /* BayTrail PCI devices */ + PCI_BDF(0, 2, 0) INTA PIRQA + PCI_BDF(0, 3, 0) INTA PIRQA + PCI_BDF(0, 16, 0) INTA PIRQA + PCI_BDF(0, 17, 0) INTA PIRQA + PCI_BDF(0, 18, 0) INTA PIRQA + PCI_BDF(0, 19, 0) INTA PIRQA + PCI_BDF(0, 20, 0) INTA PIRQA + PCI_BDF(0, 21, 0) INTA PIRQA + PCI_BDF(0, 22, 0) INTA PIRQA + PCI_BDF(0, 23, 0) INTA PIRQA + PCI_BDF(0, 24, 0) INTA PIRQA + PCI_BDF(0, 24, 1) INTC PIRQC + PCI_BDF(0, 24, 2) INTD PIRQD + PCI_BDF(0, 24, 3) INTB PIRQB + PCI_BDF(0, 24, 4) INTA PIRQA + PCI_BDF(0, 24, 5) INTC PIRQC + PCI_BDF(0, 24, 6) INTD PIRQD + PCI_BDF(0, 24, 7) INTB PIRQB + PCI_BDF(0, 26, 0) INTA PIRQA + PCI_BDF(0, 27, 0) INTA PIRQA + PCI_BDF(0, 28, 0) INTA PIRQA + PCI_BDF(0, 28, 1) INTB PIRQB + PCI_BDF(0, 28, 2) INTC PIRQC + PCI_BDF(0, 28, 3) INTD PIRQD + PCI_BDF(0, 29, 0) INTA PIRQA + PCI_BDF(0, 30, 0) INTA PIRQA + PCI_BDF(0, 30, 1) INTD PIRQD + PCI_BDF(0, 30, 2) INTB PIRQB + PCI_BDF(0, 30, 3) INTC PIRQC + PCI_BDF(0, 30, 4) INTD PIRQD + PCI_BDF(0, 30, 5) INTB PIRQB + PCI_BDF(0, 31, 3) INTB PIRQB + + /* + * PCIe root ports downstream + * interrupts + */ + PCI_BDF(1, 0, 0) INTA PIRQA + PCI_BDF(1, 0, 0) INTB PIRQB + PCI_BDF(1, 0, 0) INTC PIRQC + PCI_BDF(1, 0, 0) INTD PIRQD + PCI_BDF(2, 0, 0) INTA PIRQB + PCI_BDF(2, 0, 0) INTB PIRQC + PCI_BDF(2, 0, 0) INTC PIRQD + PCI_BDF(2, 0, 0) INTD PIRQA + PCI_BDF(3, 0, 0) INTA PIRQC + PCI_BDF(3, 0, 0) INTB PIRQD + PCI_BDF(3, 0, 0) INTC PIRQA + PCI_BDF(3, 0, 0) INTD PIRQB + PCI_BDF(4, 0, 0) INTA PIRQD + PCI_BDF(4, 0, 0) INTB PIRQA + PCI_BDF(4, 0, 0) INTC PIRQB + PCI_BDF(4, 0, 0) INTD PIRQC + >; + }; + + spi: spi { + #address-cells = <1>; + #size-cells = <0>; + compatible = "intel,ich9-spi"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + compatible = "stmicro,n25q064a", + "spi-flash"; + memory-map = <0xff800000 0x00800000>; + rw-mrc-cache { + label = "rw-mrc-cache"; + reg = <0x006f0000 0x00010000>; + }; + }; + }; + + gpioa { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0 0x20>; + bank-name = "A"; + }; + + gpiob { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x20 0x20>; + bank-name = "B"; + }; + + gpioc { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x40 0x20>; + bank-name = "C"; + }; + + gpiod { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x60 0x20>; + bank-name = "D"; + }; + + gpioe { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x80 0x20>; + bank-name = "E"; + }; + + gpiof { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0xA0 0x20>; + bank-name = "F"; + }; + }; + }; + + fsp { + compatible = "intel,baytrail-fsp"; + fsp,mrc-init-tseg-size = <0>; + fsp,mrc-init-mmio-size = <0x800>; + fsp,mrc-init-spd-addr1 = <0xa0>; + fsp,mrc-init-spd-addr2 = <0xa2>; + fsp,emmc-boot-mode = <1>; + fsp,enable-sdio; + fsp,enable-sdcard; + fsp,enable-hsuart0; + fsp,enable-hsuart1; + fsp,enable-spi; + fsp,enable-sata; + fsp,sata-mode = <1>; + fsp,enable-lpe; + fsp,lpss-sio-enable-pci-mode; + fsp,enable-dma0; + fsp,enable-dma1; + fsp,enable-i2c0; + fsp,enable-i2c1; + fsp,enable-i2c2; + fsp,enable-i2c3; + fsp,enable-i2c4; + fsp,enable-i2c5; + fsp,enable-i2c6; + fsp,enable-pwm0; + fsp,enable-pwm1; + fsp,igd-dvmt50-pre-alloc = <2>; + fsp,aperture-size = <2>; + fsp,gtt-size = <2>; + fsp,scc-enable-pci-mode; + fsp,os-selection = <4>; + fsp,emmc45-ddr50-enabled; + fsp,emmc45-retune-timer-value = <8>; + fsp,enable-igd; + fsp,enable-memory-down; + fsp,memory-down-params { + compatible = "intel,baytrail-fsp-mdp"; + fsp,dram-speed = <2>; /* 2=1333MHz */ + fsp,dram-type = <1>; /* 1=DDR3L */ + fsp,dimm-0-enable; + fsp,dimm-width = <1>; /* 1=x16, 2=x32 */ + fsp,dimm-density = <3>; /* 3=8Gbit */ + fsp,dimm-bus-width = <3>; /* 3=64bits */ + fsp,dimm-sides = <0>; /* 0=1 ranks -> 0x2b */ + + /* These following values might need a re-visit */ + fsp,dimm-tcl = <8>; + fsp,dimm-trpt-rcd = <8>; + fsp,dimm-twr = <8>; + fsp,dimm-twtr = <4>; + fsp,dimm-trrd = <6>; + fsp,dimm-trtp = <4>; + fsp,dimm-tfaw = <22>; + }; + }; + + microcode { + update@0 { +#include "microcode/m0130673325.dtsi" + }; + update@1 { +#include "microcode/m0130679907.dtsi" + }; + }; +}; diff --git a/board/dfi/Kconfig b/board/dfi/Kconfig new file mode 100644 index 0000000..25d0a11 --- /dev/null +++ b/board/dfi/Kconfig @@ -0,0 +1,29 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +if VENDOR_DFI + +choice + prompt "Mainboard model" + optional + +config TARGET_DFI_BT700 + bool "DFI BT700 BayTrail" + help + This is the DFI Q7X-151 baseboard equipped with the + DFI BayTrail Bt700 SoM. It contains an Atom E3845 with + Ethernet (in non-PCIe-x4 configuration), micro-SD, USB 2, + USB 3, SATA, serial console and DisplayPort video out. + It requires some binary blobs - see README.x86 for details. + + Note that PCIE_ECAM_BASE is set up by the FSP so the value used + by U-Boot matches that value. + +endchoice + +source "board/dfi/dfi-bt700/Kconfig" + +endif diff --git a/board/dfi/dfi-bt700/Kconfig b/board/dfi/dfi-bt700/Kconfig new file mode 100644 index 0000000..3f0acb3 --- /dev/null +++ b/board/dfi/dfi-bt700/Kconfig @@ -0,0 +1,28 @@ +if TARGET_DFI_BT700 + +config SYS_BOARD + default "dfi-bt700" + +config SYS_VENDOR + default "dfi" + +config SYS_SOC + default "baytrail" + +config SYS_CONFIG_NAME + default "dfi-bt700" + +config SYS_TEXT_BASE + default 0xfff00000 if !EFI_STUB + default 0x01110000 if EFI_STUB + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select X86_RESET_VECTOR if !EFI_STUB + select INTEL_BAYTRAIL + select BOARD_ROMSIZE_KB_8192 + +config PCIE_ECAM_BASE + default 0xe0000000 + +endif diff --git a/board/dfi/dfi-bt700/MAINTAINERS b/board/dfi/dfi-bt700/MAINTAINERS new file mode 100644 index 0000000..9c3d699 --- /dev/null +++ b/board/dfi/dfi-bt700/MAINTAINERS @@ -0,0 +1,8 @@ +congatec DFI-BT700 +M: Stefan Roese sr@denx.de +S: Maintained +F: board/dfi/dfi-bt700 +F: include/configs/dfi-bt700.h +F: configs/dfi-bt700-q7x-151_defconfig +F: arch/x86/dts/dfi-bt700.dtsi +F: arch/x86/dts/dfi-bt700-q7x-151.dts diff --git a/board/dfi/dfi-bt700/Makefile b/board/dfi/dfi-bt700/Makefile new file mode 100644 index 0000000..8052f5e --- /dev/null +++ b/board/dfi/dfi-bt700/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2015, Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += dfi-bt700.o start.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += dsdt.o diff --git a/board/dfi/dfi-bt700/acpi/mainboard.asl b/board/dfi/dfi-bt700/acpi/mainboard.asl new file mode 100644 index 0000000..544a049 --- /dev/null +++ b/board/dfi/dfi-bt700/acpi/mainboard.asl @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Power Button */ +Device (PWRB) +{ + Name(_HID, EISAID("PNP0C0C")) +} + +/* TODO: Need add Nuvoton SuperIO chipset NCT6102D ASL codes */ diff --git a/board/dfi/dfi-bt700/dfi-bt700.c b/board/dfi/dfi-bt700/dfi-bt700.c new file mode 100644 index 0000000..8645bdc --- /dev/null +++ b/board/dfi/dfi-bt700/dfi-bt700.c @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <nuvoton_nct6102d.h> +#include <asm/gpio.h> +#include <asm/ibmpc.h> +#include <asm/pnp_def.h> + +int board_early_init_f(void) +{ +#ifdef CONFIG_INTERNAL_UART + /* Disable the legacy UART which is enabled per default */ + nct6102d_uarta_disable(); +#else + /* + * The FSP enables the BayTrail internal legacy UART (again). + * Disable it again, so that the Nuvoton one can be used. + */ + setup_internal_uart(0); +#endif + + /* Disable the watchdog which is enabled per default */ + nct6102d_wdt_disable(); + + return 0; +} diff --git a/board/dfi/dfi-bt700/dsdt.asl b/board/dfi/dfi-bt700/dsdt.asl new file mode 100644 index 0000000..6042011 --- /dev/null +++ b/board/dfi/dfi-bt700/dsdt.asl @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +DefinitionBlock("dsdt.aml", "DSDT", 2, "U-BOOT", "U-BOOTBL", 0x00010000) +{ + /* platform specific */ + #include <asm/arch/acpi/platform.asl> + + /* board specific */ + #include "acpi/mainboard.asl" +} diff --git a/board/dfi/dfi-bt700/start.S b/board/dfi/dfi-bt700/start.S new file mode 100644 index 0000000..2c941a4 --- /dev/null +++ b/board/dfi/dfi-bt700/start.S @@ -0,0 +1,9 @@ +/* + * Copyright (C) 2015, Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +.globl early_board_init +early_board_init: + jmp early_board_init_ret diff --git a/configs/dfi-bt700-internal-uart_defconfig b/configs/dfi-bt700-internal-uart_defconfig new file mode 100644 index 0000000..1a7315d --- /dev/null +++ b/configs/dfi-bt700-internal-uart_defconfig @@ -0,0 +1,61 @@ +CONFIG_X86=y +CONFIG_DM_I2C=y +CONFIG_VENDOR_DFI=y +CONFIG_DEFAULT_DEVICE_TREE="dfi-bt700" +CONFIG_TARGET_DFI_BT700=y +CONFIG_HAVE_INTEL_ME=y +CONFIG_ENABLE_MRC_CACHE=y +CONFIG_SMP=y +CONFIG_HAVE_VGA_BIOS=y +CONFIG_GENERATE_PIRQ_TABLE=y +CONFIG_GENERATE_MP_TABLE=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y +CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CPU=y +CONFIG_NUVOTON_NCT6102D=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_DM_PCI=y +CONFIG_DM_RTC=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x3f8 +CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_SYS_NS16550=y +CONFIG_ICH_SPI=y +CONFIG_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_VIDEO_VESA=y +CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig new file mode 100644 index 0000000..6f00004 --- /dev/null +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -0,0 +1,63 @@ +CONFIG_X86=y +CONFIG_DM_I2C=y +CONFIG_VENDOR_DFI=y +CONFIG_DEFAULT_DEVICE_TREE="dfi-bt700-q7x-151" +CONFIG_TARGET_DFI_BT700=y +CONFIG_HAVE_INTEL_ME=y +CONFIG_ENABLE_MRC_CACHE=y +CONFIG_SMP=y +CONFIG_HAVE_VGA_BIOS=y +CONFIG_GENERATE_PIRQ_TABLE=y +CONFIG_GENERATE_MP_TABLE=y +CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_SEABIOS=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y +CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CPU=y +CONFIG_NUVOTON_NCT6102D=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_DM_PCI=y +CONFIG_DM_RTC=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x3f8 +CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_SYS_NS16550=y +CONFIG_ICH_SPI=y +CONFIG_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_VIDEO_VESA=y +CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/dfi-bt700.h b/include/configs/dfi-bt700.h new file mode 100644 index 0000000..23d8a0a --- /dev/null +++ b/include/configs/dfi-bt700.h @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * board/config.h - configuration options, board specific + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <configs/x86-common.h> + +#define CONFIG_SYS_MONITOR_LEN (1 << 20) +#define CONFIG_BOARD_EARLY_INIT_F + +#ifndef CONFIG_INTERNAL_UART +/* Use BayTrail internal HS UART which is memory-mapped */ +#undef CONFIG_SYS_NS16550_PORT_MAPPED +#endif + +#define CONFIG_PCI_PNP + +#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +#define CONFIG_SCSI_DEV_LIST \ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA}, \ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA_ALT} + +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC_SDMA + +#undef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_MCS7830 +#define CONFIG_USB_ETHER_RTL8152 + +#define VIDEO_IO_OFFSET 0 +#define CONFIG_X86EMU_RAW_IO +#define CONFIG_CMD_BMP + +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_ENV_OFFSET 0x006ef000 + +#undef CONFIG_BOOTARGS +#undef CONFIG_BOOTCOMMAND + +#define CONFIG_BOOTARGS \ + "root=/dev/sda1 ro quiet" +#define CONFIG_BOOTCOMMAND \ + "load scsi 0:1 03000000 /boot/vmlinuz-${kernel-ver}-generic;" \ + "load scsi 0:1 04000000 /boot/initrd.img-${kernel-ver}-generic;" \ + "run boot" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "kernel-ver=4.4.0-24\0" \ + "boot=zboot 03000000 0 04000000 ${filesize}\0" \ + "upd_uboot=usb reset;tftp 100000 dfi/u-boot.rom;" \ + "sf probe;sf update 100000 0 800000;saveenv\0" + +#define CONFIG_PREBOOT + +#endif /* __CONFIG_H */
v3:
v2:
applied to u-boot-x86, thanks!
Hi Stefan,
v3:
v2:
Unfortunately the dfi-bt700-internal-uart_defconfig does not build. Can you please look at this?
+ +Device Tree Source is not correctly specified. +Please define 'CONFIG_DEFAULT_DEVICE_TREE' +or build with 'DEVICE_TREE=<device_tree>' argument +make[2]: *** [arch/x86/dts/dfi-bt700.dtb] Error 1 +make[1]: *** [dts/dt.dtb] Error 2
Also buildman reports the following warnings:
WARNING: no status info for 'theadorable-x86-dfi-bt700' WARNING: no maintainers for 'theadorable-x86-dfi-bt700' WARNING: no status info for 'dfi-bt700-internal-uart' WARNING: no maintainers for 'dfi-bt700-internal-uart'
WARNING: no status info for 'conga-qeval20-qa3-e3845-internal-uart' WARNING: no maintainers for 'conga-qeval20-qa3-e3845-internal-uart'
Can you please fix these too?
Regards, Bin
Hi Bin,
v3:
v2:
Sorry for the problems. I'm just back from vacation and will take a look at it today.
Thanks, Stefan
Hi Stefan,
On Mon, Aug 15, 2016 at 5:11 PM, Stefan Roese sr@denx.de wrote:
Hi Bin,
v3:
v2:
Thanks for checking. Please post new version patches with the additional changes and I will re-apply them.
Regards, Bin
Bin Meng
Stefan Roese
