[U-Boot] [PATCH] ARC: Fix iteration in arc_xx_version()
"i" gets incremented before we're entering loop body and effectively we iterate from 1 to 8 instead of 0 to 7.
This way we: a) Skip the first line of struct hs_versions b) Go over it and access memory beyond the structure
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- arch/arc/lib/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index 07daaa8d15..01cca95d5b 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -87,7 +87,7 @@ const char *arc_em_version(int arcver, char *name, int name_len) bool xymem = ARC_FEATURE_EXISTS(ARC_AUX_XY_BUILD); int i;
- for (i = 0; i++ < sizeof(em_versions) / sizeof(struct em_template_t);) { + for (i = 0; i < sizeof(em_versions) / sizeof(struct em_template_t); i++) { if (em_versions[i].cache == cache && em_versions[i].dsp == dsp && em_versions[i].xymem == xymem) { @@ -147,7 +147,7 @@ const char *arc_hs_version(int arcver, char *name, int name_len) bool dual_issue = arcver == 0x54 ? true : false; int i;
- for (i = 0; i++ < sizeof(hs_versions) / sizeof(struct hs_template_t);) { + for (i = 0; i < sizeof(hs_versions) / sizeof(struct hs_template_t); i++) { if (hs_versions[i].cache == cache && hs_versions[i].mmu == mmu && hs_versions[i].dual_issue == dual_issue &&
Alexey Brodkin
