[U-Boot] [PATCH] armv8/ls1088a: configure PMU's PCTBENR to enable WDT
The SP805-WDT module on LS1088A requires configuration of PMU's PCTBENR register to enable watchdog counter decrement and reset signal generation. The watchdog clock needs to be enabled first.
Signed-off-by: Zhang Ying-22455 ying.zhang22455@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index c6fede3..ea983e4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -531,7 +531,7 @@ int timer_init(void) #ifdef CONFIG_FSL_LSCH3 u32 __iomem *cltbenr = (u32 *)CONFIG_SYS_FSL_PMU_CLTBENR; #endif -#ifdef CONFIG_ARCH_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS1088A) u32 __iomem *pctbenr = (u32 *)FSL_PMU_PCTBENR_OFFSET; u32 svr_dev_id; #endif @@ -550,7 +550,7 @@ int timer_init(void) out_le32(cltbenr, 0xf); #endif
-#ifdef CONFIG_ARCH_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS1088A) /* * In certain Layerscape SoCs, the clock for each core's * has an enable bit in the PMU Physical Core Time Base Enable
The subject doesn't represent your change. Please revise.
NAK. Do not revert back to CONFIG_LS2080A.
York
York Sun
