[U-Boot] [PATCH] sunxi: disable Pine A64 model detection code on non-A64 SoCs
The Pine A64 Plus/non-Plus model detection code is now built on all 64-bit ARM SoCs, even if the code cannot be triggered when H5/H6 is in use.
Disable them when the SoC is not A64 by use #ifdef to wrap them.
On GCC 7.3.1 this makes the size of the function reduces 184 bytes, and saves a 104 byte strstr() function, then makes SPL on H6 succeed to build.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- board/sunxi/board.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 857d5ff010..4fb0ff2529 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -823,13 +823,14 @@ int board_fit_config_name_match(const char *name) };
/* Differentiate the two Pine64 board DTs by their DRAM size. */ +#ifdef CONFIG_MACH_SUN50I if (strstr(name, "-pine64") && strstr(cmp_str, "-pine64")) { if ((gd->ram_size > 512 * 1024 * 1024)) return !strstr(name, "plus"); else return !!strstr(name, "plus"); - } else { - return strcmp(name, cmp_str); } +#endif + return strcmp(name, cmp_str); } #endif
Hi!
- } else {
}return strcmp(name, cmp_str);
I'd really prefer to have an opt-in option, selected only by the Pine64, rather than enabling it for all the A64 boards that don't have any use for that code.
Maxime
Icenowy Zheng
Maxime Ripard
