[U-Boot] [PATCH 1/2] esdhc: memset mmc struct before putting into use
struct mmc should be clear to all '0' after malloc to avoid unexpect variable value.
Like mmc->has_init = xxx. In this case mmcinfo will believe the card had been initialized before and skip the initialization.
Test on P5040 and T4240, Error Log:
=> mmcinfo Device: FSL_SDHC Manufacturer ID: 0 OEM: 0 Name: Tran Speed: 0 Rd Block Len: 0 MMC version 0.0 High Capacity: No Capacity: 0 Bytes Bus Width: 0-bit =>
Signed-off-by: Haijun Zhang Haijun.Zhang@freescale.com Signed-off-by: Xie Shaohui-B21989 B21989@freescale.com --- drivers/mmc/fsl_esdhc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index a7170b4..d4c1eef 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -521,6 +521,7 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) if (!mmc) return -ENOMEM;
+ memset(mmc, 0, sizeof(struct mmc)); sprintf(mmc->name, "FSL_SDHC"); regs = (struct fsl_esdhc *)cfg->esdhc_base;
T4240 eSDHC host capabilities reigster should have VS33 bit define. hack the code to add the 3.3 voltage support
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Haijun Zhang Haijun.Zhang@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 1 + drivers/mmc/fsl_esdhc.c | 6 ++++++ 2 files changed, 7 insertions(+)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 946ea97..84e79c8 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -596,6 +596,7 @@ #define CONFIG_SYS_FSL_SRIO_LIODN #define CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_SYS_FSL_ERRATUM_A004468 #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_FSL_ERRATUM_A005871 diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index d4c1eef..b8b2907 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -545,6 +545,12 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) caps = caps & ~(ESDHC_HOSTCAPBLT_SRS | ESDHC_HOSTCAPBLT_VS18 | ESDHC_HOSTCAPBLT_VS30); #endif + +/* T4240 host controller capabilities register should have VS33 bit */ +#ifdef CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 + caps = caps | ESDHC_HOSTCAPBLT_VS33; +#endif + if (caps & ESDHC_HOSTCAPBLT_VS18) voltage_caps |= MMC_VDD_165_195; if (caps & ESDHC_HOSTCAPBLT_VS30)
Shall we call it quirk rather than hack? Native English speakers, please chime in.
York
- caps = caps | ESDHC_HOSTCAPBLT_VS33;
Is there an erratum associated with this? Is this that t4240qds-specific bug, or a different bug that affects all t4240?
-Scott
于 2013/10/30 2:34, Scott Wood 写道:
No such relevant errata. I think this capacity missing is also exist on other T4240 board but not be confirmed. So, I update this patch to make sure the change only affect T4240QDS.
-Scott
Haijun Zhang Haijun.Zhang@freescale.com wrote on 10/24/2013 08:54:42 PM:
Tested-by: Ryan Barnett rjbarnet@rockwellcollins.com
Verified that this patch fixes issues related to booting from eSDHC interface on the P2041RDB with U-Boot 2013.10.
fsl_esdhc_cfg *cfg)
- memset(mmc, 0, sizeof(struct mmc)); sprintf(mmc->name, "FSL_SDHC"); regs = (struct fsl_esdhc *)cfg->esdhc_base;
-- 1.8.4
Thanks. Barnett
:-) 于 2013/10/26 0:28, Ryan Barnett 写道:
fsl_esdhc_cfg *cfg)
-- 1.8.4
participants (5)
Haijun Zhang
Ryan Barnett
Scott Wood
sun york-R58495
Zhang Haijun
