[U-Boot] [PATCH] m68k: Fix incorrect memory access on M5235
The csarX and cscrX registers in the fbcs_t struct are 16-bit for CONFIG_M5235 and 32-bit wide otherwise. The code in cpu_init.c accessed them always as 32-bit, effectively creating a wrong memory access on M5235. Fixed that by choosing out_be16/out_be32 depending on whether CONFIG_M5235 is defined or not.
Cc: Jason Jin Jason.jin@freescale.com Signed-off-by: Vasili Galka vvv444@gmail.com --- arch/m68k/cpu/mcf523x/cpu_init.c | 39 ++++++++++++++++++++++--------------- 1 files changed, 23 insertions(+), 16 deletions(-)
diff --git a/arch/m68k/cpu/mcf523x/cpu_init.c b/arch/m68k/cpu/mcf523x/cpu_init.c index 5a78954..af1fd56 100644 --- a/arch/m68k/cpu/mcf523x/cpu_init.c +++ b/arch/m68k/cpu/mcf523x/cpu_init.c @@ -20,6 +20,13 @@ #include <asm/fec.h> #endif
+/* The registers in fbcs_t struct can be 16-bit for CONFIG_M5235 or 32-bit wide otherwise. */ +#ifdef CONFIG_M5235 +#define out_be_fbcs_reg out_be16 +#else +#define out_be_fbcs_reg out_be32 +#endif + /* * Breath some life into the CPU... * @@ -45,57 +52,57 @@ void cpu_init_f(void) out_8(&gpio->par_cs, 0);
#if (defined(CONFIG_SYS_CS0_BASE) && defined(CONFIG_SYS_CS0_MASK) && defined(CONFIG_SYS_CS0_CTRL)) - out_be32(&fbcs->csar0, CONFIG_SYS_CS0_BASE); - out_be32(&fbcs->cscr0, CONFIG_SYS_CS0_CTRL); + out_be_fbcs_reg(&fbcs->csar0, CONFIG_SYS_CS0_BASE); + out_be_fbcs_reg(&fbcs->cscr0, CONFIG_SYS_CS0_CTRL); out_be32(&fbcs->csmr0, CONFIG_SYS_CS0_MASK); #endif
#if (defined(CONFIG_SYS_CS1_BASE) && defined(CONFIG_SYS_CS1_MASK) && defined(CONFIG_SYS_CS1_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS1); - out_be32(&fbcs->csar1, CONFIG_SYS_CS1_BASE); - out_be32(&fbcs->cscr1, CONFIG_SYS_CS1_CTRL); + out_be_fbcs_reg(&fbcs->csar1, CONFIG_SYS_CS1_BASE); + out_be_fbcs_reg(&fbcs->cscr1, CONFIG_SYS_CS1_CTRL); out_be32(&fbcs->csmr1, CONFIG_SYS_CS1_MASK); #endif
#if (defined(CONFIG_SYS_CS2_BASE) && defined(CONFIG_SYS_CS2_MASK) && defined(CONFIG_SYS_CS2_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS2); - out_be32(&fbcs->csar2, CONFIG_SYS_CS2_BASE); - out_be32(&fbcs->cscr2, CONFIG_SYS_CS2_CTRL); + out_be_fbcs_reg(&fbcs->csar2, CONFIG_SYS_CS2_BASE); + out_be_fbcs_reg(&fbcs->cscr2, CONFIG_SYS_CS2_CTRL); out_be32(&fbcs->csmr2, CONFIG_SYS_CS2_MASK); #endif
#if (defined(CONFIG_SYS_CS3_BASE) && defined(CONFIG_SYS_CS3_MASK) && defined(CONFIG_SYS_CS3_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS3); - out_be32(&fbcs->csar3, CONFIG_SYS_CS3_BASE); - out_be32(&fbcs->cscr3, CONFIG_SYS_CS3_CTRL); + out_be_fbcs_reg(&fbcs->csar3, CONFIG_SYS_CS3_BASE); + out_be_fbcs_reg(&fbcs->cscr3, CONFIG_SYS_CS3_CTRL); out_be32(&fbcs->csmr3, CONFIG_SYS_CS3_MASK); #endif
#if (defined(CONFIG_SYS_CS4_BASE) && defined(CONFIG_SYS_CS4_MASK) && defined(CONFIG_SYS_CS4_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS4); - out_be32(&fbcs->csar4, CONFIG_SYS_CS4_BASE); - out_be32(&fbcs->cscr4, CONFIG_SYS_CS4_CTRL); + out_be_fbcs_reg(&fbcs->csar4, CONFIG_SYS_CS4_BASE); + out_be_fbcs_reg(&fbcs->cscr4, CONFIG_SYS_CS4_CTRL); out_be32(&fbcs->csmr4, CONFIG_SYS_CS4_MASK); #endif
#if (defined(CONFIG_SYS_CS5_BASE) && defined(CONFIG_SYS_CS5_MASK) && defined(CONFIG_SYS_CS5_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS5); - out_be32(&fbcs->csar5, CONFIG_SYS_CS5_BASE); - out_be32(&fbcs->cscr5, CONFIG_SYS_CS5_CTRL); + out_be_fbcs_reg(&fbcs->csar5, CONFIG_SYS_CS5_BASE); + out_be_fbcs_reg(&fbcs->cscr5, CONFIG_SYS_CS5_CTRL); out_be32(&fbcs->csmr5, CONFIG_SYS_CS5_MASK); #endif
#if (defined(CONFIG_SYS_CS6_BASE) && defined(CONFIG_SYS_CS6_MASK) && defined(CONFIG_SYS_CS6_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS6); - out_be32(&fbcs->csar6, CONFIG_SYS_CS6_BASE); - out_be32(&fbcs->cscr6, CONFIG_SYS_CS6_CTRL); + out_be_fbcs_reg(&fbcs->csar6, CONFIG_SYS_CS6_BASE); + out_be_fbcs_reg(&fbcs->cscr6, CONFIG_SYS_CS6_CTRL); out_be32(&fbcs->csmr6, CONFIG_SYS_CS6_MASK); #endif
#if (defined(CONFIG_SYS_CS7_BASE) && defined(CONFIG_SYS_CS7_MASK) && defined(CONFIG_SYS_CS7_CTRL)) setbits_8(&gpio->par_cs, GPIO_PAR_CS_CS7); - out_be32(&fbcs->csar7, CONFIG_SYS_CS7_BASE); - out_be32(&fbcs->cscr7, CONFIG_SYS_CS7_CTRL); + out_be_fbcs_reg(&fbcs->csar7, CONFIG_SYS_CS7_BASE); + out_be_fbcs_reg(&fbcs->cscr7, CONFIG_SYS_CS7_CTRL); out_be32(&fbcs->csmr7, CONFIG_SYS_CS7_MASK); #endif
Vasili Galka
