[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks !
The following changes since commit f2e8a87305a55652488af140adcf65b1e688f287:
exynos: fdt: Add TMU node for snow (2013-04-17 10:00:44 +0900)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to d782c1fe7246301143ed78c0d86ea6c81f9325f9:
arm: mxs: video: Enable MXS LCDIF on M28EVK (2013-05-06 17:40:23 +0200)
---------------------------------------------------------------- Benoît Thébaudeau (40): imx: Homogenize and fix fuse register definitions imx: Add useful fuse definitions Add fuse API and commands Add fsl_iim driver mpc: iim: Switch to common fsl_iim mx51evk: Enable support for iim Add mxc_ocotp driver mx6qsabrelite: Enable support for ocotp nitrogen6x: Enable support for ocotp imx: Document fuse assignments for MAC addresses imx: iomux-v3: Fix common pad control definitions imx: iomux-v3: cosmetic: Reorganize definitions imx: iomux-v3: Restore Linux's NEW_PAD_CTRL() macro imx: iomux-v3: Include PKE and PUE to pad control pull definitions imx: iomux-v3: Add iomux-mx25.h imx: mx25pdk: Convert to iomux-v3 imx: mx25pdk: Fix GPIO assignments imx: tx25: Convert to iomux-v3 imx: zmx25: Convert to iomux-v3 imx: mx25: Remove legacy iomux support imx: iomux-v3: Add iomux-mx35.h imx: flea3: Convert to iomux-v3 imx: mx35pdk: Fix WDOG_RST iomux function imx: mx35pdk: Convert to iomux-v3 imx: woodburn: Convert to iomux-v3 imx: mx35: Remove legacy iomux support imx: iomux-mx51: Fix MX51_PAD_EIM_CS2__GPIO2_27 imx: iomux-v3: Add missing definitions to iomux-mx51.h imx: mx51evk: Convert to iomux-v3 imx: mx51_efikamx/sb: Convert to iomux-v3 imx: vision2: Convert to iomux-v3 imx: iomux-v3: Add iomux-mx53.h imx: ima3-mx53: Convert to iomux-v3 imx: mx53ard: Convert to iomux-v3 imx: mx53evk: Convert to iomux-v3 imx: mx53loco: Convert to iomux-v3 imx: mx53smd: Convert to iomux-v3 imx: m53evk: Convert to iomux-v3 imx: mx5: Remove legacy iomux support imx: mx35pdk: Fix MUX2_CTR GPIO
Eric Benard (1): mx28evk: add trimffs to nand command
Fabio Estevam (22): iomux-v3: Place pad control definitions into common file mx6: Add solo-lite variant support mx6sl: Add initial support for mx6slevk board imx: mx6q_4x_mt41j128.cfg: Setup CCM_CCOSR register nitrogen6x: Setup CCM_CCOSR register mx51evk: Update environment in order to allow booting a dt kernel mx51evk: Do not force the rootfs type mx5: Define a common get_board_rev() mx5: Select CONFIG_REVISION_TAG mx53ard: Move register masks into imx-regs.h mx23: Put back RAM voltage level to its original value mx23: Fix pad voltage selection bit mx23evk: Fix DDR pin iomux settings mx23_olinuxino: Fix DDR pin iomux settings mxs: spl_mem_init: Fix comment about start bit mxs: spl_mem_init: Remove erroneous DDR setting mxs: spl_mem_init: Skip the initialization of some DRAM_CTL registers mxs: spl_mem_init: Change EMI port priority mx23: Operate DDR voltage supply at 2.5V mx23evk: Do not set voltage selection bit for SSP pads mx23_olinuxino: Do not set voltage selection bit for SSP pads mxs: Explain why some mx23 DDR registers are not configured
Marek Vasut (13): tools: arm: imx: Implement BOOT_OFFSET command for imximage imx: Align the imximage header and payload to multiples of 4k nand: Add SPL_NAND support to mxc_nand_spl arm: imx: Pack u-boot.bin into uImage for SPL arm: mx5: Add SPL support code to MX5 arm: mx5: Add NAND clock handling arm: mx5: Add support for DENX M53EVK arm: mx23: Fix VDDMEM misconfiguration arm: mxs: Preprocess u-boot.bd so they contain full path arm: mxs: Add LCDIF clock configuration function arm: mxs: Add LCDIF registers for i.MX233 arm: mxs: Add MXS LCDIF driver arm: mxs: video: Enable MXS LCDIF on M28EVK
Otavio Salvador (9): mx6qsabre{sd, auto}: Add update_sd_firmware support mx6qsabresd: Return status when initializing MMC wandboard: Use env storage info for mmcdev/mmcpart wandboard: Add update_sd_firmware support wandboard: Add card detection for SOM MicroSD card wandboard: Add support for Carrier Board MicroSD card wandboard: Add boot selection support mxs: mxsboot: Move sdcard BCB header to 4 sectors offset mx53ard: Rework default environment to support FDT, MMC and netboot
Philip Paeps (2): mx35 iomux: correct offsets of IOMUX registers mx35 iomux: correct input select register index
Shawn Guo (1): ARM: mx6: define CONFIG_ARM_ERRATA_742230
Stefan Roese (7): arm: imx: Change iomux functions to void type imx: Move some header files from arch-mxs to imx-common imx: Move some i.MX common functions into the imx-common directory dma: Add i.MX6 support to drivers/dma/apbh_dma.c mtd: mxs_nand: Add support for i.MX6 imx: Add titanium board support (i.MX6 based) arm: imx: Codingstyle enhancement of include/asm/arch-mx6/crm_regs.h
Stefano Babic (1): Merge branch 'next'
.gitignore | 1 + MAINTAINERS | 4 + Makefile | 9 +- README | 1 + arch/arm/cpu/arm1136/mx35/Makefile | 1 - arch/arm/cpu/arm1136/mx35/iomux.c | 114 -- arch/arm/cpu/arm926ejs/mx25/generic.c | 117 -- arch/arm/cpu/arm926ejs/mxs/Makefile | 10 + arch/arm/cpu/arm926ejs/mxs/clock.c | 93 ++ arch/arm/cpu/arm926ejs/mxs/mxs.c | 65 +- arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 46 +- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 50 +- arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd | 4 +- arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd | 4 +- arch/arm/cpu/armv7/mx5/Makefile | 2 +- arch/arm/cpu/armv7/mx5/clock.c | 14 +- arch/arm/cpu/armv7/mx5/iomux.c | 186 --- arch/arm/cpu/armv7/mx5/soc.c | 7 + arch/arm/cpu/armv7/mx6/clock.c | 52 +- arch/arm/cpu/armv7/mx6/soc.c | 11 +- arch/arm/imx-common/Makefile | 22 +- arch/arm/imx-common/iomux-v3.c | 18 +- arch/arm/imx-common/misc.c | 84 ++ arch/arm/include/asm/arch-mx25/imx-regs.h | 21 +- arch/arm/include/asm/arch-mx25/imx25-pinmux.h | 421 ------- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 545 +++++++++ arch/arm/include/asm/arch-mx27/imx-regs.h | 3 +- arch/arm/include/asm/arch-mx31/imx-regs.h | 22 +- arch/arm/include/asm/arch-mx35/imx-regs.h | 19 +- arch/arm/include/asm/arch-mx35/iomux-mx35.h | 1276 ++++++++++++++++++++ arch/arm/include/asm/arch-mx35/iomux.h | 295 ----- arch/arm/include/asm/arch-mx35/mx35_pins.h | 353 ------ arch/arm/include/asm/arch-mx5/clock.h | 1 + arch/arm/include/asm/arch-mx5/imx-regs.h | 24 +- arch/arm/include/asm/arch-mx5/iomux-mx51.h | 180 ++- arch/arm/include/asm/arch-mx5/iomux-mx53.h | 1232 +++++++++++++++++++ arch/arm/include/asm/arch-mx5/iomux.h | 91 -- arch/arm/include/asm/arch-mx5/mx5x_pins.h | 879 -------------- arch/arm/include/asm/arch-mx5/spl.h | 19 + arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/crm_regs.h | 183 +-- arch/arm/include/asm/arch-mx6/imx-regs.h | 96 +- arch/arm/include/asm/arch-mx6/mx6-pins.h | 4 + arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 35 +- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 27 - arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 25 + arch/arm/include/asm/arch-mx6/sys_proto.h | 10 + arch/arm/include/asm/arch-mxs/clock.h | 1 + arch/arm/include/asm/arch-mxs/imx-regs.h | 6 +- arch/arm/include/asm/arch-mxs/iomux.h | 4 + arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h | 2 +- arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h | 2 +- arch/arm/include/asm/arch-mxs/regs-digctl.h | 2 +- arch/arm/include/asm/arch-mxs/regs-i2c.h | 2 +- arch/arm/include/asm/arch-mxs/regs-lcdif.h | 38 +- arch/arm/include/asm/arch-mxs/regs-lradc.h | 2 +- arch/arm/include/asm/arch-mxs/regs-ocotp.h | 2 +- arch/arm/include/asm/arch-mxs/regs-pinctrl.h | 2 +- arch/arm/include/asm/arch-mxs/regs-power-mx23.h | 2 +- arch/arm/include/asm/arch-mxs/regs-power-mx28.h | 2 +- arch/arm/include/asm/arch-mxs/regs-rtc.h | 2 +- arch/arm/include/asm/arch-mxs/regs-ssp.h | 2 +- arch/arm/include/asm/arch-mxs/regs-timrot.h | 2 +- .../arm/include/asm/{arch-mxs => imx-common}/dma.h | 12 + arch/arm/include/asm/imx-common/imximage.cfg | 30 + arch/arm/include/asm/imx-common/iomux-v3.h | 69 +- .../asm/{arch-mxs => imx-common}/regs-apbh.h | 19 +- .../asm/{arch-mxs => imx-common}/regs-bch.h | 12 +- .../asm/{arch-mxs => imx-common}/regs-common.h | 0 .../asm/{arch-mxs => imx-common}/regs-gpmi.h | 2 +- arch/powerpc/cpu/mpc512x/Makefile | 1 - arch/powerpc/cpu/mpc512x/cpu_init.c | 2 +- arch/powerpc/cpu/mpc512x/iim.c | 394 ------ arch/powerpc/include/asm/immap_512x.h | 2 + board/CarMediaLab/flea3/flea3.c | 91 +- board/boundary/nitrogen6x/clocks.cfg | 11 + board/boundary/nitrogen6x/nitrogen6x.c | 42 +- board/denx/m53evk/Makefile | 40 + board/denx/m53evk/imximage.cfg | 108 ++ board/denx/m53evk/m53evk.c | 328 +++++ board/esg/ima3-mx53/ima3-mx53.c | 228 ++-- board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg | 11 + board/freescale/mx23evk/spl_boot.c | 4 +- board/freescale/mx25pdk/mx25pdk.c | 132 +- board/freescale/mx35pdk/mx35pdk.c | 175 ++- board/freescale/mx51evk/mx51evk.c | 348 ++---- board/freescale/mx51evk/mx51evk_video.c | 22 +- board/freescale/mx53ard/mx53ard.c | 329 +++-- board/freescale/mx53evk/mx53evk.c | 289 ++--- board/freescale/mx53loco/mx53loco.c | 268 ++-- board/freescale/mx53loco/mx53loco_video.c | 68 +- board/freescale/mx53smd/mx53smd.c | 152 +-- board/freescale/mx6qarm2/mx6qarm2.c | 17 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 22 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 30 +- board/freescale/mx6qsabresd/mx6qsabresd.c | 30 +- board/freescale/mx6slevk/Makefile | 28 + board/freescale/mx6slevk/imximage.cfg | 118 ++ board/freescale/mx6slevk/mx6slevk.c | 102 ++ board/freescale/titanium/Makefile | 36 + board/freescale/titanium/imximage.cfg | 178 +++ board/freescale/titanium/titanium.c | 334 +++++ board/genesi/mx51_efikamx/efikamx-usb.c | 122 +- board/genesi/mx51_efikamx/efikamx.c | 2 +- board/karo/tx25/tx25.c | 107 +- board/olimex/mx23_olinuxino/spl_boot.c | 4 +- board/syteco/zmx25/zmx25.c | 143 +-- board/ttcontrol/vision2/vision2.c | 585 ++++----- board/wandboard/wandboard.c | 113 +- board/woodburn/woodburn.c | 69 +- boards.cfg | 3 + common/Makefile | 1 + common/cmd_fuse.c | 168 +++ doc/README.fsl_iim | 48 + doc/README.fuse | 67 + doc/README.imx25 | 10 + doc/README.imx27 | 10 + doc/README.imx5 | 6 + doc/README.imx6 | 10 + doc/README.imximage | 18 + doc/README.mxc_ocotp | 50 + drivers/dma/apbh_dma.c | 5 +- drivers/misc/Makefile | 2 + drivers/misc/fsl_iim.c | 286 +++++ drivers/misc/mxc_ocotp.c | 216 ++++ drivers/mmc/mxsmmc.c | 2 +- drivers/mtd/nand/mxc_nand_spl.c | 13 +- drivers/mtd/nand/mxs_nand.c | 15 +- drivers/spi/mxs_spi.c | 2 +- drivers/usb/host/ehci-mx5.c | 73 -- drivers/video/Makefile | 1 + drivers/video/cfb_console.c | 4 + drivers/video/mxsfb.c | 189 +++ include/config_cmd_all.h | 1 + include/configs/ac14xx.h | 5 + include/configs/aria.h | 2 +- include/configs/ima3-mx53.h | 3 - include/configs/m28evk.h | 19 + include/configs/m53evk.h | 256 ++++ include/configs/mecp5123.h | 2 +- include/configs/mpc5121ads.h | 2 +- include/configs/mx28evk.h | 1 + include/configs/mx51evk.h | 51 +- include/configs/mx53ard.h | 102 +- include/configs/mx53evk.h | 1 + include/configs/mx53smd.h | 1 + include/configs/mx6_common.h | 1 + include/configs/mx6qsabre_common.h | 14 + include/configs/mx6qsabrelite.h | 5 + include/configs/mx6slevk.h | 189 +++ include/configs/nitrogen6x.h | 5 + include/configs/pdm360ng.h | 7 + include/configs/titanium.h | 277 +++++ include/configs/wandboard.h | 24 +- .../asm/arch-mx25/sys_proto.h => include/fuse.h | 30 +- include/usb/ehci-fsl.h | 6 - spl/Makefile | 8 + tools/imximage.c | 17 +- tools/imximage.h | 9 +- tools/mxsboot.c | 8 +- 160 files changed, 8884 insertions(+), 5340 deletions(-) delete mode 100644 arch/arm/cpu/arm1136/mx35/iomux.c delete mode 100644 arch/arm/cpu/armv7/mx5/iomux.c create mode 100644 arch/arm/imx-common/misc.c delete mode 100644 arch/arm/include/asm/arch-mx25/imx25-pinmux.h create mode 100644 arch/arm/include/asm/arch-mx25/iomux-mx25.h create mode 100644 arch/arm/include/asm/arch-mx35/iomux-mx35.h delete mode 100644 arch/arm/include/asm/arch-mx35/iomux.h delete mode 100644 arch/arm/include/asm/arch-mx35/mx35_pins.h create mode 100644 arch/arm/include/asm/arch-mx5/iomux-mx53.h delete mode 100644 arch/arm/include/asm/arch-mx5/iomux.h delete mode 100644 arch/arm/include/asm/arch-mx5/mx5x_pins.h create mode 100644 arch/arm/include/asm/arch-mx5/spl.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6sl_pins.h rename arch/arm/include/asm/{arch-mxs => imx-common}/dma.h (93%) create mode 100644 arch/arm/include/asm/imx-common/imximage.cfg rename arch/arm/include/asm/{arch-mxs => imx-common}/regs-apbh.h (97%) rename arch/arm/include/asm/{arch-mxs => imx-common}/regs-bch.h (96%) rename arch/arm/include/asm/{arch-mxs => imx-common}/regs-common.h (100%) rename arch/arm/include/asm/{arch-mxs => imx-common}/regs-gpmi.h (99%) delete mode 100644 arch/powerpc/cpu/mpc512x/iim.c create mode 100644 board/denx/m53evk/Makefile create mode 100644 board/denx/m53evk/imximage.cfg create mode 100644 board/denx/m53evk/m53evk.c create mode 100644 board/freescale/mx6slevk/Makefile create mode 100644 board/freescale/mx6slevk/imximage.cfg create mode 100644 board/freescale/mx6slevk/mx6slevk.c create mode 100644 board/freescale/titanium/Makefile create mode 100644 board/freescale/titanium/imximage.cfg create mode 100644 board/freescale/titanium/titanium.c create mode 100644 common/cmd_fuse.c create mode 100644 doc/README.fsl_iim create mode 100644 doc/README.fuse create mode 100644 doc/README.imx25 create mode 100644 doc/README.imx27 create mode 100644 doc/README.imx6 create mode 100644 doc/README.mxc_ocotp create mode 100644 drivers/misc/fsl_iim.c create mode 100644 drivers/misc/mxc_ocotp.c create mode 100644 drivers/video/mxsfb.c create mode 100644 include/configs/m53evk.h create mode 100644 include/configs/mx6slevk.h create mode 100644 include/configs/titanium.h rename arch/arm/include/asm/arch-mx25/sys_proto.h => include/fuse.h (55%)
Best regards, Stefano
Hi Stefano,
On Tue, 07 May 2013 09:55:08 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master (with two trivial merge resolutions), thanks!
Amicalement,
On Sat, 11 May 2013 09:30:57 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Stefano,
Hi Albert,
Seems like the trivial merge resolution was less trivial than I thought it was -- I accidentally removed from drivers/mtd/nand/mxc_nand_spl.c the definitions for nand_init() and nand_deselect(). For some reason I missed it in the MAKEALL -a arm I did. Rolling back and fixing this.
Amicalement,
On 11/05/2013 11:15, Albert ARIBAUD wrote:
Hi Albert,
Please make modifications on top of your current tree - after your first e-mail, I have already pulled from u-boot-arm and pushed to the server. If you go back, I had to rebase my tree.
Hi Stefano,
Hi Albert,
Argh! I had already had rolled back and have just finished testing.
I can roll forward again if you confirm that the u-boot-arm/master branch you have is commit ec7023d.
Otherwise, please push the u-boot-arm/master your are based on onto the u-boot-imx repo under a new branch name, e.g.
git push ssh://gu-imx@git.denx.de/u-boot-imx u-boot-arm/master:master-aa
Amicalement,
On 11/05/2013 11:47, Albert ARIBAUD wrote:
Hi Stefano,
Hi Albert,
It is !
commit ec7023db8dc95966919589541f1ca09355a3f7a5 Merge: e825b10 d782c1f Author: Albert ARIBAUD albert.u.boot@aribaud.net Date: Sat May 11 09:25:36 2013 +0200
Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'
Hi Stefano,
Hi Albert,
It is !
I have also pushed u-boot-arm as you suggest with the name uboot_arm on u-boot-imx.
Hi Stefano,
Hi Stefano,
Hi Albert,
It is !
Er... Seems like arm_master is exactly the same as u-boot-imx/master. I thought your master was rebased upon my master?
Amicalement,
On 11/05/2013 13:07, Albert ARIBAUD wrote:
Hi Stefano,
Hi Albert,
I haved pulled your master this morning, and there are not new iMX patches.
Hi Stefano,
Hi Stefano,
Hi Albert,
It is !
Ok, but just a sec. If I put a commit above this, you'll *also* have to rebase, won't you?
(BTW, I thought rebasing was frowned upon and we should merge instead.)
Amicalement,
On 11/05/2013 13:01, Albert ARIBAUD wrote:
It is !
Well, I have not yet published any iMX patches after merging u-boot-arm this morning. At this point, u-boot-imx is equal to u-boot-arm at commit commit ec7023, after you pulled u-boot-imx. There is no iMX patches after that, and that is the reason why it should work.
See u-boot-imx, master: last commit is ec7023.
If you put a commit above, I should merge again your u-boot-arm/master (and this should go flawless) and only after that I can apply iMX patches, that I have not yet published.
Of course ! We should only merge
Hi Stefano,
It is !
Ok, so I prefer getting things right before I proceed: after I merged your PR, you did not rebase your master, you (fast-forward) merged my master to it. What you have rebased is your next branch, right?
Amicalement,
Right ! Never !
Correct !
Right !
Hi Stefano,
On Sat, 11 May 2013 13:36:45 +0200, Stefano Babic sbabic@denx.de wrote:
Correct !
Ok - ARM repo rolled forward to ec7023db and patch sent to the list. Ack it and I'll apply it onto ARM repo.
Amicalement,
Hi Albert,
On Sat, 11 May 2013 16:32:18 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Stefano,
Correct !
Patch applied, ARM repo back to 100% build-clean.
Amicalement,
Hi Stefano,
Hi Albert,
Amicalement,
Albert ARIBAUD
Stefano Babic
