[PATCH v2 00/24] Drop DT upstream compatible dt-binding headers
Many of the dt-binding headers in U-Boot are based on the upstream ones from Linux, occasionally with minor changes. Although some have additional things defined or are totally different.
This series attempts to drop as many of these headers as is easily possible. Those with differing APIs were left as-is.
Most of this work was done with a script, with some manual fixing at the end.
All-in, we're dropping 393 of the 489 headers from include/dt-bindings.
Due to how the include paths are configured, U-Boot headers override upstream ones by the same name, resulting in some upstream DTBs failing to compile (e.g. those that use newer linux-event-codes.h). Swapping the include order would conversely break a bunch of U-Boot DTS files and drivers.
Hopefully this makes a good dent, and future efforts to align more architectures with upstream DT will help drop the remaining headers.
In addition, the final patch in this series adds support for compiling all upstream DTS files for a given vendor. This is useful in cases where a single U-Boot binary can support many boards, and maintaining a list of supported DTB files would quickly become arduous (as is the case with Qualcomm).
--- Changes in v2: - Adjust OF_UPSTREAM_VENDOR defaults for marvell - Drop renesas patches for now, Marek will pick them up - Add back some headers which are actually still needed - Fix some additional compilation issues (rk3368-sheep, microchip mpfs, brcm6318) - Adjust rockchip/pinctrl-rk3568.c to just use literals instead of U-Boot specific aliases (RK_GPIO1 -> 1, RK_FUNC_1 -> 1). - Link to v1: https://lore.kernel.org/r/20240304-b4-upstream-dt-headers-v1-0-b7ff41925f92@...
--- Caleb Connolly (24): qcom: drop clock dt-binding headers qcom: drop remaining dt-binding headers sunxi: drop clock dt-binding headers sunxi: drop remaining dt-binding headers imx: drop clock dt-binding headers imx: drop dt-binding headers amlogic: drop dt-binding headers stm: drop dt-binding headers rockchip: drop clock dt-binding headers rockchip: drop remaining dt-binding headers exynos: drop dt-binding headers bcm: drop dt-binding headers ti: drop dt-binding headers tegra: drop clock dt-binding headers tegra: drop dt-binding headers xlnx: drop dt-binding headers mtk: drop dt-binding headers microchip: drop dt-binding headers hisi: drop dt-binding headers sifive: drop clock headers dt-bindings: drop clock headers dt-bindings: drop remaining device headers dt-bindings: drop generic headers dts: support building all dtb files for a specific vendor
arch/arm/dts/exynos7420.dtsi | 2 +- arch/arm/dts/rk3368-sheep.dts | 8 +- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/dts/tegra186.dtsi | 2 +- arch/mips/dts/brcm,bcm6318.dtsi | 2 +- arch/riscv/dts/fu540-c000-u-boot.dtsi | 26 +- arch/riscv/dts/mpfs.dtsi | 2 +- drivers/clk/exynos/clk-exynos7420.c | 2 +- drivers/clk/microchip/mpfs_clk.c | 2 +- drivers/clk/microchip/mpfs_clk_cfg.c | 2 +- drivers/clk/microchip/mpfs_clk_msspll.c | 2 +- drivers/clk/microchip/mpfs_clk_periph.c | 2 +- drivers/clk/rockchip/clk_rk3399.c | 2 +- drivers/clk/sifive/fu540-prci.c | 8 +- drivers/mailbox/tegra-hsp.c | 2 +- drivers/net/phy/dp83869.c | 2 + drivers/pinctrl/rockchip/pinctrl-rk3568.c | 186 ++-- dts/Kconfig | 24 + include/dt-bindings/arm/coresight-cti-dt.h | 37 - include/dt-bindings/arm/ux500_pm_domains.h | 15 - include/dt-bindings/ata/ahci.h | 20 - include/dt-bindings/bus/moxtet.h | 16 - include/dt-bindings/bus/ti-sysc.h | 28 - include/dt-bindings/clk/ti-dra7-atl.h | 40 - include/dt-bindings/clock/actions,s700-cmu.h | 118 --- include/dt-bindings/clock/actions,s900-cmu.h | 129 --- include/dt-bindings/clock/agilex-clock.h | 71 -- include/dt-bindings/clock/am3.h | 227 ----- .../clock/amlogic,a1-peripherals-clkc.h | 168 ---- include/dt-bindings/clock/amlogic,a1-pll-clkc.h | 25 - include/dt-bindings/clock/at91.h | 23 - include/dt-bindings/clock/axg-aoclkc.h | 31 - include/dt-bindings/clock/axg-audio-clkc.h | 94 --- include/dt-bindings/clock/axg-clkc.h | 100 --- include/dt-bindings/clock/bcm-nsp.h | 51 -- include/dt-bindings/clock/bcm2835-aux.h | 9 - include/dt-bindings/clock/bcm2835.h | 62 -- include/dt-bindings/clock/bcm6318-clock.h | 47 -- include/dt-bindings/clock/bcm63268-clock.h | 51 -- include/dt-bindings/clock/bcm6328-clock.h | 24 - include/dt-bindings/clock/bcm6358-clock.h | 23 - include/dt-bindings/clock/bcm6362-clock.h | 32 - include/dt-bindings/clock/bcm6368-clock.h | 30 - include/dt-bindings/clock/boston-clock.h | 12 - include/dt-bindings/clock/exynos7420-clk.h | 207 ----- include/dt-bindings/clock/exynos850.h | 337 -------- include/dt-bindings/clock/fsl,qoriq-clockgen.h | 15 - include/dt-bindings/clock/g12a-aoclkc.h | 36 - include/dt-bindings/clock/g12a-clkc.h | 153 ---- include/dt-bindings/clock/gxbb-aoclkc.h | 74 -- include/dt-bindings/clock/gxbb-clkc.h | 151 ---- include/dt-bindings/clock/hi3660-clock.h | 214 ----- include/dt-bindings/clock/hi6220-clock.h | 173 ---- include/dt-bindings/clock/imx5-clock.h | 219 ----- include/dt-bindings/clock/imx6qdl-clock.h | 278 ------ include/dt-bindings/clock/imx6sl-clock.h | 178 ---- include/dt-bindings/clock/imx6sll-clock.h | 210 ----- include/dt-bindings/clock/imx6sx-clock.h | 281 ------ include/dt-bindings/clock/imx6ul-clock.h | 262 ------ include/dt-bindings/clock/imx7d-clock.h | 456 ---------- include/dt-bindings/clock/imx7ulp-clock.h | 119 --- include/dt-bindings/clock/imx8mm-clock.h | 286 ------- include/dt-bindings/clock/imx8mn-clock.h | 262 ------ include/dt-bindings/clock/imx8mp-clock.h | 401 --------- include/dt-bindings/clock/imx8mq-clock.h | 431 ---------- include/dt-bindings/clock/imx8ulp-clock.h | 258 ------ include/dt-bindings/clock/imx93-clock.h | 208 ----- include/dt-bindings/clock/imxrt1050-clock.h | 72 -- include/dt-bindings/clock/lpc32xx-clock.h | 58 -- include/dt-bindings/clock/maxim,max77802.h | 22 - include/dt-bindings/clock/microchip-mpfs-clock.h | 71 -- include/dt-bindings/clock/mt7622-clk.h | 270 ------ include/dt-bindings/clock/mt7629-clk.h | 206 ----- include/dt-bindings/clock/mt8183-clk.h | 329 -------- include/dt-bindings/clock/nuvoton,npcm7xx-clock.h | 46 - include/dt-bindings/clock/omap4.h | 149 ---- include/dt-bindings/clock/omap5.h | 129 --- include/dt-bindings/clock/px30-cru.h | 389 --------- include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 --- include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 -- include/dt-bindings/clock/qcom,gcc-ipq4019.h | 169 ---- include/dt-bindings/clock/qcom,gcc-msm8916.h | 179 ---- include/dt-bindings/clock/qcom,gcc-msm8996.h | 362 -------- include/dt-bindings/clock/qcom,gcc-qcs404.h | 180 ---- include/dt-bindings/clock/qcom,gcc-sdm845.h | 246 ------ include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 - include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 - include/dt-bindings/clock/qcom,mmcc-msm8996.h | 295 ------- include/dt-bindings/clock/qcom,rpmcc.h | 174 ---- include/dt-bindings/clock/qcom,rpmh.h | 37 - include/dt-bindings/clock/qcom,turingcc-qcs404.h | 15 - include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 - include/dt-bindings/clock/rk3036-cru.h | 185 ---- include/dt-bindings/clock/rk3066a-cru.h | 31 - include/dt-bindings/clock/rk3128-cru.h | 273 ------ include/dt-bindings/clock/rk3188-cru-common.h | 261 ------ include/dt-bindings/clock/rk3188-cru.h | 47 -- include/dt-bindings/clock/rk3228-cru.h | 287 ------- include/dt-bindings/clock/rk3288-cru.h | 381 --------- include/dt-bindings/clock/rk3308-cru.h | 387 --------- include/dt-bindings/clock/rk3328-cru.h | 393 --------- include/dt-bindings/clock/rk3368-cru.h | 381 --------- include/dt-bindings/clock/rk3399-cru.h | 749 ---------------- include/dt-bindings/clock/rk3568-cru.h | 926 -------------------- include/dt-bindings/clock/rockchip,rk3588-cru.h | 766 ----------------- include/dt-bindings/clock/rockchip,rk808.h | 11 - include/dt-bindings/clock/rockchip,rv1126-cru.h | 632 -------------- include/dt-bindings/clock/rv1108-cru.h | 356 -------- include/dt-bindings/clock/sifive-fu540-prci.h | 18 - include/dt-bindings/clock/sifive-fu740-prci.h | 24 - include/dt-bindings/clock/ste-ab8500.h | 12 - include/dt-bindings/clock/stih407-clks.h | 90 -- include/dt-bindings/clock/stih410-clks.h | 25 - include/dt-bindings/clock/stm32fx-clock.h | 63 -- include/dt-bindings/clock/stm32h7-clks.h | 167 ---- include/dt-bindings/clock/stm32mp1-clks.h | 274 ------ include/dt-bindings/clock/stm32mp13-clks.h | 229 ----- include/dt-bindings/clock/sun20i-d1-ccu.h | 158 ---- include/dt-bindings/clock/sun20i-d1-r-ccu.h | 19 - include/dt-bindings/clock/sun4i-a10-ccu.h | 202 ----- include/dt-bindings/clock/sun4i-a10-pll2.h | 53 -- include/dt-bindings/clock/sun50i-a64-ccu.h | 138 --- include/dt-bindings/clock/sun50i-h6-ccu.h | 125 --- include/dt-bindings/clock/sun50i-h6-r-ccu.h | 27 - include/dt-bindings/clock/sun50i-h616-ccu.h | 116 --- include/dt-bindings/clock/sun5i-ccu.h | 97 --- include/dt-bindings/clock/sun6i-a31-ccu.h | 193 ----- include/dt-bindings/clock/sun6i-rtc.h | 10 - include/dt-bindings/clock/sun7i-a20-ccu.h | 53 -- include/dt-bindings/clock/sun8i-a23-a33-ccu.h | 129 --- include/dt-bindings/clock/sun8i-a83t-ccu.h | 140 --- include/dt-bindings/clock/sun8i-de2.h | 21 - include/dt-bindings/clock/sun8i-h3-ccu.h | 152 ---- include/dt-bindings/clock/sun8i-r-ccu.h | 59 -- include/dt-bindings/clock/sun8i-r40-ccu.h | 191 ----- include/dt-bindings/clock/sun8i-tcon-top.h | 11 - include/dt-bindings/clock/sun8i-v3s-ccu.h | 111 --- include/dt-bindings/clock/sun9i-a80-ccu.h | 162 ---- include/dt-bindings/clock/sun9i-a80-de.h | 80 -- include/dt-bindings/clock/sun9i-a80-usb.h | 59 -- include/dt-bindings/clock/suniv-ccu-f1c100s.h | 72 -- include/dt-bindings/clock/tegra114-car.h | 343 -------- include/dt-bindings/clock/tegra124-car-common.h | 345 -------- include/dt-bindings/clock/tegra124-car.h | 19 - include/dt-bindings/clock/tegra186-clock.h | 940 --------------------- include/dt-bindings/clock/tegra20-car.h | 158 ---- include/dt-bindings/clock/tegra210-car.h | 401 --------- include/dt-bindings/clock/tegra30-car.h | 273 ------ include/dt-bindings/clock/versaclock.h | 13 - include/dt-bindings/clock/vf610-clock.h | 202 ----- include/dt-bindings/clock/xlnx-versal-clk.h | 123 --- include/dt-bindings/clock/xlnx-zynqmp-clk.h | 126 --- include/dt-bindings/display/tda998x.h | 8 - include/dt-bindings/dma/at91.h | 52 -- include/dt-bindings/dma/qcom-gpi.h | 11 - include/dt-bindings/dma/sun4i-a10.h | 56 -- include/dt-bindings/dma/xlnx-zynqmp-dpdma.h | 16 - include/dt-bindings/firmware/qcom,scm.h | 39 - include/dt-bindings/gpio/aspeed-gpio.h | 51 -- include/dt-bindings/gpio/gpio.h | 42 - include/dt-bindings/gpio/meson-a1-gpio.h | 73 -- include/dt-bindings/gpio/meson-axg-gpio.h | 116 --- include/dt-bindings/gpio/meson-g12a-gpio.h | 114 --- include/dt-bindings/gpio/meson-gxbb-gpio.h | 148 ---- include/dt-bindings/gpio/meson-gxl-gpio.h | 125 --- include/dt-bindings/gpio/tegra-gpio.h | 51 -- include/dt-bindings/gpio/uniphier-gpio.h | 18 - include/dt-bindings/iio/qcom,spmi-vadc.h | 300 ------- include/dt-bindings/input/gpio-keys.h | 13 - include/dt-bindings/input/input.h | 17 - include/dt-bindings/input/linux-event-codes.h | 806 ------------------ include/dt-bindings/interconnect/fsl,imx8mp.h | 59 -- include/dt-bindings/interconnect/imx8mm.h | 50 -- include/dt-bindings/interconnect/imx8mn.h | 41 - include/dt-bindings/interconnect/imx8mq.h | 48 -- include/dt-bindings/interconnect/qcom,msm8916.h | 100 --- .../dt-bindings/interconnect/qcom,msm8996-cbf.h | 12 - include/dt-bindings/interconnect/qcom,msm8996.h | 163 ---- include/dt-bindings/interconnect/qcom,osm-l3.h | 15 - include/dt-bindings/interconnect/qcom,sdm845.h | 150 ---- .../dt-bindings/interrupt-controller/apple-aic.h | 15 - include/dt-bindings/interrupt-controller/arm-gic.h | 23 - include/dt-bindings/interrupt-controller/irq-st.h | 30 - include/dt-bindings/interrupt-controller/irq.h | 19 - .../dt-bindings/interrupt-controller/irqc-rzg2l.h | 25 - .../dt-bindings/interrupt-controller/mips-gic.h | 9 - include/dt-bindings/leds/common.h | 106 --- include/dt-bindings/leds/leds-netxbig.h | 18 - include/dt-bindings/leds/leds-ns2.h | 9 - include/dt-bindings/leds/leds-pca9532.h | 18 - include/dt-bindings/mailbox/tegra186-hsp.h | 19 - include/dt-bindings/media/omap3-isp.h | 22 - include/dt-bindings/media/tda1997x.h | 74 -- include/dt-bindings/media/video-interfaces.h | 16 - include/dt-bindings/memory/tegra114-mc.h | 25 - include/dt-bindings/memory/tegra124-mc.h | 31 - include/dt-bindings/memory/tegra210-mc.h | 36 - include/dt-bindings/memory/tegra30-mc.h | 24 - include/dt-bindings/mfd/at91-usart.h | 17 - include/dt-bindings/mfd/atmel-flexcom.h | 15 - include/dt-bindings/mfd/dbx500-prcmu.h | 84 -- include/dt-bindings/mfd/st,stpmic1.h | 50 -- include/dt-bindings/mfd/st-lpc.h | 16 - include/dt-bindings/mfd/stm32f4-rcc.h | 108 --- include/dt-bindings/mfd/stm32f7-rcc.h | 116 --- include/dt-bindings/mfd/stm32h7-rcc.h | 138 --- include/dt-bindings/mux/mux.h | 17 - include/dt-bindings/mux/ti-serdes.h | 190 ----- include/dt-bindings/net/microchip-lan78xx.h | 21 - include/dt-bindings/net/mscc-phy-vsc8531.h | 31 - include/dt-bindings/net/qca-ar803x.h | 13 - include/dt-bindings/net/ti-dp83867.h | 53 -- include/dt-bindings/net/ti-dp83869.h | 60 -- include/dt-bindings/phy/phy-am654-serdes.h | 13 - include/dt-bindings/phy/phy-cadence.h | 24 - include/dt-bindings/phy/phy-imx8-pcie.h | 14 - include/dt-bindings/phy/phy-qcom-qmp.h | 20 - include/dt-bindings/phy/phy-qcom-qusb2.h | 37 - include/dt-bindings/phy/phy-ti.h | 21 - include/dt-bindings/phy/phy.h | 26 - include/dt-bindings/pinctrl/am33xx.h | 172 ---- include/dt-bindings/pinctrl/am43xx.h | 39 - include/dt-bindings/pinctrl/apple.h | 13 - include/dt-bindings/pinctrl/at91.h | 49 -- include/dt-bindings/pinctrl/bcm2835.h | 26 - include/dt-bindings/pinctrl/dra.h | 79 -- include/dt-bindings/pinctrl/hisi.h | 74 -- include/dt-bindings/pinctrl/mt65xx.h | 41 - include/dt-bindings/pinctrl/mt8365-pinfunc.h | 858 ------------------- include/dt-bindings/pinctrl/omap.h | 91 -- include/dt-bindings/pinctrl/pinctrl-tegra-xusb.h | 7 - include/dt-bindings/pinctrl/pinctrl-tegra.h | 37 - include/dt-bindings/pinctrl/pinctrl-zynqmp.h | 19 - include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 ---- include/dt-bindings/pinctrl/qcom,pmic-mpp.h | 106 --- include/dt-bindings/pinctrl/rockchip.h | 60 -- include/dt-bindings/pinctrl/stm32-pinfunc.h | 45 - include/dt-bindings/pinctrl/sun4i-a10.h | 62 -- include/dt-bindings/power/fsl,imx93-power.h | 15 - include/dt-bindings/power/imx7-power.h | 13 - include/dt-bindings/power/imx8mm-power.h | 31 - include/dt-bindings/power/imx8mn-power.h | 20 - include/dt-bindings/power/imx8mp-power.h | 59 -- include/dt-bindings/power/imx8mq-power.h | 24 - include/dt-bindings/power/imx8ulp-power.h | 26 - include/dt-bindings/power/mediatek,mt8365-power.h | 19 - include/dt-bindings/power/meson-a1-power.h | 32 - include/dt-bindings/power/meson-axg-power.h | 14 - include/dt-bindings/power/meson-g12a-power.h | 13 - include/dt-bindings/power/meson-gxbb-power.h | 13 - include/dt-bindings/power/meson-sm1-power.h | 18 - include/dt-bindings/power/owl-s700-powergate.h | 19 - include/dt-bindings/power/px30-power.h | 27 - include/dt-bindings/power/qcom-rpmpd.h | 412 --------- include/dt-bindings/power/raspberrypi-power.h | 41 - include/dt-bindings/power/rk3066-power.h | 22 - include/dt-bindings/power/rk3188-power.h | 24 - include/dt-bindings/power/rk3228-power.h | 21 - include/dt-bindings/power/rk3288-power.h | 32 - include/dt-bindings/power/rk3328-power.h | 19 - include/dt-bindings/power/rk3399-power.h | 53 -- include/dt-bindings/power/rk3568-power.h | 32 - include/dt-bindings/power/rk3588-power.h | 69 -- include/dt-bindings/power/rockchip,rv1126-power.h | 35 - include/dt-bindings/power/tegra186-powergate.h | 28 - include/dt-bindings/power/xlnx-zynqmp-power.h | 50 -- include/dt-bindings/pwm/pwm.h | 14 - .../dt-bindings/regulator/dlg,da9063-regulator.h | 16 - include/dt-bindings/regulator/maxim,max77802.h | 18 - .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 - .../dt-bindings/regulator/st,stm32mp13-regulator.h | 42 - include/dt-bindings/reset/actions,s700-reset.h | 34 - include/dt-bindings/reset/actions,s900-reset.h | 65 -- include/dt-bindings/reset/altr,rst-mgr-a10.h | 110 --- include/dt-bindings/reset/altr,rst-mgr-s10.h | 96 --- include/dt-bindings/reset/altr,rst-mgr.h | 82 -- include/dt-bindings/reset/amlogic,meson-a1-reset.h | 76 -- .../reset/amlogic,meson-axg-audio-arb.h | 19 - .../dt-bindings/reset/amlogic,meson-axg-reset.h | 123 --- .../reset/amlogic,meson-g12a-audio-reset.h | 53 -- .../dt-bindings/reset/amlogic,meson-g12a-reset.h | 137 --- .../dt-bindings/reset/amlogic,meson-gxbb-reset.h | 161 ---- include/dt-bindings/reset/axg-aoclkc.h | 20 - include/dt-bindings/reset/bcm6318-reset.h | 25 - include/dt-bindings/reset/bcm63268-reset.h | 31 - include/dt-bindings/reset/bcm6328-reset.h | 23 - include/dt-bindings/reset/bcm6358-reset.h | 20 - include/dt-bindings/reset/bcm6362-reset.h | 27 - include/dt-bindings/reset/bcm6368-reset.h | 21 - include/dt-bindings/reset/g12a-aoclkc.h | 18 - include/dt-bindings/reset/gxbb-aoclkc.h | 66 -- include/dt-bindings/reset/imx7-reset.h | 52 -- include/dt-bindings/reset/imx8mp-reset.h | 50 -- include/dt-bindings/reset/imx8mq-reset.h | 67 -- include/dt-bindings/reset/imx8ulp-pcc-reset.h | 59 -- include/dt-bindings/reset/mt7621-reset.h | 38 - include/dt-bindings/reset/nuvoton,npcm7xx-reset.h | 91 -- include/dt-bindings/reset/qcom,gcc-msm8916.h | 100 --- include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 - include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 - .../dt-bindings/reset/raspberrypi,firmware-reset.h | 13 - include/dt-bindings/reset/rockchip,rk3588-cru.h | 754 ----------------- include/dt-bindings/reset/sama7g5-reset.h | 10 - include/dt-bindings/reset/snps,hsdk-reset.h | 17 - include/dt-bindings/reset/starfive,jh7110-crg.h | 183 ---- include/dt-bindings/reset/stih407-resets.h | 65 -- include/dt-bindings/reset/stm32mp1-resets.h | 123 --- include/dt-bindings/reset/stm32mp13-resets.h | 100 --- include/dt-bindings/reset/sun20i-d1-ccu.h | 79 -- include/dt-bindings/reset/sun20i-d1-r-ccu.h | 16 - include/dt-bindings/reset/sun4i-a10-ccu.h | 69 -- include/dt-bindings/reset/sun50i-a64-ccu.h | 98 --- include/dt-bindings/reset/sun50i-h6-ccu.h | 73 -- include/dt-bindings/reset/sun50i-h6-r-ccu.h | 18 - include/dt-bindings/reset/sun50i-h616-ccu.h | 70 -- include/dt-bindings/reset/sun5i-ccu.h | 23 - include/dt-bindings/reset/sun6i-a31-ccu.h | 106 --- include/dt-bindings/reset/sun8i-a23-a33-ccu.h | 87 -- include/dt-bindings/reset/sun8i-a83t-ccu.h | 98 --- include/dt-bindings/reset/sun8i-de2.h | 15 - include/dt-bindings/reset/sun8i-h3-ccu.h | 106 --- include/dt-bindings/reset/sun8i-r-ccu.h | 53 -- include/dt-bindings/reset/sun8i-r40-ccu.h | 130 --- include/dt-bindings/reset/sun8i-v3s-ccu.h | 81 -- include/dt-bindings/reset/sun9i-a80-ccu.h | 102 --- include/dt-bindings/reset/sun9i-a80-de.h | 58 -- include/dt-bindings/reset/sun9i-a80-usb.h | 56 -- include/dt-bindings/reset/suniv-ccu-f1c100s.h | 38 - include/dt-bindings/reset/tegra124-car.h | 12 - include/dt-bindings/reset/tegra186-reset.h | 205 ----- include/dt-bindings/reset/ti-syscon.h | 38 - include/dt-bindings/reset/xlnx-versal-resets.h | 105 --- include/dt-bindings/reset/xlnx-zynqmp-resets.h | 130 --- include/dt-bindings/soc/bcm2835-pm.h | 28 - include/dt-bindings/soc/qcom,apr.h | 28 - include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 - include/dt-bindings/soc/rockchip,boot-mode.h | 16 - include/dt-bindings/soc/rockchip,vop2.h | 18 - include/dt-bindings/soc/samsung,exynos-usi.h | 17 - include/dt-bindings/soc/ti,sci_pm_domain.h | 9 - include/dt-bindings/sound/apq8016-lpass.h | 9 - include/dt-bindings/sound/fsl-imx-audmux.h | 64 -- include/dt-bindings/sound/meson-aiu.h | 18 - include/dt-bindings/sound/meson-g12a-toacodec.h | 10 - include/dt-bindings/sound/meson-g12a-tohdmitx.h | 13 - include/dt-bindings/sound/microchip,pdmc.h | 13 - include/dt-bindings/sound/qcom,lpass.h | 46 - include/dt-bindings/sound/qcom,q6afe.h | 9 - include/dt-bindings/sound/qcom,q6asm.h | 26 - include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 ----- include/dt-bindings/sound/qcom,wcd9335.h | 15 - include/dt-bindings/sound/tlv320aic31xx.h | 14 - include/dt-bindings/spmi/spmi.h | 10 - include/dt-bindings/thermal/tegra124-soctherm.h | 14 - include/dt-bindings/thermal/thermal.h | 15 - include/dt-bindings/usb/pd.h | 88 -- scripts/Makefile.dts | 13 + 357 files changed, 165 insertions(+), 35859 deletions(-) --- base-commit: 2f387ba4580a2627836ec7054c8b4a64c9a98315
// Caleb (they/them)
Drop in favour of dts/upstream. This is just the clock headers.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 -------- include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 ---- include/dt-bindings/clock/qcom,gcc-ipq4019.h | 169 ----------- include/dt-bindings/clock/qcom,gcc-msm8916.h | 179 ----------- include/dt-bindings/clock/qcom,gcc-msm8996.h | 362 ----------------------- include/dt-bindings/clock/qcom,gcc-qcs404.h | 180 ----------- include/dt-bindings/clock/qcom,gcc-sdm845.h | 246 --------------- include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 -- include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 - include/dt-bindings/clock/qcom,mmcc-msm8996.h | 295 ------------------ include/dt-bindings/clock/qcom,rpmcc.h | 174 ----------- include/dt-bindings/clock/qcom,rpmh.h | 37 --- include/dt-bindings/clock/qcom,turingcc-qcs404.h | 15 - include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 --- 14 files changed, 1903 deletions(-)
diff --git a/include/dt-bindings/clock/qcom,camcc-sdm845.h b/include/dt-bindings/clock/qcom,camcc-sdm845.h deleted file mode 100644 index 4f7a2d2320bf..000000000000 --- a/include/dt-bindings/clock/qcom,camcc-sdm845.h +++ /dev/null @@ -1,116 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_CAM_CC_SDM845_H -#define _DT_BINDINGS_CLK_SDM_CAM_CC_SDM845_H - -/* CAM_CC clock registers */ -#define CAM_CC_BPS_AHB_CLK 0 -#define CAM_CC_BPS_AREG_CLK 1 -#define CAM_CC_BPS_AXI_CLK 2 -#define CAM_CC_BPS_CLK 3 -#define CAM_CC_BPS_CLK_SRC 4 -#define CAM_CC_CAMNOC_ATB_CLK 5 -#define CAM_CC_CAMNOC_AXI_CLK 6 -#define CAM_CC_CCI_CLK 7 -#define CAM_CC_CCI_CLK_SRC 8 -#define CAM_CC_CPAS_AHB_CLK 9 -#define CAM_CC_CPHY_RX_CLK_SRC 10 -#define CAM_CC_CSI0PHYTIMER_CLK 11 -#define CAM_CC_CSI0PHYTIMER_CLK_SRC 12 -#define CAM_CC_CSI1PHYTIMER_CLK 13 -#define CAM_CC_CSI1PHYTIMER_CLK_SRC 14 -#define CAM_CC_CSI2PHYTIMER_CLK 15 -#define CAM_CC_CSI2PHYTIMER_CLK_SRC 16 -#define CAM_CC_CSI3PHYTIMER_CLK 17 -#define CAM_CC_CSI3PHYTIMER_CLK_SRC 18 -#define CAM_CC_CSIPHY0_CLK 19 -#define CAM_CC_CSIPHY1_CLK 20 -#define CAM_CC_CSIPHY2_CLK 21 -#define CAM_CC_CSIPHY3_CLK 22 -#define CAM_CC_FAST_AHB_CLK_SRC 23 -#define CAM_CC_FD_CORE_CLK 24 -#define CAM_CC_FD_CORE_CLK_SRC 25 -#define CAM_CC_FD_CORE_UAR_CLK 26 -#define CAM_CC_ICP_APB_CLK 27 -#define CAM_CC_ICP_ATB_CLK 28 -#define CAM_CC_ICP_CLK 29 -#define CAM_CC_ICP_CLK_SRC 30 -#define CAM_CC_ICP_CTI_CLK 31 -#define CAM_CC_ICP_TS_CLK 32 -#define CAM_CC_IFE_0_AXI_CLK 33 -#define CAM_CC_IFE_0_CLK 34 -#define CAM_CC_IFE_0_CLK_SRC 35 -#define CAM_CC_IFE_0_CPHY_RX_CLK 36 -#define CAM_CC_IFE_0_CSID_CLK 37 -#define CAM_CC_IFE_0_CSID_CLK_SRC 38 -#define CAM_CC_IFE_0_DSP_CLK 39 -#define CAM_CC_IFE_1_AXI_CLK 40 -#define CAM_CC_IFE_1_CLK 41 -#define CAM_CC_IFE_1_CLK_SRC 42 -#define CAM_CC_IFE_1_CPHY_RX_CLK 43 -#define CAM_CC_IFE_1_CSID_CLK 44 -#define CAM_CC_IFE_1_CSID_CLK_SRC 45 -#define CAM_CC_IFE_1_DSP_CLK 46 -#define CAM_CC_IFE_LITE_CLK 47 -#define CAM_CC_IFE_LITE_CLK_SRC 48 -#define CAM_CC_IFE_LITE_CPHY_RX_CLK 49 -#define CAM_CC_IFE_LITE_CSID_CLK 50 -#define CAM_CC_IFE_LITE_CSID_CLK_SRC 51 -#define CAM_CC_IPE_0_AHB_CLK 52 -#define CAM_CC_IPE_0_AREG_CLK 53 -#define CAM_CC_IPE_0_AXI_CLK 54 -#define CAM_CC_IPE_0_CLK 55 -#define CAM_CC_IPE_0_CLK_SRC 56 -#define CAM_CC_IPE_1_AHB_CLK 57 -#define CAM_CC_IPE_1_AREG_CLK 58 -#define CAM_CC_IPE_1_AXI_CLK 59 -#define CAM_CC_IPE_1_CLK 60 -#define CAM_CC_IPE_1_CLK_SRC 61 -#define CAM_CC_JPEG_CLK 62 -#define CAM_CC_JPEG_CLK_SRC 63 -#define CAM_CC_LRME_CLK 64 -#define CAM_CC_LRME_CLK_SRC 65 -#define CAM_CC_MCLK0_CLK 66 -#define CAM_CC_MCLK0_CLK_SRC 67 -#define CAM_CC_MCLK1_CLK 68 -#define CAM_CC_MCLK1_CLK_SRC 69 -#define CAM_CC_MCLK2_CLK 70 -#define CAM_CC_MCLK2_CLK_SRC 71 -#define CAM_CC_MCLK3_CLK 72 -#define CAM_CC_MCLK3_CLK_SRC 73 -#define CAM_CC_PLL0 74 -#define CAM_CC_PLL0_OUT_EVEN 75 -#define CAM_CC_PLL1 76 -#define CAM_CC_PLL1_OUT_EVEN 77 -#define CAM_CC_PLL2 78 -#define CAM_CC_PLL2_OUT_EVEN 79 -#define CAM_CC_PLL3 80 -#define CAM_CC_PLL3_OUT_EVEN 81 -#define CAM_CC_SLOW_AHB_CLK_SRC 82 -#define CAM_CC_SOC_AHB_CLK 83 -#define CAM_CC_SYS_TMR_CLK 84 - -/* CAM_CC Resets */ -#define TITAN_CAM_CC_CCI_BCR 0 -#define TITAN_CAM_CC_CPAS_BCR 1 -#define TITAN_CAM_CC_CSI0PHY_BCR 2 -#define TITAN_CAM_CC_CSI1PHY_BCR 3 -#define TITAN_CAM_CC_CSI2PHY_BCR 4 -#define TITAN_CAM_CC_MCLK0_BCR 5 -#define TITAN_CAM_CC_MCLK1_BCR 6 -#define TITAN_CAM_CC_MCLK2_BCR 7 -#define TITAN_CAM_CC_MCLK3_BCR 8 -#define TITAN_CAM_CC_TITAN_TOP_BCR 9 - -/* CAM_CC GDSCRs */ -#define BPS_GDSC 0 -#define IPE_0_GDSC 1 -#define IPE_1_GDSC 2 -#define IFE_0_GDSC 3 -#define IFE_1_GDSC 4 -#define TITAN_TOP_GDSC 5 - -#endif diff --git a/include/dt-bindings/clock/qcom,dispcc-sdm845.h b/include/dt-bindings/clock/qcom,dispcc-sdm845.h deleted file mode 100644 index 4016fd1d5b46..000000000000 --- a/include/dt-bindings/clock/qcom,dispcc-sdm845.h +++ /dev/null @@ -1,56 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018-2019, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_DISP_CC_SDM845_H -#define _DT_BINDINGS_CLK_SDM_DISP_CC_SDM845_H - -/* DISP_CC clock registers */ -#define DISP_CC_MDSS_AHB_CLK 0 -#define DISP_CC_MDSS_AXI_CLK 1 -#define DISP_CC_MDSS_BYTE0_CLK 2 -#define DISP_CC_MDSS_BYTE0_CLK_SRC 3 -#define DISP_CC_MDSS_BYTE0_INTF_CLK 4 -#define DISP_CC_MDSS_BYTE1_CLK 5 -#define DISP_CC_MDSS_BYTE1_CLK_SRC 6 -#define DISP_CC_MDSS_BYTE1_INTF_CLK 7 -#define DISP_CC_MDSS_ESC0_CLK 8 -#define DISP_CC_MDSS_ESC0_CLK_SRC 9 -#define DISP_CC_MDSS_ESC1_CLK 10 -#define DISP_CC_MDSS_ESC1_CLK_SRC 11 -#define DISP_CC_MDSS_MDP_CLK 12 -#define DISP_CC_MDSS_MDP_CLK_SRC 13 -#define DISP_CC_MDSS_MDP_LUT_CLK 14 -#define DISP_CC_MDSS_PCLK0_CLK 15 -#define DISP_CC_MDSS_PCLK0_CLK_SRC 16 -#define DISP_CC_MDSS_PCLK1_CLK 17 -#define DISP_CC_MDSS_PCLK1_CLK_SRC 18 -#define DISP_CC_MDSS_ROT_CLK 19 -#define DISP_CC_MDSS_ROT_CLK_SRC 20 -#define DISP_CC_MDSS_RSCC_AHB_CLK 21 -#define DISP_CC_MDSS_RSCC_VSYNC_CLK 22 -#define DISP_CC_MDSS_VSYNC_CLK 23 -#define DISP_CC_MDSS_VSYNC_CLK_SRC 24 -#define DISP_CC_PLL0 25 -#define DISP_CC_MDSS_BYTE0_DIV_CLK_SRC 26 -#define DISP_CC_MDSS_BYTE1_DIV_CLK_SRC 27 -#define DISP_CC_MDSS_DP_AUX_CLK 28 -#define DISP_CC_MDSS_DP_AUX_CLK_SRC 29 -#define DISP_CC_MDSS_DP_CRYPTO_CLK 30 -#define DISP_CC_MDSS_DP_CRYPTO_CLK_SRC 31 -#define DISP_CC_MDSS_DP_LINK_CLK 32 -#define DISP_CC_MDSS_DP_LINK_CLK_SRC 33 -#define DISP_CC_MDSS_DP_LINK_INTF_CLK 34 -#define DISP_CC_MDSS_DP_PIXEL1_CLK 35 -#define DISP_CC_MDSS_DP_PIXEL1_CLK_SRC 36 -#define DISP_CC_MDSS_DP_PIXEL_CLK 37 -#define DISP_CC_MDSS_DP_PIXEL_CLK_SRC 38 - -/* DISP_CC Reset */ -#define DISP_CC_MDSS_RSCC_BCR 0 - -/* DISP_CC GDSCR */ -#define MDSS_GDSC 0 - -#endif diff --git a/include/dt-bindings/clock/qcom,gcc-ipq4019.h b/include/dt-bindings/clock/qcom,gcc-ipq4019.h deleted file mode 100644 index 7e8a7be6dcda..000000000000 --- a/include/dt-bindings/clock/qcom,gcc-ipq4019.h +++ /dev/null @@ -1,169 +0,0 @@ -/* Copyright (c) 2015 The Linux Foundation. All rights reserved. - * - * Permission to use, copy, modify, and/or distribute this software for any - * purpose with or without fee is hereby granted, provided that the above - * copyright notice and this permission notice appear in all copies. - * - * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES - * WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF - * MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR - * ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES - * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN - * ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF - * OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE. - * - */ -#ifndef __QCOM_CLK_IPQ4019_H__ -#define __QCOM_CLK_IPQ4019_H__ - -#define GCC_DUMMY_CLK 0 -#define AUDIO_CLK_SRC 1 -#define BLSP1_QUP1_I2C_APPS_CLK_SRC 2 -#define BLSP1_QUP1_SPI_APPS_CLK_SRC 3 -#define BLSP1_QUP2_I2C_APPS_CLK_SRC 4 -#define BLSP1_QUP2_SPI_APPS_CLK_SRC 5 -#define BLSP1_UART1_APPS_CLK_SRC 6 -#define BLSP1_UART2_APPS_CLK_SRC 7 -#define GCC_USB3_MOCK_UTMI_CLK_SRC 8 -#define GCC_APPS_CLK_SRC 9 -#define GCC_APPS_AHB_CLK_SRC 10 -#define GP1_CLK_SRC 11 -#define GP2_CLK_SRC 12 -#define GP3_CLK_SRC 13 -#define SDCC1_APPS_CLK_SRC 14 -#define FEPHY_125M_DLY_CLK_SRC 15 -#define WCSS2G_CLK_SRC 16 -#define WCSS5G_CLK_SRC 17 -#define GCC_APSS_AHB_CLK 18 -#define GCC_AUDIO_AHB_CLK 19 -#define GCC_AUDIO_PWM_CLK 20 -#define GCC_BLSP1_AHB_CLK 21 -#define GCC_BLSP1_QUP1_I2C_APPS_CLK 22 -#define GCC_BLSP1_QUP1_SPI_APPS_CLK 23 -#define GCC_BLSP1_QUP2_I2C_APPS_CLK 24 -#define GCC_BLSP1_QUP2_SPI_APPS_CLK 25 -#define GCC_BLSP1_UART1_APPS_CLK 26 -#define GCC_BLSP1_UART2_APPS_CLK 27 -#define GCC_DCD_XO_CLK 28 -#define GCC_GP1_CLK 29 -#define GCC_GP2_CLK 30 -#define GCC_GP3_CLK 31 -#define GCC_BOOT_ROM_AHB_CLK 32 -#define GCC_CRYPTO_AHB_CLK 33 -#define GCC_CRYPTO_AXI_CLK 34 -#define GCC_CRYPTO_CLK 35 -#define GCC_ESS_CLK 36 -#define GCC_IMEM_AXI_CLK 37 -#define GCC_IMEM_CFG_AHB_CLK 38 -#define GCC_PCIE_AHB_CLK 39 -#define GCC_PCIE_AXI_M_CLK 40 -#define GCC_PCIE_AXI_S_CLK 41 -#define GCC_PCNOC_AHB_CLK 42 -#define GCC_PRNG_AHB_CLK 43 -#define GCC_QPIC_AHB_CLK 44 -#define GCC_QPIC_CLK 45 -#define GCC_SDCC1_AHB_CLK 46 -#define GCC_SDCC1_APPS_CLK 47 -#define GCC_SNOC_PCNOC_AHB_CLK 48 -#define GCC_SYS_NOC_125M_CLK 49 -#define GCC_SYS_NOC_AXI_CLK 50 -#define GCC_TCSR_AHB_CLK 51 -#define GCC_TLMM_AHB_CLK 52 -#define GCC_USB2_MASTER_CLK 53 -#define GCC_USB2_SLEEP_CLK 54 -#define GCC_USB2_MOCK_UTMI_CLK 55 -#define GCC_USB3_MASTER_CLK 56 -#define GCC_USB3_SLEEP_CLK 57 -#define GCC_USB3_MOCK_UTMI_CLK 58 -#define GCC_WCSS2G_CLK 59 -#define GCC_WCSS2G_REF_CLK 60 -#define GCC_WCSS2G_RTC_CLK 61 -#define GCC_WCSS5G_CLK 62 -#define GCC_WCSS5G_REF_CLK 63 -#define GCC_WCSS5G_RTC_CLK 64 -#define GCC_APSS_DDRPLL_VCO 65 -#define GCC_SDCC_PLLDIV_CLK 66 -#define GCC_FEPLL_VCO 67 -#define GCC_FEPLL125_CLK 68 -#define GCC_FEPLL125DLY_CLK 69 -#define GCC_FEPLL200_CLK 70 -#define GCC_FEPLL500_CLK 71 -#define GCC_FEPLL_WCSS2G_CLK 72 -#define GCC_FEPLL_WCSS5G_CLK 73 -#define GCC_APSS_CPU_PLLDIV_CLK 74 -#define GCC_PCNOC_AHB_CLK_SRC 75 - -#define WIFI0_CPU_INIT_RESET 0 -#define WIFI0_RADIO_SRIF_RESET 1 -#define WIFI0_RADIO_WARM_RESET 2 -#define WIFI0_RADIO_COLD_RESET 3 -#define WIFI0_CORE_WARM_RESET 4 -#define WIFI0_CORE_COLD_RESET 5 -#define WIFI1_CPU_INIT_RESET 6 -#define WIFI1_RADIO_SRIF_RESET 7 -#define WIFI1_RADIO_WARM_RESET 8 -#define WIFI1_RADIO_COLD_RESET 9 -#define WIFI1_CORE_WARM_RESET 10 -#define WIFI1_CORE_COLD_RESET 11 -#define USB3_UNIPHY_PHY_ARES 12 -#define USB3_HSPHY_POR_ARES 13 -#define USB3_HSPHY_S_ARES 14 -#define USB2_HSPHY_POR_ARES 15 -#define USB2_HSPHY_S_ARES 16 -#define PCIE_PHY_AHB_ARES 17 -#define PCIE_AHB_ARES 18 -#define PCIE_PWR_ARES 19 -#define PCIE_PIPE_STICKY_ARES 20 -#define PCIE_AXI_M_STICKY_ARES 21 -#define PCIE_PHY_ARES 22 -#define PCIE_PARF_XPU_ARES 23 -#define PCIE_AXI_S_XPU_ARES 24 -#define PCIE_AXI_M_VMIDMT_ARES 25 -#define PCIE_PIPE_ARES 26 -#define PCIE_AXI_S_ARES 27 -#define PCIE_AXI_M_ARES 28 -#define ESS_RESET 29 -#define GCC_BLSP1_BCR 30 -#define GCC_BLSP1_QUP1_BCR 31 -#define GCC_BLSP1_UART1_BCR 32 -#define GCC_BLSP1_QUP2_BCR 33 -#define GCC_BLSP1_UART2_BCR 34 -#define GCC_BIMC_BCR 35 -#define GCC_TLMM_BCR 36 -#define GCC_IMEM_BCR 37 -#define GCC_ESS_BCR 38 -#define GCC_PRNG_BCR 39 -#define GCC_BOOT_ROM_BCR 40 -#define GCC_CRYPTO_BCR 41 -#define GCC_SDCC1_BCR 42 -#define GCC_SEC_CTRL_BCR 43 -#define GCC_AUDIO_BCR 44 -#define GCC_QPIC_BCR 45 -#define GCC_PCIE_BCR 46 -#define GCC_USB2_BCR 47 -#define GCC_USB2_PHY_BCR 48 -#define GCC_USB3_BCR 49 -#define GCC_USB3_PHY_BCR 50 -#define GCC_SYSTEM_NOC_BCR 51 -#define GCC_PCNOC_BCR 52 -#define GCC_DCD_BCR 53 -#define GCC_SNOC_BUS_TIMEOUT0_BCR 54 -#define GCC_SNOC_BUS_TIMEOUT1_BCR 55 -#define GCC_SNOC_BUS_TIMEOUT2_BCR 56 -#define GCC_SNOC_BUS_TIMEOUT3_BCR 57 -#define GCC_PCNOC_BUS_TIMEOUT0_BCR 58 -#define GCC_PCNOC_BUS_TIMEOUT1_BCR 59 -#define GCC_PCNOC_BUS_TIMEOUT2_BCR 60 -#define GCC_PCNOC_BUS_TIMEOUT3_BCR 61 -#define GCC_PCNOC_BUS_TIMEOUT4_BCR 62 -#define GCC_PCNOC_BUS_TIMEOUT5_BCR 63 -#define GCC_PCNOC_BUS_TIMEOUT6_BCR 64 -#define GCC_PCNOC_BUS_TIMEOUT7_BCR 65 -#define GCC_PCNOC_BUS_TIMEOUT8_BCR 66 -#define GCC_PCNOC_BUS_TIMEOUT9_BCR 67 -#define GCC_TCSR_BCR 68 -#define GCC_QDSS_BCR 69 -#define GCC_MPM_BCR 70 -#define GCC_SPDM_BCR 71 - -#endif diff --git a/include/dt-bindings/clock/qcom,gcc-msm8916.h b/include/dt-bindings/clock/qcom,gcc-msm8916.h deleted file mode 100644 index 563034406184..000000000000 --- a/include/dt-bindings/clock/qcom,gcc-msm8916.h +++ /dev/null @@ -1,179 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2015 Linaro Limited - */ - -#ifndef _DT_BINDINGS_CLK_MSM_GCC_8916_H -#define _DT_BINDINGS_CLK_MSM_GCC_8916_H - -#define GPLL0 0 -#define GPLL0_VOTE 1 -#define BIMC_PLL 2 -#define BIMC_PLL_VOTE 3 -#define GPLL1 4 -#define GPLL1_VOTE 5 -#define GPLL2 6 -#define GPLL2_VOTE 7 -#define PCNOC_BFDCD_CLK_SRC 8 -#define SYSTEM_NOC_BFDCD_CLK_SRC 9 -#define CAMSS_AHB_CLK_SRC 10 -#define APSS_AHB_CLK_SRC 11 -#define CSI0_CLK_SRC 12 -#define CSI1_CLK_SRC 13 -#define GFX3D_CLK_SRC 14 -#define VFE0_CLK_SRC 15 -#define BLSP1_QUP1_I2C_APPS_CLK_SRC 16 -#define BLSP1_QUP1_SPI_APPS_CLK_SRC 17 -#define BLSP1_QUP2_I2C_APPS_CLK_SRC 18 -#define BLSP1_QUP2_SPI_APPS_CLK_SRC 19 -#define BLSP1_QUP3_I2C_APPS_CLK_SRC 20 -#define BLSP1_QUP3_SPI_APPS_CLK_SRC 21 -#define BLSP1_QUP4_I2C_APPS_CLK_SRC 22 -#define BLSP1_QUP4_SPI_APPS_CLK_SRC 23 -#define BLSP1_QUP5_I2C_APPS_CLK_SRC 24 -#define BLSP1_QUP5_SPI_APPS_CLK_SRC 25 -#define BLSP1_QUP6_I2C_APPS_CLK_SRC 26 -#define BLSP1_QUP6_SPI_APPS_CLK_SRC 27 -#define BLSP1_UART1_APPS_CLK_SRC 28 -#define BLSP1_UART2_APPS_CLK_SRC 29 -#define CCI_CLK_SRC 30 -#define CAMSS_GP0_CLK_SRC 31 -#define CAMSS_GP1_CLK_SRC 32 -#define JPEG0_CLK_SRC 33 -#define MCLK0_CLK_SRC 34 -#define MCLK1_CLK_SRC 35 -#define CSI0PHYTIMER_CLK_SRC 36 -#define CSI1PHYTIMER_CLK_SRC 37 -#define CPP_CLK_SRC 38 -#define CRYPTO_CLK_SRC 39 -#define GP1_CLK_SRC 40 -#define GP2_CLK_SRC 41 -#define GP3_CLK_SRC 42 -#define BYTE0_CLK_SRC 43 -#define ESC0_CLK_SRC 44 -#define MDP_CLK_SRC 45 -#define PCLK0_CLK_SRC 46 -#define VSYNC_CLK_SRC 47 -#define PDM2_CLK_SRC 48 -#define SDCC1_APPS_CLK_SRC 49 -#define SDCC2_APPS_CLK_SRC 50 -#define APSS_TCU_CLK_SRC 51 -#define USB_HS_SYSTEM_CLK_SRC 52 -#define VCODEC0_CLK_SRC 53 -#define GCC_BLSP1_AHB_CLK 54 -#define GCC_BLSP1_SLEEP_CLK 55 -#define GCC_BLSP1_QUP1_I2C_APPS_CLK 56 -#define GCC_BLSP1_QUP1_SPI_APPS_CLK 57 -#define GCC_BLSP1_QUP2_I2C_APPS_CLK 58 -#define GCC_BLSP1_QUP2_SPI_APPS_CLK 59 -#define GCC_BLSP1_QUP3_I2C_APPS_CLK 60 -#define GCC_BLSP1_QUP3_SPI_APPS_CLK 61 -#define GCC_BLSP1_QUP4_I2C_APPS_CLK 62 -#define GCC_BLSP1_QUP4_SPI_APPS_CLK 63 -#define GCC_BLSP1_QUP5_I2C_APPS_CLK 64 -#define GCC_BLSP1_QUP5_SPI_APPS_CLK 65 -#define GCC_BLSP1_QUP6_I2C_APPS_CLK 66 -#define GCC_BLSP1_QUP6_SPI_APPS_CLK 67 -#define GCC_BLSP1_UART1_APPS_CLK 68 -#define GCC_BLSP1_UART2_APPS_CLK 69 -#define GCC_BOOT_ROM_AHB_CLK 70 -#define GCC_CAMSS_CCI_AHB_CLK 71 -#define GCC_CAMSS_CCI_CLK 72 -#define GCC_CAMSS_CSI0_AHB_CLK 73 -#define GCC_CAMSS_CSI0_CLK 74 -#define GCC_CAMSS_CSI0PHY_CLK 75 -#define GCC_CAMSS_CSI0PIX_CLK 76 -#define GCC_CAMSS_CSI0RDI_CLK 77 -#define GCC_CAMSS_CSI1_AHB_CLK 78 -#define GCC_CAMSS_CSI1_CLK 79 -#define GCC_CAMSS_CSI1PHY_CLK 80 -#define GCC_CAMSS_CSI1PIX_CLK 81 -#define GCC_CAMSS_CSI1RDI_CLK 82 -#define GCC_CAMSS_CSI_VFE0_CLK 83 -#define GCC_CAMSS_GP0_CLK 84 -#define GCC_CAMSS_GP1_CLK 85 -#define GCC_CAMSS_ISPIF_AHB_CLK 86 -#define GCC_CAMSS_JPEG0_CLK 87 -#define GCC_CAMSS_JPEG_AHB_CLK 88 -#define GCC_CAMSS_JPEG_AXI_CLK 89 -#define GCC_CAMSS_MCLK0_CLK 90 -#define GCC_CAMSS_MCLK1_CLK 91 -#define GCC_CAMSS_MICRO_AHB_CLK 92 -#define GCC_CAMSS_CSI0PHYTIMER_CLK 93 -#define GCC_CAMSS_CSI1PHYTIMER_CLK 94 -#define GCC_CAMSS_AHB_CLK 95 -#define GCC_CAMSS_TOP_AHB_CLK 96 -#define GCC_CAMSS_CPP_AHB_CLK 97 -#define GCC_CAMSS_CPP_CLK 98 -#define GCC_CAMSS_VFE0_CLK 99 -#define GCC_CAMSS_VFE_AHB_CLK 100 -#define GCC_CAMSS_VFE_AXI_CLK 101 -#define GCC_CRYPTO_AHB_CLK 102 -#define GCC_CRYPTO_AXI_CLK 103 -#define GCC_CRYPTO_CLK 104 -#define GCC_OXILI_GMEM_CLK 105 -#define GCC_GP1_CLK 106 -#define GCC_GP2_CLK 107 -#define GCC_GP3_CLK 108 -#define GCC_MDSS_AHB_CLK 109 -#define GCC_MDSS_AXI_CLK 110 -#define GCC_MDSS_BYTE0_CLK 111 -#define GCC_MDSS_ESC0_CLK 112 -#define GCC_MDSS_MDP_CLK 113 -#define GCC_MDSS_PCLK0_CLK 114 -#define GCC_MDSS_VSYNC_CLK 115 -#define GCC_MSS_CFG_AHB_CLK 116 -#define GCC_OXILI_AHB_CLK 117 -#define GCC_OXILI_GFX3D_CLK 118 -#define GCC_PDM2_CLK 119 -#define GCC_PDM_AHB_CLK 120 -#define GCC_PRNG_AHB_CLK 121 -#define GCC_SDCC1_AHB_CLK 122 -#define GCC_SDCC1_APPS_CLK 123 -#define GCC_SDCC2_AHB_CLK 124 -#define GCC_SDCC2_APPS_CLK 125 -#define GCC_GTCU_AHB_CLK 126 -#define GCC_JPEG_TBU_CLK 127 -#define GCC_MDP_TBU_CLK 128 -#define GCC_SMMU_CFG_CLK 129 -#define GCC_VENUS_TBU_CLK 130 -#define GCC_VFE_TBU_CLK 131 -#define GCC_USB2A_PHY_SLEEP_CLK 132 -#define GCC_USB_HS_AHB_CLK 133 -#define GCC_USB_HS_SYSTEM_CLK 134 -#define GCC_VENUS0_AHB_CLK 135 -#define GCC_VENUS0_AXI_CLK 136 -#define GCC_VENUS0_VCODEC0_CLK 137 -#define BIMC_DDR_CLK_SRC 138 -#define GCC_APSS_TCU_CLK 139 -#define GCC_GFX_TCU_CLK 140 -#define BIMC_GPU_CLK_SRC 141 -#define GCC_BIMC_GFX_CLK 142 -#define GCC_BIMC_GPU_CLK 143 -#define ULTAUDIO_LPAIF_PRI_I2S_CLK_SRC 144 -#define ULTAUDIO_LPAIF_SEC_I2S_CLK_SRC 145 -#define ULTAUDIO_LPAIF_AUX_I2S_CLK_SRC 146 -#define ULTAUDIO_XO_CLK_SRC 147 -#define ULTAUDIO_AHBFABRIC_CLK_SRC 148 -#define CODEC_DIGCODEC_CLK_SRC 149 -#define GCC_ULTAUDIO_PCNOC_MPORT_CLK 150 -#define GCC_ULTAUDIO_PCNOC_SWAY_CLK 151 -#define GCC_ULTAUDIO_AVSYNC_XO_CLK 152 -#define GCC_ULTAUDIO_STC_XO_CLK 153 -#define GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK 154 -#define GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_LPM_CLK 155 -#define GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK 156 -#define GCC_ULTAUDIO_LPAIF_SEC_I2S_CLK 157 -#define GCC_ULTAUDIO_LPAIF_AUX_I2S_CLK 158 -#define GCC_CODEC_DIGCODEC_CLK 159 -#define GCC_MSS_Q6_BIMC_AXI_CLK 160 - -/* Indexes for GDSCs */ -#define BIMC_GDSC 0 -#define VENUS_GDSC 1 -#define MDSS_GDSC 2 -#define JPEG_GDSC 3 -#define VFE_GDSC 4 -#define OXILI_GDSC 5 - -#endif diff --git a/include/dt-bindings/clock/qcom,gcc-msm8996.h b/include/dt-bindings/clock/qcom,gcc-msm8996.h deleted file mode 100644 index ddfd6fd73081..000000000000 --- a/include/dt-bindings/clock/qcom,gcc-msm8996.h +++ /dev/null @@ -1,362 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (c) 2015, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_MSM_GCC_8996_H -#define _DT_BINDINGS_CLK_MSM_GCC_8996_H - -#define GPLL0_EARLY 0 -#define GPLL0 1 -#define GPLL1_EARLY 2 -#define GPLL1 3 -#define GPLL2_EARLY 4 -#define GPLL2 5 -#define GPLL3_EARLY 6 -#define GPLL3 7 -#define GPLL4_EARLY 8 -#define GPLL4 9 -#define SYSTEM_NOC_CLK_SRC 10 -/* U-Boot: KConfig check in CI erroneously picks this up, it's unused - * anyway so comment it out for now - */ -//#define CONFIG _NOC_CLK_SRC 11 -#define PERIPH_NOC_CLK_SRC 12 -#define MMSS_BIMC_GFX_CLK_SRC 13 -#define USB30_MASTER_CLK_SRC 14 -#define USB30_MOCK_UTMI_CLK_SRC 15 -#define USB3_PHY_AUX_CLK_SRC 16 -#define USB20_MASTER_CLK_SRC 17 -#define USB20_MOCK_UTMI_CLK_SRC 18 -#define SDCC1_APPS_CLK_SRC 19 -#define SDCC1_ICE_CORE_CLK_SRC 20 -#define SDCC2_APPS_CLK_SRC 21 -#define SDCC3_APPS_CLK_SRC 22 -#define SDCC4_APPS_CLK_SRC 23 -#define BLSP1_QUP1_SPI_APPS_CLK_SRC 24 -#define BLSP1_QUP1_I2C_APPS_CLK_SRC 25 -#define BLSP1_UART1_APPS_CLK_SRC 26 -#define BLSP1_QUP2_SPI_APPS_CLK_SRC 27 -#define BLSP1_QUP2_I2C_APPS_CLK_SRC 28 -#define BLSP1_UART2_APPS_CLK_SRC 29 -#define BLSP1_QUP3_SPI_APPS_CLK_SRC 30 -#define BLSP1_QUP3_I2C_APPS_CLK_SRC 31 -#define BLSP1_UART3_APPS_CLK_SRC 32 -#define BLSP1_QUP4_SPI_APPS_CLK_SRC 33 -#define BLSP1_QUP4_I2C_APPS_CLK_SRC 34 -#define BLSP1_UART4_APPS_CLK_SRC 35 -#define BLSP1_QUP5_SPI_APPS_CLK_SRC 36 -#define BLSP1_QUP5_I2C_APPS_CLK_SRC 37 -#define BLSP1_UART5_APPS_CLK_SRC 38 -#define BLSP1_QUP6_SPI_APPS_CLK_SRC 39 -#define BLSP1_QUP6_I2C_APPS_CLK_SRC 40 -#define BLSP1_UART6_APPS_CLK_SRC 41 -#define BLSP2_QUP1_SPI_APPS_CLK_SRC 42 -#define BLSP2_QUP1_I2C_APPS_CLK_SRC 43 -#define BLSP2_UART1_APPS_CLK_SRC 44 -#define BLSP2_QUP2_SPI_APPS_CLK_SRC 45 -#define BLSP2_QUP2_I2C_APPS_CLK_SRC 46 -#define BLSP2_UART2_APPS_CLK_SRC 47 -#define BLSP2_QUP3_SPI_APPS_CLK_SRC 48 -#define BLSP2_QUP3_I2C_APPS_CLK_SRC 49 -#define BLSP2_UART3_APPS_CLK_SRC 50 -#define BLSP2_QUP4_SPI_APPS_CLK_SRC 51 -#define BLSP2_QUP4_I2C_APPS_CLK_SRC 52 -#define BLSP2_UART4_APPS_CLK_SRC 53 -#define BLSP2_QUP5_SPI_APPS_CLK_SRC 54 -#define BLSP2_QUP5_I2C_APPS_CLK_SRC 55 -#define BLSP2_UART5_APPS_CLK_SRC 56 -#define BLSP2_QUP6_SPI_APPS_CLK_SRC 57 -#define BLSP2_QUP6_I2C_APPS_CLK_SRC 58 -#define BLSP2_UART6_APPS_CLK_SRC 59 -#define PDM2_CLK_SRC 60 -#define TSIF_REF_CLK_SRC 61 -#define CE1_CLK_SRC 62 -#define GCC_SLEEP_CLK_SRC 63 -#define BIMC_CLK_SRC 64 -#define HMSS_AHB_CLK_SRC 65 -#define BIMC_HMSS_AXI_CLK_SRC 66 -#define HMSS_RBCPR_CLK_SRC 67 -#define HMSS_GPLL0_CLK_SRC 68 -#define GP1_CLK_SRC 69 -#define GP2_CLK_SRC 70 -#define GP3_CLK_SRC 71 -#define PCIE_AUX_CLK_SRC 72 -#define UFS_AXI_CLK_SRC 73 -#define UFS_ICE_CORE_CLK_SRC 74 -#define QSPI_SER_CLK_SRC 75 -#define GCC_SYS_NOC_AXI_CLK 76 -#define GCC_SYS_NOC_HMSS_AHB_CLK 77 -#define GCC_SNOC_CNOC_AHB_CLK 78 -#define GCC_SNOC_PNOC_AHB_CLK 79 -#define GCC_SYS_NOC_AT_CLK 80 -#define GCC_SYS_NOC_USB3_AXI_CLK 81 -#define GCC_SYS_NOC_UFS_AXI_CLK 82 -#define GCC_CFG_NOC_AHB_CLK 83 -#define GCC_PERIPH_NOC_AHB_CLK 84 -#define GCC_PERIPH_NOC_USB20_AHB_CLK 85 -#define GCC_TIC_CLK 86 -#define GCC_IMEM_AXI_CLK 87 -#define GCC_MMSS_SYS_NOC_AXI_CLK 88 -#define GCC_MMSS_NOC_CFG_AHB_CLK 89 -#define GCC_MMSS_BIMC_GFX_CLK 90 -#define GCC_USB30_MASTER_CLK 91 -#define GCC_USB30_SLEEP_CLK 92 -#define GCC_USB30_MOCK_UTMI_CLK 93 -#define GCC_USB3_PHY_AUX_CLK 94 -#define GCC_USB3_PHY_PIPE_CLK 95 -#define GCC_USB20_MASTER_CLK 96 -#define GCC_USB20_SLEEP_CLK 97 -#define GCC_USB20_MOCK_UTMI_CLK 98 -#define GCC_USB_PHY_CFG_AHB2PHY_CLK 99 -#define GCC_SDCC1_APPS_CLK 100 -#define GCC_SDCC1_AHB_CLK 101 -#define GCC_SDCC1_ICE_CORE_CLK 102 -#define GCC_SDCC2_APPS_CLK 103 -#define GCC_SDCC2_AHB_CLK 104 -#define GCC_SDCC3_APPS_CLK 105 -#define GCC_SDCC3_AHB_CLK 106 -#define GCC_SDCC4_APPS_CLK 107 -#define GCC_SDCC4_AHB_CLK 108 -#define GCC_BLSP1_AHB_CLK 109 -#define GCC_BLSP1_SLEEP_CLK 110 -#define GCC_BLSP1_QUP1_SPI_APPS_CLK 111 -#define GCC_BLSP1_QUP1_I2C_APPS_CLK 112 -#define GCC_BLSP1_UART1_APPS_CLK 113 -#define GCC_BLSP1_QUP2_SPI_APPS_CLK 114 -#define GCC_BLSP1_QUP2_I2C_APPS_CLK 115 -#define GCC_BLSP1_UART2_APPS_CLK 116 -#define GCC_BLSP1_QUP3_SPI_APPS_CLK 117 -#define GCC_BLSP1_QUP3_I2C_APPS_CLK 118 -#define GCC_BLSP1_UART3_APPS_CLK 119 -#define GCC_BLSP1_QUP4_SPI_APPS_CLK 120 -#define GCC_BLSP1_QUP4_I2C_APPS_CLK 121 -#define GCC_BLSP1_UART4_APPS_CLK 122 -#define GCC_BLSP1_QUP5_SPI_APPS_CLK 123 -#define GCC_BLSP1_QUP5_I2C_APPS_CLK 124 -#define GCC_BLSP1_UART5_APPS_CLK 125 -#define GCC_BLSP1_QUP6_SPI_APPS_CLK 126 -#define GCC_BLSP1_QUP6_I2C_APPS_CLK 127 -#define GCC_BLSP1_UART6_APPS_CLK 128 -#define GCC_BLSP2_AHB_CLK 129 -#define GCC_BLSP2_SLEEP_CLK 130 -#define GCC_BLSP2_QUP1_SPI_APPS_CLK 131 -#define GCC_BLSP2_QUP1_I2C_APPS_CLK 132 -#define GCC_BLSP2_UART1_APPS_CLK 133 -#define GCC_BLSP2_QUP2_SPI_APPS_CLK 134 -#define GCC_BLSP2_QUP2_I2C_APPS_CLK 135 -#define GCC_BLSP2_UART2_APPS_CLK 136 -#define GCC_BLSP2_QUP3_SPI_APPS_CLK 137 -#define GCC_BLSP2_QUP3_I2C_APPS_CLK 138 -#define GCC_BLSP2_UART3_APPS_CLK 139 -#define GCC_BLSP2_QUP4_SPI_APPS_CLK 140 -#define GCC_BLSP2_QUP4_I2C_APPS_CLK 141 -#define GCC_BLSP2_UART4_APPS_CLK 142 -#define GCC_BLSP2_QUP5_SPI_APPS_CLK 143 -#define GCC_BLSP2_QUP5_I2C_APPS_CLK 144 -#define GCC_BLSP2_UART5_APPS_CLK 145 -#define GCC_BLSP2_QUP6_SPI_APPS_CLK 146 -#define GCC_BLSP2_QUP6_I2C_APPS_CLK 147 -#define GCC_BLSP2_UART6_APPS_CLK 148 -#define GCC_PDM_AHB_CLK 149 -#define GCC_PDM_XO4_CLK 150 -#define GCC_PDM2_CLK 151 -#define GCC_PRNG_AHB_CLK 152 -#define GCC_TSIF_AHB_CLK 153 -#define GCC_TSIF_REF_CLK 154 -#define GCC_TSIF_INACTIVITY_TIMERS_CLK 155 -#define GCC_TCSR_AHB_CLK 156 -#define GCC_BOOT_ROM_AHB_CLK 157 -#define GCC_MSG_RAM_AHB_CLK 158 -#define GCC_TLMM_AHB_CLK 159 -#define GCC_TLMM_CLK 160 -#define GCC_MPM_AHB_CLK 161 -#define GCC_SPMI_SER_CLK 162 -#define GCC_SPMI_CNOC_AHB_CLK 163 -#define GCC_CE1_CLK 164 -#define GCC_CE1_AXI_CLK 165 -#define GCC_CE1_AHB_CLK 166 -#define GCC_BIMC_HMSS_AXI_CLK 167 -#define GCC_BIMC_GFX_CLK 168 -#define GCC_HMSS_AHB_CLK 169 -#define GCC_HMSS_SLV_AXI_CLK 170 -#define GCC_HMSS_MSTR_AXI_CLK 171 -#define GCC_HMSS_RBCPR_CLK 172 -#define GCC_GP1_CLK 173 -#define GCC_GP2_CLK 174 -#define GCC_GP3_CLK 175 -#define GCC_PCIE_0_SLV_AXI_CLK 176 -#define GCC_PCIE_0_MSTR_AXI_CLK 177 -#define GCC_PCIE_0_CFG_AHB_CLK 178 -#define GCC_PCIE_0_AUX_CLK 179 -#define GCC_PCIE_0_PIPE_CLK 180 -#define GCC_PCIE_1_SLV_AXI_CLK 181 -#define GCC_PCIE_1_MSTR_AXI_CLK 182 -#define GCC_PCIE_1_CFG_AHB_CLK 183 -#define GCC_PCIE_1_AUX_CLK 184 -#define GCC_PCIE_1_PIPE_CLK 185 -#define GCC_PCIE_2_SLV_AXI_CLK 186 -#define GCC_PCIE_2_MSTR_AXI_CLK 187 -#define GCC_PCIE_2_CFG_AHB_CLK 188 -#define GCC_PCIE_2_AUX_CLK 189 -#define GCC_PCIE_2_PIPE_CLK 190 -#define GCC_PCIE_PHY_CFG_AHB_CLK 191 -#define GCC_PCIE_PHY_AUX_CLK 192 -#define GCC_UFS_AXI_CLK 193 -#define GCC_UFS_AHB_CLK 194 -#define GCC_UFS_TX_CFG_CLK 195 -#define GCC_UFS_RX_CFG_CLK 196 -#define GCC_UFS_TX_SYMBOL_0_CLK 197 -#define GCC_UFS_RX_SYMBOL_0_CLK 198 -#define GCC_UFS_RX_SYMBOL_1_CLK 199 -#define GCC_UFS_UNIPRO_CORE_CLK 200 -#define GCC_UFS_ICE_CORE_CLK 201 -#define GCC_UFS_SYS_CLK_CORE_CLK 202 -#define GCC_UFS_TX_SYMBOL_CLK_CORE_CLK 203 -#define GCC_AGGRE0_SNOC_AXI_CLK 204 -#define GCC_AGGRE0_CNOC_AHB_CLK 205 -#define GCC_SMMU_AGGRE0_AXI_CLK 206 -#define GCC_SMMU_AGGRE0_AHB_CLK 207 -#define GCC_AGGRE1_PNOC_AHB_CLK 208 -#define GCC_AGGRE2_UFS_AXI_CLK 209 -#define GCC_AGGRE2_USB3_AXI_CLK 210 -#define GCC_QSPI_AHB_CLK 211 -#define GCC_QSPI_SER_CLK 212 -#define GCC_USB3_CLKREF_CLK 213 -#define GCC_HDMI_CLKREF_CLK 214 -#define GCC_UFS_CLKREF_CLK 215 -#define GCC_PCIE_CLKREF_CLK 216 -#define GCC_RX2_USB2_CLKREF_CLK 217 -#define GCC_RX1_USB2_CLKREF_CLK 218 -#define GCC_HLOS1_VOTE_LPASS_CORE_SMMU_CLK 219 -#define GCC_HLOS1_VOTE_LPASS_ADSP_SMMU_CLK 220 -#define GCC_EDP_CLKREF_CLK 221 -#define GCC_MSS_CFG_AHB_CLK 222 -#define GCC_MSS_Q6_BIMC_AXI_CLK 223 -#define GCC_MSS_SNOC_AXI_CLK 224 -#define GCC_MSS_MNOC_BIMC_AXI_CLK 225 -#define GCC_DCC_AHB_CLK 226 -#define GCC_AGGRE0_NOC_MPU_CFG_AHB_CLK 227 -#define GCC_MMSS_GPLL0_DIV_CLK 228 -#define GCC_MSS_GPLL0_DIV_CLK 229 - -#define GCC_SYSTEM_NOC_BCR 0 -#define GCC_CONFIG_NOC_BCR 1 -#define GCC_PERIPH_NOC_BCR 2 -#define GCC_IMEM_BCR 3 -#define GCC_MMSS_BCR 4 -#define GCC_PIMEM_BCR 5 -#define GCC_QDSS_BCR 6 -#define GCC_USB_30_BCR 7 -#define GCC_USB_20_BCR 8 -#define GCC_QUSB2PHY_PRIM_BCR 9 -#define GCC_QUSB2PHY_SEC_BCR 10 -#define GCC_USB_PHY_CFG_AHB2PHY_BCR 11 -#define GCC_SDCC1_BCR 12 -#define GCC_SDCC2_BCR 13 -#define GCC_SDCC3_BCR 14 -#define GCC_SDCC4_BCR 15 -#define GCC_BLSP1_BCR 16 -#define GCC_BLSP1_QUP1_BCR 17 -#define GCC_BLSP1_UART1_BCR 18 -#define GCC_BLSP1_QUP2_BCR 19 -#define GCC_BLSP1_UART2_BCR 20 -#define GCC_BLSP1_QUP3_BCR 21 -#define GCC_BLSP1_UART3_BCR 22 -#define GCC_BLSP1_QUP4_BCR 23 -#define GCC_BLSP1_UART4_BCR 24 -#define GCC_BLSP1_QUP5_BCR 25 -#define GCC_BLSP1_UART5_BCR 26 -#define GCC_BLSP1_QUP6_BCR 27 -#define GCC_BLSP1_UART6_BCR 28 -#define GCC_BLSP2_BCR 29 -#define GCC_BLSP2_QUP1_BCR 30 -#define GCC_BLSP2_UART1_BCR 31 -#define GCC_BLSP2_QUP2_BCR 32 -#define GCC_BLSP2_UART2_BCR 33 -#define GCC_BLSP2_QUP3_BCR 34 -#define GCC_BLSP2_UART3_BCR 35 -#define GCC_BLSP2_QUP4_BCR 36 -#define GCC_BLSP2_UART4_BCR 37 -#define GCC_BLSP2_QUP5_BCR 38 -#define GCC_BLSP2_UART5_BCR 39 -#define GCC_BLSP2_QUP6_BCR 40 -#define GCC_BLSP2_UART6_BCR 41 -#define GCC_PDM_BCR 42 -#define GCC_PRNG_BCR 43 -#define GCC_TSIF_BCR 44 -#define GCC_TCSR_BCR 45 -#define GCC_BOOT_ROM_BCR 46 -#define GCC_MSG_RAM_BCR 47 -#define GCC_TLMM_BCR 48 -#define GCC_MPM_BCR 49 -#define GCC_SEC_CTRL_BCR 50 -#define GCC_SPMI_BCR 51 -#define GCC_SPDM_BCR 52 -#define GCC_CE1_BCR 53 -#define GCC_BIMC_BCR 54 -#define GCC_SNOC_BUS_TIMEOUT0_BCR 55 -#define GCC_SNOC_BUS_TIMEOUT2_BCR 56 -#define GCC_SNOC_BUS_TIMEOUT1_BCR 57 -#define GCC_SNOC_BUS_TIMEOUT3_BCR 58 -#define GCC_SNOC_BUS_TIMEOUT_EXTREF_BCR 59 -#define GCC_PNOC_BUS_TIMEOUT0_BCR 60 -#define GCC_PNOC_BUS_TIMEOUT1_BCR 61 -#define GCC_PNOC_BUS_TIMEOUT2_BCR 62 -#define GCC_PNOC_BUS_TIMEOUT3_BCR 63 -#define GCC_PNOC_BUS_TIMEOUT4_BCR 64 -#define GCC_CNOC_BUS_TIMEOUT0_BCR 65 -#define GCC_CNOC_BUS_TIMEOUT1_BCR 66 -#define GCC_CNOC_BUS_TIMEOUT2_BCR 67 -#define GCC_CNOC_BUS_TIMEOUT3_BCR 68 -#define GCC_CNOC_BUS_TIMEOUT4_BCR 69 -#define GCC_CNOC_BUS_TIMEOUT5_BCR 70 -#define GCC_CNOC_BUS_TIMEOUT6_BCR 71 -#define GCC_CNOC_BUS_TIMEOUT7_BCR 72 -#define GCC_CNOC_BUS_TIMEOUT8_BCR 73 -#define GCC_CNOC_BUS_TIMEOUT9_BCR 74 -#define GCC_CNOC_BUS_TIMEOUT_EXTREF_BCR 75 -#define GCC_APB2JTAG_BCR 76 -#define GCC_RBCPR_CX_BCR 77 -#define GCC_RBCPR_MX_BCR 78 -#define GCC_PCIE_0_BCR 79 -#define GCC_PCIE_0_PHY_BCR 80 -#define GCC_PCIE_1_BCR 81 -#define GCC_PCIE_1_PHY_BCR 82 -#define GCC_PCIE_2_BCR 83 -#define GCC_PCIE_2_PHY_BCR 84 -#define GCC_PCIE_PHY_BCR 85 -#define GCC_DCD_BCR 86 -#define GCC_OBT_ODT_BCR 87 -#define GCC_UFS_BCR 88 -#define GCC_SSC_BCR 89 -#define GCC_VS_BCR 90 -#define GCC_AGGRE0_NOC_BCR 91 -#define GCC_AGGRE1_NOC_BCR 92 -#define GCC_AGGRE2_NOC_BCR 93 -#define GCC_DCC_BCR 94 -#define GCC_IPA_BCR 95 -#define GCC_QSPI_BCR 96 -#define GCC_SKL_BCR 97 -#define GCC_MSMPU_BCR 98 -#define GCC_MSS_Q6_BCR 99 -#define GCC_QREFS_VBG_CAL_BCR 100 -#define GCC_PCIE_PHY_COM_BCR 101 -#define GCC_PCIE_PHY_COM_NOCSR_BCR 102 -#define GCC_USB3_PHY_BCR 103 -#define GCC_USB3PHY_PHY_BCR 104 -#define GCC_MSS_RESTART 105 - - -/* Indexes for GDSCs */ -#define AGGRE0_NOC_GDSC 0 -#define HLOS1_VOTE_AGGRE0_NOC_GDSC 1 -#define HLOS1_VOTE_LPASS_ADSP_GDSC 2 -#define HLOS1_VOTE_LPASS_CORE_GDSC 3 -#define USB30_GDSC 4 -#define PCIE0_GDSC 5 -#define PCIE1_GDSC 6 -#define PCIE2_GDSC 7 -#define UFS_GDSC 8 - -#endif diff --git a/include/dt-bindings/clock/qcom,gcc-qcs404.h b/include/dt-bindings/clock/qcom,gcc-qcs404.h deleted file mode 100644 index bc3051543347..000000000000 --- a/include/dt-bindings/clock/qcom,gcc-qcs404.h +++ /dev/null @@ -1,180 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_QCOM_GCC_QCS404_H -#define _DT_BINDINGS_CLK_QCOM_GCC_QCS404_H - -#define GCC_APSS_AHB_CLK_SRC 0 -#define GCC_BLSP1_QUP0_I2C_APPS_CLK_SRC 1 -#define GCC_BLSP1_QUP0_SPI_APPS_CLK_SRC 2 -#define GCC_BLSP1_QUP1_I2C_APPS_CLK_SRC 3 -#define GCC_BLSP1_QUP1_SPI_APPS_CLK_SRC 4 -#define GCC_BLSP1_QUP2_I2C_APPS_CLK_SRC 5 -#define GCC_BLSP1_QUP2_SPI_APPS_CLK_SRC 6 -#define GCC_BLSP1_QUP3_I2C_APPS_CLK_SRC 7 -#define GCC_BLSP1_QUP3_SPI_APPS_CLK_SRC 8 -#define GCC_BLSP1_QUP4_I2C_APPS_CLK_SRC 9 -#define GCC_BLSP1_QUP4_SPI_APPS_CLK_SRC 10 -#define GCC_BLSP1_UART0_APPS_CLK_SRC 11 -#define GCC_BLSP1_UART1_APPS_CLK_SRC 12 -#define GCC_BLSP1_UART2_APPS_CLK_SRC 13 -#define GCC_BLSP1_UART3_APPS_CLK_SRC 14 -#define GCC_BLSP2_QUP0_I2C_APPS_CLK_SRC 15 -#define GCC_BLSP2_QUP0_SPI_APPS_CLK_SRC 16 -#define GCC_BLSP2_UART0_APPS_CLK_SRC 17 -#define GCC_BYTE0_CLK_SRC 18 -#define GCC_EMAC_CLK_SRC 19 -#define GCC_EMAC_PTP_CLK_SRC 20 -#define GCC_ESC0_CLK_SRC 21 -#define GCC_APSS_AHB_CLK 22 -#define GCC_APSS_AXI_CLK 23 -#define GCC_BIMC_APSS_AXI_CLK 24 -#define GCC_BIMC_GFX_CLK 25 -#define GCC_BIMC_MDSS_CLK 26 -#define GCC_BLSP1_AHB_CLK 27 -#define GCC_BLSP1_QUP0_I2C_APPS_CLK 28 -#define GCC_BLSP1_QUP0_SPI_APPS_CLK 29 -#define GCC_BLSP1_QUP1_I2C_APPS_CLK 30 -#define GCC_BLSP1_QUP1_SPI_APPS_CLK 31 -#define GCC_BLSP1_QUP2_I2C_APPS_CLK 32 -#define GCC_BLSP1_QUP2_SPI_APPS_CLK 33 -#define GCC_BLSP1_QUP3_I2C_APPS_CLK 34 -#define GCC_BLSP1_QUP3_SPI_APPS_CLK 35 -#define GCC_BLSP1_QUP4_I2C_APPS_CLK 36 -#define GCC_BLSP1_QUP4_SPI_APPS_CLK 37 -#define GCC_BLSP1_UART0_APPS_CLK 38 -#define GCC_BLSP1_UART1_APPS_CLK 39 -#define GCC_BLSP1_UART2_APPS_CLK 40 -#define GCC_BLSP1_UART3_APPS_CLK 41 -#define GCC_BLSP2_AHB_CLK 42 -#define GCC_BLSP2_QUP0_I2C_APPS_CLK 43 -#define GCC_BLSP2_QUP0_SPI_APPS_CLK 44 -#define GCC_BLSP2_UART0_APPS_CLK 45 -#define GCC_BOOT_ROM_AHB_CLK 46 -#define GCC_DCC_CLK 47 -#define GCC_GENI_IR_H_CLK 48 -#define GCC_ETH_AXI_CLK 49 -#define GCC_ETH_PTP_CLK 50 -#define GCC_ETH_RGMII_CLK 51 -#define GCC_ETH_SLAVE_AHB_CLK 52 -#define GCC_GENI_IR_S_CLK 53 -#define GCC_GP1_CLK 54 -#define GCC_GP2_CLK 55 -#define GCC_GP3_CLK 56 -#define GCC_MDSS_AHB_CLK 57 -#define GCC_MDSS_AXI_CLK 58 -#define GCC_MDSS_BYTE0_CLK 59 -#define GCC_MDSS_ESC0_CLK 60 -#define GCC_MDSS_HDMI_APP_CLK 61 -#define GCC_MDSS_HDMI_PCLK_CLK 62 -#define GCC_MDSS_MDP_CLK 63 -#define GCC_MDSS_PCLK0_CLK 64 -#define GCC_MDSS_VSYNC_CLK 65 -#define GCC_OXILI_AHB_CLK 66 -#define GCC_OXILI_GFX3D_CLK 67 -#define GCC_PCIE_0_AUX_CLK 68 -#define GCC_PCIE_0_CFG_AHB_CLK 69 -#define GCC_PCIE_0_MSTR_AXI_CLK 70 -#define GCC_PCIE_0_PIPE_CLK 71 -#define GCC_PCIE_0_SLV_AXI_CLK 72 -#define GCC_PCNOC_USB2_CLK 73 -#define GCC_PCNOC_USB3_CLK 74 -#define GCC_PDM2_CLK 75 -#define GCC_PDM_AHB_CLK 76 -#define GCC_VSYNC_CLK_SRC 77 -#define GCC_PRNG_AHB_CLK 78 -#define GCC_PWM0_XO512_CLK 79 -#define GCC_PWM1_XO512_CLK 80 -#define GCC_PWM2_XO512_CLK 81 -#define GCC_SDCC1_AHB_CLK 82 -#define GCC_SDCC1_APPS_CLK 83 -#define GCC_SDCC1_ICE_CORE_CLK 84 -#define GCC_SDCC2_AHB_CLK 85 -#define GCC_SDCC2_APPS_CLK 86 -#define GCC_SYS_NOC_USB3_CLK 87 -#define GCC_USB20_MOCK_UTMI_CLK 88 -#define GCC_USB2A_PHY_SLEEP_CLK 89 -#define GCC_USB30_MASTER_CLK 90 -#define GCC_USB30_MOCK_UTMI_CLK 91 -#define GCC_USB30_SLEEP_CLK 92 -#define GCC_USB3_PHY_AUX_CLK 93 -#define GCC_USB3_PHY_PIPE_CLK 94 -#define GCC_USB_HS_PHY_CFG_AHB_CLK 95 -#define GCC_USB_HS_SYSTEM_CLK 96 -#define GCC_GFX3D_CLK_SRC 97 -#define GCC_GP1_CLK_SRC 98 -#define GCC_GP2_CLK_SRC 99 -#define GCC_GP3_CLK_SRC 100 -#define GCC_GPLL0_OUT_MAIN 101 -#define GCC_GPLL1_OUT_MAIN 102 -#define GCC_GPLL3_OUT_MAIN 103 -#define GCC_GPLL4_OUT_MAIN 104 -#define GCC_HDMI_APP_CLK_SRC 105 -#define GCC_HDMI_PCLK_CLK_SRC 106 -#define GCC_MDP_CLK_SRC 107 -#define GCC_PCIE_0_AUX_CLK_SRC 108 -#define GCC_PCIE_0_PIPE_CLK_SRC 109 -#define GCC_PCLK0_CLK_SRC 110 -#define GCC_PDM2_CLK_SRC 111 -#define GCC_SDCC1_APPS_CLK_SRC 112 -#define GCC_SDCC1_ICE_CORE_CLK_SRC 113 -#define GCC_SDCC2_APPS_CLK_SRC 114 -#define GCC_USB20_MOCK_UTMI_CLK_SRC 115 -#define GCC_USB30_MASTER_CLK_SRC 116 -#define GCC_USB30_MOCK_UTMI_CLK_SRC 117 -#define GCC_USB3_PHY_AUX_CLK_SRC 118 -#define GCC_USB_HS_SYSTEM_CLK_SRC 119 -#define GCC_GPLL0_AO_CLK_SRC 120 -#define GCC_USB_HS_INACTIVITY_TIMERS_CLK 122 -#define GCC_GPLL0_AO_OUT_MAIN 123 -#define GCC_GPLL0_SLEEP_CLK_SRC 124 -#define GCC_GPLL6 125 -#define GCC_GPLL6_OUT_AUX 126 -#define GCC_MDSS_MDP_VOTE_CLK 127 -#define GCC_MDSS_ROTATOR_VOTE_CLK 128 -#define GCC_BIMC_GPU_CLK 129 -#define GCC_GTCU_AHB_CLK 130 -#define GCC_GFX_TCU_CLK 131 -#define GCC_GFX_TBU_CLK 132 -#define GCC_SMMU_CFG_CLK 133 -#define GCC_APSS_TCU_CLK 134 -#define GCC_CRYPTO_AHB_CLK 135 -#define GCC_CRYPTO_AXI_CLK 136 -#define GCC_CRYPTO_CLK 137 -#define GCC_MDP_TBU_CLK 138 -#define GCC_QDSS_DAP_CLK 139 -#define GCC_DCC_XO_CLK 140 -#define GCC_WCSS_Q6_AHB_CLK 141 -#define GCC_WCSS_Q6_AXIM_CLK 142 -#define GCC_CDSP_CFG_AHB_CLK 143 -#define GCC_BIMC_CDSP_CLK 144 -#define GCC_CDSP_TBU_CLK 145 -#define GCC_CDSP_BIMC_CLK_SRC 146 - -#define GCC_GENI_IR_BCR 0 -#define GCC_USB_HS_BCR 1 -#define GCC_USB2_HS_PHY_ONLY_BCR 2 -#define GCC_QUSB2_PHY_BCR 3 -#define GCC_USB_HS_PHY_CFG_AHB_BCR 4 -#define GCC_USB2A_PHY_BCR 5 -#define GCC_USB3_PHY_BCR 6 -#define GCC_USB_30_BCR 7 -#define GCC_USB3PHY_PHY_BCR 8 -#define GCC_PCIE_0_BCR 9 -#define GCC_PCIE_0_PHY_BCR 10 -#define GCC_PCIE_0_LINK_DOWN_BCR 11 -#define GCC_PCIEPHY_0_PHY_BCR 12 -#define GCC_EMAC_BCR 13 -#define GCC_CDSP_RESTART 14 -#define GCC_PCIE_0_AXI_MASTER_STICKY_ARES 15 -#define GCC_PCIE_0_AHB_ARES 16 -#define GCC_PCIE_0_AXI_SLAVE_ARES 17 -#define GCC_PCIE_0_AXI_MASTER_ARES 18 -#define GCC_PCIE_0_CORE_STICKY_ARES 19 -#define GCC_PCIE_0_SLEEP_ARES 20 -#define GCC_PCIE_0_PIPE_ARES 21 -#define GCC_WDSP_RESTART 22 - -#endif diff --git a/include/dt-bindings/clock/qcom,gcc-sdm845.h b/include/dt-bindings/clock/qcom,gcc-sdm845.h deleted file mode 100644 index 968fa65b9c42..000000000000 --- a/include/dt-bindings/clock/qcom,gcc-sdm845.h +++ /dev/null @@ -1,246 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_GCC_SDM845_H -#define _DT_BINDINGS_CLK_SDM_GCC_SDM845_H - -/* GCC clock registers */ -#define GCC_AGGRE_NOC_PCIE_TBU_CLK 0 -#define GCC_AGGRE_UFS_CARD_AXI_CLK 1 -#define GCC_AGGRE_UFS_PHY_AXI_CLK 2 -#define GCC_AGGRE_USB3_PRIM_AXI_CLK 3 -#define GCC_AGGRE_USB3_SEC_AXI_CLK 4 -#define GCC_BOOT_ROM_AHB_CLK 5 -#define GCC_CAMERA_AHB_CLK 6 -#define GCC_CAMERA_AXI_CLK 7 -#define GCC_CAMERA_XO_CLK 8 -#define GCC_CE1_AHB_CLK 9 -#define GCC_CE1_AXI_CLK 10 -#define GCC_CE1_CLK 11 -#define GCC_CFG_NOC_USB3_PRIM_AXI_CLK 12 -#define GCC_CFG_NOC_USB3_SEC_AXI_CLK 13 -#define GCC_CPUSS_AHB_CLK 14 -#define GCC_CPUSS_AHB_CLK_SRC 15 -#define GCC_CPUSS_RBCPR_CLK 16 -#define GCC_CPUSS_RBCPR_CLK_SRC 17 -#define GCC_DDRSS_GPU_AXI_CLK 18 -#define GCC_DISP_AHB_CLK 19 -#define GCC_DISP_AXI_CLK 20 -#define GCC_DISP_GPLL0_CLK_SRC 21 -#define GCC_DISP_GPLL0_DIV_CLK_SRC 22 -#define GCC_DISP_XO_CLK 23 -#define GCC_GP1_CLK 24 -#define GCC_GP1_CLK_SRC 25 -#define GCC_GP2_CLK 26 -#define GCC_GP2_CLK_SRC 27 -#define GCC_GP3_CLK 28 -#define GCC_GP3_CLK_SRC 29 -#define GCC_GPU_CFG_AHB_CLK 30 -#define GCC_GPU_GPLL0_CLK_SRC 31 -#define GCC_GPU_GPLL0_DIV_CLK_SRC 32 -#define GCC_GPU_MEMNOC_GFX_CLK 33 -#define GCC_GPU_SNOC_DVM_GFX_CLK 34 -#define GCC_MSS_AXIS2_CLK 35 -#define GCC_MSS_CFG_AHB_CLK 36 -#define GCC_MSS_GPLL0_DIV_CLK_SRC 37 -#define GCC_MSS_MFAB_AXIS_CLK 38 -#define GCC_MSS_Q6_MEMNOC_AXI_CLK 39 -#define GCC_MSS_SNOC_AXI_CLK 40 -#define GCC_PCIE_0_AUX_CLK 41 -#define GCC_PCIE_0_AUX_CLK_SRC 42 -#define GCC_PCIE_0_CFG_AHB_CLK 43 -#define GCC_PCIE_0_CLKREF_CLK 44 -#define GCC_PCIE_0_MSTR_AXI_CLK 45 -#define GCC_PCIE_0_PIPE_CLK 46 -#define GCC_PCIE_0_SLV_AXI_CLK 47 -#define GCC_PCIE_0_SLV_Q2A_AXI_CLK 48 -#define GCC_PCIE_1_AUX_CLK 49 -#define GCC_PCIE_1_AUX_CLK_SRC 50 -#define GCC_PCIE_1_CFG_AHB_CLK 51 -#define GCC_PCIE_1_CLKREF_CLK 52 -#define GCC_PCIE_1_MSTR_AXI_CLK 53 -#define GCC_PCIE_1_PIPE_CLK 54 -#define GCC_PCIE_1_SLV_AXI_CLK 55 -#define GCC_PCIE_1_SLV_Q2A_AXI_CLK 56 -#define GCC_PCIE_PHY_AUX_CLK 57 -#define GCC_PCIE_PHY_REFGEN_CLK 58 -#define GCC_PCIE_PHY_REFGEN_CLK_SRC 59 -#define GCC_PDM2_CLK 60 -#define GCC_PDM2_CLK_SRC 61 -#define GCC_PDM_AHB_CLK 62 -#define GCC_PDM_XO4_CLK 63 -#define GCC_PRNG_AHB_CLK 64 -#define GCC_QMIP_CAMERA_AHB_CLK 65 -#define GCC_QMIP_DISP_AHB_CLK 66 -#define GCC_QMIP_VIDEO_AHB_CLK 67 -#define GCC_QUPV3_WRAP0_S0_CLK 68 -#define GCC_QUPV3_WRAP0_S0_CLK_SRC 69 -#define GCC_QUPV3_WRAP0_S1_CLK 70 -#define GCC_QUPV3_WRAP0_S1_CLK_SRC 71 -#define GCC_QUPV3_WRAP0_S2_CLK 72 -#define GCC_QUPV3_WRAP0_S2_CLK_SRC 73 -#define GCC_QUPV3_WRAP0_S3_CLK 74 -#define GCC_QUPV3_WRAP0_S3_CLK_SRC 75 -#define GCC_QUPV3_WRAP0_S4_CLK 76 -#define GCC_QUPV3_WRAP0_S4_CLK_SRC 77 -#define GCC_QUPV3_WRAP0_S5_CLK 78 -#define GCC_QUPV3_WRAP0_S5_CLK_SRC 79 -#define GCC_QUPV3_WRAP0_S6_CLK 80 -#define GCC_QUPV3_WRAP0_S6_CLK_SRC 81 -#define GCC_QUPV3_WRAP0_S7_CLK 82 -#define GCC_QUPV3_WRAP0_S7_CLK_SRC 83 -#define GCC_QUPV3_WRAP1_S0_CLK 84 -#define GCC_QUPV3_WRAP1_S0_CLK_SRC 85 -#define GCC_QUPV3_WRAP1_S1_CLK 86 -#define GCC_QUPV3_WRAP1_S1_CLK_SRC 87 -#define GCC_QUPV3_WRAP1_S2_CLK 88 -#define GCC_QUPV3_WRAP1_S2_CLK_SRC 89 -#define GCC_QUPV3_WRAP1_S3_CLK 90 -#define GCC_QUPV3_WRAP1_S3_CLK_SRC 91 -#define GCC_QUPV3_WRAP1_S4_CLK 92 -#define GCC_QUPV3_WRAP1_S4_CLK_SRC 93 -#define GCC_QUPV3_WRAP1_S5_CLK 94 -#define GCC_QUPV3_WRAP1_S5_CLK_SRC 95 -#define GCC_QUPV3_WRAP1_S6_CLK 96 -#define GCC_QUPV3_WRAP1_S6_CLK_SRC 97 -#define GCC_QUPV3_WRAP1_S7_CLK 98 -#define GCC_QUPV3_WRAP1_S7_CLK_SRC 99 -#define GCC_QUPV3_WRAP_0_M_AHB_CLK 100 -#define GCC_QUPV3_WRAP_0_S_AHB_CLK 101 -#define GCC_QUPV3_WRAP_1_M_AHB_CLK 102 -#define GCC_QUPV3_WRAP_1_S_AHB_CLK 103 -#define GCC_SDCC2_AHB_CLK 104 -#define GCC_SDCC2_APPS_CLK 105 -#define GCC_SDCC2_APPS_CLK_SRC 106 -#define GCC_SDCC4_AHB_CLK 107 -#define GCC_SDCC4_APPS_CLK 108 -#define GCC_SDCC4_APPS_CLK_SRC 109 -#define GCC_SYS_NOC_CPUSS_AHB_CLK 110 -#define GCC_TSIF_AHB_CLK 111 -#define GCC_TSIF_INACTIVITY_TIMERS_CLK 112 -#define GCC_TSIF_REF_CLK 113 -#define GCC_TSIF_REF_CLK_SRC 114 -#define GCC_UFS_CARD_AHB_CLK 115 -#define GCC_UFS_CARD_AXI_CLK 116 -#define GCC_UFS_CARD_AXI_CLK_SRC 117 -#define GCC_UFS_CARD_CLKREF_CLK 118 -#define GCC_UFS_CARD_ICE_CORE_CLK 119 -#define GCC_UFS_CARD_ICE_CORE_CLK_SRC 120 -#define GCC_UFS_CARD_PHY_AUX_CLK 121 -#define GCC_UFS_CARD_PHY_AUX_CLK_SRC 122 -#define GCC_UFS_CARD_RX_SYMBOL_0_CLK 123 -#define GCC_UFS_CARD_RX_SYMBOL_1_CLK 124 -#define GCC_UFS_CARD_TX_SYMBOL_0_CLK 125 -#define GCC_UFS_CARD_UNIPRO_CORE_CLK 126 -#define GCC_UFS_CARD_UNIPRO_CORE_CLK_SRC 127 -#define GCC_UFS_MEM_CLKREF_CLK 128 -#define GCC_UFS_PHY_AHB_CLK 129 -#define GCC_UFS_PHY_AXI_CLK 130 -#define GCC_UFS_PHY_AXI_CLK_SRC 131 -#define GCC_UFS_PHY_ICE_CORE_CLK 132 -#define GCC_UFS_PHY_ICE_CORE_CLK_SRC 133 -#define GCC_UFS_PHY_PHY_AUX_CLK 134 -#define GCC_UFS_PHY_PHY_AUX_CLK_SRC 135 -#define GCC_UFS_PHY_RX_SYMBOL_0_CLK 136 -#define GCC_UFS_PHY_RX_SYMBOL_1_CLK 137 -#define GCC_UFS_PHY_TX_SYMBOL_0_CLK 138 -#define GCC_UFS_PHY_UNIPRO_CORE_CLK 139 -#define GCC_UFS_PHY_UNIPRO_CORE_CLK_SRC 140 -#define GCC_USB30_PRIM_MASTER_CLK 141 -#define GCC_USB30_PRIM_MASTER_CLK_SRC 142 -#define GCC_USB30_PRIM_MOCK_UTMI_CLK 143 -#define GCC_USB30_PRIM_MOCK_UTMI_CLK_SRC 144 -#define GCC_USB30_PRIM_SLEEP_CLK 145 -#define GCC_USB30_SEC_MASTER_CLK 146 -#define GCC_USB30_SEC_MASTER_CLK_SRC 147 -#define GCC_USB30_SEC_MOCK_UTMI_CLK 148 -#define GCC_USB30_SEC_MOCK_UTMI_CLK_SRC 149 -#define GCC_USB30_SEC_SLEEP_CLK 150 -#define GCC_USB3_PRIM_CLKREF_CLK 151 -#define GCC_USB3_PRIM_PHY_AUX_CLK 152 -#define GCC_USB3_PRIM_PHY_AUX_CLK_SRC 153 -#define GCC_USB3_PRIM_PHY_COM_AUX_CLK 154 -#define GCC_USB3_PRIM_PHY_PIPE_CLK 155 -#define GCC_USB3_SEC_CLKREF_CLK 156 -#define GCC_USB3_SEC_PHY_AUX_CLK 157 -#define GCC_USB3_SEC_PHY_AUX_CLK_SRC 158 -#define GCC_USB3_SEC_PHY_PIPE_CLK 159 -#define GCC_USB3_SEC_PHY_COM_AUX_CLK 160 -#define GCC_USB_PHY_CFG_AHB2PHY_CLK 161 -#define GCC_VIDEO_AHB_CLK 162 -#define GCC_VIDEO_AXI_CLK 163 -#define GCC_VIDEO_XO_CLK 164 -#define GPLL0 165 -#define GPLL0_OUT_EVEN 166 -#define GPLL0_OUT_MAIN 167 -#define GCC_GPU_IREF_CLK 168 -#define GCC_SDCC1_AHB_CLK 169 -#define GCC_SDCC1_APPS_CLK 170 -#define GCC_SDCC1_ICE_CORE_CLK 171 -#define GCC_SDCC1_APPS_CLK_SRC 172 -#define GCC_SDCC1_ICE_CORE_CLK_SRC 173 -#define GCC_APC_VS_CLK 174 -#define GCC_GPU_VS_CLK 175 -#define GCC_MSS_VS_CLK 176 -#define GCC_VDDA_VS_CLK 177 -#define GCC_VDDCX_VS_CLK 178 -#define GCC_VDDMX_VS_CLK 179 -#define GCC_VS_CTRL_AHB_CLK 180 -#define GCC_VS_CTRL_CLK 181 -#define GCC_VS_CTRL_CLK_SRC 182 -#define GCC_VSENSOR_CLK_SRC 183 -#define GPLL4 184 -#define GCC_CPUSS_DVM_BUS_CLK 185 -#define GCC_CPUSS_GNOC_CLK 186 -#define GCC_QSPI_CORE_CLK_SRC 187 -#define GCC_QSPI_CORE_CLK 188 -#define GCC_QSPI_CNOC_PERIPH_AHB_CLK 189 -#define GCC_LPASS_Q6_AXI_CLK 190 -#define GCC_LPASS_SWAY_CLK 191 - -/* GCC Resets */ -#define GCC_MMSS_BCR 0 -#define GCC_PCIE_0_BCR 1 -#define GCC_PCIE_1_BCR 2 -#define GCC_PCIE_PHY_BCR 3 -#define GCC_PDM_BCR 4 -#define GCC_PRNG_BCR 5 -#define GCC_QUPV3_WRAPPER_0_BCR 6 -#define GCC_QUPV3_WRAPPER_1_BCR 7 -#define GCC_QUSB2PHY_PRIM_BCR 8 -#define GCC_QUSB2PHY_SEC_BCR 9 -#define GCC_SDCC2_BCR 10 -#define GCC_SDCC4_BCR 11 -#define GCC_TSIF_BCR 12 -#define GCC_UFS_CARD_BCR 13 -#define GCC_UFS_PHY_BCR 14 -#define GCC_USB30_PRIM_BCR 15 -#define GCC_USB30_SEC_BCR 16 -#define GCC_USB3_PHY_PRIM_BCR 17 -#define GCC_USB3PHY_PHY_PRIM_BCR 18 -#define GCC_USB3_DP_PHY_PRIM_BCR 19 -#define GCC_USB3_PHY_SEC_BCR 20 -#define GCC_USB3PHY_PHY_SEC_BCR 21 -#define GCC_USB3_DP_PHY_SEC_BCR 22 -#define GCC_USB_PHY_CFG_AHB2PHY_BCR 23 -#define GCC_PCIE_0_PHY_BCR 24 -#define GCC_PCIE_1_PHY_BCR 25 - -/* GCC GDSCRs */ -#define PCIE_0_GDSC 0 -#define PCIE_1_GDSC 1 -#define UFS_CARD_GDSC 2 -#define UFS_PHY_GDSC 3 -#define USB30_PRIM_GDSC 4 -#define USB30_SEC_GDSC 5 -#define HLOS1_VOTE_AGGRE_NOC_MMU_AUDIO_TBU_GDSC 6 -#define HLOS1_VOTE_AGGRE_NOC_MMU_PCIE_TBU_GDSC 7 -#define HLOS1_VOTE_AGGRE_NOC_MMU_TBU1_GDSC 8 -#define HLOS1_VOTE_AGGRE_NOC_MMU_TBU2_GDSC 9 -#define HLOS1_VOTE_MMNOC_MMU_TBU_HF0_GDSC 10 -#define HLOS1_VOTE_MMNOC_MMU_TBU_HF1_GDSC 11 -#define HLOS1_VOTE_MMNOC_MMU_TBU_SF_GDSC 12 - -#endif diff --git a/include/dt-bindings/clock/qcom,gpucc-sdm845.h b/include/dt-bindings/clock/qcom,gpucc-sdm845.h deleted file mode 100644 index 9690d901b50a..000000000000 --- a/include/dt-bindings/clock/qcom,gpucc-sdm845.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_GPU_CC_SDM845_H -#define _DT_BINDINGS_CLK_SDM_GPU_CC_SDM845_H - -/* GPU_CC clock registers */ -#define GPU_CC_CX_GMU_CLK 0 -#define GPU_CC_CXO_CLK 1 -#define GPU_CC_GMU_CLK_SRC 2 -#define GPU_CC_PLL1 3 - -/* GPU_CC Resets */ -#define GPUCC_GPU_CC_CX_BCR 0 -#define GPUCC_GPU_CC_GMU_BCR 1 -#define GPUCC_GPU_CC_XO_BCR 2 - -/* GPU_CC GDSCRs */ -#define GPU_CX_GDSC 0 -#define GPU_GX_GDSC 1 - -#endif diff --git a/include/dt-bindings/clock/qcom,lpass-sdm845.h b/include/dt-bindings/clock/qcom,lpass-sdm845.h deleted file mode 100644 index 659050846f61..000000000000 --- a/include/dt-bindings/clock/qcom,lpass-sdm845.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_LPASS_SDM845_H -#define _DT_BINDINGS_CLK_SDM_LPASS_SDM845_H - -#define LPASS_Q6SS_AHBM_AON_CLK 0 -#define LPASS_Q6SS_AHBS_AON_CLK 1 -#define LPASS_QDSP6SS_XO_CLK 2 -#define LPASS_QDSP6SS_SLEEP_CLK 3 -#define LPASS_QDSP6SS_CORE_CLK 4 - -#endif diff --git a/include/dt-bindings/clock/qcom,mmcc-msm8996.h b/include/dt-bindings/clock/qcom,mmcc-msm8996.h deleted file mode 100644 index d51f9ac70566..000000000000 --- a/include/dt-bindings/clock/qcom,mmcc-msm8996.h +++ /dev/null @@ -1,295 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (c) 2015, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_MSM_MMCC_8996_H -#define _DT_BINDINGS_CLK_MSM_MMCC_8996_H - -#define MMPLL0_EARLY 0 -#define MMPLL0_PLL 1 -#define MMPLL1_EARLY 2 -#define MMPLL1_PLL 3 -#define MMPLL2_EARLY 4 -#define MMPLL2_PLL 5 -#define MMPLL3_EARLY 6 -#define MMPLL3_PLL 7 -#define MMPLL4_EARLY 8 -#define MMPLL4_PLL 9 -#define MMPLL5_EARLY 10 -#define MMPLL5_PLL 11 -#define MMPLL8_EARLY 12 -#define MMPLL8_PLL 13 -#define MMPLL9_EARLY 14 -#define MMPLL9_PLL 15 -#define AHB_CLK_SRC 16 -#define AXI_CLK_SRC 17 -#define MAXI_CLK_SRC 18 -#define DSA_CORE_CLK_SRC 19 -#define GFX3D_CLK_SRC 20 -#define RBBMTIMER_CLK_SRC 21 -#define ISENSE_CLK_SRC 22 -#define RBCPR_CLK_SRC 23 -#define VIDEO_CORE_CLK_SRC 24 -#define VIDEO_SUBCORE0_CLK_SRC 25 -#define VIDEO_SUBCORE1_CLK_SRC 26 -#define PCLK0_CLK_SRC 27 -#define PCLK1_CLK_SRC 28 -#define MDP_CLK_SRC 29 -#define EXTPCLK_CLK_SRC 30 -#define VSYNC_CLK_SRC 31 -#define HDMI_CLK_SRC 32 -#define BYTE0_CLK_SRC 33 -#define BYTE1_CLK_SRC 34 -#define ESC0_CLK_SRC 35 -#define ESC1_CLK_SRC 36 -#define CAMSS_GP0_CLK_SRC 37 -#define CAMSS_GP1_CLK_SRC 38 -#define MCLK0_CLK_SRC 39 -#define MCLK1_CLK_SRC 40 -#define MCLK2_CLK_SRC 41 -#define MCLK3_CLK_SRC 42 -#define CCI_CLK_SRC 43 -#define CSI0PHYTIMER_CLK_SRC 44 -#define CSI1PHYTIMER_CLK_SRC 45 -#define CSI2PHYTIMER_CLK_SRC 46 -#define CSIPHY0_3P_CLK_SRC 47 -#define CSIPHY1_3P_CLK_SRC 48 -#define CSIPHY2_3P_CLK_SRC 49 -#define JPEG0_CLK_SRC 50 -#define JPEG2_CLK_SRC 51 -#define JPEG_DMA_CLK_SRC 52 -#define VFE0_CLK_SRC 53 -#define VFE1_CLK_SRC 54 -#define CPP_CLK_SRC 55 -#define CSI0_CLK_SRC 56 -#define CSI1_CLK_SRC 57 -#define CSI2_CLK_SRC 58 -#define CSI3_CLK_SRC 59 -#define FD_CORE_CLK_SRC 60 -#define MMSS_CXO_CLK 61 -#define MMSS_SLEEPCLK_CLK 62 -#define MMSS_MMAGIC_AHB_CLK 63 -#define MMSS_MMAGIC_CFG_AHB_CLK 64 -#define MMSS_MISC_AHB_CLK 65 -#define MMSS_MISC_CXO_CLK 66 -#define MMSS_BTO_AHB_CLK 67 -#define MMSS_MMAGIC_AXI_CLK 68 -#define MMSS_S0_AXI_CLK 69 -#define MMSS_MMAGIC_MAXI_CLK 70 -#define DSA_CORE_CLK 71 -#define DSA_NOC_CFG_AHB_CLK 72 -#define MMAGIC_CAMSS_AXI_CLK 73 -#define MMAGIC_CAMSS_NOC_CFG_AHB_CLK 74 -#define THROTTLE_CAMSS_CXO_CLK 75 -#define THROTTLE_CAMSS_AHB_CLK 76 -#define THROTTLE_CAMSS_AXI_CLK 77 -#define SMMU_VFE_AHB_CLK 78 -#define SMMU_VFE_AXI_CLK 79 -#define SMMU_CPP_AHB_CLK 80 -#define SMMU_CPP_AXI_CLK 81 -#define SMMU_JPEG_AHB_CLK 82 -#define SMMU_JPEG_AXI_CLK 83 -#define MMAGIC_MDSS_AXI_CLK 84 -#define MMAGIC_MDSS_NOC_CFG_AHB_CLK 85 -#define THROTTLE_MDSS_CXO_CLK 86 -#define THROTTLE_MDSS_AHB_CLK 87 -#define THROTTLE_MDSS_AXI_CLK 88 -#define SMMU_ROT_AHB_CLK 89 -#define SMMU_ROT_AXI_CLK 90 -#define SMMU_MDP_AHB_CLK 91 -#define SMMU_MDP_AXI_CLK 92 -#define MMAGIC_VIDEO_AXI_CLK 93 -#define MMAGIC_VIDEO_NOC_CFG_AHB_CLK 94 -#define THROTTLE_VIDEO_CXO_CLK 95 -#define THROTTLE_VIDEO_AHB_CLK 96 -#define THROTTLE_VIDEO_AXI_CLK 97 -#define SMMU_VIDEO_AHB_CLK 98 -#define SMMU_VIDEO_AXI_CLK 99 -#define MMAGIC_BIMC_AXI_CLK 100 -#define MMAGIC_BIMC_NOC_CFG_AHB_CLK 101 -#define GPU_GX_GFX3D_CLK 102 -#define GPU_GX_RBBMTIMER_CLK 103 -#define GPU_AHB_CLK 104 -#define GPU_AON_ISENSE_CLK 105 -#define VMEM_MAXI_CLK 106 -#define VMEM_AHB_CLK 107 -#define MMSS_RBCPR_CLK 108 -#define MMSS_RBCPR_AHB_CLK 109 -#define VIDEO_CORE_CLK 110 -#define VIDEO_AXI_CLK 111 -#define VIDEO_MAXI_CLK 112 -#define VIDEO_AHB_CLK 113 -#define VIDEO_SUBCORE0_CLK 114 -#define VIDEO_SUBCORE1_CLK 115 -#define MDSS_AHB_CLK 116 -#define MDSS_HDMI_AHB_CLK 117 -#define MDSS_AXI_CLK 118 -#define MDSS_PCLK0_CLK 119 -#define MDSS_PCLK1_CLK 120 -#define MDSS_MDP_CLK 121 -#define MDSS_EXTPCLK_CLK 122 -#define MDSS_VSYNC_CLK 123 -#define MDSS_HDMI_CLK 124 -#define MDSS_BYTE0_CLK 125 -#define MDSS_BYTE1_CLK 126 -#define MDSS_ESC0_CLK 127 -#define MDSS_ESC1_CLK 128 -#define CAMSS_TOP_AHB_CLK 129 -#define CAMSS_AHB_CLK 130 -#define CAMSS_MICRO_AHB_CLK 131 -#define CAMSS_GP0_CLK 132 -#define CAMSS_GP1_CLK 133 -#define CAMSS_MCLK0_CLK 134 -#define CAMSS_MCLK1_CLK 135 -#define CAMSS_MCLK2_CLK 136 -#define CAMSS_MCLK3_CLK 137 -#define CAMSS_CCI_CLK 138 -#define CAMSS_CCI_AHB_CLK 139 -#define CAMSS_CSI0PHYTIMER_CLK 140 -#define CAMSS_CSI1PHYTIMER_CLK 141 -#define CAMSS_CSI2PHYTIMER_CLK 142 -#define CAMSS_CSIPHY0_3P_CLK 143 -#define CAMSS_CSIPHY1_3P_CLK 144 -#define CAMSS_CSIPHY2_3P_CLK 145 -#define CAMSS_JPEG0_CLK 146 -#define CAMSS_JPEG2_CLK 147 -#define CAMSS_JPEG_DMA_CLK 148 -#define CAMSS_JPEG_AHB_CLK 149 -#define CAMSS_JPEG_AXI_CLK 150 -#define CAMSS_VFE_AHB_CLK 151 -#define CAMSS_VFE_AXI_CLK 152 -#define CAMSS_VFE0_CLK 153 -#define CAMSS_VFE0_STREAM_CLK 154 -#define CAMSS_VFE0_AHB_CLK 155 -#define CAMSS_VFE1_CLK 156 -#define CAMSS_VFE1_STREAM_CLK 157 -#define CAMSS_VFE1_AHB_CLK 158 -#define CAMSS_CSI_VFE0_CLK 159 -#define CAMSS_CSI_VFE1_CLK 160 -#define CAMSS_CPP_VBIF_AHB_CLK 161 -#define CAMSS_CPP_AXI_CLK 162 -#define CAMSS_CPP_CLK 163 -#define CAMSS_CPP_AHB_CLK 164 -#define CAMSS_CSI0_CLK 165 -#define CAMSS_CSI0_AHB_CLK 166 -#define CAMSS_CSI0PHY_CLK 167 -#define CAMSS_CSI0RDI_CLK 168 -#define CAMSS_CSI0PIX_CLK 169 -#define CAMSS_CSI1_CLK 170 -#define CAMSS_CSI1_AHB_CLK 171 -#define CAMSS_CSI1PHY_CLK 172 -#define CAMSS_CSI1RDI_CLK 173 -#define CAMSS_CSI1PIX_CLK 174 -#define CAMSS_CSI2_CLK 175 -#define CAMSS_CSI2_AHB_CLK 176 -#define CAMSS_CSI2PHY_CLK 177 -#define CAMSS_CSI2RDI_CLK 178 -#define CAMSS_CSI2PIX_CLK 179 -#define CAMSS_CSI3_CLK 180 -#define CAMSS_CSI3_AHB_CLK 181 -#define CAMSS_CSI3PHY_CLK 182 -#define CAMSS_CSI3RDI_CLK 183 -#define CAMSS_CSI3PIX_CLK 184 -#define CAMSS_ISPIF_AHB_CLK 185 -#define FD_CORE_CLK 186 -#define FD_CORE_UAR_CLK 187 -#define FD_AHB_CLK 188 -#define MMSS_SPDM_CSI0_CLK 189 -#define MMSS_SPDM_JPEG_DMA_CLK 190 -#define MMSS_SPDM_CPP_CLK 191 -#define MMSS_SPDM_PCLK0_CLK 192 -#define MMSS_SPDM_AHB_CLK 193 -#define MMSS_SPDM_GFX3D_CLK 194 -#define MMSS_SPDM_PCLK1_CLK 195 -#define MMSS_SPDM_JPEG2_CLK 196 -#define MMSS_SPDM_DEBUG_CLK 197 -#define MMSS_SPDM_VFE1_CLK 198 -#define MMSS_SPDM_VFE0_CLK 199 -#define MMSS_SPDM_VIDEO_CORE_CLK 200 -#define MMSS_SPDM_AXI_CLK 201 -#define MMSS_SPDM_MDP_CLK 202 -#define MMSS_SPDM_JPEG0_CLK 203 -#define MMSS_SPDM_RM_AXI_CLK 204 -#define MMSS_SPDM_RM_MAXI_CLK 205 - -#define MMAGICAHB_BCR 0 -#define MMAGIC_CFG_BCR 1 -#define MISC_BCR 2 -#define BTO_BCR 3 -#define MMAGICAXI_BCR 4 -#define MMAGICMAXI_BCR 5 -#define DSA_BCR 6 -#define MMAGIC_CAMSS_BCR 7 -#define THROTTLE_CAMSS_BCR 8 -#define SMMU_VFE_BCR 9 -#define SMMU_CPP_BCR 10 -#define SMMU_JPEG_BCR 11 -#define MMAGIC_MDSS_BCR 12 -#define THROTTLE_MDSS_BCR 13 -#define SMMU_ROT_BCR 14 -#define SMMU_MDP_BCR 15 -#define MMAGIC_VIDEO_BCR 16 -#define THROTTLE_VIDEO_BCR 17 -#define SMMU_VIDEO_BCR 18 -#define MMAGIC_BIMC_BCR 19 -#define GPU_GX_BCR 20 -#define GPU_BCR 21 -#define GPU_AON_BCR 22 -#define VMEM_BCR 23 -#define MMSS_RBCPR_BCR 24 -#define VIDEO_BCR 25 -#define MDSS_BCR 26 -#define CAMSS_TOP_BCR 27 -#define CAMSS_AHB_BCR 28 -#define CAMSS_MICRO_BCR 29 -#define CAMSS_CCI_BCR 30 -#define CAMSS_PHY0_BCR 31 -#define CAMSS_PHY1_BCR 32 -#define CAMSS_PHY2_BCR 33 -#define CAMSS_CSIPHY0_3P_BCR 34 -#define CAMSS_CSIPHY1_3P_BCR 35 -#define CAMSS_CSIPHY2_3P_BCR 36 -#define CAMSS_JPEG_BCR 37 -#define CAMSS_VFE_BCR 38 -#define CAMSS_VFE0_BCR 39 -#define CAMSS_VFE1_BCR 40 -#define CAMSS_CSI_VFE0_BCR 41 -#define CAMSS_CSI_VFE1_BCR 42 -#define CAMSS_CPP_TOP_BCR 43 -#define CAMSS_CPP_BCR 44 -#define CAMSS_CSI0_BCR 45 -#define CAMSS_CSI0RDI_BCR 46 -#define CAMSS_CSI0PIX_BCR 47 -#define CAMSS_CSI1_BCR 48 -#define CAMSS_CSI1RDI_BCR 49 -#define CAMSS_CSI1PIX_BCR 50 -#define CAMSS_CSI2_BCR 51 -#define CAMSS_CSI2RDI_BCR 52 -#define CAMSS_CSI2PIX_BCR 53 -#define CAMSS_CSI3_BCR 54 -#define CAMSS_CSI3RDI_BCR 55 -#define CAMSS_CSI3PIX_BCR 56 -#define CAMSS_ISPIF_BCR 57 -#define FD_BCR 58 -#define MMSS_SPDM_RM_BCR 59 - -/* Indexes for GDSCs */ -#define MMAGIC_VIDEO_GDSC 0 -#define MMAGIC_MDSS_GDSC 1 -#define MMAGIC_CAMSS_GDSC 2 -#define GPU_GDSC 3 -#define VENUS_GDSC 4 -#define VENUS_CORE0_GDSC 5 -#define VENUS_CORE1_GDSC 6 -#define CAMSS_GDSC 7 -#define VFE0_GDSC 8 -#define VFE1_GDSC 9 -#define JPEG_GDSC 10 -#define CPP_GDSC 11 -#define FD_GDSC 12 -#define MDSS_GDSC 13 -#define GPU_GX_GDSC 14 -#define MMAGIC_BIMC_GDSC 15 - -#endif diff --git a/include/dt-bindings/clock/qcom,rpmcc.h b/include/dt-bindings/clock/qcom,rpmcc.h deleted file mode 100644 index 46309c9953b2..000000000000 --- a/include/dt-bindings/clock/qcom,rpmcc.h +++ /dev/null @@ -1,174 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2015 Linaro Limited - */ - -#ifndef _DT_BINDINGS_CLK_MSM_RPMCC_H -#define _DT_BINDINGS_CLK_MSM_RPMCC_H - -/* RPM clocks */ -#define RPM_PXO_CLK 0 -#define RPM_PXO_A_CLK 1 -#define RPM_CXO_CLK 2 -#define RPM_CXO_A_CLK 3 -#define RPM_APPS_FABRIC_CLK 4 -#define RPM_APPS_FABRIC_A_CLK 5 -#define RPM_CFPB_CLK 6 -#define RPM_CFPB_A_CLK 7 -#define RPM_QDSS_CLK 8 -#define RPM_QDSS_A_CLK 9 -#define RPM_DAYTONA_FABRIC_CLK 10 -#define RPM_DAYTONA_FABRIC_A_CLK 11 -#define RPM_EBI1_CLK 12 -#define RPM_EBI1_A_CLK 13 -#define RPM_MM_FABRIC_CLK 14 -#define RPM_MM_FABRIC_A_CLK 15 -#define RPM_MMFPB_CLK 16 -#define RPM_MMFPB_A_CLK 17 -#define RPM_SYS_FABRIC_CLK 18 -#define RPM_SYS_FABRIC_A_CLK 19 -#define RPM_SFPB_CLK 20 -#define RPM_SFPB_A_CLK 21 -#define RPM_SMI_CLK 22 -#define RPM_SMI_A_CLK 23 -#define RPM_PLL4_CLK 24 -#define RPM_XO_D0 25 -#define RPM_XO_D1 26 -#define RPM_XO_A0 27 -#define RPM_XO_A1 28 -#define RPM_XO_A2 29 -#define RPM_NSS_FABRIC_0_CLK 30 -#define RPM_NSS_FABRIC_0_A_CLK 31 -#define RPM_NSS_FABRIC_1_CLK 32 -#define RPM_NSS_FABRIC_1_A_CLK 33 - -/* SMD RPM clocks */ -#define RPM_SMD_XO_CLK_SRC 0 -#define RPM_SMD_XO_A_CLK_SRC 1 -#define RPM_SMD_PCNOC_CLK 2 -#define RPM_SMD_PCNOC_A_CLK 3 -#define RPM_SMD_SNOC_CLK 4 -#define RPM_SMD_SNOC_A_CLK 5 -#define RPM_SMD_BIMC_CLK 6 -#define RPM_SMD_BIMC_A_CLK 7 -#define RPM_SMD_QDSS_CLK 8 -#define RPM_SMD_QDSS_A_CLK 9 -#define RPM_SMD_BB_CLK1 10 -#define RPM_SMD_BB_CLK1_A 11 -#define RPM_SMD_BB_CLK2 12 -#define RPM_SMD_BB_CLK2_A 13 -#define RPM_SMD_RF_CLK1 14 -#define RPM_SMD_RF_CLK1_A 15 -#define RPM_SMD_RF_CLK2 16 -#define RPM_SMD_RF_CLK2_A 17 -#define RPM_SMD_BB_CLK1_PIN 18 -#define RPM_SMD_BB_CLK1_A_PIN 19 -#define RPM_SMD_BB_CLK2_PIN 20 -#define RPM_SMD_BB_CLK2_A_PIN 21 -#define RPM_SMD_RF_CLK1_PIN 22 -#define RPM_SMD_RF_CLK1_A_PIN 23 -#define RPM_SMD_RF_CLK2_PIN 24 -#define RPM_SMD_RF_CLK2_A_PIN 25 -#define RPM_SMD_PNOC_CLK 26 -#define RPM_SMD_PNOC_A_CLK 27 -#define RPM_SMD_CNOC_CLK 28 -#define RPM_SMD_CNOC_A_CLK 29 -#define RPM_SMD_MMSSNOC_AHB_CLK 30 -#define RPM_SMD_MMSSNOC_AHB_A_CLK 31 -#define RPM_SMD_GFX3D_CLK_SRC 32 -#define RPM_SMD_GFX3D_A_CLK_SRC 33 -#define RPM_SMD_OCMEMGX_CLK 34 -#define RPM_SMD_OCMEMGX_A_CLK 35 -#define RPM_SMD_CXO_D0 36 -#define RPM_SMD_CXO_D0_A 37 -#define RPM_SMD_CXO_D1 38 -#define RPM_SMD_CXO_D1_A 39 -#define RPM_SMD_CXO_A0 40 -#define RPM_SMD_CXO_A0_A 41 -#define RPM_SMD_CXO_A1 42 -#define RPM_SMD_CXO_A1_A 43 -#define RPM_SMD_CXO_A2 44 -#define RPM_SMD_CXO_A2_A 45 -#define RPM_SMD_DIV_CLK1 46 -#define RPM_SMD_DIV_A_CLK1 47 -#define RPM_SMD_DIV_CLK2 48 -#define RPM_SMD_DIV_A_CLK2 49 -#define RPM_SMD_DIFF_CLK 50 -#define RPM_SMD_DIFF_A_CLK 51 -#define RPM_SMD_CXO_D0_PIN 52 -#define RPM_SMD_CXO_D0_A_PIN 53 -#define RPM_SMD_CXO_D1_PIN 54 -#define RPM_SMD_CXO_D1_A_PIN 55 -#define RPM_SMD_CXO_A0_PIN 56 -#define RPM_SMD_CXO_A0_A_PIN 57 -#define RPM_SMD_CXO_A1_PIN 58 -#define RPM_SMD_CXO_A1_A_PIN 59 -#define RPM_SMD_CXO_A2_PIN 60 -#define RPM_SMD_CXO_A2_A_PIN 61 -#define RPM_SMD_AGGR1_NOC_CLK 62 -#define RPM_SMD_AGGR1_NOC_A_CLK 63 -#define RPM_SMD_AGGR2_NOC_CLK 64 -#define RPM_SMD_AGGR2_NOC_A_CLK 65 -#define RPM_SMD_MMAXI_CLK 66 -#define RPM_SMD_MMAXI_A_CLK 67 -#define RPM_SMD_IPA_CLK 68 -#define RPM_SMD_IPA_A_CLK 69 -#define RPM_SMD_CE1_CLK 70 -#define RPM_SMD_CE1_A_CLK 71 -#define RPM_SMD_DIV_CLK3 72 -#define RPM_SMD_DIV_A_CLK3 73 -#define RPM_SMD_LN_BB_CLK 74 -#define RPM_SMD_LN_BB_A_CLK 75 -#define RPM_SMD_BIMC_GPU_CLK 76 -#define RPM_SMD_BIMC_GPU_A_CLK 77 -#define RPM_SMD_QPIC_CLK 78 -#define RPM_SMD_QPIC_CLK_A 79 -#define RPM_SMD_LN_BB_CLK1 80 -#define RPM_SMD_LN_BB_CLK1_A 81 -#define RPM_SMD_LN_BB_CLK2 82 -#define RPM_SMD_LN_BB_CLK2_A 83 -#define RPM_SMD_LN_BB_CLK3_PIN 84 -#define RPM_SMD_LN_BB_CLK3_A_PIN 85 -#define RPM_SMD_RF_CLK3 86 -#define RPM_SMD_RF_CLK3_A 87 -#define RPM_SMD_RF_CLK3_PIN 88 -#define RPM_SMD_RF_CLK3_A_PIN 89 -#define RPM_SMD_MMSSNOC_AXI_CLK 90 -#define RPM_SMD_MMSSNOC_AXI_CLK_A 91 -#define RPM_SMD_CNOC_PERIPH_CLK 92 -#define RPM_SMD_CNOC_PERIPH_A_CLK 93 -#define RPM_SMD_LN_BB_CLK3 94 -#define RPM_SMD_LN_BB_CLK3_A 95 -#define RPM_SMD_LN_BB_CLK1_PIN 96 -#define RPM_SMD_LN_BB_CLK1_A_PIN 97 -#define RPM_SMD_LN_BB_CLK2_PIN 98 -#define RPM_SMD_LN_BB_CLK2_A_PIN 99 -#define RPM_SMD_SYSMMNOC_CLK 100 -#define RPM_SMD_SYSMMNOC_A_CLK 101 -#define RPM_SMD_CE2_CLK 102 -#define RPM_SMD_CE2_A_CLK 103 -#define RPM_SMD_CE3_CLK 104 -#define RPM_SMD_CE3_A_CLK 105 -#define RPM_SMD_QUP_CLK 106 -#define RPM_SMD_QUP_A_CLK 107 -#define RPM_SMD_MMRT_CLK 108 -#define RPM_SMD_MMRT_A_CLK 109 -#define RPM_SMD_MMNRT_CLK 110 -#define RPM_SMD_MMNRT_A_CLK 111 -#define RPM_SMD_SNOC_PERIPH_CLK 112 -#define RPM_SMD_SNOC_PERIPH_A_CLK 113 -#define RPM_SMD_SNOC_LPASS_CLK 114 -#define RPM_SMD_SNOC_LPASS_A_CLK 115 -#define RPM_SMD_HWKM_CLK 116 -#define RPM_SMD_HWKM_A_CLK 117 -#define RPM_SMD_PKA_CLK 118 -#define RPM_SMD_PKA_A_CLK 119 -#define RPM_SMD_CPUSS_GNOC_CLK 120 -#define RPM_SMD_CPUSS_GNOC_A_CLK 121 -#define RPM_SMD_MSS_CFG_AHB_CLK 122 -#define RPM_SMD_MSS_CFG_AHB_A_CLK 123 -#define RPM_SMD_BIMC_FREQ_LOG 124 -#define RPM_SMD_LN_BB_CLK_PIN 125 -#define RPM_SMD_LN_BB_A_CLK_PIN 126 - -#endif diff --git a/include/dt-bindings/clock/qcom,rpmh.h b/include/dt-bindings/clock/qcom,rpmh.h deleted file mode 100644 index 0a7d1be0d124..000000000000 --- a/include/dt-bindings/clock/qcom,rpmh.h +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* Copyright (c) 2018, 2020, The Linux Foundation. All rights reserved. */ - - -#ifndef _DT_BINDINGS_CLK_MSM_RPMH_H -#define _DT_BINDINGS_CLK_MSM_RPMH_H - -/* RPMh controlled clocks */ -#define RPMH_CXO_CLK 0 -#define RPMH_CXO_CLK_A 1 -#define RPMH_LN_BB_CLK2 2 -#define RPMH_LN_BB_CLK2_A 3 -#define RPMH_LN_BB_CLK3 4 -#define RPMH_LN_BB_CLK3_A 5 -#define RPMH_RF_CLK1 6 -#define RPMH_RF_CLK1_A 7 -#define RPMH_RF_CLK2 8 -#define RPMH_RF_CLK2_A 9 -#define RPMH_RF_CLK3 10 -#define RPMH_RF_CLK3_A 11 -#define RPMH_IPA_CLK 12 -#define RPMH_LN_BB_CLK1 13 -#define RPMH_LN_BB_CLK1_A 14 -#define RPMH_CE_CLK 15 -#define RPMH_QPIC_CLK 16 -#define RPMH_DIV_CLK1 17 -#define RPMH_DIV_CLK1_A 18 -#define RPMH_RF_CLK4 19 -#define RPMH_RF_CLK4_A 20 -#define RPMH_RF_CLK5 21 -#define RPMH_RF_CLK5_A 22 -#define RPMH_PKA_CLK 23 -#define RPMH_HWKM_CLK 24 -#define RPMH_QLINK_CLK 25 -#define RPMH_QLINK_CLK_A 26 - -#endif diff --git a/include/dt-bindings/clock/qcom,turingcc-qcs404.h b/include/dt-bindings/clock/qcom,turingcc-qcs404.h deleted file mode 100644 index 838faef57c67..000000000000 --- a/include/dt-bindings/clock/qcom,turingcc-qcs404.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019, Linaro Ltd - */ - -#ifndef _DT_BINDINGS_CLK_TURING_QCS404_H -#define _DT_BINDINGS_CLK_TURING_QCS404_H - -#define TURING_Q6SS_Q6_AXIM_CLK 0 -#define TURING_Q6SS_AHBM_AON_CLK 1 -#define TURING_WRAPPER_AON_CLK 2 -#define TURING_Q6SS_AHBS_AON_CLK 3 -#define TURING_WRAPPER_QOS_AHBS_AON_CLK 4 - -#endif diff --git a/include/dt-bindings/clock/qcom,videocc-sdm845.h b/include/dt-bindings/clock/qcom,videocc-sdm845.h deleted file mode 100644 index 1b868165e8ce..000000000000 --- a/include/dt-bindings/clock/qcom,videocc-sdm845.h +++ /dev/null @@ -1,35 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_SDM_VIDEO_CC_SDM845_H -#define _DT_BINDINGS_CLK_SDM_VIDEO_CC_SDM845_H - -/* VIDEO_CC clock registers */ -#define VIDEO_CC_APB_CLK 0 -#define VIDEO_CC_AT_CLK 1 -#define VIDEO_CC_QDSS_TRIG_CLK 2 -#define VIDEO_CC_QDSS_TSCTR_DIV8_CLK 3 -#define VIDEO_CC_VCODEC0_AXI_CLK 4 -#define VIDEO_CC_VCODEC0_CORE_CLK 5 -#define VIDEO_CC_VCODEC1_AXI_CLK 6 -#define VIDEO_CC_VCODEC1_CORE_CLK 7 -#define VIDEO_CC_VENUS_AHB_CLK 8 -#define VIDEO_CC_VENUS_CLK_SRC 9 -#define VIDEO_CC_VENUS_CTL_AXI_CLK 10 -#define VIDEO_CC_VENUS_CTL_CORE_CLK 11 -#define VIDEO_PLL0 12 - -/* VIDEO_CC Resets */ -#define VIDEO_CC_VENUS_BCR 0 -#define VIDEO_CC_VCODEC0_BCR 1 -#define VIDEO_CC_VCODEC1_BCR 2 -#define VIDEO_CC_INTERFACE_BCR 3 - -/* VIDEO_CC GDSCRs */ -#define VENUS_GDSC 0 -#define VCODEC0_GDSC 1 -#define VCODEC1_GDSC 2 - -#endif
Drop in favour of dts/upstream
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/dma/qcom-gpi.h | 11 - include/dt-bindings/firmware/qcom,scm.h | 39 -- include/dt-bindings/iio/qcom,spmi-vadc.h | 300 --------------- include/dt-bindings/interconnect/qcom,msm8916.h | 100 ----- .../dt-bindings/interconnect/qcom,msm8996-cbf.h | 12 - include/dt-bindings/interconnect/qcom,msm8996.h | 163 -------- include/dt-bindings/interconnect/qcom,osm-l3.h | 15 - include/dt-bindings/interconnect/qcom,sdm845.h | 150 -------- include/dt-bindings/phy/phy-qcom-qmp.h | 20 - include/dt-bindings/phy/phy-qcom-qusb2.h | 37 -- include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 -------- include/dt-bindings/pinctrl/qcom,pmic-mpp.h | 106 ------ include/dt-bindings/power/qcom-rpmpd.h | 412 --------------------- .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 -- include/dt-bindings/reset/qcom,gcc-msm8916.h | 100 ----- include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 - include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 -- include/dt-bindings/soc/qcom,apr.h | 28 -- include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 - include/dt-bindings/sound/qcom,lpass.h | 46 --- include/dt-bindings/sound/qcom,q6afe.h | 9 - include/dt-bindings/sound/qcom,q6asm.h | 26 -- include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 ------------ include/dt-bindings/sound/qcom,wcd9335.h | 15 - 24 files changed, 2076 deletions(-)
diff --git a/include/dt-bindings/dma/qcom-gpi.h b/include/dt-bindings/dma/qcom-gpi.h deleted file mode 100644 index ebda2a37f52a..000000000000 --- a/include/dt-bindings/dma/qcom-gpi.h +++ /dev/null @@ -1,11 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR BSD-2-Clause */ -/* Copyright (c) 2020, Linaro Ltd. */ - -#ifndef __DT_BINDINGS_DMA_QCOM_GPI_H__ -#define __DT_BINDINGS_DMA_QCOM_GPI_H__ - -#define QCOM_GPI_SPI 1 -#define QCOM_GPI_UART 2 -#define QCOM_GPI_I2C 3 - -#endif /* __DT_BINDINGS_DMA_QCOM_GPI_H__ */ diff --git a/include/dt-bindings/firmware/qcom,scm.h b/include/dt-bindings/firmware/qcom,scm.h deleted file mode 100644 index 6de8b08e1e79..000000000000 --- a/include/dt-bindings/firmware/qcom,scm.h +++ /dev/null @@ -1,39 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -/* - * Copyright (c) 2010-2015, 2018-2019 The Linux Foundation. All rights reserved. - * Copyright (C) 2015 Linaro Ltd. - * Copyright (c) 2023 Qualcomm Innovation Center, Inc. All rights reserved. - */ - -#ifndef _DT_BINDINGS_FIRMWARE_QCOM_SCM_H -#define _DT_BINDINGS_FIRMWARE_QCOM_SCM_H - -#define QCOM_SCM_VMID_TZ 0x1 -#define QCOM_SCM_VMID_HLOS 0x3 -#define QCOM_SCM_VMID_SSC_Q6 0x5 -#define QCOM_SCM_VMID_ADSP_Q6 0x6 -#define QCOM_SCM_VMID_CP_TOUCH 0x8 -#define QCOM_SCM_VMID_CP_BITSTREAM 0x9 -#define QCOM_SCM_VMID_CP_PIXEL 0xA -#define QCOM_SCM_VMID_CP_NON_PIXEL 0xB -#define QCOM_SCM_VMID_CP_CAMERA 0xD -#define QCOM_SCM_VMID_HLOS_FREE 0xE -#define QCOM_SCM_VMID_MSS_MSA 0xF -#define QCOM_SCM_VMID_MSS_NONMSA 0x10 -#define QCOM_SCM_VMID_CP_SEC_DISPLAY 0x11 -#define QCOM_SCM_VMID_CP_APP 0x12 -#define QCOM_SCM_VMID_LPASS 0x16 -#define QCOM_SCM_VMID_WLAN 0x18 -#define QCOM_SCM_VMID_WLAN_CE 0x19 -#define QCOM_SCM_VMID_CP_SPSS_SP 0x1A -#define QCOM_SCM_VMID_CP_CAMERA_PREVIEW 0x1D -#define QCOM_SCM_VMID_CDSP 0x1E -#define QCOM_SCM_VMID_CP_SPSS_SP_SHARED 0x22 -#define QCOM_SCM_VMID_CP_SPSS_HLOS_SHARED 0x24 -#define QCOM_SCM_VMID_ADSP_HEAP 0x25 -#define QCOM_SCM_VMID_CP_CDSP 0x2A -#define QCOM_SCM_VMID_NAV 0x2B -#define QCOM_SCM_VMID_TVM 0x2D -#define QCOM_SCM_VMID_OEMVM 0x31 - -#endif diff --git a/include/dt-bindings/iio/qcom,spmi-vadc.h b/include/dt-bindings/iio/qcom,spmi-vadc.h deleted file mode 100644 index 08adfe25964c..000000000000 --- a/include/dt-bindings/iio/qcom,spmi-vadc.h +++ /dev/null @@ -1,300 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2012-2014,2018,2020 The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_QCOM_SPMI_VADC_H -#define _DT_BINDINGS_QCOM_SPMI_VADC_H - -/* Voltage ADC channels */ -#define VADC_USBIN 0x00 -#define VADC_DCIN 0x01 -#define VADC_VCHG_SNS 0x02 -#define VADC_SPARE1_03 0x03 -#define VADC_USB_ID_MV 0x04 -#define VADC_VCOIN 0x05 -#define VADC_VBAT_SNS 0x06 -#define VADC_VSYS 0x07 -#define VADC_DIE_TEMP 0x08 -#define VADC_REF_625MV 0x09 -#define VADC_REF_1250MV 0x0a -#define VADC_CHG_TEMP 0x0b -#define VADC_SPARE1 0x0c -#define VADC_SPARE2 0x0d -#define VADC_GND_REF 0x0e -#define VADC_VDD_VADC 0x0f - -#define VADC_P_MUX1_1_1 0x10 -#define VADC_P_MUX2_1_1 0x11 -#define VADC_P_MUX3_1_1 0x12 -#define VADC_P_MUX4_1_1 0x13 -#define VADC_P_MUX5_1_1 0x14 -#define VADC_P_MUX6_1_1 0x15 -#define VADC_P_MUX7_1_1 0x16 -#define VADC_P_MUX8_1_1 0x17 -#define VADC_P_MUX9_1_1 0x18 -#define VADC_P_MUX10_1_1 0x19 -#define VADC_P_MUX11_1_1 0x1a -#define VADC_P_MUX12_1_1 0x1b -#define VADC_P_MUX13_1_1 0x1c -#define VADC_P_MUX14_1_1 0x1d -#define VADC_P_MUX15_1_1 0x1e -#define VADC_P_MUX16_1_1 0x1f - -#define VADC_P_MUX1_1_3 0x20 -#define VADC_P_MUX2_1_3 0x21 -#define VADC_P_MUX3_1_3 0x22 -#define VADC_P_MUX4_1_3 0x23 -#define VADC_P_MUX5_1_3 0x24 -#define VADC_P_MUX6_1_3 0x25 -#define VADC_P_MUX7_1_3 0x26 -#define VADC_P_MUX8_1_3 0x27 -#define VADC_P_MUX9_1_3 0x28 -#define VADC_P_MUX10_1_3 0x29 -#define VADC_P_MUX11_1_3 0x2a -#define VADC_P_MUX12_1_3 0x2b -#define VADC_P_MUX13_1_3 0x2c -#define VADC_P_MUX14_1_3 0x2d -#define VADC_P_MUX15_1_3 0x2e -#define VADC_P_MUX16_1_3 0x2f - -#define VADC_LR_MUX1_BAT_THERM 0x30 -#define VADC_LR_MUX2_BAT_ID 0x31 -#define VADC_LR_MUX3_XO_THERM 0x32 -#define VADC_LR_MUX4_AMUX_THM1 0x33 -#define VADC_LR_MUX5_AMUX_THM2 0x34 -#define VADC_LR_MUX6_AMUX_THM3 0x35 -#define VADC_LR_MUX7_HW_ID 0x36 -#define VADC_LR_MUX8_AMUX_THM4 0x37 -#define VADC_LR_MUX9_AMUX_THM5 0x38 -#define VADC_LR_MUX10_USB_ID 0x39 -#define VADC_AMUX_PU1 0x3a -#define VADC_AMUX_PU2 0x3b -#define VADC_LR_MUX3_BUF_XO_THERM 0x3c - -#define VADC_LR_MUX1_PU1_BAT_THERM 0x70 -#define VADC_LR_MUX2_PU1_BAT_ID 0x71 -#define VADC_LR_MUX3_PU1_XO_THERM 0x72 -#define VADC_LR_MUX4_PU1_AMUX_THM1 0x73 -#define VADC_LR_MUX5_PU1_AMUX_THM2 0x74 -#define VADC_LR_MUX6_PU1_AMUX_THM3 0x75 -#define VADC_LR_MUX7_PU1_AMUX_HW_ID 0x76 -#define VADC_LR_MUX8_PU1_AMUX_THM4 0x77 -#define VADC_LR_MUX9_PU1_AMUX_THM5 0x78 -#define VADC_LR_MUX10_PU1_AMUX_USB_ID 0x79 -#define VADC_LR_MUX3_BUF_PU1_XO_THERM 0x7c - -#define VADC_LR_MUX1_PU2_BAT_THERM 0xb0 -#define VADC_LR_MUX2_PU2_BAT_ID 0xb1 -#define VADC_LR_MUX3_PU2_XO_THERM 0xb2 -#define VADC_LR_MUX4_PU2_AMUX_THM1 0xb3 -#define VADC_LR_MUX5_PU2_AMUX_THM2 0xb4 -#define VADC_LR_MUX6_PU2_AMUX_THM3 0xb5 -#define VADC_LR_MUX7_PU2_AMUX_HW_ID 0xb6 -#define VADC_LR_MUX8_PU2_AMUX_THM4 0xb7 -#define VADC_LR_MUX9_PU2_AMUX_THM5 0xb8 -#define VADC_LR_MUX10_PU2_AMUX_USB_ID 0xb9 -#define VADC_LR_MUX3_BUF_PU2_XO_THERM 0xbc - -#define VADC_LR_MUX1_PU1_PU2_BAT_THERM 0xf0 -#define VADC_LR_MUX2_PU1_PU2_BAT_ID 0xf1 -#define VADC_LR_MUX3_PU1_PU2_XO_THERM 0xf2 -#define VADC_LR_MUX4_PU1_PU2_AMUX_THM1 0xf3 -#define VADC_LR_MUX5_PU1_PU2_AMUX_THM2 0xf4 -#define VADC_LR_MUX6_PU1_PU2_AMUX_THM3 0xf5 -#define VADC_LR_MUX7_PU1_PU2_AMUX_HW_ID 0xf6 -#define VADC_LR_MUX8_PU1_PU2_AMUX_THM4 0xf7 -#define VADC_LR_MUX9_PU1_PU2_AMUX_THM5 0xf8 -#define VADC_LR_MUX10_PU1_PU2_AMUX_USB_ID 0xf9 -#define VADC_LR_MUX3_BUF_PU1_PU2_XO_THERM 0xfc - -/* ADC channels for SPMI PMIC5 */ - -#define ADC5_REF_GND 0x00 -#define ADC5_1P25VREF 0x01 -#define ADC5_VREF_VADC 0x02 -#define ADC5_VREF_VADC5_DIV_3 0x82 -#define ADC5_VPH_PWR 0x83 -#define ADC5_VBAT_SNS 0x84 -#define ADC5_VCOIN 0x85 -#define ADC5_DIE_TEMP 0x06 -#define ADC5_USB_IN_I 0x07 -#define ADC5_USB_IN_V_16 0x08 -#define ADC5_CHG_TEMP 0x09 -#define ADC5_BAT_THERM 0x0a -#define ADC5_BAT_ID 0x0b -#define ADC5_XO_THERM 0x0c -#define ADC5_AMUX_THM1 0x0d -#define ADC5_AMUX_THM2 0x0e -#define ADC5_AMUX_THM3 0x0f -#define ADC5_AMUX_THM4 0x10 -#define ADC5_AMUX_THM5 0x11 -#define ADC5_GPIO1 0x12 -#define ADC5_GPIO2 0x13 -#define ADC5_GPIO3 0x14 -#define ADC5_GPIO4 0x15 -#define ADC5_GPIO5 0x16 -#define ADC5_GPIO6 0x17 -#define ADC5_GPIO7 0x18 -#define ADC5_SBUx 0x99 -#define ADC5_MID_CHG_DIV6 0x1e -#define ADC5_OFF 0xff - -/* 30k pull-up1 */ -#define ADC5_BAT_THERM_30K_PU 0x2a -#define ADC5_BAT_ID_30K_PU 0x2b -#define ADC5_XO_THERM_30K_PU 0x2c -#define ADC5_AMUX_THM1_30K_PU 0x2d -#define ADC5_AMUX_THM2_30K_PU 0x2e -#define ADC5_AMUX_THM3_30K_PU 0x2f -#define ADC5_AMUX_THM4_30K_PU 0x30 -#define ADC5_AMUX_THM5_30K_PU 0x31 -#define ADC5_GPIO1_30K_PU 0x32 -#define ADC5_GPIO2_30K_PU 0x33 -#define ADC5_GPIO3_30K_PU 0x34 -#define ADC5_GPIO4_30K_PU 0x35 -#define ADC5_GPIO5_30K_PU 0x36 -#define ADC5_GPIO6_30K_PU 0x37 -#define ADC5_GPIO7_30K_PU 0x38 -#define ADC5_SBUx_30K_PU 0x39 - -/* 100k pull-up2 */ -#define ADC5_BAT_THERM_100K_PU 0x4a -#define ADC5_BAT_ID_100K_PU 0x4b -#define ADC5_XO_THERM_100K_PU 0x4c -#define ADC5_AMUX_THM1_100K_PU 0x4d -#define ADC5_AMUX_THM2_100K_PU 0x4e -#define ADC5_AMUX_THM3_100K_PU 0x4f -#define ADC5_AMUX_THM4_100K_PU 0x50 -#define ADC5_AMUX_THM5_100K_PU 0x51 -#define ADC5_GPIO1_100K_PU 0x52 -#define ADC5_GPIO2_100K_PU 0x53 -#define ADC5_GPIO3_100K_PU 0x54 -#define ADC5_GPIO4_100K_PU 0x55 -#define ADC5_GPIO5_100K_PU 0x56 -#define ADC5_GPIO6_100K_PU 0x57 -#define ADC5_GPIO7_100K_PU 0x58 -#define ADC5_SBUx_100K_PU 0x59 - -/* 400k pull-up3 */ -#define ADC5_BAT_THERM_400K_PU 0x6a -#define ADC5_BAT_ID_400K_PU 0x6b -#define ADC5_XO_THERM_400K_PU 0x6c -#define ADC5_AMUX_THM1_400K_PU 0x6d -#define ADC5_AMUX_THM2_400K_PU 0x6e -#define ADC5_AMUX_THM3_400K_PU 0x6f -#define ADC5_AMUX_THM4_400K_PU 0x70 -#define ADC5_AMUX_THM5_400K_PU 0x71 -#define ADC5_GPIO1_400K_PU 0x72 -#define ADC5_GPIO2_400K_PU 0x73 -#define ADC5_GPIO3_400K_PU 0x74 -#define ADC5_GPIO4_400K_PU 0x75 -#define ADC5_GPIO5_400K_PU 0x76 -#define ADC5_GPIO6_400K_PU 0x77 -#define ADC5_GPIO7_400K_PU 0x78 -#define ADC5_SBUx_400K_PU 0x79 - -/* 1/3 Divider */ -#define ADC5_GPIO1_DIV3 0x92 -#define ADC5_GPIO2_DIV3 0x93 -#define ADC5_GPIO3_DIV3 0x94 -#define ADC5_GPIO4_DIV3 0x95 -#define ADC5_GPIO5_DIV3 0x96 -#define ADC5_GPIO6_DIV3 0x97 -#define ADC5_GPIO7_DIV3 0x98 -#define ADC5_SBUx_DIV3 0x99 - -/* Current and combined current/voltage channels */ -#define ADC5_INT_EXT_ISENSE 0xa1 -#define ADC5_PARALLEL_ISENSE 0xa5 -#define ADC5_CUR_REPLICA_VDS 0xa7 -#define ADC5_CUR_SENS_BATFET_VDS_OFFSET 0xa9 -#define ADC5_CUR_SENS_REPLICA_VDS_OFFSET 0xab -#define ADC5_EXT_SENS_OFFSET 0xad - -#define ADC5_INT_EXT_ISENSE_VBAT_VDATA 0xb0 -#define ADC5_INT_EXT_ISENSE_VBAT_IDATA 0xb1 -#define ADC5_EXT_ISENSE_VBAT_VDATA 0xb2 -#define ADC5_EXT_ISENSE_VBAT_IDATA 0xb3 -#define ADC5_PARALLEL_ISENSE_VBAT_VDATA 0xb4 -#define ADC5_PARALLEL_ISENSE_VBAT_IDATA 0xb5 - -#define ADC5_MAX_CHANNEL 0xc0 - -/* ADC channels for ADC for PMIC7 */ - -#define ADC7_REF_GND 0x00 -#define ADC7_1P25VREF 0x01 -#define ADC7_VREF_VADC 0x02 -#define ADC7_DIE_TEMP 0x03 - -#define ADC7_AMUX_THM1 0x04 -#define ADC7_AMUX_THM2 0x05 -#define ADC7_AMUX_THM3 0x06 -#define ADC7_AMUX_THM4 0x07 -#define ADC7_AMUX_THM5 0x08 -#define ADC7_AMUX_THM6 0x09 -#define ADC7_GPIO1 0x0a -#define ADC7_GPIO2 0x0b -#define ADC7_GPIO3 0x0c -#define ADC7_GPIO4 0x0d - -#define ADC7_CHG_TEMP 0x10 -#define ADC7_USB_IN_V_16 0x11 -#define ADC7_VDC_16 0x12 -#define ADC7_CC1_ID 0x13 -#define ADC7_VREF_BAT_THERM 0x15 -#define ADC7_IIN_FB 0x17 - -/* 30k pull-up1 */ -#define ADC7_AMUX_THM1_30K_PU 0x24 -#define ADC7_AMUX_THM2_30K_PU 0x25 -#define ADC7_AMUX_THM3_30K_PU 0x26 -#define ADC7_AMUX_THM4_30K_PU 0x27 -#define ADC7_AMUX_THM5_30K_PU 0x28 -#define ADC7_AMUX_THM6_30K_PU 0x29 -#define ADC7_GPIO1_30K_PU 0x2a -#define ADC7_GPIO2_30K_PU 0x2b -#define ADC7_GPIO3_30K_PU 0x2c -#define ADC7_GPIO4_30K_PU 0x2d -#define ADC7_CC1_ID_30K_PU 0x33 - -/* 100k pull-up2 */ -#define ADC7_AMUX_THM1_100K_PU 0x44 -#define ADC7_AMUX_THM2_100K_PU 0x45 -#define ADC7_AMUX_THM3_100K_PU 0x46 -#define ADC7_AMUX_THM4_100K_PU 0x47 -#define ADC7_AMUX_THM5_100K_PU 0x48 -#define ADC7_AMUX_THM6_100K_PU 0x49 -#define ADC7_GPIO1_100K_PU 0x4a -#define ADC7_GPIO2_100K_PU 0x4b -#define ADC7_GPIO3_100K_PU 0x4c -#define ADC7_GPIO4_100K_PU 0x4d -#define ADC7_CC1_ID_100K_PU 0x53 - -/* 400k pull-up3 */ -#define ADC7_AMUX_THM1_400K_PU 0x64 -#define ADC7_AMUX_THM2_400K_PU 0x65 -#define ADC7_AMUX_THM3_400K_PU 0x66 -#define ADC7_AMUX_THM4_400K_PU 0x67 -#define ADC7_AMUX_THM5_400K_PU 0x68 -#define ADC7_AMUX_THM6_400K_PU 0x69 -#define ADC7_GPIO1_400K_PU 0x6a -#define ADC7_GPIO2_400K_PU 0x6b -#define ADC7_GPIO3_400K_PU 0x6c -#define ADC7_GPIO4_400K_PU 0x6d -#define ADC7_CC1_ID_400K_PU 0x73 - -/* 1/3 Divider */ -#define ADC7_GPIO1_DIV3 0x8a -#define ADC7_GPIO2_DIV3 0x8b -#define ADC7_GPIO3_DIV3 0x8c -#define ADC7_GPIO4_DIV3 0x8d - -#define ADC7_VPH_PWR 0x8e -#define ADC7_VBAT_SNS 0x8f - -#define ADC7_SBUx 0x94 -#define ADC7_VBAT_2S_MID 0x96 - -#endif /* _DT_BINDINGS_QCOM_SPMI_VADC_H */ diff --git a/include/dt-bindings/interconnect/qcom,msm8916.h b/include/dt-bindings/interconnect/qcom,msm8916.h deleted file mode 100644 index 359a75feb198..000000000000 --- a/include/dt-bindings/interconnect/qcom,msm8916.h +++ /dev/null @@ -1,100 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Qualcomm interconnect IDs - * - * Copyright (c) 2019, Linaro Ltd. - * Author: Georgi Djakov georgi.djakov@linaro.org - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8916_H -#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8916_H - -#define BIMC_SNOC_SLV 0 -#define MASTER_JPEG 1 -#define MASTER_MDP_PORT0 2 -#define MASTER_QDSS_BAM 3 -#define MASTER_QDSS_ETR 4 -#define MASTER_SNOC_CFG 5 -#define MASTER_VFE 6 -#define MASTER_VIDEO_P0 7 -#define SNOC_MM_INT_0 8 -#define SNOC_MM_INT_1 9 -#define SNOC_MM_INT_2 10 -#define SNOC_MM_INT_BIMC 11 -#define PCNOC_SNOC_SLV 12 -#define SLAVE_APSS 13 -#define SLAVE_CATS_128 14 -#define SLAVE_OCMEM_64 15 -#define SLAVE_IMEM 16 -#define SLAVE_QDSS_STM 17 -#define SLAVE_SRVC_SNOC 18 -#define SNOC_BIMC_0_MAS 19 -#define SNOC_BIMC_1_MAS 20 -#define SNOC_INT_0 21 -#define SNOC_INT_1 22 -#define SNOC_INT_BIMC 23 -#define SNOC_PCNOC_MAS 24 -#define SNOC_QDSS_INT 25 - -#define BIMC_SNOC_MAS 0 -#define MASTER_AMPSS_M0 1 -#define MASTER_GRAPHICS_3D 2 -#define MASTER_TCU0 3 -#define MASTER_TCU1 4 -#define SLAVE_AMPSS_L2 5 -#define SLAVE_EBI_CH0 6 -#define SNOC_BIMC_0_SLV 7 -#define SNOC_BIMC_1_SLV 8 - -#define MASTER_BLSP_1 0 -#define MASTER_DEHR 1 -#define MASTER_LPASS 2 -#define MASTER_CRYPTO_CORE0 3 -#define MASTER_SDCC_1 4 -#define MASTER_SDCC_2 5 -#define MASTER_SPDM 6 -#define MASTER_USB_HS 7 -#define PCNOC_INT_0 8 -#define PCNOC_INT_1 9 -#define PCNOC_MAS_0 10 -#define PCNOC_MAS_1 11 -#define PCNOC_SLV_0 12 -#define PCNOC_SLV_1 13 -#define PCNOC_SLV_2 14 -#define PCNOC_SLV_3 15 -#define PCNOC_SLV_4 16 -#define PCNOC_SLV_8 17 -#define PCNOC_SLV_9 18 -#define PCNOC_SNOC_MAS 19 -#define SLAVE_BIMC_CFG 20 -#define SLAVE_BLSP_1 21 -#define SLAVE_BOOT_ROM 22 -#define SLAVE_CAMERA_CFG 23 -#define SLAVE_CLK_CTL 24 -#define SLAVE_CRYPTO_0_CFG 25 -#define SLAVE_DEHR_CFG 26 -#define SLAVE_DISPLAY_CFG 27 -#define SLAVE_GRAPHICS_3D_CFG 28 -#define SLAVE_IMEM_CFG 29 -#define SLAVE_LPASS 30 -#define SLAVE_MPM 31 -#define SLAVE_MSG_RAM 32 -#define SLAVE_MSS 33 -#define SLAVE_PDM 34 -#define SLAVE_PMIC_ARB 35 -#define SLAVE_PCNOC_CFG 36 -#define SLAVE_PRNG 37 -#define SLAVE_QDSS_CFG 38 -#define SLAVE_RBCPR_CFG 39 -#define SLAVE_SDCC_1 40 -#define SLAVE_SDCC_2 41 -#define SLAVE_SECURITY 42 -#define SLAVE_SNOC_CFG 43 -#define SLAVE_SPDM 44 -#define SLAVE_TCSR 45 -#define SLAVE_TLMM 46 -#define SLAVE_USB_HS 47 -#define SLAVE_VENUS_CFG 48 -#define SNOC_PCNOC_SLV 49 - -#endif diff --git a/include/dt-bindings/interconnect/qcom,msm8996-cbf.h b/include/dt-bindings/interconnect/qcom,msm8996-cbf.h deleted file mode 100644 index aac5e69f6bd5..000000000000 --- a/include/dt-bindings/interconnect/qcom,msm8996-cbf.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * Copyright (C) 2023 Linaro Ltd. All rights reserved. - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_CBF_H -#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_CBF_H - -#define MASTER_CBF_M4M 0 -#define SLAVE_CBF_M4M 1 - -#endif diff --git a/include/dt-bindings/interconnect/qcom,msm8996.h b/include/dt-bindings/interconnect/qcom,msm8996.h deleted file mode 100644 index a0b7c0ec7bed..000000000000 --- a/include/dt-bindings/interconnect/qcom,msm8996.h +++ /dev/null @@ -1,163 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-3-Clause) */ -/* - * Qualcomm MSM8996 interconnect IDs - * - * Copyright (c) 2021 Yassine Oudjana y.oudjana@protonmail.com - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_H -#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_H - -/* A0NOC */ -#define MASTER_PCIE_0 0 -#define MASTER_PCIE_1 1 -#define MASTER_PCIE_2 2 - -/* A1NOC */ -#define MASTER_CNOC_A1NOC 0 -#define MASTER_CRYPTO_CORE0 1 -#define MASTER_PNOC_A1NOC 2 - -/* A2NOC */ -#define MASTER_USB3 0 -#define MASTER_IPA 1 -#define MASTER_UFS 2 - -/* BIMC */ -#define MASTER_AMPSS_M0 0 -#define MASTER_GRAPHICS_3D 1 -#define MASTER_MNOC_BIMC 2 -#define MASTER_SNOC_BIMC 3 -#define SLAVE_EBI_CH0 4 -#define SLAVE_HMSS_L3 5 -#define SLAVE_BIMC_SNOC_0 6 -#define SLAVE_BIMC_SNOC_1 7 - -/* CNOC */ -#define MASTER_SNOC_CNOC 0 -#define MASTER_QDSS_DAP 1 -#define SLAVE_CNOC_A1NOC 2 -#define SLAVE_CLK_CTL 3 -#define SLAVE_TCSR 4 -#define SLAVE_TLMM 5 -#define SLAVE_CRYPTO_0_CFG 6 -#define SLAVE_MPM 7 -#define SLAVE_PIMEM_CFG 8 -#define SLAVE_IMEM_CFG 9 -#define SLAVE_MESSAGE_RAM 10 -#define SLAVE_BIMC_CFG 11 -#define SLAVE_PMIC_ARB 12 -#define SLAVE_PRNG 13 -#define SLAVE_DCC_CFG 14 -#define SLAVE_RBCPR_MX 15 -#define SLAVE_QDSS_CFG 16 -#define SLAVE_RBCPR_CX 17 -#define SLAVE_QDSS_RBCPR_APU 18 -#define SLAVE_CNOC_MNOC_CFG 19 -#define SLAVE_SNOC_CFG 20 -#define SLAVE_SNOC_MPU_CFG 21 -#define SLAVE_EBI1_PHY_CFG 22 -#define SLAVE_A0NOC_CFG 23 -#define SLAVE_PCIE_1_CFG 24 -#define SLAVE_PCIE_2_CFG 25 -#define SLAVE_PCIE_0_CFG 26 -#define SLAVE_PCIE20_AHB2PHY 27 -#define SLAVE_A0NOC_MPU_CFG 28 -#define SLAVE_UFS_CFG 29 -#define SLAVE_A1NOC_CFG 30 -#define SLAVE_A1NOC_MPU_CFG 31 -#define SLAVE_A2NOC_CFG 32 -#define SLAVE_A2NOC_MPU_CFG 33 -#define SLAVE_SSC_CFG 34 -#define SLAVE_A0NOC_SMMU_CFG 35 -#define SLAVE_A1NOC_SMMU_CFG 36 -#define SLAVE_A2NOC_SMMU_CFG 37 -#define SLAVE_LPASS_SMMU_CFG 38 -#define SLAVE_CNOC_MNOC_MMSS_CFG 39 - -/* MNOC */ -#define MASTER_CNOC_MNOC_CFG 0 -#define MASTER_CPP 1 -#define MASTER_JPEG 2 -#define MASTER_MDP_PORT0 3 -#define MASTER_MDP_PORT1 4 -#define MASTER_ROTATOR 5 -#define MASTER_VIDEO_P0 6 -#define MASTER_VFE 7 -#define MASTER_SNOC_VMEM 8 -#define MASTER_VIDEO_P0_OCMEM 9 -#define MASTER_CNOC_MNOC_MMSS_CFG 10 -#define SLAVE_MNOC_BIMC 11 -#define SLAVE_VMEM 12 -#define SLAVE_SERVICE_MNOC 13 -#define SLAVE_MMAGIC_CFG 14 -#define SLAVE_CPR_CFG 15 -#define SLAVE_MISC_CFG 16 -#define SLAVE_VENUS_THROTTLE_CFG 17 -#define SLAVE_VENUS_CFG 18 -#define SLAVE_VMEM_CFG 19 -#define SLAVE_DSA_CFG 20 -#define SLAVE_MMSS_CLK_CFG 21 -#define SLAVE_DSA_MPU_CFG 22 -#define SLAVE_MNOC_MPU_CFG 23 -#define SLAVE_DISPLAY_CFG 24 -#define SLAVE_DISPLAY_THROTTLE_CFG 25 -#define SLAVE_CAMERA_CFG 26 -#define SLAVE_CAMERA_THROTTLE_CFG 27 -#define SLAVE_GRAPHICS_3D_CFG 28 -#define SLAVE_SMMU_MDP_CFG 29 -#define SLAVE_SMMU_ROT_CFG 30 -#define SLAVE_SMMU_VENUS_CFG 31 -#define SLAVE_SMMU_CPP_CFG 32 -#define SLAVE_SMMU_JPEG_CFG 33 -#define SLAVE_SMMU_VFE_CFG 34 - -/* PNOC */ -#define MASTER_SNOC_PNOC 0 -#define MASTER_SDCC_1 1 -#define MASTER_SDCC_2 2 -#define MASTER_SDCC_4 3 -#define MASTER_USB_HS 4 -#define MASTER_BLSP_1 5 -#define MASTER_BLSP_2 6 -#define MASTER_TSIF 7 -#define SLAVE_PNOC_A1NOC 8 -#define SLAVE_USB_HS 9 -#define SLAVE_SDCC_2 10 -#define SLAVE_SDCC_4 11 -#define SLAVE_TSIF 12 -#define SLAVE_BLSP_2 13 -#define SLAVE_SDCC_1 14 -#define SLAVE_BLSP_1 15 -#define SLAVE_PDM 16 -#define SLAVE_AHB2PHY 17 - -/* SNOC */ -#define MASTER_HMSS 0 -#define MASTER_QDSS_BAM 1 -#define MASTER_SNOC_CFG 2 -#define MASTER_BIMC_SNOC_0 3 -#define MASTER_BIMC_SNOC_1 4 -#define MASTER_A0NOC_SNOC 5 -#define MASTER_A1NOC_SNOC 6 -#define MASTER_A2NOC_SNOC 7 -#define MASTER_QDSS_ETR 8 -#define SLAVE_A0NOC_SNOC 9 -#define SLAVE_A1NOC_SNOC 10 -#define SLAVE_A2NOC_SNOC 11 -#define SLAVE_HMSS 12 -#define SLAVE_LPASS 13 -#define SLAVE_USB3 14 -#define SLAVE_SNOC_BIMC 15 -#define SLAVE_SNOC_CNOC 16 -#define SLAVE_IMEM 17 -#define SLAVE_PIMEM 18 -#define SLAVE_SNOC_VMEM 19 -#define SLAVE_SNOC_PNOC 20 -#define SLAVE_QDSS_STM 21 -#define SLAVE_PCIE_0 22 -#define SLAVE_PCIE_1 23 -#define SLAVE_PCIE_2 24 -#define SLAVE_SERVICE_SNOC 25 - -#endif diff --git a/include/dt-bindings/interconnect/qcom,osm-l3.h b/include/dt-bindings/interconnect/qcom,osm-l3.h deleted file mode 100644 index 61ef649ae565..000000000000 --- a/include/dt-bindings/interconnect/qcom,osm-l3.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2019 The Linux Foundation. All rights reserved. - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H -#define __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H - -#define MASTER_OSM_L3_APPS 0 -#define SLAVE_OSM_L3 1 - -#define MASTER_EPSS_L3_APPS 0 -#define SLAVE_EPSS_L3_SHARED 1 - -#endif diff --git a/include/dt-bindings/interconnect/qcom,sdm845.h b/include/dt-bindings/interconnect/qcom,sdm845.h deleted file mode 100644 index 67b500e24915..000000000000 --- a/include/dt-bindings/interconnect/qcom,sdm845.h +++ /dev/null @@ -1,150 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Qualcomm SDM845 interconnect IDs - * - * Copyright (c) 2018, Linaro Ltd. - * Author: Georgi Djakov georgi.djakov@linaro.org - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_SDM845_H -#define __DT_BINDINGS_INTERCONNECT_QCOM_SDM845_H - -#define MASTER_A1NOC_CFG 0 -#define MASTER_TSIF 1 -#define MASTER_SDCC_2 2 -#define MASTER_SDCC_4 3 -#define MASTER_UFS_CARD 4 -#define MASTER_UFS_MEM 5 -#define MASTER_PCIE_0 6 -#define SLAVE_A1NOC_SNOC 7 -#define SLAVE_SERVICE_A1NOC 8 -#define SLAVE_ANOC_PCIE_A1NOC_SNOC 9 -#define MASTER_QUP_1 10 - -#define MASTER_A2NOC_CFG 0 -#define MASTER_QDSS_BAM 1 -#define MASTER_CNOC_A2NOC 2 -#define MASTER_CRYPTO 3 -#define MASTER_IPA 4 -#define MASTER_PCIE_1 5 -#define MASTER_QDSS_ETR 6 -#define MASTER_USB3_0 7 -#define MASTER_USB3_1 8 -#define SLAVE_A2NOC_SNOC 9 -#define SLAVE_ANOC_PCIE_SNOC 10 -#define SLAVE_SERVICE_A2NOC 11 -#define MASTER_QUP_2 12 - -#define MASTER_SPDM 0 -#define MASTER_TIC 1 -#define MASTER_SNOC_CNOC 2 -#define MASTER_QDSS_DAP 3 -#define SLAVE_A1NOC_CFG 4 -#define SLAVE_A2NOC_CFG 5 -#define SLAVE_AOP 6 -#define SLAVE_AOSS 7 -#define SLAVE_CAMERA_CFG 8 -#define SLAVE_CLK_CTL 9 -#define SLAVE_CDSP_CFG 10 -#define SLAVE_RBCPR_CX_CFG 11 -#define SLAVE_CRYPTO_0_CFG 12 -#define SLAVE_DCC_CFG 13 -#define SLAVE_CNOC_DDRSS 14 -#define SLAVE_DISPLAY_CFG 15 -#define SLAVE_GLM 16 -#define SLAVE_GFX3D_CFG 17 -#define SLAVE_IMEM_CFG 18 -#define SLAVE_IPA_CFG 19 -#define SLAVE_CNOC_MNOC_CFG 20 -#define SLAVE_PCIE_0_CFG 21 -#define SLAVE_PCIE_1_CFG 22 -#define SLAVE_PDM 23 -#define SLAVE_SOUTH_PHY_CFG 24 -#define SLAVE_PIMEM_CFG 25 -#define SLAVE_PRNG 26 -#define SLAVE_QDSS_CFG 27 -#define SLAVE_BLSP_2 28 -#define SLAVE_BLSP_1 29 -#define SLAVE_SDCC_2 30 -#define SLAVE_SDCC_4 31 -#define SLAVE_SNOC_CFG 32 -#define SLAVE_SPDM_WRAPPER 33 -#define SLAVE_SPSS_CFG 34 -#define SLAVE_TCSR 35 -#define SLAVE_TLMM_NORTH 36 -#define SLAVE_TLMM_SOUTH 37 -#define SLAVE_TSIF 38 -#define SLAVE_UFS_CARD_CFG 39 -#define SLAVE_UFS_MEM_CFG 40 -#define SLAVE_USB3_0 41 -#define SLAVE_USB3_1 42 -#define SLAVE_VENUS_CFG 43 -#define SLAVE_VSENSE_CTRL_CFG 44 -#define SLAVE_CNOC_A2NOC 45 -#define SLAVE_SERVICE_CNOC 46 - -#define MASTER_CNOC_DC_NOC 0 -#define SLAVE_LLCC_CFG 1 -#define SLAVE_MEM_NOC_CFG 2 - -#define MASTER_APPSS_PROC 0 -#define MASTER_GNOC_CFG 1 -#define SLAVE_GNOC_SNOC 2 -#define SLAVE_GNOC_MEM_NOC 3 -#define SLAVE_SERVICE_GNOC 4 - -#define MASTER_TCU_0 0 -#define MASTER_MEM_NOC_CFG 1 -#define MASTER_GNOC_MEM_NOC 2 -#define MASTER_MNOC_HF_MEM_NOC 3 -#define MASTER_MNOC_SF_MEM_NOC 4 -#define MASTER_SNOC_GC_MEM_NOC 5 -#define MASTER_SNOC_SF_MEM_NOC 6 -#define MASTER_GFX3D 7 -#define SLAVE_MSS_PROC_MS_MPU_CFG 8 -#define SLAVE_MEM_NOC_GNOC 9 -#define SLAVE_LLCC 10 -#define SLAVE_MEM_NOC_SNOC 11 -#define SLAVE_SERVICE_MEM_NOC 12 -#define MASTER_LLCC 13 -#define SLAVE_EBI1 14 - -#define MASTER_CNOC_MNOC_CFG 0 -#define MASTER_CAMNOC_HF0 1 -#define MASTER_CAMNOC_HF1 2 -#define MASTER_CAMNOC_SF 3 -#define MASTER_MDP0 4 -#define MASTER_MDP1 5 -#define MASTER_ROTATOR 6 -#define MASTER_VIDEO_P0 7 -#define MASTER_VIDEO_P1 8 -#define MASTER_VIDEO_PROC 9 -#define SLAVE_MNOC_SF_MEM_NOC 10 -#define SLAVE_MNOC_HF_MEM_NOC 11 -#define SLAVE_SERVICE_MNOC 12 -#define MASTER_CAMNOC_HF0_UNCOMP 13 -#define MASTER_CAMNOC_HF1_UNCOMP 14 -#define MASTER_CAMNOC_SF_UNCOMP 15 -#define SLAVE_CAMNOC_UNCOMP 16 - -#define MASTER_SNOC_CFG 0 -#define MASTER_A1NOC_SNOC 1 -#define MASTER_A2NOC_SNOC 2 -#define MASTER_GNOC_SNOC 3 -#define MASTER_MEM_NOC_SNOC 4 -#define MASTER_ANOC_PCIE_SNOC 5 -#define MASTER_PIMEM 6 -#define MASTER_GIC 7 -#define SLAVE_APPSS 8 -#define SLAVE_SNOC_CNOC 9 -#define SLAVE_SNOC_MEM_NOC_GC 10 -#define SLAVE_SNOC_MEM_NOC_SF 11 -#define SLAVE_IMEM 12 -#define SLAVE_PCIE_0 13 -#define SLAVE_PCIE_1 14 -#define SLAVE_PIMEM 15 -#define SLAVE_SERVICE_SNOC 16 -#define SLAVE_QDSS_STM 17 -#define SLAVE_TCU 18 - -#endif diff --git a/include/dt-bindings/phy/phy-qcom-qmp.h b/include/dt-bindings/phy/phy-qcom-qmp.h deleted file mode 100644 index 4edec4c5b224..000000000000 --- a/include/dt-bindings/phy/phy-qcom-qmp.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) */ -/* - * Qualcomm QMP PHY constants - * - * Copyright (C) 2022 Linaro Limited - */ - -#ifndef _DT_BINDINGS_PHY_QMP -#define _DT_BINDINGS_PHY_QMP - -/* QMP USB4-USB3-DP clocks */ -#define QMP_USB43DP_USB3_PIPE_CLK 0 -#define QMP_USB43DP_DP_LINK_CLK 1 -#define QMP_USB43DP_DP_VCO_DIV_CLK 2 - -/* QMP USB4-USB3-DP PHYs */ -#define QMP_USB43DP_USB3_PHY 0 -#define QMP_USB43DP_DP_PHY 1 - -#endif /* _DT_BINDINGS_PHY_QMP */ diff --git a/include/dt-bindings/phy/phy-qcom-qusb2.h b/include/dt-bindings/phy/phy-qcom-qusb2.h deleted file mode 100644 index 5c5e4d800cac..000000000000 --- a/include/dt-bindings/phy/phy-qcom-qusb2.h +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_QCOM_PHY_QUSB2_H_ -#define _DT_BINDINGS_QCOM_PHY_QUSB2_H_ - -/* PHY HSTX TRIM bit values (24mA to 15mA) */ -#define QUSB2_V2_HSTX_TRIM_24_0_MA 0x0 -#define QUSB2_V2_HSTX_TRIM_23_4_MA 0x1 -#define QUSB2_V2_HSTX_TRIM_22_8_MA 0x2 -#define QUSB2_V2_HSTX_TRIM_22_2_MA 0x3 -#define QUSB2_V2_HSTX_TRIM_21_6_MA 0x4 -#define QUSB2_V2_HSTX_TRIM_21_0_MA 0x5 -#define QUSB2_V2_HSTX_TRIM_20_4_MA 0x6 -#define QUSB2_V2_HSTX_TRIM_19_8_MA 0x7 -#define QUSB2_V2_HSTX_TRIM_19_2_MA 0x8 -#define QUSB2_V2_HSTX_TRIM_18_6_MA 0x9 -#define QUSB2_V2_HSTX_TRIM_18_0_MA 0xa -#define QUSB2_V2_HSTX_TRIM_17_4_MA 0xb -#define QUSB2_V2_HSTX_TRIM_16_8_MA 0xc -#define QUSB2_V2_HSTX_TRIM_16_2_MA 0xd -#define QUSB2_V2_HSTX_TRIM_15_6_MA 0xe -#define QUSB2_V2_HSTX_TRIM_15_0_MA 0xf - -/* PHY PREEMPHASIS bit values */ -#define QUSB2_V2_PREEMPHASIS_NONE 0 -#define QUSB2_V2_PREEMPHASIS_5_PERCENT 1 -#define QUSB2_V2_PREEMPHASIS_10_PERCENT 2 -#define QUSB2_V2_PREEMPHASIS_15_PERCENT 3 - -/* PHY PREEMPHASIS-WIDTH bit values */ -#define QUSB2_V2_PREEMPHASIS_WIDTH_FULL_BIT 0 -#define QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT 1 - -#endif diff --git a/include/dt-bindings/pinctrl/qcom,pmic-gpio.h b/include/dt-bindings/pinctrl/qcom,pmic-gpio.h deleted file mode 100644 index e5df5ce45a0f..000000000000 --- a/include/dt-bindings/pinctrl/qcom,pmic-gpio.h +++ /dev/null @@ -1,164 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the Qualcomm PMIC GPIO binding. - */ - -#ifndef _DT_BINDINGS_PINCTRL_QCOM_PMIC_GPIO_H -#define _DT_BINDINGS_PINCTRL_QCOM_PMIC_GPIO_H - -#define PMIC_GPIO_PULL_UP_30 0 -#define PMIC_GPIO_PULL_UP_1P5 1 -#define PMIC_GPIO_PULL_UP_31P5 2 -#define PMIC_GPIO_PULL_UP_1P5_30 3 - -#define PMIC_GPIO_STRENGTH_NO 0 -#define PMIC_GPIO_STRENGTH_HIGH 1 -#define PMIC_GPIO_STRENGTH_MED 2 -#define PMIC_GPIO_STRENGTH_LOW 3 - -/* - * Note: PM8018 GPIO3 and GPIO4 are supporting - * only S3 and L2 options (1.8V) - */ -#define PM8018_GPIO_L6 0 -#define PM8018_GPIO_L5 1 -#define PM8018_GPIO_S3 2 -#define PM8018_GPIO_L14 3 -#define PM8018_GPIO_L2 4 -#define PM8018_GPIO_L4 5 -#define PM8018_GPIO_VDD 6 - -/* - * Note: PM8038 GPIO7 and GPIO8 are supporting - * only L11 and L4 options (1.8V) - */ -#define PM8038_GPIO_VPH 0 -#define PM8038_GPIO_BB 1 -#define PM8038_GPIO_L11 2 -#define PM8038_GPIO_L15 3 -#define PM8038_GPIO_L4 4 -#define PM8038_GPIO_L3 5 -#define PM8038_GPIO_L17 6 - -#define PM8058_GPIO_VPH 0 -#define PM8058_GPIO_BB 1 -#define PM8058_GPIO_S3 2 -#define PM8058_GPIO_L3 3 -#define PM8058_GPIO_L7 4 -#define PM8058_GPIO_L6 5 -#define PM8058_GPIO_L5 6 -#define PM8058_GPIO_L2 7 - -/* - * Note: PM8916 GPIO1 and GPIO2 are supporting - * only L2(1.15V) and L5(1.8V) options - */ -#define PM8916_GPIO_VPH 0 -#define PM8916_GPIO_L2 2 -#define PM8916_GPIO_L5 3 - -#define PM8917_GPIO_VPH 0 -#define PM8917_GPIO_S4 2 -#define PM8917_GPIO_L15 3 -#define PM8917_GPIO_L4 4 -#define PM8917_GPIO_L3 5 -#define PM8917_GPIO_L17 6 - -#define PM8921_GPIO_VPH 0 -#define PM8921_GPIO_BB 1 -#define PM8921_GPIO_S4 2 -#define PM8921_GPIO_L15 3 -#define PM8921_GPIO_L4 4 -#define PM8921_GPIO_L3 5 -#define PM8921_GPIO_L17 6 - -/* - * Note: PM8941 gpios from 15 to 18 are supporting - * only S3 and L6 options (1.8V) - */ -#define PM8941_GPIO_VPH 0 -#define PM8941_GPIO_L1 1 -#define PM8941_GPIO_S3 2 -#define PM8941_GPIO_L6 3 - -/* - * Note: PMA8084 gpios from 15 to 18 are supporting - * only S4 and L6 options (1.8V) - */ -#define PMA8084_GPIO_VPH 0 -#define PMA8084_GPIO_L1 1 -#define PMA8084_GPIO_S4 2 -#define PMA8084_GPIO_L6 3 - -#define PM8994_GPIO_VPH 0 -#define PM8994_GPIO_S4 2 -#define PM8994_GPIO_L12 3 - -/* To be used with "function" */ -#define PMIC_GPIO_FUNC_NORMAL "normal" -#define PMIC_GPIO_FUNC_PAIRED "paired" -#define PMIC_GPIO_FUNC_FUNC1 "func1" -#define PMIC_GPIO_FUNC_FUNC2 "func2" -#define PMIC_GPIO_FUNC_FUNC3 "func3" -#define PMIC_GPIO_FUNC_FUNC4 "func4" -#define PMIC_GPIO_FUNC_DTEST1 "dtest1" -#define PMIC_GPIO_FUNC_DTEST2 "dtest2" -#define PMIC_GPIO_FUNC_DTEST3 "dtest3" -#define PMIC_GPIO_FUNC_DTEST4 "dtest4" - -#define PM8038_GPIO1_2_LPG_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO3_5V_BOOST_EN PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO4_SSBI_ALT_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO5_6_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO10_11_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO6_7_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO9_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 -#define PM8038_GPIO6_12_KYPD_DRV PMIC_GPIO_FUNC_FUNC2 - -#define PM8058_GPIO7_8_MP3_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO7_8_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC2 -#define PM8058_GPIO9_26_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO21_23_UART_TX PMIC_GPIO_FUNC_FUNC2 -#define PM8058_GPIO24_26_LPG_DRV PMIC_GPIO_FUNC_FUNC2 -#define PM8058_GPIO33_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO34_35_MP3_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO36_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO37_UPL_OUT PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO37_UART_M_RX PMIC_GPIO_FUNC_FUNC2 -#define PM8058_GPIO38_XO_SLEEP_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO38_39_CLK_32KHZ PMIC_GPIO_FUNC_FUNC2 -#define PM8058_GPIO39_MP3_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8058_GPIO40_EXT_BB_EN PMIC_GPIO_FUNC_FUNC1 - -#define PM8916_GPIO1_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 -#define PM8916_GPIO1_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 -#define PM8916_GPIO2_DIV_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8916_GPIO2_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 -#define PM8916_GPIO3_KEYP_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8916_GPIO4_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 - -#define PM8917_GPIO9_18_KEYP_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8917_GPIO20_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 -#define PM8917_GPIO21_23_UART_TX PMIC_GPIO_FUNC_FUNC2 -#define PM8917_GPIO25_26_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 -#define PM8917_GPIO37_38_XO_SLEEP_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8917_GPIO37_38_MP3_CLK PMIC_GPIO_FUNC_FUNC2 - -#define PM8941_GPIO9_14_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8941_GPIO15_18_DIV_CLK PMIC_GPIO_FUNC_FUNC1 -#define PM8941_GPIO15_18_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 -#define PM8941_GPIO23_26_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 -#define PM8941_GPIO23_26_LPG_DRV_HI PMIC_GPIO_FUNC_FUNC2 -#define PM8941_GPIO31_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 -#define PM8941_GPIO33_36_LPG_DRV_3D PMIC_GPIO_FUNC_FUNC1 -#define PM8941_GPIO33_36_LPG_DRV_HI PMIC_GPIO_FUNC_FUNC2 - -#define PMA8084_GPIO4_5_LPG_DRV PMIC_GPIO_FUNC_FUNC1 -#define PMA8084_GPIO7_10_LPG_DRV PMIC_GPIO_FUNC_FUNC1 -#define PMA8084_GPIO5_14_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 -#define PMA8084_GPIO19_21_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 -#define PMA8084_GPIO15_18_DIV_CLK PMIC_GPIO_FUNC_FUNC1 -#define PMA8084_GPIO15_18_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 -#define PMA8084_GPIO22_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 - -#endif diff --git a/include/dt-bindings/pinctrl/qcom,pmic-mpp.h b/include/dt-bindings/pinctrl/qcom,pmic-mpp.h deleted file mode 100644 index 32e66ee7e830..000000000000 --- a/include/dt-bindings/pinctrl/qcom,pmic-mpp.h +++ /dev/null @@ -1,106 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the Qualcomm PMIC's - * Multi-Purpose Pin binding. - */ - -#ifndef _DT_BINDINGS_PINCTRL_QCOM_PMIC_MPP_H -#define _DT_BINDINGS_PINCTRL_QCOM_PMIC_MPP_H - -/* power-source */ - -/* Digital Input/Output: level [PM8058] */ -#define PM8058_MPP_VPH 0 -#define PM8058_MPP_S3 1 -#define PM8058_MPP_L2 2 -#define PM8058_MPP_L3 3 - -/* Digital Input/Output: level [PM8901] */ -#define PM8901_MPP_MSMIO 0 -#define PM8901_MPP_DIG 1 -#define PM8901_MPP_L5 2 -#define PM8901_MPP_S4 3 -#define PM8901_MPP_VPH 4 - -/* Digital Input/Output: level [PM8921] */ -#define PM8921_MPP_S4 1 -#define PM8921_MPP_L15 3 -#define PM8921_MPP_L17 4 -#define PM8921_MPP_VPH 7 - -/* Digital Input/Output: level [PM8821] */ -#define PM8821_MPP_1P8 0 -#define PM8821_MPP_VPH 7 - -/* Digital Input/Output: level [PM8018] */ -#define PM8018_MPP_L4 0 -#define PM8018_MPP_L14 1 -#define PM8018_MPP_S3 2 -#define PM8018_MPP_L6 3 -#define PM8018_MPP_L2 4 -#define PM8018_MPP_L5 5 -#define PM8018_MPP_VPH 7 - -/* Digital Input/Output: level [PM8038] */ -#define PM8038_MPP_L20 0 -#define PM8038_MPP_L11 1 -#define PM8038_MPP_L5 2 -#define PM8038_MPP_L15 3 -#define PM8038_MPP_L17 4 -#define PM8038_MPP_VPH 7 - -#define PM8841_MPP_VPH 0 -#define PM8841_MPP_S3 2 - -#define PM8916_MPP_VPH 0 -#define PM8916_MPP_L2 2 -#define PM8916_MPP_L5 3 - -#define PM8941_MPP_VPH 0 -#define PM8941_MPP_L1 1 -#define PM8941_MPP_S3 2 -#define PM8941_MPP_L6 3 - -#define PMA8084_MPP_VPH 0 -#define PMA8084_MPP_L1 1 -#define PMA8084_MPP_S4 2 -#define PMA8084_MPP_L6 3 - -#define PM8994_MPP_VPH 0 -/* Only supported for MPP_05-MPP_08 */ -#define PM8994_MPP_L19 1 -#define PM8994_MPP_S4 2 -#define PM8994_MPP_L12 3 - -/* - * Analog Input - Set the source for analog input. - * To be used with "qcom,amux-route" property - */ -#define PMIC_MPP_AMUX_ROUTE_CH5 0 -#define PMIC_MPP_AMUX_ROUTE_CH6 1 -#define PMIC_MPP_AMUX_ROUTE_CH7 2 -#define PMIC_MPP_AMUX_ROUTE_CH8 3 -#define PMIC_MPP_AMUX_ROUTE_ABUS1 4 -#define PMIC_MPP_AMUX_ROUTE_ABUS2 5 -#define PMIC_MPP_AMUX_ROUTE_ABUS3 6 -#define PMIC_MPP_AMUX_ROUTE_ABUS4 7 - -/* Analog Output: level */ -#define PMIC_MPP_AOUT_LVL_1V25 0 -#define PMIC_MPP_AOUT_LVL_1V25_2 1 -#define PMIC_MPP_AOUT_LVL_0V625 2 -#define PMIC_MPP_AOUT_LVL_0V3125 3 -#define PMIC_MPP_AOUT_LVL_MPP 4 -#define PMIC_MPP_AOUT_LVL_ABUS1 5 -#define PMIC_MPP_AOUT_LVL_ABUS2 6 -#define PMIC_MPP_AOUT_LVL_ABUS3 7 - -/* To be used with "function" */ -#define PMIC_MPP_FUNC_NORMAL "normal" -#define PMIC_MPP_FUNC_PAIRED "paired" -#define PMIC_MPP_FUNC_DTEST1 "dtest1" -#define PMIC_MPP_FUNC_DTEST2 "dtest2" -#define PMIC_MPP_FUNC_DTEST3 "dtest3" -#define PMIC_MPP_FUNC_DTEST4 "dtest4" - -#endif diff --git a/include/dt-bindings/power/qcom-rpmpd.h b/include/dt-bindings/power/qcom-rpmpd.h deleted file mode 100644 index 7f4e2983a4c5..000000000000 --- a/include/dt-bindings/power/qcom-rpmpd.h +++ /dev/null @@ -1,412 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ - -#ifndef _DT_BINDINGS_POWER_QCOM_RPMPD_H -#define _DT_BINDINGS_POWER_QCOM_RPMPD_H - -/* SA8775P Power Domain Indexes */ -#define SA8775P_CX 0 -#define SA8775P_CX_AO 1 -#define SA8775P_DDR 2 -#define SA8775P_EBI 3 -#define SA8775P_GFX 4 -#define SA8775P_LCX 5 -#define SA8775P_LMX 6 -#define SA8775P_MMCX 7 -#define SA8775P_MMCX_AO 8 -#define SA8775P_MSS 9 -#define SA8775P_MX 10 -#define SA8775P_MX_AO 11 -#define SA8775P_MXC 12 -#define SA8775P_MXC_AO 13 -#define SA8775P_NSP0 14 -#define SA8775P_NSP1 15 -#define SA8775P_XO 16 - -/* SDM670 Power Domain Indexes */ -#define SDM670_MX 0 -#define SDM670_MX_AO 1 -#define SDM670_CX 2 -#define SDM670_CX_AO 3 -#define SDM670_LMX 4 -#define SDM670_LCX 5 -#define SDM670_GFX 6 -#define SDM670_MSS 7 - -/* SDM845 Power Domain Indexes */ -#define SDM845_EBI 0 -#define SDM845_MX 1 -#define SDM845_MX_AO 2 -#define SDM845_CX 3 -#define SDM845_CX_AO 4 -#define SDM845_LMX 5 -#define SDM845_LCX 6 -#define SDM845_GFX 7 -#define SDM845_MSS 8 - -/* SDX55 Power Domain Indexes */ -#define SDX55_MSS 0 -#define SDX55_MX 1 -#define SDX55_CX 2 - -/* SDX65 Power Domain Indexes */ -#define SDX65_MSS 0 -#define SDX65_MX 1 -#define SDX65_MX_AO 2 -#define SDX65_CX 3 -#define SDX65_CX_AO 4 -#define SDX65_MXC 5 - -/* SM6350 Power Domain Indexes */ -#define SM6350_CX 0 -#define SM6350_GFX 1 -#define SM6350_LCX 2 -#define SM6350_LMX 3 -#define SM6350_MSS 4 -#define SM6350_MX 5 - -/* SM6350 Power Domain Indexes */ -#define SM6375_VDDCX 0 -#define SM6375_VDDCX_AO 1 -#define SM6375_VDDCX_VFL 2 -#define SM6375_VDDMX 3 -#define SM6375_VDDMX_AO 4 -#define SM6375_VDDMX_VFL 5 -#define SM6375_VDDGX 6 -#define SM6375_VDDGX_AO 7 -#define SM6375_VDD_LPI_CX 8 -#define SM6375_VDD_LPI_MX 9 - -/* SM8150 Power Domain Indexes */ -#define SM8150_MSS 0 -#define SM8150_EBI 1 -#define SM8150_LMX 2 -#define SM8150_LCX 3 -#define SM8150_GFX 4 -#define SM8150_MX 5 -#define SM8150_MX_AO 6 -#define SM8150_CX 7 -#define SM8150_CX_AO 8 -#define SM8150_MMCX 9 -#define SM8150_MMCX_AO 10 - -/* SA8155P is a special case, kept for backwards compatibility */ -#define SA8155P_CX SM8150_CX -#define SA8155P_CX_AO SM8150_CX_AO -#define SA8155P_EBI SM8150_EBI -#define SA8155P_GFX SM8150_GFX -#define SA8155P_MSS SM8150_MSS -#define SA8155P_MX SM8150_MX -#define SA8155P_MX_AO SM8150_MX_AO - -/* SM8250 Power Domain Indexes */ -#define SM8250_CX 0 -#define SM8250_CX_AO 1 -#define SM8250_EBI 2 -#define SM8250_GFX 3 -#define SM8250_LCX 4 -#define SM8250_LMX 5 -#define SM8250_MMCX 6 -#define SM8250_MMCX_AO 7 -#define SM8250_MX 8 -#define SM8250_MX_AO 9 - -/* SM8350 Power Domain Indexes */ -#define SM8350_CX 0 -#define SM8350_CX_AO 1 -#define SM8350_EBI 2 -#define SM8350_GFX 3 -#define SM8350_LCX 4 -#define SM8350_LMX 5 -#define SM8350_MMCX 6 -#define SM8350_MMCX_AO 7 -#define SM8350_MX 8 -#define SM8350_MX_AO 9 -#define SM8350_MXC 10 -#define SM8350_MXC_AO 11 -#define SM8350_MSS 12 - -/* SM8450 Power Domain Indexes */ -#define SM8450_CX 0 -#define SM8450_CX_AO 1 -#define SM8450_EBI 2 -#define SM8450_GFX 3 -#define SM8450_LCX 4 -#define SM8450_LMX 5 -#define SM8450_MMCX 6 -#define SM8450_MMCX_AO 7 -#define SM8450_MX 8 -#define SM8450_MX_AO 9 -#define SM8450_MXC 10 -#define SM8450_MXC_AO 11 -#define SM8450_MSS 12 - -/* SM8550 Power Domain Indexes */ -#define SM8550_CX 0 -#define SM8550_CX_AO 1 -#define SM8550_EBI 2 -#define SM8550_GFX 3 -#define SM8550_LCX 4 -#define SM8550_LMX 5 -#define SM8550_MMCX 6 -#define SM8550_MMCX_AO 7 -#define SM8550_MX 8 -#define SM8550_MX_AO 9 -#define SM8550_MXC 10 -#define SM8550_MXC_AO 11 -#define SM8550_MSS 12 -#define SM8550_NSP 13 - -/* QDU1000/QRU1000 Power Domain Indexes */ -#define QDU1000_EBI 0 -#define QDU1000_MSS 1 -#define QDU1000_CX 2 -#define QDU1000_MX 3 - -/* SC7180 Power Domain Indexes */ -#define SC7180_CX 0 -#define SC7180_CX_AO 1 -#define SC7180_GFX 2 -#define SC7180_MX 3 -#define SC7180_MX_AO 4 -#define SC7180_LMX 5 -#define SC7180_LCX 6 -#define SC7180_MSS 7 - -/* SC7280 Power Domain Indexes */ -#define SC7280_CX 0 -#define SC7280_CX_AO 1 -#define SC7280_EBI 2 -#define SC7280_GFX 3 -#define SC7280_MX 4 -#define SC7280_MX_AO 5 -#define SC7280_LMX 6 -#define SC7280_LCX 7 -#define SC7280_MSS 8 - -/* SC8180X Power Domain Indexes */ -#define SC8180X_CX 0 -#define SC8180X_CX_AO 1 -#define SC8180X_EBI 2 -#define SC8180X_GFX 3 -#define SC8180X_LCX 4 -#define SC8180X_LMX 5 -#define SC8180X_MMCX 6 -#define SC8180X_MMCX_AO 7 -#define SC8180X_MSS 8 -#define SC8180X_MX 9 -#define SC8180X_MX_AO 10 - -/* SC8280XP Power Domain Indexes */ -#define SC8280XP_CX 0 -#define SC8280XP_CX_AO 1 -#define SC8280XP_DDR 2 -#define SC8280XP_EBI 3 -#define SC8280XP_GFX 4 -#define SC8280XP_LCX 5 -#define SC8280XP_LMX 6 -#define SC8280XP_MMCX 7 -#define SC8280XP_MMCX_AO 8 -#define SC8280XP_MSS 9 -#define SC8280XP_MX 10 -#define SC8280XP_MXC 12 -#define SC8280XP_MX_AO 11 -#define SC8280XP_NSP 13 -#define SC8280XP_QPHY 14 -#define SC8280XP_XO 15 - -/* SDM845 Power Domain performance levels */ -#define RPMH_REGULATOR_LEVEL_RETENTION 16 -#define RPMH_REGULATOR_LEVEL_MIN_SVS 48 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_D2 52 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_D1 56 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_D0 60 -#define RPMH_REGULATOR_LEVEL_LOW_SVS 64 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_P1 72 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_L1 80 -#define RPMH_REGULATOR_LEVEL_LOW_SVS_L2 96 -#define RPMH_REGULATOR_LEVEL_SVS 128 -#define RPMH_REGULATOR_LEVEL_SVS_L0 144 -#define RPMH_REGULATOR_LEVEL_SVS_L1 192 -#define RPMH_REGULATOR_LEVEL_SVS_L2 224 -#define RPMH_REGULATOR_LEVEL_NOM 256 -#define RPMH_REGULATOR_LEVEL_NOM_L0 288 -#define RPMH_REGULATOR_LEVEL_NOM_L1 320 -#define RPMH_REGULATOR_LEVEL_NOM_L2 336 -#define RPMH_REGULATOR_LEVEL_TURBO 384 -#define RPMH_REGULATOR_LEVEL_TURBO_L0 400 -#define RPMH_REGULATOR_LEVEL_TURBO_L1 416 -#define RPMH_REGULATOR_LEVEL_TURBO_L2 432 -#define RPMH_REGULATOR_LEVEL_TURBO_L3 448 -#define RPMH_REGULATOR_LEVEL_SUPER_TURBO 464 -#define RPMH_REGULATOR_LEVEL_SUPER_TURBO_NO_CPR 480 - -/* MDM9607 Power Domains */ -#define MDM9607_VDDCX 0 -#define MDM9607_VDDCX_AO 1 -#define MDM9607_VDDCX_VFL 2 -#define MDM9607_VDDMX 3 -#define MDM9607_VDDMX_AO 4 -#define MDM9607_VDDMX_VFL 5 - -/* MSM8226 Power Domain Indexes */ -#define MSM8226_VDDCX 0 -#define MSM8226_VDDCX_AO 1 -#define MSM8226_VDDCX_VFC 2 - -/* MSM8939 Power Domains */ -#define MSM8939_VDDMDCX 0 -#define MSM8939_VDDMDCX_AO 1 -#define MSM8939_VDDMDCX_VFC 2 -#define MSM8939_VDDCX 3 -#define MSM8939_VDDCX_AO 4 -#define MSM8939_VDDCX_VFC 5 -#define MSM8939_VDDMX 6 -#define MSM8939_VDDMX_AO 7 - -/* MSM8916 Power Domain Indexes */ -#define MSM8916_VDDCX 0 -#define MSM8916_VDDCX_AO 1 -#define MSM8916_VDDCX_VFC 2 -#define MSM8916_VDDMX 3 -#define MSM8916_VDDMX_AO 4 - -/* MSM8909 Power Domain Indexes */ -#define MSM8909_VDDCX MSM8916_VDDCX -#define MSM8909_VDDCX_AO MSM8916_VDDCX_AO -#define MSM8909_VDDCX_VFC MSM8916_VDDCX_VFC -#define MSM8909_VDDMX MSM8916_VDDMX -#define MSM8909_VDDMX_AO MSM8916_VDDMX_AO - -/* MSM8917 Power Domain Indexes */ -#define MSM8917_VDDCX 0 -#define MSM8917_VDDCX_AO 1 -#define MSM8917_VDDCX_VFL 2 -#define MSM8917_VDDMX 3 -#define MSM8917_VDDMX_AO 4 - -/* MSM8937 Power Domain Indexes */ -#define MSM8937_VDDCX MSM8917_VDDCX -#define MSM8937_VDDCX_AO MSM8917_VDDCX_AO -#define MSM8937_VDDCX_VFL MSM8917_VDDCX_VFL -#define MSM8937_VDDMX MSM8917_VDDMX -#define MSM8937_VDDMX_AO MSM8917_VDDMX_AO - -/* QM215 Power Domain Indexes */ -#define QM215_VDDCX MSM8917_VDDCX -#define QM215_VDDCX_AO MSM8917_VDDCX_AO -#define QM215_VDDCX_VFL MSM8917_VDDCX_VFL -#define QM215_VDDMX MSM8917_VDDMX -#define QM215_VDDMX_AO MSM8917_VDDMX_AO - -/* MSM8953 Power Domain Indexes */ -#define MSM8953_VDDMD 0 -#define MSM8953_VDDMD_AO 1 -#define MSM8953_VDDCX 2 -#define MSM8953_VDDCX_AO 3 -#define MSM8953_VDDCX_VFL 4 -#define MSM8953_VDDMX 5 -#define MSM8953_VDDMX_AO 6 - -/* MSM8976 Power Domain Indexes */ -#define MSM8976_VDDCX 0 -#define MSM8976_VDDCX_AO 1 -#define MSM8976_VDDCX_VFL 2 -#define MSM8976_VDDMX 3 -#define MSM8976_VDDMX_AO 4 -#define MSM8976_VDDMX_VFL 5 - -/* MSM8994 Power Domain Indexes */ -#define MSM8994_VDDCX 0 -#define MSM8994_VDDCX_AO 1 -#define MSM8994_VDDCX_VFC 2 -#define MSM8994_VDDMX 3 -#define MSM8994_VDDMX_AO 4 -#define MSM8994_VDDGFX 5 -#define MSM8994_VDDGFX_VFC 6 - -/* MSM8996 Power Domain Indexes */ -#define MSM8996_VDDCX 0 -#define MSM8996_VDDCX_AO 1 -#define MSM8996_VDDCX_VFC 2 -#define MSM8996_VDDMX 3 -#define MSM8996_VDDMX_AO 4 -#define MSM8996_VDDSSCX 5 -#define MSM8996_VDDSSCX_VFC 6 - -/* MSM8998 Power Domain Indexes */ -#define MSM8998_VDDCX 0 -#define MSM8998_VDDCX_AO 1 -#define MSM8998_VDDCX_VFL 2 -#define MSM8998_VDDMX 3 -#define MSM8998_VDDMX_AO 4 -#define MSM8998_VDDMX_VFL 5 -#define MSM8998_SSCCX 6 -#define MSM8998_SSCCX_VFL 7 -#define MSM8998_SSCMX 8 -#define MSM8998_SSCMX_VFL 9 - -/* QCS404 Power Domains */ -#define QCS404_VDDMX 0 -#define QCS404_VDDMX_AO 1 -#define QCS404_VDDMX_VFL 2 -#define QCS404_LPICX 3 -#define QCS404_LPICX_VFL 4 -#define QCS404_LPIMX 5 -#define QCS404_LPIMX_VFL 6 - -/* SDM660 Power Domains */ -#define SDM660_VDDCX 0 -#define SDM660_VDDCX_AO 1 -#define SDM660_VDDCX_VFL 2 -#define SDM660_VDDMX 3 -#define SDM660_VDDMX_AO 4 -#define SDM660_VDDMX_VFL 5 -#define SDM660_SSCCX 6 -#define SDM660_SSCCX_VFL 7 -#define SDM660_SSCMX 8 -#define SDM660_SSCMX_VFL 9 - -/* SM6115 Power Domains */ -#define SM6115_VDDCX 0 -#define SM6115_VDDCX_AO 1 -#define SM6115_VDDCX_VFL 2 -#define SM6115_VDDMX 3 -#define SM6115_VDDMX_AO 4 -#define SM6115_VDDMX_VFL 5 -#define SM6115_VDD_LPI_CX 6 -#define SM6115_VDD_LPI_MX 7 - -/* SM6125 Power Domains */ -#define SM6125_VDDCX 0 -#define SM6125_VDDCX_AO 1 -#define SM6125_VDDCX_VFL 2 -#define SM6125_VDDMX 3 -#define SM6125_VDDMX_AO 4 -#define SM6125_VDDMX_VFL 5 - -/* QCM2290 Power Domains */ -#define QCM2290_VDDCX 0 -#define QCM2290_VDDCX_AO 1 -#define QCM2290_VDDCX_VFL 2 -#define QCM2290_VDDMX 3 -#define QCM2290_VDDMX_AO 4 -#define QCM2290_VDDMX_VFL 5 -#define QCM2290_VDD_LPI_CX 6 -#define QCM2290_VDD_LPI_MX 7 - -/* RPM SMD Power Domain performance levels */ -#define RPM_SMD_LEVEL_RETENTION 16 -#define RPM_SMD_LEVEL_RETENTION_PLUS 32 -#define RPM_SMD_LEVEL_MIN_SVS 48 -#define RPM_SMD_LEVEL_LOW_SVS 64 -#define RPM_SMD_LEVEL_SVS 128 -#define RPM_SMD_LEVEL_SVS_PLUS 192 -#define RPM_SMD_LEVEL_NOM 256 -#define RPM_SMD_LEVEL_NOM_PLUS 320 -#define RPM_SMD_LEVEL_TURBO 384 -#define RPM_SMD_LEVEL_TURBO_NO_CPR 416 -#define RPM_SMD_LEVEL_TURBO_HIGH 448 -#define RPM_SMD_LEVEL_BINNING 512 - -#endif diff --git a/include/dt-bindings/regulator/qcom,rpmh-regulator.h b/include/dt-bindings/regulator/qcom,rpmh-regulator.h deleted file mode 100644 index 86713dcf9e02..000000000000 --- a/include/dt-bindings/regulator/qcom,rpmh-regulator.h +++ /dev/null @@ -1,36 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ - -#ifndef __QCOM_RPMH_REGULATOR_H -#define __QCOM_RPMH_REGULATOR_H - -/* - * These mode constants may be used to specify modes for various RPMh regulator - * device tree properties (e.g. regulator-initial-mode). Each type of regulator - * supports a subset of the possible modes. - * - * %RPMH_REGULATOR_MODE_RET: Retention mode in which only an extremely small - * load current is allowed. This mode is supported - * by LDO and SMPS type regulators. - * %RPMH_REGULATOR_MODE_LPM: Low power mode in which a small load current is - * allowed. This mode corresponds to PFM for SMPS - * and BOB type regulators. This mode is supported - * by LDO, HFSMPS, BOB, and PMIC4 FTSMPS type - * regulators. - * %RPMH_REGULATOR_MODE_AUTO: Auto mode in which the regulator hardware - * automatically switches between LPM and HPM based - * upon the real-time load current. This mode is - * supported by HFSMPS, BOB, and PMIC4 FTSMPS type - * regulators. - * %RPMH_REGULATOR_MODE_HPM: High power mode in which the full rated current - * of the regulator is allowed. This mode - * corresponds to PWM for SMPS and BOB type - * regulators. This mode is supported by all types - * of regulators. - */ -#define RPMH_REGULATOR_MODE_RET 0 -#define RPMH_REGULATOR_MODE_LPM 1 -#define RPMH_REGULATOR_MODE_AUTO 2 -#define RPMH_REGULATOR_MODE_HPM 3 - -#endif diff --git a/include/dt-bindings/reset/qcom,gcc-msm8916.h b/include/dt-bindings/reset/qcom,gcc-msm8916.h deleted file mode 100644 index 1f9be10872df..000000000000 --- a/include/dt-bindings/reset/qcom,gcc-msm8916.h +++ /dev/null @@ -1,100 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2015 Linaro Limited - */ - -#ifndef _DT_BINDINGS_RESET_MSM_GCC_8916_H -#define _DT_BINDINGS_RESET_MSM_GCC_8916_H - -#define GCC_BLSP1_BCR 0 -#define GCC_BLSP1_QUP1_BCR 1 -#define GCC_BLSP1_UART1_BCR 2 -#define GCC_BLSP1_QUP2_BCR 3 -#define GCC_BLSP1_UART2_BCR 4 -#define GCC_BLSP1_QUP3_BCR 5 -#define GCC_BLSP1_QUP4_BCR 6 -#define GCC_BLSP1_QUP5_BCR 7 -#define GCC_BLSP1_QUP6_BCR 8 -#define GCC_IMEM_BCR 9 -#define GCC_SMMU_BCR 10 -#define GCC_APSS_TCU_BCR 11 -#define GCC_SMMU_XPU_BCR 12 -#define GCC_PCNOC_TBU_BCR 13 -#define GCC_PRNG_BCR 14 -#define GCC_BOOT_ROM_BCR 15 -#define GCC_CRYPTO_BCR 16 -#define GCC_SEC_CTRL_BCR 17 -#define GCC_AUDIO_CORE_BCR 18 -#define GCC_ULT_AUDIO_BCR 19 -#define GCC_DEHR_BCR 20 -#define GCC_SYSTEM_NOC_BCR 21 -#define GCC_PCNOC_BCR 22 -#define GCC_TCSR_BCR 23 -#define GCC_QDSS_BCR 24 -#define GCC_DCD_BCR 25 -#define GCC_MSG_RAM_BCR 26 -#define GCC_MPM_BCR 27 -#define GCC_SPMI_BCR 28 -#define GCC_SPDM_BCR 29 -#define GCC_MM_SPDM_BCR 30 -#define GCC_BIMC_BCR 31 -#define GCC_RBCPR_BCR 32 -#define GCC_TLMM_BCR 33 -#define GCC_USB_HS_BCR 34 -#define GCC_USB2A_PHY_BCR 35 -#define GCC_SDCC1_BCR 36 -#define GCC_SDCC2_BCR 37 -#define GCC_PDM_BCR 38 -#define GCC_SNOC_BUS_TIMEOUT0_BCR 39 -#define GCC_PCNOC_BUS_TIMEOUT0_BCR 40 -#define GCC_PCNOC_BUS_TIMEOUT1_BCR 41 -#define GCC_PCNOC_BUS_TIMEOUT2_BCR 42 -#define GCC_PCNOC_BUS_TIMEOUT3_BCR 43 -#define GCC_PCNOC_BUS_TIMEOUT4_BCR 44 -#define GCC_PCNOC_BUS_TIMEOUT5_BCR 45 -#define GCC_PCNOC_BUS_TIMEOUT6_BCR 46 -#define GCC_PCNOC_BUS_TIMEOUT7_BCR 47 -#define GCC_PCNOC_BUS_TIMEOUT8_BCR 48 -#define GCC_PCNOC_BUS_TIMEOUT9_BCR 49 -#define GCC_MMSS_BCR 50 -#define GCC_VENUS0_BCR 51 -#define GCC_MDSS_BCR 52 -#define GCC_CAMSS_PHY0_BCR 53 -#define GCC_CAMSS_CSI0_BCR 54 -#define GCC_CAMSS_CSI0PHY_BCR 55 -#define GCC_CAMSS_CSI0RDI_BCR 56 -#define GCC_CAMSS_CSI0PIX_BCR 57 -#define GCC_CAMSS_PHY1_BCR 58 -#define GCC_CAMSS_CSI1_BCR 59 -#define GCC_CAMSS_CSI1PHY_BCR 60 -#define GCC_CAMSS_CSI1RDI_BCR 61 -#define GCC_CAMSS_CSI1PIX_BCR 62 -#define GCC_CAMSS_ISPIF_BCR 63 -#define GCC_CAMSS_CCI_BCR 64 -#define GCC_CAMSS_MCLK0_BCR 65 -#define GCC_CAMSS_MCLK1_BCR 66 -#define GCC_CAMSS_GP0_BCR 67 -#define GCC_CAMSS_GP1_BCR 68 -#define GCC_CAMSS_TOP_BCR 69 -#define GCC_CAMSS_MICRO_BCR 70 -#define GCC_CAMSS_JPEG_BCR 71 -#define GCC_CAMSS_VFE_BCR 72 -#define GCC_CAMSS_CSI_VFE0_BCR 73 -#define GCC_OXILI_BCR 74 -#define GCC_GMEM_BCR 75 -#define GCC_CAMSS_AHB_BCR 76 -#define GCC_MDP_TBU_BCR 77 -#define GCC_GFX_TBU_BCR 78 -#define GCC_GFX_TCU_BCR 79 -#define GCC_MSS_TBU_AXI_BCR 80 -#define GCC_MSS_TBU_GSS_AXI_BCR 81 -#define GCC_MSS_TBU_Q6_AXI_BCR 82 -#define GCC_GTCU_AHB_BCR 83 -#define GCC_SMMU_CFG_BCR 84 -#define GCC_VFE_TBU_BCR 85 -#define GCC_VENUS_TBU_BCR 86 -#define GCC_JPEG_TBU_BCR 87 -#define GCC_PRONTO_TBU_BCR 88 -#define GCC_SMMU_CATS_BCR 89 - -#endif diff --git a/include/dt-bindings/reset/qcom,sdm845-aoss.h b/include/dt-bindings/reset/qcom,sdm845-aoss.h deleted file mode 100644 index 476c5fc873b6..000000000000 --- a/include/dt-bindings/reset/qcom,sdm845-aoss.h +++ /dev/null @@ -1,17 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_RESET_AOSS_SDM_845_H -#define _DT_BINDINGS_RESET_AOSS_SDM_845_H - -#define AOSS_CC_MSS_RESTART 0 -#define AOSS_CC_CAMSS_RESTART 1 -#define AOSS_CC_VENUS_RESTART 2 -#define AOSS_CC_GPU_RESTART 3 -#define AOSS_CC_DISPSS_RESTART 4 -#define AOSS_CC_WCSS_RESTART 5 -#define AOSS_CC_LPASS_RESTART 6 - -#endif diff --git a/include/dt-bindings/reset/qcom,sdm845-pdc.h b/include/dt-bindings/reset/qcom,sdm845-pdc.h deleted file mode 100644 index 03a0c0eb8147..000000000000 --- a/include/dt-bindings/reset/qcom,sdm845-pdc.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 The Linux Foundation. All rights reserved. - */ - -#ifndef _DT_BINDINGS_RESET_PDC_SDM_845_H -#define _DT_BINDINGS_RESET_PDC_SDM_845_H - -#define PDC_APPS_SYNC_RESET 0 -#define PDC_SP_SYNC_RESET 1 -#define PDC_AUDIO_SYNC_RESET 2 -#define PDC_SENSORS_SYNC_RESET 3 -#define PDC_AOP_SYNC_RESET 4 -#define PDC_DEBUG_SYNC_RESET 5 -#define PDC_GPU_SYNC_RESET 6 -#define PDC_DISPLAY_SYNC_RESET 7 -#define PDC_COMPUTE_SYNC_RESET 8 -#define PDC_MODEM_SYNC_RESET 9 -#define PDC_WLAN_RF_SYNC_RESET 10 -#define PDC_WPSS_SYNC_RESET 11 - -#endif diff --git a/include/dt-bindings/soc/qcom,apr.h b/include/dt-bindings/soc/qcom,apr.h deleted file mode 100644 index 006362400c0f..000000000000 --- a/include/dt-bindings/soc/qcom,apr.h +++ /dev/null @@ -1,28 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_QCOM_APR_H -#define __DT_BINDINGS_QCOM_APR_H - -/* Domain IDs */ -#define APR_DOMAIN_SIM 0x1 -#define APR_DOMAIN_PC 0x2 -#define APR_DOMAIN_MODEM 0x3 -#define APR_DOMAIN_ADSP 0x4 -#define APR_DOMAIN_APPS 0x5 -#define APR_DOMAIN_MAX 0x6 - -/* ADSP service IDs */ -#define APR_SVC_ADSP_CORE 0x3 -#define APR_SVC_AFE 0x4 -#define APR_SVC_VSM 0x5 -#define APR_SVC_VPM 0x6 -#define APR_SVC_ASM 0x7 -#define APR_SVC_ADM 0x8 -#define APR_SVC_ADSP_MVM 0x09 -#define APR_SVC_ADSP_CVS 0x0A -#define APR_SVC_ADSP_CVP 0x0B -#define APR_SVC_USM 0x0C -#define APR_SVC_LSM 0x0D -#define APR_SVC_VIDC 0x16 -#define APR_SVC_MAX 0x17 - -#endif /* __DT_BINDINGS_QCOM_APR_H */ diff --git a/include/dt-bindings/soc/qcom,rpmh-rsc.h b/include/dt-bindings/soc/qcom,rpmh-rsc.h deleted file mode 100644 index 868f998ea998..000000000000 --- a/include/dt-bindings/soc/qcom,rpmh-rsc.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. - */ - -#ifndef __DT_QCOM_RPMH_RSC_H__ -#define __DT_QCOM_RPMH_RSC_H__ - -#define SLEEP_TCS 0 -#define WAKE_TCS 1 -#define ACTIVE_TCS 2 -#define CONTROL_TCS 3 - -#endif /* __DT_QCOM_RPMH_RSC_H__ */ diff --git a/include/dt-bindings/sound/qcom,lpass.h b/include/dt-bindings/sound/qcom,lpass.h deleted file mode 100644 index a9404c3b8884..000000000000 --- a/include/dt-bindings/sound/qcom,lpass.h +++ /dev/null @@ -1,46 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_QCOM_LPASS_H -#define __DT_QCOM_LPASS_H - -#define MI2S_PRIMARY 0 -#define MI2S_SECONDARY 1 -#define MI2S_TERTIARY 2 -#define MI2S_QUATERNARY 3 -#define MI2S_QUINARY 4 - -#define LPASS_DP_RX 5 - -#define LPASS_CDC_DMA_RX0 6 -#define LPASS_CDC_DMA_RX1 7 -#define LPASS_CDC_DMA_RX2 8 -#define LPASS_CDC_DMA_RX3 9 -#define LPASS_CDC_DMA_RX4 10 -#define LPASS_CDC_DMA_RX5 11 -#define LPASS_CDC_DMA_RX6 12 -#define LPASS_CDC_DMA_RX7 13 -#define LPASS_CDC_DMA_RX8 14 -#define LPASS_CDC_DMA_RX9 15 - -#define LPASS_CDC_DMA_TX0 16 -#define LPASS_CDC_DMA_TX1 17 -#define LPASS_CDC_DMA_TX2 18 -#define LPASS_CDC_DMA_TX3 19 -#define LPASS_CDC_DMA_TX4 20 -#define LPASS_CDC_DMA_TX5 21 -#define LPASS_CDC_DMA_TX6 22 -#define LPASS_CDC_DMA_TX7 23 -#define LPASS_CDC_DMA_TX8 24 - -#define LPASS_CDC_DMA_VA_TX0 25 -#define LPASS_CDC_DMA_VA_TX1 26 -#define LPASS_CDC_DMA_VA_TX2 27 -#define LPASS_CDC_DMA_VA_TX3 28 -#define LPASS_CDC_DMA_VA_TX4 29 -#define LPASS_CDC_DMA_VA_TX5 30 -#define LPASS_CDC_DMA_VA_TX6 31 -#define LPASS_CDC_DMA_VA_TX7 32 -#define LPASS_CDC_DMA_VA_TX8 33 - -#define LPASS_MCLK0 0 - -#endif /* __DT_QCOM_LPASS_H */ diff --git a/include/dt-bindings/sound/qcom,q6afe.h b/include/dt-bindings/sound/qcom,q6afe.h deleted file mode 100644 index 9d5d89cfabcf..000000000000 --- a/include/dt-bindings/sound/qcom,q6afe.h +++ /dev/null @@ -1,9 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_Q6_AFE_H__ -#define __DT_BINDINGS_Q6_AFE_H__ - -/* This file exists due to backward compatibility reasons, Please do not DELETE! */ - -#include <dt-bindings/sound/qcom,q6dsp-lpass-ports.h> - -#endif /* __DT_BINDINGS_Q6_AFE_H__ */ diff --git a/include/dt-bindings/sound/qcom,q6asm.h b/include/dt-bindings/sound/qcom,q6asm.h deleted file mode 100644 index f59d74f14395..000000000000 --- a/include/dt-bindings/sound/qcom,q6asm.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_Q6_ASM_H__ -#define __DT_BINDINGS_Q6_ASM_H__ - -#define MSM_FRONTEND_DAI_MULTIMEDIA1 0 -#define MSM_FRONTEND_DAI_MULTIMEDIA2 1 -#define MSM_FRONTEND_DAI_MULTIMEDIA3 2 -#define MSM_FRONTEND_DAI_MULTIMEDIA4 3 -#define MSM_FRONTEND_DAI_MULTIMEDIA5 4 -#define MSM_FRONTEND_DAI_MULTIMEDIA6 5 -#define MSM_FRONTEND_DAI_MULTIMEDIA7 6 -#define MSM_FRONTEND_DAI_MULTIMEDIA8 7 -#define MSM_FRONTEND_DAI_MULTIMEDIA9 8 -#define MSM_FRONTEND_DAI_MULTIMEDIA10 9 -#define MSM_FRONTEND_DAI_MULTIMEDIA11 10 -#define MSM_FRONTEND_DAI_MULTIMEDIA12 11 -#define MSM_FRONTEND_DAI_MULTIMEDIA13 12 -#define MSM_FRONTEND_DAI_MULTIMEDIA14 13 -#define MSM_FRONTEND_DAI_MULTIMEDIA15 14 -#define MSM_FRONTEND_DAI_MULTIMEDIA16 15 - -#define Q6ASM_DAI_TX_RX 0 -#define Q6ASM_DAI_TX 1 -#define Q6ASM_DAI_RX 2 - -#endif /* __DT_BINDINGS_Q6_ASM_H__ */ diff --git a/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h b/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h deleted file mode 100644 index 39f203256c4f..000000000000 --- a/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h +++ /dev/null @@ -1,234 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_Q6_AUDIO_PORTS_H__ -#define __DT_BINDINGS_Q6_AUDIO_PORTS_H__ - -/* LPASS Audio virtual ports IDs */ -#define HDMI_RX 1 -#define SLIMBUS_0_RX 2 -#define SLIMBUS_0_TX 3 -#define SLIMBUS_1_RX 4 -#define SLIMBUS_1_TX 5 -#define SLIMBUS_2_RX 6 -#define SLIMBUS_2_TX 7 -#define SLIMBUS_3_RX 8 -#define SLIMBUS_3_TX 9 -#define SLIMBUS_4_RX 10 -#define SLIMBUS_4_TX 11 -#define SLIMBUS_5_RX 12 -#define SLIMBUS_5_TX 13 -#define SLIMBUS_6_RX 14 -#define SLIMBUS_6_TX 15 -#define PRIMARY_MI2S_RX 16 -#define PRIMARY_MI2S_TX 17 -#define SECONDARY_MI2S_RX 18 -#define SECONDARY_MI2S_TX 19 -#define TERTIARY_MI2S_RX 20 -#define TERTIARY_MI2S_TX 21 -#define QUATERNARY_MI2S_RX 22 -#define QUATERNARY_MI2S_TX 23 -#define PRIMARY_TDM_RX_0 24 -#define PRIMARY_TDM_TX_0 25 -#define PRIMARY_TDM_RX_1 26 -#define PRIMARY_TDM_TX_1 27 -#define PRIMARY_TDM_RX_2 28 -#define PRIMARY_TDM_TX_2 29 -#define PRIMARY_TDM_RX_3 30 -#define PRIMARY_TDM_TX_3 31 -#define PRIMARY_TDM_RX_4 32 -#define PRIMARY_TDM_TX_4 33 -#define PRIMARY_TDM_RX_5 34 -#define PRIMARY_TDM_TX_5 35 -#define PRIMARY_TDM_RX_6 36 -#define PRIMARY_TDM_TX_6 37 -#define PRIMARY_TDM_RX_7 38 -#define PRIMARY_TDM_TX_7 39 -#define SECONDARY_TDM_RX_0 40 -#define SECONDARY_TDM_TX_0 41 -#define SECONDARY_TDM_RX_1 42 -#define SECONDARY_TDM_TX_1 43 -#define SECONDARY_TDM_RX_2 44 -#define SECONDARY_TDM_TX_2 45 -#define SECONDARY_TDM_RX_3 46 -#define SECONDARY_TDM_TX_3 47 -#define SECONDARY_TDM_RX_4 48 -#define SECONDARY_TDM_TX_4 49 -#define SECONDARY_TDM_RX_5 50 -#define SECONDARY_TDM_TX_5 51 -#define SECONDARY_TDM_RX_6 52 -#define SECONDARY_TDM_TX_6 53 -#define SECONDARY_TDM_RX_7 54 -#define SECONDARY_TDM_TX_7 55 -#define TERTIARY_TDM_RX_0 56 -#define TERTIARY_TDM_TX_0 57 -#define TERTIARY_TDM_RX_1 58 -#define TERTIARY_TDM_TX_1 59 -#define TERTIARY_TDM_RX_2 60 -#define TERTIARY_TDM_TX_2 61 -#define TERTIARY_TDM_RX_3 62 -#define TERTIARY_TDM_TX_3 63 -#define TERTIARY_TDM_RX_4 64 -#define TERTIARY_TDM_TX_4 65 -#define TERTIARY_TDM_RX_5 66 -#define TERTIARY_TDM_TX_5 67 -#define TERTIARY_TDM_RX_6 68 -#define TERTIARY_TDM_TX_6 69 -#define TERTIARY_TDM_RX_7 70 -#define TERTIARY_TDM_TX_7 71 -#define QUATERNARY_TDM_RX_0 72 -#define QUATERNARY_TDM_TX_0 73 -#define QUATERNARY_TDM_RX_1 74 -#define QUATERNARY_TDM_TX_1 75 -#define QUATERNARY_TDM_RX_2 76 -#define QUATERNARY_TDM_TX_2 77 -#define QUATERNARY_TDM_RX_3 78 -#define QUATERNARY_TDM_TX_3 79 -#define QUATERNARY_TDM_RX_4 80 -#define QUATERNARY_TDM_TX_4 81 -#define QUATERNARY_TDM_RX_5 82 -#define QUATERNARY_TDM_TX_5 83 -#define QUATERNARY_TDM_RX_6 84 -#define QUATERNARY_TDM_TX_6 85 -#define QUATERNARY_TDM_RX_7 86 -#define QUATERNARY_TDM_TX_7 87 -#define QUINARY_TDM_RX_0 88 -#define QUINARY_TDM_TX_0 89 -#define QUINARY_TDM_RX_1 90 -#define QUINARY_TDM_TX_1 91 -#define QUINARY_TDM_RX_2 92 -#define QUINARY_TDM_TX_2 93 -#define QUINARY_TDM_RX_3 94 -#define QUINARY_TDM_TX_3 95 -#define QUINARY_TDM_RX_4 96 -#define QUINARY_TDM_TX_4 97 -#define QUINARY_TDM_RX_5 98 -#define QUINARY_TDM_TX_5 99 -#define QUINARY_TDM_RX_6 100 -#define QUINARY_TDM_TX_6 101 -#define QUINARY_TDM_RX_7 102 -#define QUINARY_TDM_TX_7 103 -#define DISPLAY_PORT_RX 104 -#define WSA_CODEC_DMA_RX_0 105 -#define WSA_CODEC_DMA_TX_0 106 -#define WSA_CODEC_DMA_RX_1 107 -#define WSA_CODEC_DMA_TX_1 108 -#define WSA_CODEC_DMA_TX_2 109 -#define VA_CODEC_DMA_TX_0 110 -#define VA_CODEC_DMA_TX_1 111 -#define VA_CODEC_DMA_TX_2 112 -#define RX_CODEC_DMA_RX_0 113 -#define TX_CODEC_DMA_TX_0 114 -#define RX_CODEC_DMA_RX_1 115 -#define TX_CODEC_DMA_TX_1 116 -#define RX_CODEC_DMA_RX_2 117 -#define TX_CODEC_DMA_TX_2 118 -#define RX_CODEC_DMA_RX_3 119 -#define TX_CODEC_DMA_TX_3 120 -#define RX_CODEC_DMA_RX_4 121 -#define TX_CODEC_DMA_TX_4 122 -#define RX_CODEC_DMA_RX_5 123 -#define TX_CODEC_DMA_TX_5 124 -#define RX_CODEC_DMA_RX_6 125 -#define RX_CODEC_DMA_RX_7 126 -#define QUINARY_MI2S_RX 127 -#define QUINARY_MI2S_TX 128 -#define DISPLAY_PORT_RX_0 DISPLAY_PORT_RX -#define DISPLAY_PORT_RX_1 129 -#define DISPLAY_PORT_RX_2 130 -#define DISPLAY_PORT_RX_3 131 -#define DISPLAY_PORT_RX_4 132 -#define DISPLAY_PORT_RX_5 133 -#define DISPLAY_PORT_RX_6 134 -#define DISPLAY_PORT_RX_7 135 - -#define LPASS_CLK_ID_PRI_MI2S_IBIT 1 -#define LPASS_CLK_ID_PRI_MI2S_EBIT 2 -#define LPASS_CLK_ID_SEC_MI2S_IBIT 3 -#define LPASS_CLK_ID_SEC_MI2S_EBIT 4 -#define LPASS_CLK_ID_TER_MI2S_IBIT 5 -#define LPASS_CLK_ID_TER_MI2S_EBIT 6 -#define LPASS_CLK_ID_QUAD_MI2S_IBIT 7 -#define LPASS_CLK_ID_QUAD_MI2S_EBIT 8 -#define LPASS_CLK_ID_SPEAKER_I2S_IBIT 9 -#define LPASS_CLK_ID_SPEAKER_I2S_EBIT 10 -#define LPASS_CLK_ID_SPEAKER_I2S_OSR 11 -#define LPASS_CLK_ID_QUI_MI2S_IBIT 12 -#define LPASS_CLK_ID_QUI_MI2S_EBIT 13 -#define LPASS_CLK_ID_SEN_MI2S_IBIT 14 -#define LPASS_CLK_ID_SEN_MI2S_EBIT 15 -#define LPASS_CLK_ID_INT0_MI2S_IBIT 16 -#define LPASS_CLK_ID_INT1_MI2S_IBIT 17 -#define LPASS_CLK_ID_INT2_MI2S_IBIT 18 -#define LPASS_CLK_ID_INT3_MI2S_IBIT 19 -#define LPASS_CLK_ID_INT4_MI2S_IBIT 20 -#define LPASS_CLK_ID_INT5_MI2S_IBIT 21 -#define LPASS_CLK_ID_INT6_MI2S_IBIT 22 -#define LPASS_CLK_ID_QUI_MI2S_OSR 23 -#define LPASS_CLK_ID_PRI_PCM_IBIT 24 -#define LPASS_CLK_ID_PRI_PCM_EBIT 25 -#define LPASS_CLK_ID_SEC_PCM_IBIT 26 -#define LPASS_CLK_ID_SEC_PCM_EBIT 27 -#define LPASS_CLK_ID_TER_PCM_IBIT 28 -#define LPASS_CLK_ID_TER_PCM_EBIT 29 -#define LPASS_CLK_ID_QUAD_PCM_IBIT 30 -#define LPASS_CLK_ID_QUAD_PCM_EBIT 31 -#define LPASS_CLK_ID_QUIN_PCM_IBIT 32 -#define LPASS_CLK_ID_QUIN_PCM_EBIT 33 -#define LPASS_CLK_ID_QUI_PCM_OSR 34 -#define LPASS_CLK_ID_PRI_TDM_IBIT 35 -#define LPASS_CLK_ID_PRI_TDM_EBIT 36 -#define LPASS_CLK_ID_SEC_TDM_IBIT 37 -#define LPASS_CLK_ID_SEC_TDM_EBIT 38 -#define LPASS_CLK_ID_TER_TDM_IBIT 39 -#define LPASS_CLK_ID_TER_TDM_EBIT 40 -#define LPASS_CLK_ID_QUAD_TDM_IBIT 41 -#define LPASS_CLK_ID_QUAD_TDM_EBIT 42 -#define LPASS_CLK_ID_QUIN_TDM_IBIT 43 -#define LPASS_CLK_ID_QUIN_TDM_EBIT 44 -#define LPASS_CLK_ID_QUIN_TDM_OSR 45 -#define LPASS_CLK_ID_MCLK_1 46 -#define LPASS_CLK_ID_MCLK_2 47 -#define LPASS_CLK_ID_MCLK_3 48 -#define LPASS_CLK_ID_MCLK_4 49 -#define LPASS_CLK_ID_INTERNAL_DIGITAL_CODEC_CORE 50 -#define LPASS_CLK_ID_INT_MCLK_0 51 -#define LPASS_CLK_ID_INT_MCLK_1 52 -#define LPASS_CLK_ID_MCLK_5 53 -#define LPASS_CLK_ID_WSA_CORE_MCLK 54 -#define LPASS_CLK_ID_WSA_CORE_NPL_MCLK 55 -#define LPASS_CLK_ID_VA_CORE_MCLK 56 -#define LPASS_CLK_ID_TX_CORE_MCLK 57 -#define LPASS_CLK_ID_TX_CORE_NPL_MCLK 58 -#define LPASS_CLK_ID_RX_CORE_MCLK 59 -#define LPASS_CLK_ID_RX_CORE_NPL_MCLK 60 -#define LPASS_CLK_ID_VA_CORE_2X_MCLK 61 -/* Clock ID for MCLK for WSA2 core */ -#define LPASS_CLK_ID_WSA2_CORE_MCLK 62 -/* Clock ID for NPL MCLK for WSA2 core */ -#define LPASS_CLK_ID_WSA2_CORE_2X_MCLK 63 -/* Clock ID for RX Core TX MCLK */ -#define LPASS_CLK_ID_RX_CORE_TX_MCLK 64 -/* Clock ID for RX CORE TX 2X MCLK */ -#define LPASS_CLK_ID_RX_CORE_TX_2X_MCLK 65 -/* Clock ID for WSA core TX MCLK */ -#define LPASS_CLK_ID_WSA_CORE_TX_MCLK 66 -/* Clock ID for WSA core TX 2X MCLK */ -#define LPASS_CLK_ID_WSA_CORE_TX_2X_MCLK 67 -/* Clock ID for WSA2 core TX MCLK */ -#define LPASS_CLK_ID_WSA2_CORE_TX_MCLK 68 -/* Clock ID for WSA2 core TX 2X MCLK */ -#define LPASS_CLK_ID_WSA2_CORE_TX_2X_MCLK 69 -/* Clock ID for RX CORE MCLK2 2X MCLK */ -#define LPASS_CLK_ID_RX_CORE_MCLK2_2X_MCLK 70 - -#define LPASS_HW_AVTIMER_VOTE 101 -#define LPASS_HW_MACRO_VOTE 102 -#define LPASS_HW_DCODEC_VOTE 103 - -#define Q6AFE_MAX_CLK_ID 104 - -#define LPASS_CLK_ATTRIBUTE_INVALID 0x0 -#define LPASS_CLK_ATTRIBUTE_COUPLE_NO 0x1 -#define LPASS_CLK_ATTRIBUTE_COUPLE_DIVIDEND 0x2 -#define LPASS_CLK_ATTRIBUTE_COUPLE_DIVISOR 0x3 - -#endif /* __DT_BINDINGS_Q6_AUDIO_PORTS_H__ */ diff --git a/include/dt-bindings/sound/qcom,wcd9335.h b/include/dt-bindings/sound/qcom,wcd9335.h deleted file mode 100644 index f5e9f1db091e..000000000000 --- a/include/dt-bindings/sound/qcom,wcd9335.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ - -#ifndef __DT_SOUND_QCOM_WCD9335_H -#define __DT_SOUND_QCOM_WCD9335_H - -#define AIF1_PB 0 -#define AIF1_CAP 1 -#define AIF2_PB 2 -#define AIF2_CAP 3 -#define AIF3_PB 4 -#define AIF3_CAP 5 -#define AIF4_PB 6 -#define NUM_CODEC_DAIS 7 - -#endif
Drop in favour of dts/upstream
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/sun20i-d1-ccu.h | 158 -------------------- include/dt-bindings/clock/sun20i-d1-r-ccu.h | 19 --- include/dt-bindings/clock/sun4i-a10-ccu.h | 202 -------------------------- include/dt-bindings/clock/sun4i-a10-pll2.h | 53 ------- include/dt-bindings/clock/sun50i-a64-ccu.h | 138 ------------------ include/dt-bindings/clock/sun50i-h6-ccu.h | 125 ---------------- include/dt-bindings/clock/sun50i-h6-r-ccu.h | 27 ---- include/dt-bindings/clock/sun50i-h616-ccu.h | 116 --------------- include/dt-bindings/clock/sun5i-ccu.h | 97 ------------- include/dt-bindings/clock/sun6i-a31-ccu.h | 193 ------------------------ include/dt-bindings/clock/sun6i-rtc.h | 10 -- include/dt-bindings/clock/sun7i-a20-ccu.h | 53 ------- include/dt-bindings/clock/sun8i-a23-a33-ccu.h | 129 ---------------- include/dt-bindings/clock/sun8i-a83t-ccu.h | 140 ------------------ include/dt-bindings/clock/sun8i-de2.h | 21 --- include/dt-bindings/clock/sun8i-h3-ccu.h | 152 ------------------- include/dt-bindings/clock/sun8i-r-ccu.h | 59 -------- include/dt-bindings/clock/sun8i-r40-ccu.h | 191 ------------------------ include/dt-bindings/clock/sun8i-tcon-top.h | 11 -- include/dt-bindings/clock/sun8i-v3s-ccu.h | 111 -------------- include/dt-bindings/clock/sun9i-a80-ccu.h | 162 --------------------- include/dt-bindings/clock/sun9i-a80-de.h | 80 ---------- include/dt-bindings/clock/sun9i-a80-usb.h | 59 -------- include/dt-bindings/clock/suniv-ccu-f1c100s.h | 72 --------- 24 files changed, 2378 deletions(-)
diff --git a/include/dt-bindings/clock/sun20i-d1-ccu.h b/include/dt-bindings/clock/sun20i-d1-ccu.h deleted file mode 100644 index fdbfb404f92a..000000000000 --- a/include/dt-bindings/clock/sun20i-d1-ccu.h +++ /dev/null @@ -1,158 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2020 huangzhenwei@allwinnertech.com - * Copyright (C) 2021 Samuel Holland samuel@sholland.org - */ - -#ifndef _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ -#define _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ - -#define CLK_PLL_CPUX 0 -#define CLK_PLL_DDR0 1 -#define CLK_PLL_PERIPH0_4X 2 -#define CLK_PLL_PERIPH0_2X 3 -#define CLK_PLL_PERIPH0_800M 4 -#define CLK_PLL_PERIPH0 5 -#define CLK_PLL_PERIPH0_DIV3 6 -#define CLK_PLL_VIDEO0_4X 7 -#define CLK_PLL_VIDEO0_2X 8 -#define CLK_PLL_VIDEO0 9 -#define CLK_PLL_VIDEO1_4X 10 -#define CLK_PLL_VIDEO1_2X 11 -#define CLK_PLL_VIDEO1 12 -#define CLK_PLL_VE 13 -#define CLK_PLL_AUDIO0_4X 14 -#define CLK_PLL_AUDIO0_2X 15 -#define CLK_PLL_AUDIO0 16 -#define CLK_PLL_AUDIO1 17 -#define CLK_PLL_AUDIO1_DIV2 18 -#define CLK_PLL_AUDIO1_DIV5 19 -#define CLK_CPUX 20 -#define CLK_CPUX_AXI 21 -#define CLK_CPUX_APB 22 -#define CLK_PSI_AHB 23 -#define CLK_APB0 24 -#define CLK_APB1 25 -#define CLK_MBUS 26 -#define CLK_DE 27 -#define CLK_BUS_DE 28 -#define CLK_DI 29 -#define CLK_BUS_DI 30 -#define CLK_G2D 31 -#define CLK_BUS_G2D 32 -#define CLK_CE 33 -#define CLK_BUS_CE 34 -#define CLK_VE 35 -#define CLK_BUS_VE 36 -#define CLK_BUS_DMA 37 -#define CLK_BUS_MSGBOX0 38 -#define CLK_BUS_MSGBOX1 39 -#define CLK_BUS_MSGBOX2 40 -#define CLK_BUS_SPINLOCK 41 -#define CLK_BUS_HSTIMER 42 -#define CLK_AVS 43 -#define CLK_BUS_DBG 44 -#define CLK_BUS_PWM 45 -#define CLK_BUS_IOMMU 46 -#define CLK_DRAM 47 -#define CLK_MBUS_DMA 48 -#define CLK_MBUS_VE 49 -#define CLK_MBUS_CE 50 -#define CLK_MBUS_TVIN 51 -#define CLK_MBUS_CSI 52 -#define CLK_MBUS_G2D 53 -#define CLK_MBUS_RISCV 54 -#define CLK_BUS_DRAM 55 -#define CLK_MMC0 56 -#define CLK_MMC1 57 -#define CLK_MMC2 58 -#define CLK_BUS_MMC0 59 -#define CLK_BUS_MMC1 60 -#define CLK_BUS_MMC2 61 -#define CLK_BUS_UART0 62 -#define CLK_BUS_UART1 63 -#define CLK_BUS_UART2 64 -#define CLK_BUS_UART3 65 -#define CLK_BUS_UART4 66 -#define CLK_BUS_UART5 67 -#define CLK_BUS_I2C0 68 -#define CLK_BUS_I2C1 69 -#define CLK_BUS_I2C2 70 -#define CLK_BUS_I2C3 71 -#define CLK_SPI0 72 -#define CLK_SPI1 73 -#define CLK_BUS_SPI0 74 -#define CLK_BUS_SPI1 75 -#define CLK_EMAC_25M 76 -#define CLK_BUS_EMAC 77 -#define CLK_IR_TX 78 -#define CLK_BUS_IR_TX 79 -#define CLK_BUS_GPADC 80 -#define CLK_BUS_THS 81 -#define CLK_I2S0 82 -#define CLK_I2S1 83 -#define CLK_I2S2 84 -#define CLK_I2S2_ASRC 85 -#define CLK_BUS_I2S0 86 -#define CLK_BUS_I2S1 87 -#define CLK_BUS_I2S2 88 -#define CLK_SPDIF_TX 89 -#define CLK_SPDIF_RX 90 -#define CLK_BUS_SPDIF 91 -#define CLK_DMIC 92 -#define CLK_BUS_DMIC 93 -#define CLK_AUDIO_DAC 94 -#define CLK_AUDIO_ADC 95 -#define CLK_BUS_AUDIO 96 -#define CLK_USB_OHCI0 97 -#define CLK_USB_OHCI1 98 -#define CLK_BUS_OHCI0 99 -#define CLK_BUS_OHCI1 100 -#define CLK_BUS_EHCI0 101 -#define CLK_BUS_EHCI1 102 -#define CLK_BUS_OTG 103 -#define CLK_BUS_LRADC 104 -#define CLK_BUS_DPSS_TOP 105 -#define CLK_HDMI_24M 106 -#define CLK_HDMI_CEC_32K 107 -#define CLK_HDMI_CEC 108 -#define CLK_BUS_HDMI 109 -#define CLK_MIPI_DSI 110 -#define CLK_BUS_MIPI_DSI 111 -#define CLK_TCON_LCD0 112 -#define CLK_BUS_TCON_LCD0 113 -#define CLK_TCON_TV 114 -#define CLK_BUS_TCON_TV 115 -#define CLK_TVE 116 -#define CLK_BUS_TVE_TOP 117 -#define CLK_BUS_TVE 118 -#define CLK_TVD 119 -#define CLK_BUS_TVD_TOP 120 -#define CLK_BUS_TVD 121 -#define CLK_LEDC 122 -#define CLK_BUS_LEDC 123 -#define CLK_CSI_TOP 124 -#define CLK_CSI_MCLK 125 -#define CLK_BUS_CSI 126 -#define CLK_TPADC 127 -#define CLK_BUS_TPADC 128 -#define CLK_BUS_TZMA 129 -#define CLK_DSP 130 -#define CLK_BUS_DSP_CFG 131 -#define CLK_RISCV 132 -#define CLK_RISCV_AXI 133 -#define CLK_BUS_RISCV_CFG 134 -#define CLK_FANOUT_24M 135 -#define CLK_FANOUT_12M 136 -#define CLK_FANOUT_16M 137 -#define CLK_FANOUT_25M 138 -#define CLK_FANOUT_32K 139 -#define CLK_FANOUT_27M 140 -#define CLK_FANOUT_PCLK 141 -#define CLK_FANOUT0 142 -#define CLK_FANOUT1 143 -#define CLK_FANOUT2 144 -#define CLK_BUS_CAN0 145 -#define CLK_BUS_CAN1 146 - -#endif /* _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun20i-d1-r-ccu.h b/include/dt-bindings/clock/sun20i-d1-r-ccu.h deleted file mode 100644 index f95c170711e5..000000000000 --- a/include/dt-bindings/clock/sun20i-d1-r-ccu.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2021 Samuel Holland samuel@sholland.org - */ - -#ifndef _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ -#define _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ - -#define CLK_R_AHB 0 - -#define CLK_BUS_R_TIMER 2 -#define CLK_BUS_R_TWD 3 -#define CLK_BUS_R_PPU 4 -#define CLK_R_IR_RX 5 -#define CLK_BUS_R_IR_RX 6 -#define CLK_BUS_R_RTC 7 -#define CLK_BUS_R_CPUCFG 8 - -#endif /* _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun4i-a10-ccu.h b/include/dt-bindings/clock/sun4i-a10-ccu.h deleted file mode 100644 index e4fa61be5c75..000000000000 --- a/include/dt-bindings/clock/sun4i-a10-ccu.h +++ /dev/null @@ -1,202 +0,0 @@ -/* - * Copyright (C) 2017 Priit Laes plaes@plaes.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN4I_A10_H_ -#define _DT_BINDINGS_CLK_SUN4I_A10_H_ - -#define CLK_HOSC 1 -#define CLK_PLL_VIDEO0_2X 9 -#define CLK_PLL_VIDEO1_2X 18 -#define CLK_CPU 20 - -/* AHB Gates */ -#define CLK_AHB_OTG 26 -#define CLK_AHB_EHCI0 27 -#define CLK_AHB_OHCI0 28 -#define CLK_AHB_EHCI1 29 -#define CLK_AHB_OHCI1 30 -#define CLK_AHB_SS 31 -#define CLK_AHB_DMA 32 -#define CLK_AHB_BIST 33 -#define CLK_AHB_MMC0 34 -#define CLK_AHB_MMC1 35 -#define CLK_AHB_MMC2 36 -#define CLK_AHB_MMC3 37 -#define CLK_AHB_MS 38 -#define CLK_AHB_NAND 39 -#define CLK_AHB_SDRAM 40 -#define CLK_AHB_ACE 41 -#define CLK_AHB_EMAC 42 -#define CLK_AHB_TS 43 -#define CLK_AHB_SPI0 44 -#define CLK_AHB_SPI1 45 -#define CLK_AHB_SPI2 46 -#define CLK_AHB_SPI3 47 -#define CLK_AHB_PATA 48 -#define CLK_AHB_SATA 49 -#define CLK_AHB_GPS 50 -#define CLK_AHB_HSTIMER 51 -#define CLK_AHB_VE 52 -#define CLK_AHB_TVD 53 -#define CLK_AHB_TVE0 54 -#define CLK_AHB_TVE1 55 -#define CLK_AHB_LCD0 56 -#define CLK_AHB_LCD1 57 -#define CLK_AHB_CSI0 58 -#define CLK_AHB_CSI1 59 -#define CLK_AHB_HDMI0 60 -#define CLK_AHB_HDMI1 61 -#define CLK_AHB_DE_BE0 62 -#define CLK_AHB_DE_BE1 63 -#define CLK_AHB_DE_FE0 64 -#define CLK_AHB_DE_FE1 65 -#define CLK_AHB_GMAC 66 -#define CLK_AHB_MP 67 -#define CLK_AHB_GPU 68 - -/* APB0 Gates */ -#define CLK_APB0_CODEC 69 -#define CLK_APB0_SPDIF 70 -#define CLK_APB0_I2S0 71 -#define CLK_APB0_AC97 72 -#define CLK_APB0_I2S1 73 -#define CLK_APB0_PIO 74 -#define CLK_APB0_IR0 75 -#define CLK_APB0_IR1 76 -#define CLK_APB0_I2S2 77 -#define CLK_APB0_KEYPAD 78 - -/* APB1 Gates */ -#define CLK_APB1_I2C0 79 -#define CLK_APB1_I2C1 80 -#define CLK_APB1_I2C2 81 -#define CLK_APB1_I2C3 82 -#define CLK_APB1_CAN 83 -#define CLK_APB1_SCR 84 -#define CLK_APB1_PS20 85 -#define CLK_APB1_PS21 86 -#define CLK_APB1_I2C4 87 -#define CLK_APB1_UART0 88 -#define CLK_APB1_UART1 89 -#define CLK_APB1_UART2 90 -#define CLK_APB1_UART3 91 -#define CLK_APB1_UART4 92 -#define CLK_APB1_UART5 93 -#define CLK_APB1_UART6 94 -#define CLK_APB1_UART7 95 - -/* IP clocks */ -#define CLK_NAND 96 -#define CLK_MS 97 -#define CLK_MMC0 98 -#define CLK_MMC0_OUTPUT 99 -#define CLK_MMC0_SAMPLE 100 -#define CLK_MMC1 101 -#define CLK_MMC1_OUTPUT 102 -#define CLK_MMC1_SAMPLE 103 -#define CLK_MMC2 104 -#define CLK_MMC2_OUTPUT 105 -#define CLK_MMC2_SAMPLE 106 -#define CLK_MMC3 107 -#define CLK_MMC3_OUTPUT 108 -#define CLK_MMC3_SAMPLE 109 -#define CLK_TS 110 -#define CLK_SS 111 -#define CLK_SPI0 112 -#define CLK_SPI1 113 -#define CLK_SPI2 114 -#define CLK_PATA 115 -#define CLK_IR0 116 -#define CLK_IR1 117 -#define CLK_I2S0 118 -#define CLK_AC97 119 -#define CLK_SPDIF 120 -#define CLK_KEYPAD 121 -#define CLK_SATA 122 -#define CLK_USB_OHCI0 123 -#define CLK_USB_OHCI1 124 -#define CLK_USB_PHY 125 -#define CLK_GPS 126 -#define CLK_SPI3 127 -#define CLK_I2S1 128 -#define CLK_I2S2 129 - -/* DRAM Gates */ -#define CLK_DRAM_VE 130 -#define CLK_DRAM_CSI0 131 -#define CLK_DRAM_CSI1 132 -#define CLK_DRAM_TS 133 -#define CLK_DRAM_TVD 134 -#define CLK_DRAM_TVE0 135 -#define CLK_DRAM_TVE1 136 -#define CLK_DRAM_OUT 137 -#define CLK_DRAM_DE_FE1 138 -#define CLK_DRAM_DE_FE0 139 -#define CLK_DRAM_DE_BE0 140 -#define CLK_DRAM_DE_BE1 141 -#define CLK_DRAM_MP 142 -#define CLK_DRAM_ACE 143 - -/* Display Engine Clocks */ -#define CLK_DE_BE0 144 -#define CLK_DE_BE1 145 -#define CLK_DE_FE0 146 -#define CLK_DE_FE1 147 -#define CLK_DE_MP 148 -#define CLK_TCON0_CH0 149 -#define CLK_TCON1_CH0 150 -#define CLK_CSI_SCLK 151 -#define CLK_TVD_SCLK2 152 -#define CLK_TVD 153 -#define CLK_TCON0_CH1_SCLK2 154 -#define CLK_TCON0_CH1 155 -#define CLK_TCON1_CH1_SCLK2 156 -#define CLK_TCON1_CH1 157 -#define CLK_CSI0 158 -#define CLK_CSI1 159 -#define CLK_CODEC 160 -#define CLK_VE 161 -#define CLK_AVS 162 -#define CLK_ACE 163 -#define CLK_HDMI 164 -#define CLK_GPU 165 - -#endif /* _DT_BINDINGS_CLK_SUN4I_A10_H_ */ diff --git a/include/dt-bindings/clock/sun4i-a10-pll2.h b/include/dt-bindings/clock/sun4i-a10-pll2.h deleted file mode 100644 index 071c8112d531..000000000000 --- a/include/dt-bindings/clock/sun4i-a10-pll2.h +++ /dev/null @@ -1,53 +0,0 @@ -/* - * Copyright 2015 Maxime Ripard - * - * Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef __DT_BINDINGS_CLOCK_SUN4I_A10_PLL2_H_ -#define __DT_BINDINGS_CLOCK_SUN4I_A10_PLL2_H_ - -#define SUN4I_A10_PLL2_1X 0 -#define SUN4I_A10_PLL2_2X 1 -#define SUN4I_A10_PLL2_4X 2 -#define SUN4I_A10_PLL2_8X 3 - -#endif /* __DT_BINDINGS_CLOCK_SUN4I_A10_PLL2_H_ */ diff --git a/include/dt-bindings/clock/sun50i-a64-ccu.h b/include/dt-bindings/clock/sun50i-a64-ccu.h deleted file mode 100644 index 175892189e9d..000000000000 --- a/include/dt-bindings/clock/sun50i-a64-ccu.h +++ /dev/null @@ -1,138 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN50I_A64_H_ -#define _DT_BINDINGS_CLK_SUN50I_A64_H_ - -#define CLK_PLL_VIDEO0 7 -#define CLK_PLL_PERIPH0 11 - -#define CLK_CPUX 21 -#define CLK_BUS_MIPI_DSI 28 -#define CLK_BUS_CE 29 -#define CLK_BUS_DMA 30 -#define CLK_BUS_MMC0 31 -#define CLK_BUS_MMC1 32 -#define CLK_BUS_MMC2 33 -#define CLK_BUS_NAND 34 -#define CLK_BUS_DRAM 35 -#define CLK_BUS_EMAC 36 -#define CLK_BUS_TS 37 -#define CLK_BUS_HSTIMER 38 -#define CLK_BUS_SPI0 39 -#define CLK_BUS_SPI1 40 -#define CLK_BUS_OTG 41 -#define CLK_BUS_EHCI0 42 -#define CLK_BUS_EHCI1 43 -#define CLK_BUS_OHCI0 44 -#define CLK_BUS_OHCI1 45 -#define CLK_BUS_VE 46 -#define CLK_BUS_TCON0 47 -#define CLK_BUS_TCON1 48 -#define CLK_BUS_DEINTERLACE 49 -#define CLK_BUS_CSI 50 -#define CLK_BUS_HDMI 51 -#define CLK_BUS_DE 52 -#define CLK_BUS_GPU 53 -#define CLK_BUS_MSGBOX 54 -#define CLK_BUS_SPINLOCK 55 -#define CLK_BUS_CODEC 56 -#define CLK_BUS_SPDIF 57 -#define CLK_BUS_PIO 58 -#define CLK_BUS_THS 59 -#define CLK_BUS_I2S0 60 -#define CLK_BUS_I2S1 61 -#define CLK_BUS_I2S2 62 -#define CLK_BUS_I2C0 63 -#define CLK_BUS_I2C1 64 -#define CLK_BUS_I2C2 65 -#define CLK_BUS_SCR 66 -#define CLK_BUS_UART0 67 -#define CLK_BUS_UART1 68 -#define CLK_BUS_UART2 69 -#define CLK_BUS_UART3 70 -#define CLK_BUS_UART4 71 -#define CLK_BUS_DBG 72 -#define CLK_THS 73 -#define CLK_NAND 74 -#define CLK_MMC0 75 -#define CLK_MMC1 76 -#define CLK_MMC2 77 -#define CLK_TS 78 -#define CLK_CE 79 -#define CLK_SPI0 80 -#define CLK_SPI1 81 -#define CLK_I2S0 82 -#define CLK_I2S1 83 -#define CLK_I2S2 84 -#define CLK_SPDIF 85 -#define CLK_USB_PHY0 86 -#define CLK_USB_PHY1 87 -#define CLK_USB_HSIC 88 -#define CLK_USB_HSIC_12M 89 - -#define CLK_USB_OHCI0 91 - -#define CLK_USB_OHCI1 93 -#define CLK_DRAM 94 -#define CLK_DRAM_VE 95 -#define CLK_DRAM_CSI 96 -#define CLK_DRAM_DEINTERLACE 97 -#define CLK_DRAM_TS 98 -#define CLK_DE 99 -#define CLK_TCON0 100 -#define CLK_TCON1 101 -#define CLK_DEINTERLACE 102 -#define CLK_CSI_MISC 103 -#define CLK_CSI_SCLK 104 -#define CLK_CSI_MCLK 105 -#define CLK_VE 106 -#define CLK_AC_DIG 107 -#define CLK_AC_DIG_4X 108 -#define CLK_AVS 109 -#define CLK_HDMI 110 -#define CLK_HDMI_DDC 111 -#define CLK_MBUS 112 -#define CLK_DSI_DPHY 113 -#define CLK_GPU 114 - -#endif /* _DT_BINDINGS_CLK_SUN50I_H_ */ diff --git a/include/dt-bindings/clock/sun50i-h6-ccu.h b/include/dt-bindings/clock/sun50i-h6-ccu.h deleted file mode 100644 index ef9123d81937..000000000000 --- a/include/dt-bindings/clock/sun50i-h6-ccu.h +++ /dev/null @@ -1,125 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - */ - -#ifndef _DT_BINDINGS_CLK_SUN50I_H6_H_ -#define _DT_BINDINGS_CLK_SUN50I_H6_H_ - -#define CLK_PLL_PERIPH0 3 - -#define CLK_CPUX 21 - -#define CLK_APB1 26 - -#define CLK_DE 29 -#define CLK_BUS_DE 30 -#define CLK_DEINTERLACE 31 -#define CLK_BUS_DEINTERLACE 32 -#define CLK_GPU 33 -#define CLK_BUS_GPU 34 -#define CLK_CE 35 -#define CLK_BUS_CE 36 -#define CLK_VE 37 -#define CLK_BUS_VE 38 -#define CLK_EMCE 39 -#define CLK_BUS_EMCE 40 -#define CLK_VP9 41 -#define CLK_BUS_VP9 42 -#define CLK_BUS_DMA 43 -#define CLK_BUS_MSGBOX 44 -#define CLK_BUS_SPINLOCK 45 -#define CLK_BUS_HSTIMER 46 -#define CLK_AVS 47 -#define CLK_BUS_DBG 48 -#define CLK_BUS_PSI 49 -#define CLK_BUS_PWM 50 -#define CLK_BUS_IOMMU 51 - -#define CLK_MBUS_DMA 53 -#define CLK_MBUS_VE 54 -#define CLK_MBUS_CE 55 -#define CLK_MBUS_TS 56 -#define CLK_MBUS_NAND 57 -#define CLK_MBUS_CSI 58 -#define CLK_MBUS_DEINTERLACE 59 - -#define CLK_NAND0 61 -#define CLK_NAND1 62 -#define CLK_BUS_NAND 63 -#define CLK_MMC0 64 -#define CLK_MMC1 65 -#define CLK_MMC2 66 -#define CLK_BUS_MMC0 67 -#define CLK_BUS_MMC1 68 -#define CLK_BUS_MMC2 69 -#define CLK_BUS_UART0 70 -#define CLK_BUS_UART1 71 -#define CLK_BUS_UART2 72 -#define CLK_BUS_UART3 73 -#define CLK_BUS_I2C0 74 -#define CLK_BUS_I2C1 75 -#define CLK_BUS_I2C2 76 -#define CLK_BUS_I2C3 77 -#define CLK_BUS_SCR0 78 -#define CLK_BUS_SCR1 79 -#define CLK_SPI0 80 -#define CLK_SPI1 81 -#define CLK_BUS_SPI0 82 -#define CLK_BUS_SPI1 83 -#define CLK_BUS_EMAC 84 -#define CLK_TS 85 -#define CLK_BUS_TS 86 -#define CLK_IR_TX 87 -#define CLK_BUS_IR_TX 88 -#define CLK_BUS_THS 89 -#define CLK_I2S3 90 -#define CLK_I2S0 91 -#define CLK_I2S1 92 -#define CLK_I2S2 93 -#define CLK_BUS_I2S0 94 -#define CLK_BUS_I2S1 95 -#define CLK_BUS_I2S2 96 -#define CLK_BUS_I2S3 97 -#define CLK_SPDIF 98 -#define CLK_BUS_SPDIF 99 -#define CLK_DMIC 100 -#define CLK_BUS_DMIC 101 -#define CLK_AUDIO_HUB 102 -#define CLK_BUS_AUDIO_HUB 103 -#define CLK_USB_OHCI0 104 -#define CLK_USB_PHY0 105 -#define CLK_USB_PHY1 106 -#define CLK_USB_OHCI3 107 -#define CLK_USB_PHY3 108 -#define CLK_USB_HSIC_12M 109 -#define CLK_USB_HSIC 110 -#define CLK_BUS_OHCI0 111 -#define CLK_BUS_OHCI3 112 -#define CLK_BUS_EHCI0 113 -#define CLK_BUS_XHCI 114 -#define CLK_BUS_EHCI3 115 -#define CLK_BUS_OTG 116 -#define CLK_PCIE_REF_100M 117 -#define CLK_PCIE_REF 118 -#define CLK_PCIE_REF_OUT 119 -#define CLK_PCIE_MAXI 120 -#define CLK_PCIE_AUX 121 -#define CLK_BUS_PCIE 122 -#define CLK_HDMI 123 -#define CLK_HDMI_SLOW 124 -#define CLK_HDMI_CEC 125 -#define CLK_BUS_HDMI 126 -#define CLK_BUS_TCON_TOP 127 -#define CLK_TCON_LCD0 128 -#define CLK_BUS_TCON_LCD0 129 -#define CLK_TCON_TV0 130 -#define CLK_BUS_TCON_TV0 131 -#define CLK_CSI_CCI 132 -#define CLK_CSI_TOP 133 -#define CLK_CSI_MCLK 134 -#define CLK_BUS_CSI 135 -#define CLK_HDCP 136 -#define CLK_BUS_HDCP 137 - -#endif /* _DT_BINDINGS_CLK_SUN50I_H6_H_ */ diff --git a/include/dt-bindings/clock/sun50i-h6-r-ccu.h b/include/dt-bindings/clock/sun50i-h6-r-ccu.h deleted file mode 100644 index a96087abc86f..000000000000 --- a/include/dt-bindings/clock/sun50i-h6-r-ccu.h +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2017 Icenowy Zheng icenowy@aosc.xyz - */ - -#ifndef _DT_BINDINGS_CLK_SUN50I_H6_R_CCU_H_ -#define _DT_BINDINGS_CLK_SUN50I_H6_R_CCU_H_ - -#define CLK_AR100 0 - -#define CLK_R_APB1 2 - -#define CLK_R_APB1_TIMER 4 -#define CLK_R_APB1_TWD 5 -#define CLK_R_APB1_PWM 6 -#define CLK_R_APB2_UART 7 -#define CLK_R_APB2_I2C 8 -#define CLK_R_APB1_IR 9 -#define CLK_R_APB1_W1 10 - -#define CLK_IR 11 -#define CLK_W1 12 - -#define CLK_R_APB2_RSB 13 -#define CLK_R_APB1_RTC 14 - -#endif /* _DT_BINDINGS_CLK_SUN50I_H6_R_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun50i-h616-ccu.h b/include/dt-bindings/clock/sun50i-h616-ccu.h deleted file mode 100644 index 6f8f01e67628..000000000000 --- a/include/dt-bindings/clock/sun50i-h616-ccu.h +++ /dev/null @@ -1,116 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2020 Arm Ltd. - */ - -#ifndef _DT_BINDINGS_CLK_SUN50I_H616_H_ -#define _DT_BINDINGS_CLK_SUN50I_H616_H_ - -#define CLK_PLL_PERIPH0 4 - -#define CLK_CPUX 21 - -#define CLK_APB1 26 - -#define CLK_DE 29 -#define CLK_BUS_DE 30 -#define CLK_DEINTERLACE 31 -#define CLK_BUS_DEINTERLACE 32 -#define CLK_G2D 33 -#define CLK_BUS_G2D 34 -#define CLK_GPU0 35 -#define CLK_BUS_GPU 36 -#define CLK_GPU1 37 -#define CLK_CE 38 -#define CLK_BUS_CE 39 -#define CLK_VE 40 -#define CLK_BUS_VE 41 -#define CLK_BUS_DMA 42 -#define CLK_BUS_HSTIMER 43 -#define CLK_AVS 44 -#define CLK_BUS_DBG 45 -#define CLK_BUS_PSI 46 -#define CLK_BUS_PWM 47 -#define CLK_BUS_IOMMU 48 - -#define CLK_MBUS_DMA 50 -#define CLK_MBUS_VE 51 -#define CLK_MBUS_CE 52 -#define CLK_MBUS_TS 53 -#define CLK_MBUS_NAND 54 -#define CLK_MBUS_G2D 55 - -#define CLK_NAND0 57 -#define CLK_NAND1 58 -#define CLK_BUS_NAND 59 -#define CLK_MMC0 60 -#define CLK_MMC1 61 -#define CLK_MMC2 62 -#define CLK_BUS_MMC0 63 -#define CLK_BUS_MMC1 64 -#define CLK_BUS_MMC2 65 -#define CLK_BUS_UART0 66 -#define CLK_BUS_UART1 67 -#define CLK_BUS_UART2 68 -#define CLK_BUS_UART3 69 -#define CLK_BUS_UART4 70 -#define CLK_BUS_UART5 71 -#define CLK_BUS_I2C0 72 -#define CLK_BUS_I2C1 73 -#define CLK_BUS_I2C2 74 -#define CLK_BUS_I2C3 75 -#define CLK_BUS_I2C4 76 -#define CLK_SPI0 77 -#define CLK_SPI1 78 -#define CLK_BUS_SPI0 79 -#define CLK_BUS_SPI1 80 -#define CLK_EMAC_25M 81 -#define CLK_BUS_EMAC0 82 -#define CLK_BUS_EMAC1 83 -#define CLK_TS 84 -#define CLK_BUS_TS 85 -#define CLK_BUS_THS 86 -#define CLK_SPDIF 87 -#define CLK_BUS_SPDIF 88 -#define CLK_DMIC 89 -#define CLK_BUS_DMIC 90 -#define CLK_AUDIO_CODEC_1X 91 -#define CLK_AUDIO_CODEC_4X 92 -#define CLK_BUS_AUDIO_CODEC 93 -#define CLK_AUDIO_HUB 94 -#define CLK_BUS_AUDIO_HUB 95 -#define CLK_USB_OHCI0 96 -#define CLK_USB_PHY0 97 -#define CLK_USB_OHCI1 98 -#define CLK_USB_PHY1 99 -#define CLK_USB_OHCI2 100 -#define CLK_USB_PHY2 101 -#define CLK_USB_OHCI3 102 -#define CLK_USB_PHY3 103 -#define CLK_BUS_OHCI0 104 -#define CLK_BUS_OHCI1 105 -#define CLK_BUS_OHCI2 106 -#define CLK_BUS_OHCI3 107 -#define CLK_BUS_EHCI0 108 -#define CLK_BUS_EHCI1 109 -#define CLK_BUS_EHCI2 110 -#define CLK_BUS_EHCI3 111 -#define CLK_BUS_OTG 112 -#define CLK_BUS_KEYADC 113 -#define CLK_HDMI 114 -#define CLK_HDMI_SLOW 115 -#define CLK_HDMI_CEC 116 -#define CLK_BUS_HDMI 117 -#define CLK_BUS_TCON_TOP 118 -#define CLK_TCON_TV0 119 -#define CLK_TCON_TV1 120 -#define CLK_BUS_TCON_TV0 121 -#define CLK_BUS_TCON_TV1 122 -#define CLK_TVE0 123 -#define CLK_BUS_TVE_TOP 124 -#define CLK_BUS_TVE0 125 -#define CLK_HDCP 126 -#define CLK_BUS_HDCP 127 -#define CLK_PLL_SYSTEM_32K 128 - -#endif /* _DT_BINDINGS_CLK_SUN50I_H616_H_ */ diff --git a/include/dt-bindings/clock/sun5i-ccu.h b/include/dt-bindings/clock/sun5i-ccu.h deleted file mode 100644 index 75fe5619c3d9..000000000000 --- a/include/dt-bindings/clock/sun5i-ccu.h +++ /dev/null @@ -1,97 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright 2016 Maxime Ripard - * - * Maxime Ripard maxime.ripard@free-electrons.com - */ - -#ifndef _DT_BINDINGS_CLK_SUN5I_H_ -#define _DT_BINDINGS_CLK_SUN5I_H_ - -#define CLK_HOSC 1 - -#define CLK_PLL_VIDEO0_2X 9 - -#define CLK_PLL_VIDEO1_2X 16 -#define CLK_CPU 17 - -#define CLK_AHB_OTG 23 -#define CLK_AHB_EHCI 24 -#define CLK_AHB_OHCI 25 -#define CLK_AHB_SS 26 -#define CLK_AHB_DMA 27 -#define CLK_AHB_BIST 28 -#define CLK_AHB_MMC0 29 -#define CLK_AHB_MMC1 30 -#define CLK_AHB_MMC2 31 -#define CLK_AHB_NAND 32 -#define CLK_AHB_SDRAM 33 -#define CLK_AHB_EMAC 34 -#define CLK_AHB_TS 35 -#define CLK_AHB_SPI0 36 -#define CLK_AHB_SPI1 37 -#define CLK_AHB_SPI2 38 -#define CLK_AHB_GPS 39 -#define CLK_AHB_HSTIMER 40 -#define CLK_AHB_VE 41 -#define CLK_AHB_TVE 42 -#define CLK_AHB_LCD 43 -#define CLK_AHB_CSI 44 -#define CLK_AHB_HDMI 45 -#define CLK_AHB_DE_BE 46 -#define CLK_AHB_DE_FE 47 -#define CLK_AHB_IEP 48 -#define CLK_AHB_GPU 49 -#define CLK_APB0_CODEC 50 -#define CLK_APB0_SPDIF 51 -#define CLK_APB0_I2S 52 -#define CLK_APB0_PIO 53 -#define CLK_APB0_IR 54 -#define CLK_APB0_KEYPAD 55 -#define CLK_APB1_I2C0 56 -#define CLK_APB1_I2C1 57 -#define CLK_APB1_I2C2 58 -#define CLK_APB1_UART0 59 -#define CLK_APB1_UART1 60 -#define CLK_APB1_UART2 61 -#define CLK_APB1_UART3 62 -#define CLK_NAND 63 -#define CLK_MMC0 64 -#define CLK_MMC1 65 -#define CLK_MMC2 66 -#define CLK_TS 67 -#define CLK_SS 68 -#define CLK_SPI0 69 -#define CLK_SPI1 70 -#define CLK_SPI2 71 -#define CLK_IR 72 -#define CLK_I2S 73 -#define CLK_SPDIF 74 -#define CLK_KEYPAD 75 -#define CLK_USB_OHCI 76 -#define CLK_USB_PHY0 77 -#define CLK_USB_PHY1 78 -#define CLK_GPS 79 -#define CLK_DRAM_VE 80 -#define CLK_DRAM_CSI 81 -#define CLK_DRAM_TS 82 -#define CLK_DRAM_TVE 83 -#define CLK_DRAM_DE_FE 84 -#define CLK_DRAM_DE_BE 85 -#define CLK_DRAM_ACE 86 -#define CLK_DRAM_IEP 87 -#define CLK_DE_BE 88 -#define CLK_DE_FE 89 -#define CLK_TCON_CH0 90 - -#define CLK_TCON_CH1 92 -#define CLK_CSI 93 -#define CLK_VE 94 -#define CLK_CODEC 95 -#define CLK_AVS 96 -#define CLK_HDMI 97 -#define CLK_GPU 98 -#define CLK_MBUS 99 -#define CLK_IEP 100 - -#endif /* _DT_BINDINGS_CLK_SUN5I_H_ */ diff --git a/include/dt-bindings/clock/sun6i-a31-ccu.h b/include/dt-bindings/clock/sun6i-a31-ccu.h deleted file mode 100644 index 39878d9dce9f..000000000000 --- a/include/dt-bindings/clock/sun6i-a31-ccu.h +++ /dev/null @@ -1,193 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN6I_A31_H_ -#define _DT_BINDINGS_CLK_SUN6I_A31_H_ - -#define CLK_PLL_VIDEO0_2X 7 - -#define CLK_PLL_PERIPH 10 - -#define CLK_PLL_VIDEO1_2X 13 - -#define CLK_PLL_MIPI 15 - -#define CLK_CPU 18 - -#define CLK_AHB1_MIPIDSI 23 -#define CLK_AHB1_SS 24 -#define CLK_AHB1_DMA 25 -#define CLK_AHB1_MMC0 26 -#define CLK_AHB1_MMC1 27 -#define CLK_AHB1_MMC2 28 -#define CLK_AHB1_MMC3 29 -#define CLK_AHB1_NAND1 30 -#define CLK_AHB1_NAND0 31 -#define CLK_AHB1_SDRAM 32 -#define CLK_AHB1_EMAC 33 -#define CLK_AHB1_TS 34 -#define CLK_AHB1_HSTIMER 35 -#define CLK_AHB1_SPI0 36 -#define CLK_AHB1_SPI1 37 -#define CLK_AHB1_SPI2 38 -#define CLK_AHB1_SPI3 39 -#define CLK_AHB1_OTG 40 -#define CLK_AHB1_EHCI0 41 -#define CLK_AHB1_EHCI1 42 -#define CLK_AHB1_OHCI0 43 -#define CLK_AHB1_OHCI1 44 -#define CLK_AHB1_OHCI2 45 -#define CLK_AHB1_VE 46 -#define CLK_AHB1_LCD0 47 -#define CLK_AHB1_LCD1 48 -#define CLK_AHB1_CSI 49 -#define CLK_AHB1_HDMI 50 -#define CLK_AHB1_BE0 51 -#define CLK_AHB1_BE1 52 -#define CLK_AHB1_FE0 53 -#define CLK_AHB1_FE1 54 -#define CLK_AHB1_MP 55 -#define CLK_AHB1_GPU 56 -#define CLK_AHB1_DEU0 57 -#define CLK_AHB1_DEU1 58 -#define CLK_AHB1_DRC0 59 -#define CLK_AHB1_DRC1 60 - -#define CLK_APB1_CODEC 61 -#define CLK_APB1_SPDIF 62 -#define CLK_APB1_DIGITAL_MIC 63 -#define CLK_APB1_PIO 64 -#define CLK_APB1_DAUDIO0 65 -#define CLK_APB1_DAUDIO1 66 - -#define CLK_APB2_I2C0 67 -#define CLK_APB2_I2C1 68 -#define CLK_APB2_I2C2 69 -#define CLK_APB2_I2C3 70 -#define CLK_APB2_UART0 71 -#define CLK_APB2_UART1 72 -#define CLK_APB2_UART2 73 -#define CLK_APB2_UART3 74 -#define CLK_APB2_UART4 75 -#define CLK_APB2_UART5 76 - -#define CLK_NAND0 77 -#define CLK_NAND1 78 -#define CLK_MMC0 79 -#define CLK_MMC0_SAMPLE 80 -#define CLK_MMC0_OUTPUT 81 -#define CLK_MMC1 82 -#define CLK_MMC1_SAMPLE 83 -#define CLK_MMC1_OUTPUT 84 -#define CLK_MMC2 85 -#define CLK_MMC2_SAMPLE 86 -#define CLK_MMC2_OUTPUT 87 -#define CLK_MMC3 88 -#define CLK_MMC3_SAMPLE 89 -#define CLK_MMC3_OUTPUT 90 -#define CLK_TS 91 -#define CLK_SS 92 -#define CLK_SPI0 93 -#define CLK_SPI1 94 -#define CLK_SPI2 95 -#define CLK_SPI3 96 -#define CLK_DAUDIO0 97 -#define CLK_DAUDIO1 98 -#define CLK_SPDIF 99 -#define CLK_USB_PHY0 100 -#define CLK_USB_PHY1 101 -#define CLK_USB_PHY2 102 -#define CLK_USB_OHCI0 103 -#define CLK_USB_OHCI1 104 -#define CLK_USB_OHCI2 105 - -#define CLK_DRAM_VE 110 -#define CLK_DRAM_CSI_ISP 111 -#define CLK_DRAM_TS 112 -#define CLK_DRAM_DRC0 113 -#define CLK_DRAM_DRC1 114 -#define CLK_DRAM_DEU0 115 -#define CLK_DRAM_DEU1 116 -#define CLK_DRAM_FE0 117 -#define CLK_DRAM_FE1 118 -#define CLK_DRAM_BE0 119 -#define CLK_DRAM_BE1 120 -#define CLK_DRAM_MP 121 - -#define CLK_BE0 122 -#define CLK_BE1 123 -#define CLK_FE0 124 -#define CLK_FE1 125 -#define CLK_MP 126 -#define CLK_LCD0_CH0 127 -#define CLK_LCD1_CH0 128 -#define CLK_LCD0_CH1 129 -#define CLK_LCD1_CH1 130 -#define CLK_CSI0_SCLK 131 -#define CLK_CSI0_MCLK 132 -#define CLK_CSI1_MCLK 133 -#define CLK_VE 134 -#define CLK_CODEC 135 -#define CLK_AVS 136 -#define CLK_DIGITAL_MIC 137 -#define CLK_HDMI 138 -#define CLK_HDMI_DDC 139 -#define CLK_PS 140 - -#define CLK_MIPI_DSI 143 -#define CLK_MIPI_DSI_DPHY 144 -#define CLK_MIPI_CSI_DPHY 145 -#define CLK_IEP_DRC0 146 -#define CLK_IEP_DRC1 147 -#define CLK_IEP_DEU0 148 -#define CLK_IEP_DEU1 149 -#define CLK_GPU_CORE 150 -#define CLK_GPU_MEMORY 151 -#define CLK_GPU_HYD 152 -#define CLK_ATS 153 -#define CLK_TRACE 154 - -#define CLK_OUT_A 155 -#define CLK_OUT_B 156 -#define CLK_OUT_C 157 - -#endif /* _DT_BINDINGS_CLK_SUN6I_A31_H_ */ diff --git a/include/dt-bindings/clock/sun6i-rtc.h b/include/dt-bindings/clock/sun6i-rtc.h deleted file mode 100644 index 3bd3aa3d57ce..000000000000 --- a/include/dt-bindings/clock/sun6i-rtc.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ - -#ifndef _DT_BINDINGS_CLK_SUN6I_RTC_H_ -#define _DT_BINDINGS_CLK_SUN6I_RTC_H_ - -#define CLK_OSC32K 0 -#define CLK_OSC32K_FANOUT 1 -#define CLK_IOSC 2 - -#endif /* _DT_BINDINGS_CLK_SUN6I_RTC_H_ */ diff --git a/include/dt-bindings/clock/sun7i-a20-ccu.h b/include/dt-bindings/clock/sun7i-a20-ccu.h deleted file mode 100644 index 045a5178da0c..000000000000 --- a/include/dt-bindings/clock/sun7i-a20-ccu.h +++ /dev/null @@ -1,53 +0,0 @@ -/* - * Copyright (C) 2017 Priit Laes plaes@plaes.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN7I_A20_H_ -#define _DT_BINDINGS_CLK_SUN7I_A20_H_ - -#include <dt-bindings/clock/sun4i-a10-ccu.h> - -#define CLK_MBUS 166 -#define CLK_HDMI1_SLOW 167 -#define CLK_HDMI1 168 -#define CLK_OUT_A 169 -#define CLK_OUT_B 170 - -#endif /* _DT_BINDINGS_CLK_SUN7I_A20_H_ */ diff --git a/include/dt-bindings/clock/sun8i-a23-a33-ccu.h b/include/dt-bindings/clock/sun8i-a23-a33-ccu.h deleted file mode 100644 index eb524d0bbd01..000000000000 --- a/include/dt-bindings/clock/sun8i-a23-a33-ccu.h +++ /dev/null @@ -1,129 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ -#define _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ - -#define CLK_PLL_MIPI 13 - -#define CLK_CPUX 18 - -#define CLK_BUS_MIPI_DSI 23 -#define CLK_BUS_SS 24 -#define CLK_BUS_DMA 25 -#define CLK_BUS_MMC0 26 -#define CLK_BUS_MMC1 27 -#define CLK_BUS_MMC2 28 -#define CLK_BUS_NAND 29 -#define CLK_BUS_DRAM 30 -#define CLK_BUS_HSTIMER 31 -#define CLK_BUS_SPI0 32 -#define CLK_BUS_SPI1 33 -#define CLK_BUS_OTG 34 -#define CLK_BUS_EHCI 35 -#define CLK_BUS_OHCI 36 -#define CLK_BUS_VE 37 -#define CLK_BUS_LCD 38 -#define CLK_BUS_CSI 39 -#define CLK_BUS_DE_BE 40 -#define CLK_BUS_DE_FE 41 -#define CLK_BUS_GPU 42 -#define CLK_BUS_MSGBOX 43 -#define CLK_BUS_SPINLOCK 44 -#define CLK_BUS_DRC 45 -#define CLK_BUS_SAT 46 -#define CLK_BUS_CODEC 47 -#define CLK_BUS_PIO 48 -#define CLK_BUS_I2S0 49 -#define CLK_BUS_I2S1 50 -#define CLK_BUS_I2C0 51 -#define CLK_BUS_I2C1 52 -#define CLK_BUS_I2C2 53 -#define CLK_BUS_UART0 54 -#define CLK_BUS_UART1 55 -#define CLK_BUS_UART2 56 -#define CLK_BUS_UART3 57 -#define CLK_BUS_UART4 58 -#define CLK_NAND 59 -#define CLK_MMC0 60 -#define CLK_MMC0_SAMPLE 61 -#define CLK_MMC0_OUTPUT 62 -#define CLK_MMC1 63 -#define CLK_MMC1_SAMPLE 64 -#define CLK_MMC1_OUTPUT 65 -#define CLK_MMC2 66 -#define CLK_MMC2_SAMPLE 67 -#define CLK_MMC2_OUTPUT 68 -#define CLK_SS 69 -#define CLK_SPI0 70 -#define CLK_SPI1 71 -#define CLK_I2S0 72 -#define CLK_I2S1 73 -#define CLK_USB_PHY0 74 -#define CLK_USB_PHY1 75 -#define CLK_USB_HSIC 76 -#define CLK_USB_HSIC_12M 77 -#define CLK_USB_OHCI 78 - -#define CLK_DRAM_VE 80 -#define CLK_DRAM_CSI 81 -#define CLK_DRAM_DRC 82 -#define CLK_DRAM_DE_FE 83 -#define CLK_DRAM_DE_BE 84 -#define CLK_DE_BE 85 -#define CLK_DE_FE 86 -#define CLK_LCD_CH0 87 -#define CLK_LCD_CH1 88 -#define CLK_CSI_SCLK 89 -#define CLK_CSI_MCLK 90 -#define CLK_VE 91 -#define CLK_AC_DIG 92 -#define CLK_AC_DIG_4X 93 -#define CLK_AVS 94 - -#define CLK_DSI_SCLK 96 -#define CLK_DSI_DPHY 97 -#define CLK_DRC 98 -#define CLK_GPU 99 -#define CLK_ATS 100 - -#endif /* _DT_BINDINGS_CLK_SUN8I_A23_A33_H_ */ diff --git a/include/dt-bindings/clock/sun8i-a83t-ccu.h b/include/dt-bindings/clock/sun8i-a83t-ccu.h deleted file mode 100644 index 78af5085f630..000000000000 --- a/include/dt-bindings/clock/sun8i-a83t-ccu.h +++ /dev/null @@ -1,140 +0,0 @@ -/* - * Copyright (C) 2017 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ -#define _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ - -#define CLK_PLL_PERIPH 6 - -#define CLK_PLL_DE 9 - -#define CLK_C0CPUX 11 -#define CLK_C1CPUX 12 - -#define CLK_BUS_MIPI_DSI 19 -#define CLK_BUS_SS 20 -#define CLK_BUS_DMA 21 -#define CLK_BUS_MMC0 22 -#define CLK_BUS_MMC1 23 -#define CLK_BUS_MMC2 24 -#define CLK_BUS_NAND 25 -#define CLK_BUS_DRAM 26 -#define CLK_BUS_EMAC 27 -#define CLK_BUS_HSTIMER 28 -#define CLK_BUS_SPI0 29 -#define CLK_BUS_SPI1 30 -#define CLK_BUS_OTG 31 -#define CLK_BUS_EHCI0 32 -#define CLK_BUS_EHCI1 33 -#define CLK_BUS_OHCI0 34 - -#define CLK_BUS_VE 35 -#define CLK_BUS_TCON0 36 -#define CLK_BUS_TCON1 37 -#define CLK_BUS_CSI 38 -#define CLK_BUS_HDMI 39 -#define CLK_BUS_DE 40 -#define CLK_BUS_GPU 41 -#define CLK_BUS_MSGBOX 42 -#define CLK_BUS_SPINLOCK 43 - -#define CLK_BUS_SPDIF 44 -#define CLK_BUS_PIO 45 -#define CLK_BUS_I2S0 46 -#define CLK_BUS_I2S1 47 -#define CLK_BUS_I2S2 48 -#define CLK_BUS_TDM 49 - -#define CLK_BUS_I2C0 50 -#define CLK_BUS_I2C1 51 -#define CLK_BUS_I2C2 52 -#define CLK_BUS_UART0 53 -#define CLK_BUS_UART1 54 -#define CLK_BUS_UART2 55 -#define CLK_BUS_UART3 56 -#define CLK_BUS_UART4 57 - -#define CLK_NAND 59 -#define CLK_MMC0 60 -#define CLK_MMC0_SAMPLE 61 -#define CLK_MMC0_OUTPUT 62 -#define CLK_MMC1 63 -#define CLK_MMC1_SAMPLE 64 -#define CLK_MMC1_OUTPUT 65 -#define CLK_MMC2 66 -#define CLK_MMC2_SAMPLE 67 -#define CLK_MMC2_OUTPUT 68 -#define CLK_SS 69 -#define CLK_SPI0 70 -#define CLK_SPI1 71 -#define CLK_I2S0 72 -#define CLK_I2S1 73 -#define CLK_I2S2 74 -#define CLK_TDM 75 -#define CLK_SPDIF 76 -#define CLK_USB_PHY0 77 -#define CLK_USB_PHY1 78 -#define CLK_USB_HSIC 79 -#define CLK_USB_HSIC_12M 80 -#define CLK_USB_OHCI0 81 - -#define CLK_DRAM_VE 83 -#define CLK_DRAM_CSI 84 - -#define CLK_TCON0 85 -#define CLK_TCON1 86 -#define CLK_CSI_MISC 87 -#define CLK_MIPI_CSI 88 -#define CLK_CSI_MCLK 89 -#define CLK_CSI_SCLK 90 -#define CLK_VE 91 -#define CLK_AVS 92 -#define CLK_HDMI 93 -#define CLK_HDMI_SLOW 94 - -#define CLK_MIPI_DSI0 96 -#define CLK_MIPI_DSI1 97 -#define CLK_GPU_CORE 98 -#define CLK_GPU_MEMORY 99 -#define CLK_GPU_HYD 100 - -#endif /* _DT_BINDINGS_CLOCK_SUN8I_A83T_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun8i-de2.h b/include/dt-bindings/clock/sun8i-de2.h deleted file mode 100644 index 7768f73b051e..000000000000 --- a/include/dt-bindings/clock/sun8i-de2.h +++ /dev/null @@ -1,21 +0,0 @@ -/* - * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.io - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ - -#ifndef _DT_BINDINGS_CLOCK_SUN8I_DE2_H_ -#define _DT_BINDINGS_CLOCK_SUN8I_DE2_H_ - -#define CLK_BUS_MIXER0 0 -#define CLK_BUS_MIXER1 1 -#define CLK_BUS_WB 2 - -#define CLK_MIXER0 6 -#define CLK_MIXER1 7 -#define CLK_WB 8 - -#define CLK_BUS_ROT 9 -#define CLK_ROT 10 - -#endif /* _DT_BINDINGS_CLOCK_SUN8I_DE2_H_ */ diff --git a/include/dt-bindings/clock/sun8i-h3-ccu.h b/include/dt-bindings/clock/sun8i-h3-ccu.h deleted file mode 100644 index 5d4ada2c22e6..000000000000 --- a/include/dt-bindings/clock/sun8i-h3-ccu.h +++ /dev/null @@ -1,152 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN8I_H3_H_ -#define _DT_BINDINGS_CLK_SUN8I_H3_H_ - -#define CLK_PLL_VIDEO 6 - -#define CLK_PLL_PERIPH0 9 - -#define CLK_CPUX 14 - -#define CLK_BUS_CE 20 -#define CLK_BUS_DMA 21 -#define CLK_BUS_MMC0 22 -#define CLK_BUS_MMC1 23 -#define CLK_BUS_MMC2 24 -#define CLK_BUS_NAND 25 -#define CLK_BUS_DRAM 26 -#define CLK_BUS_EMAC 27 -#define CLK_BUS_TS 28 -#define CLK_BUS_HSTIMER 29 -#define CLK_BUS_SPI0 30 -#define CLK_BUS_SPI1 31 -#define CLK_BUS_OTG 32 -#define CLK_BUS_EHCI0 33 -#define CLK_BUS_EHCI1 34 -#define CLK_BUS_EHCI2 35 -#define CLK_BUS_EHCI3 36 -#define CLK_BUS_OHCI0 37 -#define CLK_BUS_OHCI1 38 -#define CLK_BUS_OHCI2 39 -#define CLK_BUS_OHCI3 40 -#define CLK_BUS_VE 41 -#define CLK_BUS_TCON0 42 -#define CLK_BUS_TCON1 43 -#define CLK_BUS_DEINTERLACE 44 -#define CLK_BUS_CSI 45 -#define CLK_BUS_TVE 46 -#define CLK_BUS_HDMI 47 -#define CLK_BUS_DE 48 -#define CLK_BUS_GPU 49 -#define CLK_BUS_MSGBOX 50 -#define CLK_BUS_SPINLOCK 51 -#define CLK_BUS_CODEC 52 -#define CLK_BUS_SPDIF 53 -#define CLK_BUS_PIO 54 -#define CLK_BUS_THS 55 -#define CLK_BUS_I2S0 56 -#define CLK_BUS_I2S1 57 -#define CLK_BUS_I2S2 58 -#define CLK_BUS_I2C0 59 -#define CLK_BUS_I2C1 60 -#define CLK_BUS_I2C2 61 -#define CLK_BUS_UART0 62 -#define CLK_BUS_UART1 63 -#define CLK_BUS_UART2 64 -#define CLK_BUS_UART3 65 -#define CLK_BUS_SCR0 66 -#define CLK_BUS_EPHY 67 -#define CLK_BUS_DBG 68 - -#define CLK_THS 69 -#define CLK_NAND 70 -#define CLK_MMC0 71 -#define CLK_MMC0_SAMPLE 72 -#define CLK_MMC0_OUTPUT 73 -#define CLK_MMC1 74 -#define CLK_MMC1_SAMPLE 75 -#define CLK_MMC1_OUTPUT 76 -#define CLK_MMC2 77 -#define CLK_MMC2_SAMPLE 78 -#define CLK_MMC2_OUTPUT 79 -#define CLK_TS 80 -#define CLK_CE 81 -#define CLK_SPI0 82 -#define CLK_SPI1 83 -#define CLK_I2S0 84 -#define CLK_I2S1 85 -#define CLK_I2S2 86 -#define CLK_SPDIF 87 -#define CLK_USB_PHY0 88 -#define CLK_USB_PHY1 89 -#define CLK_USB_PHY2 90 -#define CLK_USB_PHY3 91 -#define CLK_USB_OHCI0 92 -#define CLK_USB_OHCI1 93 -#define CLK_USB_OHCI2 94 -#define CLK_USB_OHCI3 95 -#define CLK_DRAM 96 -#define CLK_DRAM_VE 97 -#define CLK_DRAM_CSI 98 -#define CLK_DRAM_DEINTERLACE 99 -#define CLK_DRAM_TS 100 -#define CLK_DE 101 -#define CLK_TCON0 102 -#define CLK_TVE 103 -#define CLK_DEINTERLACE 104 -#define CLK_CSI_MISC 105 -#define CLK_CSI_SCLK 106 -#define CLK_CSI_MCLK 107 -#define CLK_VE 108 -#define CLK_AC_DIG 109 -#define CLK_AVS 110 -#define CLK_HDMI 111 -#define CLK_HDMI_DDC 112 -#define CLK_MBUS 113 -#define CLK_GPU 114 - -/* New clocks imported in H5 */ -#define CLK_BUS_SCR1 115 - -#endif /* _DT_BINDINGS_CLK_SUN8I_H3_H_ */ diff --git a/include/dt-bindings/clock/sun8i-r-ccu.h b/include/dt-bindings/clock/sun8i-r-ccu.h deleted file mode 100644 index 779d20aa0d05..000000000000 --- a/include/dt-bindings/clock/sun8i-r-ccu.h +++ /dev/null @@ -1,59 +0,0 @@ -/* - * Copyright (c) 2016 Icenowy Zheng icenowy@aosc.xyz - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ -#define _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ - -#define CLK_AR100 0 - -#define CLK_APB0_PIO 3 -#define CLK_APB0_IR 4 -#define CLK_APB0_TIMER 5 -#define CLK_APB0_RSB 6 -#define CLK_APB0_UART 7 -/* 8 is reserved for CLK_APB0_W1 on A31 */ -#define CLK_APB0_I2C 9 -#define CLK_APB0_TWD 10 - -#define CLK_IR 11 - -#endif /* _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun8i-r40-ccu.h b/include/dt-bindings/clock/sun8i-r40-ccu.h deleted file mode 100644 index d7337b55a4ef..000000000000 --- a/include/dt-bindings/clock/sun8i-r40-ccu.h +++ /dev/null @@ -1,191 +0,0 @@ -/* - * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN8I_R40_H_ -#define _DT_BINDINGS_CLK_SUN8I_R40_H_ - -#define CLK_PLL_VIDEO0 7 - -#define CLK_PLL_VIDEO1 16 - -#define CLK_CPU 24 - -#define CLK_BUS_MIPI_DSI 29 -#define CLK_BUS_CE 30 -#define CLK_BUS_DMA 31 -#define CLK_BUS_MMC0 32 -#define CLK_BUS_MMC1 33 -#define CLK_BUS_MMC2 34 -#define CLK_BUS_MMC3 35 -#define CLK_BUS_NAND 36 -#define CLK_BUS_DRAM 37 -#define CLK_BUS_EMAC 38 -#define CLK_BUS_TS 39 -#define CLK_BUS_HSTIMER 40 -#define CLK_BUS_SPI0 41 -#define CLK_BUS_SPI1 42 -#define CLK_BUS_SPI2 43 -#define CLK_BUS_SPI3 44 -#define CLK_BUS_SATA 45 -#define CLK_BUS_OTG 46 -#define CLK_BUS_EHCI0 47 -#define CLK_BUS_EHCI1 48 -#define CLK_BUS_EHCI2 49 -#define CLK_BUS_OHCI0 50 -#define CLK_BUS_OHCI1 51 -#define CLK_BUS_OHCI2 52 -#define CLK_BUS_VE 53 -#define CLK_BUS_MP 54 -#define CLK_BUS_DEINTERLACE 55 -#define CLK_BUS_CSI0 56 -#define CLK_BUS_CSI1 57 -#define CLK_BUS_HDMI1 58 -#define CLK_BUS_HDMI0 59 -#define CLK_BUS_DE 60 -#define CLK_BUS_TVE0 61 -#define CLK_BUS_TVE1 62 -#define CLK_BUS_TVE_TOP 63 -#define CLK_BUS_GMAC 64 -#define CLK_BUS_GPU 65 -#define CLK_BUS_TVD0 66 -#define CLK_BUS_TVD1 67 -#define CLK_BUS_TVD2 68 -#define CLK_BUS_TVD3 69 -#define CLK_BUS_TVD_TOP 70 -#define CLK_BUS_TCON_LCD0 71 -#define CLK_BUS_TCON_LCD1 72 -#define CLK_BUS_TCON_TV0 73 -#define CLK_BUS_TCON_TV1 74 -#define CLK_BUS_TCON_TOP 75 -#define CLK_BUS_CODEC 76 -#define CLK_BUS_SPDIF 77 -#define CLK_BUS_AC97 78 -#define CLK_BUS_PIO 79 -#define CLK_BUS_IR0 80 -#define CLK_BUS_IR1 81 -#define CLK_BUS_THS 82 -#define CLK_BUS_KEYPAD 83 -#define CLK_BUS_I2S0 84 -#define CLK_BUS_I2S1 85 -#define CLK_BUS_I2S2 86 -#define CLK_BUS_I2C0 87 -#define CLK_BUS_I2C1 88 -#define CLK_BUS_I2C2 89 -#define CLK_BUS_I2C3 90 -#define CLK_BUS_CAN 91 -#define CLK_BUS_SCR 92 -#define CLK_BUS_PS20 93 -#define CLK_BUS_PS21 94 -#define CLK_BUS_I2C4 95 -#define CLK_BUS_UART0 96 -#define CLK_BUS_UART1 97 -#define CLK_BUS_UART2 98 -#define CLK_BUS_UART3 99 -#define CLK_BUS_UART4 100 -#define CLK_BUS_UART5 101 -#define CLK_BUS_UART6 102 -#define CLK_BUS_UART7 103 -#define CLK_BUS_DBG 104 - -#define CLK_THS 105 -#define CLK_NAND 106 -#define CLK_MMC0 107 -#define CLK_MMC1 108 -#define CLK_MMC2 109 -#define CLK_MMC3 110 -#define CLK_TS 111 -#define CLK_CE 112 -#define CLK_SPI0 113 -#define CLK_SPI1 114 -#define CLK_SPI2 115 -#define CLK_SPI3 116 -#define CLK_I2S0 117 -#define CLK_I2S1 118 -#define CLK_I2S2 119 -#define CLK_AC97 120 -#define CLK_SPDIF 121 -#define CLK_KEYPAD 122 -#define CLK_SATA 123 -#define CLK_USB_PHY0 124 -#define CLK_USB_PHY1 125 -#define CLK_USB_PHY2 126 -#define CLK_USB_OHCI0 127 -#define CLK_USB_OHCI1 128 -#define CLK_USB_OHCI2 129 -#define CLK_IR0 130 -#define CLK_IR1 131 - -#define CLK_DRAM_VE 133 -#define CLK_DRAM_CSI0 134 -#define CLK_DRAM_CSI1 135 -#define CLK_DRAM_TS 136 -#define CLK_DRAM_TVD 137 -#define CLK_DRAM_MP 138 -#define CLK_DRAM_DEINTERLACE 139 -#define CLK_DE 140 -#define CLK_MP 141 -#define CLK_TCON_LCD0 142 -#define CLK_TCON_LCD1 143 -#define CLK_TCON_TV0 144 -#define CLK_TCON_TV1 145 -#define CLK_DEINTERLACE 146 -#define CLK_CSI1_MCLK 147 -#define CLK_CSI_SCLK 148 -#define CLK_CSI0_MCLK 149 -#define CLK_VE 150 -#define CLK_CODEC 151 -#define CLK_AVS 152 -#define CLK_HDMI 153 -#define CLK_HDMI_SLOW 154 -#define CLK_MBUS 155 -#define CLK_DSI_DPHY 156 -#define CLK_TVE0 157 -#define CLK_TVE1 158 -#define CLK_TVD0 159 -#define CLK_TVD1 160 -#define CLK_TVD2 161 -#define CLK_TVD3 162 -#define CLK_GPU 163 -#define CLK_OUTA 164 -#define CLK_OUTB 165 - -#endif /* _DT_BINDINGS_CLK_SUN8I_R40_H_ */ diff --git a/include/dt-bindings/clock/sun8i-tcon-top.h b/include/dt-bindings/clock/sun8i-tcon-top.h deleted file mode 100644 index 25164d767835..000000000000 --- a/include/dt-bindings/clock/sun8i-tcon-top.h +++ /dev/null @@ -1,11 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* Copyright (C) 2018 Jernej Skrabec jernej.skrabec@siol.net */ - -#ifndef _DT_BINDINGS_CLOCK_SUN8I_TCON_TOP_H_ -#define _DT_BINDINGS_CLOCK_SUN8I_TCON_TOP_H_ - -#define CLK_TCON_TOP_TV0 0 -#define CLK_TCON_TOP_TV1 1 -#define CLK_TCON_TOP_DSI 2 - -#endif /* _DT_BINDINGS_CLOCK_SUN8I_TCON_TOP_H_ */ diff --git a/include/dt-bindings/clock/sun8i-v3s-ccu.h b/include/dt-bindings/clock/sun8i-v3s-ccu.h deleted file mode 100644 index 014ac6123d17..000000000000 --- a/include/dt-bindings/clock/sun8i-v3s-ccu.h +++ /dev/null @@ -1,111 +0,0 @@ -/* - * Copyright (c) 2016 Icenowy Zheng icenowy@aosc.xyz - * - * Based on sun8i-h3-ccu.h, which is: - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLK_SUN8I_V3S_H_ -#define _DT_BINDINGS_CLK_SUN8I_V3S_H_ - -#define CLK_CPU 14 - -#define CLK_BUS_CE 20 -#define CLK_BUS_DMA 21 -#define CLK_BUS_MMC0 22 -#define CLK_BUS_MMC1 23 -#define CLK_BUS_MMC2 24 -#define CLK_BUS_DRAM 25 -#define CLK_BUS_EMAC 26 -#define CLK_BUS_HSTIMER 27 -#define CLK_BUS_SPI0 28 -#define CLK_BUS_OTG 29 -#define CLK_BUS_EHCI0 30 -#define CLK_BUS_OHCI0 31 -#define CLK_BUS_VE 32 -#define CLK_BUS_TCON0 33 -#define CLK_BUS_CSI 34 -#define CLK_BUS_DE 35 -#define CLK_BUS_CODEC 36 -#define CLK_BUS_PIO 37 -#define CLK_BUS_I2C0 38 -#define CLK_BUS_I2C1 39 -#define CLK_BUS_UART0 40 -#define CLK_BUS_UART1 41 -#define CLK_BUS_UART2 42 -#define CLK_BUS_EPHY 43 -#define CLK_BUS_DBG 44 - -#define CLK_MMC0 45 -#define CLK_MMC0_SAMPLE 46 -#define CLK_MMC0_OUTPUT 47 -#define CLK_MMC1 48 -#define CLK_MMC1_SAMPLE 49 -#define CLK_MMC1_OUTPUT 50 -#define CLK_MMC2 51 -#define CLK_MMC2_SAMPLE 52 -#define CLK_MMC2_OUTPUT 53 -#define CLK_CE 54 -#define CLK_SPI0 55 -#define CLK_USB_PHY0 56 -#define CLK_USB_OHCI0 57 - -#define CLK_DRAM_VE 59 -#define CLK_DRAM_CSI 60 -#define CLK_DRAM_EHCI 61 -#define CLK_DRAM_OHCI 62 -#define CLK_DE 63 -#define CLK_TCON0 64 -#define CLK_CSI_MISC 65 -#define CLK_CSI0_MCLK 66 -#define CLK_CSI1_SCLK 67 -#define CLK_CSI1_MCLK 68 -#define CLK_VE 69 -#define CLK_AC_DIG 70 -#define CLK_AVS 71 - -#define CLK_MIPI_CSI 73 - -/* Clocks not available on V3s */ -#define CLK_BUS_I2S0 75 -#define CLK_I2S0 76 - -#endif /* _DT_BINDINGS_CLK_SUN8I_V3S_H_ */ diff --git a/include/dt-bindings/clock/sun9i-a80-ccu.h b/include/dt-bindings/clock/sun9i-a80-ccu.h deleted file mode 100644 index 6ea1492a73a6..000000000000 --- a/include/dt-bindings/clock/sun9i-a80-ccu.h +++ /dev/null @@ -1,162 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLOCK_SUN9I_A80_CCU_H_ -#define _DT_BINDINGS_CLOCK_SUN9I_A80_CCU_H_ - -#define CLK_PLL_AUDIO 2 -#define CLK_PLL_PERIPH0 3 - -#define CLK_C0CPUX 12 -#define CLK_C1CPUX 13 - -#define CLK_OUT_A 27 -#define CLK_OUT_B 28 - -#define CLK_NAND0_0 29 -#define CLK_NAND0_1 30 -#define CLK_NAND1_0 31 -#define CLK_NAND1_1 32 -#define CLK_MMC0 33 -#define CLK_MMC0_SAMPLE 34 -#define CLK_MMC0_OUTPUT 35 -#define CLK_MMC1 36 -#define CLK_MMC1_SAMPLE 37 -#define CLK_MMC1_OUTPUT 38 -#define CLK_MMC2 39 -#define CLK_MMC2_SAMPLE 40 -#define CLK_MMC2_OUTPUT 41 -#define CLK_MMC3 42 -#define CLK_MMC3_SAMPLE 43 -#define CLK_MMC3_OUTPUT 44 -#define CLK_TS 45 -#define CLK_SS 46 -#define CLK_SPI0 47 -#define CLK_SPI1 48 -#define CLK_SPI2 49 -#define CLK_SPI3 50 -#define CLK_I2S0 51 -#define CLK_I2S1 52 -#define CLK_SPDIF 53 -#define CLK_SDRAM 54 -#define CLK_DE 55 -#define CLK_EDP 56 -#define CLK_MP 57 -#define CLK_LCD0 58 -#define CLK_LCD1 59 -#define CLK_MIPI_DSI0 60 -#define CLK_MIPI_DSI1 61 -#define CLK_HDMI 62 -#define CLK_HDMI_SLOW 63 -#define CLK_MIPI_CSI 64 -#define CLK_CSI_ISP 65 -#define CLK_CSI_MISC 66 -#define CLK_CSI0_MCLK 67 -#define CLK_CSI1_MCLK 68 -#define CLK_FD 69 -#define CLK_VE 70 -#define CLK_AVS 71 -#define CLK_GPU_CORE 72 -#define CLK_GPU_MEMORY 73 -#define CLK_GPU_AXI 74 -#define CLK_SATA 75 -#define CLK_AC97 76 -#define CLK_MIPI_HSI 77 -#define CLK_GPADC 78 -#define CLK_CIR_TX 79 - -#define CLK_BUS_FD 80 -#define CLK_BUS_VE 81 -#define CLK_BUS_GPU_CTRL 82 -#define CLK_BUS_SS 83 -#define CLK_BUS_MMC 84 -#define CLK_BUS_NAND0 85 -#define CLK_BUS_NAND1 86 -#define CLK_BUS_SDRAM 87 -#define CLK_BUS_MIPI_HSI 88 -#define CLK_BUS_SATA 89 -#define CLK_BUS_TS 90 -#define CLK_BUS_SPI0 91 -#define CLK_BUS_SPI1 92 -#define CLK_BUS_SPI2 93 -#define CLK_BUS_SPI3 94 - -#define CLK_BUS_OTG 95 -#define CLK_BUS_USB 96 -#define CLK_BUS_GMAC 97 -#define CLK_BUS_MSGBOX 98 -#define CLK_BUS_SPINLOCK 99 -#define CLK_BUS_HSTIMER 100 -#define CLK_BUS_DMA 101 - -#define CLK_BUS_LCD0 102 -#define CLK_BUS_LCD1 103 -#define CLK_BUS_EDP 104 -#define CLK_BUS_CSI 105 -#define CLK_BUS_HDMI 106 -#define CLK_BUS_DE 107 -#define CLK_BUS_MP 108 -#define CLK_BUS_MIPI_DSI 109 - -#define CLK_BUS_SPDIF 110 -#define CLK_BUS_PIO 111 -#define CLK_BUS_AC97 112 -#define CLK_BUS_I2S0 113 -#define CLK_BUS_I2S1 114 -#define CLK_BUS_LRADC 115 -#define CLK_BUS_GPADC 116 -#define CLK_BUS_TWD 117 -#define CLK_BUS_CIR_TX 118 - -#define CLK_BUS_I2C0 119 -#define CLK_BUS_I2C1 120 -#define CLK_BUS_I2C2 121 -#define CLK_BUS_I2C3 122 -#define CLK_BUS_I2C4 123 -#define CLK_BUS_UART0 124 -#define CLK_BUS_UART1 125 -#define CLK_BUS_UART2 126 -#define CLK_BUS_UART3 127 -#define CLK_BUS_UART4 128 -#define CLK_BUS_UART5 129 - -#endif /* _DT_BINDINGS_CLOCK_SUN9I_A80_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun9i-a80-de.h b/include/dt-bindings/clock/sun9i-a80-de.h deleted file mode 100644 index 3dad6c3cd131..000000000000 --- a/include/dt-bindings/clock/sun9i-a80-de.h +++ /dev/null @@ -1,80 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLOCK_SUN9I_A80_DE_H_ -#define _DT_BINDINGS_CLOCK_SUN9I_A80_DE_H_ - -#define CLK_FE0 0 -#define CLK_FE1 1 -#define CLK_FE2 2 -#define CLK_IEP_DEU0 3 -#define CLK_IEP_DEU1 4 -#define CLK_BE0 5 -#define CLK_BE1 6 -#define CLK_BE2 7 -#define CLK_IEP_DRC0 8 -#define CLK_IEP_DRC1 9 -#define CLK_MERGE 10 - -#define CLK_DRAM_FE0 11 -#define CLK_DRAM_FE1 12 -#define CLK_DRAM_FE2 13 -#define CLK_DRAM_DEU0 14 -#define CLK_DRAM_DEU1 15 -#define CLK_DRAM_BE0 16 -#define CLK_DRAM_BE1 17 -#define CLK_DRAM_BE2 18 -#define CLK_DRAM_DRC0 19 -#define CLK_DRAM_DRC1 20 - -#define CLK_BUS_FE0 21 -#define CLK_BUS_FE1 22 -#define CLK_BUS_FE2 23 -#define CLK_BUS_DEU0 24 -#define CLK_BUS_DEU1 25 -#define CLK_BUS_BE0 26 -#define CLK_BUS_BE1 27 -#define CLK_BUS_BE2 28 -#define CLK_BUS_DRC0 29 -#define CLK_BUS_DRC1 30 - -#endif /* _DT_BINDINGS_CLOCK_SUN9I_A80_DE_H_ */ diff --git a/include/dt-bindings/clock/sun9i-a80-usb.h b/include/dt-bindings/clock/sun9i-a80-usb.h deleted file mode 100644 index 783a60d2ccea..000000000000 --- a/include/dt-bindings/clock/sun9i-a80-usb.h +++ /dev/null @@ -1,59 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_CLOCK_SUN9I_A80_USB_H_ -#define _DT_BINDINGS_CLOCK_SUN9I_A80_USB_H_ - -#define CLK_BUS_HCI0 0 -#define CLK_USB_OHCI0 1 -#define CLK_BUS_HCI1 2 -#define CLK_BUS_HCI2 3 -#define CLK_USB_OHCI2 4 - -#define CLK_USB0_PHY 5 -#define CLK_USB1_HSIC 6 -#define CLK_USB1_PHY 7 -#define CLK_USB2_HSIC 8 -#define CLK_USB2_PHY 9 -#define CLK_USB_HSIC 10 - -#endif /* _DT_BINDINGS_CLOCK_SUN9I_A80_USB_H_ */ diff --git a/include/dt-bindings/clock/suniv-ccu-f1c100s.h b/include/dt-bindings/clock/suniv-ccu-f1c100s.h deleted file mode 100644 index d7570765f424..000000000000 --- a/include/dt-bindings/clock/suniv-ccu-f1c100s.h +++ /dev/null @@ -1,72 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) - * - * Copyright (c) 2018 Icenowy Zheng icenowy@aosc.xyz - * - */ - -#ifndef _DT_BINDINGS_CLK_SUNIV_F1C100S_H_ -#define _DT_BINDINGS_CLK_SUNIV_F1C100S_H_ - -#define CLK_CPU 11 - -#define CLK_BUS_DMA 14 -#define CLK_BUS_MMC0 15 -#define CLK_BUS_MMC1 16 -#define CLK_BUS_DRAM 17 -#define CLK_BUS_SPI0 18 -#define CLK_BUS_SPI1 19 -#define CLK_BUS_OTG 20 -#define CLK_BUS_VE 21 -#define CLK_BUS_LCD 22 -#define CLK_BUS_DEINTERLACE 23 -#define CLK_BUS_CSI 24 -#define CLK_BUS_TVD 25 -#define CLK_BUS_TVE 26 -#define CLK_BUS_DE_BE 27 -#define CLK_BUS_DE_FE 28 -#define CLK_BUS_CODEC 29 -#define CLK_BUS_SPDIF 30 -#define CLK_BUS_IR 31 -#define CLK_BUS_RSB 32 -#define CLK_BUS_I2S0 33 -#define CLK_BUS_I2C0 34 -#define CLK_BUS_I2C1 35 -#define CLK_BUS_I2C2 36 -#define CLK_BUS_PIO 37 -#define CLK_BUS_UART0 38 -#define CLK_BUS_UART1 39 -#define CLK_BUS_UART2 40 - -#define CLK_MMC0 41 -#define CLK_MMC0_SAMPLE 42 -#define CLK_MMC0_OUTPUT 43 -#define CLK_MMC1 44 -#define CLK_MMC1_SAMPLE 45 -#define CLK_MMC1_OUTPUT 46 -#define CLK_I2S 47 -#define CLK_SPDIF 48 - -#define CLK_USB_PHY0 49 - -#define CLK_DRAM_VE 50 -#define CLK_DRAM_CSI 51 -#define CLK_DRAM_DEINTERLACE 52 -#define CLK_DRAM_TVD 53 -#define CLK_DRAM_DE_FE 54 -#define CLK_DRAM_DE_BE 55 - -#define CLK_DE_BE 56 -#define CLK_DE_FE 57 -#define CLK_TCON 58 -#define CLK_DEINTERLACE 59 -#define CLK_TVE2_CLK 60 -#define CLK_TVE1_CLK 61 -#define CLK_TVD 62 -#define CLK_CSI 63 -#define CLK_VE 64 -#define CLK_CODEC 65 -#define CLK_AVS 66 - -#define CLK_IR 67 - -#endif
Drop in favour of dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/dma/sun4i-a10.h | 56 ----------- include/dt-bindings/pinctrl/sun4i-a10.h | 62 ------------ include/dt-bindings/reset/sun20i-d1-ccu.h | 79 ---------------- include/dt-bindings/reset/sun20i-d1-r-ccu.h | 16 ---- include/dt-bindings/reset/sun4i-a10-ccu.h | 69 -------------- include/dt-bindings/reset/sun50i-a64-ccu.h | 98 ------------------- include/dt-bindings/reset/sun50i-h6-ccu.h | 73 --------------- include/dt-bindings/reset/sun50i-h6-r-ccu.h | 18 ---- include/dt-bindings/reset/sun50i-h616-ccu.h | 70 -------------- include/dt-bindings/reset/sun5i-ccu.h | 23 ----- include/dt-bindings/reset/sun6i-a31-ccu.h | 106 --------------------- include/dt-bindings/reset/sun8i-a23-a33-ccu.h | 87 ----------------- include/dt-bindings/reset/sun8i-a83t-ccu.h | 98 ------------------- include/dt-bindings/reset/sun8i-de2.h | 15 --- include/dt-bindings/reset/sun8i-h3-ccu.h | 106 --------------------- include/dt-bindings/reset/sun8i-r-ccu.h | 53 ----------- include/dt-bindings/reset/sun8i-r40-ccu.h | 130 -------------------------- include/dt-bindings/reset/sun8i-v3s-ccu.h | 81 ---------------- include/dt-bindings/reset/sun9i-a80-ccu.h | 102 -------------------- include/dt-bindings/reset/sun9i-a80-de.h | 58 ------------ include/dt-bindings/reset/sun9i-a80-usb.h | 56 ----------- include/dt-bindings/reset/suniv-ccu-f1c100s.h | 38 -------- 22 files changed, 1494 deletions(-)
diff --git a/include/dt-bindings/dma/sun4i-a10.h b/include/dt-bindings/dma/sun4i-a10.h deleted file mode 100644 index 8caba9ef7e9d..000000000000 --- a/include/dt-bindings/dma/sun4i-a10.h +++ /dev/null @@ -1,56 +0,0 @@ -/* - * Copyright 2014 Maxime Ripard - * - * Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this file; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef __DT_BINDINGS_DMA_SUN4I_A10_H_ -#define __DT_BINDINGS_DMA_SUN4I_A10_H_ - -#define SUN4I_DMA_NORMAL 0 -#define SUN4I_DMA_DEDICATED 1 - -#endif /* __DT_BINDINGS_DMA_SUN4I_A10_H_ */ diff --git a/include/dt-bindings/pinctrl/sun4i-a10.h b/include/dt-bindings/pinctrl/sun4i-a10.h deleted file mode 100644 index f7553c143b40..000000000000 --- a/include/dt-bindings/pinctrl/sun4i-a10.h +++ /dev/null @@ -1,62 +0,0 @@ -/* - * Copyright 2014 Maxime Ripard - * - * Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with this file; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ -#define __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ - -#define SUN4I_PINCTRL_10_MA 0 -#define SUN4I_PINCTRL_20_MA 1 -#define SUN4I_PINCTRL_30_MA 2 -#define SUN4I_PINCTRL_40_MA 3 - -#define SUN4I_PINCTRL_NO_PULL 0 -#define SUN4I_PINCTRL_PULL_UP 1 -#define SUN4I_PINCTRL_PULL_DOWN 2 - -#endif /* __DT_BINDINGS_PINCTRL_SUN4I_A10_H_ */ diff --git a/include/dt-bindings/reset/sun20i-d1-ccu.h b/include/dt-bindings/reset/sun20i-d1-ccu.h deleted file mode 100644 index 79e52aca5912..000000000000 --- a/include/dt-bindings/reset/sun20i-d1-ccu.h +++ /dev/null @@ -1,79 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (c) 2020 huangzhenwei@allwinnertech.com - * Copyright (C) 2021 Samuel Holland samuel@sholland.org - */ - -#ifndef _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ -#define _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ - -#define RST_MBUS 0 -#define RST_BUS_DE 1 -#define RST_BUS_DI 2 -#define RST_BUS_G2D 3 -#define RST_BUS_CE 4 -#define RST_BUS_VE 5 -#define RST_BUS_DMA 6 -#define RST_BUS_MSGBOX0 7 -#define RST_BUS_MSGBOX1 8 -#define RST_BUS_MSGBOX2 9 -#define RST_BUS_SPINLOCK 10 -#define RST_BUS_HSTIMER 11 -#define RST_BUS_DBG 12 -#define RST_BUS_PWM 13 -#define RST_BUS_DRAM 14 -#define RST_BUS_MMC0 15 -#define RST_BUS_MMC1 16 -#define RST_BUS_MMC2 17 -#define RST_BUS_UART0 18 -#define RST_BUS_UART1 19 -#define RST_BUS_UART2 20 -#define RST_BUS_UART3 21 -#define RST_BUS_UART4 22 -#define RST_BUS_UART5 23 -#define RST_BUS_I2C0 24 -#define RST_BUS_I2C1 25 -#define RST_BUS_I2C2 26 -#define RST_BUS_I2C3 27 -#define RST_BUS_SPI0 28 -#define RST_BUS_SPI1 29 -#define RST_BUS_EMAC 30 -#define RST_BUS_IR_TX 31 -#define RST_BUS_GPADC 32 -#define RST_BUS_THS 33 -#define RST_BUS_I2S0 34 -#define RST_BUS_I2S1 35 -#define RST_BUS_I2S2 36 -#define RST_BUS_SPDIF 37 -#define RST_BUS_DMIC 38 -#define RST_BUS_AUDIO 39 -#define RST_USB_PHY0 40 -#define RST_USB_PHY1 41 -#define RST_BUS_OHCI0 42 -#define RST_BUS_OHCI1 43 -#define RST_BUS_EHCI0 44 -#define RST_BUS_EHCI1 45 -#define RST_BUS_OTG 46 -#define RST_BUS_LRADC 47 -#define RST_BUS_DPSS_TOP 48 -#define RST_BUS_HDMI_SUB 49 -#define RST_BUS_HDMI_MAIN 50 -#define RST_BUS_MIPI_DSI 51 -#define RST_BUS_TCON_LCD0 52 -#define RST_BUS_TCON_TV 53 -#define RST_BUS_LVDS0 54 -#define RST_BUS_TVE 55 -#define RST_BUS_TVE_TOP 56 -#define RST_BUS_TVD 57 -#define RST_BUS_TVD_TOP 58 -#define RST_BUS_LEDC 59 -#define RST_BUS_CSI 60 -#define RST_BUS_TPADC 61 -#define RST_DSP 62 -#define RST_BUS_DSP_CFG 63 -#define RST_BUS_DSP_DBG 64 -#define RST_BUS_RISCV_CFG 65 -#define RST_BUS_CAN0 66 -#define RST_BUS_CAN1 67 - -#endif /* _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun20i-d1-r-ccu.h b/include/dt-bindings/reset/sun20i-d1-r-ccu.h deleted file mode 100644 index e20babc990af..000000000000 --- a/include/dt-bindings/reset/sun20i-d1-r-ccu.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2021 Samuel Holland samuel@sholland.org - */ - -#ifndef _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ -#define _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ - -#define RST_BUS_R_TIMER 0 -#define RST_BUS_R_TWD 1 -#define RST_BUS_R_PPU 2 -#define RST_BUS_R_IR_RX 3 -#define RST_BUS_R_RTC 4 -#define RST_BUS_R_CPUCFG 5 - -#endif /* _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun4i-a10-ccu.h b/include/dt-bindings/reset/sun4i-a10-ccu.h deleted file mode 100644 index 5f4480bedc8a..000000000000 --- a/include/dt-bindings/reset/sun4i-a10-ccu.h +++ /dev/null @@ -1,69 +0,0 @@ -/* - * Copyright (C) 2017 Priit Laes plaes@plaes.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN4I_A10_H -#define _DT_BINDINGS_RST_SUN4I_A10_H - -#define RST_USB_PHY0 1 -#define RST_USB_PHY1 2 -#define RST_USB_PHY2 3 -#define RST_GPS 4 -#define RST_DE_BE0 5 -#define RST_DE_BE1 6 -#define RST_DE_FE0 7 -#define RST_DE_FE1 8 -#define RST_DE_MP 9 -#define RST_TVE0 10 -#define RST_TCON0 11 -#define RST_TVE1 12 -#define RST_TCON1 13 -#define RST_CSI0 14 -#define RST_CSI1 15 -#define RST_VE 16 -#define RST_ACE 17 -#define RST_LVDS 18 -#define RST_GPU 19 -#define RST_HDMI_H 20 -#define RST_HDMI_SYS 21 -#define RST_HDMI_AUDIO_DMA 22 - -#endif /* DT_BINDINGS_RST_SUN4I_A10_H */ diff --git a/include/dt-bindings/reset/sun50i-a64-ccu.h b/include/dt-bindings/reset/sun50i-a64-ccu.h deleted file mode 100644 index db60b29ddb11..000000000000 --- a/include/dt-bindings/reset/sun50i-a64-ccu.h +++ /dev/null @@ -1,98 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN50I_A64_H_ -#define _DT_BINDINGS_RST_SUN50I_A64_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_HSIC 2 -#define RST_DRAM 3 -#define RST_MBUS 4 -#define RST_BUS_MIPI_DSI 5 -#define RST_BUS_CE 6 -#define RST_BUS_DMA 7 -#define RST_BUS_MMC0 8 -#define RST_BUS_MMC1 9 -#define RST_BUS_MMC2 10 -#define RST_BUS_NAND 11 -#define RST_BUS_DRAM 12 -#define RST_BUS_EMAC 13 -#define RST_BUS_TS 14 -#define RST_BUS_HSTIMER 15 -#define RST_BUS_SPI0 16 -#define RST_BUS_SPI1 17 -#define RST_BUS_OTG 18 -#define RST_BUS_EHCI0 19 -#define RST_BUS_EHCI1 20 -#define RST_BUS_OHCI0 21 -#define RST_BUS_OHCI1 22 -#define RST_BUS_VE 23 -#define RST_BUS_TCON0 24 -#define RST_BUS_TCON1 25 -#define RST_BUS_DEINTERLACE 26 -#define RST_BUS_CSI 27 -#define RST_BUS_HDMI0 28 -#define RST_BUS_HDMI1 29 -#define RST_BUS_DE 30 -#define RST_BUS_GPU 31 -#define RST_BUS_MSGBOX 32 -#define RST_BUS_SPINLOCK 33 -#define RST_BUS_DBG 34 -#define RST_BUS_LVDS 35 -#define RST_BUS_CODEC 36 -#define RST_BUS_SPDIF 37 -#define RST_BUS_THS 38 -#define RST_BUS_I2S0 39 -#define RST_BUS_I2S1 40 -#define RST_BUS_I2S2 41 -#define RST_BUS_I2C0 42 -#define RST_BUS_I2C1 43 -#define RST_BUS_I2C2 44 -#define RST_BUS_SCR 45 -#define RST_BUS_UART0 46 -#define RST_BUS_UART1 47 -#define RST_BUS_UART2 48 -#define RST_BUS_UART3 49 -#define RST_BUS_UART4 50 - -#endif /* _DT_BINDINGS_RST_SUN50I_A64_H_ */ diff --git a/include/dt-bindings/reset/sun50i-h6-ccu.h b/include/dt-bindings/reset/sun50i-h6-ccu.h deleted file mode 100644 index d038ddfa4818..000000000000 --- a/include/dt-bindings/reset/sun50i-h6-ccu.h +++ /dev/null @@ -1,73 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - */ - -#ifndef _DT_BINDINGS_RESET_SUN50I_H6_H_ -#define _DT_BINDINGS_RESET_SUN50I_H6_H_ - -#define RST_MBUS 0 -#define RST_BUS_DE 1 -#define RST_BUS_DEINTERLACE 2 -#define RST_BUS_GPU 3 -#define RST_BUS_CE 4 -#define RST_BUS_VE 5 -#define RST_BUS_EMCE 6 -#define RST_BUS_VP9 7 -#define RST_BUS_DMA 8 -#define RST_BUS_MSGBOX 9 -#define RST_BUS_SPINLOCK 10 -#define RST_BUS_HSTIMER 11 -#define RST_BUS_DBG 12 -#define RST_BUS_PSI 13 -#define RST_BUS_PWM 14 -#define RST_BUS_IOMMU 15 -#define RST_BUS_DRAM 16 -#define RST_BUS_NAND 17 -#define RST_BUS_MMC0 18 -#define RST_BUS_MMC1 19 -#define RST_BUS_MMC2 20 -#define RST_BUS_UART0 21 -#define RST_BUS_UART1 22 -#define RST_BUS_UART2 23 -#define RST_BUS_UART3 24 -#define RST_BUS_I2C0 25 -#define RST_BUS_I2C1 26 -#define RST_BUS_I2C2 27 -#define RST_BUS_I2C3 28 -#define RST_BUS_SCR0 29 -#define RST_BUS_SCR1 30 -#define RST_BUS_SPI0 31 -#define RST_BUS_SPI1 32 -#define RST_BUS_EMAC 33 -#define RST_BUS_TS 34 -#define RST_BUS_IR_TX 35 -#define RST_BUS_THS 36 -#define RST_BUS_I2S0 37 -#define RST_BUS_I2S1 38 -#define RST_BUS_I2S2 39 -#define RST_BUS_I2S3 40 -#define RST_BUS_SPDIF 41 -#define RST_BUS_DMIC 42 -#define RST_BUS_AUDIO_HUB 43 -#define RST_USB_PHY0 44 -#define RST_USB_PHY1 45 -#define RST_USB_PHY3 46 -#define RST_USB_HSIC 47 -#define RST_BUS_OHCI0 48 -#define RST_BUS_OHCI3 49 -#define RST_BUS_EHCI0 50 -#define RST_BUS_XHCI 51 -#define RST_BUS_EHCI3 52 -#define RST_BUS_OTG 53 -#define RST_BUS_PCIE 54 -#define RST_PCIE_POWERUP 55 -#define RST_BUS_HDMI 56 -#define RST_BUS_HDMI_SUB 57 -#define RST_BUS_TCON_TOP 58 -#define RST_BUS_TCON_LCD0 59 -#define RST_BUS_TCON_TV0 60 -#define RST_BUS_CSI 61 -#define RST_BUS_HDCP 62 - -#endif /* _DT_BINDINGS_RESET_SUN50I_H6_H_ */ diff --git a/include/dt-bindings/reset/sun50i-h6-r-ccu.h b/include/dt-bindings/reset/sun50i-h6-r-ccu.h deleted file mode 100644 index d541ade884fc..000000000000 --- a/include/dt-bindings/reset/sun50i-h6-r-ccu.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz - */ - -#ifndef _DT_BINDINGS_RST_SUN50I_H6_R_CCU_H_ -#define _DT_BINDINGS_RST_SUN50I_H6_R_CCU_H_ - -#define RST_R_APB1_TIMER 0 -#define RST_R_APB1_TWD 1 -#define RST_R_APB1_PWM 2 -#define RST_R_APB2_UART 3 -#define RST_R_APB2_I2C 4 -#define RST_R_APB1_IR 5 -#define RST_R_APB1_W1 6 -#define RST_R_APB2_RSB 7 - -#endif /* _DT_BINDINGS_RST_SUN50I_H6_R_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun50i-h616-ccu.h b/include/dt-bindings/reset/sun50i-h616-ccu.h deleted file mode 100644 index 1bd8bb0a11be..000000000000 --- a/include/dt-bindings/reset/sun50i-h616-ccu.h +++ /dev/null @@ -1,70 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (C) 2020 Arm Ltd. - */ - -#ifndef _DT_BINDINGS_RESET_SUN50I_H616_H_ -#define _DT_BINDINGS_RESET_SUN50I_H616_H_ - -#define RST_MBUS 0 -#define RST_BUS_DE 1 -#define RST_BUS_DEINTERLACE 2 -#define RST_BUS_GPU 3 -#define RST_BUS_CE 4 -#define RST_BUS_VE 5 -#define RST_BUS_DMA 6 -#define RST_BUS_HSTIMER 7 -#define RST_BUS_DBG 8 -#define RST_BUS_PSI 9 -#define RST_BUS_PWM 10 -#define RST_BUS_IOMMU 11 -#define RST_BUS_DRAM 12 -#define RST_BUS_NAND 13 -#define RST_BUS_MMC0 14 -#define RST_BUS_MMC1 15 -#define RST_BUS_MMC2 16 -#define RST_BUS_UART0 17 -#define RST_BUS_UART1 18 -#define RST_BUS_UART2 19 -#define RST_BUS_UART3 20 -#define RST_BUS_UART4 21 -#define RST_BUS_UART5 22 -#define RST_BUS_I2C0 23 -#define RST_BUS_I2C1 24 -#define RST_BUS_I2C2 25 -#define RST_BUS_I2C3 26 -#define RST_BUS_I2C4 27 -#define RST_BUS_SPI0 28 -#define RST_BUS_SPI1 29 -#define RST_BUS_EMAC0 30 -#define RST_BUS_EMAC1 31 -#define RST_BUS_TS 32 -#define RST_BUS_THS 33 -#define RST_BUS_SPDIF 34 -#define RST_BUS_DMIC 35 -#define RST_BUS_AUDIO_CODEC 36 -#define RST_BUS_AUDIO_HUB 37 -#define RST_USB_PHY0 38 -#define RST_USB_PHY1 39 -#define RST_USB_PHY2 40 -#define RST_USB_PHY3 41 -#define RST_BUS_OHCI0 42 -#define RST_BUS_OHCI1 43 -#define RST_BUS_OHCI2 44 -#define RST_BUS_OHCI3 45 -#define RST_BUS_EHCI0 46 -#define RST_BUS_EHCI1 47 -#define RST_BUS_EHCI2 48 -#define RST_BUS_EHCI3 49 -#define RST_BUS_OTG 50 -#define RST_BUS_HDMI 51 -#define RST_BUS_HDMI_SUB 52 -#define RST_BUS_TCON_TOP 53 -#define RST_BUS_TCON_TV0 54 -#define RST_BUS_TCON_TV1 55 -#define RST_BUS_TVE_TOP 56 -#define RST_BUS_TVE0 57 -#define RST_BUS_HDCP 58 -#define RST_BUS_KEYADC 59 - -#endif /* _DT_BINDINGS_RESET_SUN50I_H616_H_ */ diff --git a/include/dt-bindings/reset/sun5i-ccu.h b/include/dt-bindings/reset/sun5i-ccu.h deleted file mode 100644 index 40cc22ae7630..000000000000 --- a/include/dt-bindings/reset/sun5i-ccu.h +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright 2016 Maxime Ripard - * - * Maxime Ripard maxime.ripard@free-electrons.com - */ - -#ifndef _RST_SUN5I_H_ -#define _RST_SUN5I_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_GPS 2 -#define RST_DE_BE 3 -#define RST_DE_FE 4 -#define RST_TVE 5 -#define RST_LCD 6 -#define RST_CSI 7 -#define RST_VE 8 -#define RST_GPU 9 -#define RST_IEP 10 - -#endif /* _RST_SUN5I_H_ */ diff --git a/include/dt-bindings/reset/sun6i-a31-ccu.h b/include/dt-bindings/reset/sun6i-a31-ccu.h deleted file mode 100644 index fbff365ed6e1..000000000000 --- a/include/dt-bindings/reset/sun6i-a31-ccu.h +++ /dev/null @@ -1,106 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN6I_A31_H_ -#define _DT_BINDINGS_RST_SUN6I_A31_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_PHY2 2 - -#define RST_AHB1_MIPI_DSI 3 -#define RST_AHB1_SS 4 -#define RST_AHB1_DMA 5 -#define RST_AHB1_MMC0 6 -#define RST_AHB1_MMC1 7 -#define RST_AHB1_MMC2 8 -#define RST_AHB1_MMC3 9 -#define RST_AHB1_NAND1 10 -#define RST_AHB1_NAND0 11 -#define RST_AHB1_SDRAM 12 -#define RST_AHB1_EMAC 13 -#define RST_AHB1_TS 14 -#define RST_AHB1_HSTIMER 15 -#define RST_AHB1_SPI0 16 -#define RST_AHB1_SPI1 17 -#define RST_AHB1_SPI2 18 -#define RST_AHB1_SPI3 19 -#define RST_AHB1_OTG 20 -#define RST_AHB1_EHCI0 21 -#define RST_AHB1_EHCI1 22 -#define RST_AHB1_OHCI0 23 -#define RST_AHB1_OHCI1 24 -#define RST_AHB1_OHCI2 25 -#define RST_AHB1_VE 26 -#define RST_AHB1_LCD0 27 -#define RST_AHB1_LCD1 28 -#define RST_AHB1_CSI 29 -#define RST_AHB1_HDMI 30 -#define RST_AHB1_BE0 31 -#define RST_AHB1_BE1 32 -#define RST_AHB1_FE0 33 -#define RST_AHB1_FE1 34 -#define RST_AHB1_MP 35 -#define RST_AHB1_GPU 36 -#define RST_AHB1_DEU0 37 -#define RST_AHB1_DEU1 38 -#define RST_AHB1_DRC0 39 -#define RST_AHB1_DRC1 40 -#define RST_AHB1_LVDS 41 - -#define RST_APB1_CODEC 42 -#define RST_APB1_SPDIF 43 -#define RST_APB1_DIGITAL_MIC 44 -#define RST_APB1_DAUDIO0 45 -#define RST_APB1_DAUDIO1 46 -#define RST_APB2_I2C0 47 -#define RST_APB2_I2C1 48 -#define RST_APB2_I2C2 49 -#define RST_APB2_I2C3 50 -#define RST_APB2_UART0 51 -#define RST_APB2_UART1 52 -#define RST_APB2_UART2 53 -#define RST_APB2_UART3 54 -#define RST_APB2_UART4 55 -#define RST_APB2_UART5 56 - -#endif /* _DT_BINDINGS_RST_SUN6I_A31_H_ */ diff --git a/include/dt-bindings/reset/sun8i-a23-a33-ccu.h b/include/dt-bindings/reset/sun8i-a23-a33-ccu.h deleted file mode 100644 index 6121f2b0cd0a..000000000000 --- a/include/dt-bindings/reset/sun8i-a23-a33-ccu.h +++ /dev/null @@ -1,87 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN8I_A23_A33_H_ -#define _DT_BINDINGS_RST_SUN8I_A23_A33_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_HSIC 2 -#define RST_MBUS 3 -#define RST_BUS_MIPI_DSI 4 -#define RST_BUS_SS 5 -#define RST_BUS_DMA 6 -#define RST_BUS_MMC0 7 -#define RST_BUS_MMC1 8 -#define RST_BUS_MMC2 9 -#define RST_BUS_NAND 10 -#define RST_BUS_DRAM 11 -#define RST_BUS_HSTIMER 12 -#define RST_BUS_SPI0 13 -#define RST_BUS_SPI1 14 -#define RST_BUS_OTG 15 -#define RST_BUS_EHCI 16 -#define RST_BUS_OHCI 17 -#define RST_BUS_VE 18 -#define RST_BUS_LCD 19 -#define RST_BUS_CSI 20 -#define RST_BUS_DE_BE 21 -#define RST_BUS_DE_FE 22 -#define RST_BUS_GPU 23 -#define RST_BUS_MSGBOX 24 -#define RST_BUS_SPINLOCK 25 -#define RST_BUS_DRC 26 -#define RST_BUS_SAT 27 -#define RST_BUS_LVDS 28 -#define RST_BUS_CODEC 29 -#define RST_BUS_I2S0 30 -#define RST_BUS_I2S1 31 -#define RST_BUS_I2C0 32 -#define RST_BUS_I2C1 33 -#define RST_BUS_I2C2 34 -#define RST_BUS_UART0 35 -#define RST_BUS_UART1 36 -#define RST_BUS_UART2 37 -#define RST_BUS_UART3 38 -#define RST_BUS_UART4 39 - -#endif /* _DT_BINDINGS_RST_SUN8I_A23_A33_H_ */ diff --git a/include/dt-bindings/reset/sun8i-a83t-ccu.h b/include/dt-bindings/reset/sun8i-a83t-ccu.h deleted file mode 100644 index 784f6e11664e..000000000000 --- a/include/dt-bindings/reset/sun8i-a83t-ccu.h +++ /dev/null @@ -1,98 +0,0 @@ -/* - * Copyright (C) 2017 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ -#define _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_HSIC 2 - -#define RST_DRAM 3 -#define RST_MBUS 4 - -#define RST_BUS_MIPI_DSI 5 -#define RST_BUS_SS 6 -#define RST_BUS_DMA 7 -#define RST_BUS_MMC0 8 -#define RST_BUS_MMC1 9 -#define RST_BUS_MMC2 10 -#define RST_BUS_NAND 11 -#define RST_BUS_DRAM 12 -#define RST_BUS_EMAC 13 -#define RST_BUS_HSTIMER 14 -#define RST_BUS_SPI0 15 -#define RST_BUS_SPI1 16 -#define RST_BUS_OTG 17 -#define RST_BUS_EHCI0 18 -#define RST_BUS_EHCI1 19 -#define RST_BUS_OHCI0 20 - -#define RST_BUS_VE 21 -#define RST_BUS_TCON0 22 -#define RST_BUS_TCON1 23 -#define RST_BUS_CSI 24 -#define RST_BUS_HDMI0 25 -#define RST_BUS_HDMI1 26 -#define RST_BUS_DE 27 -#define RST_BUS_GPU 28 -#define RST_BUS_MSGBOX 29 -#define RST_BUS_SPINLOCK 30 - -#define RST_BUS_LVDS 31 - -#define RST_BUS_SPDIF 32 -#define RST_BUS_I2S0 33 -#define RST_BUS_I2S1 34 -#define RST_BUS_I2S2 35 -#define RST_BUS_TDM 36 - -#define RST_BUS_I2C0 37 -#define RST_BUS_I2C1 38 -#define RST_BUS_I2C2 39 -#define RST_BUS_UART0 40 -#define RST_BUS_UART1 41 -#define RST_BUS_UART2 42 -#define RST_BUS_UART3 43 -#define RST_BUS_UART4 44 - -#endif /* _DT_BINDINGS_RESET_SUN8I_A83T_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun8i-de2.h b/include/dt-bindings/reset/sun8i-de2.h deleted file mode 100644 index 1c36a6ac86d6..000000000000 --- a/include/dt-bindings/reset/sun8i-de2.h +++ /dev/null @@ -1,15 +0,0 @@ -/* - * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.io - * - * SPDX-License-Identifier: (GPL-2.0+ OR MIT) - */ - -#ifndef _DT_BINDINGS_RESET_SUN8I_DE2_H_ -#define _DT_BINDINGS_RESET_SUN8I_DE2_H_ - -#define RST_MIXER0 0 -#define RST_MIXER1 1 -#define RST_WB 2 -#define RST_ROT 3 - -#endif /* _DT_BINDINGS_RESET_SUN8I_DE2_H_ */ diff --git a/include/dt-bindings/reset/sun8i-h3-ccu.h b/include/dt-bindings/reset/sun8i-h3-ccu.h deleted file mode 100644 index 484c2a22919d..000000000000 --- a/include/dt-bindings/reset/sun8i-h3-ccu.h +++ /dev/null @@ -1,106 +0,0 @@ -/* - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN8I_H3_H_ -#define _DT_BINDINGS_RST_SUN8I_H3_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_PHY2 2 -#define RST_USB_PHY3 3 - -#define RST_MBUS 4 - -#define RST_BUS_CE 5 -#define RST_BUS_DMA 6 -#define RST_BUS_MMC0 7 -#define RST_BUS_MMC1 8 -#define RST_BUS_MMC2 9 -#define RST_BUS_NAND 10 -#define RST_BUS_DRAM 11 -#define RST_BUS_EMAC 12 -#define RST_BUS_TS 13 -#define RST_BUS_HSTIMER 14 -#define RST_BUS_SPI0 15 -#define RST_BUS_SPI1 16 -#define RST_BUS_OTG 17 -#define RST_BUS_EHCI0 18 -#define RST_BUS_EHCI1 19 -#define RST_BUS_EHCI2 20 -#define RST_BUS_EHCI3 21 -#define RST_BUS_OHCI0 22 -#define RST_BUS_OHCI1 23 -#define RST_BUS_OHCI2 24 -#define RST_BUS_OHCI3 25 -#define RST_BUS_VE 26 -#define RST_BUS_TCON0 27 -#define RST_BUS_TCON1 28 -#define RST_BUS_DEINTERLACE 29 -#define RST_BUS_CSI 30 -#define RST_BUS_TVE 31 -#define RST_BUS_HDMI0 32 -#define RST_BUS_HDMI1 33 -#define RST_BUS_DE 34 -#define RST_BUS_GPU 35 -#define RST_BUS_MSGBOX 36 -#define RST_BUS_SPINLOCK 37 -#define RST_BUS_DBG 38 -#define RST_BUS_EPHY 39 -#define RST_BUS_CODEC 40 -#define RST_BUS_SPDIF 41 -#define RST_BUS_THS 42 -#define RST_BUS_I2S0 43 -#define RST_BUS_I2S1 44 -#define RST_BUS_I2S2 45 -#define RST_BUS_I2C0 46 -#define RST_BUS_I2C1 47 -#define RST_BUS_I2C2 48 -#define RST_BUS_UART0 49 -#define RST_BUS_UART1 50 -#define RST_BUS_UART2 51 -#define RST_BUS_UART3 52 -#define RST_BUS_SCR0 53 - -/* New resets imported in H5 */ -#define RST_BUS_SCR1 54 - -#endif /* _DT_BINDINGS_RST_SUN8I_H3_H_ */ diff --git a/include/dt-bindings/reset/sun8i-r-ccu.h b/include/dt-bindings/reset/sun8i-r-ccu.h deleted file mode 100644 index 4ba64f3d6fc9..000000000000 --- a/include/dt-bindings/reset/sun8i-r-ccu.h +++ /dev/null @@ -1,53 +0,0 @@ -/* - * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN8I_R_CCU_H_ -#define _DT_BINDINGS_RST_SUN8I_R_CCU_H_ - -#define RST_APB0_IR 0 -#define RST_APB0_TIMER 1 -#define RST_APB0_RSB 2 -#define RST_APB0_UART 3 -/* 4 is reserved for RST_APB0_W1 on A31 */ -#define RST_APB0_I2C 5 - -#endif /* _DT_BINDINGS_RST_SUN8I_R_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun8i-r40-ccu.h b/include/dt-bindings/reset/sun8i-r40-ccu.h deleted file mode 100644 index c5ebcf6672e4..000000000000 --- a/include/dt-bindings/reset/sun8i-r40-ccu.h +++ /dev/null @@ -1,130 +0,0 @@ -/* - * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN8I_R40_H_ -#define _DT_BINDINGS_RST_SUN8I_R40_H_ - -#define RST_USB_PHY0 0 -#define RST_USB_PHY1 1 -#define RST_USB_PHY2 2 - -#define RST_DRAM 3 -#define RST_MBUS 4 - -#define RST_BUS_MIPI_DSI 5 -#define RST_BUS_CE 6 -#define RST_BUS_DMA 7 -#define RST_BUS_MMC0 8 -#define RST_BUS_MMC1 9 -#define RST_BUS_MMC2 10 -#define RST_BUS_MMC3 11 -#define RST_BUS_NAND 12 -#define RST_BUS_DRAM 13 -#define RST_BUS_EMAC 14 -#define RST_BUS_TS 15 -#define RST_BUS_HSTIMER 16 -#define RST_BUS_SPI0 17 -#define RST_BUS_SPI1 18 -#define RST_BUS_SPI2 19 -#define RST_BUS_SPI3 20 -#define RST_BUS_SATA 21 -#define RST_BUS_OTG 22 -#define RST_BUS_EHCI0 23 -#define RST_BUS_EHCI1 24 -#define RST_BUS_EHCI2 25 -#define RST_BUS_OHCI0 26 -#define RST_BUS_OHCI1 27 -#define RST_BUS_OHCI2 28 -#define RST_BUS_VE 29 -#define RST_BUS_MP 30 -#define RST_BUS_DEINTERLACE 31 -#define RST_BUS_CSI0 32 -#define RST_BUS_CSI1 33 -#define RST_BUS_HDMI0 34 -#define RST_BUS_HDMI1 35 -#define RST_BUS_DE 36 -#define RST_BUS_TVE0 37 -#define RST_BUS_TVE1 38 -#define RST_BUS_TVE_TOP 39 -#define RST_BUS_GMAC 40 -#define RST_BUS_GPU 41 -#define RST_BUS_TVD0 42 -#define RST_BUS_TVD1 43 -#define RST_BUS_TVD2 44 -#define RST_BUS_TVD3 45 -#define RST_BUS_TVD_TOP 46 -#define RST_BUS_TCON_LCD0 47 -#define RST_BUS_TCON_LCD1 48 -#define RST_BUS_TCON_TV0 49 -#define RST_BUS_TCON_TV1 50 -#define RST_BUS_TCON_TOP 51 -#define RST_BUS_DBG 52 -#define RST_BUS_LVDS 53 -#define RST_BUS_CODEC 54 -#define RST_BUS_SPDIF 55 -#define RST_BUS_AC97 56 -#define RST_BUS_IR0 57 -#define RST_BUS_IR1 58 -#define RST_BUS_THS 59 -#define RST_BUS_KEYPAD 60 -#define RST_BUS_I2S0 61 -#define RST_BUS_I2S1 62 -#define RST_BUS_I2S2 63 -#define RST_BUS_I2C0 64 -#define RST_BUS_I2C1 65 -#define RST_BUS_I2C2 66 -#define RST_BUS_I2C3 67 -#define RST_BUS_CAN 68 -#define RST_BUS_SCR 69 -#define RST_BUS_PS20 70 -#define RST_BUS_PS21 71 -#define RST_BUS_I2C4 72 -#define RST_BUS_UART0 73 -#define RST_BUS_UART1 74 -#define RST_BUS_UART2 75 -#define RST_BUS_UART3 76 -#define RST_BUS_UART4 77 -#define RST_BUS_UART5 78 -#define RST_BUS_UART6 79 -#define RST_BUS_UART7 80 - -#endif /* _DT_BINDINGS_RST_SUN8I_R40_H_ */ diff --git a/include/dt-bindings/reset/sun8i-v3s-ccu.h b/include/dt-bindings/reset/sun8i-v3s-ccu.h deleted file mode 100644 index b6790173afd6..000000000000 --- a/include/dt-bindings/reset/sun8i-v3s-ccu.h +++ /dev/null @@ -1,81 +0,0 @@ -/* - * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz - * - * Based on sun8i-v3s-ccu.h, which is - * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RST_SUN8I_V3S_H_ -#define _DT_BINDINGS_RST_SUN8I_V3S_H_ - -#define RST_USB_PHY0 0 - -#define RST_MBUS 1 - -#define RST_BUS_CE 5 -#define RST_BUS_DMA 6 -#define RST_BUS_MMC0 7 -#define RST_BUS_MMC1 8 -#define RST_BUS_MMC2 9 -#define RST_BUS_DRAM 11 -#define RST_BUS_EMAC 12 -#define RST_BUS_HSTIMER 14 -#define RST_BUS_SPI0 15 -#define RST_BUS_OTG 17 -#define RST_BUS_EHCI0 18 -#define RST_BUS_OHCI0 22 -#define RST_BUS_VE 26 -#define RST_BUS_TCON0 27 -#define RST_BUS_CSI 30 -#define RST_BUS_DE 34 -#define RST_BUS_DBG 38 -#define RST_BUS_EPHY 39 -#define RST_BUS_CODEC 40 -#define RST_BUS_I2C0 46 -#define RST_BUS_I2C1 47 -#define RST_BUS_UART0 49 -#define RST_BUS_UART1 50 -#define RST_BUS_UART2 51 - -/* Reset lines not available on V3s */ -#define RST_BUS_I2S0 52 - -#endif /* _DT_BINDINGS_RST_SUN8I_H3_H_ */ diff --git a/include/dt-bindings/reset/sun9i-a80-ccu.h b/include/dt-bindings/reset/sun9i-a80-ccu.h deleted file mode 100644 index 4b8df4b36788..000000000000 --- a/include/dt-bindings/reset/sun9i-a80-ccu.h +++ /dev/null @@ -1,102 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RESET_SUN9I_A80_CCU_H_ -#define _DT_BINDINGS_RESET_SUN9I_A80_CCU_H_ - -#define RST_BUS_FD 0 -#define RST_BUS_VE 1 -#define RST_BUS_GPU_CTRL 2 -#define RST_BUS_SS 3 -#define RST_BUS_MMC 4 -#define RST_BUS_NAND0 5 -#define RST_BUS_NAND1 6 -#define RST_BUS_SDRAM 7 -#define RST_BUS_SATA 8 -#define RST_BUS_TS 9 -#define RST_BUS_SPI0 10 -#define RST_BUS_SPI1 11 -#define RST_BUS_SPI2 12 -#define RST_BUS_SPI3 13 - -#define RST_BUS_OTG 14 -#define RST_BUS_OTG_PHY 15 -#define RST_BUS_MIPI_HSI 16 -#define RST_BUS_GMAC 17 -#define RST_BUS_MSGBOX 18 -#define RST_BUS_SPINLOCK 19 -#define RST_BUS_HSTIMER 20 -#define RST_BUS_DMA 21 - -#define RST_BUS_LCD0 22 -#define RST_BUS_LCD1 23 -#define RST_BUS_EDP 24 -#define RST_BUS_LVDS 25 -#define RST_BUS_CSI 26 -#define RST_BUS_HDMI0 27 -#define RST_BUS_HDMI1 28 -#define RST_BUS_DE 29 -#define RST_BUS_MP 30 -#define RST_BUS_GPU 31 -#define RST_BUS_MIPI_DSI 32 - -#define RST_BUS_SPDIF 33 -#define RST_BUS_AC97 34 -#define RST_BUS_I2S0 35 -#define RST_BUS_I2S1 36 -#define RST_BUS_LRADC 37 -#define RST_BUS_GPADC 38 -#define RST_BUS_CIR_TX 39 - -#define RST_BUS_I2C0 40 -#define RST_BUS_I2C1 41 -#define RST_BUS_I2C2 42 -#define RST_BUS_I2C3 43 -#define RST_BUS_I2C4 44 -#define RST_BUS_UART0 45 -#define RST_BUS_UART1 46 -#define RST_BUS_UART2 47 -#define RST_BUS_UART3 48 -#define RST_BUS_UART4 49 -#define RST_BUS_UART5 50 - -#endif /* _DT_BINDINGS_RESET_SUN9I_A80_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun9i-a80-de.h b/include/dt-bindings/reset/sun9i-a80-de.h deleted file mode 100644 index 205072770171..000000000000 --- a/include/dt-bindings/reset/sun9i-a80-de.h +++ /dev/null @@ -1,58 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RESET_SUN9I_A80_DE_H_ -#define _DT_BINDINGS_RESET_SUN9I_A80_DE_H_ - -#define RST_FE0 0 -#define RST_FE1 1 -#define RST_FE2 2 -#define RST_DEU0 3 -#define RST_DEU1 4 -#define RST_BE0 5 -#define RST_BE1 6 -#define RST_BE2 7 -#define RST_DRC0 8 -#define RST_DRC1 9 -#define RST_MERGE 10 - -#endif /* _DT_BINDINGS_RESET_SUN9I_A80_DE_H_ */ diff --git a/include/dt-bindings/reset/sun9i-a80-usb.h b/include/dt-bindings/reset/sun9i-a80-usb.h deleted file mode 100644 index ee492864c2aa..000000000000 --- a/include/dt-bindings/reset/sun9i-a80-usb.h +++ /dev/null @@ -1,56 +0,0 @@ -/* - * Copyright (C) 2016 Chen-Yu Tsai wens@csie.org - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#ifndef _DT_BINDINGS_RESET_SUN9I_A80_USB_H_ -#define _DT_BINDINGS_RESET_SUN9I_A80_USB_H_ - -#define RST_USB0_HCI 0 -#define RST_USB1_HCI 1 -#define RST_USB2_HCI 2 - -#define RST_USB0_PHY 3 -#define RST_USB1_HSIC 4 -#define RST_USB1_PHY 5 -#define RST_USB2_HSIC 6 -#define RST_USB2_PHY 7 - -#endif /* _DT_BINDINGS_RESET_SUN9I_A80_USB_H_ */ diff --git a/include/dt-bindings/reset/suniv-ccu-f1c100s.h b/include/dt-bindings/reset/suniv-ccu-f1c100s.h deleted file mode 100644 index 6a4b4385fe5a..000000000000 --- a/include/dt-bindings/reset/suniv-ccu-f1c100s.h +++ /dev/null @@ -1,38 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) - * - * Copyright (C) 2018 Icenowy Zheng icenowy@aosc.xyz - * - */ - -#ifndef _DT_BINDINGS_RST_SUNIV_F1C100S_H_ -#define _DT_BINDINGS_RST_SUNIV_F1C100S_H_ - -#define RST_USB_PHY0 0 -#define RST_BUS_DMA 1 -#define RST_BUS_MMC0 2 -#define RST_BUS_MMC1 3 -#define RST_BUS_DRAM 4 -#define RST_BUS_SPI0 5 -#define RST_BUS_SPI1 6 -#define RST_BUS_OTG 7 -#define RST_BUS_VE 8 -#define RST_BUS_LCD 9 -#define RST_BUS_DEINTERLACE 10 -#define RST_BUS_CSI 11 -#define RST_BUS_TVD 12 -#define RST_BUS_TVE 13 -#define RST_BUS_DE_BE 14 -#define RST_BUS_DE_FE 15 -#define RST_BUS_CODEC 16 -#define RST_BUS_SPDIF 17 -#define RST_BUS_IR 18 -#define RST_BUS_RSB 19 -#define RST_BUS_I2S0 20 -#define RST_BUS_I2C0 21 -#define RST_BUS_I2C1 22 -#define RST_BUS_I2C2 23 -#define RST_BUS_UART0 24 -#define RST_BUS_UART1 25 -#define RST_BUS_UART2 26 - -#endif /* _DT_BINDINGS_RST_SUNIV_F1C100S_H_ */
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/imx5-clock.h | 219 ------------- include/dt-bindings/clock/imx6qdl-clock.h | 278 ----------------- include/dt-bindings/clock/imx6sl-clock.h | 178 ----------- include/dt-bindings/clock/imx6sll-clock.h | 210 ------------- include/dt-bindings/clock/imx6sx-clock.h | 281 ----------------- include/dt-bindings/clock/imx6ul-clock.h | 262 ---------------- include/dt-bindings/clock/imx7d-clock.h | 456 ---------------------------- include/dt-bindings/clock/imx7ulp-clock.h | 119 -------- include/dt-bindings/clock/imx8mm-clock.h | 286 ----------------- include/dt-bindings/clock/imx8mn-clock.h | 262 ---------------- include/dt-bindings/clock/imx8mp-clock.h | 401 ------------------------ include/dt-bindings/clock/imx8mq-clock.h | 431 -------------------------- include/dt-bindings/clock/imx8ulp-clock.h | 258 ---------------- include/dt-bindings/clock/imx93-clock.h | 208 ------------- include/dt-bindings/clock/imxrt1050-clock.h | 72 ----- 15 files changed, 3921 deletions(-)
diff --git a/include/dt-bindings/clock/imx5-clock.h b/include/dt-bindings/clock/imx5-clock.h deleted file mode 100644 index d382fc71aa83..000000000000 --- a/include/dt-bindings/clock/imx5-clock.h +++ /dev/null @@ -1,219 +0,0 @@ -/* - * Copyright 2013 Lucas Stach, Pengutronix l.stach@pengutronix.de - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX5_H -#define __DT_BINDINGS_CLOCK_IMX5_H - -#define IMX5_CLK_DUMMY 0 -#define IMX5_CLK_CKIL 1 -#define IMX5_CLK_OSC 2 -#define IMX5_CLK_CKIH1 3 -#define IMX5_CLK_CKIH2 4 -#define IMX5_CLK_AHB 5 -#define IMX5_CLK_IPG 6 -#define IMX5_CLK_AXI_A 7 -#define IMX5_CLK_AXI_B 8 -#define IMX5_CLK_UART_PRED 9 -#define IMX5_CLK_UART_ROOT 10 -#define IMX5_CLK_ESDHC_A_PRED 11 -#define IMX5_CLK_ESDHC_B_PRED 12 -#define IMX5_CLK_ESDHC_C_SEL 13 -#define IMX5_CLK_ESDHC_D_SEL 14 -#define IMX5_CLK_EMI_SEL 15 -#define IMX5_CLK_EMI_SLOW_PODF 16 -#define IMX5_CLK_NFC_PODF 17 -#define IMX5_CLK_ECSPI_PRED 18 -#define IMX5_CLK_ECSPI_PODF 19 -#define IMX5_CLK_USBOH3_PRED 20 -#define IMX5_CLK_USBOH3_PODF 21 -#define IMX5_CLK_USB_PHY_PRED 22 -#define IMX5_CLK_USB_PHY_PODF 23 -#define IMX5_CLK_CPU_PODF 24 -#define IMX5_CLK_DI_PRED 25 -#define IMX5_CLK_TVE_SEL 27 -#define IMX5_CLK_UART1_IPG_GATE 28 -#define IMX5_CLK_UART1_PER_GATE 29 -#define IMX5_CLK_UART2_IPG_GATE 30 -#define IMX5_CLK_UART2_PER_GATE 31 -#define IMX5_CLK_UART3_IPG_GATE 32 -#define IMX5_CLK_UART3_PER_GATE 33 -#define IMX5_CLK_I2C1_GATE 34 -#define IMX5_CLK_I2C2_GATE 35 -#define IMX5_CLK_GPT_IPG_GATE 36 -#define IMX5_CLK_PWM1_IPG_GATE 37 -#define IMX5_CLK_PWM1_HF_GATE 38 -#define IMX5_CLK_PWM2_IPG_GATE 39 -#define IMX5_CLK_PWM2_HF_GATE 40 -#define IMX5_CLK_GPT_HF_GATE 41 -#define IMX5_CLK_FEC_GATE 42 -#define IMX5_CLK_USBOH3_PER_GATE 43 -#define IMX5_CLK_ESDHC1_IPG_GATE 44 -#define IMX5_CLK_ESDHC2_IPG_GATE 45 -#define IMX5_CLK_ESDHC3_IPG_GATE 46 -#define IMX5_CLK_ESDHC4_IPG_GATE 47 -#define IMX5_CLK_SSI1_IPG_GATE 48 -#define IMX5_CLK_SSI2_IPG_GATE 49 -#define IMX5_CLK_SSI3_IPG_GATE 50 -#define IMX5_CLK_ECSPI1_IPG_GATE 51 -#define IMX5_CLK_ECSPI1_PER_GATE 52 -#define IMX5_CLK_ECSPI2_IPG_GATE 53 -#define IMX5_CLK_ECSPI2_PER_GATE 54 -#define IMX5_CLK_CSPI_IPG_GATE 55 -#define IMX5_CLK_SDMA_GATE 56 -#define IMX5_CLK_EMI_SLOW_GATE 57 -#define IMX5_CLK_IPU_SEL 58 -#define IMX5_CLK_IPU_GATE 59 -#define IMX5_CLK_NFC_GATE 60 -#define IMX5_CLK_IPU_DI1_GATE 61 -#define IMX5_CLK_VPU_SEL 62 -#define IMX5_CLK_VPU_GATE 63 -#define IMX5_CLK_VPU_REFERENCE_GATE 64 -#define IMX5_CLK_UART4_IPG_GATE 65 -#define IMX5_CLK_UART4_PER_GATE 66 -#define IMX5_CLK_UART5_IPG_GATE 67 -#define IMX5_CLK_UART5_PER_GATE 68 -#define IMX5_CLK_TVE_GATE 69 -#define IMX5_CLK_TVE_PRED 70 -#define IMX5_CLK_ESDHC1_PER_GATE 71 -#define IMX5_CLK_ESDHC2_PER_GATE 72 -#define IMX5_CLK_ESDHC3_PER_GATE 73 -#define IMX5_CLK_ESDHC4_PER_GATE 74 -#define IMX5_CLK_USB_PHY_GATE 75 -#define IMX5_CLK_HSI2C_GATE 76 -#define IMX5_CLK_MIPI_HSC1_GATE 77 -#define IMX5_CLK_MIPI_HSC2_GATE 78 -#define IMX5_CLK_MIPI_ESC_GATE 79 -#define IMX5_CLK_MIPI_HSP_GATE 80 -#define IMX5_CLK_LDB_DI1_DIV_3_5 81 -#define IMX5_CLK_LDB_DI1_DIV 82 -#define IMX5_CLK_LDB_DI0_DIV_3_5 83 -#define IMX5_CLK_LDB_DI0_DIV 84 -#define IMX5_CLK_LDB_DI1_GATE 85 -#define IMX5_CLK_CAN2_SERIAL_GATE 86 -#define IMX5_CLK_CAN2_IPG_GATE 87 -#define IMX5_CLK_I2C3_GATE 88 -#define IMX5_CLK_LP_APM 89 -#define IMX5_CLK_PERIPH_APM 90 -#define IMX5_CLK_MAIN_BUS 91 -#define IMX5_CLK_AHB_MAX 92 -#define IMX5_CLK_AIPS_TZ1 93 -#define IMX5_CLK_AIPS_TZ2 94 -#define IMX5_CLK_TMAX1 95 -#define IMX5_CLK_TMAX2 96 -#define IMX5_CLK_TMAX3 97 -#define IMX5_CLK_SPBA 98 -#define IMX5_CLK_UART_SEL 99 -#define IMX5_CLK_ESDHC_A_SEL 100 -#define IMX5_CLK_ESDHC_B_SEL 101 -#define IMX5_CLK_ESDHC_A_PODF 102 -#define IMX5_CLK_ESDHC_B_PODF 103 -#define IMX5_CLK_ECSPI_SEL 104 -#define IMX5_CLK_USBOH3_SEL 105 -#define IMX5_CLK_USB_PHY_SEL 106 -#define IMX5_CLK_IIM_GATE 107 -#define IMX5_CLK_USBOH3_GATE 108 -#define IMX5_CLK_EMI_FAST_GATE 109 -#define IMX5_CLK_IPU_DI0_GATE 110 -#define IMX5_CLK_GPC_DVFS 111 -#define IMX5_CLK_PLL1_SW 112 -#define IMX5_CLK_PLL2_SW 113 -#define IMX5_CLK_PLL3_SW 114 -#define IMX5_CLK_IPU_DI0_SEL 115 -#define IMX5_CLK_IPU_DI1_SEL 116 -#define IMX5_CLK_TVE_EXT_SEL 117 -#define IMX5_CLK_MX51_MIPI 118 -#define IMX5_CLK_PLL4_SW 119 -#define IMX5_CLK_LDB_DI1_SEL 120 -#define IMX5_CLK_DI_PLL4_PODF 121 -#define IMX5_CLK_LDB_DI0_SEL 122 -#define IMX5_CLK_LDB_DI0_GATE 123 -#define IMX5_CLK_USB_PHY1_GATE 124 -#define IMX5_CLK_USB_PHY2_GATE 125 -#define IMX5_CLK_PER_LP_APM 126 -#define IMX5_CLK_PER_PRED1 127 -#define IMX5_CLK_PER_PRED2 128 -#define IMX5_CLK_PER_PODF 129 -#define IMX5_CLK_PER_ROOT 130 -#define IMX5_CLK_SSI_APM 131 -#define IMX5_CLK_SSI1_ROOT_SEL 132 -#define IMX5_CLK_SSI2_ROOT_SEL 133 -#define IMX5_CLK_SSI3_ROOT_SEL 134 -#define IMX5_CLK_SSI_EXT1_SEL 135 -#define IMX5_CLK_SSI_EXT2_SEL 136 -#define IMX5_CLK_SSI_EXT1_COM_SEL 137 -#define IMX5_CLK_SSI_EXT2_COM_SEL 138 -#define IMX5_CLK_SSI1_ROOT_PRED 139 -#define IMX5_CLK_SSI1_ROOT_PODF 140 -#define IMX5_CLK_SSI2_ROOT_PRED 141 -#define IMX5_CLK_SSI2_ROOT_PODF 142 -#define IMX5_CLK_SSI_EXT1_PRED 143 -#define IMX5_CLK_SSI_EXT1_PODF 144 -#define IMX5_CLK_SSI_EXT2_PRED 145 -#define IMX5_CLK_SSI_EXT2_PODF 146 -#define IMX5_CLK_SSI1_ROOT_GATE 147 -#define IMX5_CLK_SSI2_ROOT_GATE 148 -#define IMX5_CLK_SSI3_ROOT_GATE 149 -#define IMX5_CLK_SSI_EXT1_GATE 150 -#define IMX5_CLK_SSI_EXT2_GATE 151 -#define IMX5_CLK_EPIT1_IPG_GATE 152 -#define IMX5_CLK_EPIT1_HF_GATE 153 -#define IMX5_CLK_EPIT2_IPG_GATE 154 -#define IMX5_CLK_EPIT2_HF_GATE 155 -#define IMX5_CLK_CAN_SEL 156 -#define IMX5_CLK_CAN1_SERIAL_GATE 157 -#define IMX5_CLK_CAN1_IPG_GATE 158 -#define IMX5_CLK_OWIRE_GATE 159 -#define IMX5_CLK_GPU3D_SEL 160 -#define IMX5_CLK_GPU2D_SEL 161 -#define IMX5_CLK_GPU3D_GATE 162 -#define IMX5_CLK_GPU2D_GATE 163 -#define IMX5_CLK_GARB_GATE 164 -#define IMX5_CLK_CKO1_SEL 165 -#define IMX5_CLK_CKO1_PODF 166 -#define IMX5_CLK_CKO1 167 -#define IMX5_CLK_CKO2_SEL 168 -#define IMX5_CLK_CKO2_PODF 169 -#define IMX5_CLK_CKO2 170 -#define IMX5_CLK_SRTC_GATE 171 -#define IMX5_CLK_PATA_GATE 172 -#define IMX5_CLK_SATA_GATE 173 -#define IMX5_CLK_SPDIF_XTAL_SEL 174 -#define IMX5_CLK_SPDIF0_SEL 175 -#define IMX5_CLK_SPDIF1_SEL 176 -#define IMX5_CLK_SPDIF0_PRED 177 -#define IMX5_CLK_SPDIF0_PODF 178 -#define IMX5_CLK_SPDIF1_PRED 179 -#define IMX5_CLK_SPDIF1_PODF 180 -#define IMX5_CLK_SPDIF0_COM_SEL 181 -#define IMX5_CLK_SPDIF1_COM_SEL 182 -#define IMX5_CLK_SPDIF0_GATE 183 -#define IMX5_CLK_SPDIF1_GATE 184 -#define IMX5_CLK_SPDIF_IPG_GATE 185 -#define IMX5_CLK_OCRAM 186 -#define IMX5_CLK_SAHARA_IPG_GATE 187 -#define IMX5_CLK_SATA_REF 188 -#define IMX5_CLK_STEP_SEL 189 -#define IMX5_CLK_CPU_PODF_SEL 190 -#define IMX5_CLK_ARM 191 -#define IMX5_CLK_FIRI_PRED 192 -#define IMX5_CLK_FIRI_SEL 193 -#define IMX5_CLK_FIRI_PODF 194 -#define IMX5_CLK_FIRI_SERIAL_GATE 195 -#define IMX5_CLK_FIRI_IPG_GATE 196 -#define IMX5_CLK_CSI0_MCLK1_PRED 197 -#define IMX5_CLK_CSI0_MCLK1_SEL 198 -#define IMX5_CLK_CSI0_MCLK1_PODF 199 -#define IMX5_CLK_CSI0_MCLK1_GATE 200 -#define IMX5_CLK_IEEE1588_PRED 201 -#define IMX5_CLK_IEEE1588_SEL 202 -#define IMX5_CLK_IEEE1588_PODF 203 -#define IMX5_CLK_IEEE1588_GATE 204 -#define IMX5_CLK_END 205 - -#endif /* __DT_BINDINGS_CLOCK_IMX5_H */ diff --git a/include/dt-bindings/clock/imx6qdl-clock.h b/include/dt-bindings/clock/imx6qdl-clock.h deleted file mode 100644 index e20c43cc36f6..000000000000 --- a/include/dt-bindings/clock/imx6qdl-clock.h +++ /dev/null @@ -1,278 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX6QDL_H -#define __DT_BINDINGS_CLOCK_IMX6QDL_H - -#define IMX6QDL_CLK_DUMMY 0 -#define IMX6QDL_CLK_CKIL 1 -#define IMX6QDL_CLK_CKIH 2 -#define IMX6QDL_CLK_OSC 3 -#define IMX6QDL_CLK_PLL2_PFD0_352M 4 -#define IMX6QDL_CLK_PLL2_PFD1_594M 5 -#define IMX6QDL_CLK_PLL2_PFD2_396M 6 -#define IMX6QDL_CLK_PLL3_PFD0_720M 7 -#define IMX6QDL_CLK_PLL3_PFD1_540M 8 -#define IMX6QDL_CLK_PLL3_PFD2_508M 9 -#define IMX6QDL_CLK_PLL3_PFD3_454M 10 -#define IMX6QDL_CLK_PLL2_198M 11 -#define IMX6QDL_CLK_PLL3_120M 12 -#define IMX6QDL_CLK_PLL3_80M 13 -#define IMX6QDL_CLK_PLL3_60M 14 -#define IMX6QDL_CLK_TWD 15 -#define IMX6QDL_CLK_STEP 16 -#define IMX6QDL_CLK_PLL1_SW 17 -#define IMX6QDL_CLK_PERIPH_PRE 18 -#define IMX6QDL_CLK_PERIPH2_PRE 19 -#define IMX6QDL_CLK_PERIPH_CLK2_SEL 20 -#define IMX6QDL_CLK_PERIPH2_CLK2_SEL 21 -#define IMX6QDL_CLK_AXI_SEL 22 -#define IMX6QDL_CLK_ESAI_SEL 23 -#define IMX6QDL_CLK_ASRC_SEL 24 -#define IMX6QDL_CLK_SPDIF_SEL 25 -#define IMX6QDL_CLK_GPU2D_AXI 26 -#define IMX6QDL_CLK_GPU3D_AXI 27 -#define IMX6QDL_CLK_GPU2D_CORE_SEL 28 -#define IMX6QDL_CLK_GPU3D_CORE_SEL 29 -#define IMX6QDL_CLK_GPU3D_SHADER_SEL 30 -#define IMX6QDL_CLK_IPU1_SEL 31 -#define IMX6QDL_CLK_IPU2_SEL 32 -#define IMX6QDL_CLK_LDB_DI0_SEL 33 -#define IMX6QDL_CLK_LDB_DI1_SEL 34 -#define IMX6QDL_CLK_IPU1_DI0_PRE_SEL 35 -#define IMX6QDL_CLK_IPU1_DI1_PRE_SEL 36 -#define IMX6QDL_CLK_IPU2_DI0_PRE_SEL 37 -#define IMX6QDL_CLK_IPU2_DI1_PRE_SEL 38 -#define IMX6QDL_CLK_IPU1_DI0_SEL 39 -#define IMX6QDL_CLK_IPU1_DI1_SEL 40 -#define IMX6QDL_CLK_IPU2_DI0_SEL 41 -#define IMX6QDL_CLK_IPU2_DI1_SEL 42 -#define IMX6QDL_CLK_HSI_TX_SEL 43 -#define IMX6QDL_CLK_PCIE_AXI_SEL 44 -#define IMX6QDL_CLK_SSI1_SEL 45 -#define IMX6QDL_CLK_SSI2_SEL 46 -#define IMX6QDL_CLK_SSI3_SEL 47 -#define IMX6QDL_CLK_USDHC1_SEL 48 -#define IMX6QDL_CLK_USDHC2_SEL 49 -#define IMX6QDL_CLK_USDHC3_SEL 50 -#define IMX6QDL_CLK_USDHC4_SEL 51 -#define IMX6QDL_CLK_ENFC_SEL 52 -#define IMX6QDL_CLK_EIM_SEL 53 -#define IMX6QDL_CLK_EIM_SLOW_SEL 54 -#define IMX6QDL_CLK_VDO_AXI_SEL 55 -#define IMX6QDL_CLK_VPU_AXI_SEL 56 -#define IMX6QDL_CLK_CKO1_SEL 57 -#define IMX6QDL_CLK_PERIPH 58 -#define IMX6QDL_CLK_PERIPH2 59 -#define IMX6QDL_CLK_PERIPH_CLK2 60 -#define IMX6QDL_CLK_PERIPH2_CLK2 61 -#define IMX6QDL_CLK_IPG 62 -#define IMX6QDL_CLK_IPG_PER 63 -#define IMX6QDL_CLK_ESAI_PRED 64 -#define IMX6QDL_CLK_ESAI_PODF 65 -#define IMX6QDL_CLK_ASRC_PRED 66 -#define IMX6QDL_CLK_ASRC_PODF 67 -#define IMX6QDL_CLK_SPDIF_PRED 68 -#define IMX6QDL_CLK_SPDIF_PODF 69 -#define IMX6QDL_CLK_CAN_ROOT 70 -#define IMX6QDL_CLK_ECSPI_ROOT 71 -#define IMX6QDL_CLK_GPU2D_CORE_PODF 72 -#define IMX6QDL_CLK_GPU3D_CORE_PODF 73 -#define IMX6QDL_CLK_GPU3D_SHADER 74 -#define IMX6QDL_CLK_IPU1_PODF 75 -#define IMX6QDL_CLK_IPU2_PODF 76 -#define IMX6QDL_CLK_LDB_DI0_PODF 77 -#define IMX6QDL_CLK_LDB_DI1_PODF 78 -#define IMX6QDL_CLK_IPU1_DI0_PRE 79 -#define IMX6QDL_CLK_IPU1_DI1_PRE 80 -#define IMX6QDL_CLK_IPU2_DI0_PRE 81 -#define IMX6QDL_CLK_IPU2_DI1_PRE 82 -#define IMX6QDL_CLK_HSI_TX_PODF 83 -#define IMX6QDL_CLK_SSI1_PRED 84 -#define IMX6QDL_CLK_SSI1_PODF 85 -#define IMX6QDL_CLK_SSI2_PRED 86 -#define IMX6QDL_CLK_SSI2_PODF 87 -#define IMX6QDL_CLK_SSI3_PRED 88 -#define IMX6QDL_CLK_SSI3_PODF 89 -#define IMX6QDL_CLK_UART_SERIAL_PODF 90 -#define IMX6QDL_CLK_USDHC1_PODF 91 -#define IMX6QDL_CLK_USDHC2_PODF 92 -#define IMX6QDL_CLK_USDHC3_PODF 93 -#define IMX6QDL_CLK_USDHC4_PODF 94 -#define IMX6QDL_CLK_ENFC_PRED 95 -#define IMX6QDL_CLK_ENFC_PODF 96 -#define IMX6QDL_CLK_EIM_PODF 97 -#define IMX6QDL_CLK_EIM_SLOW_PODF 98 -#define IMX6QDL_CLK_VPU_AXI_PODF 99 -#define IMX6QDL_CLK_CKO1_PODF 100 -#define IMX6QDL_CLK_AXI 101 -#define IMX6QDL_CLK_MMDC_CH0_AXI_PODF 102 -#define IMX6QDL_CLK_MMDC_CH1_AXI_PODF 103 -#define IMX6QDL_CLK_ARM 104 -#define IMX6QDL_CLK_AHB 105 -#define IMX6QDL_CLK_APBH_DMA 106 -#define IMX6QDL_CLK_ASRC 107 -#define IMX6QDL_CLK_CAN1_IPG 108 -#define IMX6QDL_CLK_CAN1_SERIAL 109 -#define IMX6QDL_CLK_CAN2_IPG 110 -#define IMX6QDL_CLK_CAN2_SERIAL 111 -#define IMX6QDL_CLK_ECSPI1 112 -#define IMX6QDL_CLK_ECSPI2 113 -#define IMX6QDL_CLK_ECSPI3 114 -#define IMX6QDL_CLK_ECSPI4 115 -#define IMX6Q_CLK_ECSPI5 116 -#define IMX6DL_CLK_I2C4 116 -#define IMX6QDL_CLK_ENET 117 -#define IMX6QDL_CLK_ESAI_EXTAL 118 -#define IMX6QDL_CLK_GPT_IPG 119 -#define IMX6QDL_CLK_GPT_IPG_PER 120 -#define IMX6QDL_CLK_GPU2D_CORE 121 -#define IMX6QDL_CLK_GPU3D_CORE 122 -#define IMX6QDL_CLK_HDMI_IAHB 123 -#define IMX6QDL_CLK_HDMI_ISFR 124 -#define IMX6QDL_CLK_I2C1 125 -#define IMX6QDL_CLK_I2C2 126 -#define IMX6QDL_CLK_I2C3 127 -#define IMX6QDL_CLK_IIM 128 -#define IMX6QDL_CLK_ENFC 129 -#define IMX6QDL_CLK_IPU1 130 -#define IMX6QDL_CLK_IPU1_DI0 131 -#define IMX6QDL_CLK_IPU1_DI1 132 -#define IMX6QDL_CLK_IPU2 133 -#define IMX6QDL_CLK_IPU2_DI0 134 -#define IMX6QDL_CLK_LDB_DI0 135 -#define IMX6QDL_CLK_LDB_DI1 136 -#define IMX6QDL_CLK_IPU2_DI1 137 -#define IMX6QDL_CLK_HSI_TX 138 -#define IMX6QDL_CLK_MLB 139 -#define IMX6QDL_CLK_MMDC_CH0_AXI 140 -#define IMX6QDL_CLK_MMDC_CH1_AXI 141 -#define IMX6QDL_CLK_OCRAM 142 -#define IMX6QDL_CLK_OPENVG_AXI 143 -#define IMX6QDL_CLK_PCIE_AXI 144 -#define IMX6QDL_CLK_PWM1 145 -#define IMX6QDL_CLK_PWM2 146 -#define IMX6QDL_CLK_PWM3 147 -#define IMX6QDL_CLK_PWM4 148 -#define IMX6QDL_CLK_PER1_BCH 149 -#define IMX6QDL_CLK_GPMI_BCH_APB 150 -#define IMX6QDL_CLK_GPMI_BCH 151 -#define IMX6QDL_CLK_GPMI_IO 152 -#define IMX6QDL_CLK_GPMI_APB 153 -#define IMX6QDL_CLK_SATA 154 -#define IMX6QDL_CLK_SDMA 155 -#define IMX6QDL_CLK_SPBA 156 -#define IMX6QDL_CLK_SSI1 157 -#define IMX6QDL_CLK_SSI2 158 -#define IMX6QDL_CLK_SSI3 159 -#define IMX6QDL_CLK_UART_IPG 160 -#define IMX6QDL_CLK_UART_SERIAL 161 -#define IMX6QDL_CLK_USBOH3 162 -#define IMX6QDL_CLK_USDHC1 163 -#define IMX6QDL_CLK_USDHC2 164 -#define IMX6QDL_CLK_USDHC3 165 -#define IMX6QDL_CLK_USDHC4 166 -#define IMX6QDL_CLK_VDO_AXI 167 -#define IMX6QDL_CLK_VPU_AXI 168 -#define IMX6QDL_CLK_CKO1 169 -#define IMX6QDL_CLK_PLL1_SYS 170 -#define IMX6QDL_CLK_PLL2_BUS 171 -#define IMX6QDL_CLK_PLL3_USB_OTG 172 -#define IMX6QDL_CLK_PLL4_AUDIO 173 -#define IMX6QDL_CLK_PLL5_VIDEO 174 -#define IMX6QDL_CLK_PLL8_MLB 175 -#define IMX6QDL_CLK_PLL7_USB_HOST 176 -#define IMX6QDL_CLK_PLL6_ENET 177 -#define IMX6QDL_CLK_SSI1_IPG 178 -#define IMX6QDL_CLK_SSI2_IPG 179 -#define IMX6QDL_CLK_SSI3_IPG 180 -#define IMX6QDL_CLK_ROM 181 -#define IMX6QDL_CLK_USBPHY1 182 -#define IMX6QDL_CLK_USBPHY2 183 -#define IMX6QDL_CLK_LDB_DI0_DIV_3_5 184 -#define IMX6QDL_CLK_LDB_DI1_DIV_3_5 185 -#define IMX6QDL_CLK_SATA_REF 186 -#define IMX6QDL_CLK_SATA_REF_100M 187 -#define IMX6QDL_CLK_PCIE_REF 188 -#define IMX6QDL_CLK_PCIE_REF_125M 189 -#define IMX6QDL_CLK_ENET_REF 190 -#define IMX6QDL_CLK_USBPHY1_GATE 191 -#define IMX6QDL_CLK_USBPHY2_GATE 192 -#define IMX6QDL_CLK_PLL4_POST_DIV 193 -#define IMX6QDL_CLK_PLL5_POST_DIV 194 -#define IMX6QDL_CLK_PLL5_VIDEO_DIV 195 -#define IMX6QDL_CLK_EIM_SLOW 196 -#define IMX6QDL_CLK_SPDIF 197 -#define IMX6QDL_CLK_CKO2_SEL 198 -#define IMX6QDL_CLK_CKO2_PODF 199 -#define IMX6QDL_CLK_CKO2 200 -#define IMX6QDL_CLK_CKO 201 -#define IMX6QDL_CLK_VDOA 202 -#define IMX6QDL_CLK_PLL4_AUDIO_DIV 203 -#define IMX6QDL_CLK_LVDS1_SEL 204 -#define IMX6QDL_CLK_LVDS2_SEL 205 -#define IMX6QDL_CLK_LVDS1_GATE 206 -#define IMX6QDL_CLK_LVDS2_GATE 207 -#define IMX6QDL_CLK_ESAI_IPG 208 -#define IMX6QDL_CLK_ESAI_MEM 209 -#define IMX6QDL_CLK_ASRC_IPG 210 -#define IMX6QDL_CLK_ASRC_MEM 211 -#define IMX6QDL_CLK_LVDS1_IN 212 -#define IMX6QDL_CLK_LVDS2_IN 213 -#define IMX6QDL_CLK_ANACLK1 214 -#define IMX6QDL_CLK_ANACLK2 215 -#define IMX6QDL_PLL1_BYPASS_SRC 216 -#define IMX6QDL_PLL2_BYPASS_SRC 217 -#define IMX6QDL_PLL3_BYPASS_SRC 218 -#define IMX6QDL_PLL4_BYPASS_SRC 219 -#define IMX6QDL_PLL5_BYPASS_SRC 220 -#define IMX6QDL_PLL6_BYPASS_SRC 221 -#define IMX6QDL_PLL7_BYPASS_SRC 222 -#define IMX6QDL_CLK_PLL1 223 -#define IMX6QDL_CLK_PLL2 224 -#define IMX6QDL_CLK_PLL3 225 -#define IMX6QDL_CLK_PLL4 226 -#define IMX6QDL_CLK_PLL5 227 -#define IMX6QDL_CLK_PLL6 228 -#define IMX6QDL_CLK_PLL7 229 -#define IMX6QDL_PLL1_BYPASS 230 -#define IMX6QDL_PLL2_BYPASS 231 -#define IMX6QDL_PLL3_BYPASS 232 -#define IMX6QDL_PLL4_BYPASS 233 -#define IMX6QDL_PLL5_BYPASS 234 -#define IMX6QDL_PLL6_BYPASS 235 -#define IMX6QDL_PLL7_BYPASS 236 -#define IMX6QDL_CLK_GPT_3M 237 -#define IMX6QDL_CLK_VIDEO_27M 238 -#define IMX6QDL_CLK_MIPI_CORE_CFG 239 -#define IMX6QDL_CLK_MIPI_IPG 240 -#define IMX6QDL_CLK_CAAM_MEM 241 -#define IMX6QDL_CLK_CAAM_ACLK 242 -#define IMX6QDL_CLK_CAAM_IPG 243 -#define IMX6QDL_CLK_SPDIF_GCLK 244 -#define IMX6QDL_CLK_UART_SEL 245 -#define IMX6QDL_CLK_IPG_PER_SEL 246 -#define IMX6QDL_CLK_ECSPI_SEL 247 -#define IMX6QDL_CLK_CAN_SEL 248 -#define IMX6QDL_CLK_MMDC_CH1_AXI_CG 249 -#define IMX6QDL_CLK_PRE0 250 -#define IMX6QDL_CLK_PRE1 251 -#define IMX6QDL_CLK_PRE2 252 -#define IMX6QDL_CLK_PRE3 253 -#define IMX6QDL_CLK_PRG0_AXI 254 -#define IMX6QDL_CLK_PRG1_AXI 255 -#define IMX6QDL_CLK_PRG0_APB 256 -#define IMX6QDL_CLK_PRG1_APB 257 -#define IMX6QDL_CLK_PRE_AXI 258 -#define IMX6QDL_CLK_MLB_SEL 259 -#define IMX6QDL_CLK_MLB_PODF 260 -#define IMX6QDL_CLK_EPIT1 261 -#define IMX6QDL_CLK_EPIT2 262 -#define IMX6QDL_CLK_MMDC_P0_IPG 263 -#define IMX6QDL_CLK_DCIC1 264 -#define IMX6QDL_CLK_DCIC2 265 -#define IMX6QDL_CLK_END 266 - -#endif /* __DT_BINDINGS_CLOCK_IMX6QDL_H */ diff --git a/include/dt-bindings/clock/imx6sl-clock.h b/include/dt-bindings/clock/imx6sl-clock.h deleted file mode 100644 index 31364d2caae6..000000000000 --- a/include/dt-bindings/clock/imx6sl-clock.h +++ /dev/null @@ -1,178 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX6SL_H -#define __DT_BINDINGS_CLOCK_IMX6SL_H - -#define IMX6SL_CLK_DUMMY 0 -#define IMX6SL_CLK_CKIL 1 -#define IMX6SL_CLK_OSC 2 -#define IMX6SL_CLK_PLL1_SYS 3 -#define IMX6SL_CLK_PLL2_BUS 4 -#define IMX6SL_CLK_PLL3_USB_OTG 5 -#define IMX6SL_CLK_PLL4_AUDIO 6 -#define IMX6SL_CLK_PLL5_VIDEO 7 -#define IMX6SL_CLK_PLL6_ENET 8 -#define IMX6SL_CLK_PLL7_USB_HOST 9 -#define IMX6SL_CLK_USBPHY1 10 -#define IMX6SL_CLK_USBPHY2 11 -#define IMX6SL_CLK_USBPHY1_GATE 12 -#define IMX6SL_CLK_USBPHY2_GATE 13 -#define IMX6SL_CLK_PLL4_POST_DIV 14 -#define IMX6SL_CLK_PLL5_POST_DIV 15 -#define IMX6SL_CLK_PLL5_VIDEO_DIV 16 -#define IMX6SL_CLK_ENET_REF 17 -#define IMX6SL_CLK_PLL2_PFD0 18 -#define IMX6SL_CLK_PLL2_PFD1 19 -#define IMX6SL_CLK_PLL2_PFD2 20 -#define IMX6SL_CLK_PLL3_PFD0 21 -#define IMX6SL_CLK_PLL3_PFD1 22 -#define IMX6SL_CLK_PLL3_PFD2 23 -#define IMX6SL_CLK_PLL3_PFD3 24 -#define IMX6SL_CLK_PLL2_198M 25 -#define IMX6SL_CLK_PLL3_120M 26 -#define IMX6SL_CLK_PLL3_80M 27 -#define IMX6SL_CLK_PLL3_60M 28 -#define IMX6SL_CLK_STEP 29 -#define IMX6SL_CLK_PLL1_SW 30 -#define IMX6SL_CLK_OCRAM_ALT_SEL 31 -#define IMX6SL_CLK_OCRAM_SEL 32 -#define IMX6SL_CLK_PRE_PERIPH2_SEL 33 -#define IMX6SL_CLK_PRE_PERIPH_SEL 34 -#define IMX6SL_CLK_PERIPH2_CLK2_SEL 35 -#define IMX6SL_CLK_PERIPH_CLK2_SEL 36 -#define IMX6SL_CLK_CSI_SEL 37 -#define IMX6SL_CLK_LCDIF_AXI_SEL 38 -#define IMX6SL_CLK_USDHC1_SEL 39 -#define IMX6SL_CLK_USDHC2_SEL 40 -#define IMX6SL_CLK_USDHC3_SEL 41 -#define IMX6SL_CLK_USDHC4_SEL 42 -#define IMX6SL_CLK_SSI1_SEL 43 -#define IMX6SL_CLK_SSI2_SEL 44 -#define IMX6SL_CLK_SSI3_SEL 45 -#define IMX6SL_CLK_PERCLK_SEL 46 -#define IMX6SL_CLK_PXP_AXI_SEL 47 -#define IMX6SL_CLK_EPDC_AXI_SEL 48 -#define IMX6SL_CLK_GPU2D_OVG_SEL 49 -#define IMX6SL_CLK_GPU2D_SEL 50 -#define IMX6SL_CLK_LCDIF_PIX_SEL 51 -#define IMX6SL_CLK_EPDC_PIX_SEL 52 -#define IMX6SL_CLK_SPDIF0_SEL 53 -#define IMX6SL_CLK_SPDIF1_SEL 54 -#define IMX6SL_CLK_EXTERN_AUDIO_SEL 55 -#define IMX6SL_CLK_ECSPI_SEL 56 -#define IMX6SL_CLK_UART_SEL 57 -#define IMX6SL_CLK_PERIPH 58 -#define IMX6SL_CLK_PERIPH2 59 -#define IMX6SL_CLK_OCRAM_PODF 60 -#define IMX6SL_CLK_PERIPH_CLK2_PODF 61 -#define IMX6SL_CLK_PERIPH2_CLK2_PODF 62 -#define IMX6SL_CLK_IPG 63 -#define IMX6SL_CLK_CSI_PODF 64 -#define IMX6SL_CLK_LCDIF_AXI_PODF 65 -#define IMX6SL_CLK_USDHC1_PODF 66 -#define IMX6SL_CLK_USDHC2_PODF 67 -#define IMX6SL_CLK_USDHC3_PODF 68 -#define IMX6SL_CLK_USDHC4_PODF 69 -#define IMX6SL_CLK_SSI1_PRED 70 -#define IMX6SL_CLK_SSI1_PODF 71 -#define IMX6SL_CLK_SSI2_PRED 72 -#define IMX6SL_CLK_SSI2_PODF 73 -#define IMX6SL_CLK_SSI3_PRED 74 -#define IMX6SL_CLK_SSI3_PODF 75 -#define IMX6SL_CLK_PERCLK 76 -#define IMX6SL_CLK_PXP_AXI_PODF 77 -#define IMX6SL_CLK_EPDC_AXI_PODF 78 -#define IMX6SL_CLK_GPU2D_OVG_PODF 79 -#define IMX6SL_CLK_GPU2D_PODF 80 -#define IMX6SL_CLK_LCDIF_PIX_PRED 81 -#define IMX6SL_CLK_EPDC_PIX_PRED 82 -#define IMX6SL_CLK_LCDIF_PIX_PODF 83 -#define IMX6SL_CLK_EPDC_PIX_PODF 84 -#define IMX6SL_CLK_SPDIF0_PRED 85 -#define IMX6SL_CLK_SPDIF0_PODF 86 -#define IMX6SL_CLK_SPDIF1_PRED 87 -#define IMX6SL_CLK_SPDIF1_PODF 88 -#define IMX6SL_CLK_EXTERN_AUDIO_PRED 89 -#define IMX6SL_CLK_EXTERN_AUDIO_PODF 90 -#define IMX6SL_CLK_ECSPI_ROOT 91 -#define IMX6SL_CLK_UART_ROOT 92 -#define IMX6SL_CLK_AHB 93 -#define IMX6SL_CLK_MMDC_ROOT 94 -#define IMX6SL_CLK_ARM 95 -#define IMX6SL_CLK_ECSPI1 96 -#define IMX6SL_CLK_ECSPI2 97 -#define IMX6SL_CLK_ECSPI3 98 -#define IMX6SL_CLK_ECSPI4 99 -#define IMX6SL_CLK_EPIT1 100 -#define IMX6SL_CLK_EPIT2 101 -#define IMX6SL_CLK_EXTERN_AUDIO 102 -#define IMX6SL_CLK_GPT 103 -#define IMX6SL_CLK_GPT_SERIAL 104 -#define IMX6SL_CLK_GPU2D_OVG 105 -#define IMX6SL_CLK_I2C1 106 -#define IMX6SL_CLK_I2C2 107 -#define IMX6SL_CLK_I2C3 108 -#define IMX6SL_CLK_OCOTP 109 -#define IMX6SL_CLK_CSI 110 -#define IMX6SL_CLK_PXP_AXI 111 -#define IMX6SL_CLK_EPDC_AXI 112 -#define IMX6SL_CLK_LCDIF_AXI 113 -#define IMX6SL_CLK_LCDIF_PIX 114 -#define IMX6SL_CLK_EPDC_PIX 115 -#define IMX6SL_CLK_OCRAM 116 -#define IMX6SL_CLK_PWM1 117 -#define IMX6SL_CLK_PWM2 118 -#define IMX6SL_CLK_PWM3 119 -#define IMX6SL_CLK_PWM4 120 -#define IMX6SL_CLK_SDMA 121 -#define IMX6SL_CLK_SPDIF 122 -#define IMX6SL_CLK_SSI1 123 -#define IMX6SL_CLK_SSI2 124 -#define IMX6SL_CLK_SSI3 125 -#define IMX6SL_CLK_UART 126 -#define IMX6SL_CLK_UART_SERIAL 127 -#define IMX6SL_CLK_USBOH3 128 -#define IMX6SL_CLK_USDHC1 129 -#define IMX6SL_CLK_USDHC2 130 -#define IMX6SL_CLK_USDHC3 131 -#define IMX6SL_CLK_USDHC4 132 -#define IMX6SL_CLK_PLL4_AUDIO_DIV 133 -#define IMX6SL_CLK_SPBA 134 -#define IMX6SL_CLK_ENET 135 -#define IMX6SL_CLK_LVDS1_SEL 136 -#define IMX6SL_CLK_LVDS1_OUT 137 -#define IMX6SL_CLK_LVDS1_IN 138 -#define IMX6SL_CLK_ANACLK1 139 -#define IMX6SL_PLL1_BYPASS_SRC 140 -#define IMX6SL_PLL2_BYPASS_SRC 141 -#define IMX6SL_PLL3_BYPASS_SRC 142 -#define IMX6SL_PLL4_BYPASS_SRC 143 -#define IMX6SL_PLL5_BYPASS_SRC 144 -#define IMX6SL_PLL6_BYPASS_SRC 145 -#define IMX6SL_PLL7_BYPASS_SRC 146 -#define IMX6SL_CLK_PLL1 147 -#define IMX6SL_CLK_PLL2 148 -#define IMX6SL_CLK_PLL3 149 -#define IMX6SL_CLK_PLL4 150 -#define IMX6SL_CLK_PLL5 151 -#define IMX6SL_CLK_PLL6 152 -#define IMX6SL_CLK_PLL7 153 -#define IMX6SL_PLL1_BYPASS 154 -#define IMX6SL_PLL2_BYPASS 155 -#define IMX6SL_PLL3_BYPASS 156 -#define IMX6SL_PLL4_BYPASS 157 -#define IMX6SL_PLL5_BYPASS 158 -#define IMX6SL_PLL6_BYPASS 159 -#define IMX6SL_PLL7_BYPASS 160 -#define IMX6SL_CLK_SSI1_IPG 161 -#define IMX6SL_CLK_SSI2_IPG 162 -#define IMX6SL_CLK_SSI3_IPG 163 -#define IMX6SL_CLK_SPDIF_GCLK 164 -#define IMX6SL_CLK_MMDC_P0_IPG 165 -#define IMX6SL_CLK_MMDC_P1_IPG 166 -#define IMX6SL_CLK_END 167 - -#endif /* __DT_BINDINGS_CLOCK_IMX6SL_H */ diff --git a/include/dt-bindings/clock/imx6sll-clock.h b/include/dt-bindings/clock/imx6sll-clock.h deleted file mode 100644 index 494fd0c37fb5..000000000000 --- a/include/dt-bindings/clock/imx6sll-clock.h +++ /dev/null @@ -1,210 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2016 Freescale Semiconductor, Inc. - * Copyright 2017-2018 NXP. - * - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX6SLL_H -#define __DT_BINDINGS_CLOCK_IMX6SLL_H - -#define IMX6SLL_CLK_DUMMY 0 -#define IMX6SLL_CLK_CKIL 1 -#define IMX6SLL_CLK_OSC 2 -#define IMX6SLL_PLL1_BYPASS_SRC 3 -#define IMX6SLL_PLL2_BYPASS_SRC 4 -#define IMX6SLL_PLL3_BYPASS_SRC 5 -#define IMX6SLL_PLL4_BYPASS_SRC 6 -#define IMX6SLL_PLL5_BYPASS_SRC 7 -#define IMX6SLL_PLL6_BYPASS_SRC 8 -#define IMX6SLL_PLL7_BYPASS_SRC 9 -#define IMX6SLL_CLK_PLL1 10 -#define IMX6SLL_CLK_PLL2 11 -#define IMX6SLL_CLK_PLL3 12 -#define IMX6SLL_CLK_PLL4 13 -#define IMX6SLL_CLK_PLL5 14 -#define IMX6SLL_CLK_PLL6 15 -#define IMX6SLL_CLK_PLL7 16 -#define IMX6SLL_PLL1_BYPASS 17 -#define IMX6SLL_PLL2_BYPASS 18 -#define IMX6SLL_PLL3_BYPASS 19 -#define IMX6SLL_PLL4_BYPASS 20 -#define IMX6SLL_PLL5_BYPASS 21 -#define IMX6SLL_PLL6_BYPASS 22 -#define IMX6SLL_PLL7_BYPASS 23 -#define IMX6SLL_CLK_PLL1_SYS 24 -#define IMX6SLL_CLK_PLL2_BUS 25 -#define IMX6SLL_CLK_PLL3_USB_OTG 26 -#define IMX6SLL_CLK_PLL4_AUDIO 27 -#define IMX6SLL_CLK_PLL5_VIDEO 28 -#define IMX6SLL_CLK_PLL6_ENET 29 -#define IMX6SLL_CLK_PLL7_USB_HOST 30 -#define IMX6SLL_CLK_USBPHY1 31 -#define IMX6SLL_CLK_USBPHY2 32 -#define IMX6SLL_CLK_USBPHY1_GATE 33 -#define IMX6SLL_CLK_USBPHY2_GATE 34 -#define IMX6SLL_CLK_PLL2_PFD0 35 -#define IMX6SLL_CLK_PLL2_PFD1 36 -#define IMX6SLL_CLK_PLL2_PFD2 37 -#define IMX6SLL_CLK_PLL2_PFD3 38 -#define IMX6SLL_CLK_PLL3_PFD0 39 -#define IMX6SLL_CLK_PLL3_PFD1 40 -#define IMX6SLL_CLK_PLL3_PFD2 41 -#define IMX6SLL_CLK_PLL3_PFD3 42 -#define IMX6SLL_CLK_PLL4_POST_DIV 43 -#define IMX6SLL_CLK_PLL4_AUDIO_DIV 44 -#define IMX6SLL_CLK_PLL5_POST_DIV 45 -#define IMX6SLL_CLK_PLL5_VIDEO_DIV 46 -#define IMX6SLL_CLK_PLL2_198M 47 -#define IMX6SLL_CLK_PLL3_120M 48 -#define IMX6SLL_CLK_PLL3_80M 49 -#define IMX6SLL_CLK_PLL3_60M 50 -#define IMX6SLL_CLK_STEP 51 -#define IMX6SLL_CLK_PLL1_SW 52 -#define IMX6SLL_CLK_AXI_ALT_SEL 53 -#define IMX6SLL_CLK_AXI_SEL 54 -#define IMX6SLL_CLK_PERIPH_PRE 55 -#define IMX6SLL_CLK_PERIPH2_PRE 56 -#define IMX6SLL_CLK_PERIPH_CLK2_SEL 57 -#define IMX6SLL_CLK_PERIPH2_CLK2_SEL 58 -#define IMX6SLL_CLK_PERCLK_SEL 59 -#define IMX6SLL_CLK_USDHC1_SEL 60 -#define IMX6SLL_CLK_USDHC2_SEL 61 -#define IMX6SLL_CLK_USDHC3_SEL 62 -#define IMX6SLL_CLK_SSI1_SEL 63 -#define IMX6SLL_CLK_SSI2_SEL 64 -#define IMX6SLL_CLK_SSI3_SEL 65 -#define IMX6SLL_CLK_PXP_SEL 66 -#define IMX6SLL_CLK_LCDIF_PRE_SEL 67 -#define IMX6SLL_CLK_LCDIF_SEL 68 -#define IMX6SLL_CLK_EPDC_PRE_SEL 69 -#define IMX6SLL_CLK_SPDIF_SEL 70 -#define IMX6SLL_CLK_ECSPI_SEL 71 -#define IMX6SLL_CLK_UART_SEL 72 -#define IMX6SLL_CLK_ARM 73 -#define IMX6SLL_CLK_PERIPH 74 -#define IMX6SLL_CLK_PERIPH2 75 -#define IMX6SLL_CLK_PERIPH2_CLK2 76 -#define IMX6SLL_CLK_PERIPH_CLK2 77 -#define IMX6SLL_CLK_MMDC_PODF 78 -#define IMX6SLL_CLK_AXI_PODF 79 -#define IMX6SLL_CLK_AHB 80 -#define IMX6SLL_CLK_IPG 81 -#define IMX6SLL_CLK_PERCLK 82 -#define IMX6SLL_CLK_USDHC1_PODF 83 -#define IMX6SLL_CLK_USDHC2_PODF 84 -#define IMX6SLL_CLK_USDHC3_PODF 85 -#define IMX6SLL_CLK_SSI1_PRED 86 -#define IMX6SLL_CLK_SSI2_PRED 87 -#define IMX6SLL_CLK_SSI3_PRED 88 -#define IMX6SLL_CLK_SSI1_PODF 89 -#define IMX6SLL_CLK_SSI2_PODF 90 -#define IMX6SLL_CLK_SSI3_PODF 91 -#define IMX6SLL_CLK_PXP_PODF 92 -#define IMX6SLL_CLK_LCDIF_PRED 93 -#define IMX6SLL_CLK_LCDIF_PODF 94 -#define IMX6SLL_CLK_EPDC_SEL 95 -#define IMX6SLL_CLK_EPDC_PODF 96 -#define IMX6SLL_CLK_SPDIF_PRED 97 -#define IMX6SLL_CLK_SPDIF_PODF 98 -#define IMX6SLL_CLK_ECSPI_PODF 99 -#define IMX6SLL_CLK_UART_PODF 100 - -/* CCGR 0 */ -#define IMX6SLL_CLK_AIPSTZ1 101 -#define IMX6SLL_CLK_AIPSTZ2 102 -#define IMX6SLL_CLK_DCP 103 -#define IMX6SLL_CLK_UART2_IPG 104 -#define IMX6SLL_CLK_UART2_SERIAL 105 - -/* CCGR 1 */ -#define IMX6SLL_CLK_ECSPI1 106 -#define IMX6SLL_CLK_ECSPI2 107 -#define IMX6SLL_CLK_ECSPI3 108 -#define IMX6SLL_CLK_ECSPI4 109 -#define IMX6SLL_CLK_UART3_IPG 110 -#define IMX6SLL_CLK_UART3_SERIAL 111 -#define IMX6SLL_CLK_UART4_IPG 112 -#define IMX6SLL_CLK_UART4_SERIAL 113 -#define IMX6SLL_CLK_EPIT1 114 -#define IMX6SLL_CLK_EPIT2 115 -#define IMX6SLL_CLK_GPT_BUS 116 -#define IMX6SLL_CLK_GPT_SERIAL 117 - -/* CCGR2 */ -#define IMX6SLL_CLK_CSI 118 -#define IMX6SLL_CLK_I2C1 119 -#define IMX6SLL_CLK_I2C2 120 -#define IMX6SLL_CLK_I2C3 121 -#define IMX6SLL_CLK_OCOTP 122 -#define IMX6SLL_CLK_LCDIF_APB 123 -#define IMX6SLL_CLK_PXP 124 - -/* CCGR3 */ -#define IMX6SLL_CLK_UART5_IPG 125 -#define IMX6SLL_CLK_UART5_SERIAL 126 -#define IMX6SLL_CLK_EPDC_AXI 127 -#define IMX6SLL_CLK_EPDC_PIX 128 -#define IMX6SLL_CLK_LCDIF_PIX 129 -#define IMX6SLL_CLK_WDOG1 130 -#define IMX6SLL_CLK_MMDC_P0_FAST 131 -#define IMX6SLL_CLK_MMDC_P0_IPG 132 -#define IMX6SLL_CLK_OCRAM 133 - -/* CCGR4 */ -#define IMX6SLL_CLK_PWM1 134 -#define IMX6SLL_CLK_PWM2 135 -#define IMX6SLL_CLK_PWM3 136 -#define IMX6SLL_CLK_PWM4 137 - -/* CCGR 5 */ -#define IMX6SLL_CLK_ROM 138 -#define IMX6SLL_CLK_SDMA 139 -#define IMX6SLL_CLK_KPP 140 -#define IMX6SLL_CLK_WDOG2 141 -#define IMX6SLL_CLK_SPBA 142 -#define IMX6SLL_CLK_SPDIF 143 -#define IMX6SLL_CLK_SPDIF_GCLK 144 -#define IMX6SLL_CLK_SSI1 145 -#define IMX6SLL_CLK_SSI1_IPG 146 -#define IMX6SLL_CLK_SSI2 147 -#define IMX6SLL_CLK_SSI2_IPG 148 -#define IMX6SLL_CLK_SSI3 149 -#define IMX6SLL_CLK_SSI3_IPG 150 -#define IMX6SLL_CLK_UART1_IPG 151 -#define IMX6SLL_CLK_UART1_SERIAL 152 - -/* CCGR 6 */ -#define IMX6SLL_CLK_USBOH3 153 -#define IMX6SLL_CLK_USDHC1 154 -#define IMX6SLL_CLK_USDHC2 155 -#define IMX6SLL_CLK_USDHC3 156 - -#define IMX6SLL_CLK_IPP_DI0 157 -#define IMX6SLL_CLK_IPP_DI1 158 -#define IMX6SLL_CLK_LDB_DI0_SEL 159 -#define IMX6SLL_CLK_LDB_DI0_DIV_3_5 160 -#define IMX6SLL_CLK_LDB_DI0_DIV_7 161 -#define IMX6SLL_CLK_LDB_DI0_DIV_SEL 162 -#define IMX6SLL_CLK_LDB_DI0 163 -#define IMX6SLL_CLK_LDB_DI1_SEL 164 -#define IMX6SLL_CLK_LDB_DI1_DIV_3_5 165 -#define IMX6SLL_CLK_LDB_DI1_DIV_7 166 -#define IMX6SLL_CLK_LDB_DI1_DIV_SEL 167 -#define IMX6SLL_CLK_LDB_DI1 168 -#define IMX6SLL_CLK_EXTERN_AUDIO_SEL 169 -#define IMX6SLL_CLK_EXTERN_AUDIO_PRED 170 -#define IMX6SLL_CLK_EXTERN_AUDIO_PODF 171 -#define IMX6SLL_CLK_EXTERN_AUDIO 172 - -#define IMX6SLL_CLK_GPIO1 173 -#define IMX6SLL_CLK_GPIO2 174 -#define IMX6SLL_CLK_GPIO3 175 -#define IMX6SLL_CLK_GPIO4 176 -#define IMX6SLL_CLK_GPIO5 177 -#define IMX6SLL_CLK_GPIO6 178 -#define IMX6SLL_CLK_MMDC_P1_IPG 179 - -#define IMX6SLL_CLK_END 180 - -#endif /* __DT_BINDINGS_CLOCK_IMX6SLL_H */ diff --git a/include/dt-bindings/clock/imx6sx-clock.h b/include/dt-bindings/clock/imx6sx-clock.h deleted file mode 100644 index 1c64997d6196..000000000000 --- a/include/dt-bindings/clock/imx6sx-clock.h +++ /dev/null @@ -1,281 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2014 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX6SX_H -#define __DT_BINDINGS_CLOCK_IMX6SX_H - -#define IMX6SX_CLK_DUMMY 0 -#define IMX6SX_CLK_CKIL 1 -#define IMX6SX_CLK_CKIH 2 -#define IMX6SX_CLK_OSC 3 -#define IMX6SX_CLK_PLL1_SYS 4 -#define IMX6SX_CLK_PLL2_BUS 5 -#define IMX6SX_CLK_PLL3_USB_OTG 6 -#define IMX6SX_CLK_PLL4_AUDIO 7 -#define IMX6SX_CLK_PLL5_VIDEO 8 -#define IMX6SX_CLK_PLL6_ENET 9 -#define IMX6SX_CLK_PLL7_USB_HOST 10 -#define IMX6SX_CLK_USBPHY1 11 -#define IMX6SX_CLK_USBPHY2 12 -#define IMX6SX_CLK_USBPHY1_GATE 13 -#define IMX6SX_CLK_USBPHY2_GATE 14 -#define IMX6SX_CLK_PCIE_REF 15 -#define IMX6SX_CLK_PCIE_REF_125M 16 -#define IMX6SX_CLK_ENET_REF 17 -#define IMX6SX_CLK_PLL2_PFD0 18 -#define IMX6SX_CLK_PLL2_PFD1 19 -#define IMX6SX_CLK_PLL2_PFD2 20 -#define IMX6SX_CLK_PLL2_PFD3 21 -#define IMX6SX_CLK_PLL3_PFD0 22 -#define IMX6SX_CLK_PLL3_PFD1 23 -#define IMX6SX_CLK_PLL3_PFD2 24 -#define IMX6SX_CLK_PLL3_PFD3 25 -#define IMX6SX_CLK_PLL2_198M 26 -#define IMX6SX_CLK_PLL3_120M 27 -#define IMX6SX_CLK_PLL3_80M 28 -#define IMX6SX_CLK_PLL3_60M 29 -#define IMX6SX_CLK_TWD 30 -#define IMX6SX_CLK_PLL4_POST_DIV 31 -#define IMX6SX_CLK_PLL4_AUDIO_DIV 32 -#define IMX6SX_CLK_PLL5_POST_DIV 33 -#define IMX6SX_CLK_PLL5_VIDEO_DIV 34 -#define IMX6SX_CLK_STEP 35 -#define IMX6SX_CLK_PLL1_SW 36 -#define IMX6SX_CLK_OCRAM_SEL 37 -#define IMX6SX_CLK_PERIPH_PRE 38 -#define IMX6SX_CLK_PERIPH2_PRE 39 -#define IMX6SX_CLK_PERIPH_CLK2_SEL 40 -#define IMX6SX_CLK_PERIPH2_CLK2_SEL 41 -#define IMX6SX_CLK_PCIE_AXI_SEL 42 -#define IMX6SX_CLK_GPU_AXI_SEL 43 -#define IMX6SX_CLK_GPU_CORE_SEL 44 -#define IMX6SX_CLK_EIM_SLOW_SEL 45 -#define IMX6SX_CLK_USDHC1_SEL 46 -#define IMX6SX_CLK_USDHC2_SEL 47 -#define IMX6SX_CLK_USDHC3_SEL 48 -#define IMX6SX_CLK_USDHC4_SEL 49 -#define IMX6SX_CLK_SSI1_SEL 50 -#define IMX6SX_CLK_SSI2_SEL 51 -#define IMX6SX_CLK_SSI3_SEL 52 -#define IMX6SX_CLK_QSPI1_SEL 53 -#define IMX6SX_CLK_PERCLK_SEL 54 -#define IMX6SX_CLK_VID_SEL 55 -#define IMX6SX_CLK_ESAI_SEL 56 -#define IMX6SX_CLK_LDB_DI0_DIV_SEL 57 -#define IMX6SX_CLK_LDB_DI1_DIV_SEL 58 -#define IMX6SX_CLK_CAN_SEL 59 -#define IMX6SX_CLK_UART_SEL 60 -#define IMX6SX_CLK_QSPI2_SEL 61 -#define IMX6SX_CLK_LDB_DI1_SEL 62 -#define IMX6SX_CLK_LDB_DI0_SEL 63 -#define IMX6SX_CLK_SPDIF_SEL 64 -#define IMX6SX_CLK_AUDIO_SEL 65 -#define IMX6SX_CLK_ENET_PRE_SEL 66 -#define IMX6SX_CLK_ENET_SEL 67 -#define IMX6SX_CLK_M4_PRE_SEL 68 -#define IMX6SX_CLK_M4_SEL 69 -#define IMX6SX_CLK_ECSPI_SEL 70 -#define IMX6SX_CLK_LCDIF1_PRE_SEL 71 -#define IMX6SX_CLK_LCDIF2_PRE_SEL 72 -#define IMX6SX_CLK_LCDIF1_SEL 73 -#define IMX6SX_CLK_LCDIF2_SEL 74 -#define IMX6SX_CLK_DISPLAY_SEL 75 -#define IMX6SX_CLK_CSI_SEL 76 -#define IMX6SX_CLK_CKO1_SEL 77 -#define IMX6SX_CLK_CKO2_SEL 78 -#define IMX6SX_CLK_CKO 79 -#define IMX6SX_CLK_PERIPH_CLK2 80 -#define IMX6SX_CLK_PERIPH2_CLK2 81 -#define IMX6SX_CLK_IPG 82 -#define IMX6SX_CLK_GPU_CORE_PODF 83 -#define IMX6SX_CLK_GPU_AXI_PODF 84 -#define IMX6SX_CLK_LCDIF1_PODF 85 -#define IMX6SX_CLK_QSPI1_PODF 86 -#define IMX6SX_CLK_EIM_SLOW_PODF 87 -#define IMX6SX_CLK_LCDIF2_PODF 88 -#define IMX6SX_CLK_PERCLK 89 -#define IMX6SX_CLK_VID_PODF 90 -#define IMX6SX_CLK_CAN_PODF 91 -#define IMX6SX_CLK_USDHC1_PODF 92 -#define IMX6SX_CLK_USDHC2_PODF 93 -#define IMX6SX_CLK_USDHC3_PODF 94 -#define IMX6SX_CLK_USDHC4_PODF 95 -#define IMX6SX_CLK_UART_PODF 96 -#define IMX6SX_CLK_ESAI_PRED 97 -#define IMX6SX_CLK_ESAI_PODF 98 -#define IMX6SX_CLK_SSI3_PRED 99 -#define IMX6SX_CLK_SSI3_PODF 100 -#define IMX6SX_CLK_SSI1_PRED 101 -#define IMX6SX_CLK_SSI1_PODF 102 -#define IMX6SX_CLK_QSPI2_PRED 103 -#define IMX6SX_CLK_QSPI2_PODF 104 -#define IMX6SX_CLK_SSI2_PRED 105 -#define IMX6SX_CLK_SSI2_PODF 106 -#define IMX6SX_CLK_SPDIF_PRED 107 -#define IMX6SX_CLK_SPDIF_PODF 108 -#define IMX6SX_CLK_AUDIO_PRED 109 -#define IMX6SX_CLK_AUDIO_PODF 110 -#define IMX6SX_CLK_ENET_PODF 111 -#define IMX6SX_CLK_M4_PODF 112 -#define IMX6SX_CLK_ECSPI_PODF 113 -#define IMX6SX_CLK_LCDIF1_PRED 114 -#define IMX6SX_CLK_LCDIF2_PRED 115 -#define IMX6SX_CLK_DISPLAY_PODF 116 -#define IMX6SX_CLK_CSI_PODF 117 -#define IMX6SX_CLK_LDB_DI0_DIV_3_5 118 -#define IMX6SX_CLK_LDB_DI0_DIV_7 119 -#define IMX6SX_CLK_LDB_DI1_DIV_3_5 120 -#define IMX6SX_CLK_LDB_DI1_DIV_7 121 -#define IMX6SX_CLK_CKO1_PODF 122 -#define IMX6SX_CLK_CKO2_PODF 123 -#define IMX6SX_CLK_PERIPH 124 -#define IMX6SX_CLK_PERIPH2 125 -#define IMX6SX_CLK_OCRAM 126 -#define IMX6SX_CLK_AHB 127 -#define IMX6SX_CLK_MMDC_PODF 128 -#define IMX6SX_CLK_ARM 129 -#define IMX6SX_CLK_AIPS_TZ1 130 -#define IMX6SX_CLK_AIPS_TZ2 131 -#define IMX6SX_CLK_APBH_DMA 132 -#define IMX6SX_CLK_ASRC_GATE 133 -#define IMX6SX_CLK_CAAM_MEM 134 -#define IMX6SX_CLK_CAAM_ACLK 135 -#define IMX6SX_CLK_CAAM_IPG 136 -#define IMX6SX_CLK_CAN1_IPG 137 -#define IMX6SX_CLK_CAN1_SERIAL 138 -#define IMX6SX_CLK_CAN2_IPG 139 -#define IMX6SX_CLK_CAN2_SERIAL 140 -#define IMX6SX_CLK_CPU_DEBUG 141 -#define IMX6SX_CLK_DCIC1 142 -#define IMX6SX_CLK_DCIC2 143 -#define IMX6SX_CLK_AIPS_TZ3 144 -#define IMX6SX_CLK_ECSPI1 145 -#define IMX6SX_CLK_ECSPI2 146 -#define IMX6SX_CLK_ECSPI3 147 -#define IMX6SX_CLK_ECSPI4 148 -#define IMX6SX_CLK_ECSPI5 149 -#define IMX6SX_CLK_EPIT1 150 -#define IMX6SX_CLK_EPIT2 151 -#define IMX6SX_CLK_ESAI_EXTAL 152 -#define IMX6SX_CLK_WAKEUP 153 -#define IMX6SX_CLK_GPT_BUS 154 -#define IMX6SX_CLK_GPT_SERIAL 155 -#define IMX6SX_CLK_GPU 156 -#define IMX6SX_CLK_OCRAM_S 157 -#define IMX6SX_CLK_CANFD 158 -#define IMX6SX_CLK_CSI 159 -#define IMX6SX_CLK_I2C1 160 -#define IMX6SX_CLK_I2C2 161 -#define IMX6SX_CLK_I2C3 162 -#define IMX6SX_CLK_OCOTP 163 -#define IMX6SX_CLK_IOMUXC 164 -#define IMX6SX_CLK_IPMUX1 165 -#define IMX6SX_CLK_IPMUX2 166 -#define IMX6SX_CLK_IPMUX3 167 -#define IMX6SX_CLK_TZASC1 168 -#define IMX6SX_CLK_LCDIF_APB 169 -#define IMX6SX_CLK_PXP_AXI 170 -#define IMX6SX_CLK_M4 171 -#define IMX6SX_CLK_ENET 172 -#define IMX6SX_CLK_DISPLAY_AXI 173 -#define IMX6SX_CLK_LCDIF2_PIX 174 -#define IMX6SX_CLK_LCDIF1_PIX 175 -#define IMX6SX_CLK_LDB_DI0 176 -#define IMX6SX_CLK_QSPI1 177 -#define IMX6SX_CLK_MLB 178 -#define IMX6SX_CLK_MMDC_P0_FAST 179 -#define IMX6SX_CLK_MMDC_P0_IPG 180 -#define IMX6SX_CLK_AXI 181 -#define IMX6SX_CLK_PCIE_AXI 182 -#define IMX6SX_CLK_QSPI2 183 -#define IMX6SX_CLK_PER1_BCH 184 -#define IMX6SX_CLK_PER2_MAIN 185 -#define IMX6SX_CLK_PWM1 186 -#define IMX6SX_CLK_PWM2 187 -#define IMX6SX_CLK_PWM3 188 -#define IMX6SX_CLK_PWM4 189 -#define IMX6SX_CLK_GPMI_BCH_APB 190 -#define IMX6SX_CLK_GPMI_BCH 191 -#define IMX6SX_CLK_GPMI_IO 192 -#define IMX6SX_CLK_GPMI_APB 193 -#define IMX6SX_CLK_ROM 194 -#define IMX6SX_CLK_SDMA 195 -#define IMX6SX_CLK_SPBA 196 -#define IMX6SX_CLK_SPDIF 197 -#define IMX6SX_CLK_SSI1_IPG 198 -#define IMX6SX_CLK_SSI2_IPG 199 -#define IMX6SX_CLK_SSI3_IPG 200 -#define IMX6SX_CLK_SSI1 201 -#define IMX6SX_CLK_SSI2 202 -#define IMX6SX_CLK_SSI3 203 -#define IMX6SX_CLK_UART_IPG 204 -#define IMX6SX_CLK_UART_SERIAL 205 -#define IMX6SX_CLK_SAI1 206 -#define IMX6SX_CLK_SAI2 207 -#define IMX6SX_CLK_USBOH3 208 -#define IMX6SX_CLK_USDHC1 209 -#define IMX6SX_CLK_USDHC2 210 -#define IMX6SX_CLK_USDHC3 211 -#define IMX6SX_CLK_USDHC4 212 -#define IMX6SX_CLK_EIM_SLOW 213 -#define IMX6SX_CLK_PWM8 214 -#define IMX6SX_CLK_VADC 215 -#define IMX6SX_CLK_GIS 216 -#define IMX6SX_CLK_I2C4 217 -#define IMX6SX_CLK_PWM5 218 -#define IMX6SX_CLK_PWM6 219 -#define IMX6SX_CLK_PWM7 220 -#define IMX6SX_CLK_CKO1 221 -#define IMX6SX_CLK_CKO2 222 -#define IMX6SX_CLK_IPP_DI0 223 -#define IMX6SX_CLK_IPP_DI1 224 -#define IMX6SX_CLK_ENET_AHB 225 -#define IMX6SX_CLK_OCRAM_PODF 226 -#define IMX6SX_CLK_GPT_3M 227 -#define IMX6SX_CLK_ENET_PTP 228 -#define IMX6SX_CLK_ENET_PTP_REF 229 -#define IMX6SX_CLK_ENET2_REF 230 -#define IMX6SX_CLK_ENET2_REF_125M 231 -#define IMX6SX_CLK_AUDIO 232 -#define IMX6SX_CLK_LVDS1_SEL 233 -#define IMX6SX_CLK_LVDS1_OUT 234 -#define IMX6SX_CLK_ASRC_IPG 235 -#define IMX6SX_CLK_ASRC_MEM 236 -#define IMX6SX_CLK_SAI1_IPG 237 -#define IMX6SX_CLK_SAI2_IPG 238 -#define IMX6SX_CLK_ESAI_IPG 239 -#define IMX6SX_CLK_ESAI_MEM 240 -#define IMX6SX_CLK_LVDS1_IN 241 -#define IMX6SX_CLK_ANACLK1 242 -#define IMX6SX_PLL1_BYPASS_SRC 243 -#define IMX6SX_PLL2_BYPASS_SRC 244 -#define IMX6SX_PLL3_BYPASS_SRC 245 -#define IMX6SX_PLL4_BYPASS_SRC 246 -#define IMX6SX_PLL5_BYPASS_SRC 247 -#define IMX6SX_PLL6_BYPASS_SRC 248 -#define IMX6SX_PLL7_BYPASS_SRC 249 -#define IMX6SX_CLK_PLL1 250 -#define IMX6SX_CLK_PLL2 251 -#define IMX6SX_CLK_PLL3 252 -#define IMX6SX_CLK_PLL4 253 -#define IMX6SX_CLK_PLL5 254 -#define IMX6SX_CLK_PLL6 255 -#define IMX6SX_CLK_PLL7 256 -#define IMX6SX_PLL1_BYPASS 257 -#define IMX6SX_PLL2_BYPASS 258 -#define IMX6SX_PLL3_BYPASS 259 -#define IMX6SX_PLL4_BYPASS 260 -#define IMX6SX_PLL5_BYPASS 261 -#define IMX6SX_PLL6_BYPASS 262 -#define IMX6SX_PLL7_BYPASS 263 -#define IMX6SX_CLK_SPDIF_GCLK 264 -#define IMX6SX_CLK_LVDS2_SEL 265 -#define IMX6SX_CLK_LVDS2_OUT 266 -#define IMX6SX_CLK_LVDS2_IN 267 -#define IMX6SX_CLK_ANACLK2 268 -#define IMX6SX_CLK_MMDC_P1_IPG 269 -#define IMX6SX_CLK_CLK_END 270 - -#endif /* __DT_BINDINGS_CLOCK_IMX6SX_H */ diff --git a/include/dt-bindings/clock/imx6ul-clock.h b/include/dt-bindings/clock/imx6ul-clock.h deleted file mode 100644 index 79094338e6f1..000000000000 --- a/include/dt-bindings/clock/imx6ul-clock.h +++ /dev/null @@ -1,262 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2015 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX6UL_H -#define __DT_BINDINGS_CLOCK_IMX6UL_H - -#define IMX6UL_CLK_DUMMY 0 -#define IMX6UL_CLK_CKIL 1 -#define IMX6UL_CLK_CKIH 2 -#define IMX6UL_CLK_OSC 3 -#define IMX6UL_PLL1_BYPASS_SRC 4 -#define IMX6UL_PLL2_BYPASS_SRC 5 -#define IMX6UL_PLL3_BYPASS_SRC 6 -#define IMX6UL_PLL4_BYPASS_SRC 7 -#define IMX6UL_PLL5_BYPASS_SRC 8 -#define IMX6UL_PLL6_BYPASS_SRC 9 -#define IMX6UL_PLL7_BYPASS_SRC 10 -#define IMX6UL_CLK_PLL1 11 -#define IMX6UL_CLK_PLL2 12 -#define IMX6UL_CLK_PLL3 13 -#define IMX6UL_CLK_PLL4 14 -#define IMX6UL_CLK_PLL5 15 -#define IMX6UL_CLK_PLL6 16 -#define IMX6UL_CLK_PLL7 17 -#define IMX6UL_PLL1_BYPASS 18 -#define IMX6UL_PLL2_BYPASS 19 -#define IMX6UL_PLL3_BYPASS 20 -#define IMX6UL_PLL4_BYPASS 21 -#define IMX6UL_PLL5_BYPASS 22 -#define IMX6UL_PLL6_BYPASS 23 -#define IMX6UL_PLL7_BYPASS 24 -#define IMX6UL_CLK_PLL1_SYS 25 -#define IMX6UL_CLK_PLL2_BUS 26 -#define IMX6UL_CLK_PLL3_USB_OTG 27 -#define IMX6UL_CLK_PLL4_AUDIO 28 -#define IMX6UL_CLK_PLL5_VIDEO 29 -#define IMX6UL_CLK_PLL6_ENET 30 -#define IMX6UL_CLK_PLL7_USB_HOST 31 -#define IMX6UL_CLK_USBPHY1 32 -#define IMX6UL_CLK_USBPHY2 33 -#define IMX6UL_CLK_USBPHY1_GATE 34 -#define IMX6UL_CLK_USBPHY2_GATE 35 -#define IMX6UL_CLK_PLL2_PFD0 36 -#define IMX6UL_CLK_PLL2_PFD1 37 -#define IMX6UL_CLK_PLL2_PFD2 38 -#define IMX6UL_CLK_PLL2_PFD3 39 -#define IMX6UL_CLK_PLL3_PFD0 40 -#define IMX6UL_CLK_PLL3_PFD1 41 -#define IMX6UL_CLK_PLL3_PFD2 42 -#define IMX6UL_CLK_PLL3_PFD3 43 -#define IMX6UL_CLK_ENET_REF 44 -#define IMX6UL_CLK_ENET2_REF 45 -#define IMX6UL_CLK_ENET2_REF_125M 46 -#define IMX6UL_CLK_ENET_PTP_REF 47 -#define IMX6UL_CLK_ENET_PTP 48 -#define IMX6UL_CLK_PLL4_POST_DIV 49 -#define IMX6UL_CLK_PLL4_AUDIO_DIV 50 -#define IMX6UL_CLK_PLL5_POST_DIV 51 -#define IMX6UL_CLK_PLL5_VIDEO_DIV 52 -#define IMX6UL_CLK_PLL2_198M 53 -#define IMX6UL_CLK_PLL3_80M 54 -#define IMX6UL_CLK_PLL3_60M 55 -#define IMX6UL_CLK_STEP 56 -#define IMX6UL_CLK_PLL1_SW 57 -#define IMX6UL_CLK_AXI_ALT_SEL 58 -#define IMX6UL_CLK_AXI_SEL 59 -#define IMX6UL_CLK_PERIPH_PRE 60 -#define IMX6UL_CLK_PERIPH2_PRE 61 -#define IMX6UL_CLK_PERIPH_CLK2_SEL 62 -#define IMX6UL_CLK_PERIPH2_CLK2_SEL 63 -#define IMX6UL_CLK_USDHC1_SEL 64 -#define IMX6UL_CLK_USDHC2_SEL 65 -#define IMX6UL_CLK_BCH_SEL 66 -#define IMX6UL_CLK_GPMI_SEL 67 -#define IMX6UL_CLK_EIM_SLOW_SEL 68 -#define IMX6UL_CLK_SPDIF_SEL 69 -#define IMX6UL_CLK_SAI1_SEL 70 -#define IMX6UL_CLK_SAI2_SEL 71 -#define IMX6UL_CLK_SAI3_SEL 72 -#define IMX6UL_CLK_LCDIF_PRE_SEL 73 -#define IMX6UL_CLK_SIM_PRE_SEL 74 -#define IMX6UL_CLK_LDB_DI0_SEL 75 -#define IMX6UL_CLK_LDB_DI1_SEL 76 -#define IMX6UL_CLK_ENFC_SEL 77 -#define IMX6UL_CLK_CAN_SEL 78 -#define IMX6UL_CLK_ECSPI_SEL 79 -#define IMX6UL_CLK_UART_SEL 80 -#define IMX6UL_CLK_QSPI1_SEL 81 -#define IMX6UL_CLK_PERCLK_SEL 82 -#define IMX6UL_CLK_LCDIF_SEL 83 -#define IMX6UL_CLK_SIM_SEL 84 -#define IMX6UL_CLK_PERIPH 85 -#define IMX6UL_CLK_PERIPH2 86 -#define IMX6UL_CLK_LDB_DI0_DIV_3_5 87 -#define IMX6UL_CLK_LDB_DI0_DIV_7 88 -#define IMX6UL_CLK_LDB_DI1_DIV_3_5 89 -#define IMX6UL_CLK_LDB_DI1_DIV_7 90 -#define IMX6UL_CLK_LDB_DI0_DIV_SEL 91 -#define IMX6UL_CLK_LDB_DI1_DIV_SEL 92 -#define IMX6UL_CLK_ARM 93 -#define IMX6UL_CLK_PERIPH_CLK2 94 -#define IMX6UL_CLK_PERIPH2_CLK2 95 -#define IMX6UL_CLK_AHB 96 -#define IMX6UL_CLK_MMDC_PODF 97 -#define IMX6UL_CLK_AXI_PODF 98 -#define IMX6UL_CLK_PERCLK 99 -#define IMX6UL_CLK_IPG 100 -#define IMX6UL_CLK_USDHC1_PODF 101 -#define IMX6UL_CLK_USDHC2_PODF 102 -#define IMX6UL_CLK_BCH_PODF 103 -#define IMX6UL_CLK_GPMI_PODF 104 -#define IMX6UL_CLK_EIM_SLOW_PODF 105 -#define IMX6UL_CLK_SPDIF_PRED 106 -#define IMX6UL_CLK_SPDIF_PODF 107 -#define IMX6UL_CLK_SAI1_PRED 108 -#define IMX6UL_CLK_SAI1_PODF 109 -#define IMX6UL_CLK_SAI2_PRED 110 -#define IMX6UL_CLK_SAI2_PODF 111 -#define IMX6UL_CLK_SAI3_PRED 112 -#define IMX6UL_CLK_SAI3_PODF 113 -#define IMX6UL_CLK_LCDIF_PRED 114 -#define IMX6UL_CLK_LCDIF_PODF 115 -#define IMX6UL_CLK_SIM_PODF 116 -#define IMX6UL_CLK_QSPI1_PDOF 117 -#define IMX6UL_CLK_ENFC_PRED 118 -#define IMX6UL_CLK_ENFC_PODF 119 -#define IMX6UL_CLK_CAN_PODF 120 -#define IMX6UL_CLK_ECSPI_PODF 121 -#define IMX6UL_CLK_UART_PODF 122 -#define IMX6UL_CLK_ADC1 123 -#define IMX6UL_CLK_ADC2 124 -#define IMX6UL_CLK_AIPSTZ1 125 -#define IMX6UL_CLK_AIPSTZ2 126 -#define IMX6UL_CLK_AIPSTZ3 127 -#define IMX6UL_CLK_APBHDMA 128 -#define IMX6UL_CLK_ASRC_IPG 129 -#define IMX6UL_CLK_ASRC_MEM 130 -#define IMX6UL_CLK_GPMI_BCH_APB 131 -#define IMX6UL_CLK_GPMI_BCH 132 -#define IMX6UL_CLK_GPMI_IO 133 -#define IMX6UL_CLK_GPMI_APB 134 -#define IMX6UL_CLK_CAAM_MEM 135 -#define IMX6UL_CLK_CAAM_ACLK 136 -#define IMX6UL_CLK_CAAM_IPG 137 -#define IMX6UL_CLK_CSI 138 -#define IMX6UL_CLK_ECSPI1 139 -#define IMX6UL_CLK_ECSPI2 140 -#define IMX6UL_CLK_ECSPI3 141 -#define IMX6UL_CLK_ECSPI4 142 -#define IMX6UL_CLK_EIM 143 -#define IMX6UL_CLK_ENET 144 -#define IMX6UL_CLK_ENET_AHB 145 -#define IMX6UL_CLK_EPIT1 146 -#define IMX6UL_CLK_EPIT2 147 -#define IMX6UL_CLK_CAN1_IPG 148 -#define IMX6UL_CLK_CAN1_SERIAL 149 -#define IMX6UL_CLK_CAN2_IPG 150 -#define IMX6UL_CLK_CAN2_SERIAL 151 -#define IMX6UL_CLK_GPT1_BUS 152 -#define IMX6UL_CLK_GPT1_SERIAL 153 -#define IMX6UL_CLK_GPT2_BUS 154 -#define IMX6UL_CLK_GPT2_SERIAL 155 -#define IMX6UL_CLK_I2C1 156 -#define IMX6UL_CLK_I2C2 157 -#define IMX6UL_CLK_I2C3 158 -#define IMX6UL_CLK_I2C4 159 -#define IMX6UL_CLK_IOMUXC 160 -#define IMX6UL_CLK_LCDIF_APB 161 -#define IMX6UL_CLK_LCDIF_PIX 162 -#define IMX6UL_CLK_MMDC_P0_FAST 163 -#define IMX6UL_CLK_MMDC_P0_IPG 164 -#define IMX6UL_CLK_OCOTP 165 -#define IMX6UL_CLK_OCRAM 166 -#define IMX6UL_CLK_PWM1 167 -#define IMX6UL_CLK_PWM2 168 -#define IMX6UL_CLK_PWM3 169 -#define IMX6UL_CLK_PWM4 170 -#define IMX6UL_CLK_PWM5 171 -#define IMX6UL_CLK_PWM6 172 -#define IMX6UL_CLK_PWM7 173 -#define IMX6UL_CLK_PWM8 174 -#define IMX6UL_CLK_PXP 175 -#define IMX6UL_CLK_QSPI 176 -#define IMX6UL_CLK_ROM 177 -#define IMX6UL_CLK_SAI1 178 -#define IMX6UL_CLK_SAI1_IPG 179 -#define IMX6UL_CLK_SAI2 180 -#define IMX6UL_CLK_SAI2_IPG 181 -#define IMX6UL_CLK_SAI3 182 -#define IMX6UL_CLK_SAI3_IPG 183 -#define IMX6UL_CLK_SDMA 184 -#define IMX6UL_CLK_SIM 185 -#define IMX6UL_CLK_SIM_S 186 -#define IMX6UL_CLK_SPBA 187 -#define IMX6UL_CLK_SPDIF 188 -#define IMX6UL_CLK_UART1_IPG 189 -#define IMX6UL_CLK_UART1_SERIAL 190 -#define IMX6UL_CLK_UART2_IPG 191 -#define IMX6UL_CLK_UART2_SERIAL 192 -#define IMX6UL_CLK_UART3_IPG 193 -#define IMX6UL_CLK_UART3_SERIAL 194 -#define IMX6UL_CLK_UART4_IPG 195 -#define IMX6UL_CLK_UART4_SERIAL 196 -#define IMX6UL_CLK_UART5_IPG 197 -#define IMX6UL_CLK_UART5_SERIAL 198 -#define IMX6UL_CLK_UART6_IPG 199 -#define IMX6UL_CLK_UART6_SERIAL 200 -#define IMX6UL_CLK_UART7_IPG 201 -#define IMX6UL_CLK_UART7_SERIAL 202 -#define IMX6UL_CLK_UART8_IPG 203 -#define IMX6UL_CLK_UART8_SERIAL 204 -#define IMX6UL_CLK_USBOH3 205 -#define IMX6UL_CLK_USDHC1 206 -#define IMX6UL_CLK_USDHC2 207 -#define IMX6UL_CLK_WDOG1 208 -#define IMX6UL_CLK_WDOG2 209 -#define IMX6UL_CLK_WDOG3 210 -#define IMX6UL_CLK_LDB_DI0 211 -#define IMX6UL_CLK_AXI 212 -#define IMX6UL_CLK_SPDIF_GCLK 213 -#define IMX6UL_CLK_GPT_3M 214 -#define IMX6UL_CLK_SIM2 215 -#define IMX6UL_CLK_SIM1 216 -#define IMX6UL_CLK_IPP_DI0 217 -#define IMX6UL_CLK_IPP_DI1 218 -#define IMX6UL_CA7_SECONDARY_SEL 219 -#define IMX6UL_CLK_PER_BCH 220 -#define IMX6UL_CLK_CSI_SEL 221 -#define IMX6UL_CLK_CSI_PODF 222 -#define IMX6UL_CLK_PLL3_120M 223 -#define IMX6UL_CLK_KPP 224 -#define IMX6ULL_CLK_ESAI_PRED 225 -#define IMX6ULL_CLK_ESAI_PODF 226 -#define IMX6ULL_CLK_ESAI_EXTAL 227 -#define IMX6ULL_CLK_ESAI_MEM 228 -#define IMX6ULL_CLK_ESAI_IPG 229 -#define IMX6ULL_CLK_DCP_CLK 230 -#define IMX6ULL_CLK_EPDC_PRE_SEL 231 -#define IMX6ULL_CLK_EPDC_SEL 232 -#define IMX6ULL_CLK_EPDC_PODF 233 -#define IMX6ULL_CLK_EPDC_ACLK 234 -#define IMX6ULL_CLK_EPDC_PIX 235 -#define IMX6ULL_CLK_ESAI_SEL 236 -#define IMX6UL_CLK_CKO1_SEL 237 -#define IMX6UL_CLK_CKO1_PODF 238 -#define IMX6UL_CLK_CKO1 239 -#define IMX6UL_CLK_CKO2_SEL 240 -#define IMX6UL_CLK_CKO2_PODF 241 -#define IMX6UL_CLK_CKO2 242 -#define IMX6UL_CLK_CKO 243 -#define IMX6UL_CLK_GPIO1 244 -#define IMX6UL_CLK_GPIO2 245 -#define IMX6UL_CLK_GPIO3 246 -#define IMX6UL_CLK_GPIO4 247 -#define IMX6UL_CLK_GPIO5 248 -#define IMX6UL_CLK_MMDC_P1_IPG 249 - -#define IMX6UL_CLK_END 250 - -#endif /* __DT_BINDINGS_CLOCK_IMX6UL_H */ diff --git a/include/dt-bindings/clock/imx7d-clock.h b/include/dt-bindings/clock/imx7d-clock.h deleted file mode 100644 index 1d4c0dfe0202..000000000000 --- a/include/dt-bindings/clock/imx7d-clock.h +++ /dev/null @@ -1,456 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX7D_H -#define __DT_BINDINGS_CLOCK_IMX7D_H - -#define IMX7D_OSC_24M_CLK 0 -#define IMX7D_PLL_ARM_MAIN 1 -#define IMX7D_PLL_ARM_MAIN_CLK 2 -#define IMX7D_PLL_ARM_MAIN_SRC 3 -#define IMX7D_PLL_ARM_MAIN_BYPASS 4 -#define IMX7D_PLL_SYS_MAIN 5 -#define IMX7D_PLL_SYS_MAIN_CLK 6 -#define IMX7D_PLL_SYS_MAIN_SRC 7 -#define IMX7D_PLL_SYS_MAIN_BYPASS 8 -#define IMX7D_PLL_SYS_MAIN_480M 9 -#define IMX7D_PLL_SYS_MAIN_240M 10 -#define IMX7D_PLL_SYS_MAIN_120M 11 -#define IMX7D_PLL_SYS_MAIN_480M_CLK 12 -#define IMX7D_PLL_SYS_MAIN_240M_CLK 13 -#define IMX7D_PLL_SYS_MAIN_120M_CLK 14 -#define IMX7D_PLL_SYS_PFD0_392M_CLK 15 -#define IMX7D_PLL_SYS_PFD0_196M 16 -#define IMX7D_PLL_SYS_PFD0_196M_CLK 17 -#define IMX7D_PLL_SYS_PFD1_332M_CLK 18 -#define IMX7D_PLL_SYS_PFD1_166M 19 -#define IMX7D_PLL_SYS_PFD1_166M_CLK 20 -#define IMX7D_PLL_SYS_PFD2_270M_CLK 21 -#define IMX7D_PLL_SYS_PFD2_135M 22 -#define IMX7D_PLL_SYS_PFD2_135M_CLK 23 -#define IMX7D_PLL_SYS_PFD3_CLK 24 -#define IMX7D_PLL_SYS_PFD4_CLK 25 -#define IMX7D_PLL_SYS_PFD5_CLK 26 -#define IMX7D_PLL_SYS_PFD6_CLK 27 -#define IMX7D_PLL_SYS_PFD7_CLK 28 -#define IMX7D_PLL_ENET_MAIN 29 -#define IMX7D_PLL_ENET_MAIN_CLK 30 -#define IMX7D_PLL_ENET_MAIN_SRC 31 -#define IMX7D_PLL_ENET_MAIN_BYPASS 32 -#define IMX7D_PLL_ENET_MAIN_500M 33 -#define IMX7D_PLL_ENET_MAIN_250M 34 -#define IMX7D_PLL_ENET_MAIN_125M 35 -#define IMX7D_PLL_ENET_MAIN_100M 36 -#define IMX7D_PLL_ENET_MAIN_50M 37 -#define IMX7D_PLL_ENET_MAIN_40M 38 -#define IMX7D_PLL_ENET_MAIN_25M 39 -#define IMX7D_PLL_ENET_MAIN_500M_CLK 40 -#define IMX7D_PLL_ENET_MAIN_250M_CLK 41 -#define IMX7D_PLL_ENET_MAIN_125M_CLK 42 -#define IMX7D_PLL_ENET_MAIN_100M_CLK 43 -#define IMX7D_PLL_ENET_MAIN_50M_CLK 44 -#define IMX7D_PLL_ENET_MAIN_40M_CLK 45 -#define IMX7D_PLL_ENET_MAIN_25M_CLK 46 -#define IMX7D_PLL_DRAM_MAIN 47 -#define IMX7D_PLL_DRAM_MAIN_CLK 48 -#define IMX7D_PLL_DRAM_MAIN_SRC 49 -#define IMX7D_PLL_DRAM_MAIN_BYPASS 50 -#define IMX7D_PLL_DRAM_MAIN_533M 51 -#define IMX7D_PLL_DRAM_MAIN_533M_CLK 52 -#define IMX7D_PLL_AUDIO_MAIN 53 -#define IMX7D_PLL_AUDIO_MAIN_CLK 54 -#define IMX7D_PLL_AUDIO_MAIN_SRC 55 -#define IMX7D_PLL_AUDIO_MAIN_BYPASS 56 -#define IMX7D_PLL_VIDEO_MAIN_CLK 57 -#define IMX7D_PLL_VIDEO_MAIN 58 -#define IMX7D_PLL_VIDEO_MAIN_SRC 59 -#define IMX7D_PLL_VIDEO_MAIN_BYPASS 60 -#define IMX7D_USB_MAIN_480M_CLK 61 -#define IMX7D_ARM_A7_ROOT_CLK 62 -#define IMX7D_ARM_A7_ROOT_SRC 63 -#define IMX7D_ARM_A7_ROOT_CG 64 -#define IMX7D_ARM_A7_ROOT_DIV 65 -#define IMX7D_ARM_M4_ROOT_CLK 66 -#define IMX7D_ARM_M4_ROOT_SRC 67 -#define IMX7D_ARM_M4_ROOT_CG 68 -#define IMX7D_ARM_M4_ROOT_DIV 69 -#define IMX7D_ARM_M0_ROOT_CLK 70 /* unused */ -#define IMX7D_ARM_M0_ROOT_SRC 71 /* unused */ -#define IMX7D_ARM_M0_ROOT_CG 72 /* unused */ -#define IMX7D_ARM_M0_ROOT_DIV 73 /* unused */ -#define IMX7D_MAIN_AXI_ROOT_CLK 74 -#define IMX7D_MAIN_AXI_ROOT_SRC 75 -#define IMX7D_MAIN_AXI_ROOT_CG 76 -#define IMX7D_MAIN_AXI_ROOT_DIV 77 -#define IMX7D_DISP_AXI_ROOT_CLK 78 -#define IMX7D_DISP_AXI_ROOT_SRC 79 -#define IMX7D_DISP_AXI_ROOT_CG 80 -#define IMX7D_DISP_AXI_ROOT_DIV 81 -#define IMX7D_ENET_AXI_ROOT_CLK 82 -#define IMX7D_ENET_AXI_ROOT_SRC 83 -#define IMX7D_ENET_AXI_ROOT_CG 84 -#define IMX7D_ENET_AXI_ROOT_DIV 85 -#define IMX7D_NAND_USDHC_BUS_ROOT_CLK 86 -#define IMX7D_NAND_USDHC_BUS_ROOT_SRC 87 -#define IMX7D_NAND_USDHC_BUS_ROOT_CG 88 -#define IMX7D_NAND_USDHC_BUS_ROOT_DIV 89 -#define IMX7D_AHB_CHANNEL_ROOT_CLK 90 -#define IMX7D_AHB_CHANNEL_ROOT_SRC 91 -#define IMX7D_AHB_CHANNEL_ROOT_CG 92 -#define IMX7D_AHB_CHANNEL_ROOT_DIV 93 -#define IMX7D_DRAM_PHYM_ROOT_CLK 94 -#define IMX7D_DRAM_PHYM_ROOT_SRC 95 -#define IMX7D_DRAM_PHYM_ROOT_CG 96 -#define IMX7D_DRAM_PHYM_ROOT_DIV 97 -#define IMX7D_DRAM_ROOT_CLK 98 -#define IMX7D_DRAM_ROOT_SRC 99 -#define IMX7D_DRAM_ROOT_CG 100 -#define IMX7D_DRAM_ROOT_DIV 101 -#define IMX7D_DRAM_PHYM_ALT_ROOT_CLK 102 -#define IMX7D_DRAM_PHYM_ALT_ROOT_SRC 103 -#define IMX7D_DRAM_PHYM_ALT_ROOT_CG 104 -#define IMX7D_DRAM_PHYM_ALT_ROOT_DIV 105 -#define IMX7D_DRAM_ALT_ROOT_CLK 106 -#define IMX7D_DRAM_ALT_ROOT_SRC 107 -#define IMX7D_DRAM_ALT_ROOT_CG 108 -#define IMX7D_DRAM_ALT_ROOT_DIV 109 -#define IMX7D_USB_HSIC_ROOT_CLK 110 -#define IMX7D_USB_HSIC_ROOT_SRC 111 -#define IMX7D_USB_HSIC_ROOT_CG 112 -#define IMX7D_USB_HSIC_ROOT_DIV 113 -#define IMX7D_PCIE_CTRL_ROOT_CLK 114 -#define IMX7D_PCIE_CTRL_ROOT_SRC 115 -#define IMX7D_PCIE_CTRL_ROOT_CG 116 -#define IMX7D_PCIE_CTRL_ROOT_DIV 117 -#define IMX7D_PCIE_PHY_ROOT_CLK 118 -#define IMX7D_PCIE_PHY_ROOT_SRC 119 -#define IMX7D_PCIE_PHY_ROOT_CG 120 -#define IMX7D_PCIE_PHY_ROOT_DIV 121 -#define IMX7D_EPDC_PIXEL_ROOT_CLK 122 -#define IMX7D_EPDC_PIXEL_ROOT_SRC 123 -#define IMX7D_EPDC_PIXEL_ROOT_CG 124 -#define IMX7D_EPDC_PIXEL_ROOT_DIV 125 -#define IMX7D_LCDIF_PIXEL_ROOT_CLK 126 -#define IMX7D_LCDIF_PIXEL_ROOT_SRC 127 -#define IMX7D_LCDIF_PIXEL_ROOT_CG 128 -#define IMX7D_LCDIF_PIXEL_ROOT_DIV 129 -#define IMX7D_MIPI_DSI_ROOT_CLK 130 -#define IMX7D_MIPI_DSI_ROOT_SRC 131 -#define IMX7D_MIPI_DSI_ROOT_CG 132 -#define IMX7D_MIPI_DSI_ROOT_DIV 133 -#define IMX7D_MIPI_CSI_ROOT_CLK 134 -#define IMX7D_MIPI_CSI_ROOT_SRC 135 -#define IMX7D_MIPI_CSI_ROOT_CG 136 -#define IMX7D_MIPI_CSI_ROOT_DIV 137 -#define IMX7D_MIPI_DPHY_ROOT_CLK 138 -#define IMX7D_MIPI_DPHY_ROOT_SRC 139 -#define IMX7D_MIPI_DPHY_ROOT_CG 140 -#define IMX7D_MIPI_DPHY_ROOT_DIV 141 -#define IMX7D_SAI1_ROOT_CLK 142 -#define IMX7D_SAI1_ROOT_SRC 143 -#define IMX7D_SAI1_ROOT_CG 144 -#define IMX7D_SAI1_ROOT_DIV 145 -#define IMX7D_SAI2_ROOT_CLK 146 -#define IMX7D_SAI2_ROOT_SRC 147 -#define IMX7D_SAI2_ROOT_CG 148 -#define IMX7D_SAI2_ROOT_DIV 149 -#define IMX7D_SAI3_ROOT_CLK 150 -#define IMX7D_SAI3_ROOT_SRC 151 -#define IMX7D_SAI3_ROOT_CG 152 -#define IMX7D_SAI3_ROOT_DIV 153 -#define IMX7D_SPDIF_ROOT_CLK 154 -#define IMX7D_SPDIF_ROOT_SRC 155 -#define IMX7D_SPDIF_ROOT_CG 156 -#define IMX7D_SPDIF_ROOT_DIV 157 -#define IMX7D_ENET1_IPG_ROOT_CLK 158 -#define IMX7D_ENET1_REF_ROOT_SRC 159 -#define IMX7D_ENET1_REF_ROOT_CG 160 -#define IMX7D_ENET1_REF_ROOT_DIV 161 -#define IMX7D_ENET1_TIME_ROOT_CLK 162 -#define IMX7D_ENET1_TIME_ROOT_SRC 163 -#define IMX7D_ENET1_TIME_ROOT_CG 164 -#define IMX7D_ENET1_TIME_ROOT_DIV 165 -#define IMX7D_ENET2_IPG_ROOT_CLK 166 -#define IMX7D_ENET2_REF_ROOT_SRC 167 -#define IMX7D_ENET2_REF_ROOT_CG 168 -#define IMX7D_ENET2_REF_ROOT_DIV 169 -#define IMX7D_ENET2_TIME_ROOT_CLK 170 -#define IMX7D_ENET2_TIME_ROOT_SRC 171 -#define IMX7D_ENET2_TIME_ROOT_CG 172 -#define IMX7D_ENET2_TIME_ROOT_DIV 173 -#define IMX7D_ENET_PHY_REF_ROOT_CLK 174 -#define IMX7D_ENET_PHY_REF_ROOT_SRC 175 -#define IMX7D_ENET_PHY_REF_ROOT_CG 176 -#define IMX7D_ENET_PHY_REF_ROOT_DIV 177 -#define IMX7D_EIM_ROOT_CLK 178 -#define IMX7D_EIM_ROOT_SRC 179 -#define IMX7D_EIM_ROOT_CG 180 -#define IMX7D_EIM_ROOT_DIV 181 -#define IMX7D_NAND_ROOT_CLK 182 -#define IMX7D_NAND_ROOT_SRC 183 -#define IMX7D_NAND_ROOT_CG 184 -#define IMX7D_NAND_ROOT_DIV 185 -#define IMX7D_QSPI_ROOT_CLK 186 -#define IMX7D_QSPI_ROOT_SRC 187 -#define IMX7D_QSPI_ROOT_CG 188 -#define IMX7D_QSPI_ROOT_DIV 189 -#define IMX7D_USDHC1_ROOT_CLK 190 -#define IMX7D_USDHC1_ROOT_SRC 191 -#define IMX7D_USDHC1_ROOT_CG 192 -#define IMX7D_USDHC1_ROOT_DIV 193 -#define IMX7D_USDHC2_ROOT_CLK 194 -#define IMX7D_USDHC2_ROOT_SRC 195 -#define IMX7D_USDHC2_ROOT_CG 196 -#define IMX7D_USDHC2_ROOT_DIV 197 -#define IMX7D_USDHC3_ROOT_CLK 198 -#define IMX7D_USDHC3_ROOT_SRC 199 -#define IMX7D_USDHC3_ROOT_CG 200 -#define IMX7D_USDHC3_ROOT_DIV 201 -#define IMX7D_CAN1_ROOT_CLK 202 -#define IMX7D_CAN1_ROOT_SRC 203 -#define IMX7D_CAN1_ROOT_CG 204 -#define IMX7D_CAN1_ROOT_DIV 205 -#define IMX7D_CAN2_ROOT_CLK 206 -#define IMX7D_CAN2_ROOT_SRC 207 -#define IMX7D_CAN2_ROOT_CG 208 -#define IMX7D_CAN2_ROOT_DIV 209 -#define IMX7D_I2C1_ROOT_CLK 210 -#define IMX7D_I2C1_ROOT_SRC 211 -#define IMX7D_I2C1_ROOT_CG 212 -#define IMX7D_I2C1_ROOT_DIV 213 -#define IMX7D_I2C2_ROOT_CLK 214 -#define IMX7D_I2C2_ROOT_SRC 215 -#define IMX7D_I2C2_ROOT_CG 216 -#define IMX7D_I2C2_ROOT_DIV 217 -#define IMX7D_I2C3_ROOT_CLK 218 -#define IMX7D_I2C3_ROOT_SRC 219 -#define IMX7D_I2C3_ROOT_CG 220 -#define IMX7D_I2C3_ROOT_DIV 221 -#define IMX7D_I2C4_ROOT_CLK 222 -#define IMX7D_I2C4_ROOT_SRC 223 -#define IMX7D_I2C4_ROOT_CG 224 -#define IMX7D_I2C4_ROOT_DIV 225 -#define IMX7D_UART1_ROOT_CLK 226 -#define IMX7D_UART1_ROOT_SRC 227 -#define IMX7D_UART1_ROOT_CG 228 -#define IMX7D_UART1_ROOT_DIV 229 -#define IMX7D_UART2_ROOT_CLK 230 -#define IMX7D_UART2_ROOT_SRC 231 -#define IMX7D_UART2_ROOT_CG 232 -#define IMX7D_UART2_ROOT_DIV 233 -#define IMX7D_UART3_ROOT_CLK 234 -#define IMX7D_UART3_ROOT_SRC 235 -#define IMX7D_UART3_ROOT_CG 236 -#define IMX7D_UART3_ROOT_DIV 237 -#define IMX7D_UART4_ROOT_CLK 238 -#define IMX7D_UART4_ROOT_SRC 239 -#define IMX7D_UART4_ROOT_CG 240 -#define IMX7D_UART4_ROOT_DIV 241 -#define IMX7D_UART5_ROOT_CLK 242 -#define IMX7D_UART5_ROOT_SRC 243 -#define IMX7D_UART5_ROOT_CG 244 -#define IMX7D_UART5_ROOT_DIV 245 -#define IMX7D_UART6_ROOT_CLK 246 -#define IMX7D_UART6_ROOT_SRC 247 -#define IMX7D_UART6_ROOT_CG 248 -#define IMX7D_UART6_ROOT_DIV 249 -#define IMX7D_UART7_ROOT_CLK 250 -#define IMX7D_UART7_ROOT_SRC 251 -#define IMX7D_UART7_ROOT_CG 252 -#define IMX7D_UART7_ROOT_DIV 253 -#define IMX7D_ECSPI1_ROOT_CLK 254 -#define IMX7D_ECSPI1_ROOT_SRC 255 -#define IMX7D_ECSPI1_ROOT_CG 256 -#define IMX7D_ECSPI1_ROOT_DIV 257 -#define IMX7D_ECSPI2_ROOT_CLK 258 -#define IMX7D_ECSPI2_ROOT_SRC 259 -#define IMX7D_ECSPI2_ROOT_CG 260 -#define IMX7D_ECSPI2_ROOT_DIV 261 -#define IMX7D_ECSPI3_ROOT_CLK 262 -#define IMX7D_ECSPI3_ROOT_SRC 263 -#define IMX7D_ECSPI3_ROOT_CG 264 -#define IMX7D_ECSPI3_ROOT_DIV 265 -#define IMX7D_ECSPI4_ROOT_CLK 266 -#define IMX7D_ECSPI4_ROOT_SRC 267 -#define IMX7D_ECSPI4_ROOT_CG 268 -#define IMX7D_ECSPI4_ROOT_DIV 269 -#define IMX7D_PWM1_ROOT_CLK 270 -#define IMX7D_PWM1_ROOT_SRC 271 -#define IMX7D_PWM1_ROOT_CG 272 -#define IMX7D_PWM1_ROOT_DIV 273 -#define IMX7D_PWM2_ROOT_CLK 274 -#define IMX7D_PWM2_ROOT_SRC 275 -#define IMX7D_PWM2_ROOT_CG 276 -#define IMX7D_PWM2_ROOT_DIV 277 -#define IMX7D_PWM3_ROOT_CLK 278 -#define IMX7D_PWM3_ROOT_SRC 279 -#define IMX7D_PWM3_ROOT_CG 280 -#define IMX7D_PWM3_ROOT_DIV 281 -#define IMX7D_PWM4_ROOT_CLK 282 -#define IMX7D_PWM4_ROOT_SRC 283 -#define IMX7D_PWM4_ROOT_CG 284 -#define IMX7D_PWM4_ROOT_DIV 285 -#define IMX7D_FLEXTIMER1_ROOT_CLK 286 -#define IMX7D_FLEXTIMER1_ROOT_SRC 287 -#define IMX7D_FLEXTIMER1_ROOT_CG 288 -#define IMX7D_FLEXTIMER1_ROOT_DIV 289 -#define IMX7D_FLEXTIMER2_ROOT_CLK 290 -#define IMX7D_FLEXTIMER2_ROOT_SRC 291 -#define IMX7D_FLEXTIMER2_ROOT_CG 292 -#define IMX7D_FLEXTIMER2_ROOT_DIV 293 -#define IMX7D_SIM1_ROOT_CLK 294 -#define IMX7D_SIM1_ROOT_SRC 295 -#define IMX7D_SIM1_ROOT_CG 296 -#define IMX7D_SIM1_ROOT_DIV 297 -#define IMX7D_SIM2_ROOT_CLK 298 -#define IMX7D_SIM2_ROOT_SRC 299 -#define IMX7D_SIM2_ROOT_CG 300 -#define IMX7D_SIM2_ROOT_DIV 301 -#define IMX7D_GPT1_ROOT_CLK 302 -#define IMX7D_GPT1_ROOT_SRC 303 -#define IMX7D_GPT1_ROOT_CG 304 -#define IMX7D_GPT1_ROOT_DIV 305 -#define IMX7D_GPT2_ROOT_CLK 306 -#define IMX7D_GPT2_ROOT_SRC 307 -#define IMX7D_GPT2_ROOT_CG 308 -#define IMX7D_GPT2_ROOT_DIV 309 -#define IMX7D_GPT3_ROOT_CLK 310 -#define IMX7D_GPT3_ROOT_SRC 311 -#define IMX7D_GPT3_ROOT_CG 312 -#define IMX7D_GPT3_ROOT_DIV 313 -#define IMX7D_GPT4_ROOT_CLK 314 -#define IMX7D_GPT4_ROOT_SRC 315 -#define IMX7D_GPT4_ROOT_CG 316 -#define IMX7D_GPT4_ROOT_DIV 317 -#define IMX7D_TRACE_ROOT_CLK 318 -#define IMX7D_TRACE_ROOT_SRC 319 -#define IMX7D_TRACE_ROOT_CG 320 -#define IMX7D_TRACE_ROOT_DIV 321 -#define IMX7D_WDOG1_ROOT_CLK 322 -#define IMX7D_WDOG_ROOT_SRC 323 -#define IMX7D_WDOG_ROOT_CG 324 -#define IMX7D_WDOG_ROOT_DIV 325 -#define IMX7D_CSI_MCLK_ROOT_CLK 326 -#define IMX7D_CSI_MCLK_ROOT_SRC 327 -#define IMX7D_CSI_MCLK_ROOT_CG 328 -#define IMX7D_CSI_MCLK_ROOT_DIV 329 -#define IMX7D_AUDIO_MCLK_ROOT_CLK 330 -#define IMX7D_AUDIO_MCLK_ROOT_SRC 331 -#define IMX7D_AUDIO_MCLK_ROOT_CG 332 -#define IMX7D_AUDIO_MCLK_ROOT_DIV 333 -#define IMX7D_WRCLK_ROOT_CLK 334 -#define IMX7D_WRCLK_ROOT_SRC 335 -#define IMX7D_WRCLK_ROOT_CG 336 -#define IMX7D_WRCLK_ROOT_DIV 337 -#define IMX7D_CLKO1_ROOT_SRC 338 -#define IMX7D_CLKO1_ROOT_CG 339 -#define IMX7D_CLKO1_ROOT_DIV 340 -#define IMX7D_CLKO2_ROOT_SRC 341 -#define IMX7D_CLKO2_ROOT_CG 342 -#define IMX7D_CLKO2_ROOT_DIV 343 -#define IMX7D_MAIN_AXI_ROOT_PRE_DIV 344 -#define IMX7D_DISP_AXI_ROOT_PRE_DIV 345 -#define IMX7D_ENET_AXI_ROOT_PRE_DIV 346 -#define IMX7D_NAND_USDHC_BUS_ROOT_PRE_DIV 347 -#define IMX7D_AHB_CHANNEL_ROOT_PRE_DIV 348 -#define IMX7D_USB_HSIC_ROOT_PRE_DIV 349 -#define IMX7D_PCIE_CTRL_ROOT_PRE_DIV 350 -#define IMX7D_PCIE_PHY_ROOT_PRE_DIV 351 -#define IMX7D_EPDC_PIXEL_ROOT_PRE_DIV 352 -#define IMX7D_LCDIF_PIXEL_ROOT_PRE_DIV 353 -#define IMX7D_MIPI_DSI_ROOT_PRE_DIV 354 -#define IMX7D_MIPI_CSI_ROOT_PRE_DIV 355 -#define IMX7D_MIPI_DPHY_ROOT_PRE_DIV 356 -#define IMX7D_SAI1_ROOT_PRE_DIV 357 -#define IMX7D_SAI2_ROOT_PRE_DIV 358 -#define IMX7D_SAI3_ROOT_PRE_DIV 359 -#define IMX7D_SPDIF_ROOT_PRE_DIV 360 -#define IMX7D_ENET1_REF_ROOT_PRE_DIV 361 -#define IMX7D_ENET1_TIME_ROOT_PRE_DIV 362 -#define IMX7D_ENET2_REF_ROOT_PRE_DIV 363 -#define IMX7D_ENET2_TIME_ROOT_PRE_DIV 364 -#define IMX7D_ENET_PHY_REF_ROOT_PRE_DIV 365 -#define IMX7D_EIM_ROOT_PRE_DIV 366 -#define IMX7D_NAND_ROOT_PRE_DIV 367 -#define IMX7D_QSPI_ROOT_PRE_DIV 368 -#define IMX7D_USDHC1_ROOT_PRE_DIV 369 -#define IMX7D_USDHC2_ROOT_PRE_DIV 370 -#define IMX7D_USDHC3_ROOT_PRE_DIV 371 -#define IMX7D_CAN1_ROOT_PRE_DIV 372 -#define IMX7D_CAN2_ROOT_PRE_DIV 373 -#define IMX7D_I2C1_ROOT_PRE_DIV 374 -#define IMX7D_I2C2_ROOT_PRE_DIV 375 -#define IMX7D_I2C3_ROOT_PRE_DIV 376 -#define IMX7D_I2C4_ROOT_PRE_DIV 377 -#define IMX7D_UART1_ROOT_PRE_DIV 378 -#define IMX7D_UART2_ROOT_PRE_DIV 379 -#define IMX7D_UART3_ROOT_PRE_DIV 380 -#define IMX7D_UART4_ROOT_PRE_DIV 381 -#define IMX7D_UART5_ROOT_PRE_DIV 382 -#define IMX7D_UART6_ROOT_PRE_DIV 383 -#define IMX7D_UART7_ROOT_PRE_DIV 384 -#define IMX7D_ECSPI1_ROOT_PRE_DIV 385 -#define IMX7D_ECSPI2_ROOT_PRE_DIV 386 -#define IMX7D_ECSPI3_ROOT_PRE_DIV 387 -#define IMX7D_ECSPI4_ROOT_PRE_DIV 388 -#define IMX7D_PWM1_ROOT_PRE_DIV 389 -#define IMX7D_PWM2_ROOT_PRE_DIV 390 -#define IMX7D_PWM3_ROOT_PRE_DIV 391 -#define IMX7D_PWM4_ROOT_PRE_DIV 392 -#define IMX7D_FLEXTIMER1_ROOT_PRE_DIV 393 -#define IMX7D_FLEXTIMER2_ROOT_PRE_DIV 394 -#define IMX7D_SIM1_ROOT_PRE_DIV 395 -#define IMX7D_SIM2_ROOT_PRE_DIV 396 -#define IMX7D_GPT1_ROOT_PRE_DIV 397 -#define IMX7D_GPT2_ROOT_PRE_DIV 398 -#define IMX7D_GPT3_ROOT_PRE_DIV 399 -#define IMX7D_GPT4_ROOT_PRE_DIV 400 -#define IMX7D_TRACE_ROOT_PRE_DIV 401 -#define IMX7D_WDOG_ROOT_PRE_DIV 402 -#define IMX7D_CSI_MCLK_ROOT_PRE_DIV 403 -#define IMX7D_AUDIO_MCLK_ROOT_PRE_DIV 404 -#define IMX7D_WRCLK_ROOT_PRE_DIV 405 -#define IMX7D_CLKO1_ROOT_PRE_DIV 406 -#define IMX7D_CLKO2_ROOT_PRE_DIV 407 -#define IMX7D_DRAM_PHYM_ALT_ROOT_PRE_DIV 408 -#define IMX7D_DRAM_ALT_ROOT_PRE_DIV 409 -#define IMX7D_LVDS1_IN_CLK 410 -#define IMX7D_LVDS1_OUT_SEL 411 -#define IMX7D_LVDS1_OUT_CLK 412 -#define IMX7D_CLK_DUMMY 413 -#define IMX7D_GPT_3M_CLK 414 -#define IMX7D_OCRAM_CLK 415 -#define IMX7D_OCRAM_S_CLK 416 -#define IMX7D_WDOG2_ROOT_CLK 417 -#define IMX7D_WDOG3_ROOT_CLK 418 -#define IMX7D_WDOG4_ROOT_CLK 419 -#define IMX7D_SDMA_CORE_CLK 420 -#define IMX7D_USB1_MAIN_480M_CLK 421 -#define IMX7D_USB_CTRL_CLK 422 -#define IMX7D_USB_PHY1_CLK 423 -#define IMX7D_USB_PHY2_CLK 424 -#define IMX7D_IPG_ROOT_CLK 425 -#define IMX7D_SAI1_IPG_CLK 426 -#define IMX7D_SAI2_IPG_CLK 427 -#define IMX7D_SAI3_IPG_CLK 428 -#define IMX7D_PLL_AUDIO_TEST_DIV 429 -#define IMX7D_PLL_AUDIO_POST_DIV 430 -#define IMX7D_PLL_VIDEO_TEST_DIV 431 -#define IMX7D_PLL_VIDEO_POST_DIV 432 -#define IMX7D_MU_ROOT_CLK 433 -#define IMX7D_SEMA4_HS_ROOT_CLK 434 -#define IMX7D_PLL_DRAM_TEST_DIV 435 -#define IMX7D_ADC_ROOT_CLK 436 -#define IMX7D_CLK_ARM 437 -#define IMX7D_CKIL 438 -#define IMX7D_OCOTP_CLK 439 -#define IMX7D_NAND_RAWNAND_CLK 440 -#define IMX7D_NAND_USDHC_BUS_RAWNAND_CLK 441 -#define IMX7D_SNVS_CLK 442 -#define IMX7D_CAAM_CLK 443 -#define IMX7D_KPP_ROOT_CLK 444 -#define IMX7D_PXP_CLK 445 -#define IMX7D_CLK_END 446 -#endif /* __DT_BINDINGS_CLOCK_IMX7D_H */ diff --git a/include/dt-bindings/clock/imx7ulp-clock.h b/include/dt-bindings/clock/imx7ulp-clock.h deleted file mode 100644 index b58370d146e2..000000000000 --- a/include/dt-bindings/clock/imx7ulp-clock.h +++ /dev/null @@ -1,119 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2016 Freescale Semiconductor, Inc. - * Copyright 2017~2018 NXP - * - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX7ULP_H -#define __DT_BINDINGS_CLOCK_IMX7ULP_H - -/* SCG1 */ - -#define IMX7ULP_CLK_DUMMY 0 -#define IMX7ULP_CLK_ROSC 1 -#define IMX7ULP_CLK_SOSC 2 -#define IMX7ULP_CLK_FIRC 3 -#define IMX7ULP_CLK_SPLL_PRE_SEL 4 -#define IMX7ULP_CLK_SPLL_PRE_DIV 5 -#define IMX7ULP_CLK_SPLL 6 -#define IMX7ULP_CLK_SPLL_POST_DIV1 7 -#define IMX7ULP_CLK_SPLL_POST_DIV2 8 -#define IMX7ULP_CLK_SPLL_PFD0 9 -#define IMX7ULP_CLK_SPLL_PFD1 10 -#define IMX7ULP_CLK_SPLL_PFD2 11 -#define IMX7ULP_CLK_SPLL_PFD3 12 -#define IMX7ULP_CLK_SPLL_PFD_SEL 13 -#define IMX7ULP_CLK_SPLL_SEL 14 -#define IMX7ULP_CLK_APLL_PRE_SEL 15 -#define IMX7ULP_CLK_APLL_PRE_DIV 16 -#define IMX7ULP_CLK_APLL 17 -#define IMX7ULP_CLK_APLL_POST_DIV1 18 -#define IMX7ULP_CLK_APLL_POST_DIV2 19 -#define IMX7ULP_CLK_APLL_PFD0 20 -#define IMX7ULP_CLK_APLL_PFD1 21 -#define IMX7ULP_CLK_APLL_PFD2 22 -#define IMX7ULP_CLK_APLL_PFD3 23 -#define IMX7ULP_CLK_APLL_PFD_SEL 24 -#define IMX7ULP_CLK_APLL_SEL 25 -#define IMX7ULP_CLK_UPLL 26 -#define IMX7ULP_CLK_SYS_SEL 27 -#define IMX7ULP_CLK_CORE_DIV 28 -#define IMX7ULP_CLK_BUS_DIV 29 -#define IMX7ULP_CLK_PLAT_DIV 30 -#define IMX7ULP_CLK_DDR_SEL 31 -#define IMX7ULP_CLK_DDR_DIV 32 -#define IMX7ULP_CLK_NIC_SEL 33 -#define IMX7ULP_CLK_NIC0_DIV 34 -#define IMX7ULP_CLK_GPU_DIV 35 -#define IMX7ULP_CLK_NIC1_DIV 36 -#define IMX7ULP_CLK_NIC1_BUS_DIV 37 -#define IMX7ULP_CLK_NIC1_EXT_DIV 38 -/* IMX7ULP_CLK_MIPI_PLL is unsupported and shouldn't be used in DT */ -#define IMX7ULP_CLK_MIPI_PLL 39 -#define IMX7ULP_CLK_SIRC 40 -#define IMX7ULP_CLK_SOSC_BUS_CLK 41 -#define IMX7ULP_CLK_FIRC_BUS_CLK 42 -#define IMX7ULP_CLK_SPLL_BUS_CLK 43 -#define IMX7ULP_CLK_HSRUN_SYS_SEL 44 -#define IMX7ULP_CLK_HSRUN_CORE_DIV 45 - -#define IMX7ULP_CLK_CORE 46 -#define IMX7ULP_CLK_HSRUN_CORE 47 - -#define IMX7ULP_CLK_SCG1_END 48 - -/* PCC2 */ -#define IMX7ULP_CLK_DMA1 0 -#define IMX7ULP_CLK_RGPIO2P1 1 -#define IMX7ULP_CLK_FLEXBUS 2 -#define IMX7ULP_CLK_SEMA42_1 3 -#define IMX7ULP_CLK_DMA_MUX1 4 -#define IMX7ULP_CLK_CAAM 6 -#define IMX7ULP_CLK_LPTPM4 7 -#define IMX7ULP_CLK_LPTPM5 8 -#define IMX7ULP_CLK_LPIT1 9 -#define IMX7ULP_CLK_LPSPI2 10 -#define IMX7ULP_CLK_LPSPI3 11 -#define IMX7ULP_CLK_LPI2C4 12 -#define IMX7ULP_CLK_LPI2C5 13 -#define IMX7ULP_CLK_LPUART4 14 -#define IMX7ULP_CLK_LPUART5 15 -#define IMX7ULP_CLK_FLEXIO1 16 -#define IMX7ULP_CLK_USB0 17 -#define IMX7ULP_CLK_USB1 18 -#define IMX7ULP_CLK_USB_PHY 19 -#define IMX7ULP_CLK_USB_PL301 20 -#define IMX7ULP_CLK_USDHC0 21 -#define IMX7ULP_CLK_USDHC1 22 -#define IMX7ULP_CLK_WDG1 23 -#define IMX7ULP_CLK_WDG2 24 - -#define IMX7ULP_CLK_PCC2_END 25 - -/* PCC3 */ -#define IMX7ULP_CLK_LPTPM6 0 -#define IMX7ULP_CLK_LPTPM7 1 -#define IMX7ULP_CLK_LPI2C6 2 -#define IMX7ULP_CLK_LPI2C7 3 -#define IMX7ULP_CLK_LPUART6 4 -#define IMX7ULP_CLK_LPUART7 5 -#define IMX7ULP_CLK_VIU 6 -#define IMX7ULP_CLK_DSI 7 -#define IMX7ULP_CLK_LCDIF 8 -#define IMX7ULP_CLK_MMDC 9 -#define IMX7ULP_CLK_PCTLC 10 -#define IMX7ULP_CLK_PCTLD 11 -#define IMX7ULP_CLK_PCTLE 12 -#define IMX7ULP_CLK_PCTLF 13 -#define IMX7ULP_CLK_GPU3D 14 -#define IMX7ULP_CLK_GPU2D 15 - -#define IMX7ULP_CLK_PCC3_END 16 - -/* SMC1 */ -#define IMX7ULP_CLK_ARM 0 - -#define IMX7ULP_CLK_SMC1_END 1 - -#endif /* __DT_BINDINGS_CLOCK_IMX7ULP_H */ diff --git a/include/dt-bindings/clock/imx8mm-clock.h b/include/dt-bindings/clock/imx8mm-clock.h deleted file mode 100644 index 1f768b2eeb1a..000000000000 --- a/include/dt-bindings/clock/imx8mm-clock.h +++ /dev/null @@ -1,286 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright 2017-2018 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX8MM_H -#define __DT_BINDINGS_CLOCK_IMX8MM_H - -#define IMX8MM_CLK_DUMMY 0 -#define IMX8MM_CLK_32K 1 -#define IMX8MM_CLK_24M 2 -#define IMX8MM_OSC_HDMI_CLK 3 -#define IMX8MM_CLK_EXT1 4 -#define IMX8MM_CLK_EXT2 5 -#define IMX8MM_CLK_EXT3 6 -#define IMX8MM_CLK_EXT4 7 -#define IMX8MM_AUDIO_PLL1_REF_SEL 8 -#define IMX8MM_AUDIO_PLL2_REF_SEL 9 -#define IMX8MM_VIDEO_PLL1_REF_SEL 10 -#define IMX8MM_DRAM_PLL_REF_SEL 11 -#define IMX8MM_GPU_PLL_REF_SEL 12 -#define IMX8MM_VPU_PLL_REF_SEL 13 -#define IMX8MM_ARM_PLL_REF_SEL 14 -#define IMX8MM_SYS_PLL1_REF_SEL 15 -#define IMX8MM_SYS_PLL2_REF_SEL 16 -#define IMX8MM_SYS_PLL3_REF_SEL 17 -#define IMX8MM_AUDIO_PLL1 18 -#define IMX8MM_AUDIO_PLL2 19 -#define IMX8MM_VIDEO_PLL1 20 -#define IMX8MM_DRAM_PLL 21 -#define IMX8MM_GPU_PLL 22 -#define IMX8MM_VPU_PLL 23 -#define IMX8MM_ARM_PLL 24 -#define IMX8MM_SYS_PLL1 25 -#define IMX8MM_SYS_PLL2 26 -#define IMX8MM_SYS_PLL3 27 -#define IMX8MM_AUDIO_PLL1_BYPASS 28 -#define IMX8MM_AUDIO_PLL2_BYPASS 29 -#define IMX8MM_VIDEO_PLL1_BYPASS 30 -#define IMX8MM_DRAM_PLL_BYPASS 31 -#define IMX8MM_GPU_PLL_BYPASS 32 -#define IMX8MM_VPU_PLL_BYPASS 33 -#define IMX8MM_ARM_PLL_BYPASS 34 -#define IMX8MM_SYS_PLL1_BYPASS 35 -#define IMX8MM_SYS_PLL2_BYPASS 36 -#define IMX8MM_SYS_PLL3_BYPASS 37 -#define IMX8MM_AUDIO_PLL1_OUT 38 -#define IMX8MM_AUDIO_PLL2_OUT 39 -#define IMX8MM_VIDEO_PLL1_OUT 40 -#define IMX8MM_DRAM_PLL_OUT 41 -#define IMX8MM_GPU_PLL_OUT 42 -#define IMX8MM_VPU_PLL_OUT 43 -#define IMX8MM_ARM_PLL_OUT 44 -#define IMX8MM_SYS_PLL1_OUT 45 -#define IMX8MM_SYS_PLL2_OUT 46 -#define IMX8MM_SYS_PLL3_OUT 47 -#define IMX8MM_SYS_PLL1_40M 48 -#define IMX8MM_SYS_PLL1_80M 49 -#define IMX8MM_SYS_PLL1_100M 50 -#define IMX8MM_SYS_PLL1_133M 51 -#define IMX8MM_SYS_PLL1_160M 52 -#define IMX8MM_SYS_PLL1_200M 53 -#define IMX8MM_SYS_PLL1_266M 54 -#define IMX8MM_SYS_PLL1_400M 55 -#define IMX8MM_SYS_PLL1_800M 56 -#define IMX8MM_SYS_PLL2_50M 57 -#define IMX8MM_SYS_PLL2_100M 58 -#define IMX8MM_SYS_PLL2_125M 59 -#define IMX8MM_SYS_PLL2_166M 60 -#define IMX8MM_SYS_PLL2_200M 61 -#define IMX8MM_SYS_PLL2_250M 62 -#define IMX8MM_SYS_PLL2_333M 63 -#define IMX8MM_SYS_PLL2_500M 64 -#define IMX8MM_SYS_PLL2_1000M 65 - -/* core */ -#define IMX8MM_CLK_A53_SRC 66 -#define IMX8MM_CLK_M4_SRC 67 -#define IMX8MM_CLK_VPU_SRC 68 -#define IMX8MM_CLK_GPU3D_SRC 69 -#define IMX8MM_CLK_GPU2D_SRC 70 -#define IMX8MM_CLK_A53_CG 71 -#define IMX8MM_CLK_M4_CG 72 -#define IMX8MM_CLK_VPU_CG 73 -#define IMX8MM_CLK_GPU3D_CG 74 -#define IMX8MM_CLK_GPU2D_CG 75 -#define IMX8MM_CLK_A53_DIV 76 -#define IMX8MM_CLK_M4_DIV 77 -#define IMX8MM_CLK_VPU_DIV 78 -#define IMX8MM_CLK_GPU3D_DIV 79 -#define IMX8MM_CLK_GPU2D_DIV 80 - -/* bus */ -#define IMX8MM_CLK_MAIN_AXI 81 -#define IMX8MM_CLK_ENET_AXI 82 -#define IMX8MM_CLK_NAND_USDHC_BUS 83 -#define IMX8MM_CLK_VPU_BUS 84 -#define IMX8MM_CLK_DISP_AXI 85 -#define IMX8MM_CLK_DISP_APB 86 -#define IMX8MM_CLK_DISP_RTRM 87 -#define IMX8MM_CLK_USB_BUS 88 -#define IMX8MM_CLK_GPU_AXI 89 -#define IMX8MM_CLK_GPU_AHB 90 -#define IMX8MM_CLK_NOC 91 -#define IMX8MM_CLK_NOC_APB 92 - -#define IMX8MM_CLK_AHB 93 -#define IMX8MM_CLK_AUDIO_AHB 94 -#define IMX8MM_CLK_IPG_ROOT 95 -#define IMX8MM_CLK_IPG_AUDIO_ROOT 96 - -#define IMX8MM_CLK_DRAM_ALT 97 -#define IMX8MM_CLK_DRAM_APB 98 -#define IMX8MM_CLK_VPU_G1 99 -#define IMX8MM_CLK_VPU_G2 100 -#define IMX8MM_CLK_DISP_DTRC 101 -#define IMX8MM_CLK_DISP_DC8000 102 -#define IMX8MM_CLK_PCIE1_CTRL 103 -#define IMX8MM_CLK_PCIE1_PHY 104 -#define IMX8MM_CLK_PCIE1_AUX 105 -#define IMX8MM_CLK_DC_PIXEL 106 -#define IMX8MM_CLK_LCDIF_PIXEL 107 -#define IMX8MM_CLK_SAI1 108 -#define IMX8MM_CLK_SAI2 109 -#define IMX8MM_CLK_SAI3 110 -#define IMX8MM_CLK_SAI4 111 -#define IMX8MM_CLK_SAI5 112 -#define IMX8MM_CLK_SAI6 113 -#define IMX8MM_CLK_SPDIF1 114 -#define IMX8MM_CLK_SPDIF2 115 -#define IMX8MM_CLK_ENET_REF 116 -#define IMX8MM_CLK_ENET_TIMER 117 -#define IMX8MM_CLK_ENET_PHY_REF 118 -#define IMX8MM_CLK_NAND 119 -#define IMX8MM_CLK_QSPI 120 -#define IMX8MM_CLK_USDHC1 121 -#define IMX8MM_CLK_USDHC2 122 -#define IMX8MM_CLK_I2C1 123 -#define IMX8MM_CLK_I2C2 124 -#define IMX8MM_CLK_I2C3 125 -#define IMX8MM_CLK_I2C4 126 -#define IMX8MM_CLK_UART1 127 -#define IMX8MM_CLK_UART2 128 -#define IMX8MM_CLK_UART3 129 -#define IMX8MM_CLK_UART4 130 -#define IMX8MM_CLK_USB_CORE_REF 131 -#define IMX8MM_CLK_USB_PHY_REF 132 -#define IMX8MM_CLK_ECSPI1 133 -#define IMX8MM_CLK_ECSPI2 134 -#define IMX8MM_CLK_PWM1 135 -#define IMX8MM_CLK_PWM2 136 -#define IMX8MM_CLK_PWM3 137 -#define IMX8MM_CLK_PWM4 138 -#define IMX8MM_CLK_GPT1 139 -#define IMX8MM_CLK_WDOG 140 -#define IMX8MM_CLK_WRCLK 141 -#define IMX8MM_CLK_DSI_CORE 142 -#define IMX8MM_CLK_DSI_PHY_REF 143 -#define IMX8MM_CLK_DSI_DBI 144 -#define IMX8MM_CLK_USDHC3 145 -#define IMX8MM_CLK_CSI1_CORE 146 -#define IMX8MM_CLK_CSI1_PHY_REF 147 -#define IMX8MM_CLK_CSI1_ESC 148 -#define IMX8MM_CLK_CSI2_CORE 149 -#define IMX8MM_CLK_CSI2_PHY_REF 150 -#define IMX8MM_CLK_CSI2_ESC 151 -#define IMX8MM_CLK_PCIE2_CTRL 152 -#define IMX8MM_CLK_PCIE2_PHY 153 -#define IMX8MM_CLK_PCIE2_AUX 154 -#define IMX8MM_CLK_ECSPI3 155 -#define IMX8MM_CLK_PDM 156 -#define IMX8MM_CLK_VPU_H1 157 -#define IMX8MM_CLK_CLKO1 158 - -#define IMX8MM_CLK_ECSPI1_ROOT 159 -#define IMX8MM_CLK_ECSPI2_ROOT 160 -#define IMX8MM_CLK_ECSPI3_ROOT 161 -#define IMX8MM_CLK_ENET1_ROOT 162 -#define IMX8MM_CLK_GPT1_ROOT 163 -#define IMX8MM_CLK_I2C1_ROOT 164 -#define IMX8MM_CLK_I2C2_ROOT 165 -#define IMX8MM_CLK_I2C3_ROOT 166 -#define IMX8MM_CLK_I2C4_ROOT 167 -#define IMX8MM_CLK_OCOTP_ROOT 168 -#define IMX8MM_CLK_PCIE1_ROOT 169 -#define IMX8MM_CLK_PWM1_ROOT 170 -#define IMX8MM_CLK_PWM2_ROOT 171 -#define IMX8MM_CLK_PWM3_ROOT 172 -#define IMX8MM_CLK_PWM4_ROOT 173 -#define IMX8MM_CLK_QSPI_ROOT 174 -#define IMX8MM_CLK_NAND_ROOT 175 -#define IMX8MM_CLK_SAI1_ROOT 176 -#define IMX8MM_CLK_SAI1_IPG 177 -#define IMX8MM_CLK_SAI2_ROOT 178 -#define IMX8MM_CLK_SAI2_IPG 179 -#define IMX8MM_CLK_SAI3_ROOT 180 -#define IMX8MM_CLK_SAI3_IPG 181 -#define IMX8MM_CLK_SAI4_ROOT 182 -#define IMX8MM_CLK_SAI4_IPG 183 -#define IMX8MM_CLK_SAI5_ROOT 184 -#define IMX8MM_CLK_SAI5_IPG 185 -#define IMX8MM_CLK_SAI6_ROOT 186 -#define IMX8MM_CLK_SAI6_IPG 187 -#define IMX8MM_CLK_UART1_ROOT 188 -#define IMX8MM_CLK_UART2_ROOT 189 -#define IMX8MM_CLK_UART3_ROOT 190 -#define IMX8MM_CLK_UART4_ROOT 191 -#define IMX8MM_CLK_USB1_CTRL_ROOT 192 -#define IMX8MM_CLK_GPU3D_ROOT 193 -#define IMX8MM_CLK_USDHC1_ROOT 194 -#define IMX8MM_CLK_USDHC2_ROOT 195 -#define IMX8MM_CLK_WDOG1_ROOT 196 -#define IMX8MM_CLK_WDOG2_ROOT 197 -#define IMX8MM_CLK_WDOG3_ROOT 198 -#define IMX8MM_CLK_VPU_G1_ROOT 199 -#define IMX8MM_CLK_GPU_BUS_ROOT 200 -#define IMX8MM_CLK_VPU_H1_ROOT 201 -#define IMX8MM_CLK_VPU_G2_ROOT 202 -#define IMX8MM_CLK_PDM_ROOT 203 -#define IMX8MM_CLK_DISP_ROOT 204 -#define IMX8MM_CLK_DISP_AXI_ROOT 205 -#define IMX8MM_CLK_DISP_APB_ROOT 206 -#define IMX8MM_CLK_DISP_RTRM_ROOT 207 -#define IMX8MM_CLK_USDHC3_ROOT 208 -#define IMX8MM_CLK_TMU_ROOT 209 -#define IMX8MM_CLK_VPU_DEC_ROOT 210 -#define IMX8MM_CLK_SDMA1_ROOT 211 -#define IMX8MM_CLK_SDMA2_ROOT 212 -#define IMX8MM_CLK_SDMA3_ROOT 213 -#define IMX8MM_CLK_GPT_3M 214 -#define IMX8MM_CLK_ARM 215 -#define IMX8MM_CLK_PDM_IPG 216 -#define IMX8MM_CLK_GPU2D_ROOT 217 -#define IMX8MM_CLK_MU_ROOT 218 -#define IMX8MM_CLK_CSI1_ROOT 219 - -#define IMX8MM_CLK_DRAM_CORE 220 -#define IMX8MM_CLK_DRAM_ALT_ROOT 221 - -#define IMX8MM_CLK_NAND_USDHC_BUS_RAWNAND_CLK 222 - -#define IMX8MM_CLK_GPIO1_ROOT 223 -#define IMX8MM_CLK_GPIO2_ROOT 224 -#define IMX8MM_CLK_GPIO3_ROOT 225 -#define IMX8MM_CLK_GPIO4_ROOT 226 -#define IMX8MM_CLK_GPIO5_ROOT 227 - -#define IMX8MM_CLK_SNVS_ROOT 228 -#define IMX8MM_CLK_GIC 229 - -#define IMX8MM_SYS_PLL1_40M_CG 230 -#define IMX8MM_SYS_PLL1_80M_CG 231 -#define IMX8MM_SYS_PLL1_100M_CG 232 -#define IMX8MM_SYS_PLL1_133M_CG 233 -#define IMX8MM_SYS_PLL1_160M_CG 234 -#define IMX8MM_SYS_PLL1_200M_CG 235 -#define IMX8MM_SYS_PLL1_266M_CG 236 -#define IMX8MM_SYS_PLL1_400M_CG 237 -#define IMX8MM_SYS_PLL2_50M_CG 238 -#define IMX8MM_SYS_PLL2_100M_CG 239 -#define IMX8MM_SYS_PLL2_125M_CG 240 -#define IMX8MM_SYS_PLL2_166M_CG 241 -#define IMX8MM_SYS_PLL2_200M_CG 242 -#define IMX8MM_SYS_PLL2_250M_CG 243 -#define IMX8MM_SYS_PLL2_333M_CG 244 -#define IMX8MM_SYS_PLL2_500M_CG 245 - -#define IMX8MM_CLK_M4_CORE 246 -#define IMX8MM_CLK_VPU_CORE 247 -#define IMX8MM_CLK_GPU3D_CORE 248 -#define IMX8MM_CLK_GPU2D_CORE 249 - -#define IMX8MM_CLK_CLKO2 250 - -#define IMX8MM_CLK_A53_CORE 251 - -#define IMX8MM_CLK_CLKOUT1_SEL 252 -#define IMX8MM_CLK_CLKOUT1_DIV 253 -#define IMX8MM_CLK_CLKOUT1 254 -#define IMX8MM_CLK_CLKOUT2_SEL 255 -#define IMX8MM_CLK_CLKOUT2_DIV 256 -#define IMX8MM_CLK_CLKOUT2 257 - -#define IMX8MM_CLK_END 258 - -#endif diff --git a/include/dt-bindings/clock/imx8mn-clock.h b/include/dt-bindings/clock/imx8mn-clock.h deleted file mode 100644 index 07b8a282c268..000000000000 --- a/include/dt-bindings/clock/imx8mn-clock.h +++ /dev/null @@ -1,262 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright 2018-2019 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX8MN_H -#define __DT_BINDINGS_CLOCK_IMX8MN_H - -#define IMX8MN_CLK_DUMMY 0 -#define IMX8MN_CLK_32K 1 -#define IMX8MN_CLK_24M 2 -#define IMX8MN_OSC_HDMI_CLK 3 -#define IMX8MN_CLK_EXT1 4 -#define IMX8MN_CLK_EXT2 5 -#define IMX8MN_CLK_EXT3 6 -#define IMX8MN_CLK_EXT4 7 -#define IMX8MN_AUDIO_PLL1_REF_SEL 8 -#define IMX8MN_AUDIO_PLL2_REF_SEL 9 -#define IMX8MN_VIDEO_PLL1_REF_SEL 10 -#define IMX8MN_DRAM_PLL_REF_SEL 11 -#define IMX8MN_GPU_PLL_REF_SEL 12 -#define IMX8MN_VPU_PLL_REF_SEL 13 -#define IMX8MN_ARM_PLL_REF_SEL 14 -#define IMX8MN_SYS_PLL1_REF_SEL 15 -#define IMX8MN_SYS_PLL2_REF_SEL 16 -#define IMX8MN_SYS_PLL3_REF_SEL 17 -#define IMX8MN_AUDIO_PLL1 18 -#define IMX8MN_AUDIO_PLL2 19 -#define IMX8MN_VIDEO_PLL1 20 -#define IMX8MN_DRAM_PLL 21 -#define IMX8MN_GPU_PLL 22 -#define IMX8MN_VPU_PLL 23 -#define IMX8MN_ARM_PLL 24 -#define IMX8MN_SYS_PLL1 25 -#define IMX8MN_SYS_PLL2 26 -#define IMX8MN_SYS_PLL3 27 -#define IMX8MN_AUDIO_PLL1_BYPASS 28 -#define IMX8MN_AUDIO_PLL2_BYPASS 29 -#define IMX8MN_VIDEO_PLL1_BYPASS 30 -#define IMX8MN_DRAM_PLL_BYPASS 31 -#define IMX8MN_GPU_PLL_BYPASS 32 -#define IMX8MN_VPU_PLL_BYPASS 33 -#define IMX8MN_ARM_PLL_BYPASS 34 -#define IMX8MN_SYS_PLL1_BYPASS 35 -#define IMX8MN_SYS_PLL2_BYPASS 36 -#define IMX8MN_SYS_PLL3_BYPASS 37 -#define IMX8MN_AUDIO_PLL1_OUT 38 -#define IMX8MN_AUDIO_PLL2_OUT 39 -#define IMX8MN_VIDEO_PLL1_OUT 40 -#define IMX8MN_DRAM_PLL_OUT 41 -#define IMX8MN_GPU_PLL_OUT 42 -#define IMX8MN_VPU_PLL_OUT 43 -#define IMX8MN_ARM_PLL_OUT 44 -#define IMX8MN_SYS_PLL1_OUT 45 -#define IMX8MN_SYS_PLL2_OUT 46 -#define IMX8MN_SYS_PLL3_OUT 47 -#define IMX8MN_SYS_PLL1_40M 48 -#define IMX8MN_SYS_PLL1_80M 49 -#define IMX8MN_SYS_PLL1_100M 50 -#define IMX8MN_SYS_PLL1_133M 51 -#define IMX8MN_SYS_PLL1_160M 52 -#define IMX8MN_SYS_PLL1_200M 53 -#define IMX8MN_SYS_PLL1_266M 54 -#define IMX8MN_SYS_PLL1_400M 55 -#define IMX8MN_SYS_PLL1_800M 56 -#define IMX8MN_SYS_PLL2_50M 57 -#define IMX8MN_SYS_PLL2_100M 58 -#define IMX8MN_SYS_PLL2_125M 59 -#define IMX8MN_SYS_PLL2_166M 60 -#define IMX8MN_SYS_PLL2_200M 61 -#define IMX8MN_SYS_PLL2_250M 62 -#define IMX8MN_SYS_PLL2_333M 63 -#define IMX8MN_SYS_PLL2_500M 64 -#define IMX8MN_SYS_PLL2_1000M 65 - -/* CORE CLOCK ROOT */ -#define IMX8MN_CLK_A53_SRC 66 -#define IMX8MN_CLK_GPU_CORE_SRC 67 -#define IMX8MN_CLK_GPU_SHADER_SRC 68 -#define IMX8MN_CLK_A53_CG 69 -#define IMX8MN_CLK_GPU_CORE_CG 70 -#define IMX8MN_CLK_GPU_SHADER_CG 71 -#define IMX8MN_CLK_A53_DIV 72 -#define IMX8MN_CLK_GPU_CORE_DIV 73 -#define IMX8MN_CLK_GPU_SHADER_DIV 74 - -/* BUS CLOCK ROOT */ -#define IMX8MN_CLK_MAIN_AXI 75 -#define IMX8MN_CLK_ENET_AXI 76 -#define IMX8MN_CLK_NAND_USDHC_BUS 77 -#define IMX8MN_CLK_DISP_AXI 78 -#define IMX8MN_CLK_DISP_APB 79 -#define IMX8MN_CLK_USB_BUS 80 -#define IMX8MN_CLK_GPU_AXI 81 -#define IMX8MN_CLK_GPU_AHB 82 -#define IMX8MN_CLK_NOC 83 -#define IMX8MN_CLK_AHB 84 -#define IMX8MN_CLK_AUDIO_AHB 85 - -/* IPG CLOCK ROOT */ -#define IMX8MN_CLK_IPG_ROOT 86 -#define IMX8MN_CLK_IPG_AUDIO_ROOT 87 - -/* IP */ -#define IMX8MN_CLK_DRAM_CORE 88 -#define IMX8MN_CLK_DRAM_ALT 89 -#define IMX8MN_CLK_DRAM_APB 90 -#define IMX8MN_CLK_DRAM_ALT_ROOT 91 -#define IMX8MN_CLK_DISP_PIXEL 92 -#define IMX8MN_CLK_SAI2 93 -#define IMX8MN_CLK_SAI3 94 -#define IMX8MN_CLK_SAI5 95 -#define IMX8MN_CLK_SAI6 96 -#define IMX8MN_CLK_SPDIF1 97 -#define IMX8MN_CLK_ENET_REF 98 -#define IMX8MN_CLK_ENET_TIMER 99 -#define IMX8MN_CLK_ENET_PHY_REF 100 -#define IMX8MN_CLK_NAND 101 -#define IMX8MN_CLK_QSPI 102 -#define IMX8MN_CLK_USDHC1 103 -#define IMX8MN_CLK_USDHC2 104 -#define IMX8MN_CLK_I2C1 105 -#define IMX8MN_CLK_I2C2 106 -#define IMX8MN_CLK_I2C3 107 -#define IMX8MN_CLK_I2C4 108 -#define IMX8MN_CLK_UART1 109 -#define IMX8MN_CLK_UART2 110 -#define IMX8MN_CLK_UART3 111 -#define IMX8MN_CLK_UART4 112 -#define IMX8MN_CLK_USB_CORE_REF 113 -#define IMX8MN_CLK_USB_PHY_REF 114 -#define IMX8MN_CLK_ECSPI1 115 -#define IMX8MN_CLK_ECSPI2 116 -#define IMX8MN_CLK_PWM1 117 -#define IMX8MN_CLK_PWM2 118 -#define IMX8MN_CLK_PWM3 119 -#define IMX8MN_CLK_PWM4 120 -#define IMX8MN_CLK_WDOG 121 -#define IMX8MN_CLK_WRCLK 122 -#define IMX8MN_CLK_CLKO1 123 -#define IMX8MN_CLK_CLKO2 124 -#define IMX8MN_CLK_DSI_CORE 125 -#define IMX8MN_CLK_DSI_PHY_REF 126 -#define IMX8MN_CLK_DSI_DBI 127 -#define IMX8MN_CLK_USDHC3 128 -#define IMX8MN_CLK_CAMERA_PIXEL 129 -#define IMX8MN_CLK_CSI1_PHY_REF 130 -#define IMX8MN_CLK_CSI2_PHY_REF 131 -#define IMX8MN_CLK_CSI2_ESC 132 -#define IMX8MN_CLK_ECSPI3 133 -#define IMX8MN_CLK_PDM 134 -#define IMX8MN_CLK_SAI7 135 - -#define IMX8MN_CLK_ECSPI1_ROOT 136 -#define IMX8MN_CLK_ECSPI2_ROOT 137 -#define IMX8MN_CLK_ECSPI3_ROOT 138 -#define IMX8MN_CLK_ENET1_ROOT 139 -#define IMX8MN_CLK_GPIO1_ROOT 140 -#define IMX8MN_CLK_GPIO2_ROOT 141 -#define IMX8MN_CLK_GPIO3_ROOT 142 -#define IMX8MN_CLK_GPIO4_ROOT 143 -#define IMX8MN_CLK_GPIO5_ROOT 144 -#define IMX8MN_CLK_I2C1_ROOT 145 -#define IMX8MN_CLK_I2C2_ROOT 146 -#define IMX8MN_CLK_I2C3_ROOT 147 -#define IMX8MN_CLK_I2C4_ROOT 148 -#define IMX8MN_CLK_MU_ROOT 149 -#define IMX8MN_CLK_OCOTP_ROOT 150 -#define IMX8MN_CLK_PWM1_ROOT 151 -#define IMX8MN_CLK_PWM2_ROOT 152 -#define IMX8MN_CLK_PWM3_ROOT 153 -#define IMX8MN_CLK_PWM4_ROOT 154 -#define IMX8MN_CLK_QSPI_ROOT 155 -#define IMX8MN_CLK_NAND_ROOT 156 -#define IMX8MN_CLK_SAI2_ROOT 157 -#define IMX8MN_CLK_SAI2_IPG 158 -#define IMX8MN_CLK_SAI3_ROOT 159 -#define IMX8MN_CLK_SAI3_IPG 160 -#define IMX8MN_CLK_SAI5_ROOT 161 -#define IMX8MN_CLK_SAI5_IPG 162 -#define IMX8MN_CLK_SAI6_ROOT 163 -#define IMX8MN_CLK_SAI6_IPG 164 -#define IMX8MN_CLK_SAI7_ROOT 165 -#define IMX8MN_CLK_SAI7_IPG 166 -#define IMX8MN_CLK_SDMA1_ROOT 167 -#define IMX8MN_CLK_SDMA2_ROOT 168 -#define IMX8MN_CLK_UART1_ROOT 169 -#define IMX8MN_CLK_UART2_ROOT 170 -#define IMX8MN_CLK_UART3_ROOT 171 -#define IMX8MN_CLK_UART4_ROOT 172 -#define IMX8MN_CLK_USB1_CTRL_ROOT 173 -#define IMX8MN_CLK_USDHC1_ROOT 174 -#define IMX8MN_CLK_USDHC2_ROOT 175 -#define IMX8MN_CLK_WDOG1_ROOT 176 -#define IMX8MN_CLK_WDOG2_ROOT 177 -#define IMX8MN_CLK_WDOG3_ROOT 178 -#define IMX8MN_CLK_GPU_BUS_ROOT 179 -#define IMX8MN_CLK_ASRC_ROOT 180 -#define IMX8MN_CLK_GPU3D_ROOT 181 -#define IMX8MN_CLK_PDM_ROOT 182 -#define IMX8MN_CLK_PDM_IPG 183 -#define IMX8MN_CLK_DISP_AXI_ROOT 184 -#define IMX8MN_CLK_DISP_APB_ROOT 185 -#define IMX8MN_CLK_DISP_PIXEL_ROOT 186 -#define IMX8MN_CLK_CAMERA_PIXEL_ROOT 187 -#define IMX8MN_CLK_USDHC3_ROOT 188 -#define IMX8MN_CLK_SDMA3_ROOT 189 -#define IMX8MN_CLK_TMU_ROOT 190 -#define IMX8MN_CLK_ARM 191 -#define IMX8MN_CLK_NAND_USDHC_BUS_RAWNAND_CLK 192 -#define IMX8MN_CLK_GPU_CORE_ROOT 193 -#define IMX8MN_CLK_GIC 194 - -#define IMX8MN_SYS_PLL1_40M_CG 195 -#define IMX8MN_SYS_PLL1_80M_CG 196 -#define IMX8MN_SYS_PLL1_100M_CG 197 -#define IMX8MN_SYS_PLL1_133M_CG 198 -#define IMX8MN_SYS_PLL1_160M_CG 199 -#define IMX8MN_SYS_PLL1_200M_CG 200 -#define IMX8MN_SYS_PLL1_266M_CG 201 -#define IMX8MN_SYS_PLL1_400M_CG 202 -#define IMX8MN_SYS_PLL2_50M_CG 203 -#define IMX8MN_SYS_PLL2_100M_CG 204 -#define IMX8MN_SYS_PLL2_125M_CG 205 -#define IMX8MN_SYS_PLL2_166M_CG 206 -#define IMX8MN_SYS_PLL2_200M_CG 207 -#define IMX8MN_SYS_PLL2_250M_CG 208 -#define IMX8MN_SYS_PLL2_333M_CG 209 -#define IMX8MN_SYS_PLL2_500M_CG 210 - -#define IMX8MN_CLK_SNVS_ROOT 211 -#define IMX8MN_CLK_GPU_CORE 212 -#define IMX8MN_CLK_GPU_SHADER 213 - -#define IMX8MN_CLK_A53_CORE 214 - -#define IMX8MN_CLK_CLKOUT1_SEL 215 -#define IMX8MN_CLK_CLKOUT1_DIV 216 -#define IMX8MN_CLK_CLKOUT1 217 -#define IMX8MN_CLK_CLKOUT2_SEL 218 -#define IMX8MN_CLK_CLKOUT2_DIV 219 -#define IMX8MN_CLK_CLKOUT2 220 - -#define IMX8MN_CLK_M7_CORE 221 - -#define IMX8MN_CLK_GPT_3M 222 -#define IMX8MN_CLK_GPT1 223 -#define IMX8MN_CLK_GPT1_ROOT 224 -#define IMX8MN_CLK_GPT2 225 -#define IMX8MN_CLK_GPT2_ROOT 226 -#define IMX8MN_CLK_GPT3 227 -#define IMX8MN_CLK_GPT3_ROOT 228 -#define IMX8MN_CLK_GPT4 229 -#define IMX8MN_CLK_GPT4_ROOT 230 -#define IMX8MN_CLK_GPT5 231 -#define IMX8MN_CLK_GPT5_ROOT 232 -#define IMX8MN_CLK_GPT6 233 -#define IMX8MN_CLK_GPT6_ROOT 234 - -#define IMX8MN_CLK_END 235 - -#endif diff --git a/include/dt-bindings/clock/imx8mp-clock.h b/include/dt-bindings/clock/imx8mp-clock.h deleted file mode 100644 index 7da4243984b2..000000000000 --- a/include/dt-bindings/clock/imx8mp-clock.h +++ /dev/null @@ -1,401 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright 2019 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX8MP_H -#define __DT_BINDINGS_CLOCK_IMX8MP_H - -#define IMX8MP_CLK_DUMMY 0 -#define IMX8MP_CLK_32K 1 -#define IMX8MP_CLK_24M 2 -#define IMX8MP_OSC_HDMI_CLK 3 -#define IMX8MP_CLK_EXT1 4 -#define IMX8MP_CLK_EXT2 5 -#define IMX8MP_CLK_EXT3 6 -#define IMX8MP_CLK_EXT4 7 -#define IMX8MP_AUDIO_PLL1_REF_SEL 8 -#define IMX8MP_AUDIO_PLL2_REF_SEL 9 -#define IMX8MP_VIDEO_PLL1_REF_SEL 10 -#define IMX8MP_DRAM_PLL_REF_SEL 11 -#define IMX8MP_GPU_PLL_REF_SEL 12 -#define IMX8MP_VPU_PLL_REF_SEL 13 -#define IMX8MP_ARM_PLL_REF_SEL 14 -#define IMX8MP_SYS_PLL1_REF_SEL 15 -#define IMX8MP_SYS_PLL2_REF_SEL 16 -#define IMX8MP_SYS_PLL3_REF_SEL 17 -#define IMX8MP_AUDIO_PLL1 18 -#define IMX8MP_AUDIO_PLL2 19 -#define IMX8MP_VIDEO_PLL1 20 -#define IMX8MP_DRAM_PLL 21 -#define IMX8MP_GPU_PLL 22 -#define IMX8MP_VPU_PLL 23 -#define IMX8MP_ARM_PLL 24 -#define IMX8MP_SYS_PLL1 25 -#define IMX8MP_SYS_PLL2 26 -#define IMX8MP_SYS_PLL3 27 -#define IMX8MP_AUDIO_PLL1_BYPASS 28 -#define IMX8MP_AUDIO_PLL2_BYPASS 29 -#define IMX8MP_VIDEO_PLL1_BYPASS 30 -#define IMX8MP_DRAM_PLL_BYPASS 31 -#define IMX8MP_GPU_PLL_BYPASS 32 -#define IMX8MP_VPU_PLL_BYPASS 33 -#define IMX8MP_ARM_PLL_BYPASS 34 -#define IMX8MP_SYS_PLL1_BYPASS 35 -#define IMX8MP_SYS_PLL2_BYPASS 36 -#define IMX8MP_SYS_PLL3_BYPASS 37 -#define IMX8MP_AUDIO_PLL1_OUT 38 -#define IMX8MP_AUDIO_PLL2_OUT 39 -#define IMX8MP_VIDEO_PLL1_OUT 40 -#define IMX8MP_DRAM_PLL_OUT 41 -#define IMX8MP_GPU_PLL_OUT 42 -#define IMX8MP_VPU_PLL_OUT 43 -#define IMX8MP_ARM_PLL_OUT 44 -#define IMX8MP_SYS_PLL1_OUT 45 -#define IMX8MP_SYS_PLL2_OUT 46 -#define IMX8MP_SYS_PLL3_OUT 47 -#define IMX8MP_SYS_PLL1_40M 48 -#define IMX8MP_SYS_PLL1_80M 49 -#define IMX8MP_SYS_PLL1_100M 50 -#define IMX8MP_SYS_PLL1_133M 51 -#define IMX8MP_SYS_PLL1_160M 52 -#define IMX8MP_SYS_PLL1_200M 53 -#define IMX8MP_SYS_PLL1_266M 54 -#define IMX8MP_SYS_PLL1_400M 55 -#define IMX8MP_SYS_PLL1_800M 56 -#define IMX8MP_SYS_PLL2_50M 57 -#define IMX8MP_SYS_PLL2_100M 58 -#define IMX8MP_SYS_PLL2_125M 59 -#define IMX8MP_SYS_PLL2_166M 60 -#define IMX8MP_SYS_PLL2_200M 61 -#define IMX8MP_SYS_PLL2_250M 62 -#define IMX8MP_SYS_PLL2_333M 63 -#define IMX8MP_SYS_PLL2_500M 64 -#define IMX8MP_SYS_PLL2_1000M 65 -#define IMX8MP_CLK_A53_SRC 66 -#define IMX8MP_CLK_M7_SRC 67 -#define IMX8MP_CLK_ML_SRC 68 -#define IMX8MP_CLK_GPU3D_CORE_SRC 69 -#define IMX8MP_CLK_GPU3D_SHADER_SRC 70 -#define IMX8MP_CLK_GPU2D_SRC 71 -#define IMX8MP_CLK_AUDIO_AXI_SRC 72 -#define IMX8MP_CLK_HSIO_AXI_SRC 73 -#define IMX8MP_CLK_MEDIA_ISP_SRC 74 -#define IMX8MP_CLK_A53_CG 75 -#define IMX8MP_CLK_M4_CG 76 -#define IMX8MP_CLK_ML_CG 77 -#define IMX8MP_CLK_GPU3D_CORE_CG 78 -#define IMX8MP_CLK_GPU3D_SHADER_CG 79 -#define IMX8MP_CLK_GPU2D_CG 80 -#define IMX8MP_CLK_AUDIO_AXI_CG 81 -#define IMX8MP_CLK_HSIO_AXI_CG 82 -#define IMX8MP_CLK_MEDIA_ISP_CG 83 -#define IMX8MP_CLK_A53_DIV 84 -#define IMX8MP_CLK_M7_DIV 85 -#define IMX8MP_CLK_ML_DIV 86 -#define IMX8MP_CLK_GPU3D_CORE_DIV 87 -#define IMX8MP_CLK_GPU3D_SHADER_DIV 88 -#define IMX8MP_CLK_GPU2D_DIV 89 -#define IMX8MP_CLK_AUDIO_AXI_DIV 90 -#define IMX8MP_CLK_HSIO_AXI_DIV 91 -#define IMX8MP_CLK_MEDIA_ISP_DIV 92 -#define IMX8MP_CLK_MAIN_AXI 93 -#define IMX8MP_CLK_ENET_AXI 94 -#define IMX8MP_CLK_NAND_USDHC_BUS 95 -#define IMX8MP_CLK_VPU_BUS 96 -#define IMX8MP_CLK_MEDIA_AXI 97 -#define IMX8MP_CLK_MEDIA_APB 98 -#define IMX8MP_CLK_HDMI_APB 99 -#define IMX8MP_CLK_HDMI_AXI 100 -#define IMX8MP_CLK_GPU_AXI 101 -#define IMX8MP_CLK_GPU_AHB 102 -#define IMX8MP_CLK_NOC 103 -#define IMX8MP_CLK_NOC_IO 104 -#define IMX8MP_CLK_ML_AXI 105 -#define IMX8MP_CLK_ML_AHB 106 -#define IMX8MP_CLK_AHB 107 -#define IMX8MP_CLK_AUDIO_AHB 108 -#define IMX8MP_CLK_MIPI_DSI_ESC_RX 109 -#define IMX8MP_CLK_IPG_ROOT 110 -#define IMX8MP_CLK_DRAM_ALT 112 -#define IMX8MP_CLK_DRAM_APB 113 -#define IMX8MP_CLK_VPU_G1 114 -#define IMX8MP_CLK_VPU_G2 115 -#define IMX8MP_CLK_CAN1 116 -#define IMX8MP_CLK_CAN2 117 -#define IMX8MP_CLK_MEMREPAIR 118 -#define IMX8MP_CLK_PCIE_AUX 120 -#define IMX8MP_CLK_I2C5 121 -#define IMX8MP_CLK_I2C6 122 -#define IMX8MP_CLK_SAI1 123 -#define IMX8MP_CLK_SAI2 124 -#define IMX8MP_CLK_SAI3 125 -/* #define IMX8MP_CLK_SAI4 126 */ -#define IMX8MP_CLK_SAI5 127 -#define IMX8MP_CLK_SAI6 128 -#define IMX8MP_CLK_ENET_QOS 129 -#define IMX8MP_CLK_ENET_QOS_TIMER 130 -#define IMX8MP_CLK_ENET_REF 131 -#define IMX8MP_CLK_ENET_TIMER 132 -#define IMX8MP_CLK_ENET_PHY_REF 133 -#define IMX8MP_CLK_NAND 134 -#define IMX8MP_CLK_QSPI 135 -#define IMX8MP_CLK_USDHC1 136 -#define IMX8MP_CLK_USDHC2 137 -#define IMX8MP_CLK_I2C1 138 -#define IMX8MP_CLK_I2C2 139 -#define IMX8MP_CLK_I2C3 140 -#define IMX8MP_CLK_I2C4 141 -#define IMX8MP_CLK_UART1 142 -#define IMX8MP_CLK_UART2 143 -#define IMX8MP_CLK_UART3 144 -#define IMX8MP_CLK_UART4 145 -#define IMX8MP_CLK_USB_CORE_REF 146 -#define IMX8MP_CLK_USB_PHY_REF 147 -#define IMX8MP_CLK_GIC 148 -#define IMX8MP_CLK_ECSPI1 149 -#define IMX8MP_CLK_ECSPI2 150 -#define IMX8MP_CLK_PWM1 151 -#define IMX8MP_CLK_PWM2 152 -#define IMX8MP_CLK_PWM3 153 -#define IMX8MP_CLK_PWM4 154 -#define IMX8MP_CLK_GPT1 155 -#define IMX8MP_CLK_GPT2 156 -#define IMX8MP_CLK_GPT3 157 -#define IMX8MP_CLK_GPT4 158 -#define IMX8MP_CLK_GPT5 159 -#define IMX8MP_CLK_GPT6 160 -#define IMX8MP_CLK_TRACE 161 -#define IMX8MP_CLK_WDOG 162 -#define IMX8MP_CLK_WRCLK 163 -#define IMX8MP_CLK_IPP_DO_CLKO1 164 -#define IMX8MP_CLK_IPP_DO_CLKO2 165 -#define IMX8MP_CLK_HDMI_FDCC_TST 166 -#define IMX8MP_CLK_HDMI_24M 167 -#define IMX8MP_CLK_HDMI_REF_266M 168 -#define IMX8MP_CLK_USDHC3 169 -#define IMX8MP_CLK_MEDIA_CAM1_PIX 170 -#define IMX8MP_CLK_MEDIA_MIPI_PHY1_REF 171 -#define IMX8MP_CLK_MEDIA_DISP1_PIX 172 -#define IMX8MP_CLK_MEDIA_CAM2_PIX 173 -#define IMX8MP_CLK_MEDIA_LDB 174 -#define IMX8MP_CLK_MEDIA_MIPI_CSI2_ESC 175 -#define IMX8MP_CLK_MEDIA_MIPI_TEST_BYTE 178 -#define IMX8MP_CLK_ECSPI3 179 -#define IMX8MP_CLK_PDM 180 -#define IMX8MP_CLK_VPU_VC8000E 181 -#define IMX8MP_CLK_SAI7 182 -#define IMX8MP_CLK_GPC_ROOT 183 -#define IMX8MP_CLK_ANAMIX_ROOT 184 -#define IMX8MP_CLK_CPU_ROOT 185 -#define IMX8MP_CLK_CSU_ROOT 186 -#define IMX8MP_CLK_DEBUG_ROOT 187 -#define IMX8MP_CLK_DRAM1_ROOT 188 -#define IMX8MP_CLK_ECSPI1_ROOT 189 -#define IMX8MP_CLK_ECSPI2_ROOT 190 -#define IMX8MP_CLK_ECSPI3_ROOT 191 -#define IMX8MP_CLK_ENET1_ROOT 192 -#define IMX8MP_CLK_GPIO1_ROOT 193 -#define IMX8MP_CLK_GPIO2_ROOT 194 -#define IMX8MP_CLK_GPIO3_ROOT 195 -#define IMX8MP_CLK_GPIO4_ROOT 196 -#define IMX8MP_CLK_GPIO5_ROOT 197 -#define IMX8MP_CLK_GPT1_ROOT 198 -#define IMX8MP_CLK_GPT2_ROOT 199 -#define IMX8MP_CLK_GPT3_ROOT 200 -#define IMX8MP_CLK_GPT4_ROOT 201 -#define IMX8MP_CLK_GPT5_ROOT 202 -#define IMX8MP_CLK_GPT6_ROOT 203 -#define IMX8MP_CLK_HS_ROOT 204 -#define IMX8MP_CLK_I2C1_ROOT 205 -#define IMX8MP_CLK_I2C2_ROOT 206 -#define IMX8MP_CLK_I2C3_ROOT 207 -#define IMX8MP_CLK_I2C4_ROOT 208 -#define IMX8MP_CLK_IOMUX_ROOT 209 -#define IMX8MP_CLK_IPMUX1_ROOT 210 -#define IMX8MP_CLK_IPMUX2_ROOT 211 -#define IMX8MP_CLK_IPMUX3_ROOT 212 -#define IMX8MP_CLK_MU_ROOT 213 -#define IMX8MP_CLK_OCOTP_ROOT 214 -#define IMX8MP_CLK_OCRAM_ROOT 215 -#define IMX8MP_CLK_OCRAM_S_ROOT 216 -#define IMX8MP_CLK_PCIE_ROOT 217 -#define IMX8MP_CLK_PERFMON1_ROOT 218 -#define IMX8MP_CLK_PERFMON2_ROOT 219 -#define IMX8MP_CLK_PWM1_ROOT 220 -#define IMX8MP_CLK_PWM2_ROOT 221 -#define IMX8MP_CLK_PWM3_ROOT 222 -#define IMX8MP_CLK_PWM4_ROOT 223 -#define IMX8MP_CLK_QOS_ROOT 224 -#define IMX8MP_CLK_QOS_ENET_ROOT 225 -#define IMX8MP_CLK_QSPI_ROOT 226 -#define IMX8MP_CLK_NAND_ROOT 227 -#define IMX8MP_CLK_NAND_USDHC_BUS_RAWNAND_CLK 228 -#define IMX8MP_CLK_RDC_ROOT 229 -#define IMX8MP_CLK_ROM_ROOT 230 -#define IMX8MP_CLK_I2C5_ROOT 231 -#define IMX8MP_CLK_I2C6_ROOT 232 -#define IMX8MP_CLK_CAN1_ROOT 233 -#define IMX8MP_CLK_CAN2_ROOT 234 -#define IMX8MP_CLK_SCTR_ROOT 235 -#define IMX8MP_CLK_SDMA1_ROOT 236 -#define IMX8MP_CLK_ENET_QOS_ROOT 237 -#define IMX8MP_CLK_SEC_DEBUG_ROOT 238 -#define IMX8MP_CLK_SEMA1_ROOT 239 -#define IMX8MP_CLK_SEMA2_ROOT 240 -#define IMX8MP_CLK_IRQ_STEER_ROOT 241 -#define IMX8MP_CLK_SIM_ENET_ROOT 242 -#define IMX8MP_CLK_SIM_M_ROOT 243 -#define IMX8MP_CLK_SIM_MAIN_ROOT 244 -#define IMX8MP_CLK_SIM_S_ROOT 245 -#define IMX8MP_CLK_SIM_WAKEUP_ROOT 246 -#define IMX8MP_CLK_GPU2D_ROOT 247 -#define IMX8MP_CLK_GPU3D_ROOT 248 -#define IMX8MP_CLK_SNVS_ROOT 249 -#define IMX8MP_CLK_TRACE_ROOT 250 -#define IMX8MP_CLK_UART1_ROOT 251 -#define IMX8MP_CLK_UART2_ROOT 252 -#define IMX8MP_CLK_UART3_ROOT 253 -#define IMX8MP_CLK_UART4_ROOT 254 -#define IMX8MP_CLK_USB_ROOT 255 -#define IMX8MP_CLK_USB_PHY_ROOT 256 -#define IMX8MP_CLK_USDHC1_ROOT 257 -#define IMX8MP_CLK_USDHC2_ROOT 258 -#define IMX8MP_CLK_WDOG1_ROOT 259 -#define IMX8MP_CLK_WDOG2_ROOT 260 -#define IMX8MP_CLK_WDOG3_ROOT 261 -#define IMX8MP_CLK_VPU_G1_ROOT 262 -#define IMX8MP_CLK_GPU_ROOT 263 -#define IMX8MP_CLK_NOC_WRAPPER_ROOT 264 -#define IMX8MP_CLK_VPU_VC8KE_ROOT 265 -#define IMX8MP_CLK_VPU_G2_ROOT 266 -#define IMX8MP_CLK_NPU_ROOT 267 -#define IMX8MP_CLK_HSIO_ROOT 268 -#define IMX8MP_CLK_MEDIA_APB_ROOT 269 -#define IMX8MP_CLK_MEDIA_AXI_ROOT 270 -#define IMX8MP_CLK_MEDIA_CAM1_PIX_ROOT 271 -#define IMX8MP_CLK_MEDIA_CAM2_PIX_ROOT 272 -#define IMX8MP_CLK_MEDIA_DISP1_PIX_ROOT 273 -#define IMX8MP_CLK_MEDIA_DISP2_PIX_ROOT 274 -#define IMX8MP_CLK_MEDIA_MIPI_PHY1_REF_ROOT 275 -#define IMX8MP_CLK_MEDIA_ISP_ROOT 276 -#define IMX8MP_CLK_USDHC3_ROOT 277 -#define IMX8MP_CLK_HDMI_ROOT 278 -#define IMX8MP_CLK_XTAL_ROOT 279 -#define IMX8MP_CLK_PLL_ROOT 280 -#define IMX8MP_CLK_TSENSOR_ROOT 281 -#define IMX8MP_CLK_VPU_ROOT 282 -#define IMX8MP_CLK_MRPR_ROOT 283 -#define IMX8MP_CLK_AUDIO_ROOT 284 -#define IMX8MP_CLK_DRAM_ALT_ROOT 285 -#define IMX8MP_CLK_DRAM_CORE 286 -#define IMX8MP_CLK_ARM 287 -#define IMX8MP_CLK_A53_CORE 288 - -#define IMX8MP_SYS_PLL1_40M_CG 289 -#define IMX8MP_SYS_PLL1_80M_CG 290 -#define IMX8MP_SYS_PLL1_100M_CG 291 -#define IMX8MP_SYS_PLL1_133M_CG 292 -#define IMX8MP_SYS_PLL1_160M_CG 293 -#define IMX8MP_SYS_PLL1_200M_CG 294 -#define IMX8MP_SYS_PLL1_266M_CG 295 -#define IMX8MP_SYS_PLL1_400M_CG 296 -#define IMX8MP_SYS_PLL2_50M_CG 297 -#define IMX8MP_SYS_PLL2_100M_CG 298 -#define IMX8MP_SYS_PLL2_125M_CG 299 -#define IMX8MP_SYS_PLL2_166M_CG 300 -#define IMX8MP_SYS_PLL2_200M_CG 301 -#define IMX8MP_SYS_PLL2_250M_CG 302 -#define IMX8MP_SYS_PLL2_333M_CG 303 -#define IMX8MP_SYS_PLL2_500M_CG 304 - -#define IMX8MP_CLK_M7_CORE 305 -#define IMX8MP_CLK_ML_CORE 306 -#define IMX8MP_CLK_GPU3D_CORE 307 -#define IMX8MP_CLK_GPU3D_SHADER_CORE 308 -#define IMX8MP_CLK_GPU2D_CORE 309 -#define IMX8MP_CLK_AUDIO_AXI 310 -#define IMX8MP_CLK_HSIO_AXI 311 -#define IMX8MP_CLK_MEDIA_ISP 312 -#define IMX8MP_CLK_MEDIA_DISP2_PIX 313 -#define IMX8MP_CLK_CLKOUT1_SEL 314 -#define IMX8MP_CLK_CLKOUT1_DIV 315 -#define IMX8MP_CLK_CLKOUT1 316 -#define IMX8MP_CLK_CLKOUT2_SEL 317 -#define IMX8MP_CLK_CLKOUT2_DIV 318 -#define IMX8MP_CLK_CLKOUT2 319 -#define IMX8MP_CLK_USB_SUSP 320 -#define IMX8MP_CLK_AUDIO_AHB_ROOT IMX8MP_CLK_AUDIO_ROOT -#define IMX8MP_CLK_AUDIO_AXI_ROOT 321 -#define IMX8MP_CLK_SAI1_ROOT 322 -#define IMX8MP_CLK_SAI2_ROOT 323 -#define IMX8MP_CLK_SAI3_ROOT 324 -#define IMX8MP_CLK_SAI5_ROOT 325 -#define IMX8MP_CLK_SAI6_ROOT 326 -#define IMX8MP_CLK_SAI7_ROOT 327 -#define IMX8MP_CLK_PDM_ROOT 328 -#define IMX8MP_CLK_MEDIA_LDB_ROOT 329 -#define IMX8MP_CLK_END 330 - -#define IMX8MP_CLK_AUDIOMIX_SAI1_IPG 0 -#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1 1 -#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK2 2 -#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK3 3 -#define IMX8MP_CLK_AUDIOMIX_SAI2_IPG 4 -#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1 5 -#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK2 6 -#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK3 7 -#define IMX8MP_CLK_AUDIOMIX_SAI3_IPG 8 -#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1 9 -#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK2 10 -#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK3 11 -#define IMX8MP_CLK_AUDIOMIX_SAI5_IPG 12 -#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK1 13 -#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK2 14 -#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK3 15 -#define IMX8MP_CLK_AUDIOMIX_SAI6_IPG 16 -#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK1 17 -#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK2 18 -#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK3 19 -#define IMX8MP_CLK_AUDIOMIX_SAI7_IPG 20 -#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK1 21 -#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK2 22 -#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK3 23 -#define IMX8MP_CLK_AUDIOMIX_ASRC_IPG 24 -#define IMX8MP_CLK_AUDIOMIX_PDM_IPG 25 -#define IMX8MP_CLK_AUDIOMIX_SDMA2_ROOT 26 -#define IMX8MP_CLK_AUDIOMIX_SDMA3_ROOT 27 -#define IMX8MP_CLK_AUDIOMIX_SPBA2_ROOT 28 -#define IMX8MP_CLK_AUDIOMIX_DSP_ROOT 29 -#define IMX8MP_CLK_AUDIOMIX_DSPDBG_ROOT 30 -#define IMX8MP_CLK_AUDIOMIX_EARC_IPG 31 -#define IMX8MP_CLK_AUDIOMIX_OCRAMA_IPG 32 -#define IMX8MP_CLK_AUDIOMIX_AUD2HTX_IPG 33 -#define IMX8MP_CLK_AUDIOMIX_EDMA_ROOT 34 -#define IMX8MP_CLK_AUDIOMIX_AUDPLL_ROOT 35 -#define IMX8MP_CLK_AUDIOMIX_MU2_ROOT 36 -#define IMX8MP_CLK_AUDIOMIX_MU3_ROOT 37 -#define IMX8MP_CLK_AUDIOMIX_EARC_PHY 38 -#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1_SEL 40 -#define IMX8MP_CLK_AUDIOMIX_SAI1_MCLK2_SEL 41 -#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK1_SEL 42 -#define IMX8MP_CLK_AUDIOMIX_SAI2_MCLK2_SEL 43 -#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1_SEL 44 -#define IMX8MP_CLK_AUDIOMIX_SAI3_MCLK2_SEL 45 -#define IMX8MP_CLK_AUDIOMIX_SAI4_MCLK1_SEL 46 -#define IMX8MP_CLK_AUDIOMIX_SAI4_MCLK2_SEL 47 -#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK1_SEL 48 -#define IMX8MP_CLK_AUDIOMIX_SAI5_MCLK2_SEL 49 -#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK1_SEL 50 -#define IMX8MP_CLK_AUDIOMIX_SAI6_MCLK2_SEL 51 -#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK1_SEL 52 -#define IMX8MP_CLK_AUDIOMIX_SAI7_MCLK2_SEL 53 -#define IMX8MP_CLK_AUDIOMIX_PDM_SEL 54 -#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_REF_SEL 55 -#define IMX8MP_CLK_AUDIOMIX_SAI_PLL 56 -#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_BYPASS 57 -#define IMX8MP_CLK_AUDIOMIX_SAI_PLL_OUT 58 - -#define IMX8MP_CLK_AUDIOMIX_END 59 - -#endif diff --git a/include/dt-bindings/clock/imx8mq-clock.h b/include/dt-bindings/clock/imx8mq-clock.h deleted file mode 100644 index afa74d7ba100..000000000000 --- a/include/dt-bindings/clock/imx8mq-clock.h +++ /dev/null @@ -1,431 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright 2016 Freescale Semiconductor, Inc. - * Copyright 2017 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX8MQ_H -#define __DT_BINDINGS_CLOCK_IMX8MQ_H - -#define IMX8MQ_CLK_DUMMY 0 -#define IMX8MQ_CLK_32K 1 -#define IMX8MQ_CLK_25M 2 -#define IMX8MQ_CLK_27M 3 -#define IMX8MQ_CLK_EXT1 4 -#define IMX8MQ_CLK_EXT2 5 -#define IMX8MQ_CLK_EXT3 6 -#define IMX8MQ_CLK_EXT4 7 - -/* ANAMIX PLL clocks */ -/* FRAC PLLs */ -/* ARM PLL */ -#define IMX8MQ_ARM_PLL_REF_SEL 8 -#define IMX8MQ_ARM_PLL_REF_DIV 9 -#define IMX8MQ_ARM_PLL 10 -#define IMX8MQ_ARM_PLL_BYPASS 11 -#define IMX8MQ_ARM_PLL_OUT 12 - -/* GPU PLL */ -#define IMX8MQ_GPU_PLL_REF_SEL 13 -#define IMX8MQ_GPU_PLL_REF_DIV 14 -#define IMX8MQ_GPU_PLL 15 -#define IMX8MQ_GPU_PLL_BYPASS 16 -#define IMX8MQ_GPU_PLL_OUT 17 - -/* VPU PLL */ -#define IMX8MQ_VPU_PLL_REF_SEL 18 -#define IMX8MQ_VPU_PLL_REF_DIV 19 -#define IMX8MQ_VPU_PLL 20 -#define IMX8MQ_VPU_PLL_BYPASS 21 -#define IMX8MQ_VPU_PLL_OUT 22 - -/* AUDIO PLL1 */ -#define IMX8MQ_AUDIO_PLL1_REF_SEL 23 -#define IMX8MQ_AUDIO_PLL1_REF_DIV 24 -#define IMX8MQ_AUDIO_PLL1 25 -#define IMX8MQ_AUDIO_PLL1_BYPASS 26 -#define IMX8MQ_AUDIO_PLL1_OUT 27 - -/* AUDIO PLL2 */ -#define IMX8MQ_AUDIO_PLL2_REF_SEL 28 -#define IMX8MQ_AUDIO_PLL2_REF_DIV 29 -#define IMX8MQ_AUDIO_PLL2 30 -#define IMX8MQ_AUDIO_PLL2_BYPASS 31 -#define IMX8MQ_AUDIO_PLL2_OUT 32 - -/* VIDEO PLL1 */ -#define IMX8MQ_VIDEO_PLL1_REF_SEL 33 -#define IMX8MQ_VIDEO_PLL1_REF_DIV 34 -#define IMX8MQ_VIDEO_PLL1 35 -#define IMX8MQ_VIDEO_PLL1_BYPASS 36 -#define IMX8MQ_VIDEO_PLL1_OUT 37 - -/* SYS1 PLL */ -#define IMX8MQ_SYS1_PLL1_REF_SEL 38 -#define IMX8MQ_SYS1_PLL1_REF_DIV 39 -#define IMX8MQ_SYS1_PLL1 40 -#define IMX8MQ_SYS1_PLL1_OUT 41 -#define IMX8MQ_SYS1_PLL1_OUT_DIV 42 -#define IMX8MQ_SYS1_PLL2 43 -#define IMX8MQ_SYS1_PLL2_DIV 44 -#define IMX8MQ_SYS1_PLL2_OUT 45 - -/* SYS2 PLL */ -#define IMX8MQ_SYS2_PLL1_REF_SEL 46 -#define IMX8MQ_SYS2_PLL1_REF_DIV 47 -#define IMX8MQ_SYS2_PLL1 48 -#define IMX8MQ_SYS2_PLL1_OUT 49 -#define IMX8MQ_SYS2_PLL1_OUT_DIV 50 -#define IMX8MQ_SYS2_PLL2 51 -#define IMX8MQ_SYS2_PLL2_DIV 52 -#define IMX8MQ_SYS2_PLL2_OUT 53 - -/* SYS3 PLL */ -#define IMX8MQ_SYS3_PLL1_REF_SEL 54 -#define IMX8MQ_SYS3_PLL1_REF_DIV 55 -#define IMX8MQ_SYS3_PLL1 56 -#define IMX8MQ_SYS3_PLL1_OUT 57 -#define IMX8MQ_SYS3_PLL1_OUT_DIV 58 -#define IMX8MQ_SYS3_PLL2 59 -#define IMX8MQ_SYS3_PLL2_DIV 60 -#define IMX8MQ_SYS3_PLL2_OUT 61 - -/* DRAM PLL */ -#define IMX8MQ_DRAM_PLL1_REF_SEL 62 -#define IMX8MQ_DRAM_PLL1_REF_DIV 63 -#define IMX8MQ_DRAM_PLL1 64 -#define IMX8MQ_DRAM_PLL1_OUT 65 -#define IMX8MQ_DRAM_PLL1_OUT_DIV 66 -#define IMX8MQ_DRAM_PLL2 67 -#define IMX8MQ_DRAM_PLL2_DIV 68 -#define IMX8MQ_DRAM_PLL2_OUT 69 - -/* SYS PLL DIV */ -#define IMX8MQ_SYS1_PLL_40M 70 -#define IMX8MQ_SYS1_PLL_80M 71 -#define IMX8MQ_SYS1_PLL_100M 72 -#define IMX8MQ_SYS1_PLL_133M 73 -#define IMX8MQ_SYS1_PLL_160M 74 -#define IMX8MQ_SYS1_PLL_200M 75 -#define IMX8MQ_SYS1_PLL_266M 76 -#define IMX8MQ_SYS1_PLL_400M 77 -#define IMX8MQ_SYS1_PLL_800M 78 - -#define IMX8MQ_SYS2_PLL_50M 79 -#define IMX8MQ_SYS2_PLL_100M 80 -#define IMX8MQ_SYS2_PLL_125M 81 -#define IMX8MQ_SYS2_PLL_166M 82 -#define IMX8MQ_SYS2_PLL_200M 83 -#define IMX8MQ_SYS2_PLL_250M 84 -#define IMX8MQ_SYS2_PLL_333M 85 -#define IMX8MQ_SYS2_PLL_500M 86 -#define IMX8MQ_SYS2_PLL_1000M 87 - -/* CCM ROOT clocks */ -/* A53 */ -#define IMX8MQ_CLK_A53_SRC 88 -#define IMX8MQ_CLK_A53_CG 89 -#define IMX8MQ_CLK_A53_DIV 90 -/* M4 */ -#define IMX8MQ_CLK_M4_SRC 91 -#define IMX8MQ_CLK_M4_CG 92 -#define IMX8MQ_CLK_M4_DIV 93 -/* VPU */ -#define IMX8MQ_CLK_VPU_SRC 94 -#define IMX8MQ_CLK_VPU_CG 95 -#define IMX8MQ_CLK_VPU_DIV 96 -/* GPU CORE */ -#define IMX8MQ_CLK_GPU_CORE_SRC 97 -#define IMX8MQ_CLK_GPU_CORE_CG 98 -#define IMX8MQ_CLK_GPU_CORE_DIV 99 -/* GPU SHADER */ -#define IMX8MQ_CLK_GPU_SHADER_SRC 100 -#define IMX8MQ_CLK_GPU_SHADER_CG 101 -#define IMX8MQ_CLK_GPU_SHADER_DIV 102 - -/* BUS TYPE */ -/* MAIN AXI */ -#define IMX8MQ_CLK_MAIN_AXI 103 -/* ENET AXI */ -#define IMX8MQ_CLK_ENET_AXI 104 -/* NAND_USDHC_BUS */ -#define IMX8MQ_CLK_NAND_USDHC_BUS 105 -/* VPU BUS */ -#define IMX8MQ_CLK_VPU_BUS 106 -/* DISP_AXI */ -#define IMX8MQ_CLK_DISP_AXI 107 -/* DISP APB */ -#define IMX8MQ_CLK_DISP_APB 108 -/* DISP RTRM */ -#define IMX8MQ_CLK_DISP_RTRM 109 -/* USB_BUS */ -#define IMX8MQ_CLK_USB_BUS 110 -/* GPU_AXI */ -#define IMX8MQ_CLK_GPU_AXI 111 -/* GPU_AHB */ -#define IMX8MQ_CLK_GPU_AHB 112 -/* NOC */ -#define IMX8MQ_CLK_NOC 113 -/* NOC_APB */ -#define IMX8MQ_CLK_NOC_APB 115 - -/* AHB */ -#define IMX8MQ_CLK_AHB 116 -/* AUDIO AHB */ -#define IMX8MQ_CLK_AUDIO_AHB 117 - -/* DRAM_ALT */ -#define IMX8MQ_CLK_DRAM_ALT 118 -/* DRAM APB */ -#define IMX8MQ_CLK_DRAM_APB 119 -/* VPU_G1 */ -#define IMX8MQ_CLK_VPU_G1 120 -/* VPU_G2 */ -#define IMX8MQ_CLK_VPU_G2 121 -/* DISP_DTRC */ -#define IMX8MQ_CLK_DISP_DTRC 122 -/* DISP_DC8000 */ -#define IMX8MQ_CLK_DISP_DC8000 123 -/* PCIE_CTRL */ -#define IMX8MQ_CLK_PCIE1_CTRL 124 -/* PCIE_PHY */ -#define IMX8MQ_CLK_PCIE1_PHY 125 -/* PCIE_AUX */ -#define IMX8MQ_CLK_PCIE1_AUX 126 -/* DC_PIXEL */ -#define IMX8MQ_CLK_DC_PIXEL 127 -/* LCDIF_PIXEL */ -#define IMX8MQ_CLK_LCDIF_PIXEL 128 -/* SAI1~6 */ -#define IMX8MQ_CLK_SAI1 129 - -#define IMX8MQ_CLK_SAI2 130 - -#define IMX8MQ_CLK_SAI3 131 - -#define IMX8MQ_CLK_SAI4 132 - -#define IMX8MQ_CLK_SAI5 133 - -#define IMX8MQ_CLK_SAI6 134 -/* SPDIF1 */ -#define IMX8MQ_CLK_SPDIF1 135 -/* SPDIF2 */ -#define IMX8MQ_CLK_SPDIF2 136 -/* ENET_REF */ -#define IMX8MQ_CLK_ENET_REF 137 -/* ENET_TIMER */ -#define IMX8MQ_CLK_ENET_TIMER 138 -/* ENET_PHY */ -#define IMX8MQ_CLK_ENET_PHY_REF 139 -/* NAND */ -#define IMX8MQ_CLK_NAND 140 -/* QSPI */ -#define IMX8MQ_CLK_QSPI 141 -/* USDHC1 */ -#define IMX8MQ_CLK_USDHC1 142 -/* USDHC2 */ -#define IMX8MQ_CLK_USDHC2 143 -/* I2C1 */ -#define IMX8MQ_CLK_I2C1 144 -/* I2C2 */ -#define IMX8MQ_CLK_I2C2 145 -/* I2C3 */ -#define IMX8MQ_CLK_I2C3 146 -/* I2C4 */ -#define IMX8MQ_CLK_I2C4 147 -/* UART1 */ -#define IMX8MQ_CLK_UART1 148 -/* UART2 */ -#define IMX8MQ_CLK_UART2 149 -/* UART3 */ -#define IMX8MQ_CLK_UART3 150 -/* UART4 */ -#define IMX8MQ_CLK_UART4 151 -/* USB_CORE_REF */ -#define IMX8MQ_CLK_USB_CORE_REF 152 -/* USB_PHY_REF */ -#define IMX8MQ_CLK_USB_PHY_REF 153 -/* ECSPI1 */ -#define IMX8MQ_CLK_ECSPI1 154 -/* ECSPI2 */ -#define IMX8MQ_CLK_ECSPI2 155 -/* PWM1 */ -#define IMX8MQ_CLK_PWM1 156 -/* PWM2 */ -#define IMX8MQ_CLK_PWM2 157 -/* PWM3 */ -#define IMX8MQ_CLK_PWM3 158 -/* PWM4 */ -#define IMX8MQ_CLK_PWM4 159 -/* GPT1 */ -#define IMX8MQ_CLK_GPT1 160 -/* WDOG */ -#define IMX8MQ_CLK_WDOG 161 -/* WRCLK */ -#define IMX8MQ_CLK_WRCLK 162 -/* DSI_CORE */ -#define IMX8MQ_CLK_DSI_CORE 163 -/* DSI_PHY */ -#define IMX8MQ_CLK_DSI_PHY_REF 164 -/* DSI_DBI */ -#define IMX8MQ_CLK_DSI_DBI 165 -/*DSI_ESC */ -#define IMX8MQ_CLK_DSI_ESC 166 -/* CSI1_CORE */ -#define IMX8MQ_CLK_CSI1_CORE 167 -/* CSI1_PHY */ -#define IMX8MQ_CLK_CSI1_PHY_REF 168 -/* CSI_ESC */ -#define IMX8MQ_CLK_CSI1_ESC 169 -/* CSI2_CORE */ -#define IMX8MQ_CLK_CSI2_CORE 170 -/* CSI2_PHY */ -#define IMX8MQ_CLK_CSI2_PHY_REF 171 -/* CSI2_ESC */ -#define IMX8MQ_CLK_CSI2_ESC 172 -/* PCIE2_CTRL */ -#define IMX8MQ_CLK_PCIE2_CTRL 173 -/* PCIE2_PHY */ -#define IMX8MQ_CLK_PCIE2_PHY 174 -/* PCIE2_AUX */ -#define IMX8MQ_CLK_PCIE2_AUX 175 -/* ECSPI3 */ -#define IMX8MQ_CLK_ECSPI3 176 - -/* CCGR clocks */ -#define IMX8MQ_CLK_A53_ROOT 177 -#define IMX8MQ_CLK_DRAM_ROOT 178 -#define IMX8MQ_CLK_ECSPI1_ROOT 179 -#define IMX8MQ_CLK_ECSPI2_ROOT 180 -#define IMX8MQ_CLK_ECSPI3_ROOT 181 -#define IMX8MQ_CLK_ENET1_ROOT 182 -#define IMX8MQ_CLK_GPT1_ROOT 183 -#define IMX8MQ_CLK_I2C1_ROOT 184 -#define IMX8MQ_CLK_I2C2_ROOT 185 -#define IMX8MQ_CLK_I2C3_ROOT 186 -#define IMX8MQ_CLK_I2C4_ROOT 187 -#define IMX8MQ_CLK_M4_ROOT 188 -#define IMX8MQ_CLK_PCIE1_ROOT 189 -#define IMX8MQ_CLK_PCIE2_ROOT 190 -#define IMX8MQ_CLK_PWM1_ROOT 191 -#define IMX8MQ_CLK_PWM2_ROOT 192 -#define IMX8MQ_CLK_PWM3_ROOT 193 -#define IMX8MQ_CLK_PWM4_ROOT 194 -#define IMX8MQ_CLK_QSPI_ROOT 195 -#define IMX8MQ_CLK_SAI1_ROOT 196 -#define IMX8MQ_CLK_SAI2_ROOT 197 -#define IMX8MQ_CLK_SAI3_ROOT 198 -#define IMX8MQ_CLK_SAI4_ROOT 199 -#define IMX8MQ_CLK_SAI5_ROOT 200 -#define IMX8MQ_CLK_SAI6_ROOT 201 -#define IMX8MQ_CLK_UART1_ROOT 202 -#define IMX8MQ_CLK_UART2_ROOT 203 -#define IMX8MQ_CLK_UART3_ROOT 204 -#define IMX8MQ_CLK_UART4_ROOT 205 -#define IMX8MQ_CLK_USB1_CTRL_ROOT 206 -#define IMX8MQ_CLK_USB2_CTRL_ROOT 207 -#define IMX8MQ_CLK_USB1_PHY_ROOT 208 -#define IMX8MQ_CLK_USB2_PHY_ROOT 209 -#define IMX8MQ_CLK_USDHC1_ROOT 210 -#define IMX8MQ_CLK_USDHC2_ROOT 211 -#define IMX8MQ_CLK_WDOG1_ROOT 212 -#define IMX8MQ_CLK_WDOG2_ROOT 213 -#define IMX8MQ_CLK_WDOG3_ROOT 214 -#define IMX8MQ_CLK_GPU_ROOT 215 -#define IMX8MQ_CLK_HEVC_ROOT 216 -#define IMX8MQ_CLK_AVC_ROOT 217 -#define IMX8MQ_CLK_VP9_ROOT 218 -#define IMX8MQ_CLK_HEVC_INTER_ROOT 219 -#define IMX8MQ_CLK_DISP_ROOT 220 -#define IMX8MQ_CLK_HDMI_ROOT 221 -#define IMX8MQ_CLK_HDMI_PHY_ROOT 222 -#define IMX8MQ_CLK_VPU_DEC_ROOT 223 -#define IMX8MQ_CLK_CSI1_ROOT 224 -#define IMX8MQ_CLK_CSI2_ROOT 225 -#define IMX8MQ_CLK_RAWNAND_ROOT 226 -#define IMX8MQ_CLK_SDMA1_ROOT 227 -#define IMX8MQ_CLK_SDMA2_ROOT 228 -#define IMX8MQ_CLK_VPU_G1_ROOT 229 -#define IMX8MQ_CLK_VPU_G2_ROOT 230 - -/* SCCG PLL GATE */ -#define IMX8MQ_SYS1_PLL_OUT 231 -#define IMX8MQ_SYS2_PLL_OUT 232 -#define IMX8MQ_SYS3_PLL_OUT 233 -#define IMX8MQ_DRAM_PLL_OUT 234 - -#define IMX8MQ_GPT_3M_CLK 235 - -#define IMX8MQ_CLK_IPG_ROOT 236 -#define IMX8MQ_CLK_IPG_AUDIO_ROOT 237 -#define IMX8MQ_CLK_SAI1_IPG 238 -#define IMX8MQ_CLK_SAI2_IPG 239 -#define IMX8MQ_CLK_SAI3_IPG 240 -#define IMX8MQ_CLK_SAI4_IPG 241 -#define IMX8MQ_CLK_SAI5_IPG 242 -#define IMX8MQ_CLK_SAI6_IPG 243 - -/* DSI AHB/IPG clocks */ -/* rxesc clock */ -#define IMX8MQ_CLK_DSI_AHB 244 -/* txesc clock */ -#define IMX8MQ_CLK_DSI_IPG_DIV 245 - -#define IMX8MQ_CLK_TMU_ROOT 246 - -/* Display root clocks */ -#define IMX8MQ_CLK_DISP_AXI_ROOT 247 -#define IMX8MQ_CLK_DISP_APB_ROOT 248 -#define IMX8MQ_CLK_DISP_RTRM_ROOT 249 - -#define IMX8MQ_CLK_OCOTP_ROOT 250 - -#define IMX8MQ_CLK_DRAM_ALT_ROOT 251 -#define IMX8MQ_CLK_DRAM_CORE 252 - -#define IMX8MQ_CLK_MU_ROOT 253 -#define IMX8MQ_VIDEO2_PLL_OUT 254 - -#define IMX8MQ_CLK_CLKO2 255 - -#define IMX8MQ_CLK_NAND_USDHC_BUS_RAWNAND_CLK 256 - -#define IMX8MQ_CLK_CLKO1 257 -#define IMX8MQ_CLK_ARM 258 - -#define IMX8MQ_CLK_GPIO1_ROOT 259 -#define IMX8MQ_CLK_GPIO2_ROOT 260 -#define IMX8MQ_CLK_GPIO3_ROOT 261 -#define IMX8MQ_CLK_GPIO4_ROOT 262 -#define IMX8MQ_CLK_GPIO5_ROOT 263 - -#define IMX8MQ_CLK_SNVS_ROOT 264 -#define IMX8MQ_CLK_GIC 265 - -#define IMX8MQ_VIDEO2_PLL1_REF_SEL 266 - -#define IMX8MQ_CLK_GPU_CORE 285 -#define IMX8MQ_CLK_GPU_SHADER 286 -#define IMX8MQ_CLK_M4_CORE 287 -#define IMX8MQ_CLK_VPU_CORE 288 - -#define IMX8MQ_CLK_A53_CORE 289 - -#define IMX8MQ_CLK_MON_AUDIO_PLL1_DIV 290 -#define IMX8MQ_CLK_MON_AUDIO_PLL2_DIV 291 -#define IMX8MQ_CLK_MON_VIDEO_PLL1_DIV 292 -#define IMX8MQ_CLK_MON_GPU_PLL_DIV 293 -#define IMX8MQ_CLK_MON_VPU_PLL_DIV 294 -#define IMX8MQ_CLK_MON_ARM_PLL_DIV 295 -#define IMX8MQ_CLK_MON_SYS_PLL1_DIV 296 -#define IMX8MQ_CLK_MON_SYS_PLL2_DIV 297 -#define IMX8MQ_CLK_MON_SYS_PLL3_DIV 298 -#define IMX8MQ_CLK_MON_DRAM_PLL_DIV 299 -#define IMX8MQ_CLK_MON_VIDEO_PLL2_DIV 300 -#define IMX8MQ_CLK_MON_SEL 301 -#define IMX8MQ_CLK_MON_CLK2_OUT 302 - -#define IMX8MQ_CLK_END 303 - -#endif /* __DT_BINDINGS_CLOCK_IMX8MQ_H */ diff --git a/include/dt-bindings/clock/imx8ulp-clock.h b/include/dt-bindings/clock/imx8ulp-clock.h deleted file mode 100644 index 953ecfe8ebcc..000000000000 --- a/include/dt-bindings/clock/imx8ulp-clock.h +++ /dev/null @@ -1,258 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ -/* - * Copyright 2021 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX8ULP_H -#define __DT_BINDINGS_CLOCK_IMX8ULP_H - -#define IMX8ULP_CLK_DUMMY 0 - -/* CGC1 */ -#define IMX8ULP_CLK_SPLL2 5 -#define IMX8ULP_CLK_SPLL3 6 -#define IMX8ULP_CLK_A35_SEL 7 -#define IMX8ULP_CLK_A35_DIV 8 -#define IMX8ULP_CLK_SPLL2_PRE_SEL 9 -#define IMX8ULP_CLK_SPLL3_PRE_SEL 10 -#define IMX8ULP_CLK_SPLL3_PFD0 11 -#define IMX8ULP_CLK_SPLL3_PFD1 12 -#define IMX8ULP_CLK_SPLL3_PFD2 13 -#define IMX8ULP_CLK_SPLL3_PFD3 14 -#define IMX8ULP_CLK_SPLL3_PFD0_DIV1 15 -#define IMX8ULP_CLK_SPLL3_PFD0_DIV2 16 -#define IMX8ULP_CLK_SPLL3_PFD1_DIV1 17 -#define IMX8ULP_CLK_SPLL3_PFD1_DIV2 18 -#define IMX8ULP_CLK_SPLL3_PFD2_DIV1 19 -#define IMX8ULP_CLK_SPLL3_PFD2_DIV2 20 -#define IMX8ULP_CLK_SPLL3_PFD3_DIV1 21 -#define IMX8ULP_CLK_SPLL3_PFD3_DIV2 22 -#define IMX8ULP_CLK_NIC_SEL 23 -#define IMX8ULP_CLK_NIC_AD_DIVPLAT 24 -#define IMX8ULP_CLK_NIC_PER_DIVPLAT 25 -#define IMX8ULP_CLK_XBAR_SEL 26 -#define IMX8ULP_CLK_XBAR_AD_DIVPLAT 27 -#define IMX8ULP_CLK_XBAR_DIVBUS 28 -#define IMX8ULP_CLK_XBAR_AD_SLOW 29 -#define IMX8ULP_CLK_SOSC_DIV1 30 -#define IMX8ULP_CLK_SOSC_DIV2 31 -#define IMX8ULP_CLK_SOSC_DIV3 32 -#define IMX8ULP_CLK_FROSC_DIV1 33 -#define IMX8ULP_CLK_FROSC_DIV2 34 -#define IMX8ULP_CLK_FROSC_DIV3 35 -#define IMX8ULP_CLK_SPLL3_VCODIV 36 -#define IMX8ULP_CLK_SPLL3_PFD0_DIV1_GATE 37 -#define IMX8ULP_CLK_SPLL3_PFD0_DIV2_GATE 38 -#define IMX8ULP_CLK_SPLL3_PFD1_DIV1_GATE 39 -#define IMX8ULP_CLK_SPLL3_PFD1_DIV2_GATE 40 -#define IMX8ULP_CLK_SPLL3_PFD2_DIV1_GATE 41 -#define IMX8ULP_CLK_SPLL3_PFD2_DIV2_GATE 42 -#define IMX8ULP_CLK_SPLL3_PFD3_DIV1_GATE 43 -#define IMX8ULP_CLK_SPLL3_PFD3_DIV2_GATE 44 -#define IMX8ULP_CLK_SOSC_DIV1_GATE 45 -#define IMX8ULP_CLK_SOSC_DIV2_GATE 46 -#define IMX8ULP_CLK_SOSC_DIV3_GATE 47 -#define IMX8ULP_CLK_FROSC_DIV1_GATE 48 -#define IMX8ULP_CLK_FROSC_DIV2_GATE 49 -#define IMX8ULP_CLK_FROSC_DIV3_GATE 50 -#define IMX8ULP_CLK_SAI4_SEL 51 -#define IMX8ULP_CLK_SAI5_SEL 52 -#define IMX8ULP_CLK_AUD_CLK1 53 -#define IMX8ULP_CLK_ARM 54 -#define IMX8ULP_CLK_ENET_TS_SEL 55 - -#define IMX8ULP_CLK_CGC1_END 56 - -/* CGC2 */ -#define IMX8ULP_CLK_PLL4_PRE_SEL 0 -#define IMX8ULP_CLK_PLL4 1 -#define IMX8ULP_CLK_PLL4_VCODIV 2 -#define IMX8ULP_CLK_DDR_SEL 3 -#define IMX8ULP_CLK_DDR_DIV 4 -#define IMX8ULP_CLK_LPAV_AXI_SEL 5 -#define IMX8ULP_CLK_LPAV_AXI_DIV 6 -#define IMX8ULP_CLK_LPAV_AHB_DIV 7 -#define IMX8ULP_CLK_LPAV_BUS_DIV 8 -#define IMX8ULP_CLK_PLL4_PFD0 9 -#define IMX8ULP_CLK_PLL4_PFD1 10 -#define IMX8ULP_CLK_PLL4_PFD2 11 -#define IMX8ULP_CLK_PLL4_PFD3 12 -#define IMX8ULP_CLK_PLL4_PFD0_DIV1_GATE 13 -#define IMX8ULP_CLK_PLL4_PFD0_DIV2_GATE 14 -#define IMX8ULP_CLK_PLL4_PFD1_DIV1_GATE 15 -#define IMX8ULP_CLK_PLL4_PFD1_DIV2_GATE 16 -#define IMX8ULP_CLK_PLL4_PFD2_DIV1_GATE 17 -#define IMX8ULP_CLK_PLL4_PFD2_DIV2_GATE 18 -#define IMX8ULP_CLK_PLL4_PFD3_DIV1_GATE 19 -#define IMX8ULP_CLK_PLL4_PFD3_DIV2_GATE 20 -#define IMX8ULP_CLK_PLL4_PFD0_DIV1 21 -#define IMX8ULP_CLK_PLL4_PFD0_DIV2 22 -#define IMX8ULP_CLK_PLL4_PFD1_DIV1 23 -#define IMX8ULP_CLK_PLL4_PFD1_DIV2 24 -#define IMX8ULP_CLK_PLL4_PFD2_DIV1 25 -#define IMX8ULP_CLK_PLL4_PFD2_DIV2 26 -#define IMX8ULP_CLK_PLL4_PFD3_DIV1 27 -#define IMX8ULP_CLK_PLL4_PFD3_DIV2 28 -#define IMX8ULP_CLK_CGC2_SOSC_DIV1_GATE 29 -#define IMX8ULP_CLK_CGC2_SOSC_DIV2_GATE 30 -#define IMX8ULP_CLK_CGC2_SOSC_DIV3_GATE 31 -#define IMX8ULP_CLK_CGC2_SOSC_DIV1 32 -#define IMX8ULP_CLK_CGC2_SOSC_DIV2 33 -#define IMX8ULP_CLK_CGC2_SOSC_DIV3 34 -#define IMX8ULP_CLK_CGC2_FROSC_DIV1_GATE 35 -#define IMX8ULP_CLK_CGC2_FROSC_DIV2_GATE 36 -#define IMX8ULP_CLK_CGC2_FROSC_DIV3_GATE 37 -#define IMX8ULP_CLK_CGC2_FROSC_DIV1 38 -#define IMX8ULP_CLK_CGC2_FROSC_DIV2 39 -#define IMX8ULP_CLK_CGC2_FROSC_DIV3 40 -#define IMX8ULP_CLK_AUD_CLK2 41 -#define IMX8ULP_CLK_SAI6_SEL 42 -#define IMX8ULP_CLK_SAI7_SEL 43 -#define IMX8ULP_CLK_SPDIF_SEL 44 -#define IMX8ULP_CLK_HIFI_SEL 45 -#define IMX8ULP_CLK_HIFI_DIVCORE 46 -#define IMX8ULP_CLK_HIFI_DIVPLAT 47 -#define IMX8ULP_CLK_DSI_PHY_REF 48 - -#define IMX8ULP_CLK_CGC2_END 49 - -/* PCC3 */ -#define IMX8ULP_CLK_WDOG3 0 -#define IMX8ULP_CLK_WDOG4 1 -#define IMX8ULP_CLK_LPIT1 2 -#define IMX8ULP_CLK_TPM4 3 -#define IMX8ULP_CLK_TPM5 4 -#define IMX8ULP_CLK_FLEXIO1 5 -#define IMX8ULP_CLK_I3C2 6 -#define IMX8ULP_CLK_LPI2C4 7 -#define IMX8ULP_CLK_LPI2C5 8 -#define IMX8ULP_CLK_LPUART4 9 -#define IMX8ULP_CLK_LPUART5 10 -#define IMX8ULP_CLK_LPSPI4 11 -#define IMX8ULP_CLK_LPSPI5 12 -#define IMX8ULP_CLK_DMA1_MP 13 -#define IMX8ULP_CLK_DMA1_CH0 14 -#define IMX8ULP_CLK_DMA1_CH1 15 -#define IMX8ULP_CLK_DMA1_CH2 16 -#define IMX8ULP_CLK_DMA1_CH3 17 -#define IMX8ULP_CLK_DMA1_CH4 18 -#define IMX8ULP_CLK_DMA1_CH5 19 -#define IMX8ULP_CLK_DMA1_CH6 20 -#define IMX8ULP_CLK_DMA1_CH7 21 -#define IMX8ULP_CLK_DMA1_CH8 22 -#define IMX8ULP_CLK_DMA1_CH9 23 -#define IMX8ULP_CLK_DMA1_CH10 24 -#define IMX8ULP_CLK_DMA1_CH11 25 -#define IMX8ULP_CLK_DMA1_CH12 26 -#define IMX8ULP_CLK_DMA1_CH13 27 -#define IMX8ULP_CLK_DMA1_CH14 28 -#define IMX8ULP_CLK_DMA1_CH15 29 -#define IMX8ULP_CLK_DMA1_CH16 30 -#define IMX8ULP_CLK_DMA1_CH17 31 -#define IMX8ULP_CLK_DMA1_CH18 32 -#define IMX8ULP_CLK_DMA1_CH19 33 -#define IMX8ULP_CLK_DMA1_CH20 34 -#define IMX8ULP_CLK_DMA1_CH21 35 -#define IMX8ULP_CLK_DMA1_CH22 36 -#define IMX8ULP_CLK_DMA1_CH23 37 -#define IMX8ULP_CLK_DMA1_CH24 38 -#define IMX8ULP_CLK_DMA1_CH25 39 -#define IMX8ULP_CLK_DMA1_CH26 40 -#define IMX8ULP_CLK_DMA1_CH27 41 -#define IMX8ULP_CLK_DMA1_CH28 42 -#define IMX8ULP_CLK_DMA1_CH29 43 -#define IMX8ULP_CLK_DMA1_CH30 44 -#define IMX8ULP_CLK_DMA1_CH31 45 -#define IMX8ULP_CLK_MU3_A 46 -#define IMX8ULP_CLK_MU0_B 47 - -#define IMX8ULP_CLK_PCC3_END 48 - -/* PCC4 */ -#define IMX8ULP_CLK_FLEXSPI2 0 -#define IMX8ULP_CLK_TPM6 1 -#define IMX8ULP_CLK_TPM7 2 -#define IMX8ULP_CLK_LPI2C6 3 -#define IMX8ULP_CLK_LPI2C7 4 -#define IMX8ULP_CLK_LPUART6 5 -#define IMX8ULP_CLK_LPUART7 6 -#define IMX8ULP_CLK_SAI4 7 -#define IMX8ULP_CLK_SAI5 8 -#define IMX8ULP_CLK_PCTLE 9 -#define IMX8ULP_CLK_PCTLF 10 -#define IMX8ULP_CLK_USDHC0 11 -#define IMX8ULP_CLK_USDHC1 12 -#define IMX8ULP_CLK_USDHC2 13 -#define IMX8ULP_CLK_USB0 14 -#define IMX8ULP_CLK_USB0_PHY 15 -#define IMX8ULP_CLK_USB1 16 -#define IMX8ULP_CLK_USB1_PHY 17 -#define IMX8ULP_CLK_USB_XBAR 18 -#define IMX8ULP_CLK_ENET 19 -#define IMX8ULP_CLK_SFA1 20 -#define IMX8ULP_CLK_RGPIOE 21 -#define IMX8ULP_CLK_RGPIOF 22 - -#define IMX8ULP_CLK_PCC4_END 23 - -/* PCC5 */ -#define IMX8ULP_CLK_TPM8 0 -#define IMX8ULP_CLK_SAI6 1 -#define IMX8ULP_CLK_SAI7 2 -#define IMX8ULP_CLK_SPDIF 3 -#define IMX8ULP_CLK_ISI 4 -#define IMX8ULP_CLK_CSI_REGS 5 -#define IMX8ULP_CLK_PCTLD 6 -#define IMX8ULP_CLK_CSI 7 -#define IMX8ULP_CLK_DSI 8 -#define IMX8ULP_CLK_WDOG5 9 -#define IMX8ULP_CLK_EPDC 10 -#define IMX8ULP_CLK_PXP 11 -#define IMX8ULP_CLK_SFA2 12 -#define IMX8ULP_CLK_GPU2D 13 -#define IMX8ULP_CLK_GPU3D 14 -#define IMX8ULP_CLK_DC_NANO 15 -#define IMX8ULP_CLK_CSI_CLK_UI 16 -#define IMX8ULP_CLK_CSI_CLK_ESC 17 -#define IMX8ULP_CLK_RGPIOD 18 -#define IMX8ULP_CLK_DMA2_MP 19 -#define IMX8ULP_CLK_DMA2_CH0 20 -#define IMX8ULP_CLK_DMA2_CH1 21 -#define IMX8ULP_CLK_DMA2_CH2 22 -#define IMX8ULP_CLK_DMA2_CH3 23 -#define IMX8ULP_CLK_DMA2_CH4 24 -#define IMX8ULP_CLK_DMA2_CH5 25 -#define IMX8ULP_CLK_DMA2_CH6 26 -#define IMX8ULP_CLK_DMA2_CH7 27 -#define IMX8ULP_CLK_DMA2_CH8 28 -#define IMX8ULP_CLK_DMA2_CH9 29 -#define IMX8ULP_CLK_DMA2_CH10 30 -#define IMX8ULP_CLK_DMA2_CH11 31 -#define IMX8ULP_CLK_DMA2_CH12 32 -#define IMX8ULP_CLK_DMA2_CH13 33 -#define IMX8ULP_CLK_DMA2_CH14 34 -#define IMX8ULP_CLK_DMA2_CH15 35 -#define IMX8ULP_CLK_DMA2_CH16 36 -#define IMX8ULP_CLK_DMA2_CH17 37 -#define IMX8ULP_CLK_DMA2_CH18 38 -#define IMX8ULP_CLK_DMA2_CH19 39 -#define IMX8ULP_CLK_DMA2_CH20 40 -#define IMX8ULP_CLK_DMA2_CH21 41 -#define IMX8ULP_CLK_DMA2_CH22 42 -#define IMX8ULP_CLK_DMA2_CH23 43 -#define IMX8ULP_CLK_DMA2_CH24 44 -#define IMX8ULP_CLK_DMA2_CH25 45 -#define IMX8ULP_CLK_DMA2_CH26 46 -#define IMX8ULP_CLK_DMA2_CH27 47 -#define IMX8ULP_CLK_DMA2_CH28 48 -#define IMX8ULP_CLK_DMA2_CH29 49 -#define IMX8ULP_CLK_DMA2_CH30 50 -#define IMX8ULP_CLK_DMA2_CH31 51 -#define IMX8ULP_CLK_MU2_B 52 -#define IMX8ULP_CLK_MU3_B 53 -#define IMX8ULP_CLK_AVD_SIM 54 -#define IMX8ULP_CLK_DSI_TX_ESC 55 - -#define IMX8ULP_CLK_PCC5_END 56 - -#endif diff --git a/include/dt-bindings/clock/imx93-clock.h b/include/dt-bindings/clock/imx93-clock.h deleted file mode 100644 index 35a1f62053a5..000000000000 --- a/include/dt-bindings/clock/imx93-clock.h +++ /dev/null @@ -1,208 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ -/* - * Copyright 2022 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX93_CLK_H -#define __DT_BINDINGS_CLOCK_IMX93_CLK_H - -#define IMX93_CLK_DUMMY 0 -#define IMX93_CLK_24M 1 -#define IMX93_CLK_EXT1 2 -#define IMX93_CLK_SYS_PLL_PFD0 3 -#define IMX93_CLK_SYS_PLL_PFD0_DIV2 4 -#define IMX93_CLK_SYS_PLL_PFD1 5 -#define IMX93_CLK_SYS_PLL_PFD1_DIV2 6 -#define IMX93_CLK_SYS_PLL_PFD2 7 -#define IMX93_CLK_SYS_PLL_PFD2_DIV2 8 -#define IMX93_CLK_AUDIO_PLL 9 -#define IMX93_CLK_VIDEO_PLL 10 -#define IMX93_CLK_A55_PERIPH 11 -#define IMX93_CLK_A55_MTR_BUS 12 -#define IMX93_CLK_A55 13 -#define IMX93_CLK_M33 14 -#define IMX93_CLK_BUS_WAKEUP 15 -#define IMX93_CLK_BUS_AON 16 -#define IMX93_CLK_WAKEUP_AXI 17 -#define IMX93_CLK_SWO_TRACE 18 -#define IMX93_CLK_M33_SYSTICK 19 -#define IMX93_CLK_FLEXIO1 20 -#define IMX93_CLK_FLEXIO2 21 -#define IMX93_CLK_LPTMR1 24 -#define IMX93_CLK_LPTMR2 25 -#define IMX93_CLK_TPM2 27 -#define IMX93_CLK_TPM4 29 -#define IMX93_CLK_TPM5 30 -#define IMX93_CLK_TPM6 31 -#define IMX93_CLK_FLEXSPI1 32 -#define IMX93_CLK_CAN1 33 -#define IMX93_CLK_CAN2 34 -#define IMX93_CLK_LPUART1 35 -#define IMX93_CLK_LPUART2 36 -#define IMX93_CLK_LPUART3 37 -#define IMX93_CLK_LPUART4 38 -#define IMX93_CLK_LPUART5 39 -#define IMX93_CLK_LPUART6 40 -#define IMX93_CLK_LPUART7 41 -#define IMX93_CLK_LPUART8 42 -#define IMX93_CLK_LPI2C1 43 -#define IMX93_CLK_LPI2C2 44 -#define IMX93_CLK_LPI2C3 45 -#define IMX93_CLK_LPI2C4 46 -#define IMX93_CLK_LPI2C5 47 -#define IMX93_CLK_LPI2C6 48 -#define IMX93_CLK_LPI2C7 49 -#define IMX93_CLK_LPI2C8 50 -#define IMX93_CLK_LPSPI1 51 -#define IMX93_CLK_LPSPI2 52 -#define IMX93_CLK_LPSPI3 53 -#define IMX93_CLK_LPSPI4 54 -#define IMX93_CLK_LPSPI5 55 -#define IMX93_CLK_LPSPI6 56 -#define IMX93_CLK_LPSPI7 57 -#define IMX93_CLK_LPSPI8 58 -#define IMX93_CLK_I3C1 59 -#define IMX93_CLK_I3C2 60 -#define IMX93_CLK_USDHC1 61 -#define IMX93_CLK_USDHC2 62 -#define IMX93_CLK_USDHC3 63 -#define IMX93_CLK_SAI1 64 -#define IMX93_CLK_SAI2 65 -#define IMX93_CLK_SAI3 66 -#define IMX93_CLK_CCM_CKO1 67 -#define IMX93_CLK_CCM_CKO2 68 -#define IMX93_CLK_CCM_CKO3 69 -#define IMX93_CLK_CCM_CKO4 70 -#define IMX93_CLK_HSIO 71 -#define IMX93_CLK_HSIO_USB_TEST_60M 72 -#define IMX93_CLK_HSIO_ACSCAN_80M 73 -#define IMX93_CLK_HSIO_ACSCAN_480M 74 -#define IMX93_CLK_ML_APB 75 -#define IMX93_CLK_ML 76 -#define IMX93_CLK_MEDIA_AXI 77 -#define IMX93_CLK_MEDIA_APB 78 -#define IMX93_CLK_MEDIA_LDB 79 -#define IMX93_CLK_MEDIA_DISP_PIX 80 -#define IMX93_CLK_CAM_PIX 81 -#define IMX93_CLK_MIPI_TEST_BYTE 82 -#define IMX93_CLK_MIPI_PHY_CFG 83 -#define IMX93_CLK_ADC 84 -#define IMX93_CLK_PDM 85 -#define IMX93_CLK_TSTMR1 86 -#define IMX93_CLK_TSTMR2 87 -#define IMX93_CLK_MQS1 88 -#define IMX93_CLK_MQS2 89 -#define IMX93_CLK_AUDIO_XCVR 90 -#define IMX93_CLK_SPDIF 91 -#define IMX93_CLK_ENET 92 -#define IMX93_CLK_ENET_TIMER1 93 -#define IMX93_CLK_ENET_TIMER2 94 -#define IMX93_CLK_ENET_REF 95 -#define IMX93_CLK_ENET_REF_PHY 96 -#define IMX93_CLK_I3C1_SLOW 97 -#define IMX93_CLK_I3C2_SLOW 98 -#define IMX93_CLK_USB_PHY_BURUNIN 99 -#define IMX93_CLK_PAL_CAME_SCAN 100 -#define IMX93_CLK_A55_GATE 101 -#define IMX93_CLK_CM33_GATE 102 -#define IMX93_CLK_ADC1_GATE 103 -#define IMX93_CLK_WDOG1_GATE 104 -#define IMX93_CLK_WDOG2_GATE 105 -#define IMX93_CLK_WDOG3_GATE 106 -#define IMX93_CLK_WDOG4_GATE 107 -#define IMX93_CLK_WDOG5_GATE 108 -#define IMX93_CLK_SEMA1_GATE 109 -#define IMX93_CLK_SEMA2_GATE 110 -#define IMX93_CLK_MU_A_GATE 111 -#define IMX93_CLK_MU_B_GATE 112 -#define IMX93_CLK_EDMA1_GATE 113 -#define IMX93_CLK_EDMA2_GATE 114 -#define IMX93_CLK_FLEXSPI1_GATE 115 -#define IMX93_CLK_GPIO1_GATE 116 -#define IMX93_CLK_GPIO2_GATE 117 -#define IMX93_CLK_GPIO3_GATE 118 -#define IMX93_CLK_GPIO4_GATE 119 -#define IMX93_CLK_FLEXIO1_GATE 120 -#define IMX93_CLK_FLEXIO2_GATE 121 -#define IMX93_CLK_LPIT1_GATE 122 -#define IMX93_CLK_LPIT2_GATE 123 -#define IMX93_CLK_LPTMR1_GATE 124 -#define IMX93_CLK_LPTMR2_GATE 125 -#define IMX93_CLK_TPM1_GATE 126 -#define IMX93_CLK_TPM2_GATE 127 -#define IMX93_CLK_TPM3_GATE 128 -#define IMX93_CLK_TPM4_GATE 129 -#define IMX93_CLK_TPM5_GATE 130 -#define IMX93_CLK_TPM6_GATE 131 -#define IMX93_CLK_CAN1_GATE 132 -#define IMX93_CLK_CAN2_GATE 133 -#define IMX93_CLK_LPUART1_GATE 134 -#define IMX93_CLK_LPUART2_GATE 135 -#define IMX93_CLK_LPUART3_GATE 136 -#define IMX93_CLK_LPUART4_GATE 137 -#define IMX93_CLK_LPUART5_GATE 138 -#define IMX93_CLK_LPUART6_GATE 139 -#define IMX93_CLK_LPUART7_GATE 140 -#define IMX93_CLK_LPUART8_GATE 141 -#define IMX93_CLK_LPI2C1_GATE 142 -#define IMX93_CLK_LPI2C2_GATE 143 -#define IMX93_CLK_LPI2C3_GATE 144 -#define IMX93_CLK_LPI2C4_GATE 145 -#define IMX93_CLK_LPI2C5_GATE 146 -#define IMX93_CLK_LPI2C6_GATE 147 -#define IMX93_CLK_LPI2C7_GATE 148 -#define IMX93_CLK_LPI2C8_GATE 149 -#define IMX93_CLK_LPSPI1_GATE 150 -#define IMX93_CLK_LPSPI2_GATE 151 -#define IMX93_CLK_LPSPI3_GATE 152 -#define IMX93_CLK_LPSPI4_GATE 153 -#define IMX93_CLK_LPSPI5_GATE 154 -#define IMX93_CLK_LPSPI6_GATE 155 -#define IMX93_CLK_LPSPI7_GATE 156 -#define IMX93_CLK_LPSPI8_GATE 157 -#define IMX93_CLK_I3C1_GATE 158 -#define IMX93_CLK_I3C2_GATE 159 -#define IMX93_CLK_USDHC1_GATE 160 -#define IMX93_CLK_USDHC2_GATE 161 -#define IMX93_CLK_USDHC3_GATE 162 -#define IMX93_CLK_SAI1_GATE 163 -#define IMX93_CLK_SAI2_GATE 164 -#define IMX93_CLK_SAI3_GATE 165 -#define IMX93_CLK_MIPI_CSI_GATE 166 -#define IMX93_CLK_MIPI_DSI_GATE 167 -#define IMX93_CLK_LVDS_GATE 168 -#define IMX93_CLK_LCDIF_GATE 169 -#define IMX93_CLK_PXP_GATE 170 -#define IMX93_CLK_ISI_GATE 171 -#define IMX93_CLK_NIC_MEDIA_GATE 172 -#define IMX93_CLK_USB_CONTROLLER_GATE 173 -#define IMX93_CLK_USB_TEST_60M_GATE 174 -#define IMX93_CLK_HSIO_TROUT_24M_GATE 175 -#define IMX93_CLK_PDM_GATE 176 -#define IMX93_CLK_MQS1_GATE 177 -#define IMX93_CLK_MQS2_GATE 178 -#define IMX93_CLK_AUD_XCVR_GATE 179 -#define IMX93_CLK_SPDIF_GATE 180 -#define IMX93_CLK_HSIO_32K_GATE 181 -#define IMX93_CLK_ENET1_GATE 182 -#define IMX93_CLK_ENET_QOS_GATE 183 -#define IMX93_CLK_SYS_CNT_GATE 184 -#define IMX93_CLK_TSTMR1_GATE 185 -#define IMX93_CLK_TSTMR2_GATE 186 -#define IMX93_CLK_TMC_GATE 187 -#define IMX93_CLK_PMRO_GATE 188 -#define IMX93_CLK_32K 189 -#define IMX93_CLK_SAI1_IPG 190 -#define IMX93_CLK_SAI2_IPG 191 -#define IMX93_CLK_SAI3_IPG 192 -#define IMX93_CLK_MU1_A_GATE 193 -#define IMX93_CLK_MU1_B_GATE 194 -#define IMX93_CLK_MU2_A_GATE 195 -#define IMX93_CLK_MU2_B_GATE 196 -#define IMX93_CLK_NIC_AXI 197 -#define IMX93_CLK_ARM_PLL 198 -#define IMX93_CLK_A55_SEL 199 -#define IMX93_CLK_A55_CORE 200 -#define IMX93_CLK_END 201 - -#endif diff --git a/include/dt-bindings/clock/imxrt1050-clock.h b/include/dt-bindings/clock/imxrt1050-clock.h deleted file mode 100644 index 93bef0832d16..000000000000 --- a/include/dt-bindings/clock/imxrt1050-clock.h +++ /dev/null @@ -1,72 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright(C) 2019 - * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com - */ - -#ifndef __DT_BINDINGS_CLOCK_IMXRT1050_H -#define __DT_BINDINGS_CLOCK_IMXRT1050_H - -#define IMXRT1050_CLK_DUMMY 0 -#define IMXRT1050_CLK_CKIL 1 -#define IMXRT1050_CLK_CKIH 2 -#define IMXRT1050_CLK_OSC 3 -#define IMXRT1050_CLK_PLL2_PFD0_352M 4 -#define IMXRT1050_CLK_PLL2_PFD1_594M 5 -#define IMXRT1050_CLK_PLL2_PFD2_396M 6 -#define IMXRT1050_CLK_PLL3_PFD0_720M 7 -#define IMXRT1050_CLK_PLL3_PFD1_664_62M 8 -#define IMXRT1050_CLK_PLL3_PFD2_508_24M 9 -#define IMXRT1050_CLK_PLL3_PFD3_454_74M 10 -#define IMXRT1050_CLK_PLL2_198M 11 -#define IMXRT1050_CLK_PLL3_120M 12 -#define IMXRT1050_CLK_PLL3_80M 13 -#define IMXRT1050_CLK_PLL3_60M 14 -#define IMXRT1050_CLK_PLL1_BYPASS 15 -#define IMXRT1050_CLK_PLL2_BYPASS 16 -#define IMXRT1050_CLK_PLL3_BYPASS 17 -#define IMXRT1050_CLK_PLL5_BYPASS 19 -#define IMXRT1050_CLK_PLL1_REF_SEL 20 -#define IMXRT1050_CLK_PLL2_REF_SEL 21 -#define IMXRT1050_CLK_PLL3_REF_SEL 22 -#define IMXRT1050_CLK_PLL5_REF_SEL 23 -#define IMXRT1050_CLK_PRE_PERIPH_SEL 24 -#define IMXRT1050_CLK_PERIPH_SEL 25 -#define IMXRT1050_CLK_SEMC_ALT_SEL 26 -#define IMXRT1050_CLK_SEMC_SEL 27 -#define IMXRT1050_CLK_USDHC1_SEL 28 -#define IMXRT1050_CLK_USDHC2_SEL 29 -#define IMXRT1050_CLK_LPUART_SEL 30 -#define IMXRT1050_CLK_LCDIF_SEL 31 -#define IMXRT1050_CLK_VIDEO_POST_DIV_SEL 32 -#define IMXRT1050_CLK_VIDEO_DIV 33 -#define IMXRT1050_CLK_ARM_PODF 34 -#define IMXRT1050_CLK_LPUART_PODF 35 -#define IMXRT1050_CLK_USDHC1_PODF 36 -#define IMXRT1050_CLK_USDHC2_PODF 37 -#define IMXRT1050_CLK_SEMC_PODF 38 -#define IMXRT1050_CLK_AHB_PODF 39 -#define IMXRT1050_CLK_LCDIF_PRED 40 -#define IMXRT1050_CLK_LCDIF_PODF 41 -#define IMXRT1050_CLK_USDHC1 42 -#define IMXRT1050_CLK_USDHC2 43 -#define IMXRT1050_CLK_LPUART1 44 -#define IMXRT1050_CLK_SEMC 45 -#define IMXRT1050_CLK_LCDIF_APB 46 -#define IMXRT1050_CLK_PLL1_ARM 47 -#define IMXRT1050_CLK_PLL2_SYS 48 -#define IMXRT1050_CLK_PLL3_USB_OTG 49 -#define IMXRT1050_CLK_PLL4_AUDIO 50 -#define IMXRT1050_CLK_PLL5_VIDEO 51 -#define IMXRT1050_CLK_PLL6_ENET 52 -#define IMXRT1050_CLK_PLL7_USB_HOST 53 -#define IMXRT1050_CLK_LCDIF_PIX 54 -#define IMXRT1050_CLK_USBOH3 55 -#define IMXRT1050_CLK_IPG_PDOF 56 -#define IMXRT1050_CLK_PER_CLK_SEL 57 -#define IMXRT1050_CLK_PER_PDOF 58 -#define IMXRT1050_CLK_DMA 59 -#define IMXRT1050_CLK_DMA_MUX 60 -#define IMXRT1050_CLK_END 61 - -#endif /* __DT_BINDINGS_CLOCK_IMXRT1050_H */
Drop in favour of dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/interconnect/fsl,imx8mp.h | 59 ----------------------- include/dt-bindings/interconnect/imx8mm.h | 50 -------------------- include/dt-bindings/interconnect/imx8mn.h | 41 ---------------- include/dt-bindings/interconnect/imx8mq.h | 48 ------------------- include/dt-bindings/phy/phy-imx8-pcie.h | 14 ------ include/dt-bindings/power/fsl,imx93-power.h | 15 ------ include/dt-bindings/power/imx7-power.h | 13 ------ include/dt-bindings/power/imx8mm-power.h | 31 ------------- include/dt-bindings/power/imx8mn-power.h | 20 -------- include/dt-bindings/power/imx8mp-power.h | 59 ----------------------- include/dt-bindings/power/imx8mq-power.h | 24 ---------- include/dt-bindings/power/imx8ulp-power.h | 26 ----------- include/dt-bindings/reset/imx7-reset.h | 52 --------------------- include/dt-bindings/reset/imx8mp-reset.h | 50 -------------------- include/dt-bindings/reset/imx8mq-reset.h | 67 --------------------------- include/dt-bindings/reset/imx8ulp-pcc-reset.h | 59 ----------------------- include/dt-bindings/sound/fsl-imx-audmux.h | 64 ------------------------- 17 files changed, 692 deletions(-)
diff --git a/include/dt-bindings/interconnect/fsl,imx8mp.h b/include/dt-bindings/interconnect/fsl,imx8mp.h deleted file mode 100644 index 7357d417529a..000000000000 --- a/include/dt-bindings/interconnect/fsl,imx8mp.h +++ /dev/null @@ -1,59 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR MIT */ -/* - * Interconnect framework driver for i.MX SoC - * - * Copyright 2022 NXP - * Peng Fan peng.fan@nxp.com - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MP_H -#define __DT_BINDINGS_INTERCONNECT_IMX8MP_H - -#define IMX8MP_ICN_NOC 0 -#define IMX8MP_ICN_MAIN 1 -#define IMX8MP_ICS_DRAM 2 -#define IMX8MP_ICS_OCRAM 3 -#define IMX8MP_ICM_A53 4 -#define IMX8MP_ICM_SUPERMIX 5 -#define IMX8MP_ICM_GIC 6 -#define IMX8MP_ICM_MLMIX 7 - -#define IMX8MP_ICN_AUDIO 8 -#define IMX8MP_ICM_DSP 9 -#define IMX8MP_ICM_SDMA2PER 10 -#define IMX8MP_ICM_SDMA2BURST 11 -#define IMX8MP_ICM_SDMA3PER 12 -#define IMX8MP_ICM_SDMA3BURST 13 -#define IMX8MP_ICM_EDMA 14 - -#define IMX8MP_ICN_GPU 15 -#define IMX8MP_ICM_GPU2D 16 -#define IMX8MP_ICM_GPU3D 17 - -#define IMX8MP_ICN_HDMI 18 -#define IMX8MP_ICM_HRV 19 -#define IMX8MP_ICM_LCDIF_HDMI 20 -#define IMX8MP_ICM_HDCP 21 - -#define IMX8MP_ICN_HSIO 22 -#define IMX8MP_ICM_NOC_PCIE 23 -#define IMX8MP_ICM_USB1 24 -#define IMX8MP_ICM_USB2 25 -#define IMX8MP_ICM_PCIE 26 - -#define IMX8MP_ICN_MEDIA 27 -#define IMX8MP_ICM_LCDIF_RD 28 -#define IMX8MP_ICM_LCDIF_WR 29 -#define IMX8MP_ICM_ISI0 30 -#define IMX8MP_ICM_ISI1 31 -#define IMX8MP_ICM_ISI2 32 -#define IMX8MP_ICM_ISP0 33 -#define IMX8MP_ICM_ISP1 34 -#define IMX8MP_ICM_DWE 35 - -#define IMX8MP_ICN_VIDEO 36 -#define IMX8MP_ICM_VPU_G1 37 -#define IMX8MP_ICM_VPU_G2 38 -#define IMX8MP_ICM_VPU_H1 39 - -#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MP_H */ diff --git a/include/dt-bindings/interconnect/imx8mm.h b/include/dt-bindings/interconnect/imx8mm.h deleted file mode 100644 index 8f10bb06cb59..000000000000 --- a/include/dt-bindings/interconnect/imx8mm.h +++ /dev/null @@ -1,50 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Interconnect framework driver for i.MX SoC - * - * Copyright (c) 2019, BayLibre - * Copyright (c) 2019-2020, NXP - * Author: Alexandre Bailon abailon@baylibre.com - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MM_H -#define __DT_BINDINGS_INTERCONNECT_IMX8MM_H - -#define IMX8MM_ICN_NOC 1 -#define IMX8MM_ICS_DRAM 2 -#define IMX8MM_ICS_OCRAM 3 -#define IMX8MM_ICM_A53 4 - -#define IMX8MM_ICM_VPU_H1 5 -#define IMX8MM_ICM_VPU_G1 6 -#define IMX8MM_ICM_VPU_G2 7 -#define IMX8MM_ICN_VIDEO 8 - -#define IMX8MM_ICM_GPU2D 9 -#define IMX8MM_ICM_GPU3D 10 -#define IMX8MM_ICN_GPU 11 - -#define IMX8MM_ICM_CSI 12 -#define IMX8MM_ICM_LCDIF 13 -#define IMX8MM_ICN_MIPI 14 - -#define IMX8MM_ICM_USB1 15 -#define IMX8MM_ICM_USB2 16 -#define IMX8MM_ICM_PCIE 17 -#define IMX8MM_ICN_HSIO 18 - -#define IMX8MM_ICM_SDMA2 19 -#define IMX8MM_ICM_SDMA3 20 -#define IMX8MM_ICN_AUDIO 21 - -#define IMX8MM_ICN_ENET 22 -#define IMX8MM_ICM_ENET 23 - -#define IMX8MM_ICN_MAIN 24 -#define IMX8MM_ICM_NAND 25 -#define IMX8MM_ICM_SDMA1 26 -#define IMX8MM_ICM_USDHC1 27 -#define IMX8MM_ICM_USDHC2 28 -#define IMX8MM_ICM_USDHC3 29 - -#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MM_H */ diff --git a/include/dt-bindings/interconnect/imx8mn.h b/include/dt-bindings/interconnect/imx8mn.h deleted file mode 100644 index 307b977100b6..000000000000 --- a/include/dt-bindings/interconnect/imx8mn.h +++ /dev/null @@ -1,41 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Interconnect framework driver for i.MX SoC - * - * Copyright (c) 2019-2020, NXP - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MN_H -#define __DT_BINDINGS_INTERCONNECT_IMX8MN_H - -#define IMX8MN_ICN_NOC 1 -#define IMX8MN_ICS_DRAM 2 -#define IMX8MN_ICS_OCRAM 3 -#define IMX8MN_ICM_A53 4 - -#define IMX8MN_ICM_GPU 5 -#define IMX8MN_ICN_GPU 6 - -#define IMX8MN_ICM_CSI1 7 -#define IMX8MN_ICM_CSI2 8 -#define IMX8MN_ICM_ISI 9 -#define IMX8MN_ICM_LCDIF 10 -#define IMX8MN_ICN_MIPI 11 - -#define IMX8MN_ICM_USB 12 - -#define IMX8MN_ICM_SDMA2 13 -#define IMX8MN_ICM_SDMA3 14 -#define IMX8MN_ICN_AUDIO 15 - -#define IMX8MN_ICN_ENET 16 -#define IMX8MN_ICM_ENET 17 - -#define IMX8MN_ICM_NAND 18 -#define IMX8MN_ICM_SDMA1 19 -#define IMX8MN_ICM_USDHC1 20 -#define IMX8MN_ICM_USDHC2 21 -#define IMX8MN_ICM_USDHC3 22 -#define IMX8MN_ICN_MAIN 23 - -#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MN_H */ diff --git a/include/dt-bindings/interconnect/imx8mq.h b/include/dt-bindings/interconnect/imx8mq.h deleted file mode 100644 index 1a4cae7f8be2..000000000000 --- a/include/dt-bindings/interconnect/imx8mq.h +++ /dev/null @@ -1,48 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Interconnect framework driver for i.MX SoC - * - * Copyright (c) 2019-2020, NXP - */ - -#ifndef __DT_BINDINGS_INTERCONNECT_IMX8MQ_H -#define __DT_BINDINGS_INTERCONNECT_IMX8MQ_H - -#define IMX8MQ_ICN_NOC 1 -#define IMX8MQ_ICS_DRAM 2 -#define IMX8MQ_ICS_OCRAM 3 -#define IMX8MQ_ICM_A53 4 - -#define IMX8MQ_ICM_VPU 5 -#define IMX8MQ_ICN_VIDEO 6 - -#define IMX8MQ_ICM_GPU 7 -#define IMX8MQ_ICN_GPU 8 - -#define IMX8MQ_ICM_DCSS 9 -#define IMX8MQ_ICN_DCSS 10 - -#define IMX8MQ_ICM_USB1 11 -#define IMX8MQ_ICM_USB2 12 -#define IMX8MQ_ICN_USB 13 - -#define IMX8MQ_ICM_CSI1 14 -#define IMX8MQ_ICM_CSI2 15 -#define IMX8MQ_ICM_LCDIF 16 -#define IMX8MQ_ICN_DISPLAY 17 - -#define IMX8MQ_ICM_SDMA2 18 -#define IMX8MQ_ICN_AUDIO 19 - -#define IMX8MQ_ICN_ENET 20 -#define IMX8MQ_ICM_ENET 21 - -#define IMX8MQ_ICM_SDMA1 22 -#define IMX8MQ_ICM_NAND 23 -#define IMX8MQ_ICM_USDHC1 24 -#define IMX8MQ_ICM_USDHC2 25 -#define IMX8MQ_ICM_PCIE1 26 -#define IMX8MQ_ICM_PCIE2 27 -#define IMX8MQ_ICN_MAIN 28 - -#endif /* __DT_BINDINGS_INTERCONNECT_IMX8MQ_H */ diff --git a/include/dt-bindings/phy/phy-imx8-pcie.h b/include/dt-bindings/phy/phy-imx8-pcie.h deleted file mode 100644 index 8bbe2d6538d8..000000000000 --- a/include/dt-bindings/phy/phy-imx8-pcie.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * This header provides constants for i.MX8 PCIe. - */ - -#ifndef _DT_BINDINGS_IMX8_PCIE_H -#define _DT_BINDINGS_IMX8_PCIE_H - -/* Reference clock PAD mode */ -#define IMX8_PCIE_REFCLK_PAD_UNUSED 0 -#define IMX8_PCIE_REFCLK_PAD_INPUT 1 -#define IMX8_PCIE_REFCLK_PAD_OUTPUT 2 - -#endif /* _DT_BINDINGS_IMX8_PCIE_H */ diff --git a/include/dt-bindings/power/fsl,imx93-power.h b/include/dt-bindings/power/fsl,imx93-power.h deleted file mode 100644 index 17f9f015bf7d..000000000000 --- a/include/dt-bindings/power/fsl,imx93-power.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright 2022 NXP - */ - -#ifndef __DT_BINDINGS_IMX93_POWER_H__ -#define __DT_BINDINGS_IMX93_POWER_H__ - -#define IMX93_MEDIABLK_PD_MIPI_DSI 0 -#define IMX93_MEDIABLK_PD_MIPI_CSI 1 -#define IMX93_MEDIABLK_PD_PXP 2 -#define IMX93_MEDIABLK_PD_LCDIF 3 -#define IMX93_MEDIABLK_PD_ISI 4 - -#endif diff --git a/include/dt-bindings/power/imx7-power.h b/include/dt-bindings/power/imx7-power.h deleted file mode 100644 index 597c1aa06ae5..000000000000 --- a/include/dt-bindings/power/imx7-power.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2017 Impinj - */ - -#ifndef __DT_BINDINGS_IMX7_POWER_H__ -#define __DT_BINDINGS_IMX7_POWER_H__ - -#define IMX7_POWER_DOMAIN_MIPI_PHY 0 -#define IMX7_POWER_DOMAIN_PCIE_PHY 1 -#define IMX7_POWER_DOMAIN_USB_HSIC_PHY 2 - -#endif diff --git a/include/dt-bindings/power/imx8mm-power.h b/include/dt-bindings/power/imx8mm-power.h deleted file mode 100644 index 648938f24c8e..000000000000 --- a/include/dt-bindings/power/imx8mm-power.h +++ /dev/null @@ -1,31 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (C) 2020 Pengutronix, Lucas Stach kernel@pengutronix.de - */ - -#ifndef __DT_BINDINGS_IMX8MM_POWER_H__ -#define __DT_BINDINGS_IMX8MM_POWER_H__ - -#define IMX8MM_POWER_DOMAIN_HSIOMIX 0 -#define IMX8MM_POWER_DOMAIN_PCIE 1 -#define IMX8MM_POWER_DOMAIN_OTG1 2 -#define IMX8MM_POWER_DOMAIN_OTG2 3 -#define IMX8MM_POWER_DOMAIN_GPUMIX 4 -#define IMX8MM_POWER_DOMAIN_GPU 5 -#define IMX8MM_POWER_DOMAIN_VPUMIX 6 -#define IMX8MM_POWER_DOMAIN_VPUG1 7 -#define IMX8MM_POWER_DOMAIN_VPUG2 8 -#define IMX8MM_POWER_DOMAIN_VPUH1 9 -#define IMX8MM_POWER_DOMAIN_DISPMIX 10 -#define IMX8MM_POWER_DOMAIN_MIPI 11 - -#define IMX8MM_VPUBLK_PD_G1 0 -#define IMX8MM_VPUBLK_PD_G2 1 -#define IMX8MM_VPUBLK_PD_H1 2 - -#define IMX8MM_DISPBLK_PD_CSI_BRIDGE 0 -#define IMX8MM_DISPBLK_PD_LCDIF 1 -#define IMX8MM_DISPBLK_PD_MIPI_DSI 2 -#define IMX8MM_DISPBLK_PD_MIPI_CSI 3 - -#endif diff --git a/include/dt-bindings/power/imx8mn-power.h b/include/dt-bindings/power/imx8mn-power.h deleted file mode 100644 index eedd0e581939..000000000000 --- a/include/dt-bindings/power/imx8mn-power.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (C) 2020 Compass Electronics Group, LLC - */ - -#ifndef __DT_BINDINGS_IMX8MN_POWER_H__ -#define __DT_BINDINGS_IMX8MN_POWER_H__ - -#define IMX8MN_POWER_DOMAIN_HSIOMIX 0 -#define IMX8MN_POWER_DOMAIN_OTG1 1 -#define IMX8MN_POWER_DOMAIN_GPUMIX 2 -#define IMX8MN_POWER_DOMAIN_DISPMIX 3 -#define IMX8MN_POWER_DOMAIN_MIPI 4 - -#define IMX8MN_DISPBLK_PD_MIPI_DSI 0 -#define IMX8MN_DISPBLK_PD_MIPI_CSI 1 -#define IMX8MN_DISPBLK_PD_LCDIF 2 -#define IMX8MN_DISPBLK_PD_ISI 3 - -#endif diff --git a/include/dt-bindings/power/imx8mp-power.h b/include/dt-bindings/power/imx8mp-power.h deleted file mode 100644 index 2fe3c2abad13..000000000000 --- a/include/dt-bindings/power/imx8mp-power.h +++ /dev/null @@ -1,59 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (C) 2020 Pengutronix, Sascha Hauer kernel@pengutronix.de - */ - -#ifndef __DT_BINDINGS_IMX8MP_POWER_DOMAIN_POWER_H__ -#define __DT_BINDINGS_IMX8MP_POWER_DOMAIN_POWER_H__ - -#define IMX8MP_POWER_DOMAIN_MIPI_PHY1 0 -#define IMX8MP_POWER_DOMAIN_PCIE_PHY 1 -#define IMX8MP_POWER_DOMAIN_USB1_PHY 2 -#define IMX8MP_POWER_DOMAIN_USB2_PHY 3 -#define IMX8MP_POWER_DOMAIN_MLMIX 4 -#define IMX8MP_POWER_DOMAIN_AUDIOMIX 5 -#define IMX8MP_POWER_DOMAIN_GPU2D 6 -#define IMX8MP_POWER_DOMAIN_GPUMIX 7 -#define IMX8MP_POWER_DOMAIN_VPUMIX 8 -#define IMX8MP_POWER_DOMAIN_GPU3D 9 -#define IMX8MP_POWER_DOMAIN_MEDIAMIX 10 -#define IMX8MP_POWER_DOMAIN_VPU_G1 11 -#define IMX8MP_POWER_DOMAIN_VPU_G2 12 -#define IMX8MP_POWER_DOMAIN_VPU_VC8000E 13 -#define IMX8MP_POWER_DOMAIN_HDMIMIX 14 -#define IMX8MP_POWER_DOMAIN_HDMI_PHY 15 -#define IMX8MP_POWER_DOMAIN_MIPI_PHY2 16 -#define IMX8MP_POWER_DOMAIN_HSIOMIX 17 -#define IMX8MP_POWER_DOMAIN_MEDIAMIX_ISPDWP 18 - -#define IMX8MP_HSIOBLK_PD_USB 0 -#define IMX8MP_HSIOBLK_PD_USB_PHY1 1 -#define IMX8MP_HSIOBLK_PD_USB_PHY2 2 -#define IMX8MP_HSIOBLK_PD_PCIE 3 -#define IMX8MP_HSIOBLK_PD_PCIE_PHY 4 - -#define IMX8MP_MEDIABLK_PD_MIPI_DSI_1 0 -#define IMX8MP_MEDIABLK_PD_MIPI_CSI2_1 1 -#define IMX8MP_MEDIABLK_PD_LCDIF_1 2 -#define IMX8MP_MEDIABLK_PD_ISI 3 -#define IMX8MP_MEDIABLK_PD_MIPI_CSI2_2 4 -#define IMX8MP_MEDIABLK_PD_LCDIF_2 5 -#define IMX8MP_MEDIABLK_PD_ISP 6 -#define IMX8MP_MEDIABLK_PD_DWE 7 -#define IMX8MP_MEDIABLK_PD_MIPI_DSI_2 8 - -#define IMX8MP_HDMIBLK_PD_IRQSTEER 0 -#define IMX8MP_HDMIBLK_PD_LCDIF 1 -#define IMX8MP_HDMIBLK_PD_PAI 2 -#define IMX8MP_HDMIBLK_PD_PVI 3 -#define IMX8MP_HDMIBLK_PD_TRNG 4 -#define IMX8MP_HDMIBLK_PD_HDMI_TX 5 -#define IMX8MP_HDMIBLK_PD_HDMI_TX_PHY 6 -#define IMX8MP_HDMIBLK_PD_HDCP 7 -#define IMX8MP_HDMIBLK_PD_HRV 8 - -#define IMX8MP_VPUBLK_PD_G1 0 -#define IMX8MP_VPUBLK_PD_G2 1 -#define IMX8MP_VPUBLK_PD_VC8000E 2 - -#endif diff --git a/include/dt-bindings/power/imx8mq-power.h b/include/dt-bindings/power/imx8mq-power.h deleted file mode 100755 index 9f7d0f1e7c32..000000000000 --- a/include/dt-bindings/power/imx8mq-power.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (C) 2018 Pengutronix, Lucas Stach kernel@pengutronix.de - */ - -#ifndef __DT_BINDINGS_IMX8MQ_POWER_H__ -#define __DT_BINDINGS_IMX8MQ_POWER_H__ - -#define IMX8M_POWER_DOMAIN_MIPI 0 -#define IMX8M_POWER_DOMAIN_PCIE1 1 -#define IMX8M_POWER_DOMAIN_USB_OTG1 2 -#define IMX8M_POWER_DOMAIN_USB_OTG2 3 -#define IMX8M_POWER_DOMAIN_DDR1 4 -#define IMX8M_POWER_DOMAIN_GPU 5 -#define IMX8M_POWER_DOMAIN_VPU 6 -#define IMX8M_POWER_DOMAIN_DISP 7 -#define IMX8M_POWER_DOMAIN_MIPI_CSI1 8 -#define IMX8M_POWER_DOMAIN_MIPI_CSI2 9 -#define IMX8M_POWER_DOMAIN_PCIE2 10 - -#define IMX8MQ_VPUBLK_PD_G1 0 -#define IMX8MQ_VPUBLK_PD_G2 1 - -#endif diff --git a/include/dt-bindings/power/imx8ulp-power.h b/include/dt-bindings/power/imx8ulp-power.h deleted file mode 100644 index a556b2e96df1..000000000000 --- a/include/dt-bindings/power/imx8ulp-power.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright 2021 NXP - */ - -#ifndef __DT_BINDINGS_IMX8ULP_POWER_H__ -#define __DT_BINDINGS_IMX8ULP_POWER_H__ - -#define IMX8ULP_PD_DMA1 0 -#define IMX8ULP_PD_FLEXSPI2 1 -#define IMX8ULP_PD_USB0 2 -#define IMX8ULP_PD_USDHC0 3 -#define IMX8ULP_PD_USDHC1 4 -#define IMX8ULP_PD_USDHC2_USB1 5 -#define IMX8ULP_PD_DCNANO 6 -#define IMX8ULP_PD_EPDC 7 -#define IMX8ULP_PD_DMA2 8 -#define IMX8ULP_PD_GPU2D 9 -#define IMX8ULP_PD_GPU3D 10 -#define IMX8ULP_PD_HIFI4 11 -#define IMX8ULP_PD_ISI 12 -#define IMX8ULP_PD_MIPI_CSI 13 -#define IMX8ULP_PD_MIPI_DSI 14 -#define IMX8ULP_PD_PXP 15 - -#endif diff --git a/include/dt-bindings/reset/imx7-reset.h b/include/dt-bindings/reset/imx7-reset.h deleted file mode 100644 index bb92452ffb8b..000000000000 --- a/include/dt-bindings/reset/imx7-reset.h +++ /dev/null @@ -1,52 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2017 Impinj, Inc. - * - * Author: Andrey Smirnov andrew.smirnov@gmail.com - */ - -#ifndef DT_BINDING_RESET_IMX7_H -#define DT_BINDING_RESET_IMX7_H - -#define IMX7_RESET_A7_CORE_POR_RESET0 0 -#define IMX7_RESET_A7_CORE_POR_RESET1 1 -#define IMX7_RESET_A7_CORE_RESET0 2 -#define IMX7_RESET_A7_CORE_RESET1 3 -#define IMX7_RESET_A7_DBG_RESET0 4 -#define IMX7_RESET_A7_DBG_RESET1 5 -#define IMX7_RESET_A7_ETM_RESET0 6 -#define IMX7_RESET_A7_ETM_RESET1 7 -#define IMX7_RESET_A7_SOC_DBG_RESET 8 -#define IMX7_RESET_A7_L2RESET 9 -#define IMX7_RESET_SW_M4C_RST 10 -#define IMX7_RESET_SW_M4P_RST 11 -#define IMX7_RESET_EIM_RST 12 -#define IMX7_RESET_HSICPHY_PORT_RST 13 -#define IMX7_RESET_USBPHY1_POR 14 -#define IMX7_RESET_USBPHY1_PORT_RST 15 -#define IMX7_RESET_USBPHY2_POR 16 -#define IMX7_RESET_USBPHY2_PORT_RST 17 -#define IMX7_RESET_MIPI_PHY_MRST 18 -#define IMX7_RESET_MIPI_PHY_SRST 19 - -/* - * IMX7_RESET_PCIEPHY is a logical reset line combining PCIEPHY_BTN - * and PCIEPHY_G_RST - */ -#define IMX7_RESET_PCIEPHY 20 -#define IMX7_RESET_PCIEPHY_PERST 21 - -/* - * IMX7_RESET_PCIE_CTRL_APPS_EN is not strictly a reset line, but it - * can be used to inhibit PCIe LTTSM, so, in a way, it can be thoguht - * of as one - */ -#define IMX7_RESET_PCIE_CTRL_APPS_EN 22 -#define IMX7_RESET_DDRC_PRST 23 -#define IMX7_RESET_DDRC_CORE_RST 24 - -#define IMX7_RESET_PCIE_CTRL_APPS_TURNOFF 25 - -#define IMX7_RESET_NUM 26 - -#endif diff --git a/include/dt-bindings/reset/imx8mp-reset.h b/include/dt-bindings/reset/imx8mp-reset.h deleted file mode 100644 index 2e8c9104b666..000000000000 --- a/include/dt-bindings/reset/imx8mp-reset.h +++ /dev/null @@ -1,50 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2020 NXP - */ - -#ifndef DT_BINDING_RESET_IMX8MP_H -#define DT_BINDING_RESET_IMX8MP_H - -#define IMX8MP_RESET_A53_CORE_POR_RESET0 0 -#define IMX8MP_RESET_A53_CORE_POR_RESET1 1 -#define IMX8MP_RESET_A53_CORE_POR_RESET2 2 -#define IMX8MP_RESET_A53_CORE_POR_RESET3 3 -#define IMX8MP_RESET_A53_CORE_RESET0 4 -#define IMX8MP_RESET_A53_CORE_RESET1 5 -#define IMX8MP_RESET_A53_CORE_RESET2 6 -#define IMX8MP_RESET_A53_CORE_RESET3 7 -#define IMX8MP_RESET_A53_DBG_RESET0 8 -#define IMX8MP_RESET_A53_DBG_RESET1 9 -#define IMX8MP_RESET_A53_DBG_RESET2 10 -#define IMX8MP_RESET_A53_DBG_RESET3 11 -#define IMX8MP_RESET_A53_ETM_RESET0 12 -#define IMX8MP_RESET_A53_ETM_RESET1 13 -#define IMX8MP_RESET_A53_ETM_RESET2 14 -#define IMX8MP_RESET_A53_ETM_RESET3 15 -#define IMX8MP_RESET_A53_SOC_DBG_RESET 16 -#define IMX8MP_RESET_A53_L2RESET 17 -#define IMX8MP_RESET_SW_NON_SCLR_M7C_RST 18 -#define IMX8MP_RESET_OTG1_PHY_RESET 19 -#define IMX8MP_RESET_OTG2_PHY_RESET 20 -#define IMX8MP_RESET_SUPERMIX_RESET 21 -#define IMX8MP_RESET_AUDIOMIX_RESET 22 -#define IMX8MP_RESET_MLMIX_RESET 23 -#define IMX8MP_RESET_PCIEPHY 24 -#define IMX8MP_RESET_PCIEPHY_PERST 25 -#define IMX8MP_RESET_PCIE_CTRL_APPS_EN 26 -#define IMX8MP_RESET_PCIE_CTRL_APPS_TURNOFF 27 -#define IMX8MP_RESET_HDMI_PHY_APB_RESET 28 -#define IMX8MP_RESET_MEDIA_RESET 29 -#define IMX8MP_RESET_GPU2D_RESET 30 -#define IMX8MP_RESET_GPU3D_RESET 31 -#define IMX8MP_RESET_GPU_RESET 32 -#define IMX8MP_RESET_VPU_RESET 33 -#define IMX8MP_RESET_VPU_G1_RESET 34 -#define IMX8MP_RESET_VPU_G2_RESET 35 -#define IMX8MP_RESET_VPUVC8KE_RESET 36 -#define IMX8MP_RESET_NOC_RESET 37 - -#define IMX8MP_RESET_NUM 38 - -#endif diff --git a/include/dt-bindings/reset/imx8mq-reset.h b/include/dt-bindings/reset/imx8mq-reset.h deleted file mode 100755 index 705870693ec2..000000000000 --- a/include/dt-bindings/reset/imx8mq-reset.h +++ /dev/null @@ -1,67 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 Zodiac Inflight Innovations - * - * Author: Andrey Smirnov andrew.smirnov@gmail.com - */ - -#ifndef DT_BINDING_RESET_IMX8MQ_H -#define DT_BINDING_RESET_IMX8MQ_H - -#define IMX8MQ_RESET_A53_CORE_POR_RESET0 0 -#define IMX8MQ_RESET_A53_CORE_POR_RESET1 1 -#define IMX8MQ_RESET_A53_CORE_POR_RESET2 2 -#define IMX8MQ_RESET_A53_CORE_POR_RESET3 3 -#define IMX8MQ_RESET_A53_CORE_RESET0 4 -#define IMX8MQ_RESET_A53_CORE_RESET1 5 -#define IMX8MQ_RESET_A53_CORE_RESET2 6 -#define IMX8MQ_RESET_A53_CORE_RESET3 7 -#define IMX8MQ_RESET_A53_DBG_RESET0 8 -#define IMX8MQ_RESET_A53_DBG_RESET1 9 -#define IMX8MQ_RESET_A53_DBG_RESET2 10 -#define IMX8MQ_RESET_A53_DBG_RESET3 11 -#define IMX8MQ_RESET_A53_ETM_RESET0 12 -#define IMX8MQ_RESET_A53_ETM_RESET1 13 -#define IMX8MQ_RESET_A53_ETM_RESET2 14 -#define IMX8MQ_RESET_A53_ETM_RESET3 15 -#define IMX8MQ_RESET_A53_SOC_DBG_RESET 16 -#define IMX8MQ_RESET_A53_L2RESET 17 -#define IMX8MQ_RESET_SW_NON_SCLR_M4C_RST 18 -#define IMX8MQ_RESET_OTG1_PHY_RESET 19 -#define IMX8MQ_RESET_OTG2_PHY_RESET 20 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_DSI_RESET_BYTE_N 21 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_DSI_RESET_N 22 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_DSI_DPI_RESET_N 23 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_DSI_ESC_RESET_N 24 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_DSI_PCLK_RESET_N 25 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIEPHY 26 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIEPHY_PERST 27 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIE_CTRL_APPS_EN 28 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIE_CTRL_APPS_TURNOFF 29 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_HDMI_PHY_APB_RESET 30 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DISP_RESET 31 -#define IMX8MQ_RESET_GPU_RESET 32 -#define IMX8MQ_RESET_VPU_RESET 33 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIEPHY2 34 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIEPHY2_PERST 35 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIE2_CTRL_APPS_EN 36 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_PCIE2_CTRL_APPS_TURNOFF 37 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_CORE_RESET 38 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_PHY_REF_RESET 39 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI1_ESC_RESET 40 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_CORE_RESET 41 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_PHY_REF_RESET 42 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_MIPI_CSI2_ESC_RESET 43 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC1_PRST 44 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC1_CORE_RESET 45 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC1_PHY_RESET 46 /* i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC2_PRST 47 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC2_CORE_RESET 48 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_DDRC2_PHY_RESET 49 /* i.MX8MM/i.MX8MN does NOT support */ -#define IMX8MQ_RESET_SW_M4C_RST 50 -#define IMX8MQ_RESET_SW_M4P_RST 51 -#define IMX8MQ_RESET_M4_ENABLE 52 - -#define IMX8MQ_RESET_NUM 53 - -#endif diff --git a/include/dt-bindings/reset/imx8ulp-pcc-reset.h b/include/dt-bindings/reset/imx8ulp-pcc-reset.h deleted file mode 100644 index e99a4735c3c4..000000000000 --- a/include/dt-bindings/reset/imx8ulp-pcc-reset.h +++ /dev/null @@ -1,59 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2021 NXP - */ - -#ifndef DT_BINDING_PCC_RESET_IMX8ULP_H -#define DT_BINDING_PCC_RESET_IMX8ULP_H - -/* PCC3 */ -#define PCC3_WDOG3_SWRST 0 -#define PCC3_WDOG4_SWRST 1 -#define PCC3_LPIT1_SWRST 2 -#define PCC3_TPM4_SWRST 3 -#define PCC3_TPM5_SWRST 4 -#define PCC3_FLEXIO1_SWRST 5 -#define PCC3_I3C2_SWRST 6 -#define PCC3_LPI2C4_SWRST 7 -#define PCC3_LPI2C5_SWRST 8 -#define PCC3_LPUART4_SWRST 9 -#define PCC3_LPUART5_SWRST 10 -#define PCC3_LPSPI4_SWRST 11 -#define PCC3_LPSPI5_SWRST 12 - -/* PCC4 */ -#define PCC4_FLEXSPI2_SWRST 0 -#define PCC4_TPM6_SWRST 1 -#define PCC4_TPM7_SWRST 2 -#define PCC4_LPI2C6_SWRST 3 -#define PCC4_LPI2C7_SWRST 4 -#define PCC4_LPUART6_SWRST 5 -#define PCC4_LPUART7_SWRST 6 -#define PCC4_SAI4_SWRST 7 -#define PCC4_SAI5_SWRST 8 -#define PCC4_USDHC0_SWRST 9 -#define PCC4_USDHC1_SWRST 10 -#define PCC4_USDHC2_SWRST 11 -#define PCC4_USB0_SWRST 12 -#define PCC4_USB0_PHY_SWRST 13 -#define PCC4_USB1_SWRST 14 -#define PCC4_USB1_PHY_SWRST 15 -#define PCC4_ENET_SWRST 16 - -/* PCC5 */ -#define PCC5_TPM8_SWRST 0 -#define PCC5_SAI6_SWRST 1 -#define PCC5_SAI7_SWRST 2 -#define PCC5_SPDIF_SWRST 3 -#define PCC5_ISI_SWRST 4 -#define PCC5_CSI_REGS_SWRST 5 -#define PCC5_CSI_SWRST 6 -#define PCC5_DSI_SWRST 7 -#define PCC5_WDOG5_SWRST 8 -#define PCC5_EPDC_SWRST 9 -#define PCC5_PXP_SWRST 10 -#define PCC5_GPU2D_SWRST 11 -#define PCC5_GPU3D_SWRST 12 -#define PCC5_DC_NANO_SWRST 13 - -#endif /*DT_BINDING_RESET_IMX8ULP_H */ diff --git a/include/dt-bindings/sound/fsl-imx-audmux.h b/include/dt-bindings/sound/fsl-imx-audmux.h deleted file mode 100644 index 15f138bebe16..000000000000 --- a/include/dt-bindings/sound/fsl-imx-audmux.h +++ /dev/null @@ -1,64 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_FSL_IMX_AUDMUX_H -#define __DT_FSL_IMX_AUDMUX_H - -#define MX27_AUDMUX_HPCR1_SSI0 0 -#define MX27_AUDMUX_HPCR2_SSI1 1 -#define MX27_AUDMUX_HPCR3_SSI_PINS_4 2 -#define MX27_AUDMUX_PPCR1_SSI_PINS_1 3 -#define MX27_AUDMUX_PPCR2_SSI_PINS_2 4 -#define MX27_AUDMUX_PPCR3_SSI_PINS_3 5 - -#define MX31_AUDMUX_PORT1_SSI0 0 -#define MX31_AUDMUX_PORT2_SSI1 1 -#define MX31_AUDMUX_PORT3_SSI_PINS_3 2 -#define MX31_AUDMUX_PORT4_SSI_PINS_4 3 -#define MX31_AUDMUX_PORT5_SSI_PINS_5 4 -#define MX31_AUDMUX_PORT6_SSI_PINS_6 5 -#define MX31_AUDMUX_PORT7_SSI_PINS_7 6 - -#define MX51_AUDMUX_PORT1_SSI0 0 -#define MX51_AUDMUX_PORT2_SSI1 1 -#define MX51_AUDMUX_PORT3 2 -#define MX51_AUDMUX_PORT4 3 -#define MX51_AUDMUX_PORT5 4 -#define MX51_AUDMUX_PORT6 5 -#define MX51_AUDMUX_PORT7 6 - -/* - * TFCSEL/RFCSEL (i.MX27) or TFSEL/TCSEL/RFSEL/RCSEL (i.MX31/51/53/6Q) - * can be sourced from Rx/Tx. - */ -#define IMX_AUDMUX_RXFS 0x8 -#define IMX_AUDMUX_RXCLK 0x8 - -/* Register definitions for the i.MX21/27 Digital Audio Multiplexer */ -#define IMX_AUDMUX_V1_PCR_INMMASK(x) ((x) & 0xff) -#define IMX_AUDMUX_V1_PCR_INMEN (1 << 8) -#define IMX_AUDMUX_V1_PCR_TXRXEN (1 << 10) -#define IMX_AUDMUX_V1_PCR_SYN (1 << 12) -#define IMX_AUDMUX_V1_PCR_RXDSEL(x) (((x) & 0x7) << 13) -#define IMX_AUDMUX_V1_PCR_RFCSEL(x) (((x) & 0xf) << 20) -#define IMX_AUDMUX_V1_PCR_RCLKDIR (1 << 24) -#define IMX_AUDMUX_V1_PCR_RFSDIR (1 << 25) -#define IMX_AUDMUX_V1_PCR_TFCSEL(x) (((x) & 0xf) << 26) -#define IMX_AUDMUX_V1_PCR_TCLKDIR (1 << 30) -#define IMX_AUDMUX_V1_PCR_TFSDIR (1 << 31) - -/* Register definitions for the i.MX25/31/35/51 Digital Audio Multiplexer */ -#define IMX_AUDMUX_V2_PTCR_TFSDIR (1 << 31) -#define IMX_AUDMUX_V2_PTCR_TFSEL(x) (((x) & 0xf) << 27) -#define IMX_AUDMUX_V2_PTCR_TCLKDIR (1 << 26) -#define IMX_AUDMUX_V2_PTCR_TCSEL(x) (((x) & 0xf) << 22) -#define IMX_AUDMUX_V2_PTCR_RFSDIR (1 << 21) -#define IMX_AUDMUX_V2_PTCR_RFSEL(x) (((x) & 0xf) << 17) -#define IMX_AUDMUX_V2_PTCR_RCLKDIR (1 << 16) -#define IMX_AUDMUX_V2_PTCR_RCSEL(x) (((x) & 0xf) << 12) -#define IMX_AUDMUX_V2_PTCR_SYN (1 << 11) - -#define IMX_AUDMUX_V2_PDCR_RXDSEL(x) (((x) & 0x7) << 13) -#define IMX_AUDMUX_V2_PDCR_TXRXEN (1 << 12) -#define IMX_AUDMUX_V2_PDCR_MODE(x) (((x) & 0x3) << 8) -#define IMX_AUDMUX_V2_PDCR_INMMASK(x) ((x) & 0xff) - -#endif /* __DT_FSL_IMX_AUDMUX_H */
Dropped in favour of dts/upstream
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Tested-by: Neil Armstrong neil.armstrong@linaro.org # on AML-S805X-AC Tested-by: Neil Armstrong neil.armstrong@linaro.org # on AML-S905X-CC Tested-by: Neil Armstrong neil.armstrong@linaro.org # on BPI-M2S Tested-by: Neil Armstrong neil.armstrong@linaro.org # on BPI-M5 --- .../clock/amlogic,a1-peripherals-clkc.h | 168 --------------------- include/dt-bindings/clock/amlogic,a1-pll-clkc.h | 25 --- include/dt-bindings/clock/axg-aoclkc.h | 31 ---- include/dt-bindings/clock/axg-audio-clkc.h | 94 ------------ include/dt-bindings/clock/axg-clkc.h | 100 ------------ include/dt-bindings/clock/g12a-aoclkc.h | 36 ----- include/dt-bindings/clock/g12a-clkc.h | 153 ------------------- include/dt-bindings/clock/gxbb-aoclkc.h | 74 --------- include/dt-bindings/clock/gxbb-clkc.h | 151 ------------------ include/dt-bindings/gpio/meson-a1-gpio.h | 73 --------- include/dt-bindings/gpio/meson-axg-gpio.h | 116 -------------- include/dt-bindings/gpio/meson-g12a-gpio.h | 114 -------------- include/dt-bindings/gpio/meson-gxbb-gpio.h | 148 ------------------ include/dt-bindings/gpio/meson-gxl-gpio.h | 125 --------------- include/dt-bindings/power/meson-a1-power.h | 32 ---- include/dt-bindings/power/meson-axg-power.h | 14 -- include/dt-bindings/power/meson-g12a-power.h | 13 -- include/dt-bindings/power/meson-gxbb-power.h | 13 -- include/dt-bindings/power/meson-sm1-power.h | 18 --- include/dt-bindings/reset/amlogic,meson-a1-reset.h | 76 ---------- .../reset/amlogic,meson-axg-audio-arb.h | 19 --- .../dt-bindings/reset/amlogic,meson-axg-reset.h | 123 --------------- .../reset/amlogic,meson-g12a-audio-reset.h | 53 ------- .../dt-bindings/reset/amlogic,meson-g12a-reset.h | 137 ----------------- .../dt-bindings/reset/amlogic,meson-gxbb-reset.h | 161 -------------------- include/dt-bindings/reset/axg-aoclkc.h | 20 --- include/dt-bindings/reset/g12a-aoclkc.h | 18 --- include/dt-bindings/reset/gxbb-aoclkc.h | 66 -------- include/dt-bindings/sound/meson-aiu.h | 18 --- include/dt-bindings/sound/meson-g12a-toacodec.h | 10 -- include/dt-bindings/sound/meson-g12a-tohdmitx.h | 13 -- 31 files changed, 2212 deletions(-)
diff --git a/include/dt-bindings/clock/amlogic,a1-peripherals-clkc.h b/include/dt-bindings/clock/amlogic,a1-peripherals-clkc.h deleted file mode 100644 index 06f198ee7623..000000000000 --- a/include/dt-bindings/clock/amlogic,a1-peripherals-clkc.h +++ /dev/null @@ -1,168 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -/* - * Copyright (c) 2019 Amlogic, Inc. All rights reserved. - * Author: Jian Hu jian.hu@amlogic.com - * - * Copyright (c) 2023, SberDevices. All Rights Reserved. - * Author: Dmitry Rokosov ddrokosov@sberdevices.ru - */ - -#ifndef __A1_PERIPHERALS_CLKC_H -#define __A1_PERIPHERALS_CLKC_H - -#define CLKID_XTAL_IN 0 -#define CLKID_FIXPLL_IN 1 -#define CLKID_USB_PHY_IN 2 -#define CLKID_USB_CTRL_IN 3 -#define CLKID_HIFIPLL_IN 4 -#define CLKID_SYSPLL_IN 5 -#define CLKID_DDS_IN 6 -#define CLKID_SYS 7 -#define CLKID_CLKTREE 8 -#define CLKID_RESET_CTRL 9 -#define CLKID_ANALOG_CTRL 10 -#define CLKID_PWR_CTRL 11 -#define CLKID_PAD_CTRL 12 -#define CLKID_SYS_CTRL 13 -#define CLKID_TEMP_SENSOR 14 -#define CLKID_AM2AXI_DIV 15 -#define CLKID_SPICC_B 16 -#define CLKID_SPICC_A 17 -#define CLKID_MSR 18 -#define CLKID_AUDIO 19 -#define CLKID_JTAG_CTRL 20 -#define CLKID_SARADC_EN 21 -#define CLKID_PWM_EF 22 -#define CLKID_PWM_CD 23 -#define CLKID_PWM_AB 24 -#define CLKID_CEC 25 -#define CLKID_I2C_S 26 -#define CLKID_IR_CTRL 27 -#define CLKID_I2C_M_D 28 -#define CLKID_I2C_M_C 29 -#define CLKID_I2C_M_B 30 -#define CLKID_I2C_M_A 31 -#define CLKID_ACODEC 32 -#define CLKID_OTP 33 -#define CLKID_SD_EMMC_A 34 -#define CLKID_USB_PHY 35 -#define CLKID_USB_CTRL 36 -#define CLKID_SYS_DSPB 37 -#define CLKID_SYS_DSPA 38 -#define CLKID_DMA 39 -#define CLKID_IRQ_CTRL 40 -#define CLKID_NIC 41 -#define CLKID_GIC 42 -#define CLKID_UART_C 43 -#define CLKID_UART_B 44 -#define CLKID_UART_A 45 -#define CLKID_SYS_PSRAM 46 -#define CLKID_RSA 47 -#define CLKID_CORESIGHT 48 -#define CLKID_AM2AXI_VAD 49 -#define CLKID_AUDIO_VAD 50 -#define CLKID_AXI_DMC 51 -#define CLKID_AXI_PSRAM 52 -#define CLKID_RAMB 53 -#define CLKID_RAMA 54 -#define CLKID_AXI_SPIFC 55 -#define CLKID_AXI_NIC 56 -#define CLKID_AXI_DMA 57 -#define CLKID_CPU_CTRL 58 -#define CLKID_ROM 59 -#define CLKID_PROC_I2C 60 -#define CLKID_DSPA_SEL 61 -#define CLKID_DSPB_SEL 62 -#define CLKID_DSPA_EN 63 -#define CLKID_DSPA_EN_NIC 64 -#define CLKID_DSPB_EN 65 -#define CLKID_DSPB_EN_NIC 66 -#define CLKID_RTC 67 -#define CLKID_CECA_32K 68 -#define CLKID_CECB_32K 69 -#define CLKID_24M 70 -#define CLKID_12M 71 -#define CLKID_FCLK_DIV2_DIVN 72 -#define CLKID_GEN 73 -#define CLKID_SARADC_SEL 74 -#define CLKID_SARADC 75 -#define CLKID_PWM_A 76 -#define CLKID_PWM_B 77 -#define CLKID_PWM_C 78 -#define CLKID_PWM_D 79 -#define CLKID_PWM_E 80 -#define CLKID_PWM_F 81 -#define CLKID_SPICC 82 -#define CLKID_TS 83 -#define CLKID_SPIFC 84 -#define CLKID_USB_BUS 85 -#define CLKID_SD_EMMC 86 -#define CLKID_PSRAM 87 -#define CLKID_DMC 88 -#define CLKID_SYS_A_SEL 89 -#define CLKID_SYS_A_DIV 90 -#define CLKID_SYS_A 91 -#define CLKID_SYS_B_SEL 92 -#define CLKID_SYS_B_DIV 93 -#define CLKID_SYS_B 94 -#define CLKID_DSPA_A_SEL 95 -#define CLKID_DSPA_A_DIV 96 -#define CLKID_DSPA_A 97 -#define CLKID_DSPA_B_SEL 98 -#define CLKID_DSPA_B_DIV 99 -#define CLKID_DSPA_B 100 -#define CLKID_DSPB_A_SEL 101 -#define CLKID_DSPB_A_DIV 102 -#define CLKID_DSPB_A 103 -#define CLKID_DSPB_B_SEL 104 -#define CLKID_DSPB_B_DIV 105 -#define CLKID_DSPB_B 106 -#define CLKID_RTC_32K_IN 107 -#define CLKID_RTC_32K_DIV 108 -#define CLKID_RTC_32K_XTAL 109 -#define CLKID_RTC_32K_SEL 110 -#define CLKID_CECB_32K_IN 111 -#define CLKID_CECB_32K_DIV 112 -#define CLKID_CECB_32K_SEL_PRE 113 -#define CLKID_CECB_32K_SEL 114 -#define CLKID_CECA_32K_IN 115 -#define CLKID_CECA_32K_DIV 116 -#define CLKID_CECA_32K_SEL_PRE 117 -#define CLKID_CECA_32K_SEL 118 -#define CLKID_DIV2_PRE 119 -#define CLKID_24M_DIV2 120 -#define CLKID_GEN_SEL 121 -#define CLKID_GEN_DIV 122 -#define CLKID_SARADC_DIV 123 -#define CLKID_PWM_A_SEL 124 -#define CLKID_PWM_A_DIV 125 -#define CLKID_PWM_B_SEL 126 -#define CLKID_PWM_B_DIV 127 -#define CLKID_PWM_C_SEL 128 -#define CLKID_PWM_C_DIV 129 -#define CLKID_PWM_D_SEL 130 -#define CLKID_PWM_D_DIV 131 -#define CLKID_PWM_E_SEL 132 -#define CLKID_PWM_E_DIV 133 -#define CLKID_PWM_F_SEL 134 -#define CLKID_PWM_F_DIV 135 -#define CLKID_SPICC_SEL 136 -#define CLKID_SPICC_DIV 137 -#define CLKID_SPICC_SEL2 138 -#define CLKID_TS_DIV 139 -#define CLKID_SPIFC_SEL 140 -#define CLKID_SPIFC_DIV 141 -#define CLKID_SPIFC_SEL2 142 -#define CLKID_USB_BUS_SEL 143 -#define CLKID_USB_BUS_DIV 144 -#define CLKID_SD_EMMC_SEL 145 -#define CLKID_SD_EMMC_DIV 146 -#define CLKID_SD_EMMC_SEL2 147 -#define CLKID_PSRAM_SEL 148 -#define CLKID_PSRAM_DIV 149 -#define CLKID_PSRAM_SEL2 150 -#define CLKID_DMC_SEL 151 -#define CLKID_DMC_DIV 152 -#define CLKID_DMC_SEL2 153 - -#endif /* __A1_PERIPHERALS_CLKC_H */ diff --git a/include/dt-bindings/clock/amlogic,a1-pll-clkc.h b/include/dt-bindings/clock/amlogic,a1-pll-clkc.h deleted file mode 100644 index 2b660c0f2c9f..000000000000 --- a/include/dt-bindings/clock/amlogic,a1-pll-clkc.h +++ /dev/null @@ -1,25 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -/* - * Copyright (c) 2019 Amlogic, Inc. All rights reserved. - * Author: Jian Hu jian.hu@amlogic.com - * - * Copyright (c) 2023, SberDevices. All Rights Reserved. - * Author: Dmitry Rokosov ddrokosov@sberdevices.ru - */ - -#ifndef __A1_PLL_CLKC_H -#define __A1_PLL_CLKC_H - -#define CLKID_FIXED_PLL_DCO 0 -#define CLKID_FIXED_PLL 1 -#define CLKID_FCLK_DIV2_DIV 2 -#define CLKID_FCLK_DIV3_DIV 3 -#define CLKID_FCLK_DIV5_DIV 4 -#define CLKID_FCLK_DIV7_DIV 5 -#define CLKID_FCLK_DIV2 6 -#define CLKID_FCLK_DIV3 7 -#define CLKID_FCLK_DIV5 8 -#define CLKID_FCLK_DIV7 9 -#define CLKID_HIFI_PLL 10 - -#endif /* __A1_PLL_CLKC_H */ diff --git a/include/dt-bindings/clock/axg-aoclkc.h b/include/dt-bindings/clock/axg-aoclkc.h deleted file mode 100644 index 8ec4a269c7a6..000000000000 --- a/include/dt-bindings/clock/axg-aoclkc.h +++ /dev/null @@ -1,31 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) */ -/* - * Copyright (c) 2016 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Copyright (c) 2018 Amlogic, inc. - * Author: Qiufang Dai qiufang.dai@amlogic.com - */ - -#ifndef DT_BINDINGS_CLOCK_AMLOGIC_MESON_AXG_AOCLK -#define DT_BINDINGS_CLOCK_AMLOGIC_MESON_AXG_AOCLK - -#define CLKID_AO_REMOTE 0 -#define CLKID_AO_I2C_MASTER 1 -#define CLKID_AO_I2C_SLAVE 2 -#define CLKID_AO_UART1 3 -#define CLKID_AO_UART2 4 -#define CLKID_AO_IR_BLASTER 5 -#define CLKID_AO_SAR_ADC 6 -#define CLKID_AO_CLK81 7 -#define CLKID_AO_SAR_ADC_SEL 8 -#define CLKID_AO_SAR_ADC_DIV 9 -#define CLKID_AO_SAR_ADC_CLK 10 -#define CLKID_AO_CTS_OSCIN 11 -#define CLKID_AO_32K_PRE 12 -#define CLKID_AO_32K_DIV 13 -#define CLKID_AO_32K_SEL 14 -#define CLKID_AO_32K 15 -#define CLKID_AO_CTS_RTC_OSCIN 16 - -#endif diff --git a/include/dt-bindings/clock/axg-audio-clkc.h b/include/dt-bindings/clock/axg-audio-clkc.h deleted file mode 100644 index f561f5c5ef8f..000000000000 --- a/include/dt-bindings/clock/axg-audio-clkc.h +++ /dev/null @@ -1,94 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (c) 2018 Baylibre SAS. - * Author: Jerome Brunet jbrunet@baylibre.com - */ - -#ifndef __AXG_AUDIO_CLKC_BINDINGS_H -#define __AXG_AUDIO_CLKC_BINDINGS_H - -#define AUD_CLKID_DDR_ARB 29 -#define AUD_CLKID_PDM 30 -#define AUD_CLKID_TDMIN_A 31 -#define AUD_CLKID_TDMIN_B 32 -#define AUD_CLKID_TDMIN_C 33 -#define AUD_CLKID_TDMIN_LB 34 -#define AUD_CLKID_TDMOUT_A 35 -#define AUD_CLKID_TDMOUT_B 36 -#define AUD_CLKID_TDMOUT_C 37 -#define AUD_CLKID_FRDDR_A 38 -#define AUD_CLKID_FRDDR_B 39 -#define AUD_CLKID_FRDDR_C 40 -#define AUD_CLKID_TODDR_A 41 -#define AUD_CLKID_TODDR_B 42 -#define AUD_CLKID_TODDR_C 43 -#define AUD_CLKID_LOOPBACK 44 -#define AUD_CLKID_SPDIFIN 45 -#define AUD_CLKID_SPDIFOUT 46 -#define AUD_CLKID_RESAMPLE 47 -#define AUD_CLKID_POWER_DETECT 48 -#define AUD_CLKID_MST_A_MCLK 49 -#define AUD_CLKID_MST_B_MCLK 50 -#define AUD_CLKID_MST_C_MCLK 51 -#define AUD_CLKID_MST_D_MCLK 52 -#define AUD_CLKID_MST_E_MCLK 53 -#define AUD_CLKID_MST_F_MCLK 54 -#define AUD_CLKID_SPDIFOUT_CLK 55 -#define AUD_CLKID_SPDIFIN_CLK 56 -#define AUD_CLKID_PDM_DCLK 57 -#define AUD_CLKID_PDM_SYSCLK 58 -#define AUD_CLKID_MST_A_SCLK 79 -#define AUD_CLKID_MST_B_SCLK 80 -#define AUD_CLKID_MST_C_SCLK 81 -#define AUD_CLKID_MST_D_SCLK 82 -#define AUD_CLKID_MST_E_SCLK 83 -#define AUD_CLKID_MST_F_SCLK 84 -#define AUD_CLKID_MST_A_LRCLK 86 -#define AUD_CLKID_MST_B_LRCLK 87 -#define AUD_CLKID_MST_C_LRCLK 88 -#define AUD_CLKID_MST_D_LRCLK 89 -#define AUD_CLKID_MST_E_LRCLK 90 -#define AUD_CLKID_MST_F_LRCLK 91 -#define AUD_CLKID_TDMIN_A_SCLK_SEL 116 -#define AUD_CLKID_TDMIN_B_SCLK_SEL 117 -#define AUD_CLKID_TDMIN_C_SCLK_SEL 118 -#define AUD_CLKID_TDMIN_LB_SCLK_SEL 119 -#define AUD_CLKID_TDMOUT_A_SCLK_SEL 120 -#define AUD_CLKID_TDMOUT_B_SCLK_SEL 121 -#define AUD_CLKID_TDMOUT_C_SCLK_SEL 122 -#define AUD_CLKID_TDMIN_A_SCLK 123 -#define AUD_CLKID_TDMIN_B_SCLK 124 -#define AUD_CLKID_TDMIN_C_SCLK 125 -#define AUD_CLKID_TDMIN_LB_SCLK 126 -#define AUD_CLKID_TDMOUT_A_SCLK 127 -#define AUD_CLKID_TDMOUT_B_SCLK 128 -#define AUD_CLKID_TDMOUT_C_SCLK 129 -#define AUD_CLKID_TDMIN_A_LRCLK 130 -#define AUD_CLKID_TDMIN_B_LRCLK 131 -#define AUD_CLKID_TDMIN_C_LRCLK 132 -#define AUD_CLKID_TDMIN_LB_LRCLK 133 -#define AUD_CLKID_TDMOUT_A_LRCLK 134 -#define AUD_CLKID_TDMOUT_B_LRCLK 135 -#define AUD_CLKID_TDMOUT_C_LRCLK 136 -#define AUD_CLKID_SPDIFOUT_B 151 -#define AUD_CLKID_SPDIFOUT_B_CLK 152 -#define AUD_CLKID_TDM_MCLK_PAD0 155 -#define AUD_CLKID_TDM_MCLK_PAD1 156 -#define AUD_CLKID_TDM_LRCLK_PAD0 157 -#define AUD_CLKID_TDM_LRCLK_PAD1 158 -#define AUD_CLKID_TDM_LRCLK_PAD2 159 -#define AUD_CLKID_TDM_SCLK_PAD0 160 -#define AUD_CLKID_TDM_SCLK_PAD1 161 -#define AUD_CLKID_TDM_SCLK_PAD2 162 -#define AUD_CLKID_TOP 163 -#define AUD_CLKID_TORAM 164 -#define AUD_CLKID_EQDRC 165 -#define AUD_CLKID_RESAMPLE_B 166 -#define AUD_CLKID_TOVAD 167 -#define AUD_CLKID_LOCKER 168 -#define AUD_CLKID_SPDIFIN_LB 169 -#define AUD_CLKID_FRDDR_D 170 -#define AUD_CLKID_TODDR_D 171 -#define AUD_CLKID_LOOPBACK_B 172 - -#endif /* __AXG_AUDIO_CLKC_BINDINGS_H */ diff --git a/include/dt-bindings/clock/axg-clkc.h b/include/dt-bindings/clock/axg-clkc.h deleted file mode 100644 index 93752ea107e3..000000000000 --- a/include/dt-bindings/clock/axg-clkc.h +++ /dev/null @@ -1,100 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Meson-AXG clock tree IDs - * - * Copyright (c) 2017 Amlogic, Inc. All rights reserved. - */ - -#ifndef __AXG_CLKC_H -#define __AXG_CLKC_H - -#define CLKID_SYS_PLL 0 -#define CLKID_FIXED_PLL 1 -#define CLKID_FCLK_DIV2 2 -#define CLKID_FCLK_DIV3 3 -#define CLKID_FCLK_DIV4 4 -#define CLKID_FCLK_DIV5 5 -#define CLKID_FCLK_DIV7 6 -#define CLKID_GP0_PLL 7 -#define CLKID_CLK81 10 -#define CLKID_MPLL0 11 -#define CLKID_MPLL1 12 -#define CLKID_MPLL2 13 -#define CLKID_MPLL3 14 -#define CLKID_DDR 15 -#define CLKID_AUDIO_LOCKER 16 -#define CLKID_MIPI_DSI_HOST 17 -#define CLKID_ISA 18 -#define CLKID_PL301 19 -#define CLKID_PERIPHS 20 -#define CLKID_SPICC0 21 -#define CLKID_I2C 22 -#define CLKID_RNG0 23 -#define CLKID_UART0 24 -#define CLKID_MIPI_DSI_PHY 25 -#define CLKID_SPICC1 26 -#define CLKID_PCIE_A 27 -#define CLKID_PCIE_B 28 -#define CLKID_HIU_IFACE 29 -#define CLKID_ASSIST_MISC 30 -#define CLKID_SD_EMMC_B 31 -#define CLKID_SD_EMMC_C 32 -#define CLKID_DMA 33 -#define CLKID_SPI 34 -#define CLKID_AUDIO 35 -#define CLKID_ETH 36 -#define CLKID_UART1 37 -#define CLKID_G2D 38 -#define CLKID_USB0 39 -#define CLKID_USB1 40 -#define CLKID_RESET 41 -#define CLKID_USB 42 -#define CLKID_AHB_ARB0 43 -#define CLKID_EFUSE 44 -#define CLKID_BOOT_ROM 45 -#define CLKID_AHB_DATA_BUS 46 -#define CLKID_AHB_CTRL_BUS 47 -#define CLKID_USB1_DDR_BRIDGE 48 -#define CLKID_USB0_DDR_BRIDGE 49 -#define CLKID_MMC_PCLK 50 -#define CLKID_VPU_INTR 51 -#define CLKID_SEC_AHB_AHB3_BRIDGE 52 -#define CLKID_GIC 53 -#define CLKID_AO_MEDIA_CPU 54 -#define CLKID_AO_AHB_SRAM 55 -#define CLKID_AO_AHB_BUS 56 -#define CLKID_AO_IFACE 57 -#define CLKID_AO_I2C 58 -#define CLKID_SD_EMMC_B_CLK0 59 -#define CLKID_SD_EMMC_C_CLK0 60 -#define CLKID_HIFI_PLL 69 -#define CLKID_PCIE_CML_EN0 79 -#define CLKID_PCIE_CML_EN1 80 -#define CLKID_GEN_CLK 84 -#define CLKID_VPU_0_SEL 92 -#define CLKID_VPU_0 93 -#define CLKID_VPU_1_SEL 95 -#define CLKID_VPU_1 96 -#define CLKID_VPU 97 -#define CLKID_VAPB_0_SEL 99 -#define CLKID_VAPB_0 100 -#define CLKID_VAPB_1_SEL 102 -#define CLKID_VAPB_1 103 -#define CLKID_VAPB_SEL 104 -#define CLKID_VAPB 105 -#define CLKID_VCLK 106 -#define CLKID_VCLK2 107 -#define CLKID_VCLK_DIV1 122 -#define CLKID_VCLK_DIV2 123 -#define CLKID_VCLK_DIV4 124 -#define CLKID_VCLK_DIV6 125 -#define CLKID_VCLK_DIV12 126 -#define CLKID_VCLK2_DIV1 127 -#define CLKID_VCLK2_DIV2 128 -#define CLKID_VCLK2_DIV4 129 -#define CLKID_VCLK2_DIV6 130 -#define CLKID_VCLK2_DIV12 131 -#define CLKID_CTS_ENCL 133 -#define CLKID_VDIN_MEAS 136 - -#endif /* __AXG_CLKC_H */ diff --git a/include/dt-bindings/clock/g12a-aoclkc.h b/include/dt-bindings/clock/g12a-aoclkc.h deleted file mode 100644 index e916e49ff288..000000000000 --- a/include/dt-bindings/clock/g12a-aoclkc.h +++ /dev/null @@ -1,36 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) */ -/* - * Copyright (c) 2016 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Copyright (c) 2018 Amlogic, inc. - * Author: Qiufang Dai qiufang.dai@amlogic.com - */ - -#ifndef DT_BINDINGS_CLOCK_AMLOGIC_MESON_G12A_AOCLK -#define DT_BINDINGS_CLOCK_AMLOGIC_MESON_G12A_AOCLK - -#define CLKID_AO_AHB 0 -#define CLKID_AO_IR_IN 1 -#define CLKID_AO_I2C_M0 2 -#define CLKID_AO_I2C_S0 3 -#define CLKID_AO_UART 4 -#define CLKID_AO_PROD_I2C 5 -#define CLKID_AO_UART2 6 -#define CLKID_AO_IR_OUT 7 -#define CLKID_AO_SAR_ADC 8 -#define CLKID_AO_MAILBOX 9 -#define CLKID_AO_M3 10 -#define CLKID_AO_AHB_SRAM 11 -#define CLKID_AO_RTI 12 -#define CLKID_AO_M4_FCLK 13 -#define CLKID_AO_M4_HCLK 14 -#define CLKID_AO_CLK81 15 -#define CLKID_AO_SAR_ADC_SEL 16 -#define CLKID_AO_SAR_ADC_CLK 18 -#define CLKID_AO_CTS_OSCIN 19 -#define CLKID_AO_32K 23 -#define CLKID_AO_CEC 27 -#define CLKID_AO_CTS_RTC_OSCIN 28 - -#endif diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h deleted file mode 100644 index a93b58c5e18e..000000000000 --- a/include/dt-bindings/clock/g12a-clkc.h +++ /dev/null @@ -1,153 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ -/* - * Meson-G12A clock tree IDs - * - * Copyright (c) 2018 Amlogic, Inc. All rights reserved. - */ - -#ifndef __G12A_CLKC_H -#define __G12A_CLKC_H - -#define CLKID_SYS_PLL 0 -#define CLKID_FIXED_PLL 1 -#define CLKID_FCLK_DIV2 2 -#define CLKID_FCLK_DIV3 3 -#define CLKID_FCLK_DIV4 4 -#define CLKID_FCLK_DIV5 5 -#define CLKID_FCLK_DIV7 6 -#define CLKID_GP0_PLL 7 -#define CLKID_CLK81 10 -#define CLKID_MPLL0 11 -#define CLKID_MPLL1 12 -#define CLKID_MPLL2 13 -#define CLKID_MPLL3 14 -#define CLKID_DDR 15 -#define CLKID_DOS 16 -#define CLKID_AUDIO_LOCKER 17 -#define CLKID_MIPI_DSI_HOST 18 -#define CLKID_ETH_PHY 19 -#define CLKID_ISA 20 -#define CLKID_PL301 21 -#define CLKID_PERIPHS 22 -#define CLKID_SPICC0 23 -#define CLKID_I2C 24 -#define CLKID_SANA 25 -#define CLKID_SD 26 -#define CLKID_RNG0 27 -#define CLKID_UART0 28 -#define CLKID_SPICC1 29 -#define CLKID_HIU_IFACE 30 -#define CLKID_MIPI_DSI_PHY 31 -#define CLKID_ASSIST_MISC 32 -#define CLKID_SD_EMMC_A 33 -#define CLKID_SD_EMMC_B 34 -#define CLKID_SD_EMMC_C 35 -#define CLKID_AUDIO_CODEC 36 -#define CLKID_AUDIO 37 -#define CLKID_ETH 38 -#define CLKID_DEMUX 39 -#define CLKID_AUDIO_IFIFO 40 -#define CLKID_ADC 41 -#define CLKID_UART1 42 -#define CLKID_G2D 43 -#define CLKID_RESET 44 -#define CLKID_PCIE_COMB 45 -#define CLKID_PARSER 46 -#define CLKID_USB 47 -#define CLKID_PCIE_PHY 48 -#define CLKID_AHB_ARB0 49 -#define CLKID_AHB_DATA_BUS 50 -#define CLKID_AHB_CTRL_BUS 51 -#define CLKID_HTX_HDCP22 52 -#define CLKID_HTX_PCLK 53 -#define CLKID_BT656 54 -#define CLKID_USB1_DDR_BRIDGE 55 -#define CLKID_MMC_PCLK 56 -#define CLKID_UART2 57 -#define CLKID_VPU_INTR 58 -#define CLKID_GIC 59 -#define CLKID_SD_EMMC_A_CLK0 60 -#define CLKID_SD_EMMC_B_CLK0 61 -#define CLKID_SD_EMMC_C_CLK0 62 -#define CLKID_HIFI_PLL 74 -#define CLKID_VCLK2_VENCI0 80 -#define CLKID_VCLK2_VENCI1 81 -#define CLKID_VCLK2_VENCP0 82 -#define CLKID_VCLK2_VENCP1 83 -#define CLKID_VCLK2_VENCT0 84 -#define CLKID_VCLK2_VENCT1 85 -#define CLKID_VCLK2_OTHER 86 -#define CLKID_VCLK2_ENCI 87 -#define CLKID_VCLK2_ENCP 88 -#define CLKID_DAC_CLK 89 -#define CLKID_AOCLK 90 -#define CLKID_IEC958 91 -#define CLKID_ENC480P 92 -#define CLKID_RNG1 93 -#define CLKID_VCLK2_ENCT 94 -#define CLKID_VCLK2_ENCL 95 -#define CLKID_VCLK2_VENCLMMC 96 -#define CLKID_VCLK2_VENCL 97 -#define CLKID_VCLK2_OTHER1 98 -#define CLKID_FCLK_DIV2P5 99 -#define CLKID_DMA 105 -#define CLKID_EFUSE 106 -#define CLKID_ROM_BOOT 107 -#define CLKID_RESET_SEC 108 -#define CLKID_SEC_AHB_APB3 109 -#define CLKID_VPU_0_SEL 110 -#define CLKID_VPU_0 112 -#define CLKID_VPU_1_SEL 113 -#define CLKID_VPU_1 115 -#define CLKID_VPU 116 -#define CLKID_VAPB_0_SEL 117 -#define CLKID_VAPB_0 119 -#define CLKID_VAPB_1_SEL 120 -#define CLKID_VAPB_1 122 -#define CLKID_VAPB_SEL 123 -#define CLKID_VAPB 124 -#define CLKID_HDMI_PLL 128 -#define CLKID_VID_PLL 129 -#define CLKID_VCLK 138 -#define CLKID_VCLK2 139 -#define CLKID_VCLK_DIV1 148 -#define CLKID_VCLK_DIV2 149 -#define CLKID_VCLK_DIV4 150 -#define CLKID_VCLK_DIV6 151 -#define CLKID_VCLK_DIV12 152 -#define CLKID_VCLK2_DIV1 153 -#define CLKID_VCLK2_DIV2 154 -#define CLKID_VCLK2_DIV4 155 -#define CLKID_VCLK2_DIV6 156 -#define CLKID_VCLK2_DIV12 157 -#define CLKID_CTS_ENCI 162 -#define CLKID_CTS_ENCP 163 -#define CLKID_CTS_VDAC 164 -#define CLKID_HDMI_TX 165 -#define CLKID_HDMI 168 -#define CLKID_MALI_0_SEL 169 -#define CLKID_MALI_0 171 -#define CLKID_MALI_1_SEL 172 -#define CLKID_MALI_1 174 -#define CLKID_MALI 175 -#define CLKID_MPLL_50M 177 -#define CLKID_CPU_CLK 187 -#define CLKID_PCIE_PLL 201 -#define CLKID_VDEC_1 204 -#define CLKID_VDEC_HEVC 207 -#define CLKID_VDEC_HEVCF 210 -#define CLKID_TS 212 -#define CLKID_CPUB_CLK 224 -#define CLKID_GP1_PLL 243 -#define CLKID_DSU_CLK 252 -#define CLKID_CPU1_CLK 253 -#define CLKID_CPU2_CLK 254 -#define CLKID_CPU3_CLK 255 -#define CLKID_SPICC0_SCLK 258 -#define CLKID_SPICC1_SCLK 261 -#define CLKID_NNA_AXI_CLK 264 -#define CLKID_NNA_CORE_CLK 267 -#define CLKID_MIPI_DSI_PXCLK_SEL 269 -#define CLKID_MIPI_DSI_PXCLK 270 - -#endif /* __G12A_CLKC_H */ diff --git a/include/dt-bindings/clock/gxbb-aoclkc.h b/include/dt-bindings/clock/gxbb-aoclkc.h deleted file mode 100644 index ec3b26319fc4..000000000000 --- a/include/dt-bindings/clock/gxbb-aoclkc.h +++ /dev/null @@ -1,74 +0,0 @@ -/* - * This file is provided under a dual BSD/GPLv2 license. When using or - * redistributing this file, you may do so under either license. - * - * GPL LICENSE SUMMARY - * - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of version 2 of the GNU General Public License as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU - * General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, see http://www.gnu.org/licenses/. - * The full GNU General Public License is included in this distribution - * in the file called COPYING. - * - * BSD LICENSE - * - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * * Neither the name of Intel Corporation nor the names of its - * contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS - * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT - * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR - * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT - * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, - * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY - * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE - * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - */ - -#ifndef DT_BINDINGS_CLOCK_AMLOGIC_MESON_GXBB_AOCLK -#define DT_BINDINGS_CLOCK_AMLOGIC_MESON_GXBB_AOCLK - -#define CLKID_AO_REMOTE 0 -#define CLKID_AO_I2C_MASTER 1 -#define CLKID_AO_I2C_SLAVE 2 -#define CLKID_AO_UART1 3 -#define CLKID_AO_UART2 4 -#define CLKID_AO_IR_BLASTER 5 -#define CLKID_AO_CEC_32K 6 -#define CLKID_AO_CTS_OSCIN 7 -#define CLKID_AO_32K_PRE 8 -#define CLKID_AO_32K_DIV 9 -#define CLKID_AO_32K_SEL 10 -#define CLKID_AO_32K 11 -#define CLKID_AO_CTS_RTC_OSCIN 12 -#define CLKID_AO_CLK81 13 - -#endif diff --git a/include/dt-bindings/clock/gxbb-clkc.h b/include/dt-bindings/clock/gxbb-clkc.h deleted file mode 100644 index 4073eb7a9da1..000000000000 --- a/include/dt-bindings/clock/gxbb-clkc.h +++ /dev/null @@ -1,151 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * GXBB clock tree IDs - */ - -#ifndef __GXBB_CLKC_H -#define __GXBB_CLKC_H - -#define CLKID_SYS_PLL 0 -#define CLKID_HDMI_PLL 2 -#define CLKID_FIXED_PLL 3 -#define CLKID_FCLK_DIV2 4 -#define CLKID_FCLK_DIV3 5 -#define CLKID_FCLK_DIV4 6 -#define CLKID_FCLK_DIV5 7 -#define CLKID_FCLK_DIV7 8 -#define CLKID_GP0_PLL 9 -#define CLKID_CLK81 12 -#define CLKID_MPLL0 13 -#define CLKID_MPLL1 14 -#define CLKID_MPLL2 15 -#define CLKID_DDR 16 -#define CLKID_DOS 17 -#define CLKID_ISA 18 -#define CLKID_PL301 19 -#define CLKID_PERIPHS 20 -#define CLKID_SPICC 21 -#define CLKID_I2C 22 -#define CLKID_SAR_ADC 23 -#define CLKID_SMART_CARD 24 -#define CLKID_RNG0 25 -#define CLKID_UART0 26 -#define CLKID_SDHC 27 -#define CLKID_STREAM 28 -#define CLKID_ASYNC_FIFO 29 -#define CLKID_SDIO 30 -#define CLKID_ABUF 31 -#define CLKID_HIU_IFACE 32 -#define CLKID_ASSIST_MISC 33 -#define CLKID_SPI 34 -#define CLKID_ETH 36 -#define CLKID_I2S_SPDIF 35 -#define CLKID_DEMUX 37 -#define CLKID_AIU_GLUE 38 -#define CLKID_IEC958 39 -#define CLKID_I2S_OUT 40 -#define CLKID_AMCLK 41 -#define CLKID_AIFIFO2 42 -#define CLKID_MIXER 43 -#define CLKID_MIXER_IFACE 44 -#define CLKID_ADC 45 -#define CLKID_BLKMV 46 -#define CLKID_AIU 47 -#define CLKID_UART1 48 -#define CLKID_G2D 49 -#define CLKID_USB0 50 -#define CLKID_USB1 51 -#define CLKID_RESET 52 -#define CLKID_NAND 53 -#define CLKID_DOS_PARSER 54 -#define CLKID_USB 55 -#define CLKID_VDIN1 56 -#define CLKID_AHB_ARB0 57 -#define CLKID_EFUSE 58 -#define CLKID_BOOT_ROM 59 -#define CLKID_AHB_DATA_BUS 60 -#define CLKID_AHB_CTRL_BUS 61 -#define CLKID_HDMI_INTR_SYNC 62 -#define CLKID_HDMI_PCLK 63 -#define CLKID_USB1_DDR_BRIDGE 64 -#define CLKID_USB0_DDR_BRIDGE 65 -#define CLKID_MMC_PCLK 66 -#define CLKID_DVIN 67 -#define CLKID_UART2 68 -#define CLKID_SANA 69 -#define CLKID_VPU_INTR 70 -#define CLKID_SEC_AHB_AHB3_BRIDGE 71 -#define CLKID_CLK81_A53 72 -#define CLKID_VCLK2_VENCI0 73 -#define CLKID_VCLK2_VENCI1 74 -#define CLKID_VCLK2_VENCP0 75 -#define CLKID_VCLK2_VENCP1 76 -#define CLKID_GCLK_VENCI_INT0 77 -#define CLKID_GCLK_VENCI_INT 78 -#define CLKID_DAC_CLK 79 -#define CLKID_AOCLK_GATE 80 -#define CLKID_IEC958_GATE 81 -#define CLKID_ENC480P 82 -#define CLKID_RNG1 83 -#define CLKID_GCLK_VENCI_INT1 84 -#define CLKID_VCLK2_VENCLMCC 85 -#define CLKID_VCLK2_VENCL 86 -#define CLKID_VCLK_OTHER 87 -#define CLKID_EDP 88 -#define CLKID_AO_MEDIA_CPU 89 -#define CLKID_AO_AHB_SRAM 90 -#define CLKID_AO_AHB_BUS 91 -#define CLKID_AO_IFACE 92 -#define CLKID_AO_I2C 93 -#define CLKID_SD_EMMC_A 94 -#define CLKID_SD_EMMC_B 95 -#define CLKID_SD_EMMC_C 96 -#define CLKID_SAR_ADC_CLK 97 -#define CLKID_SAR_ADC_SEL 98 -#define CLKID_MALI_0_SEL 100 -#define CLKID_MALI_0 102 -#define CLKID_MALI_1_SEL 103 -#define CLKID_MALI_1 105 -#define CLKID_MALI 106 -#define CLKID_CTS_AMCLK 107 -#define CLKID_CTS_MCLK_I958 110 -#define CLKID_CTS_I958 113 -#define CLKID_32K_CLK 114 -#define CLKID_SD_EMMC_A_CLK0 119 -#define CLKID_SD_EMMC_B_CLK0 122 -#define CLKID_SD_EMMC_C_CLK0 125 -#define CLKID_VPU_0_SEL 126 -#define CLKID_VPU_0 128 -#define CLKID_VPU_1_SEL 129 -#define CLKID_VPU_1 131 -#define CLKID_VPU 132 -#define CLKID_VAPB_0_SEL 133 -#define CLKID_VAPB_0 135 -#define CLKID_VAPB_1_SEL 136 -#define CLKID_VAPB_1 138 -#define CLKID_VAPB_SEL 139 -#define CLKID_VAPB 140 -#define CLKID_VDEC_1 153 -#define CLKID_VDEC_HEVC 156 -#define CLKID_GEN_CLK 159 -#define CLKID_VID_PLL 166 -#define CLKID_VCLK 175 -#define CLKID_VCLK2 176 -#define CLKID_VCLK_DIV1 185 -#define CLKID_VCLK_DIV2 186 -#define CLKID_VCLK_DIV4 187 -#define CLKID_VCLK_DIV6 188 -#define CLKID_VCLK_DIV12 189 -#define CLKID_VCLK2_DIV1 190 -#define CLKID_VCLK2_DIV2 191 -#define CLKID_VCLK2_DIV4 192 -#define CLKID_VCLK2_DIV6 193 -#define CLKID_VCLK2_DIV12 194 -#define CLKID_CTS_ENCI 199 -#define CLKID_CTS_ENCP 200 -#define CLKID_CTS_VDAC 201 -#define CLKID_HDMI_TX 202 -#define CLKID_HDMI 205 -#define CLKID_ACODEC 206 - -#endif /* __GXBB_CLKC_H */ diff --git a/include/dt-bindings/gpio/meson-a1-gpio.h b/include/dt-bindings/gpio/meson-a1-gpio.h deleted file mode 100644 index 40e57a5ff1db..000000000000 --- a/include/dt-bindings/gpio/meson-a1-gpio.h +++ /dev/null @@ -1,73 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (c) 2019 Amlogic, Inc. All rights reserved. - * Author: Qianggui Song qianggui.song@amlogic.com - */ - -#ifndef _DT_BINDINGS_MESON_A1_GPIO_H -#define _DT_BINDINGS_MESON_A1_GPIO_H - -#define GPIOP_0 0 -#define GPIOP_1 1 -#define GPIOP_2 2 -#define GPIOP_3 3 -#define GPIOP_4 4 -#define GPIOP_5 5 -#define GPIOP_6 6 -#define GPIOP_7 7 -#define GPIOP_8 8 -#define GPIOP_9 9 -#define GPIOP_10 10 -#define GPIOP_11 11 -#define GPIOP_12 12 -#define GPIOB_0 13 -#define GPIOB_1 14 -#define GPIOB_2 15 -#define GPIOB_3 16 -#define GPIOB_4 17 -#define GPIOB_5 18 -#define GPIOB_6 19 -#define GPIOX_0 20 -#define GPIOX_1 21 -#define GPIOX_2 22 -#define GPIOX_3 23 -#define GPIOX_4 24 -#define GPIOX_5 25 -#define GPIOX_6 26 -#define GPIOX_7 27 -#define GPIOX_8 28 -#define GPIOX_9 29 -#define GPIOX_10 30 -#define GPIOX_11 31 -#define GPIOX_12 32 -#define GPIOX_13 33 -#define GPIOX_14 34 -#define GPIOX_15 35 -#define GPIOX_16 36 -#define GPIOF_0 37 -#define GPIOF_1 38 -#define GPIOF_2 39 -#define GPIOF_3 40 -#define GPIOF_4 41 -#define GPIOF_5 42 -#define GPIOF_6 43 -#define GPIOF_7 44 -#define GPIOF_8 45 -#define GPIOF_9 46 -#define GPIOF_10 47 -#define GPIOF_11 48 -#define GPIOF_12 49 -#define GPIOA_0 50 -#define GPIOA_1 51 -#define GPIOA_2 52 -#define GPIOA_3 53 -#define GPIOA_4 54 -#define GPIOA_5 55 -#define GPIOA_6 56 -#define GPIOA_7 57 -#define GPIOA_8 58 -#define GPIOA_9 59 -#define GPIOA_10 60 -#define GPIOA_11 61 - -#endif /* _DT_BINDINGS_MESON_A1_GPIO_H */ diff --git a/include/dt-bindings/gpio/meson-axg-gpio.h b/include/dt-bindings/gpio/meson-axg-gpio.h deleted file mode 100644 index 25bb1fffa97a..000000000000 --- a/include/dt-bindings/gpio/meson-axg-gpio.h +++ /dev/null @@ -1,116 +0,0 @@ -/* - * Copyright (c) 2017 Amlogic, Inc. All rights reserved. - * Author: Xingyu Chen xingyu.chen@amlogic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _DT_BINDINGS_MESON_AXG_GPIO_H -#define _DT_BINDINGS_MESON_AXG_GPIO_H - -/* First GPIO chip */ -#define GPIOAO_0 0 -#define GPIOAO_1 1 -#define GPIOAO_2 2 -#define GPIOAO_3 3 -#define GPIOAO_4 4 -#define GPIOAO_5 5 -#define GPIOAO_6 6 -#define GPIOAO_7 7 -#define GPIOAO_8 8 -#define GPIOAO_9 9 -#define GPIOAO_10 10 -#define GPIOAO_11 11 -#define GPIOAO_12 12 -#define GPIOAO_13 13 -#define GPIO_TEST_N 14 - -/* Second GPIO chip */ -#define GPIOZ_0 0 -#define GPIOZ_1 1 -#define GPIOZ_2 2 -#define GPIOZ_3 3 -#define GPIOZ_4 4 -#define GPIOZ_5 5 -#define GPIOZ_6 6 -#define GPIOZ_7 7 -#define GPIOZ_8 8 -#define GPIOZ_9 9 -#define GPIOZ_10 10 -#define BOOT_0 11 -#define BOOT_1 12 -#define BOOT_2 13 -#define BOOT_3 14 -#define BOOT_4 15 -#define BOOT_5 16 -#define BOOT_6 17 -#define BOOT_7 18 -#define BOOT_8 19 -#define BOOT_9 20 -#define BOOT_10 21 -#define BOOT_11 22 -#define BOOT_12 23 -#define BOOT_13 24 -#define BOOT_14 25 -#define GPIOA_0 26 -#define GPIOA_1 27 -#define GPIOA_2 28 -#define GPIOA_3 29 -#define GPIOA_4 30 -#define GPIOA_5 31 -#define GPIOA_6 32 -#define GPIOA_7 33 -#define GPIOA_8 34 -#define GPIOA_9 35 -#define GPIOA_10 36 -#define GPIOA_11 37 -#define GPIOA_12 38 -#define GPIOA_13 39 -#define GPIOA_14 40 -#define GPIOA_15 41 -#define GPIOA_16 42 -#define GPIOA_17 43 -#define GPIOA_18 44 -#define GPIOA_19 45 -#define GPIOA_20 46 -#define GPIOX_0 47 -#define GPIOX_1 48 -#define GPIOX_2 49 -#define GPIOX_3 50 -#define GPIOX_4 51 -#define GPIOX_5 52 -#define GPIOX_6 53 -#define GPIOX_7 54 -#define GPIOX_8 55 -#define GPIOX_9 56 -#define GPIOX_10 57 -#define GPIOX_11 58 -#define GPIOX_12 59 -#define GPIOX_13 60 -#define GPIOX_14 61 -#define GPIOX_15 62 -#define GPIOX_16 63 -#define GPIOX_17 64 -#define GPIOX_18 65 -#define GPIOX_19 66 -#define GPIOX_20 67 -#define GPIOX_21 68 -#define GPIOX_22 69 -#define GPIOY_0 70 -#define GPIOY_1 71 -#define GPIOY_2 72 -#define GPIOY_3 73 -#define GPIOY_4 74 -#define GPIOY_5 75 -#define GPIOY_6 76 -#define GPIOY_7 77 -#define GPIOY_8 78 -#define GPIOY_9 79 -#define GPIOY_10 80 -#define GPIOY_11 81 -#define GPIOY_12 82 -#define GPIOY_13 83 -#define GPIOY_14 84 -#define GPIOY_15 85 - -#endif /* _DT_BINDINGS_MESON_AXG_GPIO_H */ diff --git a/include/dt-bindings/gpio/meson-g12a-gpio.h b/include/dt-bindings/gpio/meson-g12a-gpio.h deleted file mode 100644 index f7bd69350d18..000000000000 --- a/include/dt-bindings/gpio/meson-g12a-gpio.h +++ /dev/null @@ -1,114 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2018 Amlogic, Inc. All rights reserved. - * Author: Xingyu Chen xingyu.chen@amlogic.com - */ - -#ifndef _DT_BINDINGS_MESON_G12A_GPIO_H -#define _DT_BINDINGS_MESON_G12A_GPIO_H - -/* First GPIO chip */ -#define GPIOAO_0 0 -#define GPIOAO_1 1 -#define GPIOAO_2 2 -#define GPIOAO_3 3 -#define GPIOAO_4 4 -#define GPIOAO_5 5 -#define GPIOAO_6 6 -#define GPIOAO_7 7 -#define GPIOAO_8 8 -#define GPIOAO_9 9 -#define GPIOAO_10 10 -#define GPIOAO_11 11 -#define GPIOE_0 12 -#define GPIOE_1 13 -#define GPIOE_2 14 - -/* Second GPIO chip */ -#define GPIOZ_0 0 -#define GPIOZ_1 1 -#define GPIOZ_2 2 -#define GPIOZ_3 3 -#define GPIOZ_4 4 -#define GPIOZ_5 5 -#define GPIOZ_6 6 -#define GPIOZ_7 7 -#define GPIOZ_8 8 -#define GPIOZ_9 9 -#define GPIOZ_10 10 -#define GPIOZ_11 11 -#define GPIOZ_12 12 -#define GPIOZ_13 13 -#define GPIOZ_14 14 -#define GPIOZ_15 15 -#define GPIOH_0 16 -#define GPIOH_1 17 -#define GPIOH_2 18 -#define GPIOH_3 19 -#define GPIOH_4 20 -#define GPIOH_5 21 -#define GPIOH_6 22 -#define GPIOH_7 23 -#define GPIOH_8 24 -#define BOOT_0 25 -#define BOOT_1 26 -#define BOOT_2 27 -#define BOOT_3 28 -#define BOOT_4 29 -#define BOOT_5 30 -#define BOOT_6 31 -#define BOOT_7 32 -#define BOOT_8 33 -#define BOOT_9 34 -#define BOOT_10 35 -#define BOOT_11 36 -#define BOOT_12 37 -#define BOOT_13 38 -#define BOOT_14 39 -#define BOOT_15 40 -#define GPIOC_0 41 -#define GPIOC_1 42 -#define GPIOC_2 43 -#define GPIOC_3 44 -#define GPIOC_4 45 -#define GPIOC_5 46 -#define GPIOC_6 47 -#define GPIOC_7 48 -#define GPIOA_0 49 -#define GPIOA_1 50 -#define GPIOA_2 51 -#define GPIOA_3 52 -#define GPIOA_4 53 -#define GPIOA_5 54 -#define GPIOA_6 55 -#define GPIOA_7 56 -#define GPIOA_8 57 -#define GPIOA_9 58 -#define GPIOA_10 59 -#define GPIOA_11 60 -#define GPIOA_12 61 -#define GPIOA_13 62 -#define GPIOA_14 63 -#define GPIOA_15 64 -#define GPIOX_0 65 -#define GPIOX_1 66 -#define GPIOX_2 67 -#define GPIOX_3 68 -#define GPIOX_4 69 -#define GPIOX_5 70 -#define GPIOX_6 71 -#define GPIOX_7 72 -#define GPIOX_8 73 -#define GPIOX_9 74 -#define GPIOX_10 75 -#define GPIOX_11 76 -#define GPIOX_12 77 -#define GPIOX_13 78 -#define GPIOX_14 79 -#define GPIOX_15 80 -#define GPIOX_16 81 -#define GPIOX_17 82 -#define GPIOX_18 83 -#define GPIOX_19 84 - -#endif /* _DT_BINDINGS_MESON_G12A_GPIO_H */ diff --git a/include/dt-bindings/gpio/meson-gxbb-gpio.h b/include/dt-bindings/gpio/meson-gxbb-gpio.h deleted file mode 100644 index 489c75b27645..000000000000 --- a/include/dt-bindings/gpio/meson-gxbb-gpio.h +++ /dev/null @@ -1,148 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * GPIO definitions for Amlogic Meson GXBB SoCs - * - * Copyright (C) 2016 Endless Mobile, Inc. - * Author: Carlo Caione carlo@endlessm.com - */ - -#ifndef _DT_BINDINGS_MESON_GXBB_GPIO_H -#define _DT_BINDINGS_MESON_GXBB_GPIO_H - -#define GPIOAO_0 0 -#define GPIOAO_1 1 -#define GPIOAO_2 2 -#define GPIOAO_3 3 -#define GPIOAO_4 4 -#define GPIOAO_5 5 -#define GPIOAO_6 6 -#define GPIOAO_7 7 -#define GPIOAO_8 8 -#define GPIOAO_9 9 -#define GPIOAO_10 10 -#define GPIOAO_11 11 -#define GPIOAO_12 12 -#define GPIOAO_13 13 -#define GPIO_TEST_N 14 - -#define GPIOZ_0 0 -#define GPIOZ_1 1 -#define GPIOZ_2 2 -#define GPIOZ_3 3 -#define GPIOZ_4 4 -#define GPIOZ_5 5 -#define GPIOZ_6 6 -#define GPIOZ_7 7 -#define GPIOZ_8 8 -#define GPIOZ_9 9 -#define GPIOZ_10 10 -#define GPIOZ_11 11 -#define GPIOZ_12 12 -#define GPIOZ_13 13 -#define GPIOZ_14 14 -#define GPIOZ_15 15 -#define GPIOH_0 16 -#define GPIOH_1 17 -#define GPIOH_2 18 -#define GPIOH_3 19 -#define BOOT_0 20 -#define BOOT_1 21 -#define BOOT_2 22 -#define BOOT_3 23 -#define BOOT_4 24 -#define BOOT_5 25 -#define BOOT_6 26 -#define BOOT_7 27 -#define BOOT_8 28 -#define BOOT_9 29 -#define BOOT_10 30 -#define BOOT_11 31 -#define BOOT_12 32 -#define BOOT_13 33 -#define BOOT_14 34 -#define BOOT_15 35 -#define BOOT_16 36 -#define BOOT_17 37 -#define CARD_0 38 -#define CARD_1 39 -#define CARD_2 40 -#define CARD_3 41 -#define CARD_4 42 -#define CARD_5 43 -#define CARD_6 44 -#define GPIODV_0 45 -#define GPIODV_1 46 -#define GPIODV_2 47 -#define GPIODV_3 48 -#define GPIODV_4 49 -#define GPIODV_5 50 -#define GPIODV_6 51 -#define GPIODV_7 52 -#define GPIODV_8 53 -#define GPIODV_9 54 -#define GPIODV_10 55 -#define GPIODV_11 56 -#define GPIODV_12 57 -#define GPIODV_13 58 -#define GPIODV_14 59 -#define GPIODV_15 60 -#define GPIODV_16 61 -#define GPIODV_17 62 -#define GPIODV_18 63 -#define GPIODV_19 64 -#define GPIODV_20 65 -#define GPIODV_21 66 -#define GPIODV_22 67 -#define GPIODV_23 68 -#define GPIODV_24 69 -#define GPIODV_25 70 -#define GPIODV_26 71 -#define GPIODV_27 72 -#define GPIODV_28 73 -#define GPIODV_29 74 -#define GPIOY_0 75 -#define GPIOY_1 76 -#define GPIOY_2 77 -#define GPIOY_3 78 -#define GPIOY_4 79 -#define GPIOY_5 80 -#define GPIOY_6 81 -#define GPIOY_7 82 -#define GPIOY_8 83 -#define GPIOY_9 84 -#define GPIOY_10 85 -#define GPIOY_11 86 -#define GPIOY_12 87 -#define GPIOY_13 88 -#define GPIOY_14 89 -#define GPIOY_15 90 -#define GPIOY_16 91 -#define GPIOX_0 92 -#define GPIOX_1 93 -#define GPIOX_2 94 -#define GPIOX_3 95 -#define GPIOX_4 96 -#define GPIOX_5 97 -#define GPIOX_6 98 -#define GPIOX_7 99 -#define GPIOX_8 100 -#define GPIOX_9 101 -#define GPIOX_10 102 -#define GPIOX_11 103 -#define GPIOX_12 104 -#define GPIOX_13 105 -#define GPIOX_14 106 -#define GPIOX_15 107 -#define GPIOX_16 108 -#define GPIOX_17 109 -#define GPIOX_18 110 -#define GPIOX_19 111 -#define GPIOX_20 112 -#define GPIOX_21 113 -#define GPIOX_22 114 -#define GPIOCLK_0 115 -#define GPIOCLK_1 116 -#define GPIOCLK_2 117 -#define GPIOCLK_3 118 - -#endif diff --git a/include/dt-bindings/gpio/meson-gxl-gpio.h b/include/dt-bindings/gpio/meson-gxl-gpio.h deleted file mode 100644 index 0a001ae48272..000000000000 --- a/include/dt-bindings/gpio/meson-gxl-gpio.h +++ /dev/null @@ -1,125 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * GPIO definitions for Amlogic Meson GXL SoCs - * - * Copyright (C) 2016 Endless Mobile, Inc. - * Author: Carlo Caione carlo@endlessm.com - */ - -#ifndef _DT_BINDINGS_MESON_GXL_GPIO_H -#define _DT_BINDINGS_MESON_GXL_GPIO_H - -#define GPIOAO_0 0 -#define GPIOAO_1 1 -#define GPIOAO_2 2 -#define GPIOAO_3 3 -#define GPIOAO_4 4 -#define GPIOAO_5 5 -#define GPIOAO_6 6 -#define GPIOAO_7 7 -#define GPIOAO_8 8 -#define GPIOAO_9 9 -#define GPIO_TEST_N 10 - -#define GPIOZ_0 0 -#define GPIOZ_1 1 -#define GPIOZ_2 2 -#define GPIOZ_3 3 -#define GPIOZ_4 4 -#define GPIOZ_5 5 -#define GPIOZ_6 6 -#define GPIOZ_7 7 -#define GPIOZ_8 8 -#define GPIOZ_9 9 -#define GPIOZ_10 10 -#define GPIOZ_11 11 -#define GPIOZ_12 12 -#define GPIOZ_13 13 -#define GPIOZ_14 14 -#define GPIOZ_15 15 -#define GPIOH_0 16 -#define GPIOH_1 17 -#define GPIOH_2 18 -#define GPIOH_3 19 -#define GPIOH_4 20 -#define GPIOH_5 21 -#define GPIOH_6 22 -#define GPIOH_7 23 -#define GPIOH_8 24 -#define GPIOH_9 25 -#define BOOT_0 26 -#define BOOT_1 27 -#define BOOT_2 28 -#define BOOT_3 29 -#define BOOT_4 30 -#define BOOT_5 31 -#define BOOT_6 32 -#define BOOT_7 33 -#define BOOT_8 34 -#define BOOT_9 35 -#define BOOT_10 36 -#define BOOT_11 37 -#define BOOT_12 38 -#define BOOT_13 39 -#define BOOT_14 40 -#define BOOT_15 41 -#define CARD_0 42 -#define CARD_1 43 -#define CARD_2 44 -#define CARD_3 45 -#define CARD_4 46 -#define CARD_5 47 -#define CARD_6 48 -#define GPIODV_0 49 -#define GPIODV_1 50 -#define GPIODV_2 51 -#define GPIODV_3 52 -#define GPIODV_4 53 -#define GPIODV_5 54 -#define GPIODV_6 55 -#define GPIODV_7 56 -#define GPIODV_8 57 -#define GPIODV_9 58 -#define GPIODV_10 59 -#define GPIODV_11 60 -#define GPIODV_12 61 -#define GPIODV_13 62 -#define GPIODV_14 63 -#define GPIODV_15 64 -#define GPIODV_16 65 -#define GPIODV_17 66 -#define GPIODV_18 67 -#define GPIODV_19 68 -#define GPIODV_20 69 -#define GPIODV_21 70 -#define GPIODV_22 71 -#define GPIODV_23 72 -#define GPIODV_24 73 -#define GPIODV_25 74 -#define GPIODV_26 75 -#define GPIODV_27 76 -#define GPIODV_28 77 -#define GPIODV_29 78 -#define GPIOX_0 79 -#define GPIOX_1 80 -#define GPIOX_2 81 -#define GPIOX_3 82 -#define GPIOX_4 83 -#define GPIOX_5 84 -#define GPIOX_6 85 -#define GPIOX_7 86 -#define GPIOX_8 87 -#define GPIOX_9 88 -#define GPIOX_10 89 -#define GPIOX_11 90 -#define GPIOX_12 91 -#define GPIOX_13 92 -#define GPIOX_14 93 -#define GPIOX_15 94 -#define GPIOX_16 95 -#define GPIOX_17 96 -#define GPIOX_18 97 -#define GPIOCLK_0 98 -#define GPIOCLK_1 99 - -#endif diff --git a/include/dt-bindings/power/meson-a1-power.h b/include/dt-bindings/power/meson-a1-power.h deleted file mode 100644 index 8e39dfc0b62a..000000000000 --- a/include/dt-bindings/power/meson-a1-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2023 SberDevices, Inc. - * Author: Alexey Romanov avromanov@sberdevices.ru - */ - -#ifndef _DT_BINDINGS_MESON_A1_POWER_H -#define _DT_BINDINGS_MESON_A1_POWER_H - -#define PWRC_DSPA_ID 8 -#define PWRC_DSPB_ID 9 -#define PWRC_UART_ID 10 -#define PWRC_DMC_ID 11 -#define PWRC_I2C_ID 12 -#define PWRC_PSRAM_ID 13 -#define PWRC_ACODEC_ID 14 -#define PWRC_AUDIO_ID 15 -#define PWRC_OTP_ID 16 -#define PWRC_DMA_ID 17 -#define PWRC_SD_EMMC_ID 18 -#define PWRC_RAMA_ID 19 -#define PWRC_RAMB_ID 20 -#define PWRC_IR_ID 21 -#define PWRC_SPICC_ID 22 -#define PWRC_SPIFC_ID 23 -#define PWRC_USB_ID 24 -#define PWRC_NIC_ID 25 -#define PWRC_PDMIN_ID 26 -#define PWRC_RSA_ID 27 -#define PWRC_MAX_ID 28 - -#endif diff --git a/include/dt-bindings/power/meson-axg-power.h b/include/dt-bindings/power/meson-axg-power.h deleted file mode 100644 index e5243884b249..000000000000 --- a/include/dt-bindings/power/meson-axg-power.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2020 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#ifndef _DT_BINDINGS_MESON_AXG_POWER_H -#define _DT_BINDINGS_MESON_AXG_POWER_H - -#define PWRC_AXG_VPU_ID 0 -#define PWRC_AXG_ETHERNET_MEM_ID 1 -#define PWRC_AXG_AUDIO_ID 2 - -#endif diff --git a/include/dt-bindings/power/meson-g12a-power.h b/include/dt-bindings/power/meson-g12a-power.h deleted file mode 100644 index bb5e67a842de..000000000000 --- a/include/dt-bindings/power/meson-g12a-power.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2019 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#ifndef _DT_BINDINGS_MESON_G12A_POWER_H -#define _DT_BINDINGS_MESON_G12A_POWER_H - -#define PWRC_G12A_VPU_ID 0 -#define PWRC_G12A_ETH_ID 1 - -#endif diff --git a/include/dt-bindings/power/meson-gxbb-power.h b/include/dt-bindings/power/meson-gxbb-power.h deleted file mode 100644 index 1262dac696c0..000000000000 --- a/include/dt-bindings/power/meson-gxbb-power.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2019 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#ifndef _DT_BINDINGS_MESON_GXBB_POWER_H -#define _DT_BINDINGS_MESON_GXBB_POWER_H - -#define PWRC_GXBB_VPU_ID 0 -#define PWRC_GXBB_ETHERNET_MEM_ID 1 - -#endif diff --git a/include/dt-bindings/power/meson-sm1-power.h b/include/dt-bindings/power/meson-sm1-power.h deleted file mode 100644 index a020ab00c134..000000000000 --- a/include/dt-bindings/power/meson-sm1-power.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ -/* - * Copyright (c) 2019 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#ifndef _DT_BINDINGS_MESON_SM1_POWER_H -#define _DT_BINDINGS_MESON_SM1_POWER_H - -#define PWRC_SM1_VPU_ID 0 -#define PWRC_SM1_NNA_ID 1 -#define PWRC_SM1_USB_ID 2 -#define PWRC_SM1_PCIE_ID 3 -#define PWRC_SM1_GE2D_ID 4 -#define PWRC_SM1_AUDIO_ID 5 -#define PWRC_SM1_ETH_ID 6 - -#endif diff --git a/include/dt-bindings/reset/amlogic,meson-a1-reset.h b/include/dt-bindings/reset/amlogic,meson-a1-reset.h deleted file mode 100644 index 2c749c655e1e..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-a1-reset.h +++ /dev/null @@ -1,76 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2019 Amlogic, Inc. All rights reserved. - * Author: Xingyu Chen xingyu.chen@amlogic.com - * - * Copyright (c) 2023, SberDevices, Inc. - * Author: Alexey Romanov avromanov@salutedevices.com - */ - -#ifndef _DT_BINDINGS_AMLOGIC_MESON_A1_RESET_H -#define _DT_BINDINGS_AMLOGIC_MESON_A1_RESET_H - -/* RESET0 */ -/* 0 */ -#define RESET_AM2AXI_VAD 1 -/* 2-3 */ -#define RESET_PSRAM 4 -#define RESET_PAD_CTRL 5 -/* 6 */ -#define RESET_TEMP_SENSOR 7 -#define RESET_AM2AXI_DEV 8 -/* 9 */ -#define RESET_SPICC_A 10 -#define RESET_MSR_CLK 11 -#define RESET_AUDIO 12 -#define RESET_ANALOG_CTRL 13 -#define RESET_SAR_ADC 14 -#define RESET_AUDIO_VAD 15 -#define RESET_CEC 16 -#define RESET_PWM_EF 17 -#define RESET_PWM_CD 18 -#define RESET_PWM_AB 19 -/* 20 */ -#define RESET_IR_CTRL 21 -#define RESET_I2C_S_A 22 -/* 23 */ -#define RESET_I2C_M_D 24 -#define RESET_I2C_M_C 25 -#define RESET_I2C_M_B 26 -#define RESET_I2C_M_A 27 -#define RESET_I2C_PROD_AHB 28 -#define RESET_I2C_PROD 29 -/* 30-31 */ - -/* RESET1 */ -#define RESET_ACODEC 32 -#define RESET_DMA 33 -#define RESET_SD_EMMC_A 34 -/* 35 */ -#define RESET_USBCTRL 36 -/* 37 */ -#define RESET_USBPHY 38 -/* 39-41 */ -#define RESET_RSA 42 -#define RESET_DMC 43 -/* 44 */ -#define RESET_IRQ_CTRL 45 -/* 46 */ -#define RESET_NIC_VAD 47 -#define RESET_NIC_AXI 48 -#define RESET_RAMA 49 -#define RESET_RAMB 50 -/* 51-52 */ -#define RESET_ROM 53 -#define RESET_SPIFC 54 -#define RESET_GIC 55 -#define RESET_UART_C 56 -#define RESET_UART_B 57 -#define RESET_UART_A 58 -#define RESET_OSC_RING 59 -/* 60-63 */ - -/* RESET2 */ -/* 64-95 */ - -#endif diff --git a/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h b/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h deleted file mode 100644 index 1ef807856cb8..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) - * - * Copyright (c) 2018 Baylibre SAS. - * Author: Jerome Brunet jbrunet@baylibre.com - */ - -#ifndef _DT_BINDINGS_AMLOGIC_MESON_AXG_AUDIO_ARB_H -#define _DT_BINDINGS_AMLOGIC_MESON_AXG_AUDIO_ARB_H - -#define AXG_ARB_TODDR_A 0 -#define AXG_ARB_TODDR_B 1 -#define AXG_ARB_TODDR_C 2 -#define AXG_ARB_FRDDR_A 3 -#define AXG_ARB_FRDDR_B 4 -#define AXG_ARB_FRDDR_C 5 -#define AXG_ARB_TODDR_D 6 -#define AXG_ARB_FRDDR_D 7 - -#endif /* _DT_BINDINGS_AMLOGIC_MESON_AXG_AUDIO_ARB_H */ diff --git a/include/dt-bindings/reset/amlogic,meson-axg-reset.h b/include/dt-bindings/reset/amlogic,meson-axg-reset.h deleted file mode 100644 index 0f2e0fe45ca4..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-axg-reset.h +++ /dev/null @@ -1,123 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ -/* - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Copyright (c) 2017 Amlogic, inc. - * Author: Yixun Lan yixun.lan@amlogic.com - * - */ - -#ifndef _DT_BINDINGS_AMLOGIC_MESON_AXG_RESET_H -#define _DT_BINDINGS_AMLOGIC_MESON_AXG_RESET_H - -/* RESET0 */ -#define RESET_HIU 0 -#define RESET_PCIE_A 1 -#define RESET_PCIE_B 2 -#define RESET_DDR_TOP 3 -/* 4 */ -#define RESET_VIU 5 -#define RESET_PCIE_PHY 6 -#define RESET_PCIE_APB 7 -/* 8 */ -/* 9 */ -#define RESET_VENC 10 -#define RESET_ASSIST 11 -/* 12 */ -#define RESET_VCBUS 13 -/* 14 */ -/* 15 */ -#define RESET_GIC 16 -#define RESET_CAPB3_DECODE 17 -/* 18-21 */ -#define RESET_SYS_CPU_CAPB3 22 -#define RESET_CBUS_CAPB3 23 -#define RESET_AHB_CNTL 24 -#define RESET_AHB_DATA 25 -#define RESET_VCBUS_CLK81 26 -#define RESET_MMC 27 -/* 28-31 */ -/* RESET1 */ -/* 32 */ -/* 33 */ -#define RESET_USB_OTG 34 -#define RESET_DDR 35 -#define RESET_AO_RESET 36 -/* 37 */ -#define RESET_AHB_SRAM 38 -/* 39 */ -/* 40 */ -#define RESET_DMA 41 -#define RESET_ISA 42 -#define RESET_ETHERNET 43 -/* 44 */ -#define RESET_SD_EMMC_B 45 -#define RESET_SD_EMMC_C 46 -#define RESET_ROM_BOOT 47 -#define RESET_SYS_CPU_0 48 -#define RESET_SYS_CPU_1 49 -#define RESET_SYS_CPU_2 50 -#define RESET_SYS_CPU_3 51 -#define RESET_SYS_CPU_CORE_0 52 -#define RESET_SYS_CPU_CORE_1 53 -#define RESET_SYS_CPU_CORE_2 54 -#define RESET_SYS_CPU_CORE_3 55 -#define RESET_SYS_PLL_DIV 56 -#define RESET_SYS_CPU_AXI 57 -#define RESET_SYS_CPU_L2 58 -#define RESET_SYS_CPU_P 59 -#define RESET_SYS_CPU_MBIST 60 -/* 61-63 */ -/* RESET2 */ -/* 64 */ -/* 65 */ -#define RESET_AUDIO 66 -/* 67 */ -#define RESET_MIPI_HOST 68 -#define RESET_AUDIO_LOCKER 69 -#define RESET_GE2D 70 -/* 71-76 */ -#define RESET_AO_CPU_RESET 77 -/* 78-95 */ -/* RESET3 */ -#define RESET_RING_OSCILLATOR 96 -/* 97-127 */ -/* RESET4 */ -/* 128 */ -/* 129 */ -#define RESET_MIPI_PHY 130 -/* 131-140 */ -#define RESET_VENCL 141 -#define RESET_I2C_MASTER_2 142 -#define RESET_I2C_MASTER_1 143 -/* 144-159 */ -/* RESET5 */ -/* 160-191 */ -/* RESET6 */ -#define RESET_PERIPHS_GENERAL 192 -#define RESET_PERIPHS_SPICC 193 -/* 194 */ -/* 195 */ -#define RESET_PERIPHS_I2C_MASTER_0 196 -/* 197-200 */ -#define RESET_PERIPHS_UART_0 201 -#define RESET_PERIPHS_UART_1 202 -/* 203-204 */ -#define RESET_PERIPHS_SPI_0 205 -#define RESET_PERIPHS_I2C_MASTER_3 206 -/* 207-223 */ -/* RESET7 */ -#define RESET_USB_DDR_0 224 -#define RESET_USB_DDR_1 225 -#define RESET_USB_DDR_2 226 -#define RESET_USB_DDR_3 227 -/* 228 */ -#define RESET_DEVICE_MMC_ARB 229 -/* 230 */ -#define RESET_VID_LOCK 231 -#define RESET_A9_DMC_PIPEL 232 -#define RESET_DMC_VPU_PIPEL 233 -/* 234-255 */ - -#endif diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h deleted file mode 100644 index f805129ca7af..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h +++ /dev/null @@ -1,53 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019 BayLibre, SAS. - * Author: Jerome Brunet jbrunet@baylibre.com - * - */ - -#ifndef _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H -#define _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H - -#define AUD_RESET_PDM 0 -#define AUD_RESET_TDMIN_A 1 -#define AUD_RESET_TDMIN_B 2 -#define AUD_RESET_TDMIN_C 3 -#define AUD_RESET_TDMIN_LB 4 -#define AUD_RESET_LOOPBACK 5 -#define AUD_RESET_TODDR_A 6 -#define AUD_RESET_TODDR_B 7 -#define AUD_RESET_TODDR_C 8 -#define AUD_RESET_FRDDR_A 9 -#define AUD_RESET_FRDDR_B 10 -#define AUD_RESET_FRDDR_C 11 -#define AUD_RESET_TDMOUT_A 12 -#define AUD_RESET_TDMOUT_B 13 -#define AUD_RESET_TDMOUT_C 14 -#define AUD_RESET_SPDIFOUT 15 -#define AUD_RESET_SPDIFOUT_B 16 -#define AUD_RESET_SPDIFIN 17 -#define AUD_RESET_EQDRC 18 -#define AUD_RESET_RESAMPLE 19 -#define AUD_RESET_DDRARB 20 -#define AUD_RESET_POWDET 21 -#define AUD_RESET_TORAM 22 -#define AUD_RESET_TOACODEC 23 -#define AUD_RESET_TOHDMITX 24 -#define AUD_RESET_CLKTREE 25 - -/* SM1 added resets */ -#define AUD_RESET_RESAMPLE_B 26 -#define AUD_RESET_TOVAD 27 -#define AUD_RESET_LOCKER 28 -#define AUD_RESET_SPDIFIN_LB 29 -#define AUD_RESET_FRATV 30 -#define AUD_RESET_FRHDMIRX 31 -#define AUD_RESET_FRDDR_D 32 -#define AUD_RESET_TODDR_D 33 -#define AUD_RESET_LOOPBACK_B 34 -#define AUD_RESET_EARCTX 35 -#define AUD_RESET_EARCRX 36 -#define AUD_RESET_FRDDR_E 37 -#define AUD_RESET_TODDR_E 38 - -#endif diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-reset.h deleted file mode 100644 index 6d487c5eba2c..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-g12a-reset.h +++ /dev/null @@ -1,137 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ -/* - * Copyright (c) 2019 BayLibre, SAS. - * Author: Jerome Brunet jbrunet@baylibre.com - * - */ - -#ifndef _DT_BINDINGS_AMLOGIC_MESON_G12A_RESET_H -#define _DT_BINDINGS_AMLOGIC_MESON_G12A_RESET_H - -/* RESET0 */ -#define RESET_HIU 0 -/* 1 */ -#define RESET_DOS 2 -/* 3-4 */ -#define RESET_VIU 5 -#define RESET_AFIFO 6 -#define RESET_VID_PLL_DIV 7 -/* 8-9 */ -#define RESET_VENC 10 -#define RESET_ASSIST 11 -#define RESET_PCIE_CTRL_A 12 -#define RESET_VCBUS 13 -#define RESET_PCIE_PHY 14 -#define RESET_PCIE_APB 15 -#define RESET_GIC 16 -#define RESET_CAPB3_DECODE 17 -/* 18 */ -#define RESET_HDMITX_CAPB3 19 -#define RESET_DVALIN_CAPB3 20 -#define RESET_DOS_CAPB3 21 -/* 22 */ -#define RESET_CBUS_CAPB3 23 -#define RESET_AHB_CNTL 24 -#define RESET_AHB_DATA 25 -#define RESET_VCBUS_CLK81 26 -/* 27-31 */ -/* RESET1 */ -/* 32 */ -#define RESET_DEMUX 33 -#define RESET_USB 34 -#define RESET_DDR 35 -/* 36 */ -#define RESET_BT656 37 -#define RESET_AHB_SRAM 38 -/* 39 */ -#define RESET_PARSER 40 -/* 41 */ -#define RESET_ISA 42 -#define RESET_ETHERNET 43 -#define RESET_SD_EMMC_A 44 -#define RESET_SD_EMMC_B 45 -#define RESET_SD_EMMC_C 46 -/* 47 */ -#define RESET_USB_PHY20 48 -#define RESET_USB_PHY21 49 -/* 50-60 */ -#define RESET_AUDIO_CODEC 61 -/* 62-63 */ -/* RESET2 */ -/* 64 */ -#define RESET_AUDIO 65 -#define RESET_HDMITX_PHY 66 -/* 67 */ -#define RESET_MIPI_DSI_HOST 68 -#define RESET_ALOCKER 69 -#define RESET_GE2D 70 -#define RESET_PARSER_REG 71 -#define RESET_PARSER_FETCH 72 -#define RESET_CTL 73 -#define RESET_PARSER_TOP 74 -/* 75-77 */ -#define RESET_DVALIN 78 -#define RESET_HDMITX 79 -/* 80-95 */ -/* RESET3 */ -/* 96-95 */ -#define RESET_DEMUX_TOP 105 -#define RESET_DEMUX_DES_PL 106 -#define RESET_DEMUX_S2P_0 107 -#define RESET_DEMUX_S2P_1 108 -#define RESET_DEMUX_0 109 -#define RESET_DEMUX_1 110 -#define RESET_DEMUX_2 111 -/* 112-127 */ -/* RESET4 */ -/* 128-129 */ -#define RESET_MIPI_DSI_PHY 130 -/* 131-132 */ -#define RESET_RDMA 133 -#define RESET_VENCI 134 -#define RESET_VENCP 135 -/* 136 */ -#define RESET_VDAC 137 -/* 138-139 */ -#define RESET_VDI6 140 -#define RESET_VENCL 141 -#define RESET_I2C_M1 142 -#define RESET_I2C_M2 143 -/* 144-159 */ -/* RESET5 */ -/* 160-191 */ -/* RESET6 */ -#define RESET_GEN 192 -#define RESET_SPICC0 193 -#define RESET_SC 194 -#define RESET_SANA_3 195 -#define RESET_I2C_M0 196 -#define RESET_TS_PLL 197 -#define RESET_SPICC1 198 -#define RESET_STREAM 199 -#define RESET_TS_CPU 200 -#define RESET_UART0 201 -#define RESET_UART1_2 202 -#define RESET_ASYNC0 203 -#define RESET_ASYNC1 204 -#define RESET_SPIFC0 205 -#define RESET_I2C_M3 206 -/* 207-223 */ -/* RESET7 */ -#define RESET_USB_DDR_0 224 -#define RESET_USB_DDR_1 225 -#define RESET_USB_DDR_2 226 -#define RESET_USB_DDR_3 227 -#define RESET_TS_GPU 228 -#define RESET_DEVICE_MMC_ARB 229 -#define RESET_DVALIN_DMC_PIPL 230 -#define RESET_VID_LOCK 231 -#define RESET_NIC_DMC_PIPL 232 -#define RESET_DMC_VPU_PIPL 233 -#define RESET_GE2D_DMC_PIPL 234 -#define RESET_HCODEC_DMC_PIPL 235 -#define RESET_WAVE420_DMC_PIPL 236 -#define RESET_HEVCF_DMC_PIPL 237 -/* 238-255 */ - -#endif diff --git a/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h b/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h deleted file mode 100644 index 883bfd3bcbad..000000000000 --- a/include/dt-bindings/reset/amlogic,meson-gxbb-reset.h +++ /dev/null @@ -1,161 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR BSD-3-Clause */ -/* - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - */ -#ifndef _DT_BINDINGS_AMLOGIC_MESON_GXBB_RESET_H -#define _DT_BINDINGS_AMLOGIC_MESON_GXBB_RESET_H - -/* RESET0 */ -#define RESET_HIU 0 -/* 1 */ -#define RESET_DOS_RESET 2 -#define RESET_DDR_TOP 3 -#define RESET_DCU_RESET 4 -#define RESET_VIU 5 -#define RESET_AIU 6 -#define RESET_VID_PLL_DIV 7 -/* 8 */ -#define RESET_PMUX 9 -#define RESET_VENC 10 -#define RESET_ASSIST 11 -#define RESET_AFIFO2 12 -#define RESET_VCBUS 13 -/* 14 */ -/* 15 */ -#define RESET_GIC 16 -#define RESET_CAPB3_DECODE 17 -#define RESET_NAND_CAPB3 18 -#define RESET_HDMITX_CAPB3 19 -#define RESET_MALI_CAPB3 20 -#define RESET_DOS_CAPB3 21 -#define RESET_SYS_CPU_CAPB3 22 -#define RESET_CBUS_CAPB3 23 -#define RESET_AHB_CNTL 24 -#define RESET_AHB_DATA 25 -#define RESET_VCBUS_CLK81 26 -#define RESET_MMC 27 -#define RESET_MIPI_0 28 -#define RESET_MIPI_1 29 -#define RESET_MIPI_2 30 -#define RESET_MIPI_3 31 -/* RESET1 */ -#define RESET_CPPM 32 -#define RESET_DEMUX 33 -#define RESET_USB_OTG 34 -#define RESET_DDR 35 -#define RESET_AO_RESET 36 -#define RESET_BT656 37 -#define RESET_AHB_SRAM 38 -/* 39 */ -#define RESET_PARSER 40 -#define RESET_BLKMV 41 -#define RESET_ISA 42 -#define RESET_ETHERNET 43 -#define RESET_SD_EMMC_A 44 -#define RESET_SD_EMMC_B 45 -#define RESET_SD_EMMC_C 46 -#define RESET_ROM_BOOT 47 -#define RESET_SYS_CPU_0 48 -#define RESET_SYS_CPU_1 49 -#define RESET_SYS_CPU_2 50 -#define RESET_SYS_CPU_3 51 -#define RESET_SYS_CPU_CORE_0 52 -#define RESET_SYS_CPU_CORE_1 53 -#define RESET_SYS_CPU_CORE_2 54 -#define RESET_SYS_CPU_CORE_3 55 -#define RESET_SYS_PLL_DIV 56 -#define RESET_SYS_CPU_AXI 57 -#define RESET_SYS_CPU_L2 58 -#define RESET_SYS_CPU_P 59 -#define RESET_SYS_CPU_MBIST 60 -#define RESET_ACODEC 61 -/* 62 */ -/* 63 */ -/* RESET2 */ -#define RESET_VD_RMEM 64 -#define RESET_AUDIN 65 -#define RESET_HDMI_TX 66 -/* 67 */ -/* 68 */ -/* 69 */ -#define RESET_GE2D 70 -#define RESET_PARSER_REG 71 -#define RESET_PARSER_FETCH 72 -#define RESET_PARSER_CTL 73 -#define RESET_PARSER_TOP 74 -/* 75 */ -/* 76 */ -#define RESET_AO_CPU_RESET 77 -#define RESET_MALI 78 -#define RESET_HDMI_SYSTEM_RESET 79 -/* 80-95 */ -/* RESET3 */ -#define RESET_RING_OSCILLATOR 96 -#define RESET_SYS_CPU 97 -#define RESET_EFUSE 98 -#define RESET_SYS_CPU_BVCI 99 -#define RESET_AIFIFO 100 -#define RESET_TVFE 101 -#define RESET_AHB_BRIDGE_CNTL 102 -/* 103 */ -#define RESET_AUDIO_DAC 104 -#define RESET_DEMUX_TOP 105 -#define RESET_DEMUX_DES 106 -#define RESET_DEMUX_S2P_0 107 -#define RESET_DEMUX_S2P_1 108 -#define RESET_DEMUX_RESET_0 109 -#define RESET_DEMUX_RESET_1 110 -#define RESET_DEMUX_RESET_2 111 -/* 112-127 */ -/* RESET4 */ -/* 128 */ -/* 129 */ -/* 130 */ -/* 131 */ -#define RESET_DVIN_RESET 132 -#define RESET_RDMA 133 -#define RESET_VENCI 134 -#define RESET_VENCP 135 -/* 136 */ -#define RESET_VDAC 137 -#define RESET_RTC 138 -/* 139 */ -#define RESET_VDI6 140 -#define RESET_VENCL 141 -#define RESET_I2C_MASTER_2 142 -#define RESET_I2C_MASTER_1 143 -/* 144-159 */ -/* RESET5 */ -/* 160-191 */ -/* RESET6 */ -#define RESET_PERIPHS_GENERAL 192 -#define RESET_PERIPHS_SPICC 193 -#define RESET_PERIPHS_SMART_CARD 194 -#define RESET_PERIPHS_SAR_ADC 195 -#define RESET_PERIPHS_I2C_MASTER_0 196 -#define RESET_SANA 197 -/* 198 */ -#define RESET_PERIPHS_STREAM_INTERFACE 199 -#define RESET_PERIPHS_SDIO 200 -#define RESET_PERIPHS_UART_0 201 -#define RESET_PERIPHS_UART_1_2 202 -#define RESET_PERIPHS_ASYNC_0 203 -#define RESET_PERIPHS_ASYNC_1 204 -#define RESET_PERIPHS_SPI_0 205 -#define RESET_PERIPHS_SDHC 206 -#define RESET_UART_SLIP 207 -/* 208-223 */ -/* RESET7 */ -#define RESET_USB_DDR_0 224 -#define RESET_USB_DDR_1 225 -#define RESET_USB_DDR_2 226 -#define RESET_USB_DDR_3 227 -/* 228 */ -#define RESET_DEVICE_MMC_ARB 229 -/* 230 */ -#define RESET_VID_LOCK 231 -#define RESET_A9_DMC_PIPEL 232 -/* 233-255 */ - -#endif diff --git a/include/dt-bindings/reset/axg-aoclkc.h b/include/dt-bindings/reset/axg-aoclkc.h deleted file mode 100644 index d342c0b6b2a7..000000000000 --- a/include/dt-bindings/reset/axg-aoclkc.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) */ -/* - * Copyright (c) 2016 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Copyright (c) 2018 Amlogic, inc. - * Author: Qiufang Dai qiufang.dai@amlogic.com - */ - -#ifndef DT_BINDINGS_RESET_AMLOGIC_MESON_AXG_AOCLK -#define DT_BINDINGS_RESET_AMLOGIC_MESON_AXG_AOCLK - -#define RESET_AO_REMOTE 0 -#define RESET_AO_I2C_MASTER 1 -#define RESET_AO_I2C_SLAVE 2 -#define RESET_AO_UART1 3 -#define RESET_AO_UART2 4 -#define RESET_AO_IR_BLASTER 5 - -#endif diff --git a/include/dt-bindings/reset/g12a-aoclkc.h b/include/dt-bindings/reset/g12a-aoclkc.h deleted file mode 100644 index bd2e2337135c..000000000000 --- a/include/dt-bindings/reset/g12a-aoclkc.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) */ -/* - * Copyright (c) 2016 BayLibre, SAS - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -#ifndef DT_BINDINGS_RESET_AMLOGIC_MESON_G12A_AOCLK -#define DT_BINDINGS_RESET_AMLOGIC_MESON_G12A_AOCLK - -#define RESET_AO_IR_IN 0 -#define RESET_AO_UART 1 -#define RESET_AO_I2C_M 2 -#define RESET_AO_I2C_S 3 -#define RESET_AO_SAR_ADC 4 -#define RESET_AO_UART2 5 -#define RESET_AO_IR_OUT 6 - -#endif diff --git a/include/dt-bindings/reset/gxbb-aoclkc.h b/include/dt-bindings/reset/gxbb-aoclkc.h deleted file mode 100644 index 9e3fd60c309c..000000000000 --- a/include/dt-bindings/reset/gxbb-aoclkc.h +++ /dev/null @@ -1,66 +0,0 @@ -/* - * This file is provided under a dual BSD/GPLv2 license. When using or - * redistributing this file, you may do so under either license. - * - * GPL LICENSE SUMMARY - * - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of version 2 of the GNU General Public License as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU - * General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, see http://www.gnu.org/licenses/. - * The full GNU General Public License is included in this distribution - * in the file called COPYING. - * - * BSD LICENSE - * - * Copyright (c) 2016 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * * Neither the name of Intel Corporation nor the names of its - * contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS - * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT - * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR - * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT - * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, - * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY - * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE - * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - */ - -#ifndef DT_BINDINGS_RESET_AMLOGIC_MESON_GXBB_AOCLK -#define DT_BINDINGS_RESET_AMLOGIC_MESON_GXBB_AOCLK - -#define RESET_AO_REMOTE 0 -#define RESET_AO_I2C_MASTER 1 -#define RESET_AO_I2C_SLAVE 2 -#define RESET_AO_UART1 3 -#define RESET_AO_UART2 4 -#define RESET_AO_IR_BLASTER 5 - -#endif diff --git a/include/dt-bindings/sound/meson-aiu.h b/include/dt-bindings/sound/meson-aiu.h deleted file mode 100644 index 1051b8af298b..000000000000 --- a/include/dt-bindings/sound/meson-aiu.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_MESON_AIU_H -#define __DT_MESON_AIU_H - -#define AIU_CPU 0 -#define AIU_HDMI 1 -#define AIU_ACODEC 2 - -#define CPU_I2S_FIFO 0 -#define CPU_SPDIF_FIFO 1 -#define CPU_I2S_ENCODER 2 -#define CPU_SPDIF_ENCODER 3 - -#define CTRL_I2S 0 -#define CTRL_PCM 1 -#define CTRL_OUT 2 - -#endif /* __DT_MESON_AIU_H */ diff --git a/include/dt-bindings/sound/meson-g12a-toacodec.h b/include/dt-bindings/sound/meson-g12a-toacodec.h deleted file mode 100644 index 69d7a75592a2..000000000000 --- a/include/dt-bindings/sound/meson-g12a-toacodec.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_MESON_G12A_TOACODEC_H -#define __DT_MESON_G12A_TOACODEC_H - -#define TOACODEC_IN_A 0 -#define TOACODEC_IN_B 1 -#define TOACODEC_IN_C 2 -#define TOACODEC_OUT 3 - -#endif /* __DT_MESON_G12A_TOACODEC_H */ diff --git a/include/dt-bindings/sound/meson-g12a-tohdmitx.h b/include/dt-bindings/sound/meson-g12a-tohdmitx.h deleted file mode 100644 index c5e1f48d30d0..000000000000 --- a/include/dt-bindings/sound/meson-g12a-tohdmitx.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_MESON_G12A_TOHDMITX_H -#define __DT_MESON_G12A_TOHDMITX_H - -#define TOHDMITX_I2S_IN_A 0 -#define TOHDMITX_I2S_IN_B 1 -#define TOHDMITX_I2S_IN_C 2 -#define TOHDMITX_I2S_OUT 3 -#define TOHDMITX_SPDIF_IN_A 4 -#define TOHDMITX_SPDIF_IN_B 5 -#define TOHDMITX_SPDIF_OUT 6 - -#endif /* __DT_MESON_G12A_TOHDMITX_H */
Dropped in favour of dts/upstream
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/ste-ab8500.h | 12 - include/dt-bindings/clock/stih407-clks.h | 90 ------- include/dt-bindings/clock/stih410-clks.h | 25 -- include/dt-bindings/clock/stm32fx-clock.h | 63 ----- include/dt-bindings/clock/stm32h7-clks.h | 167 ------------- include/dt-bindings/clock/stm32mp1-clks.h | 274 --------------------- include/dt-bindings/clock/stm32mp13-clks.h | 229 ----------------- include/dt-bindings/mfd/st,stpmic1.h | 50 ---- include/dt-bindings/mfd/st-lpc.h | 16 -- include/dt-bindings/mfd/stm32f4-rcc.h | 108 -------- include/dt-bindings/mfd/stm32f7-rcc.h | 116 --------- include/dt-bindings/mfd/stm32h7-rcc.h | 138 ----------- include/dt-bindings/pinctrl/stm32-pinfunc.h | 45 ---- .../dt-bindings/regulator/st,stm32mp13-regulator.h | 42 ---- include/dt-bindings/reset/stih407-resets.h | 65 ----- include/dt-bindings/reset/stm32mp1-resets.h | 123 --------- include/dt-bindings/reset/stm32mp13-resets.h | 100 -------- 17 files changed, 1663 deletions(-)
diff --git a/include/dt-bindings/clock/ste-ab8500.h b/include/dt-bindings/clock/ste-ab8500.h deleted file mode 100644 index fb42dd0cab5f..000000000000 --- a/include/dt-bindings/clock/ste-ab8500.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __STE_CLK_AB8500_H__ -#define __STE_CLK_AB8500_H__ - -#define AB8500_SYSCLK_BUF2 0 -#define AB8500_SYSCLK_BUF3 1 -#define AB8500_SYSCLK_BUF4 2 -#define AB8500_SYSCLK_ULP 3 -#define AB8500_SYSCLK_INT 4 -#define AB8500_SYSCLK_AUDIO 5 - -#endif diff --git a/include/dt-bindings/clock/stih407-clks.h b/include/dt-bindings/clock/stih407-clks.h deleted file mode 100644 index 082edd9badfa..000000000000 --- a/include/dt-bindings/clock/stih407-clks.h +++ /dev/null @@ -1,90 +0,0 @@ -/* - * This header provides constants clk index STMicroelectronics - * STiH407 SoC. - */ -#ifndef _DT_BINDINGS_CLK_STIH407 -#define _DT_BINDINGS_CLK_STIH407 - -/* CLOCKGEN A0 */ -#define CLK_IC_LMI0 0 -#define CLK_IC_LMI1 1 - -/* CLOCKGEN C0 */ -#define CLK_ICN_GPU 0 -#define CLK_FDMA 1 -#define CLK_NAND 2 -#define CLK_HVA 3 -#define CLK_PROC_STFE 4 -#define CLK_PROC_TP 5 -#define CLK_RX_ICN_DMU 6 -#define CLK_RX_ICN_DISP_0 6 -#define CLK_RX_ICN_DISP_1 6 -#define CLK_RX_ICN_HVA 7 -#define CLK_RX_ICN_TS 7 -#define CLK_ICN_CPU 8 -#define CLK_TX_ICN_DMU 9 -#define CLK_TX_ICN_HVA 9 -#define CLK_TX_ICN_TS 9 -#define CLK_ICN_COMPO 9 -#define CLK_MMC_0 10 -#define CLK_MMC_1 11 -#define CLK_JPEGDEC 12 -#define CLK_ICN_REG 13 -#define CLK_TRACE_A9 13 -#define CLK_PTI_STM 13 -#define CLK_EXT2F_A9 13 -#define CLK_IC_BDISP_0 14 -#define CLK_IC_BDISP_1 15 -#define CLK_PP_DMU 16 -#define CLK_VID_DMU 17 -#define CLK_DSS_LPC 18 -#define CLK_ST231_AUD_0 19 -#define CLK_ST231_GP_0 19 -#define CLK_ST231_GP_1 20 -#define CLK_ST231_DMU 21 -#define CLK_ICN_LMI 22 -#define CLK_TX_ICN_DISP_0 23 -#define CLK_TX_ICN_DISP_1 23 -#define CLK_ICN_SBC 24 -#define CLK_STFE_FRC2 25 -#define CLK_ETH_PHY 26 -#define CLK_ETH_REF_PHYCLK 27 -#define CLK_FLASH_PROMIP 28 -#define CLK_MAIN_DISP 29 -#define CLK_AUX_DISP 30 -#define CLK_COMPO_DVP 31 - -/* CLOCKGEN D0 */ -#define CLK_PCM_0 0 -#define CLK_PCM_1 1 -#define CLK_PCM_2 2 -#define CLK_SPDIFF 3 - -/* CLOCKGEN D2 */ -#define CLK_PIX_MAIN_DISP 0 -#define CLK_PIX_PIP 1 -#define CLK_PIX_GDP1 2 -#define CLK_PIX_GDP2 3 -#define CLK_PIX_GDP3 4 -#define CLK_PIX_GDP4 5 -#define CLK_PIX_AUX_DISP 6 -#define CLK_DENC 7 -#define CLK_PIX_HDDAC 8 -#define CLK_HDDAC 9 -#define CLK_SDDAC 10 -#define CLK_PIX_DVO 11 -#define CLK_DVO 12 -#define CLK_PIX_HDMI 13 -#define CLK_TMDS_HDMI 14 -#define CLK_REF_HDMIPHY 15 - -/* CLOCKGEN D3 */ -#define CLK_STFE_FRC1 0 -#define CLK_TSOUT_0 1 -#define CLK_TSOUT_1 2 -#define CLK_MCHI 3 -#define CLK_VSENS_COMPO 4 -#define CLK_FRC1_REMOTE 5 -#define CLK_LPC_0 6 -#define CLK_LPC_1 7 -#endif diff --git a/include/dt-bindings/clock/stih410-clks.h b/include/dt-bindings/clock/stih410-clks.h deleted file mode 100644 index 2097a4bbe155..000000000000 --- a/include/dt-bindings/clock/stih410-clks.h +++ /dev/null @@ -1,25 +0,0 @@ -/* - * This header provides constants clk index STMicroelectronics - * STiH410 SoC. - */ -#ifndef _DT_BINDINGS_CLK_STIH410 -#define _DT_BINDINGS_CLK_STIH410 - -#include "stih407-clks.h" - -/* STiH410 introduces new clock outputs compared to STiH407 */ - -/* CLOCKGEN C0 */ -#define CLK_TX_ICN_HADES 32 -#define CLK_RX_ICN_HADES 33 -#define CLK_ICN_REG_16 34 -#define CLK_PP_HADES 35 -#define CLK_CLUST_HADES 36 -#define CLK_HWPE_HADES 37 -#define CLK_FC_HADES 38 - -/* CLOCKGEN D0 */ -#define CLK_PCMR10_MASTER 4 -#define CLK_USB2_PHY 5 - -#endif diff --git a/include/dt-bindings/clock/stm32fx-clock.h b/include/dt-bindings/clock/stm32fx-clock.h deleted file mode 100644 index e5dad050d518..000000000000 --- a/include/dt-bindings/clock/stm32fx-clock.h +++ /dev/null @@ -1,63 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * stm32fx-clock.h - * - * Copyright (C) 2016 STMicroelectronics - * Author: Gabriel Fernandez for STMicroelectronics. - */ - -/* - * List of clocks which are not derived from system clock (SYSCLOCK) - * - * The index of these clocks is the secondary index of DT bindings - * (see Documentation/devicetree/bindings/clock/st,stm32-rcc.txt) - * - * e.g: - <assigned-clocks = <&rcc 1 CLK_LSE>; -*/ - -#ifndef _DT_BINDINGS_CLK_STMFX_H -#define _DT_BINDINGS_CLK_STMFX_H - -#define SYSTICK 0 -#define FCLK 1 -#define CLK_LSI 2 -#define CLK_LSE 3 -#define CLK_HSE_RTC 4 -#define CLK_RTC 5 -#define PLL_VCO_I2S 6 -#define PLL_VCO_SAI 7 -#define CLK_LCD 8 -#define CLK_I2S 9 -#define CLK_SAI1 10 -#define CLK_SAI2 11 -#define CLK_I2SQ_PDIV 12 -#define CLK_SAIQ_PDIV 13 -#define CLK_HSI 14 -#define CLK_SYSCLK 15 -#define CLK_F469_DSI 16 - -#define END_PRIMARY_CLK 17 - -#define CLK_HDMI_CEC 16 -#define CLK_SPDIF 17 -#define CLK_USART1 18 -#define CLK_USART2 19 -#define CLK_USART3 20 -#define CLK_UART4 21 -#define CLK_UART5 22 -#define CLK_USART6 23 -#define CLK_UART7 24 -#define CLK_UART8 25 -#define CLK_I2C1 26 -#define CLK_I2C2 27 -#define CLK_I2C3 28 -#define CLK_I2C4 29 -#define CLK_LPTIMER 30 -#define CLK_PLL_SRC 31 -#define CLK_DFSDM1 32 -#define CLK_ADFSDM1 33 -#define CLK_F769_DSI 34 -#define END_PRIMARY_CLK_F7 35 - -#endif diff --git a/include/dt-bindings/clock/stm32h7-clks.h b/include/dt-bindings/clock/stm32h7-clks.h deleted file mode 100644 index 4d87e7ebc39b..000000000000 --- a/include/dt-bindings/clock/stm32h7-clks.h +++ /dev/null @@ -1,167 +0,0 @@ -/* SYS, CORE AND BUS CLOCKS */ -#define SYS_D1CPRE 0 -#define HCLK 1 -#define PCLK1 2 -#define PCLK2 3 -#define PCLK3 4 -#define PCLK4 5 -#define HSI_DIV 6 -#define HSE_1M 7 -#define I2S_CKIN 8 -#define CK_DSI_PHY 9 -#define HSE_CK 10 -#define LSE_CK 11 -#define CSI_KER_DIV122 12 -#define RTC_CK 13 -#define CPU_SYSTICK 14 - -/* OSCILLATOR BANK */ -#define OSC_BANK 18 -#define HSI_CK 18 -#define HSI_KER_CK 19 -#define CSI_CK 20 -#define CSI_KER_CK 21 -#define RC48_CK 22 -#define LSI_CK 23 - -/* MCLOCK BANK */ -#define MCLK_BANK 28 -#define PER_CK 28 -#define PLLSRC 29 -#define SYS_CK 30 -#define TRACEIN_CK 31 - -/* ODF BANK */ -#define ODF_BANK 32 -#define PLL1_P 32 -#define PLL1_Q 33 -#define PLL1_R 34 -#define PLL2_P 35 -#define PLL2_Q 36 -#define PLL2_R 37 -#define PLL3_P 38 -#define PLL3_Q 39 -#define PLL3_R 40 - -/* MCO BANK */ -#define MCO_BANK 41 -#define MCO1 41 -#define MCO2 42 - -/* PERIF BANK */ -#define PERIF_BANK 50 -#define D1SRAM1_CK 50 -#define ITCM_CK 51 -#define DTCM2_CK 52 -#define DTCM1_CK 53 -#define FLITF_CK 54 -#define JPGDEC_CK 55 -#define DMA2D_CK 56 -#define MDMA_CK 57 -#define USB2ULPI_CK 58 -#define USB1ULPI_CK 59 -#define ETH1RX_CK 60 -#define ETH1TX_CK 61 -#define ETH1MAC_CK 62 -#define ART_CK 63 -#define DMA2_CK 64 -#define DMA1_CK 65 -#define D2SRAM3_CK 66 -#define D2SRAM2_CK 67 -#define D2SRAM1_CK 68 -#define HASH_CK 69 -#define CRYPT_CK 70 -#define CAMITF_CK 71 -#define BKPRAM_CK 72 -#define HSEM_CK 73 -#define BDMA_CK 74 -#define CRC_CK 75 -#define GPIOK_CK 76 -#define GPIOJ_CK 77 -#define GPIOI_CK 78 -#define GPIOH_CK 79 -#define GPIOG_CK 80 -#define GPIOF_CK 81 -#define GPIOE_CK 82 -#define GPIOD_CK 83 -#define GPIOC_CK 84 -#define GPIOB_CK 85 -#define GPIOA_CK 86 -#define WWDG1_CK 87 -#define DAC12_CK 88 -#define WWDG2_CK 89 -#define TIM14_CK 90 -#define TIM13_CK 91 -#define TIM12_CK 92 -#define TIM7_CK 93 -#define TIM6_CK 94 -#define TIM5_CK 95 -#define TIM4_CK 96 -#define TIM3_CK 97 -#define TIM2_CK 98 -#define MDIOS_CK 99 -#define OPAMP_CK 100 -#define CRS_CK 101 -#define TIM17_CK 102 -#define TIM16_CK 103 -#define TIM15_CK 104 -#define TIM8_CK 105 -#define TIM1_CK 106 -#define TMPSENS_CK 107 -#define RTCAPB_CK 108 -#define VREF_CK 109 -#define COMP12_CK 110 -#define SYSCFG_CK 111 -/* must be equal to last peripheral clock index */ -#define LAST_PERIF_BANK SYSCFG_CK - -/* KERNEL BANK */ -#define KERN_BANK 120 -#define SDMMC1_CK 120 -#define QUADSPI_CK 121 -#define FMC_CK 122 -#define USB2OTG_CK 123 -#define USB1OTG_CK 124 -#define ADC12_CK 125 -#define SDMMC2_CK 126 -#define RNG_CK 127 -#define ADC3_CK 128 -#define DSI_CK 129 -#define LTDC_CK 130 -#define USART8_CK 131 -#define USART7_CK 132 -#define HDMICEC_CK 133 -#define I2C3_CK 134 -#define I2C2_CK 135 -#define I2C1_CK 136 -#define UART5_CK 137 -#define UART4_CK 138 -#define USART3_CK 139 -#define USART2_CK 140 -#define SPDIFRX_CK 141 -#define SPI3_CK 142 -#define SPI2_CK 143 -#define LPTIM1_CK 144 -#define FDCAN_CK 145 -#define SWP_CK 146 -#define HRTIM_CK 147 -#define DFSDM1_CK 148 -#define SAI3_CK 149 -#define SAI2_CK 150 -#define SAI1_CK 151 -#define SPI5_CK 152 -#define SPI4_CK 153 -#define SPI1_CK 154 -#define USART6_CK 155 -#define USART1_CK 156 -#define SAI4B_CK 157 -#define SAI4A_CK 158 -#define LPTIM5_CK 159 -#define LPTIM4_CK 160 -#define LPTIM3_CK 161 -#define LPTIM2_CK 162 -#define I2C4_CK 163 -#define SPI6_CK 164 -#define LPUART1_CK 165 - -#define STM32H7_MAX_CLKS 166 diff --git a/include/dt-bindings/clock/stm32mp1-clks.h b/include/dt-bindings/clock/stm32mp1-clks.h deleted file mode 100644 index 0a5324bcdbda..000000000000 --- a/include/dt-bindings/clock/stm32mp1-clks.h +++ /dev/null @@ -1,274 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR BSD-3-Clause */ -/* - * Copyright (C) STMicroelectronics 2018 - All Rights Reserved - * Author: Gabriel Fernandez gabriel.fernandez@st.com for STMicroelectronics. - */ - -#ifndef _DT_BINDINGS_STM32MP1_CLKS_H_ -#define _DT_BINDINGS_STM32MP1_CLKS_H_ - -/* OSCILLATOR clocks */ -#define CK_HSE 0 -#define CK_CSI 1 -#define CK_LSI 2 -#define CK_LSE 3 -#define CK_HSI 4 -#define CK_HSE_DIV2 5 - -/* Bus clocks */ -#define TIM2 6 -#define TIM3 7 -#define TIM4 8 -#define TIM5 9 -#define TIM6 10 -#define TIM7 11 -#define TIM12 12 -#define TIM13 13 -#define TIM14 14 -#define LPTIM1 15 -#define SPI2 16 -#define SPI3 17 -#define USART2 18 -#define USART3 19 -#define UART4 20 -#define UART5 21 -#define UART7 22 -#define UART8 23 -#define I2C1 24 -#define I2C2 25 -#define I2C3 26 -#define I2C5 27 -#define SPDIF 28 -#define CEC 29 -#define DAC12 30 -#define MDIO 31 -#define TIM1 32 -#define TIM8 33 -#define TIM15 34 -#define TIM16 35 -#define TIM17 36 -#define SPI1 37 -#define SPI4 38 -#define SPI5 39 -#define USART6 40 -#define SAI1 41 -#define SAI2 42 -#define SAI3 43 -#define DFSDM 44 -#define FDCAN 45 -#define LPTIM2 46 -#define LPTIM3 47 -#define LPTIM4 48 -#define LPTIM5 49 -#define SAI4 50 -#define SYSCFG 51 -#define VREF 52 -#define TMPSENS 53 -#define PMBCTRL 54 -#define HDP 55 -#define LTDC 56 -#define DSI 57 -#define IWDG2 58 -#define USBPHY 59 -#define STGENRO 60 -#define SPI6 61 -#define I2C4 62 -#define I2C6 63 -#define USART1 64 -#define RTCAPB 65 -#define TZC1 66 -#define TZPC 67 -#define IWDG1 68 -#define BSEC 69 -#define STGEN 70 -#define DMA1 71 -#define DMA2 72 -#define DMAMUX 73 -#define ADC12 74 -#define USBO 75 -#define SDMMC3 76 -#define DCMI 77 -#define CRYP2 78 -#define HASH2 79 -#define RNG2 80 -#define CRC2 81 -#define HSEM 82 -#define IPCC 83 -#define GPIOA 84 -#define GPIOB 85 -#define GPIOC 86 -#define GPIOD 87 -#define GPIOE 88 -#define GPIOF 89 -#define GPIOG 90 -#define GPIOH 91 -#define GPIOI 92 -#define GPIOJ 93 -#define GPIOK 94 -#define GPIOZ 95 -#define CRYP1 96 -#define HASH1 97 -#define RNG1 98 -#define BKPSRAM 99 -#define MDMA 100 -#define GPU 101 -#define ETHCK 102 -#define ETHTX 103 -#define ETHRX 104 -#define ETHMAC 105 -#define FMC 106 -#define QSPI 107 -#define SDMMC1 108 -#define SDMMC2 109 -#define CRC1 110 -#define USBH 111 -#define ETHSTP 112 -#define TZC2 113 - -/* Kernel clocks */ -#define SDMMC1_K 118 -#define SDMMC2_K 119 -#define SDMMC3_K 120 -#define FMC_K 121 -#define QSPI_K 122 -#define ETHCK_K 123 -#define RNG1_K 124 -#define RNG2_K 125 -#define GPU_K 126 -#define USBPHY_K 127 -#define STGEN_K 128 -#define SPDIF_K 129 -#define SPI1_K 130 -#define SPI2_K 131 -#define SPI3_K 132 -#define SPI4_K 133 -#define SPI5_K 134 -#define SPI6_K 135 -#define CEC_K 136 -#define I2C1_K 137 -#define I2C2_K 138 -#define I2C3_K 139 -#define I2C4_K 140 -#define I2C5_K 141 -#define I2C6_K 142 -#define LPTIM1_K 143 -#define LPTIM2_K 144 -#define LPTIM3_K 145 -#define LPTIM4_K 146 -#define LPTIM5_K 147 -#define USART1_K 148 -#define USART2_K 149 -#define USART3_K 150 -#define UART4_K 151 -#define UART5_K 152 -#define USART6_K 153 -#define UART7_K 154 -#define UART8_K 155 -#define DFSDM_K 156 -#define FDCAN_K 157 -#define SAI1_K 158 -#define SAI2_K 159 -#define SAI3_K 160 -#define SAI4_K 161 -#define ADC12_K 162 -#define DSI_K 163 -#define DSI_PX 164 -#define ADFSDM_K 165 -#define USBO_K 166 -#define LTDC_PX 167 -#define DAC12_K 168 -#define ETHPTP_K 169 - -/* PLL */ -#define PLL1 176 -#define PLL2 177 -#define PLL3 178 -#define PLL4 179 - -/* ODF */ -#define PLL1_P 180 -#define PLL1_Q 181 -#define PLL1_R 182 -#define PLL2_P 183 -#define PLL2_Q 184 -#define PLL2_R 185 -#define PLL3_P 186 -#define PLL3_Q 187 -#define PLL3_R 188 -#define PLL4_P 189 -#define PLL4_Q 190 -#define PLL4_R 191 - -/* AUX */ -#define RTC 192 - -/* MCLK */ -#define CK_PER 193 -#define CK_MPU 194 -#define CK_AXI 195 -#define CK_MCU 196 - -/* Time base */ -#define TIM2_K 197 -#define TIM3_K 198 -#define TIM4_K 199 -#define TIM5_K 200 -#define TIM6_K 201 -#define TIM7_K 202 -#define TIM12_K 203 -#define TIM13_K 204 -#define TIM14_K 205 -#define TIM1_K 206 -#define TIM8_K 207 -#define TIM15_K 208 -#define TIM16_K 209 -#define TIM17_K 210 - -/* MCO clocks */ -#define CK_MCO1 211 -#define CK_MCO2 212 - -/* TRACE & DEBUG clocks */ -#define CK_DBG 214 -#define CK_TRACE 215 - -/* DDR */ -#define DDRC1 220 -#define DDRC1LP 221 -#define DDRC2 222 -#define DDRC2LP 223 -#define DDRPHYC 224 -#define DDRPHYCLP 225 -#define DDRCAPB 226 -#define DDRCAPBLP 227 -#define AXIDCG 228 -#define DDRPHYCAPB 229 -#define DDRPHYCAPBLP 230 -#define DDRPERFM 231 - -#define STM32MP1_LAST_CLK 232 - -/* SCMI clock identifiers */ -#define CK_SCMI_HSE 0 -#define CK_SCMI_HSI 1 -#define CK_SCMI_CSI 2 -#define CK_SCMI_LSE 3 -#define CK_SCMI_LSI 4 -#define CK_SCMI_PLL2_Q 5 -#define CK_SCMI_PLL2_R 6 -#define CK_SCMI_MPU 7 -#define CK_SCMI_AXI 8 -#define CK_SCMI_BSEC 9 -#define CK_SCMI_CRYP1 10 -#define CK_SCMI_GPIOZ 11 -#define CK_SCMI_HASH1 12 -#define CK_SCMI_I2C4 13 -#define CK_SCMI_I2C6 14 -#define CK_SCMI_IWDG1 15 -#define CK_SCMI_RNG1 16 -#define CK_SCMI_RTC 17 -#define CK_SCMI_RTCAPB 18 -#define CK_SCMI_SPI6 19 -#define CK_SCMI_USART1 20 - -#endif /* _DT_BINDINGS_STM32MP1_CLKS_H_ */ diff --git a/include/dt-bindings/clock/stm32mp13-clks.h b/include/dt-bindings/clock/stm32mp13-clks.h deleted file mode 100644 index 0bd7b54c65ff..000000000000 --- a/include/dt-bindings/clock/stm32mp13-clks.h +++ /dev/null @@ -1,229 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-3-Clause */ -/* - * Copyright (C) STMicroelectronics 2020 - All Rights Reserved - * Author: Gabriel Fernandez gabriel.fernandez@foss.st.com for STMicroelectronics. - */ - -#ifndef _DT_BINDINGS_STM32MP13_CLKS_H_ -#define _DT_BINDINGS_STM32MP13_CLKS_H_ - -/* OSCILLATOR clocks */ -#define CK_HSE 0 -#define CK_CSI 1 -#define CK_LSI 2 -#define CK_LSE 3 -#define CK_HSI 4 -#define CK_HSE_DIV2 5 - -/* PLL */ -#define PLL1 6 -#define PLL2 7 -#define PLL3 8 -#define PLL4 9 - -/* ODF */ -#define PLL1_P 10 -#define PLL1_Q 11 -#define PLL1_R 12 -#define PLL2_P 13 -#define PLL2_Q 14 -#define PLL2_R 15 -#define PLL3_P 16 -#define PLL3_Q 17 -#define PLL3_R 18 -#define PLL4_P 19 -#define PLL4_Q 20 -#define PLL4_R 21 - -#define PCLK1 22 -#define PCLK2 23 -#define PCLK3 24 -#define PCLK4 25 -#define PCLK5 26 -#define PCLK6 27 - -/* SYSTEM CLOCK */ -#define CK_PER 28 -#define CK_MPU 29 -#define CK_AXI 30 -#define CK_MLAHB 31 - -/* BASE TIMER */ -#define CK_TIMG1 32 -#define CK_TIMG2 33 -#define CK_TIMG3 34 - -/* AUX */ -#define RTC 35 - -/* TRACE & DEBUG clocks */ -#define CK_DBG 36 -#define CK_TRACE 37 - -/* MCO clocks */ -#define CK_MCO1 38 -#define CK_MCO2 39 - -/* IP clocks */ -#define SYSCFG 40 -#define VREF 41 -#define DTS 42 -#define PMBCTRL 43 -#define HDP 44 -#define IWDG2 45 -#define STGENRO 46 -#define USART1 47 -#define RTCAPB 48 -#define TZC 49 -#define TZPC 50 -#define IWDG1 51 -#define BSEC 52 -#define DMA1 53 -#define DMA2 54 -#define DMAMUX1 55 -#define DMAMUX2 56 -#define GPIOA 57 -#define GPIOB 58 -#define GPIOC 59 -#define GPIOD 60 -#define GPIOE 61 -#define GPIOF 62 -#define GPIOG 63 -#define GPIOH 64 -#define GPIOI 65 -#define CRYP1 66 -#define HASH1 67 -#define BKPSRAM 68 -#define MDMA 69 -#define CRC1 70 -#define USBH 71 -#define DMA3 72 -#define TSC 73 -#define PKA 74 -#define AXIMC 75 -#define MCE 76 -#define ETH1TX 77 -#define ETH2TX 78 -#define ETH1RX 79 -#define ETH2RX 80 -#define ETH1MAC 81 -#define ETH2MAC 82 -#define ETH1STP 83 -#define ETH2STP 84 - -/* IP clocks with parents */ -#define SDMMC1_K 85 -#define SDMMC2_K 86 -#define ADC1_K 87 -#define ADC2_K 88 -#define FMC_K 89 -#define QSPI_K 90 -#define RNG1_K 91 -#define USBPHY_K 92 -#define STGEN_K 93 -#define SPDIF_K 94 -#define SPI1_K 95 -#define SPI2_K 96 -#define SPI3_K 97 -#define SPI4_K 98 -#define SPI5_K 99 -#define I2C1_K 100 -#define I2C2_K 101 -#define I2C3_K 102 -#define I2C4_K 103 -#define I2C5_K 104 -#define TIM2_K 105 -#define TIM3_K 106 -#define TIM4_K 107 -#define TIM5_K 108 -#define TIM6_K 109 -#define TIM7_K 110 -#define TIM12_K 111 -#define TIM13_K 112 -#define TIM14_K 113 -#define TIM1_K 114 -#define TIM8_K 115 -#define TIM15_K 116 -#define TIM16_K 117 -#define TIM17_K 118 -#define LPTIM1_K 119 -#define LPTIM2_K 120 -#define LPTIM3_K 121 -#define LPTIM4_K 122 -#define LPTIM5_K 123 -#define USART1_K 124 -#define USART2_K 125 -#define USART3_K 126 -#define UART4_K 127 -#define UART5_K 128 -#define USART6_K 129 -#define UART7_K 130 -#define UART8_K 131 -#define DFSDM_K 132 -#define FDCAN_K 133 -#define SAI1_K 134 -#define SAI2_K 135 -#define ADFSDM_K 136 -#define USBO_K 137 -#define LTDC_PX 138 -#define ETH1CK_K 139 -#define ETH1PTP_K 140 -#define ETH2CK_K 141 -#define ETH2PTP_K 142 -#define DCMIPP_K 143 -#define SAES_K 144 -#define DTS_K 145 - -/* DDR */ -#define DDRC1 146 -#define DDRC1LP 147 -#define DDRC2 148 -#define DDRC2LP 149 -#define DDRPHYC 150 -#define DDRPHYCLP 151 -#define DDRCAPB 152 -#define DDRCAPBLP 153 -#define AXIDCG 154 -#define DDRPHYCAPB 155 -#define DDRPHYCAPBLP 156 -#define DDRPERFM 157 - -#define ADC1 158 -#define ADC2 159 -#define SAI1 160 -#define SAI2 161 - -#define STM32MP1_LAST_CLK 162 - -/* SCMI clock identifiers */ -#define CK_SCMI_HSE 0 -#define CK_SCMI_HSI 1 -#define CK_SCMI_CSI 2 -#define CK_SCMI_LSE 3 -#define CK_SCMI_LSI 4 -#define CK_SCMI_HSE_DIV2 5 -#define CK_SCMI_PLL2_Q 6 -#define CK_SCMI_PLL2_R 7 -#define CK_SCMI_PLL3_P 8 -#define CK_SCMI_PLL3_Q 9 -#define CK_SCMI_PLL3_R 10 -#define CK_SCMI_PLL4_P 11 -#define CK_SCMI_PLL4_Q 12 -#define CK_SCMI_PLL4_R 13 -#define CK_SCMI_MPU 14 -#define CK_SCMI_AXI 15 -#define CK_SCMI_MLAHB 16 -#define CK_SCMI_CKPER 17 -#define CK_SCMI_PCLK1 18 -#define CK_SCMI_PCLK2 19 -#define CK_SCMI_PCLK3 20 -#define CK_SCMI_PCLK4 21 -#define CK_SCMI_PCLK5 22 -#define CK_SCMI_PCLK6 23 -#define CK_SCMI_CKTIMG1 24 -#define CK_SCMI_CKTIMG2 25 -#define CK_SCMI_CKTIMG3 26 -#define CK_SCMI_RTC 27 -#define CK_SCMI_RTCAPB 28 - -#endif /* _DT_BINDINGS_STM32MP13_CLKS_H_ */ diff --git a/include/dt-bindings/mfd/st,stpmic1.h b/include/dt-bindings/mfd/st,stpmic1.h deleted file mode 100644 index 321cd08797d9..000000000000 --- a/include/dt-bindings/mfd/st,stpmic1.h +++ /dev/null @@ -1,50 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) STMicroelectronics 2018 - All Rights Reserved - * Author: Philippe Peurichard philippe.peurichard@st.com, - * Pascal Paillet p.paillet@st.com for STMicroelectronics. - */ - -#ifndef __DT_BINDINGS_STPMIC1_H__ -#define __DT_BINDINGS_STPMIC1_H__ - -/* IRQ definitions */ -#define IT_PONKEY_F 0 -#define IT_PONKEY_R 1 -#define IT_WAKEUP_F 2 -#define IT_WAKEUP_R 3 -#define IT_VBUS_OTG_F 4 -#define IT_VBUS_OTG_R 5 -#define IT_SWOUT_F 6 -#define IT_SWOUT_R 7 - -#define IT_CURLIM_BUCK1 8 -#define IT_CURLIM_BUCK2 9 -#define IT_CURLIM_BUCK3 10 -#define IT_CURLIM_BUCK4 11 -#define IT_OCP_OTG 12 -#define IT_OCP_SWOUT 13 -#define IT_OCP_BOOST 14 -#define IT_OVP_BOOST 15 - -#define IT_CURLIM_LDO1 16 -#define IT_CURLIM_LDO2 17 -#define IT_CURLIM_LDO3 18 -#define IT_CURLIM_LDO4 19 -#define IT_CURLIM_LDO5 20 -#define IT_CURLIM_LDO6 21 -#define IT_SHORT_SWOTG 22 -#define IT_SHORT_SWOUT 23 - -#define IT_TWARN_F 24 -#define IT_TWARN_R 25 -#define IT_VINLOW_F 26 -#define IT_VINLOW_R 27 -#define IT_SWIN_F 30 -#define IT_SWIN_R 31 - -/* BUCK MODES definitions */ -#define STPMIC1_BUCK_MODE_NORMAL 0 -#define STPMIC1_BUCK_MODE_LP 2 - -#endif /* __DT_BINDINGS_STPMIC1_H__ */ diff --git a/include/dt-bindings/mfd/st-lpc.h b/include/dt-bindings/mfd/st-lpc.h deleted file mode 100644 index d05894afa7e7..000000000000 --- a/include/dt-bindings/mfd/st-lpc.h +++ /dev/null @@ -1,16 +0,0 @@ -/* - * This header provides shared DT/Driver defines for ST's LPC device - * - * Copyright (C) 2014 STMicroelectronics -- All Rights Reserved - * - * Author: Lee Jones lee.jones@linaro.org for STMicroelectronics - */ - -#ifndef __DT_BINDINGS_ST_LPC_H__ -#define __DT_BINDINGS_ST_LPC_H__ - -#define ST_LPC_MODE_RTC 0 -#define ST_LPC_MODE_WDT 1 -#define ST_LPC_MODE_CLKSRC 2 - -#endif /* __DT_BINDINGS_ST_LPC_H__ */ diff --git a/include/dt-bindings/mfd/stm32f4-rcc.h b/include/dt-bindings/mfd/stm32f4-rcc.h deleted file mode 100644 index 36448a5619a1..000000000000 --- a/include/dt-bindings/mfd/stm32f4-rcc.h +++ /dev/null @@ -1,108 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the STM32F4 RCC IP - */ - -#ifndef _DT_BINDINGS_MFD_STM32F4_RCC_H -#define _DT_BINDINGS_MFD_STM32F4_RCC_H - -/* AHB1 */ -#define STM32F4_RCC_AHB1_GPIOA 0 -#define STM32F4_RCC_AHB1_GPIOB 1 -#define STM32F4_RCC_AHB1_GPIOC 2 -#define STM32F4_RCC_AHB1_GPIOD 3 -#define STM32F4_RCC_AHB1_GPIOE 4 -#define STM32F4_RCC_AHB1_GPIOF 5 -#define STM32F4_RCC_AHB1_GPIOG 6 -#define STM32F4_RCC_AHB1_GPIOH 7 -#define STM32F4_RCC_AHB1_GPIOI 8 -#define STM32F4_RCC_AHB1_GPIOJ 9 -#define STM32F4_RCC_AHB1_GPIOK 10 -#define STM32F4_RCC_AHB1_CRC 12 -#define STM32F4_RCC_AHB1_BKPSRAM 18 -#define STM32F4_RCC_AHB1_CCMDATARAM 20 -#define STM32F4_RCC_AHB1_DMA1 21 -#define STM32F4_RCC_AHB1_DMA2 22 -#define STM32F4_RCC_AHB1_DMA2D 23 -#define STM32F4_RCC_AHB1_ETHMAC 25 -#define STM32F4_RCC_AHB1_ETHMACTX 26 -#define STM32F4_RCC_AHB1_ETHMACRX 27 -#define STM32F4_RCC_AHB1_ETHMACPTP 28 -#define STM32F4_RCC_AHB1_OTGHS 29 -#define STM32F4_RCC_AHB1_OTGHSULPI 30 - -#define STM32F4_AHB1_RESET(bit) (STM32F4_RCC_AHB1_##bit + (0x10 * 8)) -#define STM32F4_AHB1_CLOCK(bit) (STM32F4_RCC_AHB1_##bit) - -/* AHB2 */ -#define STM32F4_RCC_AHB2_DCMI 0 -#define STM32F4_RCC_AHB2_CRYP 4 -#define STM32F4_RCC_AHB2_HASH 5 -#define STM32F4_RCC_AHB2_RNG 6 -#define STM32F4_RCC_AHB2_OTGFS 7 - -#define STM32F4_AHB2_RESET(bit) (STM32F4_RCC_AHB2_##bit + (0x14 * 8)) -#define STM32F4_AHB2_CLOCK(bit) (STM32F4_RCC_AHB2_##bit + 0x20) - -/* AHB3 */ -#define STM32F4_RCC_AHB3_FMC 0 -#define STM32F4_RCC_AHB3_QSPI 1 - -#define STM32F4_AHB3_RESET(bit) (STM32F4_RCC_AHB3_##bit + (0x18 * 8)) -#define STM32F4_AHB3_CLOCK(bit) (STM32F4_RCC_AHB3_##bit + 0x40) - -/* APB1 */ -#define STM32F4_RCC_APB1_TIM2 0 -#define STM32F4_RCC_APB1_TIM3 1 -#define STM32F4_RCC_APB1_TIM4 2 -#define STM32F4_RCC_APB1_TIM5 3 -#define STM32F4_RCC_APB1_TIM6 4 -#define STM32F4_RCC_APB1_TIM7 5 -#define STM32F4_RCC_APB1_TIM12 6 -#define STM32F4_RCC_APB1_TIM13 7 -#define STM32F4_RCC_APB1_TIM14 8 -#define STM32F4_RCC_APB1_WWDG 11 -#define STM32F4_RCC_APB1_SPI2 14 -#define STM32F4_RCC_APB1_SPI3 15 -#define STM32F4_RCC_APB1_UART2 17 -#define STM32F4_RCC_APB1_UART3 18 -#define STM32F4_RCC_APB1_UART4 19 -#define STM32F4_RCC_APB1_UART5 20 -#define STM32F4_RCC_APB1_I2C1 21 -#define STM32F4_RCC_APB1_I2C2 22 -#define STM32F4_RCC_APB1_I2C3 23 -#define STM32F4_RCC_APB1_CAN1 25 -#define STM32F4_RCC_APB1_CAN2 26 -#define STM32F4_RCC_APB1_PWR 28 -#define STM32F4_RCC_APB1_DAC 29 -#define STM32F4_RCC_APB1_UART7 30 -#define STM32F4_RCC_APB1_UART8 31 - -#define STM32F4_APB1_RESET(bit) (STM32F4_RCC_APB1_##bit + (0x20 * 8)) -#define STM32F4_APB1_CLOCK(bit) (STM32F4_RCC_APB1_##bit + 0x80) - -/* APB2 */ -#define STM32F4_RCC_APB2_TIM1 0 -#define STM32F4_RCC_APB2_TIM8 1 -#define STM32F4_RCC_APB2_USART1 4 -#define STM32F4_RCC_APB2_USART6 5 -#define STM32F4_RCC_APB2_ADC1 8 -#define STM32F4_RCC_APB2_ADC2 9 -#define STM32F4_RCC_APB2_ADC3 10 -#define STM32F4_RCC_APB2_SDIO 11 -#define STM32F4_RCC_APB2_SPI1 12 -#define STM32F4_RCC_APB2_SPI4 13 -#define STM32F4_RCC_APB2_SYSCFG 14 -#define STM32F4_RCC_APB2_TIM9 16 -#define STM32F4_RCC_APB2_TIM10 17 -#define STM32F4_RCC_APB2_TIM11 18 -#define STM32F4_RCC_APB2_SPI5 20 -#define STM32F4_RCC_APB2_SPI6 21 -#define STM32F4_RCC_APB2_SAI1 22 -#define STM32F4_RCC_APB2_LTDC 26 -#define STM32F4_RCC_APB2_DSI 27 - -#define STM32F4_APB2_RESET(bit) (STM32F4_RCC_APB2_##bit + (0x24 * 8)) -#define STM32F4_APB2_CLOCK(bit) (STM32F4_RCC_APB2_##bit + 0xA0) - -#endif /* _DT_BINDINGS_MFD_STM32F4_RCC_H */ diff --git a/include/dt-bindings/mfd/stm32f7-rcc.h b/include/dt-bindings/mfd/stm32f7-rcc.h deleted file mode 100644 index a4e4f9271395..000000000000 --- a/include/dt-bindings/mfd/stm32f7-rcc.h +++ /dev/null @@ -1,116 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the STM32F7 RCC IP - */ - -#ifndef _DT_BINDINGS_MFD_STM32F7_RCC_H -#define _DT_BINDINGS_MFD_STM32F7_RCC_H - -/* AHB1 */ -#define STM32F7_RCC_AHB1_GPIOA 0 -#define STM32F7_RCC_AHB1_GPIOB 1 -#define STM32F7_RCC_AHB1_GPIOC 2 -#define STM32F7_RCC_AHB1_GPIOD 3 -#define STM32F7_RCC_AHB1_GPIOE 4 -#define STM32F7_RCC_AHB1_GPIOF 5 -#define STM32F7_RCC_AHB1_GPIOG 6 -#define STM32F7_RCC_AHB1_GPIOH 7 -#define STM32F7_RCC_AHB1_GPIOI 8 -#define STM32F7_RCC_AHB1_GPIOJ 9 -#define STM32F7_RCC_AHB1_GPIOK 10 -#define STM32F7_RCC_AHB1_CRC 12 -#define STM32F7_RCC_AHB1_BKPSRAM 18 -#define STM32F7_RCC_AHB1_DTCMRAM 20 -#define STM32F7_RCC_AHB1_DMA1 21 -#define STM32F7_RCC_AHB1_DMA2 22 -#define STM32F7_RCC_AHB1_DMA2D 23 -#define STM32F7_RCC_AHB1_ETHMAC 25 -#define STM32F7_RCC_AHB1_ETHMACTX 26 -#define STM32F7_RCC_AHB1_ETHMACRX 27 -#define STM32FF_RCC_AHB1_ETHMACPTP 28 -#define STM32F7_RCC_AHB1_OTGHS 29 -#define STM32F7_RCC_AHB1_OTGHSULPI 30 - -#define STM32F7_AHB1_RESET(bit) (STM32F7_RCC_AHB1_##bit + (0x10 * 8)) -#define STM32F7_AHB1_CLOCK(bit) (STM32F7_RCC_AHB1_##bit) - - -/* AHB2 */ -#define STM32F7_RCC_AHB2_DCMI 0 -#define STM32F7_RCC_AHB2_CRYP 4 -#define STM32F7_RCC_AHB2_HASH 5 -#define STM32F7_RCC_AHB2_RNG 6 -#define STM32F7_RCC_AHB2_OTGFS 7 - -#define STM32F7_AHB2_RESET(bit) (STM32F7_RCC_AHB2_##bit + (0x14 * 8)) -#define STM32F7_AHB2_CLOCK(bit) (STM32F7_RCC_AHB2_##bit + 0x20) - -/* AHB3 */ -#define STM32F7_RCC_AHB3_FMC 0 -#define STM32F7_RCC_AHB3_QSPI 1 - -#define STM32F7_AHB3_RESET(bit) (STM32F7_RCC_AHB3_##bit + (0x18 * 8)) -#define STM32F7_AHB3_CLOCK(bit) (STM32F7_RCC_AHB3_##bit + 0x40) - -/* APB1 */ -#define STM32F7_RCC_APB1_TIM2 0 -#define STM32F7_RCC_APB1_TIM3 1 -#define STM32F7_RCC_APB1_TIM4 2 -#define STM32F7_RCC_APB1_TIM5 3 -#define STM32F7_RCC_APB1_TIM6 4 -#define STM32F7_RCC_APB1_TIM7 5 -#define STM32F7_RCC_APB1_TIM12 6 -#define STM32F7_RCC_APB1_TIM13 7 -#define STM32F7_RCC_APB1_TIM14 8 -#define STM32F7_RCC_APB1_LPTIM1 9 -#define STM32F7_RCC_APB1_WWDG 11 -#define STM32F7_RCC_APB1_CAN3 13 -#define STM32F7_RCC_APB1_SPI2 14 -#define STM32F7_RCC_APB1_SPI3 15 -#define STM32F7_RCC_APB1_SPDIFRX 16 -#define STM32F7_RCC_APB1_UART2 17 -#define STM32F7_RCC_APB1_UART3 18 -#define STM32F7_RCC_APB1_UART4 19 -#define STM32F7_RCC_APB1_UART5 20 -#define STM32F7_RCC_APB1_I2C1 21 -#define STM32F7_RCC_APB1_I2C2 22 -#define STM32F7_RCC_APB1_I2C3 23 -#define STM32F7_RCC_APB1_I2C4 24 -#define STM32F7_RCC_APB1_CAN1 25 -#define STM32F7_RCC_APB1_CAN2 26 -#define STM32F7_RCC_APB1_CEC 27 -#define STM32F7_RCC_APB1_PWR 28 -#define STM32F7_RCC_APB1_DAC 29 -#define STM32F7_RCC_APB1_UART7 30 -#define STM32F7_RCC_APB1_UART8 31 - -#define STM32F7_APB1_RESET(bit) (STM32F7_RCC_APB1_##bit + (0x20 * 8)) -#define STM32F7_APB1_CLOCK(bit) (STM32F7_RCC_APB1_##bit + 0x80) - -/* APB2 */ -#define STM32F7_RCC_APB2_TIM1 0 -#define STM32F7_RCC_APB2_TIM8 1 -#define STM32F7_RCC_APB2_USART1 4 -#define STM32F7_RCC_APB2_USART6 5 -#define STM32F7_RCC_APB2_SDMMC2 7 -#define STM32F7_RCC_APB2_ADC1 8 -#define STM32F7_RCC_APB2_ADC2 9 -#define STM32F7_RCC_APB2_ADC3 10 -#define STM32F7_RCC_APB2_SDMMC1 11 -#define STM32F7_RCC_APB2_SPI1 12 -#define STM32F7_RCC_APB2_SPI4 13 -#define STM32F7_RCC_APB2_SYSCFG 14 -#define STM32F7_RCC_APB2_TIM9 16 -#define STM32F7_RCC_APB2_TIM10 17 -#define STM32F7_RCC_APB2_TIM11 18 -#define STM32F7_RCC_APB2_SPI5 20 -#define STM32F7_RCC_APB2_SPI6 21 -#define STM32F7_RCC_APB2_SAI1 22 -#define STM32F7_RCC_APB2_SAI2 23 -#define STM32F7_RCC_APB2_LTDC 26 -#define STM32F7_RCC_APB2_DSI 27 - -#define STM32F7_APB2_RESET(bit) (STM32F7_RCC_APB2_##bit + (0x24 * 8)) -#define STM32F7_APB2_CLOCK(bit) (STM32F7_RCC_APB2_##bit + 0xA0) - -#endif /* _DT_BINDINGS_MFD_STM32F7_RCC_H */ diff --git a/include/dt-bindings/mfd/stm32h7-rcc.h b/include/dt-bindings/mfd/stm32h7-rcc.h deleted file mode 100644 index 06e8476bf08f..000000000000 --- a/include/dt-bindings/mfd/stm32h7-rcc.h +++ /dev/null @@ -1,138 +0,0 @@ -/* - * This header provides constants for the STM32H7 RCC IP - */ - -#ifndef _DT_BINDINGS_MFD_STM32H7_RCC_H -#define _DT_BINDINGS_MFD_STM32H7_RCC_H - -/* AHB3 */ -#define STM32H7_RCC_AHB3_MDMA 0 -#define STM32H7_RCC_AHB3_DMA2D 4 -#define STM32H7_RCC_AHB3_JPGDEC 5 -#define STM32H7_RCC_AHB3_FMC 12 -#define STM32H7_RCC_AHB3_QUADSPI 14 -#define STM32H7_RCC_AHB3_SDMMC1 16 -#define STM32H7_RCC_AHB3_CPU 31 -#define STM32H7_RCC_AHB3_CPU1 31 - -#define STM32H7_AHB3_RESET(bit) (STM32H7_RCC_AHB3_##bit + (0x7C * 8)) - -/* AHB1 */ -#define STM32H7_RCC_AHB1_DMA1 0 -#define STM32H7_RCC_AHB1_DMA2 1 -#define STM32H7_RCC_AHB1_ADC12 5 -#define STM32H7_RCC_AHB1_ART 14 -#define STM32H7_RCC_AHB1_ETH1MAC 15 -#define STM32H7_RCC_AHB1_USB1OTG 25 -#define STM32H7_RCC_AHB1_USB2OTG 27 -#define STM32H7_RCC_AHB1_CPU2 31 - -#define STM32H7_AHB1_RESET(bit) (STM32H7_RCC_AHB1_##bit + (0x80 * 8)) - -/* AHB2 */ -#define STM32H7_RCC_AHB2_CAMITF 0 -#define STM32H7_RCC_AHB2_CRYPT 4 -#define STM32H7_RCC_AHB2_HASH 5 -#define STM32H7_RCC_AHB2_RNG 6 -#define STM32H7_RCC_AHB2_SDMMC2 9 - -#define STM32H7_AHB2_RESET(bit) (STM32H7_RCC_AHB2_##bit + (0x84 * 8)) - -/* AHB4 */ -#define STM32H7_RCC_AHB4_GPIOA 0 -#define STM32H7_RCC_AHB4_GPIOB 1 -#define STM32H7_RCC_AHB4_GPIOC 2 -#define STM32H7_RCC_AHB4_GPIOD 3 -#define STM32H7_RCC_AHB4_GPIOE 4 -#define STM32H7_RCC_AHB4_GPIOF 5 -#define STM32H7_RCC_AHB4_GPIOG 6 -#define STM32H7_RCC_AHB4_GPIOH 7 -#define STM32H7_RCC_AHB4_GPIOI 8 -#define STM32H7_RCC_AHB4_GPIOJ 9 -#define STM32H7_RCC_AHB4_GPIOK 10 -#define STM32H7_RCC_AHB4_CRC 19 -#define STM32H7_RCC_AHB4_BDMA 21 -#define STM32H7_RCC_AHB4_ADC3 24 -#define STM32H7_RCC_AHB4_HSEM 25 - -#define STM32H7_AHB4_RESET(bit) (STM32H7_RCC_AHB4_##bit + (0x88 * 8)) - -/* APB3 */ -#define STM32H7_RCC_APB3_LTDC 3 -#define STM32H7_RCC_APB3_DSI 4 - -#define STM32H7_APB3_RESET(bit) (STM32H7_RCC_APB3_##bit + (0x8C * 8)) - -/* APB1L */ -#define STM32H7_RCC_APB1L_TIM2 0 -#define STM32H7_RCC_APB1L_TIM3 1 -#define STM32H7_RCC_APB1L_TIM4 2 -#define STM32H7_RCC_APB1L_TIM5 3 -#define STM32H7_RCC_APB1L_TIM6 4 -#define STM32H7_RCC_APB1L_TIM7 5 -#define STM32H7_RCC_APB1L_TIM12 6 -#define STM32H7_RCC_APB1L_TIM13 7 -#define STM32H7_RCC_APB1L_TIM14 8 -#define STM32H7_RCC_APB1L_LPTIM1 9 -#define STM32H7_RCC_APB1L_SPI2 14 -#define STM32H7_RCC_APB1L_SPI3 15 -#define STM32H7_RCC_APB1L_SPDIF_RX 16 -#define STM32H7_RCC_APB1L_USART2 17 -#define STM32H7_RCC_APB1L_USART3 18 -#define STM32H7_RCC_APB1L_UART4 19 -#define STM32H7_RCC_APB1L_UART5 20 -#define STM32H7_RCC_APB1L_I2C1 21 -#define STM32H7_RCC_APB1L_I2C2 22 -#define STM32H7_RCC_APB1L_I2C3 23 -#define STM32H7_RCC_APB1L_HDMICEC 27 -#define STM32H7_RCC_APB1L_DAC12 29 -#define STM32H7_RCC_APB1L_USART7 30 -#define STM32H7_RCC_APB1L_USART8 31 - -#define STM32H7_APB1L_RESET(bit) (STM32H7_RCC_APB1L_##bit + (0x90 * 8)) - -/* APB1H */ -#define STM32H7_RCC_APB1H_CRS 1 -#define STM32H7_RCC_APB1H_SWP 2 -#define STM32H7_RCC_APB1H_OPAMP 4 -#define STM32H7_RCC_APB1H_MDIOS 5 -#define STM32H7_RCC_APB1H_FDCAN 8 - -#define STM32H7_APB1H_RESET(bit) (STM32H7_RCC_APB1H_##bit + (0x94 * 8)) - -/* APB2 */ -#define STM32H7_RCC_APB2_TIM1 0 -#define STM32H7_RCC_APB2_TIM8 1 -#define STM32H7_RCC_APB2_USART1 4 -#define STM32H7_RCC_APB2_USART6 5 -#define STM32H7_RCC_APB2_SPI1 12 -#define STM32H7_RCC_APB2_SPI4 13 -#define STM32H7_RCC_APB2_TIM15 16 -#define STM32H7_RCC_APB2_TIM16 17 -#define STM32H7_RCC_APB2_TIM17 18 -#define STM32H7_RCC_APB2_SPI5 20 -#define STM32H7_RCC_APB2_SAI1 22 -#define STM32H7_RCC_APB2_SAI2 23 -#define STM32H7_RCC_APB2_SAI3 24 -#define STM32H7_RCC_APB2_DFSDM1 28 -#define STM32H7_RCC_APB2_HRTIM 29 - -#define STM32H7_APB2_RESET(bit) (STM32H7_RCC_APB2_##bit + (0x98 * 8)) - -/* APB4 */ -#define STM32H7_RCC_APB4_SYSCFG 1 -#define STM32H7_RCC_APB4_LPUART1 3 -#define STM32H7_RCC_APB4_SPI6 5 -#define STM32H7_RCC_APB4_I2C4 7 -#define STM32H7_RCC_APB4_LPTIM2 9 -#define STM32H7_RCC_APB4_LPTIM3 10 -#define STM32H7_RCC_APB4_LPTIM4 11 -#define STM32H7_RCC_APB4_LPTIM5 12 -#define STM32H7_RCC_APB4_COMP12 14 -#define STM32H7_RCC_APB4_VREF 15 -#define STM32H7_RCC_APB4_SAI4 21 -#define STM32H7_RCC_APB4_TMPSENS 26 - -#define STM32H7_APB4_RESET(bit) (STM32H7_RCC_APB4_##bit + (0x9C * 8)) - -#endif /* _DT_BINDINGS_MFD_STM32H7_RCC_H */ diff --git a/include/dt-bindings/pinctrl/stm32-pinfunc.h b/include/dt-bindings/pinctrl/stm32-pinfunc.h deleted file mode 100644 index 28ad0235086a..000000000000 --- a/include/dt-bindings/pinctrl/stm32-pinfunc.h +++ /dev/null @@ -1,45 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) */ -/* - * Copyright (C) STMicroelectronics 2017 - All Rights Reserved - * Author: Torgue Alexandre alexandre.torgue@st.com for STMicroelectronics. - */ - -#ifndef _DT_BINDINGS_STM32_PINFUNC_H -#define _DT_BINDINGS_STM32_PINFUNC_H - -/* define PIN modes */ -#define GPIO 0x0 -#define AF0 0x1 -#define AF1 0x2 -#define AF2 0x3 -#define AF3 0x4 -#define AF4 0x5 -#define AF5 0x6 -#define AF6 0x7 -#define AF7 0x8 -#define AF8 0x9 -#define AF9 0xa -#define AF10 0xb -#define AF11 0xc -#define AF12 0xd -#define AF13 0xe -#define AF14 0xf -#define AF15 0x10 -#define ANALOG 0x11 - -/* define Pins number*/ -#define PIN_NO(port, line) (((port) - 'A') * 0x10 + (line)) - -#define STM32_PINMUX(port, line, mode) (((PIN_NO(port, line)) << 8) | (mode)) - -/* package information */ -#define STM32MP_PKG_AA 0x1 -#define STM32MP_PKG_AB 0x2 -#define STM32MP_PKG_AC 0x4 -#define STM32MP_PKG_AD 0x8 -#define STM32MP_PKG_AI 0x100 -#define STM32MP_PKG_AK 0x400 -#define STM32MP_PKG_AL 0x800 - -#endif /* _DT_BINDINGS_STM32_PINFUNC_H */ - diff --git a/include/dt-bindings/regulator/st,stm32mp13-regulator.h b/include/dt-bindings/regulator/st,stm32mp13-regulator.h deleted file mode 100644 index b3a974dfc585..000000000000 --- a/include/dt-bindings/regulator/st,stm32mp13-regulator.h +++ /dev/null @@ -1,42 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) */ -/* - * Copyright (C) 2022, STMicroelectronics - All Rights Reserved - */ - -#ifndef __DT_BINDINGS_REGULATOR_ST_STM32MP13_REGULATOR_H -#define __DT_BINDINGS_REGULATOR_ST_STM32MP13_REGULATOR_H - -/* SCMI voltage domains identifiers */ - -/* SOC Internal regulators */ -#define VOLTD_SCMI_REG11 0 -#define VOLTD_SCMI_REG18 1 -#define VOLTD_SCMI_USB33 2 -#define VOLTD_SCMI_SDMMC1_IO 3 -#define VOLTD_SCMI_SDMMC2_IO 4 -#define VOLTD_SCMI_VREFBUF 5 - -/* STPMIC1 regulators */ -#define VOLTD_SCMI_STPMIC1_BUCK1 6 -#define VOLTD_SCMI_STPMIC1_BUCK2 7 -#define VOLTD_SCMI_STPMIC1_BUCK3 8 -#define VOLTD_SCMI_STPMIC1_BUCK4 9 -#define VOLTD_SCMI_STPMIC1_LDO1 10 -#define VOLTD_SCMI_STPMIC1_LDO2 11 -#define VOLTD_SCMI_STPMIC1_LDO3 12 -#define VOLTD_SCMI_STPMIC1_LDO4 13 -#define VOLTD_SCMI_STPMIC1_LDO5 14 -#define VOLTD_SCMI_STPMIC1_LDO6 15 -#define VOLTD_SCMI_STPMIC1_VREFDDR 16 -#define VOLTD_SCMI_STPMIC1_BOOST 17 -#define VOLTD_SCMI_STPMIC1_PWR_SW1 18 -#define VOLTD_SCMI_STPMIC1_PWR_SW2 19 - -/* External regulators */ -#define VOLTD_SCMI_REGU0 20 -#define VOLTD_SCMI_REGU1 21 -#define VOLTD_SCMI_REGU2 22 -#define VOLTD_SCMI_REGU3 23 -#define VOLTD_SCMI_REGU4 24 - -#endif /*__DT_BINDINGS_REGULATOR_ST_STM32MP13_REGULATOR_H */ diff --git a/include/dt-bindings/reset/stih407-resets.h b/include/dt-bindings/reset/stih407-resets.h deleted file mode 100644 index 4ab3a1c94958..000000000000 --- a/include/dt-bindings/reset/stih407-resets.h +++ /dev/null @@ -1,65 +0,0 @@ -/* - * This header provides constants for the reset controller - * based peripheral powerdown requests on the STMicroelectronics - * STiH407 SoC. - */ -#ifndef _DT_BINDINGS_RESET_CONTROLLER_STIH407 -#define _DT_BINDINGS_RESET_CONTROLLER_STIH407 - -/* Powerdown requests control 0 */ -#define STIH407_EMISS_POWERDOWN 0 -#define STIH407_NAND_POWERDOWN 1 - -/* Synp GMAC PowerDown */ -#define STIH407_ETH1_POWERDOWN 2 - -/* Powerdown requests control 1 */ -#define STIH407_USB3_POWERDOWN 3 -#define STIH407_USB2_PORT1_POWERDOWN 4 -#define STIH407_USB2_PORT0_POWERDOWN 5 -#define STIH407_PCIE1_POWERDOWN 6 -#define STIH407_PCIE0_POWERDOWN 7 -#define STIH407_SATA1_POWERDOWN 8 -#define STIH407_SATA0_POWERDOWN 9 - -/* Reset defines */ -#define STIH407_ETH1_SOFTRESET 0 -#define STIH407_MMC1_SOFTRESET 1 -#define STIH407_PICOPHY_SOFTRESET 2 -#define STIH407_IRB_SOFTRESET 3 -#define STIH407_PCIE0_SOFTRESET 4 -#define STIH407_PCIE1_SOFTRESET 5 -#define STIH407_SATA0_SOFTRESET 6 -#define STIH407_SATA1_SOFTRESET 7 -#define STIH407_MIPHY0_SOFTRESET 8 -#define STIH407_MIPHY1_SOFTRESET 9 -#define STIH407_MIPHY2_SOFTRESET 10 -#define STIH407_SATA0_PWR_SOFTRESET 11 -#define STIH407_SATA1_PWR_SOFTRESET 12 -#define STIH407_DELTA_SOFTRESET 13 -#define STIH407_BLITTER_SOFTRESET 14 -#define STIH407_HDTVOUT_SOFTRESET 15 -#define STIH407_HDQVDP_SOFTRESET 16 -#define STIH407_VDP_AUX_SOFTRESET 17 -#define STIH407_COMPO_SOFTRESET 18 -#define STIH407_HDMI_TX_PHY_SOFTRESET 19 -#define STIH407_JPEG_DEC_SOFTRESET 20 -#define STIH407_VP8_DEC_SOFTRESET 21 -#define STIH407_GPU_SOFTRESET 22 -#define STIH407_HVA_SOFTRESET 23 -#define STIH407_ERAM_HVA_SOFTRESET 24 -#define STIH407_LPM_SOFTRESET 25 -#define STIH407_KEYSCAN_SOFTRESET 26 -#define STIH407_USB2_PORT0_SOFTRESET 27 -#define STIH407_USB2_PORT1_SOFTRESET 28 -#define STIH407_ST231_AUD_SOFTRESET 29 -#define STIH407_ST231_DMU_SOFTRESET 30 -#define STIH407_ST231_GP0_SOFTRESET 31 -#define STIH407_ST231_GP1_SOFTRESET 32 - -/* Picophy reset defines */ -#define STIH407_PICOPHY0_RESET 0 -#define STIH407_PICOPHY1_RESET 1 -#define STIH407_PICOPHY2_RESET 2 - -#endif /* _DT_BINDINGS_RESET_CONTROLLER_STIH407 */ diff --git a/include/dt-bindings/reset/stm32mp1-resets.h b/include/dt-bindings/reset/stm32mp1-resets.h deleted file mode 100644 index 9071f139649f..000000000000 --- a/include/dt-bindings/reset/stm32mp1-resets.h +++ /dev/null @@ -1,123 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR BSD-3-Clause */ -/* - * Copyright (C) STMicroelectronics 2018 - All Rights Reserved - * Author: Gabriel Fernandez gabriel.fernandez@st.com for STMicroelectronics. - */ - -#ifndef _DT_BINDINGS_STM32MP1_RESET_H_ -#define _DT_BINDINGS_STM32MP1_RESET_H_ - -#define MCU_HOLD_BOOT_R 2144 -#define LTDC_R 3072 -#define DSI_R 3076 -#define DDRPERFM_R 3080 -#define USBPHY_R 3088 -#define SPI6_R 3136 -#define I2C4_R 3138 -#define I2C6_R 3139 -#define USART1_R 3140 -#define STGEN_R 3156 -#define GPIOZ_R 3200 -#define CRYP1_R 3204 -#define HASH1_R 3205 -#define RNG1_R 3206 -#define AXIM_R 3216 -#define GPU_R 3269 -#define ETHMAC_R 3274 -#define FMC_R 3276 -#define QSPI_R 3278 -#define SDMMC1_R 3280 -#define SDMMC2_R 3281 -#define CRC1_R 3284 -#define USBH_R 3288 -#define MDMA_R 3328 -#define MCU_R 8225 -#define TIM2_R 19456 -#define TIM3_R 19457 -#define TIM4_R 19458 -#define TIM5_R 19459 -#define TIM6_R 19460 -#define TIM7_R 19461 -#define TIM12_R 16462 -#define TIM13_R 16463 -#define TIM14_R 16464 -#define LPTIM1_R 19465 -#define SPI2_R 19467 -#define SPI3_R 19468 -#define USART2_R 19470 -#define USART3_R 19471 -#define UART4_R 19472 -#define UART5_R 19473 -#define UART7_R 19474 -#define UART8_R 19475 -#define I2C1_R 19477 -#define I2C2_R 19478 -#define I2C3_R 19479 -#define I2C5_R 19480 -#define SPDIF_R 19482 -#define CEC_R 19483 -#define DAC12_R 19485 -#define MDIO_R 19847 -#define TIM1_R 19520 -#define TIM8_R 19521 -#define TIM15_R 19522 -#define TIM16_R 19523 -#define TIM17_R 19524 -#define SPI1_R 19528 -#define SPI4_R 19529 -#define SPI5_R 19530 -#define USART6_R 19533 -#define SAI1_R 19536 -#define SAI2_R 19537 -#define SAI3_R 19538 -#define DFSDM_R 19540 -#define FDCAN_R 19544 -#define LPTIM2_R 19584 -#define LPTIM3_R 19585 -#define LPTIM4_R 19586 -#define LPTIM5_R 19587 -#define SAI4_R 19592 -#define SYSCFG_R 19595 -#define VREF_R 19597 -#define TMPSENS_R 19600 -#define PMBCTRL_R 19601 -#define DMA1_R 19648 -#define DMA2_R 19649 -#define DMAMUX_R 19650 -#define ADC12_R 19653 -#define USBO_R 19656 -#define SDMMC3_R 19664 -#define CAMITF_R 19712 -#define CRYP2_R 19716 -#define HASH2_R 19717 -#define RNG2_R 19718 -#define CRC2_R 19719 -#define HSEM_R 19723 -#define MBOX_R 19724 -#define GPIOA_R 19776 -#define GPIOB_R 19777 -#define GPIOC_R 19778 -#define GPIOD_R 19779 -#define GPIOE_R 19780 -#define GPIOF_R 19781 -#define GPIOG_R 19782 -#define GPIOH_R 19783 -#define GPIOI_R 19784 -#define GPIOJ_R 19785 -#define GPIOK_R 19786 - -/* SCMI reset domain identifiers */ -#define RST_SCMI_SPI6 0 -#define RST_SCMI_I2C4 1 -#define RST_SCMI_I2C6 2 -#define RST_SCMI_USART1 3 -#define RST_SCMI_STGEN 4 -#define RST_SCMI_GPIOZ 5 -#define RST_SCMI_CRYP1 6 -#define RST_SCMI_HASH1 7 -#define RST_SCMI_RNG1 8 -#define RST_SCMI_MDMA 9 -#define RST_SCMI_MCU 10 -#define RST_SCMI_MCU_HOLD_BOOT 11 - -#endif /* _DT_BINDINGS_STM32MP1_RESET_H_ */ diff --git a/include/dt-bindings/reset/stm32mp13-resets.h b/include/dt-bindings/reset/stm32mp13-resets.h deleted file mode 100644 index ecb37c7ddde1..000000000000 --- a/include/dt-bindings/reset/stm32mp13-resets.h +++ /dev/null @@ -1,100 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-3-Clause */ -/* - * Copyright (C) STMicroelectronics 2018 - All Rights Reserved - * Author: Gabriel Fernandez gabriel.fernandez@foss.st.com for STMicroelectronics. - */ - -#ifndef _DT_BINDINGS_STM32MP13_RESET_H_ -#define _DT_BINDINGS_STM32MP13_RESET_H_ - -#define TIM2_R 13568 -#define TIM3_R 13569 -#define TIM4_R 13570 -#define TIM5_R 13571 -#define TIM6_R 13572 -#define TIM7_R 13573 -#define LPTIM1_R 13577 -#define SPI2_R 13579 -#define SPI3_R 13580 -#define USART3_R 13583 -#define UART4_R 13584 -#define UART5_R 13585 -#define UART7_R 13586 -#define UART8_R 13587 -#define I2C1_R 13589 -#define I2C2_R 13590 -#define SPDIF_R 13594 -#define TIM1_R 13632 -#define TIM8_R 13633 -#define SPI1_R 13640 -#define USART6_R 13645 -#define SAI1_R 13648 -#define SAI2_R 13649 -#define DFSDM_R 13652 -#define FDCAN_R 13656 -#define LPTIM2_R 13696 -#define LPTIM3_R 13697 -#define LPTIM4_R 13698 -#define LPTIM5_R 13699 -#define SYSCFG_R 13707 -#define VREF_R 13709 -#define DTS_R 13712 -#define PMBCTRL_R 13713 -#define LTDC_R 13760 -#define DCMIPP_R 13761 -#define DDRPERFM_R 13768 -#define USBPHY_R 13776 -#define STGEN_R 13844 -#define USART1_R 13888 -#define USART2_R 13889 -#define SPI4_R 13890 -#define SPI5_R 13891 -#define I2C3_R 13892 -#define I2C4_R 13893 -#define I2C5_R 13894 -#define TIM12_R 13895 -#define TIM13_R 13896 -#define TIM14_R 13897 -#define TIM15_R 13898 -#define TIM16_R 13899 -#define TIM17_R 13900 -#define DMA1_R 13952 -#define DMA2_R 13953 -#define DMAMUX1_R 13954 -#define DMA3_R 13955 -#define DMAMUX2_R 13956 -#define ADC1_R 13957 -#define ADC2_R 13958 -#define USBO_R 13960 -#define GPIOA_R 14080 -#define GPIOB_R 14081 -#define GPIOC_R 14082 -#define GPIOD_R 14083 -#define GPIOE_R 14084 -#define GPIOF_R 14085 -#define GPIOG_R 14086 -#define GPIOH_R 14087 -#define GPIOI_R 14088 -#define TSC_R 14095 -#define PKA_R 14146 -#define SAES_R 14147 -#define CRYP1_R 14148 -#define HASH1_R 14149 -#define RNG1_R 14150 -#define AXIMC_R 14160 -#define MDMA_R 14208 -#define MCE_R 14209 -#define ETH1MAC_R 14218 -#define FMC_R 14220 -#define QSPI_R 14222 -#define SDMMC1_R 14224 -#define SDMMC2_R 14225 -#define CRC1_R 14228 -#define USBH_R 14232 -#define ETH2MAC_R 14238 - -/* SCMI reset domain identifiers */ -#define RST_SCMI_LTDC 0 -#define RST_SCMI_MDMA 1 - -#endif /* _DT_BINDINGS_STM32MP13_RESET_H_ */
Drop in favour of dts/upstream.
Small driver/dts adjustments to fix compatibility.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- drivers/clk/rockchip/clk_rk3399.c | 2 +- include/dt-bindings/clock/px30-cru.h | 389 ---------- include/dt-bindings/clock/rk3036-cru.h | 185 ----- include/dt-bindings/clock/rk3066a-cru.h | 31 - include/dt-bindings/clock/rk3128-cru.h | 273 ------- include/dt-bindings/clock/rk3188-cru-common.h | 261 ------- include/dt-bindings/clock/rk3188-cru.h | 47 -- include/dt-bindings/clock/rk3228-cru.h | 287 -------- include/dt-bindings/clock/rk3288-cru.h | 381 ---------- include/dt-bindings/clock/rk3308-cru.h | 387 ---------- include/dt-bindings/clock/rk3328-cru.h | 393 ---------- include/dt-bindings/clock/rk3368-cru.h | 381 ---------- include/dt-bindings/clock/rk3399-cru.h | 749 ------------------- include/dt-bindings/clock/rk3568-cru.h | 926 ------------------------ include/dt-bindings/clock/rockchip,rk3588-cru.h | 766 -------------------- include/dt-bindings/clock/rockchip,rk808.h | 11 - include/dt-bindings/clock/rockchip,rv1126-cru.h | 632 ---------------- 18 files changed, 2 insertions(+), 6101 deletions(-)
diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 87b173e59579..320fa824cc80 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -39,9 +39,9 @@ bootph-all; compatible = "rockchip,rk3399-dmc"; devfreq-events = <&dfi>; interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_DDRCLK>; + clocks = <&cru SCLK_DDRC>; clock-names = "dmc_clk"; reg = <0x0 0xffa80000 0x0 0x0800 0x0 0xffa80800 0x0 0x1800 0x0 0xffa82000 0x0 0x2000 diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 80f65a237e8e..f0ce54067f8c 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1048,9 +1048,9 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) * assigned-clocks handling won't require for vopl, so * return 0 to satisfy clk_set_defaults during device probe. */ return 0; - case SCLK_DDRCLK: + case SCLK_DDRC: ret = rk3399_ddr_set_clk(priv->cru, rate); break; case PCLK_EFUSE1024NS: break; diff --git a/include/dt-bindings/clock/px30-cru.h b/include/dt-bindings/clock/px30-cru.h deleted file mode 100644 index e5e59690b5f5..000000000000 --- a/include/dt-bindings/clock/px30-cru.h +++ /dev/null @@ -1,389 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2017 Rockchip Electronics Co. Ltd. - * Author: Elaine zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_PX30_H -#define _DT_BINDINGS_CLK_ROCKCHIP_PX30_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_NPLL 4 -#define APLL_BOOST_H 5 -#define APLL_BOOST_L 6 -#define ARMCLK 7 - -/* sclk gates (special clocks) */ -#define USB480M 14 -#define SCLK_PDM 15 -#define SCLK_I2S0_TX 16 -#define SCLK_I2S0_TX_OUT 17 -#define SCLK_I2S0_RX 18 -#define SCLK_I2S0_RX_OUT 19 -#define SCLK_I2S1 20 -#define SCLK_I2S1_OUT 21 -#define SCLK_I2S2 22 -#define SCLK_I2S2_OUT 23 -#define SCLK_UART1 24 -#define SCLK_UART2 25 -#define SCLK_UART3 26 -#define SCLK_UART4 27 -#define SCLK_UART5 28 -#define SCLK_I2C0 29 -#define SCLK_I2C1 30 -#define SCLK_I2C2 31 -#define SCLK_I2C3 32 -#define SCLK_I2C4 33 -#define SCLK_PWM0 34 -#define SCLK_PWM1 35 -#define SCLK_SPI0 36 -#define SCLK_SPI1 37 -#define SCLK_TIMER0 38 -#define SCLK_TIMER1 39 -#define SCLK_TIMER2 40 -#define SCLK_TIMER3 41 -#define SCLK_TIMER4 42 -#define SCLK_TIMER5 43 -#define SCLK_TSADC 44 -#define SCLK_SARADC 45 -#define SCLK_OTP 46 -#define SCLK_OTP_USR 47 -#define SCLK_CRYPTO 48 -#define SCLK_CRYPTO_APK 49 -#define SCLK_DDRC 50 -#define SCLK_ISP 51 -#define SCLK_CIF_OUT 52 -#define SCLK_RGA_CORE 53 -#define SCLK_VOPB_PWM 54 -#define SCLK_NANDC 55 -#define SCLK_SDIO 56 -#define SCLK_EMMC 57 -#define SCLK_SFC 58 -#define SCLK_SDMMC 59 -#define SCLK_OTG_ADP 60 -#define SCLK_GMAC_SRC 61 -#define SCLK_GMAC 62 -#define SCLK_GMAC_RX_TX 63 -#define SCLK_MAC_REF 64 -#define SCLK_MAC_REFOUT 65 -#define SCLK_MAC_OUT 66 -#define SCLK_SDMMC_DRV 67 -#define SCLK_SDMMC_SAMPLE 68 -#define SCLK_SDIO_DRV 69 -#define SCLK_SDIO_SAMPLE 70 -#define SCLK_EMMC_DRV 71 -#define SCLK_EMMC_SAMPLE 72 -#define SCLK_GPU 73 -#define SCLK_PVTM 74 -#define SCLK_CORE_VPU 75 -#define SCLK_GMAC_RMII 76 -#define SCLK_UART2_SRC 77 -#define SCLK_NANDC_DIV 78 -#define SCLK_NANDC_DIV50 79 -#define SCLK_SDIO_DIV 80 -#define SCLK_SDIO_DIV50 81 -#define SCLK_EMMC_DIV 82 -#define SCLK_EMMC_DIV50 83 - -/* dclk gates */ -#define DCLK_VOPB 150 -#define DCLK_VOPL 151 - -/* aclk gates */ -#define ACLK_GPU 170 -#define ACLK_BUS_PRE 171 -#define ACLK_CRYPTO 172 -#define ACLK_VI_PRE 173 -#define ACLK_VO_PRE 174 -#define ACLK_VPU 175 -#define ACLK_PERI_PRE 176 -#define ACLK_GMAC 178 -#define ACLK_CIF 179 -#define ACLK_ISP 180 -#define ACLK_VOPB 181 -#define ACLK_VOPL 182 -#define ACLK_RGA 183 -#define ACLK_GIC 184 -#define ACLK_DCF 186 -#define ACLK_DMAC 187 - -/* hclk gates */ -#define HCLK_BUS_PRE 240 -#define HCLK_CRYPTO 241 -#define HCLK_VI_PRE 242 -#define HCLK_VO_PRE 243 -#define HCLK_VPU 244 -#define HCLK_PERI_PRE 245 -#define HCLK_MMC_NAND 246 -#define HCLK_SDMMC 247 -#define HCLK_USB 248 -#define HCLK_CIF 249 -#define HCLK_ISP 250 -#define HCLK_VOPB 251 -#define HCLK_VOPL 252 -#define HCLK_RGA 253 -#define HCLK_NANDC 254 -#define HCLK_SDIO 255 -#define HCLK_EMMC 256 -#define HCLK_SFC 257 -#define HCLK_OTG 258 -#define HCLK_HOST 259 -#define HCLK_HOST_ARB 260 -#define HCLK_PDM 261 -#define HCLK_I2S0 262 -#define HCLK_I2S1 263 -#define HCLK_I2S2 264 - -/* pclk gates */ -#define PCLK_BUS_PRE 320 -#define PCLK_DDR 321 -#define PCLK_VO_PRE 322 -#define PCLK_GMAC 323 -#define PCLK_MIPI_DSI 324 -#define PCLK_MIPIDSIPHY 325 -#define PCLK_MIPICSIPHY 326 -#define PCLK_USB_GRF 327 -#define PCLK_DCF 328 -#define PCLK_UART1 329 -#define PCLK_UART2 330 -#define PCLK_UART3 331 -#define PCLK_UART4 332 -#define PCLK_UART5 333 -#define PCLK_I2C0 334 -#define PCLK_I2C1 335 -#define PCLK_I2C2 336 -#define PCLK_I2C3 337 -#define PCLK_I2C4 338 -#define PCLK_PWM0 339 -#define PCLK_PWM1 340 -#define PCLK_SPI0 341 -#define PCLK_SPI1 342 -#define PCLK_SARADC 343 -#define PCLK_TSADC 344 -#define PCLK_TIMER 345 -#define PCLK_OTP_NS 346 -#define PCLK_WDT_NS 347 -#define PCLK_GPIO1 348 -#define PCLK_GPIO2 349 -#define PCLK_GPIO3 350 -#define PCLK_ISP 351 -#define PCLK_CIF 352 -#define PCLK_OTP_PHY 353 - -#define CLK_NR_CLKS (PCLK_OTP_PHY + 1) - -/* pmu-clocks indices */ - -#define PLL_GPLL 1 - -#define SCLK_RTC32K_PMU 4 -#define SCLK_WIFI_PMU 5 -#define SCLK_UART0_PMU 6 -#define SCLK_PVTM_PMU 7 -#define PCLK_PMU_PRE 8 -#define SCLK_REF24M_PMU 9 -#define SCLK_USBPHY_REF 10 -#define SCLK_MIPIDSIPHY_REF 11 - -#define XIN24M_DIV 12 - -#define PCLK_GPIO0_PMU 20 -#define PCLK_UART0_PMU 21 - -#define CLKPMU_NR_CLKS (PCLK_UART0_PMU + 1) - -/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NOC 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15 - -#define SRST_DAP 16 -#define SRST_CORE_PVTM 17 -#define SRST_GPU 18 -#define SRST_GPU_NIU 19 -#define SRST_UPCTL2 20 -#define SRST_UPCTL2_A 21 -#define SRST_UPCTL2_P 22 -#define SRST_MSCH 23 -#define SRST_MSCH_P 24 -#define SRST_DDRMON_P 25 -#define SRST_DDRSTDBY_P 26 -#define SRST_DDRSTDBY 27 -#define SRST_DDRGRF_p 28 -#define SRST_AXI_SPLIT_A 29 -#define SRST_AXI_CMD_A 30 -#define SRST_AXI_CMD_P 31 - -#define SRST_DDRPHY 32 -#define SRST_DDRPHYDIV 33 -#define SRST_DDRPHY_P 34 -#define SRST_VPU_A 36 -#define SRST_VPU_NIU_A 37 -#define SRST_VPU_H 38 -#define SRST_VPU_NIU_H 39 -#define SRST_VI_NIU_A 40 -#define SRST_VI_NIU_H 41 -#define SRST_ISP_H 42 -#define SRST_ISP 43 -#define SRST_CIF_A 44 -#define SRST_CIF_H 45 -#define SRST_CIF_PCLKIN 46 -#define SRST_MIPICSIPHY_P 47 - -#define SRST_VO_NIU_A 48 -#define SRST_VO_NIU_H 49 -#define SRST_VO_NIU_P 50 -#define SRST_VOPB_A 51 -#define SRST_VOPB_H 52 -#define SRST_VOPB 53 -#define SRST_PWM_VOPB 54 -#define SRST_VOPL_A 55 -#define SRST_VOPL_H 56 -#define SRST_VOPL 57 -#define SRST_RGA_A 58 -#define SRST_RGA_H 59 -#define SRST_RGA 60 -#define SRST_MIPIDSI_HOST_P 61 -#define SRST_MIPIDSIPHY_P 62 -#define SRST_VPU_CORE 63 - -#define SRST_PERI_NIU_A 64 -#define SRST_USB_NIU_H 65 -#define SRST_USB2OTG_H 66 -#define SRST_USB2OTG 67 -#define SRST_USB2OTG_ADP 68 -#define SRST_USB2HOST_H 69 -#define SRST_USB2HOST_ARB_H 70 -#define SRST_USB2HOST_AUX_H 71 -#define SRST_USB2HOST_EHCI 72 -#define SRST_USB2HOST 73 -#define SRST_USBPHYPOR 74 -#define SRST_USBPHY_OTG_PORT 75 -#define SRST_USBPHY_HOST_PORT 76 -#define SRST_USBPHY_GRF 77 -#define SRST_CPU_BOOST_P 78 -#define SRST_CPU_BOOST 79 - -#define SRST_MMC_NAND_NIU_H 80 -#define SRST_SDIO_H 81 -#define SRST_EMMC_H 82 -#define SRST_SFC_H 83 -#define SRST_SFC 84 -#define SRST_SDCARD_NIU_H 85 -#define SRST_SDMMC_H 86 -#define SRST_NANDC_H 89 -#define SRST_NANDC 90 -#define SRST_GMAC_NIU_A 92 -#define SRST_GMAC_NIU_P 93 -#define SRST_GMAC_A 94 - -#define SRST_PMU_NIU_P 96 -#define SRST_PMU_SGRF_P 97 -#define SRST_PMU_GRF_P 98 -#define SRST_PMU 99 -#define SRST_PMU_MEM_P 100 -#define SRST_PMU_GPIO0_P 101 -#define SRST_PMU_UART0_P 102 -#define SRST_PMU_CRU_P 103 -#define SRST_PMU_PVTM 104 -#define SRST_PMU_UART 105 -#define SRST_PMU_NIU_H 106 -#define SRST_PMU_DDR_FAIL_SAVE 107 -#define SRST_PMU_CORE_PERF_A 108 -#define SRST_PMU_CORE_GRF_P 109 -#define SRST_PMU_GPU_PERF_A 110 -#define SRST_PMU_GPU_GRF_P 111 - -#define SRST_CRYPTO_NIU_A 112 -#define SRST_CRYPTO_NIU_H 113 -#define SRST_CRYPTO_A 114 -#define SRST_CRYPTO_H 115 -#define SRST_CRYPTO 116 -#define SRST_CRYPTO_APK 117 -#define SRST_BUS_NIU_H 120 -#define SRST_USB_NIU_P 121 -#define SRST_BUS_TOP_NIU_P 122 -#define SRST_INTMEM_A 123 -#define SRST_GIC_A 124 -#define SRST_ROM_H 126 -#define SRST_DCF_A 127 - -#define SRST_DCF_P 128 -#define SRST_PDM_H 129 -#define SRST_PDM 130 -#define SRST_I2S0_H 131 -#define SRST_I2S0_TX 132 -#define SRST_I2S1_H 133 -#define SRST_I2S1 134 -#define SRST_I2S2_H 135 -#define SRST_I2S2 136 -#define SRST_UART1_P 137 -#define SRST_UART1 138 -#define SRST_UART2_P 139 -#define SRST_UART2 140 -#define SRST_UART3_P 141 -#define SRST_UART3 142 -#define SRST_UART4_P 143 - -#define SRST_UART4 144 -#define SRST_UART5_P 145 -#define SRST_UART5 146 -#define SRST_I2C0_P 147 -#define SRST_I2C0 148 -#define SRST_I2C1_P 149 -#define SRST_I2C1 150 -#define SRST_I2C2_P 151 -#define SRST_I2C2 152 -#define SRST_I2C3_P 153 -#define SRST_I2C3 154 -#define SRST_PWM0_P 157 -#define SRST_PWM0 158 -#define SRST_PWM1_P 159 - -#define SRST_PWM1 160 -#define SRST_SPI0_P 161 -#define SRST_SPI0 162 -#define SRST_SPI1_P 163 -#define SRST_SPI1 164 -#define SRST_SARADC_P 165 -#define SRST_SARADC 166 -#define SRST_TSADC_P 167 -#define SRST_TSADC 168 -#define SRST_TIMER_P 169 -#define SRST_TIMER0 170 -#define SRST_TIMER1 171 -#define SRST_TIMER2 172 -#define SRST_TIMER3 173 -#define SRST_TIMER4 174 -#define SRST_TIMER5 175 - -#define SRST_OTP_NS_P 176 -#define SRST_OTP_NS_SBPI 177 -#define SRST_OTP_NS_USR 178 -#define SRST_OTP_PHY_P 179 -#define SRST_OTP_PHY 180 -#define SRST_WDT_NS_P 181 -#define SRST_GPIO1_P 182 -#define SRST_GPIO2_P 183 -#define SRST_GPIO3_P 184 -#define SRST_SGRF_P 185 -#define SRST_GRF_P 186 -#define SRST_I2S0_RX 191 - -#endif diff --git a/include/dt-bindings/clock/rk3036-cru.h b/include/dt-bindings/clock/rk3036-cru.h deleted file mode 100644 index 2c0552d1a936..000000000000 --- a/include/dt-bindings/clock/rk3036-cru.h +++ /dev/null @@ -1,185 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3036_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3036_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_GPLL 3 -#define ARMCLK 4 - -/* sclk gates (special clocks) */ -#define SCLK_GPU 64 -#define SCLK_SPI 65 -#define SCLK_SDMMC 68 -#define SCLK_SDIO 69 -#define SCLK_EMMC 71 -#define SCLK_NANDC 76 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_I2S 82 -#define SCLK_SPDIF 83 -#define SCLK_TIMER0 85 -#define SCLK_TIMER1 86 -#define SCLK_TIMER2 87 -#define SCLK_TIMER3 88 -#define SCLK_OTGPHY0 93 -#define SCLK_LCDC 100 -#define SCLK_HDMI 109 -#define SCLK_HEVC 111 -#define SCLK_I2S_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO_DRV 115 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO_SAMPLE 119 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_PVTM_CORE 123 -#define SCLK_PVTM_GPU 124 -#define SCLK_PVTM_VIDEO 125 -#define SCLK_MAC 151 -#define SCLK_MACREF 152 -#define SCLK_SFC 160 - -#define DCLK_LCDC 190 - -/* aclk gates */ -#define ACLK_DMAC2 194 -#define ACLK_LCDC 197 -#define ACLK_VIO 203 -#define ACLK_VCODEC 208 -#define ACLK_CPU 209 -#define ACLK_PERI 210 - -/* pclk gates */ -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GRF 329 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_SPI 338 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_PWM 350 -#define PCLK_TIMER 353 -#define PCLK_HDMI 360 -#define PCLK_CPU 362 -#define PCLK_PERI 363 -#define PCLK_DDRUPCTL 364 -#define PCLK_WDT 368 - -/* hclk gates */ -#define HCLK_OTG0 449 -#define HCLK_OTG1 450 -#define HCLK_NANDC 453 -#define HCLK_SDMMC 456 -#define HCLK_SDIO 457 -#define HCLK_EMMC 459 -#define HCLK_I2S 462 -#define HCLK_LCDC 465 -#define HCLK_ROM 467 -#define HCLK_VIO_BUS 472 -#define HCLK_VCODEC 476 -#define HCLK_CPU 477 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE0 0 -#define SRST_CORE1 1 -#define SRST_CORE0_DBG 4 -#define SRST_CORE1_DBG 5 -#define SRST_CORE0_POR 8 -#define SRST_CORE1_POR 9 -#define SRST_L2C 12 -#define SRST_TOPDBG 13 -#define SRST_STRC_SYS_A 14 -#define SRST_PD_CORE_NIU 15 - -#define SRST_TIMER2 16 -#define SRST_CPUSYS_H 17 -#define SRST_AHB2APB_H 19 -#define SRST_TIMER3 20 -#define SRST_INTMEM 21 -#define SRST_ROM 22 -#define SRST_PERI_NIU 23 -#define SRST_I2S 24 -#define SRST_DDR_PLL 25 -#define SRST_GPU_DLL 26 -#define SRST_TIMER0 27 -#define SRST_TIMER1 28 -#define SRST_CORE_DLL 29 -#define SRST_EFUSE_P 30 -#define SRST_ACODEC_P 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_UART0 39 -#define SRST_UART1 40 -#define SRST_UART2 41 -#define SRST_I2C0 43 -#define SRST_I2C1 44 -#define SRST_I2C2 45 -#define SRST_SFC 47 - -#define SRST_PWM0 48 -#define SRST_DAP 51 -#define SRST_DAP_SYS 52 -#define SRST_GRF 55 -#define SRST_PERIPHSYS_A 57 -#define SRST_PERIPHSYS_H 58 -#define SRST_PERIPHSYS_P 59 -#define SRST_CPU_PERI 61 -#define SRST_EMEM_PERI 62 -#define SRST_USB_PERI 63 - -#define SRST_DMA2 64 -#define SRST_MAC 66 -#define SRST_NANDC 68 -#define SRST_USBOTG0 69 -#define SRST_OTGC0 71 -#define SRST_USBOTG1 72 -#define SRST_OTGC1 74 -#define SRST_DDRMSCH 79 - -#define SRST_MMC0 81 -#define SRST_SDIO 82 -#define SRST_EMMC 83 -#define SRST_SPI0 84 -#define SRST_WDT 86 -#define SRST_DDRPHY 88 -#define SRST_DDRPHY_P 89 -#define SRST_DDRCTRL 90 -#define SRST_DDRCTRL_P 91 - -#define SRST_HDMI_P 96 -#define SRST_VIO_BUS_H 99 -#define SRST_UTMI0 103 -#define SRST_UTMI1 104 -#define SRST_USBPOR 105 - -#define SRST_VCODEC_A 112 -#define SRST_VCODEC_H 113 -#define SRST_VIO1_A 114 -#define SRST_HEVC 115 -#define SRST_VCODEC_NIU_A 116 -#define SRST_LCDC1_A 117 -#define SRST_LCDC1_H 118 -#define SRST_LCDC1_D 119 -#define SRST_GPU 120 -#define SRST_GPU_NIU_A 122 - -#define SRST_DBG_P 131 - -#endif diff --git a/include/dt-bindings/clock/rk3066a-cru.h b/include/dt-bindings/clock/rk3066a-cru.h deleted file mode 100644 index 014eec586689..000000000000 --- a/include/dt-bindings/clock/rk3066a-cru.h +++ /dev/null @@ -1,31 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3066A_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3066A_H - -#include <dt-bindings/clock/rk3188-cru-common.h> - -/* soft-reset indices */ -#define SRST_SRST1 0 -#define SRST_SRST2 1 - -#define SRST_L2MEM 18 -#define SRST_I2S0 23 -#define SRST_I2S1 24 -#define SRST_I2S2 25 -#define SRST_TIMER2 29 - -#define SRST_GPIO4 36 -#define SRST_GPIO6 38 - -#define SRST_TSADC 92 - -#define SRST_HDMI 96 -#define SRST_HDMI_APB 97 -#define SRST_CIF1 111 - -#endif diff --git a/include/dt-bindings/clock/rk3128-cru.h b/include/dt-bindings/clock/rk3128-cru.h deleted file mode 100644 index 6a47825dac5d..000000000000 --- a/include/dt-bindings/clock/rk3128-cru.h +++ /dev/null @@ -1,273 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2017 Rockchip Electronics Co. Ltd. - * Author: Elaine zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3128_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3128_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define ARMCLK 5 -#define PLL_GPLL_DIV2 6 -#define PLL_GPLL_DIV3 7 - -/* sclk gates (special clocks) */ -#define SCLK_SPI0 65 -#define SCLK_NANDC 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO 69 -#define SCLK_EMMC 71 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_I2S0 80 -#define SCLK_I2S1 81 -#define SCLK_SPDIF 83 -#define SCLK_TIMER0 85 -#define SCLK_TIMER1 86 -#define SCLK_TIMER2 87 -#define SCLK_TIMER3 88 -#define SCLK_TIMER4 89 -#define SCLK_TIMER5 90 -#define SCLK_SARADC 91 -#define SCLK_I2S_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO_DRV 115 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO_SAMPLE 119 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_VOP 122 -#define SCLK_MAC_SRC 124 -#define SCLK_MAC 126 -#define SCLK_MAC_REFOUT 127 -#define SCLK_MAC_REF 128 -#define SCLK_MAC_RX 129 -#define SCLK_MAC_TX 130 -#define SCLK_HEVC_CORE 134 -#define SCLK_RGA 135 -#define SCLK_CRYPTO 138 -#define SCLK_TSP 139 -#define SCLK_OTGPHY0 142 -#define SCLK_OTGPHY1 143 -#define SCLK_DDRC 144 -#define SCLK_PVTM_FUNC 145 -#define SCLK_PVTM_CORE 146 -#define SCLK_PVTM_GPU 147 -#define SCLK_MIPI_24M 148 -#define SCLK_PVTM 149 -#define SCLK_CIF_SRC 150 -#define SCLK_CIF_OUT_SRC 151 -#define SCLK_CIF_OUT 152 -#define SCLK_SFC 153 -#define SCLK_USB480M 154 - -/* dclk gates */ -#define DCLK_VOP 190 -#define DCLK_EBC 191 - -/* aclk gates */ -#define ACLK_VIO0 192 -#define ACLK_VIO1 193 -#define ACLK_DMAC 194 -#define ACLK_CPU 195 -#define ACLK_VEPU 196 -#define ACLK_VDPU 197 -#define ACLK_CIF 198 -#define ACLK_IEP 199 -#define ACLK_LCDC0 204 -#define ACLK_RGA 205 -#define ACLK_PERI 210 -#define ACLK_VOP 211 -#define ACLK_GMAC 212 -#define ACLK_GPU 213 - -/* pclk gates */ -#define PCLK_SARADC 318 -#define PCLK_WDT 319 -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GPIO3 323 -#define PCLK_VIO_H2P 324 -#define PCLK_MIPI 325 -#define PCLK_EFUSE 326 -#define PCLK_HDMI 327 -#define PCLK_ACODEC 328 -#define PCLK_GRF 329 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_I2C3 335 -#define PCLK_SPI0 338 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_TSADC 344 -#define PCLK_PWM 350 -#define PCLK_TIMER 353 -#define PCLK_CPU 354 -#define PCLK_PERI 363 -#define PCLK_GMAC 367 -#define PCLK_PMU_PRE 368 -#define PCLK_SIM_CARD 369 - -/* hclk gates */ -#define HCLK_SPDIF 440 -#define HCLK_GPS 441 -#define HCLK_USBHOST 442 -#define HCLK_I2S_8CH 443 -#define HCLK_I2S_2CH 444 -#define HCLK_VOP 452 -#define HCLK_NANDC 453 -#define HCLK_SDMMC 456 -#define HCLK_SDIO 457 -#define HCLK_EMMC 459 -#define HCLK_CPU 460 -#define HCLK_VEPU 461 -#define HCLK_VDPU 462 -#define HCLK_LCDC0 463 -#define HCLK_EBC 465 -#define HCLK_VIO 466 -#define HCLK_RGA 467 -#define HCLK_IEP 468 -#define HCLK_VIO_H2P 469 -#define HCLK_CIF 470 -#define HCLK_HOST2 473 -#define HCLK_OTG 474 -#define HCLK_TSP 475 -#define HCLK_CRYPTO 476 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_ACLK_CORE 13 -#define SRST_STRC_SYS_A 14 -#define SRST_L2C 15 - -#define SRST_CPUSYS_H 18 -#define SRST_AHB2APBSYS_H 19 -#define SRST_SPDIF 20 -#define SRST_INTMEM 21 -#define SRST_ROM 22 -#define SRST_PERI_NIU 23 -#define SRST_I2S_2CH 24 -#define SRST_I2S_8CH 25 -#define SRST_GPU_PVTM 26 -#define SRST_FUNC_PVTM 27 -#define SRST_CORE_PVTM 29 -#define SRST_EFUSE_P 30 -#define SRST_ACODEC_P 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 -#define SRST_MIPIPHY_P 36 -#define SRST_UART0 39 -#define SRST_UART1 40 -#define SRST_UART2 41 -#define SRST_I2C0 43 -#define SRST_I2C1 44 -#define SRST_I2C2 45 -#define SRST_I2C3 46 -#define SRST_SFC 47 - -#define SRST_PWM 48 -#define SRST_DAP_PO 50 -#define SRST_DAP 51 -#define SRST_DAP_SYS 52 -#define SRST_CRYPTO 53 -#define SRST_GRF 55 -#define SRST_GMAC 56 -#define SRST_PERIPH_SYS_A 57 -#define SRST_PERIPH_SYS_H 58 -#define SRST_PERIPH_SYS_P 59 -#define SRST_SMART_CARD 60 -#define SRST_CPU_PERI 61 -#define SRST_EMEM_PERI 62 -#define SRST_USB_PERI 63 - -#define SRST_DMA 64 -#define SRST_GPS 67 -#define SRST_NANDC 68 -#define SRST_USBOTG0 69 -#define SRST_OTGC0 71 -#define SRST_USBOTG1 72 -#define SRST_OTGC1 74 -#define SRST_DDRMSCH 79 - -#define SRST_SDMMC 81 -#define SRST_SDIO 82 -#define SRST_EMMC 83 -#define SRST_SPI 84 -#define SRST_WDT 86 -#define SRST_SARADC 87 -#define SRST_DDRPHY 88 -#define SRST_DDRPHY_P 89 -#define SRST_DDRCTRL 90 -#define SRST_DDRCTRL_P 91 -#define SRST_TSP 92 -#define SRST_TSP_CLKIN 93 -#define SRST_HOST0_ECHI 94 - -#define SRST_HDMI_P 96 -#define SRST_VIO_ARBI_H 97 -#define SRST_VIO0_A 98 -#define SRST_VIO_BUS_H 99 -#define SRST_VOP_A 100 -#define SRST_VOP_H 101 -#define SRST_VOP_D 102 -#define SRST_UTMI0 103 -#define SRST_UTMI1 104 -#define SRST_USBPOR 105 -#define SRST_IEP_A 106 -#define SRST_IEP_H 107 -#define SRST_RGA_A 108 -#define SRST_RGA_H 109 -#define SRST_CIF0 110 -#define SRST_PMU 111 - -#define SRST_VCODEC_A 112 -#define SRST_VCODEC_H 113 -#define SRST_VIO1_A 114 -#define SRST_HEVC_CORE 115 -#define SRST_VCODEC_NIU_A 116 -#define SRST_PMU_NIU_P 117 -#define SRST_LCDC0_S 119 -#define SRST_GPU 120 -#define SRST_GPU_NIU_A 122 -#define SRST_EBC_A 123 -#define SRST_EBC_H 124 - -#define SRST_CORE_DBG 128 -#define SRST_DBG_P 129 -#define SRST_TIMER0 130 -#define SRST_TIMER1 131 -#define SRST_TIMER2 132 -#define SRST_TIMER3 133 -#define SRST_TIMER4 134 -#define SRST_TIMER5 135 -#define SRST_VIO_H2P 136 -#define SRST_VIO_MIPI_DSI 137 - -#endif diff --git a/include/dt-bindings/clock/rk3188-cru-common.h b/include/dt-bindings/clock/rk3188-cru-common.h deleted file mode 100644 index afad90680fce..000000000000 --- a/include/dt-bindings/clock/rk3188-cru-common.h +++ /dev/null @@ -1,261 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3188_COMMON_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3188_COMMON_H - -/* core clocks from */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define CORE_PERI 5 -#define CORE_L2C 6 -#define ARMCLK 7 - -/* sclk gates (special clocks) */ -#define SCLK_UART0 64 -#define SCLK_UART1 65 -#define SCLK_UART2 66 -#define SCLK_UART3 67 -#define SCLK_MAC 68 -#define SCLK_SPI0 69 -#define SCLK_SPI1 70 -#define SCLK_SARADC 71 -#define SCLK_SDMMC 72 -#define SCLK_SDIO 73 -#define SCLK_EMMC 74 -#define SCLK_I2S0 75 -#define SCLK_I2S1 76 -#define SCLK_I2S2 77 -#define SCLK_SPDIF 78 -#define SCLK_CIF0 79 -#define SCLK_CIF1 80 -#define SCLK_OTGPHY0 81 -#define SCLK_OTGPHY1 82 -#define SCLK_HSADC 83 -#define SCLK_TIMER0 84 -#define SCLK_TIMER1 85 -#define SCLK_TIMER2 86 -#define SCLK_TIMER3 87 -#define SCLK_TIMER4 88 -#define SCLK_TIMER5 89 -#define SCLK_TIMER6 90 -#define SCLK_JTAG 91 -#define SCLK_SMC 92 -#define SCLK_TSADC 93 - -#define DCLK_LCDC0 190 -#define DCLK_LCDC1 191 - -/* aclk gates */ -#define ACLK_DMA1 192 -#define ACLK_DMA2 193 -#define ACLK_GPS 194 -#define ACLK_LCDC0 195 -#define ACLK_LCDC1 196 -#define ACLK_GPU 197 -#define ACLK_SMC 198 -#define ACLK_CIF1 199 -#define ACLK_IPP 200 -#define ACLK_RGA 201 -#define ACLK_CIF0 202 -#define ACLK_CPU 203 -#define ACLK_PERI 204 -#define ACLK_VEPU 205 -#define ACLK_VDPU 206 - -/* pclk gates */ -#define PCLK_GRF 320 -#define PCLK_PMU 321 -#define PCLK_TIMER0 322 -#define PCLK_TIMER1 323 -#define PCLK_TIMER2 324 -#define PCLK_TIMER3 325 -#define PCLK_PWM01 326 -#define PCLK_PWM23 327 -#define PCLK_SPI0 328 -#define PCLK_SPI1 329 -#define PCLK_SARADC 330 -#define PCLK_WDT 331 -#define PCLK_UART0 332 -#define PCLK_UART1 333 -#define PCLK_UART2 334 -#define PCLK_UART3 335 -#define PCLK_I2C0 336 -#define PCLK_I2C1 337 -#define PCLK_I2C2 338 -#define PCLK_I2C3 339 -#define PCLK_I2C4 340 -#define PCLK_GPIO0 341 -#define PCLK_GPIO1 342 -#define PCLK_GPIO2 343 -#define PCLK_GPIO3 344 -#define PCLK_GPIO4 345 -#define PCLK_GPIO6 346 -#define PCLK_EFUSE 347 -#define PCLK_TZPC 348 -#define PCLK_TSADC 349 -#define PCLK_CPU 350 -#define PCLK_PERI 351 -#define PCLK_DDRUPCTL 352 -#define PCLK_PUBL 353 - -/* hclk gates */ -#define HCLK_SDMMC 448 -#define HCLK_SDIO 449 -#define HCLK_EMMC 450 -#define HCLK_OTG0 451 -#define HCLK_EMAC 452 -#define HCLK_SPDIF 453 -#define HCLK_I2S0 454 -#define HCLK_I2S1 455 -#define HCLK_I2S2 456 -#define HCLK_OTG1 457 -#define HCLK_HSIC 458 -#define HCLK_HSADC 459 -#define HCLK_PIDF 460 -#define HCLK_LCDC0 461 -#define HCLK_LCDC1 462 -#define HCLK_ROM 463 -#define HCLK_CIF0 464 -#define HCLK_IPP 465 -#define HCLK_RGA 466 -#define HCLK_NANDC0 467 -#define HCLK_CPU 468 -#define HCLK_PERI 469 -#define HCLK_CIF1 470 -#define HCLK_VEPU 471 -#define HCLK_VDPU 472 -#define HCLK_HDMI 473 - -#define CLK_NR_CLKS (HCLK_HDMI + 1) - -/* soft-reset indices */ -#define SRST_MCORE 2 -#define SRST_CORE0 3 -#define SRST_CORE1 4 -#define SRST_MCORE_DBG 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE0_WDT 12 -#define SRST_CORE1_WDT 13 -#define SRST_STRC_SYS 14 -#define SRST_L2C 15 - -#define SRST_CPU_AHB 17 -#define SRST_AHB2APB 19 -#define SRST_DMA1 20 -#define SRST_INTMEM 21 -#define SRST_ROM 22 -#define SRST_SPDIF 26 -#define SRST_TIMER0 27 -#define SRST_TIMER1 28 -#define SRST_EFUSE 30 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 - -#define SRST_UART0 39 -#define SRST_UART1 40 -#define SRST_UART2 41 -#define SRST_UART3 42 -#define SRST_I2C0 43 -#define SRST_I2C1 44 -#define SRST_I2C2 45 -#define SRST_I2C3 46 -#define SRST_I2C4 47 - -#define SRST_PWM0 48 -#define SRST_PWM1 49 -#define SRST_DAP_PO 50 -#define SRST_DAP 51 -#define SRST_DAP_SYS 52 -#define SRST_TPIU_ATB 53 -#define SRST_PMU_APB 54 -#define SRST_GRF 55 -#define SRST_PMU 56 -#define SRST_PERI_AXI 57 -#define SRST_PERI_AHB 58 -#define SRST_PERI_APB 59 -#define SRST_PERI_NIU 60 -#define SRST_CPU_PERI 61 -#define SRST_EMEM_PERI 62 -#define SRST_USB_PERI 63 - -#define SRST_DMA2 64 -#define SRST_SMC 65 -#define SRST_MAC 66 -#define SRST_NANC0 68 -#define SRST_USBOTG0 69 -#define SRST_USBPHY0 70 -#define SRST_OTGC0 71 -#define SRST_USBOTG1 72 -#define SRST_USBPHY1 73 -#define SRST_OTGC1 74 -#define SRST_HSADC 76 -#define SRST_PIDFILTER 77 -#define SRST_DDR_MSCH 79 - -#define SRST_TZPC 80 -#define SRST_SDMMC 81 -#define SRST_SDIO 82 -#define SRST_EMMC 83 -#define SRST_SPI0 84 -#define SRST_SPI1 85 -#define SRST_WDT 86 -#define SRST_SARADC 87 -#define SRST_DDRPHY 88 -#define SRST_DDRPHY_APB 89 -#define SRST_DDRCTL 90 -#define SRST_DDRCTL_APB 91 -#define SRST_DDRPUB 93 - -#define SRST_VIO0_AXI 98 -#define SRST_VIO0_AHB 99 -#define SRST_LCDC0_AXI 100 -#define SRST_LCDC0_AHB 101 -#define SRST_LCDC0_DCLK 102 -#define SRST_LCDC1_AXI 103 -#define SRST_LCDC1_AHB 104 -#define SRST_LCDC1_DCLK 105 -#define SRST_IPP_AXI 106 -#define SRST_IPP_AHB 107 -#define SRST_RGA_AXI 108 -#define SRST_RGA_AHB 109 -#define SRST_CIF0 110 - -#define SRST_VCODEC_AXI 112 -#define SRST_VCODEC_AHB 113 -#define SRST_VIO1_AXI 114 -#define SRST_VCODEC_CPU 115 -#define SRST_VCODEC_NIU 116 -#define SRST_GPU 120 -#define SRST_GPU_NIU 122 -#define SRST_TFUN_ATB 125 -#define SRST_TFUN_APB 126 -#define SRST_CTI4_APB 127 - -#define SRST_TPIU_APB 128 -#define SRST_TRACE 129 -#define SRST_CORE_DBG 130 -#define SRST_DBG_APB 131 -#define SRST_CTI0 132 -#define SRST_CTI0_APB 133 -#define SRST_CTI1 134 -#define SRST_CTI1_APB 135 -#define SRST_PTM_CORE0 136 -#define SRST_PTM_CORE1 137 -#define SRST_PTM0 138 -#define SRST_PTM0_ATB 139 -#define SRST_PTM1 140 -#define SRST_PTM1_ATB 141 -#define SRST_CTM 142 -#define SRST_TS 143 - -#endif diff --git a/include/dt-bindings/clock/rk3188-cru.h b/include/dt-bindings/clock/rk3188-cru.h deleted file mode 100644 index 1da306e1788c..000000000000 --- a/include/dt-bindings/clock/rk3188-cru.h +++ /dev/null @@ -1,47 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3188_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3188_H - -#include <dt-bindings/clock/rk3188-cru-common.h> - -/* soft-reset indices */ -#define SRST_PTM_CORE2 0 -#define SRST_PTM_CORE3 1 -#define SRST_CORE2 5 -#define SRST_CORE3 6 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 - -#define SRST_TIMER2 16 -#define SRST_TIMER4 23 -#define SRST_I2S0 24 -#define SRST_TIMER5 25 -#define SRST_TIMER3 29 -#define SRST_TIMER6 31 - -#define SRST_PTM3 36 -#define SRST_PTM3_ATB 37 - -#define SRST_GPS 67 -#define SRST_HSICPHY 75 -#define SRST_TIMER 78 - -#define SRST_PTM2 92 -#define SRST_CORE2_WDT 94 -#define SRST_CORE3_WDT 95 - -#define SRST_PTM2_ATB 111 - -#define SRST_HSIC 117 -#define SRST_CTI2 118 -#define SRST_CTI2_APB 119 -#define SRST_GPU_BRIDGE 121 -#define SRST_CTI3 123 -#define SRST_CTI3_APB 124 - -#endif diff --git a/include/dt-bindings/clock/rk3228-cru.h b/include/dt-bindings/clock/rk3228-cru.h deleted file mode 100644 index de550ea56eeb..000000000000 --- a/include/dt-bindings/clock/rk3228-cru.h +++ /dev/null @@ -1,287 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2015 Rockchip Electronics Co. Ltd. - * Author: Jeffy Chen jeffy.chen@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3228_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define ARMCLK 5 - -/* sclk gates (special clocks) */ -#define SCLK_SPI0 65 -#define SCLK_NANDC 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO 69 -#define SCLK_EMMC 71 -#define SCLK_TSADC 72 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_I2S0 80 -#define SCLK_I2S1 81 -#define SCLK_I2S2 82 -#define SCLK_SPDIF 83 -#define SCLK_TIMER0 85 -#define SCLK_TIMER1 86 -#define SCLK_TIMER2 87 -#define SCLK_TIMER3 88 -#define SCLK_TIMER4 89 -#define SCLK_TIMER5 90 -#define SCLK_I2S_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO_DRV 115 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO_SAMPLE 119 -#define SCLK_SDIO_SRC 120 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_VOP 122 -#define SCLK_HDMI_HDCP 123 -#define SCLK_MAC_SRC 124 -#define SCLK_MAC_EXTCLK 125 -#define SCLK_MAC 126 -#define SCLK_MAC_REFOUT 127 -#define SCLK_MAC_REF 128 -#define SCLK_MAC_RX 129 -#define SCLK_MAC_TX 130 -#define SCLK_MAC_PHY 131 -#define SCLK_MAC_OUT 132 -#define SCLK_VDEC_CABAC 133 -#define SCLK_VDEC_CORE 134 -#define SCLK_RGA 135 -#define SCLK_HDCP 136 -#define SCLK_HDMI_CEC 137 -#define SCLK_CRYPTO 138 -#define SCLK_TSP 139 -#define SCLK_HSADC 140 -#define SCLK_WIFI 141 -#define SCLK_OTGPHY0 142 -#define SCLK_OTGPHY1 143 -#define SCLK_HDMI_PHY 144 - -/* dclk gates */ -#define DCLK_VOP 190 -#define DCLK_HDMI_PHY 191 - -/* aclk gates */ -#define ACLK_DMAC 194 -#define ACLK_CPU 195 -#define ACLK_VPU_PRE 196 -#define ACLK_RKVDEC_PRE 197 -#define ACLK_RGA_PRE 198 -#define ACLK_IEP_PRE 199 -#define ACLK_HDCP_PRE 200 -#define ACLK_VOP_PRE 201 -#define ACLK_VPU 202 -#define ACLK_RKVDEC 203 -#define ACLK_IEP 204 -#define ACLK_RGA 205 -#define ACLK_HDCP 206 -#define ACLK_PERI 210 -#define ACLK_VOP 211 -#define ACLK_GMAC 212 -#define ACLK_GPU 213 - -/* pclk gates */ -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GPIO3 323 -#define PCLK_VIO_H2P 324 -#define PCLK_HDCP 325 -#define PCLK_EFUSE_1024 326 -#define PCLK_EFUSE_256 327 -#define PCLK_GRF 329 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_I2C3 335 -#define PCLK_SPI0 338 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_TSADC 344 -#define PCLK_PWM 350 -#define PCLK_TIMER 353 -#define PCLK_CPU 354 -#define PCLK_PERI 363 -#define PCLK_HDMI_CTRL 364 -#define PCLK_HDMI_PHY 365 -#define PCLK_GMAC 367 - -/* hclk gates */ -#define HCLK_I2S0_8CH 442 -#define HCLK_I2S1_8CH 443 -#define HCLK_I2S2_2CH 444 -#define HCLK_SPDIF_8CH 445 -#define HCLK_VOP 452 -#define HCLK_NANDC 453 -#define HCLK_SDMMC 456 -#define HCLK_SDIO 457 -#define HCLK_EMMC 459 -#define HCLK_CPU 460 -#define HCLK_VPU_PRE 461 -#define HCLK_RKVDEC_PRE 462 -#define HCLK_VIO_PRE 463 -#define HCLK_VPU 464 -#define HCLK_RKVDEC 465 -#define HCLK_VIO 466 -#define HCLK_RGA 467 -#define HCLK_IEP 468 -#define HCLK_VIO_H2P 469 -#define HCLK_HDCP_MMU 470 -#define HCLK_HOST0 471 -#define HCLK_HOST1 472 -#define HCLK_HOST2 473 -#define HCLK_OTG 474 -#define HCLK_TSP 475 -#define HCLK_M_CRYPTO 476 -#define HCLK_S_CRYPTO 477 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_ACLK_CORE 13 -#define SRST_NOC 14 -#define SRST_L2C 15 - -#define SRST_CPUSYS_H 18 -#define SRST_BUSSYS_H 19 -#define SRST_SPDIF 20 -#define SRST_INTMEM 21 -#define SRST_ROM 22 -#define SRST_OTG_ADP 23 -#define SRST_I2S0 24 -#define SRST_I2S1 25 -#define SRST_I2S2 26 -#define SRST_ACODEC_P 27 -#define SRST_DFIMON 28 -#define SRST_MSCH 29 -#define SRST_EFUSE1024 30 -#define SRST_EFUSE256 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 -#define SRST_PERIPH_NOC_A 36 -#define SRST_PERIPH_NOC_BUS_H 37 -#define SRST_PERIPH_NOC_P 38 -#define SRST_UART0 39 -#define SRST_UART1 40 -#define SRST_UART2 41 -#define SRST_PHYNOC 42 -#define SRST_I2C0 43 -#define SRST_I2C1 44 -#define SRST_I2C2 45 -#define SRST_I2C3 46 - -#define SRST_PWM 48 -#define SRST_A53_GIC 49 -#define SRST_DAP 51 -#define SRST_DAP_NOC 52 -#define SRST_CRYPTO 53 -#define SRST_SGRF 54 -#define SRST_GRF 55 -#define SRST_GMAC 56 -#define SRST_PERIPH_NOC_H 58 -#define SRST_MACPHY 63 - -#define SRST_DMA 64 -#define SRST_NANDC 68 -#define SRST_USBOTG 69 -#define SRST_OTGC 70 -#define SRST_USBHOST0 71 -#define SRST_HOST_CTRL0 72 -#define SRST_USBHOST1 73 -#define SRST_HOST_CTRL1 74 -#define SRST_USBHOST2 75 -#define SRST_HOST_CTRL2 76 -#define SRST_USBPOR0 77 -#define SRST_USBPOR1 78 -#define SRST_DDRMSCH 79 - -#define SRST_SMART_CARD 80 -#define SRST_SDMMC 81 -#define SRST_SDIO 82 -#define SRST_EMMC 83 -#define SRST_SPI 84 -#define SRST_TSP_H 85 -#define SRST_TSP 86 -#define SRST_TSADC 87 -#define SRST_DDRPHY 88 -#define SRST_DDRPHY_P 89 -#define SRST_DDRCTRL 90 -#define SRST_DDRCTRL_P 91 -#define SRST_HOST0_ECHI 92 -#define SRST_HOST1_ECHI 93 -#define SRST_HOST2_ECHI 94 -#define SRST_VOP_NOC_A 95 - -#define SRST_HDMI_P 96 -#define SRST_VIO_ARBI_H 97 -#define SRST_IEP_NOC_A 98 -#define SRST_VIO_NOC_H 99 -#define SRST_VOP_A 100 -#define SRST_VOP_H 101 -#define SRST_VOP_D 102 -#define SRST_UTMI0 103 -#define SRST_UTMI1 104 -#define SRST_UTMI2 105 -#define SRST_UTMI3 106 -#define SRST_RGA 107 -#define SRST_RGA_NOC_A 108 -#define SRST_RGA_A 109 -#define SRST_RGA_H 110 -#define SRST_HDCP_A 111 - -#define SRST_VPU_A 112 -#define SRST_VPU_H 113 -#define SRST_VPU_NOC_A 116 -#define SRST_VPU_NOC_H 117 -#define SRST_RKVDEC_A 118 -#define SRST_RKVDEC_NOC_A 119 -#define SRST_RKVDEC_H 120 -#define SRST_RKVDEC_NOC_H 121 -#define SRST_RKVDEC_CORE 122 -#define SRST_RKVDEC_CABAC 123 -#define SRST_IEP_A 124 -#define SRST_IEP_H 125 -#define SRST_GPU_A 126 -#define SRST_GPU_NOC_A 127 - -#define SRST_CORE_DBG 128 -#define SRST_DBG_P 129 -#define SRST_TIMER0 130 -#define SRST_TIMER1 131 -#define SRST_TIMER2 132 -#define SRST_TIMER3 133 -#define SRST_TIMER4 134 -#define SRST_TIMER5 135 -#define SRST_VIO_H2P 136 -#define SRST_HDMIPHY 139 -#define SRST_VDAC 140 -#define SRST_TIMER_6CH_P 141 - -#endif diff --git a/include/dt-bindings/clock/rk3288-cru.h b/include/dt-bindings/clock/rk3288-cru.h deleted file mode 100644 index 453f66718c6b..000000000000 --- a/include/dt-bindings/clock/rk3288-cru.h +++ /dev/null @@ -1,381 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_NPLL 5 -#define ARMCLK 6 - -/* sclk gates (special clocks) */ -#define SCLK_GPU 64 -#define SCLK_SPI0 65 -#define SCLK_SPI1 66 -#define SCLK_SPI2 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO0 69 -#define SCLK_SDIO1 70 -#define SCLK_EMMC 71 -#define SCLK_TSADC 72 -#define SCLK_SARADC 73 -#define SCLK_PS2C 74 -#define SCLK_NANDC0 75 -#define SCLK_NANDC1 76 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_UART3 80 -#define SCLK_UART4 81 -#define SCLK_I2S0 82 -#define SCLK_SPDIF 83 -#define SCLK_SPDIF8CH 84 -#define SCLK_TIMER0 85 -#define SCLK_TIMER1 86 -#define SCLK_TIMER2 87 -#define SCLK_TIMER3 88 -#define SCLK_TIMER4 89 -#define SCLK_TIMER5 90 -#define SCLK_TIMER6 91 -#define SCLK_HSADC 92 -#define SCLK_OTGPHY0 93 -#define SCLK_OTGPHY1 94 -#define SCLK_OTGPHY2 95 -#define SCLK_OTG_ADP 96 -#define SCLK_HSICPHY480M 97 -#define SCLK_HSICPHY12M 98 -#define SCLK_MACREF 99 -#define SCLK_LCDC_PWM0 100 -#define SCLK_LCDC_PWM1 101 -#define SCLK_MAC_RX 102 -#define SCLK_MAC_TX 103 -#define SCLK_EDP_24M 104 -#define SCLK_EDP 105 -#define SCLK_RGA 106 -#define SCLK_ISP 107 -#define SCLK_ISP_JPE 108 -#define SCLK_HDMI_HDCP 109 -#define SCLK_HDMI_CEC 110 -#define SCLK_HEVC_CABAC 111 -#define SCLK_HEVC_CORE 112 -#define SCLK_I2S0_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO0_DRV 115 -#define SCLK_SDIO1_DRV 116 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO0_SAMPLE 119 -#define SCLK_SDIO1_SAMPLE 120 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_USBPHY480M_SRC 122 -#define SCLK_PVTM_CORE 123 -#define SCLK_PVTM_GPU 124 -#define SCLK_CRYPTO 125 -#define SCLK_MIPIDSI_24M 126 -#define SCLK_VIP_OUT 127 - -#define SCLK_MAC_PLL 150 -#define SCLK_MAC 151 -#define SCLK_MACREF_OUT 152 - -#define DCLK_VOP0 190 -#define DCLK_VOP1 191 - -/* aclk gates */ -#define ACLK_GPU 192 -#define ACLK_DMAC1 193 -#define ACLK_DMAC2 194 -#define ACLK_MMU 195 -#define ACLK_GMAC 196 -#define ACLK_VOP0 197 -#define ACLK_VOP1 198 -#define ACLK_CRYPTO 199 -#define ACLK_RGA 200 -#define ACLK_RGA_NIU 201 -#define ACLK_IEP 202 -#define ACLK_VIO0_NIU 203 -#define ACLK_VIP 204 -#define ACLK_ISP 205 -#define ACLK_VIO1_NIU 206 -#define ACLK_HEVC 207 -#define ACLK_VCODEC 208 -#define ACLK_CPU 209 -#define ACLK_PERI 210 - -/* pclk gates */ -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GPIO3 323 -#define PCLK_GPIO4 324 -#define PCLK_GPIO5 325 -#define PCLK_GPIO6 326 -#define PCLK_GPIO7 327 -#define PCLK_GPIO8 328 -#define PCLK_GRF 329 -#define PCLK_SGRF 330 -#define PCLK_PMU 331 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_I2C3 335 -#define PCLK_I2C4 336 -#define PCLK_I2C5 337 -#define PCLK_SPI0 338 -#define PCLK_SPI1 339 -#define PCLK_SPI2 340 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_UART3 344 -#define PCLK_UART4 345 -#define PCLK_TSADC 346 -#define PCLK_SARADC 347 -#define PCLK_SIM 348 -#define PCLK_GMAC 349 -#define PCLK_PWM 350 -#define PCLK_RKPWM 351 -#define PCLK_PS2C 352 -#define PCLK_TIMER 353 -#define PCLK_TZPC 354 -#define PCLK_EDP_CTRL 355 -#define PCLK_MIPI_DSI0 356 -#define PCLK_MIPI_DSI1 357 -#define PCLK_MIPI_CSI 358 -#define PCLK_LVDS_PHY 359 -#define PCLK_HDMI_CTRL 360 -#define PCLK_VIO2_H2P 361 -#define PCLK_CPU 362 -#define PCLK_PERI 363 -#define PCLK_DDRUPCTL0 364 -#define PCLK_PUBL0 365 -#define PCLK_DDRUPCTL1 366 -#define PCLK_PUBL1 367 -#define PCLK_WDT 368 -#define PCLK_EFUSE256 369 -#define PCLK_EFUSE1024 370 -#define PCLK_ISP_IN 371 - -/* hclk gates */ -#define HCLK_GPS 448 -#define HCLK_OTG0 449 -#define HCLK_USBHOST0 450 -#define HCLK_USBHOST1 451 -#define HCLK_HSIC 452 -#define HCLK_NANDC0 453 -#define HCLK_NANDC1 454 -#define HCLK_TSP 455 -#define HCLK_SDMMC 456 -#define HCLK_SDIO0 457 -#define HCLK_SDIO1 458 -#define HCLK_EMMC 459 -#define HCLK_HSADC 460 -#define HCLK_CRYPTO 461 -#define HCLK_I2S0 462 -#define HCLK_SPDIF 463 -#define HCLK_SPDIF8CH 464 -#define HCLK_VOP0 465 -#define HCLK_VOP1 466 -#define HCLK_ROM 467 -#define HCLK_IEP 468 -#define HCLK_ISP 469 -#define HCLK_RGA 470 -#define HCLK_VIO_AHB_ARBI 471 -#define HCLK_VIO_NIU 472 -#define HCLK_VIP 473 -#define HCLK_VIO2_H2P 474 -#define HCLK_HEVC 475 -#define HCLK_VCODEC 476 -#define HCLK_CPU 477 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE0 0 -#define SRST_CORE1 1 -#define SRST_CORE2 2 -#define SRST_CORE3 3 -#define SRST_CORE0_PO 4 -#define SRST_CORE1_PO 5 -#define SRST_CORE2_PO 6 -#define SRST_CORE3_PO 7 -#define SRST_PDCORE_STRSYS 8 -#define SRST_PDBUS_STRSYS 9 -#define SRST_L2C 10 -#define SRST_TOPDBG 11 -#define SRST_CORE0_DBG 12 -#define SRST_CORE1_DBG 13 -#define SRST_CORE2_DBG 14 -#define SRST_CORE3_DBG 15 - -#define SRST_PDBUG_AHB_ARBITOR 16 -#define SRST_EFUSE256 17 -#define SRST_DMAC1 18 -#define SRST_INTMEM 19 -#define SRST_ROM 20 -#define SRST_SPDIF8CH 21 -#define SRST_TIMER 22 -#define SRST_I2S0 23 -#define SRST_SPDIF 24 -#define SRST_TIMER0 25 -#define SRST_TIMER1 26 -#define SRST_TIMER2 27 -#define SRST_TIMER3 28 -#define SRST_TIMER4 29 -#define SRST_TIMER5 30 -#define SRST_EFUSE 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 -#define SRST_GPIO4 36 -#define SRST_GPIO5 37 -#define SRST_GPIO6 38 -#define SRST_GPIO7 39 -#define SRST_GPIO8 40 -#define SRST_I2C0 42 -#define SRST_I2C1 43 -#define SRST_I2C2 44 -#define SRST_I2C3 45 -#define SRST_I2C4 46 -#define SRST_I2C5 47 - -#define SRST_DWPWM 48 -#define SRST_MMC_PERI 49 -#define SRST_PERIPH_MMU 50 -#define SRST_DAP 51 -#define SRST_DAP_SYS 52 -#define SRST_TPIU 53 -#define SRST_PMU_APB 54 -#define SRST_GRF 55 -#define SRST_PMU 56 -#define SRST_PERIPH_AXI 57 -#define SRST_PERIPH_AHB 58 -#define SRST_PERIPH_APB 59 -#define SRST_PERIPH_NIU 60 -#define SRST_PDPERI_AHB_ARBI 61 -#define SRST_EMEM 62 -#define SRST_USB_PERI 63 - -#define SRST_DMAC2 64 -#define SRST_MAC 66 -#define SRST_GPS 67 -#define SRST_RKPWM 69 -#define SRST_CCP 71 -#define SRST_USBHOST0 72 -#define SRST_HSIC 73 -#define SRST_HSIC_AUX 74 -#define SRST_HSIC_PHY 75 -#define SRST_HSADC 76 -#define SRST_NANDC0 77 -#define SRST_NANDC1 78 - -#define SRST_TZPC 80 -#define SRST_SPI0 83 -#define SRST_SPI1 84 -#define SRST_SPI2 85 -#define SRST_SARADC 87 -#define SRST_PDALIVE_NIU 88 -#define SRST_PDPMU_INTMEM 89 -#define SRST_PDPMU_NIU 90 -#define SRST_SGRF 91 - -#define SRST_VIO_ARBI 96 -#define SRST_RGA_NIU 97 -#define SRST_VIO0_NIU_AXI 98 -#define SRST_VIO_NIU_AHB 99 -#define SRST_LCDC0_AXI 100 -#define SRST_LCDC0_AHB 101 -#define SRST_LCDC0_DCLK 102 -#define SRST_VIO1_NIU_AXI 103 -#define SRST_VIP 104 -#define SRST_RGA_CORE 105 -#define SRST_IEP_AXI 106 -#define SRST_IEP_AHB 107 -#define SRST_RGA_AXI 108 -#define SRST_RGA_AHB 109 -#define SRST_ISP 110 -#define SRST_EDP 111 - -#define SRST_VCODEC_AXI 112 -#define SRST_VCODEC_AHB 113 -#define SRST_VIO_H2P 114 -#define SRST_MIPIDSI0 115 -#define SRST_MIPIDSI1 116 -#define SRST_MIPICSI 117 -#define SRST_LVDS_PHY 118 -#define SRST_LVDS_CON 119 -#define SRST_GPU 120 -#define SRST_HDMI 121 -#define SRST_CORE_PVTM 124 -#define SRST_GPU_PVTM 125 - -#define SRST_MMC0 128 -#define SRST_SDIO0 129 -#define SRST_SDIO1 130 -#define SRST_EMMC 131 -#define SRST_USBOTG_AHB 132 -#define SRST_USBOTG_PHY 133 -#define SRST_USBOTG_CON 134 -#define SRST_USBHOST0_AHB 135 -#define SRST_USBHOST0_PHY 136 -#define SRST_USBHOST0_CON 137 -#define SRST_USBHOST1_AHB 138 -#define SRST_USBHOST1_PHY 139 -#define SRST_USBHOST1_CON 140 -#define SRST_USB_ADP 141 -#define SRST_ACC_EFUSE 142 - -#define SRST_CORESIGHT 144 -#define SRST_PD_CORE_AHB_NOC 145 -#define SRST_PD_CORE_APB_NOC 146 -#define SRST_PD_CORE_MP_AXI 147 -#define SRST_GIC 148 -#define SRST_LCDC_PWM0 149 -#define SRST_LCDC_PWM1 150 -#define SRST_VIO0_H2P_BRG 151 -#define SRST_VIO1_H2P_BRG 152 -#define SRST_RGA_H2P_BRG 153 -#define SRST_HEVC 154 -#define SRST_TSADC 159 - -#define SRST_DDRPHY0 160 -#define SRST_DDRPHY0_APB 161 -#define SRST_DDRCTRL0 162 -#define SRST_DDRCTRL0_APB 163 -#define SRST_DDRPHY0_CTRL 164 -#define SRST_DDRPHY1 165 -#define SRST_DDRPHY1_APB 166 -#define SRST_DDRCTRL1 167 -#define SRST_DDRCTRL1_APB 168 -#define SRST_DDRPHY1_CTRL 169 -#define SRST_DDRMSCH0 170 -#define SRST_DDRMSCH1 171 -#define SRST_CRYPTO 174 -#define SRST_C2C_HOST 175 - -#define SRST_LCDC1_AXI 176 -#define SRST_LCDC1_AHB 177 -#define SRST_LCDC1_DCLK 178 -#define SRST_UART0 179 -#define SRST_UART1 180 -#define SRST_UART2 181 -#define SRST_UART3 182 -#define SRST_UART4 183 -#define SRST_SIMC 186 -#define SRST_PS2C 187 -#define SRST_TSP 188 -#define SRST_TSP_CLKIN0 189 -#define SRST_TSP_CLKIN1 190 -#define SRST_TSP_27M 191 - -#endif diff --git a/include/dt-bindings/clock/rk3308-cru.h b/include/dt-bindings/clock/rk3308-cru.h deleted file mode 100644 index d97840f9ee2e..000000000000 --- a/include/dt-bindings/clock/rk3308-cru.h +++ /dev/null @@ -1,387 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019 Rockchip Electronics Co. Ltd. - * Author: Finley Xiao finley.xiao@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3308_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3308_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_VPLL0 3 -#define PLL_VPLL1 4 -#define ARMCLK 5 - -/* sclk (special clocks) */ -#define USB480M 14 -#define SCLK_RTC32K 15 -#define SCLK_PVTM_CORE 16 -#define SCLK_UART0 17 -#define SCLK_UART1 18 -#define SCLK_UART2 19 -#define SCLK_UART3 20 -#define SCLK_UART4 21 -#define SCLK_I2C0 22 -#define SCLK_I2C1 23 -#define SCLK_I2C2 24 -#define SCLK_I2C3 25 -#define SCLK_PWM0 26 -#define SCLK_SPI0 27 -#define SCLK_SPI1 28 -#define SCLK_SPI2 29 -#define SCLK_TIMER0 30 -#define SCLK_TIMER1 31 -#define SCLK_TIMER2 32 -#define SCLK_TIMER3 33 -#define SCLK_TIMER4 34 -#define SCLK_TIMER5 35 -#define SCLK_TSADC 36 -#define SCLK_SARADC 37 -#define SCLK_OTP 38 -#define SCLK_OTP_USR 39 -#define SCLK_CPU_BOOST 40 -#define SCLK_CRYPTO 41 -#define SCLK_CRYPTO_APK 42 -#define SCLK_NANDC_DIV 43 -#define SCLK_NANDC_DIV50 44 -#define SCLK_NANDC 45 -#define SCLK_SDMMC_DIV 46 -#define SCLK_SDMMC_DIV50 47 -#define SCLK_SDMMC 48 -#define SCLK_SDMMC_DRV 49 -#define SCLK_SDMMC_SAMPLE 50 -#define SCLK_SDIO_DIV 51 -#define SCLK_SDIO_DIV50 52 -#define SCLK_SDIO 53 -#define SCLK_SDIO_DRV 54 -#define SCLK_SDIO_SAMPLE 55 -#define SCLK_EMMC_DIV 56 -#define SCLK_EMMC_DIV50 57 -#define SCLK_EMMC 58 -#define SCLK_EMMC_DRV 59 -#define SCLK_EMMC_SAMPLE 60 -#define SCLK_SFC 61 -#define SCLK_OTG_ADP 62 -#define SCLK_MAC_SRC 63 -#define SCLK_MAC 64 -#define SCLK_MAC_REF 65 -#define SCLK_MAC_RX_TX 66 -#define SCLK_MAC_RMII 67 -#define SCLK_DDR_MON_TIMER 68 -#define SCLK_DDR_MON 69 -#define SCLK_DDRCLK 70 -#define SCLK_PMU 71 -#define SCLK_USBPHY_REF 72 -#define SCLK_WIFI 73 -#define SCLK_PVTM_PMU 74 -#define SCLK_PDM 75 -#define SCLK_I2S0_8CH_TX 76 -#define SCLK_I2S0_8CH_TX_OUT 77 -#define SCLK_I2S0_8CH_RX 78 -#define SCLK_I2S0_8CH_RX_OUT 79 -#define SCLK_I2S1_8CH_TX 80 -#define SCLK_I2S1_8CH_TX_OUT 81 -#define SCLK_I2S1_8CH_RX 82 -#define SCLK_I2S1_8CH_RX_OUT 83 -#define SCLK_I2S2_8CH_TX 84 -#define SCLK_I2S2_8CH_TX_OUT 85 -#define SCLK_I2S2_8CH_RX 86 -#define SCLK_I2S2_8CH_RX_OUT 87 -#define SCLK_I2S3_8CH_TX 88 -#define SCLK_I2S3_8CH_TX_OUT 89 -#define SCLK_I2S3_8CH_RX 90 -#define SCLK_I2S3_8CH_RX_OUT 91 -#define SCLK_I2S0_2CH 92 -#define SCLK_I2S0_2CH_OUT 93 -#define SCLK_I2S1_2CH 94 -#define SCLK_I2S1_2CH_OUT 95 -#define SCLK_SPDIF_TX_DIV 96 -#define SCLK_SPDIF_TX_DIV50 97 -#define SCLK_SPDIF_TX 98 -#define SCLK_SPDIF_RX_DIV 99 -#define SCLK_SPDIF_RX_DIV50 100 -#define SCLK_SPDIF_RX 101 -#define SCLK_I2S0_8CH_TX_MUX 102 -#define SCLK_I2S0_8CH_RX_MUX 103 -#define SCLK_I2S1_8CH_TX_MUX 104 -#define SCLK_I2S1_8CH_RX_MUX 105 -#define SCLK_I2S2_8CH_TX_MUX 106 -#define SCLK_I2S2_8CH_RX_MUX 107 -#define SCLK_I2S3_8CH_TX_MUX 108 -#define SCLK_I2S3_8CH_RX_MUX 109 -#define SCLK_I2S0_8CH_TX_SRC 110 -#define SCLK_I2S0_8CH_RX_SRC 111 -#define SCLK_I2S1_8CH_TX_SRC 112 -#define SCLK_I2S1_8CH_RX_SRC 113 -#define SCLK_I2S2_8CH_TX_SRC 114 -#define SCLK_I2S2_8CH_RX_SRC 115 -#define SCLK_I2S3_8CH_TX_SRC 116 -#define SCLK_I2S3_8CH_RX_SRC 117 -#define SCLK_I2S0_2CH_SRC 118 -#define SCLK_I2S1_2CH_SRC 119 -#define SCLK_PWM1 120 -#define SCLK_PWM2 121 -#define SCLK_OWIRE 122 - -/* dclk */ -#define DCLK_VOP 125 - -/* aclk */ -#define ACLK_BUS_SRC 130 -#define ACLK_BUS 131 -#define ACLK_PERI_SRC 132 -#define ACLK_PERI 133 -#define ACLK_MAC 134 -#define ACLK_CRYPTO 135 -#define ACLK_VOP 136 -#define ACLK_GIC 137 -#define ACLK_DMAC0 138 -#define ACLK_DMAC1 139 - -/* hclk */ -#define HCLK_BUS 150 -#define HCLK_PERI 151 -#define HCLK_AUDIO 152 -#define HCLK_NANDC 153 -#define HCLK_SDMMC 154 -#define HCLK_SDIO 155 -#define HCLK_EMMC 156 -#define HCLK_SFC 157 -#define HCLK_OTG 158 -#define HCLK_HOST 159 -#define HCLK_HOST_ARB 160 -#define HCLK_PDM 161 -#define HCLK_SPDIFTX 162 -#define HCLK_SPDIFRX 163 -#define HCLK_I2S0_8CH 164 -#define HCLK_I2S1_8CH 165 -#define HCLK_I2S2_8CH 166 -#define HCLK_I2S3_8CH 167 -#define HCLK_I2S0_2CH 168 -#define HCLK_I2S1_2CH 169 -#define HCLK_VAD 170 -#define HCLK_CRYPTO 171 -#define HCLK_VOP 172 - -/* pclk */ -#define PCLK_BUS 190 -#define PCLK_DDR 191 -#define PCLK_PERI 192 -#define PCLK_PMU 193 -#define PCLK_AUDIO 194 -#define PCLK_MAC 195 -#define PCLK_ACODEC 196 -#define PCLK_UART0 197 -#define PCLK_UART1 198 -#define PCLK_UART2 199 -#define PCLK_UART3 200 -#define PCLK_UART4 201 -#define PCLK_I2C0 202 -#define PCLK_I2C1 203 -#define PCLK_I2C2 204 -#define PCLK_I2C3 205 -#define PCLK_PWM0 206 -#define PCLK_SPI0 207 -#define PCLK_SPI1 208 -#define PCLK_SPI2 209 -#define PCLK_SARADC 210 -#define PCLK_TSADC 211 -#define PCLK_TIMER 212 -#define PCLK_OTP_NS 213 -#define PCLK_WDT 214 -#define PCLK_GPIO0 215 -#define PCLK_GPIO1 216 -#define PCLK_GPIO2 217 -#define PCLK_GPIO3 218 -#define PCLK_GPIO4 219 -#define PCLK_SGRF 220 -#define PCLK_GRF 221 -#define PCLK_USBSD_DET 222 -#define PCLK_DDR_UPCTL 223 -#define PCLK_DDR_MON 224 -#define PCLK_DDRPHY 225 -#define PCLK_DDR_STDBY 226 -#define PCLK_USB_GRF 227 -#define PCLK_CRU 228 -#define PCLK_OTP_PHY 229 -#define PCLK_CPU_BOOST 230 -#define PCLK_PWM1 231 -#define PCLK_PWM2 232 -#define PCLK_CAN 233 -#define PCLK_OWIRE 234 - -#define CLK_NR_CLKS (PCLK_OWIRE + 1) - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NOC 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15 - -/* cru_softrst_con1 */ -#define SRST_DAP 16 -#define SRST_CORE_PVTM 17 -#define SRST_CORE_PRF 18 -#define SRST_CORE_GRF 19 -#define SRST_DDRUPCTL 20 -#define SRST_DDRUPCTL_P 22 -#define SRST_MSCH 23 -#define SRST_DDRMON_P 25 -#define SRST_DDRSTDBY_P 26 -#define SRST_DDRSTDBY 27 -#define SRST_DDRPHY 28 -#define SRST_DDRPHY_DIV 29 -#define SRST_DDRPHY_P 30 - -/* cru_softrst_con2 */ -#define SRST_BUS_NIU_H 32 -#define SRST_USB_NIU_P 33 -#define SRST_CRYPTO_A 34 -#define SRST_CRYPTO_H 35 -#define SRST_CRYPTO 36 -#define SRST_CRYPTO_APK 37 -#define SRST_VOP_A 38 -#define SRST_VOP_H 39 -#define SRST_VOP_D 40 -#define SRST_INTMEM_A 41 -#define SRST_ROM_H 42 -#define SRST_GIC_A 43 -#define SRST_UART0_P 44 -#define SRST_UART0 45 -#define SRST_UART1_P 46 -#define SRST_UART1 47 - -/* cru_softrst_con3 */ -#define SRST_UART2_P 48 -#define SRST_UART2 49 -#define SRST_UART3_P 50 -#define SRST_UART3 51 -#define SRST_UART4_P 52 -#define SRST_UART4 53 -#define SRST_I2C0_P 54 -#define SRST_I2C0 55 -#define SRST_I2C1_P 56 -#define SRST_I2C1 57 -#define SRST_I2C2_P 58 -#define SRST_I2C2 59 -#define SRST_I2C3_P 60 -#define SRST_I2C3 61 -#define SRST_PWM0_P 62 -#define SRST_PWM0 63 - -/* cru_softrst_con4 */ -#define SRST_SPI0_P 64 -#define SRST_SPI0 65 -#define SRST_SPI1_P 66 -#define SRST_SPI1 67 -#define SRST_SPI2_P 68 -#define SRST_SPI2 69 -#define SRST_SARADC_P 70 -#define SRST_TSADC_P 71 -#define SRST_TSADC 72 -#define SRST_TIMER0_P 73 -#define SRST_TIMER0 74 -#define SRST_TIMER1 75 -#define SRST_TIMER2 76 -#define SRST_TIMER3 77 -#define SRST_TIMER4 78 -#define SRST_TIMER5 79 - -/* cru_softrst_con5 */ -#define SRST_OTP_NS_P 80 -#define SRST_OTP_NS_SBPI 81 -#define SRST_OTP_NS_USR 82 -#define SRST_OTP_PHY_P 83 -#define SRST_OTP_PHY 84 -#define SRST_GPIO0_P 86 -#define SRST_GPIO1_P 87 -#define SRST_GPIO2_P 88 -#define SRST_GPIO3_P 89 -#define SRST_GPIO4_P 90 -#define SRST_GRF_P 91 -#define SRST_USBSD_DET_P 92 -#define SRST_PMU 93 -#define SRST_PMU_PVTM 94 -#define SRST_USB_GRF_P 95 - -/* cru_softrst_con6 */ -#define SRST_CPU_BOOST 96 -#define SRST_CPU_BOOST_P 97 -#define SRST_PWM1_P 98 -#define SRST_PWM1 99 -#define SRST_PWM2_P 100 -#define SRST_PWM2 101 -#define SRST_PERI_NIU_A 104 -#define SRST_PERI_NIU_H 105 -#define SRST_PERI_NIU_p 106 -#define SRST_USB2OTG_H 107 -#define SRST_USB2OTG 108 -#define SRST_USB2OTG_ADP 109 -#define SRST_USB2HOST_H 110 -#define SRST_USB2HOST_ARB_H 111 - -/* cru_softrst_con7 */ -#define SRST_USB2HOST_AUX_H 112 -#define SRST_USB2HOST_EHCI 113 -#define SRST_USB2HOST 114 -#define SRST_USBPHYPOR 115 -#define SRST_UTMI0 116 -#define SRST_UTMI1 117 -#define SRST_SDIO_H 118 -#define SRST_EMMC_H 119 -#define SRST_SFC_H 120 -#define SRST_SFC 121 -#define SRST_SD_H 122 -#define SRST_NANDC_H 123 -#define SRST_NANDC_N 124 -#define SRST_MAC_A 125 -#define SRST_CAN_P 126 -#define SRST_OWIRE_P 127 - -/* cru_softrst_con8 */ -#define SRST_AUDIO_NIU_H 128 -#define SRST_AUDIO_NIU_P 129 -#define SRST_PDM_H 130 -#define SRST_PDM_M 131 -#define SRST_SPDIFTX_H 132 -#define SRST_SPDIFTX_M 133 -#define SRST_SPDIFRX_H 134 -#define SRST_SPDIFRX_M 135 -#define SRST_I2S0_8CH_H 136 -#define SRST_I2S0_8CH_TX_M 137 -#define SRST_I2S0_8CH_RX_M 138 -#define SRST_I2S1_8CH_H 139 -#define SRST_I2S1_8CH_TX_M 140 -#define SRST_I2S1_8CH_RX_M 141 -#define SRST_I2S2_8CH_H 142 -#define SRST_I2S2_8CH_TX_M 143 - -/* cru_softrst_con9 */ -#define SRST_I2S2_8CH_RX_M 144 -#define SRST_I2S3_8CH_H 145 -#define SRST_I2S3_8CH_TX_M 146 -#define SRST_I2S3_8CH_RX_M 147 -#define SRST_I2S0_2CH_H 148 -#define SRST_I2S0_2CH_M 149 -#define SRST_I2S1_2CH_H 150 -#define SRST_I2S1_2CH_M 151 -#define SRST_VAD_H 152 -#define SRST_ACODEC_P 153 - -#endif diff --git a/include/dt-bindings/clock/rk3328-cru.h b/include/dt-bindings/clock/rk3328-cru.h deleted file mode 100644 index 555b4ff660ae..000000000000 --- a/include/dt-bindings/clock/rk3328-cru.h +++ /dev/null @@ -1,393 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2016 Rockchip Electronics Co. Ltd. - * Author: Elaine zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_NPLL 5 -#define ARMCLK 6 - -/* sclk gates (special clocks) */ -#define SCLK_RTC32K 30 -#define SCLK_SDMMC_EXT 31 -#define SCLK_SPI 32 -#define SCLK_SDMMC 33 -#define SCLK_SDIO 34 -#define SCLK_EMMC 35 -#define SCLK_TSADC 36 -#define SCLK_SARADC 37 -#define SCLK_UART0 38 -#define SCLK_UART1 39 -#define SCLK_UART2 40 -#define SCLK_I2S0 41 -#define SCLK_I2S1 42 -#define SCLK_I2S2 43 -#define SCLK_I2S1_OUT 44 -#define SCLK_I2S2_OUT 45 -#define SCLK_SPDIF 46 -#define SCLK_TIMER0 47 -#define SCLK_TIMER1 48 -#define SCLK_TIMER2 49 -#define SCLK_TIMER3 50 -#define SCLK_TIMER4 51 -#define SCLK_TIMER5 52 -#define SCLK_WIFI 53 -#define SCLK_CIF_OUT 54 -#define SCLK_I2C0 55 -#define SCLK_I2C1 56 -#define SCLK_I2C2 57 -#define SCLK_I2C3 58 -#define SCLK_CRYPTO 59 -#define SCLK_PWM 60 -#define SCLK_PDM 61 -#define SCLK_EFUSE 62 -#define SCLK_OTP 63 -#define SCLK_DDRCLK 64 -#define SCLK_VDEC_CABAC 65 -#define SCLK_VDEC_CORE 66 -#define SCLK_VENC_DSP 67 -#define SCLK_VENC_CORE 68 -#define SCLK_RGA 69 -#define SCLK_HDMI_SFC 70 -#define SCLK_HDMI_CEC 71 -#define SCLK_USB3_REF 72 -#define SCLK_USB3_SUSPEND 73 -#define SCLK_SDMMC_DRV 74 -#define SCLK_SDIO_DRV 75 -#define SCLK_EMMC_DRV 76 -#define SCLK_SDMMC_EXT_DRV 77 -#define SCLK_SDMMC_SAMPLE 78 -#define SCLK_SDIO_SAMPLE 79 -#define SCLK_EMMC_SAMPLE 80 -#define SCLK_SDMMC_EXT_SAMPLE 81 -#define SCLK_VOP 82 -#define SCLK_MAC2PHY_RXTX 83 -#define SCLK_MAC2PHY_SRC 84 -#define SCLK_MAC2PHY_REF 85 -#define SCLK_MAC2PHY_OUT 86 -#define SCLK_MAC2IO_RX 87 -#define SCLK_MAC2IO_TX 88 -#define SCLK_MAC2IO_REFOUT 89 -#define SCLK_MAC2IO_REF 90 -#define SCLK_MAC2IO_OUT 91 -#define SCLK_TSP 92 -#define SCLK_HSADC_TSP 93 -#define SCLK_USB3PHY_REF 94 -#define SCLK_REF_USB3OTG 95 -#define SCLK_USB3OTG_REF 96 -#define SCLK_USB3OTG_SUSPEND 97 -#define SCLK_REF_USB3OTG_SRC 98 -#define SCLK_MAC2IO_SRC 99 -#define SCLK_MAC2IO 100 -#define SCLK_MAC2PHY 101 -#define SCLK_MAC2IO_EXT 102 - -/* dclk gates */ -#define DCLK_LCDC 120 -#define DCLK_HDMIPHY 121 -#define HDMIPHY 122 -#define USB480M 123 -#define DCLK_LCDC_SRC 124 - -/* aclk gates */ -#define ACLK_AXISRAM 130 -#define ACLK_VOP_PRE 131 -#define ACLK_USB3OTG 132 -#define ACLK_RGA_PRE 133 -#define ACLK_DMAC 134 -#define ACLK_GPU 135 -#define ACLK_BUS_PRE 136 -#define ACLK_PERI_PRE 137 -#define ACLK_RKVDEC_PRE 138 -#define ACLK_RKVDEC 139 -#define ACLK_RKVENC 140 -#define ACLK_VPU_PRE 141 -#define ACLK_VIO_PRE 142 -#define ACLK_VPU 143 -#define ACLK_VIO 144 -#define ACLK_VOP 145 -#define ACLK_GMAC 146 -#define ACLK_H265 147 -#define ACLK_H264 148 -#define ACLK_MAC2PHY 149 -#define ACLK_MAC2IO 150 -#define ACLK_DCF 151 -#define ACLK_TSP 152 -#define ACLK_PERI 153 -#define ACLK_RGA 154 -#define ACLK_IEP 155 -#define ACLK_CIF 156 -#define ACLK_HDCP 157 - -/* pclk gates */ -#define PCLK_GPIO0 200 -#define PCLK_GPIO1 201 -#define PCLK_GPIO2 202 -#define PCLK_GPIO3 203 -#define PCLK_GRF 204 -#define PCLK_I2C0 205 -#define PCLK_I2C1 206 -#define PCLK_I2C2 207 -#define PCLK_I2C3 208 -#define PCLK_SPI 209 -#define PCLK_UART0 210 -#define PCLK_UART1 211 -#define PCLK_UART2 212 -#define PCLK_TSADC 213 -#define PCLK_PWM 214 -#define PCLK_TIMER 215 -#define PCLK_BUS_PRE 216 -#define PCLK_PERI_PRE 217 -#define PCLK_HDMI_CTRL 218 -#define PCLK_HDMI_PHY 219 -#define PCLK_GMAC 220 -#define PCLK_H265 221 -#define PCLK_MAC2PHY 222 -#define PCLK_MAC2IO 223 -#define PCLK_USB3PHY_OTG 224 -#define PCLK_USB3PHY_PIPE 225 -#define PCLK_USB3_GRF 226 -#define PCLK_USB2_GRF 227 -#define PCLK_HDMIPHY 228 -#define PCLK_DDR 229 -#define PCLK_PERI 230 -#define PCLK_HDMI 231 -#define PCLK_HDCP 232 -#define PCLK_DCF 233 -#define PCLK_SARADC 234 -#define PCLK_ACODECPHY 235 -#define PCLK_WDT 236 - -/* hclk gates */ -#define HCLK_PERI 308 -#define HCLK_TSP 309 -#define HCLK_GMAC 310 -#define HCLK_I2S0_8CH 311 -#define HCLK_I2S1_8CH 312 -#define HCLK_I2S2_2CH 313 -#define HCLK_SPDIF_8CH 314 -#define HCLK_VOP 315 -#define HCLK_NANDC 316 -#define HCLK_SDMMC 317 -#define HCLK_SDIO 318 -#define HCLK_EMMC 319 -#define HCLK_SDMMC_EXT 320 -#define HCLK_RKVDEC_PRE 321 -#define HCLK_RKVDEC 322 -#define HCLK_RKVENC 323 -#define HCLK_VPU_PRE 324 -#define HCLK_VIO_PRE 325 -#define HCLK_VPU 326 -#define HCLK_BUS_PRE 328 -#define HCLK_PERI_PRE 329 -#define HCLK_H264 330 -#define HCLK_CIF 331 -#define HCLK_OTG_PMU 332 -#define HCLK_OTG 333 -#define HCLK_HOST0 334 -#define HCLK_HOST0_ARB 335 -#define HCLK_CRYPTO_MST 336 -#define HCLK_CRYPTO_SLV 337 -#define HCLK_PDM 338 -#define HCLK_IEP 339 -#define HCLK_RGA 340 -#define HCLK_HDCP 341 - -#define CLK_NR_CLKS (HCLK_HDCP + 1) - -/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NIU 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15 - -#define SRST_A53_GIC 18 -#define SRST_DAP 19 -#define SRST_PMU_P 21 -#define SRST_EFUSE 22 -#define SRST_BUSSYS_H 23 -#define SRST_BUSSYS_P 24 -#define SRST_SPDIF 25 -#define SRST_INTMEM 26 -#define SRST_ROM 27 -#define SRST_GPIO0 28 -#define SRST_GPIO1 29 -#define SRST_GPIO2 30 -#define SRST_GPIO3 31 - -#define SRST_I2S0 32 -#define SRST_I2S1 33 -#define SRST_I2S2 34 -#define SRST_I2S0_H 35 -#define SRST_I2S1_H 36 -#define SRST_I2S2_H 37 -#define SRST_UART0 38 -#define SRST_UART1 39 -#define SRST_UART2 40 -#define SRST_UART0_P 41 -#define SRST_UART1_P 42 -#define SRST_UART2_P 43 -#define SRST_I2C0 44 -#define SRST_I2C1 45 -#define SRST_I2C2 46 -#define SRST_I2C3 47 - -#define SRST_I2C0_P 48 -#define SRST_I2C1_P 49 -#define SRST_I2C2_P 50 -#define SRST_I2C3_P 51 -#define SRST_EFUSE_SE_P 52 -#define SRST_EFUSE_NS_P 53 -#define SRST_PWM0 54 -#define SRST_PWM0_P 55 -#define SRST_DMA 56 -#define SRST_TSP_A 57 -#define SRST_TSP_H 58 -#define SRST_TSP 59 -#define SRST_TSP_HSADC 60 -#define SRST_DCF_A 61 -#define SRST_DCF_P 62 - -#define SRST_SCR 64 -#define SRST_SPI 65 -#define SRST_TSADC 66 -#define SRST_TSADC_P 67 -#define SRST_CRYPTO 68 -#define SRST_SGRF 69 -#define SRST_GRF 70 -#define SRST_USB_GRF 71 -#define SRST_TIMER_6CH_P 72 -#define SRST_TIMER0 73 -#define SRST_TIMER1 74 -#define SRST_TIMER2 75 -#define SRST_TIMER3 76 -#define SRST_TIMER4 77 -#define SRST_TIMER5 78 -#define SRST_USB3GRF 79 - -#define SRST_PHYNIU 80 -#define SRST_HDMIPHY 81 -#define SRST_VDAC 82 -#define SRST_ACODEC_p 83 -#define SRST_SARADC 85 -#define SRST_SARADC_P 86 -#define SRST_GRF_DDR 87 -#define SRST_DFIMON 88 -#define SRST_MSCH 89 -#define SRST_DDRMSCH 91 -#define SRST_DDRCTRL 92 -#define SRST_DDRCTRL_P 93 -#define SRST_DDRPHY 94 -#define SRST_DDRPHY_P 95 - -#define SRST_GMAC_NIU_A 96 -#define SRST_GMAC_NIU_P 97 -#define SRST_GMAC2PHY_A 98 -#define SRST_GMAC2IO_A 99 -#define SRST_MACPHY 100 -#define SRST_OTP_PHY 101 -#define SRST_GPU_A 102 -#define SRST_GPU_NIU_A 103 -#define SRST_SDMMCEXT 104 -#define SRST_PERIPH_NIU_A 105 -#define SRST_PERIHP_NIU_H 106 -#define SRST_PERIHP_P 107 -#define SRST_PERIPHSYS_H 108 -#define SRST_MMC0 109 -#define SRST_SDIO 110 -#define SRST_EMMC 111 - -#define SRST_USB2OTG_H 112 -#define SRST_USB2OTG 113 -#define SRST_USB2OTG_ADP 114 -#define SRST_USB2HOST_H 115 -#define SRST_USB2HOST_ARB 116 -#define SRST_USB2HOST_AUX 117 -#define SRST_USB2HOST_EHCIPHY 118 -#define SRST_USB2HOST_UTMI 119 -#define SRST_USB3OTG 120 -#define SRST_USBPOR 121 -#define SRST_USB2OTG_UTMI 122 -#define SRST_USB2HOST_PHY_UTMI 123 -#define SRST_USB3OTG_UTMI 124 -#define SRST_USB3PHY_U2 125 -#define SRST_USB3PHY_U3 126 -#define SRST_USB3PHY_PIPE 127 - -#define SRST_VIO_A 128 -#define SRST_VIO_BUS_H 129 -#define SRST_VIO_H2P_H 130 -#define SRST_VIO_ARBI_H 131 -#define SRST_VOP_NIU_A 132 -#define SRST_VOP_A 133 -#define SRST_VOP_H 134 -#define SRST_VOP_D 135 -#define SRST_RGA 136 -#define SRST_RGA_NIU_A 137 -#define SRST_RGA_A 138 -#define SRST_RGA_H 139 -#define SRST_IEP_A 140 -#define SRST_IEP_H 141 -#define SRST_HDMI 142 -#define SRST_HDMI_P 143 - -#define SRST_HDCP_A 144 -#define SRST_HDCP 145 -#define SRST_HDCP_H 146 -#define SRST_CIF_A 147 -#define SRST_CIF_H 148 -#define SRST_CIF_P 149 -#define SRST_OTP_P 150 -#define SRST_OTP_SBPI 151 -#define SRST_OTP_USER 152 -#define SRST_DDRCTRL_A 153 -#define SRST_DDRSTDY_P 154 -#define SRST_DDRSTDY 155 -#define SRST_PDM_H 156 -#define SRST_PDM 157 -#define SRST_USB3PHY_OTG_P 158 -#define SRST_USB3PHY_PIPE_P 159 - -#define SRST_VCODEC_A 160 -#define SRST_VCODEC_NIU_A 161 -#define SRST_VCODEC_H 162 -#define SRST_VCODEC_NIU_H 163 -#define SRST_VDEC_A 164 -#define SRST_VDEC_NIU_A 165 -#define SRST_VDEC_H 166 -#define SRST_VDEC_NIU_H 167 -#define SRST_VDEC_CORE 168 -#define SRST_VDEC_CABAC 169 -#define SRST_DDRPHYDIV 175 - -#define SRST_RKVENC_NIU_A 176 -#define SRST_RKVENC_NIU_H 177 -#define SRST_RKVENC_H265_A 178 -#define SRST_RKVENC_H265_P 179 -#define SRST_RKVENC_H265_CORE 180 -#define SRST_RKVENC_H265_DSP 181 -#define SRST_RKVENC_H264_A 182 -#define SRST_RKVENC_H264_H 183 -#define SRST_RKVENC_INTMEM 184 - -#endif diff --git a/include/dt-bindings/clock/rk3368-cru.h b/include/dt-bindings/clock/rk3368-cru.h deleted file mode 100644 index 0a06c5f514d7..000000000000 --- a/include/dt-bindings/clock/rk3368-cru.h +++ /dev/null @@ -1,381 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2015 Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3368_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3368_H - -/* core clocks */ -#define PLL_APLLB 1 -#define PLL_APLLL 2 -#define PLL_DPLL 3 -#define PLL_CPLL 4 -#define PLL_GPLL 5 -#define PLL_NPLL 6 -#define ARMCLKB 7 -#define ARMCLKL 8 - -/* sclk gates (special clocks) */ -#define SCLK_GPU_CORE 64 -#define SCLK_SPI0 65 -#define SCLK_SPI1 66 -#define SCLK_SPI2 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO0 69 -#define SCLK_EMMC 71 -#define SCLK_TSADC 72 -#define SCLK_SARADC 73 -#define SCLK_NANDC0 75 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_UART3 80 -#define SCLK_UART4 81 -#define SCLK_I2S_8CH 82 -#define SCLK_SPDIF_8CH 83 -#define SCLK_I2S_2CH 84 -#define SCLK_TIMER00 85 -#define SCLK_TIMER01 86 -#define SCLK_TIMER02 87 -#define SCLK_TIMER03 88 -#define SCLK_TIMER04 89 -#define SCLK_TIMER05 90 -#define SCLK_OTGPHY0 93 -#define SCLK_OTG_ADP 96 -#define SCLK_HSICPHY480M 97 -#define SCLK_HSICPHY12M 98 -#define SCLK_MACREF 99 -#define SCLK_VOP0_PWM 100 -#define SCLK_MAC_RX 102 -#define SCLK_MAC_TX 103 -#define SCLK_EDP_24M 104 -#define SCLK_EDP 105 -#define SCLK_RGA 106 -#define SCLK_ISP 107 -#define SCLK_HDCP 108 -#define SCLK_HDMI_HDCP 109 -#define SCLK_HDMI_CEC 110 -#define SCLK_HEVC_CABAC 111 -#define SCLK_HEVC_CORE 112 -#define SCLK_I2S_8CH_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO0_DRV 115 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO0_SAMPLE 119 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_USBPHY480M 122 -#define SCLK_PVTM_CORE 123 -#define SCLK_PVTM_GPU 124 -#define SCLK_PVTM_PMU 125 -#define SCLK_SFC 126 -#define SCLK_MAC 127 -#define SCLK_MACREF_OUT 128 -#define SCLK_TIMER10 133 -#define SCLK_TIMER11 134 -#define SCLK_TIMER12 135 -#define SCLK_TIMER13 136 -#define SCLK_TIMER14 137 -#define SCLK_TIMER15 138 - -#define DCLK_VOP 190 -#define MCLK_CRYPTO 191 - -/* aclk gates */ -#define ACLK_GPU_MEM 192 -#define ACLK_GPU_CFG 193 -#define ACLK_DMAC_BUS 194 -#define ACLK_DMAC_PERI 195 -#define ACLK_PERI_MMU 196 -#define ACLK_GMAC 197 -#define ACLK_VOP 198 -#define ACLK_VOP_IEP 199 -#define ACLK_RGA 200 -#define ACLK_HDCP 201 -#define ACLK_IEP 202 -#define ACLK_VIO0_NOC 203 -#define ACLK_VIP 204 -#define ACLK_ISP 205 -#define ACLK_VIO1_NOC 206 -#define ACLK_VIDEO 208 -#define ACLK_BUS 209 -#define ACLK_PERI 210 - -/* pclk gates */ -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GPIO3 323 -#define PCLK_PMUGRF 324 -#define PCLK_MAILBOX 325 -#define PCLK_GRF 329 -#define PCLK_SGRF 330 -#define PCLK_PMU 331 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_I2C3 335 -#define PCLK_I2C4 336 -#define PCLK_I2C5 337 -#define PCLK_SPI0 338 -#define PCLK_SPI1 339 -#define PCLK_SPI2 340 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_UART3 344 -#define PCLK_UART4 345 -#define PCLK_TSADC 346 -#define PCLK_SARADC 347 -#define PCLK_SIM 348 -#define PCLK_GMAC 349 -#define PCLK_PWM0 350 -#define PCLK_PWM1 351 -#define PCLK_TIMER0 353 -#define PCLK_TIMER1 354 -#define PCLK_EDP_CTRL 355 -#define PCLK_MIPI_DSI0 356 -#define PCLK_MIPI_CSI 358 -#define PCLK_HDCP 359 -#define PCLK_HDMI_CTRL 360 -#define PCLK_VIO_H2P 361 -#define PCLK_BUS 362 -#define PCLK_PERI 363 -#define PCLK_DDRUPCTL 364 -#define PCLK_DDRPHY 365 -#define PCLK_ISP 366 -#define PCLK_VIP 367 -#define PCLK_WDT 368 -#define PCLK_EFUSE256 369 - -/* hclk gates */ -#define HCLK_SFC 448 -#define HCLK_OTG0 449 -#define HCLK_HOST0 450 -#define HCLK_HOST1 451 -#define HCLK_HSIC 452 -#define HCLK_NANDC0 453 -#define HCLK_TSP 455 -#define HCLK_SDMMC 456 -#define HCLK_SDIO0 457 -#define HCLK_EMMC 459 -#define HCLK_HSADC 460 -#define HCLK_CRYPTO 461 -#define HCLK_I2S_2CH 462 -#define HCLK_I2S_8CH 463 -#define HCLK_SPDIF 464 -#define HCLK_VOP 465 -#define HCLK_ROM 467 -#define HCLK_IEP 468 -#define HCLK_ISP 469 -#define HCLK_RGA 470 -#define HCLK_VIO_AHB_ARBI 471 -#define HCLK_VIO_NOC 472 -#define HCLK_VIP 473 -#define HCLK_VIO_H2P 474 -#define HCLK_VIO_HDCPMMU 475 -#define HCLK_VIDEO 476 -#define HCLK_BUS 477 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE_B0 0 -#define SRST_CORE_B1 1 -#define SRST_CORE_B2 2 -#define SRST_CORE_B3 3 -#define SRST_CORE_B0_PO 4 -#define SRST_CORE_B1_PO 5 -#define SRST_CORE_B2_PO 6 -#define SRST_CORE_B3_PO 7 -#define SRST_L2_B 8 -#define SRST_ADB_B 9 -#define SRST_PD_CORE_B_NIU 10 -#define SRST_PDBUS_STRSYS 11 -#define SRST_SOCDBG_B 14 -#define SRST_CORE_B_DBG 15 - -#define SRST_DMAC1 18 -#define SRST_INTMEM 19 -#define SRST_ROM 20 -#define SRST_SPDIF8CH 21 -#define SRST_I2S8CH 23 -#define SRST_MAILBOX 24 -#define SRST_I2S2CH 25 -#define SRST_EFUSE_256 26 -#define SRST_MCU_SYS 28 -#define SRST_MCU_PO 29 -#define SRST_MCU_NOC 30 -#define SRST_EFUSE 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 -#define SRST_GPIO4 36 -#define SRST_PMUGRF 41 -#define SRST_I2C0 42 -#define SRST_I2C1 43 -#define SRST_I2C2 44 -#define SRST_I2C3 45 -#define SRST_I2C4 46 -#define SRST_I2C5 47 - -#define SRST_DWPWM 48 -#define SRST_MMC_PERI 49 -#define SRST_PERIPH_MMU 50 -#define SRST_GRF 55 -#define SRST_PMU 56 -#define SRST_PERIPH_AXI 57 -#define SRST_PERIPH_AHB 58 -#define SRST_PERIPH_APB 59 -#define SRST_PERIPH_NIU 60 -#define SRST_PDPERI_AHB_ARBI 61 -#define SRST_EMEM 62 -#define SRST_USB_PERI 63 - -#define SRST_DMAC2 64 -#define SRST_MAC 66 -#define SRST_GPS 67 -#define SRST_RKPWM 69 -#define SRST_USBHOST0 72 -#define SRST_HSIC 73 -#define SRST_HSIC_AUX 74 -#define SRST_HSIC_PHY 75 -#define SRST_HSADC 76 -#define SRST_NANDC0 77 -#define SRST_SFC 79 - -#define SRST_SPI0 83 -#define SRST_SPI1 84 -#define SRST_SPI2 85 -#define SRST_SARADC 87 -#define SRST_PDALIVE_NIU 88 -#define SRST_PDPMU_INTMEM 89 -#define SRST_PDPMU_NIU 90 -#define SRST_SGRF 91 - -#define SRST_VIO_ARBI 96 -#define SRST_RGA_NIU 97 -#define SRST_VIO0_NIU_AXI 98 -#define SRST_VIO_NIU_AHB 99 -#define SRST_LCDC0_AXI 100 -#define SRST_LCDC0_AHB 101 -#define SRST_LCDC0_DCLK 102 -#define SRST_VIP 104 -#define SRST_RGA_CORE 105 -#define SRST_IEP_AXI 106 -#define SRST_IEP_AHB 107 -#define SRST_RGA_AXI 108 -#define SRST_RGA_AHB 109 -#define SRST_ISP 110 -#define SRST_EDP_24M 111 - -#define SRST_VIDEO_AXI 112 -#define SRST_VIDEO_AHB 113 -#define SRST_MIPIDPHYTX 114 -#define SRST_MIPIDSI0 115 -#define SRST_MIPIDPHYRX 116 -#define SRST_MIPICSI 117 -#define SRST_GPU 120 -#define SRST_HDMI 121 -#define SRST_EDP 122 -#define SRST_PMU_PVTM 123 -#define SRST_CORE_PVTM 124 -#define SRST_GPU_PVTM 125 -#define SRST_GPU_SYS 126 -#define SRST_GPU_MEM_NIU 127 - -#define SRST_MMC0 128 -#define SRST_SDIO0 129 -#define SRST_EMMC 131 -#define SRST_USBOTG_AHB 132 -#define SRST_USBOTG_PHY 133 -#define SRST_USBOTG_CON 134 -#define SRST_USBHOST0_AHB 135 -#define SRST_USBHOST0_PHY 136 -#define SRST_USBHOST0_CON 137 -#define SRST_USBOTG_UTMI 138 -#define SRST_USBHOST1_UTMI 139 -#define SRST_USB_ADP 141 - -#define SRST_CORESIGHT 144 -#define SRST_PD_CORE_AHB_NOC 145 -#define SRST_PD_CORE_APB_NOC 146 -#define SRST_GIC 148 -#define SRST_LCDC_PWM0 149 -#define SRST_RGA_H2P_BRG 153 -#define SRST_VIDEO 154 -#define SRST_GPU_CFG_NIU 157 -#define SRST_TSADC 159 - -#define SRST_DDRPHY0 160 -#define SRST_DDRPHY0_APB 161 -#define SRST_DDRCTRL0 162 -#define SRST_DDRCTRL0_APB 163 -#define SRST_VIDEO_NIU 165 -#define SRST_VIDEO_NIU_AHB 167 -#define SRST_DDRMSCH0 170 -#define SRST_PDBUS_AHB 173 -#define SRST_CRYPTO 174 - -#define SRST_UART0 179 -#define SRST_UART1 180 -#define SRST_UART2 181 -#define SRST_UART3 182 -#define SRST_UART4 183 -#define SRST_SIMC 186 -#define SRST_TSP 188 -#define SRST_TSP_CLKIN0 189 - -#define SRST_CORE_L0 192 -#define SRST_CORE_L1 193 -#define SRST_CORE_L2 194 -#define SRST_CORE_L3 195 -#define SRST_CORE_L0_PO 195 -#define SRST_CORE_L1_PO 197 -#define SRST_CORE_L2_PO 198 -#define SRST_CORE_L3_PO 199 -#define SRST_L2_L 200 -#define SRST_ADB_L 201 -#define SRST_PD_CORE_L_NIU 202 -#define SRST_CCI_SYS 203 -#define SRST_CCI_DDR 204 -#define SRST_CCI 205 -#define SRST_SOCDBG_L 206 -#define SRST_CORE_L_DBG 207 - -#define SRST_CORE_B0_NC 208 -#define SRST_CORE_B0_PO_NC 209 -#define SRST_L2_B_NC 210 -#define SRST_ADB_B_NC 211 -#define SRST_PD_CORE_B_NIU_NC 212 -#define SRST_PDBUS_STRSYS_NC 213 -#define SRST_CORE_L0_NC 214 -#define SRST_CORE_L0_PO_NC 215 -#define SRST_L2_L_NC 216 -#define SRST_ADB_L_NC 217 -#define SRST_PD_CORE_L_NIU_NC 218 -#define SRST_CCI_SYS_NC 219 -#define SRST_CCI_DDR_NC 220 -#define SRST_CCI_NC 221 -#define SRST_TRACE_NC 222 - -#define SRST_TIMER00 224 -#define SRST_TIMER01 225 -#define SRST_TIMER02 226 -#define SRST_TIMER03 227 -#define SRST_TIMER04 228 -#define SRST_TIMER05 229 -#define SRST_TIMER10 230 -#define SRST_TIMER11 231 -#define SRST_TIMER12 232 -#define SRST_TIMER13 233 -#define SRST_TIMER14 234 -#define SRST_TIMER15 235 -#define SRST_TIMER0_APB 236 -#define SRST_TIMER1_APB 237 - -#endif diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h deleted file mode 100644 index 211faf8fa891..000000000000 --- a/include/dt-bindings/clock/rk3399-cru.h +++ /dev/null @@ -1,749 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2016 Rockchip Electronics Co. Ltd. - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H - -/* core clocks */ -#define PLL_APLLL 1 -#define PLL_APLLB 2 -#define PLL_DPLL 3 -#define PLL_CPLL 4 -#define PLL_GPLL 5 -#define PLL_NPLL 6 -#define PLL_VPLL 7 -#define ARMCLKL 8 -#define ARMCLKB 9 - -/* sclk gates (special clocks) */ -#define SCLK_I2C1 65 -#define SCLK_I2C2 66 -#define SCLK_I2C3 67 -#define SCLK_I2C5 68 -#define SCLK_I2C6 69 -#define SCLK_I2C7 70 -#define SCLK_SPI0 71 -#define SCLK_SPI1 72 -#define SCLK_SPI2 73 -#define SCLK_SPI4 74 -#define SCLK_SPI5 75 -#define SCLK_SDMMC 76 -#define SCLK_SDIO 77 -#define SCLK_EMMC 78 -#define SCLK_TSADC 79 -#define SCLK_SARADC 80 -#define SCLK_UART0 81 -#define SCLK_UART1 82 -#define SCLK_UART2 83 -#define SCLK_UART3 84 -#define SCLK_SPDIF_8CH 85 -#define SCLK_I2S0_8CH 86 -#define SCLK_I2S1_8CH 87 -#define SCLK_I2S2_8CH 88 -#define SCLK_I2S_8CH_OUT 89 -#define SCLK_TIMER00 90 -#define SCLK_TIMER01 91 -#define SCLK_TIMER02 92 -#define SCLK_TIMER03 93 -#define SCLK_TIMER04 94 -#define SCLK_TIMER05 95 -#define SCLK_TIMER06 96 -#define SCLK_TIMER07 97 -#define SCLK_TIMER08 98 -#define SCLK_TIMER09 99 -#define SCLK_TIMER10 100 -#define SCLK_TIMER11 101 -#define SCLK_MACREF 102 -#define SCLK_MAC_RX 103 -#define SCLK_MAC_TX 104 -#define SCLK_MAC 105 -#define SCLK_MACREF_OUT 106 -#define SCLK_VOP0_PWM 107 -#define SCLK_VOP1_PWM 108 -#define SCLK_RGA_CORE 109 -#define SCLK_ISP0 110 -#define SCLK_ISP1 111 -#define SCLK_HDMI_CEC 112 -#define SCLK_HDMI_SFR 113 -#define SCLK_DP_CORE 114 -#define SCLK_PVTM_CORE_L 115 -#define SCLK_PVTM_CORE_B 116 -#define SCLK_PVTM_GPU 117 -#define SCLK_PVTM_DDR 118 -#define SCLK_MIPIDPHY_REF 119 -#define SCLK_MIPIDPHY_CFG 120 -#define SCLK_HSICPHY 121 -#define SCLK_USBPHY480M 122 -#define SCLK_USB2PHY0_REF 123 -#define SCLK_USB2PHY1_REF 124 -#define SCLK_UPHY0_TCPDPHY_REF 125 -#define SCLK_UPHY0_TCPDCORE 126 -#define SCLK_UPHY1_TCPDPHY_REF 127 -#define SCLK_UPHY1_TCPDCORE 128 -#define SCLK_USB3OTG0_REF 129 -#define SCLK_USB3OTG1_REF 130 -#define SCLK_USB3OTG0_SUSPEND 131 -#define SCLK_USB3OTG1_SUSPEND 132 -#define SCLK_CRYPTO0 133 -#define SCLK_CRYPTO1 134 -#define SCLK_CCI_TRACE 135 -#define SCLK_CS 136 -#define SCLK_CIF_OUT 137 -#define SCLK_PCIEPHY_REF 138 -#define SCLK_PCIE_CORE 139 -#define SCLK_M0_PERILP 140 -#define SCLK_M0_PERILP_DEC 141 -#define SCLK_CM0S 142 -#define SCLK_DBG_NOC 143 -#define SCLK_DBG_PD_CORE_B 144 -#define SCLK_DBG_PD_CORE_L 145 -#define SCLK_DFIMON0_TIMER 146 -#define SCLK_DFIMON1_TIMER 147 -#define SCLK_INTMEM0 148 -#define SCLK_INTMEM1 149 -#define SCLK_INTMEM2 150 -#define SCLK_INTMEM3 151 -#define SCLK_INTMEM4 152 -#define SCLK_INTMEM5 153 -#define SCLK_SDMMC_DRV 154 -#define SCLK_SDMMC_SAMPLE 155 -#define SCLK_SDIO_DRV 156 -#define SCLK_SDIO_SAMPLE 157 -#define SCLK_VDU_CORE 158 -#define SCLK_VDU_CA 159 -#define SCLK_PCIE_PM 160 -#define SCLK_SPDIF_REC_DPTX 161 -#define SCLK_DPHY_PLL 162 -#define SCLK_DPHY_TX0_CFG 163 -#define SCLK_DPHY_TX1RX1_CFG 164 -#define SCLK_DPHY_RX0_CFG 165 -#define SCLK_RMII_SRC 166 -#define SCLK_PCIEPHY_REF100M 167 -#define SCLK_USBPHY0_480M_SRC 168 -#define SCLK_USBPHY1_480M_SRC 169 -#define SCLK_DDRCLK 170 -#define SCLK_TESTOUT2 171 - -#define DCLK_VOP0 180 -#define DCLK_VOP1 181 -#define DCLK_VOP0_DIV 182 -#define DCLK_VOP1_DIV 183 -#define DCLK_M0_PERILP 184 - -#define FCLK_CM0S 190 - -/* aclk gates */ -#define ACLK_PERIHP 192 -#define ACLK_PERIHP_NOC 193 -#define ACLK_PERILP0 194 -#define ACLK_PERILP0_NOC 195 -#define ACLK_PERF_PCIE 196 -#define ACLK_PCIE 197 -#define ACLK_INTMEM 198 -#define ACLK_TZMA 199 -#define ACLK_DCF 200 -#define ACLK_CCI 201 -#define ACLK_CCI_NOC0 202 -#define ACLK_CCI_NOC1 203 -#define ACLK_CCI_GRF 204 -#define ACLK_CENTER 205 -#define ACLK_CENTER_MAIN_NOC 206 -#define ACLK_CENTER_PERI_NOC 207 -#define ACLK_GPU 208 -#define ACLK_PERF_GPU 209 -#define ACLK_GPU_GRF 210 -#define ACLK_DMAC0_PERILP 211 -#define ACLK_DMAC1_PERILP 212 -#define ACLK_GMAC 213 -#define ACLK_GMAC_NOC 214 -#define ACLK_PERF_GMAC 215 -#define ACLK_VOP0_NOC 216 -#define ACLK_VOP0 217 -#define ACLK_VOP1_NOC 218 -#define ACLK_VOP1 219 -#define ACLK_RGA 220 -#define ACLK_RGA_NOC 221 -#define ACLK_HDCP 222 -#define ACLK_HDCP_NOC 223 -#define ACLK_HDCP22 224 -#define ACLK_IEP 225 -#define ACLK_IEP_NOC 226 -#define ACLK_VIO 227 -#define ACLK_VIO_NOC 228 -#define ACLK_ISP0 229 -#define ACLK_ISP1 230 -#define ACLK_ISP0_NOC 231 -#define ACLK_ISP1_NOC 232 -#define ACLK_ISP0_WRAPPER 233 -#define ACLK_ISP1_WRAPPER 234 -#define ACLK_VCODEC 235 -#define ACLK_VCODEC_NOC 236 -#define ACLK_VDU 237 -#define ACLK_VDU_NOC 238 -#define ACLK_PERI 239 -#define ACLK_EMMC 240 -#define ACLK_EMMC_CORE 241 -#define ACLK_EMMC_NOC 242 -#define ACLK_EMMC_GRF 243 -#define ACLK_USB3 244 -#define ACLK_USB3_NOC 245 -#define ACLK_USB3OTG0 246 -#define ACLK_USB3OTG1 247 -#define ACLK_USB3_RKSOC_AXI_PERF 248 -#define ACLK_USB3_GRF 249 -#define ACLK_GIC 250 -#define ACLK_GIC_NOC 251 -#define ACLK_GIC_ADB400_CORE_L_2_GIC 252 -#define ACLK_GIC_ADB400_CORE_B_2_GIC 253 -#define ACLK_GIC_ADB400_GIC_2_CORE_L 254 -#define ACLK_GIC_ADB400_GIC_2_CORE_B 255 -#define ACLK_CORE_ADB400_CORE_L_2_CCI500 256 -#define ACLK_CORE_ADB400_CORE_B_2_CCI500 257 -#define ACLK_ADB400M_PD_CORE_L 258 -#define ACLK_ADB400M_PD_CORE_B 259 -#define ACLK_PERF_CORE_L 260 -#define ACLK_PERF_CORE_B 261 -#define ACLK_GIC_PRE 262 -#define ACLK_VOP0_PRE 263 -#define ACLK_VOP1_PRE 264 - -/* pclk gates */ -#define PCLK_PERIHP 320 -#define PCLK_PERIHP_NOC 321 -#define PCLK_PERILP0 322 -#define PCLK_PERILP1 323 -#define PCLK_PERILP1_NOC 324 -#define PCLK_PERILP_SGRF 325 -#define PCLK_PERIHP_GRF 326 -#define PCLK_PCIE 327 -#define PCLK_SGRF 328 -#define PCLK_INTR_ARB 329 -#define PCLK_CENTER_MAIN_NOC 330 -#define PCLK_CIC 331 -#define PCLK_COREDBG_B 332 -#define PCLK_COREDBG_L 333 -#define PCLK_DBG_CXCS_PD_CORE_B 334 -#define PCLK_DCF 335 -#define PCLK_GPIO2 336 -#define PCLK_GPIO3 337 -#define PCLK_GPIO4 338 -#define PCLK_GRF 339 -#define PCLK_HSICPHY 340 -#define PCLK_I2C1 341 -#define PCLK_I2C2 342 -#define PCLK_I2C3 343 -#define PCLK_I2C5 344 -#define PCLK_I2C6 345 -#define PCLK_I2C7 346 -#define PCLK_SPI0 347 -#define PCLK_SPI1 348 -#define PCLK_SPI2 349 -#define PCLK_SPI4 350 -#define PCLK_SPI5 351 -#define PCLK_UART0 352 -#define PCLK_UART1 353 -#define PCLK_UART2 354 -#define PCLK_UART3 355 -#define PCLK_TSADC 356 -#define PCLK_SARADC 357 -#define PCLK_GMAC 358 -#define PCLK_GMAC_NOC 359 -#define PCLK_TIMER0 360 -#define PCLK_TIMER1 361 -#define PCLK_EDP 362 -#define PCLK_EDP_NOC 363 -#define PCLK_EDP_CTRL 364 -#define PCLK_VIO 365 -#define PCLK_VIO_NOC 366 -#define PCLK_VIO_GRF 367 -#define PCLK_MIPI_DSI0 368 -#define PCLK_MIPI_DSI1 369 -#define PCLK_HDCP 370 -#define PCLK_HDCP_NOC 371 -#define PCLK_HDMI_CTRL 372 -#define PCLK_DP_CTRL 373 -#define PCLK_HDCP22 374 -#define PCLK_GASKET 375 -#define PCLK_DDR 376 -#define PCLK_DDR_MON 377 -#define PCLK_DDR_SGRF 378 -#define PCLK_ISP1_WRAPPER 379 -#define PCLK_WDT 380 -#define PCLK_EFUSE1024NS 381 -#define PCLK_EFUSE1024S 382 -#define PCLK_PMU_INTR_ARB 383 -#define PCLK_MAILBOX0 384 -#define PCLK_USBPHY_MUX_G 385 -#define PCLK_UPHY0_TCPHY_G 386 -#define PCLK_UPHY0_TCPD_G 387 -#define PCLK_UPHY1_TCPHY_G 388 -#define PCLK_UPHY1_TCPD_G 389 -#define PCLK_ALIVE 390 - -/* hclk gates */ -#define HCLK_PERIHP 448 -#define HCLK_PERILP0 449 -#define HCLK_PERILP1 450 -#define HCLK_PERILP0_NOC 451 -#define HCLK_PERILP1_NOC 452 -#define HCLK_M0_PERILP 453 -#define HCLK_M0_PERILP_NOC 454 -#define HCLK_AHB1TOM 455 -#define HCLK_HOST0 456 -#define HCLK_HOST0_ARB 457 -#define HCLK_HOST1 458 -#define HCLK_HOST1_ARB 459 -#define HCLK_HSIC 460 -#define HCLK_SD 461 -#define HCLK_SDMMC 462 -#define HCLK_SDMMC_NOC 463 -#define HCLK_M_CRYPTO0 464 -#define HCLK_M_CRYPTO1 465 -#define HCLK_S_CRYPTO0 466 -#define HCLK_S_CRYPTO1 467 -#define HCLK_I2S0_8CH 468 -#define HCLK_I2S1_8CH 469 -#define HCLK_I2S2_8CH 470 -#define HCLK_SPDIF 471 -#define HCLK_VOP0_NOC 472 -#define HCLK_VOP0 473 -#define HCLK_VOP1_NOC 474 -#define HCLK_VOP1 475 -#define HCLK_ROM 476 -#define HCLK_IEP 477 -#define HCLK_IEP_NOC 478 -#define HCLK_ISP0 479 -#define HCLK_ISP1 480 -#define HCLK_ISP0_NOC 481 -#define HCLK_ISP1_NOC 482 -#define HCLK_ISP0_WRAPPER 483 -#define HCLK_ISP1_WRAPPER 484 -#define HCLK_RGA 485 -#define HCLK_RGA_NOC 486 -#define HCLK_HDCP 487 -#define HCLK_HDCP_NOC 488 -#define HCLK_HDCP22 489 -#define HCLK_VCODEC 490 -#define HCLK_VCODEC_NOC 491 -#define HCLK_VDU 492 -#define HCLK_VDU_NOC 493 -#define HCLK_SDIO 494 -#define HCLK_SDIO_NOC 495 -#define HCLK_SDIOAUDIO_NOC 496 - -#define CLK_NR_CLKS (HCLK_SDIOAUDIO_NOC + 1) - -/* pmu-clocks indices */ - -#define PLL_PPLL 1 - -#define SCLK_32K_SUSPEND_PMU 2 -#define SCLK_SPI3_PMU 3 -#define SCLK_TIMER12_PMU 4 -#define SCLK_TIMER13_PMU 5 -#define SCLK_UART4_PMU 6 -#define SCLK_PVTM_PMU 7 -#define SCLK_WIFI_PMU 8 -#define SCLK_I2C0_PMU 9 -#define SCLK_I2C4_PMU 10 -#define SCLK_I2C8_PMU 11 - -#define PCLK_SRC_PMU 19 -#define PCLK_PMU 20 -#define PCLK_PMUGRF_PMU 21 -#define PCLK_INTMEM1_PMU 22 -#define PCLK_GPIO0_PMU 23 -#define PCLK_GPIO1_PMU 24 -#define PCLK_SGRF_PMU 25 -#define PCLK_NOC_PMU 26 -#define PCLK_I2C0_PMU 27 -#define PCLK_I2C4_PMU 28 -#define PCLK_I2C8_PMU 29 -#define PCLK_RKPWM_PMU 30 -#define PCLK_SPI3_PMU 31 -#define PCLK_TIMER_PMU 32 -#define PCLK_MAILBOX_PMU 33 -#define PCLK_UART4_PMU 34 -#define PCLK_WDT_M0_PMU 35 - -#define FCLK_CM0S_SRC_PMU 44 -#define FCLK_CM0S_PMU 45 -#define SCLK_CM0S_PMU 46 -#define HCLK_CM0S_PMU 47 -#define DCLK_CM0S_PMU 48 -#define PCLK_INTR_ARB_PMU 49 -#define HCLK_NOC_PMU 50 - -#define CLKPMU_NR_CLKS (HCLK_NOC_PMU + 1) - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE_L0 0 -#define SRST_CORE_B0 1 -#define SRST_CORE_PO_L0 2 -#define SRST_CORE_PO_B0 3 -#define SRST_L2_L 4 -#define SRST_L2_B 5 -#define SRST_ADB_L 6 -#define SRST_ADB_B 7 -#define SRST_A_CCI 8 -#define SRST_A_CCIM0_NOC 9 -#define SRST_A_CCIM1_NOC 10 -#define SRST_DBG_NOC 11 - -/* cru_softrst_con1 */ -#define SRST_CORE_L0_T 16 -#define SRST_CORE_L1 17 -#define SRST_CORE_L2 18 -#define SRST_CORE_L3 19 -#define SRST_CORE_PO_L0_T 20 -#define SRST_CORE_PO_L1 21 -#define SRST_CORE_PO_L2 22 -#define SRST_CORE_PO_L3 23 -#define SRST_A_ADB400_GIC2COREL 24 -#define SRST_A_ADB400_COREL2GIC 25 -#define SRST_P_DBG_L 26 -#define SRST_L2_L_T 28 -#define SRST_ADB_L_T 29 -#define SRST_A_RKPERF_L 30 -#define SRST_PVTM_CORE_L 31 - -/* cru_softrst_con2 */ -#define SRST_CORE_B0_T 32 -#define SRST_CORE_B1 33 -#define SRST_CORE_PO_B0_T 36 -#define SRST_CORE_PO_B1 37 -#define SRST_A_ADB400_GIC2COREB 40 -#define SRST_A_ADB400_COREB2GIC 41 -#define SRST_P_DBG_B 42 -#define SRST_L2_B_T 43 -#define SRST_ADB_B_T 45 -#define SRST_A_RKPERF_B 46 -#define SRST_PVTM_CORE_B 47 - -/* cru_softrst_con3 */ -#define SRST_A_CCI_T 50 -#define SRST_A_CCIM0_NOC_T 51 -#define SRST_A_CCIM1_NOC_T 52 -#define SRST_A_ADB400M_PD_CORE_B_T 53 -#define SRST_A_ADB400M_PD_CORE_L_T 54 -#define SRST_DBG_NOC_T 55 -#define SRST_DBG_CXCS 56 -#define SRST_CCI_TRACE 57 -#define SRST_P_CCI_GRF 58 - -/* cru_softrst_con4 */ -#define SRST_A_CENTER_MAIN_NOC 64 -#define SRST_A_CENTER_PERI_NOC 65 -#define SRST_P_CENTER_MAIN 66 -#define SRST_P_DDRMON 67 -#define SRST_P_CIC 68 -#define SRST_P_CENTER_SGRF 69 -#define SRST_DDR0_MSCH 70 -#define SRST_DDRCFG0_MSCH 71 -#define SRST_DDR0 72 -#define SRST_DDRPHY0 73 -#define SRST_DDR1_MSCH 74 -#define SRST_DDRCFG1_MSCH 75 -#define SRST_DDR1 76 -#define SRST_DDRPHY1 77 -#define SRST_DDR_CIC 78 -#define SRST_PVTM_DDR 79 - -/* cru_softrst_con5 */ -#define SRST_A_VCODEC_NOC 80 -#define SRST_A_VCODEC 81 -#define SRST_H_VCODEC_NOC 82 -#define SRST_H_VCODEC 83 -#define SRST_A_VDU_NOC 88 -#define SRST_A_VDU 89 -#define SRST_H_VDU_NOC 90 -#define SRST_H_VDU 91 -#define SRST_VDU_CORE 92 -#define SRST_VDU_CA 93 - -/* cru_softrst_con6 */ -#define SRST_A_IEP_NOC 96 -#define SRST_A_VOP_IEP 97 -#define SRST_A_IEP 98 -#define SRST_H_IEP_NOC 99 -#define SRST_H_IEP 100 -#define SRST_A_RGA_NOC 102 -#define SRST_A_RGA 103 -#define SRST_H_RGA_NOC 104 -#define SRST_H_RGA 105 -#define SRST_RGA_CORE 106 -#define SRST_EMMC_NOC 108 -#define SRST_EMMC 109 -#define SRST_EMMC_GRF 110 - -/* cru_softrst_con7 */ -#define SRST_A_PERIHP_NOC 112 -#define SRST_P_PERIHP_GRF 113 -#define SRST_H_PERIHP_NOC 114 -#define SRST_USBHOST0 115 -#define SRST_HOSTC0_AUX 116 -#define SRST_HOST0_ARB 117 -#define SRST_USBHOST1 118 -#define SRST_HOSTC1_AUX 119 -#define SRST_HOST1_ARB 120 -#define SRST_SDIO0 121 -#define SRST_SDMMC 122 -#define SRST_HSIC 123 -#define SRST_HSIC_AUX 124 -#define SRST_AHB1TOM 125 -#define SRST_P_PERIHP_NOC 126 -#define SRST_HSICPHY 127 - -/* cru_softrst_con8 */ -#define SRST_A_PCIE 128 -#define SRST_P_PCIE 129 -#define SRST_PCIE_CORE 130 -#define SRST_PCIE_MGMT 131 -#define SRST_PCIE_MGMT_STICKY 132 -#define SRST_PCIE_PIPE 133 -#define SRST_PCIE_PM 134 -#define SRST_PCIEPHY 135 -#define SRST_A_GMAC_NOC 136 -#define SRST_A_GMAC 137 -#define SRST_P_GMAC_NOC 138 -#define SRST_P_GMAC_GRF 140 -#define SRST_HSICPHY_POR 142 -#define SRST_HSICPHY_UTMI 143 - -/* cru_softrst_con9 */ -#define SRST_USB2PHY0_POR 144 -#define SRST_USB2PHY0_UTMI_PORT0 145 -#define SRST_USB2PHY0_UTMI_PORT1 146 -#define SRST_USB2PHY0_EHCIPHY 147 -#define SRST_UPHY0_PIPE_L00 148 -#define SRST_UPHY0 149 -#define SRST_UPHY0_TCPDPWRUP 150 -#define SRST_USB2PHY1_POR 152 -#define SRST_USB2PHY1_UTMI_PORT0 153 -#define SRST_USB2PHY1_UTMI_PORT1 154 -#define SRST_USB2PHY1_EHCIPHY 155 -#define SRST_UPHY1_PIPE_L00 156 -#define SRST_UPHY1 157 -#define SRST_UPHY1_TCPDPWRUP 158 - -/* cru_softrst_con10 */ -#define SRST_A_PERILP0_NOC 160 -#define SRST_A_DCF 161 -#define SRST_GIC500 162 -#define SRST_DMAC0_PERILP0 163 -#define SRST_DMAC1_PERILP0 164 -#define SRST_TZMA 165 -#define SRST_INTMEM 166 -#define SRST_ADB400_MST0 167 -#define SRST_ADB400_MST1 168 -#define SRST_ADB400_SLV0 169 -#define SRST_ADB400_SLV1 170 -#define SRST_H_PERILP0 171 -#define SRST_H_PERILP0_NOC 172 -#define SRST_ROM 173 -#define SRST_CRYPTO_S 174 -#define SRST_CRYPTO_M 175 - -/* cru_softrst_con11 */ -#define SRST_P_DCF 176 -#define SRST_CM0S_NOC 177 -#define SRST_CM0S 178 -#define SRST_CM0S_DBG 179 -#define SRST_CM0S_PO 180 -#define SRST_CRYPTO 181 -#define SRST_P_PERILP1_SGRF 182 -#define SRST_P_PERILP1_GRF 183 -#define SRST_CRYPTO1_S 184 -#define SRST_CRYPTO1_M 185 -#define SRST_CRYPTO1 186 -#define SRST_GIC_NOC 188 -#define SRST_SD_NOC 189 -#define SRST_SDIOAUDIO_BRG 190 - -/* cru_softrst_con12 */ -#define SRST_H_PERILP1 192 -#define SRST_H_PERILP1_NOC 193 -#define SRST_H_I2S0_8CH 194 -#define SRST_H_I2S1_8CH 195 -#define SRST_H_I2S2_8CH 196 -#define SRST_H_SPDIF_8CH 197 -#define SRST_P_PERILP1_NOC 198 -#define SRST_P_EFUSE_1024 199 -#define SRST_P_EFUSE_1024S 200 -#define SRST_P_I2C0 201 -#define SRST_P_I2C1 202 -#define SRST_P_I2C2 203 -#define SRST_P_I2C3 204 -#define SRST_P_I2C4 205 -#define SRST_P_I2C5 206 -#define SRST_P_MAILBOX0 207 - -/* cru_softrst_con13 */ -#define SRST_P_UART0 208 -#define SRST_P_UART1 209 -#define SRST_P_UART2 210 -#define SRST_P_UART3 211 -#define SRST_P_SARADC 212 -#define SRST_P_TSADC 213 -#define SRST_P_SPI0 214 -#define SRST_P_SPI1 215 -#define SRST_P_SPI2 216 -#define SRST_P_SPI4 217 -#define SRST_P_SPI5 218 -#define SRST_SPI0 219 -#define SRST_SPI1 220 -#define SRST_SPI2 221 -#define SRST_SPI4 222 -#define SRST_SPI5 223 - -/* cru_softrst_con14 */ -#define SRST_I2S0_8CH 224 -#define SRST_I2S1_8CH 225 -#define SRST_I2S2_8CH 226 -#define SRST_SPDIF_8CH 227 -#define SRST_UART0 228 -#define SRST_UART1 229 -#define SRST_UART2 230 -#define SRST_UART3 231 -#define SRST_TSADC 232 -#define SRST_I2C0 233 -#define SRST_I2C1 234 -#define SRST_I2C2 235 -#define SRST_I2C3 236 -#define SRST_I2C4 237 -#define SRST_I2C5 238 -#define SRST_SDIOAUDIO_NOC 239 - -/* cru_softrst_con15 */ -#define SRST_A_VIO_NOC 240 -#define SRST_A_HDCP_NOC 241 -#define SRST_A_HDCP 242 -#define SRST_H_HDCP_NOC 243 -#define SRST_H_HDCP 244 -#define SRST_P_HDCP_NOC 245 -#define SRST_P_HDCP 246 -#define SRST_P_HDMI_CTRL 247 -#define SRST_P_DP_CTRL 248 -#define SRST_S_DP_CTRL 249 -#define SRST_C_DP_CTRL 250 -#define SRST_P_MIPI_DSI0 251 -#define SRST_P_MIPI_DSI1 252 -#define SRST_DP_CORE 253 -#define SRST_DP_I2S 254 - -/* cru_softrst_con16 */ -#define SRST_GASKET 256 -#define SRST_VIO_GRF 258 -#define SRST_DPTX_SPDIF_REC 259 -#define SRST_HDMI_CTRL 260 -#define SRST_HDCP_CTRL 261 -#define SRST_A_ISP0_NOC 262 -#define SRST_A_ISP1_NOC 263 -#define SRST_H_ISP0_NOC 266 -#define SRST_H_ISP1_NOC 267 -#define SRST_H_ISP0 268 -#define SRST_H_ISP1 269 -#define SRST_ISP0 270 -#define SRST_ISP1 271 - -/* cru_softrst_con17 */ -#define SRST_A_VOP0_NOC 272 -#define SRST_A_VOP1_NOC 273 -#define SRST_A_VOP0 274 -#define SRST_A_VOP1 275 -#define SRST_H_VOP0_NOC 276 -#define SRST_H_VOP1_NOC 277 -#define SRST_H_VOP0 278 -#define SRST_H_VOP1 279 -#define SRST_D_VOP0 280 -#define SRST_D_VOP1 281 -#define SRST_VOP0_PWM 282 -#define SRST_VOP1_PWM 283 -#define SRST_P_EDP_NOC 284 -#define SRST_P_EDP_CTRL 285 - -/* cru_softrst_con18 */ -#define SRST_A_GPU 288 -#define SRST_A_GPU_NOC 289 -#define SRST_A_GPU_GRF 290 -#define SRST_PVTM_GPU 291 -#define SRST_A_USB3_NOC 292 -#define SRST_A_USB3_OTG0 293 -#define SRST_A_USB3_OTG1 294 -#define SRST_A_USB3_GRF 295 -#define SRST_PMU 296 - -/* cru_softrst_con19 */ -#define SRST_P_TIMER0_5 304 -#define SRST_TIMER0 305 -#define SRST_TIMER1 306 -#define SRST_TIMER2 307 -#define SRST_TIMER3 308 -#define SRST_TIMER4 309 -#define SRST_TIMER5 310 -#define SRST_P_TIMER6_11 311 -#define SRST_TIMER6 312 -#define SRST_TIMER7 313 -#define SRST_TIMER8 314 -#define SRST_TIMER9 315 -#define SRST_TIMER10 316 -#define SRST_TIMER11 317 -#define SRST_P_INTR_ARB_PMU 318 -#define SRST_P_ALIVE_SGRF 319 - -/* cru_softrst_con20 */ -#define SRST_P_GPIO2 320 -#define SRST_P_GPIO3 321 -#define SRST_P_GPIO4 322 -#define SRST_P_GRF 323 -#define SRST_P_ALIVE_NOC 324 -#define SRST_P_WDT0 325 -#define SRST_P_WDT1 326 -#define SRST_P_INTR_ARB 327 -#define SRST_P_UPHY0_DPTX 328 -#define SRST_P_UPHY0_APB 330 -#define SRST_P_UPHY0_TCPHY 332 -#define SRST_P_UPHY1_TCPHY 333 -#define SRST_P_UPHY0_TCPDCTRL 334 -#define SRST_P_UPHY1_TCPDCTRL 335 - -/* pmu soft-reset indices */ - -/* pmu_cru_softrst_con0 */ -#define SRST_P_NOC 0 -#define SRST_P_INTMEM 1 -#define SRST_H_CM0S 2 -#define SRST_H_CM0S_NOC 3 -#define SRST_DBG_CM0S 4 -#define SRST_PO_CM0S 5 -#define SRST_P_SPI3 6 -#define SRST_SPI3 7 -#define SRST_P_TIMER_0_1 8 -#define SRST_P_TIMER_0 9 -#define SRST_P_TIMER_1 10 -#define SRST_P_UART4 11 -#define SRST_UART4 12 -#define SRST_P_WDT 13 - -/* pmu_cru_softrst_con1 */ -#define SRST_P_I2C6 16 -#define SRST_P_I2C7 17 -#define SRST_P_I2C8 18 -#define SRST_P_MAILBOX 19 -#define SRST_P_RKPWM 20 -#define SRST_P_PMUGRF 21 -#define SRST_P_SGRF 22 -#define SRST_P_GPIO0 23 -#define SRST_P_GPIO1 24 -#define SRST_P_CRU 25 -#define SRST_P_INTR 26 -#define SRST_PVTM 27 -#define SRST_I2C6 28 -#define SRST_I2C7 29 -#define SRST_I2C8 30 - -#endif diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h deleted file mode 100644 index d29890865150..000000000000 --- a/include/dt-bindings/clock/rk3568-cru.h +++ /dev/null @@ -1,926 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2021 Rockchip Electronics Co. Ltd. - * Author: Elaine Zhang zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H - -/* pmucru-clocks indices */ - -/* pmucru plls */ -#define PLL_PPLL 1 -#define PLL_HPLL 2 - -/* pmucru clocks */ -#define XIN_OSC0_DIV 4 -#define CLK_RTC_32K 5 -#define CLK_PMU 6 -#define CLK_I2C0 7 -#define CLK_RTC32K_FRAC 8 -#define CLK_UART0_DIV 9 -#define CLK_UART0_FRAC 10 -#define SCLK_UART0 11 -#define DBCLK_GPIO0 12 -#define CLK_PWM0 13 -#define CLK_CAPTURE_PWM0_NDFT 14 -#define CLK_PMUPVTM 15 -#define CLK_CORE_PMUPVTM 16 -#define CLK_REF24M 17 -#define XIN_OSC0_USBPHY0_G 18 -#define CLK_USBPHY0_REF 19 -#define XIN_OSC0_USBPHY1_G 20 -#define CLK_USBPHY1_REF 21 -#define XIN_OSC0_MIPIDSIPHY0_G 22 -#define CLK_MIPIDSIPHY0_REF 23 -#define XIN_OSC0_MIPIDSIPHY1_G 24 -#define CLK_MIPIDSIPHY1_REF 25 -#define CLK_WIFI_DIV 26 -#define CLK_WIFI_OSC0 27 -#define CLK_WIFI 28 -#define CLK_PCIEPHY0_DIV 29 -#define CLK_PCIEPHY0_OSC0 30 -#define CLK_PCIEPHY0_REF 31 -#define CLK_PCIEPHY1_DIV 32 -#define CLK_PCIEPHY1_OSC0 33 -#define CLK_PCIEPHY1_REF 34 -#define CLK_PCIEPHY2_DIV 35 -#define CLK_PCIEPHY2_OSC0 36 -#define CLK_PCIEPHY2_REF 37 -#define CLK_PCIE30PHY_REF_M 38 -#define CLK_PCIE30PHY_REF_N 39 -#define CLK_HDMI_REF 40 -#define XIN_OSC0_EDPPHY_G 41 -#define PCLK_PDPMU 42 -#define PCLK_PMU 43 -#define PCLK_UART0 44 -#define PCLK_I2C0 45 -#define PCLK_GPIO0 46 -#define PCLK_PMUPVTM 47 -#define PCLK_PWM0 48 -#define CLK_PDPMU 49 -#define SCLK_32K_IOE 50 - -#define CLKPMU_NR_CLKS (SCLK_32K_IOE + 1) - -/* cru-clocks indices */ - -/* cru plls */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_VPLL 5 -#define PLL_NPLL 6 - -/* cru clocks */ -#define CPLL_333M 9 -#define ARMCLK 10 -#define USB480M 11 -#define ACLK_CORE_NIU2BUS 18 -#define CLK_CORE_PVTM 19 -#define CLK_CORE_PVTM_CORE 20 -#define CLK_CORE_PVTPLL 21 -#define CLK_GPU_SRC 22 -#define CLK_GPU_PRE_NDFT 23 -#define CLK_GPU_PRE_MUX 24 -#define ACLK_GPU_PRE 25 -#define PCLK_GPU_PRE 26 -#define CLK_GPU 27 -#define CLK_GPU_NP5 28 -#define PCLK_GPU_PVTM 29 -#define CLK_GPU_PVTM 30 -#define CLK_GPU_PVTM_CORE 31 -#define CLK_GPU_PVTPLL 32 -#define CLK_NPU_SRC 33 -#define CLK_NPU_PRE_NDFT 34 -#define CLK_NPU 35 -#define CLK_NPU_NP5 36 -#define HCLK_NPU_PRE 37 -#define PCLK_NPU_PRE 38 -#define ACLK_NPU_PRE 39 -#define ACLK_NPU 40 -#define HCLK_NPU 41 -#define PCLK_NPU_PVTM 42 -#define CLK_NPU_PVTM 43 -#define CLK_NPU_PVTM_CORE 44 -#define CLK_NPU_PVTPLL 45 -#define CLK_DDRPHY1X_SRC 46 -#define CLK_DDRPHY1X_HWFFC_SRC 47 -#define CLK_DDR1X 48 -#define CLK_MSCH 49 -#define CLK24_DDRMON 50 -#define ACLK_GIC_AUDIO 51 -#define HCLK_GIC_AUDIO 52 -#define HCLK_SDMMC_BUFFER 53 -#define DCLK_SDMMC_BUFFER 54 -#define ACLK_GIC600 55 -#define ACLK_SPINLOCK 56 -#define HCLK_I2S0_8CH 57 -#define HCLK_I2S1_8CH 58 -#define HCLK_I2S2_2CH 59 -#define HCLK_I2S3_2CH 60 -#define CLK_I2S0_8CH_TX_SRC 61 -#define CLK_I2S0_8CH_TX_FRAC 62 -#define MCLK_I2S0_8CH_TX 63 -#define I2S0_MCLKOUT_TX 64 -#define CLK_I2S0_8CH_RX_SRC 65 -#define CLK_I2S0_8CH_RX_FRAC 66 -#define MCLK_I2S0_8CH_RX 67 -#define I2S0_MCLKOUT_RX 68 -#define CLK_I2S1_8CH_TX_SRC 69 -#define CLK_I2S1_8CH_TX_FRAC 70 -#define MCLK_I2S1_8CH_TX 71 -#define I2S1_MCLKOUT_TX 72 -#define CLK_I2S1_8CH_RX_SRC 73 -#define CLK_I2S1_8CH_RX_FRAC 74 -#define MCLK_I2S1_8CH_RX 75 -#define I2S1_MCLKOUT_RX 76 -#define CLK_I2S2_2CH_SRC 77 -#define CLK_I2S2_2CH_FRAC 78 -#define MCLK_I2S2_2CH 79 -#define I2S2_MCLKOUT 80 -#define CLK_I2S3_2CH_TX_SRC 81 -#define CLK_I2S3_2CH_TX_FRAC 82 -#define MCLK_I2S3_2CH_TX 83 -#define I2S3_MCLKOUT_TX 84 -#define CLK_I2S3_2CH_RX_SRC 85 -#define CLK_I2S3_2CH_RX_FRAC 86 -#define MCLK_I2S3_2CH_RX 87 -#define I2S3_MCLKOUT_RX 88 -#define HCLK_PDM 89 -#define MCLK_PDM 90 -#define HCLK_VAD 91 -#define HCLK_SPDIF_8CH 92 -#define MCLK_SPDIF_8CH_SRC 93 -#define MCLK_SPDIF_8CH_FRAC 94 -#define MCLK_SPDIF_8CH 95 -#define HCLK_AUDPWM 96 -#define SCLK_AUDPWM_SRC 97 -#define SCLK_AUDPWM_FRAC 98 -#define SCLK_AUDPWM 99 -#define HCLK_ACDCDIG 100 -#define CLK_ACDCDIG_I2C 101 -#define CLK_ACDCDIG_DAC 102 -#define CLK_ACDCDIG_ADC 103 -#define ACLK_SECURE_FLASH 104 -#define HCLK_SECURE_FLASH 105 -#define ACLK_CRYPTO_NS 106 -#define HCLK_CRYPTO_NS 107 -#define CLK_CRYPTO_NS_CORE 108 -#define CLK_CRYPTO_NS_PKA 109 -#define CLK_CRYPTO_NS_RNG 110 -#define HCLK_TRNG_NS 111 -#define CLK_TRNG_NS 112 -#define PCLK_OTPC_NS 113 -#define CLK_OTPC_NS_SBPI 114 -#define CLK_OTPC_NS_USR 115 -#define HCLK_NANDC 116 -#define NCLK_NANDC 117 -#define HCLK_SFC 118 -#define HCLK_SFC_XIP 119 -#define SCLK_SFC 120 -#define ACLK_EMMC 121 -#define HCLK_EMMC 122 -#define BCLK_EMMC 123 -#define CCLK_EMMC 124 -#define TCLK_EMMC 125 -#define ACLK_PIPE 126 -#define PCLK_PIPE 127 -#define PCLK_PIPE_GRF 128 -#define ACLK_PCIE20_MST 129 -#define ACLK_PCIE20_SLV 130 -#define ACLK_PCIE20_DBI 131 -#define PCLK_PCIE20 132 -#define CLK_PCIE20_AUX_NDFT 133 -#define CLK_PCIE20_AUX_DFT 134 -#define CLK_PCIE20_PIPE_DFT 135 -#define ACLK_PCIE30X1_MST 136 -#define ACLK_PCIE30X1_SLV 137 -#define ACLK_PCIE30X1_DBI 138 -#define PCLK_PCIE30X1 139 -#define CLK_PCIE30X1_AUX_NDFT 140 -#define CLK_PCIE30X1_AUX_DFT 141 -#define CLK_PCIE30X1_PIPE_DFT 142 -#define ACLK_PCIE30X2_MST 143 -#define ACLK_PCIE30X2_SLV 144 -#define ACLK_PCIE30X2_DBI 145 -#define PCLK_PCIE30X2 146 -#define CLK_PCIE30X2_AUX_NDFT 147 -#define CLK_PCIE30X2_AUX_DFT 148 -#define CLK_PCIE30X2_PIPE_DFT 149 -#define ACLK_SATA0 150 -#define CLK_SATA0_PMALIVE 151 -#define CLK_SATA0_RXOOB 152 -#define CLK_SATA0_PIPE_NDFT 153 -#define CLK_SATA0_PIPE_DFT 154 -#define ACLK_SATA1 155 -#define CLK_SATA1_PMALIVE 156 -#define CLK_SATA1_RXOOB 157 -#define CLK_SATA1_PIPE_NDFT 158 -#define CLK_SATA1_PIPE_DFT 159 -#define ACLK_SATA2 160 -#define CLK_SATA2_PMALIVE 161 -#define CLK_SATA2_RXOOB 162 -#define CLK_SATA2_PIPE_NDFT 163 -#define CLK_SATA2_PIPE_DFT 164 -#define ACLK_USB3OTG0 165 -#define CLK_USB3OTG0_REF 166 -#define CLK_USB3OTG0_SUSPEND 167 -#define ACLK_USB3OTG1 168 -#define CLK_USB3OTG1_REF 169 -#define CLK_USB3OTG1_SUSPEND 170 -#define CLK_XPCS_EEE 171 -#define PCLK_XPCS 172 -#define ACLK_PHP 173 -#define HCLK_PHP 174 -#define PCLK_PHP 175 -#define HCLK_SDMMC0 176 -#define CLK_SDMMC0 177 -#define HCLK_SDMMC1 178 -#define CLK_SDMMC1 179 -#define ACLK_GMAC0 180 -#define PCLK_GMAC0 181 -#define CLK_MAC0_2TOP 182 -#define CLK_MAC0_OUT 183 -#define CLK_MAC0_REFOUT 184 -#define CLK_GMAC0_PTP_REF 185 -#define ACLK_USB 186 -#define HCLK_USB 187 -#define PCLK_USB 188 -#define HCLK_USB2HOST0 189 -#define HCLK_USB2HOST0_ARB 190 -#define HCLK_USB2HOST1 191 -#define HCLK_USB2HOST1_ARB 192 -#define HCLK_SDMMC2 193 -#define CLK_SDMMC2 194 -#define ACLK_GMAC1 195 -#define PCLK_GMAC1 196 -#define CLK_MAC1_2TOP 197 -#define CLK_MAC1_OUT 198 -#define CLK_MAC1_REFOUT 199 -#define CLK_GMAC1_PTP_REF 200 -#define ACLK_PERIMID 201 -#define HCLK_PERIMID 202 -#define ACLK_VI 203 -#define HCLK_VI 204 -#define PCLK_VI 205 -#define ACLK_VICAP 206 -#define HCLK_VICAP 207 -#define DCLK_VICAP 208 -#define ICLK_VICAP_G 209 -#define ACLK_ISP 210 -#define HCLK_ISP 211 -#define CLK_ISP 212 -#define PCLK_CSI2HOST1 213 -#define CLK_CIF_OUT 214 -#define CLK_CAM0_OUT 215 -#define CLK_CAM1_OUT 216 -#define ACLK_VO 217 -#define HCLK_VO 218 -#define PCLK_VO 219 -#define ACLK_VOP_PRE 220 -#define ACLK_VOP 221 -#define HCLK_VOP 222 -#define DCLK_VOP0 223 -#define DCLK_VOP1 224 -#define DCLK_VOP2 225 -#define CLK_VOP_PWM 226 -#define ACLK_HDCP 227 -#define HCLK_HDCP 228 -#define PCLK_HDCP 229 -#define PCLK_HDMI_HOST 230 -#define CLK_HDMI_SFR 231 -#define PCLK_DSITX_0 232 -#define PCLK_DSITX_1 233 -#define PCLK_EDP_CTRL 234 -#define CLK_EDP_200M 235 -#define ACLK_VPU_PRE 236 -#define HCLK_VPU_PRE 237 -#define ACLK_VPU 238 -#define HCLK_VPU 239 -#define ACLK_RGA_PRE 240 -#define HCLK_RGA_PRE 241 -#define PCLK_RGA_PRE 242 -#define ACLK_RGA 243 -#define HCLK_RGA 244 -#define CLK_RGA_CORE 245 -#define ACLK_IEP 246 -#define HCLK_IEP 247 -#define CLK_IEP_CORE 248 -#define HCLK_EBC 249 -#define DCLK_EBC 250 -#define ACLK_JDEC 251 -#define HCLK_JDEC 252 -#define ACLK_JENC 253 -#define HCLK_JENC 254 -#define PCLK_EINK 255 -#define HCLK_EINK 256 -#define ACLK_RKVENC_PRE 257 -#define HCLK_RKVENC_PRE 258 -#define ACLK_RKVENC 259 -#define HCLK_RKVENC 260 -#define CLK_RKVENC_CORE 261 -#define ACLK_RKVDEC_PRE 262 -#define HCLK_RKVDEC_PRE 263 -#define ACLK_RKVDEC 264 -#define HCLK_RKVDEC 265 -#define CLK_RKVDEC_CA 266 -#define CLK_RKVDEC_CORE 267 -#define CLK_RKVDEC_HEVC_CA 268 -#define ACLK_BUS 269 -#define PCLK_BUS 270 -#define PCLK_TSADC 271 -#define CLK_TSADC_TSEN 272 -#define CLK_TSADC 273 -#define PCLK_SARADC 274 -#define CLK_SARADC 275 -#define PCLK_SCR 276 -#define PCLK_WDT_NS 277 -#define TCLK_WDT_NS 278 -#define ACLK_DMAC0 279 -#define ACLK_DMAC1 280 -#define ACLK_MCU 281 -#define PCLK_INTMUX 282 -#define PCLK_MAILBOX 283 -#define PCLK_UART1 284 -#define CLK_UART1_SRC 285 -#define CLK_UART1_FRAC 286 -#define SCLK_UART1 287 -#define PCLK_UART2 288 -#define CLK_UART2_SRC 289 -#define CLK_UART2_FRAC 290 -#define SCLK_UART2 291 -#define PCLK_UART3 292 -#define CLK_UART3_SRC 293 -#define CLK_UART3_FRAC 294 -#define SCLK_UART3 295 -#define PCLK_UART4 296 -#define CLK_UART4_SRC 297 -#define CLK_UART4_FRAC 298 -#define SCLK_UART4 299 -#define PCLK_UART5 300 -#define CLK_UART5_SRC 301 -#define CLK_UART5_FRAC 302 -#define SCLK_UART5 303 -#define PCLK_UART6 304 -#define CLK_UART6_SRC 305 -#define CLK_UART6_FRAC 306 -#define SCLK_UART6 307 -#define PCLK_UART7 308 -#define CLK_UART7_SRC 309 -#define CLK_UART7_FRAC 310 -#define SCLK_UART7 311 -#define PCLK_UART8 312 -#define CLK_UART8_SRC 313 -#define CLK_UART8_FRAC 314 -#define SCLK_UART8 315 -#define PCLK_UART9 316 -#define CLK_UART9_SRC 317 -#define CLK_UART9_FRAC 318 -#define SCLK_UART9 319 -#define PCLK_CAN0 320 -#define CLK_CAN0 321 -#define PCLK_CAN1 322 -#define CLK_CAN1 323 -#define PCLK_CAN2 324 -#define CLK_CAN2 325 -#define CLK_I2C 326 -#define PCLK_I2C1 327 -#define CLK_I2C1 328 -#define PCLK_I2C2 329 -#define CLK_I2C2 330 -#define PCLK_I2C3 331 -#define CLK_I2C3 332 -#define PCLK_I2C4 333 -#define CLK_I2C4 334 -#define PCLK_I2C5 335 -#define CLK_I2C5 336 -#define PCLK_SPI0 337 -#define CLK_SPI0 338 -#define PCLK_SPI1 339 -#define CLK_SPI1 340 -#define PCLK_SPI2 341 -#define CLK_SPI2 342 -#define PCLK_SPI3 343 -#define CLK_SPI3 344 -#define PCLK_PWM1 345 -#define CLK_PWM1 346 -#define CLK_PWM1_CAPTURE 347 -#define PCLK_PWM2 348 -#define CLK_PWM2 349 -#define CLK_PWM2_CAPTURE 350 -#define PCLK_PWM3 351 -#define CLK_PWM3 352 -#define CLK_PWM3_CAPTURE 353 -#define DBCLK_GPIO 354 -#define PCLK_GPIO1 355 -#define DBCLK_GPIO1 356 -#define PCLK_GPIO2 357 -#define DBCLK_GPIO2 358 -#define PCLK_GPIO3 359 -#define DBCLK_GPIO3 360 -#define PCLK_GPIO4 361 -#define DBCLK_GPIO4 362 -#define OCC_SCAN_CLK_GPIO 363 -#define PCLK_TIMER 364 -#define CLK_TIMER0 365 -#define CLK_TIMER1 366 -#define CLK_TIMER2 367 -#define CLK_TIMER3 368 -#define CLK_TIMER4 369 -#define CLK_TIMER5 370 -#define ACLK_TOP_HIGH 371 -#define ACLK_TOP_LOW 372 -#define HCLK_TOP 373 -#define PCLK_TOP 374 -#define PCLK_PCIE30PHY 375 -#define CLK_OPTC_ARB 376 -#define PCLK_MIPICSIPHY 377 -#define PCLK_MIPIDSIPHY0 378 -#define PCLK_MIPIDSIPHY1 379 -#define PCLK_PIPEPHY0 380 -#define PCLK_PIPEPHY1 381 -#define PCLK_PIPEPHY2 382 -#define PCLK_CPU_BOOST 383 -#define CLK_CPU_BOOST 384 -#define PCLK_OTPPHY 385 -#define SCLK_GMAC0 386 -#define SCLK_GMAC0_RGMII_SPEED 387 -#define SCLK_GMAC0_RMII_SPEED 388 -#define SCLK_GMAC0_RX_TX 389 -#define SCLK_GMAC1 390 -#define SCLK_GMAC1_RGMII_SPEED 391 -#define SCLK_GMAC1_RMII_SPEED 392 -#define SCLK_GMAC1_RX_TX 393 -#define SCLK_SDMMC0_DRV 394 -#define SCLK_SDMMC0_SAMPLE 395 -#define SCLK_SDMMC1_DRV 396 -#define SCLK_SDMMC1_SAMPLE 397 -#define SCLK_SDMMC2_DRV 398 -#define SCLK_SDMMC2_SAMPLE 399 -#define SCLK_EMMC_DRV 400 -#define SCLK_EMMC_SAMPLE 401 -#define PCLK_EDPPHY_GRF 402 -#define CLK_HDMI_CEC 403 -#define CLK_I2S0_8CH_TX 404 -#define CLK_I2S0_8CH_RX 405 -#define CLK_I2S1_8CH_TX 406 -#define CLK_I2S1_8CH_RX 407 -#define CLK_I2S2_2CH 408 -#define CLK_I2S3_2CH_TX 409 -#define CLK_I2S3_2CH_RX 410 -#define CPLL_500M 411 -#define CPLL_250M 412 -#define CPLL_125M 413 -#define CPLL_62P5M 414 -#define CPLL_50M 415 -#define CPLL_25M 416 -#define CPLL_100M 417 -#define SCLK_DDRCLK 418 - -#define PCLK_CORE_PVTM 450 - -#define CLK_NR_CLKS (PCLK_CORE_PVTM + 1) - -/* pmu soft-reset indices */ -/* pmucru_softrst_con0 */ -#define SRST_P_PDPMU_NIU 0 -#define SRST_P_PMUCRU 1 -#define SRST_P_PMUGRF 2 -#define SRST_P_I2C0 3 -#define SRST_I2C0 4 -#define SRST_P_UART0 5 -#define SRST_S_UART0 6 -#define SRST_P_PWM0 7 -#define SRST_PWM0 8 -#define SRST_P_GPIO0 9 -#define SRST_GPIO0 10 -#define SRST_P_PMUPVTM 11 -#define SRST_PMUPVTM 12 - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_NCORERESET0 0 -#define SRST_NCORERESET1 1 -#define SRST_NCORERESET2 2 -#define SRST_NCORERESET3 3 -#define SRST_NCPUPORESET0 4 -#define SRST_NCPUPORESET1 5 -#define SRST_NCPUPORESET2 6 -#define SRST_NCPUPORESET3 7 -#define SRST_NSRESET 8 -#define SRST_NSPORESET 9 -#define SRST_NATRESET 10 -#define SRST_NGICRESET 11 -#define SRST_NPRESET 12 -#define SRST_NPERIPHRESET 13 - -/* cru_softrst_con1 */ -#define SRST_A_CORE_NIU2DDR 16 -#define SRST_A_CORE_NIU2BUS 17 -#define SRST_P_DBG_NIU 18 -#define SRST_P_DBG 19 -#define SRST_P_DBG_DAPLITE 20 -#define SRST_DAP 21 -#define SRST_A_ADB400_CORE2GIC 22 -#define SRST_A_ADB400_GIC2CORE 23 -#define SRST_P_CORE_GRF 24 -#define SRST_P_CORE_PVTM 25 -#define SRST_CORE_PVTM 26 -#define SRST_CORE_PVTPLL 27 - -/* cru_softrst_con2 */ -#define SRST_GPU 32 -#define SRST_A_GPU_NIU 33 -#define SRST_P_GPU_NIU 34 -#define SRST_P_GPU_PVTM 35 -#define SRST_GPU_PVTM 36 -#define SRST_GPU_PVTPLL 37 -#define SRST_A_NPU_NIU 40 -#define SRST_H_NPU_NIU 41 -#define SRST_P_NPU_NIU 42 -#define SRST_A_NPU 43 -#define SRST_H_NPU 44 -#define SRST_P_NPU_PVTM 45 -#define SRST_NPU_PVTM 46 -#define SRST_NPU_PVTPLL 47 - -/* cru_softrst_con3 */ -#define SRST_A_MSCH 51 -#define SRST_HWFFC_CTRL 52 -#define SRST_DDR_ALWAYSON 53 -#define SRST_A_DDRSPLIT 54 -#define SRST_DDRDFI_CTL 55 -#define SRST_A_DMA2DDR 57 - -/* cru_softrst_con4 */ -#define SRST_A_PERIMID_NIU 64 -#define SRST_H_PERIMID_NIU 65 -#define SRST_A_GIC_AUDIO_NIU 66 -#define SRST_H_GIC_AUDIO_NIU 67 -#define SRST_A_GIC600 68 -#define SRST_A_GIC600_DEBUG 69 -#define SRST_A_GICADB_CORE2GIC 70 -#define SRST_A_GICADB_GIC2CORE 71 -#define SRST_A_SPINLOCK 72 -#define SRST_H_SDMMC_BUFFER 73 -#define SRST_D_SDMMC_BUFFER 74 -#define SRST_H_I2S0_8CH 75 -#define SRST_H_I2S1_8CH 76 -#define SRST_H_I2S2_2CH 77 -#define SRST_H_I2S3_2CH 78 - -/* cru_softrst_con5 */ -#define SRST_M_I2S0_8CH_TX 80 -#define SRST_M_I2S0_8CH_RX 81 -#define SRST_M_I2S1_8CH_TX 82 -#define SRST_M_I2S1_8CH_RX 83 -#define SRST_M_I2S2_2CH 84 -#define SRST_M_I2S3_2CH_TX 85 -#define SRST_M_I2S3_2CH_RX 86 -#define SRST_H_PDM 87 -#define SRST_M_PDM 88 -#define SRST_H_VAD 89 -#define SRST_H_SPDIF_8CH 90 -#define SRST_M_SPDIF_8CH 91 -#define SRST_H_AUDPWM 92 -#define SRST_S_AUDPWM 93 -#define SRST_H_ACDCDIG 94 -#define SRST_ACDCDIG 95 - -/* cru_softrst_con6 */ -#define SRST_A_SECURE_FLASH_NIU 96 -#define SRST_H_SECURE_FLASH_NIU 97 -#define SRST_A_CRYPTO_NS 103 -#define SRST_H_CRYPTO_NS 104 -#define SRST_CRYPTO_NS_CORE 105 -#define SRST_CRYPTO_NS_PKA 106 -#define SRST_CRYPTO_NS_RNG 107 -#define SRST_H_TRNG_NS 108 -#define SRST_TRNG_NS 109 - -/* cru_softrst_con7 */ -#define SRST_H_NANDC 112 -#define SRST_N_NANDC 113 -#define SRST_H_SFC 114 -#define SRST_H_SFC_XIP 115 -#define SRST_S_SFC 116 -#define SRST_A_EMMC 117 -#define SRST_H_EMMC 118 -#define SRST_B_EMMC 119 -#define SRST_C_EMMC 120 -#define SRST_T_EMMC 121 - -/* cru_softrst_con8 */ -#define SRST_A_PIPE_NIU 128 -#define SRST_P_PIPE_NIU 130 -#define SRST_P_PIPE_GRF 133 -#define SRST_A_SATA0 134 -#define SRST_SATA0_PIPE 135 -#define SRST_SATA0_PMALIVE 136 -#define SRST_SATA0_RXOOB 137 -#define SRST_A_SATA1 138 -#define SRST_SATA1_PIPE 139 -#define SRST_SATA1_PMALIVE 140 -#define SRST_SATA1_RXOOB 141 - -/* cru_softrst_con9 */ -#define SRST_A_SATA2 144 -#define SRST_SATA2_PIPE 145 -#define SRST_SATA2_PMALIVE 146 -#define SRST_SATA2_RXOOB 147 -#define SRST_USB3OTG0 148 -#define SRST_USB3OTG1 149 -#define SRST_XPCS 150 -#define SRST_XPCS_TX_DIV10 151 -#define SRST_XPCS_RX_DIV10 152 -#define SRST_XPCS_XGXS_RX 153 - -/* cru_softrst_con10 */ -#define SRST_P_PCIE20 160 -#define SRST_PCIE20_POWERUP 161 -#define SRST_MSTR_ARESET_PCIE20 162 -#define SRST_SLV_ARESET_PCIE20 163 -#define SRST_DBI_ARESET_PCIE20 164 -#define SRST_BRESET_PCIE20 165 -#define SRST_PERST_PCIE20 166 -#define SRST_CORE_RST_PCIE20 167 -#define SRST_NSTICKY_RST_PCIE20 168 -#define SRST_STICKY_RST_PCIE20 169 -#define SRST_PWR_RST_PCIE20 170 - -/* cru_softrst_con11 */ -#define SRST_P_PCIE30X1 176 -#define SRST_PCIE30X1_POWERUP 177 -#define SRST_M_ARESET_PCIE30X1 178 -#define SRST_S_ARESET_PCIE30X1 179 -#define SRST_D_ARESET_PCIE30X1 180 -#define SRST_BRESET_PCIE30X1 181 -#define SRST_PERST_PCIE30X1 182 -#define SRST_CORE_RST_PCIE30X1 183 -#define SRST_NSTC_RST_PCIE30X1 184 -#define SRST_STC_RST_PCIE30X1 185 -#define SRST_PWR_RST_PCIE30X1 186 - -/* cru_softrst_con12 */ -#define SRST_P_PCIE30X2 192 -#define SRST_PCIE30X2_POWERUP 193 -#define SRST_M_ARESET_PCIE30X2 194 -#define SRST_S_ARESET_PCIE30X2 195 -#define SRST_D_ARESET_PCIE30X2 196 -#define SRST_BRESET_PCIE30X2 197 -#define SRST_PERST_PCIE30X2 198 -#define SRST_CORE_RST_PCIE30X2 199 -#define SRST_NSTC_RST_PCIE30X2 200 -#define SRST_STC_RST_PCIE30X2 201 -#define SRST_PWR_RST_PCIE30X2 202 - -/* cru_softrst_con13 */ -#define SRST_A_PHP_NIU 208 -#define SRST_H_PHP_NIU 209 -#define SRST_P_PHP_NIU 210 -#define SRST_H_SDMMC0 211 -#define SRST_SDMMC0 212 -#define SRST_H_SDMMC1 213 -#define SRST_SDMMC1 214 -#define SRST_A_GMAC0 215 -#define SRST_GMAC0_TIMESTAMP 216 - -/* cru_softrst_con14 */ -#define SRST_A_USB_NIU 224 -#define SRST_H_USB_NIU 225 -#define SRST_P_USB_NIU 226 -#define SRST_P_USB_GRF 227 -#define SRST_H_USB2HOST0 228 -#define SRST_H_USB2HOST0_ARB 229 -#define SRST_USB2HOST0_UTMI 230 -#define SRST_H_USB2HOST1 231 -#define SRST_H_USB2HOST1_ARB 232 -#define SRST_USB2HOST1_UTMI 233 -#define SRST_H_SDMMC2 234 -#define SRST_SDMMC2 235 -#define SRST_A_GMAC1 236 -#define SRST_GMAC1_TIMESTAMP 237 - -/* cru_softrst_con15 */ -#define SRST_A_VI_NIU 240 -#define SRST_H_VI_NIU 241 -#define SRST_P_VI_NIU 242 -#define SRST_A_VICAP 247 -#define SRST_H_VICAP 248 -#define SRST_D_VICAP 249 -#define SRST_I_VICAP 250 -#define SRST_P_VICAP 251 -#define SRST_H_ISP 252 -#define SRST_ISP 253 -#define SRST_P_CSI2HOST1 255 - -/* cru_softrst_con16 */ -#define SRST_A_VO_NIU 256 -#define SRST_H_VO_NIU 257 -#define SRST_P_VO_NIU 258 -#define SRST_A_VOP_NIU 259 -#define SRST_A_VOP 260 -#define SRST_H_VOP 261 -#define SRST_VOP0 262 -#define SRST_VOP1 263 -#define SRST_VOP2 264 -#define SRST_VOP_PWM 265 -#define SRST_A_HDCP 266 -#define SRST_H_HDCP 267 -#define SRST_P_HDCP 268 -#define SRST_P_HDMI_HOST 270 -#define SRST_HDMI_HOST 271 - -/* cru_softrst_con17 */ -#define SRST_P_DSITX_0 272 -#define SRST_P_DSITX_1 273 -#define SRST_P_EDP_CTRL 274 -#define SRST_EDP_24M 275 -#define SRST_A_VPU_NIU 280 -#define SRST_H_VPU_NIU 281 -#define SRST_A_VPU 282 -#define SRST_H_VPU 283 -#define SRST_H_EINK 286 -#define SRST_P_EINK 287 - -/* cru_softrst_con18 */ -#define SRST_A_RGA_NIU 288 -#define SRST_H_RGA_NIU 289 -#define SRST_P_RGA_NIU 290 -#define SRST_A_RGA 292 -#define SRST_H_RGA 293 -#define SRST_RGA_CORE 294 -#define SRST_A_IEP 295 -#define SRST_H_IEP 296 -#define SRST_IEP_CORE 297 -#define SRST_H_EBC 298 -#define SRST_D_EBC 299 -#define SRST_A_JDEC 300 -#define SRST_H_JDEC 301 -#define SRST_A_JENC 302 -#define SRST_H_JENC 303 - -/* cru_softrst_con19 */ -#define SRST_A_VENC_NIU 304 -#define SRST_H_VENC_NIU 305 -#define SRST_A_RKVENC 307 -#define SRST_H_RKVENC 308 -#define SRST_RKVENC_CORE 309 - -/* cru_softrst_con20 */ -#define SRST_A_RKVDEC_NIU 320 -#define SRST_H_RKVDEC_NIU 321 -#define SRST_A_RKVDEC 322 -#define SRST_H_RKVDEC 323 -#define SRST_RKVDEC_CA 324 -#define SRST_RKVDEC_CORE 325 -#define SRST_RKVDEC_HEVC_CA 326 - -/* cru_softrst_con21 */ -#define SRST_A_BUS_NIU 336 -#define SRST_P_BUS_NIU 338 -#define SRST_P_CAN0 340 -#define SRST_CAN0 341 -#define SRST_P_CAN1 342 -#define SRST_CAN1 343 -#define SRST_P_CAN2 344 -#define SRST_CAN2 345 -#define SRST_P_GPIO1 346 -#define SRST_GPIO1 347 -#define SRST_P_GPIO2 348 -#define SRST_GPIO2 349 -#define SRST_P_GPIO3 350 -#define SRST_GPIO3 351 - -/* cru_softrst_con22 */ -#define SRST_P_GPIO4 352 -#define SRST_GPIO4 353 -#define SRST_P_I2C1 354 -#define SRST_I2C1 355 -#define SRST_P_I2C2 356 -#define SRST_I2C2 357 -#define SRST_P_I2C3 358 -#define SRST_I2C3 359 -#define SRST_P_I2C4 360 -#define SRST_I2C4 361 -#define SRST_P_I2C5 362 -#define SRST_I2C5 363 -#define SRST_P_OTPC_NS 364 -#define SRST_OTPC_NS_SBPI 365 -#define SRST_OTPC_NS_USR 366 - -/* cru_softrst_con23 */ -#define SRST_P_PWM1 368 -#define SRST_PWM1 369 -#define SRST_P_PWM2 370 -#define SRST_PWM2 371 -#define SRST_P_PWM3 372 -#define SRST_PWM3 373 -#define SRST_P_SPI0 374 -#define SRST_SPI0 375 -#define SRST_P_SPI1 376 -#define SRST_SPI1 377 -#define SRST_P_SPI2 378 -#define SRST_SPI2 379 -#define SRST_P_SPI3 380 -#define SRST_SPI3 381 - -/* cru_softrst_con24 */ -#define SRST_P_SARADC 384 -#define SRST_P_TSADC 385 -#define SRST_TSADC 386 -#define SRST_P_TIMER 387 -#define SRST_TIMER0 388 -#define SRST_TIMER1 389 -#define SRST_TIMER2 390 -#define SRST_TIMER3 391 -#define SRST_TIMER4 392 -#define SRST_TIMER5 393 -#define SRST_P_UART1 394 -#define SRST_S_UART1 395 - -/* cru_softrst_con25 */ -#define SRST_P_UART2 400 -#define SRST_S_UART2 401 -#define SRST_P_UART3 402 -#define SRST_S_UART3 403 -#define SRST_P_UART4 404 -#define SRST_S_UART4 405 -#define SRST_P_UART5 406 -#define SRST_S_UART5 407 -#define SRST_P_UART6 408 -#define SRST_S_UART6 409 -#define SRST_P_UART7 410 -#define SRST_S_UART7 411 -#define SRST_P_UART8 412 -#define SRST_S_UART8 413 -#define SRST_P_UART9 414 -#define SRST_S_UART9 415 - -/* cru_softrst_con26 */ -#define SRST_P_GRF 416 -#define SRST_P_GRF_VCCIO12 417 -#define SRST_P_GRF_VCCIO34 418 -#define SRST_P_GRF_VCCIO567 419 -#define SRST_P_SCR 420 -#define SRST_P_WDT_NS 421 -#define SRST_T_WDT_NS 422 -#define SRST_P_DFT2APB 423 -#define SRST_A_MCU 426 -#define SRST_P_INTMUX 427 -#define SRST_P_MAILBOX 428 - -/* cru_softrst_con27 */ -#define SRST_A_TOP_HIGH_NIU 432 -#define SRST_A_TOP_LOW_NIU 433 -#define SRST_H_TOP_NIU 434 -#define SRST_P_TOP_NIU 435 -#define SRST_P_TOP_CRU 438 -#define SRST_P_DDRPHY 439 -#define SRST_DDRPHY 440 -#define SRST_P_MIPICSIPHY 442 -#define SRST_P_MIPIDSIPHY0 443 -#define SRST_P_MIPIDSIPHY1 444 -#define SRST_P_PCIE30PHY 445 -#define SRST_PCIE30PHY 446 -#define SRST_P_PCIE30PHY_GRF 447 - -/* cru_softrst_con28 */ -#define SRST_P_APB2ASB_LEFT 448 -#define SRST_P_APB2ASB_BOTTOM 449 -#define SRST_P_ASB2APB_LEFT 450 -#define SRST_P_ASB2APB_BOTTOM 451 -#define SRST_P_PIPEPHY0 452 -#define SRST_PIPEPHY0 453 -#define SRST_P_PIPEPHY1 454 -#define SRST_PIPEPHY1 455 -#define SRST_P_PIPEPHY2 456 -#define SRST_PIPEPHY2 457 -#define SRST_P_USB2PHY0_GRF 458 -#define SRST_P_USB2PHY1_GRF 459 -#define SRST_P_CPU_BOOST 460 -#define SRST_CPU_BOOST 461 -#define SRST_P_OTPPHY 462 -#define SRST_OTPPHY 463 - -/* cru_softrst_con29 */ -#define SRST_USB2PHY0_POR 464 -#define SRST_USB2PHY0_USB3OTG0 465 -#define SRST_USB2PHY0_USB3OTG1 466 -#define SRST_USB2PHY1_POR 467 -#define SRST_USB2PHY1_USB2HOST0 468 -#define SRST_USB2PHY1_USB2HOST1 469 -#define SRST_P_EDPPHY_GRF 470 -#define SRST_TSADCPHY 471 -#define SRST_GMAC0_DELAYLINE 472 -#define SRST_GMAC1_DELAYLINE 473 -#define SRST_OTPC_ARB 474 -#define SRST_P_PIPEPHY0_GRF 475 -#define SRST_P_PIPEPHY1_GRF 476 -#define SRST_P_PIPEPHY2_GRF 477 - -#endif diff --git a/include/dt-bindings/clock/rockchip,rk3588-cru.h b/include/dt-bindings/clock/rockchip,rk3588-cru.h deleted file mode 100644 index b5616bca7b44..000000000000 --- a/include/dt-bindings/clock/rockchip,rk3588-cru.h +++ /dev/null @@ -1,766 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or MIT) */ -/* - * Copyright (c) 2021 Rockchip Electronics Co. Ltd. - * Copyright (c) 2022 Collabora Ltd. - * - * Author: Elaine Zhang zhangqing@rock-chips.com - * Author: Sebastian Reichel sebastian.reichel@collabora.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3588_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3588_H - -/* cru-clocks indices */ - -#define PLL_B0PLL 0 -#define PLL_B1PLL 1 -#define PLL_LPLL 2 -#define PLL_V0PLL 3 -#define PLL_AUPLL 4 -#define PLL_CPLL 5 -#define PLL_GPLL 6 -#define PLL_NPLL 7 -#define PLL_PPLL 8 -#define ARMCLK_L 9 -#define ARMCLK_B01 10 -#define ARMCLK_B23 11 -#define PCLK_BIGCORE0_ROOT 12 -#define PCLK_BIGCORE0_PVTM 13 -#define PCLK_BIGCORE1_ROOT 14 -#define PCLK_BIGCORE1_PVTM 15 -#define PCLK_DSU_S_ROOT 16 -#define PCLK_DSU_ROOT 17 -#define PCLK_DSU_NS_ROOT 18 -#define PCLK_LITCORE_PVTM 19 -#define PCLK_DBG 20 -#define PCLK_DSU 21 -#define PCLK_S_DAPLITE 22 -#define PCLK_M_DAPLITE 23 -#define MBIST_MCLK_PDM1 24 -#define MBIST_CLK_ACDCDIG 25 -#define HCLK_I2S2_2CH 26 -#define HCLK_I2S3_2CH 27 -#define CLK_I2S2_2CH_SRC 28 -#define CLK_I2S2_2CH_FRAC 29 -#define CLK_I2S2_2CH 30 -#define MCLK_I2S2_2CH 31 -#define I2S2_2CH_MCLKOUT 32 -#define CLK_DAC_ACDCDIG 33 -#define CLK_I2S3_2CH_SRC 34 -#define CLK_I2S3_2CH_FRAC 35 -#define CLK_I2S3_2CH 36 -#define MCLK_I2S3_2CH 37 -#define I2S3_2CH_MCLKOUT 38 -#define PCLK_ACDCDIG 39 -#define HCLK_I2S0_8CH 40 -#define CLK_I2S0_8CH_TX_SRC 41 -#define CLK_I2S0_8CH_TX_FRAC 42 -#define MCLK_I2S0_8CH_TX 43 -#define CLK_I2S0_8CH_TX 44 -#define CLK_I2S0_8CH_RX_SRC 45 -#define CLK_I2S0_8CH_RX_FRAC 46 -#define MCLK_I2S0_8CH_RX 47 -#define CLK_I2S0_8CH_RX 48 -#define I2S0_8CH_MCLKOUT 49 -#define HCLK_PDM1 50 -#define MCLK_PDM1 51 -#define HCLK_AUDIO_ROOT 52 -#define PCLK_AUDIO_ROOT 53 -#define HCLK_SPDIF0 54 -#define CLK_SPDIF0_SRC 55 -#define CLK_SPDIF0_FRAC 56 -#define MCLK_SPDIF0 57 -#define CLK_SPDIF0 58 -#define CLK_SPDIF1 59 -#define HCLK_SPDIF1 60 -#define CLK_SPDIF1_SRC 61 -#define CLK_SPDIF1_FRAC 62 -#define MCLK_SPDIF1 63 -#define ACLK_AV1_ROOT 64 -#define ACLK_AV1 65 -#define PCLK_AV1_ROOT 66 -#define PCLK_AV1 67 -#define PCLK_MAILBOX0 68 -#define PCLK_MAILBOX1 69 -#define PCLK_MAILBOX2 70 -#define PCLK_PMU2 71 -#define PCLK_PMUCM0_INTMUX 72 -#define PCLK_DDRCM0_INTMUX 73 -#define PCLK_TOP 74 -#define PCLK_PWM1 75 -#define CLK_PWM1 76 -#define CLK_PWM1_CAPTURE 77 -#define PCLK_PWM2 78 -#define CLK_PWM2 79 -#define CLK_PWM2_CAPTURE 80 -#define PCLK_PWM3 81 -#define CLK_PWM3 82 -#define CLK_PWM3_CAPTURE 83 -#define PCLK_BUSTIMER0 84 -#define PCLK_BUSTIMER1 85 -#define CLK_BUS_TIMER_ROOT 86 -#define CLK_BUSTIMER0 87 -#define CLK_BUSTIMER1 88 -#define CLK_BUSTIMER2 89 -#define CLK_BUSTIMER3 90 -#define CLK_BUSTIMER4 91 -#define CLK_BUSTIMER5 92 -#define CLK_BUSTIMER6 93 -#define CLK_BUSTIMER7 94 -#define CLK_BUSTIMER8 95 -#define CLK_BUSTIMER9 96 -#define CLK_BUSTIMER10 97 -#define CLK_BUSTIMER11 98 -#define PCLK_WDT0 99 -#define TCLK_WDT0 100 -#define PCLK_CAN0 101 -#define CLK_CAN0 102 -#define PCLK_CAN1 103 -#define CLK_CAN1 104 -#define PCLK_CAN2 105 -#define CLK_CAN2 106 -#define ACLK_DECOM 107 -#define PCLK_DECOM 108 -#define DCLK_DECOM 109 -#define ACLK_DMAC0 110 -#define ACLK_DMAC1 111 -#define ACLK_DMAC2 112 -#define ACLK_BUS_ROOT 113 -#define ACLK_GIC 114 -#define PCLK_GPIO1 115 -#define DBCLK_GPIO1 116 -#define PCLK_GPIO2 117 -#define DBCLK_GPIO2 118 -#define PCLK_GPIO3 119 -#define DBCLK_GPIO3 120 -#define PCLK_GPIO4 121 -#define DBCLK_GPIO4 122 -#define PCLK_I2C1 123 -#define PCLK_I2C2 124 -#define PCLK_I2C3 125 -#define PCLK_I2C4 126 -#define PCLK_I2C5 127 -#define PCLK_I2C6 128 -#define PCLK_I2C7 129 -#define PCLK_I2C8 130 -#define CLK_I2C1 131 -#define CLK_I2C2 132 -#define CLK_I2C3 133 -#define CLK_I2C4 134 -#define CLK_I2C5 135 -#define CLK_I2C6 136 -#define CLK_I2C7 137 -#define CLK_I2C8 138 -#define PCLK_OTPC_NS 139 -#define CLK_OTPC_NS 140 -#define CLK_OTPC_ARB 141 -#define CLK_OTPC_AUTO_RD_G 142 -#define CLK_OTP_PHY_G 143 -#define PCLK_SARADC 144 -#define CLK_SARADC 145 -#define PCLK_SPI0 146 -#define PCLK_SPI1 147 -#define PCLK_SPI2 148 -#define PCLK_SPI3 149 -#define PCLK_SPI4 150 -#define CLK_SPI0 151 -#define CLK_SPI1 152 -#define CLK_SPI2 153 -#define CLK_SPI3 154 -#define CLK_SPI4 155 -#define ACLK_SPINLOCK 156 -#define PCLK_TSADC 157 -#define CLK_TSADC 158 -#define PCLK_UART1 159 -#define PCLK_UART2 160 -#define PCLK_UART3 161 -#define PCLK_UART4 162 -#define PCLK_UART5 163 -#define PCLK_UART6 164 -#define PCLK_UART7 165 -#define PCLK_UART8 166 -#define PCLK_UART9 167 -#define CLK_UART1_SRC 168 -#define CLK_UART1_FRAC 169 -#define CLK_UART1 170 -#define SCLK_UART1 171 -#define CLK_UART2_SRC 172 -#define CLK_UART2_FRAC 173 -#define CLK_UART2 174 -#define SCLK_UART2 175 -#define CLK_UART3_SRC 176 -#define CLK_UART3_FRAC 177 -#define CLK_UART3 178 -#define SCLK_UART3 179 -#define CLK_UART4_SRC 180 -#define CLK_UART4_FRAC 181 -#define CLK_UART4 182 -#define SCLK_UART4 183 -#define CLK_UART5_SRC 184 -#define CLK_UART5_FRAC 185 -#define CLK_UART5 186 -#define SCLK_UART5 187 -#define CLK_UART6_SRC 188 -#define CLK_UART6_FRAC 189 -#define CLK_UART6 190 -#define SCLK_UART6 191 -#define CLK_UART7_SRC 192 -#define CLK_UART7_FRAC 193 -#define CLK_UART7 194 -#define SCLK_UART7 195 -#define CLK_UART8_SRC 196 -#define CLK_UART8_FRAC 197 -#define CLK_UART8 198 -#define SCLK_UART8 199 -#define CLK_UART9_SRC 200 -#define CLK_UART9_FRAC 201 -#define CLK_UART9 202 -#define SCLK_UART9 203 -#define ACLK_CENTER_ROOT 204 -#define ACLK_CENTER_LOW_ROOT 205 -#define HCLK_CENTER_ROOT 206 -#define PCLK_CENTER_ROOT 207 -#define ACLK_DMA2DDR 208 -#define ACLK_DDR_SHAREMEM 209 -#define ACLK_CENTER_S200_ROOT 210 -#define ACLK_CENTER_S400_ROOT 211 -#define FCLK_DDR_CM0_CORE 212 -#define CLK_DDR_TIMER_ROOT 213 -#define CLK_DDR_TIMER0 214 -#define CLK_DDR_TIMER1 215 -#define TCLK_WDT_DDR 216 -#define CLK_DDR_CM0_RTC 217 -#define PCLK_WDT 218 -#define PCLK_TIMER 219 -#define PCLK_DMA2DDR 220 -#define PCLK_SHAREMEM 221 -#define CLK_50M_SRC 222 -#define CLK_100M_SRC 223 -#define CLK_150M_SRC 224 -#define CLK_200M_SRC 225 -#define CLK_250M_SRC 226 -#define CLK_300M_SRC 227 -#define CLK_350M_SRC 228 -#define CLK_400M_SRC 229 -#define CLK_450M_SRC 230 -#define CLK_500M_SRC 231 -#define CLK_600M_SRC 232 -#define CLK_650M_SRC 233 -#define CLK_700M_SRC 234 -#define CLK_800M_SRC 235 -#define CLK_1000M_SRC 236 -#define CLK_1200M_SRC 237 -#define ACLK_TOP_M300_ROOT 238 -#define ACLK_TOP_M500_ROOT 239 -#define ACLK_TOP_M400_ROOT 240 -#define ACLK_TOP_S200_ROOT 241 -#define ACLK_TOP_S400_ROOT 242 -#define CLK_MIPI_CAMARAOUT_M0 243 -#define CLK_MIPI_CAMARAOUT_M1 244 -#define CLK_MIPI_CAMARAOUT_M2 245 -#define CLK_MIPI_CAMARAOUT_M3 246 -#define CLK_MIPI_CAMARAOUT_M4 247 -#define MCLK_GMAC0_OUT 248 -#define REFCLKO25M_ETH0_OUT 249 -#define REFCLKO25M_ETH1_OUT 250 -#define CLK_CIFOUT_OUT 251 -#define PCLK_MIPI_DCPHY0 252 -#define PCLK_MIPI_DCPHY1 253 -#define PCLK_CSIPHY0 254 -#define PCLK_CSIPHY1 255 -#define ACLK_TOP_ROOT 256 -#define PCLK_TOP_ROOT 257 -#define ACLK_LOW_TOP_ROOT 258 -#define PCLK_CRU 259 -#define PCLK_GPU_ROOT 260 -#define CLK_GPU_SRC 261 -#define CLK_GPU 262 -#define CLK_GPU_COREGROUP 263 -#define CLK_GPU_STACKS 264 -#define PCLK_GPU_PVTM 265 -#define CLK_GPU_PVTM 266 -#define CLK_CORE_GPU_PVTM 267 -#define PCLK_GPU_GRF 268 -#define ACLK_ISP1_ROOT 269 -#define HCLK_ISP1_ROOT 270 -#define CLK_ISP1_CORE 271 -#define CLK_ISP1_CORE_MARVIN 272 -#define CLK_ISP1_CORE_VICAP 273 -#define ACLK_ISP1 274 -#define HCLK_ISP1 275 -#define ACLK_NPU1 276 -#define HCLK_NPU1 277 -#define ACLK_NPU2 278 -#define HCLK_NPU2 279 -#define HCLK_NPU_CM0_ROOT 280 -#define FCLK_NPU_CM0_CORE 281 -#define CLK_NPU_CM0_RTC 282 -#define PCLK_NPU_PVTM 283 -#define PCLK_NPU_GRF 284 -#define CLK_NPU_PVTM 285 -#define CLK_CORE_NPU_PVTM 286 -#define ACLK_NPU0 287 -#define HCLK_NPU0 288 -#define HCLK_NPU_ROOT 289 -#define CLK_NPU_DSU0 290 -#define PCLK_NPU_ROOT 291 -#define PCLK_NPU_TIMER 292 -#define CLK_NPUTIMER_ROOT 293 -#define CLK_NPUTIMER0 294 -#define CLK_NPUTIMER1 295 -#define PCLK_NPU_WDT 296 -#define TCLK_NPU_WDT 297 -#define HCLK_EMMC 298 -#define ACLK_EMMC 299 -#define CCLK_EMMC 300 -#define BCLK_EMMC 301 -#define TMCLK_EMMC 302 -#define SCLK_SFC 303 -#define HCLK_SFC 304 -#define HCLK_SFC_XIP 305 -#define HCLK_NVM_ROOT 306 -#define ACLK_NVM_ROOT 307 -#define CLK_GMAC0_PTP_REF 308 -#define CLK_GMAC1_PTP_REF 309 -#define CLK_GMAC_125M 310 -#define CLK_GMAC_50M 311 -#define ACLK_PHP_GIC_ITS 312 -#define ACLK_MMU_PCIE 313 -#define ACLK_MMU_PHP 314 -#define ACLK_PCIE_4L_DBI 315 -#define ACLK_PCIE_2L_DBI 316 -#define ACLK_PCIE_1L0_DBI 317 -#define ACLK_PCIE_1L1_DBI 318 -#define ACLK_PCIE_1L2_DBI 319 -#define ACLK_PCIE_4L_MSTR 320 -#define ACLK_PCIE_2L_MSTR 321 -#define ACLK_PCIE_1L0_MSTR 322 -#define ACLK_PCIE_1L1_MSTR 323 -#define ACLK_PCIE_1L2_MSTR 324 -#define ACLK_PCIE_4L_SLV 325 -#define ACLK_PCIE_2L_SLV 326 -#define ACLK_PCIE_1L0_SLV 327 -#define ACLK_PCIE_1L1_SLV 328 -#define ACLK_PCIE_1L2_SLV 329 -#define PCLK_PCIE_4L 330 -#define PCLK_PCIE_2L 331 -#define PCLK_PCIE_1L0 332 -#define PCLK_PCIE_1L1 333 -#define PCLK_PCIE_1L2 334 -#define CLK_PCIE_AUX0 335 -#define CLK_PCIE_AUX1 336 -#define CLK_PCIE_AUX2 337 -#define CLK_PCIE_AUX3 338 -#define CLK_PCIE_AUX4 339 -#define CLK_PIPEPHY0_REF 340 -#define CLK_PIPEPHY1_REF 341 -#define CLK_PIPEPHY2_REF 342 -#define PCLK_PHP_ROOT 343 -#define PCLK_GMAC0 344 -#define PCLK_GMAC1 345 -#define ACLK_PCIE_ROOT 346 -#define ACLK_PHP_ROOT 347 -#define ACLK_PCIE_BRIDGE 348 -#define ACLK_GMAC0 349 -#define ACLK_GMAC1 350 -#define CLK_PMALIVE0 351 -#define CLK_PMALIVE1 352 -#define CLK_PMALIVE2 353 -#define ACLK_SATA0 354 -#define ACLK_SATA1 355 -#define ACLK_SATA2 356 -#define CLK_RXOOB0 357 -#define CLK_RXOOB1 358 -#define CLK_RXOOB2 359 -#define ACLK_USB3OTG2 360 -#define SUSPEND_CLK_USB3OTG2 361 -#define REF_CLK_USB3OTG2 362 -#define CLK_UTMI_OTG2 363 -#define CLK_PIPEPHY0_PIPE_G 364 -#define CLK_PIPEPHY1_PIPE_G 365 -#define CLK_PIPEPHY2_PIPE_G 366 -#define CLK_PIPEPHY0_PIPE_ASIC_G 367 -#define CLK_PIPEPHY1_PIPE_ASIC_G 368 -#define CLK_PIPEPHY2_PIPE_ASIC_G 369 -#define CLK_PIPEPHY2_PIPE_U3_G 370 -#define CLK_PCIE1L2_PIPE 371 -#define CLK_PCIE4L_PIPE 372 -#define CLK_PCIE2L_PIPE 373 -#define PCLK_PCIE_COMBO_PIPE_PHY0 374 -#define PCLK_PCIE_COMBO_PIPE_PHY1 375 -#define PCLK_PCIE_COMBO_PIPE_PHY2 376 -#define PCLK_PCIE_COMBO_PIPE_PHY 377 -#define HCLK_RGA3_1 378 -#define ACLK_RGA3_1 379 -#define CLK_RGA3_1_CORE 380 -#define ACLK_RGA3_ROOT 381 -#define HCLK_RGA3_ROOT 382 -#define ACLK_RKVDEC_CCU 383 -#define HCLK_RKVDEC0 384 -#define ACLK_RKVDEC0 385 -#define CLK_RKVDEC0_CA 386 -#define CLK_RKVDEC0_HEVC_CA 387 -#define CLK_RKVDEC0_CORE 388 -#define HCLK_RKVDEC1 389 -#define ACLK_RKVDEC1 390 -#define CLK_RKVDEC1_CA 391 -#define CLK_RKVDEC1_HEVC_CA 392 -#define CLK_RKVDEC1_CORE 393 -#define HCLK_SDIO 394 -#define CCLK_SRC_SDIO 395 -#define ACLK_USB_ROOT 396 -#define HCLK_USB_ROOT 397 -#define HCLK_HOST0 398 -#define HCLK_HOST_ARB0 399 -#define HCLK_HOST1 400 -#define HCLK_HOST_ARB1 401 -#define ACLK_USB3OTG0 402 -#define SUSPEND_CLK_USB3OTG0 403 -#define REF_CLK_USB3OTG0 404 -#define ACLK_USB3OTG1 405 -#define SUSPEND_CLK_USB3OTG1 406 -#define REF_CLK_USB3OTG1 407 -#define UTMI_OHCI_CLK48_HOST0 408 -#define UTMI_OHCI_CLK48_HOST1 409 -#define HCLK_IEP2P0 410 -#define ACLK_IEP2P0 411 -#define CLK_IEP2P0_CORE 412 -#define ACLK_JPEG_ENCODER0 413 -#define HCLK_JPEG_ENCODER0 414 -#define ACLK_JPEG_ENCODER1 415 -#define HCLK_JPEG_ENCODER1 416 -#define ACLK_JPEG_ENCODER2 417 -#define HCLK_JPEG_ENCODER2 418 -#define ACLK_JPEG_ENCODER3 419 -#define HCLK_JPEG_ENCODER3 420 -#define ACLK_JPEG_DECODER 421 -#define HCLK_JPEG_DECODER 422 -#define HCLK_RGA2 423 -#define ACLK_RGA2 424 -#define CLK_RGA2_CORE 425 -#define HCLK_RGA3_0 426 -#define ACLK_RGA3_0 427 -#define CLK_RGA3_0_CORE 428 -#define ACLK_VDPU_ROOT 429 -#define ACLK_VDPU_LOW_ROOT 430 -#define HCLK_VDPU_ROOT 431 -#define ACLK_JPEG_DECODER_ROOT 432 -#define ACLK_VPU 433 -#define HCLK_VPU 434 -#define HCLK_RKVENC0_ROOT 435 -#define ACLK_RKVENC0_ROOT 436 -#define HCLK_RKVENC0 437 -#define ACLK_RKVENC0 438 -#define CLK_RKVENC0_CORE 439 -#define HCLK_RKVENC1_ROOT 440 -#define ACLK_RKVENC1_ROOT 441 -#define HCLK_RKVENC1 442 -#define ACLK_RKVENC1 443 -#define CLK_RKVENC1_CORE 444 -#define ICLK_CSIHOST01 445 -#define ICLK_CSIHOST0 446 -#define ICLK_CSIHOST1 447 -#define PCLK_CSI_HOST_0 448 -#define PCLK_CSI_HOST_1 449 -#define PCLK_CSI_HOST_2 450 -#define PCLK_CSI_HOST_3 451 -#define PCLK_CSI_HOST_4 452 -#define PCLK_CSI_HOST_5 453 -#define ACLK_FISHEYE0 454 -#define HCLK_FISHEYE0 455 -#define CLK_FISHEYE0_CORE 456 -#define ACLK_FISHEYE1 457 -#define HCLK_FISHEYE1 458 -#define CLK_FISHEYE1_CORE 459 -#define CLK_ISP0_CORE 460 -#define CLK_ISP0_CORE_MARVIN 461 -#define CLK_ISP0_CORE_VICAP 462 -#define ACLK_ISP0 463 -#define HCLK_ISP0 464 -#define ACLK_VI_ROOT 465 -#define HCLK_VI_ROOT 466 -#define PCLK_VI_ROOT 467 -#define DCLK_VICAP 468 -#define ACLK_VICAP 469 -#define HCLK_VICAP 470 -#define PCLK_DP0 471 -#define PCLK_DP1 472 -#define PCLK_S_DP0 473 -#define PCLK_S_DP1 474 -#define CLK_DP0 475 -#define CLK_DP1 476 -#define HCLK_HDCP_KEY0 477 -#define ACLK_HDCP0 478 -#define HCLK_HDCP0 479 -#define PCLK_HDCP0 480 -#define HCLK_I2S4_8CH 481 -#define ACLK_TRNG0 482 -#define PCLK_TRNG0 483 -#define ACLK_VO0_ROOT 484 -#define HCLK_VO0_ROOT 485 -#define HCLK_VO0_S_ROOT 486 -#define PCLK_VO0_ROOT 487 -#define PCLK_VO0_S_ROOT 488 -#define PCLK_VO0GRF 489 -#define CLK_I2S4_8CH_TX_SRC 490 -#define CLK_I2S4_8CH_TX_FRAC 491 -#define MCLK_I2S4_8CH_TX 492 -#define CLK_I2S4_8CH_TX 493 -#define HCLK_I2S8_8CH 494 -#define CLK_I2S8_8CH_TX_SRC 495 -#define CLK_I2S8_8CH_TX_FRAC 496 -#define MCLK_I2S8_8CH_TX 497 -#define CLK_I2S8_8CH_TX 498 -#define HCLK_SPDIF2_DP0 499 -#define CLK_SPDIF2_DP0_SRC 500 -#define CLK_SPDIF2_DP0_FRAC 501 -#define MCLK_SPDIF2_DP0 502 -#define CLK_SPDIF2_DP0 503 -#define MCLK_SPDIF2 504 -#define HCLK_SPDIF5_DP1 505 -#define CLK_SPDIF5_DP1_SRC 506 -#define CLK_SPDIF5_DP1_FRAC 507 -#define MCLK_SPDIF5_DP1 508 -#define CLK_SPDIF5_DP1 509 -#define MCLK_SPDIF5 510 -#define PCLK_EDP0 511 -#define CLK_EDP0_24M 512 -#define CLK_EDP0_200M 513 -#define PCLK_EDP1 514 -#define CLK_EDP1_24M 515 -#define CLK_EDP1_200M 516 -#define HCLK_HDCP_KEY1 517 -#define ACLK_HDCP1 518 -#define HCLK_HDCP1 519 -#define PCLK_HDCP1 520 -#define ACLK_HDMIRX 521 -#define PCLK_HDMIRX 522 -#define CLK_HDMIRX_REF 523 -#define CLK_HDMIRX_AUD_SRC 524 -#define CLK_HDMIRX_AUD_FRAC 525 -#define CLK_HDMIRX_AUD 526 -#define CLK_HDMIRX_AUD_P_MUX 527 -#define PCLK_HDMITX0 528 -#define CLK_HDMITX0_EARC 529 -#define CLK_HDMITX0_REF 530 -#define PCLK_HDMITX1 531 -#define CLK_HDMITX1_EARC 532 -#define CLK_HDMITX1_REF 533 -#define CLK_HDMITRX_REFSRC 534 -#define ACLK_TRNG1 535 -#define PCLK_TRNG1 536 -#define ACLK_HDCP1_ROOT 537 -#define ACLK_HDMIRX_ROOT 538 -#define HCLK_VO1_ROOT 539 -#define HCLK_VO1_S_ROOT 540 -#define PCLK_VO1_ROOT 541 -#define PCLK_VO1_S_ROOT 542 -#define PCLK_S_EDP0 543 -#define PCLK_S_EDP1 544 -#define PCLK_S_HDMIRX 545 -#define HCLK_I2S10_8CH 546 -#define CLK_I2S10_8CH_RX_SRC 547 -#define CLK_I2S10_8CH_RX_FRAC 548 -#define CLK_I2S10_8CH_RX 549 -#define MCLK_I2S10_8CH_RX 550 -#define HCLK_I2S7_8CH 551 -#define CLK_I2S7_8CH_RX_SRC 552 -#define CLK_I2S7_8CH_RX_FRAC 553 -#define CLK_I2S7_8CH_RX 554 -#define MCLK_I2S7_8CH_RX 555 -#define HCLK_I2S9_8CH 556 -#define CLK_I2S9_8CH_RX_SRC 557 -#define CLK_I2S9_8CH_RX_FRAC 558 -#define CLK_I2S9_8CH_RX 559 -#define MCLK_I2S9_8CH_RX 560 -#define CLK_I2S5_8CH_TX_SRC 561 -#define CLK_I2S5_8CH_TX_FRAC 562 -#define CLK_I2S5_8CH_TX 563 -#define MCLK_I2S5_8CH_TX 564 -#define HCLK_I2S5_8CH 565 -#define CLK_I2S6_8CH_TX_SRC 566 -#define CLK_I2S6_8CH_TX_FRAC 567 -#define CLK_I2S6_8CH_TX 568 -#define MCLK_I2S6_8CH_TX 569 -#define CLK_I2S6_8CH_RX_SRC 570 -#define CLK_I2S6_8CH_RX_FRAC 571 -#define CLK_I2S6_8CH_RX 572 -#define MCLK_I2S6_8CH_RX 573 -#define I2S6_8CH_MCLKOUT 574 -#define HCLK_I2S6_8CH 575 -#define HCLK_SPDIF3 576 -#define CLK_SPDIF3_SRC 577 -#define CLK_SPDIF3_FRAC 578 -#define CLK_SPDIF3 579 -#define MCLK_SPDIF3 580 -#define HCLK_SPDIF4 581 -#define CLK_SPDIF4_SRC 582 -#define CLK_SPDIF4_FRAC 583 -#define CLK_SPDIF4 584 -#define MCLK_SPDIF4 585 -#define HCLK_SPDIFRX0 586 -#define MCLK_SPDIFRX0 587 -#define HCLK_SPDIFRX1 588 -#define MCLK_SPDIFRX1 589 -#define HCLK_SPDIFRX2 590 -#define MCLK_SPDIFRX2 591 -#define ACLK_VO1USB_TOP_ROOT 592 -#define HCLK_VO1USB_TOP_ROOT 593 -#define CLK_HDMIHDP0 594 -#define CLK_HDMIHDP1 595 -#define PCLK_HDPTX0 596 -#define PCLK_HDPTX1 597 -#define PCLK_USBDPPHY0 598 -#define PCLK_USBDPPHY1 599 -#define ACLK_VOP_ROOT 600 -#define ACLK_VOP_LOW_ROOT 601 -#define HCLK_VOP_ROOT 602 -#define PCLK_VOP_ROOT 603 -#define HCLK_VOP 604 -#define ACLK_VOP 605 -#define DCLK_VOP0_SRC 606 -#define DCLK_VOP1_SRC 607 -#define DCLK_VOP2_SRC 608 -#define DCLK_VOP0 609 -#define DCLK_VOP1 610 -#define DCLK_VOP2 611 -#define DCLK_VOP3 612 -#define PCLK_DSIHOST0 613 -#define PCLK_DSIHOST1 614 -#define CLK_DSIHOST0 615 -#define CLK_DSIHOST1 616 -#define CLK_VOP_PMU 617 -#define ACLK_VOP_DOBY 618 -#define ACLK_VOP_SUB_SRC 619 -#define CLK_USBDP_PHY0_IMMORTAL 620 -#define CLK_USBDP_PHY1_IMMORTAL 621 -#define CLK_PMU0 622 -#define PCLK_PMU0 623 -#define PCLK_PMU0IOC 624 -#define PCLK_GPIO0 625 -#define DBCLK_GPIO0 626 -#define PCLK_I2C0 627 -#define CLK_I2C0 628 -#define HCLK_I2S1_8CH 629 -#define CLK_I2S1_8CH_TX_SRC 630 -#define CLK_I2S1_8CH_TX_FRAC 631 -#define CLK_I2S1_8CH_TX 632 -#define MCLK_I2S1_8CH_TX 633 -#define CLK_I2S1_8CH_RX_SRC 634 -#define CLK_I2S1_8CH_RX_FRAC 635 -#define CLK_I2S1_8CH_RX 636 -#define MCLK_I2S1_8CH_RX 637 -#define I2S1_8CH_MCLKOUT 638 -#define CLK_PMU1_50M_SRC 639 -#define CLK_PMU1_100M_SRC 640 -#define CLK_PMU1_200M_SRC 641 -#define CLK_PMU1_300M_SRC 642 -#define CLK_PMU1_400M_SRC 643 -#define HCLK_PMU1_ROOT 644 -#define PCLK_PMU1_ROOT 645 -#define PCLK_PMU0_ROOT 646 -#define HCLK_PMU_CM0_ROOT 647 -#define PCLK_PMU1 648 -#define CLK_DDR_FAIL_SAFE 649 -#define CLK_PMU1 650 -#define HCLK_PDM0 651 -#define MCLK_PDM0 652 -#define HCLK_VAD 653 -#define FCLK_PMU_CM0_CORE 654 -#define CLK_PMU_CM0_RTC 655 -#define PCLK_PMU1_IOC 656 -#define PCLK_PMU1PWM 657 -#define CLK_PMU1PWM 658 -#define CLK_PMU1PWM_CAPTURE 659 -#define PCLK_PMU1TIMER 660 -#define CLK_PMU1TIMER_ROOT 661 -#define CLK_PMU1TIMER0 662 -#define CLK_PMU1TIMER1 663 -#define CLK_UART0_SRC 664 -#define CLK_UART0_FRAC 665 -#define CLK_UART0 666 -#define SCLK_UART0 667 -#define PCLK_UART0 668 -#define PCLK_PMU1WDT 669 -#define TCLK_PMU1WDT 670 -#define CLK_CR_PARA 671 -#define CLK_USB2PHY_HDPTXRXPHY_REF 672 -#define CLK_USBDPPHY_MIPIDCPPHY_REF 673 -#define CLK_REF_PIPE_PHY0_OSC_SRC 674 -#define CLK_REF_PIPE_PHY1_OSC_SRC 675 -#define CLK_REF_PIPE_PHY2_OSC_SRC 676 -#define CLK_REF_PIPE_PHY0_PLL_SRC 677 -#define CLK_REF_PIPE_PHY1_PLL_SRC 678 -#define CLK_REF_PIPE_PHY2_PLL_SRC 679 -#define CLK_REF_PIPE_PHY0 680 -#define CLK_REF_PIPE_PHY1 681 -#define CLK_REF_PIPE_PHY2 682 -#define SCLK_SDIO_DRV 683 -#define SCLK_SDIO_SAMPLE 684 -#define SCLK_SDMMC_DRV 685 -#define SCLK_SDMMC_SAMPLE 686 -#define CLK_PCIE1L0_PIPE 687 -#define CLK_PCIE1L1_PIPE 688 -#define CLK_BIGCORE0_PVTM 689 -#define CLK_CORE_BIGCORE0_PVTM 690 -#define CLK_BIGCORE1_PVTM 691 -#define CLK_CORE_BIGCORE1_PVTM 692 -#define CLK_LITCORE_PVTM 693 -#define CLK_CORE_LITCORE_PVTM 694 -#define CLK_AUX16M_0 695 -#define CLK_AUX16M_1 696 -#define CLK_PHY0_REF_ALT_P 697 -#define CLK_PHY0_REF_ALT_M 698 -#define CLK_PHY1_REF_ALT_P 699 -#define CLK_PHY1_REF_ALT_M 700 -#define ACLK_ISP1_PRE 701 -#define HCLK_ISP1_PRE 702 -#define HCLK_NVM 703 -#define ACLK_USB 704 -#define HCLK_USB 705 -#define ACLK_JPEG_DECODER_PRE 706 -#define ACLK_VDPU_LOW_PRE 707 -#define ACLK_RKVENC1_PRE 708 -#define HCLK_RKVENC1_PRE 709 -#define HCLK_RKVDEC0_PRE 710 -#define ACLK_RKVDEC0_PRE 711 -#define HCLK_RKVDEC1_PRE 712 -#define ACLK_RKVDEC1_PRE 713 -#define ACLK_HDCP0_PRE 714 -#define HCLK_VO0 715 -#define ACLK_HDCP1_PRE 716 -#define HCLK_VO1 717 -#define ACLK_AV1_PRE 718 -#define PCLK_AV1_PRE 719 -#define HCLK_SDIO_PRE 720 - -#define CLK_NR_CLKS (HCLK_SDIO_PRE + 1) - -/* scmi-clocks indices */ - -#define SCMI_CLK_CPUL 0 -#define SCMI_CLK_DSU 1 -#define SCMI_CLK_CPUB01 2 -#define SCMI_CLK_CPUB23 3 -#define SCMI_CLK_DDR 4 -#define SCMI_CLK_GPU 5 -#define SCMI_CLK_NPU 6 -#define SCMI_CLK_SBUS 7 -#define SCMI_PCLK_SBUS 8 -#define SCMI_CCLK_SD 9 -#define SCMI_DCLK_SD 10 -#define SCMI_ACLK_SECURE_NS 11 -#define SCMI_HCLK_SECURE_NS 12 -#define SCMI_TCLK_WDT 13 -#define SCMI_KEYLADDER_CORE 14 -#define SCMI_KEYLADDER_RNG 15 -#define SCMI_ACLK_SECURE_S 16 -#define SCMI_HCLK_SECURE_S 17 -#define SCMI_PCLK_SECURE_S 18 -#define SCMI_CRYPTO_RNG 19 -#define SCMI_CRYPTO_CORE 20 -#define SCMI_CRYPTO_PKA 21 -#define SCMI_SPLL 22 -#define SCMI_HCLK_SD 23 - -#endif diff --git a/include/dt-bindings/clock/rockchip,rk808.h b/include/dt-bindings/clock/rockchip,rk808.h deleted file mode 100644 index 1a873432f965..000000000000 --- a/include/dt-bindings/clock/rockchip,rk808.h +++ /dev/null @@ -1,11 +0,0 @@ -/* - * This header provides constants clk index RK808 pmic clkout - */ -#ifndef _CLK_ROCKCHIP_RK808 -#define _CLK_ROCKCHIP_RK808 - -/* CLOCKOUT index */ -#define RK808_CLKOUT0 0 -#define RK808_CLKOUT1 1 - -#endif diff --git a/include/dt-bindings/clock/rockchip,rv1126-cru.h b/include/dt-bindings/clock/rockchip,rv1126-cru.h deleted file mode 100644 index e89a3a5a4a34..000000000000 --- a/include/dt-bindings/clock/rockchip,rv1126-cru.h +++ /dev/null @@ -1,632 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright (c) 2019 Rockchip Electronics Co. Ltd. - * Author: Finley Xiao finley.xiao@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H - -/* pmucru-clocks indices */ - -/* pll clocks */ -#define PLL_GPLL 1 - -/* sclk (special clocks) */ -#define CLK_OSC0_DIV32K 2 -#define CLK_RTC32K 3 -#define CLK_WIFI_DIV 4 -#define CLK_WIFI_OSC0 5 -#define CLK_WIFI 6 -#define CLK_PMU 7 -#define SCLK_UART1_DIV 8 -#define SCLK_UART1_FRACDIV 9 -#define SCLK_UART1_MUX 10 -#define SCLK_UART1 11 -#define CLK_I2C0 12 -#define CLK_I2C2 13 -#define CLK_CAPTURE_PWM0 14 -#define CLK_PWM0 15 -#define CLK_CAPTURE_PWM1 16 -#define CLK_PWM1 17 -#define CLK_SPI0 18 -#define DBCLK_GPIO0 19 -#define CLK_PMUPVTM 20 -#define CLK_CORE_PMUPVTM 21 -#define CLK_REF12M 22 -#define CLK_USBPHY_OTG_REF 23 -#define CLK_USBPHY_HOST_REF 24 -#define CLK_REF24M 25 -#define CLK_MIPIDSIPHY_REF 26 - -/* pclk */ -#define PCLK_PDPMU 30 -#define PCLK_PMU 31 -#define PCLK_UART1 32 -#define PCLK_I2C0 33 -#define PCLK_I2C2 34 -#define PCLK_PWM0 35 -#define PCLK_PWM1 36 -#define PCLK_SPI0 37 -#define PCLK_GPIO0 38 -#define PCLK_PMUSGRF 39 -#define PCLK_PMUGRF 40 -#define PCLK_PMUCRU 41 -#define PCLK_CHIPVEROTP 42 -#define PCLK_PDPMU_NIU 43 -#define PCLK_PMUPVTM 44 -#define PCLK_SCRKEYGEN 45 - -#define CLKPMU_NR_CLKS (PCLK_SCRKEYGEN + 1) - -/* cru-clocks indices */ - -/* pll clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_HPLL 4 - -/* sclk (special clocks) */ -#define ARMCLK 5 -#define USB480M 6 -#define CLK_CORE_CPUPVTM 7 -#define CLK_CPUPVTM 8 -#define CLK_SCR1 9 -#define CLK_SCR1_CORE 10 -#define CLK_SCR1_RTC 11 -#define CLK_SCR1_JTAG 12 -#define SCLK_UART0_DIV 13 -#define SCLK_UART0_FRAC 14 -#define SCLK_UART0_MUX 15 -#define SCLK_UART0 16 -#define SCLK_UART2_DIV 17 -#define SCLK_UART2_FRAC 18 -#define SCLK_UART2_MUX 19 -#define SCLK_UART2 20 -#define SCLK_UART3_DIV 21 -#define SCLK_UART3_FRAC 22 -#define SCLK_UART3_MUX 23 -#define SCLK_UART3 24 -#define SCLK_UART4_DIV 25 -#define SCLK_UART4_FRAC 26 -#define SCLK_UART4_MUX 27 -#define SCLK_UART4 28 -#define SCLK_UART5_DIV 29 -#define SCLK_UART5_FRAC 30 -#define SCLK_UART5_MUX 31 -#define SCLK_UART5 32 -#define CLK_I2C1 33 -#define CLK_I2C3 34 -#define CLK_I2C4 35 -#define CLK_I2C5 36 -#define CLK_SPI1 37 -#define CLK_CAPTURE_PWM2 38 -#define CLK_PWM2 39 -#define DBCLK_GPIO1 40 -#define DBCLK_GPIO2 41 -#define DBCLK_GPIO3 42 -#define DBCLK_GPIO4 43 -#define CLK_SARADC 44 -#define CLK_TIMER0 45 -#define CLK_TIMER1 46 -#define CLK_TIMER2 47 -#define CLK_TIMER3 48 -#define CLK_TIMER4 49 -#define CLK_TIMER5 50 -#define CLK_CAN 51 -#define CLK_NPU_TSADC 52 -#define CLK_NPU_TSADCPHY 53 -#define CLK_CPU_TSADC 54 -#define CLK_CPU_TSADCPHY 55 -#define CLK_CRYPTO_CORE 56 -#define CLK_CRYPTO_PKA 57 -#define MCLK_I2S0_TX_DIV 58 -#define MCLK_I2S0_TX_FRACDIV 59 -#define MCLK_I2S0_TX_MUX 60 -#define MCLK_I2S0_TX 61 -#define MCLK_I2S0_RX_DIV 62 -#define MCLK_I2S0_RX_FRACDIV 63 -#define MCLK_I2S0_RX_MUX 64 -#define MCLK_I2S0_RX 65 -#define MCLK_I2S0_TX_OUT2IO 66 -#define MCLK_I2S0_RX_OUT2IO 67 -#define MCLK_I2S1_DIV 68 -#define MCLK_I2S1_FRACDIV 69 -#define MCLK_I2S1_MUX 70 -#define MCLK_I2S1 71 -#define MCLK_I2S1_OUT2IO 72 -#define MCLK_I2S2_DIV 73 -#define MCLK_I2S2_FRACDIV 74 -#define MCLK_I2S2_MUX 75 -#define MCLK_I2S2 76 -#define MCLK_I2S2_OUT2IO 77 -#define MCLK_PDM 78 -#define SCLK_ADUPWM_DIV 79 -#define SCLK_AUDPWM_FRACDIV 80 -#define SCLK_AUDPWM_MUX 81 -#define SCLK_AUDPWM 82 -#define CLK_ACDCDIG_ADC 83 -#define CLK_ACDCDIG_DAC 84 -#define CLK_ACDCDIG_I2C 85 -#define CLK_VENC_CORE 86 -#define CLK_VDEC_CORE 87 -#define CLK_VDEC_CA 88 -#define CLK_VDEC_HEVC_CA 89 -#define CLK_RGA_CORE 90 -#define CLK_IEP_CORE 91 -#define CLK_ISP_DIV 92 -#define CLK_ISP_NP5 93 -#define CLK_ISP_NUX 94 -#define CLK_ISP 95 -#define CLK_CIF_OUT_DIV 96 -#define CLK_CIF_OUT_FRACDIV 97 -#define CLK_CIF_OUT_MUX 98 -#define CLK_CIF_OUT 99 -#define CLK_MIPICSI_OUT_DIV 100 -#define CLK_MIPICSI_OUT_FRACDIV 101 -#define CLK_MIPICSI_OUT_MUX 102 -#define CLK_MIPICSI_OUT 103 -#define CLK_ISPP_DIV 104 -#define CLK_ISPP_NP5 105 -#define CLK_ISPP_NUX 106 -#define CLK_ISPP 107 -#define CLK_SDMMC 108 -#define SCLK_SDMMC_DRV 109 -#define SCLK_SDMMC_SAMPLE 110 -#define CLK_SDIO 111 -#define SCLK_SDIO_DRV 112 -#define SCLK_SDIO_SAMPLE 113 -#define CLK_EMMC 114 -#define SCLK_EMMC_DRV 115 -#define SCLK_EMMC_SAMPLE 116 -#define CLK_NANDC 117 -#define SCLK_SFC 118 -#define CLK_USBHOST_UTMI_OHCI 119 -#define CLK_USBOTG_REF 120 -#define CLK_GMAC_DIV 121 -#define CLK_GMAC_RGMII_M0 122 -#define CLK_GMAC_SRC_M0 123 -#define CLK_GMAC_RGMII_M1 124 -#define CLK_GMAC_SRC_M1 125 -#define CLK_GMAC_SRC 126 -#define CLK_GMAC_REF 127 -#define CLK_GMAC_TX_SRC 128 -#define CLK_GMAC_TX_DIV5 129 -#define CLK_GMAC_TX_DIV50 130 -#define RGMII_MODE_CLK 131 -#define CLK_GMAC_RX_SRC 132 -#define CLK_GMAC_RX_DIV2 133 -#define CLK_GMAC_RX_DIV20 134 -#define RMII_MODE_CLK 135 -#define CLK_GMAC_TX_RX 136 -#define CLK_GMAC_PTPREF 137 -#define CLK_GMAC_ETHERNET_OUT 138 -#define CLK_DDRPHY 139 -#define CLK_DDR_MON 140 -#define TMCLK_DDR_MON 141 -#define CLK_NPU_DIV 142 -#define CLK_NPU_NP5 143 -#define CLK_CORE_NPU 144 -#define CLK_CORE_NPUPVTM 145 -#define CLK_NPUPVTM 146 -#define SCLK_DDRCLK 147 -#define CLK_OTP 148 - -/* dclk */ -#define DCLK_DECOM 150 -#define DCLK_VOP_DIV 151 -#define DCLK_VOP_FRACDIV 152 -#define DCLK_VOP_MUX 153 -#define DCLK_VOP 154 -#define DCLK_CIF 155 -#define DCLK_CIFLITE 156 - -/* aclk */ -#define ACLK_PDBUS 160 -#define ACLK_DMAC 161 -#define ACLK_DCF 162 -#define ACLK_SPINLOCK 163 -#define ACLK_DECOM 164 -#define ACLK_PDCRYPTO 165 -#define ACLK_CRYPTO 166 -#define ACLK_PDVEPU 167 -#define ACLK_VENC 168 -#define ACLK_PDVDEC 169 -#define ACLK_PDJPEG 170 -#define ACLK_VDEC 171 -#define ACLK_JPEG 172 -#define ACLK_PDVO 173 -#define ACLK_RGA 174 -#define ACLK_VOP 175 -#define ACLK_IEP 176 -#define ACLK_PDVI_DIV 177 -#define ACLK_PDVI_NP5 178 -#define ACLK_PDVI 179 -#define ACLK_ISP 180 -#define ACLK_CIF 181 -#define ACLK_CIFLITE 182 -#define ACLK_PDISPP_DIV 183 -#define ACLK_PDISPP_NP5 184 -#define ACLK_PDISPP 185 -#define ACLK_ISPP 186 -#define ACLK_PDPHP 187 -#define ACLK_PDUSB 188 -#define ACLK_USBOTG 189 -#define ACLK_PDGMAC 190 -#define ACLK_GMAC 191 -#define ACLK_PDNPU_DIV 192 -#define ACLK_PDNPU_NP5 193 -#define ACLK_PDNPU 194 -#define ACLK_NPU 195 - -/* hclk */ -#define HCLK_PDCORE_NIU 200 -#define HCLK_PDUSB 201 -#define HCLK_PDCRYPTO 202 -#define HCLK_CRYPTO 203 -#define HCLK_PDAUDIO 204 -#define HCLK_I2S0 205 -#define HCLK_I2S1 206 -#define HCLK_I2S2 207 -#define HCLK_PDM 208 -#define HCLK_AUDPWM 209 -#define HCLK_PDVEPU 210 -#define HCLK_VENC 211 -#define HCLK_PDVDEC 212 -#define HCLK_PDJPEG 213 -#define HCLK_VDEC 214 -#define HCLK_JPEG 215 -#define HCLK_PDVO 216 -#define HCLK_RGA 217 -#define HCLK_VOP 218 -#define HCLK_IEP 219 -#define HCLK_PDVI 220 -#define HCLK_ISP 221 -#define HCLK_CIF 222 -#define HCLK_CIFLITE 223 -#define HCLK_PDISPP 224 -#define HCLK_ISPP 225 -#define HCLK_PDPHP 226 -#define HCLK_PDSDMMC 227 -#define HCLK_SDMMC 228 -#define HCLK_PDSDIO 229 -#define HCLK_SDIO 230 -#define HCLK_PDNVM 231 -#define HCLK_EMMC 232 -#define HCLK_NANDC 233 -#define HCLK_SFC 234 -#define HCLK_SFCXIP 235 -#define HCLK_PDBUS 236 -#define HCLK_USBHOST 237 -#define HCLK_USBHOST_ARB 238 -#define HCLK_PDNPU 239 -#define HCLK_NPU 240 - -/* pclk */ -#define PCLK_CPUPVTM 245 -#define PCLK_PDBUS 246 -#define PCLK_DCF 247 -#define PCLK_WDT 248 -#define PCLK_MAILBOX 249 -#define PCLK_UART0 250 -#define PCLK_UART2 251 -#define PCLK_UART3 252 -#define PCLK_UART4 253 -#define PCLK_UART5 254 -#define PCLK_I2C1 255 -#define PCLK_I2C3 256 -#define PCLK_I2C4 257 -#define PCLK_I2C5 258 -#define PCLK_SPI1 259 -#define PCLK_PWM2 261 -#define PCLK_GPIO1 262 -#define PCLK_GPIO2 263 -#define PCLK_GPIO3 264 -#define PCLK_GPIO4 265 -#define PCLK_SARADC 266 -#define PCLK_TIMER 267 -#define PCLK_DECOM 268 -#define PCLK_CAN 269 -#define PCLK_NPU_TSADC 270 -#define PCLK_CPU_TSADC 271 -#define PCLK_ACDCDIG 272 -#define PCLK_PDVO 273 -#define PCLK_DSIHOST 274 -#define PCLK_PDVI 275 -#define PCLK_CSIHOST 276 -#define PCLK_PDGMAC 277 -#define PCLK_GMAC 278 -#define PCLK_PDDDR 279 -#define PCLK_DDR_MON 280 -#define PCLK_PDNPU 281 -#define PCLK_NPUPVTM 282 -#define PCLK_PDTOP 283 -#define PCLK_TOPCRU 284 -#define PCLK_TOPGRF 285 -#define PCLK_CPUEMADET 286 -#define PCLK_DDRPHY 287 -#define PCLK_DSIPHY 289 -#define PCLK_CSIPHY0 290 -#define PCLK_CSIPHY1 291 -#define PCLK_USBPHY_HOST 292 -#define PCLK_USBPHY_OTG 293 -#define PCLK_OTP 294 - -#define CLK_NR_CLKS (PCLK_OTP + 1) - -/* pmu soft-reset indices */ - -/* pmu_cru_softrst_con0 */ -#define SRST_PDPMU_NIU_P 0 -#define SRST_PMU_SGRF_P 1 -#define SRST_PMU_SGRF_REMAP_P 2 -#define SRST_I2C0_P 3 -#define SRST_I2C0 4 -#define SRST_I2C2_P 7 -#define SRST_I2C2 8 -#define SRST_UART1_P 9 -#define SRST_UART1 10 -#define SRST_PWM0_P 11 -#define SRST_PWM0 12 -#define SRST_PWM1_P 13 -#define SRST_PWM1 14 -#define SRST_DDR_FAIL_SAFE 15 - -/* pmu_cru_softrst_con1 */ -#define SRST_GPIO0_P 17 -#define SRST_GPIO0_DB 18 -#define SRST_SPI0_P 19 -#define SRST_SPI0 20 -#define SRST_PMUGRF_P 21 -#define SRST_CHIPVEROTP_P 22 -#define SRST_PMUPVTM 24 -#define SRST_PMUPVTM_P 25 -#define SRST_PMUCRU_P 30 - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_NL2 12 -#define SRST_CORE_NIU_A 13 -#define SRST_DBG_DAPLITE_P 14 -#define SRST_DAPLITE_P 15 - -/* cru_softrst_con1 */ -#define SRST_PDBUS_NIU1_A 16 -#define SRST_PDBUS_NIU1_H 17 -#define SRST_PDBUS_NIU1_P 18 -#define SRST_PDBUS_NIU2_A 19 -#define SRST_PDBUS_NIU2_H 20 -#define SRST_PDBUS_NIU3_A 21 -#define SRST_PDBUS_NIU3_H 22 -#define SRST_PDBUS_HOLD_NIU1_A 23 -#define SRST_DBG_NIU_P 24 -#define SRST_PDCORE_NIIU_H 25 -#define SRST_MUC_NIU 26 -#define SRST_DCF_A 29 -#define SRST_DCF_P 30 -#define SRST_SYSTEM_SRAM_A 31 - -/* cru_softrst_con2 */ -#define SRST_I2C1_P 32 -#define SRST_I2C1 33 -#define SRST_I2C3_P 34 -#define SRST_I2C3 35 -#define SRST_I2C4_P 36 -#define SRST_I2C4 37 -#define SRST_I2C5_P 38 -#define SRST_I2C5 39 -#define SRST_SPI1_P 40 -#define SRST_SPI1 41 -#define SRST_MCU_CORE 42 -#define SRST_PWM2_P 44 -#define SRST_PWM2 45 -#define SRST_SPINLOCK_A 46 - -/* cru_softrst_con3 */ -#define SRST_UART0_P 48 -#define SRST_UART0 49 -#define SRST_UART2_P 50 -#define SRST_UART2 51 -#define SRST_UART3_P 52 -#define SRST_UART3 53 -#define SRST_UART4_P 54 -#define SRST_UART4 55 -#define SRST_UART5_P 56 -#define SRST_UART5 57 -#define SRST_WDT_P 58 -#define SRST_SARADC_P 59 -#define SRST_GRF_P 61 -#define SRST_TIMER_P 62 -#define SRST_MAILBOX_P 63 - -/* cru_softrst_con4 */ -#define SRST_TIMER0 64 -#define SRST_TIMER1 65 -#define SRST_TIMER2 66 -#define SRST_TIMER3 67 -#define SRST_TIMER4 68 -#define SRST_TIMER5 69 -#define SRST_INTMUX_P 70 -#define SRST_GPIO1_P 72 -#define SRST_GPIO1_DB 73 -#define SRST_GPIO2_P 74 -#define SRST_GPIO2_DB 75 -#define SRST_GPIO3_P 76 -#define SRST_GPIO3_DB 77 -#define SRST_GPIO4_P 78 -#define SRST_GPIO4_DB 79 - -/* cru_softrst_con5 */ -#define SRST_CAN_P 80 -#define SRST_CAN 81 -#define SRST_DECOM_A 85 -#define SRST_DECOM_P 86 -#define SRST_DECOM_D 87 -#define SRST_PDCRYPTO_NIU_A 88 -#define SRST_PDCRYPTO_NIU_H 89 -#define SRST_CRYPTO_A 90 -#define SRST_CRYPTO_H 91 -#define SRST_CRYPTO_CORE 92 -#define SRST_CRYPTO_PKA 93 -#define SRST_SGRF_P 95 - -/* cru_softrst_con6 */ -#define SRST_PDAUDIO_NIU_H 96 -#define SRST_PDAUDIO_NIU_P 97 -#define SRST_I2S0_H 98 -#define SRST_I2S0_TX_M 99 -#define SRST_I2S0_RX_M 100 -#define SRST_I2S1_H 101 -#define SRST_I2S1_M 102 -#define SRST_I2S2_H 103 -#define SRST_I2S2_M 104 -#define SRST_PDM_H 105 -#define SRST_PDM_M 106 -#define SRST_AUDPWM_H 107 -#define SRST_AUDPWM 108 -#define SRST_ACDCDIG_P 109 -#define SRST_ACDCDIG 110 - -/* cru_softrst_con7 */ -#define SRST_PDVEPU_NIU_A 112 -#define SRST_PDVEPU_NIU_H 113 -#define SRST_VENC_A 114 -#define SRST_VENC_H 115 -#define SRST_VENC_CORE 116 -#define SRST_PDVDEC_NIU_A 117 -#define SRST_PDVDEC_NIU_H 118 -#define SRST_VDEC_A 119 -#define SRST_VDEC_H 120 -#define SRST_VDEC_CORE 121 -#define SRST_VDEC_CA 122 -#define SRST_VDEC_HEVC_CA 123 -#define SRST_PDJPEG_NIU_A 124 -#define SRST_PDJPEG_NIU_H 125 -#define SRST_JPEG_A 126 -#define SRST_JPEG_H 127 - -/* cru_softrst_con8 */ -#define SRST_PDVO_NIU_A 128 -#define SRST_PDVO_NIU_H 129 -#define SRST_PDVO_NIU_P 130 -#define SRST_RGA_A 131 -#define SRST_RGA_H 132 -#define SRST_RGA_CORE 133 -#define SRST_VOP_A 134 -#define SRST_VOP_H 135 -#define SRST_VOP_D 136 -#define SRST_TXBYTEHS_DSIHOST 137 -#define SRST_DSIHOST_P 138 -#define SRST_IEP_A 139 -#define SRST_IEP_H 140 -#define SRST_IEP_CORE 141 -#define SRST_ISP_RX_P 142 - -/* cru_softrst_con9 */ -#define SRST_PDVI_NIU_A 144 -#define SRST_PDVI_NIU_H 145 -#define SRST_PDVI_NIU_P 146 -#define SRST_ISP 147 -#define SRST_CIF_A 148 -#define SRST_CIF_H 149 -#define SRST_CIF_D 150 -#define SRST_CIF_P 151 -#define SRST_CIF_I 152 -#define SRST_CIF_RX_P 153 -#define SRST_PDISPP_NIU_A 154 -#define SRST_PDISPP_NIU_H 155 -#define SRST_ISPP_A 156 -#define SRST_ISPP_H 157 -#define SRST_ISPP 158 -#define SRST_CSIHOST_P 159 - -/* cru_softrst_con10 */ -#define SRST_PDPHPMID_NIU_A 160 -#define SRST_PDPHPMID_NIU_H 161 -#define SRST_PDNVM_NIU_H 163 -#define SRST_SDMMC_H 164 -#define SRST_SDIO_H 165 -#define SRST_EMMC_H 166 -#define SRST_SFC_H 167 -#define SRST_SFCXIP_H 168 -#define SRST_SFC 169 -#define SRST_NANDC_H 170 -#define SRST_NANDC 171 -#define SRST_PDSDMMC_H 173 -#define SRST_PDSDIO_H 174 - -/* cru_softrst_con11 */ -#define SRST_PDUSB_NIU_A 176 -#define SRST_PDUSB_NIU_H 177 -#define SRST_USBHOST_H 178 -#define SRST_USBHOST_ARB_H 179 -#define SRST_USBHOST_UTMI 180 -#define SRST_USBOTG_A 181 -#define SRST_USBPHY_OTG_P 182 -#define SRST_USBPHY_HOST_P 183 -#define SRST_USBPHYPOR_OTG 184 -#define SRST_USBPHYPOR_HOST 185 -#define SRST_PDGMAC_NIU_A 188 -#define SRST_PDGMAC_NIU_P 189 -#define SRST_GMAC_A 190 - -/* cru_softrst_con12 */ -#define SRST_DDR_DFICTL_P 193 -#define SRST_DDR_MON_P 194 -#define SRST_DDR_STANDBY_P 195 -#define SRST_DDR_GRF_P 196 -#define SRST_DDR_MSCH_P 197 -#define SRST_DDR_SPLIT_A 198 -#define SRST_DDR_MSCH 199 -#define SRST_DDR_DFICTL 202 -#define SRST_DDR_STANDBY 203 -#define SRST_NPUMCU_NIU 205 -#define SRST_DDRPHY_P 206 -#define SRST_DDRPHY 207 - -/* cru_softrst_con13 */ -#define SRST_PDNPU_NIU_A 208 -#define SRST_PDNPU_NIU_H 209 -#define SRST_PDNPU_NIU_P 210 -#define SRST_NPU_A 211 -#define SRST_NPU_H 212 -#define SRST_NPU 213 -#define SRST_NPUPVTM_P 214 -#define SRST_NPUPVTM 215 -#define SRST_NPU_TSADC_P 216 -#define SRST_NPU_TSADC 217 -#define SRST_NPU_TSADCPHY 218 -#define SRST_CIFLITE_A 220 -#define SRST_CIFLITE_H 221 -#define SRST_CIFLITE_D 222 -#define SRST_CIFLITE_RX_P 223 - -/* cru_softrst_con14 */ -#define SRST_TOPNIU_P 224 -#define SRST_TOPCRU_P 225 -#define SRST_TOPGRF_P 226 -#define SRST_CPUEMADET_P 227 -#define SRST_CSIPHY0_P 228 -#define SRST_CSIPHY1_P 229 -#define SRST_DSIPHY_P 230 -#define SRST_CPU_TSADC_P 232 -#define SRST_CPU_TSADC 233 -#define SRST_CPU_TSADCPHY 234 -#define SRST_CPUPVTM_P 235 -#define SRST_CPUPVTM 236 - -#endif
Drop in favour of dts/upstream.
Small driver adjustment to fix compatibility, adjusted rk3368-sheep.dts to replace some GPIO defines with literals.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/rk3368-sheep.dts | 8 +- drivers/pinctrl/rockchip/pinctrl-rk3568.c | 186 +++--- include/dt-bindings/pinctrl/rockchip.h | 60 -- include/dt-bindings/power/px30-power.h | 27 - include/dt-bindings/power/rk3066-power.h | 22 - include/dt-bindings/power/rk3188-power.h | 24 - include/dt-bindings/power/rk3228-power.h | 21 - include/dt-bindings/power/rk3288-power.h | 32 - include/dt-bindings/power/rk3328-power.h | 19 - include/dt-bindings/power/rk3399-power.h | 53 -- include/dt-bindings/power/rk3568-power.h | 32 - include/dt-bindings/power/rk3588-power.h | 69 -- include/dt-bindings/power/rockchip,rv1126-power.h | 35 - include/dt-bindings/reset/rockchip,rk3588-cru.h | 754 ---------------------- include/dt-bindings/soc/rockchip,boot-mode.h | 16 - include/dt-bindings/soc/rockchip,vop2.h | 18 - 16 files changed, 97 insertions(+), 1279 deletions(-)
diff --git a/arch/arm/dts/rk3368-sheep.dts b/arch/arm/dts/rk3368-sheep.dts index 120dec1a3de9..03fb4c3e8f8b 100644 --- a/arch/arm/dts/rk3368-sheep.dts +++ b/arch/arm/dts/rk3368-sheep.dts @@ -237,25 +237,25 @@
&pinctrl { ir { ir_int: ir-int { - rockchip,pins = <3 30 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <3 30 0 &pcfg_pull_none>; }; };
keys { pwr_key: pwr-key { - rockchip,pins = <0 2 RK_FUNC_GPIO &pcfg_pull_none>; + rockchip,pins = <0 2 0 &pcfg_pull_none>; }; };
pmic { pmic_sleep: pmic-sleep { - rockchip,pins = <0 0 RK_FUNC_2 &pcfg_pull_none>; + rockchip,pins = <0 0 2 &pcfg_pull_none>; };
pmic_int: pmic-int { - rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + rockchip,pins = <0 5 0 &pcfg_pull_up>; }; }; };
diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3568.c b/drivers/pinctrl/rockchip/pinctrl-rk3568.c index 1d4391982605..6a49f02ee3be 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3568.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3568.c @@ -12,101 +12,101 @@
#include "pinctrl-rockchip.h"
static struct rockchip_mux_route_data rk3568_mux_route_data[] = { - MR_PMUGRF(RK_GPIO0, RK_PB7, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(1, 0, 0)), /* PWM0 IO mux selection M0 */ - MR_PMUGRF(RK_GPIO0, RK_PC7, RK_FUNC_2, 0x0110, RK_GENMASK_VAL(1, 0, 1)), /* PWM0 IO mux selection M1 */ - MR_PMUGRF(RK_GPIO0, RK_PC0, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(3, 2, 0)), /* PWM1 IO mux selection M0 */ - MR_PMUGRF(RK_GPIO0, RK_PB5, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(3, 2, 1)), /* PWM1 IO mux selection M1 */ - MR_PMUGRF(RK_GPIO0, RK_PC1, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(5, 4, 0)), /* PWM2 IO mux selection M0 */ - MR_PMUGRF(RK_GPIO0, RK_PB6, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(5, 4, 1)), /* PWM2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO0, RK_PB3, RK_FUNC_2, 0x0300, RK_GENMASK_VAL(0, 0, 0)), /* CAN0 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_4, 0x0300, RK_GENMASK_VAL(0, 0, 1)), /* CAN0 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(2, 2, 0)), /* CAN1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC3, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(2, 2, 1)), /* CAN1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PB5, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(4, 4, 0)), /* CAN2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PB2, RK_FUNC_4, 0x0300, RK_GENMASK_VAL(4, 4, 1)), /* CAN2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PC4, RK_FUNC_1, 0x0300, RK_GENMASK_VAL(6, 6, 0)), /* EDPDP_HPDIN IO mux selection M0 */ - MR_TOPGRF(RK_GPIO0, RK_PC2, RK_FUNC_2, 0x0300, RK_GENMASK_VAL(6, 6, 1)), /* EDPDP_HPDIN IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB1, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(8, 8, 0)), /* GMAC1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PA7, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(8, 8, 1)), /* GMAC1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PD1, RK_FUNC_1, 0x0300, RK_GENMASK_VAL(10, 10, 0)), /* HDMITX IO mux selection M0 */ - MR_TOPGRF(RK_GPIO0, RK_PC7, RK_FUNC_1, 0x0300, RK_GENMASK_VAL(10, 10, 1)), /* HDMITX IO mux selection M1 */ - MR_TOPGRF(RK_GPIO0, RK_PB6, RK_FUNC_1, 0x0300, RK_GENMASK_VAL(14, 14, 0)), /* I2C2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PB4, RK_FUNC_1, 0x0300, RK_GENMASK_VAL(14, 14, 1)), /* I2C2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA0, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(0, 0, 0)), /* I2C3 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PB6, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(0, 0, 1)), /* I2C3 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PB2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(2, 2, 0)), /* I2C4 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PB1, RK_FUNC_2, 0x0304, RK_GENMASK_VAL(2, 2, 1)), /* I2C4 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB4, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(4, 4, 0)), /* I2C5 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PD0, RK_FUNC_2, 0x0304, RK_GENMASK_VAL(4, 4, 1)), /* I2C5 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB1, RK_FUNC_5, 0x0304, RK_GENMASK_VAL(14, 14, 0)), /* PWM8 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(14, 14, 1)), /* PWM8 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB2, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(0, 0, 0)), /* PWM9 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO1, RK_PD6, RK_FUNC_4, 0x0308, RK_GENMASK_VAL(0, 0, 1)), /* PWM9 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(2, 2, 0)), /* PWM10 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(2, 2, 1)), /* PWM10 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB6, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(4, 4, 0)), /* PWM11 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC0, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(4, 4, 1)), /* PWM11 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PB7, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(6, 6, 0)), /* PWM12 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(6, 6, 1)), /* PWM12 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PC0, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(8, 8, 0)), /* PWM13 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC6, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(8, 8, 1)), /* PWM13 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 0)), /* PWM14 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 1)), /* PWM14 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 0)), /* PWM15 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC3, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 1)), /* PWM15 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(14, 14, 0)), /* SDMMC2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PA5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(14, 14, 1)), /* SDMMC2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO0, RK_PB5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(0, 0, 0)), /* SPI0 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PD3, RK_FUNC_3, 0x030c, RK_GENMASK_VAL(0, 0, 1)), /* SPI0 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PB5, RK_FUNC_3, 0x030c, RK_GENMASK_VAL(2, 2, 0)), /* SPI1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PC3, RK_FUNC_3, 0x030c, RK_GENMASK_VAL(2, 2, 1)), /* SPI1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PC1, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(4, 4, 0)), /* SPI2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PA0, RK_FUNC_3, 0x030c, RK_GENMASK_VAL(4, 4, 1)), /* SPI2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PB3, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(6, 6, 0)), /* SPI3 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(6, 6, 1)), /* SPI3 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PB4, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(8, 8, 0)), /* UART1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(8, 8, 1)), /* UART1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO0, RK_PD1, RK_FUNC_1, 0x030c, RK_GENMASK_VAL(10, 10, 0)), /* UART2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(10, 10, 1)), /* UART2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(12, 12, 0)), /* UART3 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PB7, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(12, 12, 1)), /* UART3 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA6, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(14, 14, 0)), /* UART4 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PB2, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(14, 14, 1)), /* UART4 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PA2, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(0, 0, 0)), /* UART5 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PC2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(0, 0, 1)), /* UART5 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PA4, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(2, 2, 0)), /* UART6 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(2, 2, 1)), /* UART6 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PA6, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(5, 4, 0)), /* UART7 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(5, 4, 1)), /* UART7 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PA2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(5, 4, 2)), /* UART7 IO mux selection M2 */ - MR_TOPGRF(RK_GPIO2, RK_PC5, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(6, 6, 0)), /* UART8 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PD7, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(6, 6, 1)), /* UART8 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PB0, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(9, 8, 0)), /* UART9 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC5, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(9, 8, 1)), /* UART9 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PA4, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(9, 8, 2)), /* UART9 IO mux selection M2 */ - MR_TOPGRF(RK_GPIO1, RK_PA2, RK_FUNC_1, 0x0310, RK_GENMASK_VAL(11, 10, 0)), /* I2S1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PC6, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(11, 10, 1)), /* I2S1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO2, RK_PD0, RK_FUNC_5, 0x0310, RK_GENMASK_VAL(11, 10, 2)), /* I2S1 IO mux selection M2 */ - MR_TOPGRF(RK_GPIO2, RK_PC1, RK_FUNC_1, 0x0310, RK_GENMASK_VAL(12, 12, 0)), /* I2S2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PB6, RK_FUNC_5, 0x0310, RK_GENMASK_VAL(12, 12, 1)), /* I2S2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PA2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(14, 14, 0)), /* I2S3 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_5, 0x0310, RK_GENMASK_VAL(14, 14, 1)), /* I2S3 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA4, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ - MR_TOPGRF(RK_GPIO1, RK_PA6, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PA0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 2)), /* PDM IO mux selection M2 */ - MR_TOPGRF(RK_GPIO0, RK_PA5, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(3, 2, 0)), /* PCIE20 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PD0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 1)), /* PCIE20 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PB0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 2)), /* PCIE20 IO mux selection M2 */ - MR_TOPGRF(RK_GPIO0, RK_PA4, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(5, 4, 0)), /* PCIE30X1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PD2, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(5, 4, 1)), /* PCIE30X1 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA5, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(5, 4, 2)), /* PCIE30X1 IO mux selection M2 */ - MR_TOPGRF(RK_GPIO0, RK_PA6, RK_FUNC_2, 0x0314, RK_GENMASK_VAL(7, 6, 0)), /* PCIE30X2 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO2, RK_PD4, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(7, 6, 1)), /* PCIE30X2 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(7, 6, 2)), /* PCIE30X2 IO mux selection M2 */ + MR_PMUGRF(0, RK_PB7, 1, 0x0110, RK_GENMASK_VAL(1, 0, 0)), /* PWM0 IO mux selection M0 */ + MR_PMUGRF(0, RK_PC7, 2, 0x0110, RK_GENMASK_VAL(1, 0, 1)), /* PWM0 IO mux selection M1 */ + MR_PMUGRF(0, RK_PC0, 1, 0x0110, RK_GENMASK_VAL(3, 2, 0)), /* PWM1 IO mux selection M0 */ + MR_PMUGRF(0, RK_PB5, 4, 0x0110, RK_GENMASK_VAL(3, 2, 1)), /* PWM1 IO mux selection M1 */ + MR_PMUGRF(0, RK_PC1, 1, 0x0110, RK_GENMASK_VAL(5, 4, 0)), /* PWM2 IO mux selection M0 */ + MR_PMUGRF(0, RK_PB6, 4, 0x0110, RK_GENMASK_VAL(5, 4, 1)), /* PWM2 IO mux selection M1 */ + MR_TOPGRF(0, RK_PB3, 2, 0x0300, RK_GENMASK_VAL(0, 0, 0)), /* CAN0 IO mux selection M0 */ + MR_TOPGRF(2, RK_PA1, 4, 0x0300, RK_GENMASK_VAL(0, 0, 1)), /* CAN0 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA1, 3, 0x0300, RK_GENMASK_VAL(2, 2, 0)), /* CAN1 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC3, 3, 0x0300, RK_GENMASK_VAL(2, 2, 1)), /* CAN1 IO mux selection M1 */ + MR_TOPGRF(4, RK_PB5, 3, 0x0300, RK_GENMASK_VAL(4, 4, 0)), /* CAN2 IO mux selection M0 */ + MR_TOPGRF(2, RK_PB2, 4, 0x0300, RK_GENMASK_VAL(4, 4, 1)), /* CAN2 IO mux selection M1 */ + MR_TOPGRF(4, RK_PC4, 1, 0x0300, RK_GENMASK_VAL(6, 6, 0)), /* EDPDP_HPDIN IO mux selection M0 */ + MR_TOPGRF(0, RK_PC2, 2, 0x0300, RK_GENMASK_VAL(6, 6, 1)), /* EDPDP_HPDIN IO mux selection M1 */ + MR_TOPGRF(3, RK_PB1, 3, 0x0300, RK_GENMASK_VAL(8, 8, 0)), /* GMAC1 IO mux selection M0 */ + MR_TOPGRF(4, RK_PA7, 3, 0x0300, RK_GENMASK_VAL(8, 8, 1)), /* GMAC1 IO mux selection M1 */ + MR_TOPGRF(4, RK_PD1, 1, 0x0300, RK_GENMASK_VAL(10, 10, 0)), /* HDMITX IO mux selection M0 */ + MR_TOPGRF(0, RK_PC7, 1, 0x0300, RK_GENMASK_VAL(10, 10, 1)), /* HDMITX IO mux selection M1 */ + MR_TOPGRF(0, RK_PB6, 1, 0x0300, RK_GENMASK_VAL(14, 14, 0)), /* I2C2 IO mux selection M0 */ + MR_TOPGRF(4, RK_PB4, 1, 0x0300, RK_GENMASK_VAL(14, 14, 1)), /* I2C2 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA0, 1, 0x0304, RK_GENMASK_VAL(0, 0, 0)), /* I2C3 IO mux selection M0 */ + MR_TOPGRF(3, RK_PB6, 4, 0x0304, RK_GENMASK_VAL(0, 0, 1)), /* I2C3 IO mux selection M1 */ + MR_TOPGRF(4, RK_PB2, 1, 0x0304, RK_GENMASK_VAL(2, 2, 0)), /* I2C4 IO mux selection M0 */ + MR_TOPGRF(2, RK_PB1, 2, 0x0304, RK_GENMASK_VAL(2, 2, 1)), /* I2C4 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB4, 4, 0x0304, RK_GENMASK_VAL(4, 4, 0)), /* I2C5 IO mux selection M0 */ + MR_TOPGRF(4, RK_PD0, 2, 0x0304, RK_GENMASK_VAL(4, 4, 1)), /* I2C5 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB1, 5, 0x0304, RK_GENMASK_VAL(14, 14, 0)), /* PWM8 IO mux selection M0 */ + MR_TOPGRF(1, RK_PD5, 4, 0x0304, RK_GENMASK_VAL(14, 14, 1)), /* PWM8 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB2, 5, 0x0308, RK_GENMASK_VAL(0, 0, 0)), /* PWM9 IO mux selection M0 */ + MR_TOPGRF(1, RK_PD6, 4, 0x0308, RK_GENMASK_VAL(0, 0, 1)), /* PWM9 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB5, 5, 0x0308, RK_GENMASK_VAL(2, 2, 0)), /* PWM10 IO mux selection M0 */ + MR_TOPGRF(2, RK_PA1, 2, 0x0308, RK_GENMASK_VAL(2, 2, 1)), /* PWM10 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB6, 5, 0x0308, RK_GENMASK_VAL(4, 4, 0)), /* PWM11 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC0, 3, 0x0308, RK_GENMASK_VAL(4, 4, 1)), /* PWM11 IO mux selection M1 */ + MR_TOPGRF(3, RK_PB7, 2, 0x0308, RK_GENMASK_VAL(6, 6, 0)), /* PWM12 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC5, 1, 0x0308, RK_GENMASK_VAL(6, 6, 1)), /* PWM12 IO mux selection M1 */ + MR_TOPGRF(3, RK_PC0, 2, 0x0308, RK_GENMASK_VAL(8, 8, 0)), /* PWM13 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC6, 1, 0x0308, RK_GENMASK_VAL(8, 8, 1)), /* PWM13 IO mux selection M1 */ + MR_TOPGRF(3, RK_PC4, 1, 0x0308, RK_GENMASK_VAL(10, 10, 0)), /* PWM14 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC2, 1, 0x0308, RK_GENMASK_VAL(10, 10, 1)), /* PWM14 IO mux selection M1 */ + MR_TOPGRF(3, RK_PC5, 1, 0x0308, RK_GENMASK_VAL(12, 12, 0)), /* PWM15 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC3, 1, 0x0308, RK_GENMASK_VAL(12, 12, 1)), /* PWM15 IO mux selection M1 */ + MR_TOPGRF(3, RK_PD2, 3, 0x0308, RK_GENMASK_VAL(14, 14, 0)), /* SDMMC2 IO mux selection M0 */ + MR_TOPGRF(3, RK_PA5, 5, 0x0308, RK_GENMASK_VAL(14, 14, 1)), /* SDMMC2 IO mux selection M1 */ + MR_TOPGRF(0, RK_PB5, 2, 0x030c, RK_GENMASK_VAL(0, 0, 0)), /* SPI0 IO mux selection M0 */ + MR_TOPGRF(2, RK_PD3, 3, 0x030c, RK_GENMASK_VAL(0, 0, 1)), /* SPI0 IO mux selection M1 */ + MR_TOPGRF(2, RK_PB5, 3, 0x030c, RK_GENMASK_VAL(2, 2, 0)), /* SPI1 IO mux selection M0 */ + MR_TOPGRF(3, RK_PC3, 3, 0x030c, RK_GENMASK_VAL(2, 2, 1)), /* SPI1 IO mux selection M1 */ + MR_TOPGRF(2, RK_PC1, 4, 0x030c, RK_GENMASK_VAL(4, 4, 0)), /* SPI2 IO mux selection M0 */ + MR_TOPGRF(3, RK_PA0, 3, 0x030c, RK_GENMASK_VAL(4, 4, 1)), /* SPI2 IO mux selection M1 */ + MR_TOPGRF(4, RK_PB3, 4, 0x030c, RK_GENMASK_VAL(6, 6, 0)), /* SPI3 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC2, 2, 0x030c, RK_GENMASK_VAL(6, 6, 1)), /* SPI3 IO mux selection M1 */ + MR_TOPGRF(2, RK_PB4, 2, 0x030c, RK_GENMASK_VAL(8, 8, 0)), /* UART1 IO mux selection M0 */ + MR_TOPGRF(3, RK_PD6, 4, 0x030c, RK_GENMASK_VAL(8, 8, 1)), /* UART1 IO mux selection M1 */ + MR_TOPGRF(0, RK_PD1, 1, 0x030c, RK_GENMASK_VAL(10, 10, 0)), /* UART2 IO mux selection M0 */ + MR_TOPGRF(1, RK_PD5, 2, 0x030c, RK_GENMASK_VAL(10, 10, 1)), /* UART2 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA1, 2, 0x030c, RK_GENMASK_VAL(12, 12, 0)), /* UART3 IO mux selection M0 */ + MR_TOPGRF(3, RK_PB7, 4, 0x030c, RK_GENMASK_VAL(12, 12, 1)), /* UART3 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA6, 2, 0x030c, RK_GENMASK_VAL(14, 14, 0)), /* UART4 IO mux selection M0 */ + MR_TOPGRF(3, RK_PB2, 4, 0x030c, RK_GENMASK_VAL(14, 14, 1)), /* UART4 IO mux selection M1 */ + MR_TOPGRF(2, RK_PA2, 3, 0x0310, RK_GENMASK_VAL(0, 0, 0)), /* UART5 IO mux selection M0 */ + MR_TOPGRF(3, RK_PC2, 4, 0x0310, RK_GENMASK_VAL(0, 0, 1)), /* UART5 IO mux selection M1 */ + MR_TOPGRF(2, RK_PA4, 3, 0x0310, RK_GENMASK_VAL(2, 2, 0)), /* UART6 IO mux selection M0 */ + MR_TOPGRF(1, RK_PD5, 3, 0x0310, RK_GENMASK_VAL(2, 2, 1)), /* UART6 IO mux selection M1 */ + MR_TOPGRF(2, RK_PA6, 3, 0x0310, RK_GENMASK_VAL(5, 4, 0)), /* UART7 IO mux selection M0 */ + MR_TOPGRF(3, RK_PC4, 4, 0x0310, RK_GENMASK_VAL(5, 4, 1)), /* UART7 IO mux selection M1 */ + MR_TOPGRF(4, RK_PA2, 4, 0x0310, RK_GENMASK_VAL(5, 4, 2)), /* UART7 IO mux selection M2 */ + MR_TOPGRF(2, RK_PC5, 3, 0x0310, RK_GENMASK_VAL(6, 6, 0)), /* UART8 IO mux selection M0 */ + MR_TOPGRF(2, RK_PD7, 4, 0x0310, RK_GENMASK_VAL(6, 6, 1)), /* UART8 IO mux selection M1 */ + MR_TOPGRF(2, RK_PB0, 3, 0x0310, RK_GENMASK_VAL(9, 8, 0)), /* UART9 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC5, 4, 0x0310, RK_GENMASK_VAL(9, 8, 1)), /* UART9 IO mux selection M1 */ + MR_TOPGRF(4, RK_PA4, 4, 0x0310, RK_GENMASK_VAL(9, 8, 2)), /* UART9 IO mux selection M2 */ + MR_TOPGRF(1, RK_PA2, 1, 0x0310, RK_GENMASK_VAL(11, 10, 0)), /* I2S1 IO mux selection M0 */ + MR_TOPGRF(3, RK_PC6, 4, 0x0310, RK_GENMASK_VAL(11, 10, 1)), /* I2S1 IO mux selection M1 */ + MR_TOPGRF(2, RK_PD0, 5, 0x0310, RK_GENMASK_VAL(11, 10, 2)), /* I2S1 IO mux selection M2 */ + MR_TOPGRF(2, RK_PC1, 1, 0x0310, RK_GENMASK_VAL(12, 12, 0)), /* I2S2 IO mux selection M0 */ + MR_TOPGRF(4, RK_PB6, 5, 0x0310, RK_GENMASK_VAL(12, 12, 1)), /* I2S2 IO mux selection M1 */ + MR_TOPGRF(3, RK_PA2, 4, 0x0310, RK_GENMASK_VAL(14, 14, 0)), /* I2S3 IO mux selection M0 */ + MR_TOPGRF(4, RK_PC2, 5, 0x0310, RK_GENMASK_VAL(14, 14, 1)), /* I2S3 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA4, 3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ + MR_TOPGRF(1, RK_PA6, 3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ + MR_TOPGRF(3, RK_PD6, 5, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ + MR_TOPGRF(4, RK_PA0, 4, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ + MR_TOPGRF(3, RK_PC4, 5, 0x0314, RK_GENMASK_VAL(1, 0, 2)), /* PDM IO mux selection M2 */ + MR_TOPGRF(0, RK_PA5, 3, 0x0314, RK_GENMASK_VAL(3, 2, 0)), /* PCIE20 IO mux selection M0 */ + MR_TOPGRF(2, RK_PD0, 4, 0x0314, RK_GENMASK_VAL(3, 2, 1)), /* PCIE20 IO mux selection M1 */ + MR_TOPGRF(1, RK_PB0, 4, 0x0314, RK_GENMASK_VAL(3, 2, 2)), /* PCIE20 IO mux selection M2 */ + MR_TOPGRF(0, RK_PA4, 3, 0x0314, RK_GENMASK_VAL(5, 4, 0)), /* PCIE30X1 IO mux selection M0 */ + MR_TOPGRF(2, RK_PD2, 4, 0x0314, RK_GENMASK_VAL(5, 4, 1)), /* PCIE30X1 IO mux selection M1 */ + MR_TOPGRF(1, RK_PA5, 4, 0x0314, RK_GENMASK_VAL(5, 4, 2)), /* PCIE30X1 IO mux selection M2 */ + MR_TOPGRF(0, RK_PA6, 2, 0x0314, RK_GENMASK_VAL(7, 6, 0)), /* PCIE30X2 IO mux selection M0 */ + MR_TOPGRF(2, RK_PD4, 4, 0x0314, RK_GENMASK_VAL(7, 6, 1)), /* PCIE30X2 IO mux selection M1 */ + MR_TOPGRF(4, RK_PC2, 4, 0x0314, RK_GENMASK_VAL(7, 6, 2)), /* PCIE30X2 IO mux selection M2 */ };
static int rk3568_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) { diff --git a/include/dt-bindings/pinctrl/rockchip.h b/include/dt-bindings/pinctrl/rockchip.h deleted file mode 100644 index 1c28d6cb1fad..000000000000 --- a/include/dt-bindings/pinctrl/rockchip.h +++ /dev/null @@ -1,60 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Header providing constants for Rockchip pinctrl bindings. - * - * Copyright (c) 2013 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef __DT_BINDINGS_ROCKCHIP_PINCTRL_H__ -#define __DT_BINDINGS_ROCKCHIP_PINCTRL_H__ - -#define RK_GPIO0 0 -#define RK_GPIO1 1 -#define RK_GPIO2 2 -#define RK_GPIO3 3 -#define RK_GPIO4 4 -#define RK_GPIO6 6 - -#define RK_PA0 0 -#define RK_PA1 1 -#define RK_PA2 2 -#define RK_PA3 3 -#define RK_PA4 4 -#define RK_PA5 5 -#define RK_PA6 6 -#define RK_PA7 7 -#define RK_PB0 8 -#define RK_PB1 9 -#define RK_PB2 10 -#define RK_PB3 11 -#define RK_PB4 12 -#define RK_PB5 13 -#define RK_PB6 14 -#define RK_PB7 15 -#define RK_PC0 16 -#define RK_PC1 17 -#define RK_PC2 18 -#define RK_PC3 19 -#define RK_PC4 20 -#define RK_PC5 21 -#define RK_PC6 22 -#define RK_PC7 23 -#define RK_PD0 24 -#define RK_PD1 25 -#define RK_PD2 26 -#define RK_PD3 27 -#define RK_PD4 28 -#define RK_PD5 29 -#define RK_PD6 30 -#define RK_PD7 31 - -#define RK_FUNC_GPIO 0 -#define RK_FUNC_1 1 -#define RK_FUNC_2 2 -#define RK_FUNC_3 3 -#define RK_FUNC_4 4 -#define RK_FUNC_5 5 -#define RK_FUNC_6 6 - -#endif diff --git a/include/dt-bindings/power/px30-power.h b/include/dt-bindings/power/px30-power.h deleted file mode 100644 index 30917a99ad20..000000000000 --- a/include/dt-bindings/power/px30-power.h +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_PX30_POWER_H__ -#define __DT_BINDINGS_POWER_PX30_POWER_H__ - -/* VD_CORE */ -#define PX30_PD_A35_0 0 -#define PX30_PD_A35_1 1 -#define PX30_PD_A35_2 2 -#define PX30_PD_A35_3 3 -#define PX30_PD_SCU 4 - -/* VD_LOGIC */ -#define PX30_PD_USB 5 -#define PX30_PD_DDR 6 -#define PX30_PD_SDCARD 7 -#define PX30_PD_CRYPTO 8 -#define PX30_PD_GMAC 9 -#define PX30_PD_MMC_NAND 10 -#define PX30_PD_VPU 11 -#define PX30_PD_VO 12 -#define PX30_PD_VI 13 -#define PX30_PD_GPU 14 - -/* VD_PMU */ -#define PX30_PD_PMU 15 - -#endif diff --git a/include/dt-bindings/power/rk3066-power.h b/include/dt-bindings/power/rk3066-power.h deleted file mode 100644 index acf9f310ac53..000000000000 --- a/include/dt-bindings/power/rk3066-power.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3066_POWER_H__ -#define __DT_BINDINGS_POWER_RK3066_POWER_H__ - -/* VD_CORE */ -#define RK3066_PD_A9_0 0 -#define RK3066_PD_A9_1 1 -#define RK3066_PD_DBG 4 -#define RK3066_PD_SCU 5 - -/* VD_LOGIC */ -#define RK3066_PD_VIDEO 6 -#define RK3066_PD_VIO 7 -#define RK3066_PD_GPU 8 -#define RK3066_PD_PERI 9 -#define RK3066_PD_CPU 10 -#define RK3066_PD_ALIVE 11 - -/* VD_PMU */ -#define RK3066_PD_RTC 12 - -#endif diff --git a/include/dt-bindings/power/rk3188-power.h b/include/dt-bindings/power/rk3188-power.h deleted file mode 100644 index 93d23dfba33f..000000000000 --- a/include/dt-bindings/power/rk3188-power.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3188_POWER_H__ -#define __DT_BINDINGS_POWER_RK3188_POWER_H__ - -/* VD_CORE */ -#define RK3188_PD_A9_0 0 -#define RK3188_PD_A9_1 1 -#define RK3188_PD_A9_2 2 -#define RK3188_PD_A9_3 3 -#define RK3188_PD_DBG 4 -#define RK3188_PD_SCU 5 - -/* VD_LOGIC */ -#define RK3188_PD_VIDEO 6 -#define RK3188_PD_VIO 7 -#define RK3188_PD_GPU 8 -#define RK3188_PD_PERI 9 -#define RK3188_PD_CPU 10 -#define RK3188_PD_ALIVE 11 - -/* VD_PMU */ -#define RK3188_PD_RTC 12 - -#endif diff --git a/include/dt-bindings/power/rk3228-power.h b/include/dt-bindings/power/rk3228-power.h deleted file mode 100644 index 6a8dc1bf76ce..000000000000 --- a/include/dt-bindings/power/rk3228-power.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3228_POWER_H__ -#define __DT_BINDINGS_POWER_RK3228_POWER_H__ - -/** - * RK3228 idle id Summary. - */ - -#define RK3228_PD_CORE 0 -#define RK3228_PD_MSCH 1 -#define RK3228_PD_BUS 2 -#define RK3228_PD_SYS 3 -#define RK3228_PD_VIO 4 -#define RK3228_PD_VOP 5 -#define RK3228_PD_VPU 6 -#define RK3228_PD_RKVDEC 7 -#define RK3228_PD_GPU 8 -#define RK3228_PD_PERI 9 -#define RK3228_PD_GMAC 10 - -#endif diff --git a/include/dt-bindings/power/rk3288-power.h b/include/dt-bindings/power/rk3288-power.h deleted file mode 100644 index f710b56ccd81..000000000000 --- a/include/dt-bindings/power/rk3288-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3288_POWER_H__ -#define __DT_BINDINGS_POWER_RK3288_POWER_H__ - -/** - * RK3288 Power Domain and Voltage Domain Summary. - */ - -/* VD_CORE */ -#define RK3288_PD_A17_0 0 -#define RK3288_PD_A17_1 1 -#define RK3288_PD_A17_2 2 -#define RK3288_PD_A17_3 3 -#define RK3288_PD_SCU 4 -#define RK3288_PD_DEBUG 5 -#define RK3288_PD_MEM 6 - -/* VD_LOGIC */ -#define RK3288_PD_BUS 7 -#define RK3288_PD_PERI 8 -#define RK3288_PD_VIO 9 -#define RK3288_PD_ALIVE 10 -#define RK3288_PD_HEVC 11 -#define RK3288_PD_VIDEO 12 - -/* VD_GPU */ -#define RK3288_PD_GPU 13 - -/* VD_PMU */ -#define RK3288_PD_PMU 14 - -#endif diff --git a/include/dt-bindings/power/rk3328-power.h b/include/dt-bindings/power/rk3328-power.h deleted file mode 100644 index 02e3d7fc1cce..000000000000 --- a/include/dt-bindings/power/rk3328-power.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3328_POWER_H__ -#define __DT_BINDINGS_POWER_RK3328_POWER_H__ - -/** - * RK3328 idle id Summary. - */ -#define RK3328_PD_CORE 0 -#define RK3328_PD_GPU 1 -#define RK3328_PD_BUS 2 -#define RK3328_PD_MSCH 3 -#define RK3328_PD_PERI 4 -#define RK3328_PD_VIDEO 5 -#define RK3328_PD_HEVC 6 -#define RK3328_PD_SYS 7 -#define RK3328_PD_VPU 8 -#define RK3328_PD_VIO 9 - -#endif diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h deleted file mode 100644 index 168b3bfbd6f5..000000000000 --- a/include/dt-bindings/power/rk3399-power.h +++ /dev/null @@ -1,53 +0,0 @@ -#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ -#define __DT_BINDINGS_POWER_RK3399_POWER_H__ - -/* VD_CORE_L */ -#define RK3399_PD_A53_L0 0 -#define RK3399_PD_A53_L1 1 -#define RK3399_PD_A53_L2 2 -#define RK3399_PD_A53_L3 3 -#define RK3399_PD_SCU_L 4 - -/* VD_CORE_B */ -#define RK3399_PD_A72_B0 5 -#define RK3399_PD_A72_B1 6 -#define RK3399_PD_SCU_B 7 - -/* VD_LOGIC */ -#define RK3399_PD_TCPD0 8 -#define RK3399_PD_TCPD1 9 -#define RK3399_PD_CCI 10 -#define RK3399_PD_CCI0 11 -#define RK3399_PD_CCI1 12 -#define RK3399_PD_PERILP 13 -#define RK3399_PD_PERIHP 14 -#define RK3399_PD_VIO 15 -#define RK3399_PD_VO 16 -#define RK3399_PD_VOPB 17 -#define RK3399_PD_VOPL 18 -#define RK3399_PD_ISP0 19 -#define RK3399_PD_ISP1 20 -#define RK3399_PD_HDCP 21 -#define RK3399_PD_GMAC 22 -#define RK3399_PD_EMMC 23 -#define RK3399_PD_USB3 24 -#define RK3399_PD_EDP 25 -#define RK3399_PD_GIC 26 -#define RK3399_PD_SD 27 -#define RK3399_PD_SDIOAUDIO 28 -#define RK3399_PD_ALIVE 29 - -/* VD_CENTER */ -#define RK3399_PD_CENTER 30 -#define RK3399_PD_VCODEC 31 -#define RK3399_PD_VDU 32 -#define RK3399_PD_RGA 33 -#define RK3399_PD_IEP 34 - -/* VD_GPU */ -#define RK3399_PD_GPU 35 - -/* VD_PMU */ -#define RK3399_PD_PMU 36 - -#endif diff --git a/include/dt-bindings/power/rk3568-power.h b/include/dt-bindings/power/rk3568-power.h deleted file mode 100644 index 6cc1af1a9d26..000000000000 --- a/include/dt-bindings/power/rk3568-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3568_POWER_H__ -#define __DT_BINDINGS_POWER_RK3568_POWER_H__ - -/* VD_CORE */ -#define RK3568_PD_CPU_0 0 -#define RK3568_PD_CPU_1 1 -#define RK3568_PD_CPU_2 2 -#define RK3568_PD_CPU_3 3 -#define RK3568_PD_CORE_ALIVE 4 - -/* VD_PMU */ -#define RK3568_PD_PMU 5 - -/* VD_NPU */ -#define RK3568_PD_NPU 6 - -/* VD_GPU */ -#define RK3568_PD_GPU 7 - -/* VD_LOGIC */ -#define RK3568_PD_VI 8 -#define RK3568_PD_VO 9 -#define RK3568_PD_RGA 10 -#define RK3568_PD_VPU 11 -#define RK3568_PD_CENTER 12 -#define RK3568_PD_RKVDEC 13 -#define RK3568_PD_RKVENC 14 -#define RK3568_PD_PIPE 15 -#define RK3568_PD_LOGIC_ALIVE 16 - -#endif diff --git a/include/dt-bindings/power/rk3588-power.h b/include/dt-bindings/power/rk3588-power.h deleted file mode 100644 index 1b92fec013cb..000000000000 --- a/include/dt-bindings/power/rk3588-power.h +++ /dev/null @@ -1,69 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or MIT) */ -#ifndef __DT_BINDINGS_POWER_RK3588_POWER_H__ -#define __DT_BINDINGS_POWER_RK3588_POWER_H__ - -/* VD_LITDSU */ -#define RK3588_PD_CPU_0 0 -#define RK3588_PD_CPU_1 1 -#define RK3588_PD_CPU_2 2 -#define RK3588_PD_CPU_3 3 - -/* VD_BIGCORE0 */ -#define RK3588_PD_CPU_4 4 -#define RK3588_PD_CPU_5 5 - -/* VD_BIGCORE1 */ -#define RK3588_PD_CPU_6 6 -#define RK3588_PD_CPU_7 7 - -/* VD_NPU */ -#define RK3588_PD_NPU 8 -#define RK3588_PD_NPUTOP 9 -#define RK3588_PD_NPU1 10 -#define RK3588_PD_NPU2 11 - -/* VD_GPU */ -#define RK3588_PD_GPU 12 - -/* VD_VCODEC */ -#define RK3588_PD_VCODEC 13 -#define RK3588_PD_RKVDEC0 14 -#define RK3588_PD_RKVDEC1 15 -#define RK3588_PD_VENC0 16 -#define RK3588_PD_VENC1 17 - -/* VD_DD01 */ -#define RK3588_PD_DDR01 18 - -/* VD_DD23 */ -#define RK3588_PD_DDR23 19 - -/* VD_LOGIC */ -#define RK3588_PD_CENTER 20 -#define RK3588_PD_VDPU 21 -#define RK3588_PD_RGA30 22 -#define RK3588_PD_AV1 23 -#define RK3588_PD_VOP 24 -#define RK3588_PD_VO0 25 -#define RK3588_PD_VO1 26 -#define RK3588_PD_VI 27 -#define RK3588_PD_ISP1 28 -#define RK3588_PD_FEC 29 -#define RK3588_PD_RGA31 30 -#define RK3588_PD_USB 31 -#define RK3588_PD_PHP 32 -#define RK3588_PD_GMAC 33 -#define RK3588_PD_PCIE 34 -#define RK3588_PD_NVM 35 -#define RK3588_PD_NVM0 36 -#define RK3588_PD_SDIO 37 -#define RK3588_PD_AUDIO 38 -#define RK3588_PD_SECURE 39 -#define RK3588_PD_SDMMC 40 -#define RK3588_PD_CRYPTO 41 -#define RK3588_PD_BUS 42 - -/* VD_PMU */ -#define RK3588_PD_PMU1 43 - -#endif diff --git a/include/dt-bindings/power/rockchip,rv1126-power.h b/include/dt-bindings/power/rockchip,rv1126-power.h deleted file mode 100644 index 38a68e000d38..000000000000 --- a/include/dt-bindings/power/rockchip,rv1126-power.h +++ /dev/null @@ -1,35 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ - -#ifndef __DT_BINDINGS_POWER_RV1126_POWER_H__ -#define __DT_BINDINGS_POWER_RV1126_POWER_H__ - -/* VD_CORE */ -#define RV1126_PD_CPU_0 0 -#define RV1126_PD_CPU_1 1 -#define RV1126_PD_CPU_2 2 -#define RV1126_PD_CPU_3 3 -#define RV1126_PD_CORE_ALIVE 4 - -/* VD_PMU */ -#define RV1126_PD_PMU 5 -#define RV1126_PD_PMU_ALIVE 6 - -/* VD_NPU */ -#define RV1126_PD_NPU 7 - -/* VD_VEPU */ -#define RV1126_PD_VEPU 8 - -/* VD_LOGIC */ -#define RV1126_PD_VI 9 -#define RV1126_PD_VO 10 -#define RV1126_PD_ISPP 11 -#define RV1126_PD_VDPU 12 -#define RV1126_PD_CRYPTO 13 -#define RV1126_PD_DDR 14 -#define RV1126_PD_NVM 15 -#define RV1126_PD_SDIO 16 -#define RV1126_PD_USB 17 -#define RV1126_PD_LOGIC_ALIVE 18 - -#endif diff --git a/include/dt-bindings/reset/rockchip,rk3588-cru.h b/include/dt-bindings/reset/rockchip,rk3588-cru.h deleted file mode 100644 index 738e56aead93..000000000000 --- a/include/dt-bindings/reset/rockchip,rk3588-cru.h +++ /dev/null @@ -1,754 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or MIT) */ -/* - * Copyright (c) 2021 Rockchip Electronics Co. Ltd. - * Copyright (c) 2022 Collabora Ltd. - * - * Author: Elaine Zhang zhangqing@rock-chips.com - * Author: Sebastian Reichel sebastian.reichel@collabora.com - */ - -#ifndef _DT_BINDINGS_RESET_ROCKCHIP_RK3588_H -#define _DT_BINDINGS_RESET_ROCKCHIP_RK3588_H - -#define SRST_A_TOP_BIU 0 -#define SRST_P_TOP_BIU 1 -#define SRST_P_CSIPHY0 2 -#define SRST_CSIPHY0 3 -#define SRST_P_CSIPHY1 4 -#define SRST_CSIPHY1 5 -#define SRST_A_TOP_M500_BIU 6 - -#define SRST_A_TOP_M400_BIU 7 -#define SRST_A_TOP_S200_BIU 8 -#define SRST_A_TOP_S400_BIU 9 -#define SRST_A_TOP_M300_BIU 10 -#define SRST_USBDP_COMBO_PHY0_INIT 11 -#define SRST_USBDP_COMBO_PHY0_CMN 12 -#define SRST_USBDP_COMBO_PHY0_LANE 13 -#define SRST_USBDP_COMBO_PHY0_PCS 14 -#define SRST_USBDP_COMBO_PHY1_INIT 15 - -#define SRST_USBDP_COMBO_PHY1_CMN 16 -#define SRST_USBDP_COMBO_PHY1_LANE 17 -#define SRST_USBDP_COMBO_PHY1_PCS 18 -#define SRST_DCPHY0 19 -#define SRST_P_MIPI_DCPHY0 20 -#define SRST_P_MIPI_DCPHY0_GRF 21 - -#define SRST_DCPHY1 22 -#define SRST_P_MIPI_DCPHY1 23 -#define SRST_P_MIPI_DCPHY1_GRF 24 -#define SRST_P_APB2ASB_SLV_CDPHY 25 -#define SRST_P_APB2ASB_SLV_CSIPHY 26 -#define SRST_P_APB2ASB_SLV_VCCIO3_5 27 -#define SRST_P_APB2ASB_SLV_VCCIO6 28 -#define SRST_P_APB2ASB_SLV_EMMCIO 29 -#define SRST_P_APB2ASB_SLV_IOC_TOP 30 -#define SRST_P_APB2ASB_SLV_IOC_RIGHT 31 - -#define SRST_P_CRU 32 -#define SRST_A_CHANNEL_SECURE2VO1USB 33 -#define SRST_A_CHANNEL_SECURE2CENTER 34 -#define SRST_H_CHANNEL_SECURE2VO1USB 35 -#define SRST_H_CHANNEL_SECURE2CENTER 36 - -#define SRST_P_CHANNEL_SECURE2VO1USB 37 -#define SRST_P_CHANNEL_SECURE2CENTER 38 - -#define SRST_H_AUDIO_BIU 39 -#define SRST_P_AUDIO_BIU 40 -#define SRST_H_I2S0_8CH 41 -#define SRST_M_I2S0_8CH_TX 42 -#define SRST_M_I2S0_8CH_RX 43 -#define SRST_P_ACDCDIG 44 -#define SRST_H_I2S2_2CH 45 -#define SRST_H_I2S3_2CH 46 - -#define SRST_M_I2S2_2CH 47 -#define SRST_M_I2S3_2CH 48 -#define SRST_DAC_ACDCDIG 49 -#define SRST_H_SPDIF0 50 - -#define SRST_M_SPDIF0 51 -#define SRST_H_SPDIF1 52 -#define SRST_M_SPDIF1 53 -#define SRST_H_PDM1 54 -#define SRST_PDM1 55 - -#define SRST_A_BUS_BIU 56 -#define SRST_P_BUS_BIU 57 -#define SRST_A_GIC 58 -#define SRST_A_GIC_DBG 59 -#define SRST_A_DMAC0 60 -#define SRST_A_DMAC1 61 -#define SRST_A_DMAC2 62 -#define SRST_P_I2C1 63 -#define SRST_P_I2C2 64 -#define SRST_P_I2C3 65 -#define SRST_P_I2C4 66 -#define SRST_P_I2C5 67 -#define SRST_P_I2C6 68 -#define SRST_P_I2C7 69 -#define SRST_P_I2C8 70 - -#define SRST_I2C1 71 -#define SRST_I2C2 72 -#define SRST_I2C3 73 -#define SRST_I2C4 74 -#define SRST_I2C5 75 -#define SRST_I2C6 76 -#define SRST_I2C7 77 -#define SRST_I2C8 78 -#define SRST_P_CAN0 79 -#define SRST_CAN0 80 -#define SRST_P_CAN1 81 -#define SRST_CAN1 82 -#define SRST_P_CAN2 83 -#define SRST_CAN2 84 -#define SRST_P_SARADC 85 - -#define SRST_P_TSADC 86 -#define SRST_TSADC 87 -#define SRST_P_UART1 88 -#define SRST_P_UART2 89 -#define SRST_P_UART3 90 -#define SRST_P_UART4 91 -#define SRST_P_UART5 92 -#define SRST_P_UART6 93 -#define SRST_P_UART7 94 -#define SRST_P_UART8 95 -#define SRST_P_UART9 96 -#define SRST_S_UART1 97 - -#define SRST_S_UART2 98 -#define SRST_S_UART3 99 -#define SRST_S_UART4 100 -#define SRST_S_UART5 101 -#define SRST_S_UART6 102 -#define SRST_S_UART7 103 - -#define SRST_S_UART8 104 -#define SRST_S_UART9 105 -#define SRST_P_SPI0 106 -#define SRST_P_SPI1 107 -#define SRST_P_SPI2 108 -#define SRST_P_SPI3 109 -#define SRST_P_SPI4 110 -#define SRST_SPI0 111 -#define SRST_SPI1 112 -#define SRST_SPI2 113 -#define SRST_SPI3 114 -#define SRST_SPI4 115 - -#define SRST_P_WDT0 116 -#define SRST_T_WDT0 117 -#define SRST_P_SYS_GRF 118 -#define SRST_P_PWM1 119 -#define SRST_PWM1 120 -#define SRST_P_PWM2 121 -#define SRST_PWM2 122 -#define SRST_P_PWM3 123 -#define SRST_PWM3 124 -#define SRST_P_BUSTIMER0 125 -#define SRST_P_BUSTIMER1 126 -#define SRST_BUSTIMER0 127 - -#define SRST_BUSTIMER1 128 -#define SRST_BUSTIMER2 129 -#define SRST_BUSTIMER3 130 -#define SRST_BUSTIMER4 131 -#define SRST_BUSTIMER5 132 -#define SRST_BUSTIMER6 133 -#define SRST_BUSTIMER7 134 -#define SRST_BUSTIMER8 135 -#define SRST_BUSTIMER9 136 -#define SRST_BUSTIMER10 137 -#define SRST_BUSTIMER11 138 -#define SRST_P_MAILBOX0 139 -#define SRST_P_MAILBOX1 140 -#define SRST_P_MAILBOX2 141 -#define SRST_P_GPIO1 142 -#define SRST_GPIO1 143 - -#define SRST_P_GPIO2 144 -#define SRST_GPIO2 145 -#define SRST_P_GPIO3 146 -#define SRST_GPIO3 147 -#define SRST_P_GPIO4 148 -#define SRST_GPIO4 149 -#define SRST_A_DECOM 150 -#define SRST_P_DECOM 151 -#define SRST_D_DECOM 152 -#define SRST_P_TOP 153 -#define SRST_A_GICADB_GIC2CORE_BUS 154 -#define SRST_P_DFT2APB 155 -#define SRST_P_APB2ASB_MST_TOP 156 -#define SRST_P_APB2ASB_MST_CDPHY 157 -#define SRST_P_APB2ASB_MST_BOT_RIGHT 158 - -#define SRST_P_APB2ASB_MST_IOC_TOP 159 -#define SRST_P_APB2ASB_MST_IOC_RIGHT 160 -#define SRST_P_APB2ASB_MST_CSIPHY 161 -#define SRST_P_APB2ASB_MST_VCCIO3_5 162 -#define SRST_P_APB2ASB_MST_VCCIO6 163 -#define SRST_P_APB2ASB_MST_EMMCIO 164 -#define SRST_A_SPINLOCK 165 -#define SRST_P_OTPC_NS 166 -#define SRST_OTPC_NS 167 -#define SRST_OTPC_ARB 168 - -#define SRST_P_BUSIOC 169 -#define SRST_P_PMUCM0_INTMUX 170 -#define SRST_P_DDRCM0_INTMUX 171 - -#define SRST_P_DDR_DFICTL_CH0 172 -#define SRST_P_DDR_MON_CH0 173 -#define SRST_P_DDR_STANDBY_CH0 174 -#define SRST_P_DDR_UPCTL_CH0 175 -#define SRST_TM_DDR_MON_CH0 176 -#define SRST_P_DDR_GRF_CH01 177 -#define SRST_DFI_CH0 178 -#define SRST_SBR_CH0 179 -#define SRST_DDR_UPCTL_CH0 180 -#define SRST_DDR_DFICTL_CH0 181 -#define SRST_DDR_MON_CH0 182 -#define SRST_DDR_STANDBY_CH0 183 -#define SRST_A_DDR_UPCTL_CH0 184 -#define SRST_P_DDR_DFICTL_CH1 185 -#define SRST_P_DDR_MON_CH1 186 -#define SRST_P_DDR_STANDBY_CH1 187 - -#define SRST_P_DDR_UPCTL_CH1 188 -#define SRST_TM_DDR_MON_CH1 189 -#define SRST_DFI_CH1 190 -#define SRST_SBR_CH1 191 -#define SRST_DDR_UPCTL_CH1 192 -#define SRST_DDR_DFICTL_CH1 193 -#define SRST_DDR_MON_CH1 194 -#define SRST_DDR_STANDBY_CH1 195 -#define SRST_A_DDR_UPCTL_CH1 196 -#define SRST_A_DDR01_MSCH0 197 -#define SRST_A_DDR01_RS_MSCH0 198 -#define SRST_A_DDR01_FRS_MSCH0 199 - -#define SRST_A_DDR01_SCRAMBLE0 200 -#define SRST_A_DDR01_FRS_SCRAMBLE0 201 -#define SRST_A_DDR01_MSCH1 202 -#define SRST_A_DDR01_RS_MSCH1 203 -#define SRST_A_DDR01_FRS_MSCH1 204 -#define SRST_A_DDR01_SCRAMBLE1 205 -#define SRST_A_DDR01_FRS_SCRAMBLE1 206 -#define SRST_P_DDR01_MSCH0 207 -#define SRST_P_DDR01_MSCH1 208 - -#define SRST_P_DDR_DFICTL_CH2 209 -#define SRST_P_DDR_MON_CH2 210 -#define SRST_P_DDR_STANDBY_CH2 211 -#define SRST_P_DDR_UPCTL_CH2 212 -#define SRST_TM_DDR_MON_CH2 213 -#define SRST_P_DDR_GRF_CH23 214 -#define SRST_DFI_CH2 215 -#define SRST_SBR_CH2 216 -#define SRST_DDR_UPCTL_CH2 217 -#define SRST_DDR_DFICTL_CH2 218 -#define SRST_DDR_MON_CH2 219 -#define SRST_DDR_STANDBY_CH2 220 -#define SRST_A_DDR_UPCTL_CH2 221 -#define SRST_P_DDR_DFICTL_CH3 222 -#define SRST_P_DDR_MON_CH3 223 -#define SRST_P_DDR_STANDBY_CH3 224 - -#define SRST_P_DDR_UPCTL_CH3 225 -#define SRST_TM_DDR_MON_CH3 226 -#define SRST_DFI_CH3 227 -#define SRST_SBR_CH3 228 -#define SRST_DDR_UPCTL_CH3 229 -#define SRST_DDR_DFICTL_CH3 230 -#define SRST_DDR_MON_CH3 231 -#define SRST_DDR_STANDBY_CH3 232 -#define SRST_A_DDR_UPCTL_CH3 233 -#define SRST_A_DDR23_MSCH2 234 -#define SRST_A_DDR23_RS_MSCH2 235 -#define SRST_A_DDR23_FRS_MSCH2 236 - -#define SRST_A_DDR23_SCRAMBLE2 237 -#define SRST_A_DDR23_FRS_SCRAMBLE2 238 -#define SRST_A_DDR23_MSCH3 239 -#define SRST_A_DDR23_RS_MSCH3 240 -#define SRST_A_DDR23_FRS_MSCH3 241 -#define SRST_A_DDR23_SCRAMBLE3 242 -#define SRST_A_DDR23_FRS_SCRAMBLE3 243 -#define SRST_P_DDR23_MSCH2 244 -#define SRST_P_DDR23_MSCH3 245 - -#define SRST_ISP1 246 -#define SRST_ISP1_VICAP 247 -#define SRST_A_ISP1_BIU 248 -#define SRST_H_ISP1_BIU 249 - -#define SRST_A_RKNN1 250 -#define SRST_A_RKNN1_BIU 251 -#define SRST_H_RKNN1 252 -#define SRST_H_RKNN1_BIU 253 - -#define SRST_A_RKNN2 254 -#define SRST_A_RKNN2_BIU 255 -#define SRST_H_RKNN2 256 -#define SRST_H_RKNN2_BIU 257 - -#define SRST_A_RKNN_DSU0 258 -#define SRST_P_NPUTOP_BIU 259 -#define SRST_P_NPU_TIMER 260 -#define SRST_NPUTIMER0 261 -#define SRST_NPUTIMER1 262 -#define SRST_P_NPU_WDT 263 -#define SRST_T_NPU_WDT 264 -#define SRST_P_NPU_PVTM 265 -#define SRST_P_NPU_GRF 266 -#define SRST_NPU_PVTM 267 - -#define SRST_NPU_PVTPLL 268 -#define SRST_H_NPU_CM0_BIU 269 -#define SRST_F_NPU_CM0_CORE 270 -#define SRST_T_NPU_CM0_JTAG 271 -#define SRST_A_RKNN0 272 -#define SRST_A_RKNN0_BIU 273 -#define SRST_H_RKNN0 274 -#define SRST_H_RKNN0_BIU 275 - -#define SRST_H_NVM_BIU 276 -#define SRST_A_NVM_BIU 277 -#define SRST_H_EMMC 278 -#define SRST_A_EMMC 279 -#define SRST_C_EMMC 280 -#define SRST_B_EMMC 281 -#define SRST_T_EMMC 282 -#define SRST_S_SFC 283 -#define SRST_H_SFC 284 -#define SRST_H_SFC_XIP 285 - -#define SRST_P_GRF 286 -#define SRST_P_DEC_BIU 287 -#define SRST_P_PHP_BIU 288 -#define SRST_A_PCIE_GRIDGE 289 -#define SRST_A_PHP_BIU 290 -#define SRST_A_GMAC0 291 -#define SRST_A_GMAC1 292 -#define SRST_A_PCIE_BIU 293 -#define SRST_PCIE0_POWER_UP 294 -#define SRST_PCIE1_POWER_UP 295 -#define SRST_PCIE2_POWER_UP 296 - -#define SRST_PCIE3_POWER_UP 297 -#define SRST_PCIE4_POWER_UP 298 -#define SRST_P_PCIE0 299 -#define SRST_P_PCIE1 300 -#define SRST_P_PCIE2 301 -#define SRST_P_PCIE3 302 - -#define SRST_P_PCIE4 303 -#define SRST_A_PHP_GIC_ITS 304 -#define SRST_A_MMU_PCIE 305 -#define SRST_A_MMU_PHP 306 -#define SRST_A_MMU_BIU 307 - -#define SRST_A_USB3OTG2 308 - -#define SRST_PMALIVE0 309 -#define SRST_PMALIVE1 310 -#define SRST_PMALIVE2 311 -#define SRST_A_SATA0 312 -#define SRST_A_SATA1 313 -#define SRST_A_SATA2 314 -#define SRST_RXOOB0 315 -#define SRST_RXOOB1 316 -#define SRST_RXOOB2 317 -#define SRST_ASIC0 318 -#define SRST_ASIC1 319 -#define SRST_ASIC2 320 - -#define SRST_A_RKVDEC_CCU 321 -#define SRST_H_RKVDEC0 322 -#define SRST_A_RKVDEC0 323 -#define SRST_H_RKVDEC0_BIU 324 -#define SRST_A_RKVDEC0_BIU 325 -#define SRST_RKVDEC0_CA 326 -#define SRST_RKVDEC0_HEVC_CA 327 -#define SRST_RKVDEC0_CORE 328 - -#define SRST_H_RKVDEC1 329 -#define SRST_A_RKVDEC1 330 -#define SRST_H_RKVDEC1_BIU 331 -#define SRST_A_RKVDEC1_BIU 332 -#define SRST_RKVDEC1_CA 333 -#define SRST_RKVDEC1_HEVC_CA 334 -#define SRST_RKVDEC1_CORE 335 - -#define SRST_A_USB_BIU 336 -#define SRST_H_USB_BIU 337 -#define SRST_A_USB3OTG0 338 -#define SRST_A_USB3OTG1 339 -#define SRST_H_HOST0 340 -#define SRST_H_HOST_ARB0 341 -#define SRST_H_HOST1 342 -#define SRST_H_HOST_ARB1 343 -#define SRST_A_USB_GRF 344 -#define SRST_C_USB2P0_HOST0 345 - -#define SRST_C_USB2P0_HOST1 346 -#define SRST_HOST_UTMI0 347 -#define SRST_HOST_UTMI1 348 - -#define SRST_A_VDPU_BIU 349 -#define SRST_A_VDPU_LOW_BIU 350 -#define SRST_H_VDPU_BIU 351 -#define SRST_A_JPEG_DECODER_BIU 352 -#define SRST_A_VPU 353 -#define SRST_H_VPU 354 -#define SRST_A_JPEG_ENCODER0 355 -#define SRST_H_JPEG_ENCODER0 356 -#define SRST_A_JPEG_ENCODER1 357 -#define SRST_H_JPEG_ENCODER1 358 -#define SRST_A_JPEG_ENCODER2 359 -#define SRST_H_JPEG_ENCODER2 360 - -#define SRST_A_JPEG_ENCODER3 361 -#define SRST_H_JPEG_ENCODER3 362 -#define SRST_A_JPEG_DECODER 363 -#define SRST_H_JPEG_DECODER 364 -#define SRST_H_IEP2P0 365 -#define SRST_A_IEP2P0 366 -#define SRST_IEP2P0_CORE 367 -#define SRST_H_RGA2 368 -#define SRST_A_RGA2 369 -#define SRST_RGA2_CORE 370 -#define SRST_H_RGA3_0 371 -#define SRST_A_RGA3_0 372 -#define SRST_RGA3_0_CORE 373 - -#define SRST_H_RKVENC0_BIU 374 -#define SRST_A_RKVENC0_BIU 375 -#define SRST_H_RKVENC0 376 -#define SRST_A_RKVENC0 377 -#define SRST_RKVENC0_CORE 378 - -#define SRST_H_RKVENC1_BIU 379 -#define SRST_A_RKVENC1_BIU 380 -#define SRST_H_RKVENC1 381 -#define SRST_A_RKVENC1 382 -#define SRST_RKVENC1_CORE 383 - -#define SRST_A_VI_BIU 384 -#define SRST_H_VI_BIU 385 -#define SRST_P_VI_BIU 386 -#define SRST_D_VICAP 387 -#define SRST_A_VICAP 388 -#define SRST_H_VICAP 389 -#define SRST_ISP0 390 -#define SRST_ISP0_VICAP 391 - -#define SRST_FISHEYE0 392 -#define SRST_FISHEYE1 393 -#define SRST_P_CSI_HOST_0 394 -#define SRST_P_CSI_HOST_1 395 -#define SRST_P_CSI_HOST_2 396 -#define SRST_P_CSI_HOST_3 397 -#define SRST_P_CSI_HOST_4 398 -#define SRST_P_CSI_HOST_5 399 - -#define SRST_CSIHOST0_VICAP 400 -#define SRST_CSIHOST1_VICAP 401 -#define SRST_CSIHOST2_VICAP 402 -#define SRST_CSIHOST3_VICAP 403 -#define SRST_CSIHOST4_VICAP 404 -#define SRST_CSIHOST5_VICAP 405 -#define SRST_CIFIN 406 - -#define SRST_A_VOP_BIU 407 -#define SRST_A_VOP_LOW_BIU 408 -#define SRST_H_VOP_BIU 409 -#define SRST_P_VOP_BIU 410 -#define SRST_H_VOP 411 -#define SRST_A_VOP 412 -#define SRST_D_VOP0 413 -#define SRST_D_VOP2HDMI_BRIDGE0 414 -#define SRST_D_VOP2HDMI_BRIDGE1 415 - -#define SRST_D_VOP1 416 -#define SRST_D_VOP2 417 -#define SRST_D_VOP3 418 -#define SRST_P_VOPGRF 419 -#define SRST_P_DSIHOST0 420 -#define SRST_P_DSIHOST1 421 -#define SRST_DSIHOST0 422 -#define SRST_DSIHOST1 423 -#define SRST_VOP_PMU 424 -#define SRST_P_VOP_CHANNEL_BIU 425 - -#define SRST_H_VO0_BIU 426 -#define SRST_H_VO0_S_BIU 427 -#define SRST_P_VO0_BIU 428 -#define SRST_P_VO0_S_BIU 429 -#define SRST_A_HDCP0_BIU 430 -#define SRST_P_VO0GRF 431 -#define SRST_H_HDCP_KEY0 432 -#define SRST_A_HDCP0 433 -#define SRST_H_HDCP0 434 -#define SRST_HDCP0 435 - -#define SRST_P_TRNG0 436 -#define SRST_DP0 437 -#define SRST_DP1 438 -#define SRST_H_I2S4_8CH 439 -#define SRST_M_I2S4_8CH_TX 440 -#define SRST_H_I2S8_8CH 441 - -#define SRST_M_I2S8_8CH_TX 442 -#define SRST_H_SPDIF2_DP0 443 -#define SRST_M_SPDIF2_DP0 444 -#define SRST_H_SPDIF5_DP1 445 -#define SRST_M_SPDIF5_DP1 446 - -#define SRST_A_HDCP1_BIU 447 -#define SRST_A_VO1_BIU 448 -#define SRST_H_VOP1_BIU 449 -#define SRST_H_VOP1_S_BIU 450 -#define SRST_P_VOP1_BIU 451 -#define SRST_P_VO1GRF 452 -#define SRST_P_VO1_S_BIU 453 - -#define SRST_H_I2S7_8CH 454 -#define SRST_M_I2S7_8CH_RX 455 -#define SRST_H_HDCP_KEY1 456 -#define SRST_A_HDCP1 457 -#define SRST_H_HDCP1 458 -#define SRST_HDCP1 459 -#define SRST_P_TRNG1 460 -#define SRST_P_HDMITX0 461 - -#define SRST_HDMITX0_REF 462 -#define SRST_P_HDMITX1 463 -#define SRST_HDMITX1_REF 464 -#define SRST_A_HDMIRX 465 -#define SRST_P_HDMIRX 466 -#define SRST_HDMIRX_REF 467 - -#define SRST_P_EDP0 468 -#define SRST_EDP0_24M 469 -#define SRST_P_EDP1 470 -#define SRST_EDP1_24M 471 -#define SRST_M_I2S5_8CH_TX 472 -#define SRST_H_I2S5_8CH 473 -#define SRST_M_I2S6_8CH_TX 474 - -#define SRST_M_I2S6_8CH_RX 475 -#define SRST_H_I2S6_8CH 476 -#define SRST_H_SPDIF3 477 -#define SRST_M_SPDIF3 478 -#define SRST_H_SPDIF4 479 -#define SRST_M_SPDIF4 480 -#define SRST_H_SPDIFRX0 481 -#define SRST_M_SPDIFRX0 482 -#define SRST_H_SPDIFRX1 483 -#define SRST_M_SPDIFRX1 484 - -#define SRST_H_SPDIFRX2 485 -#define SRST_M_SPDIFRX2 486 -#define SRST_LINKSYM_HDMITXPHY0 487 -#define SRST_LINKSYM_HDMITXPHY1 488 -#define SRST_VO1_BRIDGE0 489 -#define SRST_VO1_BRIDGE1 490 - -#define SRST_H_I2S9_8CH 491 -#define SRST_M_I2S9_8CH_RX 492 -#define SRST_H_I2S10_8CH 493 -#define SRST_M_I2S10_8CH_RX 494 -#define SRST_P_S_HDMIRX 495 - -#define SRST_GPU 496 -#define SRST_SYS_GPU 497 -#define SRST_A_S_GPU_BIU 498 -#define SRST_A_M0_GPU_BIU 499 -#define SRST_A_M1_GPU_BIU 500 -#define SRST_A_M2_GPU_BIU 501 -#define SRST_A_M3_GPU_BIU 502 -#define SRST_P_GPU_BIU 503 -#define SRST_P_GPU_PVTM 504 - -#define SRST_GPU_PVTM 505 -#define SRST_P_GPU_GRF 506 -#define SRST_GPU_PVTPLL 507 -#define SRST_GPU_JTAG 508 - -#define SRST_A_AV1_BIU 509 -#define SRST_A_AV1 510 -#define SRST_P_AV1_BIU 511 -#define SRST_P_AV1 512 - -#define SRST_A_DDR_BIU 513 -#define SRST_A_DMA2DDR 514 -#define SRST_A_DDR_SHAREMEM 515 -#define SRST_A_DDR_SHAREMEM_BIU 516 -#define SRST_A_CENTER_S200_BIU 517 -#define SRST_A_CENTER_S400_BIU 518 -#define SRST_H_AHB2APB 519 -#define SRST_H_CENTER_BIU 520 -#define SRST_F_DDR_CM0_CORE 521 - -#define SRST_DDR_TIMER0 522 -#define SRST_DDR_TIMER1 523 -#define SRST_T_WDT_DDR 524 -#define SRST_T_DDR_CM0_JTAG 525 -#define SRST_P_CENTER_GRF 526 -#define SRST_P_AHB2APB 527 -#define SRST_P_WDT 528 -#define SRST_P_TIMER 529 -#define SRST_P_DMA2DDR 530 -#define SRST_P_SHAREMEM 531 -#define SRST_P_CENTER_BIU 532 -#define SRST_P_CENTER_CHANNEL_BIU 533 - -#define SRST_P_USBDPGRF0 534 -#define SRST_P_USBDPPHY0 535 -#define SRST_P_USBDPGRF1 536 -#define SRST_P_USBDPPHY1 537 -#define SRST_P_HDPTX0 538 -#define SRST_P_HDPTX1 539 -#define SRST_P_APB2ASB_SLV_BOT_RIGHT 540 -#define SRST_P_USB2PHY_U3_0_GRF0 541 -#define SRST_P_USB2PHY_U3_1_GRF0 542 -#define SRST_P_USB2PHY_U2_0_GRF0 543 -#define SRST_P_USB2PHY_U2_1_GRF0 544 -#define SRST_HDPTX0_ROPLL 545 -#define SRST_HDPTX0_LCPLL 546 -#define SRST_HDPTX0 547 -#define SRST_HDPTX1_ROPLL 548 - -#define SRST_HDPTX1_LCPLL 549 -#define SRST_HDPTX1 550 -#define SRST_HDPTX0_HDMIRXPHY_SET 551 -#define SRST_USBDP_COMBO_PHY0 552 -#define SRST_USBDP_COMBO_PHY0_LCPLL 553 -#define SRST_USBDP_COMBO_PHY0_ROPLL 554 -#define SRST_USBDP_COMBO_PHY0_PCS_HS 555 -#define SRST_USBDP_COMBO_PHY1 556 -#define SRST_USBDP_COMBO_PHY1_LCPLL 557 -#define SRST_USBDP_COMBO_PHY1_ROPLL 558 -#define SRST_USBDP_COMBO_PHY1_PCS_HS 559 -#define SRST_HDMIHDP0 560 -#define SRST_HDMIHDP1 561 - -#define SRST_A_VO1USB_TOP_BIU 562 -#define SRST_H_VO1USB_TOP_BIU 563 - -#define SRST_H_SDIO_BIU 564 -#define SRST_H_SDIO 565 -#define SRST_SDIO 566 - -#define SRST_H_RGA3_BIU 567 -#define SRST_A_RGA3_BIU 568 -#define SRST_H_RGA3_1 569 -#define SRST_A_RGA3_1 570 -#define SRST_RGA3_1_CORE 571 - -#define SRST_REF_PIPE_PHY0 572 -#define SRST_REF_PIPE_PHY1 573 -#define SRST_REF_PIPE_PHY2 574 - -#define SRST_P_PHPTOP_CRU 575 -#define SRST_P_PCIE2_GRF0 576 -#define SRST_P_PCIE2_GRF1 577 -#define SRST_P_PCIE2_GRF2 578 -#define SRST_P_PCIE2_PHY0 579 -#define SRST_P_PCIE2_PHY1 580 -#define SRST_P_PCIE2_PHY2 581 -#define SRST_P_PCIE3_PHY 582 -#define SRST_P_APB2ASB_SLV_CHIP_TOP 583 -#define SRST_PCIE30_PHY 584 - -#define SRST_H_PMU1_BIU 585 -#define SRST_P_PMU1_BIU 586 -#define SRST_H_PMU_CM0_BIU 587 -#define SRST_F_PMU_CM0_CORE 588 -#define SRST_T_PMU1_CM0_JTAG 589 - -#define SRST_DDR_FAIL_SAFE 590 -#define SRST_P_CRU_PMU1 591 -#define SRST_P_PMU1_GRF 592 -#define SRST_P_PMU1_IOC 593 -#define SRST_P_PMU1WDT 594 -#define SRST_T_PMU1WDT 595 -#define SRST_P_PMU1TIMER 596 -#define SRST_PMU1TIMER0 597 -#define SRST_PMU1TIMER1 598 -#define SRST_P_PMU1PWM 599 -#define SRST_PMU1PWM 600 - -#define SRST_P_I2C0 601 -#define SRST_I2C0 602 -#define SRST_S_UART0 603 -#define SRST_P_UART0 604 -#define SRST_H_I2S1_8CH 605 -#define SRST_M_I2S1_8CH_TX 606 -#define SRST_M_I2S1_8CH_RX 607 -#define SRST_H_PDM0 608 -#define SRST_PDM0 609 - -#define SRST_H_VAD 610 -#define SRST_HDPTX0_INIT 611 -#define SRST_HDPTX0_CMN 612 -#define SRST_HDPTX0_LANE 613 -#define SRST_HDPTX1_INIT 614 - -#define SRST_HDPTX1_CMN 615 -#define SRST_HDPTX1_LANE 616 -#define SRST_M_MIPI_DCPHY0 617 -#define SRST_S_MIPI_DCPHY0 618 -#define SRST_M_MIPI_DCPHY1 619 -#define SRST_S_MIPI_DCPHY1 620 -#define SRST_OTGPHY_U3_0 621 -#define SRST_OTGPHY_U3_1 622 -#define SRST_OTGPHY_U2_0 623 -#define SRST_OTGPHY_U2_1 624 - -#define SRST_P_PMU0GRF 625 -#define SRST_P_PMU0IOC 626 -#define SRST_P_GPIO0 627 -#define SRST_GPIO0 628 - -#define SRST_A_SECURE_NS_BIU 629 -#define SRST_H_SECURE_NS_BIU 630 -#define SRST_A_SECURE_S_BIU 631 -#define SRST_H_SECURE_S_BIU 632 -#define SRST_P_SECURE_S_BIU 633 -#define SRST_CRYPTO_CORE 634 - -#define SRST_CRYPTO_PKA 635 -#define SRST_CRYPTO_RNG 636 -#define SRST_A_CRYPTO 637 -#define SRST_H_CRYPTO 638 -#define SRST_KEYLADDER_CORE 639 -#define SRST_KEYLADDER_RNG 640 -#define SRST_A_KEYLADDER 641 -#define SRST_H_KEYLADDER 642 -#define SRST_P_OTPC_S 643 -#define SRST_OTPC_S 644 -#define SRST_WDT_S 645 - -#define SRST_T_WDT_S 646 -#define SRST_H_BOOTROM 647 -#define SRST_A_DCF 648 -#define SRST_P_DCF 649 -#define SRST_H_BOOTROM_NS 650 -#define SRST_P_KEYLADDER 651 -#define SRST_H_TRNG_S 652 - -#define SRST_H_TRNG_NS 653 -#define SRST_D_SDMMC_BUFFER 654 -#define SRST_H_SDMMC 655 -#define SRST_H_SDMMC_BUFFER 656 -#define SRST_SDMMC 657 -#define SRST_P_TRNG_CHK 658 -#define SRST_TRNG_S 659 - -#endif diff --git a/include/dt-bindings/soc/rockchip,boot-mode.h b/include/dt-bindings/soc/rockchip,boot-mode.h deleted file mode 100644 index 4b0914c0989d..000000000000 --- a/include/dt-bindings/soc/rockchip,boot-mode.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __ROCKCHIP_BOOT_MODE_H -#define __ROCKCHIP_BOOT_MODE_H - -/*high 24 bits is tag, low 8 bits is type*/ -#define REBOOT_FLAG 0x5242C300 -/* normal boot */ -#define BOOT_NORMAL (REBOOT_FLAG + 0) -/* enter bootloader rockusb mode */ -#define BOOT_BL_DOWNLOAD (REBOOT_FLAG + 1) -/* enter recovery */ -#define BOOT_RECOVERY (REBOOT_FLAG + 3) - /* enter fastboot mode */ -#define BOOT_FASTBOOT (REBOOT_FLAG + 9) - -#endif diff --git a/include/dt-bindings/soc/rockchip,vop2.h b/include/dt-bindings/soc/rockchip,vop2.h deleted file mode 100644 index 668f199df9f0..000000000000 --- a/include/dt-bindings/soc/rockchip,vop2.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR BSD-2-Clause */ - -#ifndef __DT_BINDINGS_ROCKCHIP_VOP2_H -#define __DT_BINDINGS_ROCKCHIP_VOP2_H - -#define ROCKCHIP_VOP2_EP_RGB0 1 -#define ROCKCHIP_VOP2_EP_HDMI0 2 -#define ROCKCHIP_VOP2_EP_EDP0 3 -#define ROCKCHIP_VOP2_EP_MIPI0 4 -#define ROCKCHIP_VOP2_EP_LVDS0 5 -#define ROCKCHIP_VOP2_EP_MIPI1 6 -#define ROCKCHIP_VOP2_EP_LVDS1 7 -#define ROCKCHIP_VOP2_EP_HDMI1 8 -#define ROCKCHIP_VOP2_EP_EDP1 9 -#define ROCKCHIP_VOP2_EP_DP0 10 -#define ROCKCHIP_VOP2_EP_DP1 11 - -#endif /* __DT_BINDINGS_ROCKCHIP_VOP2_H */
Small driver and DTS adjustments to use upstream headers.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/exynos7420.dtsi | 2 +- drivers/clk/exynos/clk-exynos7420.c | 2 +- include/dt-bindings/clock/exynos7420-clk.h | 207 ---------------- include/dt-bindings/clock/exynos850.h | 337 --------------------------- include/dt-bindings/soc/samsung,exynos-usi.h | 17 -- 5 files changed, 2 insertions(+), 563 deletions(-)
diff --git a/arch/arm/dts/exynos7420.dtsi b/arch/arm/dts/exynos7420.dtsi index 373f48cf2eca..ba9666f3de01 100644 --- a/arch/arm/dts/exynos7420.dtsi +++ b/arch/arm/dts/exynos7420.dtsi @@ -7,9 +7,9 @@ */
/dts-v1/; #include "skeleton.dtsi" -#include <dt-bindings/clock/exynos7420-clk.h> +#include <dt-bindings/clock/exynos7-clk.h> / { compatible = "samsung,exynos7420";
fin_pll: xxti { diff --git a/drivers/clk/exynos/clk-exynos7420.c b/drivers/clk/exynos/clk-exynos7420.c index 9caa932e12fb..cd6d67a0752b 100644 --- a/drivers/clk/exynos/clk-exynos7420.c +++ b/drivers/clk/exynos/clk-exynos7420.c @@ -10,9 +10,9 @@ #include <errno.h> #include <clk-uclass.h> #include <asm/io.h> #include <div64.h> -#include <dt-bindings/clock/exynos7420-clk.h> +#include <dt-bindings/clock/exynos7-clk.h>
#define PLL145X_MDIV_SHIFT 16 #define PLL145X_MDIV_MASK 0x3ff #define PLL145X_PDIV_SHIFT 8 diff --git a/include/dt-bindings/clock/exynos7420-clk.h b/include/dt-bindings/clock/exynos7420-clk.h deleted file mode 100644 index 10c558611085..000000000000 --- a/include/dt-bindings/clock/exynos7420-clk.h +++ /dev/null @@ -1,207 +0,0 @@ -/* - * Copyright (c) 2014 Samsung Electronics Co., Ltd. - * Author: Naveen Krishna Ch naveenkrishna.ch@gmail.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. -*/ - -#ifndef _DT_BINDINGS_CLOCK_EXYNOS7_H -#define _DT_BINDINGS_CLOCK_EXYNOS7_H - -/* TOPC */ -#define DOUT_ACLK_PERIS 1 -#define DOUT_SCLK_BUS0_PLL 2 -#define DOUT_SCLK_BUS1_PLL 3 -#define DOUT_SCLK_CC_PLL 4 -#define DOUT_SCLK_MFC_PLL 5 -#define DOUT_ACLK_CCORE_133 6 -#define DOUT_ACLK_MSCL_532 7 -#define ACLK_MSCL_532 8 -#define DOUT_SCLK_AUD_PLL 9 -#define FOUT_AUD_PLL 10 -#define SCLK_AUD_PLL 11 -#define SCLK_MFC_PLL_B 12 -#define SCLK_MFC_PLL_A 13 -#define SCLK_BUS1_PLL_B 14 -#define SCLK_BUS1_PLL_A 15 -#define SCLK_BUS0_PLL_B 16 -#define SCLK_BUS0_PLL_A 17 -#define SCLK_CC_PLL_B 18 -#define SCLK_CC_PLL_A 19 -#define ACLK_CCORE_133 20 -#define ACLK_PERIS_66 21 -#define TOPC_NR_CLK 22 - -/* TOP0 */ -#define DOUT_ACLK_PERIC1 1 -#define DOUT_ACLK_PERIC0 2 -#define CLK_SCLK_UART0 3 -#define CLK_SCLK_UART1 4 -#define CLK_SCLK_UART2 5 -#define CLK_SCLK_UART3 6 -#define CLK_SCLK_SPI0 7 -#define CLK_SCLK_SPI1 8 -#define CLK_SCLK_SPI2 9 -#define CLK_SCLK_SPI3 10 -#define CLK_SCLK_SPI4 11 -#define CLK_SCLK_SPDIF 12 -#define CLK_SCLK_PCM1 13 -#define CLK_SCLK_I2S1 14 -#define CLK_ACLK_PERIC0_66 15 -#define CLK_ACLK_PERIC1_66 16 -#define TOP0_NR_CLK 17 - -/* TOP1 */ -#define DOUT_ACLK_FSYS1_200 1 -#define DOUT_ACLK_FSYS0_200 2 -#define DOUT_SCLK_MMC2 3 -#define DOUT_SCLK_MMC1 4 -#define DOUT_SCLK_MMC0 5 -#define CLK_SCLK_MMC2 6 -#define CLK_SCLK_MMC1 7 -#define CLK_SCLK_MMC0 8 -#define CLK_ACLK_FSYS0_200 9 -#define CLK_ACLK_FSYS1_200 10 -#define CLK_SCLK_PHY_FSYS1 11 -#define CLK_SCLK_PHY_FSYS1_26M 12 -#define MOUT_SCLK_UFSUNIPRO20 13 -#define DOUT_SCLK_UFSUNIPRO20 14 -#define CLK_SCLK_UFSUNIPRO20 15 -#define DOUT_SCLK_PHY_FSYS1 16 -#define DOUT_SCLK_PHY_FSYS1_26M 17 -#define TOP1_NR_CLK 18 - -/* CCORE */ -#define PCLK_RTC 1 -#define CCORE_NR_CLK 2 - -/* PERIC0 */ -#define PCLK_UART0 1 -#define SCLK_UART0 2 -#define PCLK_HSI2C0 3 -#define PCLK_HSI2C1 4 -#define PCLK_HSI2C4 5 -#define PCLK_HSI2C5 6 -#define PCLK_HSI2C9 7 -#define PCLK_HSI2C10 8 -#define PCLK_HSI2C11 9 -#define PCLK_PWM 10 -#define SCLK_PWM 11 -#define PCLK_ADCIF 12 -#define PERIC0_NR_CLK 13 - -/* PERIC1 */ -#define PCLK_UART1 1 -#define PCLK_UART2 2 -#define PCLK_UART3 3 -#define SCLK_UART1 4 -#define SCLK_UART2 5 -#define SCLK_UART3 6 -#define PCLK_HSI2C2 7 -#define PCLK_HSI2C3 8 -#define PCLK_HSI2C6 9 -#define PCLK_HSI2C7 10 -#define PCLK_HSI2C8 11 -#define PCLK_SPI0 12 -#define PCLK_SPI1 13 -#define PCLK_SPI2 14 -#define PCLK_SPI3 15 -#define PCLK_SPI4 16 -#define SCLK_SPI0 17 -#define SCLK_SPI1 18 -#define SCLK_SPI2 19 -#define SCLK_SPI3 20 -#define SCLK_SPI4 21 -#define PCLK_I2S1 22 -#define PCLK_PCM1 23 -#define PCLK_SPDIF 24 -#define SCLK_I2S1 25 -#define SCLK_PCM1 26 -#define SCLK_SPDIF 27 -#define PERIC1_NR_CLK 28 - -/* PERIS */ -#define PCLK_CHIPID 1 -#define SCLK_CHIPID 2 -#define PCLK_WDT 3 -#define PCLK_TMU 4 -#define SCLK_TMU 5 -#define PERIS_NR_CLK 6 - -/* FSYS0 */ -#define ACLK_MMC2 1 -#define ACLK_AXIUS_USBDRD30X_FSYS0X 2 -#define ACLK_USBDRD300 3 -#define SCLK_USBDRD300_SUSPENDCLK 4 -#define SCLK_USBDRD300_REFCLK 5 -#define PHYCLK_USBDRD300_UDRD30_PIPE_PCLK_USER 6 -#define PHYCLK_USBDRD300_UDRD30_PHYCLK_USER 7 -#define OSCCLK_PHY_CLKOUT_USB30_PHY 8 -#define ACLK_PDMA0 9 -#define ACLK_PDMA1 10 -#define FSYS0_NR_CLK 11 - -/* FSYS1 */ -#define ACLK_MMC1 1 -#define ACLK_MMC0 2 -#define PHYCLK_UFS20_TX0_SYMBOL 3 -#define PHYCLK_UFS20_RX0_SYMBOL 4 -#define PHYCLK_UFS20_RX1_SYMBOL 5 -#define ACLK_UFS20_LINK 6 -#define SCLK_UFSUNIPRO20_USER 7 -#define PHYCLK_UFS20_RX1_SYMBOL_USER 8 -#define PHYCLK_UFS20_RX0_SYMBOL_USER 9 -#define PHYCLK_UFS20_TX0_SYMBOL_USER 10 -#define OSCCLK_PHY_CLKOUT_EMBEDDED_COMBO_PHY 11 -#define SCLK_COMBO_PHY_EMBEDDED_26M 12 -#define DOUT_PCLK_FSYS1 13 -#define PCLK_GPIO_FSYS1 14 -#define MOUT_FSYS1_PHYCLK_SEL1 15 -#define FSYS1_NR_CLK 16 - -/* MSCL */ -#define USERMUX_ACLK_MSCL_532 1 -#define DOUT_PCLK_MSCL 2 -#define ACLK_MSCL_0 3 -#define ACLK_MSCL_1 4 -#define ACLK_JPEG 5 -#define ACLK_G2D 6 -#define ACLK_LH_ASYNC_SI_MSCL_0 7 -#define ACLK_LH_ASYNC_SI_MSCL_1 8 -#define ACLK_AXI2ACEL_BRIDGE 9 -#define ACLK_XIU_MSCLX_0 10 -#define ACLK_XIU_MSCLX_1 11 -#define ACLK_QE_MSCL_0 12 -#define ACLK_QE_MSCL_1 13 -#define ACLK_QE_JPEG 14 -#define ACLK_QE_G2D 15 -#define ACLK_PPMU_MSCL_0 16 -#define ACLK_PPMU_MSCL_1 17 -#define ACLK_MSCLNP_133 18 -#define ACLK_AHB2APB_MSCL0P 19 -#define ACLK_AHB2APB_MSCL1P 20 - -#define PCLK_MSCL_0 21 -#define PCLK_MSCL_1 22 -#define PCLK_JPEG 23 -#define PCLK_G2D 24 -#define PCLK_QE_MSCL_0 25 -#define PCLK_QE_MSCL_1 26 -#define PCLK_QE_JPEG 27 -#define PCLK_QE_G2D 28 -#define PCLK_PPMU_MSCL_0 29 -#define PCLK_PPMU_MSCL_1 30 -#define PCLK_AXI2ACEL_BRIDGE 31 -#define PCLK_PMU_MSCL 32 -#define MSCL_NR_CLK 33 - -/* AUD */ -#define SCLK_I2S 1 -#define SCLK_PCM 2 -#define PCLK_I2S 3 -#define PCLK_PCM 4 -#define ACLK_ADMA 5 -#define AUD_NR_CLK 6 -#endif /* _DT_BINDINGS_CLOCK_EXYNOS7_H */ diff --git a/include/dt-bindings/clock/exynos850.h b/include/dt-bindings/clock/exynos850.h deleted file mode 100644 index 3090e09c9a55..000000000000 --- a/include/dt-bindings/clock/exynos850.h +++ /dev/null @@ -1,337 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * Copyright (C) 2021 Linaro Ltd. - * Author: Sam Protsenko semen.protsenko@linaro.org - * - * Device Tree binding constants for Exynos850 clock controller. - */ - -#ifndef _DT_BINDINGS_CLOCK_EXYNOS_850_H -#define _DT_BINDINGS_CLOCK_EXYNOS_850_H - -/* CMU_TOP */ -#define CLK_FOUT_SHARED0_PLL 1 -#define CLK_FOUT_SHARED1_PLL 2 -#define CLK_FOUT_MMC_PLL 3 -#define CLK_MOUT_SHARED0_PLL 4 -#define CLK_MOUT_SHARED1_PLL 5 -#define CLK_MOUT_MMC_PLL 6 -#define CLK_MOUT_CORE_BUS 7 -#define CLK_MOUT_CORE_CCI 8 -#define CLK_MOUT_CORE_MMC_EMBD 9 -#define CLK_MOUT_CORE_SSS 10 -#define CLK_MOUT_DPU 11 -#define CLK_MOUT_HSI_BUS 12 -#define CLK_MOUT_HSI_MMC_CARD 13 -#define CLK_MOUT_HSI_USB20DRD 14 -#define CLK_MOUT_PERI_BUS 15 -#define CLK_MOUT_PERI_UART 16 -#define CLK_MOUT_PERI_IP 17 -#define CLK_DOUT_SHARED0_DIV3 18 -#define CLK_DOUT_SHARED0_DIV2 19 -#define CLK_DOUT_SHARED1_DIV3 20 -#define CLK_DOUT_SHARED1_DIV2 21 -#define CLK_DOUT_SHARED0_DIV4 22 -#define CLK_DOUT_SHARED1_DIV4 23 -#define CLK_DOUT_CORE_BUS 24 -#define CLK_DOUT_CORE_CCI 25 -#define CLK_DOUT_CORE_MMC_EMBD 26 -#define CLK_DOUT_CORE_SSS 27 -#define CLK_DOUT_DPU 28 -#define CLK_DOUT_HSI_BUS 29 -#define CLK_DOUT_HSI_MMC_CARD 30 -#define CLK_DOUT_HSI_USB20DRD 31 -#define CLK_DOUT_PERI_BUS 32 -#define CLK_DOUT_PERI_UART 33 -#define CLK_DOUT_PERI_IP 34 -#define CLK_GOUT_CORE_BUS 35 -#define CLK_GOUT_CORE_CCI 36 -#define CLK_GOUT_CORE_MMC_EMBD 37 -#define CLK_GOUT_CORE_SSS 38 -#define CLK_GOUT_DPU 39 -#define CLK_GOUT_HSI_BUS 40 -#define CLK_GOUT_HSI_MMC_CARD 41 -#define CLK_GOUT_HSI_USB20DRD 42 -#define CLK_GOUT_PERI_BUS 43 -#define CLK_GOUT_PERI_UART 44 -#define CLK_GOUT_PERI_IP 45 -#define CLK_MOUT_CLKCMU_APM_BUS 46 -#define CLK_DOUT_CLKCMU_APM_BUS 47 -#define CLK_GOUT_CLKCMU_APM_BUS 48 -#define CLK_MOUT_AUD 49 -#define CLK_GOUT_AUD 50 -#define CLK_DOUT_AUD 51 -#define CLK_MOUT_IS_BUS 52 -#define CLK_MOUT_IS_ITP 53 -#define CLK_MOUT_IS_VRA 54 -#define CLK_MOUT_IS_GDC 55 -#define CLK_GOUT_IS_BUS 56 -#define CLK_GOUT_IS_ITP 57 -#define CLK_GOUT_IS_VRA 58 -#define CLK_GOUT_IS_GDC 59 -#define CLK_DOUT_IS_BUS 60 -#define CLK_DOUT_IS_ITP 61 -#define CLK_DOUT_IS_VRA 62 -#define CLK_DOUT_IS_GDC 63 -#define CLK_MOUT_MFCMSCL_MFC 64 -#define CLK_MOUT_MFCMSCL_M2M 65 -#define CLK_MOUT_MFCMSCL_MCSC 66 -#define CLK_MOUT_MFCMSCL_JPEG 67 -#define CLK_GOUT_MFCMSCL_MFC 68 -#define CLK_GOUT_MFCMSCL_M2M 69 -#define CLK_GOUT_MFCMSCL_MCSC 70 -#define CLK_GOUT_MFCMSCL_JPEG 71 -#define CLK_DOUT_MFCMSCL_MFC 72 -#define CLK_DOUT_MFCMSCL_M2M 73 -#define CLK_DOUT_MFCMSCL_MCSC 74 -#define CLK_DOUT_MFCMSCL_JPEG 75 -#define CLK_MOUT_G3D_SWITCH 76 -#define CLK_GOUT_G3D_SWITCH 77 -#define CLK_DOUT_G3D_SWITCH 78 - -/* CMU_APM */ -#define CLK_RCO_I3C_PMIC 1 -#define OSCCLK_RCO_APM 2 -#define CLK_RCO_APM__ALV 3 -#define CLK_DLL_DCO 4 -#define CLK_MOUT_APM_BUS_USER 5 -#define CLK_MOUT_RCO_APM_I3C_USER 6 -#define CLK_MOUT_RCO_APM_USER 7 -#define CLK_MOUT_DLL_USER 8 -#define CLK_MOUT_CLKCMU_CHUB_BUS 9 -#define CLK_MOUT_APM_BUS 10 -#define CLK_MOUT_APM_I3C 11 -#define CLK_DOUT_CLKCMU_CHUB_BUS 12 -#define CLK_DOUT_APM_BUS 13 -#define CLK_DOUT_APM_I3C 14 -#define CLK_GOUT_CLKCMU_CMGP_BUS 15 -#define CLK_GOUT_CLKCMU_CHUB_BUS 16 -#define CLK_GOUT_RTC_PCLK 17 -#define CLK_GOUT_TOP_RTC_PCLK 18 -#define CLK_GOUT_I3C_PCLK 19 -#define CLK_GOUT_I3C_SCLK 20 -#define CLK_GOUT_SPEEDY_PCLK 21 -#define CLK_GOUT_GPIO_ALIVE_PCLK 22 -#define CLK_GOUT_PMU_ALIVE_PCLK 23 -#define CLK_GOUT_SYSREG_APM_PCLK 24 - -/* CMU_AUD */ -#define CLK_DOUT_AUD_AUDIF 1 -#define CLK_DOUT_AUD_BUSD 2 -#define CLK_DOUT_AUD_BUSP 3 -#define CLK_DOUT_AUD_CNT 4 -#define CLK_DOUT_AUD_CPU 5 -#define CLK_DOUT_AUD_CPU_ACLK 6 -#define CLK_DOUT_AUD_CPU_PCLKDBG 7 -#define CLK_DOUT_AUD_FM 8 -#define CLK_DOUT_AUD_FM_SPDY 9 -#define CLK_DOUT_AUD_MCLK 10 -#define CLK_DOUT_AUD_UAIF0 11 -#define CLK_DOUT_AUD_UAIF1 12 -#define CLK_DOUT_AUD_UAIF2 13 -#define CLK_DOUT_AUD_UAIF3 14 -#define CLK_DOUT_AUD_UAIF4 15 -#define CLK_DOUT_AUD_UAIF5 16 -#define CLK_DOUT_AUD_UAIF6 17 -#define CLK_FOUT_AUD_PLL 18 -#define CLK_GOUT_AUD_ABOX_ACLK 19 -#define CLK_GOUT_AUD_ASB_CCLK 20 -#define CLK_GOUT_AUD_CA32_CCLK 21 -#define CLK_GOUT_AUD_CNT_BCLK 22 -#define CLK_GOUT_AUD_CODEC_MCLK 23 -#define CLK_GOUT_AUD_DAP_CCLK 24 -#define CLK_GOUT_AUD_GPIO_PCLK 25 -#define CLK_GOUT_AUD_PPMU_ACLK 26 -#define CLK_GOUT_AUD_PPMU_PCLK 27 -#define CLK_GOUT_AUD_SPDY_BCLK 28 -#define CLK_GOUT_AUD_SYSMMU_CLK 29 -#define CLK_GOUT_AUD_SYSREG_PCLK 30 -#define CLK_GOUT_AUD_TZPC_PCLK 31 -#define CLK_GOUT_AUD_UAIF0_BCLK 32 -#define CLK_GOUT_AUD_UAIF1_BCLK 33 -#define CLK_GOUT_AUD_UAIF2_BCLK 34 -#define CLK_GOUT_AUD_UAIF3_BCLK 35 -#define CLK_GOUT_AUD_UAIF4_BCLK 36 -#define CLK_GOUT_AUD_UAIF5_BCLK 37 -#define CLK_GOUT_AUD_UAIF6_BCLK 38 -#define CLK_GOUT_AUD_WDT_PCLK 39 -#define CLK_MOUT_AUD_CPU 40 -#define CLK_MOUT_AUD_CPU_HCH 41 -#define CLK_MOUT_AUD_CPU_USER 42 -#define CLK_MOUT_AUD_FM 43 -#define CLK_MOUT_AUD_PLL 44 -#define CLK_MOUT_AUD_TICK_USB_USER 45 -#define CLK_MOUT_AUD_UAIF0 46 -#define CLK_MOUT_AUD_UAIF1 47 -#define CLK_MOUT_AUD_UAIF2 48 -#define CLK_MOUT_AUD_UAIF3 49 -#define CLK_MOUT_AUD_UAIF4 50 -#define CLK_MOUT_AUD_UAIF5 51 -#define CLK_MOUT_AUD_UAIF6 52 -#define IOCLK_AUDIOCDCLK0 53 -#define IOCLK_AUDIOCDCLK1 54 -#define IOCLK_AUDIOCDCLK2 55 -#define IOCLK_AUDIOCDCLK3 56 -#define IOCLK_AUDIOCDCLK4 57 -#define IOCLK_AUDIOCDCLK5 58 -#define IOCLK_AUDIOCDCLK6 59 -#define TICK_USB 60 -#define CLK_GOUT_AUD_CMU_AUD_PCLK 61 - -/* CMU_CMGP */ -#define CLK_RCO_CMGP 1 -#define CLK_MOUT_CMGP_ADC 2 -#define CLK_MOUT_CMGP_USI0 3 -#define CLK_MOUT_CMGP_USI1 4 -#define CLK_DOUT_CMGP_ADC 5 -#define CLK_DOUT_CMGP_USI0 6 -#define CLK_DOUT_CMGP_USI1 7 -#define CLK_GOUT_CMGP_ADC_S0_PCLK 8 -#define CLK_GOUT_CMGP_ADC_S1_PCLK 9 -#define CLK_GOUT_CMGP_GPIO_PCLK 10 -#define CLK_GOUT_CMGP_USI0_IPCLK 11 -#define CLK_GOUT_CMGP_USI0_PCLK 12 -#define CLK_GOUT_CMGP_USI1_IPCLK 13 -#define CLK_GOUT_CMGP_USI1_PCLK 14 -#define CLK_GOUT_SYSREG_CMGP_PCLK 15 - -/* CMU_G3D */ -#define CLK_FOUT_G3D_PLL 1 -#define CLK_MOUT_G3D_PLL 2 -#define CLK_MOUT_G3D_SWITCH_USER 3 -#define CLK_MOUT_G3D_BUSD 4 -#define CLK_DOUT_G3D_BUSP 5 -#define CLK_GOUT_G3D_CMU_G3D_PCLK 6 -#define CLK_GOUT_G3D_GPU_CLK 7 -#define CLK_GOUT_G3D_TZPC_PCLK 8 -#define CLK_GOUT_G3D_GRAY2BIN_CLK 9 -#define CLK_GOUT_G3D_BUSD_CLK 10 -#define CLK_GOUT_G3D_BUSP_CLK 11 -#define CLK_GOUT_G3D_SYSREG_PCLK 12 - -/* CMU_HSI */ -#define CLK_MOUT_HSI_BUS_USER 1 -#define CLK_MOUT_HSI_MMC_CARD_USER 2 -#define CLK_MOUT_HSI_USB20DRD_USER 3 -#define CLK_MOUT_HSI_RTC 4 -#define CLK_GOUT_USB_RTC_CLK 5 -#define CLK_GOUT_USB_REF_CLK 6 -#define CLK_GOUT_USB_PHY_REF_CLK 7 -#define CLK_GOUT_USB_PHY_ACLK 8 -#define CLK_GOUT_USB_BUS_EARLY_CLK 9 -#define CLK_GOUT_GPIO_HSI_PCLK 10 -#define CLK_GOUT_MMC_CARD_ACLK 11 -#define CLK_GOUT_MMC_CARD_SDCLKIN 12 -#define CLK_GOUT_SYSREG_HSI_PCLK 13 -#define CLK_GOUT_HSI_PPMU_ACLK 14 -#define CLK_GOUT_HSI_PPMU_PCLK 15 -#define CLK_GOUT_HSI_CMU_HSI_PCLK 16 - -/* CMU_IS */ -#define CLK_MOUT_IS_BUS_USER 1 -#define CLK_MOUT_IS_ITP_USER 2 -#define CLK_MOUT_IS_VRA_USER 3 -#define CLK_MOUT_IS_GDC_USER 4 -#define CLK_DOUT_IS_BUSP 5 -#define CLK_GOUT_IS_CMU_IS_PCLK 6 -#define CLK_GOUT_IS_CSIS0_ACLK 7 -#define CLK_GOUT_IS_CSIS1_ACLK 8 -#define CLK_GOUT_IS_CSIS2_ACLK 9 -#define CLK_GOUT_IS_TZPC_PCLK 10 -#define CLK_GOUT_IS_CSIS_DMA_CLK 11 -#define CLK_GOUT_IS_GDC_CLK 12 -#define CLK_GOUT_IS_IPP_CLK 13 -#define CLK_GOUT_IS_ITP_CLK 14 -#define CLK_GOUT_IS_MCSC_CLK 15 -#define CLK_GOUT_IS_VRA_CLK 16 -#define CLK_GOUT_IS_PPMU_IS0_ACLK 17 -#define CLK_GOUT_IS_PPMU_IS0_PCLK 18 -#define CLK_GOUT_IS_PPMU_IS1_ACLK 19 -#define CLK_GOUT_IS_PPMU_IS1_PCLK 20 -#define CLK_GOUT_IS_SYSMMU_IS0_CLK 21 -#define CLK_GOUT_IS_SYSMMU_IS1_CLK 22 -#define CLK_GOUT_IS_SYSREG_PCLK 23 - -/* CMU_MFCMSCL */ -#define CLK_MOUT_MFCMSCL_MFC_USER 1 -#define CLK_MOUT_MFCMSCL_M2M_USER 2 -#define CLK_MOUT_MFCMSCL_MCSC_USER 3 -#define CLK_MOUT_MFCMSCL_JPEG_USER 4 -#define CLK_DOUT_MFCMSCL_BUSP 5 -#define CLK_GOUT_MFCMSCL_CMU_MFCMSCL_PCLK 6 -#define CLK_GOUT_MFCMSCL_TZPC_PCLK 7 -#define CLK_GOUT_MFCMSCL_JPEG_ACLK 8 -#define CLK_GOUT_MFCMSCL_M2M_ACLK 9 -#define CLK_GOUT_MFCMSCL_MCSC_CLK 10 -#define CLK_GOUT_MFCMSCL_MFC_ACLK 11 -#define CLK_GOUT_MFCMSCL_PPMU_ACLK 12 -#define CLK_GOUT_MFCMSCL_PPMU_PCLK 13 -#define CLK_GOUT_MFCMSCL_SYSMMU_CLK 14 -#define CLK_GOUT_MFCMSCL_SYSREG_PCLK 15 - -/* CMU_PERI */ -#define CLK_MOUT_PERI_BUS_USER 1 -#define CLK_MOUT_PERI_UART_USER 2 -#define CLK_MOUT_PERI_HSI2C_USER 3 -#define CLK_MOUT_PERI_SPI_USER 4 -#define CLK_DOUT_PERI_HSI2C0 5 -#define CLK_DOUT_PERI_HSI2C1 6 -#define CLK_DOUT_PERI_HSI2C2 7 -#define CLK_DOUT_PERI_SPI0 8 -#define CLK_GOUT_PERI_HSI2C0 9 -#define CLK_GOUT_PERI_HSI2C1 10 -#define CLK_GOUT_PERI_HSI2C2 11 -#define CLK_GOUT_GPIO_PERI_PCLK 12 -#define CLK_GOUT_HSI2C0_IPCLK 13 -#define CLK_GOUT_HSI2C0_PCLK 14 -#define CLK_GOUT_HSI2C1_IPCLK 15 -#define CLK_GOUT_HSI2C1_PCLK 16 -#define CLK_GOUT_HSI2C2_IPCLK 17 -#define CLK_GOUT_HSI2C2_PCLK 18 -#define CLK_GOUT_I2C0_PCLK 19 -#define CLK_GOUT_I2C1_PCLK 20 -#define CLK_GOUT_I2C2_PCLK 21 -#define CLK_GOUT_I2C3_PCLK 22 -#define CLK_GOUT_I2C4_PCLK 23 -#define CLK_GOUT_I2C5_PCLK 24 -#define CLK_GOUT_I2C6_PCLK 25 -#define CLK_GOUT_MCT_PCLK 26 -#define CLK_GOUT_PWM_MOTOR_PCLK 27 -#define CLK_GOUT_SPI0_IPCLK 28 -#define CLK_GOUT_SPI0_PCLK 29 -#define CLK_GOUT_SYSREG_PERI_PCLK 30 -#define CLK_GOUT_UART_IPCLK 31 -#define CLK_GOUT_UART_PCLK 32 -#define CLK_GOUT_WDT0_PCLK 33 -#define CLK_GOUT_WDT1_PCLK 34 - -/* CMU_CORE */ -#define CLK_MOUT_CORE_BUS_USER 1 -#define CLK_MOUT_CORE_CCI_USER 2 -#define CLK_MOUT_CORE_MMC_EMBD_USER 3 -#define CLK_MOUT_CORE_SSS_USER 4 -#define CLK_MOUT_CORE_GIC 5 -#define CLK_DOUT_CORE_BUSP 6 -#define CLK_GOUT_CCI_ACLK 7 -#define CLK_GOUT_GIC_CLK 8 -#define CLK_GOUT_MMC_EMBD_ACLK 9 -#define CLK_GOUT_MMC_EMBD_SDCLKIN 10 -#define CLK_GOUT_SSS_ACLK 11 -#define CLK_GOUT_SSS_PCLK 12 -#define CLK_GOUT_GPIO_CORE_PCLK 13 -#define CLK_GOUT_SYSREG_CORE_PCLK 14 - -/* CMU_DPU */ -#define CLK_MOUT_DPU_USER 1 -#define CLK_DOUT_DPU_BUSP 2 -#define CLK_GOUT_DPU_CMU_DPU_PCLK 3 -#define CLK_GOUT_DPU_DECON0_ACLK 4 -#define CLK_GOUT_DPU_DMA_ACLK 5 -#define CLK_GOUT_DPU_DPP_ACLK 6 -#define CLK_GOUT_DPU_PPMU_ACLK 7 -#define CLK_GOUT_DPU_PPMU_PCLK 8 -#define CLK_GOUT_DPU_SMMU_CLK 9 -#define CLK_GOUT_DPU_SYSREG_PCLK 10 -#define DPU_NR_CLK 11 - -#endif /* _DT_BINDINGS_CLOCK_EXYNOS_850_H */ diff --git a/include/dt-bindings/soc/samsung,exynos-usi.h b/include/dt-bindings/soc/samsung,exynos-usi.h deleted file mode 100644 index a01af169d249..000000000000 --- a/include/dt-bindings/soc/samsung,exynos-usi.h +++ /dev/null @@ -1,17 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * Copyright (c) 2021 Linaro Ltd. - * Author: Sam Protsenko semen.protsenko@linaro.org - * - * Device Tree bindings for Samsung Exynos USI (Universal Serial Interface). - */ - -#ifndef __DT_BINDINGS_SAMSUNG_EXYNOS_USI_H -#define __DT_BINDINGS_SAMSUNG_EXYNOS_USI_H - -#define USI_V2_NONE 0 -#define USI_V2_UART 1 -#define USI_V2_SPI 2 -#define USI_V2_I2C 3 - -#endif /* __DT_BINDINGS_SAMSUNG_EXYNOS_USI_H */
Drop in favour of dts/upstream
Fix bcm6318 USB clock name
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/mips/dts/brcm,bcm6318.dtsi | 2 +- include/dt-bindings/clock/bcm-nsp.h | 51 ------------------------ include/dt-bindings/clock/bcm2835-aux.h | 9 ----- include/dt-bindings/clock/bcm2835.h | 62 ------------------------------ include/dt-bindings/clock/bcm6318-clock.h | 47 ---------------------- include/dt-bindings/clock/bcm63268-clock.h | 51 ------------------------ include/dt-bindings/clock/bcm6328-clock.h | 24 ------------ include/dt-bindings/clock/bcm6358-clock.h | 23 ----------- include/dt-bindings/clock/bcm6362-clock.h | 32 --------------- include/dt-bindings/clock/bcm6368-clock.h | 30 --------------- include/dt-bindings/pinctrl/bcm2835.h | 26 ------------- include/dt-bindings/reset/bcm6318-reset.h | 25 ------------ include/dt-bindings/reset/bcm63268-reset.h | 31 --------------- include/dt-bindings/reset/bcm6328-reset.h | 23 ----------- include/dt-bindings/reset/bcm6358-reset.h | 20 ---------- include/dt-bindings/reset/bcm6362-reset.h | 27 ------------- include/dt-bindings/reset/bcm6368-reset.h | 21 ---------- include/dt-bindings/soc/bcm2835-pm.h | 28 -------------- 18 files changed, 1 insertion(+), 531 deletions(-)
diff --git a/arch/mips/dts/brcm,bcm6318.dtsi b/arch/mips/dts/brcm,bcm6318.dtsi index 5813de7bf6b9..b9cc0712f8bc 100644 --- a/arch/mips/dts/brcm,bcm6318.dtsi +++ b/arch/mips/dts/brcm,bcm6318.dtsi @@ -181,9 +181,9 @@ usbh: usb-phy@10005200 { compatible = "brcm,bcm6318-usbh"; reg = <0x10005200 0x30>; #phy-cells = <0>; - clocks = <&periph_clk BCM6318_CLK_USB>; + clocks = <&periph_clk BCM6318_CLK_USBD>; clock-names = "usbh"; power-domains = <&periph_pwr BCM6318_PWR_USB>; resets = <&periph_rst BCM6318_RST_USBH>;
diff --git a/include/dt-bindings/clock/bcm-nsp.h b/include/dt-bindings/clock/bcm-nsp.h deleted file mode 100644 index ad5827cde782..000000000000 --- a/include/dt-bindings/clock/bcm-nsp.h +++ /dev/null @@ -1,51 +0,0 @@ -/* - * BSD LICENSE - * - * Copyright(c) 2015 Broadcom Corporation. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * * Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * * Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * * Neither the name of Broadcom Corporation nor the names of its - * contributors may be used to endorse or promote products derived - * from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS - * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT - * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR - * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT - * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, - * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY - * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT - * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE - * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. - */ - -#ifndef _CLOCK_BCM_NSP_H -#define _CLOCK_BCM_NSP_H - -/* GENPLL clock channel ID */ -#define BCM_NSP_GENPLL 0 -#define BCM_NSP_GENPLL_PHY_CLK 1 -#define BCM_NSP_GENPLL_ENET_SW_CLK 2 -#define BCM_NSP_GENPLL_USB_PHY_REF_CLK 3 -#define BCM_NSP_GENPLL_IPROCFAST_CLK 4 -#define BCM_NSP_GENPLL_SATA1_CLK 5 -#define BCM_NSP_GENPLL_SATA2_CLK 6 - -/* LCPLL0 clock channel ID */ -#define BCM_NSP_LCPLL0 0 -#define BCM_NSP_LCPLL0_PCIE_PHY_REF_CLK 1 -#define BCM_NSP_LCPLL0_SDIO_CLK 2 -#define BCM_NSP_LCPLL0_DDR_PHY_CLK 3 - -#endif /* _CLOCK_BCM_NSP_H */ diff --git a/include/dt-bindings/clock/bcm2835-aux.h b/include/dt-bindings/clock/bcm2835-aux.h deleted file mode 100644 index bb79de383a3b..000000000000 --- a/include/dt-bindings/clock/bcm2835-aux.h +++ /dev/null @@ -1,9 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2015 Broadcom Corporation - */ - -#define BCM2835_AUX_CLOCK_UART 0 -#define BCM2835_AUX_CLOCK_SPI1 1 -#define BCM2835_AUX_CLOCK_SPI2 2 -#define BCM2835_AUX_CLOCK_COUNT 3 diff --git a/include/dt-bindings/clock/bcm2835.h b/include/dt-bindings/clock/bcm2835.h deleted file mode 100644 index b60c03430cf1..000000000000 --- a/include/dt-bindings/clock/bcm2835.h +++ /dev/null @@ -1,62 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2015 Broadcom Corporation - */ - -#define BCM2835_PLLA 0 -#define BCM2835_PLLB 1 -#define BCM2835_PLLC 2 -#define BCM2835_PLLD 3 -#define BCM2835_PLLH 4 - -#define BCM2835_PLLA_CORE 5 -#define BCM2835_PLLA_PER 6 -#define BCM2835_PLLB_ARM 7 -#define BCM2835_PLLC_CORE0 8 -#define BCM2835_PLLC_CORE1 9 -#define BCM2835_PLLC_CORE2 10 -#define BCM2835_PLLC_PER 11 -#define BCM2835_PLLD_CORE 12 -#define BCM2835_PLLD_PER 13 -#define BCM2835_PLLH_RCAL 14 -#define BCM2835_PLLH_AUX 15 -#define BCM2835_PLLH_PIX 16 - -#define BCM2835_CLOCK_TIMER 17 -#define BCM2835_CLOCK_OTP 18 -#define BCM2835_CLOCK_UART 19 -#define BCM2835_CLOCK_VPU 20 -#define BCM2835_CLOCK_V3D 21 -#define BCM2835_CLOCK_ISP 22 -#define BCM2835_CLOCK_H264 23 -#define BCM2835_CLOCK_VEC 24 -#define BCM2835_CLOCK_HSM 25 -#define BCM2835_CLOCK_SDRAM 26 -#define BCM2835_CLOCK_TSENS 27 -#define BCM2835_CLOCK_EMMC 28 -#define BCM2835_CLOCK_PERI_IMAGE 29 -#define BCM2835_CLOCK_PWM 30 -#define BCM2835_CLOCK_PCM 31 - -#define BCM2835_PLLA_DSI0 32 -#define BCM2835_PLLA_CCP2 33 -#define BCM2835_PLLD_DSI0 34 -#define BCM2835_PLLD_DSI1 35 - -#define BCM2835_CLOCK_AVEO 36 -#define BCM2835_CLOCK_DFT 37 -#define BCM2835_CLOCK_GP0 38 -#define BCM2835_CLOCK_GP1 39 -#define BCM2835_CLOCK_GP2 40 -#define BCM2835_CLOCK_SLIM 41 -#define BCM2835_CLOCK_SMI 42 -#define BCM2835_CLOCK_TEC 43 -#define BCM2835_CLOCK_DPI 44 -#define BCM2835_CLOCK_CAM0 45 -#define BCM2835_CLOCK_CAM1 46 -#define BCM2835_CLOCK_DSI0E 47 -#define BCM2835_CLOCK_DSI1E 48 -#define BCM2835_CLOCK_DSI0P 49 -#define BCM2835_CLOCK_DSI1P 50 - -#define BCM2711_CLOCK_EMMC2 51 diff --git a/include/dt-bindings/clock/bcm6318-clock.h b/include/dt-bindings/clock/bcm6318-clock.h deleted file mode 100644 index 3f10448cef11..000000000000 --- a/include/dt-bindings/clock/bcm6318-clock.h +++ /dev/null @@ -1,47 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM6318_H -#define __DT_BINDINGS_CLOCK_BCM6318_H - -#define BCM6318_CLK_ADSL_ASB 0 -#define BCM6318_CLK_USB_ASB 1 -#define BCM6318_CLK_MIPS_ASB 2 -#define BCM6318_CLK_PCIE_ASB 3 -#define BCM6318_CLK_PHYMIPS_ASB 4 -#define BCM6318_CLK_ROBOSW_ASB 5 -#define BCM6318_CLK_SAR_ASB 6 -#define BCM6318_CLK_SDR_ASB 7 -#define BCM6318_CLK_SWREG_ASB 8 -#define BCM6318_CLK_PERIPH_ASB 9 -#define BCM6318_CLK_CPUBUS160 10 -#define BCM6318_CLK_ADSL 11 -#define BCM6318_CLK_SAR125 12 -#define BCM6318_CLK_MIPS 13 -#define BCM6318_CLK_PCIE 14 -#define BCM6318_CLK_ROBOSW250 16 -#define BCM6318_CLK_ROBOSW025 17 -#define BCM6318_CLK_SDR 19 -#define BCM6318_CLK_USB 20 -#define BCM6318_CLK_HSSPI 25 -#define BCM6318_CLK_PCIE25 27 -#define BCM6318_CLK_PHYMIPS 28 -#define BCM6318_CLK_AFE 29 -#define BCM6318_CLK_QPROC 30 - -#define BCM6318_UCLK_ADSL 0 -#define BCM6318_UCLK_ARB 1 -#define BCM6318_UCLK_MIPS 2 -#define BCM6318_UCLK_PCIE 3 -#define BCM6318_UCLK_PERIPH 4 -#define BCM6318_UCLK_PHYMIPS 5 -#define BCM6318_UCLK_ROBOSW 6 -#define BCM6318_UCLK_SAR 7 -#define BCM6318_UCLK_SDR 8 -#define BCM6318_UCLK_USB 9 - -#endif /* __DT_BINDINGS_CLOCK_BCM6318_H */ diff --git a/include/dt-bindings/clock/bcm63268-clock.h b/include/dt-bindings/clock/bcm63268-clock.h deleted file mode 100644 index 2725dcd06bcc..000000000000 --- a/include/dt-bindings/clock/bcm63268-clock.h +++ /dev/null @@ -1,51 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM63268_H -#define __DT_BINDINGS_CLOCK_BCM63268_H - -#define BCM63268_CLK_GLESS 0 -#define BCM63268_CLK_VDSL_QPROC 1 -#define BCM63268_CLK_VDSL_AFE 2 -#define BCM63268_CLK_VDSL 3 -#define BCM63268_CLK_MIPS 4 -#define BCM63268_CLK_WLAN_OCP 5 -#define BCM63268_CLK_DECT 6 -#define BCM63268_CLK_FAP0 7 -#define BCM63268_CLK_FAP1 8 -#define BCM63268_CLK_SAR 9 -#define BCM63268_CLK_ROBOSW 10 -#define BCM63268_CLK_PCM 11 -#define BCM63268_CLK_USBD 12 -#define BCM63268_CLK_USBH 13 -#define BCM63268_CLK_IPSEC 14 -#define BCM63268_CLK_SPI 15 -#define BCM63268_CLK_HSSPI 16 -#define BCM63268_CLK_PCIE 17 -#define BCM63268_CLK_PHYMIPS 18 -#define BCM63268_CLK_GMAC 19 -#define BCM63268_CLK_NAND 20 -#define BCM63268_CLK_TBUS 27 -#define BCM63268_CLK_ROBOSW250 31 - -#define BCM63268_TCLK_EPHY1 0 -#define BCM63268_TCLK_EPHY2 1 -#define BCM63268_TCLK_EPHY3 2 -#define BCM63268_TCLK_GPHY 3 -#define BCM63268_TCLK_DSL 4 -#define BCM63268_TCLK_WO_EPHY 5 -#define BCM63268_TCLK_WO_DSL 6 -#define BCM63268_TCLK_FAP1 11 -#define BCM63268_TCLK_FAP2 15 -#define BCM63268_TCLK_UTO_50 16 -#define BCM63268_TCLK_UTO_EXT 17 -#define BCM63268_TCLK_USB_REF 18 -#define BCM63268_TCLK_SW_RST 29 -#define BCM63268_TCLK_HW_RST 30 -#define BCM63268_TCLK_POR_RST 31 - -#endif /* __DT_BINDINGS_CLOCK_BCM63268_H */ diff --git a/include/dt-bindings/clock/bcm6328-clock.h b/include/dt-bindings/clock/bcm6328-clock.h deleted file mode 100644 index 6f1e018a74bb..000000000000 --- a/include/dt-bindings/clock/bcm6328-clock.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM6328_H -#define __DT_BINDINGS_CLOCK_BCM6328_H - -#define BCM6328_CLK_PHYMIPS 0 -#define BCM6328_CLK_ADSL_QPROC 1 -#define BCM6328_CLK_ADSL_AFE 2 -#define BCM6328_CLK_ADSL 3 -#define BCM6328_CLK_MIPS 4 -#define BCM6328_CLK_SAR 5 -#define BCM6328_CLK_PCM 6 -#define BCM6328_CLK_USBD 7 -#define BCM6328_CLK_USBH 8 -#define BCM6328_CLK_HSSPI 9 -#define BCM6328_CLK_PCIE 10 -#define BCM6328_CLK_ROBOSW 11 - -#endif /* __DT_BINDINGS_CLOCK_BCM6328_H */ diff --git a/include/dt-bindings/clock/bcm6358-clock.h b/include/dt-bindings/clock/bcm6358-clock.h deleted file mode 100644 index a7529bcc0303..000000000000 --- a/include/dt-bindings/clock/bcm6358-clock.h +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM6358_H -#define __DT_BINDINGS_CLOCK_BCM6358_H - -#define BCM6358_CLK_ENET 4 -#define BCM6358_CLK_ADSL 5 -#define BCM6358_CLK_PCM 8 -#define BCM6358_CLK_SPI 9 -#define BCM6358_CLK_USBS 10 -#define BCM6358_CLK_SAR 11 -#define BCM6358_CLK_EMUSB 17 -#define BCM6358_CLK_ENET0 18 -#define BCM6358_CLK_ENET1 19 -#define BCM6358_CLK_USBSU 20 -#define BCM6358_CLK_EPHY 21 - -#endif /* __DT_BINDINGS_CLOCK_BCM6358_H */ diff --git a/include/dt-bindings/clock/bcm6362-clock.h b/include/dt-bindings/clock/bcm6362-clock.h deleted file mode 100644 index d3770c504909..000000000000 --- a/include/dt-bindings/clock/bcm6362-clock.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM6362_H -#define __DT_BINDINGS_CLOCK_BCM6362_H - -#define BCM6362_CLK_GLESS 0 -#define BCM6362_CLK_ADSL_QPROC 1 -#define BCM6362_CLK_ADSL_AFE 2 -#define BCM6362_CLK_ADSL 3 -#define BCM6362_CLK_MIPS 4 -#define BCM6362_CLK_WLAN_OCP 5 -#define BCM6362_CLK_SWPKT_USB 7 -#define BCM6362_CLK_SWPKT_SAR 8 -#define BCM6362_CLK_SAR 9 -#define BCM6362_CLK_ROBOSW 10 -#define BCM6362_CLK_PCM 11 -#define BCM6362_CLK_USBD 12 -#define BCM6362_CLK_USBH 13 -#define BCM6362_CLK_IPSEC 14 -#define BCM6362_CLK_SPI 15 -#define BCM6362_CLK_HSSPI 16 -#define BCM6362_CLK_PCIE 17 -#define BCM6362_CLK_FAP 18 -#define BCM6362_CLK_PHYMIPS 19 -#define BCM6362_CLK_NAND 20 - -#endif /* __DT_BINDINGS_CLOCK_BCM6362_H */ diff --git a/include/dt-bindings/clock/bcm6368-clock.h b/include/dt-bindings/clock/bcm6368-clock.h deleted file mode 100644 index 0c857826329a..000000000000 --- a/include/dt-bindings/clock/bcm6368-clock.h +++ /dev/null @@ -1,30 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_CLOCK_BCM6368_H -#define __DT_BINDINGS_CLOCK_BCM6368_H - -#define BCM6368_CLK_VDSL_QPROC 2 -#define BCM6368_CLK_VDSL_AFE 3 -#define BCM6368_CLK_VDSL_BONDING 4 -#define BCM6368_CLK_VDSL 5 -#define BCM6368_CLK_PHYMIPS 6 -#define BCM6368_CLK_SWPKT_USB 7 -#define BCM6368_CLK_SWPKT_SAR 8 -#define BCM6368_CLK_SPI 9 -#define BCM6368_CLK_USBD 10 -#define BCM6368_CLK_SAR 11 -#define BCM6368_CLK_ROBOSW 12 -#define BCM6368_CLK_UTOPIA 13 -#define BCM6368_CLK_PCM 14 -#define BCM6368_CLK_USBH 15 -#define BCM6368_CLK_GLESS 16 -#define BCM6368_CLK_NAND 17 -#define BCM6368_CLK_IPSEC 18 -#define BCM6368_CLK_USBH_IDDQ 19 - -#endif /* __DT_BINDINGS_CLOCK_BCM6368_H */ diff --git a/include/dt-bindings/pinctrl/bcm2835.h b/include/dt-bindings/pinctrl/bcm2835.h deleted file mode 100644 index b5b2654a0e4d..000000000000 --- a/include/dt-bindings/pinctrl/bcm2835.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Header providing constants for bcm2835 pinctrl bindings. - * - * Copyright (C) 2015 Stefan Wahren stefan.wahren@i2se.com - */ - -#ifndef __DT_BINDINGS_PINCTRL_BCM2835_H__ -#define __DT_BINDINGS_PINCTRL_BCM2835_H__ - -/* brcm,function property */ -#define BCM2835_FSEL_GPIO_IN 0 -#define BCM2835_FSEL_GPIO_OUT 1 -#define BCM2835_FSEL_ALT5 2 -#define BCM2835_FSEL_ALT4 3 -#define BCM2835_FSEL_ALT0 4 -#define BCM2835_FSEL_ALT1 5 -#define BCM2835_FSEL_ALT2 6 -#define BCM2835_FSEL_ALT3 7 - -/* brcm,pull property */ -#define BCM2835_PUD_OFF 0 -#define BCM2835_PUD_DOWN 1 -#define BCM2835_PUD_UP 2 - -#endif /* __DT_BINDINGS_PINCTRL_BCM2835_H__ */ diff --git a/include/dt-bindings/reset/bcm6318-reset.h b/include/dt-bindings/reset/bcm6318-reset.h deleted file mode 100644 index 1422500f8f52..000000000000 --- a/include/dt-bindings/reset/bcm6318-reset.h +++ /dev/null @@ -1,25 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM6318_H -#define __DT_BINDINGS_RESET_BCM6318_H - -#define BCM6318_RST_SPI 0 -#define BCM6318_RST_EPHY 1 -#define BCM6318_RST_SAR 2 -#define BCM6318_RST_ENETSW 3 -#define BCM6318_RST_USBD 4 -#define BCM6318_RST_USBH 5 -#define BCM6318_RST_PCIE_CORE 6 -#define BCM6318_RST_PCIE 7 -#define BCM6318_RST_PCIE_EXT 8 -#define BCM6318_RST_PCIE_HARD 9 -#define BCM6318_RST_ADSL 10 -#define BCM6318_RST_PHYMIPS 11 -#define BCM6318_RST_HOSTMIPS 11 - -#endif /* __DT_BINDINGS_RESET_BCM6318_H */ diff --git a/include/dt-bindings/reset/bcm63268-reset.h b/include/dt-bindings/reset/bcm63268-reset.h deleted file mode 100644 index a45abed1ceb7..000000000000 --- a/include/dt-bindings/reset/bcm63268-reset.h +++ /dev/null @@ -1,31 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM63268_H -#define __DT_BINDINGS_RESET_BCM63268_H - -#define BCM63268_RST_SPI 0 -#define BCM63268_RST_IPSEC 1 -#define BCM63268_RST_EPHY 2 -#define BCM63268_RST_SAR 3 -#define BCM63268_RST_ENETSW 4 -#define BCM63268_RST_USBS 5 -#define BCM63268_RST_USBH 6 -#define BCM63268_RST_PCM 7 -#define BCM63268_RST_PCIE_CORE 8 -#define BCM63268_RST_PCIE 9 -#define BCM63268_RST_PCIE_EXT 10 -#define BCM63268_RST_WLAN_SHIM 11 -#define BCM63268_RST_DDR_PHY 12 -#define BCM63268_RST_FAP0 13 -#define BCM63268_RST_WLAN_UBUS 14 -#define BCM63268_RST_DECT 15 -#define BCM63268_RST_FAP1 16 -#define BCM63268_RST_PCIE_HARD 17 -#define BCM63268_RST_GPHY 18 - -#endif /* __DT_BINDINGS_RESET_BCM63268_H */ diff --git a/include/dt-bindings/reset/bcm6328-reset.h b/include/dt-bindings/reset/bcm6328-reset.h deleted file mode 100644 index f2dd4f79cc61..000000000000 --- a/include/dt-bindings/reset/bcm6328-reset.h +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM6328_H -#define __DT_BINDINGS_RESET_BCM6328_H - -#define BCM6328_RST_SPI 0 -#define BCM6328_RST_EPHY 1 -#define BCM6328_RST_SAR 2 -#define BCM6328_RST_ENETSW 3 -#define BCM6328_RST_USBS 4 -#define BCM6328_RST_USBH 5 -#define BCM6328_RST_PCM 6 -#define BCM6328_RST_PCIE_CORE 7 -#define BCM6328_RST_PCIE 8 -#define BCM6328_RST_PCIE_EXT 9 -#define BCM6328_RST_PCIE_HARD 10 - -#endif /* __DT_BINDINGS_RESET_BCM6328_H */ diff --git a/include/dt-bindings/reset/bcm6358-reset.h b/include/dt-bindings/reset/bcm6358-reset.h deleted file mode 100644 index 075706eff7ad..000000000000 --- a/include/dt-bindings/reset/bcm6358-reset.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM6358_H -#define __DT_BINDINGS_RESET_BCM6358_H - -#define BCM6358_RST_SPI 0 -#define BCM6358_RST_ENET 2 -#define BCM6358_RST_MPI 3 -#define BCM6358_RST_EPHY 6 -#define BCM6358_RST_SAR 7 -#define BCM6358_RST_USBH 12 -#define BCM6358_RST_PCM 13 -#define BCM6358_RST_ADSL 14 - -#endif /* __DT_BINDINGS_RESET_BCM6358_H */ diff --git a/include/dt-bindings/reset/bcm6362-reset.h b/include/dt-bindings/reset/bcm6362-reset.h deleted file mode 100644 index 8202e4991905..000000000000 --- a/include/dt-bindings/reset/bcm6362-reset.h +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM6362_H -#define __DT_BINDINGS_RESET_BCM6362_H - -#define BCM6362_RST_SPI 0 -#define BCM6362_RST_IPSEC 1 -#define BCM6362_RST_EPHY 2 -#define BCM6362_RST_SAR 3 -#define BCM6362_RST_ENETSW 4 -#define BCM6362_RST_USBD 5 -#define BCM6362_RST_USBH 6 -#define BCM6362_RST_PCM 7 -#define BCM6362_RST_PCIE_CORE 8 -#define BCM6362_RST_PCIE 9 -#define BCM6362_RST_PCIE_EXT 10 -#define BCM6362_RST_WLAN_SHIM 11 -#define BCM6362_RST_DDR_PHY 12 -#define BCM6362_RST_FAP 13 -#define BCM6362_RST_WLAN_UBUS 14 - -#endif /* __DT_BINDINGS_RESET_BCM6362_H */ diff --git a/include/dt-bindings/reset/bcm6368-reset.h b/include/dt-bindings/reset/bcm6368-reset.h deleted file mode 100644 index 0038a7ccf5c6..000000000000 --- a/include/dt-bindings/reset/bcm6368-reset.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com - * - * Derived from linux/arch/mips/include/asm/mach-bcm63xx/bcm63xx_regs.h - */ - -#ifndef __DT_BINDINGS_RESET_BCM6368_H -#define __DT_BINDINGS_RESET_BCM6368_H - -#define BCM6368_RST_SPI 0 -#define BCM6368_RST_MPI 3 -#define BCM6368_RST_IPSEC 4 -#define BCM6368_RST_EPHY 6 -#define BCM6368_RST_SAR 7 -#define BCM6368_RST_SWITCH 10 -#define BCM6368_RST_USBD 11 -#define BCM6368_RST_USBH 12 -#define BCM6368_RST_PCM 13 - -#endif /* __DT_BINDINGS_RESET_BCM6368_H */ diff --git a/include/dt-bindings/soc/bcm2835-pm.h b/include/dt-bindings/soc/bcm2835-pm.h deleted file mode 100644 index 153d75b8d99f..000000000000 --- a/include/dt-bindings/soc/bcm2835-pm.h +++ /dev/null @@ -1,28 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ - -#ifndef _DT_BINDINGS_ARM_BCM2835_PM_H -#define _DT_BINDINGS_ARM_BCM2835_PM_H - -#define BCM2835_POWER_DOMAIN_GRAFX 0 -#define BCM2835_POWER_DOMAIN_GRAFX_V3D 1 -#define BCM2835_POWER_DOMAIN_IMAGE 2 -#define BCM2835_POWER_DOMAIN_IMAGE_PERI 3 -#define BCM2835_POWER_DOMAIN_IMAGE_ISP 4 -#define BCM2835_POWER_DOMAIN_IMAGE_H264 5 -#define BCM2835_POWER_DOMAIN_USB 6 -#define BCM2835_POWER_DOMAIN_DSI0 7 -#define BCM2835_POWER_DOMAIN_DSI1 8 -#define BCM2835_POWER_DOMAIN_CAM0 9 -#define BCM2835_POWER_DOMAIN_CAM1 10 -#define BCM2835_POWER_DOMAIN_CCP2TX 11 -#define BCM2835_POWER_DOMAIN_HDMI 12 - -#define BCM2835_POWER_DOMAIN_COUNT 13 - -#define BCM2835_RESET_V3D 0 -#define BCM2835_RESET_ISP 1 -#define BCM2835_RESET_H264 2 - -#define BCM2835_RESET_COUNT 3 - -#endif /* _DT_BINDINGS_ARM_BCM2835_PM_H */
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/net/phy/dp83869.c | 2 + include/dt-bindings/bus/ti-sysc.h | 28 ---- include/dt-bindings/clk/ti-dra7-atl.h | 40 ----- include/dt-bindings/clock/am3.h | 227 ----------------------------- include/dt-bindings/clock/omap4.h | 149 ------------------- include/dt-bindings/clock/omap5.h | 129 ---------------- include/dt-bindings/media/omap3-isp.h | 22 --- include/dt-bindings/mux/ti-serdes.h | 190 ------------------------ include/dt-bindings/net/ti-dp83867.h | 53 ------- include/dt-bindings/net/ti-dp83869.h | 60 -------- include/dt-bindings/phy/phy-ti.h | 21 --- include/dt-bindings/pinctrl/am33xx.h | 172 ---------------------- include/dt-bindings/pinctrl/am43xx.h | 39 ----- include/dt-bindings/pinctrl/omap.h | 91 ------------ include/dt-bindings/reset/ti-syscon.h | 38 ----- include/dt-bindings/soc/ti,sci_pm_domain.h | 9 -- 16 files changed, 2 insertions(+), 1268 deletions(-)
diff --git a/drivers/net/phy/dp83869.c b/drivers/net/phy/dp83869.c index f9d4782580e9..fa6be1f3ecde 100644 --- a/drivers/net/phy/dp83869.c +++ b/drivers/net/phy/dp83869.c @@ -105,8 +105,10 @@ #define DP83869_IO_MUX_CFG_CLK_O_DISABLE BIT(6) #define DP83869_IO_MUX_CFG_CLK_O_SEL_SHIFT 8 #define DP83869_IO_MUX_CFG_CLK_O_SEL_MASK \ GENMASK(0x1f, DP83869_IO_MUX_CFG_CLK_O_SEL_SHIFT) +/* Special flag to indicate clock should be off */ +#define DP83869_CLK_O_SEL_OFF 0xFFFFFFFF
/* CFG3 bits */ #define DP83869_CFG3_PORT_MIRROR_EN BIT(0)
diff --git a/include/dt-bindings/bus/ti-sysc.h b/include/dt-bindings/bus/ti-sysc.h deleted file mode 100644 index eae427454374..000000000000 --- a/include/dt-bindings/bus/ti-sysc.h +++ /dev/null @@ -1,28 +0,0 @@ -/* TI sysc interconnect target module defines */ - -/* Generic sysc found on omap2 and later, also known as type1 */ -#define SYSC_OMAP2_CLOCKACTIVITY (3 << 8) -#define SYSC_OMAP2_EMUFREE (1 << 5) -#define SYSC_OMAP2_ENAWAKEUP (1 << 2) -#define SYSC_OMAP2_SOFTRESET (1 << 1) -#define SYSC_OMAP2_AUTOIDLE (1 << 0) - -/* Generic sysc found on omap4 and later, also known as type2 */ -#define SYSC_OMAP4_DMADISABLE (1 << 16) -#define SYSC_OMAP4_FREEEMU (1 << 1) /* Also known as EMUFREE */ -#define SYSC_OMAP4_SOFTRESET (1 << 0) - -/* SmartReflex sysc found on 36xx and later */ -#define SYSC_OMAP3_SR_ENAWAKEUP (1 << 26) - -#define SYSC_DRA7_MCAN_ENAWAKEUP (1 << 4) - -/* PRUSS sysc found on AM33xx/AM43xx/AM57xx */ -#define SYSC_PRUSS_SUB_MWAIT (1 << 5) -#define SYSC_PRUSS_STANDBY_INIT (1 << 4) - -/* SYSCONFIG STANDBYMODE/MIDLEMODE/SIDLEMODE supported by hardware */ -#define SYSC_IDLE_FORCE 0 -#define SYSC_IDLE_NO 1 -#define SYSC_IDLE_SMART 2 -#define SYSC_IDLE_SMART_WKUP 3 diff --git a/include/dt-bindings/clk/ti-dra7-atl.h b/include/dt-bindings/clk/ti-dra7-atl.h deleted file mode 100644 index 42dd4164f6f4..000000000000 --- a/include/dt-bindings/clk/ti-dra7-atl.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * This header provides constants for DRA7 ATL (Audio Tracking Logic) - * - * The constants defined in this header are used in dts files - * - * Copyright (C) 2013 Texas Instruments, Inc. - * - * Peter Ujfalusi peter.ujfalusi@ti.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _DT_BINDINGS_CLK_DRA7_ATL_H -#define _DT_BINDINGS_CLK_DRA7_ATL_H - -#define DRA7_ATL_WS_MCASP1_FSR 0 -#define DRA7_ATL_WS_MCASP1_FSX 1 -#define DRA7_ATL_WS_MCASP2_FSR 2 -#define DRA7_ATL_WS_MCASP2_FSX 3 -#define DRA7_ATL_WS_MCASP3_FSX 4 -#define DRA7_ATL_WS_MCASP4_FSX 5 -#define DRA7_ATL_WS_MCASP5_FSX 6 -#define DRA7_ATL_WS_MCASP6_FSX 7 -#define DRA7_ATL_WS_MCASP7_FSX 8 -#define DRA7_ATL_WS_MCASP8_FSX 9 -#define DRA7_ATL_WS_MCASP8_AHCLKX 10 -#define DRA7_ATL_WS_XREF_CLK3 11 -#define DRA7_ATL_WS_XREF_CLK0 12 -#define DRA7_ATL_WS_XREF_CLK1 13 -#define DRA7_ATL_WS_XREF_CLK2 14 -#define DRA7_ATL_WS_OSC1_X1 15 - -#endif diff --git a/include/dt-bindings/clock/am3.h b/include/dt-bindings/clock/am3.h deleted file mode 100644 index 86a8806e2140..000000000000 --- a/include/dt-bindings/clock/am3.h +++ /dev/null @@ -1,227 +0,0 @@ -/* - * Copyright 2017 Texas Instruments, Inc. - * - * This software is licensed under the terms of the GNU General Public - * License version 2, as published by the Free Software Foundation, and - * may be copied, distributed, and modified under those terms. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ -#ifndef __DT_BINDINGS_CLK_AM3_H -#define __DT_BINDINGS_CLK_AM3_H - -#define AM3_CLKCTRL_OFFSET 0x0 -#define AM3_CLKCTRL_INDEX(offset) ((offset) - AM3_CLKCTRL_OFFSET) - -/* XXX: Compatibility part begin, remove this once compatibility support is no longer needed */ - -/* l4_per clocks */ -#define AM3_L4_PER_CLKCTRL_OFFSET 0x14 -#define AM3_L4_PER_CLKCTRL_INDEX(offset) ((offset) - AM3_L4_PER_CLKCTRL_OFFSET) -#define AM3_CPGMAC0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x14) -#define AM3_LCDC_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x18) -#define AM3_USB_OTG_HS_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x1c) -#define AM3_TPTC0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x24) -#define AM3_EMIF_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x28) -#define AM3_OCMCRAM_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x2c) -#define AM3_GPMC_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x30) -#define AM3_MCASP0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x34) -#define AM3_UART6_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x38) -#define AM3_MMC1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x3c) -#define AM3_ELM_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x40) -#define AM3_I2C3_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x44) -#define AM3_I2C2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x48) -#define AM3_SPI0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x4c) -#define AM3_SPI1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x50) -#define AM3_L4_LS_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x60) -#define AM3_MCASP1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x68) -#define AM3_UART2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x6c) -#define AM3_UART3_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x70) -#define AM3_UART4_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x74) -#define AM3_UART5_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x78) -#define AM3_TIMER7_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x7c) -#define AM3_TIMER2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x80) -#define AM3_TIMER3_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x84) -#define AM3_TIMER4_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x88) -#define AM3_RNG_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x90) -#define AM3_AES_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x94) -#define AM3_SHAM_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xa0) -#define AM3_GPIO2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xac) -#define AM3_GPIO3_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xb0) -#define AM3_GPIO4_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xb4) -#define AM3_TPCC_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xbc) -#define AM3_D_CAN0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xc0) -#define AM3_D_CAN1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xc4) -#define AM3_EPWMSS1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xcc) -#define AM3_EPWMSS0_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xd4) -#define AM3_EPWMSS2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xd8) -#define AM3_L3_INSTR_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xdc) -#define AM3_L3_MAIN_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xe0) -#define AM3_PRUSS_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xe8) -#define AM3_TIMER5_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xec) -#define AM3_TIMER6_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xf0) -#define AM3_MMC2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xf4) -#define AM3_MMC3_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xf8) -#define AM3_TPTC1_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0xfc) -#define AM3_TPTC2_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x100) -#define AM3_SPINLOCK_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x10c) -#define AM3_MAILBOX_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x110) -#define AM3_L4_HS_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x120) -#define AM3_OCPWP_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x130) -#define AM3_CLKDIV32K_CLKCTRL AM3_L4_PER_CLKCTRL_INDEX(0x14c) - -/* l4_wkup clocks */ -#define AM3_L4_WKUP_CLKCTRL_OFFSET 0x4 -#define AM3_L4_WKUP_CLKCTRL_INDEX(offset) ((offset) - AM3_L4_WKUP_CLKCTRL_OFFSET) -#define AM3_CONTROL_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0x4) -#define AM3_GPIO1_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0x8) -#define AM3_L4_WKUP_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xc) -#define AM3_DEBUGSS_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0x14) -#define AM3_WKUP_M3_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xb0) -#define AM3_UART1_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xb4) -#define AM3_I2C1_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xb8) -#define AM3_ADC_TSC_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xbc) -#define AM3_SMARTREFLEX0_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xc0) -#define AM3_TIMER1_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xc4) -#define AM3_SMARTREFLEX1_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xc8) -#define AM3_WD_TIMER2_CLKCTRL AM3_L4_WKUP_CLKCTRL_INDEX(0xd4) - -/* mpu clocks */ -#define AM3_MPU_CLKCTRL_OFFSET 0x4 -#define AM3_MPU_CLKCTRL_INDEX(offset) ((offset) - AM3_MPU_CLKCTRL_OFFSET) -#define AM3_MPU_CLKCTRL AM3_MPU_CLKCTRL_INDEX(0x4) - -/* l4_rtc clocks */ -#define AM3_RTC_CLKCTRL AM3_CLKCTRL_INDEX(0x0) - -/* gfx_l3 clocks */ -#define AM3_GFX_L3_CLKCTRL_OFFSET 0x4 -#define AM3_GFX_L3_CLKCTRL_INDEX(offset) ((offset) - AM3_GFX_L3_CLKCTRL_OFFSET) -#define AM3_GFX_CLKCTRL AM3_GFX_L3_CLKCTRL_INDEX(0x4) - -/* l4_cefuse clocks */ -#define AM3_L4_CEFUSE_CLKCTRL_OFFSET 0x20 -#define AM3_L4_CEFUSE_CLKCTRL_INDEX(offset) ((offset) - AM3_L4_CEFUSE_CLKCTRL_OFFSET) -#define AM3_CEFUSE_CLKCTRL AM3_L4_CEFUSE_CLKCTRL_INDEX(0x20) - -/* XXX: Compatibility part end */ - -/* l4ls clocks */ -#define AM3_L4LS_CLKCTRL_OFFSET 0x38 -#define AM3_L4LS_CLKCTRL_INDEX(offset) ((offset) - AM3_L4LS_CLKCTRL_OFFSET) -#define AM3_L4LS_UART6_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x38) -#define AM3_L4LS_MMC1_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x3c) -#define AM3_L4LS_ELM_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x40) -#define AM3_L4LS_I2C3_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x44) -#define AM3_L4LS_I2C2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x48) -#define AM3_L4LS_SPI0_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x4c) -#define AM3_L4LS_SPI1_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x50) -#define AM3_L4LS_L4_LS_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x60) -#define AM3_L4LS_UART2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x6c) -#define AM3_L4LS_UART3_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x70) -#define AM3_L4LS_UART4_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x74) -#define AM3_L4LS_UART5_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x78) -#define AM3_L4LS_TIMER7_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x7c) -#define AM3_L4LS_TIMER2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x80) -#define AM3_L4LS_TIMER3_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x84) -#define AM3_L4LS_TIMER4_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x88) -#define AM3_L4LS_RNG_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x90) -#define AM3_L4LS_GPIO2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xac) -#define AM3_L4LS_GPIO3_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xb0) -#define AM3_L4LS_GPIO4_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xb4) -#define AM3_L4LS_D_CAN0_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xc0) -#define AM3_L4LS_D_CAN1_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xc4) -#define AM3_L4LS_EPWMSS1_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xcc) -#define AM3_L4LS_EPWMSS0_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xd4) -#define AM3_L4LS_EPWMSS2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xd8) -#define AM3_L4LS_TIMER5_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xec) -#define AM3_L4LS_TIMER6_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xf0) -#define AM3_L4LS_MMC2_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0xf4) -#define AM3_L4LS_SPINLOCK_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x10c) -#define AM3_L4LS_MAILBOX_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x110) -#define AM3_L4LS_OCPWP_CLKCTRL AM3_L4LS_CLKCTRL_INDEX(0x130) - -/* l3s clocks */ -#define AM3_L3S_CLKCTRL_OFFSET 0x1c -#define AM3_L3S_CLKCTRL_INDEX(offset) ((offset) - AM3_L3S_CLKCTRL_OFFSET) -#define AM3_L3S_USB_OTG_HS_CLKCTRL AM3_L3S_CLKCTRL_INDEX(0x1c) -#define AM3_L3S_GPMC_CLKCTRL AM3_L3S_CLKCTRL_INDEX(0x30) -#define AM3_L3S_MCASP0_CLKCTRL AM3_L3S_CLKCTRL_INDEX(0x34) -#define AM3_L3S_MCASP1_CLKCTRL AM3_L3S_CLKCTRL_INDEX(0x68) -#define AM3_L3S_MMC3_CLKCTRL AM3_L3S_CLKCTRL_INDEX(0xf8) - -/* l3 clocks */ -#define AM3_L3_CLKCTRL_OFFSET 0x24 -#define AM3_L3_CLKCTRL_INDEX(offset) ((offset) - AM3_L3_CLKCTRL_OFFSET) -#define AM3_L3_TPTC0_CLKCTRL AM3_L3_CLKCTRL_INDEX(0x24) -#define AM3_L3_EMIF_CLKCTRL AM3_L3_CLKCTRL_INDEX(0x28) -#define AM3_L3_OCMCRAM_CLKCTRL AM3_L3_CLKCTRL_INDEX(0x2c) -#define AM3_L3_AES_CLKCTRL AM3_L3_CLKCTRL_INDEX(0x94) -#define AM3_L3_SHAM_CLKCTRL AM3_L3_CLKCTRL_INDEX(0xa0) -#define AM3_L3_TPCC_CLKCTRL AM3_L3_CLKCTRL_INDEX(0xbc) -#define AM3_L3_L3_INSTR_CLKCTRL AM3_L3_CLKCTRL_INDEX(0xdc) -#define AM3_L3_L3_MAIN_CLKCTRL AM3_L3_CLKCTRL_INDEX(0xe0) -#define AM3_L3_TPTC1_CLKCTRL AM3_L3_CLKCTRL_INDEX(0xfc) -#define AM3_L3_TPTC2_CLKCTRL AM3_L3_CLKCTRL_INDEX(0x100) - -/* l4hs clocks */ -#define AM3_L4HS_CLKCTRL_OFFSET 0x120 -#define AM3_L4HS_CLKCTRL_INDEX(offset) ((offset) - AM3_L4HS_CLKCTRL_OFFSET) -#define AM3_L4HS_L4_HS_CLKCTRL AM3_L4HS_CLKCTRL_INDEX(0x120) - -/* pruss_ocp clocks */ -#define AM3_PRUSS_OCP_CLKCTRL_OFFSET 0xe8 -#define AM3_PRUSS_OCP_CLKCTRL_INDEX(offset) ((offset) - AM3_PRUSS_OCP_CLKCTRL_OFFSET) -#define AM3_PRUSS_OCP_PRUSS_CLKCTRL AM3_PRUSS_OCP_CLKCTRL_INDEX(0xe8) - -/* cpsw_125mhz clocks */ -#define AM3_CPSW_125MHZ_CPGMAC0_CLKCTRL AM3_CLKCTRL_INDEX(0x14) - -/* lcdc clocks */ -#define AM3_LCDC_CLKCTRL_OFFSET 0x18 -#define AM3_LCDC_CLKCTRL_INDEX(offset) ((offset) - AM3_LCDC_CLKCTRL_OFFSET) -#define AM3_LCDC_LCDC_CLKCTRL AM3_LCDC_CLKCTRL_INDEX(0x18) - -/* clk_24mhz clocks */ -#define AM3_CLK_24MHZ_CLKCTRL_OFFSET 0x14c -#define AM3_CLK_24MHZ_CLKCTRL_INDEX(offset) ((offset) - AM3_CLK_24MHZ_CLKCTRL_OFFSET) -#define AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL AM3_CLK_24MHZ_CLKCTRL_INDEX(0x14c) - -/* l4_wkup clocks */ -#define AM3_L4_WKUP_CONTROL_CLKCTRL AM3_CLKCTRL_INDEX(0x4) -#define AM3_L4_WKUP_GPIO1_CLKCTRL AM3_CLKCTRL_INDEX(0x8) -#define AM3_L4_WKUP_L4_WKUP_CLKCTRL AM3_CLKCTRL_INDEX(0xc) -#define AM3_L4_WKUP_UART1_CLKCTRL AM3_CLKCTRL_INDEX(0xb4) -#define AM3_L4_WKUP_I2C1_CLKCTRL AM3_CLKCTRL_INDEX(0xb8) -#define AM3_L4_WKUP_ADC_TSC_CLKCTRL AM3_CLKCTRL_INDEX(0xbc) -#define AM3_L4_WKUP_SMARTREFLEX0_CLKCTRL AM3_CLKCTRL_INDEX(0xc0) -#define AM3_L4_WKUP_TIMER1_CLKCTRL AM3_CLKCTRL_INDEX(0xc4) -#define AM3_L4_WKUP_SMARTREFLEX1_CLKCTRL AM3_CLKCTRL_INDEX(0xc8) -#define AM3_L4_WKUP_WD_TIMER2_CLKCTRL AM3_CLKCTRL_INDEX(0xd4) - -/* l3_aon clocks */ -#define AM3_L3_AON_CLKCTRL_OFFSET 0x14 -#define AM3_L3_AON_CLKCTRL_INDEX(offset) ((offset) - AM3_L3_AON_CLKCTRL_OFFSET) -#define AM3_L3_AON_DEBUGSS_CLKCTRL AM3_L3_AON_CLKCTRL_INDEX(0x14) - -/* l4_wkup_aon clocks */ -#define AM3_L4_WKUP_AON_CLKCTRL_OFFSET 0xb0 -#define AM3_L4_WKUP_AON_CLKCTRL_INDEX(offset) ((offset) - AM3_L4_WKUP_AON_CLKCTRL_OFFSET) -#define AM3_L4_WKUP_AON_WKUP_M3_CLKCTRL AM3_L4_WKUP_AON_CLKCTRL_INDEX(0xb0) - -/* mpu clocks */ -#define AM3_MPU_MPU_CLKCTRL AM3_CLKCTRL_INDEX(0x4) - -/* l4_rtc clocks */ -#define AM3_L4_RTC_RTC_CLKCTRL AM3_CLKCTRL_INDEX(0x0) - -/* gfx_l3 clocks */ -#define AM3_GFX_L3_GFX_CLKCTRL AM3_CLKCTRL_INDEX(0x4) - -/* l4_cefuse clocks */ -#define AM3_L4_CEFUSE_CEFUSE_CLKCTRL AM3_CLKCTRL_INDEX(0x20) - -#endif diff --git a/include/dt-bindings/clock/omap4.h b/include/dt-bindings/clock/omap4.h deleted file mode 100644 index 88d73be84b94..000000000000 --- a/include/dt-bindings/clock/omap4.h +++ /dev/null @@ -1,149 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2017 Texas Instruments, Inc. - */ -#ifndef __DT_BINDINGS_CLK_OMAP4_H -#define __DT_BINDINGS_CLK_OMAP4_H - -#define OMAP4_CLKCTRL_OFFSET 0x20 -#define OMAP4_CLKCTRL_INDEX(offset) ((offset) - OMAP4_CLKCTRL_OFFSET) - -/* mpuss clocks */ -#define OMAP4_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* tesla clocks */ -#define OMAP4_DSP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* abe clocks */ -#define OMAP4_L4_ABE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_AESS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_MCPDM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_DMIC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) -#define OMAP4_MCASP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) -#define OMAP4_MCBSP1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) -#define OMAP4_MCBSP2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) -#define OMAP4_MCBSP3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) -#define OMAP4_SLIMBUS1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) -#define OMAP4_TIMER5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) -#define OMAP4_TIMER6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) -#define OMAP4_TIMER7_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) -#define OMAP4_TIMER8_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) -#define OMAP4_WD_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) - -/* l4_ao clocks */ -#define OMAP4_SMARTREFLEX_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_SMARTREFLEX_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_SMARTREFLEX_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) - -/* l3_1 clocks */ -#define OMAP4_L3_MAIN_1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l3_2 clocks */ -#define OMAP4_L3_MAIN_2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_GPMC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_OCMC_RAM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) - -/* ducati clocks */ -#define OMAP4_IPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l3_dma clocks */ -#define OMAP4_DMA_SYSTEM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l3_emif clocks */ -#define OMAP4_DMM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_EMIF1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_EMIF2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) - -/* d2d clocks */ -#define OMAP4_C2C_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l4_cfg clocks */ -#define OMAP4_L4_CFG_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_SPINLOCK_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_MAILBOX_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) - -/* l3_instr clocks */ -#define OMAP4_L3_MAIN_3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_L3_INSTR_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_OCP_WP_NOC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) - -/* ivahd clocks */ -#define OMAP4_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_SL2IF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) - -/* iss clocks */ -#define OMAP4_ISS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_FDIF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) - -/* l3_dss clocks */ -#define OMAP4_DSS_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l3_gfx clocks */ -#define OMAP4_GPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -/* l3_init clocks */ -#define OMAP4_MMC1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_MMC2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_HSI_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) -#define OMAP4_USB_HOST_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) -#define OMAP4_USB_OTG_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) -#define OMAP4_USB_TLL_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) -#define OMAP4_USB_HOST_FS_CLKCTRL OMAP4_CLKCTRL_INDEX(0xd0) -#define OMAP4_OCP2SCP_USB_PHY_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) - -/* l4_per clocks */ -#define OMAP4_TIMER10_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) -#define OMAP4_TIMER11_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) -#define OMAP4_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) -#define OMAP4_TIMER4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) -#define OMAP4_TIMER9_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) -#define OMAP4_ELM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) -#define OMAP4_GPIO2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) -#define OMAP4_GPIO3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) -#define OMAP4_GPIO4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) -#define OMAP4_GPIO5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) -#define OMAP4_GPIO6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) -#define OMAP4_HDQ1W_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) -#define OMAP4_I2C1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa0) -#define OMAP4_I2C2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa8) -#define OMAP4_I2C3_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb0) -#define OMAP4_I2C4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb8) -#define OMAP4_L4_PER_CLKCTRL OMAP4_CLKCTRL_INDEX(0xc0) -#define OMAP4_MCBSP4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) -#define OMAP4_MCSPI1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf0) -#define OMAP4_MCSPI2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf8) -#define OMAP4_MCSPI3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x100) -#define OMAP4_MCSPI4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x108) -#define OMAP4_MMC3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x120) -#define OMAP4_MMC4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x128) -#define OMAP4_SLIMBUS2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x138) -#define OMAP4_UART1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x140) -#define OMAP4_UART2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x148) -#define OMAP4_UART3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x150) -#define OMAP4_UART4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x158) -#define OMAP4_MMC5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x160) - -/* l4_secure clocks */ -#define OMAP4_L4_SECURE_CLKCTRL_OFFSET 0x1a0 -#define OMAP4_L4_SECURE_CLKCTRL_INDEX(offset) ((offset) - OMAP4_L4_SECURE_CLKCTRL_OFFSET) -#define OMAP4_AES1_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a0) -#define OMAP4_AES2_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a8) -#define OMAP4_DES3DES_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b0) -#define OMAP4_PKA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b8) -#define OMAP4_RNG_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c0) -#define OMAP4_SHA2MD5_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c8) -#define OMAP4_CRYPTODMA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1d8) - -/* l4_wkup clocks */ -#define OMAP4_L4_WKUP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) -#define OMAP4_WD_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) -#define OMAP4_GPIO1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) -#define OMAP4_TIMER1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) -#define OMAP4_COUNTER_32K_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) -#define OMAP4_KBD_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) - -/* emu_sys clocks */ -#define OMAP4_DEBUGSS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) - -#endif diff --git a/include/dt-bindings/clock/omap5.h b/include/dt-bindings/clock/omap5.h deleted file mode 100644 index 41775272fd27..000000000000 --- a/include/dt-bindings/clock/omap5.h +++ /dev/null @@ -1,129 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright 2017 Texas Instruments, Inc. - */ -#ifndef __DT_BINDINGS_CLK_OMAP5_H -#define __DT_BINDINGS_CLK_OMAP5_H - -#define OMAP5_CLKCTRL_OFFSET 0x20 -#define OMAP5_CLKCTRL_INDEX(offset) ((offset) - OMAP5_CLKCTRL_OFFSET) - -/* mpu clocks */ -#define OMAP5_MPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* dsp clocks */ -#define OMAP5_MMU_DSP_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* abe clocks */ -#define OMAP5_L4_ABE_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_AESS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) -#define OMAP5_MCPDM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) -#define OMAP5_DMIC_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) -#define OMAP5_MCBSP1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x48) -#define OMAP5_MCBSP2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) -#define OMAP5_MCBSP3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x58) -#define OMAP5_TIMER5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) -#define OMAP5_TIMER6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x70) -#define OMAP5_TIMER7_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) -#define OMAP5_TIMER8_CLKCTRL OMAP5_CLKCTRL_INDEX(0x80) - -/* l3main1 clocks */ -#define OMAP5_L3_MAIN_1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* l3main2 clocks */ -#define OMAP5_L3_MAIN_2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* ipu clocks */ -#define OMAP5_MMU_IPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* dma clocks */ -#define OMAP5_DMA_SYSTEM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* emif clocks */ -#define OMAP5_DMM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_EMIF1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) -#define OMAP5_EMIF2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) - -/* l4cfg clocks */ -#define OMAP5_L4_CFG_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_SPINLOCK_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) -#define OMAP5_MAILBOX_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) - -/* l3instr clocks */ -#define OMAP5_L3_MAIN_3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_L3_INSTR_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) - -/* l4per clocks */ -#define OMAP5_TIMER10_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) -#define OMAP5_TIMER11_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) -#define OMAP5_TIMER2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) -#define OMAP5_TIMER3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x40) -#define OMAP5_TIMER4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x48) -#define OMAP5_TIMER9_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) -#define OMAP5_GPIO2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x60) -#define OMAP5_GPIO3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) -#define OMAP5_GPIO4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x70) -#define OMAP5_GPIO5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) -#define OMAP5_GPIO6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x80) -#define OMAP5_I2C1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xa0) -#define OMAP5_I2C2_CLKCTRL OMAP5_CLKCTRL_INDEX(0xa8) -#define OMAP5_I2C3_CLKCTRL OMAP5_CLKCTRL_INDEX(0xb0) -#define OMAP5_I2C4_CLKCTRL OMAP5_CLKCTRL_INDEX(0xb8) -#define OMAP5_L4_PER_CLKCTRL OMAP5_CLKCTRL_INDEX(0xc0) -#define OMAP5_MCSPI1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf0) -#define OMAP5_MCSPI2_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf8) -#define OMAP5_MCSPI3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x100) -#define OMAP5_MCSPI4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x108) -#define OMAP5_GPIO7_CLKCTRL OMAP5_CLKCTRL_INDEX(0x110) -#define OMAP5_GPIO8_CLKCTRL OMAP5_CLKCTRL_INDEX(0x118) -#define OMAP5_MMC3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x120) -#define OMAP5_MMC4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x128) -#define OMAP5_UART1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x140) -#define OMAP5_UART2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x148) -#define OMAP5_UART3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x150) -#define OMAP5_UART4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x158) -#define OMAP5_MMC5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x160) -#define OMAP5_I2C5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x168) -#define OMAP5_UART5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x170) -#define OMAP5_UART6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x178) - -/* l4_secure clocks */ -#define OMAP5_L4_SECURE_CLKCTRL_OFFSET 0x1a0 -#define OMAP5_L4_SECURE_CLKCTRL_INDEX(offset) ((offset) - OMAP5_L4_SECURE_CLKCTRL_OFFSET) -#define OMAP5_AES1_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1a0) -#define OMAP5_AES2_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1a8) -#define OMAP5_DES3DES_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1b0) -#define OMAP5_FPKA_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1b8) -#define OMAP5_RNG_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1c0) -#define OMAP5_SHA2MD5_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1c8) -#define OMAP5_DMA_CRYPTO_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1d8) - -/* iva clocks */ -#define OMAP5_IVA_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_SL2IF_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) - -/* dss clocks */ -#define OMAP5_DSS_CORE_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* gpu clocks */ -#define OMAP5_GPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) - -/* l3init clocks */ -#define OMAP5_MMC1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) -#define OMAP5_MMC2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) -#define OMAP5_USB_HOST_HS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x58) -#define OMAP5_USB_TLL_HS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) -#define OMAP5_SATA_CLKCTRL OMAP5_CLKCTRL_INDEX(0x88) -#define OMAP5_OCP2SCP1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xe0) -#define OMAP5_OCP2SCP3_CLKCTRL OMAP5_CLKCTRL_INDEX(0xe8) -#define OMAP5_USB_OTG_SS_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf0) - -/* wkupaon clocks */ -#define OMAP5_L4_WKUP_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) -#define OMAP5_WD_TIMER2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) -#define OMAP5_GPIO1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) -#define OMAP5_TIMER1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x40) -#define OMAP5_COUNTER_32K_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) -#define OMAP5_KBD_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) - -#endif diff --git a/include/dt-bindings/media/omap3-isp.h b/include/dt-bindings/media/omap3-isp.h deleted file mode 100644 index 4e4208462142..000000000000 --- a/include/dt-bindings/media/omap3-isp.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * include/dt-bindings/media/omap3-isp.h - * - * Copyright (C) 2015 Sakari Ailus - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * version 2 as published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU - * General Public License for more details. - */ - -#ifndef __DT_BINDINGS_OMAP3_ISP_H__ -#define __DT_BINDINGS_OMAP3_ISP_H__ - -#define OMAP3ISP_PHY_TYPE_COMPLEX_IO 0 -#define OMAP3ISP_PHY_TYPE_CSIPHY 1 - -#endif /* __DT_BINDINGS_OMAP3_ISP_H__ */ diff --git a/include/dt-bindings/mux/ti-serdes.h b/include/dt-bindings/mux/ti-serdes.h deleted file mode 100644 index b0b1091aad6d..000000000000 --- a/include/dt-bindings/mux/ti-serdes.h +++ /dev/null @@ -1,190 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for SERDES MUX for TI SoCs - */ - -#ifndef _DT_BINDINGS_MUX_TI_SERDES -#define _DT_BINDINGS_MUX_TI_SERDES - -/* - * These bindings are deprecated, because they do not match the actual - * concept of bindings but rather contain pure constants values used only - * in DTS board files. - * Instead include the header in the DTS source directory. - */ -#warning "These bindings are deprecated. Instead, use the header in the DTS source directory." - -/* J721E */ - -#define J721E_SERDES0_LANE0_QSGMII_LANE1 0x0 -#define J721E_SERDES0_LANE0_PCIE0_LANE0 0x1 -#define J721E_SERDES0_LANE0_USB3_0_SWAP 0x2 -#define J721E_SERDES0_LANE0_IP4_UNUSED 0x3 - -#define J721E_SERDES0_LANE1_QSGMII_LANE2 0x0 -#define J721E_SERDES0_LANE1_PCIE0_LANE1 0x1 -#define J721E_SERDES0_LANE1_USB3_0 0x2 -#define J721E_SERDES0_LANE1_IP4_UNUSED 0x3 - -#define J721E_SERDES1_LANE0_QSGMII_LANE3 0x0 -#define J721E_SERDES1_LANE0_PCIE1_LANE0 0x1 -#define J721E_SERDES1_LANE0_USB3_1_SWAP 0x2 -#define J721E_SERDES1_LANE0_SGMII_LANE0 0x3 - -#define J721E_SERDES1_LANE1_QSGMII_LANE4 0x0 -#define J721E_SERDES1_LANE1_PCIE1_LANE1 0x1 -#define J721E_SERDES1_LANE1_USB3_1 0x2 -#define J721E_SERDES1_LANE1_SGMII_LANE1 0x3 - -#define J721E_SERDES2_LANE0_IP1_UNUSED 0x0 -#define J721E_SERDES2_LANE0_PCIE2_LANE0 0x1 -#define J721E_SERDES2_LANE0_USB3_1_SWAP 0x2 -#define J721E_SERDES2_LANE0_SGMII_LANE0 0x3 - -#define J721E_SERDES2_LANE1_IP1_UNUSED 0x0 -#define J721E_SERDES2_LANE1_PCIE2_LANE1 0x1 -#define J721E_SERDES2_LANE1_USB3_1 0x2 -#define J721E_SERDES2_LANE1_SGMII_LANE1 0x3 - -#define J721E_SERDES3_LANE0_IP1_UNUSED 0x0 -#define J721E_SERDES3_LANE0_PCIE3_LANE0 0x1 -#define J721E_SERDES3_LANE0_USB3_0_SWAP 0x2 -#define J721E_SERDES3_LANE0_IP4_UNUSED 0x3 - -#define J721E_SERDES3_LANE1_IP1_UNUSED 0x0 -#define J721E_SERDES3_LANE1_PCIE3_LANE1 0x1 -#define J721E_SERDES3_LANE1_USB3_0 0x2 -#define J721E_SERDES3_LANE1_IP4_UNUSED 0x3 - -#define J721E_SERDES4_LANE0_EDP_LANE0 0x0 -#define J721E_SERDES4_LANE0_IP2_UNUSED 0x1 -#define J721E_SERDES4_LANE0_QSGMII_LANE5 0x2 -#define J721E_SERDES4_LANE0_IP4_UNUSED 0x3 - -#define J721E_SERDES4_LANE1_EDP_LANE1 0x0 -#define J721E_SERDES4_LANE1_IP2_UNUSED 0x1 -#define J721E_SERDES4_LANE1_QSGMII_LANE6 0x2 -#define J721E_SERDES4_LANE1_IP4_UNUSED 0x3 - -#define J721E_SERDES4_LANE2_EDP_LANE2 0x0 -#define J721E_SERDES4_LANE2_IP2_UNUSED 0x1 -#define J721E_SERDES4_LANE2_QSGMII_LANE7 0x2 -#define J721E_SERDES4_LANE2_IP4_UNUSED 0x3 - -#define J721E_SERDES4_LANE3_EDP_LANE3 0x0 -#define J721E_SERDES4_LANE3_IP2_UNUSED 0x1 -#define J721E_SERDES4_LANE3_QSGMII_LANE8 0x2 -#define J721E_SERDES4_LANE3_IP4_UNUSED 0x3 - -/* J7200 */ - -#define J7200_SERDES0_LANE0_QSGMII_LANE3 0x0 -#define J7200_SERDES0_LANE0_PCIE1_LANE0 0x1 -#define J7200_SERDES0_LANE0_IP3_UNUSED 0x2 -#define J7200_SERDES0_LANE0_IP4_UNUSED 0x3 - -#define J7200_SERDES0_LANE1_QSGMII_LANE4 0x0 -#define J7200_SERDES0_LANE1_PCIE1_LANE1 0x1 -#define J7200_SERDES0_LANE1_IP3_UNUSED 0x2 -#define J7200_SERDES0_LANE1_IP4_UNUSED 0x3 - -#define J7200_SERDES0_LANE2_QSGMII_LANE1 0x0 -#define J7200_SERDES0_LANE2_PCIE1_LANE2 0x1 -#define J7200_SERDES0_LANE2_IP3_UNUSED 0x2 -#define J7200_SERDES0_LANE2_IP4_UNUSED 0x3 - -#define J7200_SERDES0_LANE3_QSGMII_LANE2 0x0 -#define J7200_SERDES0_LANE3_PCIE1_LANE3 0x1 -#define J7200_SERDES0_LANE3_USB 0x2 -#define J7200_SERDES0_LANE3_IP4_UNUSED 0x3 - -/* AM64 */ - -#define AM64_SERDES0_LANE0_PCIE0 0x0 -#define AM64_SERDES0_LANE0_USB 0x1 - -/* J721S2 */ - -#define J721S2_SERDES0_LANE0_EDP_LANE0 0x0 -#define J721S2_SERDES0_LANE0_PCIE1_LANE0 0x1 -#define J721S2_SERDES0_LANE0_IP3_UNUSED 0x2 -#define J721S2_SERDES0_LANE0_IP4_UNUSED 0x3 - -#define J721S2_SERDES0_LANE1_EDP_LANE1 0x0 -#define J721S2_SERDES0_LANE1_PCIE1_LANE1 0x1 -#define J721S2_SERDES0_LANE1_USB 0x2 -#define J721S2_SERDES0_LANE1_IP4_UNUSED 0x3 - -#define J721S2_SERDES0_LANE2_EDP_LANE2 0x0 -#define J721S2_SERDES0_LANE2_PCIE1_LANE2 0x1 -#define J721S2_SERDES0_LANE2_IP3_UNUSED 0x2 -#define J721S2_SERDES0_LANE2_IP4_UNUSED 0x3 - -#define J721S2_SERDES0_LANE3_EDP_LANE3 0x0 -#define J721S2_SERDES0_LANE3_PCIE1_LANE3 0x1 -#define J721S2_SERDES0_LANE3_USB 0x2 -#define J721S2_SERDES0_LANE3_IP4_UNUSED 0x3 - -/* J784S4 */ - -#define J784S4_SERDES0_LANE0_IP1_UNUSED 0x0 -#define J784S4_SERDES0_LANE0_PCIE1_LANE0 0x1 -#define J784S4_SERDES0_LANE0_IP3_UNUSED 0x2 -#define J784S4_SERDES0_LANE0_IP4_UNUSED 0x3 - -#define J784S4_SERDES0_LANE1_IP1_UNUSED 0x0 -#define J784S4_SERDES0_LANE1_PCIE1_LANE1 0x1 -#define J784S4_SERDES0_LANE1_IP3_UNUSED 0x2 -#define J784S4_SERDES0_LANE1_IP4_UNUSED 0x3 - -#define J784S4_SERDES0_LANE2_PCIE3_LANE0 0x0 -#define J784S4_SERDES0_LANE2_PCIE1_LANE2 0x1 -#define J784S4_SERDES0_LANE2_IP3_UNUSED 0x2 -#define J784S4_SERDES0_LANE2_IP4_UNUSED 0x3 - -#define J784S4_SERDES0_LANE3_PCIE3_LANE1 0x0 -#define J784S4_SERDES0_LANE3_PCIE1_LANE3 0x1 -#define J784S4_SERDES0_LANE3_USB 0x2 -#define J784S4_SERDES0_LANE3_IP4_UNUSED 0x3 - -#define J784S4_SERDES1_LANE0_QSGMII_LANE3 0x0 -#define J784S4_SERDES1_LANE0_PCIE0_LANE0 0x1 -#define J784S4_SERDES1_LANE0_IP3_UNUSED 0x2 -#define J784S4_SERDES1_LANE0_IP4_UNUSED 0x3 - -#define J784S4_SERDES1_LANE1_QSGMII_LANE4 0x0 -#define J784S4_SERDES1_LANE1_PCIE0_LANE1 0x1 -#define J784S4_SERDES1_LANE1_IP3_UNUSED 0x2 -#define J784S4_SERDES1_LANE1_IP4_UNUSED 0x3 - -#define J784S4_SERDES1_LANE2_QSGMII_LANE1 0x0 -#define J784S4_SERDES1_LANE2_PCIE0_LANE2 0x1 -#define J784S4_SERDES1_LANE2_PCIE2_LANE0 0x2 -#define J784S4_SERDES1_LANE2_IP4_UNUSED 0x3 - -#define J784S4_SERDES1_LANE3_QSGMII_LANE2 0x0 -#define J784S4_SERDES1_LANE3_PCIE0_LANE3 0x1 -#define J784S4_SERDES1_LANE3_PCIE2_LANE1 0x2 -#define J784S4_SERDES1_LANE3_IP4_UNUSED 0x3 - -#define J784S4_SERDES2_LANE0_QSGMII_LANE5 0x0 -#define J784S4_SERDES2_LANE0_IP2_UNUSED 0x1 -#define J784S4_SERDES2_LANE0_IP3_UNUSED 0x2 -#define J784S4_SERDES2_LANE0_IP4_UNUSED 0x3 - -#define J784S4_SERDES2_LANE1_QSGMII_LANE6 0x0 -#define J784S4_SERDES2_LANE1_IP2_UNUSED 0x1 -#define J784S4_SERDES2_LANE1_IP3_UNUSED 0x2 -#define J784S4_SERDES2_LANE1_IP4_UNUSED 0x3 - -#define J784S4_SERDES2_LANE2_QSGMII_LANE7 0x0 -#define J784S4_SERDES2_LANE2_QSGMII_LANE1 0x1 -#define J784S4_SERDES2_LANE2_IP3_UNUSED 0x2 -#define J784S4_SERDES2_LANE2_IP4_UNUSED 0x3 - -#define J784S4_SERDES2_LANE3_QSGMII_LANE8 0x0 -#define J784S4_SERDES2_LANE3_QSGMII_LANE2 0x1 -#define J784S4_SERDES2_LANE3_IP3_UNUSED 0x2 -#define J784S4_SERDES2_LANE3_IP4_UNUSED 0x3 - -#endif /* _DT_BINDINGS_MUX_TI_SERDES */ diff --git a/include/dt-bindings/net/ti-dp83867.h b/include/dt-bindings/net/ti-dp83867.h deleted file mode 100644 index 6fc4b445d3a1..000000000000 --- a/include/dt-bindings/net/ti-dp83867.h +++ /dev/null @@ -1,53 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Device Tree constants for the Texas Instruments DP83867 PHY - * - * Author: Dan Murphy dmurphy@ti.com - * - * Copyright: (C) 2015 Texas Instruments, Inc. - */ - -#ifndef _DT_BINDINGS_TI_DP83867_H -#define _DT_BINDINGS_TI_DP83867_H - -/* PHY CTRL bits */ -#define DP83867_PHYCR_FIFO_DEPTH_3_B_NIB 0x00 -#define DP83867_PHYCR_FIFO_DEPTH_4_B_NIB 0x01 -#define DP83867_PHYCR_FIFO_DEPTH_6_B_NIB 0x02 -#define DP83867_PHYCR_FIFO_DEPTH_8_B_NIB 0x03 - -/* RGMIIDCTL internal delay for rx and tx */ -#define DP83867_RGMIIDCTL_250_PS 0x0 -#define DP83867_RGMIIDCTL_500_PS 0x1 -#define DP83867_RGMIIDCTL_750_PS 0x2 -#define DP83867_RGMIIDCTL_1_NS 0x3 -#define DP83867_RGMIIDCTL_1_25_NS 0x4 -#define DP83867_RGMIIDCTL_1_50_NS 0x5 -#define DP83867_RGMIIDCTL_1_75_NS 0x6 -#define DP83867_RGMIIDCTL_2_00_NS 0x7 -#define DP83867_RGMIIDCTL_2_25_NS 0x8 -#define DP83867_RGMIIDCTL_2_50_NS 0x9 -#define DP83867_RGMIIDCTL_2_75_NS 0xa -#define DP83867_RGMIIDCTL_3_00_NS 0xb -#define DP83867_RGMIIDCTL_3_25_NS 0xc -#define DP83867_RGMIIDCTL_3_50_NS 0xd -#define DP83867_RGMIIDCTL_3_75_NS 0xe -#define DP83867_RGMIIDCTL_4_00_NS 0xf - -/* IO_MUX_CFG - Clock output selection */ -#define DP83867_CLK_O_SEL_CHN_A_RCLK 0x0 -#define DP83867_CLK_O_SEL_CHN_B_RCLK 0x1 -#define DP83867_CLK_O_SEL_CHN_C_RCLK 0x2 -#define DP83867_CLK_O_SEL_CHN_D_RCLK 0x3 -#define DP83867_CLK_O_SEL_CHN_A_RCLK_DIV5 0x4 -#define DP83867_CLK_O_SEL_CHN_B_RCLK_DIV5 0x5 -#define DP83867_CLK_O_SEL_CHN_C_RCLK_DIV5 0x6 -#define DP83867_CLK_O_SEL_CHN_D_RCLK_DIV5 0x7 -#define DP83867_CLK_O_SEL_CHN_A_TCLK 0x8 -#define DP83867_CLK_O_SEL_CHN_B_TCLK 0x9 -#define DP83867_CLK_O_SEL_CHN_C_TCLK 0xA -#define DP83867_CLK_O_SEL_CHN_D_TCLK 0xB -#define DP83867_CLK_O_SEL_REF_CLK 0xC -/* Special flag to indicate clock should be off */ -#define DP83867_CLK_O_SEL_OFF 0xFFFFFFFF -#endif diff --git a/include/dt-bindings/net/ti-dp83869.h b/include/dt-bindings/net/ti-dp83869.h deleted file mode 100644 index b3a5ac4a17b3..000000000000 --- a/include/dt-bindings/net/ti-dp83869.h +++ /dev/null @@ -1,60 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * TI DP83869 PHY drivers - * - */ - -#ifndef _DT_BINDINGS_TI_DP83869_H -#define _DT_BINDINGS_TI_DP83869_H - -/* PHY CTRL bits */ -#define DP83869_PHYCR_FIFO_DEPTH_3_B_NIB 0x00 -#define DP83869_PHYCR_FIFO_DEPTH_4_B_NIB 0x01 -#define DP83869_PHYCR_FIFO_DEPTH_6_B_NIB 0x02 -#define DP83869_PHYCR_FIFO_DEPTH_8_B_NIB 0x03 - -/* RGMIIDCTL internal delay for rx and tx */ -#define DP83869_RGMIIDCTL_250_PS 0x0 -#define DP83869_RGMIIDCTL_500_PS 0x1 -#define DP83869_RGMIIDCTL_750_PS 0x2 -#define DP83869_RGMIIDCTL_1_NS 0x3 -#define DP83869_RGMIIDCTL_1_25_NS 0x4 -#define DP83869_RGMIIDCTL_1_50_NS 0x5 -#define DP83869_RGMIIDCTL_1_75_NS 0x6 -#define DP83869_RGMIIDCTL_2_00_NS 0x7 -#define DP83869_RGMIIDCTL_2_25_NS 0x8 -#define DP83869_RGMIIDCTL_2_50_NS 0x9 -#define DP83869_RGMIIDCTL_2_75_NS 0xa -#define DP83869_RGMIIDCTL_3_00_NS 0xb -#define DP83869_RGMIIDCTL_3_25_NS 0xc -#define DP83869_RGMIIDCTL_3_50_NS 0xd -#define DP83869_RGMIIDCTL_3_75_NS 0xe -#define DP83869_RGMIIDCTL_4_00_NS 0xf - -/* IO_MUX_CFG - Clock output selection */ -#define DP83869_CLK_O_SEL_CHN_A_RCLK 0x0 -#define DP83869_CLK_O_SEL_CHN_B_RCLK 0x1 -#define DP83869_CLK_O_SEL_CHN_C_RCLK 0x2 -#define DP83869_CLK_O_SEL_CHN_D_RCLK 0x3 -#define DP83869_CLK_O_SEL_CHN_A_RCLK_DIV5 0x4 -#define DP83869_CLK_O_SEL_CHN_B_RCLK_DIV5 0x5 -#define DP83869_CLK_O_SEL_CHN_C_RCLK_DIV5 0x6 -#define DP83869_CLK_O_SEL_CHN_D_RCLK_DIV5 0x7 -#define DP83869_CLK_O_SEL_CHN_A_TCLK 0x8 -#define DP83869_CLK_O_SEL_CHN_B_TCLK 0x9 -#define DP83869_CLK_O_SEL_CHN_C_TCLK 0xA -#define DP83869_CLK_O_SEL_CHN_D_TCLK 0xB -#define DP83869_CLK_O_SEL_REF_CLK 0xC -/* Special flag to indicate clock should be off */ -#define DP83869_CLK_O_SEL_OFF 0xFFFFFFFF - -/* OPMODE - Operation mode */ -#define DP83869_RGMII_COPPER_ETHERNET 0x00 -#define DP83869_RGMII_1000_BASE 0x01 -#define DP83869_RGMII_100_BASE 0x02 -#define DP83869_RGMII_SGMII_BRIDGE 0x03 -#define DP83869_1000M_MEDIA_CONVERT 0x04 -#define DP83869_100M_MEDIA_CONVERT 0x05 -#define DP83869_SGMII_COPPER_ETHERNET 0x06 - -#endif diff --git a/include/dt-bindings/phy/phy-ti.h b/include/dt-bindings/phy/phy-ti.h deleted file mode 100644 index ad955d3a56b4..000000000000 --- a/include/dt-bindings/phy/phy-ti.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for TI SERDES. - */ - -#ifndef _DT_BINDINGS_TI_SERDES -#define _DT_BINDINGS_TI_SERDES - -/* Clock index for output clocks from WIZ */ - -/* MUX Clocks */ -#define TI_WIZ_PLL0_REFCLK 0 -#define TI_WIZ_PLL1_REFCLK 1 -#define TI_WIZ_REFCLK_DIG 2 - -/* Reserve index here for future additions */ - -/* MISC Clocks */ -#define TI_WIZ_PHY_EN_REFCLK 16 - -#endif /* _DT_BINDINGS_TI_SERDES */ diff --git a/include/dt-bindings/pinctrl/am33xx.h b/include/dt-bindings/pinctrl/am33xx.h deleted file mode 100644 index 17877e85980b..000000000000 --- a/include/dt-bindings/pinctrl/am33xx.h +++ /dev/null @@ -1,172 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants specific to AM33XX pinctrl bindings. - */ - -#ifndef _DT_BINDINGS_PINCTRL_AM33XX_H -#define _DT_BINDINGS_PINCTRL_AM33XX_H - -#include <dt-bindings/pinctrl/omap.h> - -/* am33xx specific mux bit defines */ -#undef PULL_ENA -#undef INPUT_EN - -#define PULL_DISABLE (1 << 3) -#define INPUT_EN (1 << 5) -#define SLEWCTRL_SLOW (1 << 6) -#define SLEWCTRL_FAST 0 - -/* update macro depending on INPUT_EN and PULL_ENA */ -#undef PIN_OUTPUT -#undef PIN_OUTPUT_PULLUP -#undef PIN_OUTPUT_PULLDOWN -#undef PIN_INPUT -#undef PIN_INPUT_PULLUP -#undef PIN_INPUT_PULLDOWN - -#define PIN_OUTPUT (PULL_DISABLE) -#define PIN_OUTPUT_PULLUP (PULL_UP) -#define PIN_OUTPUT_PULLDOWN 0 -#define PIN_INPUT (INPUT_EN | PULL_DISABLE) -#define PIN_INPUT_PULLUP (INPUT_EN | PULL_UP) -#define PIN_INPUT_PULLDOWN (INPUT_EN) - -/* undef non-existing modes */ -#undef PIN_OFF_NONE -#undef PIN_OFF_OUTPUT_HIGH -#undef PIN_OFF_OUTPUT_LOW -#undef PIN_OFF_INPUT_PULLUP -#undef PIN_OFF_INPUT_PULLDOWN -#undef PIN_OFF_WAKEUPENABLE - -#define AM335X_PIN_OFFSET_MIN 0x0800U - -#define AM335X_PIN_GPMC_AD0 0x800 -#define AM335X_PIN_GPMC_AD1 0x804 -#define AM335X_PIN_GPMC_AD2 0x808 -#define AM335X_PIN_GPMC_AD3 0x80c -#define AM335X_PIN_GPMC_AD4 0x810 -#define AM335X_PIN_GPMC_AD5 0x814 -#define AM335X_PIN_GPMC_AD6 0x818 -#define AM335X_PIN_GPMC_AD7 0x81c -#define AM335X_PIN_GPMC_AD8 0x820 -#define AM335X_PIN_GPMC_AD9 0x824 -#define AM335X_PIN_GPMC_AD10 0x828 -#define AM335X_PIN_GPMC_AD11 0x82c -#define AM335X_PIN_GPMC_AD12 0x830 -#define AM335X_PIN_GPMC_AD13 0x834 -#define AM335X_PIN_GPMC_AD14 0x838 -#define AM335X_PIN_GPMC_AD15 0x83c -#define AM335X_PIN_GPMC_A0 0x840 -#define AM335X_PIN_GPMC_A1 0x844 -#define AM335X_PIN_GPMC_A2 0x848 -#define AM335X_PIN_GPMC_A3 0x84c -#define AM335X_PIN_GPMC_A4 0x850 -#define AM335X_PIN_GPMC_A5 0x854 -#define AM335X_PIN_GPMC_A6 0x858 -#define AM335X_PIN_GPMC_A7 0x85c -#define AM335X_PIN_GPMC_A8 0x860 -#define AM335X_PIN_GPMC_A9 0x864 -#define AM335X_PIN_GPMC_A10 0x868 -#define AM335X_PIN_GPMC_A11 0x86c -#define AM335X_PIN_GPMC_WAIT0 0x870 -#define AM335X_PIN_GPMC_WPN 0x874 -#define AM335X_PIN_GPMC_BEN1 0x878 -#define AM335X_PIN_GPMC_CSN0 0x87c -#define AM335X_PIN_GPMC_CSN1 0x880 -#define AM335X_PIN_GPMC_CSN2 0x884 -#define AM335X_PIN_GPMC_CSN3 0x888 -#define AM335X_PIN_GPMC_CLK 0x88c -#define AM335X_PIN_GPMC_ADVN_ALE 0x890 -#define AM335X_PIN_GPMC_OEN_REN 0x894 -#define AM335X_PIN_GPMC_WEN 0x898 -#define AM335X_PIN_GPMC_BEN0_CLE 0x89c -#define AM335X_PIN_LCD_DATA0 0x8a0 -#define AM335X_PIN_LCD_DATA1 0x8a4 -#define AM335X_PIN_LCD_DATA2 0x8a8 -#define AM335X_PIN_LCD_DATA3 0x8ac -#define AM335X_PIN_LCD_DATA4 0x8b0 -#define AM335X_PIN_LCD_DATA5 0x8b4 -#define AM335X_PIN_LCD_DATA6 0x8b8 -#define AM335X_PIN_LCD_DATA7 0x8bc -#define AM335X_PIN_LCD_DATA8 0x8c0 -#define AM335X_PIN_LCD_DATA9 0x8c4 -#define AM335X_PIN_LCD_DATA10 0x8c8 -#define AM335X_PIN_LCD_DATA11 0x8cc -#define AM335X_PIN_LCD_DATA12 0x8d0 -#define AM335X_PIN_LCD_DATA13 0x8d4 -#define AM335X_PIN_LCD_DATA14 0x8d8 -#define AM335X_PIN_LCD_DATA15 0x8dc -#define AM335X_PIN_LCD_VSYNC 0x8e0 -#define AM335X_PIN_LCD_HSYNC 0x8e4 -#define AM335X_PIN_LCD_PCLK 0x8e8 -#define AM335X_PIN_LCD_AC_BIAS_EN 0x8ec -#define AM335X_PIN_MMC0_DAT3 0x8f0 -#define AM335X_PIN_MMC0_DAT2 0x8f4 -#define AM335X_PIN_MMC0_DAT1 0x8f8 -#define AM335X_PIN_MMC0_DAT0 0x8fc -#define AM335X_PIN_MMC0_CLK 0x900 -#define AM335X_PIN_MMC0_CMD 0x904 -#define AM335X_PIN_MII1_COL 0x908 -#define AM335X_PIN_MII1_CRS 0x90c -#define AM335X_PIN_MII1_RX_ER 0x910 -#define AM335X_PIN_MII1_TX_EN 0x914 -#define AM335X_PIN_MII1_RX_DV 0x918 -#define AM335X_PIN_MII1_TXD3 0x91c -#define AM335X_PIN_MII1_TXD2 0x920 -#define AM335X_PIN_MII1_TXD1 0x924 -#define AM335X_PIN_MII1_TXD0 0x928 -#define AM335X_PIN_MII1_TX_CLK 0x92c -#define AM335X_PIN_MII1_RX_CLK 0x930 -#define AM335X_PIN_MII1_RXD3 0x934 -#define AM335X_PIN_MII1_RXD2 0x938 -#define AM335X_PIN_MII1_RXD1 0x93c -#define AM335X_PIN_MII1_RXD0 0x940 -#define AM335X_PIN_RMII1_REF_CLK 0x944 -#define AM335X_PIN_MDIO 0x948 -#define AM335X_PIN_MDC 0x94c -#define AM335X_PIN_SPI0_SCLK 0x950 -#define AM335X_PIN_SPI0_D0 0x954 -#define AM335X_PIN_SPI0_D1 0x958 -#define AM335X_PIN_SPI0_CS0 0x95c -#define AM335X_PIN_SPI0_CS1 0x960 -#define AM335X_PIN_ECAP0_IN_PWM0_OUT 0x964 -#define AM335X_PIN_UART0_CTSN 0x968 -#define AM335X_PIN_UART0_RTSN 0x96c -#define AM335X_PIN_UART0_RXD 0x970 -#define AM335X_PIN_UART0_TXD 0x974 -#define AM335X_PIN_UART1_CTSN 0x978 -#define AM335X_PIN_UART1_RTSN 0x97c -#define AM335X_PIN_UART1_RXD 0x980 -#define AM335X_PIN_UART1_TXD 0x984 -#define AM335X_PIN_I2C0_SDA 0x988 -#define AM335X_PIN_I2C0_SCL 0x98c -#define AM335X_PIN_MCASP0_ACLKX 0x990 -#define AM335X_PIN_MCASP0_FSX 0x994 -#define AM335X_PIN_MCASP0_AXR0 0x998 -#define AM335X_PIN_MCASP0_AHCLKR 0x99c -#define AM335X_PIN_MCASP0_ACLKR 0x9a0 -#define AM335X_PIN_MCASP0_FSR 0x9a4 -#define AM335X_PIN_MCASP0_AXR1 0x9a8 -#define AM335X_PIN_MCASP0_AHCLKX 0x9ac -#define AM335X_PIN_XDMA_EVENT_INTR0 0x9b0 -#define AM335X_PIN_XDMA_EVENT_INTR1 0x9b4 -#define AM335X_PIN_WARMRSTN 0x9b8 -#define AM335X_PIN_NNMI 0x9c0 -#define AM335X_PIN_TMS 0x9d0 -#define AM335X_PIN_TDI 0x9d4 -#define AM335X_PIN_TDO 0x9d8 -#define AM335X_PIN_TCK 0x9dc -#define AM335X_PIN_TRSTN 0x9e0 -#define AM335X_PIN_EMU0 0x9e4 -#define AM335X_PIN_EMU1 0x9e8 -#define AM335X_PIN_RTC_PWRONRSTN 0x9f8 -#define AM335X_PIN_PMIC_POWER_EN 0x9fc -#define AM335X_PIN_EXT_WAKEUP 0xa00 -#define AM335X_PIN_USB0_DRVVBUS 0xa1c -#define AM335X_PIN_USB1_DRVVBUS 0xa34 - -#define AM335X_PIN_OFFSET_MAX 0x0a34U - -#endif diff --git a/include/dt-bindings/pinctrl/am43xx.h b/include/dt-bindings/pinctrl/am43xx.h deleted file mode 100644 index 292c2ebf58dd..000000000000 --- a/include/dt-bindings/pinctrl/am43xx.h +++ /dev/null @@ -1,39 +0,0 @@ -/* - * This header provides constants specific to AM43XX pinctrl bindings. - */ - -#ifndef _DT_BINDINGS_PINCTRL_AM43XX_H -#define _DT_BINDINGS_PINCTRL_AM43XX_H - -#define MUX_MODE0 0 -#define MUX_MODE1 1 -#define MUX_MODE2 2 -#define MUX_MODE3 3 -#define MUX_MODE4 4 -#define MUX_MODE5 5 -#define MUX_MODE6 6 -#define MUX_MODE7 7 -#define MUX_MODE8 8 - -#define PULL_DISABLE (1 << 16) -#define PULL_UP (1 << 17) -#define INPUT_EN (1 << 18) -#define SLEWCTRL_SLOW (1 << 19) -#define SLEWCTRL_FAST 0 -#define DS0_PULL_UP_DOWN_EN (1 << 27) -#define WAKEUP_ENABLE (1 << 29) - -#define PIN_OUTPUT (PULL_DISABLE) -#define PIN_OUTPUT_PULLUP (PULL_UP) -#define PIN_OUTPUT_PULLDOWN 0 -#define PIN_INPUT (INPUT_EN | PULL_DISABLE) -#define PIN_INPUT_PULLUP (INPUT_EN | PULL_UP) -#define PIN_INPUT_PULLDOWN (INPUT_EN) - -/* - * Macro to allow using the absolute physical address instead of the - * padconf registers instead of the offset from padconf base. - */ -#define AM4372_IOPAD(pa, val) (((pa) & 0xffff) - 0x0800) (val) - -#endif diff --git a/include/dt-bindings/pinctrl/omap.h b/include/dt-bindings/pinctrl/omap.h deleted file mode 100644 index 4c060ee0e0ad..000000000000 --- a/include/dt-bindings/pinctrl/omap.h +++ /dev/null @@ -1,91 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for OMAP pinctrl bindings. - * - * Copyright (C) 2009 Nokia - * Copyright (C) 2009-2010 Texas Instruments - */ - -#ifndef _DT_BINDINGS_PINCTRL_OMAP_H -#define _DT_BINDINGS_PINCTRL_OMAP_H - -/* 34xx mux mode options for each pin. See TRM for options */ -#define MUX_MODE0 0 -#define MUX_MODE1 1 -#define MUX_MODE2 2 -#define MUX_MODE3 3 -#define MUX_MODE4 4 -#define MUX_MODE5 5 -#define MUX_MODE6 6 -#define MUX_MODE7 7 - -/* 24xx/34xx mux bit defines */ -#define PULL_ENA (1 << 3) -#define PULL_UP (1 << 4) -#define ALTELECTRICALSEL (1 << 5) - -/* omap3/4/5 specific mux bit defines */ -#define INPUT_EN (1 << 8) -#define OFF_EN (1 << 9) -#define OFFOUT_EN (1 << 10) -#define OFFOUT_VAL (1 << 11) -#define OFF_PULL_EN (1 << 12) -#define OFF_PULL_UP (1 << 13) -#define WAKEUP_EN (1 << 14) -#define WAKEUP_EVENT (1 << 15) - -/* Active pin states */ -#define PIN_OUTPUT 0 -#define PIN_OUTPUT_PULLUP (PIN_OUTPUT | PULL_ENA | PULL_UP) -#define PIN_OUTPUT_PULLDOWN (PIN_OUTPUT | PULL_ENA) -#define PIN_INPUT INPUT_EN -#define PIN_INPUT_PULLUP (PULL_ENA | INPUT_EN | PULL_UP) -#define PIN_INPUT_PULLDOWN (PULL_ENA | INPUT_EN) - -/* Off mode states */ -#define PIN_OFF_NONE 0 -#define PIN_OFF_OUTPUT_HIGH (OFF_EN | OFFOUT_EN | OFFOUT_VAL) -#define PIN_OFF_OUTPUT_LOW (OFF_EN | OFFOUT_EN) -#define PIN_OFF_INPUT_PULLUP (OFF_EN | OFFOUT_EN | OFF_PULL_EN | OFF_PULL_UP) -#define PIN_OFF_INPUT_PULLDOWN (OFF_EN | OFFOUT_EN | OFF_PULL_EN) -#define PIN_OFF_WAKEUPENABLE WAKEUP_EN - -/* - * Macros to allow using the absolute physical address instead of the - * padconf registers instead of the offset from padconf base. - */ -#define OMAP_IOPAD_OFFSET(pa, offset) (((pa) & 0xffff) - (offset)) - -#define OMAP2420_CORE_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0030) (val) -#define OMAP2430_CORE_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2030) (val) -#define OMAP3_CORE1_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2030) (val) -#define OMAP3430_CORE2_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x25d8) (val) -#define OMAP3630_CORE2_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x25a0) (val) -#define OMAP3_WKUP_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2a00) (val) -#define DM814X_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) -#define DM816X_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) -#define AM33XX_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) (0) -#define AM33XX_PADCONF(pa, conf, mux) OMAP_IOPAD_OFFSET((pa), 0x0800) (conf) (mux) - -/* - * Macros to allow using the offset from the padconf physical address - * instead of the offset from padconf base. - */ -#define OMAP_PADCONF_OFFSET(offset, base_offset) ((offset) - (base_offset)) - -#define OMAP4_IOPAD(offset, val) OMAP_PADCONF_OFFSET((offset), 0x0040) (val) -#define OMAP5_IOPAD(offset, val) OMAP_PADCONF_OFFSET((offset), 0x0040) (val) - -/* - * Define some commonly used pins configured by the boards. - * Note that some boards use alternative pins, so check - * the schematics before using these. - */ -#define OMAP3_UART1_RX 0x152 -#define OMAP3_UART2_RX 0x14a -#define OMAP3_UART3_RX 0x16e -#define OMAP4_UART2_RX 0xdc -#define OMAP4_UART3_RX 0x104 -#define OMAP4_UART4_RX 0x11c - -#endif diff --git a/include/dt-bindings/reset/ti-syscon.h b/include/dt-bindings/reset/ti-syscon.h deleted file mode 100644 index 1427ff140f11..000000000000 --- a/include/dt-bindings/reset/ti-syscon.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * TI Syscon Reset definitions - * - * Copyright (C) 2015-2016 Texas Instruments Incorporated - https://www.ti.com/ - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __DT_BINDINGS_RESET_TI_SYSCON_H__ -#define __DT_BINDINGS_RESET_TI_SYSCON_H__ - -/* - * The reset does not support the feature and corresponding - * values are not valid - */ -#define ASSERT_NONE (1 << 0) -#define DEASSERT_NONE (1 << 1) -#define STATUS_NONE (1 << 2) - -/* When set this function is activated by setting(vs clearing) this bit */ -#define ASSERT_SET (1 << 3) -#define DEASSERT_SET (1 << 4) -#define STATUS_SET (1 << 5) - -/* The following are the inverse of the above and are added for consistency */ -#define ASSERT_CLEAR (0 << 3) -#define DEASSERT_CLEAR (0 << 4) -#define STATUS_CLEAR (0 << 5) - -#endif diff --git a/include/dt-bindings/soc/ti,sci_pm_domain.h b/include/dt-bindings/soc/ti,sci_pm_domain.h deleted file mode 100644 index 8f2a7360b65e..000000000000 --- a/include/dt-bindings/soc/ti,sci_pm_domain.h +++ /dev/null @@ -1,9 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ - -#ifndef __DT_BINDINGS_TI_SCI_PM_DOMAIN_H -#define __DT_BINDINGS_TI_SCI_PM_DOMAIN_H - -#define TI_SCI_PD_EXCLUSIVE 1 -#define TI_SCI_PD_SHARED 0 - -#endif /* __DT_BINDINGS_TI_SCI_PM_DOMAIN_H */
Drop in favour of dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/tegra114-car.h | 343 --------- include/dt-bindings/clock/tegra124-car-common.h | 345 --------- include/dt-bindings/clock/tegra124-car.h | 19 - include/dt-bindings/clock/tegra186-clock.h | 940 ------------------------ include/dt-bindings/clock/tegra20-car.h | 158 ---- include/dt-bindings/clock/tegra210-car.h | 401 ---------- include/dt-bindings/clock/tegra30-car.h | 273 ------- 7 files changed, 2479 deletions(-)
diff --git a/include/dt-bindings/clock/tegra114-car.h b/include/dt-bindings/clock/tegra114-car.h deleted file mode 100644 index 534c03f8ad72..000000000000 --- a/include/dt-bindings/clock/tegra114-car.h +++ /dev/null @@ -1,343 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra114-car. - * - * The first 160 clocks are numbered to match the bits in the CAR's CLK_OUT_ENB - * registers. These IDs often match those in the CAR's RST_DEVICES registers, - * but not in all cases. Some bits in CLK_OUT_ENB affect multiple clocks. In - * this case, those clocks are assigned IDs above 160 in order to highlight - * this issue. Implementations that interpret these clock IDs as bit values - * within the CLK_OUT_ENB or RST_DEVICES registers should be careful to - * explicitly handle these special cases. - * - * The balance of the clocks controlled by the CAR are assigned IDs of 160 and - * above. - */ - -#ifndef _DT_BINDINGS_CLOCK_TEGRA114_CAR_H -#define _DT_BINDINGS_CLOCK_TEGRA114_CAR_H - -/* 0 */ -/* 1 */ -/* 2 */ -/* 3 */ -#define TEGRA114_CLK_RTC 4 -#define TEGRA114_CLK_TIMER 5 -#define TEGRA114_CLK_UARTA 6 -/* 7 (register bit affects uartb and vfir) */ -/* 8 */ -#define TEGRA114_CLK_SDMMC2 9 -/* 10 (register bit affects spdif_in and spdif_out) */ -#define TEGRA114_CLK_I2S1 11 -#define TEGRA114_CLK_I2C1 12 -#define TEGRA114_CLK_NDFLASH 13 -#define TEGRA114_CLK_SDMMC1 14 -#define TEGRA114_CLK_SDMMC4 15 -/* 16 */ -#define TEGRA114_CLK_PWM 17 -#define TEGRA114_CLK_I2S2 18 -#define TEGRA114_CLK_EPP 19 -/* 20 (register bit affects vi and vi_sensor) */ -#define TEGRA114_CLK_GR2D 21 -#define TEGRA114_CLK_USBD 22 -#define TEGRA114_CLK_ISP 23 -#define TEGRA114_CLK_GR3D 24 -/* 25 */ -#define TEGRA114_CLK_DISP2 26 -#define TEGRA114_CLK_DISP1 27 -#define TEGRA114_CLK_HOST1X 28 -#define TEGRA114_CLK_VCP 29 -#define TEGRA114_CLK_I2S0 30 -/* 31 */ - -#define TEGRA114_CLK_MC 32 -/* 33 */ -#define TEGRA114_CLK_APBDMA 34 -/* 35 */ -#define TEGRA114_CLK_KBC 36 -/* 37 */ -/* 38 */ -/* 39 (register bit affects fuse and fuse_burn) */ -#define TEGRA114_CLK_KFUSE 40 -#define TEGRA114_CLK_SBC1 41 -#define TEGRA114_CLK_NOR 42 -/* 43 */ -#define TEGRA114_CLK_SBC2 44 -/* 45 */ -#define TEGRA114_CLK_SBC3 46 -#define TEGRA114_CLK_I2C5 47 -#define TEGRA114_CLK_DSIA 48 -/* 49 */ -#define TEGRA114_CLK_MIPI 50 -#define TEGRA114_CLK_HDMI 51 -#define TEGRA114_CLK_CSI 52 -/* 53 */ -#define TEGRA114_CLK_I2C2 54 -#define TEGRA114_CLK_UARTC 55 -#define TEGRA114_CLK_MIPI_CAL 56 -#define TEGRA114_CLK_EMC 57 -#define TEGRA114_CLK_USB2 58 -#define TEGRA114_CLK_USB3 59 -/* 60 */ -#define TEGRA114_CLK_VDE 61 -#define TEGRA114_CLK_BSEA 62 -#define TEGRA114_CLK_BSEV 63 - -/* 64 */ -#define TEGRA114_CLK_UARTD 65 -/* 66 */ -#define TEGRA114_CLK_I2C3 67 -#define TEGRA114_CLK_SBC4 68 -#define TEGRA114_CLK_SDMMC3 69 -/* 70 */ -#define TEGRA114_CLK_OWR 71 -/* 72 */ -#define TEGRA114_CLK_CSITE 73 -/* 74 */ -/* 75 */ -#define TEGRA114_CLK_LA 76 -#define TEGRA114_CLK_TRACE 77 -#define TEGRA114_CLK_SOC_THERM 78 -#define TEGRA114_CLK_DTV 79 -#define TEGRA114_CLK_NDSPEED 80 -#define TEGRA114_CLK_I2CSLOW 81 -#define TEGRA114_CLK_DSIB 82 -#define TEGRA114_CLK_TSEC 83 -/* 84 */ -/* 85 */ -/* 86 */ -/* 87 */ -/* 88 */ -#define TEGRA114_CLK_XUSB_HOST 89 -/* 90 */ -#define TEGRA114_CLK_MSENC 91 -#define TEGRA114_CLK_CSUS 92 -/* 93 */ -/* 94 */ -/* 95 (bit affects xusb_dev and xusb_dev_src) */ - -/* 96 */ -/* 97 */ -/* 98 */ -#define TEGRA114_CLK_MSELECT 99 -#define TEGRA114_CLK_TSENSOR 100 -#define TEGRA114_CLK_I2S3 101 -#define TEGRA114_CLK_I2S4 102 -#define TEGRA114_CLK_I2C4 103 -#define TEGRA114_CLK_SBC5 104 -#define TEGRA114_CLK_SBC6 105 -#define TEGRA114_CLK_D_AUDIO 106 -#define TEGRA114_CLK_APBIF 107 -#define TEGRA114_CLK_DAM0 108 -#define TEGRA114_CLK_DAM1 109 -#define TEGRA114_CLK_DAM2 110 -#define TEGRA114_CLK_HDA2CODEC_2X 111 -/* 112 */ -#define TEGRA114_CLK_AUDIO0_2X 113 -#define TEGRA114_CLK_AUDIO1_2X 114 -#define TEGRA114_CLK_AUDIO2_2X 115 -#define TEGRA114_CLK_AUDIO3_2X 116 -#define TEGRA114_CLK_AUDIO4_2X 117 -#define TEGRA114_CLK_SPDIF_2X 118 -#define TEGRA114_CLK_ACTMON 119 -#define TEGRA114_CLK_EXTERN1 120 -#define TEGRA114_CLK_EXTERN2 121 -#define TEGRA114_CLK_EXTERN3 122 -/* 123 */ -/* 124 */ -#define TEGRA114_CLK_HDA 125 -/* 126 */ -#define TEGRA114_CLK_SE 127 - -#define TEGRA114_CLK_HDA2HDMI 128 -/* 129 */ -/* 130 */ -/* 131 */ -/* 132 */ -/* 133 */ -/* 134 */ -/* 135 */ -/* 136 */ -/* 137 */ -/* 138 */ -/* 139 */ -/* 140 */ -/* 141 */ -/* 142 */ -/* 143 (bit affects xusb_falcon_src, xusb_fs_src, */ -/* xusb_host_src and xusb_ss_src) */ -#define TEGRA114_CLK_CILAB 144 -#define TEGRA114_CLK_CILCD 145 -#define TEGRA114_CLK_CILE 146 -#define TEGRA114_CLK_DSIALP 147 -#define TEGRA114_CLK_DSIBLP 148 -/* 149 */ -#define TEGRA114_CLK_DDS 150 -/* 151 */ -#define TEGRA114_CLK_DP2 152 -#define TEGRA114_CLK_AMX 153 -#define TEGRA114_CLK_ADX 154 -/* 155 (bit affects dfll_ref and dfll_soc) */ -#define TEGRA114_CLK_XUSB_SS 156 -/* 157 */ -/* 158 */ -/* 159 */ - -/* 160 */ -/* 161 */ -/* 162 */ -/* 163 */ -/* 164 */ -/* 165 */ -/* 166 */ -/* 167 */ -/* 168 */ -/* 169 */ -/* 170 */ -/* 171 */ -/* 172 */ -/* 173 */ -/* 174 */ -/* 175 */ -/* 176 */ -/* 177 */ -/* 178 */ -/* 179 */ -/* 180 */ -/* 181 */ -/* 182 */ -/* 183 */ -/* 184 */ -/* 185 */ -/* 186 */ -/* 187 */ -/* 188 */ -/* 189 */ -/* 190 */ -/* 191 */ - -#define TEGRA114_CLK_UARTB 192 -#define TEGRA114_CLK_VFIR 193 -#define TEGRA114_CLK_SPDIF_IN 194 -#define TEGRA114_CLK_SPDIF_OUT 195 -#define TEGRA114_CLK_VI 196 -#define TEGRA114_CLK_VI_SENSOR 197 -#define TEGRA114_CLK_FUSE 198 -#define TEGRA114_CLK_FUSE_BURN 199 -#define TEGRA114_CLK_CLK_32K 200 -#define TEGRA114_CLK_CLK_M 201 -#define TEGRA114_CLK_CLK_M_DIV2 202 -#define TEGRA114_CLK_CLK_M_DIV4 203 -#define TEGRA114_CLK_PLL_REF 204 -#define TEGRA114_CLK_PLL_C 205 -#define TEGRA114_CLK_PLL_C_OUT1 206 -#define TEGRA114_CLK_PLL_C2 207 -#define TEGRA114_CLK_PLL_C3 208 -#define TEGRA114_CLK_PLL_M 209 -#define TEGRA114_CLK_PLL_M_OUT1 210 -#define TEGRA114_CLK_PLL_P 211 -#define TEGRA114_CLK_PLL_P_OUT1 212 -#define TEGRA114_CLK_PLL_P_OUT2 213 -#define TEGRA114_CLK_PLL_P_OUT3 214 -#define TEGRA114_CLK_PLL_P_OUT4 215 -#define TEGRA114_CLK_PLL_A 216 -#define TEGRA114_CLK_PLL_A_OUT0 217 -#define TEGRA114_CLK_PLL_D 218 -#define TEGRA114_CLK_PLL_D_OUT0 219 -#define TEGRA114_CLK_PLL_D2 220 -#define TEGRA114_CLK_PLL_D2_OUT0 221 -#define TEGRA114_CLK_PLL_U 222 -#define TEGRA114_CLK_PLL_U_480M 223 - -#define TEGRA114_CLK_PLL_U_60M 224 -#define TEGRA114_CLK_PLL_U_48M 225 -#define TEGRA114_CLK_PLL_U_12M 226 -#define TEGRA114_CLK_PLL_X 227 -#define TEGRA114_CLK_PLL_X_OUT0 228 -#define TEGRA114_CLK_PLL_RE_VCO 229 -#define TEGRA114_CLK_PLL_RE_OUT 230 -#define TEGRA114_CLK_PLL_E_OUT0 231 -#define TEGRA114_CLK_SPDIF_IN_SYNC 232 -#define TEGRA114_CLK_I2S0_SYNC 233 -#define TEGRA114_CLK_I2S1_SYNC 234 -#define TEGRA114_CLK_I2S2_SYNC 235 -#define TEGRA114_CLK_I2S3_SYNC 236 -#define TEGRA114_CLK_I2S4_SYNC 237 -#define TEGRA114_CLK_VIMCLK_SYNC 238 -#define TEGRA114_CLK_AUDIO0 239 -#define TEGRA114_CLK_AUDIO1 240 -#define TEGRA114_CLK_AUDIO2 241 -#define TEGRA114_CLK_AUDIO3 242 -#define TEGRA114_CLK_AUDIO4 243 -#define TEGRA114_CLK_SPDIF 244 -#define TEGRA114_CLK_CLK_OUT_1 245 -#define TEGRA114_CLK_CLK_OUT_2 246 -#define TEGRA114_CLK_CLK_OUT_3 247 -#define TEGRA114_CLK_BLINK 248 -/* 249 */ -/* 250 */ -/* 251 */ -#define TEGRA114_CLK_XUSB_HOST_SRC 252 -#define TEGRA114_CLK_XUSB_FALCON_SRC 253 -#define TEGRA114_CLK_XUSB_FS_SRC 254 -#define TEGRA114_CLK_XUSB_SS_SRC 255 - -#define TEGRA114_CLK_XUSB_DEV_SRC 256 -#define TEGRA114_CLK_XUSB_DEV 257 -#define TEGRA114_CLK_XUSB_HS_SRC 258 -#define TEGRA114_CLK_SCLK 259 -#define TEGRA114_CLK_HCLK 260 -#define TEGRA114_CLK_PCLK 261 -#define TEGRA114_CLK_CCLK_G 262 -#define TEGRA114_CLK_CCLK_LP 263 -#define TEGRA114_CLK_DFLL_REF 264 -#define TEGRA114_CLK_DFLL_SOC 265 -/* 266 */ -/* 267 */ -/* 268 */ -/* 269 */ -/* 270 */ -/* 271 */ -/* 272 */ -/* 273 */ -/* 274 */ -/* 275 */ -/* 276 */ -/* 277 */ -/* 278 */ -/* 279 */ -/* 280 */ -/* 281 */ -/* 282 */ -/* 283 */ -/* 284 */ -/* 285 */ -/* 286 */ -/* 287 */ - -/* 288 */ -/* 289 */ -/* 290 */ -/* 291 */ -/* 292 */ -/* 293 */ -/* 294 */ -/* 295 */ -/* 296 */ -/* 297 */ -/* 298 */ -/* 299 */ -#define TEGRA114_CLK_AUDIO0_MUX 300 -#define TEGRA114_CLK_AUDIO1_MUX 301 -#define TEGRA114_CLK_AUDIO2_MUX 302 -#define TEGRA114_CLK_AUDIO3_MUX 303 -#define TEGRA114_CLK_AUDIO4_MUX 304 -#define TEGRA114_CLK_SPDIF_MUX 305 -#define TEGRA114_CLK_CLK_OUT_1_MUX 306 -#define TEGRA114_CLK_CLK_OUT_2_MUX 307 -#define TEGRA114_CLK_CLK_OUT_3_MUX 308 -#define TEGRA114_CLK_DSIA_MUX 309 -#define TEGRA114_CLK_DSIB_MUX 310 -#define TEGRA114_CLK_XUSB_SS_DIV2 311 -#define TEGRA114_CLK_CLK_MAX 312 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA114_CAR_H */ diff --git a/include/dt-bindings/clock/tegra124-car-common.h b/include/dt-bindings/clock/tegra124-car-common.h deleted file mode 100644 index a2156090563f..000000000000 --- a/include/dt-bindings/clock/tegra124-car-common.h +++ /dev/null @@ -1,345 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra124-car or - * nvidia,tegra132-car. - * - * The first 192 clocks are numbered to match the bits in the CAR's CLK_OUT_ENB - * registers. These IDs often match those in the CAR's RST_DEVICES registers, - * but not in all cases. Some bits in CLK_OUT_ENB affect multiple clocks. In - * this case, those clocks are assigned IDs above 185 in order to highlight - * this issue. Implementations that interpret these clock IDs as bit values - * within the CLK_OUT_ENB or RST_DEVICES registers should be careful to - * explicitly handle these special cases. - * - * The balance of the clocks controlled by the CAR are assigned IDs of 185 and - * above. - */ - -#ifndef _DT_BINDINGS_CLOCK_TEGRA124_CAR_COMMON_H -#define _DT_BINDINGS_CLOCK_TEGRA124_CAR_COMMON_H - -/* 0 */ -/* 1 */ -/* 2 */ -#define TEGRA124_CLK_ISPB 3 -#define TEGRA124_CLK_RTC 4 -#define TEGRA124_CLK_TIMER 5 -#define TEGRA124_CLK_UARTA 6 -/* 7 (register bit affects uartb and vfir) */ -/* 8 */ -#define TEGRA124_CLK_SDMMC2 9 -/* 10 (register bit affects spdif_in and spdif_out) */ -#define TEGRA124_CLK_I2S1 11 -#define TEGRA124_CLK_I2C1 12 -/* 13 */ -#define TEGRA124_CLK_SDMMC1 14 -#define TEGRA124_CLK_SDMMC4 15 -/* 16 */ -#define TEGRA124_CLK_PWM 17 -#define TEGRA124_CLK_I2S2 18 -/* 20 (register bit affects vi and vi_sensor) */ -/* 21 */ -#define TEGRA124_CLK_USBD 22 -#define TEGRA124_CLK_ISP 23 -/* 26 */ -/* 25 */ -#define TEGRA124_CLK_DISP2 26 -#define TEGRA124_CLK_DISP1 27 -#define TEGRA124_CLK_HOST1X 28 -#define TEGRA124_CLK_VCP 29 -#define TEGRA124_CLK_I2S0 30 -/* 31 */ - -#define TEGRA124_CLK_MC 32 -/* 33 */ -#define TEGRA124_CLK_APBDMA 34 -/* 35 */ -#define TEGRA124_CLK_KBC 36 -/* 37 */ -/* 38 */ -/* 39 (register bit affects fuse and fuse_burn) */ -#define TEGRA124_CLK_KFUSE 40 -#define TEGRA124_CLK_SBC1 41 -#define TEGRA124_CLK_NOR 42 -/* 43 */ -#define TEGRA124_CLK_SBC2 44 -/* 45 */ -#define TEGRA124_CLK_SBC3 46 -#define TEGRA124_CLK_I2C5 47 -#define TEGRA124_CLK_DSIA 48 -/* 49 */ -#define TEGRA124_CLK_MIPI 50 -#define TEGRA124_CLK_HDMI 51 -#define TEGRA124_CLK_CSI 52 -/* 53 */ -#define TEGRA124_CLK_I2C2 54 -#define TEGRA124_CLK_UARTC 55 -#define TEGRA124_CLK_MIPI_CAL 56 -#define TEGRA124_CLK_EMC 57 -#define TEGRA124_CLK_USB2 58 -#define TEGRA124_CLK_USB3 59 -/* 60 */ -#define TEGRA124_CLK_VDE 61 -#define TEGRA124_CLK_BSEA 62 -#define TEGRA124_CLK_BSEV 63 - -/* 64 */ -#define TEGRA124_CLK_UARTD 65 -/* 66 */ -#define TEGRA124_CLK_I2C3 67 -#define TEGRA124_CLK_SBC4 68 -#define TEGRA124_CLK_SDMMC3 69 -#define TEGRA124_CLK_PCIE 70 -#define TEGRA124_CLK_OWR 71 -#define TEGRA124_CLK_AFI 72 -#define TEGRA124_CLK_CSITE 73 -/* 74 */ -/* 75 */ -#define TEGRA124_CLK_LA 76 -#define TEGRA124_CLK_TRACE 77 -#define TEGRA124_CLK_SOC_THERM 78 -#define TEGRA124_CLK_DTV 79 -/* 80 */ -#define TEGRA124_CLK_I2CSLOW 81 -#define TEGRA124_CLK_DSIB 82 -#define TEGRA124_CLK_TSEC 83 -/* 84 */ -/* 85 */ -/* 86 */ -/* 87 */ -/* 88 */ -#define TEGRA124_CLK_XUSB_HOST 89 -/* 90 */ -#define TEGRA124_CLK_MSENC 91 -#define TEGRA124_CLK_CSUS 92 -/* 93 */ -/* 94 */ -/* 95 (bit affects xusb_dev and xusb_dev_src) */ - -/* 96 */ -/* 97 */ -/* 98 */ -#define TEGRA124_CLK_MSELECT 99 -#define TEGRA124_CLK_TSENSOR 100 -#define TEGRA124_CLK_I2S3 101 -#define TEGRA124_CLK_I2S4 102 -#define TEGRA124_CLK_I2C4 103 -#define TEGRA124_CLK_SBC5 104 -#define TEGRA124_CLK_SBC6 105 -#define TEGRA124_CLK_D_AUDIO 106 -#define TEGRA124_CLK_APBIF 107 -#define TEGRA124_CLK_DAM0 108 -#define TEGRA124_CLK_DAM1 109 -#define TEGRA124_CLK_DAM2 110 -#define TEGRA124_CLK_HDA2CODEC_2X 111 -/* 112 */ -#define TEGRA124_CLK_AUDIO0_2X 113 -#define TEGRA124_CLK_AUDIO1_2X 114 -#define TEGRA124_CLK_AUDIO2_2X 115 -#define TEGRA124_CLK_AUDIO3_2X 116 -#define TEGRA124_CLK_AUDIO4_2X 117 -#define TEGRA124_CLK_SPDIF_2X 118 -#define TEGRA124_CLK_ACTMON 119 -#define TEGRA124_CLK_EXTERN1 120 -#define TEGRA124_CLK_EXTERN2 121 -#define TEGRA124_CLK_EXTERN3 122 -#define TEGRA124_CLK_SATA_OOB 123 -#define TEGRA124_CLK_SATA 124 -#define TEGRA124_CLK_HDA 125 -/* 126 */ -#define TEGRA124_CLK_SE 127 - -#define TEGRA124_CLK_HDA2HDMI 128 -#define TEGRA124_CLK_SATA_COLD 129 -/* 130 */ -/* 131 */ -/* 132 */ -/* 133 */ -/* 134 */ -/* 135 */ -/* 136 */ -/* 137 */ -/* 138 */ -/* 139 */ -/* 140 */ -/* 141 */ -/* 142 */ -/* 143 (bit affects xusb_falcon_src, xusb_fs_src, */ -/* xusb_host_src and xusb_ss_src) */ -#define TEGRA124_CLK_CILAB 144 -#define TEGRA124_CLK_CILCD 145 -#define TEGRA124_CLK_CILE 146 -#define TEGRA124_CLK_DSIALP 147 -#define TEGRA124_CLK_DSIBLP 148 -#define TEGRA124_CLK_ENTROPY 149 -#define TEGRA124_CLK_DDS 150 -/* 151 */ -#define TEGRA124_CLK_DP2 152 -#define TEGRA124_CLK_AMX 153 -#define TEGRA124_CLK_ADX 154 -/* 155 (bit affects dfll_ref and dfll_soc) */ -#define TEGRA124_CLK_XUSB_SS 156 -/* 157 */ -/* 158 */ -/* 159 */ - -/* 160 */ -/* 161 */ -/* 162 */ -/* 163 */ -/* 164 */ -/* 165 */ -#define TEGRA124_CLK_I2C6 166 -/* 167 */ -/* 168 */ -/* 169 */ -/* 170 */ -#define TEGRA124_CLK_VIM2_CLK 171 -/* 172 */ -/* 173 */ -/* 174 */ -/* 175 */ -#define TEGRA124_CLK_HDMI_AUDIO 176 -#define TEGRA124_CLK_CLK72MHZ 177 -#define TEGRA124_CLK_VIC03 178 -/* 179 */ -#define TEGRA124_CLK_ADX1 180 -#define TEGRA124_CLK_DPAUX 181 -#define TEGRA124_CLK_SOR0 182 -/* 183 */ -#define TEGRA124_CLK_GPU 184 -#define TEGRA124_CLK_AMX1 185 -/* 186 */ -/* 187 */ -/* 188 */ -/* 189 */ -/* 190 */ -/* 191 */ -#define TEGRA124_CLK_UARTB 192 -#define TEGRA124_CLK_VFIR 193 -#define TEGRA124_CLK_SPDIF_IN 194 -#define TEGRA124_CLK_SPDIF_OUT 195 -#define TEGRA124_CLK_VI 196 -#define TEGRA124_CLK_VI_SENSOR 197 -#define TEGRA124_CLK_FUSE 198 -#define TEGRA124_CLK_FUSE_BURN 199 -#define TEGRA124_CLK_CLK_32K 200 -#define TEGRA124_CLK_CLK_M 201 -#define TEGRA124_CLK_CLK_M_DIV2 202 -#define TEGRA124_CLK_CLK_M_DIV4 203 -#define TEGRA124_CLK_PLL_REF 204 -#define TEGRA124_CLK_PLL_C 205 -#define TEGRA124_CLK_PLL_C_OUT1 206 -#define TEGRA124_CLK_PLL_C2 207 -#define TEGRA124_CLK_PLL_C3 208 -#define TEGRA124_CLK_PLL_M 209 -#define TEGRA124_CLK_PLL_M_OUT1 210 -#define TEGRA124_CLK_PLL_P 211 -#define TEGRA124_CLK_PLL_P_OUT1 212 -#define TEGRA124_CLK_PLL_P_OUT2 213 -#define TEGRA124_CLK_PLL_P_OUT3 214 -#define TEGRA124_CLK_PLL_P_OUT4 215 -#define TEGRA124_CLK_PLL_A 216 -#define TEGRA124_CLK_PLL_A_OUT0 217 -#define TEGRA124_CLK_PLL_D 218 -#define TEGRA124_CLK_PLL_D_OUT0 219 -#define TEGRA124_CLK_PLL_D2 220 -#define TEGRA124_CLK_PLL_D2_OUT0 221 -#define TEGRA124_CLK_PLL_U 222 -#define TEGRA124_CLK_PLL_U_480M 223 - -#define TEGRA124_CLK_PLL_U_60M 224 -#define TEGRA124_CLK_PLL_U_48M 225 -#define TEGRA124_CLK_PLL_U_12M 226 -/* 227 */ -/* 228 */ -#define TEGRA124_CLK_PLL_RE_VCO 229 -#define TEGRA124_CLK_PLL_RE_OUT 230 -#define TEGRA124_CLK_PLL_E 231 -#define TEGRA124_CLK_SPDIF_IN_SYNC 232 -#define TEGRA124_CLK_I2S0_SYNC 233 -#define TEGRA124_CLK_I2S1_SYNC 234 -#define TEGRA124_CLK_I2S2_SYNC 235 -#define TEGRA124_CLK_I2S3_SYNC 236 -#define TEGRA124_CLK_I2S4_SYNC 237 -#define TEGRA124_CLK_VIMCLK_SYNC 238 -#define TEGRA124_CLK_AUDIO0 239 -#define TEGRA124_CLK_AUDIO1 240 -#define TEGRA124_CLK_AUDIO2 241 -#define TEGRA124_CLK_AUDIO3 242 -#define TEGRA124_CLK_AUDIO4 243 -#define TEGRA124_CLK_SPDIF 244 -#define TEGRA124_CLK_CLK_OUT_1 245 -#define TEGRA124_CLK_CLK_OUT_2 246 -#define TEGRA124_CLK_CLK_OUT_3 247 -#define TEGRA124_CLK_BLINK 248 -/* 249 */ -/* 250 */ -/* 251 */ -#define TEGRA124_CLK_XUSB_HOST_SRC 252 -#define TEGRA124_CLK_XUSB_FALCON_SRC 253 -#define TEGRA124_CLK_XUSB_FS_SRC 254 -#define TEGRA124_CLK_XUSB_SS_SRC 255 - -#define TEGRA124_CLK_XUSB_DEV_SRC 256 -#define TEGRA124_CLK_XUSB_DEV 257 -#define TEGRA124_CLK_XUSB_HS_SRC 258 -#define TEGRA124_CLK_SCLK 259 -#define TEGRA124_CLK_HCLK 260 -#define TEGRA124_CLK_PCLK 261 -/* 262 */ -/* 263 */ -#define TEGRA124_CLK_DFLL_REF 264 -#define TEGRA124_CLK_DFLL_SOC 265 -#define TEGRA124_CLK_VI_SENSOR2 266 -#define TEGRA124_CLK_PLL_P_OUT5 267 -#define TEGRA124_CLK_CML0 268 -#define TEGRA124_CLK_CML1 269 -#define TEGRA124_CLK_PLL_C4 270 -#define TEGRA124_CLK_PLL_DP 271 -#define TEGRA124_CLK_PLL_E_MUX 272 -#define TEGRA124_CLK_PLL_D_DSI_OUT 273 -/* 274 */ -/* 275 */ -/* 276 */ -/* 277 */ -/* 278 */ -/* 279 */ -/* 280 */ -/* 281 */ -/* 282 */ -/* 283 */ -/* 284 */ -/* 285 */ -/* 286 */ -/* 287 */ - -/* 288 */ -/* 289 */ -/* 290 */ -/* 291 */ -/* 292 */ -/* 293 */ -/* 294 */ -/* 295 */ -/* 296 */ -/* 297 */ -/* 298 */ -/* 299 */ -#define TEGRA124_CLK_AUDIO0_MUX 300 -#define TEGRA124_CLK_AUDIO1_MUX 301 -#define TEGRA124_CLK_AUDIO2_MUX 302 -#define TEGRA124_CLK_AUDIO3_MUX 303 -#define TEGRA124_CLK_AUDIO4_MUX 304 -#define TEGRA124_CLK_SPDIF_MUX 305 -#define TEGRA124_CLK_CLK_OUT_1_MUX 306 -#define TEGRA124_CLK_CLK_OUT_2_MUX 307 -#define TEGRA124_CLK_CLK_OUT_3_MUX 308 -/* 309 */ -/* 310 */ -#define TEGRA124_CLK_SOR0_LVDS 311 -#define TEGRA124_CLK_XUSB_SS_DIV2 312 - -#define TEGRA124_CLK_PLL_M_UD 313 -#define TEGRA124_CLK_PLL_C_UD 314 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA124_CAR_COMMON_H */ diff --git a/include/dt-bindings/clock/tegra124-car.h b/include/dt-bindings/clock/tegra124-car.h deleted file mode 100644 index 2860737f0443..000000000000 --- a/include/dt-bindings/clock/tegra124-car.h +++ /dev/null @@ -1,19 +0,0 @@ -/* - * This header provides Tegra124-specific constants for binding - * nvidia,tegra124-car. - */ - -#include <dt-bindings/clock/tegra124-car-common.h> - -#ifndef _DT_BINDINGS_CLOCK_TEGRA124_CAR_H -#define _DT_BINDINGS_CLOCK_TEGRA124_CAR_H - -#define TEGRA124_CLK_PLL_X 227 -#define TEGRA124_CLK_PLL_X_OUT0 228 - -#define TEGRA124_CLK_CCLK_G 262 -#define TEGRA124_CLK_CCLK_LP 263 - -#define TEGRA124_CLK_CLK_MAX 315 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA124_CAR_H */ diff --git a/include/dt-bindings/clock/tegra186-clock.h b/include/dt-bindings/clock/tegra186-clock.h deleted file mode 100644 index f73d32098f99..000000000000 --- a/include/dt-bindings/clock/tegra186-clock.h +++ /dev/null @@ -1,940 +0,0 @@ -/** @file */ - -#ifndef _MACH_T186_CLK_T186_H -#define _MACH_T186_CLK_T186_H - -/** - * @defgroup clock_ids Clock Identifiers - * @{ - * @defgroup extern_input external input clocks - * @{ - * @def TEGRA186_CLK_OSC - * @def TEGRA186_CLK_CLK_32K - * @def TEGRA186_CLK_DTV_INPUT - * @def TEGRA186_CLK_SOR0_PAD_CLKOUT - * @def TEGRA186_CLK_SOR1_PAD_CLKOUT - * @def TEGRA186_CLK_I2S1_SYNC_INPUT - * @def TEGRA186_CLK_I2S2_SYNC_INPUT - * @def TEGRA186_CLK_I2S3_SYNC_INPUT - * @def TEGRA186_CLK_I2S4_SYNC_INPUT - * @def TEGRA186_CLK_I2S5_SYNC_INPUT - * @def TEGRA186_CLK_I2S6_SYNC_INPUT - * @def TEGRA186_CLK_SPDIFIN_SYNC_INPUT - * @} - * - * @defgroup extern_output external output clocks - * @{ - * @def TEGRA186_CLK_EXTPERIPH1 - * @def TEGRA186_CLK_EXTPERIPH2 - * @def TEGRA186_CLK_EXTPERIPH3 - * @def TEGRA186_CLK_EXTPERIPH4 - * @} - * - * @defgroup display_clks display related clocks - * @{ - * @def TEGRA186_CLK_CEC - * @def TEGRA186_CLK_DSIC - * @def TEGRA186_CLK_DSIC_LP - * @def TEGRA186_CLK_DSID - * @def TEGRA186_CLK_DSID_LP - * @def TEGRA186_CLK_DPAUX1 - * @def TEGRA186_CLK_DPAUX - * @def TEGRA186_CLK_HDA2HDMICODEC - * @def TEGRA186_CLK_NVDISPLAY_DISP - * @def TEGRA186_CLK_NVDISPLAY_DSC - * @def TEGRA186_CLK_NVDISPLAY_P0 - * @def TEGRA186_CLK_NVDISPLAY_P1 - * @def TEGRA186_CLK_NVDISPLAY_P2 - * @def TEGRA186_CLK_NVDISPLAYHUB - * @def TEGRA186_CLK_SOR_SAFE - * @def TEGRA186_CLK_SOR0 - * @def TEGRA186_CLK_SOR0_OUT - * @def TEGRA186_CLK_SOR1 - * @def TEGRA186_CLK_SOR1_OUT - * @def TEGRA186_CLK_DSI - * @def TEGRA186_CLK_MIPI_CAL - * @def TEGRA186_CLK_DSIA_LP - * @def TEGRA186_CLK_DSIB - * @def TEGRA186_CLK_DSIB_LP - * @} - * - * @defgroup camera_clks camera related clocks - * @{ - * @def TEGRA186_CLK_NVCSI - * @def TEGRA186_CLK_NVCSILP - * @def TEGRA186_CLK_VI - * @} - * - * @defgroup audio_clks audio related clocks - * @{ - * @def TEGRA186_CLK_ACLK - * @def TEGRA186_CLK_ADSP - * @def TEGRA186_CLK_ADSPNEON - * @def TEGRA186_CLK_AHUB - * @def TEGRA186_CLK_APE - * @def TEGRA186_CLK_APB2APE - * @def TEGRA186_CLK_AUD_MCLK - * @def TEGRA186_CLK_DMIC1 - * @def TEGRA186_CLK_DMIC2 - * @def TEGRA186_CLK_DMIC3 - * @def TEGRA186_CLK_DMIC4 - * @def TEGRA186_CLK_DSPK1 - * @def TEGRA186_CLK_DSPK2 - * @def TEGRA186_CLK_HDA - * @def TEGRA186_CLK_HDA2CODEC_2X - * @def TEGRA186_CLK_I2S1 - * @def TEGRA186_CLK_I2S2 - * @def TEGRA186_CLK_I2S3 - * @def TEGRA186_CLK_I2S4 - * @def TEGRA186_CLK_I2S5 - * @def TEGRA186_CLK_I2S6 - * @def TEGRA186_CLK_MAUD - * @def TEGRA186_CLK_PLL_A_OUT0 - * @def TEGRA186_CLK_SPDIF_DOUBLER - * @def TEGRA186_CLK_SPDIF_IN - * @def TEGRA186_CLK_SPDIF_OUT - * @def TEGRA186_CLK_SYNC_DMIC1 - * @def TEGRA186_CLK_SYNC_DMIC2 - * @def TEGRA186_CLK_SYNC_DMIC3 - * @def TEGRA186_CLK_SYNC_DMIC4 - * @def TEGRA186_CLK_SYNC_DMIC5 - * @def TEGRA186_CLK_SYNC_DSPK1 - * @def TEGRA186_CLK_SYNC_DSPK2 - * @def TEGRA186_CLK_SYNC_I2S1 - * @def TEGRA186_CLK_SYNC_I2S2 - * @def TEGRA186_CLK_SYNC_I2S3 - * @def TEGRA186_CLK_SYNC_I2S4 - * @def TEGRA186_CLK_SYNC_I2S5 - * @def TEGRA186_CLK_SYNC_I2S6 - * @def TEGRA186_CLK_SYNC_SPDIF - * @} - * - * @defgroup uart_clks UART clocks - * @{ - * @def TEGRA186_CLK_AON_UART_FST_MIPI_CAL - * @def TEGRA186_CLK_UARTA - * @def TEGRA186_CLK_UARTB - * @def TEGRA186_CLK_UARTC - * @def TEGRA186_CLK_UARTD - * @def TEGRA186_CLK_UARTE - * @def TEGRA186_CLK_UARTF - * @def TEGRA186_CLK_UARTG - * @def TEGRA186_CLK_UART_FST_MIPI_CAL - * @} - * - * @defgroup i2c_clks I2C clocks - * @{ - * @def TEGRA186_CLK_AON_I2C_SLOW - * @def TEGRA186_CLK_I2C1 - * @def TEGRA186_CLK_I2C2 - * @def TEGRA186_CLK_I2C3 - * @def TEGRA186_CLK_I2C4 - * @def TEGRA186_CLK_I2C5 - * @def TEGRA186_CLK_I2C6 - * @def TEGRA186_CLK_I2C8 - * @def TEGRA186_CLK_I2C9 - * @def TEGRA186_CLK_I2C1 - * @def TEGRA186_CLK_I2C12 - * @def TEGRA186_CLK_I2C13 - * @def TEGRA186_CLK_I2C14 - * @def TEGRA186_CLK_I2C_SLOW - * @def TEGRA186_CLK_VI_I2C - * @} - * - * @defgroup spi_clks SPI clocks - * @{ - * @def TEGRA186_CLK_SPI1 - * @def TEGRA186_CLK_SPI2 - * @def TEGRA186_CLK_SPI3 - * @def TEGRA186_CLK_SPI4 - * @} - * - * @defgroup storage storage related clocks - * @{ - * @def TEGRA186_CLK_SATA - * @def TEGRA186_CLK_SATA_OOB - * @def TEGRA186_CLK_SATA_IOBIST - * @def TEGRA186_CLK_SDMMC_LEGACY_TM - * @def TEGRA186_CLK_SDMMC1 - * @def TEGRA186_CLK_SDMMC2 - * @def TEGRA186_CLK_SDMMC3 - * @def TEGRA186_CLK_SDMMC4 - * @def TEGRA186_CLK_QSPI - * @def TEGRA186_CLK_QSPI_OUT - * @def TEGRA186_CLK_UFSDEV_REF - * @def TEGRA186_CLK_UFSHC - * @} - * - * @defgroup pwm_clks PWM clocks - * @{ - * @def TEGRA186_CLK_PWM1 - * @def TEGRA186_CLK_PWM2 - * @def TEGRA186_CLK_PWM3 - * @def TEGRA186_CLK_PWM4 - * @def TEGRA186_CLK_PWM5 - * @def TEGRA186_CLK_PWM6 - * @def TEGRA186_CLK_PWM7 - * @def TEGRA186_CLK_PWM8 - * @} - * - * @defgroup plls PLLs and related clocks - * @{ - * @def TEGRA186_CLK_PLLREFE_OUT_GATED - * @def TEGRA186_CLK_PLLREFE_OUT1 - * @def TEGRA186_CLK_PLLD_OUT1 - * @def TEGRA186_CLK_PLLP_OUT0 - * @def TEGRA186_CLK_PLLP_OUT5 - * @def TEGRA186_CLK_PLLA - * @def TEGRA186_CLK_PLLE_PWRSEQ - * @def TEGRA186_CLK_PLLA_OUT1 - * @def TEGRA186_CLK_PLLREFE_REF - * @def TEGRA186_CLK_UPHY_PLL0_PWRSEQ - * @def TEGRA186_CLK_UPHY_PLL1_PWRSEQ - * @def TEGRA186_CLK_PLLREFE_PLLE_PASSTHROUGH - * @def TEGRA186_CLK_PLLREFE_PEX - * @def TEGRA186_CLK_PLLREFE_IDDQ - * @def TEGRA186_CLK_PLLC_OUT_AON - * @def TEGRA186_CLK_PLLC_OUT_ISP - * @def TEGRA186_CLK_PLLC_OUT_VE - * @def TEGRA186_CLK_PLLC4_OUT - * @def TEGRA186_CLK_PLLREFE_OUT - * @def TEGRA186_CLK_PLLREFE_PLL_REF - * @def TEGRA186_CLK_PLLE - * @def TEGRA186_CLK_PLLC - * @def TEGRA186_CLK_PLLP - * @def TEGRA186_CLK_PLLD - * @def TEGRA186_CLK_PLLD2 - * @def TEGRA186_CLK_PLLREFE_VCO - * @def TEGRA186_CLK_PLLC2 - * @def TEGRA186_CLK_PLLC3 - * @def TEGRA186_CLK_PLLDP - * @def TEGRA186_CLK_PLLC4_VCO - * @def TEGRA186_CLK_PLLA1 - * @def TEGRA186_CLK_PLLNVCSI - * @def TEGRA186_CLK_PLLDISPHUB - * @def TEGRA186_CLK_PLLD3 - * @def TEGRA186_CLK_PLLBPMPCAM - * @def TEGRA186_CLK_PLLAON - * @def TEGRA186_CLK_PLLU - * @def TEGRA186_CLK_PLLC4_VCO_DIV2 - * @def TEGRA186_CLK_PLL_REF - * @def TEGRA186_CLK_PLLREFE_OUT1_DIV5 - * @def TEGRA186_CLK_UTMIP_PLL_PWRSEQ - * @def TEGRA186_CLK_PLL_U_48M - * @def TEGRA186_CLK_PLL_U_480M - * @def TEGRA186_CLK_PLLC4_OUT0 - * @def TEGRA186_CLK_PLLC4_OUT1 - * @def TEGRA186_CLK_PLLC4_OUT2 - * @def TEGRA186_CLK_PLLC4_OUT_MUX - * @def TEGRA186_CLK_DFLLDISP_DIV - * @def TEGRA186_CLK_PLLDISPHUB_DIV - * @def TEGRA186_CLK_PLLP_DIV8 - * @} - * - * @defgroup nafll_clks NAFLL clock sources - * @{ - * @def TEGRA186_CLK_NAFLL_AXI_CBB - * @def TEGRA186_CLK_NAFLL_BCPU - * @def TEGRA186_CLK_NAFLL_BPMP - * @def TEGRA186_CLK_NAFLL_DISP - * @def TEGRA186_CLK_NAFLL_GPU - * @def TEGRA186_CLK_NAFLL_ISP - * @def TEGRA186_CLK_NAFLL_MCPU - * @def TEGRA186_CLK_NAFLL_NVDEC - * @def TEGRA186_CLK_NAFLL_NVENC - * @def TEGRA186_CLK_NAFLL_NVJPG - * @def TEGRA186_CLK_NAFLL_SCE - * @def TEGRA186_CLK_NAFLL_SE - * @def TEGRA186_CLK_NAFLL_TSEC - * @def TEGRA186_CLK_NAFLL_TSECB - * @def TEGRA186_CLK_NAFLL_VI - * @def TEGRA186_CLK_NAFLL_VIC - * @} - * - * @defgroup mphy MPHY related clocks - * @{ - * @def TEGRA186_CLK_MPHY_L0_RX_SYMB - * @def TEGRA186_CLK_MPHY_L0_RX_LS_BIT - * @def TEGRA186_CLK_MPHY_L0_TX_SYMB - * @def TEGRA186_CLK_MPHY_L0_TX_LS_3XBIT - * @def TEGRA186_CLK_MPHY_L0_RX_ANA - * @def TEGRA186_CLK_MPHY_L1_RX_ANA - * @def TEGRA186_CLK_MPHY_IOBIST - * @def TEGRA186_CLK_MPHY_TX_1MHZ_REF - * @def TEGRA186_CLK_MPHY_CORE_PLL_FIXED - * @} - * - * @defgroup eavb EAVB related clocks - * @{ - * @def TEGRA186_CLK_EQOS_AXI - * @def TEGRA186_CLK_EQOS_PTP_REF - * @def TEGRA186_CLK_EQOS_RX - * @def TEGRA186_CLK_EQOS_RX_INPUT - * @def TEGRA186_CLK_EQOS_TX - * @} - * - * @defgroup usb USB related clocks - * @{ - * @def TEGRA186_CLK_PEX_USB_PAD0_MGMT - * @def TEGRA186_CLK_PEX_USB_PAD1_MGMT - * @def TEGRA186_CLK_HSIC_TRK - * @def TEGRA186_CLK_USB2_TRK - * @def TEGRA186_CLK_USB2_HSIC_TRK - * @def TEGRA186_CLK_XUSB_CORE_SS - * @def TEGRA186_CLK_XUSB_CORE_DEV - * @def TEGRA186_CLK_XUSB_FALCON - * @def TEGRA186_CLK_XUSB_FS - * @def TEGRA186_CLK_XUSB - * @def TEGRA186_CLK_XUSB_DEV - * @def TEGRA186_CLK_XUSB_HOST - * @def TEGRA186_CLK_XUSB_SS - * @} - * - * @defgroup bigblock compute block related clocks - * @{ - * @def TEGRA186_CLK_GPCCLK - * @def TEGRA186_CLK_GPC2CLK - * @def TEGRA186_CLK_GPU - * @def TEGRA186_CLK_HOST1X - * @def TEGRA186_CLK_ISP - * @def TEGRA186_CLK_NVDEC - * @def TEGRA186_CLK_NVENC - * @def TEGRA186_CLK_NVJPG - * @def TEGRA186_CLK_SE - * @def TEGRA186_CLK_TSEC - * @def TEGRA186_CLK_TSECB - * @def TEGRA186_CLK_VIC - * @} - * - * @defgroup can CAN bus related clocks - * @{ - * @def TEGRA186_CLK_CAN1 - * @def TEGRA186_CLK_CAN1_HOST - * @def TEGRA186_CLK_CAN2 - * @def TEGRA186_CLK_CAN2_HOST - * @} - * - * @defgroup system basic system clocks - * @{ - * @def TEGRA186_CLK_ACTMON - * @def TEGRA186_CLK_AON_APB - * @def TEGRA186_CLK_AON_CPU_NIC - * @def TEGRA186_CLK_AON_NIC - * @def TEGRA186_CLK_AXI_CBB - * @def TEGRA186_CLK_BPMP_APB - * @def TEGRA186_CLK_BPMP_CPU_NIC - * @def TEGRA186_CLK_BPMP_NIC_RATE - * @def TEGRA186_CLK_CLK_M - * @def TEGRA186_CLK_EMC - * @def TEGRA186_CLK_MSS_ENCRYPT - * @def TEGRA186_CLK_SCE_APB - * @def TEGRA186_CLK_SCE_CPU_NIC - * @def TEGRA186_CLK_SCE_NIC - * @def TEGRA186_CLK_TSC - * @} - * - * @defgroup pcie_clks PCIe related clocks - * @{ - * @def TEGRA186_CLK_AFI - * @def TEGRA186_CLK_PCIE - * @def TEGRA186_CLK_PCIE2_IOBIST - * @def TEGRA186_CLK_PCIERX0 - * @def TEGRA186_CLK_PCIERX1 - * @def TEGRA186_CLK_PCIERX2 - * @def TEGRA186_CLK_PCIERX3 - * @def TEGRA186_CLK_PCIERX4 - * @} - */ - -/** @brief output of gate CLK_ENB_FUSE */ -#define TEGRA186_CLK_FUSE 0 -/** - * @brief It's not what you think - * @details output of gate CLK_ENB_GPU. This output connects to the GPU - * pwrclk. @warning: This is almost certainly not the clock you think - * it is. If you're looking for the clock of the graphics engine, see - * TEGRA186_GPCCLK - */ -#define TEGRA186_CLK_GPU 1 -/** @brief output of gate CLK_ENB_PCIE */ -#define TEGRA186_CLK_PCIE 3 -/** @brief output of the divider IPFS_CLK_DIVISOR */ -#define TEGRA186_CLK_AFI 4 -/** @brief output of gate CLK_ENB_PCIE2_IOBIST */ -#define TEGRA186_CLK_PCIE2_IOBIST 5 -/** @brief output of gate CLK_ENB_PCIERX0*/ -#define TEGRA186_CLK_PCIERX0 6 -/** @brief output of gate CLK_ENB_PCIERX1*/ -#define TEGRA186_CLK_PCIERX1 7 -/** @brief output of gate CLK_ENB_PCIERX2*/ -#define TEGRA186_CLK_PCIERX2 8 -/** @brief output of gate CLK_ENB_PCIERX3*/ -#define TEGRA186_CLK_PCIERX3 9 -/** @brief output of gate CLK_ENB_PCIERX4*/ -#define TEGRA186_CLK_PCIERX4 10 -/** @brief output branch of PLL_C for ISP, controlled by gate CLK_ENB_PLLC_OUT_ISP */ -#define TEGRA186_CLK_PLLC_OUT_ISP 11 -/** @brief output branch of PLL_C for VI, controlled by gate CLK_ENB_PLLC_OUT_VE */ -#define TEGRA186_CLK_PLLC_OUT_VE 12 -/** @brief output branch of PLL_C for AON domain, controlled by gate CLK_ENB_PLLC_OUT_AON */ -#define TEGRA186_CLK_PLLC_OUT_AON 13 -/** @brief output of gate CLK_ENB_SOR_SAFE */ -#define TEGRA186_CLK_SOR_SAFE 39 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2S2 */ -#define TEGRA186_CLK_I2S2 42 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2S3 */ -#define TEGRA186_CLK_I2S3 43 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SPDF_IN */ -#define TEGRA186_CLK_SPDIF_IN 44 -/** @brief output of gate CLK_ENB_SPDIF_DOUBLER */ -#define TEGRA186_CLK_SPDIF_DOUBLER 45 -/** @clkdesc{spi_clks, out, mux, CLK_RST_CONTROLLER_CLK_SOURCE_SPI3} */ -#define TEGRA186_CLK_SPI3 46 -/** @clkdesc{i2c_clks, out, mux, CLK_RST_CONTROLLER_CLK_SOURCE_I2C1} */ -#define TEGRA186_CLK_I2C1 47 -/** @clkdesc{i2c_clks, out, mux, CLK_RST_CONTROLLER_CLK_SOURCE_I2C5} */ -#define TEGRA186_CLK_I2C5 48 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SPI1 */ -#define TEGRA186_CLK_SPI1 49 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_ISP */ -#define TEGRA186_CLK_ISP 50 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_VI */ -#define TEGRA186_CLK_VI 51 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SDMMC1 */ -#define TEGRA186_CLK_SDMMC1 52 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SDMMC2 */ -#define TEGRA186_CLK_SDMMC2 53 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SDMMC4 */ -#define TEGRA186_CLK_SDMMC4 54 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTA */ -#define TEGRA186_CLK_UARTA 55 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTB */ -#define TEGRA186_CLK_UARTB 56 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_HOST1X */ -#define TEGRA186_CLK_HOST1X 57 -/** - * @brief controls the EMC clock frequency. - * @details Doing a clk_set_rate on this clock will select the - * appropriate clock source, program the source rate and execute a - * specific sequence to switch to the new clock source for both memory - * controllers. This can be used to control the balance between memory - * throughput and memory controller power. - */ -#define TEGRA186_CLK_EMC 58 -/* @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_EXTPERIPH4 */ -#define TEGRA186_CLK_EXTPERIPH4 73 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SPI4 */ -#define TEGRA186_CLK_SPI4 74 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C3 */ -#define TEGRA186_CLK_I2C3 75 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SDMMC3 */ -#define TEGRA186_CLK_SDMMC3 76 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTD */ -#define TEGRA186_CLK_UARTD 77 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2S1 */ -#define TEGRA186_CLK_I2S1 79 -/** output of gate CLK_ENB_DTV */ -#define TEGRA186_CLK_DTV 80 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_TSEC */ -#define TEGRA186_CLK_TSEC 81 -/** @brief output of gate CLK_ENB_DP2 */ -#define TEGRA186_CLK_DP2 82 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2S4 */ -#define TEGRA186_CLK_I2S4 84 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2S5 */ -#define TEGRA186_CLK_I2S5 85 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C4 */ -#define TEGRA186_CLK_I2C4 86 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AHUB */ -#define TEGRA186_CLK_AHUB 87 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_HDA2CODEC_2X */ -#define TEGRA186_CLK_HDA2CODEC_2X 88 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_EXTPERIPH1 */ -#define TEGRA186_CLK_EXTPERIPH1 89 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_EXTPERIPH2 */ -#define TEGRA186_CLK_EXTPERIPH2 90 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_EXTPERIPH3 */ -#define TEGRA186_CLK_EXTPERIPH3 91 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C_SLOW */ -#define TEGRA186_CLK_I2C_SLOW 92 -/** @brief output of the SOR1_CLK_SRC mux in CLK_RST_CONTROLLER_CLK_SOURCE_SOR1 */ -#define TEGRA186_CLK_SOR1 93 -/** @brief output of gate CLK_ENB_CEC */ -#define TEGRA186_CLK_CEC 94 -/** @brief output of gate CLK_ENB_DPAUX1 */ -#define TEGRA186_CLK_DPAUX1 95 -/** @brief output of gate CLK_ENB_DPAUX */ -#define TEGRA186_CLK_DPAUX 96 -/** @brief output of the SOR0_CLK_SRC mux in CLK_RST_CONTROLLER_CLK_SOURCE_SOR0 */ -#define TEGRA186_CLK_SOR0 97 -/** @brief output of gate CLK_ENB_HDA2HDMICODEC */ -#define TEGRA186_CLK_HDA2HDMICODEC 98 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SATA */ -#define TEGRA186_CLK_SATA 99 -/** @brief output of gate CLK_ENB_SATA_OOB */ -#define TEGRA186_CLK_SATA_OOB 100 -/** @brief output of gate CLK_ENB_SATA_IOBIST */ -#define TEGRA186_CLK_SATA_IOBIST 101 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_HDA */ -#define TEGRA186_CLK_HDA 102 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SE */ -#define TEGRA186_CLK_SE 103 -/** @brief output of gate CLK_ENB_APB2APE */ -#define TEGRA186_CLK_APB2APE 104 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_APE */ -#define TEGRA186_CLK_APE 105 -/** @brief output of gate CLK_ENB_IQC1 */ -#define TEGRA186_CLK_IQC1 106 -/** @brief output of gate CLK_ENB_IQC2 */ -#define TEGRA186_CLK_IQC2 107 -/** divide by 2 version of TEGRA186_CLK_PLLREFE_VCO */ -#define TEGRA186_CLK_PLLREFE_OUT 108 -/** @brief output of gate CLK_ENB_PLLREFE_PLL_REF */ -#define TEGRA186_CLK_PLLREFE_PLL_REF 109 -/** @brief output of gate CLK_ENB_PLLC4_OUT */ -#define TEGRA186_CLK_PLLC4_OUT 110 -/** @brief output of mux xusb_core_clk_switch on page 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB 111 -/** controls xusb_dev_ce signal on page 66 and 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_DEV 112 -/** controls xusb_host_ce signal on page 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_HOST 113 -/** controls xusb_ss_ce signal on page 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_SS 114 -/** @brief output of gate CLK_ENB_DSI */ -#define TEGRA186_CLK_DSI 115 -/** @brief output of gate CLK_ENB_MIPI_CAL */ -#define TEGRA186_CLK_MIPI_CAL 116 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSIA_LP */ -#define TEGRA186_CLK_DSIA_LP 117 -/** @brief output of gate CLK_ENB_DSIB */ -#define TEGRA186_CLK_DSIB 118 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSIB_LP */ -#define TEGRA186_CLK_DSIB_LP 119 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DMIC1 */ -#define TEGRA186_CLK_DMIC1 122 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DMIC2 */ -#define TEGRA186_CLK_DMIC2 123 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AUD_MCLK */ -#define TEGRA186_CLK_AUD_MCLK 124 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C6 */ -#define TEGRA186_CLK_I2C6 125 -/**output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UART_FST_MIPI_CAL */ -#define TEGRA186_CLK_UART_FST_MIPI_CAL 126 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_VIC */ -#define TEGRA186_CLK_VIC 127 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SDMMC_LEGACY_TM */ -#define TEGRA186_CLK_SDMMC_LEGACY_TM 128 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVDEC */ -#define TEGRA186_CLK_NVDEC 129 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVJPG */ -#define TEGRA186_CLK_NVJPG 130 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVENC */ -#define TEGRA186_CLK_NVENC 131 -/** @brief output of the QSPI_CLK_SRC mux in CLK_RST_CONTROLLER_CLK_SOURCE_QSPI */ -#define TEGRA186_CLK_QSPI 132 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_VI_I2C */ -#define TEGRA186_CLK_VI_I2C 133 -/** @brief output of gate CLK_ENB_HSIC_TRK */ -#define TEGRA186_CLK_HSIC_TRK 134 -/** @brief output of gate CLK_ENB_USB2_TRK */ -#define TEGRA186_CLK_USB2_TRK 135 -/** output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_MAUD */ -#define TEGRA186_CLK_MAUD 136 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_TSECB */ -#define TEGRA186_CLK_TSECB 137 -/** @brief output of gate CLK_ENB_ADSP */ -#define TEGRA186_CLK_ADSP 138 -/** @brief output of gate CLK_ENB_ADSPNEON */ -#define TEGRA186_CLK_ADSPNEON 139 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_MPHY_L0_RX_LS_SYMB */ -#define TEGRA186_CLK_MPHY_L0_RX_SYMB 140 -/** @brief output of gate CLK_ENB_MPHY_L0_RX_LS_BIT */ -#define TEGRA186_CLK_MPHY_L0_RX_LS_BIT 141 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_MPHY_L0_TX_LS_SYMB */ -#define TEGRA186_CLK_MPHY_L0_TX_SYMB 142 -/** @brief output of gate CLK_ENB_MPHY_L0_TX_LS_3XBIT */ -#define TEGRA186_CLK_MPHY_L0_TX_LS_3XBIT 143 -/** @brief output of gate CLK_ENB_MPHY_L0_RX_ANA */ -#define TEGRA186_CLK_MPHY_L0_RX_ANA 144 -/** @brief output of gate CLK_ENB_MPHY_L1_RX_ANA */ -#define TEGRA186_CLK_MPHY_L1_RX_ANA 145 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_MPHY_IOBIST */ -#define TEGRA186_CLK_MPHY_IOBIST 146 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_MPHY_TX_1MHZ_REF */ -#define TEGRA186_CLK_MPHY_TX_1MHZ_REF 147 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_MPHY_CORE_PLL_FIXED */ -#define TEGRA186_CLK_MPHY_CORE_PLL_FIXED 148 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AXI_CBB */ -#define TEGRA186_CLK_AXI_CBB 149 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DMIC3 */ -#define TEGRA186_CLK_DMIC3 150 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DMIC4 */ -#define TEGRA186_CLK_DMIC4 151 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSPK1 */ -#define TEGRA186_CLK_DSPK1 152 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSPK2 */ -#define TEGRA186_CLK_DSPK2 153 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C6 */ -#define TEGRA186_CLK_I2S6 154 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_P0 */ -#define TEGRA186_CLK_NVDISPLAY_P0 155 -/** @brief output of the NVDISPLAY_DISP_CLK_SRC mux in CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_DISP */ -#define TEGRA186_CLK_NVDISPLAY_DISP 156 -/** @brief output of gate CLK_ENB_NVDISPLAY_DSC */ -#define TEGRA186_CLK_NVDISPLAY_DSC 157 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAYHUB */ -#define TEGRA186_CLK_NVDISPLAYHUB 158 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_P1 */ -#define TEGRA186_CLK_NVDISPLAY_P1 159 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_P2 */ -#define TEGRA186_CLK_NVDISPLAY_P2 160 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_TACH */ -#define TEGRA186_CLK_TACH 166 -/** @brief output of gate CLK_ENB_EQOS */ -#define TEGRA186_CLK_EQOS_AXI 167 -/** @brief output of gate CLK_ENB_EQOS_RX */ -#define TEGRA186_CLK_EQOS_RX 168 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UFSHC_CG_SYS */ -#define TEGRA186_CLK_UFSHC 178 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UFSDEV_REF */ -#define TEGRA186_CLK_UFSDEV_REF 179 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVCSI */ -#define TEGRA186_CLK_NVCSI 180 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_NVCSILP */ -#define TEGRA186_CLK_NVCSILP 181 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C7 */ -#define TEGRA186_CLK_I2C7 182 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C9 */ -#define TEGRA186_CLK_I2C9 183 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C12 */ -#define TEGRA186_CLK_I2C12 184 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C13 */ -#define TEGRA186_CLK_I2C13 185 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C14 */ -#define TEGRA186_CLK_I2C14 186 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM1 */ -#define TEGRA186_CLK_PWM1 187 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM2 */ -#define TEGRA186_CLK_PWM2 188 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM3 */ -#define TEGRA186_CLK_PWM3 189 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM5 */ -#define TEGRA186_CLK_PWM5 190 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM6 */ -#define TEGRA186_CLK_PWM6 191 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM7 */ -#define TEGRA186_CLK_PWM7 192 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM8 */ -#define TEGRA186_CLK_PWM8 193 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTE */ -#define TEGRA186_CLK_UARTE 194 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTF */ -#define TEGRA186_CLK_UARTF 195 -/** @deprecated */ -#define TEGRA186_CLK_DBGAPB 196 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_BPMP_CPU_NIC */ -#define TEGRA186_CLK_BPMP_CPU_NIC 197 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_BPMP_APB */ -#define TEGRA186_CLK_BPMP_APB 199 -/** @brief output of mux controlled by TEGRA186_CLK_SOC_ACTMON */ -#define TEGRA186_CLK_ACTMON 201 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AON_CPU_NIC */ -#define TEGRA186_CLK_AON_CPU_NIC 208 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_CAN1 */ -#define TEGRA186_CLK_CAN1 210 -/** @brief output of gate CLK_ENB_CAN1_HOST */ -#define TEGRA186_CLK_CAN1_HOST 211 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_CAN2 */ -#define TEGRA186_CLK_CAN2 212 -/** @brief output of gate CLK_ENB_CAN2_HOST */ -#define TEGRA186_CLK_CAN2_HOST 213 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AON_APB */ -#define TEGRA186_CLK_AON_APB 214 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTC */ -#define TEGRA186_CLK_UARTC 215 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_UARTG */ -#define TEGRA186_CLK_UARTG 216 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AON_UART_FST_MIPI_CAL */ -#define TEGRA186_CLK_AON_UART_FST_MIPI_CAL 217 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C2 */ -#define TEGRA186_CLK_I2C2 218 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C8 */ -#define TEGRA186_CLK_I2C8 219 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_I2C10 */ -#define TEGRA186_CLK_I2C10 220 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AON_I2C_SLOW */ -#define TEGRA186_CLK_AON_I2C_SLOW 221 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SPI2 */ -#define TEGRA186_CLK_SPI2 222 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DMIC5 */ -#define TEGRA186_CLK_DMIC5 223 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_AON_TOUCH */ -#define TEGRA186_CLK_AON_TOUCH 224 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_PWM4 */ -#define TEGRA186_CLK_PWM4 225 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_TSC. This clock object is read only and is used for all timers in the system. */ -#define TEGRA186_CLK_TSC 226 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_MSS_ENCRYPT */ -#define TEGRA186_CLK_MSS_ENCRYPT 227 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SCE_CPU_NIC */ -#define TEGRA186_CLK_SCE_CPU_NIC 228 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SCE_APB */ -#define TEGRA186_CLK_SCE_APB 230 -/** @brief output of gate CLK_ENB_DSIC */ -#define TEGRA186_CLK_DSIC 231 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSIC_LP */ -#define TEGRA186_CLK_DSIC_LP 232 -/** @brief output of gate CLK_ENB_DSID */ -#define TEGRA186_CLK_DSID 233 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_DSID_LP */ -#define TEGRA186_CLK_DSID_LP 234 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_PEX_SATA_USB_RX_BYP */ -#define TEGRA186_CLK_PEX_SATA_USB_RX_BYP 236 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_CLK_SOURCE_SPDIF_OUT */ -#define TEGRA186_CLK_SPDIF_OUT 238 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_EQOS_PTP_REF_CLK_0 */ -#define TEGRA186_CLK_EQOS_PTP_REF 239 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_EQOS_TX_CLK */ -#define TEGRA186_CLK_EQOS_TX 240 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_USB2_HSIC_TRK */ -#define TEGRA186_CLK_USB2_HSIC_TRK 241 -/** @brief output of mux xusb_ss_clk_switch on page 66 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_CORE_SS 242 -/** @brief output of mux xusb_core_dev_clk_switch on page 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_CORE_DEV 243 -/** @brief output of mux xusb_core_falcon_clk_switch on page 67 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_FALCON 244 -/** @brief output of mux xusb_fs_clk_switch on page 66 of T186_Clocks_IAS.doc */ -#define TEGRA186_CLK_XUSB_FS 245 -/** @brief output of the divider CLK_RST_CONTROLLER_PLLA_OUT */ -#define TEGRA186_CLK_PLL_A_OUT0 246 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S1 */ -#define TEGRA186_CLK_SYNC_I2S1 247 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S2 */ -#define TEGRA186_CLK_SYNC_I2S2 248 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S3 */ -#define TEGRA186_CLK_SYNC_I2S3 249 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S4 */ -#define TEGRA186_CLK_SYNC_I2S4 250 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S5 */ -#define TEGRA186_CLK_SYNC_I2S5 251 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_I2S6 */ -#define TEGRA186_CLK_SYNC_I2S6 252 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DSPK1 */ -#define TEGRA186_CLK_SYNC_DSPK1 253 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DSPK2 */ -#define TEGRA186_CLK_SYNC_DSPK2 254 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DMIC1 */ -#define TEGRA186_CLK_SYNC_DMIC1 255 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DMIC2 */ -#define TEGRA186_CLK_SYNC_DMIC2 256 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DMIC3 */ -#define TEGRA186_CLK_SYNC_DMIC3 257 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_DMIC4 */ -#define TEGRA186_CLK_SYNC_DMIC4 259 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_AUDIO_SYNC_CLK_SPDIF */ -#define TEGRA186_CLK_SYNC_SPDIF 260 -/** @brief output of gate CLK_ENB_PLLREFE_OUT */ -#define TEGRA186_CLK_PLLREFE_OUT_GATED 261 -/** @brief output of the divider PLLREFE_DIVP in CLK_RST_CONTROLLER_PLLREFE_BASE. PLLREFE has 2 outputs: - * * VCO/pdiv defined by this clock object - * * VCO/2 defined by TEGRA186_CLK_PLLREFE_OUT - */ -#define TEGRA186_CLK_PLLREFE_OUT1 262 -#define TEGRA186_CLK_PLLD_OUT1 267 -/** @brief output of the divider PLLP_DIVP in CLK_RST_CONTROLLER_PLLP_BASE */ -#define TEGRA186_CLK_PLLP_OUT0 269 -/** @brief output of the divider CLK_RST_CONTROLLER_PLLP_OUTC */ -#define TEGRA186_CLK_PLLP_OUT5 270 -/** PLL controlled by CLK_RST_CONTROLLER_PLLA_BASE for use by audio clocks */ -#define TEGRA186_CLK_PLLA 271 -/** @brief output of mux controlled by CLK_RST_CONTROLLER_ACLK_BURST_POLICY divided by the divider controlled by ACLK_CLK_DIVISOR in CLK_RST_CONTROLLER_SUPER_ACLK_DIVIDER */ -#define TEGRA186_CLK_ACLK 273 -/** fixed 48MHz clock divided down from TEGRA186_CLK_PLL_U */ -#define TEGRA186_CLK_PLL_U_48M 274 -/** fixed 480MHz clock divided down from TEGRA186_CLK_PLL_U */ -#define TEGRA186_CLK_PLL_U_480M 275 -/** @brief output of the divider PLLC4_DIVP in CLK_RST_CONTROLLER_PLLC4_BASE. Output frequency is TEGRA186_CLK_PLLC4_VCO/PLLC4_DIVP */ -#define TEGRA186_CLK_PLLC4_OUT0 276 -/** fixed /3 divider. Output frequency of this clock is TEGRA186_CLK_PLLC4_VCO/3 */ -#define TEGRA186_CLK_PLLC4_OUT1 277 -/** fixed /5 divider. Output frequency of this clock is TEGRA186_CLK_PLLC4_VCO/5 */ -#define TEGRA186_CLK_PLLC4_OUT2 278 -/** @brief output of mux controlled by PLLC4_CLK_SEL in CLK_RST_CONTROLLER_PLLC4_MISC1 */ -#define TEGRA186_CLK_PLLC4_OUT_MUX 279 -/** @brief output of divider NVDISPLAY_DISP_CLK_DIVISOR in CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_DISP when DFLLDISP_DIV is selected in NVDISPLAY_DISP_CLK_SRC */ -#define TEGRA186_CLK_DFLLDISP_DIV 284 -/** @brief output of divider NVDISPLAY_DISP_CLK_DIVISOR in CLK_RST_CONTROLLER_CLK_SOURCE_NVDISPLAY_DISP when PLLDISPHUB_DIV is selected in NVDISPLAY_DISP_CLK_SRC */ -#define TEGRA186_CLK_PLLDISPHUB_DIV 285 -/** fixed /8 divider which is used as the input for TEGRA186_CLK_SOR_SAFE */ -#define TEGRA186_CLK_PLLP_DIV8 286 -/** @brief output of divider CLK_RST_CONTROLLER_BPMP_NIC_RATE */ -#define TEGRA186_CLK_BPMP_NIC 287 -/** @brief output of the divider CLK_RST_CONTROLLER_PLLA1_OUT1 */ -#define TEGRA186_CLK_PLL_A_OUT1 288 -/** @deprecated */ -#define TEGRA186_CLK_GPC2CLK 289 -/** A fake clock which must be enabled during KFUSE read operations to ensure adequate VDD_CORE voltage. */ -#define TEGRA186_CLK_KFUSE 293 -/** - * @brief controls the PLLE hardware sequencer. - * @details This clock only has enable and disable methods. When the - * PLLE hw sequencer is enabled, PLLE, will be enabled or disabled by - * hw based on the control signals from the PCIe, SATA and XUSB - * clocks. When the PLLE hw sequencer is disabled, the state of PLLE - * is controlled by sw using clk_enable/clk_disable on - * TEGRA186_CLK_PLLE. - */ -#define TEGRA186_CLK_PLLE_PWRSEQ 294 -/** fixed 60MHz clock divided down from, TEGRA186_CLK_PLL_U */ -#define TEGRA186_CLK_PLLREFE_REF 295 -/** @brief output of mux controlled by SOR0_CLK_SEL0 and SOR0_CLK_SEL1 in CLK_RST_CONTROLLER_CLK_SOURCE_SOR0 */ -#define TEGRA186_CLK_SOR0_OUT 296 -/** @brief output of mux controlled by SOR1_CLK_SEL0 and SOR1_CLK_SEL1 in CLK_RST_CONTROLLER_CLK_SOURCE_SOR1 */ -#define TEGRA186_CLK_SOR1_OUT 297 -/** @brief fixed /5 divider. Output frequency of this clock is TEGRA186_CLK_PLLREFE_OUT1/5. Used as input for TEGRA186_CLK_EQOS_AXI */ -#define TEGRA186_CLK_PLLREFE_OUT1_DIV5 298 -/** @brief controls the UTMIP_PLL (aka PLLU) hardware sqeuencer */ -#define TEGRA186_CLK_UTMIP_PLL_PWRSEQ 301 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_PEX_USB_PAD_PLL0_MGMT */ -#define TEGRA186_CLK_PEX_USB_PAD0_MGMT 302 -/** @brief output of the divider CLK_RST_CONTROLLER_CLK_SOURCE_PEX_USB_PAD_PLL1_MGMT */ -#define TEGRA186_CLK_PEX_USB_PAD1_MGMT 303 -/** @brief controls the UPHY_PLL0 hardware sqeuencer */ -#define TEGRA186_CLK_UPHY_PLL0_PWRSEQ 304 -/** @brief controls the UPHY_PLL1 hardware sqeuencer */ -#define TEGRA186_CLK_UPHY_PLL1_PWRSEQ 305 -/** @brief control for PLLREFE_IDDQ in CLK_RST_CONTROLLER_PLLREFE_MISC so the bypass output even be used when the PLL is disabled */ -#define TEGRA186_CLK_PLLREFE_PLLE_PASSTHROUGH 306 -/** @brief output of the mux controlled by PLLREFE_SEL_CLKIN_PEX in CLK_RST_CONTROLLER_PLLREFE_MISC */ -#define TEGRA186_CLK_PLLREFE_PEX 307 -/** @brief control for PLLREFE_IDDQ in CLK_RST_CONTROLLER_PLLREFE_MISC to turn on the PLL when enabled */ -#define TEGRA186_CLK_PLLREFE_IDDQ 308 -/** @brief output of the divider QSPI_CLK_DIV2_SEL in CLK_RST_CONTROLLER_CLK_SOURCE_QSPI */ -#define TEGRA186_CLK_QSPI_OUT 309 -/** - * @brief GPC2CLK-div-2 - * @details fixed /2 divider. Output frequency is - * TEGRA186_CLK_GPC2CLK/2. The frequency of this clock is the - * frequency at which the GPU graphics engine runs. */ -#define TEGRA186_CLK_GPCCLK 310 -/** @brief output of divider CLK_RST_CONTROLLER_AON_NIC_RATE */ -#define TEGRA186_CLK_AON_NIC 450 -/** @brief output of divider CLK_RST_CONTROLLER_SCE_NIC_RATE */ -#define TEGRA186_CLK_SCE_NIC 451 -/** Fixed 100MHz PLL for PCIe, SATA and superspeed USB */ -#define TEGRA186_CLK_PLLE 512 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLC_BASE */ -#define TEGRA186_CLK_PLLC 513 -/** Fixed 408MHz PLL for use by peripheral clocks */ -#define TEGRA186_CLK_PLLP 516 -/** @deprecated */ -#define TEGRA186_CLK_PLL_P TEGRA186_CLK_PLLP -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLD_BASE for use by DSI */ -#define TEGRA186_CLK_PLLD 518 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLD2_BASE for use by HDMI or DP */ -#define TEGRA186_CLK_PLLD2 519 -/** - * @brief PLL controlled by CLK_RST_CONTROLLER_PLLREFE_BASE. - * @details Note that this clock only controls the VCO output, before - * the post-divider. See TEGRA186_CLK_PLLREFE_OUT1 for more - * information. - */ -#define TEGRA186_CLK_PLLREFE_VCO 520 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLC2_BASE */ -#define TEGRA186_CLK_PLLC2 521 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLC3_BASE */ -#define TEGRA186_CLK_PLLC3 522 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLDP_BASE for use as the DP link clock */ -#define TEGRA186_CLK_PLLDP 523 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLC4_BASE */ -#define TEGRA186_CLK_PLLC4_VCO 524 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLA1_BASE for use by audio clocks */ -#define TEGRA186_CLK_PLLA1 525 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLNVCSI_BASE */ -#define TEGRA186_CLK_PLLNVCSI 526 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLDISPHUB_BASE */ -#define TEGRA186_CLK_PLLDISPHUB 527 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLD3_BASE for use by HDMI or DP */ -#define TEGRA186_CLK_PLLD3 528 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLBPMPCAM_BASE */ -#define TEGRA186_CLK_PLLBPMPCAM 531 -/** @brief PLL controlled by CLK_RST_CONTROLLER_PLLAON_BASE for use by IP blocks in the AON domain */ -#define TEGRA186_CLK_PLLAON 532 -/** Fixed frequency 960MHz PLL for USB and EAVB */ -#define TEGRA186_CLK_PLLU 533 -/** fixed /2 divider. Output frequency is TEGRA186_CLK_PLLC4_VCO/2 */ -#define TEGRA186_CLK_PLLC4_VCO_DIV2 535 -/** @brief NAFLL clock source for AXI_CBB */ -#define TEGRA186_CLK_NAFLL_AXI_CBB 564 -/** @brief NAFLL clock source for BPMP */ -#define TEGRA186_CLK_NAFLL_BPMP 565 -/** @brief NAFLL clock source for ISP */ -#define TEGRA186_CLK_NAFLL_ISP 566 -/** @brief NAFLL clock source for NVDEC */ -#define TEGRA186_CLK_NAFLL_NVDEC 567 -/** @brief NAFLL clock source for NVENC */ -#define TEGRA186_CLK_NAFLL_NVENC 568 -/** @brief NAFLL clock source for NVJPG */ -#define TEGRA186_CLK_NAFLL_NVJPG 569 -/** @brief NAFLL clock source for SCE */ -#define TEGRA186_CLK_NAFLL_SCE 570 -/** @brief NAFLL clock source for SE */ -#define TEGRA186_CLK_NAFLL_SE 571 -/** @brief NAFLL clock source for TSEC */ -#define TEGRA186_CLK_NAFLL_TSEC 572 -/** @brief NAFLL clock source for TSECB */ -#define TEGRA186_CLK_NAFLL_TSECB 573 -/** @brief NAFLL clock source for VI */ -#define TEGRA186_CLK_NAFLL_VI 574 -/** @brief NAFLL clock source for VIC */ -#define TEGRA186_CLK_NAFLL_VIC 575 -/** @brief NAFLL clock source for DISP */ -#define TEGRA186_CLK_NAFLL_DISP 576 -/** @brief NAFLL clock source for GPU */ -#define TEGRA186_CLK_NAFLL_GPU 577 -/** @brief NAFLL clock source for M-CPU cluster */ -#define TEGRA186_CLK_NAFLL_MCPU 578 -/** @brief NAFLL clock source for B-CPU cluster */ -#define TEGRA186_CLK_NAFLL_BCPU 579 -/** @brief input from Tegra's CLK_32K_IN pad */ -#define TEGRA186_CLK_CLK_32K 608 -/** @brief output of divider CLK_RST_CONTROLLER_CLK_M_DIVIDE */ -#define TEGRA186_CLK_CLK_M 609 -/** @brief output of divider PLL_REF_DIV in CLK_RST_CONTROLLER_OSC_CTRL */ -#define TEGRA186_CLK_PLL_REF 610 -/** @brief input from Tegra's XTAL_IN */ -#define TEGRA186_CLK_OSC 612 -/** @brief clock recovered from EAVB input */ -#define TEGRA186_CLK_EQOS_RX_INPUT 613 -/** @brief clock recovered from DTV input */ -#define TEGRA186_CLK_DTV_INPUT 614 -/** @brief SOR0 brick output which feeds into SOR0_CLK_SEL mux in CLK_RST_CONTROLLER_CLK_SOURCE_SOR0*/ -#define TEGRA186_CLK_SOR0_PAD_CLKOUT 615 -/** @brief SOR1 brick output which feeds into SOR1_CLK_SEL mux in CLK_RST_CONTROLLER_CLK_SOURCE_SOR1*/ -#define TEGRA186_CLK_SOR1_PAD_CLKOUT 616 -/** @brief clock recovered from I2S1 input */ -#define TEGRA186_CLK_I2S1_SYNC_INPUT 617 -/** @brief clock recovered from I2S2 input */ -#define TEGRA186_CLK_I2S2_SYNC_INPUT 618 -/** @brief clock recovered from I2S3 input */ -#define TEGRA186_CLK_I2S3_SYNC_INPUT 619 -/** @brief clock recovered from I2S4 input */ -#define TEGRA186_CLK_I2S4_SYNC_INPUT 620 -/** @brief clock recovered from I2S5 input */ -#define TEGRA186_CLK_I2S5_SYNC_INPUT 621 -/** @brief clock recovered from I2S6 input */ -#define TEGRA186_CLK_I2S6_SYNC_INPUT 622 -/** @brief clock recovered from SPDIFIN input */ -#define TEGRA186_CLK_SPDIFIN_SYNC_INPUT 623 - -/** - * @brief subject to change - * @details maximum clock identifier value plus one. - */ -#define TEGRA186_CLK_CLK_MAX 624 - -/** @} */ - -#endif diff --git a/include/dt-bindings/clock/tegra20-car.h b/include/dt-bindings/clock/tegra20-car.h deleted file mode 100644 index 04500b243a4d..000000000000 --- a/include/dt-bindings/clock/tegra20-car.h +++ /dev/null @@ -1,158 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra20-car. - * - * The first 96 clocks are numbered to match the bits in the CAR's CLK_OUT_ENB - * registers. These IDs often match those in the CAR's RST_DEVICES registers, - * but not in all cases. Some bits in CLK_OUT_ENB affect multiple clocks. In - * this case, those clocks are assigned IDs above 95 in order to highlight - * this issue. Implementations that interpret these clock IDs as bit values - * within the CLK_OUT_ENB or RST_DEVICES registers should be careful to - * explicitly handle these special cases. - * - * The balance of the clocks controlled by the CAR are assigned IDs of 96 and - * above. - */ - -#ifndef _DT_BINDINGS_CLOCK_TEGRA20_CAR_H -#define _DT_BINDINGS_CLOCK_TEGRA20_CAR_H - -#define TEGRA20_CLK_CPU 0 -/* 1 */ -/* 2 */ -#define TEGRA20_CLK_AC97 3 -#define TEGRA20_CLK_RTC 4 -#define TEGRA20_CLK_TIMER 5 -#define TEGRA20_CLK_UARTA 6 -/* 7 (register bit affects uart2 and vfir) */ -#define TEGRA20_CLK_GPIO 8 -#define TEGRA20_CLK_SDMMC2 9 -/* 10 (register bit affects spdif_in and spdif_out) */ -#define TEGRA20_CLK_I2S1 11 -#define TEGRA20_CLK_I2C1 12 -#define TEGRA20_CLK_NDFLASH 13 -#define TEGRA20_CLK_SDMMC1 14 -#define TEGRA20_CLK_SDMMC4 15 -#define TEGRA20_CLK_TWC 16 -#define TEGRA20_CLK_PWM 17 -#define TEGRA20_CLK_I2S2 18 -#define TEGRA20_CLK_EPP 19 -/* 20 (register bit affects vi and vi_sensor) */ -#define TEGRA20_CLK_GR2D 21 -#define TEGRA20_CLK_USBD 22 -#define TEGRA20_CLK_ISP 23 -#define TEGRA20_CLK_GR3D 24 -#define TEGRA20_CLK_IDE 25 -#define TEGRA20_CLK_DISP2 26 -#define TEGRA20_CLK_DISP1 27 -#define TEGRA20_CLK_HOST1X 28 -#define TEGRA20_CLK_VCP 29 -/* 30 */ -#define TEGRA20_CLK_CACHE2 31 - -#define TEGRA20_CLK_MC 32 -#define TEGRA20_CLK_AHBDMA 33 -#define TEGRA20_CLK_APBDMA 34 -/* 35 */ -#define TEGRA20_CLK_KBC 36 -#define TEGRA20_CLK_STAT_MON 37 -#define TEGRA20_CLK_PMC 38 -#define TEGRA20_CLK_FUSE 39 -#define TEGRA20_CLK_KFUSE 40 -#define TEGRA20_CLK_SBC1 41 -#define TEGRA20_CLK_NOR 42 -#define TEGRA20_CLK_SPI 43 -#define TEGRA20_CLK_SBC2 44 -#define TEGRA20_CLK_XIO 45 -#define TEGRA20_CLK_SBC3 46 -#define TEGRA20_CLK_DVC 47 -#define TEGRA20_CLK_DSI 48 -/* 49 (register bit affects tvo and cve) */ -#define TEGRA20_CLK_MIPI 50 -#define TEGRA20_CLK_HDMI 51 -#define TEGRA20_CLK_CSI 52 -#define TEGRA20_CLK_TVDAC 53 -#define TEGRA20_CLK_I2C2 54 -#define TEGRA20_CLK_UARTC 55 -/* 56 */ -#define TEGRA20_CLK_EMC 57 -#define TEGRA20_CLK_USB2 58 -#define TEGRA20_CLK_USB3 59 -#define TEGRA20_CLK_MPE 60 -#define TEGRA20_CLK_VDE 61 -#define TEGRA20_CLK_BSEA 62 -#define TEGRA20_CLK_BSEV 63 - -#define TEGRA20_CLK_SPEEDO 64 -#define TEGRA20_CLK_UARTD 65 -#define TEGRA20_CLK_UARTE 66 -#define TEGRA20_CLK_I2C3 67 -#define TEGRA20_CLK_SBC4 68 -#define TEGRA20_CLK_SDMMC3 69 -#define TEGRA20_CLK_PEX 70 -#define TEGRA20_CLK_OWR 71 -#define TEGRA20_CLK_AFI 72 -#define TEGRA20_CLK_CSITE 73 -/* 74 */ -#define TEGRA20_CLK_AVPUCQ 75 -#define TEGRA20_CLK_LA 76 -/* 77 */ -/* 78 */ -/* 79 */ -/* 80 */ -/* 81 */ -/* 82 */ -/* 83 */ -#define TEGRA20_CLK_IRAMA 84 -#define TEGRA20_CLK_IRAMB 85 -#define TEGRA20_CLK_IRAMC 86 -#define TEGRA20_CLK_IRAMD 87 -#define TEGRA20_CLK_CRAM2 88 -#define TEGRA20_CLK_AUDIO_2X 89 /* a/k/a audio_2x_sync_clk */ -#define TEGRA20_CLK_CLK_D 90 -/* 91 */ -#define TEGRA20_CLK_CSUS 92 -#define TEGRA20_CLK_CDEV2 93 -#define TEGRA20_CLK_CDEV1 94 -/* 95 */ - -#define TEGRA20_CLK_UARTB 96 -#define TEGRA20_CLK_VFIR 97 -#define TEGRA20_CLK_SPDIF_IN 98 -#define TEGRA20_CLK_SPDIF_OUT 99 -#define TEGRA20_CLK_VI 100 -#define TEGRA20_CLK_VI_SENSOR 101 -#define TEGRA20_CLK_TVO 102 -#define TEGRA20_CLK_CVE 103 -#define TEGRA20_CLK_OSC 104 -#define TEGRA20_CLK_CLK_32K 105 /* a/k/a clk_s */ -#define TEGRA20_CLK_CLK_M 106 -#define TEGRA20_CLK_SCLK 107 -#define TEGRA20_CLK_CCLK 108 -#define TEGRA20_CLK_HCLK 109 -#define TEGRA20_CLK_PCLK 110 -#define TEGRA20_CLK_BLINK 111 -#define TEGRA20_CLK_PLL_A 112 -#define TEGRA20_CLK_PLL_A_OUT0 113 -#define TEGRA20_CLK_PLL_C 114 -#define TEGRA20_CLK_PLL_C_OUT1 115 -#define TEGRA20_CLK_PLL_D 116 -#define TEGRA20_CLK_PLL_D_OUT0 117 -#define TEGRA20_CLK_PLL_E 118 -#define TEGRA20_CLK_PLL_M 119 -#define TEGRA20_CLK_PLL_M_OUT1 120 -#define TEGRA20_CLK_PLL_P 121 -#define TEGRA20_CLK_PLL_P_OUT1 122 -#define TEGRA20_CLK_PLL_P_OUT2 123 -#define TEGRA20_CLK_PLL_P_OUT3 124 -#define TEGRA20_CLK_PLL_P_OUT4 125 -#define TEGRA20_CLK_PLL_S 126 -#define TEGRA20_CLK_PLL_U 127 - -#define TEGRA20_CLK_PLL_X 128 -#define TEGRA20_CLK_COP 129 /* a/k/a avp */ -#define TEGRA20_CLK_AUDIO 130 /* a/k/a audio_sync_clk */ -#define TEGRA20_CLK_PLL_REF 131 -#define TEGRA20_CLK_TWD 132 -#define TEGRA20_CLK_CLK_MAX 133 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA20_CAR_H */ diff --git a/include/dt-bindings/clock/tegra210-car.h b/include/dt-bindings/clock/tegra210-car.h deleted file mode 100644 index bd3530e56d46..000000000000 --- a/include/dt-bindings/clock/tegra210-car.h +++ /dev/null @@ -1,401 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra210-car. - * - * The first 224 clocks are numbered to match the bits in the CAR's CLK_OUT_ENB - * registers. These IDs often match those in the CAR's RST_DEVICES registers, - * but not in all cases. Some bits in CLK_OUT_ENB affect multiple clocks. In - * this case, those clocks are assigned IDs above 224 in order to highlight - * this issue. Implementations that interpret these clock IDs as bit values - * within the CLK_OUT_ENB or RST_DEVICES registers should be careful to - * explicitly handle these special cases. - * - * The balance of the clocks controlled by the CAR are assigned IDs of 224 and - * above. - */ - -#ifndef _DT_BINDINGS_CLOCK_TEGRA210_CAR_H -#define _DT_BINDINGS_CLOCK_TEGRA210_CAR_H - -/* 0 */ -/* 1 */ -/* 2 */ -#define TEGRA210_CLK_ISPB 3 -#define TEGRA210_CLK_RTC 4 -#define TEGRA210_CLK_TIMER 5 -#define TEGRA210_CLK_UARTA 6 -/* 7 (register bit affects uartb and vfir) */ -#define TEGRA210_CLK_GPIO 8 -#define TEGRA210_CLK_SDMMC2 9 -/* 10 (register bit affects spdif_in and spdif_out) */ -#define TEGRA210_CLK_I2S1 11 -#define TEGRA210_CLK_I2C1 12 -/* 13 */ -#define TEGRA210_CLK_SDMMC1 14 -#define TEGRA210_CLK_SDMMC4 15 -/* 16 */ -#define TEGRA210_CLK_PWM 17 -#define TEGRA210_CLK_I2S2 18 -/* 19 */ -/* 20 (register bit affects vi and vi_sensor) */ -/* 21 */ -#define TEGRA210_CLK_USBD 22 -#define TEGRA210_CLK_ISP 23 -/* 24 */ -/* 25 */ -#define TEGRA210_CLK_DISP2 26 -#define TEGRA210_CLK_DISP1 27 -#define TEGRA210_CLK_HOST1X 28 -/* 29 */ -#define TEGRA210_CLK_I2S0 30 -/* 31 */ - -#define TEGRA210_CLK_MC 32 -#define TEGRA210_CLK_AHBDMA 33 -#define TEGRA210_CLK_APBDMA 34 -/* 35 */ -/* 36 */ -/* 37 */ -#define TEGRA210_CLK_PMC 38 -/* 39 (register bit affects fuse and fuse_burn) */ -#define TEGRA210_CLK_KFUSE 40 -#define TEGRA210_CLK_SBC1 41 -/* 42 */ -/* 43 */ -#define TEGRA210_CLK_SBC2 44 -/* 45 */ -#define TEGRA210_CLK_SBC3 46 -#define TEGRA210_CLK_I2C5 47 -#define TEGRA210_CLK_DSIA 48 -/* 49 */ -/* 50 */ -/* 51 */ -#define TEGRA210_CLK_CSI 52 -/* 53 */ -#define TEGRA210_CLK_I2C2 54 -#define TEGRA210_CLK_UARTC 55 -#define TEGRA210_CLK_MIPI_CAL 56 -#define TEGRA210_CLK_EMC 57 -#define TEGRA210_CLK_USB2 58 -/* 59 */ -/* 60 */ -/* 61 */ -/* 62 */ -#define TEGRA210_CLK_BSEV 63 - -/* 64 */ -#define TEGRA210_CLK_UARTD 65 -/* 66 */ -#define TEGRA210_CLK_I2C3 67 -#define TEGRA210_CLK_SBC4 68 -#define TEGRA210_CLK_SDMMC3 69 -#define TEGRA210_CLK_PCIE 70 -#define TEGRA210_CLK_OWR 71 -#define TEGRA210_CLK_AFI 72 -#define TEGRA210_CLK_CSITE 73 -/* 74 */ -/* 75 */ -/* 76 */ -/* 77 */ -#define TEGRA210_CLK_SOC_THERM 78 -#define TEGRA210_CLK_DTV 79 -/* 80 */ -#define TEGRA210_CLK_I2CSLOW 81 -#define TEGRA210_CLK_DSIB 82 -#define TEGRA210_CLK_TSEC 83 -/* 84 */ -/* 85 */ -/* 86 */ -/* 87 */ -/* 88 */ -#define TEGRA210_CLK_XUSB_HOST 89 -/* 90 */ -/* 91 */ -#define TEGRA210_CLK_CSUS 92 -/* 93 */ -/* 94 */ -/* 95 (bit affects xusb_dev and xusb_dev_src) */ - -/* 96 */ -/* 97 */ -/* 98 */ -#define TEGRA210_CLK_MSELECT 99 -#define TEGRA210_CLK_TSENSOR 100 -#define TEGRA210_CLK_I2S3 101 -#define TEGRA210_CLK_I2S4 102 -#define TEGRA210_CLK_I2C4 103 -/* 104 */ -/* 105 */ -#define TEGRA210_CLK_D_AUDIO 106 -#define TEGRA210_CLK_APB2APE 107 -/* 108 */ -/* 109 */ -/* 110 */ -#define TEGRA210_CLK_HDA2CODEC_2X 111 -/* 112 */ -/* 113 */ -/* 114 */ -/* 115 */ -/* 116 */ -/* 117 */ -#define TEGRA210_CLK_SPDIF_2X 118 -#define TEGRA210_CLK_ACTMON 119 -#define TEGRA210_CLK_EXTERN1 120 -#define TEGRA210_CLK_EXTERN2 121 -#define TEGRA210_CLK_EXTERN3 122 -#define TEGRA210_CLK_SATA_OOB 123 -#define TEGRA210_CLK_SATA 124 -#define TEGRA210_CLK_HDA 125 -/* 126 */ -/* 127 */ - -#define TEGRA210_CLK_HDA2HDMI 128 -/* 129 */ -/* 130 */ -/* 131 */ -/* 132 */ -/* 133 */ -/* 134 */ -/* 135 */ -/* 136 */ -/* 137 */ -/* 138 */ -/* 139 */ -/* 140 */ -/* 141 */ -/* 142 */ -/* (bit affects xusb_falcon_src, xusb_fs_src, xusb_host_src and xusb_ss_src) */ -#define TEGRA210_CLK_XUSB_GATE 143 -#define TEGRA210_CLK_CILAB 144 -#define TEGRA210_CLK_CILCD 145 -#define TEGRA210_CLK_CILE 146 -#define TEGRA210_CLK_DSIALP 147 -#define TEGRA210_CLK_DSIBLP 148 -#define TEGRA210_CLK_ENTROPY 149 -/* 150 */ -/* 151 */ -/* 152 */ -/* 153 */ -/* 154 */ -/* 155 (bit affects dfll_ref and dfll_soc) */ -#define TEGRA210_CLK_XUSB_SS 156 -/* 157 */ -/* 158 */ -/* 159 */ - -/* 160 */ -#define TEGRA210_CLK_DMIC1 161 -#define TEGRA210_CLK_DMIC2 162 -/* 163 */ -/* 164 */ -/* 165 */ -#define TEGRA210_CLK_I2C6 166 -/* 167 */ -/* 168 */ -/* 169 */ -/* 170 */ -#define TEGRA210_CLK_VIM2_CLK 171 -/* 172 */ -#define TEGRA210_CLK_MIPIBIF 173 -/* 174 */ -/* 175 */ -/* 176 */ -#define TEGRA210_CLK_CLK72MHZ 177 -#define TEGRA210_CLK_VIC03 178 -/* 179 */ -/* 180 */ -#define TEGRA210_CLK_DPAUX 181 -#define TEGRA210_CLK_SOR0 182 -#define TEGRA210_CLK_SOR1 183 -#define TEGRA210_CLK_GPU 184 -#define TEGRA210_CLK_DBGAPB 185 -/* 186 */ -#define TEGRA210_CLK_PLL_P_OUT_ADSP 187 -/* 188 */ -#define TEGRA210_CLK_PLL_G_REF 189 -/* 190 */ -/* 191 */ - -/* 192 */ -#define TEGRA210_CLK_SDMMC_LEGACY 193 -#define TEGRA210_CLK_NVDEC 194 -#define TEGRA210_CLK_NVJPG 195 -/* 196 */ -#define TEGRA210_CLK_DMIC3 197 -#define TEGRA210_CLK_APE 198 -/* 199 */ -/* 200 */ -/* 201 */ -#define TEGRA210_CLK_MAUD 202 -/* 203 */ -/* 204 */ -/* 205 */ -#define TEGRA210_CLK_TSECB 206 -#define TEGRA210_CLK_DPAUX1 207 -#define TEGRA210_CLK_VI_I2C 208 -#define TEGRA210_CLK_HSIC_TRK 209 -#define TEGRA210_CLK_USB2_TRK 210 -#define TEGRA210_CLK_QSPI 211 -#define TEGRA210_CLK_UARTAPE 212 -/* 213 */ -/* 214 */ -/* 215 */ -/* 216 */ -/* 217 */ -/* 218 */ -#define TEGRA210_CLK_NVENC 219 -/* 220 */ -/* 221 */ -#define TEGRA210_CLK_SOR_SAFE 222 -#define TEGRA210_CLK_PLL_P_OUT_CPU 223 - - -#define TEGRA210_CLK_UARTB 224 -#define TEGRA210_CLK_VFIR 225 -#define TEGRA210_CLK_SPDIF_IN 226 -#define TEGRA210_CLK_SPDIF_OUT 227 -#define TEGRA210_CLK_VI 228 -#define TEGRA210_CLK_VI_SENSOR 229 -#define TEGRA210_CLK_FUSE 230 -#define TEGRA210_CLK_FUSE_BURN 231 -#define TEGRA210_CLK_CLK_32K 232 -#define TEGRA210_CLK_CLK_M 233 -#define TEGRA210_CLK_CLK_M_DIV2 234 -#define TEGRA210_CLK_CLK_M_DIV4 235 -#define TEGRA210_CLK_PLL_REF 236 -#define TEGRA210_CLK_PLL_C 237 -#define TEGRA210_CLK_PLL_C_OUT1 238 -#define TEGRA210_CLK_PLL_C2 239 -#define TEGRA210_CLK_PLL_C3 240 -#define TEGRA210_CLK_PLL_M 241 -#define TEGRA210_CLK_PLL_M_OUT1 242 -#define TEGRA210_CLK_PLL_P 243 -#define TEGRA210_CLK_PLL_P_OUT1 244 -#define TEGRA210_CLK_PLL_P_OUT2 245 -#define TEGRA210_CLK_PLL_P_OUT3 246 -#define TEGRA210_CLK_PLL_P_OUT4 247 -#define TEGRA210_CLK_PLL_A 248 -#define TEGRA210_CLK_PLL_A_OUT0 249 -#define TEGRA210_CLK_PLL_D 250 -#define TEGRA210_CLK_PLL_D_OUT0 251 -#define TEGRA210_CLK_PLL_D2 252 -#define TEGRA210_CLK_PLL_D2_OUT0 253 -#define TEGRA210_CLK_PLL_U 254 -#define TEGRA210_CLK_PLL_U_480M 255 - -#define TEGRA210_CLK_PLL_U_60M 256 -#define TEGRA210_CLK_PLL_U_48M 257 -/* 258 */ -#define TEGRA210_CLK_PLL_X 259 -#define TEGRA210_CLK_PLL_X_OUT0 260 -#define TEGRA210_CLK_PLL_RE_VCO 261 -#define TEGRA210_CLK_PLL_RE_OUT 262 -#define TEGRA210_CLK_PLL_E 263 -#define TEGRA210_CLK_SPDIF_IN_SYNC 264 -#define TEGRA210_CLK_I2S0_SYNC 265 -#define TEGRA210_CLK_I2S1_SYNC 266 -#define TEGRA210_CLK_I2S2_SYNC 267 -#define TEGRA210_CLK_I2S3_SYNC 268 -#define TEGRA210_CLK_I2S4_SYNC 269 -#define TEGRA210_CLK_VIMCLK_SYNC 270 -#define TEGRA210_CLK_AUDIO0 271 -#define TEGRA210_CLK_AUDIO1 272 -#define TEGRA210_CLK_AUDIO2 273 -#define TEGRA210_CLK_AUDIO3 274 -#define TEGRA210_CLK_AUDIO4 275 -#define TEGRA210_CLK_SPDIF 276 -#define TEGRA210_CLK_CLK_OUT_1 277 -#define TEGRA210_CLK_CLK_OUT_2 278 -#define TEGRA210_CLK_CLK_OUT_3 279 -#define TEGRA210_CLK_BLINK 280 -/* 281 */ -/* 282 */ -/* 283 */ -#define TEGRA210_CLK_XUSB_HOST_SRC 284 -#define TEGRA210_CLK_XUSB_FALCON_SRC 285 -#define TEGRA210_CLK_XUSB_FS_SRC 286 -#define TEGRA210_CLK_XUSB_SS_SRC 287 - -#define TEGRA210_CLK_XUSB_DEV_SRC 288 -#define TEGRA210_CLK_XUSB_DEV 289 -#define TEGRA210_CLK_XUSB_HS_SRC 290 -#define TEGRA210_CLK_SCLK 291 -#define TEGRA210_CLK_HCLK 292 -#define TEGRA210_CLK_PCLK 293 -#define TEGRA210_CLK_CCLK_G 294 -#define TEGRA210_CLK_CCLK_LP 295 -#define TEGRA210_CLK_DFLL_REF 296 -#define TEGRA210_CLK_DFLL_SOC 297 -#define TEGRA210_CLK_VI_SENSOR2 298 -#define TEGRA210_CLK_PLL_P_OUT5 299 -#define TEGRA210_CLK_CML0 300 -#define TEGRA210_CLK_CML1 301 -#define TEGRA210_CLK_PLL_C4 302 -#define TEGRA210_CLK_PLL_DP 303 -#define TEGRA210_CLK_PLL_E_MUX 304 -#define TEGRA210_CLK_PLL_MB 305 -#define TEGRA210_CLK_PLL_A1 306 -#define TEGRA210_CLK_PLL_D_DSI_OUT 307 -#define TEGRA210_CLK_PLL_C4_OUT0 308 -#define TEGRA210_CLK_PLL_C4_OUT1 309 -#define TEGRA210_CLK_PLL_C4_OUT2 310 -#define TEGRA210_CLK_PLL_C4_OUT3 311 -#define TEGRA210_CLK_PLL_U_OUT 312 -#define TEGRA210_CLK_PLL_U_OUT1 313 -#define TEGRA210_CLK_PLL_U_OUT2 314 -#define TEGRA210_CLK_USB2_HSIC_TRK 315 -#define TEGRA210_CLK_PLL_P_OUT_HSIO 316 -#define TEGRA210_CLK_PLL_P_OUT_XUSB 317 -#define TEGRA210_CLK_XUSB_SSP_SRC 318 -#define TEGRA210_CLK_PLL_RE_OUT1 319 -/* 320 */ -/* 321 */ -/* 322 */ -/* 323 */ -/* 324 */ -/* 325 */ -/* 326 */ -/* 327 */ -/* 328 */ -/* 329 */ -/* 330 */ -/* 331 */ -/* 332 */ -/* 333 */ -/* 334 */ -/* 335 */ -/* 336 */ -/* 337 */ -/* 338 */ -/* 339 */ -/* 340 */ -/* 341 */ -/* 342 */ -/* 343 */ -/* 344 */ -/* 345 */ -/* 346 */ -/* 347 */ -/* 348 */ -/* 349 */ - -#define TEGRA210_CLK_AUDIO0_MUX 350 -#define TEGRA210_CLK_AUDIO1_MUX 351 -#define TEGRA210_CLK_AUDIO2_MUX 352 -#define TEGRA210_CLK_AUDIO3_MUX 353 -#define TEGRA210_CLK_AUDIO4_MUX 354 -#define TEGRA210_CLK_SPDIF_MUX 355 -#define TEGRA210_CLK_CLK_OUT_1_MUX 356 -#define TEGRA210_CLK_CLK_OUT_2_MUX 357 -#define TEGRA210_CLK_CLK_OUT_3_MUX 358 -#define TEGRA210_CLK_DSIA_MUX 359 -#define TEGRA210_CLK_DSIB_MUX 360 -#define TEGRA210_CLK_SOR0_LVDS 361 -#define TEGRA210_CLK_XUSB_SS_DIV2 362 - -#define TEGRA210_CLK_PLL_M_UD 363 -#define TEGRA210_CLK_PLL_C_UD 364 -#define TEGRA210_CLK_SCLK_MUX 365 - -#define TEGRA210_CLK_CLK_MAX 366 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA210_CAR_H */ diff --git a/include/dt-bindings/clock/tegra30-car.h b/include/dt-bindings/clock/tegra30-car.h deleted file mode 100644 index 889e49ba0aa3..000000000000 --- a/include/dt-bindings/clock/tegra30-car.h +++ /dev/null @@ -1,273 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra30-car. - * - * The first 130 clocks are numbered to match the bits in the CAR's CLK_OUT_ENB - * registers. These IDs often match those in the CAR's RST_DEVICES registers, - * but not in all cases. Some bits in CLK_OUT_ENB affect multiple clocks. In - * this case, those clocks are assigned IDs above 160 in order to highlight - * this issue. Implementations that interpret these clock IDs as bit values - * within the CLK_OUT_ENB or RST_DEVICES registers should be careful to - * explicitly handle these special cases. - * - * The balance of the clocks controlled by the CAR are assigned IDs of 160 and - * above. - */ - -#ifndef _DT_BINDINGS_CLOCK_TEGRA30_CAR_H -#define _DT_BINDINGS_CLOCK_TEGRA30_CAR_H - -#define TEGRA30_CLK_CPU 0 -/* 1 */ -/* 2 */ -/* 3 */ -#define TEGRA30_CLK_RTC 4 -#define TEGRA30_CLK_TIMER 5 -#define TEGRA30_CLK_UARTA 6 -/* 7 (register bit affects uartb and vfir) */ -#define TEGRA30_CLK_GPIO 8 -#define TEGRA30_CLK_SDMMC2 9 -/* 10 (register bit affects spdif_in and spdif_out) */ -#define TEGRA30_CLK_I2S1 11 -#define TEGRA30_CLK_I2C1 12 -#define TEGRA30_CLK_NDFLASH 13 -#define TEGRA30_CLK_SDMMC1 14 -#define TEGRA30_CLK_SDMMC4 15 -/* 16 */ -#define TEGRA30_CLK_PWM 17 -#define TEGRA30_CLK_I2S2 18 -#define TEGRA30_CLK_EPP 19 -/* 20 (register bit affects vi and vi_sensor) */ -#define TEGRA30_CLK_GR2D 21 -#define TEGRA30_CLK_USBD 22 -#define TEGRA30_CLK_ISP 23 -#define TEGRA30_CLK_GR3D 24 -/* 25 */ -#define TEGRA30_CLK_DISP2 26 -#define TEGRA30_CLK_DISP1 27 -#define TEGRA30_CLK_HOST1X 28 -#define TEGRA30_CLK_VCP 29 -#define TEGRA30_CLK_I2S0 30 -#define TEGRA30_CLK_COP_CACHE 31 - -#define TEGRA30_CLK_MC 32 -#define TEGRA30_CLK_AHBDMA 33 -#define TEGRA30_CLK_APBDMA 34 -/* 35 */ -#define TEGRA30_CLK_KBC 36 -#define TEGRA30_CLK_STATMON 37 -#define TEGRA30_CLK_PMC 38 -/* 39 (register bit affects fuse and fuse_burn) */ -#define TEGRA30_CLK_KFUSE 40 -#define TEGRA30_CLK_SBC1 41 -#define TEGRA30_CLK_NOR 42 -/* 43 */ -#define TEGRA30_CLK_SBC2 44 -/* 45 */ -#define TEGRA30_CLK_SBC3 46 -#define TEGRA30_CLK_I2C5 47 -#define TEGRA30_CLK_DSIA 48 -/* 49 (register bit affects cve and tvo) */ -#define TEGRA30_CLK_MIPI 50 -#define TEGRA30_CLK_HDMI 51 -#define TEGRA30_CLK_CSI 52 -#define TEGRA30_CLK_TVDAC 53 -#define TEGRA30_CLK_I2C2 54 -#define TEGRA30_CLK_UARTC 55 -/* 56 */ -#define TEGRA30_CLK_EMC 57 -#define TEGRA30_CLK_USB2 58 -#define TEGRA30_CLK_USB3 59 -#define TEGRA30_CLK_MPE 60 -#define TEGRA30_CLK_VDE 61 -#define TEGRA30_CLK_BSEA 62 -#define TEGRA30_CLK_BSEV 63 - -#define TEGRA30_CLK_SPEEDO 64 -#define TEGRA30_CLK_UARTD 65 -#define TEGRA30_CLK_UARTE 66 -#define TEGRA30_CLK_I2C3 67 -#define TEGRA30_CLK_SBC4 68 -#define TEGRA30_CLK_SDMMC3 69 -#define TEGRA30_CLK_PCIE 70 -#define TEGRA30_CLK_OWR 71 -#define TEGRA30_CLK_AFI 72 -#define TEGRA30_CLK_CSITE 73 -/* 74 */ -#define TEGRA30_CLK_AVPUCQ 75 -#define TEGRA30_CLK_LA 76 -/* 77 */ -/* 78 */ -#define TEGRA30_CLK_DTV 79 -#define TEGRA30_CLK_NDSPEED 80 -#define TEGRA30_CLK_I2CSLOW 81 -#define TEGRA30_CLK_DSIB 82 -/* 83 */ -#define TEGRA30_CLK_IRAMA 84 -#define TEGRA30_CLK_IRAMB 85 -#define TEGRA30_CLK_IRAMC 86 -#define TEGRA30_CLK_IRAMD 87 -#define TEGRA30_CLK_CRAM2 88 -/* 89 */ -#define TEGRA30_CLK_AUDIO_2X 90 /* a/k/a audio_2x_sync_clk */ -/* 91 */ -#define TEGRA30_CLK_CSUS 92 -#define TEGRA30_CLK_CDEV2 93 -#define TEGRA30_CLK_CDEV1 94 -/* 95 */ - -#define TEGRA30_CLK_CPU_G 96 -#define TEGRA30_CLK_CPU_LP 97 -#define TEGRA30_CLK_GR3D2 98 -#define TEGRA30_CLK_MSELECT 99 -#define TEGRA30_CLK_TSENSOR 100 -#define TEGRA30_CLK_I2S3 101 -#define TEGRA30_CLK_I2S4 102 -#define TEGRA30_CLK_I2C4 103 -#define TEGRA30_CLK_SBC5 104 -#define TEGRA30_CLK_SBC6 105 -#define TEGRA30_CLK_D_AUDIO 106 -#define TEGRA30_CLK_APBIF 107 -#define TEGRA30_CLK_DAM0 108 -#define TEGRA30_CLK_DAM1 109 -#define TEGRA30_CLK_DAM2 110 -#define TEGRA30_CLK_HDA2CODEC_2X 111 -#define TEGRA30_CLK_ATOMICS 112 -#define TEGRA30_CLK_AUDIO0_2X 113 -#define TEGRA30_CLK_AUDIO1_2X 114 -#define TEGRA30_CLK_AUDIO2_2X 115 -#define TEGRA30_CLK_AUDIO3_2X 116 -#define TEGRA30_CLK_AUDIO4_2X 117 -#define TEGRA30_CLK_SPDIF_2X 118 -#define TEGRA30_CLK_ACTMON 119 -#define TEGRA30_CLK_EXTERN1 120 -#define TEGRA30_CLK_EXTERN2 121 -#define TEGRA30_CLK_EXTERN3 122 -#define TEGRA30_CLK_SATA_OOB 123 -#define TEGRA30_CLK_SATA 124 -#define TEGRA30_CLK_HDA 125 -/* 126 */ -#define TEGRA30_CLK_SE 127 - -#define TEGRA30_CLK_HDA2HDMI 128 -#define TEGRA30_CLK_SATA_COLD 129 -/* 130 */ -/* 131 */ -/* 132 */ -/* 133 */ -/* 134 */ -/* 135 */ -/* 136 */ -/* 137 */ -/* 138 */ -/* 139 */ -/* 140 */ -/* 141 */ -/* 142 */ -/* 143 */ -/* 144 */ -/* 145 */ -/* 146 */ -/* 147 */ -/* 148 */ -/* 149 */ -/* 150 */ -/* 151 */ -/* 152 */ -/* 153 */ -/* 154 */ -/* 155 */ -/* 156 */ -/* 157 */ -/* 158 */ -/* 159 */ - -#define TEGRA30_CLK_UARTB 160 -#define TEGRA30_CLK_VFIR 161 -#define TEGRA30_CLK_SPDIF_IN 162 -#define TEGRA30_CLK_SPDIF_OUT 163 -#define TEGRA30_CLK_VI 164 -#define TEGRA30_CLK_VI_SENSOR 165 -#define TEGRA30_CLK_FUSE 166 -#define TEGRA30_CLK_FUSE_BURN 167 -#define TEGRA30_CLK_CVE 168 -#define TEGRA30_CLK_TVO 169 -#define TEGRA30_CLK_CLK_32K 170 -#define TEGRA30_CLK_CLK_M 171 -#define TEGRA30_CLK_CLK_M_DIV2 172 -#define TEGRA30_CLK_CLK_M_DIV4 173 -#define TEGRA30_CLK_PLL_REF 174 -#define TEGRA30_CLK_PLL_C 175 -#define TEGRA30_CLK_PLL_C_OUT1 176 -#define TEGRA30_CLK_PLL_M 177 -#define TEGRA30_CLK_PLL_M_OUT1 178 -#define TEGRA30_CLK_PLL_P 179 -#define TEGRA30_CLK_PLL_P_OUT1 180 -#define TEGRA30_CLK_PLL_P_OUT2 181 -#define TEGRA30_CLK_PLL_P_OUT3 182 -#define TEGRA30_CLK_PLL_P_OUT4 183 -#define TEGRA30_CLK_PLL_A 184 -#define TEGRA30_CLK_PLL_A_OUT0 185 -#define TEGRA30_CLK_PLL_D 186 -#define TEGRA30_CLK_PLL_D_OUT0 187 -#define TEGRA30_CLK_PLL_D2 188 -#define TEGRA30_CLK_PLL_D2_OUT0 189 -#define TEGRA30_CLK_PLL_U 190 -#define TEGRA30_CLK_PLL_X 191 - -#define TEGRA30_CLK_PLL_X_OUT0 192 -#define TEGRA30_CLK_PLL_E 193 -#define TEGRA30_CLK_SPDIF_IN_SYNC 194 -#define TEGRA30_CLK_I2S0_SYNC 195 -#define TEGRA30_CLK_I2S1_SYNC 196 -#define TEGRA30_CLK_I2S2_SYNC 197 -#define TEGRA30_CLK_I2S3_SYNC 198 -#define TEGRA30_CLK_I2S4_SYNC 199 -#define TEGRA30_CLK_VIMCLK_SYNC 200 -#define TEGRA30_CLK_AUDIO0 201 -#define TEGRA30_CLK_AUDIO1 202 -#define TEGRA30_CLK_AUDIO2 203 -#define TEGRA30_CLK_AUDIO3 204 -#define TEGRA30_CLK_AUDIO4 205 -#define TEGRA30_CLK_SPDIF 206 -#define TEGRA30_CLK_CLK_OUT_1 207 /* (extern1) */ -#define TEGRA30_CLK_CLK_OUT_2 208 /* (extern2) */ -#define TEGRA30_CLK_CLK_OUT_3 209 /* (extern3) */ -#define TEGRA30_CLK_SCLK 210 -#define TEGRA30_CLK_BLINK 211 -#define TEGRA30_CLK_CCLK_G 212 -#define TEGRA30_CLK_CCLK_LP 213 -#define TEGRA30_CLK_TWD 214 -#define TEGRA30_CLK_CML0 215 -#define TEGRA30_CLK_CML1 216 -#define TEGRA30_CLK_HCLK 217 -#define TEGRA30_CLK_PCLK 218 -/* 219 */ -/* 220 */ -/* 221 */ -/* 222 */ -/* 223 */ - -/* 288 */ -/* 289 */ -/* 290 */ -/* 291 */ -/* 292 */ -/* 293 */ -/* 294 */ -/* 295 */ -/* 296 */ -/* 297 */ -/* 298 */ -/* 299 */ -#define TEGRA30_CLK_CLK_OUT_1_MUX 300 -#define TEGRA30_CLK_CLK_OUT_2_MUX 301 -#define TEGRA30_CLK_CLK_OUT_3_MUX 302 -#define TEGRA30_CLK_AUDIO0_MUX 303 -#define TEGRA30_CLK_AUDIO1_MUX 304 -#define TEGRA30_CLK_AUDIO2_MUX 305 -#define TEGRA30_CLK_AUDIO3_MUX 306 -#define TEGRA30_CLK_AUDIO4_MUX 307 -#define TEGRA30_CLK_SPDIF_MUX 308 -#define TEGRA30_CLK_CLK_MAX 309 - -#endif /* _DT_BINDINGS_CLOCK_TEGRA30_CAR_H */
Drop in favour of dts/upstream.
Small driver adjustment to fix compatibility.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/tegra186.dtsi | 2 +- drivers/mailbox/tegra-hsp.c | 2 +- include/dt-bindings/gpio/tegra-gpio.h | 51 ------ include/dt-bindings/mailbox/tegra186-hsp.h | 19 --- include/dt-bindings/memory/tegra114-mc.h | 25 --- include/dt-bindings/memory/tegra124-mc.h | 31 ---- include/dt-bindings/memory/tegra210-mc.h | 36 ---- include/dt-bindings/memory/tegra30-mc.h | 24 --- include/dt-bindings/pinctrl/pinctrl-tegra-xusb.h | 7 - include/dt-bindings/pinctrl/pinctrl-tegra.h | 37 ---- include/dt-bindings/power/tegra186-powergate.h | 28 ---- include/dt-bindings/reset/tegra124-car.h | 12 -- include/dt-bindings/reset/tegra186-reset.h | 205 ----------------------- include/dt-bindings/thermal/tegra124-soctherm.h | 14 -- 14 files changed, 2 insertions(+), 491 deletions(-)
diff --git a/arch/arm/dts/tegra186.dtsi b/arch/arm/dts/tegra186.dtsi index edcb7aacb8ee..58dadc944888 100644 --- a/arch/arm/dts/tegra186.dtsi +++ b/arch/arm/dts/tegra186.dtsi @@ -313,9 +313,9 @@ };
bpmp: bpmp { compatible = "nvidia,tegra186-bpmp"; - mboxes = <&hsp HSP_MBOX_TYPE_DB HSP_DB_MASTER_BPMP>; + mboxes = <&hsp TEGRA_HSP_MBOX_TYPE_DB TEGRA_HSP_DB_MASTER_BPMP>; /* * In theory, these references, and the configuration in the * node these reference point at, are board-specific, since * they depend on the BCT's memory carve-out setup, the diff --git a/drivers/mailbox/tegra-hsp.c b/drivers/mailbox/tegra-hsp.c index 08c51c40f141..e5a3d8243780 100644 --- a/drivers/mailbox/tegra-hsp.c +++ b/drivers/mailbox/tegra-hsp.c @@ -62,9 +62,9 @@ static void tegra_hsp_writel(struct tegra_hsp *thsp, uint32_t val,
static int tegra_hsp_db_id(ulong chan_id) { switch (chan_id) { - case (HSP_MBOX_TYPE_DB << 16) | HSP_DB_MASTER_BPMP: + case (TEGRA_HSP_MBOX_TYPE_DB << 16) | TEGRA_HSP_DB_MASTER_BPMP: return TEGRA_HSP_DB_ID_BPMP; default: debug("Invalid channel ID\n"); return -EINVAL; diff --git a/include/dt-bindings/gpio/tegra-gpio.h b/include/dt-bindings/gpio/tegra-gpio.h deleted file mode 100644 index a1c09e88e80b..000000000000 --- a/include/dt-bindings/gpio/tegra-gpio.h +++ /dev/null @@ -1,51 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra*-gpio. - * - * The first cell in Tegra's GPIO specifier is the GPIO ID. The macros below - * provide names for this. - * - * The second cell contains standard flag values specified in gpio.h. - */ - -#ifndef _DT_BINDINGS_GPIO_TEGRA_GPIO_H -#define _DT_BINDINGS_GPIO_TEGRA_GPIO_H - -#include <dt-bindings/gpio/gpio.h> - -#define TEGRA_GPIO_PORT_A 0 -#define TEGRA_GPIO_PORT_B 1 -#define TEGRA_GPIO_PORT_C 2 -#define TEGRA_GPIO_PORT_D 3 -#define TEGRA_GPIO_PORT_E 4 -#define TEGRA_GPIO_PORT_F 5 -#define TEGRA_GPIO_PORT_G 6 -#define TEGRA_GPIO_PORT_H 7 -#define TEGRA_GPIO_PORT_I 8 -#define TEGRA_GPIO_PORT_J 9 -#define TEGRA_GPIO_PORT_K 10 -#define TEGRA_GPIO_PORT_L 11 -#define TEGRA_GPIO_PORT_M 12 -#define TEGRA_GPIO_PORT_N 13 -#define TEGRA_GPIO_PORT_O 14 -#define TEGRA_GPIO_PORT_P 15 -#define TEGRA_GPIO_PORT_Q 16 -#define TEGRA_GPIO_PORT_R 17 -#define TEGRA_GPIO_PORT_S 18 -#define TEGRA_GPIO_PORT_T 19 -#define TEGRA_GPIO_PORT_U 20 -#define TEGRA_GPIO_PORT_V 21 -#define TEGRA_GPIO_PORT_W 22 -#define TEGRA_GPIO_PORT_X 23 -#define TEGRA_GPIO_PORT_Y 24 -#define TEGRA_GPIO_PORT_Z 25 -#define TEGRA_GPIO_PORT_AA 26 -#define TEGRA_GPIO_PORT_BB 27 -#define TEGRA_GPIO_PORT_CC 28 -#define TEGRA_GPIO_PORT_DD 29 -#define TEGRA_GPIO_PORT_EE 30 -#define TEGRA_GPIO_PORT_FF 31 - -#define TEGRA_GPIO(port, offset) \ - ((TEGRA_GPIO_PORT_##port * 8) + offset) - -#endif diff --git a/include/dt-bindings/mailbox/tegra186-hsp.h b/include/dt-bindings/mailbox/tegra186-hsp.h deleted file mode 100644 index b4864325d74b..000000000000 --- a/include/dt-bindings/mailbox/tegra186-hsp.h +++ /dev/null @@ -1,19 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra186-hsp. - * - * The number with HSP_DB_MASTER prefix indicates the bit that is - * associated with a master ID in the doorbell registers. - */ - -#ifndef _DT_BINDINGS_MAILBOX_TEGRA186_HSP_H -#define _DT_BINDINGS_MAILBOX_TEGRA186_HSP_H - -#define HSP_MBOX_TYPE_DB 0x0 -#define HSP_MBOX_TYPE_SM 0x1 -#define HSP_MBOX_TYPE_SS 0x2 -#define HSP_MBOX_TYPE_AS 0x3 - -#define HSP_DB_MASTER_CCPLEX 17 -#define HSP_DB_MASTER_BPMP 19 - -#endif diff --git a/include/dt-bindings/memory/tegra114-mc.h b/include/dt-bindings/memory/tegra114-mc.h deleted file mode 100644 index 8f48985a3139..000000000000 --- a/include/dt-bindings/memory/tegra114-mc.h +++ /dev/null @@ -1,25 +0,0 @@ -#ifndef DT_BINDINGS_MEMORY_TEGRA114_MC_H -#define DT_BINDINGS_MEMORY_TEGRA114_MC_H - -#define TEGRA_SWGROUP_PTC 0 -#define TEGRA_SWGROUP_DC 1 -#define TEGRA_SWGROUP_DCB 2 -#define TEGRA_SWGROUP_EPP 3 -#define TEGRA_SWGROUP_G2 4 -#define TEGRA_SWGROUP_AVPC 5 -#define TEGRA_SWGROUP_NV 6 -#define TEGRA_SWGROUP_HDA 7 -#define TEGRA_SWGROUP_HC 8 -#define TEGRA_SWGROUP_MSENC 9 -#define TEGRA_SWGROUP_PPCS 10 -#define TEGRA_SWGROUP_VDE 11 -#define TEGRA_SWGROUP_MPCORELP 12 -#define TEGRA_SWGROUP_MPCORE 13 -#define TEGRA_SWGROUP_VI 14 -#define TEGRA_SWGROUP_ISP 15 -#define TEGRA_SWGROUP_XUSB_HOST 16 -#define TEGRA_SWGROUP_XUSB_DEV 17 -#define TEGRA_SWGROUP_EMUCIF 18 -#define TEGRA_SWGROUP_TSEC 19 - -#endif diff --git a/include/dt-bindings/memory/tegra124-mc.h b/include/dt-bindings/memory/tegra124-mc.h deleted file mode 100644 index 7d8ee798f34e..000000000000 --- a/include/dt-bindings/memory/tegra124-mc.h +++ /dev/null @@ -1,31 +0,0 @@ -#ifndef DT_BINDINGS_MEMORY_TEGRA124_MC_H -#define DT_BINDINGS_MEMORY_TEGRA124_MC_H - -#define TEGRA_SWGROUP_PTC 0 -#define TEGRA_SWGROUP_DC 1 -#define TEGRA_SWGROUP_DCB 2 -#define TEGRA_SWGROUP_AFI 3 -#define TEGRA_SWGROUP_AVPC 4 -#define TEGRA_SWGROUP_HDA 5 -#define TEGRA_SWGROUP_HC 6 -#define TEGRA_SWGROUP_MSENC 7 -#define TEGRA_SWGROUP_PPCS 8 -#define TEGRA_SWGROUP_SATA 9 -#define TEGRA_SWGROUP_VDE 10 -#define TEGRA_SWGROUP_MPCORELP 11 -#define TEGRA_SWGROUP_MPCORE 12 -#define TEGRA_SWGROUP_ISP2 13 -#define TEGRA_SWGROUP_XUSB_HOST 14 -#define TEGRA_SWGROUP_XUSB_DEV 15 -#define TEGRA_SWGROUP_ISP2B 16 -#define TEGRA_SWGROUP_TSEC 17 -#define TEGRA_SWGROUP_A9AVP 18 -#define TEGRA_SWGROUP_GPU 19 -#define TEGRA_SWGROUP_SDMMC1A 20 -#define TEGRA_SWGROUP_SDMMC2A 21 -#define TEGRA_SWGROUP_SDMMC3A 22 -#define TEGRA_SWGROUP_SDMMC4A 23 -#define TEGRA_SWGROUP_VIC 24 -#define TEGRA_SWGROUP_VI 25 - -#endif diff --git a/include/dt-bindings/memory/tegra210-mc.h b/include/dt-bindings/memory/tegra210-mc.h deleted file mode 100644 index d1731bc14dbc..000000000000 --- a/include/dt-bindings/memory/tegra210-mc.h +++ /dev/null @@ -1,36 +0,0 @@ -#ifndef DT_BINDINGS_MEMORY_TEGRA210_MC_H -#define DT_BINDINGS_MEMORY_TEGRA210_MC_H - -#define TEGRA_SWGROUP_PTC 0 -#define TEGRA_SWGROUP_DC 1 -#define TEGRA_SWGROUP_DCB 2 -#define TEGRA_SWGROUP_AFI 3 -#define TEGRA_SWGROUP_AVPC 4 -#define TEGRA_SWGROUP_HDA 5 -#define TEGRA_SWGROUP_HC 6 -#define TEGRA_SWGROUP_NVENC 7 -#define TEGRA_SWGROUP_PPCS 8 -#define TEGRA_SWGROUP_SATA 9 -#define TEGRA_SWGROUP_MPCORE 10 -#define TEGRA_SWGROUP_ISP2 11 -#define TEGRA_SWGROUP_XUSB_HOST 12 -#define TEGRA_SWGROUP_XUSB_DEV 13 -#define TEGRA_SWGROUP_ISP2B 14 -#define TEGRA_SWGROUP_TSEC 15 -#define TEGRA_SWGROUP_A9AVP 16 -#define TEGRA_SWGROUP_GPU 17 -#define TEGRA_SWGROUP_SDMMC1A 18 -#define TEGRA_SWGROUP_SDMMC2A 19 -#define TEGRA_SWGROUP_SDMMC3A 20 -#define TEGRA_SWGROUP_SDMMC4A 21 -#define TEGRA_SWGROUP_VIC 22 -#define TEGRA_SWGROUP_VI 23 -#define TEGRA_SWGROUP_NVDEC 24 -#define TEGRA_SWGROUP_APE 25 -#define TEGRA_SWGROUP_NVJPG 26 -#define TEGRA_SWGROUP_SE 27 -#define TEGRA_SWGROUP_AXIAP 28 -#define TEGRA_SWGROUP_ETR 29 -#define TEGRA_SWGROUP_TSECB 30 - -#endif diff --git a/include/dt-bindings/memory/tegra30-mc.h b/include/dt-bindings/memory/tegra30-mc.h deleted file mode 100644 index 502beb03d777..000000000000 --- a/include/dt-bindings/memory/tegra30-mc.h +++ /dev/null @@ -1,24 +0,0 @@ -#ifndef DT_BINDINGS_MEMORY_TEGRA30_MC_H -#define DT_BINDINGS_MEMORY_TEGRA30_MC_H - -#define TEGRA_SWGROUP_PTC 0 -#define TEGRA_SWGROUP_DC 1 -#define TEGRA_SWGROUP_DCB 2 -#define TEGRA_SWGROUP_EPP 3 -#define TEGRA_SWGROUP_G2 4 -#define TEGRA_SWGROUP_MPE 5 -#define TEGRA_SWGROUP_VI 6 -#define TEGRA_SWGROUP_AFI 7 -#define TEGRA_SWGROUP_AVPC 8 -#define TEGRA_SWGROUP_NV 9 -#define TEGRA_SWGROUP_NV2 10 -#define TEGRA_SWGROUP_HDA 11 -#define TEGRA_SWGROUP_HC 12 -#define TEGRA_SWGROUP_PPCS 13 -#define TEGRA_SWGROUP_SATA 14 -#define TEGRA_SWGROUP_VDE 15 -#define TEGRA_SWGROUP_MPCORELP 16 -#define TEGRA_SWGROUP_MPCORE 17 -#define TEGRA_SWGROUP_ISP 18 - -#endif diff --git a/include/dt-bindings/pinctrl/pinctrl-tegra-xusb.h b/include/dt-bindings/pinctrl/pinctrl-tegra-xusb.h deleted file mode 100644 index 914d56da9324..000000000000 --- a/include/dt-bindings/pinctrl/pinctrl-tegra-xusb.h +++ /dev/null @@ -1,7 +0,0 @@ -#ifndef _DT_BINDINGS_PINCTRL_TEGRA_XUSB_H -#define _DT_BINDINGS_PINCTRL_TEGRA_XUSB_H 1 - -#define TEGRA_XUSB_PADCTL_PCIE 0 -#define TEGRA_XUSB_PADCTL_SATA 1 - -#endif /* _DT_BINDINGS_PINCTRL_TEGRA_XUSB_H */ diff --git a/include/dt-bindings/pinctrl/pinctrl-tegra.h b/include/dt-bindings/pinctrl/pinctrl-tegra.h deleted file mode 100644 index c9b57408de68..000000000000 --- a/include/dt-bindings/pinctrl/pinctrl-tegra.h +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for Tegra pinctrl bindings. - * - * Copyright (c) 2013, NVIDIA CORPORATION. All rights reserved. - * - * Author: Laxman Dewangan ldewangan@nvidia.com - */ - -#ifndef _DT_BINDINGS_PINCTRL_TEGRA_H -#define _DT_BINDINGS_PINCTRL_TEGRA_H - -/* - * Enable/disable for diffeent dt properties. This is applicable for - * properties nvidia,enable-input, nvidia,tristate, nvidia,open-drain, - * nvidia,lock, nvidia,rcv-sel, nvidia,high-speed-mode, nvidia,schmitt. - */ -#define TEGRA_PIN_DISABLE 0 -#define TEGRA_PIN_ENABLE 1 - -#define TEGRA_PIN_PULL_NONE 0 -#define TEGRA_PIN_PULL_DOWN 1 -#define TEGRA_PIN_PULL_UP 2 - -/* Low power mode driver */ -#define TEGRA_PIN_LP_DRIVE_DIV_8 0 -#define TEGRA_PIN_LP_DRIVE_DIV_4 1 -#define TEGRA_PIN_LP_DRIVE_DIV_2 2 -#define TEGRA_PIN_LP_DRIVE_DIV_1 3 - -/* Rising/Falling slew rate */ -#define TEGRA_PIN_SLEW_RATE_FASTEST 0 -#define TEGRA_PIN_SLEW_RATE_FAST 1 -#define TEGRA_PIN_SLEW_RATE_SLOW 2 -#define TEGRA_PIN_SLEW_RATE_SLOWEST 3 - -#endif diff --git a/include/dt-bindings/power/tegra186-powergate.h b/include/dt-bindings/power/tegra186-powergate.h deleted file mode 100644 index 17e75498563c..000000000000 --- a/include/dt-bindings/power/tegra186-powergate.h +++ /dev/null @@ -1,28 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2015-2016, NVIDIA CORPORATION. - */ - -#ifndef _DT_BINDINGS_POWER_TEGRA186_POWERGATE_H -#define _DT_BINDINGS_POWER_TEGRA186_POWERGATE_H - -#define TEGRA186_POWER_DOMAIN_AUD 0 -#define TEGRA186_POWER_DOMAIN_DFD 1 -#define TEGRA186_POWER_DOMAIN_DISP 2 -#define TEGRA186_POWER_DOMAIN_DISPB 3 -#define TEGRA186_POWER_DOMAIN_DISPC 4 -#define TEGRA186_POWER_DOMAIN_ISPA 5 -#define TEGRA186_POWER_DOMAIN_NVDEC 6 -#define TEGRA186_POWER_DOMAIN_NVJPG 7 -#define TEGRA186_POWER_DOMAIN_MPE 8 -#define TEGRA186_POWER_DOMAIN_PCX 9 -#define TEGRA186_POWER_DOMAIN_SAX 10 -#define TEGRA186_POWER_DOMAIN_VE 11 -#define TEGRA186_POWER_DOMAIN_VIC 12 -#define TEGRA186_POWER_DOMAIN_XUSBA 13 -#define TEGRA186_POWER_DOMAIN_XUSBB 14 -#define TEGRA186_POWER_DOMAIN_XUSBC 15 -#define TEGRA186_POWER_DOMAIN_GPU 43 -#define TEGRA186_POWER_DOMAIN_MAX 44 - -#endif diff --git a/include/dt-bindings/reset/tegra124-car.h b/include/dt-bindings/reset/tegra124-car.h deleted file mode 100644 index 070e4f6e7486..000000000000 --- a/include/dt-bindings/reset/tegra124-car.h +++ /dev/null @@ -1,12 +0,0 @@ -/* - * This header provides Tegra124-specific constants for binding - * nvidia,tegra124-car. - */ - -#ifndef _DT_BINDINGS_RESET_TEGRA124_CAR_H -#define _DT_BINDINGS_RESET_TEGRA124_CAR_H - -#define TEGRA124_RESET(x) (6 * 32 + (x)) -#define TEGRA124_RST_DFLL_DVCO TEGRA124_RESET(0) - -#endif /* _DT_BINDINGS_RESET_TEGRA124_CAR_H */ diff --git a/include/dt-bindings/reset/tegra186-reset.h b/include/dt-bindings/reset/tegra186-reset.h deleted file mode 100644 index 7efec9200532..000000000000 --- a/include/dt-bindings/reset/tegra186-reset.h +++ /dev/null @@ -1,205 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2015, NVIDIA CORPORATION. - */ - -#ifndef _ABI_MACH_T186_RESET_T186_H_ -#define _ABI_MACH_T186_RESET_T186_H_ - -#define TEGRA186_RESET_ACTMON 0 -#define TEGRA186_RESET_AFI 1 -#define TEGRA186_RESET_CEC 2 -#define TEGRA186_RESET_CSITE 3 -#define TEGRA186_RESET_DP2 4 -#define TEGRA186_RESET_DPAUX 5 -#define TEGRA186_RESET_DSI 6 -#define TEGRA186_RESET_DSIB 7 -#define TEGRA186_RESET_DTV 8 -#define TEGRA186_RESET_DVFS 9 -#define TEGRA186_RESET_ENTROPY 10 -#define TEGRA186_RESET_EXTPERIPH1 11 -#define TEGRA186_RESET_EXTPERIPH2 12 -#define TEGRA186_RESET_EXTPERIPH3 13 -#define TEGRA186_RESET_GPU 14 -#define TEGRA186_RESET_HDA 15 -#define TEGRA186_RESET_HDA2CODEC_2X 16 -#define TEGRA186_RESET_HDA2HDMICODEC 17 -#define TEGRA186_RESET_HOST1X 18 -#define TEGRA186_RESET_I2C1 19 -#define TEGRA186_RESET_I2C2 20 -#define TEGRA186_RESET_I2C3 21 -#define TEGRA186_RESET_I2C4 22 -#define TEGRA186_RESET_I2C5 23 -#define TEGRA186_RESET_I2C6 24 -#define TEGRA186_RESET_ISP 25 -#define TEGRA186_RESET_KFUSE 26 -#define TEGRA186_RESET_LA 27 -#define TEGRA186_RESET_MIPI_CAL 28 -#define TEGRA186_RESET_PCIE 29 -#define TEGRA186_RESET_PCIEXCLK 30 -#define TEGRA186_RESET_SATA 31 -#define TEGRA186_RESET_SATACOLD 32 -#define TEGRA186_RESET_SDMMC1 33 -#define TEGRA186_RESET_SDMMC2 34 -#define TEGRA186_RESET_SDMMC3 35 -#define TEGRA186_RESET_SDMMC4 36 -#define TEGRA186_RESET_SE 37 -#define TEGRA186_RESET_SOC_THERM 38 -#define TEGRA186_RESET_SOR0 39 -#define TEGRA186_RESET_SPI1 40 -#define TEGRA186_RESET_SPI2 41 -#define TEGRA186_RESET_SPI3 42 -#define TEGRA186_RESET_SPI4 43 -#define TEGRA186_RESET_TMR 44 -#define TEGRA186_RESET_TRIG_SYS 45 -#define TEGRA186_RESET_TSEC 46 -#define TEGRA186_RESET_UARTA 47 -#define TEGRA186_RESET_UARTB 48 -#define TEGRA186_RESET_UARTC 49 -#define TEGRA186_RESET_UARTD 50 -#define TEGRA186_RESET_VI 51 -#define TEGRA186_RESET_VIC 52 -#define TEGRA186_RESET_XUSB_DEV 53 -#define TEGRA186_RESET_XUSB_HOST 54 -#define TEGRA186_RESET_XUSB_PADCTL 55 -#define TEGRA186_RESET_XUSB_SS 56 -#define TEGRA186_RESET_AON_APB 57 -#define TEGRA186_RESET_AXI_CBB 58 -#define TEGRA186_RESET_BPMP_APB 59 -#define TEGRA186_RESET_CAN1 60 -#define TEGRA186_RESET_CAN2 61 -#define TEGRA186_RESET_DMIC5 62 -#define TEGRA186_RESET_DSIC 63 -#define TEGRA186_RESET_DSID 64 -#define TEGRA186_RESET_EMC_EMC 65 -#define TEGRA186_RESET_EMC_MEM 66 -#define TEGRA186_RESET_EMCSB_EMC 67 -#define TEGRA186_RESET_EMCSB_MEM 68 -#define TEGRA186_RESET_EQOS 69 -#define TEGRA186_RESET_GPCDMA 70 -#define TEGRA186_RESET_GPIO_CTL0 71 -#define TEGRA186_RESET_GPIO_CTL1 72 -#define TEGRA186_RESET_GPIO_CTL2 73 -#define TEGRA186_RESET_GPIO_CTL3 74 -#define TEGRA186_RESET_GPIO_CTL4 75 -#define TEGRA186_RESET_GPIO_CTL5 76 -#define TEGRA186_RESET_I2C10 77 -#define TEGRA186_RESET_I2C12 78 -#define TEGRA186_RESET_I2C13 79 -#define TEGRA186_RESET_I2C14 80 -#define TEGRA186_RESET_I2C7 81 -#define TEGRA186_RESET_I2C8 82 -#define TEGRA186_RESET_I2C9 83 -#define TEGRA186_RESET_JTAG2AXI 84 -#define TEGRA186_RESET_MPHY_IOBIST 85 -#define TEGRA186_RESET_MPHY_L0_RX 86 -#define TEGRA186_RESET_MPHY_L0_TX 87 -#define TEGRA186_RESET_NVCSI 88 -#define TEGRA186_RESET_NVDISPLAY0_HEAD0 89 -#define TEGRA186_RESET_NVDISPLAY0_HEAD1 90 -#define TEGRA186_RESET_NVDISPLAY0_HEAD2 91 -#define TEGRA186_RESET_NVDISPLAY0_MISC 92 -#define TEGRA186_RESET_NVDISPLAY0_WGRP0 93 -#define TEGRA186_RESET_NVDISPLAY0_WGRP1 94 -#define TEGRA186_RESET_NVDISPLAY0_WGRP2 95 -#define TEGRA186_RESET_NVDISPLAY0_WGRP3 96 -#define TEGRA186_RESET_NVDISPLAY0_WGRP4 97 -#define TEGRA186_RESET_NVDISPLAY0_WGRP5 98 -#define TEGRA186_RESET_PWM1 99 -#define TEGRA186_RESET_PWM2 100 -#define TEGRA186_RESET_PWM3 101 -#define TEGRA186_RESET_PWM4 102 -#define TEGRA186_RESET_PWM5 103 -#define TEGRA186_RESET_PWM6 104 -#define TEGRA186_RESET_PWM7 105 -#define TEGRA186_RESET_PWM8 106 -#define TEGRA186_RESET_SCE_APB 107 -#define TEGRA186_RESET_SOR1 108 -#define TEGRA186_RESET_TACH 109 -#define TEGRA186_RESET_TSC 110 -#define TEGRA186_RESET_UARTF 111 -#define TEGRA186_RESET_UARTG 112 -#define TEGRA186_RESET_UFSHC 113 -#define TEGRA186_RESET_UFSHC_AXI_M 114 -#define TEGRA186_RESET_UPHY 115 -#define TEGRA186_RESET_ADSP 116 -#define TEGRA186_RESET_ADSPDBG 117 -#define TEGRA186_RESET_ADSPINTF 118 -#define TEGRA186_RESET_ADSPNEON 119 -#define TEGRA186_RESET_ADSPPERIPH 120 -#define TEGRA186_RESET_ADSPSCU 121 -#define TEGRA186_RESET_ADSPWDT 122 -#define TEGRA186_RESET_APE 123 -#define TEGRA186_RESET_DPAUX1 124 -#define TEGRA186_RESET_NVDEC 125 -#define TEGRA186_RESET_NVENC 126 -#define TEGRA186_RESET_NVJPG 127 -#define TEGRA186_RESET_PEX_USB_UPHY 128 -#define TEGRA186_RESET_QSPI 129 -#define TEGRA186_RESET_TSECB 130 -#define TEGRA186_RESET_VI_I2C 131 -#define TEGRA186_RESET_UARTE 132 -#define TEGRA186_RESET_TOP_GTE 133 -#define TEGRA186_RESET_SHSP 134 -#define TEGRA186_RESET_PEX_USB_UPHY_L5 135 -#define TEGRA186_RESET_PEX_USB_UPHY_L4 136 -#define TEGRA186_RESET_PEX_USB_UPHY_L3 137 -#define TEGRA186_RESET_PEX_USB_UPHY_L2 138 -#define TEGRA186_RESET_PEX_USB_UPHY_L1 139 -#define TEGRA186_RESET_PEX_USB_UPHY_L0 140 -#define TEGRA186_RESET_PEX_USB_UPHY_PLL1 141 -#define TEGRA186_RESET_PEX_USB_UPHY_PLL0 142 -#define TEGRA186_RESET_TSCTNVI 143 -#define TEGRA186_RESET_EXTPERIPH4 144 -#define TEGRA186_RESET_DSIPADCTL 145 -#define TEGRA186_RESET_AUD_MCLK 146 -#define TEGRA186_RESET_MPHY_CLK_CTL 147 -#define TEGRA186_RESET_MPHY_L1_RX 148 -#define TEGRA186_RESET_MPHY_L1_TX 149 -#define TEGRA186_RESET_UFSHC_LP 150 -#define TEGRA186_RESET_BPMP_NIC 151 -#define TEGRA186_RESET_BPMP_NSYSPORESET 152 -#define TEGRA186_RESET_BPMP_NRESET 153 -#define TEGRA186_RESET_BPMP_DBGRESETN 154 -#define TEGRA186_RESET_BPMP_PRESETDBGN 155 -#define TEGRA186_RESET_BPMP_PM 156 -#define TEGRA186_RESET_BPMP_CVC 157 -#define TEGRA186_RESET_BPMP_DMA 158 -#define TEGRA186_RESET_BPMP_HSP 159 -#define TEGRA186_RESET_TSCTNBPMP 160 -#define TEGRA186_RESET_BPMP_TKE 161 -#define TEGRA186_RESET_BPMP_GTE 162 -#define TEGRA186_RESET_BPMP_PM_ACTMON 163 -#define TEGRA186_RESET_AON_NIC 164 -#define TEGRA186_RESET_AON_NSYSPORESET 165 -#define TEGRA186_RESET_AON_NRESET 166 -#define TEGRA186_RESET_AON_DBGRESETN 167 -#define TEGRA186_RESET_AON_PRESETDBGN 168 -#define TEGRA186_RESET_AON_ACTMON 169 -#define TEGRA186_RESET_AOPM 170 -#define TEGRA186_RESET_AOVC 171 -#define TEGRA186_RESET_AON_DMA 172 -#define TEGRA186_RESET_AON_GPIO 173 -#define TEGRA186_RESET_AON_HSP 174 -#define TEGRA186_RESET_TSCTNAON 175 -#define TEGRA186_RESET_AON_TKE 176 -#define TEGRA186_RESET_AON_GTE 177 -#define TEGRA186_RESET_SCE_NIC 178 -#define TEGRA186_RESET_SCE_NSYSPORESET 179 -#define TEGRA186_RESET_SCE_NRESET 180 -#define TEGRA186_RESET_SCE_DBGRESETN 181 -#define TEGRA186_RESET_SCE_PRESETDBGN 182 -#define TEGRA186_RESET_SCE_ACTMON 183 -#define TEGRA186_RESET_SCE_PM 184 -#define TEGRA186_RESET_SCE_DMA 185 -#define TEGRA186_RESET_SCE_HSP 186 -#define TEGRA186_RESET_TSCTNSCE 187 -#define TEGRA186_RESET_SCE_TKE 188 -#define TEGRA186_RESET_SCE_GTE 189 -#define TEGRA186_RESET_SCE_CFG 190 -#define TEGRA186_RESET_ADSP_ALL 191 -/** @brief controls the power up/down sequence of UFSHC PSW partition. Controls LP_PWR_READY, LP_ISOL_EN, and LP_RESET_N signals */ -#define TEGRA186_RESET_UFSHC_LP_SEQ 192 -#define TEGRA186_RESET_SIZE 193 - -#endif diff --git a/include/dt-bindings/thermal/tegra124-soctherm.h b/include/dt-bindings/thermal/tegra124-soctherm.h deleted file mode 100644 index 729ab9fc325e..000000000000 --- a/include/dt-bindings/thermal/tegra124-soctherm.h +++ /dev/null @@ -1,14 +0,0 @@ -/* - * This header provides constants for binding nvidia,tegra124-soctherm. - */ - -#ifndef _DT_BINDINGS_THERMAL_TEGRA124_SOCTHERM_H -#define _DT_BINDINGS_THERMAL_TEGRA124_SOCTHERM_H - -#define TEGRA124_SOCTHERM_SENSOR_CPU 0 -#define TEGRA124_SOCTHERM_SENSOR_MEM 1 -#define TEGRA124_SOCTHERM_SENSOR_GPU 2 -#define TEGRA124_SOCTHERM_SENSOR_PLLX 3 -#define TEGRA124_SOCTHERM_SENSOR_NUM 4 - -#endif
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/xlnx-versal-clk.h | 123 ----------------------- include/dt-bindings/clock/xlnx-zynqmp-clk.h | 126 ------------------------ include/dt-bindings/dma/xlnx-zynqmp-dpdma.h | 16 --- include/dt-bindings/pinctrl/pinctrl-zynqmp.h | 19 ---- include/dt-bindings/power/xlnx-zynqmp-power.h | 50 ---------- include/dt-bindings/reset/xlnx-versal-resets.h | 105 -------------------- include/dt-bindings/reset/xlnx-zynqmp-resets.h | 130 ------------------------- 7 files changed, 569 deletions(-)
diff --git a/include/dt-bindings/clock/xlnx-versal-clk.h b/include/dt-bindings/clock/xlnx-versal-clk.h deleted file mode 100644 index 264d634d226e..000000000000 --- a/include/dt-bindings/clock/xlnx-versal-clk.h +++ /dev/null @@ -1,123 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2019 Xilinx Inc. - * - */ - -#ifndef _DT_BINDINGS_CLK_VERSAL_H -#define _DT_BINDINGS_CLK_VERSAL_H - -#define PMC_PLL 1 -#define APU_PLL 2 -#define RPU_PLL 3 -#define CPM_PLL 4 -#define NOC_PLL 5 -#define PLL_MAX 6 -#define PMC_PRESRC 7 -#define PMC_POSTCLK 8 -#define PMC_PLL_OUT 9 -#define PPLL 10 -#define NOC_PRESRC 11 -#define NOC_POSTCLK 12 -#define NOC_PLL_OUT 13 -#define NPLL 14 -#define APU_PRESRC 15 -#define APU_POSTCLK 16 -#define APU_PLL_OUT 17 -#define APLL 18 -#define RPU_PRESRC 19 -#define RPU_POSTCLK 20 -#define RPU_PLL_OUT 21 -#define RPLL 22 -#define CPM_PRESRC 23 -#define CPM_POSTCLK 24 -#define CPM_PLL_OUT 25 -#define CPLL 26 -#define PPLL_TO_XPD 27 -#define NPLL_TO_XPD 28 -#define APLL_TO_XPD 29 -#define RPLL_TO_XPD 30 -#define EFUSE_REF 31 -#define SYSMON_REF 32 -#define IRO_SUSPEND_REF 33 -#define USB_SUSPEND 34 -#define SWITCH_TIMEOUT 35 -#define RCLK_PMC 36 -#define RCLK_LPD 37 -#define WDT 38 -#define TTC0 39 -#define TTC1 40 -#define TTC2 41 -#define TTC3 42 -#define GEM_TSU 43 -#define GEM_TSU_LB 44 -#define MUXED_IRO_DIV2 45 -#define MUXED_IRO_DIV4 46 -#define PSM_REF 47 -#define GEM0_RX 48 -#define GEM0_TX 49 -#define GEM1_RX 50 -#define GEM1_TX 51 -#define CPM_CORE_REF 52 -#define CPM_LSBUS_REF 53 -#define CPM_DBG_REF 54 -#define CPM_AUX0_REF 55 -#define CPM_AUX1_REF 56 -#define QSPI_REF 57 -#define OSPI_REF 58 -#define SDIO0_REF 59 -#define SDIO1_REF 60 -#define PMC_LSBUS_REF 61 -#define I2C_REF 62 -#define TEST_PATTERN_REF 63 -#define DFT_OSC_REF 64 -#define PMC_PL0_REF 65 -#define PMC_PL1_REF 66 -#define PMC_PL2_REF 67 -#define PMC_PL3_REF 68 -#define CFU_REF 69 -#define SPARE_REF 70 -#define NPI_REF 71 -#define HSM0_REF 72 -#define HSM1_REF 73 -#define SD_DLL_REF 74 -#define FPD_TOP_SWITCH 75 -#define FPD_LSBUS 76 -#define ACPU 77 -#define DBG_TRACE 78 -#define DBG_FPD 79 -#define LPD_TOP_SWITCH 80 -#define ADMA 81 -#define LPD_LSBUS 82 -#define CPU_R5 83 -#define CPU_R5_CORE 84 -#define CPU_R5_OCM 85 -#define CPU_R5_OCM2 86 -#define IOU_SWITCH 87 -#define GEM0_REF 88 -#define GEM1_REF 89 -#define GEM_TSU_REF 90 -#define USB0_BUS_REF 91 -#define UART0_REF 92 -#define UART1_REF 93 -#define SPI0_REF 94 -#define SPI1_REF 95 -#define CAN0_REF 96 -#define CAN1_REF 97 -#define I2C0_REF 98 -#define I2C1_REF 99 -#define DBG_LPD 100 -#define TIMESTAMP_REF 101 -#define DBG_TSTMP 102 -#define CPM_TOPSW_REF 103 -#define USB3_DUAL_REF 104 -#define OUTCLK_MAX 105 -#define REF_CLK 106 -#define PL_ALT_REF_CLK 107 -#define MUXED_IRO 108 -#define PL_EXT 109 -#define PL_LB 110 -#define MIO_50_OR_51 111 -#define MIO_24_OR_25 112 - -#endif diff --git a/include/dt-bindings/clock/xlnx-zynqmp-clk.h b/include/dt-bindings/clock/xlnx-zynqmp-clk.h deleted file mode 100644 index cdc4c0b9a374..000000000000 --- a/include/dt-bindings/clock/xlnx-zynqmp-clk.h +++ /dev/null @@ -1,126 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Xilinx Zynq MPSoC Firmware layer - * - * Copyright (C) 2014-2018 Xilinx, Inc. - * - */ - -#ifndef _DT_BINDINGS_CLK_ZYNQMP_H -#define _DT_BINDINGS_CLK_ZYNQMP_H - -#define IOPLL 0 -#define RPLL 1 -#define APLL 2 -#define DPLL 3 -#define VPLL 4 -#define IOPLL_TO_FPD 5 -#define RPLL_TO_FPD 6 -#define APLL_TO_LPD 7 -#define DPLL_TO_LPD 8 -#define VPLL_TO_LPD 9 -#define ACPU 10 -#define ACPU_HALF 11 -#define DBF_FPD 12 -#define DBF_LPD 13 -#define DBG_TRACE 14 -#define DBG_TSTMP 15 -#define DP_VIDEO_REF 16 -#define DP_AUDIO_REF 17 -#define DP_STC_REF 18 -#define GDMA_REF 19 -#define DPDMA_REF 20 -#define DDR_REF 21 -#define SATA_REF 22 -#define PCIE_REF 23 -#define GPU_REF 24 -#define GPU_PP0_REF 25 -#define GPU_PP1_REF 26 -#define TOPSW_MAIN 27 -#define TOPSW_LSBUS 28 -#define GTGREF0_REF 29 -#define LPD_SWITCH 30 -#define LPD_LSBUS 31 -#define USB0_BUS_REF 32 -#define USB1_BUS_REF 33 -#define USB3_DUAL_REF 34 -#define USB0 35 -#define USB1 36 -#define CPU_R5 37 -#define CPU_R5_CORE 38 -#define CSU_SPB 39 -#define CSU_PLL 40 -#define PCAP 41 -#define IOU_SWITCH 42 -#define GEM_TSU_REF 43 -#define GEM_TSU 44 -#define GEM0_TX 45 -#define GEM1_TX 46 -#define GEM2_TX 47 -#define GEM3_TX 48 -#define GEM0_RX 49 -#define GEM1_RX 50 -#define GEM2_RX 51 -#define GEM3_RX 52 -#define QSPI_REF 53 -#define SDIO0_REF 54 -#define SDIO1_REF 55 -#define UART0_REF 56 -#define UART1_REF 57 -#define SPI0_REF 58 -#define SPI1_REF 59 -#define NAND_REF 60 -#define I2C0_REF 61 -#define I2C1_REF 62 -#define CAN0_REF 63 -#define CAN1_REF 64 -#define CAN0 65 -#define CAN1 66 -#define DLL_REF 67 -#define ADMA_REF 68 -#define TIMESTAMP_REF 69 -#define AMS_REF 70 -#define PL0_REF 71 -#define PL1_REF 72 -#define PL2_REF 73 -#define PL3_REF 74 -#define WDT 75 -#define IOPLL_INT 76 -#define IOPLL_PRE_SRC 77 -#define IOPLL_HALF 78 -#define IOPLL_INT_MUX 79 -#define IOPLL_POST_SRC 80 -#define RPLL_INT 81 -#define RPLL_PRE_SRC 82 -#define RPLL_HALF 83 -#define RPLL_INT_MUX 84 -#define RPLL_POST_SRC 85 -#define APLL_INT 86 -#define APLL_PRE_SRC 87 -#define APLL_HALF 88 -#define APLL_INT_MUX 89 -#define APLL_POST_SRC 90 -#define DPLL_INT 91 -#define DPLL_PRE_SRC 92 -#define DPLL_HALF 93 -#define DPLL_INT_MUX 94 -#define DPLL_POST_SRC 95 -#define VPLL_INT 96 -#define VPLL_PRE_SRC 97 -#define VPLL_HALF 98 -#define VPLL_INT_MUX 99 -#define VPLL_POST_SRC 100 -#define CAN0_MIO 101 -#define CAN1_MIO 102 -#define ACPU_FULL 103 -#define GEM0_REF 104 -#define GEM1_REF 105 -#define GEM2_REF 106 -#define GEM3_REF 107 -#define GEM0_REF_UNG 108 -#define GEM1_REF_UNG 109 -#define GEM2_REF_UNG 110 -#define GEM3_REF_UNG 111 -#define LPD_WDT 112 - -#endif diff --git a/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h b/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h deleted file mode 100644 index 3719cda5679d..000000000000 --- a/include/dt-bindings/dma/xlnx-zynqmp-dpdma.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright 2019 Laurent Pinchart laurent.pinchart@ideasonboard.com - */ - -#ifndef __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ -#define __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ - -#define ZYNQMP_DPDMA_VIDEO0 0 -#define ZYNQMP_DPDMA_VIDEO1 1 -#define ZYNQMP_DPDMA_VIDEO2 2 -#define ZYNQMP_DPDMA_GRAPHICS 3 -#define ZYNQMP_DPDMA_AUDIO0 4 -#define ZYNQMP_DPDMA_AUDIO1 5 - -#endif /* __DT_BINDINGS_DMA_XLNX_ZYNQMP_DPDMA_H__ */ diff --git a/include/dt-bindings/pinctrl/pinctrl-zynqmp.h b/include/dt-bindings/pinctrl/pinctrl-zynqmp.h deleted file mode 100644 index cdb215734bdf..000000000000 --- a/include/dt-bindings/pinctrl/pinctrl-zynqmp.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * MIO pin configuration defines for Xilinx ZynqMP - * - * Copyright (C) 2020 Xilinx, Inc. - */ - -#ifndef _DT_BINDINGS_PINCTRL_ZYNQMP_H -#define _DT_BINDINGS_PINCTRL_ZYNQMP_H - -/* Bit value for different voltage levels */ -#define IO_STANDARD_LVCMOS33 0 -#define IO_STANDARD_LVCMOS18 1 - -/* Bit values for Slew Rates */ -#define SLEW_RATE_FAST 0 -#define SLEW_RATE_SLOW 1 - -#endif /* _DT_BINDINGS_PINCTRL_ZYNQMP_H */ diff --git a/include/dt-bindings/power/xlnx-zynqmp-power.h b/include/dt-bindings/power/xlnx-zynqmp-power.h deleted file mode 100644 index e7eb0960480a..000000000000 --- a/include/dt-bindings/power/xlnx-zynqmp-power.h +++ /dev/null @@ -1,50 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 Xilinx, Inc. - */ - -#ifndef _DT_BINDINGS_ZYNQMP_POWER_H -#define _DT_BINDINGS_ZYNQMP_POWER_H - -#define PD_RPU_0 6 -#define PD_RPU_1 7 -#define PD_OCM_BANK_0 11 -#define PD_OCM_BANK_1 12 -#define PD_OCM_BANK_2 13 -#define PD_OCM_BANK_3 14 -#define PD_TCM_BANK_0 15 -#define PD_TCM_BANK_1 16 -#define PD_TCM_BANK_2 17 -#define PD_TCM_BANK_3 18 -#define PD_USB_0 22 -#define PD_USB_1 23 -#define PD_TTC_0 24 -#define PD_TTC_1 25 -#define PD_TTC_2 26 -#define PD_TTC_3 27 -#define PD_SATA 28 -#define PD_ETH_0 29 -#define PD_ETH_1 30 -#define PD_ETH_2 31 -#define PD_ETH_3 32 -#define PD_UART_0 33 -#define PD_UART_1 34 -#define PD_SPI_0 35 -#define PD_SPI_1 36 -#define PD_I2C_0 37 -#define PD_I2C_1 38 -#define PD_SD_0 39 -#define PD_SD_1 40 -#define PD_DP 41 -#define PD_GDMA 42 -#define PD_ADMA 43 -#define PD_NAND 44 -#define PD_QSPI 45 -#define PD_GPIO 46 -#define PD_CAN_0 47 -#define PD_CAN_1 48 -#define PD_GPU 58 -#define PD_PCIE 59 -#define PD_PL 69 - -#endif diff --git a/include/dt-bindings/reset/xlnx-versal-resets.h b/include/dt-bindings/reset/xlnx-versal-resets.h deleted file mode 100644 index 895424e9b0e5..000000000000 --- a/include/dt-bindings/reset/xlnx-versal-resets.h +++ /dev/null @@ -1,105 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2020 Xilinx, Inc. - */ - -#ifndef _DT_BINDINGS_VERSAL_RESETS_H -#define _DT_BINDINGS_VERSAL_RESETS_H - -#define VERSAL_RST_PMC_POR (0xc30c001U) -#define VERSAL_RST_PMC (0xc410002U) -#define VERSAL_RST_PS_POR (0xc30c003U) -#define VERSAL_RST_PL_POR (0xc30c004U) -#define VERSAL_RST_NOC_POR (0xc30c005U) -#define VERSAL_RST_FPD_POR (0xc30c006U) -#define VERSAL_RST_ACPU_0_POR (0xc30c007U) -#define VERSAL_RST_ACPU_1_POR (0xc30c008U) -#define VERSAL_RST_OCM2_POR (0xc30c009U) -#define VERSAL_RST_PS_SRST (0xc41000aU) -#define VERSAL_RST_PL_SRST (0xc41000bU) -#define VERSAL_RST_NOC (0xc41000cU) -#define VERSAL_RST_NPI (0xc41000dU) -#define VERSAL_RST_SYS_RST_1 (0xc41000eU) -#define VERSAL_RST_SYS_RST_2 (0xc41000fU) -#define VERSAL_RST_SYS_RST_3 (0xc410010U) -#define VERSAL_RST_FPD (0xc410011U) -#define VERSAL_RST_PL0 (0xc410012U) -#define VERSAL_RST_PL1 (0xc410013U) -#define VERSAL_RST_PL2 (0xc410014U) -#define VERSAL_RST_PL3 (0xc410015U) -#define VERSAL_RST_APU (0xc410016U) -#define VERSAL_RST_ACPU_0 (0xc410017U) -#define VERSAL_RST_ACPU_1 (0xc410018U) -#define VERSAL_RST_ACPU_L2 (0xc410019U) -#define VERSAL_RST_ACPU_GIC (0xc41001aU) -#define VERSAL_RST_RPU_ISLAND (0xc41001bU) -#define VERSAL_RST_RPU_AMBA (0xc41001cU) -#define VERSAL_RST_R5_0 (0xc41001dU) -#define VERSAL_RST_R5_1 (0xc41001eU) -#define VERSAL_RST_SYSMON_PMC_SEQ_RST (0xc41001fU) -#define VERSAL_RST_SYSMON_PMC_CFG_RST (0xc410020U) -#define VERSAL_RST_SYSMON_FPD_CFG_RST (0xc410021U) -#define VERSAL_RST_SYSMON_FPD_SEQ_RST (0xc410022U) -#define VERSAL_RST_SYSMON_LPD (0xc410023U) -#define VERSAL_RST_PDMA_RST1 (0xc410024U) -#define VERSAL_RST_PDMA_RST0 (0xc410025U) -#define VERSAL_RST_ADMA (0xc410026U) -#define VERSAL_RST_TIMESTAMP (0xc410027U) -#define VERSAL_RST_OCM (0xc410028U) -#define VERSAL_RST_OCM2_RST (0xc410029U) -#define VERSAL_RST_IPI (0xc41002aU) -#define VERSAL_RST_SBI (0xc41002bU) -#define VERSAL_RST_LPD (0xc41002cU) -#define VERSAL_RST_QSPI (0xc10402dU) -#define VERSAL_RST_OSPI (0xc10402eU) -#define VERSAL_RST_SDIO_0 (0xc10402fU) -#define VERSAL_RST_SDIO_1 (0xc104030U) -#define VERSAL_RST_I2C_PMC (0xc104031U) -#define VERSAL_RST_GPIO_PMC (0xc104032U) -#define VERSAL_RST_GEM_0 (0xc104033U) -#define VERSAL_RST_GEM_1 (0xc104034U) -#define VERSAL_RST_SPARE (0xc104035U) -#define VERSAL_RST_USB_0 (0xc104036U) -#define VERSAL_RST_UART_0 (0xc104037U) -#define VERSAL_RST_UART_1 (0xc104038U) -#define VERSAL_RST_SPI_0 (0xc104039U) -#define VERSAL_RST_SPI_1 (0xc10403aU) -#define VERSAL_RST_CAN_FD_0 (0xc10403bU) -#define VERSAL_RST_CAN_FD_1 (0xc10403cU) -#define VERSAL_RST_I2C_0 (0xc10403dU) -#define VERSAL_RST_I2C_1 (0xc10403eU) -#define VERSAL_RST_GPIO_LPD (0xc10403fU) -#define VERSAL_RST_TTC_0 (0xc104040U) -#define VERSAL_RST_TTC_1 (0xc104041U) -#define VERSAL_RST_TTC_2 (0xc104042U) -#define VERSAL_RST_TTC_3 (0xc104043U) -#define VERSAL_RST_SWDT_FPD (0xc104044U) -#define VERSAL_RST_SWDT_LPD (0xc104045U) -#define VERSAL_RST_USB (0xc104046U) -#define VERSAL_RST_DPC (0xc208047U) -#define VERSAL_RST_PMCDBG (0xc208048U) -#define VERSAL_RST_DBG_TRACE (0xc208049U) -#define VERSAL_RST_DBG_FPD (0xc20804aU) -#define VERSAL_RST_DBG_TSTMP (0xc20804bU) -#define VERSAL_RST_RPU0_DBG (0xc20804cU) -#define VERSAL_RST_RPU1_DBG (0xc20804dU) -#define VERSAL_RST_HSDP (0xc20804eU) -#define VERSAL_RST_DBG_LPD (0xc20804fU) -#define VERSAL_RST_CPM_POR (0xc30c050U) -#define VERSAL_RST_CPM (0xc410051U) -#define VERSAL_RST_CPMDBG (0xc208052U) -#define VERSAL_RST_PCIE_CFG (0xc410053U) -#define VERSAL_RST_PCIE_CORE0 (0xc410054U) -#define VERSAL_RST_PCIE_CORE1 (0xc410055U) -#define VERSAL_RST_PCIE_DMA (0xc410056U) -#define VERSAL_RST_CMN (0xc410057U) -#define VERSAL_RST_L2_0 (0xc410058U) -#define VERSAL_RST_L2_1 (0xc410059U) -#define VERSAL_RST_ADDR_REMAP (0xc41005aU) -#define VERSAL_RST_CPI0 (0xc41005bU) -#define VERSAL_RST_CPI1 (0xc41005cU) -#define VERSAL_RST_XRAM (0xc30c05dU) -#define VERSAL_RST_AIE_ARRAY (0xc10405eU) -#define VERSAL_RST_AIE_SHIM (0xc10405fU) - -#endif diff --git a/include/dt-bindings/reset/xlnx-zynqmp-resets.h b/include/dt-bindings/reset/xlnx-zynqmp-resets.h deleted file mode 100644 index d44525b9f8db..000000000000 --- a/include/dt-bindings/reset/xlnx-zynqmp-resets.h +++ /dev/null @@ -1,130 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 Xilinx, Inc. - */ - -#ifndef _DT_BINDINGS_ZYNQMP_RESETS_H -#define _DT_BINDINGS_ZYNQMP_RESETS_H - -#define ZYNQMP_RESET_PCIE_CFG 0 -#define ZYNQMP_RESET_PCIE_BRIDGE 1 -#define ZYNQMP_RESET_PCIE_CTRL 2 -#define ZYNQMP_RESET_DP 3 -#define ZYNQMP_RESET_SWDT_CRF 4 -#define ZYNQMP_RESET_AFI_FM5 5 -#define ZYNQMP_RESET_AFI_FM4 6 -#define ZYNQMP_RESET_AFI_FM3 7 -#define ZYNQMP_RESET_AFI_FM2 8 -#define ZYNQMP_RESET_AFI_FM1 9 -#define ZYNQMP_RESET_AFI_FM0 10 -#define ZYNQMP_RESET_GDMA 11 -#define ZYNQMP_RESET_GPU_PP1 12 -#define ZYNQMP_RESET_GPU_PP0 13 -#define ZYNQMP_RESET_GPU 14 -#define ZYNQMP_RESET_GT 15 -#define ZYNQMP_RESET_SATA 16 -#define ZYNQMP_RESET_ACPU3_PWRON 17 -#define ZYNQMP_RESET_ACPU2_PWRON 18 -#define ZYNQMP_RESET_ACPU1_PWRON 19 -#define ZYNQMP_RESET_ACPU0_PWRON 20 -#define ZYNQMP_RESET_APU_L2 21 -#define ZYNQMP_RESET_ACPU3 22 -#define ZYNQMP_RESET_ACPU2 23 -#define ZYNQMP_RESET_ACPU1 24 -#define ZYNQMP_RESET_ACPU0 25 -#define ZYNQMP_RESET_DDR 26 -#define ZYNQMP_RESET_APM_FPD 27 -#define ZYNQMP_RESET_SOFT 28 -#define ZYNQMP_RESET_GEM0 29 -#define ZYNQMP_RESET_GEM1 30 -#define ZYNQMP_RESET_GEM2 31 -#define ZYNQMP_RESET_GEM3 32 -#define ZYNQMP_RESET_QSPI 33 -#define ZYNQMP_RESET_UART0 34 -#define ZYNQMP_RESET_UART1 35 -#define ZYNQMP_RESET_SPI0 36 -#define ZYNQMP_RESET_SPI1 37 -#define ZYNQMP_RESET_SDIO0 38 -#define ZYNQMP_RESET_SDIO1 39 -#define ZYNQMP_RESET_CAN0 40 -#define ZYNQMP_RESET_CAN1 41 -#define ZYNQMP_RESET_I2C0 42 -#define ZYNQMP_RESET_I2C1 43 -#define ZYNQMP_RESET_TTC0 44 -#define ZYNQMP_RESET_TTC1 45 -#define ZYNQMP_RESET_TTC2 46 -#define ZYNQMP_RESET_TTC3 47 -#define ZYNQMP_RESET_SWDT_CRL 48 -#define ZYNQMP_RESET_NAND 49 -#define ZYNQMP_RESET_ADMA 50 -#define ZYNQMP_RESET_GPIO 51 -#define ZYNQMP_RESET_IOU_CC 52 -#define ZYNQMP_RESET_TIMESTAMP 53 -#define ZYNQMP_RESET_RPU_R50 54 -#define ZYNQMP_RESET_RPU_R51 55 -#define ZYNQMP_RESET_RPU_AMBA 56 -#define ZYNQMP_RESET_OCM 57 -#define ZYNQMP_RESET_RPU_PGE 58 -#define ZYNQMP_RESET_USB0_CORERESET 59 -#define ZYNQMP_RESET_USB1_CORERESET 60 -#define ZYNQMP_RESET_USB0_HIBERRESET 61 -#define ZYNQMP_RESET_USB1_HIBERRESET 62 -#define ZYNQMP_RESET_USB0_APB 63 -#define ZYNQMP_RESET_USB1_APB 64 -#define ZYNQMP_RESET_IPI 65 -#define ZYNQMP_RESET_APM_LPD 66 -#define ZYNQMP_RESET_RTC 67 -#define ZYNQMP_RESET_SYSMON 68 -#define ZYNQMP_RESET_AFI_FM6 69 -#define ZYNQMP_RESET_LPD_SWDT 70 -#define ZYNQMP_RESET_FPD 71 -#define ZYNQMP_RESET_RPU_DBG1 72 -#define ZYNQMP_RESET_RPU_DBG0 73 -#define ZYNQMP_RESET_DBG_LPD 74 -#define ZYNQMP_RESET_DBG_FPD 75 -#define ZYNQMP_RESET_APLL 76 -#define ZYNQMP_RESET_DPLL 77 -#define ZYNQMP_RESET_VPLL 78 -#define ZYNQMP_RESET_IOPLL 79 -#define ZYNQMP_RESET_RPLL 80 -#define ZYNQMP_RESET_GPO3_PL_0 81 -#define ZYNQMP_RESET_GPO3_PL_1 82 -#define ZYNQMP_RESET_GPO3_PL_2 83 -#define ZYNQMP_RESET_GPO3_PL_3 84 -#define ZYNQMP_RESET_GPO3_PL_4 85 -#define ZYNQMP_RESET_GPO3_PL_5 86 -#define ZYNQMP_RESET_GPO3_PL_6 87 -#define ZYNQMP_RESET_GPO3_PL_7 88 -#define ZYNQMP_RESET_GPO3_PL_8 89 -#define ZYNQMP_RESET_GPO3_PL_9 90 -#define ZYNQMP_RESET_GPO3_PL_10 91 -#define ZYNQMP_RESET_GPO3_PL_11 92 -#define ZYNQMP_RESET_GPO3_PL_12 93 -#define ZYNQMP_RESET_GPO3_PL_13 94 -#define ZYNQMP_RESET_GPO3_PL_14 95 -#define ZYNQMP_RESET_GPO3_PL_15 96 -#define ZYNQMP_RESET_GPO3_PL_16 97 -#define ZYNQMP_RESET_GPO3_PL_17 98 -#define ZYNQMP_RESET_GPO3_PL_18 99 -#define ZYNQMP_RESET_GPO3_PL_19 100 -#define ZYNQMP_RESET_GPO3_PL_20 101 -#define ZYNQMP_RESET_GPO3_PL_21 102 -#define ZYNQMP_RESET_GPO3_PL_22 103 -#define ZYNQMP_RESET_GPO3_PL_23 104 -#define ZYNQMP_RESET_GPO3_PL_24 105 -#define ZYNQMP_RESET_GPO3_PL_25 106 -#define ZYNQMP_RESET_GPO3_PL_26 107 -#define ZYNQMP_RESET_GPO3_PL_27 108 -#define ZYNQMP_RESET_GPO3_PL_28 109 -#define ZYNQMP_RESET_GPO3_PL_29 110 -#define ZYNQMP_RESET_GPO3_PL_30 111 -#define ZYNQMP_RESET_GPO3_PL_31 112 -#define ZYNQMP_RESET_RPU_LS 113 -#define ZYNQMP_RESET_PS_ONLY 114 -#define ZYNQMP_RESET_PL 115 -#define ZYNQMP_RESET_PS_PL0 116 -#define ZYNQMP_RESET_PS_PL1 117 -#define ZYNQMP_RESET_PS_PL2 118 -#define ZYNQMP_RESET_PS_PL3 119 - -#endif
- Copyright (C) 2019 Xilinx Inc.
- Xilinx Zynq MPSoC Firmware layer
- Copyright (C) 2014-2018 Xilinx, Inc.
- Copyright 2019 Laurent Pinchart laurent.pinchart@ideasonboard.com
- MIO pin configuration defines for Xilinx ZynqMP
- Copyright (C) 2020 Xilinx, Inc.
- Copyright (C) 2018 Xilinx, Inc.
-#endif
Acked-by: Michal Simek michal.simek@amd.com
Thanks, Michal
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/mt7622-clk.h | 270 ------- include/dt-bindings/clock/mt7629-clk.h | 206 ------ include/dt-bindings/clock/mt8183-clk.h | 329 --------- include/dt-bindings/pinctrl/mt65xx.h | 41 -- include/dt-bindings/pinctrl/mt8365-pinfunc.h | 858 ---------------------- include/dt-bindings/power/mediatek,mt8365-power.h | 19 - include/dt-bindings/reset/mt7621-reset.h | 38 - 7 files changed, 1761 deletions(-)
diff --git a/include/dt-bindings/clock/mt7622-clk.h b/include/dt-bindings/clock/mt7622-clk.h deleted file mode 100644 index 76fcaff0e42e..000000000000 --- a/include/dt-bindings/clock/mt7622-clk.h +++ /dev/null @@ -1,270 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (c) 2019 MediaTek Inc. - */ -#ifndef _DT_BINDINGS_CLK_MT7622_H -#define _DT_BINDINGS_CLK_MT7622_H - -/* TOPCKGEN */ - -/* FIXED_CLKS */ -#define CLK_TOP_TO_U2_PHY 0 -#define CLK_TOP_TO_U2_PHY_1P 1 -#define CLK_TOP_PCIE0_PIPE_EN 2 -#define CLK_TOP_PCIE1_PIPE_EN 3 -#define CLK_TOP_SSUSB_TX250M 4 -#define CLK_TOP_SSUSB_EQ_RX250M 5 -#define CLK_TOP_SSUSB_CDR_REF 6 -#define CLK_TOP_SSUSB_CDR_FB 7 -#define CLK_TOP_SATA_ASIC 8 -#define CLK_TOP_SATA_RBC 9 -/* FIXED_DIVS */ -#define CLK_TOP_TO_USB3_SYS 10 -#define CLK_TOP_P1_1MHZ 11 -#define CLK_TOP_4MHZ 12 -#define CLK_TOP_P0_1MHZ 13 -#define CLK_TOP_TXCLK_SRC_PRE 14 -#define CLK_TOP_RTC 15 -#define CLK_TOP_MEMPLL 16 -#define CLK_TOP_DMPLL 17 -#define CLK_TOP_SYSPLL_D2 18 -#define CLK_TOP_SYSPLL1_D2 19 -#define CLK_TOP_SYSPLL1_D4 20 -#define CLK_TOP_SYSPLL1_D8 21 -#define CLK_TOP_SYSPLL2_D4 22 -#define CLK_TOP_SYSPLL2_D8 23 -#define CLK_TOP_SYSPLL_D5 24 -#define CLK_TOP_SYSPLL3_D2 25 -#define CLK_TOP_SYSPLL3_D4 26 -#define CLK_TOP_SYSPLL4_D2 27 -#define CLK_TOP_SYSPLL4_D4 28 -#define CLK_TOP_SYSPLL4_D16 29 -#define CLK_TOP_UNIVPLL 30 -#define CLK_TOP_UNIVPLL_D2 31 -#define CLK_TOP_UNIVPLL1_D2 32 -#define CLK_TOP_UNIVPLL1_D4 33 -#define CLK_TOP_UNIVPLL1_D8 34 -#define CLK_TOP_UNIVPLL1_D16 35 -#define CLK_TOP_UNIVPLL2_D2 36 -#define CLK_TOP_UNIVPLL2_D4 37 -#define CLK_TOP_UNIVPLL2_D8 38 -#define CLK_TOP_UNIVPLL2_D16 39 -#define CLK_TOP_UNIVPLL_D5 40 -#define CLK_TOP_UNIVPLL3_D2 41 -#define CLK_TOP_UNIVPLL3_D4 42 -#define CLK_TOP_UNIVPLL3_D16 43 -#define CLK_TOP_UNIVPLL_D7 44 -#define CLK_TOP_UNIVPLL_D80_D4 45 -#define CLK_TOP_UNIV48M 46 -#define CLK_TOP_SGMIIPLL 47 -#define CLK_TOP_SGMIIPLL_D2 48 -#define CLK_TOP_AUD1PLL 49 -#define CLK_TOP_AUD2PLL 50 -#define CLK_TOP_AUD_I2S2_MCK 51 -#define CLK_TOP_TO_USB3_REF 52 -#define CLK_TOP_PCIE1_MAC_EN 53 -#define CLK_TOP_PCIE0_MAC_EN 54 -#define CLK_TOP_ETH_500M 55 -/* TOP_MUXES */ -#define CLK_TOP_AXI_SEL 56 -#define CLK_TOP_MEM_SEL 57 -#define CLK_TOP_DDRPHYCFG_SEL 58 -#define CLK_TOP_ETH_SEL 59 -#define CLK_TOP_PWM_SEL 60 -#define CLK_TOP_F10M_REF_SEL 61 -#define CLK_TOP_NFI_INFRA_SEL 62 -#define CLK_TOP_FLASH_SEL 63 -#define CLK_TOP_UART_SEL 64 -#define CLK_TOP_SPI0_SEL 65 -#define CLK_TOP_SPI1_SEL 66 -#define CLK_TOP_MSDC50_0_SEL 67 -#define CLK_TOP_MSDC30_0_SEL 68 -#define CLK_TOP_MSDC30_1_SEL 69 -#define CLK_TOP_A1SYS_HP_SEL 70 -#define CLK_TOP_A2SYS_HP_SEL 71 -#define CLK_TOP_INTDIR_SEL 72 -#define CLK_TOP_AUD_INTBUS_SEL 73 -#define CLK_TOP_PMICSPI_SEL 74 -#define CLK_TOP_SCP_SEL 75 -#define CLK_TOP_ATB_SEL 76 -#define CLK_TOP_HIF_SEL 77 -#define CLK_TOP_AUDIO_SEL 78 -#define CLK_TOP_U2_SEL 79 -#define CLK_TOP_AUD1_SEL 80 -#define CLK_TOP_AUD2_SEL 81 -#define CLK_TOP_IRRX_SEL 82 -#define CLK_TOP_IRTX_SEL 83 -#define CLK_TOP_ASM_L_SEL 84 -#define CLK_TOP_ASM_M_SEL 85 -#define CLK_TOP_ASM_H_SEL 86 -#define CLK_TOP_APLL1_SEL 87 -#define CLK_TOP_APLL2_SEL 88 -#define CLK_TOP_I2S0_MCK_SEL 89 -#define CLK_TOP_I2S1_MCK_SEL 90 -#define CLK_TOP_I2S2_MCK_SEL 91 -#define CLK_TOP_I2S3_MCK_SEL 92 -#define CLK_TOP_APLL1_DIV 93 -#define CLK_TOP_APLL2_DIV 94 -#define CLK_TOP_I2S0_MCK_DIV 95 -#define CLK_TOP_I2S1_MCK_DIV 96 -#define CLK_TOP_I2S2_MCK_DIV 97 -#define CLK_TOP_I2S3_MCK_DIV 98 -#define CLK_TOP_A1SYS_HP_DIV 99 -#define CLK_TOP_A2SYS_HP_DIV 100 -#define CLK_TOP_APLL1_DIV_PD 101 -#define CLK_TOP_APLL2_DIV_PD 102 -#define CLK_TOP_I2S0_MCK_DIV_PD 103 -#define CLK_TOP_I2S1_MCK_DIV_PD 104 -#define CLK_TOP_I2S2_MCK_DIV_PD 105 -#define CLK_TOP_I2S3_MCK_DIV_PD 106 - -/* INFRACFG */ - -#define CLK_INFRA_DBGCLK_PD 0 -#define CLK_INFRA_TRNG 1 -#define CLK_INFRA_AUDIO_PD 2 -#define CLK_INFRA_IRRX_PD 3 -#define CLK_INFRA_APXGPT_PD 4 -#define CLK_INFRA_PMIC_PD 5 - -/* PERICFG */ - -#define CLK_PERI_THERM_PD 0 -#define CLK_PERI_PWM1_PD 1 -#define CLK_PERI_PWM2_PD 2 -#define CLK_PERI_PWM3_PD 3 -#define CLK_PERI_PWM4_PD 4 -#define CLK_PERI_PWM5_PD 5 -#define CLK_PERI_PWM6_PD 6 -#define CLK_PERI_PWM7_PD 7 -#define CLK_PERI_PWM_PD 8 -#define CLK_PERI_AP_DMA_PD 9 -#define CLK_PERI_MSDC30_0_PD 10 -#define CLK_PERI_MSDC30_1_PD 11 -#define CLK_PERI_UART0_PD 12 -#define CLK_PERI_UART1_PD 13 -#define CLK_PERI_UART2_PD 14 -#define CLK_PERI_UART3_PD 15 -#define CLK_PERI_BTIF_PD 16 -#define CLK_PERI_I2C0_PD 17 -#define CLK_PERI_I2C1_PD 18 -#define CLK_PERI_I2C2_PD 19 -#define CLK_PERI_SPI1_PD 20 -#define CLK_PERI_AUXADC_PD 21 -#define CLK_PERI_SPI0_PD 22 -#define CLK_PERI_SNFI_PD 23 -#define CLK_PERI_NFI_PD 24 -#define CLK_PERI_NFIECC_PD 25 -#define CLK_PERI_FLASH_PD 26 -#define CLK_PERI_IRTX_PD 27 - -/* APMIXEDSYS */ - -#define CLK_APMIXED_ARMPLL 0 -#define CLK_APMIXED_MAINPLL 1 -#define CLK_APMIXED_UNIV2PLL 2 -#define CLK_APMIXED_ETH1PLL 3 -#define CLK_APMIXED_ETH2PLL 4 -#define CLK_APMIXED_AUD1PLL 5 -#define CLK_APMIXED_AUD2PLL 6 -#define CLK_APMIXED_TRGPLL 7 -#define CLK_APMIXED_SGMIPLL 8 - -/* AUDIOSYS */ - -#define CLK_AUDIO_AFE 0 -#define CLK_AUDIO_HDMI 1 -#define CLK_AUDIO_SPDF 2 -#define CLK_AUDIO_APLL 3 -#define CLK_AUDIO_I2SIN1 4 -#define CLK_AUDIO_I2SIN2 5 -#define CLK_AUDIO_I2SIN3 6 -#define CLK_AUDIO_I2SIN4 7 -#define CLK_AUDIO_I2SO1 8 -#define CLK_AUDIO_I2SO2 9 -#define CLK_AUDIO_I2SO3 10 -#define CLK_AUDIO_I2SO4 11 -#define CLK_AUDIO_ASRCI1 12 -#define CLK_AUDIO_ASRCI2 13 -#define CLK_AUDIO_ASRCO1 14 -#define CLK_AUDIO_ASRCO2 15 -#define CLK_AUDIO_INTDIR 16 -#define CLK_AUDIO_A1SYS 17 -#define CLK_AUDIO_A2SYS 18 -#define CLK_AUDIO_UL1 19 -#define CLK_AUDIO_UL2 20 -#define CLK_AUDIO_UL3 21 -#define CLK_AUDIO_UL4 22 -#define CLK_AUDIO_UL5 23 -#define CLK_AUDIO_UL6 24 -#define CLK_AUDIO_DL1 25 -#define CLK_AUDIO_DL2 26 -#define CLK_AUDIO_DL3 27 -#define CLK_AUDIO_DL4 28 -#define CLK_AUDIO_DL5 29 -#define CLK_AUDIO_DL6 30 -#define CLK_AUDIO_DLMCH 31 -#define CLK_AUDIO_ARB1 32 -#define CLK_AUDIO_AWB 33 -#define CLK_AUDIO_AWB3 34 -#define CLK_AUDIO_DAI 35 -#define CLK_AUDIO_MOD 36 -#define CLK_AUDIO_ASRCI3 37 -#define CLK_AUDIO_ASRCI4 38 -#define CLK_AUDIO_ASRCO3 39 -#define CLK_AUDIO_ASRCO4 40 -#define CLK_AUDIO_MEM_ASRC1 41 -#define CLK_AUDIO_MEM_ASRC2 42 -#define CLK_AUDIO_MEM_ASRC3 43 -#define CLK_AUDIO_MEM_ASRC4 44 -#define CLK_AUDIO_MEM_ASRC5 45 -#define CLK_AUDIO_AFE_CONN 46 -#define CLK_AUDIO_NR_CLK 47 - -/* SSUSBSYS */ - -#define CLK_SSUSB_U2_PHY_1P_EN 0 -#define CLK_SSUSB_U2_PHY_EN 1 -#define CLK_SSUSB_REF_EN 2 -#define CLK_SSUSB_SYS_EN 3 -#define CLK_SSUSB_MCU_EN 4 -#define CLK_SSUSB_DMA_EN 5 -#define CLK_SSUSB_NR_CLK 6 - -/* PCIESYS */ - -#define CLK_PCIE_P1_AUX_EN 0 -#define CLK_PCIE_P1_OBFF_EN 1 -#define CLK_PCIE_P1_AHB_EN 2 -#define CLK_PCIE_P1_AXI_EN 3 -#define CLK_PCIE_P1_MAC_EN 4 -#define CLK_PCIE_P1_PIPE_EN 5 -#define CLK_PCIE_P0_AUX_EN 6 -#define CLK_PCIE_P0_OBFF_EN 7 -#define CLK_PCIE_P0_AHB_EN 8 -#define CLK_PCIE_P0_AXI_EN 9 -#define CLK_PCIE_P0_MAC_EN 10 -#define CLK_PCIE_P0_PIPE_EN 11 -#define CLK_SATA_AHB_EN 12 -#define CLK_SATA_AXI_EN 13 -#define CLK_SATA_ASIC_EN 14 -#define CLK_SATA_RBC_EN 15 -#define CLK_SATA_PM_EN 16 -#define CLK_PCIE_NR_CLK 17 - -/* ETHSYS */ - -#define CLK_ETH_HSDMA_EN 0 -#define CLK_ETH_ESW_EN 1 -#define CLK_ETH_GP2_EN 2 -#define CLK_ETH_GP1_EN 3 -#define CLK_ETH_GP0_EN 4 - -/* SGMIISYS */ - -#define CLK_SGMII_TX250M_EN 0 -#define CLK_SGMII_RX250M_EN 1 -#define CLK_SGMII_CDR_REF 2 -#define CLK_SGMII_CDR_FB 3 - -#endif /* _DT_BINDINGS_CLK_MT7622_H */ diff --git a/include/dt-bindings/clock/mt7629-clk.h b/include/dt-bindings/clock/mt7629-clk.h deleted file mode 100644 index 0bbfbfa744aa..000000000000 --- a/include/dt-bindings/clock/mt7629-clk.h +++ /dev/null @@ -1,206 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018 MediaTek Inc. - */ - -#ifndef _DT_BINDINGS_CLK_MT7629_H -#define _DT_BINDINGS_CLK_MT7629_H - -/* TOPCKGEN */ -#define CLK_TOP_FCLKS_OFF 0 - -#define CLK_TOP_TO_U2_PHY 0 -#define CLK_TOP_TO_U2_PHY_1P 1 -#define CLK_TOP_PCIE0_PIPE_EN 2 -#define CLK_TOP_PCIE1_PIPE_EN 3 -#define CLK_TOP_SSUSB_TX250M 4 -#define CLK_TOP_SSUSB_EQ_RX250M 5 -#define CLK_TOP_SSUSB_CDR_REF 6 -#define CLK_TOP_SSUSB_CDR_FB 7 -#define CLK_TOP_SATA_ASIC 8 -#define CLK_TOP_SATA_RBC 9 - -#define CLK_TOP_TO_USB3_SYS 10 -#define CLK_TOP_P1_1MHZ 11 -#define CLK_TOP_4MHZ 12 -#define CLK_TOP_P0_1MHZ 13 -#define CLK_TOP_ETH_500M 14 -#define CLK_TOP_TXCLK_SRC_PRE 15 -#define CLK_TOP_RTC 16 -#define CLK_TOP_PWM_QTR_26M 17 -#define CLK_TOP_CPUM_TCK_IN 18 -#define CLK_TOP_TO_USB3_DA_TOP 19 -#define CLK_TOP_MEMPLL 20 -#define CLK_TOP_DMPLL 21 -#define CLK_TOP_DMPLL_D4 22 -#define CLK_TOP_DMPLL_D8 23 -#define CLK_TOP_SYSPLL_D2 24 -#define CLK_TOP_SYSPLL1_D2 25 -#define CLK_TOP_SYSPLL1_D4 26 -#define CLK_TOP_SYSPLL1_D8 27 -#define CLK_TOP_SYSPLL1_D16 28 -#define CLK_TOP_SYSPLL2_D2 29 -#define CLK_TOP_SYSPLL2_D4 30 -#define CLK_TOP_SYSPLL2_D8 31 -#define CLK_TOP_SYSPLL_D5 32 -#define CLK_TOP_SYSPLL3_D2 33 -#define CLK_TOP_SYSPLL3_D4 34 -#define CLK_TOP_SYSPLL_D7 35 -#define CLK_TOP_SYSPLL4_D2 36 -#define CLK_TOP_SYSPLL4_D4 37 -#define CLK_TOP_SYSPLL4_D16 38 -#define CLK_TOP_UNIVPLL 39 -#define CLK_TOP_UNIVPLL1_D2 40 -#define CLK_TOP_UNIVPLL1_D4 41 -#define CLK_TOP_UNIVPLL1_D8 42 -#define CLK_TOP_UNIVPLL_D3 43 -#define CLK_TOP_UNIVPLL2_D2 44 -#define CLK_TOP_UNIVPLL2_D4 45 -#define CLK_TOP_UNIVPLL2_D8 46 -#define CLK_TOP_UNIVPLL2_D16 47 -#define CLK_TOP_UNIVPLL_D5 48 -#define CLK_TOP_UNIVPLL3_D2 49 -#define CLK_TOP_UNIVPLL3_D4 50 -#define CLK_TOP_UNIVPLL3_D16 51 -#define CLK_TOP_UNIVPLL_D7 52 -#define CLK_TOP_UNIVPLL_D80_D4 53 -#define CLK_TOP_UNIV48M 54 -#define CLK_TOP_SGMIIPLL_D2 55 -#define CLK_TOP_CLKXTAL_D4 56 -#define CLK_TOP_HD_FAXI 57 -#define CLK_TOP_FAXI 58 -#define CLK_TOP_F_FAUD_INTBUS 59 -#define CLK_TOP_AP2WBHIF_HCLK 60 -#define CLK_TOP_10M_INFRAO 61 -#define CLK_TOP_MSDC30_1 62 -#define CLK_TOP_SPI 63 -#define CLK_TOP_SF 64 -#define CLK_TOP_FLASH 65 -#define CLK_TOP_TO_USB3_REF 66 -#define CLK_TOP_TO_USB3_MCU 67 -#define CLK_TOP_TO_USB3_DMA 68 -#define CLK_TOP_FROM_TOP_AHB 69 -#define CLK_TOP_FROM_TOP_AXI 70 -#define CLK_TOP_PCIE1_MAC_EN 71 -#define CLK_TOP_PCIE0_MAC_EN 72 - -#define CLK_TOP_AXI_SEL 73 -#define CLK_TOP_MEM_SEL 74 -#define CLK_TOP_DDRPHYCFG_SEL 75 -#define CLK_TOP_ETH_SEL 76 -#define CLK_TOP_PWM_SEL 77 -#define CLK_TOP_F10M_REF_SEL 78 -#define CLK_TOP_NFI_INFRA_SEL 79 -#define CLK_TOP_FLASH_SEL 80 -#define CLK_TOP_UART_SEL 81 -#define CLK_TOP_SPI0_SEL 82 -#define CLK_TOP_SPI1_SEL 83 -#define CLK_TOP_MSDC50_0_SEL 84 -#define CLK_TOP_MSDC30_0_SEL 85 -#define CLK_TOP_MSDC30_1_SEL 86 -#define CLK_TOP_AP2WBMCU_SEL 87 -#define CLK_TOP_AP2WBHIF_SEL 88 -#define CLK_TOP_AUDIO_SEL 89 -#define CLK_TOP_AUD_INTBUS_SEL 90 -#define CLK_TOP_PMICSPI_SEL 91 -#define CLK_TOP_SCP_SEL 92 -#define CLK_TOP_ATB_SEL 93 -#define CLK_TOP_HIF_SEL 94 -#define CLK_TOP_SATA_SEL 95 -#define CLK_TOP_U2_SEL 96 -#define CLK_TOP_AUD1_SEL 97 -#define CLK_TOP_AUD2_SEL 98 -#define CLK_TOP_IRRX_SEL 99 -#define CLK_TOP_IRTX_SEL 100 -#define CLK_TOP_SATA_MCU_SEL 101 -#define CLK_TOP_PCIE0_MCU_SEL 102 -#define CLK_TOP_PCIE1_MCU_SEL 103 -#define CLK_TOP_SSUSB_MCU_SEL 104 -#define CLK_TOP_CRYPTO_SEL 105 -#define CLK_TOP_SGMII_REF_1_SEL 106 -#define CLK_TOP_10M_SEL 107 -#define CLK_TOP_NR_CLK 108 - -/* INFRACFG */ -#define CLK_INFRA_MUX1_SEL 0 -#define CLK_INFRA_DBGCLK_PD 1 -#define CLK_INFRA_TRNG_PD 2 -#define CLK_INFRA_DEVAPC_PD 3 -#define CLK_INFRA_APXGPT_PD 4 -#define CLK_INFRA_SEJ_PD 5 -#define CLK_INFRA_NR_CLK 6 - -/* PERICFG */ -#define CLK_PERIBUS_SEL 0 -#define CLK_PERI_PWM1_PD 1 -#define CLK_PERI_PWM2_PD 2 -#define CLK_PERI_PWM3_PD 3 -#define CLK_PERI_PWM4_PD 4 -#define CLK_PERI_PWM5_PD 5 -#define CLK_PERI_PWM6_PD 6 -#define CLK_PERI_PWM7_PD 7 -#define CLK_PERI_PWM_PD 8 -#define CLK_PERI_AP_DMA_PD 9 -#define CLK_PERI_MSDC30_1_PD 10 -#define CLK_PERI_UART0_PD 11 -#define CLK_PERI_UART1_PD 12 -#define CLK_PERI_UART2_PD 13 -#define CLK_PERI_UART3_PD 14 -#define CLK_PERI_BTIF_PD 15 -#define CLK_PERI_I2C0_PD 16 -#define CLK_PERI_SPI0_PD 17 -#define CLK_PERI_SNFI_PD 18 -#define CLK_PERI_NFI_PD 19 -#define CLK_PERI_NFIECC_PD 20 -#define CLK_PERI_FLASH_PD 21 -#define CLK_PERI_NR_CLK 22 - -/* APMIXEDSYS */ -#define CLK_APMIXED_ARMPLL 0 -#define CLK_APMIXED_MAINPLL 1 -#define CLK_APMIXED_UNIV2PLL 2 -#define CLK_APMIXED_ETH1PLL 3 -#define CLK_APMIXED_ETH2PLL 4 -#define CLK_APMIXED_SGMIPLL 5 -#define CLK_APMIXED_NR_CLK 6 - -/* SSUSBSYS */ -#define CLK_SSUSB_U2_PHY_1P_EN 0 -#define CLK_SSUSB_U2_PHY_EN 1 -#define CLK_SSUSB_REF_EN 2 -#define CLK_SSUSB_SYS_EN 3 -#define CLK_SSUSB_MCU_EN 4 -#define CLK_SSUSB_DMA_EN 5 -#define CLK_SSUSB_NR_CLK 6 - -/* PCIESYS */ -#define CLK_PCIE_P1_AUX_EN 0 -#define CLK_PCIE_P1_OBFF_EN 1 -#define CLK_PCIE_P1_AHB_EN 2 -#define CLK_PCIE_P1_AXI_EN 3 -#define CLK_PCIE_P1_MAC_EN 4 -#define CLK_PCIE_P1_PIPE_EN 5 -#define CLK_PCIE_P0_AUX_EN 6 -#define CLK_PCIE_P0_OBFF_EN 7 -#define CLK_PCIE_P0_AHB_EN 8 -#define CLK_PCIE_P0_AXI_EN 9 -#define CLK_PCIE_P0_MAC_EN 10 -#define CLK_PCIE_P0_PIPE_EN 11 -#define CLK_PCIE_NR_CLK 12 - -/* ETHSYS */ -#define CLK_ETH_FE_EN 0 -#define CLK_ETH_GP2_EN 1 -#define CLK_ETH_GP1_EN 2 -#define CLK_ETH_GP0_EN 3 -#define CLK_ETH_ESW_EN 4 -#define CLK_ETH_NR_CLK 5 - -/* SGMIISYS */ -#define CLK_SGMII_TX_EN 0 -#define CLK_SGMII_RX_EN 1 -#define CLK_SGMII_CDR_REF 2 -#define CLK_SGMII_CDR_FB 3 -#define CLK_SGMII_NR_CLK 4 - -#endif /* _DT_BINDINGS_CLK_MT7629_H */ diff --git a/include/dt-bindings/clock/mt8183-clk.h b/include/dt-bindings/clock/mt8183-clk.h deleted file mode 100644 index f7e6367ce844..000000000000 --- a/include/dt-bindings/clock/mt8183-clk.h +++ /dev/null @@ -1,329 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2020 MediaTek Inc. - * Author: Weiyi Lu weiyi.lu@mediatek.com - */ - -#ifndef _DT_BINDINGS_CLK_MT8183_H -#define _DT_BINDINGS_CLK_MT8183_H - -/* APMIXED */ -#define CLK_APMIXED_ARMPLL_LL 0 -#define CLK_APMIXED_ARMPLL_L 1 -#define CLK_APMIXED_CCIPLL 2 -#define CLK_APMIXED_MAINPLL 3 -#define CLK_APMIXED_UNIV2PLL 4 -#define CLK_APMIXED_MSDCPLL 5 -#define CLK_APMIXED_MMPLL 6 -#define CLK_APMIXED_MFGPLL 7 -#define CLK_APMIXED_TVDPLL 8 -#define CLK_APMIXED_APLL1 9 -#define CLK_APMIXED_APLL2 10 -#define CLK_APMIXED_SSUSB_26M 11 -#define CLK_APMIXED_APPLL_26M 12 -#define CLK_APMIXED_MIPIC0_26M 13 -#define CLK_APMIXED_MDPLLGP_26M 14 -#define CLK_APMIXED_MMSYS_26M 15 -#define CLK_APMIXED_UFS_26M 16 -#define CLK_APMIXED_MIPIC1_26M 17 -#define CLK_APMIXED_MEMPLL_26M 18 -#define CLK_APMIXED_CLKSQ_LVPLL_26M 19 -#define CLK_APMIXED_MIPID0_26M 20 -#define CLK_APMIXED_MIPID1_26M 21 -#define CLK_APMIXED_NR_CLK 22 - -/* TOPCKGEN */ -#define CLK_TOP_CLK26M 0 -#define CLK_TOP_ULPOSC 1 -#define CLK_TOP_UNIVP_192M 2 -#define CLK_TOP_CLK13M 3 -#define CLK_TOP_F26M_CK_D2 4 -#define CLK_TOP_SYSPLL_CK 5 -#define CLK_TOP_SYSPLL_D2 6 -#define CLK_TOP_SYSPLL_D3 7 -#define CLK_TOP_SYSPLL_D5 8 -#define CLK_TOP_SYSPLL_D7 9 -#define CLK_TOP_SYSPLL_D2_D2 10 -#define CLK_TOP_SYSPLL_D2_D4 11 -#define CLK_TOP_SYSPLL_D2_D8 12 -#define CLK_TOP_SYSPLL_D2_D16 13 -#define CLK_TOP_SYSPLL_D3_D2 14 -#define CLK_TOP_SYSPLL_D3_D4 15 -#define CLK_TOP_SYSPLL_D3_D8 16 -#define CLK_TOP_SYSPLL_D5_D2 17 -#define CLK_TOP_SYSPLL_D5_D4 18 -#define CLK_TOP_SYSPLL_D7_D2 19 -#define CLK_TOP_SYSPLL_D7_D4 20 -#define CLK_TOP_UNIVPLL_CK 21 -#define CLK_TOP_UNIVPLL_D2 22 -#define CLK_TOP_UNIVPLL_D3 23 -#define CLK_TOP_UNIVPLL_D5 24 -#define CLK_TOP_UNIVPLL_D7 25 -#define CLK_TOP_UNIVPLL_D2_D2 26 -#define CLK_TOP_UNIVPLL_D2_D4 27 -#define CLK_TOP_UNIVPLL_D2_D8 28 -#define CLK_TOP_UNIVPLL_D3_D2 29 -#define CLK_TOP_UNIVPLL_D3_D4 30 -#define CLK_TOP_UNIVPLL_D3_D8 31 -#define CLK_TOP_UNIVPLL_D5_D2 32 -#define CLK_TOP_UNIVPLL_D5_D4 33 -#define CLK_TOP_UNIVPLL_D5_D8 34 -#define CLK_TOP_UNIVP_192M_CK 35 -#define CLK_TOP_UNIVP_192M_D2 36 -#define CLK_TOP_UNIVP_192M_D4 37 -#define CLK_TOP_UNIVP_192M_D8 38 -#define CLK_TOP_UNIVP_192M_D16 39 -#define CLK_TOP_UNIVP_192M_D32 40 -#define CLK_TOP_APLL1_CK 41 -#define CLK_TOP_APLL1_D2 42 -#define CLK_TOP_APLL1_D4 43 -#define CLK_TOP_APLL1_D8 44 -#define CLK_TOP_APLL2_CK 45 -#define CLK_TOP_APLL2_D2 46 -#define CLK_TOP_APLL2_D4 47 -#define CLK_TOP_APLL2_D8 48 -#define CLK_TOP_TVDPLL_CK 49 -#define CLK_TOP_TVDPLL_D2 50 -#define CLK_TOP_TVDPLL_D4 51 -#define CLK_TOP_TVDPLL_D8 52 -#define CLK_TOP_TVDPLL_D16 53 -#define CLK_TOP_MMPLL_CK 54 -#define CLK_TOP_MMPLL_D4 55 -#define CLK_TOP_MMPLL_D4_D2 56 -#define CLK_TOP_MMPLL_D4_D4 57 -#define CLK_TOP_MMPLL_D5 58 -#define CLK_TOP_MMPLL_D5_D2 59 -#define CLK_TOP_MMPLL_D5_D4 60 -#define CLK_TOP_MMPLL_D6 61 -#define CLK_TOP_MMPLL_D7 62 -#define CLK_TOP_MFGPLL_CK 63 -#define CLK_TOP_MSDCPLL_CK 64 -#define CLK_TOP_MSDCPLL_D2 65 -#define CLK_TOP_MSDCPLL_D4 66 -#define CLK_TOP_MSDCPLL_D8 67 -#define CLK_TOP_MSDCPLL_D16 68 -#define CLK_TOP_AD_OSC_CK 69 -#define CLK_TOP_OSC_D2 70 -#define CLK_TOP_OSC_D4 71 -#define CLK_TOP_OSC_D8 72 -#define CLK_TOP_OSC_D16 73 -#define CLK_TOP_UNIVPLL 74 -#define CLK_TOP_UNIVPLL_D3_D16 75 -#define CLK_TOP_APLL12_DIV0 76 -#define CLK_TOP_APLL12_DIV1 77 -#define CLK_TOP_APLL12_DIV2 78 -#define CLK_TOP_APLL12_DIV3 79 -#define CLK_TOP_APLL12_DIV4 80 -#define CLK_TOP_APLL12_DIVB 81 -#define CLK_TOP_ARMPLL_DIV_PLL1 82 -#define CLK_TOP_ARMPLL_DIV_PLL2 83 -#define CLK_TOP_MUX_AXI 84 -#define CLK_TOP_MUX_MM 85 -#define CLK_TOP_MUX_IMG 86 -#define CLK_TOP_MUX_CAM 87 -#define CLK_TOP_MUX_DSP 88 -#define CLK_TOP_MUX_DSP1 89 -#define CLK_TOP_MUX_DSP2 90 -#define CLK_TOP_MUX_IPU_IF 91 -#define CLK_TOP_MUX_MFG 92 -#define CLK_TOP_MUX_F52M_MFG 93 -#define CLK_TOP_MUX_CAMTG 94 -#define CLK_TOP_MUX_CAMTG2 95 -#define CLK_TOP_MUX_CAMTG3 96 -#define CLK_TOP_MUX_CAMTG4 97 -#define CLK_TOP_MUX_UART 98 -#define CLK_TOP_MUX_SPI 99 -#define CLK_TOP_MUX_MSDC50_0_HCLK 100 -#define CLK_TOP_MUX_MSDC50_0 101 -#define CLK_TOP_MUX_MSDC30_1 102 -#define CLK_TOP_MUX_MSDC30_2 103 -#define CLK_TOP_MUX_AUDIO 104 -#define CLK_TOP_MUX_AUD_INTBUS 105 -#define CLK_TOP_MUX_PMICSPI 106 -#define CLK_TOP_MUX_FPWRAP_ULPOSC 107 -#define CLK_TOP_MUX_ATB 108 -#define CLK_TOP_MUX_SSPM 109 -#define CLK_TOP_MUX_DPI0 110 -#define CLK_TOP_MUX_SCAM 111 -#define CLK_TOP_MUX_DISP_PWM 112 -#define CLK_TOP_MUX_USB_TOP 113 -#define CLK_TOP_MUX_SSUSB_TOP_XHCI 114 -#define CLK_TOP_MUX_SPM 115 -#define CLK_TOP_MUX_I2C 116 -#define CLK_TOP_MUX_SCP 117 -#define CLK_TOP_MUX_SENINF 118 -#define CLK_TOP_MUX_DXCC 119 -#define CLK_TOP_MUX_AUD_ENG1 120 -#define CLK_TOP_MUX_AUD_ENG2 121 -#define CLK_TOP_MUX_FAES_UFSFDE 122 -#define CLK_TOP_MUX_FUFS 123 -#define CLK_TOP_MUX_AUD_1 124 -#define CLK_TOP_MUX_AUD_2 125 -#define CLK_TOP_MUX_APLL_I2S0 126 -#define CLK_TOP_MUX_APLL_I2S1 127 -#define CLK_TOP_MUX_APLL_I2S2 128 -#define CLK_TOP_MUX_APLL_I2S3 129 -#define CLK_TOP_MUX_APLL_I2S4 130 -#define CLK_TOP_MUX_APLL_I2S5 131 -#define CLK_TOP_NR_CLK 132 - -/* INFRACFG_AO */ -#define CLK_INFRA_PMIC_TMR 0 -#define CLK_INFRA_PMIC_AP 1 -#define CLK_INFRA_PMIC_MD 2 -#define CLK_INFRA_PMIC_CONN 3 -#define CLK_INFRA_SCPSYS 4 -#define CLK_INFRA_SEJ 5 -#define CLK_INFRA_APXGPT 6 -#define CLK_INFRA_ICUSB 7 -#define CLK_INFRA_GCE 8 -#define CLK_INFRA_THERM 9 -#define CLK_INFRA_I2C0 10 -#define CLK_INFRA_I2C1 11 -#define CLK_INFRA_I2C2 12 -#define CLK_INFRA_I2C3 13 -#define CLK_INFRA_PWM_HCLK 14 -#define CLK_INFRA_PWM1 15 -#define CLK_INFRA_PWM2 16 -#define CLK_INFRA_PWM3 17 -#define CLK_INFRA_PWM4 18 -#define CLK_INFRA_PWM 19 -#define CLK_INFRA_UART0 20 -#define CLK_INFRA_UART1 21 -#define CLK_INFRA_UART2 22 -#define CLK_INFRA_UART3 23 -#define CLK_INFRA_GCE_26M 24 -#define CLK_INFRA_CQ_DMA_FPC 25 -#define CLK_INFRA_BTIF 26 -#define CLK_INFRA_SPI0 27 -#define CLK_INFRA_MSDC0 28 -#define CLK_INFRA_MSDC1 29 -#define CLK_INFRA_MSDC2 30 -#define CLK_INFRA_MSDC0_SCK 31 -#define CLK_INFRA_DVFSRC 32 -#define CLK_INFRA_GCPU 33 -#define CLK_INFRA_TRNG 34 -#define CLK_INFRA_AUXADC 35 -#define CLK_INFRA_CPUM 36 -#define CLK_INFRA_CCIF1_AP 37 -#define CLK_INFRA_CCIF1_MD 38 -#define CLK_INFRA_AUXADC_MD 39 -#define CLK_INFRA_MSDC1_SCK 40 -#define CLK_INFRA_MSDC2_SCK 41 -#define CLK_INFRA_AP_DMA 42 -#define CLK_INFRA_XIU 43 -#define CLK_INFRA_DEVICE_APC 44 -#define CLK_INFRA_CCIF_AP 45 -#define CLK_INFRA_DEBUGSYS 46 -#define CLK_INFRA_AUDIO 47 -#define CLK_INFRA_CCIF_MD 48 -#define CLK_INFRA_DXCC_SEC_CORE 49 -#define CLK_INFRA_DXCC_AO 50 -#define CLK_INFRA_DRAMC_F26M 51 -#define CLK_INFRA_IRTX 52 -#define CLK_INFRA_DISP_PWM 53 -#define CLK_INFRA_CLDMA_BCLK 54 -#define CLK_INFRA_AUDIO_26M_BCLK 55 -#define CLK_INFRA_SPI1 56 -#define CLK_INFRA_I2C4 57 -#define CLK_INFRA_MODEM_TEMP_SHARE 58 -#define CLK_INFRA_SPI2 59 -#define CLK_INFRA_SPI3 60 -#define CLK_INFRA_UNIPRO_SCK 61 -#define CLK_INFRA_UNIPRO_TICK 62 -#define CLK_INFRA_UFS_MP_SAP_BCLK 63 -#define CLK_INFRA_MD32_BCLK 64 -#define CLK_INFRA_SSPM 65 -#define CLK_INFRA_UNIPRO_MBIST 66 -#define CLK_INFRA_SSPM_BUS_HCLK 67 -#define CLK_INFRA_I2C5 68 -#define CLK_INFRA_I2C5_ARBITER 69 -#define CLK_INFRA_I2C5_IMM 70 -#define CLK_INFRA_I2C1_ARBITER 71 -#define CLK_INFRA_I2C1_IMM 72 -#define CLK_INFRA_I2C2_ARBITER 73 -#define CLK_INFRA_I2C2_IMM 74 -#define CLK_INFRA_SPI4 75 -#define CLK_INFRA_SPI5 76 -#define CLK_INFRA_CQ_DMA 77 -#define CLK_INFRA_UFS 78 -#define CLK_INFRA_AES_UFSFDE 79 -#define CLK_INFRA_UFS_TICK 80 -#define CLK_INFRA_MSDC0_SELF 81 -#define CLK_INFRA_MSDC1_SELF 82 -#define CLK_INFRA_MSDC2_SELF 83 -#define CLK_INFRA_SSPM_26M_SELF 84 -#define CLK_INFRA_SSPM_32K_SELF 85 -#define CLK_INFRA_UFS_AXI 86 -#define CLK_INFRA_I2C6 87 -#define CLK_INFRA_AP_MSDC0 88 -#define CLK_INFRA_MD_MSDC0 89 -#define CLK_INFRA_USB 90 -#define CLK_INFRA_DEVMPU_BCLK 91 -#define CLK_INFRA_CCIF2_AP 92 -#define CLK_INFRA_CCIF2_MD 93 -#define CLK_INFRA_CCIF3_AP 94 -#define CLK_INFRA_CCIF3_MD 95 -#define CLK_INFRA_SEJ_F13M 96 -#define CLK_INFRA_AES_BCLK 97 -#define CLK_INFRA_I2C7 98 -#define CLK_INFRA_I2C8 99 -#define CLK_INFRA_FBIST2FPC 100 -#define CLK_INFRA_NR_CLK 101 - -/* MMSYS_CONFIG */ -#define CLK_MM_SMI_COMMON 0 -#define CLK_MM_SMI_LARB0 1 -#define CLK_MM_SMI_LARB1 2 -#define CLK_MM_GALS_COMM0 3 -#define CLK_MM_GALS_COMM1 4 -#define CLK_MM_GALS_CCU2MM 5 -#define CLK_MM_GALS_IPU12MM 6 -#define CLK_MM_GALS_IMG2MM 7 -#define CLK_MM_GALS_CAM2MM 8 -#define CLK_MM_GALS_IPU2MM 9 -#define CLK_MM_MDP_DL_TXCK 10 -#define CLK_MM_IPU_DL_TXCK 11 -#define CLK_MM_MDP_RDMA0 12 -#define CLK_MM_MDP_RDMA1 13 -#define CLK_MM_MDP_RSZ0 14 -#define CLK_MM_MDP_RSZ1 15 -#define CLK_MM_MDP_TDSHP 16 -#define CLK_MM_MDP_WROT0 17 -#define CLK_MM_FAKE_ENG 18 -#define CLK_MM_DISP_OVL0 19 -#define CLK_MM_DISP_OVL0_2L 20 -#define CLK_MM_DISP_OVL1_2L 21 -#define CLK_MM_DISP_RDMA0 22 -#define CLK_MM_DISP_RDMA1 23 -#define CLK_MM_DISP_WDMA0 24 -#define CLK_MM_DISP_COLOR0 25 -#define CLK_MM_DISP_CCORR0 26 -#define CLK_MM_DISP_AAL0 27 -#define CLK_MM_DISP_GAMMA0 28 -#define CLK_MM_DISP_DITHER0 29 -#define CLK_MM_DISP_SPLIT 30 -#define CLK_MM_DSI0_MM 31 -#define CLK_MM_DSI0_IF 32 -#define CLK_MM_DPI_MM 33 -#define CLK_MM_DPI_IF 34 -#define CLK_MM_FAKE_ENG2 35 -#define CLK_MM_MDP_DL_RX 36 -#define CLK_MM_IPU_DL_RX 37 -#define CLK_MM_26M 38 -#define CLK_MM_MMSYS_R2Y 39 -#define CLK_MM_DISP_RSZ 40 -#define CLK_MM_MDP_WDMA0 41 -#define CLK_MM_MDP_AAL 42 -#define CLK_MM_MDP_CCORR 43 -#define CLK_MM_DBI_MM 44 -#define CLK_MM_DBI_IF 45 -#define CLK_MM_NR_CLK 46 - -/* MCUCFG */ -#define CLK_MCU_MP0_SEL 0 -#define CLK_MCU_MP2_SEL 1 -#define CLK_MCU_BUS_SEL 2 -#define CLK_MCU_NR_CLK 3 - -#endif /* _DT_BINDINGS_CLK_MT8183_H */ diff --git a/include/dt-bindings/pinctrl/mt65xx.h b/include/dt-bindings/pinctrl/mt65xx.h deleted file mode 100644 index fbea8d35bcf1..000000000000 --- a/include/dt-bindings/pinctrl/mt65xx.h +++ /dev/null @@ -1,41 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (c) 2022 MediaTek Inc. - * Author: Hongzhou.Yang hongzhou.yang@mediatek.com - */ - -#ifndef _DT_BINDINGS_PINCTRL_MT65XX_H -#define _DT_BINDINGS_PINCTRL_MT65XX_H - -#define MTK_PIN_NO(x) ((x) << 8) -#define MTK_GET_PIN_NO(x) ((x) >> 8) -#define MTK_GET_PIN_FUNC(x) ((x) & 0xf) - -#define MTK_PUPD_SET_R1R0_00 100 -#define MTK_PUPD_SET_R1R0_01 101 -#define MTK_PUPD_SET_R1R0_10 102 -#define MTK_PUPD_SET_R1R0_11 103 - -#define MTK_PULL_SET_RSEL_000 200 -#define MTK_PULL_SET_RSEL_001 201 -#define MTK_PULL_SET_RSEL_010 202 -#define MTK_PULL_SET_RSEL_011 203 -#define MTK_PULL_SET_RSEL_100 204 -#define MTK_PULL_SET_RSEL_101 205 -#define MTK_PULL_SET_RSEL_110 206 -#define MTK_PULL_SET_RSEL_111 207 - -#define MTK_DRIVE_2mA 2 -#define MTK_DRIVE_4mA 4 -#define MTK_DRIVE_6mA 6 -#define MTK_DRIVE_8mA 8 -#define MTK_DRIVE_10mA 10 -#define MTK_DRIVE_12mA 12 -#define MTK_DRIVE_14mA 14 -#define MTK_DRIVE_16mA 16 -#define MTK_DRIVE_20mA 20 -#define MTK_DRIVE_24mA 24 -#define MTK_DRIVE_28mA 28 -#define MTK_DRIVE_32mA 32 - -#endif /* _DT_BINDINGS_PINCTRL_MT65XX_H */ diff --git a/include/dt-bindings/pinctrl/mt8365-pinfunc.h b/include/dt-bindings/pinctrl/mt8365-pinfunc.h deleted file mode 100644 index e2ec8af57dcf..000000000000 --- a/include/dt-bindings/pinctrl/mt8365-pinfunc.h +++ /dev/null @@ -1,858 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2021 MediaTek Inc. - */ -#ifndef __MT8365_PINFUNC_H -#define __MT8365_PINFUNC_H - -#include <dt-bindings/pinctrl/mt65xx.h> - -#define MT8365_PIN_0_GPIO0__FUNC_GPIO0 (MTK_PIN_NO(0) | 0) -#define MT8365_PIN_0_GPIO0__FUNC_DPI_D0 (MTK_PIN_NO(0) | 1) -#define MT8365_PIN_0_GPIO0__FUNC_PWM_A (MTK_PIN_NO(0) | 2) -#define MT8365_PIN_0_GPIO0__FUNC_I2S2_BCK (MTK_PIN_NO(0) | 3) -#define MT8365_PIN_0_GPIO0__FUNC_EXT_TXD0 (MTK_PIN_NO(0) | 4) -#define MT8365_PIN_0_GPIO0__FUNC_CONN_MCU_TDO (MTK_PIN_NO(0) | 5) -#define MT8365_PIN_0_GPIO0__FUNC_DBG_MON_A0 (MTK_PIN_NO(0) | 7) - -#define MT8365_PIN_1_GPIO1__FUNC_GPIO1 (MTK_PIN_NO(1) | 0) -#define MT8365_PIN_1_GPIO1__FUNC_DPI_D1 (MTK_PIN_NO(1) | 1) -#define MT8365_PIN_1_GPIO1__FUNC_PWM_B (MTK_PIN_NO(1) | 2) -#define MT8365_PIN_1_GPIO1__FUNC_I2S2_LRCK (MTK_PIN_NO(1) | 3) -#define MT8365_PIN_1_GPIO1__FUNC_EXT_TXD1 (MTK_PIN_NO(1) | 4) -#define MT8365_PIN_1_GPIO1__FUNC_CONN_MCU_DBGACK_N (MTK_PIN_NO(1) | 5) -#define MT8365_PIN_1_GPIO1__FUNC_DBG_MON_A1 (MTK_PIN_NO(1) | 7) - -#define MT8365_PIN_2_GPIO2__FUNC_GPIO2 (MTK_PIN_NO(2) | 0) -#define MT8365_PIN_2_GPIO2__FUNC_DPI_D2 (MTK_PIN_NO(2) | 1) -#define MT8365_PIN_2_GPIO2__FUNC_PWM_C (MTK_PIN_NO(2) | 2) -#define MT8365_PIN_2_GPIO2__FUNC_I2S2_MCK (MTK_PIN_NO(2) | 3) -#define MT8365_PIN_2_GPIO2__FUNC_EXT_TXD2 (MTK_PIN_NO(2) | 4) -#define MT8365_PIN_2_GPIO2__FUNC_CONN_MCU_DBGI_N (MTK_PIN_NO(2) | 5) -#define MT8365_PIN_2_GPIO2__FUNC_DBG_MON_A2 (MTK_PIN_NO(2) | 7) - -#define MT8365_PIN_3_GPIO3__FUNC_GPIO3 (MTK_PIN_NO(3) | 0) -#define MT8365_PIN_3_GPIO3__FUNC_DPI_D3 (MTK_PIN_NO(3) | 1) -#define MT8365_PIN_3_GPIO3__FUNC_CLKM0 (MTK_PIN_NO(3) | 2) -#define MT8365_PIN_3_GPIO3__FUNC_I2S2_DI (MTK_PIN_NO(3) | 3) -#define MT8365_PIN_3_GPIO3__FUNC_EXT_TXD3 (MTK_PIN_NO(3) | 4) -#define MT8365_PIN_3_GPIO3__FUNC_CONN_MCU_TCK (MTK_PIN_NO(3) | 5) -#define MT8365_PIN_3_GPIO3__FUNC_CONN_MCU_AICE_TCKC (MTK_PIN_NO(3) | 6) -#define MT8365_PIN_3_GPIO3__FUNC_DBG_MON_A3 (MTK_PIN_NO(3) | 7) - -#define MT8365_PIN_4_GPIO4__FUNC_GPIO4 (MTK_PIN_NO(4) | 0) -#define MT8365_PIN_4_GPIO4__FUNC_DPI_D4 (MTK_PIN_NO(4) | 1) -#define MT8365_PIN_4_GPIO4__FUNC_CLKM1 (MTK_PIN_NO(4) | 2) -#define MT8365_PIN_4_GPIO4__FUNC_I2S1_BCK (MTK_PIN_NO(4) | 3) -#define MT8365_PIN_4_GPIO4__FUNC_EXT_TXC (MTK_PIN_NO(4) | 4) -#define MT8365_PIN_4_GPIO4__FUNC_CONN_MCU_TDI (MTK_PIN_NO(4) | 5) -#define MT8365_PIN_4_GPIO4__FUNC_VDEC_TEST_CK (MTK_PIN_NO(4) | 6) -#define MT8365_PIN_4_GPIO4__FUNC_DBG_MON_A4 (MTK_PIN_NO(4) | 7) - -#define MT8365_PIN_5_GPIO5__FUNC_GPIO5 (MTK_PIN_NO(5) | 0) -#define MT8365_PIN_5_GPIO5__FUNC_DPI_D5 (MTK_PIN_NO(5) | 1) -#define MT8365_PIN_5_GPIO5__FUNC_CLKM2 (MTK_PIN_NO(5) | 2) -#define MT8365_PIN_5_GPIO5__FUNC_I2S1_LRCK (MTK_PIN_NO(5) | 3) -#define MT8365_PIN_5_GPIO5__FUNC_EXT_RXER (MTK_PIN_NO(5) | 4) -#define MT8365_PIN_5_GPIO5__FUNC_CONN_MCU_TRST_B (MTK_PIN_NO(5) | 5) -#define MT8365_PIN_5_GPIO5__FUNC_MM_TEST_CK (MTK_PIN_NO(5) | 6) -#define MT8365_PIN_5_GPIO5__FUNC_DBG_MON_A5 (MTK_PIN_NO(5) | 7) - -#define MT8365_PIN_6_GPIO6__FUNC_GPIO6 (MTK_PIN_NO(6) | 0) -#define MT8365_PIN_6_GPIO6__FUNC_DPI_D6 (MTK_PIN_NO(6) | 1) -#define MT8365_PIN_6_GPIO6__FUNC_CLKM3 (MTK_PIN_NO(6) | 2) -#define MT8365_PIN_6_GPIO6__FUNC_I2S1_MCK (MTK_PIN_NO(6) | 3) -#define MT8365_PIN_6_GPIO6__FUNC_EXT_RXC (MTK_PIN_NO(6) | 4) -#define MT8365_PIN_6_GPIO6__FUNC_CONN_MCU_TMS (MTK_PIN_NO(6) | 5) -#define MT8365_PIN_6_GPIO6__FUNC_CONN_MCU_AICE_TMSC (MTK_PIN_NO(6) | 6) -#define MT8365_PIN_6_GPIO6__FUNC_DBG_MON_A6 (MTK_PIN_NO(6) | 7) - -#define MT8365_PIN_7_GPIO7__FUNC_GPIO7 (MTK_PIN_NO(7) | 0) -#define MT8365_PIN_7_GPIO7__FUNC_DPI_D7 (MTK_PIN_NO(7) | 1) -#define MT8365_PIN_7_GPIO7__FUNC_I2S1_DO (MTK_PIN_NO(7) | 3) -#define MT8365_PIN_7_GPIO7__FUNC_EXT_RXDV (MTK_PIN_NO(7) | 4) -#define MT8365_PIN_7_GPIO7__FUNC_CONN_DSP_JCK (MTK_PIN_NO(7) | 5) -#define MT8365_PIN_7_GPIO7__FUNC_DBG_MON_A7 (MTK_PIN_NO(7) | 7) - -#define MT8365_PIN_8_GPIO8__FUNC_GPIO8 (MTK_PIN_NO(8) | 0) -#define MT8365_PIN_8_GPIO8__FUNC_DPI_D8 (MTK_PIN_NO(8) | 1) -#define MT8365_PIN_8_GPIO8__FUNC_SPI_CLK (MTK_PIN_NO(8) | 2) -#define MT8365_PIN_8_GPIO8__FUNC_I2S0_BCK (MTK_PIN_NO(8) | 3) -#define MT8365_PIN_8_GPIO8__FUNC_EXT_RXD0 (MTK_PIN_NO(8) | 4) -#define MT8365_PIN_8_GPIO8__FUNC_CONN_DSP_JINTP (MTK_PIN_NO(8) | 5) -#define MT8365_PIN_8_GPIO8__FUNC_DBG_MON_A8 (MTK_PIN_NO(8) | 7) - -#define MT8365_PIN_9_GPIO9__FUNC_GPIO9 (MTK_PIN_NO(9) | 0) -#define MT8365_PIN_9_GPIO9__FUNC_DPI_D9 (MTK_PIN_NO(9) | 1) -#define MT8365_PIN_9_GPIO9__FUNC_SPI_CSB (MTK_PIN_NO(9) | 2) -#define MT8365_PIN_9_GPIO9__FUNC_I2S0_LRCK (MTK_PIN_NO(9) | 3) -#define MT8365_PIN_9_GPIO9__FUNC_EXT_RXD1 (MTK_PIN_NO(9) | 4) -#define MT8365_PIN_9_GPIO9__FUNC_CONN_DSP_JDI (MTK_PIN_NO(9) | 5) -#define MT8365_PIN_9_GPIO9__FUNC_DBG_MON_A9 (MTK_PIN_NO(9) | 7) - -#define MT8365_PIN_10_GPIO10__FUNC_GPIO10 (MTK_PIN_NO(10) | 0) -#define MT8365_PIN_10_GPIO10__FUNC_DPI_D10 (MTK_PIN_NO(10) | 1) -#define MT8365_PIN_10_GPIO10__FUNC_SPI_MI (MTK_PIN_NO(10) | 2) -#define MT8365_PIN_10_GPIO10__FUNC_I2S0_MCK (MTK_PIN_NO(10) | 3) -#define MT8365_PIN_10_GPIO10__FUNC_EXT_RXD2 (MTK_PIN_NO(10) | 4) -#define MT8365_PIN_10_GPIO10__FUNC_CONN_DSP_JMS (MTK_PIN_NO(10) | 5) -#define MT8365_PIN_10_GPIO10__FUNC_DBG_MON_A10 (MTK_PIN_NO(10) | 7) - -#define MT8365_PIN_11_GPIO11__FUNC_GPIO11 (MTK_PIN_NO(11) | 0) -#define MT8365_PIN_11_GPIO11__FUNC_DPI_D11 (MTK_PIN_NO(11) | 1) -#define MT8365_PIN_11_GPIO11__FUNC_SPI_MO (MTK_PIN_NO(11) | 2) -#define MT8365_PIN_11_GPIO11__FUNC_I2S0_DI (MTK_PIN_NO(11) | 3) -#define MT8365_PIN_11_GPIO11__FUNC_EXT_RXD3 (MTK_PIN_NO(11) | 4) -#define MT8365_PIN_11_GPIO11__FUNC_CONN_DSP_JDO (MTK_PIN_NO(11) | 5) -#define MT8365_PIN_11_GPIO11__FUNC_DBG_MON_A11 (MTK_PIN_NO(11) | 7) - -#define MT8365_PIN_12_GPIO12__FUNC_GPIO12 (MTK_PIN_NO(12) | 0) -#define MT8365_PIN_12_GPIO12__FUNC_DPI_DE (MTK_PIN_NO(12) | 1) -#define MT8365_PIN_12_GPIO12__FUNC_UCTS1 (MTK_PIN_NO(12) | 2) -#define MT8365_PIN_12_GPIO12__FUNC_I2S3_BCK (MTK_PIN_NO(12) | 3) -#define MT8365_PIN_12_GPIO12__FUNC_EXT_TXEN (MTK_PIN_NO(12) | 4) -#define MT8365_PIN_12_GPIO12__FUNC_O_WIFI_TXD (MTK_PIN_NO(12) | 5) -#define MT8365_PIN_12_GPIO12__FUNC_DBG_MON_A12 (MTK_PIN_NO(12) | 7) - -#define MT8365_PIN_13_GPIO13__FUNC_GPIO13 (MTK_PIN_NO(13) | 0) -#define MT8365_PIN_13_GPIO13__FUNC_DPI_VSYNC (MTK_PIN_NO(13) | 1) -#define MT8365_PIN_13_GPIO13__FUNC_URTS1 (MTK_PIN_NO(13) | 2) -#define MT8365_PIN_13_GPIO13__FUNC_I2S3_LRCK (MTK_PIN_NO(13) | 3) -#define MT8365_PIN_13_GPIO13__FUNC_EXT_COL (MTK_PIN_NO(13) | 4) -#define MT8365_PIN_13_GPIO13__FUNC_SPDIF_IN (MTK_PIN_NO(13) | 5) -#define MT8365_PIN_13_GPIO13__FUNC_DBG_MON_A13 (MTK_PIN_NO(13) | 7) - -#define MT8365_PIN_14_GPIO14__FUNC_GPIO14 (MTK_PIN_NO(14) | 0) -#define MT8365_PIN_14_GPIO14__FUNC_DPI_CK (MTK_PIN_NO(14) | 1) -#define MT8365_PIN_14_GPIO14__FUNC_UCTS2 (MTK_PIN_NO(14) | 2) -#define MT8365_PIN_14_GPIO14__FUNC_I2S3_MCK (MTK_PIN_NO(14) | 3) -#define MT8365_PIN_14_GPIO14__FUNC_EXT_MDIO (MTK_PIN_NO(14) | 4) -#define MT8365_PIN_14_GPIO14__FUNC_SPDIF_OUT (MTK_PIN_NO(14) | 5) -#define MT8365_PIN_14_GPIO14__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(14) | 6) -#define MT8365_PIN_14_GPIO14__FUNC_DBG_MON_A14 (MTK_PIN_NO(14) | 7) - -#define MT8365_PIN_15_GPIO15__FUNC_GPIO15 (MTK_PIN_NO(15) | 0) -#define MT8365_PIN_15_GPIO15__FUNC_DPI_HSYNC (MTK_PIN_NO(15) | 1) -#define MT8365_PIN_15_GPIO15__FUNC_URTS2 (MTK_PIN_NO(15) | 2) -#define MT8365_PIN_15_GPIO15__FUNC_I2S3_DO (MTK_PIN_NO(15) | 3) -#define MT8365_PIN_15_GPIO15__FUNC_EXT_MDC (MTK_PIN_NO(15) | 4) -#define MT8365_PIN_15_GPIO15__FUNC_IRRX (MTK_PIN_NO(15) | 5) -#define MT8365_PIN_15_GPIO15__FUNC_EXT_FRAME_SYNC (MTK_PIN_NO(15) | 6) -#define MT8365_PIN_15_GPIO15__FUNC_DBG_MON_A15 (MTK_PIN_NO(15) | 7) - -#define MT8365_PIN_16_GPIO16__FUNC_GPIO16 (MTK_PIN_NO(16) | 0) -#define MT8365_PIN_16_GPIO16__FUNC_DPI_D12 (MTK_PIN_NO(16) | 1) -#define MT8365_PIN_16_GPIO16__FUNC_USB_DRVVBUS (MTK_PIN_NO(16) | 2) -#define MT8365_PIN_16_GPIO16__FUNC_PWM_A (MTK_PIN_NO(16) | 3) -#define MT8365_PIN_16_GPIO16__FUNC_CLKM0 (MTK_PIN_NO(16) | 4) -#define MT8365_PIN_16_GPIO16__FUNC_ANT_SEL0 (MTK_PIN_NO(16) | 5) -#define MT8365_PIN_16_GPIO16__FUNC_TSF_IN (MTK_PIN_NO(16) | 6) -#define MT8365_PIN_16_GPIO16__FUNC_DBG_MON_A16 (MTK_PIN_NO(16) | 7) - -#define MT8365_PIN_17_GPIO17__FUNC_GPIO17 (MTK_PIN_NO(17) | 0) -#define MT8365_PIN_17_GPIO17__FUNC_DPI_D13 (MTK_PIN_NO(17) | 1) -#define MT8365_PIN_17_GPIO17__FUNC_IDDIG (MTK_PIN_NO(17) | 2) -#define MT8365_PIN_17_GPIO17__FUNC_PWM_B (MTK_PIN_NO(17) | 3) -#define MT8365_PIN_17_GPIO17__FUNC_CLKM1 (MTK_PIN_NO(17) | 4) -#define MT8365_PIN_17_GPIO17__FUNC_ANT_SEL1 (MTK_PIN_NO(17) | 5) -#define MT8365_PIN_17_GPIO17__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(17) | 6) -#define MT8365_PIN_17_GPIO17__FUNC_DBG_MON_A17 (MTK_PIN_NO(17) | 7) - -#define MT8365_PIN_18_GPIO18__FUNC_GPIO18 (MTK_PIN_NO(18) | 0) -#define MT8365_PIN_18_GPIO18__FUNC_DPI_D14 (MTK_PIN_NO(18) | 1) -#define MT8365_PIN_18_GPIO18__FUNC_EXT_FRAME_SYNC (MTK_PIN_NO(18) | 2) -#define MT8365_PIN_18_GPIO18__FUNC_PWM_C (MTK_PIN_NO(18) | 3) -#define MT8365_PIN_18_GPIO18__FUNC_CLKM2 (MTK_PIN_NO(18) | 4) -#define MT8365_PIN_18_GPIO18__FUNC_ANT_SEL2 (MTK_PIN_NO(18) | 5) -#define MT8365_PIN_18_GPIO18__FUNC_MFG_TEST_CK (MTK_PIN_NO(18) | 6) -#define MT8365_PIN_18_GPIO18__FUNC_DBG_MON_A18 (MTK_PIN_NO(18) | 7) - -#define MT8365_PIN_19_DISP_PWM__FUNC_GPIO19 (MTK_PIN_NO(19) | 0) -#define MT8365_PIN_19_DISP_PWM__FUNC_DISP_PWM (MTK_PIN_NO(19) | 1) -#define MT8365_PIN_19_DISP_PWM__FUNC_PWM_A (MTK_PIN_NO(19) | 2) -#define MT8365_PIN_19_DISP_PWM__FUNC_DBG_MON_A19 (MTK_PIN_NO(19) | 7) - -#define MT8365_PIN_20_LCM_RST__FUNC_GPIO20 (MTK_PIN_NO(20) | 0) -#define MT8365_PIN_20_LCM_RST__FUNC_LCM_RST (MTK_PIN_NO(20) | 1) -#define MT8365_PIN_20_LCM_RST__FUNC_PWM_B (MTK_PIN_NO(20) | 2) -#define MT8365_PIN_20_LCM_RST__FUNC_DBG_MON_A20 (MTK_PIN_NO(20) | 7) - -#define MT8365_PIN_21_DSI_TE__FUNC_GPIO21 (MTK_PIN_NO(21) | 0) -#define MT8365_PIN_21_DSI_TE__FUNC_DSI_TE (MTK_PIN_NO(21) | 1) -#define MT8365_PIN_21_DSI_TE__FUNC_PWM_C (MTK_PIN_NO(21) | 2) -#define MT8365_PIN_21_DSI_TE__FUNC_ANT_SEL0 (MTK_PIN_NO(21) | 3) -#define MT8365_PIN_21_DSI_TE__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(21) | 4) -#define MT8365_PIN_21_DSI_TE__FUNC_DBG_MON_A21 (MTK_PIN_NO(21) | 7) - -#define MT8365_PIN_22_KPROW0__FUNC_GPIO22 (MTK_PIN_NO(22) | 0) -#define MT8365_PIN_22_KPROW0__FUNC_KPROW0 (MTK_PIN_NO(22) | 1) -#define MT8365_PIN_22_KPROW0__FUNC_DBG_MON_A22 (MTK_PIN_NO(22) | 7) - -#define MT8365_PIN_23_KPROW1__FUNC_GPIO23 (MTK_PIN_NO(23) | 0) -#define MT8365_PIN_23_KPROW1__FUNC_KPROW1 (MTK_PIN_NO(23) | 1) -#define MT8365_PIN_23_KPROW1__FUNC_IDDIG (MTK_PIN_NO(23) | 2) -#define MT8365_PIN_23_KPROW1__FUNC_WIFI_TXD (MTK_PIN_NO(23) | 3) -#define MT8365_PIN_23_KPROW1__FUNC_CLKM3 (MTK_PIN_NO(23) | 4) -#define MT8365_PIN_23_KPROW1__FUNC_ANT_SEL1 (MTK_PIN_NO(23) | 5) -#define MT8365_PIN_23_KPROW1__FUNC_EXT_FRAME_SYNC (MTK_PIN_NO(23) | 6) -#define MT8365_PIN_23_KPROW1__FUNC_DBG_MON_B0 (MTK_PIN_NO(23) | 7) - -#define MT8365_PIN_24_KPCOL0__FUNC_GPIO24 (MTK_PIN_NO(24) | 0) -#define MT8365_PIN_24_KPCOL0__FUNC_KPCOL0 (MTK_PIN_NO(24) | 1) -#define MT8365_PIN_24_KPCOL0__FUNC_DBG_MON_A23 (MTK_PIN_NO(24) | 7) - -#define MT8365_PIN_25_KPCOL1__FUNC_GPIO25 (MTK_PIN_NO(25) | 0) -#define MT8365_PIN_25_KPCOL1__FUNC_KPCOL1 (MTK_PIN_NO(25) | 1) -#define MT8365_PIN_25_KPCOL1__FUNC_USB_DRVVBUS (MTK_PIN_NO(25) | 2) -#define MT8365_PIN_25_KPCOL1__FUNC_APU_JTAG_TRST (MTK_PIN_NO(25) | 3) -#define MT8365_PIN_25_KPCOL1__FUNC_UDI_NTRST_XI (MTK_PIN_NO(25) | 4) -#define MT8365_PIN_25_KPCOL1__FUNC_DFD_NTRST_XI (MTK_PIN_NO(25) | 5) -#define MT8365_PIN_25_KPCOL1__FUNC_CONN_TEST_CK (MTK_PIN_NO(25) | 6) -#define MT8365_PIN_25_KPCOL1__FUNC_DBG_MON_B1 (MTK_PIN_NO(25) | 7) - -#define MT8365_PIN_26_SPI_CS__FUNC_GPIO26 (MTK_PIN_NO(26) | 0) -#define MT8365_PIN_26_SPI_CS__FUNC_SPI_CSB (MTK_PIN_NO(26) | 1) -#define MT8365_PIN_26_SPI_CS__FUNC_APU_JTAG_TMS (MTK_PIN_NO(26) | 3) -#define MT8365_PIN_26_SPI_CS__FUNC_UDI_TMS_XI (MTK_PIN_NO(26) | 4) -#define MT8365_PIN_26_SPI_CS__FUNC_DFD_TMS_XI (MTK_PIN_NO(26) | 5) -#define MT8365_PIN_26_SPI_CS__FUNC_CONN_TEST_CK (MTK_PIN_NO(26) | 6) -#define MT8365_PIN_26_SPI_CS__FUNC_DBG_MON_A24 (MTK_PIN_NO(26) | 7) - -#define MT8365_PIN_27_SPI_CK__FUNC_GPIO27 (MTK_PIN_NO(27) | 0) -#define MT8365_PIN_27_SPI_CK__FUNC_SPI_CLK (MTK_PIN_NO(27) | 1) -#define MT8365_PIN_27_SPI_CK__FUNC_APU_JTAG_TCK (MTK_PIN_NO(27) | 3) -#define MT8365_PIN_27_SPI_CK__FUNC_UDI_TCK_XI (MTK_PIN_NO(27) | 4) -#define MT8365_PIN_27_SPI_CK__FUNC_DFD_TCK_XI (MTK_PIN_NO(27) | 5) -#define MT8365_PIN_27_SPI_CK__FUNC_APU_TEST_CK (MTK_PIN_NO(27) | 6) -#define MT8365_PIN_27_SPI_CK__FUNC_DBG_MON_A25 (MTK_PIN_NO(27) | 7) - -#define MT8365_PIN_28_SPI_MI__FUNC_GPIO28 (MTK_PIN_NO(28) | 0) -#define MT8365_PIN_28_SPI_MI__FUNC_SPI_MI (MTK_PIN_NO(28) | 1) -#define MT8365_PIN_28_SPI_MI__FUNC_SPI_MO (MTK_PIN_NO(28) | 2) -#define MT8365_PIN_28_SPI_MI__FUNC_APU_JTAG_TDI (MTK_PIN_NO(28) | 3) -#define MT8365_PIN_28_SPI_MI__FUNC_UDI_TDI_XI (MTK_PIN_NO(28) | 4) -#define MT8365_PIN_28_SPI_MI__FUNC_DFD_TDI_XI (MTK_PIN_NO(28) | 5) -#define MT8365_PIN_28_SPI_MI__FUNC_DSP_TEST_CK (MTK_PIN_NO(28) | 6) -#define MT8365_PIN_28_SPI_MI__FUNC_DBG_MON_A26 (MTK_PIN_NO(28) | 7) - -#define MT8365_PIN_29_SPI_MO__FUNC_GPIO29 (MTK_PIN_NO(29) | 0) -#define MT8365_PIN_29_SPI_MO__FUNC_SPI_MO (MTK_PIN_NO(29) | 1) -#define MT8365_PIN_29_SPI_MO__FUNC_SPI_MI (MTK_PIN_NO(29) | 2) -#define MT8365_PIN_29_SPI_MO__FUNC_APU_JTAG_TDO (MTK_PIN_NO(29) | 3) -#define MT8365_PIN_29_SPI_MO__FUNC_UDI_TDO (MTK_PIN_NO(29) | 4) -#define MT8365_PIN_29_SPI_MO__FUNC_DFD_TDO (MTK_PIN_NO(29) | 5) -#define MT8365_PIN_29_SPI_MO__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(29) | 6) -#define MT8365_PIN_29_SPI_MO__FUNC_DBG_MON_A27 (MTK_PIN_NO(29) | 7) - -#define MT8365_PIN_30_JTMS__FUNC_GPIO30 (MTK_PIN_NO(30) | 0) -#define MT8365_PIN_30_JTMS__FUNC_JTMS (MTK_PIN_NO(30) | 1) -#define MT8365_PIN_30_JTMS__FUNC_DFD_TMS_XI (MTK_PIN_NO(30) | 2) -#define MT8365_PIN_30_JTMS__FUNC_UDI_TMS_XI (MTK_PIN_NO(30) | 3) -#define MT8365_PIN_30_JTMS__FUNC_MCU_SPM_TMS (MTK_PIN_NO(30) | 4) -#define MT8365_PIN_30_JTMS__FUNC_CONN_MCU_TMS (MTK_PIN_NO(30) | 5) -#define MT8365_PIN_30_JTMS__FUNC_CONN_MCU_AICE_TMSC (MTK_PIN_NO(30) | 6) - -#define MT8365_PIN_31_JTCK__FUNC_GPIO31 (MTK_PIN_NO(31) | 0) -#define MT8365_PIN_31_JTCK__FUNC_JTCK (MTK_PIN_NO(31) | 1) -#define MT8365_PIN_31_JTCK__FUNC_DFD_TCK_XI (MTK_PIN_NO(31) | 2) -#define MT8365_PIN_31_JTCK__FUNC_UDI_TCK_XI (MTK_PIN_NO(31) | 3) -#define MT8365_PIN_31_JTCK__FUNC_MCU_SPM_TCK (MTK_PIN_NO(31) | 4) -#define MT8365_PIN_31_JTCK__FUNC_CONN_MCU_TCK (MTK_PIN_NO(31) | 5) -#define MT8365_PIN_31_JTCK__FUNC_CONN_MCU_AICE_TCKC (MTK_PIN_NO(31) | 6) - -#define MT8365_PIN_32_JTDI__FUNC_GPIO32 (MTK_PIN_NO(32) | 0) -#define MT8365_PIN_32_JTDI__FUNC_JTDI (MTK_PIN_NO(32) | 1) -#define MT8365_PIN_32_JTDI__FUNC_DFD_TDI_XI (MTK_PIN_NO(32) | 2) -#define MT8365_PIN_32_JTDI__FUNC_UDI_TDI_XI (MTK_PIN_NO(32) | 3) -#define MT8365_PIN_32_JTDI__FUNC_MCU_SPM_TDI (MTK_PIN_NO(32) | 4) -#define MT8365_PIN_32_JTDI__FUNC_CONN_MCU_TDI (MTK_PIN_NO(32) | 5) - -#define MT8365_PIN_33_JTDO__FUNC_GPIO33 (MTK_PIN_NO(33) | 0) -#define MT8365_PIN_33_JTDO__FUNC_JTDO (MTK_PIN_NO(33) | 1) -#define MT8365_PIN_33_JTDO__FUNC_DFD_TDO (MTK_PIN_NO(33) | 2) -#define MT8365_PIN_33_JTDO__FUNC_UDI_TDO (MTK_PIN_NO(33) | 3) -#define MT8365_PIN_33_JTDO__FUNC_MCU_SPM_TDO (MTK_PIN_NO(33) | 4) -#define MT8365_PIN_33_JTDO__FUNC_CONN_MCU_TDO (MTK_PIN_NO(33) | 5) - -#define MT8365_PIN_34_JTRST__FUNC_GPIO34 (MTK_PIN_NO(34) | 0) -#define MT8365_PIN_34_JTRST__FUNC_JTRST (MTK_PIN_NO(34) | 1) -#define MT8365_PIN_34_JTRST__FUNC_DFD_NTRST_XI (MTK_PIN_NO(34) | 2) -#define MT8365_PIN_34_JTRST__FUNC_UDI_NTRST_XI (MTK_PIN_NO(34) | 3) -#define MT8365_PIN_34_JTRST__FUNC_MCU_SPM_NTRST (MTK_PIN_NO(34) | 4) -#define MT8365_PIN_34_JTRST__FUNC_CONN_MCU_TRST_B (MTK_PIN_NO(34) | 5) - -#define MT8365_PIN_35_URXD0__FUNC_GPIO35 (MTK_PIN_NO(35) | 0) -#define MT8365_PIN_35_URXD0__FUNC_URXD0 (MTK_PIN_NO(35) | 1) -#define MT8365_PIN_35_URXD0__FUNC_UTXD0 (MTK_PIN_NO(35) | 2) -#define MT8365_PIN_35_URXD0__FUNC_DSP_URXD0 (MTK_PIN_NO(35) | 7) - -#define MT8365_PIN_36_UTXD0__FUNC_GPIO36 (MTK_PIN_NO(36) | 0) -#define MT8365_PIN_36_UTXD0__FUNC_UTXD0 (MTK_PIN_NO(36) | 1) -#define MT8365_PIN_36_UTXD0__FUNC_URXD0 (MTK_PIN_NO(36) | 2) -#define MT8365_PIN_36_UTXD0__FUNC_DSP_UTXD0 (MTK_PIN_NO(36) | 7) - -#define MT8365_PIN_37_URXD1__FUNC_GPIO37 (MTK_PIN_NO(37) | 0) -#define MT8365_PIN_37_URXD1__FUNC_URXD1 (MTK_PIN_NO(37) | 1) -#define MT8365_PIN_37_URXD1__FUNC_UTXD1 (MTK_PIN_NO(37) | 2) -#define MT8365_PIN_37_URXD1__FUNC_UCTS2 (MTK_PIN_NO(37) | 3) -#define MT8365_PIN_37_URXD1__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(37) | 4) -#define MT8365_PIN_37_URXD1__FUNC_CONN_UART0_RXD (MTK_PIN_NO(37) | 5) -#define MT8365_PIN_37_URXD1__FUNC_I2S0_MCK (MTK_PIN_NO(37) | 6) -#define MT8365_PIN_37_URXD1__FUNC_DSP_URXD0 (MTK_PIN_NO(37) | 7) - -#define MT8365_PIN_38_UTXD1__FUNC_GPIO38 (MTK_PIN_NO(38) | 0) -#define MT8365_PIN_38_UTXD1__FUNC_UTXD1 (MTK_PIN_NO(38) | 1) -#define MT8365_PIN_38_UTXD1__FUNC_URXD1 (MTK_PIN_NO(38) | 2) -#define MT8365_PIN_38_UTXD1__FUNC_URTS2 (MTK_PIN_NO(38) | 3) -#define MT8365_PIN_38_UTXD1__FUNC_ANT_SEL2 (MTK_PIN_NO(38) | 4) -#define MT8365_PIN_38_UTXD1__FUNC_CONN_UART0_TXD (MTK_PIN_NO(38) | 5) -#define MT8365_PIN_38_UTXD1__FUNC_I2S1_MCK (MTK_PIN_NO(38) | 6) -#define MT8365_PIN_38_UTXD1__FUNC_DSP_UTXD0 (MTK_PIN_NO(38) | 7) - -#define MT8365_PIN_39_URXD2__FUNC_GPIO39 (MTK_PIN_NO(39) | 0) -#define MT8365_PIN_39_URXD2__FUNC_URXD2 (MTK_PIN_NO(39) | 1) -#define MT8365_PIN_39_URXD2__FUNC_UTXD2 (MTK_PIN_NO(39) | 2) -#define MT8365_PIN_39_URXD2__FUNC_UCTS1 (MTK_PIN_NO(39) | 3) -#define MT8365_PIN_39_URXD2__FUNC_IDDIG (MTK_PIN_NO(39) | 4) -#define MT8365_PIN_39_URXD2__FUNC_CONN_MCU_DBGACK_N (MTK_PIN_NO(39) | 5) -#define MT8365_PIN_39_URXD2__FUNC_I2S2_MCK (MTK_PIN_NO(39) | 6) -#define MT8365_PIN_39_URXD2__FUNC_DSP_URXD0 (MTK_PIN_NO(39) | 7) - -#define MT8365_PIN_40_UTXD2__FUNC_GPIO40 (MTK_PIN_NO(40) | 0) -#define MT8365_PIN_40_UTXD2__FUNC_UTXD2 (MTK_PIN_NO(40) | 1) -#define MT8365_PIN_40_UTXD2__FUNC_URXD2 (MTK_PIN_NO(40) | 2) -#define MT8365_PIN_40_UTXD2__FUNC_URTS1 (MTK_PIN_NO(40) | 3) -#define MT8365_PIN_40_UTXD2__FUNC_USB_DRVVBUS (MTK_PIN_NO(40) | 4) -#define MT8365_PIN_40_UTXD2__FUNC_CONN_MCU_DBGI_N (MTK_PIN_NO(40) | 5) -#define MT8365_PIN_40_UTXD2__FUNC_I2S3_MCK (MTK_PIN_NO(40) | 6) -#define MT8365_PIN_40_UTXD2__FUNC_DSP_UTXD0 (MTK_PIN_NO(40) | 7) - -#define MT8365_PIN_41_PWRAP_SPI0_MI__FUNC_GPIO41 (MTK_PIN_NO(41) | 0) -#define MT8365_PIN_41_PWRAP_SPI0_MI__FUNC_PWRAP_SPI0_MI (MTK_PIN_NO(41) | 1) -#define MT8365_PIN_41_PWRAP_SPI0_MI__FUNC_PWRAP_SPI0_MO (MTK_PIN_NO(41) | 2) - -#define MT8365_PIN_42_PWRAP_SPI0_MO__FUNC_GPIO42 (MTK_PIN_NO(42) | 0) -#define MT8365_PIN_42_PWRAP_SPI0_MO__FUNC_PWRAP_SPI0_MO (MTK_PIN_NO(42) | 1) -#define MT8365_PIN_42_PWRAP_SPI0_MO__FUNC_PWRAP_SPI0_MI (MTK_PIN_NO(42) | 2) - -#define MT8365_PIN_43_PWRAP_SPI0_CK__FUNC_GPIO43 (MTK_PIN_NO(43) | 0) -#define MT8365_PIN_43_PWRAP_SPI0_CK__FUNC_PWRAP_SPI0_CK (MTK_PIN_NO(43) | 1) - -#define MT8365_PIN_44_PWRAP_SPI0_CSN__FUNC_GPIO44 (MTK_PIN_NO(44) | 0) -#define MT8365_PIN_44_PWRAP_SPI0_CSN__FUNC_PWRAP_SPI0_CSN (MTK_PIN_NO(44) | 1) - -#define MT8365_PIN_45_RTC32K_CK__FUNC_GPIO45 (MTK_PIN_NO(45) | 0) -#define MT8365_PIN_45_RTC32K_CK__FUNC_RTC32K_CK (MTK_PIN_NO(45) | 1) - -#define MT8365_PIN_46_WATCHDOG__FUNC_GPIO46 (MTK_PIN_NO(46) | 0) -#define MT8365_PIN_46_WATCHDOG__FUNC_WATCHDOG (MTK_PIN_NO(46) | 1) - -#define MT8365_PIN_47_SRCLKENA0__FUNC_GPIO47 (MTK_PIN_NO(47) | 0) -#define MT8365_PIN_47_SRCLKENA0__FUNC_SRCLKENA0 (MTK_PIN_NO(47) | 1) -#define MT8365_PIN_47_SRCLKENA0__FUNC_SRCLKENA1 (MTK_PIN_NO(47) | 2) - -#define MT8365_PIN_48_SRCLKENA1__FUNC_GPIO48 (MTK_PIN_NO(48) | 0) -#define MT8365_PIN_48_SRCLKENA1__FUNC_SRCLKENA1 (MTK_PIN_NO(48) | 1) - -#define MT8365_PIN_49_AUD_CLK_MOSI__FUNC_GPIO49 (MTK_PIN_NO(49) | 0) -#define MT8365_PIN_49_AUD_CLK_MOSI__FUNC_AUD_CLK_MOSI (MTK_PIN_NO(49) | 1) -#define MT8365_PIN_49_AUD_CLK_MOSI__FUNC_AUD_CLK_MISO (MTK_PIN_NO(49) | 2) -#define MT8365_PIN_49_AUD_CLK_MOSI__FUNC_I2S1_MCK (MTK_PIN_NO(49) | 3) - -#define MT8365_PIN_50_AUD_SYNC_MOSI__FUNC_GPIO50 (MTK_PIN_NO(50) | 0) -#define MT8365_PIN_50_AUD_SYNC_MOSI__FUNC_AUD_SYNC_MOSI (MTK_PIN_NO(50) | 1) -#define MT8365_PIN_50_AUD_SYNC_MOSI__FUNC_AUD_SYNC_MISO (MTK_PIN_NO(50) | 2) -#define MT8365_PIN_50_AUD_SYNC_MOSI__FUNC_I2S1_BCK (MTK_PIN_NO(50) | 3) - -#define MT8365_PIN_51_AUD_DAT_MOSI0__FUNC_GPIO51 (MTK_PIN_NO(51) | 0) -#define MT8365_PIN_51_AUD_DAT_MOSI0__FUNC_AUD_DAT_MOSI0 (MTK_PIN_NO(51) | 1) -#define MT8365_PIN_51_AUD_DAT_MOSI0__FUNC_AUD_DAT_MISO0 (MTK_PIN_NO(51) | 2) -#define MT8365_PIN_51_AUD_DAT_MOSI0__FUNC_I2S1_LRCK (MTK_PIN_NO(51) | 3) - -#define MT8365_PIN_52_AUD_DAT_MOSI1__FUNC_GPIO52 (MTK_PIN_NO(52) | 0) -#define MT8365_PIN_52_AUD_DAT_MOSI1__FUNC_AUD_DAT_MOSI1 (MTK_PIN_NO(52) | 1) -#define MT8365_PIN_52_AUD_DAT_MOSI1__FUNC_AUD_DAT_MISO1 (MTK_PIN_NO(52) | 2) -#define MT8365_PIN_52_AUD_DAT_MOSI1__FUNC_I2S1_DO (MTK_PIN_NO(52) | 3) - -#define MT8365_PIN_53_AUD_CLK_MISO__FUNC_GPIO53 (MTK_PIN_NO(53) | 0) -#define MT8365_PIN_53_AUD_CLK_MISO__FUNC_AUD_CLK_MISO (MTK_PIN_NO(53) | 1) -#define MT8365_PIN_53_AUD_CLK_MISO__FUNC_AUD_CLK_MOSI (MTK_PIN_NO(53) | 2) -#define MT8365_PIN_53_AUD_CLK_MISO__FUNC_I2S2_MCK (MTK_PIN_NO(53) | 3) - -#define MT8365_PIN_54_AUD_SYNC_MISO__FUNC_GPIO54 (MTK_PIN_NO(54) | 0) -#define MT8365_PIN_54_AUD_SYNC_MISO__FUNC_AUD_SYNC_MISO (MTK_PIN_NO(54) | 1) -#define MT8365_PIN_54_AUD_SYNC_MISO__FUNC_AUD_SYNC_MOSI (MTK_PIN_NO(54) | 2) -#define MT8365_PIN_54_AUD_SYNC_MISO__FUNC_I2S2_BCK (MTK_PIN_NO(54) | 3) - -#define MT8365_PIN_55_AUD_DAT_MISO0__FUNC_GPIO55 (MTK_PIN_NO(55) | 0) -#define MT8365_PIN_55_AUD_DAT_MISO0__FUNC_AUD_DAT_MISO0 (MTK_PIN_NO(55) | 1) -#define MT8365_PIN_55_AUD_DAT_MISO0__FUNC_AUD_DAT_MOSI0 (MTK_PIN_NO(55) | 2) -#define MT8365_PIN_55_AUD_DAT_MISO0__FUNC_I2S2_LRCK (MTK_PIN_NO(55) | 3) - -#define MT8365_PIN_56_AUD_DAT_MISO1__FUNC_GPIO56 (MTK_PIN_NO(56) | 0) -#define MT8365_PIN_56_AUD_DAT_MISO1__FUNC_AUD_DAT_MISO1 (MTK_PIN_NO(56) | 1) -#define MT8365_PIN_56_AUD_DAT_MISO1__FUNC_AUD_DAT_MOSI1 (MTK_PIN_NO(56) | 2) -#define MT8365_PIN_56_AUD_DAT_MISO1__FUNC_I2S2_DI (MTK_PIN_NO(56) | 3) - -#define MT8365_PIN_57_SDA0__FUNC_GPIO57 (MTK_PIN_NO(57) | 0) -#define MT8365_PIN_57_SDA0__FUNC_SDA0_0 (MTK_PIN_NO(57) | 1) - -#define MT8365_PIN_58_SCL0__FUNC_GPIO58 (MTK_PIN_NO(58) | 0) -#define MT8365_PIN_58_SCL0__FUNC_SCL0_0 (MTK_PIN_NO(58) | 1) - -#define MT8365_PIN_59_SDA1__FUNC_GPIO59 (MTK_PIN_NO(59) | 0) -#define MT8365_PIN_59_SDA1__FUNC_SDA1_0 (MTK_PIN_NO(59) | 1) -#define MT8365_PIN_59_SDA1__FUNC_USB_SDA (MTK_PIN_NO(59) | 6) -#define MT8365_PIN_59_SDA1__FUNC_DBG_SDA (MTK_PIN_NO(59) | 7) - -#define MT8365_PIN_60_SCL1__FUNC_GPIO60 (MTK_PIN_NO(60) | 0) -#define MT8365_PIN_60_SCL1__FUNC_SCL1_0 (MTK_PIN_NO(60) | 1) -#define MT8365_PIN_60_SCL1__FUNC_USB_SCL (MTK_PIN_NO(60) | 6) -#define MT8365_PIN_60_SCL1__FUNC_DBG_SCL (MTK_PIN_NO(60) | 7) - -#define MT8365_PIN_61_SDA2__FUNC_GPIO61 (MTK_PIN_NO(61) | 0) -#define MT8365_PIN_61_SDA2__FUNC_SDA2_0 (MTK_PIN_NO(61) | 1) - -#define MT8365_PIN_62_SCL2__FUNC_GPIO62 (MTK_PIN_NO(62) | 0) -#define MT8365_PIN_62_SCL2__FUNC_SCL2_0 (MTK_PIN_NO(62) | 1) - -#define MT8365_PIN_63_SDA3__FUNC_GPIO63 (MTK_PIN_NO(63) | 0) -#define MT8365_PIN_63_SDA3__FUNC_SDA3_0 (MTK_PIN_NO(63) | 1) - -#define MT8365_PIN_64_SCL3__FUNC_GPIO64 (MTK_PIN_NO(64) | 0) -#define MT8365_PIN_64_SCL3__FUNC_SCL3_0 (MTK_PIN_NO(64) | 1) - -#define MT8365_PIN_65_CMMCLK0__FUNC_GPIO65 (MTK_PIN_NO(65) | 0) -#define MT8365_PIN_65_CMMCLK0__FUNC_CMMCLK0 (MTK_PIN_NO(65) | 1) -#define MT8365_PIN_65_CMMCLK0__FUNC_CMMCLK1 (MTK_PIN_NO(65) | 2) -#define MT8365_PIN_65_CMMCLK0__FUNC_DBG_MON_A28 (MTK_PIN_NO(65) | 7) - -#define MT8365_PIN_66_CMMCLK1__FUNC_GPIO66 (MTK_PIN_NO(66) | 0) -#define MT8365_PIN_66_CMMCLK1__FUNC_CMMCLK1 (MTK_PIN_NO(66) | 1) -#define MT8365_PIN_66_CMMCLK1__FUNC_CMMCLK0 (MTK_PIN_NO(66) | 2) -#define MT8365_PIN_66_CMMCLK1__FUNC_DBG_MON_B2 (MTK_PIN_NO(66) | 7) - -#define MT8365_PIN_67_CMPCLK__FUNC_GPIO67 (MTK_PIN_NO(67) | 0) -#define MT8365_PIN_67_CMPCLK__FUNC_CMPCLK (MTK_PIN_NO(67) | 1) -#define MT8365_PIN_67_CMPCLK__FUNC_ANT_SEL0 (MTK_PIN_NO(67) | 2) -#define MT8365_PIN_67_CMPCLK__FUNC_TDM_RX_BCK (MTK_PIN_NO(67) | 4) -#define MT8365_PIN_67_CMPCLK__FUNC_I2S0_BCK (MTK_PIN_NO(67) | 5) -#define MT8365_PIN_67_CMPCLK__FUNC_DBG_MON_B3 (MTK_PIN_NO(67) | 7) - -#define MT8365_PIN_68_CMDAT0__FUNC_GPIO68 (MTK_PIN_NO(68) | 0) -#define MT8365_PIN_68_CMDAT0__FUNC_CMDAT0 (MTK_PIN_NO(68) | 1) -#define MT8365_PIN_68_CMDAT0__FUNC_ANT_SEL1 (MTK_PIN_NO(68) | 2) -#define MT8365_PIN_68_CMDAT0__FUNC_TDM_RX_LRCK (MTK_PIN_NO(68) | 4) -#define MT8365_PIN_68_CMDAT0__FUNC_I2S0_LRCK (MTK_PIN_NO(68) | 5) -#define MT8365_PIN_68_CMDAT0__FUNC_DBG_MON_B4 (MTK_PIN_NO(68) | 7) - -#define MT8365_PIN_69_CMDAT1__FUNC_GPIO69 (MTK_PIN_NO(69) | 0) -#define MT8365_PIN_69_CMDAT1__FUNC_CMDAT1 (MTK_PIN_NO(69) | 1) -#define MT8365_PIN_69_CMDAT1__FUNC_ANT_SEL2 (MTK_PIN_NO(69) | 2) -#define MT8365_PIN_69_CMDAT1__FUNC_DVFSRC_EXT_REQ (MTK_PIN_NO(69) | 3) -#define MT8365_PIN_69_CMDAT1__FUNC_TDM_RX_MCK (MTK_PIN_NO(69) | 4) -#define MT8365_PIN_69_CMDAT1__FUNC_I2S0_MCK (MTK_PIN_NO(69) | 5) -#define MT8365_PIN_69_CMDAT1__FUNC_DBG_MON_B5 (MTK_PIN_NO(69) | 7) - -#define MT8365_PIN_70_CMDAT2__FUNC_GPIO70 (MTK_PIN_NO(70) | 0) -#define MT8365_PIN_70_CMDAT2__FUNC_CMDAT2 (MTK_PIN_NO(70) | 1) -#define MT8365_PIN_70_CMDAT2__FUNC_ANT_SEL3 (MTK_PIN_NO(70) | 2) -#define MT8365_PIN_70_CMDAT2__FUNC_TDM_RX_DI (MTK_PIN_NO(70) | 4) -#define MT8365_PIN_70_CMDAT2__FUNC_I2S0_DI (MTK_PIN_NO(70) | 5) -#define MT8365_PIN_70_CMDAT2__FUNC_DBG_MON_B6 (MTK_PIN_NO(70) | 7) - -#define MT8365_PIN_71_CMDAT3__FUNC_GPIO71 (MTK_PIN_NO(71) | 0) -#define MT8365_PIN_71_CMDAT3__FUNC_CMDAT3 (MTK_PIN_NO(71) | 1) -#define MT8365_PIN_71_CMDAT3__FUNC_ANT_SEL4 (MTK_PIN_NO(71) | 2) -#define MT8365_PIN_71_CMDAT3__FUNC_DBG_MON_B7 (MTK_PIN_NO(71) | 7) - -#define MT8365_PIN_72_CMDAT4__FUNC_GPIO72 (MTK_PIN_NO(72) | 0) -#define MT8365_PIN_72_CMDAT4__FUNC_CMDAT4 (MTK_PIN_NO(72) | 1) -#define MT8365_PIN_72_CMDAT4__FUNC_ANT_SEL5 (MTK_PIN_NO(72) | 2) -#define MT8365_PIN_72_CMDAT4__FUNC_I2S3_BCK (MTK_PIN_NO(72) | 5) -#define MT8365_PIN_72_CMDAT4__FUNC_DBG_MON_B8 (MTK_PIN_NO(72) | 7) - -#define MT8365_PIN_73_CMDAT5__FUNC_GPIO73 (MTK_PIN_NO(73) | 0) -#define MT8365_PIN_73_CMDAT5__FUNC_CMDAT5 (MTK_PIN_NO(73) | 1) -#define MT8365_PIN_73_CMDAT5__FUNC_ANT_SEL6 (MTK_PIN_NO(73) | 2) -#define MT8365_PIN_73_CMDAT5__FUNC_I2S3_LRCK (MTK_PIN_NO(73) | 5) -#define MT8365_PIN_73_CMDAT5__FUNC_DBG_MON_B9 (MTK_PIN_NO(73) | 7) - -#define MT8365_PIN_74_CMDAT6__FUNC_GPIO74 (MTK_PIN_NO(74) | 0) -#define MT8365_PIN_74_CMDAT6__FUNC_CMDAT6 (MTK_PIN_NO(74) | 1) -#define MT8365_PIN_74_CMDAT6__FUNC_ANT_SEL7 (MTK_PIN_NO(74) | 2) -#define MT8365_PIN_74_CMDAT6__FUNC_I2S3_MCK (MTK_PIN_NO(74) | 5) -#define MT8365_PIN_74_CMDAT6__FUNC_DBG_MON_B10 (MTK_PIN_NO(74) | 7) - -#define MT8365_PIN_75_CMDAT7__FUNC_GPIO75 (MTK_PIN_NO(75) | 0) -#define MT8365_PIN_75_CMDAT7__FUNC_CMDAT7 (MTK_PIN_NO(75) | 1) -#define MT8365_PIN_75_CMDAT7__FUNC_I2S3_DO (MTK_PIN_NO(75) | 5) -#define MT8365_PIN_75_CMDAT7__FUNC_DBG_MON_B11 (MTK_PIN_NO(75) | 7) - -#define MT8365_PIN_76_CMDAT8__FUNC_GPIO76 (MTK_PIN_NO(76) | 0) -#define MT8365_PIN_76_CMDAT8__FUNC_CMDAT8 (MTK_PIN_NO(76) | 1) -#define MT8365_PIN_76_CMDAT8__FUNC_PCM_CLK (MTK_PIN_NO(76) | 5) -#define MT8365_PIN_76_CMDAT8__FUNC_DBG_MON_A29 (MTK_PIN_NO(76) | 7) - -#define MT8365_PIN_77_CMDAT9__FUNC_GPIO77 (MTK_PIN_NO(77) | 0) -#define MT8365_PIN_77_CMDAT9__FUNC_CMDAT9 (MTK_PIN_NO(77) | 1) -#define MT8365_PIN_77_CMDAT9__FUNC_PCM_SYNC (MTK_PIN_NO(77) | 5) -#define MT8365_PIN_77_CMDAT9__FUNC_DBG_MON_A30 (MTK_PIN_NO(77) | 7) - -#define MT8365_PIN_78_CMHSYNC__FUNC_GPIO78 (MTK_PIN_NO(78) | 0) -#define MT8365_PIN_78_CMHSYNC__FUNC_CMHSYNC (MTK_PIN_NO(78) | 1) -#define MT8365_PIN_78_CMHSYNC__FUNC_PCM_RX (MTK_PIN_NO(78) | 5) -#define MT8365_PIN_78_CMHSYNC__FUNC_DBG_MON_A31 (MTK_PIN_NO(78) | 7) - -#define MT8365_PIN_79_CMVSYNC__FUNC_GPIO79 (MTK_PIN_NO(79) | 0) -#define MT8365_PIN_79_CMVSYNC__FUNC_CMVSYNC (MTK_PIN_NO(79) | 1) -#define MT8365_PIN_79_CMVSYNC__FUNC_PCM_TX (MTK_PIN_NO(79) | 5) -#define MT8365_PIN_79_CMVSYNC__FUNC_DBG_MON_A32 (MTK_PIN_NO(79) | 7) - -#define MT8365_PIN_80_MSDC2_CMD__FUNC_GPIO80 (MTK_PIN_NO(80) | 0) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_MSDC2_CMD (MTK_PIN_NO(80) | 1) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_TDM_TX_LRCK (MTK_PIN_NO(80) | 2) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_UTXD1 (MTK_PIN_NO(80) | 3) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_DPI_D19 (MTK_PIN_NO(80) | 4) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_UDI_TMS_XI (MTK_PIN_NO(80) | 5) -#define MT8365_PIN_80_MSDC2_CMD__FUNC_ADSP_JTAG_TMS (MTK_PIN_NO(80) | 6) - -#define MT8365_PIN_81_MSDC2_CLK__FUNC_GPIO81 (MTK_PIN_NO(81) | 0) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_MSDC2_CLK (MTK_PIN_NO(81) | 1) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_TDM_TX_BCK (MTK_PIN_NO(81) | 2) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_URXD1 (MTK_PIN_NO(81) | 3) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_DPI_D20 (MTK_PIN_NO(81) | 4) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_UDI_TCK_XI (MTK_PIN_NO(81) | 5) -#define MT8365_PIN_81_MSDC2_CLK__FUNC_ADSP_JTAG_TCK (MTK_PIN_NO(81) | 6) - -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_GPIO82 (MTK_PIN_NO(82) | 0) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_MSDC2_DAT0 (MTK_PIN_NO(82) | 1) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_TDM_TX_DATA0 (MTK_PIN_NO(82) | 2) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_UTXD2 (MTK_PIN_NO(82) | 3) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_DPI_D21 (MTK_PIN_NO(82) | 4) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_UDI_TDI_XI (MTK_PIN_NO(82) | 5) -#define MT8365_PIN_82_MSDC2_DAT0__FUNC_ADSP_JTAG_TDI (MTK_PIN_NO(82) | 6) - -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_GPIO83 (MTK_PIN_NO(83) | 0) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_MSDC2_DAT1 (MTK_PIN_NO(83) | 1) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_TDM_TX_DATA1 (MTK_PIN_NO(83) | 2) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_URXD2 (MTK_PIN_NO(83) | 3) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_DPI_D22 (MTK_PIN_NO(83) | 4) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_UDI_TDO (MTK_PIN_NO(83) | 5) -#define MT8365_PIN_83_MSDC2_DAT1__FUNC_ADSP_JTAG_TDO (MTK_PIN_NO(83) | 6) - -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_GPIO84 (MTK_PIN_NO(84) | 0) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_MSDC2_DAT2 (MTK_PIN_NO(84) | 1) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_TDM_TX_DATA2 (MTK_PIN_NO(84) | 2) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_PWM_A (MTK_PIN_NO(84) | 3) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_DPI_D23 (MTK_PIN_NO(84) | 4) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_UDI_NTRST_XI (MTK_PIN_NO(84) | 5) -#define MT8365_PIN_84_MSDC2_DAT2__FUNC_ADSP_JTAG_TRST (MTK_PIN_NO(84) | 6) - -#define MT8365_PIN_85_MSDC2_DAT3__FUNC_GPIO85 (MTK_PIN_NO(85) | 0) -#define MT8365_PIN_85_MSDC2_DAT3__FUNC_MSDC2_DAT3 (MTK_PIN_NO(85) | 1) -#define MT8365_PIN_85_MSDC2_DAT3__FUNC_TDM_TX_DATA3 (MTK_PIN_NO(85) | 2) -#define MT8365_PIN_85_MSDC2_DAT3__FUNC_PWM_B (MTK_PIN_NO(85) | 3) -#define MT8365_PIN_85_MSDC2_DAT3__FUNC_EXT_FRAME_SYNC (MTK_PIN_NO(85) | 5) - -#define MT8365_PIN_86_MSDC2_DSL__FUNC_GPIO86 (MTK_PIN_NO(86) | 0) -#define MT8365_PIN_86_MSDC2_DSL__FUNC_MSDC2_DSL (MTK_PIN_NO(86) | 1) -#define MT8365_PIN_86_MSDC2_DSL__FUNC_TDM_TX_MCK (MTK_PIN_NO(86) | 2) -#define MT8365_PIN_86_MSDC2_DSL__FUNC_PWM_C (MTK_PIN_NO(86) | 3) - -#define MT8365_PIN_87_MSDC1_CMD__FUNC_GPIO87 (MTK_PIN_NO(87) | 0) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_MSDC1_CMD (MTK_PIN_NO(87) | 1) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_CONN_MCU_AICE_TMSC (MTK_PIN_NO(87) | 2) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_DFD_TMS_XI (MTK_PIN_NO(87) | 3) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_APU_JTAG_TMS (MTK_PIN_NO(87) | 4) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_MCU_SPM_TMS (MTK_PIN_NO(87) | 5) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_CONN_DSP_JMS (MTK_PIN_NO(87) | 6) -#define MT8365_PIN_87_MSDC1_CMD__FUNC_ADSP_JTAG_TMS (MTK_PIN_NO(87) | 7) - -#define MT8365_PIN_88_MSDC1_CLK__FUNC_GPIO88 (MTK_PIN_NO(88) | 0) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_MSDC1_CLK (MTK_PIN_NO(88) | 1) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_CONN_MCU_AICE_TCKC (MTK_PIN_NO(88) | 2) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_DFD_TCK_XI (MTK_PIN_NO(88) | 3) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_APU_JTAG_TCK (MTK_PIN_NO(88) | 4) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_MCU_SPM_TCK (MTK_PIN_NO(88) | 5) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_CONN_DSP_JCK (MTK_PIN_NO(88) | 6) -#define MT8365_PIN_88_MSDC1_CLK__FUNC_ADSP_JTAG_TCK (MTK_PIN_NO(88) | 7) - -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_GPIO89 (MTK_PIN_NO(89) | 0) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_MSDC1_DAT0 (MTK_PIN_NO(89) | 1) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_PWM_C (MTK_PIN_NO(89) | 2) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_DFD_TDI_XI (MTK_PIN_NO(89) | 3) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_APU_JTAG_TDI (MTK_PIN_NO(89) | 4) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_MCU_SPM_TDI (MTK_PIN_NO(89) | 5) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_CONN_DSP_JDI (MTK_PIN_NO(89) | 6) -#define MT8365_PIN_89_MSDC1_DAT0__FUNC_ADSP_JTAG_TDI (MTK_PIN_NO(89) | 7) - -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_GPIO90 (MTK_PIN_NO(90) | 0) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_MSDC1_DAT1 (MTK_PIN_NO(90) | 1) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_SPDIF_IN (MTK_PIN_NO(90) | 2) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_DFD_TDO (MTK_PIN_NO(90) | 3) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_APU_JTAG_TDO (MTK_PIN_NO(90) | 4) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_MCU_SPM_TDO (MTK_PIN_NO(90) | 5) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_CONN_DSP_JDO (MTK_PIN_NO(90) | 6) -#define MT8365_PIN_90_MSDC1_DAT1__FUNC_ADSP_JTAG_TDO (MTK_PIN_NO(90) | 7) - -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_GPIO91 (MTK_PIN_NO(91) | 0) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_MSDC1_DAT2 (MTK_PIN_NO(91) | 1) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_SPDIF_OUT (MTK_PIN_NO(91) | 2) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_DFD_NTRST_XI (MTK_PIN_NO(91) | 3) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_APU_JTAG_TRST (MTK_PIN_NO(91) | 4) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_MCU_SPM_NTRST (MTK_PIN_NO(91) | 5) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_CONN_DSP_JINTP (MTK_PIN_NO(91) | 6) -#define MT8365_PIN_91_MSDC1_DAT2__FUNC_ADSP_JTAG_TRST (MTK_PIN_NO(91) | 7) - -#define MT8365_PIN_92_MSDC1_DAT3__FUNC_GPIO92 (MTK_PIN_NO(92) | 0) -#define MT8365_PIN_92_MSDC1_DAT3__FUNC_MSDC1_DAT3 (MTK_PIN_NO(92) | 1) -#define MT8365_PIN_92_MSDC1_DAT3__FUNC_IRRX (MTK_PIN_NO(92) | 2) -#define MT8365_PIN_92_MSDC1_DAT3__FUNC_PWM_A (MTK_PIN_NO(92) | 3) - -#define MT8365_PIN_93_MSDC0_DAT7__FUNC_GPIO93 (MTK_PIN_NO(93) | 0) -#define MT8365_PIN_93_MSDC0_DAT7__FUNC_MSDC0_DAT7 (MTK_PIN_NO(93) | 1) -#define MT8365_PIN_93_MSDC0_DAT7__FUNC_NLD7 (MTK_PIN_NO(93) | 2) - -#define MT8365_PIN_94_MSDC0_DAT6__FUNC_GPIO94 (MTK_PIN_NO(94) | 0) -#define MT8365_PIN_94_MSDC0_DAT6__FUNC_MSDC0_DAT6 (MTK_PIN_NO(94) | 1) -#define MT8365_PIN_94_MSDC0_DAT6__FUNC_NLD6 (MTK_PIN_NO(94) | 2) - -#define MT8365_PIN_95_MSDC0_DAT5__FUNC_GPIO95 (MTK_PIN_NO(95) | 0) -#define MT8365_PIN_95_MSDC0_DAT5__FUNC_MSDC0_DAT5 (MTK_PIN_NO(95) | 1) -#define MT8365_PIN_95_MSDC0_DAT5__FUNC_NLD4 (MTK_PIN_NO(95) | 2) - -#define MT8365_PIN_96_MSDC0_DAT4__FUNC_GPIO96 (MTK_PIN_NO(96) | 0) -#define MT8365_PIN_96_MSDC0_DAT4__FUNC_MSDC0_DAT4 (MTK_PIN_NO(96) | 1) -#define MT8365_PIN_96_MSDC0_DAT4__FUNC_NLD3 (MTK_PIN_NO(96) | 2) - -#define MT8365_PIN_97_MSDC0_RSTB__FUNC_GPIO97 (MTK_PIN_NO(97) | 0) -#define MT8365_PIN_97_MSDC0_RSTB__FUNC_MSDC0_RSTB (MTK_PIN_NO(97) | 1) -#define MT8365_PIN_97_MSDC0_RSTB__FUNC_NLD0 (MTK_PIN_NO(97) | 2) - -#define MT8365_PIN_98_MSDC0_CMD__FUNC_GPIO98 (MTK_PIN_NO(98) | 0) -#define MT8365_PIN_98_MSDC0_CMD__FUNC_MSDC0_CMD (MTK_PIN_NO(98) | 1) -#define MT8365_PIN_98_MSDC0_CMD__FUNC_NALE (MTK_PIN_NO(98) | 2) - -#define MT8365_PIN_99_MSDC0_CLK__FUNC_GPIO99 (MTK_PIN_NO(99) | 0) -#define MT8365_PIN_99_MSDC0_CLK__FUNC_MSDC0_CLK (MTK_PIN_NO(99) | 1) -#define MT8365_PIN_99_MSDC0_CLK__FUNC_NWEB (MTK_PIN_NO(99) | 2) - -#define MT8365_PIN_100_MSDC0_DAT3__FUNC_GPIO100 (MTK_PIN_NO(100) | 0) -#define MT8365_PIN_100_MSDC0_DAT3__FUNC_MSDC0_DAT3 (MTK_PIN_NO(100) | 1) -#define MT8365_PIN_100_MSDC0_DAT3__FUNC_NLD1 (MTK_PIN_NO(100) | 2) - -#define MT8365_PIN_101_MSDC0_DAT2__FUNC_GPIO101 (MTK_PIN_NO(101) | 0) -#define MT8365_PIN_101_MSDC0_DAT2__FUNC_MSDC0_DAT2 (MTK_PIN_NO(101) | 1) -#define MT8365_PIN_101_MSDC0_DAT2__FUNC_NLD5 (MTK_PIN_NO(101) | 2) - -#define MT8365_PIN_102_MSDC0_DAT1__FUNC_GPIO102 (MTK_PIN_NO(102) | 0) -#define MT8365_PIN_102_MSDC0_DAT1__FUNC_MSDC0_DAT1 (MTK_PIN_NO(102) | 1) -#define MT8365_PIN_102_MSDC0_DAT1__FUNC_NDQS (MTK_PIN_NO(102) | 2) - -#define MT8365_PIN_103_MSDC0_DAT0__FUNC_GPIO103 (MTK_PIN_NO(103) | 0) -#define MT8365_PIN_103_MSDC0_DAT0__FUNC_MSDC0_DAT0 (MTK_PIN_NO(103) | 1) -#define MT8365_PIN_103_MSDC0_DAT0__FUNC_NLD2 (MTK_PIN_NO(103) | 2) - -#define MT8365_PIN_104_MSDC0_DSL__FUNC_GPIO104 (MTK_PIN_NO(104) | 0) -#define MT8365_PIN_104_MSDC0_DSL__FUNC_MSDC0_DSL (MTK_PIN_NO(104) | 1) - -#define MT8365_PIN_105_NCLE__FUNC_GPIO105 (MTK_PIN_NO(105) | 0) -#define MT8365_PIN_105_NCLE__FUNC_NCLE (MTK_PIN_NO(105) | 1) -#define MT8365_PIN_105_NCLE__FUNC_TDM_RX_MCK (MTK_PIN_NO(105) | 2) -#define MT8365_PIN_105_NCLE__FUNC_DBG_MON_B12 (MTK_PIN_NO(105) | 7) - -#define MT8365_PIN_106_NCEB1__FUNC_GPIO106 (MTK_PIN_NO(106) | 0) -#define MT8365_PIN_106_NCEB1__FUNC_NCEB1 (MTK_PIN_NO(106) | 1) -#define MT8365_PIN_106_NCEB1__FUNC_TDM_RX_BCK (MTK_PIN_NO(106) | 2) -#define MT8365_PIN_106_NCEB1__FUNC_DBG_MON_B13 (MTK_PIN_NO(106) | 7) - -#define MT8365_PIN_107_NCEB0__FUNC_GPIO107 (MTK_PIN_NO(107) | 0) -#define MT8365_PIN_107_NCEB0__FUNC_NCEB0 (MTK_PIN_NO(107) | 1) -#define MT8365_PIN_107_NCEB0__FUNC_TDM_RX_LRCK (MTK_PIN_NO(107) | 2) -#define MT8365_PIN_107_NCEB0__FUNC_DBG_MON_B14 (MTK_PIN_NO(107) | 7) - -#define MT8365_PIN_108_NREB__FUNC_GPIO108 (MTK_PIN_NO(108) | 0) -#define MT8365_PIN_108_NREB__FUNC_NREB (MTK_PIN_NO(108) | 1) -#define MT8365_PIN_108_NREB__FUNC_TDM_RX_DI (MTK_PIN_NO(108) | 2) -#define MT8365_PIN_108_NREB__FUNC_DBG_MON_B15 (MTK_PIN_NO(108) | 7) - -#define MT8365_PIN_109_NRNB__FUNC_GPIO109 (MTK_PIN_NO(109) | 0) -#define MT8365_PIN_109_NRNB__FUNC_NRNB (MTK_PIN_NO(109) | 1) -#define MT8365_PIN_109_NRNB__FUNC_TSF_IN (MTK_PIN_NO(109) | 2) -#define MT8365_PIN_109_NRNB__FUNC_DBG_MON_B16 (MTK_PIN_NO(109) | 7) - -#define MT8365_PIN_110_PCM_CLK__FUNC_GPIO110 (MTK_PIN_NO(110) | 0) -#define MT8365_PIN_110_PCM_CLK__FUNC_PCM_CLK (MTK_PIN_NO(110) | 1) -#define MT8365_PIN_110_PCM_CLK__FUNC_I2S0_BCK (MTK_PIN_NO(110) | 2) -#define MT8365_PIN_110_PCM_CLK__FUNC_I2S3_BCK (MTK_PIN_NO(110) | 3) -#define MT8365_PIN_110_PCM_CLK__FUNC_SPDIF_IN (MTK_PIN_NO(110) | 4) -#define MT8365_PIN_110_PCM_CLK__FUNC_DPI_D15 (MTK_PIN_NO(110) | 5) - -#define MT8365_PIN_111_PCM_SYNC__FUNC_GPIO111 (MTK_PIN_NO(111) | 0) -#define MT8365_PIN_111_PCM_SYNC__FUNC_PCM_SYNC (MTK_PIN_NO(111) | 1) -#define MT8365_PIN_111_PCM_SYNC__FUNC_I2S0_LRCK (MTK_PIN_NO(111) | 2) -#define MT8365_PIN_111_PCM_SYNC__FUNC_I2S3_LRCK (MTK_PIN_NO(111) | 3) -#define MT8365_PIN_111_PCM_SYNC__FUNC_SPDIF_OUT (MTK_PIN_NO(111) | 4) -#define MT8365_PIN_111_PCM_SYNC__FUNC_DPI_D16 (MTK_PIN_NO(111) | 5) - -#define MT8365_PIN_112_PCM_RX__FUNC_GPIO112 (MTK_PIN_NO(112) | 0) -#define MT8365_PIN_112_PCM_RX__FUNC_PCM_RX (MTK_PIN_NO(112) | 1) -#define MT8365_PIN_112_PCM_RX__FUNC_I2S0_DI (MTK_PIN_NO(112) | 2) -#define MT8365_PIN_112_PCM_RX__FUNC_I2S3_MCK (MTK_PIN_NO(112) | 3) -#define MT8365_PIN_112_PCM_RX__FUNC_IRRX (MTK_PIN_NO(112) | 4) -#define MT8365_PIN_112_PCM_RX__FUNC_DPI_D17 (MTK_PIN_NO(112) | 5) - -#define MT8365_PIN_113_PCM_TX__FUNC_GPIO113 (MTK_PIN_NO(113) | 0) -#define MT8365_PIN_113_PCM_TX__FUNC_PCM_TX (MTK_PIN_NO(113) | 1) -#define MT8365_PIN_113_PCM_TX__FUNC_I2S0_MCK (MTK_PIN_NO(113) | 2) -#define MT8365_PIN_113_PCM_TX__FUNC_I2S3_DO (MTK_PIN_NO(113) | 3) -#define MT8365_PIN_113_PCM_TX__FUNC_PWM_B (MTK_PIN_NO(113) | 4) -#define MT8365_PIN_113_PCM_TX__FUNC_DPI_D18 (MTK_PIN_NO(113) | 5) - -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_GPIO114 (MTK_PIN_NO(114) | 0) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_I2S0_DI (MTK_PIN_NO(114) | 1) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_I2S1_DO (MTK_PIN_NO(114) | 2) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_I2S2_DI (MTK_PIN_NO(114) | 3) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_I2S3_DO (MTK_PIN_NO(114) | 4) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_PWM_A (MTK_PIN_NO(114) | 5) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_SPDIF_IN (MTK_PIN_NO(114) | 6) -#define MT8365_PIN_114_I2S_DATA_IN__FUNC_DBG_MON_B17 (MTK_PIN_NO(114) | 7) - -#define MT8365_PIN_115_I2S_LRCK__FUNC_GPIO115 (MTK_PIN_NO(115) | 0) -#define MT8365_PIN_115_I2S_LRCK__FUNC_I2S0_LRCK (MTK_PIN_NO(115) | 1) -#define MT8365_PIN_115_I2S_LRCK__FUNC_I2S1_LRCK (MTK_PIN_NO(115) | 2) -#define MT8365_PIN_115_I2S_LRCK__FUNC_I2S2_LRCK (MTK_PIN_NO(115) | 3) -#define MT8365_PIN_115_I2S_LRCK__FUNC_I2S3_LRCK (MTK_PIN_NO(115) | 4) -#define MT8365_PIN_115_I2S_LRCK__FUNC_PWM_B (MTK_PIN_NO(115) | 5) -#define MT8365_PIN_115_I2S_LRCK__FUNC_SPDIF_OUT (MTK_PIN_NO(115) | 6) -#define MT8365_PIN_115_I2S_LRCK__FUNC_DBG_MON_B18 (MTK_PIN_NO(115) | 7) - -#define MT8365_PIN_116_I2S_BCK__FUNC_GPIO116 (MTK_PIN_NO(116) | 0) -#define MT8365_PIN_116_I2S_BCK__FUNC_I2S0_BCK (MTK_PIN_NO(116) | 1) -#define MT8365_PIN_116_I2S_BCK__FUNC_I2S1_BCK (MTK_PIN_NO(116) | 2) -#define MT8365_PIN_116_I2S_BCK__FUNC_I2S2_BCK (MTK_PIN_NO(116) | 3) -#define MT8365_PIN_116_I2S_BCK__FUNC_I2S3_BCK (MTK_PIN_NO(116) | 4) -#define MT8365_PIN_116_I2S_BCK__FUNC_PWM_C (MTK_PIN_NO(116) | 5) -#define MT8365_PIN_116_I2S_BCK__FUNC_IRRX (MTK_PIN_NO(116) | 6) -#define MT8365_PIN_116_I2S_BCK__FUNC_DBG_MON_B19 (MTK_PIN_NO(116) | 7) - -#define MT8365_PIN_117_DMIC0_CLK__FUNC_GPIO117 (MTK_PIN_NO(117) | 0) -#define MT8365_PIN_117_DMIC0_CLK__FUNC_DMIC0_CLK (MTK_PIN_NO(117) | 1) -#define MT8365_PIN_117_DMIC0_CLK__FUNC_I2S2_BCK (MTK_PIN_NO(117) | 2) -#define MT8365_PIN_117_DMIC0_CLK__FUNC_DBG_MON_B20 (MTK_PIN_NO(117) | 7) - -#define MT8365_PIN_118_DMIC0_DAT0__FUNC_GPIO118 (MTK_PIN_NO(118) | 0) -#define MT8365_PIN_118_DMIC0_DAT0__FUNC_DMIC0_DAT0 (MTK_PIN_NO(118) | 1) -#define MT8365_PIN_118_DMIC0_DAT0__FUNC_I2S2_DI (MTK_PIN_NO(118) | 2) -#define MT8365_PIN_118_DMIC0_DAT0__FUNC_DBG_MON_B21 (MTK_PIN_NO(118) | 7) - -#define MT8365_PIN_119_DMIC0_DAT1__FUNC_GPIO119 (MTK_PIN_NO(119) | 0) -#define MT8365_PIN_119_DMIC0_DAT1__FUNC_DMIC0_DAT1 (MTK_PIN_NO(119) | 1) -#define MT8365_PIN_119_DMIC0_DAT1__FUNC_I2S2_LRCK (MTK_PIN_NO(119) | 2) -#define MT8365_PIN_119_DMIC0_DAT1__FUNC_DBG_MON_B22 (MTK_PIN_NO(119) | 7) - -#define MT8365_PIN_120_DMIC1_CLK__FUNC_GPIO120 (MTK_PIN_NO(120) | 0) -#define MT8365_PIN_120_DMIC1_CLK__FUNC_DMIC1_CLK (MTK_PIN_NO(120) | 1) -#define MT8365_PIN_120_DMIC1_CLK__FUNC_I2S2_MCK (MTK_PIN_NO(120) | 2) -#define MT8365_PIN_120_DMIC1_CLK__FUNC_DBG_MON_B23 (MTK_PIN_NO(120) | 7) - -#define MT8365_PIN_121_DMIC1_DAT0__FUNC_GPIO121 (MTK_PIN_NO(121) | 0) -#define MT8365_PIN_121_DMIC1_DAT0__FUNC_DMIC1_DAT0 (MTK_PIN_NO(121) | 1) -#define MT8365_PIN_121_DMIC1_DAT0__FUNC_I2S1_BCK (MTK_PIN_NO(121) | 2) -#define MT8365_PIN_121_DMIC1_DAT0__FUNC_DBG_MON_B24 (MTK_PIN_NO(121) | 7) - -#define MT8365_PIN_122_DMIC1_DAT1__FUNC_GPIO122 (MTK_PIN_NO(122) | 0) -#define MT8365_PIN_122_DMIC1_DAT1__FUNC_DMIC1_DAT1 (MTK_PIN_NO(122) | 1) -#define MT8365_PIN_122_DMIC1_DAT1__FUNC_I2S1_LRCK (MTK_PIN_NO(122) | 2) -#define MT8365_PIN_122_DMIC1_DAT1__FUNC_DBG_MON_B25 (MTK_PIN_NO(122) | 7) - -#define MT8365_PIN_123_DMIC2_CLK__FUNC_GPIO123 (MTK_PIN_NO(123) | 0) -#define MT8365_PIN_123_DMIC2_CLK__FUNC_DMIC2_CLK (MTK_PIN_NO(123) | 1) -#define MT8365_PIN_123_DMIC2_CLK__FUNC_I2S1_MCK (MTK_PIN_NO(123) | 2) -#define MT8365_PIN_123_DMIC2_CLK__FUNC_DBG_MON_B26 (MTK_PIN_NO(123) | 7) - -#define MT8365_PIN_124_DMIC2_DAT0__FUNC_GPIO124 (MTK_PIN_NO(124) | 0) -#define MT8365_PIN_124_DMIC2_DAT0__FUNC_DMIC2_DAT0 (MTK_PIN_NO(124) | 1) -#define MT8365_PIN_124_DMIC2_DAT0__FUNC_I2S1_DO (MTK_PIN_NO(124) | 2) -#define MT8365_PIN_124_DMIC2_DAT0__FUNC_DBG_MON_B27 (MTK_PIN_NO(124) | 7) - -#define MT8365_PIN_125_DMIC2_DAT1__FUNC_GPIO125 (MTK_PIN_NO(125) | 0) -#define MT8365_PIN_125_DMIC2_DAT1__FUNC_DMIC2_DAT1 (MTK_PIN_NO(125) | 1) -#define MT8365_PIN_125_DMIC2_DAT1__FUNC_TDM_RX_BCK (MTK_PIN_NO(125) | 2) -#define MT8365_PIN_125_DMIC2_DAT1__FUNC_DBG_MON_B28 (MTK_PIN_NO(125) | 7) - -#define MT8365_PIN_126_DMIC3_CLK__FUNC_GPIO126 (MTK_PIN_NO(126) | 0) -#define MT8365_PIN_126_DMIC3_CLK__FUNC_DMIC3_CLK (MTK_PIN_NO(126) | 1) -#define MT8365_PIN_126_DMIC3_CLK__FUNC_TDM_RX_LRCK (MTK_PIN_NO(126) | 2) - -#define MT8365_PIN_127_DMIC3_DAT0__FUNC_GPIO127 (MTK_PIN_NO(127) | 0) -#define MT8365_PIN_127_DMIC3_DAT0__FUNC_DMIC3_DAT0 (MTK_PIN_NO(127) | 1) -#define MT8365_PIN_127_DMIC3_DAT0__FUNC_TDM_RX_DI (MTK_PIN_NO(127) | 2) - -#define MT8365_PIN_128_DMIC3_DAT1__FUNC_GPIO128 (MTK_PIN_NO(128) | 0) -#define MT8365_PIN_128_DMIC3_DAT1__FUNC_DMIC3_DAT1 (MTK_PIN_NO(128) | 1) -#define MT8365_PIN_128_DMIC3_DAT1__FUNC_TDM_RX_MCK (MTK_PIN_NO(128) | 2) -#define MT8365_PIN_128_DMIC3_DAT1__FUNC_VAD_CLK (MTK_PIN_NO(128) | 3) - -#define MT8365_PIN_129_TDM_TX_BCK__FUNC_GPIO129 (MTK_PIN_NO(129) | 0) -#define MT8365_PIN_129_TDM_TX_BCK__FUNC_TDM_TX_BCK (MTK_PIN_NO(129) | 1) -#define MT8365_PIN_129_TDM_TX_BCK__FUNC_I2S3_BCK (MTK_PIN_NO(129) | 2) -#define MT8365_PIN_129_TDM_TX_BCK__FUNC_ckmon1_ck (MTK_PIN_NO(129) | 3) - -#define MT8365_PIN_130_TDM_TX_LRCK__FUNC_GPIO130 (MTK_PIN_NO(130) | 0) -#define MT8365_PIN_130_TDM_TX_LRCK__FUNC_TDM_TX_LRCK (MTK_PIN_NO(130) | 1) -#define MT8365_PIN_130_TDM_TX_LRCK__FUNC_I2S3_LRCK (MTK_PIN_NO(130) | 2) -#define MT8365_PIN_130_TDM_TX_LRCK__FUNC_ckmon2_ck (MTK_PIN_NO(130) | 3) - -#define MT8365_PIN_131_TDM_TX_MCK__FUNC_GPIO131 (MTK_PIN_NO(131) | 0) -#define MT8365_PIN_131_TDM_TX_MCK__FUNC_TDM_TX_MCK (MTK_PIN_NO(131) | 1) -#define MT8365_PIN_131_TDM_TX_MCK__FUNC_I2S3_MCK (MTK_PIN_NO(131) | 2) -#define MT8365_PIN_131_TDM_TX_MCK__FUNC_ckmon3_ck (MTK_PIN_NO(131) | 3) - -#define MT8365_PIN_132_TDM_TX_DATA0__FUNC_GPIO132 (MTK_PIN_NO(132) | 0) -#define MT8365_PIN_132_TDM_TX_DATA0__FUNC_TDM_TX_DATA0 (MTK_PIN_NO(132) | 1) -#define MT8365_PIN_132_TDM_TX_DATA0__FUNC_I2S3_DO (MTK_PIN_NO(132) | 2) -#define MT8365_PIN_132_TDM_TX_DATA0__FUNC_ckmon4_ck (MTK_PIN_NO(132) | 3) -#define MT8365_PIN_132_TDM_TX_DATA0__FUNC_DBG_MON_B29 (MTK_PIN_NO(132) | 7) - -#define MT8365_PIN_133_TDM_TX_DATA1__FUNC_GPIO133 (MTK_PIN_NO(133) | 0) -#define MT8365_PIN_133_TDM_TX_DATA1__FUNC_TDM_TX_DATA1 (MTK_PIN_NO(133) | 1) -#define MT8365_PIN_133_TDM_TX_DATA1__FUNC_DBG_MON_B30 (MTK_PIN_NO(133) | 7) - -#define MT8365_PIN_134_TDM_TX_DATA2__FUNC_GPIO134 (MTK_PIN_NO(134) | 0) -#define MT8365_PIN_134_TDM_TX_DATA2__FUNC_TDM_TX_DATA2 (MTK_PIN_NO(134) | 1) -#define MT8365_PIN_134_TDM_TX_DATA2__FUNC_DBG_MON_B31 (MTK_PIN_NO(134) | 7) - -#define MT8365_PIN_135_TDM_TX_DATA3__FUNC_GPIO135 (MTK_PIN_NO(135) | 0) -#define MT8365_PIN_135_TDM_TX_DATA3__FUNC_TDM_TX_DATA3 (MTK_PIN_NO(135) | 1) -#define MT8365_PIN_135_TDM_TX_DATA3__FUNC_DBG_MON_B32 (MTK_PIN_NO(135) | 7) - -#define MT8365_PIN_136_CONN_TOP_CLK__FUNC_GPIO136 (MTK_PIN_NO(136) | 0) -#define MT8365_PIN_136_CONN_TOP_CLK__FUNC_CONN_TOP_CLK (MTK_PIN_NO(136) | 1) - -#define MT8365_PIN_137_CONN_TOP_DATA__FUNC_GPIO137 (MTK_PIN_NO(137) | 0) -#define MT8365_PIN_137_CONN_TOP_DATA__FUNC_CONN_TOP_DATA (MTK_PIN_NO(137) | 1) - -#define MT8365_PIN_138_CONN_HRST_B__FUNC_GPIO138 (MTK_PIN_NO(138) | 0) -#define MT8365_PIN_138_CONN_HRST_B__FUNC_CONN_HRST_B (MTK_PIN_NO(138) | 1) - -#define MT8365_PIN_139_CONN_WB_PTA__FUNC_GPIO139 (MTK_PIN_NO(139) | 0) -#define MT8365_PIN_139_CONN_WB_PTA__FUNC_CONN_WB_PTA (MTK_PIN_NO(139) | 1) - -#define MT8365_PIN_140_CONN_BT_CLK__FUNC_GPIO140 (MTK_PIN_NO(140) | 0) -#define MT8365_PIN_140_CONN_BT_CLK__FUNC_CONN_BT_CLK (MTK_PIN_NO(140) | 1) - -#define MT8365_PIN_141_CONN_BT_DATA__FUNC_GPIO141 (MTK_PIN_NO(141) | 0) -#define MT8365_PIN_141_CONN_BT_DATA__FUNC_CONN_BT_DATA (MTK_PIN_NO(141) | 1) - -#define MT8365_PIN_142_CONN_WF_CTRL0__FUNC_GPIO142 (MTK_PIN_NO(142) | 0) -#define MT8365_PIN_142_CONN_WF_CTRL0__FUNC_CONN_WF_CTRL0 (MTK_PIN_NO(142) | 1) - -#define MT8365_PIN_143_CONN_WF_CTRL1__FUNC_GPIO143 (MTK_PIN_NO(143) | 0) -#define MT8365_PIN_143_CONN_WF_CTRL1__FUNC_CONN_WF_CTRL1 (MTK_PIN_NO(143) | 1) - -#define MT8365_PIN_144_CONN_WF_CTRL2__FUNC_GPIO144 (MTK_PIN_NO(144) | 0) -#define MT8365_PIN_144_CONN_WF_CTRL2__FUNC_CONN_WF_CTRL2 (MTK_PIN_NO(144) | 1) - -#endif /* __MT8365_PINFUNC_H */ diff --git a/include/dt-bindings/power/mediatek,mt8365-power.h b/include/dt-bindings/power/mediatek,mt8365-power.h deleted file mode 100644 index e6cfd0ec7871..000000000000 --- a/include/dt-bindings/power/mediatek,mt8365-power.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (c) 2022 MediaTek Inc. - */ - -#ifndef _DT_BINDINGS_POWER_MT8365_POWER_H -#define _DT_BINDINGS_POWER_MT8365_POWER_H - -#define MT8365_POWER_DOMAIN_MM 0 -#define MT8365_POWER_DOMAIN_CONN 1 -#define MT8365_POWER_DOMAIN_MFG 2 -#define MT8365_POWER_DOMAIN_AUDIO 3 -#define MT8365_POWER_DOMAIN_CAM 4 -#define MT8365_POWER_DOMAIN_DSP 5 -#define MT8365_POWER_DOMAIN_VDEC 6 -#define MT8365_POWER_DOMAIN_VENC 7 -#define MT8365_POWER_DOMAIN_APU 8 - -#endif /* _DT_BINDINGS_POWER_MT8365_POWER_H */ diff --git a/include/dt-bindings/reset/mt7621-reset.h b/include/dt-bindings/reset/mt7621-reset.h deleted file mode 100644 index 8e4341f04074..000000000000 --- a/include/dt-bindings/reset/mt7621-reset.h +++ /dev/null @@ -1,38 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2022 MediaTek Inc. All rights reserved. - * - * Author: Weijie Gao weijie.gao@mediatek.com - */ - -#ifndef _DT_BINDINGS_MT7621_RESET_H_ -#define _DT_BINDINGS_MT7621_RESET_H_ - -#define RST_PPE 31 -#define RST_SDXC 30 -#define RST_CRYPTO 29 -#define RST_AUX_STCK 28 -#define RST_PCIE2 26 -#define RST_PCIE1 25 -#define RST_PCIE0 24 -#define RST_GMAC 23 -#define RST_UART3 21 -#define RST_UART2 20 -#define RST_UART1 19 -#define RST_SPI 18 -#define RST_I2S 17 -#define RST_I2C 16 -#define RST_NFI 15 -#define RST_GDMA 14 -#define RST_PIO 13 -#define RST_PCM 11 -#define RST_MC 10 -#define RST_INTC 9 -#define RST_TIMER 8 -#define RST_SPDIFTX 7 -#define RST_FE 6 -#define RST_HSDMA 5 -#define RST_MCM 2 -#define RST_SYS 0 - -#endif /* _DT_BINDINGS_MT7621_RESET_H_ */
Drop in favour of dts/upstream
Adjust header include path naming for mpfs clock.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/riscv/dts/mpfs.dtsi | 2 +- drivers/clk/microchip/mpfs_clk.c | 2 +- drivers/clk/microchip/mpfs_clk_cfg.c | 2 +- drivers/clk/microchip/mpfs_clk_msspll.c | 2 +- drivers/clk/microchip/mpfs_clk_periph.c | 2 +- include/dt-bindings/clock/at91.h | 23 -------- include/dt-bindings/clock/microchip-mpfs-clock.h | 71 ------------------------ include/dt-bindings/dma/at91.h | 52 ----------------- include/dt-bindings/mfd/at91-usart.h | 17 ------ include/dt-bindings/net/microchip-lan78xx.h | 21 ------- include/dt-bindings/pinctrl/at91.h | 49 ---------------- include/dt-bindings/sound/microchip,pdmc.h | 13 ----- 12 files changed, 5 insertions(+), 251 deletions(-)
diff --git a/arch/riscv/dts/mpfs.dtsi b/arch/riscv/dts/mpfs.dtsi index 6012a2850703..5827d5c5d19b 100644 --- a/arch/riscv/dts/mpfs.dtsi +++ b/arch/riscv/dts/mpfs.dtsi @@ -1,8 +1,8 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* Copyright (c) 2020-2021 Microchip Technology Inc */
-#include "dt-bindings/clock/microchip-mpfs-clock.h" +#include <dt-bindings/clock/microchip,mpfs-clock.h>
/ { #address-cells = <2>; #size-cells = <2>; diff --git a/drivers/clk/microchip/mpfs_clk.c b/drivers/clk/microchip/mpfs_clk.c index 08f8bfcecbed..44ac4306eace 100644 --- a/drivers/clk/microchip/mpfs_clk.c +++ b/drivers/clk/microchip/mpfs_clk.c @@ -10,9 +10,9 @@ #include <log.h> #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> -#include <dt-bindings/clock/microchip-mpfs-clock.h> +#include <dt-bindings/clock/microchip,mpfs-clock.h> #include <linux/err.h>
#include "mpfs_clk.h"
diff --git a/drivers/clk/microchip/mpfs_clk_cfg.c b/drivers/clk/microchip/mpfs_clk_cfg.c index 5739fd66e8df..953e88e283ed 100644 --- a/drivers/clk/microchip/mpfs_clk_cfg.c +++ b/drivers/clk/microchip/mpfs_clk_cfg.c @@ -9,9 +9,9 @@ #include <asm/io.h> #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> -#include <dt-bindings/clock/microchip-mpfs-clock.h> +#include <dt-bindings/clock/microchip,mpfs-clock.h> #include <linux/err.h>
diff --git a/drivers/clk/microchip/mpfs_clk_msspll.c b/drivers/clk/microchip/mpfs_clk_msspll.c index f37c0d86047c..7b5020404549 100644 --- a/drivers/clk/microchip/mpfs_clk_msspll.c +++ b/drivers/clk/microchip/mpfs_clk_msspll.c @@ -8,9 +8,9 @@ #include <asm/io.h> #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> -#include <dt-bindings/clock/microchip-mpfs-clock.h> +#include <dt-bindings/clock/microchip,mpfs-clock.h> #include <linux/err.h>
diff --git a/drivers/clk/microchip/mpfs_clk_periph.c b/drivers/clk/microchip/mpfs_clk_periph.c index ddeccb914575..16823402def3 100644 --- a/drivers/clk/microchip/mpfs_clk_periph.c +++ b/drivers/clk/microchip/mpfs_clk_periph.c @@ -9,9 +9,9 @@ #include <asm/io.h> #include <dm/device.h> #include <dm/devres.h> #include <dm/uclass.h> -#include <dt-bindings/clock/microchip-mpfs-clock.h> +#include <dt-bindings/clock/microchip,mpfs-clock.h> #include <linux/err.h>
diff --git a/include/dt-bindings/clock/at91.h b/include/dt-bindings/clock/at91.h deleted file mode 100644 index ab3ee241d10c..000000000000 --- a/include/dt-bindings/clock/at91.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * This header provides constants for AT91 pmc status. - * - * The constants defined in this header are being used in dts. - * - * Licensed under GPLv2 or later. - */ - -#ifndef _DT_BINDINGS_CLK_AT91_H -#define _DT_BINDINGS_CLK_AT91_H - -#define AT91_PMC_MOSCS 0 /* MOSCS Flag */ -#define AT91_PMC_LOCKA 1 /* PLLA Lock */ -#define AT91_PMC_LOCKB 2 /* PLLB Lock */ -#define AT91_PMC_MCKRDY 3 /* Master Clock */ -#define AT91_PMC_LOCKU 6 /* UPLL Lock */ -#define AT91_PMC_PCKRDY(id) (8 + (id)) /* Programmable Clock */ -#define AT91_PMC_MOSCSELS 16 /* Main Oscillator Selection */ -#define AT91_PMC_MOSCRCS 17 /* Main On-Chip RC */ -#define AT91_PMC_CFDEV 18 /* Clock Failure Detector Event */ -#define AT91_PMC_GCKRDY 24 /* Generated Clocks */ - -#endif diff --git a/include/dt-bindings/clock/microchip-mpfs-clock.h b/include/dt-bindings/clock/microchip-mpfs-clock.h deleted file mode 100644 index 79775a5134ca..000000000000 --- a/include/dt-bindings/clock/microchip-mpfs-clock.h +++ /dev/null @@ -1,71 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * Daire McNamara,daire.mcnamara@microchip.com - * Copyright (C) 2020-2022 Microchip Technology Inc. All rights reserved. - */ - -#ifndef _DT_BINDINGS_CLK_MICROCHIP_MPFS_H_ -#define _DT_BINDINGS_CLK_MICROCHIP_MPFS_H_ - -#define CLK_CPU 0 -#define CLK_AXI 1 -#define CLK_AHB 2 - -#define CLK_ENVM 3 -#define CLK_MAC0 4 -#define CLK_MAC1 5 -#define CLK_MMC 6 -#define CLK_TIMER 7 -#define CLK_MMUART0 8 -#define CLK_MMUART1 9 -#define CLK_MMUART2 10 -#define CLK_MMUART3 11 -#define CLK_MMUART4 12 -#define CLK_SPI0 13 -#define CLK_SPI1 14 -#define CLK_I2C0 15 -#define CLK_I2C1 16 -#define CLK_CAN0 17 -#define CLK_CAN1 18 -#define CLK_USB 19 -#define CLK_RESERVED 20 -#define CLK_RTC 21 -#define CLK_QSPI 22 -#define CLK_GPIO0 23 -#define CLK_GPIO1 24 -#define CLK_GPIO2 25 -#define CLK_DDRC 26 -#define CLK_FIC0 27 -#define CLK_FIC1 28 -#define CLK_FIC2 29 -#define CLK_FIC3 30 -#define CLK_ATHENA 31 -#define CLK_CFM 32 - -#define CLK_RTCREF 33 -#define CLK_MSSPLL 34 - -/* Clock Conditioning Circuitry Clock IDs */ - -#define CLK_CCC_PLL0 0 -#define CLK_CCC_PLL1 1 -#define CLK_CCC_DLL0 2 -#define CLK_CCC_DLL1 3 - -#define CLK_CCC_PLL0_OUT0 4 -#define CLK_CCC_PLL0_OUT1 5 -#define CLK_CCC_PLL0_OUT2 6 -#define CLK_CCC_PLL0_OUT3 7 - -#define CLK_CCC_PLL1_OUT0 8 -#define CLK_CCC_PLL1_OUT1 9 -#define CLK_CCC_PLL1_OUT2 10 -#define CLK_CCC_PLL1_OUT3 11 - -#define CLK_CCC_DLL0_OUT0 12 -#define CLK_CCC_DLL0_OUT1 13 - -#define CLK_CCC_DLL1_OUT0 14 -#define CLK_CCC_DLL1_OUT1 15 - -#endif /* _DT_BINDINGS_CLK_MICROCHIP_MPFS_H_ */ diff --git a/include/dt-bindings/dma/at91.h b/include/dt-bindings/dma/at91.h deleted file mode 100644 index ab6cbba45401..000000000000 --- a/include/dt-bindings/dma/at91.h +++ /dev/null @@ -1,52 +0,0 @@ -/* - * This header provides macros for at91 dma bindings. - * - * Copyright (C) 2013 Ludovic Desroches ludovic.desroches@atmel.com - * - * GPLv2 only - */ - -#ifndef __DT_BINDINGS_AT91_DMA_H__ -#define __DT_BINDINGS_AT91_DMA_H__ - -/* ---------- HDMAC ---------- */ - -/* - * Source and/or destination peripheral ID - */ -#define AT91_DMA_CFG_PER_ID_MASK (0xff) -#define AT91_DMA_CFG_PER_ID(id) (id & AT91_DMA_CFG_PER_ID_MASK) - -/* - * FIFO configuration: it defines when a request is serviced. - */ -#define AT91_DMA_CFG_FIFOCFG_OFFSET (8) -#define AT91_DMA_CFG_FIFOCFG_MASK (0xf << AT91_DMA_CFG_FIFOCFG_OFFSET) -#define AT91_DMA_CFG_FIFOCFG_HALF (0x0 << AT91_DMA_CFG_FIFOCFG_OFFSET) /* half FIFO (default behavior) */ -#define AT91_DMA_CFG_FIFOCFG_ALAP (0x1 << AT91_DMA_CFG_FIFOCFG_OFFSET) /* largest defined AHB burst */ -#define AT91_DMA_CFG_FIFOCFG_ASAP (0x2 << AT91_DMA_CFG_FIFOCFG_OFFSET) /* single AHB access */ - - -/* ---------- XDMAC ---------- */ -#define AT91_XDMAC_DT_MEM_IF_MASK (0x1) -#define AT91_XDMAC_DT_MEM_IF_OFFSET (13) -#define AT91_XDMAC_DT_MEM_IF(mem_if) (((mem_if) & AT91_XDMAC_DT_MEM_IF_MASK) \ - << AT91_XDMAC_DT_MEM_IF_OFFSET) -#define AT91_XDMAC_DT_GET_MEM_IF(cfg) (((cfg) >> AT91_XDMAC_DT_MEM_IF_OFFSET) \ - & AT91_XDMAC_DT_MEM_IF_MASK) - -#define AT91_XDMAC_DT_PER_IF_MASK (0x1) -#define AT91_XDMAC_DT_PER_IF_OFFSET (14) -#define AT91_XDMAC_DT_PER_IF(per_if) (((per_if) & AT91_XDMAC_DT_PER_IF_MASK) \ - << AT91_XDMAC_DT_PER_IF_OFFSET) -#define AT91_XDMAC_DT_GET_PER_IF(cfg) (((cfg) >> AT91_XDMAC_DT_PER_IF_OFFSET) \ - & AT91_XDMAC_DT_PER_IF_MASK) - -#define AT91_XDMAC_DT_PERID_MASK (0x7f) -#define AT91_XDMAC_DT_PERID_OFFSET (24) -#define AT91_XDMAC_DT_PERID(perid) (((perid) & AT91_XDMAC_DT_PERID_MASK) \ - << AT91_XDMAC_DT_PERID_OFFSET) -#define AT91_XDMAC_DT_GET_PERID(cfg) (((cfg) >> AT91_XDMAC_DT_PERID_OFFSET) \ - & AT91_XDMAC_DT_PERID_MASK) - -#endif /* __DT_BINDINGS_AT91_DMA_H__ */ diff --git a/include/dt-bindings/mfd/at91-usart.h b/include/dt-bindings/mfd/at91-usart.h deleted file mode 100644 index 2de5bc312e1e..000000000000 --- a/include/dt-bindings/mfd/at91-usart.h +++ /dev/null @@ -1,17 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides macros for AT91 USART DT bindings. - * - * Copyright (C) 2018 Microchip Technology - * - * Author: Radu Pirea radu.pirea@microchip.com - * - */ - -#ifndef __DT_BINDINGS_AT91_USART_H__ -#define __DT_BINDINGS_AT91_USART_H__ - -#define AT91_USART_MODE_SERIAL 0 -#define AT91_USART_MODE_SPI 1 - -#endif /* __DT_BINDINGS_AT91_USART_H__ */ diff --git a/include/dt-bindings/net/microchip-lan78xx.h b/include/dt-bindings/net/microchip-lan78xx.h deleted file mode 100644 index 0742ff075307..000000000000 --- a/include/dt-bindings/net/microchip-lan78xx.h +++ /dev/null @@ -1,21 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef _DT_BINDINGS_MICROCHIP_LAN78XX_H -#define _DT_BINDINGS_MICROCHIP_LAN78XX_H - -/* LED modes for LAN7800/LAN7850 embedded PHY */ - -#define LAN78XX_LINK_ACTIVITY 0 -#define LAN78XX_LINK_1000_ACTIVITY 1 -#define LAN78XX_LINK_100_ACTIVITY 2 -#define LAN78XX_LINK_10_ACTIVITY 3 -#define LAN78XX_LINK_100_1000_ACTIVITY 4 -#define LAN78XX_LINK_10_1000_ACTIVITY 5 -#define LAN78XX_LINK_10_100_ACTIVITY 6 -#define LAN78XX_DUPLEX_COLLISION 8 -#define LAN78XX_COLLISION 9 -#define LAN78XX_ACTIVITY 10 -#define LAN78XX_AUTONEG_FAULT 12 -#define LAN78XX_FORCE_LED_OFF 14 -#define LAN78XX_FORCE_LED_ON 15 - -#endif diff --git a/include/dt-bindings/pinctrl/at91.h b/include/dt-bindings/pinctrl/at91.h deleted file mode 100644 index 3831f91fb3ba..000000000000 --- a/include/dt-bindings/pinctrl/at91.h +++ /dev/null @@ -1,49 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * This header provides constants for most at91 pinctrl bindings. - * - * Copyright (C) 2013 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com - */ - -#ifndef __DT_BINDINGS_AT91_PINCTRL_H__ -#define __DT_BINDINGS_AT91_PINCTRL_H__ - -#define AT91_PINCTRL_NONE (0 << 0) -#define AT91_PINCTRL_PULL_UP (1 << 0) -#define AT91_PINCTRL_MULTI_DRIVE (1 << 1) -#define AT91_PINCTRL_DEGLITCH (1 << 2) -#define AT91_PINCTRL_PULL_DOWN (1 << 3) -#define AT91_PINCTRL_DIS_SCHMIT (1 << 4) -#define AT91_PINCTRL_OUTPUT (1 << 7) -#define AT91_PINCTRL_OUTPUT_VAL(x) ((x & 0x1) << 8) -#define AT91_PINCTRL_SLEWRATE (1 << 9) -#define AT91_PINCTRL_DEBOUNCE (1 << 16) -#define AT91_PINCTRL_DEBOUNCE_VAL(x) (x << 17) - -#define AT91_PINCTRL_PULL_UP_DEGLITCH (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DEGLITCH) - -#define AT91_PINCTRL_DRIVE_STRENGTH_DEFAULT (0x0 << 5) -#define AT91_PINCTRL_DRIVE_STRENGTH_LOW (0x1 << 5) -#define AT91_PINCTRL_DRIVE_STRENGTH_MED (0x2 << 5) -#define AT91_PINCTRL_DRIVE_STRENGTH_HI (0x3 << 5) - -#define AT91_PINCTRL_SLEWRATE_DIS (0x0 << 9) -#define AT91_PINCTRL_SLEWRATE_ENA (0x1 << 9) - -#define AT91_PIOA 0 -#define AT91_PIOB 1 -#define AT91_PIOC 2 -#define AT91_PIOD 3 -#define AT91_PIOE 4 - -#define AT91_PERIPH_GPIO 0 -#define AT91_PERIPH_A 1 -#define AT91_PERIPH_B 2 -#define AT91_PERIPH_C 3 -#define AT91_PERIPH_D 4 - -#define ATMEL_PIO_DRVSTR_LO 1 -#define ATMEL_PIO_DRVSTR_ME 2 -#define ATMEL_PIO_DRVSTR_HI 3 - -#endif /* __DT_BINDINGS_AT91_PINCTRL_H__ */ diff --git a/include/dt-bindings/sound/microchip,pdmc.h b/include/dt-bindings/sound/microchip,pdmc.h deleted file mode 100644 index 96cde94ce74f..000000000000 --- a/include/dt-bindings/sound/microchip,pdmc.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_MICROCHIP_PDMC_H__ -#define __DT_BINDINGS_MICROCHIP_PDMC_H__ - -/* PDM microphone's pin placement */ -#define MCHP_PDMC_DS0 0 -#define MCHP_PDMC_DS1 1 - -/* PDM microphone clock edge sampling */ -#define MCHP_PDMC_CLK_POSITIVE 0 -#define MCHP_PDMC_CLK_NEGATIVE 1 - -#endif /* __DT_BINDINGS_MICROCHIP_PDMC_H__ */
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/hi3660-clock.h | 214 ------------------------------- include/dt-bindings/clock/hi6220-clock.h | 173 ------------------------- include/dt-bindings/pinctrl/hisi.h | 74 ----------- 3 files changed, 461 deletions(-)
diff --git a/include/dt-bindings/clock/hi3660-clock.h b/include/dt-bindings/clock/hi3660-clock.h deleted file mode 100644 index e1374e180943..000000000000 --- a/include/dt-bindings/clock/hi3660-clock.h +++ /dev/null @@ -1,214 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2016-2017 Linaro Ltd. - * Copyright (c) 2016-2017 HiSilicon Technologies Co., Ltd. - */ - -#ifndef __DTS_HI3660_CLOCK_H -#define __DTS_HI3660_CLOCK_H - -/* fixed rate clocks */ -#define HI3660_CLKIN_SYS 0 -#define HI3660_CLKIN_REF 1 -#define HI3660_CLK_FLL_SRC 2 -#define HI3660_CLK_PPLL0 3 -#define HI3660_CLK_PPLL1 4 -#define HI3660_CLK_PPLL2 5 -#define HI3660_CLK_PPLL3 6 -#define HI3660_CLK_SCPLL 7 -#define HI3660_PCLK 8 -#define HI3660_CLK_UART0_DBG 9 -#define HI3660_CLK_UART6 10 -#define HI3660_OSC32K 11 -#define HI3660_OSC19M 12 -#define HI3660_CLK_480M 13 -#define HI3660_CLK_INV 14 - -/* clk in crgctrl */ -#define HI3660_FACTOR_UART3 15 -#define HI3660_CLK_FACTOR_MMC 16 -#define HI3660_CLK_GATE_I2C0 17 -#define HI3660_CLK_GATE_I2C1 18 -#define HI3660_CLK_GATE_I2C2 19 -#define HI3660_CLK_GATE_I2C6 20 -#define HI3660_CLK_DIV_SYSBUS 21 -#define HI3660_CLK_DIV_320M 22 -#define HI3660_CLK_DIV_A53 23 -#define HI3660_CLK_GATE_SPI0 24 -#define HI3660_CLK_GATE_SPI2 25 -#define HI3660_PCIEPHY_REF 26 -#define HI3660_CLK_ABB_USB 27 -#define HI3660_HCLK_GATE_SDIO0 28 -#define HI3660_HCLK_GATE_SD 29 -#define HI3660_CLK_GATE_AOMM 30 -#define HI3660_PCLK_GPIO0 31 -#define HI3660_PCLK_GPIO1 32 -#define HI3660_PCLK_GPIO2 33 -#define HI3660_PCLK_GPIO3 34 -#define HI3660_PCLK_GPIO4 35 -#define HI3660_PCLK_GPIO5 36 -#define HI3660_PCLK_GPIO6 37 -#define HI3660_PCLK_GPIO7 38 -#define HI3660_PCLK_GPIO8 39 -#define HI3660_PCLK_GPIO9 40 -#define HI3660_PCLK_GPIO10 41 -#define HI3660_PCLK_GPIO11 42 -#define HI3660_PCLK_GPIO12 43 -#define HI3660_PCLK_GPIO13 44 -#define HI3660_PCLK_GPIO14 45 -#define HI3660_PCLK_GPIO15 46 -#define HI3660_PCLK_GPIO16 47 -#define HI3660_PCLK_GPIO17 48 -#define HI3660_PCLK_GPIO18 49 -#define HI3660_PCLK_GPIO19 50 -#define HI3660_PCLK_GPIO20 51 -#define HI3660_PCLK_GPIO21 52 -#define HI3660_CLK_GATE_SPI3 53 -#define HI3660_CLK_GATE_I2C7 54 -#define HI3660_CLK_GATE_I2C3 55 -#define HI3660_CLK_GATE_SPI1 56 -#define HI3660_CLK_GATE_UART1 57 -#define HI3660_CLK_GATE_UART2 58 -#define HI3660_CLK_GATE_UART4 59 -#define HI3660_CLK_GATE_UART5 60 -#define HI3660_CLK_GATE_I2C4 61 -#define HI3660_CLK_GATE_DMAC 62 -#define HI3660_PCLK_GATE_DSS 63 -#define HI3660_ACLK_GATE_DSS 64 -#define HI3660_CLK_GATE_LDI1 65 -#define HI3660_CLK_GATE_LDI0 66 -#define HI3660_CLK_GATE_VIVOBUS 67 -#define HI3660_CLK_GATE_EDC0 68 -#define HI3660_CLK_GATE_TXDPHY0_CFG 69 -#define HI3660_CLK_GATE_TXDPHY0_REF 70 -#define HI3660_CLK_GATE_TXDPHY1_CFG 71 -#define HI3660_CLK_GATE_TXDPHY1_REF 72 -#define HI3660_ACLK_GATE_USB3OTG 73 -#define HI3660_CLK_GATE_SPI4 74 -#define HI3660_CLK_GATE_SD 75 -#define HI3660_CLK_GATE_SDIO0 76 -#define HI3660_CLK_GATE_UFS_SUBSYS 77 -#define HI3660_PCLK_GATE_DSI0 78 -#define HI3660_PCLK_GATE_DSI1 79 -#define HI3660_ACLK_GATE_PCIE 80 -#define HI3660_PCLK_GATE_PCIE_SYS 81 -#define HI3660_CLK_GATE_PCIEAUX 82 -#define HI3660_PCLK_GATE_PCIE_PHY 83 -#define HI3660_CLK_ANDGT_LDI0 84 -#define HI3660_CLK_ANDGT_LDI1 85 -#define HI3660_CLK_ANDGT_EDC0 86 -#define HI3660_CLK_GATE_UFSPHY_GT 87 -#define HI3660_CLK_ANDGT_MMC 88 -#define HI3660_CLK_ANDGT_SD 89 -#define HI3660_CLK_A53HPM_ANDGT 90 -#define HI3660_CLK_ANDGT_SDIO 91 -#define HI3660_CLK_ANDGT_UART0 92 -#define HI3660_CLK_ANDGT_UART1 93 -#define HI3660_CLK_ANDGT_UARTH 94 -#define HI3660_CLK_ANDGT_SPI 95 -#define HI3660_CLK_VIVOBUS_ANDGT 96 -#define HI3660_CLK_AOMM_ANDGT 97 -#define HI3660_CLK_320M_PLL_GT 98 -#define HI3660_AUTODIV_EMMC0BUS 99 -#define HI3660_AUTODIV_SYSBUS 100 -#define HI3660_CLK_GATE_UFSPHY_CFG 101 -#define HI3660_CLK_GATE_UFSIO_REF 102 -#define HI3660_CLK_MUX_SYSBUS 103 -#define HI3660_CLK_MUX_UART0 104 -#define HI3660_CLK_MUX_UART1 105 -#define HI3660_CLK_MUX_UARTH 106 -#define HI3660_CLK_MUX_SPI 107 -#define HI3660_CLK_MUX_I2C 108 -#define HI3660_CLK_MUX_MMC_PLL 109 -#define HI3660_CLK_MUX_LDI1 110 -#define HI3660_CLK_MUX_LDI0 111 -#define HI3660_CLK_MUX_SD_PLL 112 -#define HI3660_CLK_MUX_SD_SYS 113 -#define HI3660_CLK_MUX_EDC0 114 -#define HI3660_CLK_MUX_SDIO_SYS 115 -#define HI3660_CLK_MUX_SDIO_PLL 116 -#define HI3660_CLK_MUX_VIVOBUS 117 -#define HI3660_CLK_MUX_A53HPM 118 -#define HI3660_CLK_MUX_320M 119 -#define HI3660_CLK_MUX_IOPERI 120 -#define HI3660_CLK_DIV_UART0 121 -#define HI3660_CLK_DIV_UART1 122 -#define HI3660_CLK_DIV_UARTH 123 -#define HI3660_CLK_DIV_MMC 124 -#define HI3660_CLK_DIV_SD 125 -#define HI3660_CLK_DIV_EDC0 126 -#define HI3660_CLK_DIV_LDI0 127 -#define HI3660_CLK_DIV_SDIO 128 -#define HI3660_CLK_DIV_LDI1 129 -#define HI3660_CLK_DIV_SPI 130 -#define HI3660_CLK_DIV_VIVOBUS 131 -#define HI3660_CLK_DIV_I2C 132 -#define HI3660_CLK_DIV_UFSPHY 133 -#define HI3660_CLK_DIV_CFGBUS 134 -#define HI3660_CLK_DIV_MMC0BUS 135 -#define HI3660_CLK_DIV_MMC1BUS 136 -#define HI3660_CLK_DIV_UFSPERI 137 -#define HI3660_CLK_DIV_AOMM 138 -#define HI3660_CLK_DIV_IOPERI 139 -#define HI3660_VENC_VOLT_HOLD 140 -#define HI3660_PERI_VOLT_HOLD 141 -#define HI3660_CLK_GATE_VENC 142 -#define HI3660_CLK_GATE_VDEC 143 -#define HI3660_CLK_ANDGT_VENC 144 -#define HI3660_CLK_ANDGT_VDEC 145 -#define HI3660_CLK_MUX_VENC 146 -#define HI3660_CLK_MUX_VDEC 147 -#define HI3660_CLK_DIV_VENC 148 -#define HI3660_CLK_DIV_VDEC 149 -#define HI3660_CLK_FAC_ISP_SNCLK 150 -#define HI3660_CLK_GATE_ISP_SNCLK0 151 -#define HI3660_CLK_GATE_ISP_SNCLK1 152 -#define HI3660_CLK_GATE_ISP_SNCLK2 153 -#define HI3660_CLK_ANGT_ISP_SNCLK 154 -#define HI3660_CLK_MUX_ISP_SNCLK 155 -#define HI3660_CLK_DIV_ISP_SNCLK 156 - -/* clk in pmuctrl */ -#define HI3660_GATE_ABB_192 0 - -/* clk in pctrl */ -#define HI3660_GATE_UFS_TCXO_EN 0 -#define HI3660_GATE_USB_TCXO_EN 1 - -/* clk in sctrl */ -#define HI3660_PCLK_AO_GPIO0 0 -#define HI3660_PCLK_AO_GPIO1 1 -#define HI3660_PCLK_AO_GPIO2 2 -#define HI3660_PCLK_AO_GPIO3 3 -#define HI3660_PCLK_AO_GPIO4 4 -#define HI3660_PCLK_AO_GPIO5 5 -#define HI3660_PCLK_AO_GPIO6 6 -#define HI3660_PCLK_GATE_MMBUF 7 -#define HI3660_CLK_GATE_DSS_AXI_MM 8 -#define HI3660_PCLK_MMBUF_ANDGT 9 -#define HI3660_CLK_MMBUF_PLL_ANDGT 10 -#define HI3660_CLK_FLL_MMBUF_ANDGT 11 -#define HI3660_CLK_SYS_MMBUF_ANDGT 12 -#define HI3660_CLK_GATE_PCIEPHY_GT 13 -#define HI3660_ACLK_MUX_MMBUF 14 -#define HI3660_CLK_SW_MMBUF 15 -#define HI3660_CLK_DIV_AOBUS 16 -#define HI3660_PCLK_DIV_MMBUF 17 -#define HI3660_ACLK_DIV_MMBUF 18 -#define HI3660_CLK_DIV_PCIEPHY 19 - -/* clk in iomcu */ -#define HI3660_CLK_I2C0_IOMCU 0 -#define HI3660_CLK_I2C1_IOMCU 1 -#define HI3660_CLK_I2C2_IOMCU 2 -#define HI3660_CLK_I2C6_IOMCU 3 -#define HI3660_CLK_IOMCU_PERI0 4 - -/* clk in stub clock */ -#define HI3660_CLK_STUB_CLUSTER0 0 -#define HI3660_CLK_STUB_CLUSTER1 1 -#define HI3660_CLK_STUB_GPU 2 -#define HI3660_CLK_STUB_DDR 3 -#define HI3660_CLK_STUB_NUM 4 - -#endif /* __DTS_HI3660_CLOCK_H */ diff --git a/include/dt-bindings/clock/hi6220-clock.h b/include/dt-bindings/clock/hi6220-clock.h deleted file mode 100644 index 70ee3833a7a0..000000000000 --- a/include/dt-bindings/clock/hi6220-clock.h +++ /dev/null @@ -1,173 +0,0 @@ -/* - * Copyright (c) 2015 Hisilicon Limited. - * - * Author: Bintian Wang bintian.wang@huawei.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#ifndef __DT_BINDINGS_CLOCK_HI6220_H -#define __DT_BINDINGS_CLOCK_HI6220_H - -/* clk in Hi6220 AO (always on) controller */ -#define HI6220_NONE_CLOCK 0 - -/* fixed rate clocks */ -#define HI6220_REF32K 1 -#define HI6220_CLK_TCXO 2 -#define HI6220_MMC1_PAD 3 -#define HI6220_MMC2_PAD 4 -#define HI6220_MMC0_PAD 5 -#define HI6220_PLL_BBP 6 -#define HI6220_PLL_GPU 7 -#define HI6220_PLL1_DDR 8 -#define HI6220_PLL_SYS 9 -#define HI6220_PLL_SYS_MEDIA 10 -#define HI6220_DDR_SRC 11 -#define HI6220_PLL_MEDIA 12 -#define HI6220_PLL_DDR 13 - -/* fixed factor clocks */ -#define HI6220_300M 14 -#define HI6220_150M 15 -#define HI6220_PICOPHY_SRC 16 -#define HI6220_MMC0_SRC_SEL 17 -#define HI6220_MMC1_SRC_SEL 18 -#define HI6220_MMC2_SRC_SEL 19 -#define HI6220_VPU_CODEC 20 -#define HI6220_MMC0_SMP 21 -#define HI6220_MMC1_SMP 22 -#define HI6220_MMC2_SMP 23 - -/* gate clocks */ -#define HI6220_WDT0_PCLK 24 -#define HI6220_WDT1_PCLK 25 -#define HI6220_WDT2_PCLK 26 -#define HI6220_TIMER0_PCLK 27 -#define HI6220_TIMER1_PCLK 28 -#define HI6220_TIMER2_PCLK 29 -#define HI6220_TIMER3_PCLK 30 -#define HI6220_TIMER4_PCLK 31 -#define HI6220_TIMER5_PCLK 32 -#define HI6220_TIMER6_PCLK 33 -#define HI6220_TIMER7_PCLK 34 -#define HI6220_TIMER8_PCLK 35 -#define HI6220_UART0_PCLK 36 - -#define HI6220_AO_NR_CLKS 37 - -/* clk in Hi6220 systrl */ -/* gate clock */ -#define HI6220_MMC0_CLK 1 -#define HI6220_MMC0_CIUCLK 2 -#define HI6220_MMC1_CLK 3 -#define HI6220_MMC1_CIUCLK 4 -#define HI6220_MMC2_CLK 5 -#define HI6220_MMC2_CIUCLK 6 -#define HI6220_USBOTG_HCLK 7 -#define HI6220_CLK_PICOPHY 8 -#define HI6220_HIFI 9 -#define HI6220_DACODEC_PCLK 10 -#define HI6220_EDMAC_ACLK 11 -#define HI6220_CS_ATB 12 -#define HI6220_I2C0_CLK 13 -#define HI6220_I2C1_CLK 14 -#define HI6220_I2C2_CLK 15 -#define HI6220_I2C3_CLK 16 -#define HI6220_UART1_PCLK 17 -#define HI6220_UART2_PCLK 18 -#define HI6220_UART3_PCLK 19 -#define HI6220_UART4_PCLK 20 -#define HI6220_SPI_CLK 21 -#define HI6220_TSENSOR_CLK 22 -#define HI6220_MMU_CLK 23 -#define HI6220_HIFI_SEL 24 -#define HI6220_MMC0_SYSPLL 25 -#define HI6220_MMC1_SYSPLL 26 -#define HI6220_MMC2_SYSPLL 27 -#define HI6220_MMC0_SEL 28 -#define HI6220_MMC1_SEL 29 -#define HI6220_BBPPLL_SEL 30 -#define HI6220_MEDIA_PLL_SRC 31 -#define HI6220_MMC2_SEL 32 -#define HI6220_CS_ATB_SYSPLL 33 - -/* mux clocks */ -#define HI6220_MMC0_SRC 34 -#define HI6220_MMC0_SMP_IN 35 -#define HI6220_MMC1_SRC 36 -#define HI6220_MMC1_SMP_IN 37 -#define HI6220_MMC2_SRC 38 -#define HI6220_MMC2_SMP_IN 39 -#define HI6220_HIFI_SRC 40 -#define HI6220_UART1_SRC 41 -#define HI6220_UART2_SRC 42 -#define HI6220_UART3_SRC 43 -#define HI6220_UART4_SRC 44 -#define HI6220_MMC0_MUX0 45 -#define HI6220_MMC1_MUX0 46 -#define HI6220_MMC2_MUX0 47 -#define HI6220_MMC0_MUX1 48 -#define HI6220_MMC1_MUX1 49 -#define HI6220_MMC2_MUX1 50 - -/* divider clocks */ -#define HI6220_CLK_BUS 51 -#define HI6220_MMC0_DIV 52 -#define HI6220_MMC1_DIV 53 -#define HI6220_MMC2_DIV 54 -#define HI6220_HIFI_DIV 55 -#define HI6220_BBPPLL0_DIV 56 -#define HI6220_CS_DAPB 57 -#define HI6220_CS_ATB_DIV 58 - -#define HI6220_SYS_NR_CLKS 59 - -/* clk in Hi6220 media controller */ -/* gate clocks */ -#define HI6220_DSI_PCLK 1 -#define HI6220_G3D_PCLK 2 -#define HI6220_ACLK_CODEC_VPU 3 -#define HI6220_ISP_SCLK 4 -#define HI6220_ADE_CORE 5 -#define HI6220_MED_MMU 6 -#define HI6220_CFG_CSI4PHY 7 -#define HI6220_CFG_CSI2PHY 8 -#define HI6220_ISP_SCLK_GATE 9 -#define HI6220_ISP_SCLK_GATE1 10 -#define HI6220_ADE_CORE_GATE 11 -#define HI6220_CODEC_VPU_GATE 12 -#define HI6220_MED_SYSPLL 13 - -/* mux clocks */ -#define HI6220_1440_1200 14 -#define HI6220_1000_1200 15 -#define HI6220_1000_1440 16 - -/* divider clocks */ -#define HI6220_CODEC_JPEG 17 -#define HI6220_ISP_SCLK_SRC 18 -#define HI6220_ISP_SCLK1 19 -#define HI6220_ADE_CORE_SRC 20 -#define HI6220_ADE_PIX_SRC 21 -#define HI6220_G3D_CLK 22 -#define HI6220_CODEC_VPU_SRC 23 - -#define HI6220_MEDIA_NR_CLKS 24 - -/* clk in Hi6220 power controller */ -/* gate clocks */ -#define HI6220_PLL_GPU_GATE 1 -#define HI6220_PLL1_DDR_GATE 2 -#define HI6220_PLL_DDR_GATE 3 -#define HI6220_PLL_MEDIA_GATE 4 -#define HI6220_PLL0_BBP_GATE 5 - -/* divider clocks */ -#define HI6220_DDRC_SRC 6 -#define HI6220_DDRC_AXI1 7 - -#define HI6220_POWER_NR_CLKS 8 -#endif diff --git a/include/dt-bindings/pinctrl/hisi.h b/include/dt-bindings/pinctrl/hisi.h deleted file mode 100644 index 0359bfdc9119..000000000000 --- a/include/dt-bindings/pinctrl/hisi.h +++ /dev/null @@ -1,74 +0,0 @@ -/* - * This header provides constants for hisilicon pinctrl bindings. - * - * Copyright (c) 2015 Hisilicon Limited. - * Copyright (c) 2015 Linaro Limited. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _DT_BINDINGS_PINCTRL_HISI_H -#define _DT_BINDINGS_PINCTRL_HISI_H - -/* iomg bit definition */ -#define MUX_M0 0 -#define MUX_M1 1 -#define MUX_M2 2 -#define MUX_M3 3 -#define MUX_M4 4 -#define MUX_M5 5 -#define MUX_M6 6 -#define MUX_M7 7 - -/* iocg bit definition */ -#define PULL_MASK (3) -#define PULL_DIS (0) -#define PULL_UP (1 << 0) -#define PULL_DOWN (1 << 1) - -/* drive strength definition */ -#define DRIVE_MASK (7 << 4) -#define DRIVE1_02MA (0 << 4) -#define DRIVE1_04MA (1 << 4) -#define DRIVE1_08MA (2 << 4) -#define DRIVE1_10MA (3 << 4) -#define DRIVE2_02MA (0 << 4) -#define DRIVE2_04MA (1 << 4) -#define DRIVE2_08MA (2 << 4) -#define DRIVE2_10MA (3 << 4) -#define DRIVE3_04MA (0 << 4) -#define DRIVE3_08MA (1 << 4) -#define DRIVE3_12MA (2 << 4) -#define DRIVE3_16MA (3 << 4) -#define DRIVE3_20MA (4 << 4) -#define DRIVE3_24MA (5 << 4) -#define DRIVE3_32MA (6 << 4) -#define DRIVE3_40MA (7 << 4) -#define DRIVE4_02MA (0 << 4) -#define DRIVE4_04MA (2 << 4) -#define DRIVE4_08MA (4 << 4) -#define DRIVE4_10MA (6 << 4) - -/* drive strength definition for hi3660 */ -#define DRIVE6_MASK (15 << 4) -#define DRIVE6_04MA (0 << 4) -#define DRIVE6_12MA (4 << 4) -#define DRIVE6_19MA (8 << 4) -#define DRIVE6_27MA (10 << 4) -#define DRIVE6_32MA (15 << 4) -#define DRIVE7_02MA (0 << 4) -#define DRIVE7_04MA (1 << 4) -#define DRIVE7_06MA (2 << 4) -#define DRIVE7_08MA (3 << 4) -#define DRIVE7_10MA (4 << 4) -#define DRIVE7_12MA (5 << 4) -#define DRIVE7_14MA (6 << 4) -#define DRIVE7_16MA (7 << 4) -#endif
Drop in favour of dts/upstream.
Small driver/dts change to fix compatibility.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 26 +++++++++++++------------- drivers/clk/sifive/fu540-prci.c | 8 ++++---- include/dt-bindings/clock/sifive-fu540-prci.h | 18 ------------------ include/dt-bindings/clock/sifive-fu740-prci.h | 24 ------------------------ 4 files changed, 17 insertions(+), 59 deletions(-)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index 360679a1781a..0f8181436410 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -6,42 +6,42 @@ #include <dt-bindings/reset/sifive-fu540-prci.h>
/ { cpus { - assigned-clocks = <&prci PRCI_CLK_COREPLL>; + assigned-clocks = <&prci FU540_PRCI_CLK_COREPLL>; assigned-clock-rates = <1000000000>; bootph-pre-ram; cpu0: cpu@0 { - clocks = <&prci PRCI_CLK_COREPLL>; + clocks = <&prci FU540_PRCI_CLK_COREPLL>; bootph-pre-ram; status = "okay"; cpu0_intc: interrupt-controller { bootph-pre-ram; }; }; cpu1: cpu@1 { - clocks = <&prci PRCI_CLK_COREPLL>; + clocks = <&prci FU540_PRCI_CLK_COREPLL>; bootph-pre-ram; cpu1_intc: interrupt-controller { bootph-pre-ram; }; }; cpu2: cpu@2 { - clocks = <&prci PRCI_CLK_COREPLL>; + clocks = <&prci FU540_PRCI_CLK_COREPLL>; bootph-pre-ram; cpu2_intc: interrupt-controller { bootph-pre-ram; }; }; cpu3: cpu@3 { - clocks = <&prci PRCI_CLK_COREPLL>; + clocks = <&prci FU540_PRCI_CLK_COREPLL>; bootph-pre-ram; cpu3_intc: interrupt-controller { bootph-pre-ram; }; }; cpu4: cpu@4 { - clocks = <&prci PRCI_CLK_COREPLL>; + clocks = <&prci FU540_PRCI_CLK_COREPLL>; bootph-pre-ram; cpu4_intc: interrupt-controller { bootph-pre-ram; }; @@ -66,22 +66,22 @@ bootph-pre-ram; }; prci: clock-controller@10000000 { #reset-cells = <1>; - resets = <&prci PRCI_RST_DDR_CTRL_N>, - <&prci PRCI_RST_DDR_AXI_N>, - <&prci PRCI_RST_DDR_AHB_N>, - <&prci PRCI_RST_DDR_PHY_N>, - <&prci PRCI_RST_GEMGXL_N>; + resets = <&prci FU540_PRCI_RST_DDR_CTRL_N>, + <&prci FU540_PRCI_RST_DDR_AXI_N>, + <&prci FU540_PRCI_RST_DDR_AHB_N>, + <&prci FU540_PRCI_RST_DDR_PHY_N>, + <&prci FU540_PRCI_RST_GEMGXL_N>; reset-names = "ddr_ctrl", "ddr_axi", "ddr_ahb", "ddr_phy", "gemgxl_reset"; }; dmc: dmc@100b0000 { compatible = "sifive,fu540-c000-ddr"; reg = <0x0 0x100b0000 0x0 0x0800 0x0 0x100b2000 0x0 0x2000 0x0 0x100b8000 0x0 0x1000>; - clocks = <&prci PRCI_CLK_DDRPLL>; + clocks = <&prci FU540_PRCI_CLK_DDRPLL>; clock-frequency = <933333324>; bootph-pre-ram; }; }; @@ -99,9 +99,9 @@ bootph-pre-ram; };
ð0 { - assigned-clocks = <&prci PRCI_CLK_GEMGXLPLL>; + assigned-clocks = <&prci FU540_PRCI_CLK_GEMGXLPLL>; assigned-clock-rates = <125000000>; };
&l2cache { diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index ceb2c6fab0da..b019f682ac49 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -58,27 +58,27 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { };
/* List of clock controls provided by the PRCI */ struct __prci_clock __prci_init_clocks_fu540[] = { - [PRCI_CLK_COREPLL] = { + [FU540_PRCI_CLK_COREPLL] = { .name = "corepll", .parent_name = "hfclk", .ops = &sifive_fu540_prci_wrpll_clk_ops, .pwd = &__prci_corepll_data, }, - [PRCI_CLK_DDRPLL] = { + [FU540_PRCI_CLK_DDRPLL] = { .name = "ddrpll", .parent_name = "hfclk", .ops = &sifive_fu540_prci_wrpll_clk_ops, .pwd = &__prci_ddrpll_data, }, - [PRCI_CLK_GEMGXLPLL] = { + [FU540_PRCI_CLK_GEMGXLPLL] = { .name = "gemgxlpll", .parent_name = "hfclk", .ops = &sifive_fu540_prci_wrpll_clk_ops, .pwd = &__prci_gemgxlpll_data, }, - [PRCI_CLK_TLCLK] = { + [FU540_PRCI_CLK_TLCLK] = { .name = "tlclk", .parent_name = "corepll", .ops = &sifive_fu540_prci_tlclksel_clk_ops, }, diff --git a/include/dt-bindings/clock/sifive-fu540-prci.h b/include/dt-bindings/clock/sifive-fu540-prci.h deleted file mode 100644 index 6a0b70a37d78..000000000000 --- a/include/dt-bindings/clock/sifive-fu540-prci.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2018-2019 SiFive, Inc. - * Wesley Terpstra - * Paul Walmsley - */ - -#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H -#define __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H - -/* Clock indexes for use by Device Tree data and the PRCI driver */ - -#define PRCI_CLK_COREPLL 0 -#define PRCI_CLK_DDRPLL 1 -#define PRCI_CLK_GEMGXLPLL 2 -#define PRCI_CLK_TLCLK 3 - -#endif diff --git a/include/dt-bindings/clock/sifive-fu740-prci.h b/include/dt-bindings/clock/sifive-fu740-prci.h deleted file mode 100644 index 672bdadbf6c0..000000000000 --- a/include/dt-bindings/clock/sifive-fu740-prci.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright (C) 2019 SiFive, Inc. - * Wesley Terpstra - * Paul Walmsley - * Zong Li - */ - -#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H -#define __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H - -/* Clock indexes for use by Device Tree data and the PRCI driver */ - -#define FU740_PRCI_CLK_COREPLL 0 -#define FU740_PRCI_CLK_DDRPLL 1 -#define FU740_PRCI_CLK_GEMGXLPLL 2 -#define FU740_PRCI_CLK_DVFSCOREPLL 3 -#define FU740_PRCI_CLK_HFPCLKPLL 4 -#define FU740_PRCI_CLK_CLTXPLL 5 -#define FU740_PRCI_CLK_TLCLK 6 -#define FU740_PRCI_CLK_PCLK 7 -#define FU740_PRCI_CLK_PCIE_AUX 8 - -#endif /* __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H */
Clock headers for remaining smaller vendors that are compatible with dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/actions,s700-cmu.h | 118 ------- include/dt-bindings/clock/actions,s900-cmu.h | 129 -------- include/dt-bindings/clock/agilex-clock.h | 71 ----- include/dt-bindings/clock/boston-clock.h | 12 - include/dt-bindings/clock/fsl,qoriq-clockgen.h | 15 - include/dt-bindings/clock/lpc32xx-clock.h | 58 ---- include/dt-bindings/clock/maxim,max77802.h | 22 -- include/dt-bindings/clock/nuvoton,npcm7xx-clock.h | 46 --- include/dt-bindings/clock/rv1108-cru.h | 356 ---------------------- include/dt-bindings/clock/versaclock.h | 13 - include/dt-bindings/clock/vf610-clock.h | 202 ------------ 11 files changed, 1042 deletions(-)
diff --git a/include/dt-bindings/clock/actions,s700-cmu.h b/include/dt-bindings/clock/actions,s700-cmu.h deleted file mode 100644 index 3e1942996724..000000000000 --- a/include/dt-bindings/clock/actions,s700-cmu.h +++ /dev/null @@ -1,118 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 - * - * Device Tree binding constants for Actions Semi S700 Clock Management Unit - * - * Copyright (c) 2014 Actions Semi Inc. - * Author: David Liu liuwei@actions-semi.com - * - * Author: Pathiban Nallathambi pn@denx.de - * Author: Saravanan Sekar sravanhome@gmail.com - */ - -#ifndef __DT_BINDINGS_CLOCK_S700_H -#define __DT_BINDINGS_CLOCK_S700_H - -#define CLK_NONE 0 - -/* pll clocks */ -#define CLK_CORE_PLL 1 -#define CLK_DEV_PLL 2 -#define CLK_DDR_PLL 3 -#define CLK_NAND_PLL 4 -#define CLK_DISPLAY_PLL 5 -#define CLK_TVOUT_PLL 6 -#define CLK_CVBS_PLL 7 -#define CLK_AUDIO_PLL 8 -#define CLK_ETHERNET_PLL 9 - -/* system clock */ -#define CLK_CPU 10 -#define CLK_DEV 11 -#define CLK_AHB 12 -#define CLK_APB 13 -#define CLK_DMAC 14 -#define CLK_NOC0_CLK_MUX 15 -#define CLK_NOC1_CLK_MUX 16 -#define CLK_HP_CLK_MUX 17 -#define CLK_HP_CLK_DIV 18 -#define CLK_NOC1_CLK_DIV 19 -#define CLK_NOC0 20 -#define CLK_NOC1 21 -#define CLK_SENOR_SRC 22 - -/* peripheral device clock */ -#define CLK_GPIO 23 -#define CLK_TIMER 24 -#define CLK_DSI 25 -#define CLK_CSI 26 -#define CLK_SI 27 -#define CLK_DE 28 -#define CLK_HDE 29 -#define CLK_VDE 30 -#define CLK_VCE 31 -#define CLK_NAND 32 -#define CLK_SD0 33 -#define CLK_SD1 34 -#define CLK_SD2 35 - -#define CLK_UART0 36 -#define CLK_UART1 37 -#define CLK_UART2 38 -#define CLK_UART3 39 -#define CLK_UART4 40 -#define CLK_UART5 41 -#define CLK_UART6 42 - -#define CLK_PWM0 43 -#define CLK_PWM1 44 -#define CLK_PWM2 45 -#define CLK_PWM3 46 -#define CLK_PWM4 47 -#define CLK_PWM5 48 -#define CLK_GPU3D 49 - -#define CLK_I2C0 50 -#define CLK_I2C1 51 -#define CLK_I2C2 52 -#define CLK_I2C3 53 - -#define CLK_SPI0 54 -#define CLK_SPI1 55 -#define CLK_SPI2 56 -#define CLK_SPI3 57 - -#define CLK_USB3_480MPLL0 58 -#define CLK_USB3_480MPHY0 59 -#define CLK_USB3_5GPHY 60 -#define CLK_USB3_CCE 61 -#define CLK_USB3_MAC 62 - -#define CLK_LCD 63 -#define CLK_HDMI_AUDIO 64 -#define CLK_I2SRX 65 -#define CLK_I2STX 66 - -#define CLK_SENSOR0 67 -#define CLK_SENSOR1 68 - -#define CLK_HDMI_DEV 69 - -#define CLK_ETHERNET 70 -#define CLK_RMII_REF 71 - -#define CLK_USB2H0_PLLEN 72 -#define CLK_USB2H0_PHY 73 -#define CLK_USB2H0_CCE 74 -#define CLK_USB2H1_PLLEN 75 -#define CLK_USB2H1_PHY 76 -#define CLK_USB2H1_CCE 77 - -#define CLK_TVOUT 78 - -#define CLK_THERMAL_SENSOR 79 - -#define CLK_IRC_SWITCH 80 -#define CLK_PCM1 81 -#define CLK_NR_CLKS (CLK_PCM1 + 1) - -#endif /* __DT_BINDINGS_CLOCK_S700_H */ diff --git a/include/dt-bindings/clock/actions,s900-cmu.h b/include/dt-bindings/clock/actions,s900-cmu.h deleted file mode 100644 index 7c1251565f43..000000000000 --- a/include/dt-bindings/clock/actions,s900-cmu.h +++ /dev/null @@ -1,129 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -// -// Device Tree binding constants for Actions Semi S900 Clock Management Unit -// -// Copyright (c) 2014 Actions Semi Inc. -// Copyright (c) 2018 Linaro Ltd. - -#ifndef __DT_BINDINGS_CLOCK_S900_CMU_H -#define __DT_BINDINGS_CLOCK_S900_CMU_H - -#define CLK_NONE 0 - -/* fixed rate clocks */ -#define CLK_LOSC 1 -#define CLK_HOSC 2 - -/* pll clocks */ -#define CLK_CORE_PLL 3 -#define CLK_DEV_PLL 4 -#define CLK_DDR_PLL 5 -#define CLK_NAND_PLL 6 -#define CLK_DISPLAY_PLL 7 -#define CLK_DSI_PLL 8 -#define CLK_ASSIST_PLL 9 -#define CLK_AUDIO_PLL 10 - -/* system clock */ -#define CLK_CPU 15 -#define CLK_DEV 16 -#define CLK_NOC 17 -#define CLK_NOC_MUX 18 -#define CLK_NOC_DIV 19 -#define CLK_AHB 20 -#define CLK_APB 21 -#define CLK_DMAC 22 - -/* peripheral device clock */ -#define CLK_GPIO 23 - -#define CLK_BISP 24 -#define CLK_CSI0 25 -#define CLK_CSI1 26 - -#define CLK_DE0 27 -#define CLK_DE1 28 -#define CLK_DE2 29 -#define CLK_DE3 30 -#define CLK_DSI 32 - -#define CLK_GPU 33 -#define CLK_GPU_CORE 34 -#define CLK_GPU_MEM 35 -#define CLK_GPU_SYS 36 - -#define CLK_HDE 37 -#define CLK_I2C0 38 -#define CLK_I2C1 39 -#define CLK_I2C2 40 -#define CLK_I2C3 41 -#define CLK_I2C4 42 -#define CLK_I2C5 43 -#define CLK_I2SRX 44 -#define CLK_I2STX 45 -#define CLK_IMX 46 -#define CLK_LCD 47 -#define CLK_NAND0 48 -#define CLK_NAND1 49 -#define CLK_PWM0 50 -#define CLK_PWM1 51 -#define CLK_PWM2 52 -#define CLK_PWM3 53 -#define CLK_PWM4 54 -#define CLK_PWM5 55 -#define CLK_SD0 56 -#define CLK_SD1 57 -#define CLK_SD2 58 -#define CLK_SD3 59 -#define CLK_SENSOR 60 -#define CLK_SPEED_SENSOR 61 -#define CLK_SPI0 62 -#define CLK_SPI1 63 -#define CLK_SPI2 64 -#define CLK_SPI3 65 -#define CLK_THERMAL_SENSOR 66 -#define CLK_UART0 67 -#define CLK_UART1 68 -#define CLK_UART2 69 -#define CLK_UART3 70 -#define CLK_UART4 71 -#define CLK_UART5 72 -#define CLK_UART6 73 -#define CLK_VCE 74 -#define CLK_VDE 75 - -#define CLK_USB3_480MPLL0 76 -#define CLK_USB3_480MPHY0 77 -#define CLK_USB3_5GPHY 78 -#define CLK_USB3_CCE 79 -#define CLK_USB3_MAC 80 - -#define CLK_TIMER 83 - -#define CLK_HDMI_AUDIO 84 - -#define CLK_24M 85 - -#define CLK_EDP 86 - -#define CLK_24M_EDP 87 -#define CLK_EDP_PLL 88 -#define CLK_EDP_LINK 89 - -#define CLK_USB2H0_PLLEN 90 -#define CLK_USB2H0_PHY 91 -#define CLK_USB2H0_CCE 92 -#define CLK_USB2H1_PLLEN 93 -#define CLK_USB2H1_PHY 94 -#define CLK_USB2H1_CCE 95 - -#define CLK_DDR0 96 -#define CLK_DDR1 97 -#define CLK_DMM 98 - -#define CLK_ETH_MAC 99 -#define CLK_RMII_REF 100 - -#define CLK_NR_CLKS (CLK_RMII_REF + 1) - -#endif /* __DT_BINDINGS_CLOCK_S900_CMU_H */ diff --git a/include/dt-bindings/clock/agilex-clock.h b/include/dt-bindings/clock/agilex-clock.h deleted file mode 100644 index f751aad4dafc..000000000000 --- a/include/dt-bindings/clock/agilex-clock.h +++ /dev/null @@ -1,71 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2019, Intel Corporation - */ - -#ifndef __AGILEX_CLOCK_H -#define __AGILEX_CLOCK_H - -/* fixed rate clocks */ -#define AGILEX_OSC1 0 -#define AGILEX_CB_INTOSC_HS_DIV2_CLK 1 -#define AGILEX_CB_INTOSC_LS_CLK 2 -#define AGILEX_L4_SYS_FREE_CLK 3 -#define AGILEX_F2S_FREE_CLK 4 - -/* PLL clocks */ -#define AGILEX_MAIN_PLL_CLK 5 -#define AGILEX_MAIN_PLL_C0_CLK 6 -#define AGILEX_MAIN_PLL_C1_CLK 7 -#define AGILEX_MAIN_PLL_C2_CLK 8 -#define AGILEX_MAIN_PLL_C3_CLK 9 -#define AGILEX_PERIPH_PLL_CLK 10 -#define AGILEX_PERIPH_PLL_C0_CLK 11 -#define AGILEX_PERIPH_PLL_C1_CLK 12 -#define AGILEX_PERIPH_PLL_C2_CLK 13 -#define AGILEX_PERIPH_PLL_C3_CLK 14 -#define AGILEX_MPU_FREE_CLK 15 -#define AGILEX_MPU_CCU_CLK 16 -#define AGILEX_BOOT_CLK 17 - -/* fixed factor clocks */ -#define AGILEX_L3_MAIN_FREE_CLK 18 -#define AGILEX_NOC_FREE_CLK 19 -#define AGILEX_S2F_USR0_CLK 20 -#define AGILEX_NOC_CLK 21 -#define AGILEX_EMAC_A_FREE_CLK 22 -#define AGILEX_EMAC_B_FREE_CLK 23 -#define AGILEX_EMAC_PTP_FREE_CLK 24 -#define AGILEX_GPIO_DB_FREE_CLK 25 -#define AGILEX_SDMMC_FREE_CLK 26 -#define AGILEX_S2F_USER0_FREE_CLK 27 -#define AGILEX_S2F_USER1_FREE_CLK 28 -#define AGILEX_PSI_REF_FREE_CLK 29 - -/* Gate clocks */ -#define AGILEX_MPU_CLK 30 -#define AGILEX_MPU_PERIPH_CLK 31 -#define AGILEX_L4_MAIN_CLK 32 -#define AGILEX_L4_MP_CLK 33 -#define AGILEX_L4_SP_CLK 34 -#define AGILEX_CS_AT_CLK 35 -#define AGILEX_CS_TRACE_CLK 36 -#define AGILEX_CS_PDBG_CLK 37 -#define AGILEX_CS_TIMER_CLK 38 -#define AGILEX_S2F_USER0_CLK 39 -#define AGILEX_EMAC0_CLK 40 -#define AGILEX_EMAC1_CLK 41 -#define AGILEX_EMAC2_CLK 42 -#define AGILEX_EMAC_PTP_CLK 43 -#define AGILEX_GPIO_DB_CLK 44 -#define AGILEX_NAND_CLK 45 -#define AGILEX_PSI_REF_CLK 46 -#define AGILEX_S2F_USER1_CLK 47 -#define AGILEX_SDMMC_CLK 48 -#define AGILEX_SPI_M_CLK 49 -#define AGILEX_USB_CLK 50 -#define AGILEX_NAND_X_CLK 51 -#define AGILEX_NAND_ECC_CLK 52 -#define AGILEX_NUM_CLKS 53 - -#endif /* __AGILEX_CLOCK_H */ diff --git a/include/dt-bindings/clock/boston-clock.h b/include/dt-bindings/clock/boston-clock.h deleted file mode 100644 index 0b3906247c8b..000000000000 --- a/include/dt-bindings/clock/boston-clock.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2016 Imagination Technologies - */ - -#ifndef __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ -#define __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ - -#define BOSTON_CLK_SYS 0 -#define BOSTON_CLK_CPU 1 - -#endif /* __DT_BINDINGS_CLOCK_BOSTON_CLOCK_H__ */ diff --git a/include/dt-bindings/clock/fsl,qoriq-clockgen.h b/include/dt-bindings/clock/fsl,qoriq-clockgen.h deleted file mode 100644 index ddec7d0bdc7f..000000000000 --- a/include/dt-bindings/clock/fsl,qoriq-clockgen.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#ifndef DT_CLOCK_FSL_QORIQ_CLOCKGEN_H -#define DT_CLOCK_FSL_QORIQ_CLOCKGEN_H - -#define QORIQ_CLK_SYSCLK 0 -#define QORIQ_CLK_CMUX 1 -#define QORIQ_CLK_HWACCEL 2 -#define QORIQ_CLK_FMAN 3 -#define QORIQ_CLK_PLATFORM_PLL 4 -#define QORIQ_CLK_CORECLK 5 - -#define QORIQ_CLK_PLL_DIV(x) ((x) - 1) - -#endif /* DT_CLOCK_FSL_QORIQ_CLOCKGEN_H */ diff --git a/include/dt-bindings/clock/lpc32xx-clock.h b/include/dt-bindings/clock/lpc32xx-clock.h deleted file mode 100644 index e624d3a52798..000000000000 --- a/include/dt-bindings/clock/lpc32xx-clock.h +++ /dev/null @@ -1,58 +0,0 @@ -/* - * Copyright (c) 2015 Vladimir Zapolskiy vz@mleia.com - * - * This code is released using a dual license strategy: BSD/GPL - * You can choose the licence that better fits your requirements. - * - * Released under the terms of 3-clause BSD License - * Released under the terms of GNU General Public License Version 2.0 - * - */ - -#ifndef __DT_BINDINGS_LPC32XX_CLOCK_H -#define __DT_BINDINGS_LPC32XX_CLOCK_H - -/* LPC32XX System Control Block clocks */ -#define LPC32XX_CLK_RTC 1 -#define LPC32XX_CLK_DMA 2 -#define LPC32XX_CLK_MLC 3 -#define LPC32XX_CLK_SLC 4 -#define LPC32XX_CLK_LCD 5 -#define LPC32XX_CLK_MAC 6 -#define LPC32XX_CLK_SD 7 -#define LPC32XX_CLK_DDRAM 8 -#define LPC32XX_CLK_SSP0 9 -#define LPC32XX_CLK_SSP1 10 -#define LPC32XX_CLK_UART3 11 -#define LPC32XX_CLK_UART4 12 -#define LPC32XX_CLK_UART5 13 -#define LPC32XX_CLK_UART6 14 -#define LPC32XX_CLK_IRDA 15 -#define LPC32XX_CLK_I2C1 16 -#define LPC32XX_CLK_I2C2 17 -#define LPC32XX_CLK_TIMER0 18 -#define LPC32XX_CLK_TIMER1 19 -#define LPC32XX_CLK_TIMER2 20 -#define LPC32XX_CLK_TIMER3 21 -#define LPC32XX_CLK_TIMER4 22 -#define LPC32XX_CLK_TIMER5 23 -#define LPC32XX_CLK_WDOG 24 -#define LPC32XX_CLK_I2S0 25 -#define LPC32XX_CLK_I2S1 26 -#define LPC32XX_CLK_SPI1 27 -#define LPC32XX_CLK_SPI2 28 -#define LPC32XX_CLK_MCPWM 29 -#define LPC32XX_CLK_HSTIMER 30 -#define LPC32XX_CLK_KEY 31 -#define LPC32XX_CLK_PWM1 32 -#define LPC32XX_CLK_PWM2 33 -#define LPC32XX_CLK_ADC 34 -#define LPC32XX_CLK_HCLK_PLL 35 -#define LPC32XX_CLK_PERIPH 36 - -/* LPC32XX USB clocks */ -#define LPC32XX_USB_CLK_I2C 1 -#define LPC32XX_USB_CLK_DEVICE 2 -#define LPC32XX_USB_CLK_HOST 3 - -#endif /* __DT_BINDINGS_LPC32XX_CLOCK_H */ diff --git a/include/dt-bindings/clock/maxim,max77802.h b/include/dt-bindings/clock/maxim,max77802.h deleted file mode 100644 index 997312edcbb5..000000000000 --- a/include/dt-bindings/clock/maxim,max77802.h +++ /dev/null @@ -1,22 +0,0 @@ -/* - * Copyright (C) 2014 Google, Inc - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * Device Tree binding constants clocks for the Maxim 77802 PMIC. - */ - -#ifndef _DT_BINDINGS_CLOCK_MAXIM_MAX77802_CLOCK_H -#define _DT_BINDINGS_CLOCK_MAXIM_MAX77802_CLOCK_H - -/* Fixed rate clocks. */ - -#define MAX77802_CLK_32K_AP 0 -#define MAX77802_CLK_32K_CP 1 - -/* Total number of clocks. */ -#define MAX77802_CLKS_NUM (MAX77802_CLK_32K_CP + 1) - -#endif /* _DT_BINDINGS_CLOCK_MAXIM_MAX77802_CLOCK_H */ diff --git a/include/dt-bindings/clock/nuvoton,npcm7xx-clock.h b/include/dt-bindings/clock/nuvoton,npcm7xx-clock.h deleted file mode 100644 index 65e6bc4eeea0..000000000000 --- a/include/dt-bindings/clock/nuvoton,npcm7xx-clock.h +++ /dev/null @@ -1,46 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Nuvoton NPCM7xx Clock Generator binding - * clock binding number for all clocks supportted by nuvoton,npcm7xx-clk - * - * Copyright (C) 2018 Nuvoton Technologies tali.perry@nuvoton.com - * - */ - -#ifndef __DT_BINDINGS_CLOCK_NPCM7XX_H -#define __DT_BINDINGS_CLOCK_NPCM7XX_H - -#define NPCM7XX_CLK_CPU 0 -#define NPCM7XX_CLK_GFX_PIXEL 1 -#define NPCM7XX_CLK_MC 2 -#define NPCM7XX_CLK_ADC 3 -#define NPCM7XX_CLK_AHB 4 -#define NPCM7XX_CLK_TIMER 5 -#define NPCM7XX_CLK_UART 6 -#define NPCM7XX_CLK_MMC 7 -#define NPCM7XX_CLK_SPI3 8 -#define NPCM7XX_CLK_PCI 9 -#define NPCM7XX_CLK_AXI 10 -#define NPCM7XX_CLK_APB4 11 -#define NPCM7XX_CLK_APB3 12 -#define NPCM7XX_CLK_APB2 13 -#define NPCM7XX_CLK_APB1 14 -#define NPCM7XX_CLK_APB5 15 -#define NPCM7XX_CLK_CLKOUT 16 -#define NPCM7XX_CLK_GFX 17 -#define NPCM7XX_CLK_SU 18 -#define NPCM7XX_CLK_SU48 19 -#define NPCM7XX_CLK_SDHC 20 -#define NPCM7XX_CLK_SPI0 21 -#define NPCM7XX_CLK_SPIX 22 -#define NPCM7XX_CLK_REFCLK 23 -#define NPCM7XX_CLK_SYSBYPCK 24 -#define NPCM7XX_CLK_MCBYPCK 25 -#define NPCM7XX_CLK_PLL0 26 -#define NPCM7XX_CLK_PLL1 27 -#define NPCM7XX_CLK_PLL2 28 -#define NPCM7XX_CLK_PLL2DIV2 29 -#define NPCM7XX_NUM_CLOCKS (NPCM7XX_CLK_PLL2DIV2 + 1) - -#endif - diff --git a/include/dt-bindings/clock/rv1108-cru.h b/include/dt-bindings/clock/rv1108-cru.h deleted file mode 100644 index 10ed9d140f4b..000000000000 --- a/include/dt-bindings/clock/rv1108-cru.h +++ /dev/null @@ -1,356 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (c) 2017 Rockchip Electronics Co. Ltd. - * Author: Shawn Lin shawn.lin@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H - -/* pll id */ -#define PLL_APLL 0 -#define PLL_DPLL 1 -#define PLL_GPLL 2 -#define ARMCLK 3 - -/* sclk gates (special clocks) */ -#define SCLK_SPI0 65 -#define SCLK_NANDC 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO 69 -#define SCLK_EMMC 71 -#define SCLK_UART0 72 -#define SCLK_UART1 73 -#define SCLK_UART2 74 -#define SCLK_I2S0 75 -#define SCLK_I2S1 76 -#define SCLK_I2S2 77 -#define SCLK_TIMER0 78 -#define SCLK_TIMER1 79 -#define SCLK_SFC 80 -#define SCLK_SDMMC_DRV 81 -#define SCLK_SDIO_DRV 82 -#define SCLK_EMMC_DRV 83 -#define SCLK_SDMMC_SAMPLE 84 -#define SCLK_SDIO_SAMPLE 85 -#define SCLK_EMMC_SAMPLE 86 -#define SCLK_VENC_CORE 87 -#define SCLK_HEVC_CORE 88 -#define SCLK_HEVC_CABAC 89 -#define SCLK_PWM0_PMU 90 -#define SCLK_I2C0_PMU 91 -#define SCLK_WIFI 92 -#define SCLK_CIFOUT 93 -#define SCLK_MIPI_CSI_OUT 94 -#define SCLK_CIF0 95 -#define SCLK_CIF1 96 -#define SCLK_CIF2 97 -#define SCLK_CIF3 98 -#define SCLK_DSP 99 -#define SCLK_DSP_IOP 100 -#define SCLK_DSP_EPP 101 -#define SCLK_DSP_EDP 102 -#define SCLK_DSP_EDAP 103 -#define SCLK_CVBS_HOST 104 -#define SCLK_HDMI_SFR 105 -#define SCLK_HDMI_CEC 106 -#define SCLK_CRYPTO 107 -#define SCLK_SPI 108 -#define SCLK_SARADC 109 -#define SCLK_TSADC 110 -#define SCLK_MAC_PRE 111 -#define SCLK_MAC 112 -#define SCLK_MAC_RX 113 -#define SCLK_MAC_REF 114 -#define SCLK_MAC_REFOUT 115 -#define SCLK_DSP_PFM 116 -#define SCLK_RGA 117 -#define SCLK_I2C1 118 -#define SCLK_I2C2 119 -#define SCLK_I2C3 120 -#define SCLK_PWM 121 -#define SCLK_ISP 122 -#define SCLK_USBPHY 123 -#define SCLK_I2S0_SRC 124 -#define SCLK_I2S1_SRC 125 -#define SCLK_I2S2_SRC 126 -#define SCLK_UART0_SRC 127 -#define SCLK_UART1_SRC 128 -#define SCLK_UART2_SRC 129 -#define SCLK_MAC_TX 130 -#define SCLK_MACREF 131 -#define SCLK_MACREF_OUT 132 - -#define DCLK_VOP_SRC 185 -#define DCLK_HDMIPHY 186 -#define DCLK_VOP 187 - -/* aclk gates */ -#define ACLK_DMAC 192 -#define ACLK_PRE 193 -#define ACLK_CORE 194 -#define ACLK_ENMCORE 195 -#define ACLK_RKVENC 196 -#define ACLK_RKVDEC 197 -#define ACLK_VPU 198 -#define ACLK_CIF0 199 -#define ACLK_VIO0 200 -#define ACLK_VIO1 201 -#define ACLK_VOP 202 -#define ACLK_IEP 203 -#define ACLK_RGA 204 -#define ACLK_ISP 205 -#define ACLK_CIF1 206 -#define ACLK_CIF2 207 -#define ACLK_CIF3 208 -#define ACLK_PERI 209 -#define ACLK_GMAC 210 - -/* pclk gates */ -#define PCLK_GPIO1 256 -#define PCLK_GPIO2 257 -#define PCLK_GPIO3 258 -#define PCLK_GRF 259 -#define PCLK_I2C1 260 -#define PCLK_I2C2 261 -#define PCLK_I2C3 262 -#define PCLK_SPI 263 -#define PCLK_SFC 264 -#define PCLK_UART0 265 -#define PCLK_UART1 266 -#define PCLK_UART2 267 -#define PCLK_TSADC 268 -#define PCLK_PWM 269 -#define PCLK_TIMER 270 -#define PCLK_PERI 271 -#define PCLK_GPIO0_PMU 272 -#define PCLK_I2C0_PMU 273 -#define PCLK_PWM0_PMU 274 -#define PCLK_ISP 275 -#define PCLK_VIO 276 -#define PCLK_MIPI_DSI 277 -#define PCLK_HDMI_CTRL 278 -#define PCLK_SARADC 279 -#define PCLK_DSP_CFG 280 -#define PCLK_BUS 281 -#define PCLK_EFUSE0 282 -#define PCLK_EFUSE1 283 -#define PCLK_WDT 284 -#define PCLK_GMAC 285 - -/* hclk gates */ -#define HCLK_I2S0_8CH 320 -#define HCLK_I2S1_2CH 321 -#define HCLK_I2S2_2CH 322 -#define HCLK_NANDC 323 -#define HCLK_SDMMC 324 -#define HCLK_SDIO 325 -#define HCLK_EMMC 326 -#define HCLK_PERI 327 -#define HCLK_SFC 328 -#define HCLK_RKVENC 329 -#define HCLK_RKVDEC 330 -#define HCLK_CIF0 331 -#define HCLK_VIO 332 -#define HCLK_VOP 333 -#define HCLK_IEP 334 -#define HCLK_RGA 335 -#define HCLK_ISP 336 -#define HCLK_CRYPTO_MST 337 -#define HCLK_CRYPTO_SLV 338 -#define HCLK_HOST0 339 -#define HCLK_OTG 340 -#define HCLK_CIF1 341 -#define HCLK_CIF2 342 -#define HCLK_CIF3 343 -#define HCLK_BUS 344 -#define HCLK_VPU 345 - -#define CLK_NR_CLKS (HCLK_VPU + 1) - -/* reset id */ -#define SRST_CORE_PO_AD 0 -#define SRST_CORE_AD 1 -#define SRST_L2_AD 2 -#define SRST_CPU_NIU_AD 3 -#define SRST_CORE_PO 4 -#define SRST_CORE 5 -#define SRST_L2 6 -#define SRST_CORE_DBG 8 -#define PRST_DBG 9 -#define RST_DAP 10 -#define PRST_DBG_NIU 11 -#define ARST_STRC_SYS_AD 15 - -#define SRST_DDRPHY_CLKDIV 16 -#define SRST_DDRPHY 17 -#define PRST_DDRPHY 18 -#define PRST_HDMIPHY 19 -#define PRST_VDACPHY 20 -#define PRST_VADCPHY 21 -#define PRST_MIPI_CSI_PHY 22 -#define PRST_MIPI_DSI_PHY 23 -#define PRST_ACODEC 24 -#define ARST_BUS_NIU 25 -#define PRST_TOP_NIU 26 -#define ARST_INTMEM 27 -#define HRST_ROM 28 -#define ARST_DMAC 29 -#define SRST_MSCH_NIU 30 -#define PRST_MSCH_NIU 31 - -#define PRST_DDRUPCTL 32 -#define NRST_DDRUPCTL 33 -#define PRST_DDRMON 34 -#define HRST_I2S0_8CH 35 -#define MRST_I2S0_8CH 36 -#define HRST_I2S1_2CH 37 -#define MRST_IS21_2CH 38 -#define HRST_I2S2_2CH 39 -#define MRST_I2S2_2CH 40 -#define HRST_CRYPTO 41 -#define SRST_CRYPTO 42 -#define PRST_SPI 43 -#define SRST_SPI 44 -#define PRST_UART0 45 -#define PRST_UART1 46 -#define PRST_UART2 47 - -#define SRST_UART0 48 -#define SRST_UART1 49 -#define SRST_UART2 50 -#define PRST_I2C1 51 -#define PRST_I2C2 52 -#define PRST_I2C3 53 -#define SRST_I2C1 54 -#define SRST_I2C2 55 -#define SRST_I2C3 56 -#define PRST_PWM1 58 -#define SRST_PWM1 60 -#define PRST_WDT 61 -#define PRST_GPIO1 62 -#define PRST_GPIO2 63 - -#define PRST_GPIO3 64 -#define PRST_GRF 65 -#define PRST_EFUSE 66 -#define PRST_EFUSE512 67 -#define PRST_TIMER0 68 -#define SRST_TIMER0 69 -#define SRST_TIMER1 70 -#define PRST_TSADC 71 -#define SRST_TSADC 72 -#define PRST_SARADC 73 -#define SRST_SARADC 74 -#define HRST_SYSBUS 75 -#define PRST_USBGRF 76 - -#define ARST_PERIPH_NIU 80 -#define HRST_PERIPH_NIU 81 -#define PRST_PERIPH_NIU 82 -#define HRST_PERIPH 83 -#define HRST_SDMMC 84 -#define HRST_SDIO 85 -#define HRST_EMMC 86 -#define HRST_NANDC 87 -#define NRST_NANDC 88 -#define HRST_SFC 89 -#define SRST_SFC 90 -#define ARST_GMAC 91 -#define HRST_OTG 92 -#define SRST_OTG 93 -#define SRST_OTG_ADP 94 -#define HRST_HOST0 95 - -#define HRST_HOST0_AUX 96 -#define HRST_HOST0_ARB 97 -#define SRST_HOST0_EHCIPHY 98 -#define SRST_HOST0_UTMI 99 -#define SRST_USBPOR 100 -#define SRST_UTMI0 101 -#define SRST_UTMI1 102 - -#define ARST_VIO0_NIU 102 -#define ARST_VIO1_NIU 103 -#define HRST_VIO_NIU 104 -#define PRST_VIO_NIU 105 -#define ARST_VOP 106 -#define HRST_VOP 107 -#define DRST_VOP 108 -#define ARST_IEP 109 -#define HRST_IEP 110 -#define ARST_RGA 111 -#define HRST_RGA 112 -#define SRST_RGA 113 -#define PRST_CVBS 114 -#define PRST_HDMI 115 -#define SRST_HDMI 116 -#define PRST_MIPI_DSI 117 - -#define ARST_ISP_NIU 118 -#define HRST_ISP_NIU 119 -#define HRST_ISP 120 -#define SRST_ISP 121 -#define ARST_VIP0 122 -#define HRST_VIP0 123 -#define PRST_VIP0 124 -#define ARST_VIP1 125 -#define HRST_VIP1 126 -#define PRST_VIP1 127 -#define ARST_VIP2 128 -#define HRST_VIP2 129 -#define PRST_VIP2 120 -#define ARST_VIP3 121 -#define HRST_VIP3 122 -#define PRST_VIP4 123 - -#define PRST_CIF1TO4 124 -#define SRST_CVBS_CLK 125 -#define HRST_CVBS 126 - -#define ARST_VPU_NIU 140 -#define HRST_VPU_NIU 141 -#define ARST_VPU 142 -#define HRST_VPU 143 -#define ARST_RKVDEC_NIU 144 -#define HRST_RKVDEC_NIU 145 -#define ARST_RKVDEC 146 -#define HRST_RKVDEC 147 -#define SRST_RKVDEC_CABAC 148 -#define SRST_RKVDEC_CORE 149 -#define ARST_RKVENC_NIU 150 -#define HRST_RKVENC_NIU 151 -#define ARST_RKVENC 152 -#define HRST_RKVENC 153 -#define SRST_RKVENC_CORE 154 - -#define SRST_DSP_CORE 156 -#define SRST_DSP_SYS 157 -#define SRST_DSP_GLOBAL 158 -#define SRST_DSP_OECM 159 -#define PRST_DSP_IOP_NIU 160 -#define ARST_DSP_EPP_NIU 161 -#define ARST_DSP_EDP_NIU 162 -#define PRST_DSP_DBG_NIU 163 -#define PRST_DSP_CFG_NIU 164 -#define PRST_DSP_GRF 165 -#define PRST_DSP_MAILBOX 166 -#define PRST_DSP_INTC 167 -#define PRST_DSP_PFM_MON 169 -#define SRST_DSP_PFM_MON 170 -#define ARST_DSP_EDAP_NIU 171 - -#define SRST_PMU 172 -#define SRST_PMU_I2C0 173 -#define PRST_PMU_I2C0 174 -#define PRST_PMU_GPIO0 175 -#define PRST_PMU_INTMEM 176 -#define PRST_PMU_PWM0 177 -#define SRST_PMU_PWM0 178 -#define PRST_PMU_GRF 179 -#define SRST_PMU_NIU 180 -#define SRST_PMU_PVTM 181 -#define ARST_DSP_EDP_PERF 184 -#define ARST_DSP_EPP_PERF 185 - -#endif /* _DT_BINDINGS_CLK_ROCKCHIP_RV1108_H */ diff --git a/include/dt-bindings/clock/versaclock.h b/include/dt-bindings/clock/versaclock.h deleted file mode 100644 index c6a6a0946564..000000000000 --- a/include/dt-bindings/clock/versaclock.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ - -/* This file defines field values used by the versaclock 6 family - * for defining output type - */ - -#define VC5_LVPECL 0 -#define VC5_CMOS 1 -#define VC5_HCSL33 2 -#define VC5_LVDS 3 -#define VC5_CMOS2 4 -#define VC5_CMOSD 5 -#define VC5_HCSL25 6 diff --git a/include/dt-bindings/clock/vf610-clock.h b/include/dt-bindings/clock/vf610-clock.h deleted file mode 100644 index 373644e46747..000000000000 --- a/include/dt-bindings/clock/vf610-clock.h +++ /dev/null @@ -1,202 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#ifndef __DT_BINDINGS_CLOCK_VF610_H -#define __DT_BINDINGS_CLOCK_VF610_H - -#define VF610_CLK_DUMMY 0 -#define VF610_CLK_SIRC_128K 1 -#define VF610_CLK_SIRC_32K 2 -#define VF610_CLK_FIRC 3 -#define VF610_CLK_SXOSC 4 -#define VF610_CLK_FXOSC 5 -#define VF610_CLK_FXOSC_HALF 6 -#define VF610_CLK_SLOW_CLK_SEL 7 -#define VF610_CLK_FASK_CLK_SEL 8 -#define VF610_CLK_AUDIO_EXT 9 -#define VF610_CLK_ENET_EXT 10 -#define VF610_CLK_PLL1_SYS 11 -#define VF610_CLK_PLL1_PFD1 12 -#define VF610_CLK_PLL1_PFD2 13 -#define VF610_CLK_PLL1_PFD3 14 -#define VF610_CLK_PLL1_PFD4 15 -#define VF610_CLK_PLL2_BUS 16 -#define VF610_CLK_PLL2_PFD1 17 -#define VF610_CLK_PLL2_PFD2 18 -#define VF610_CLK_PLL2_PFD3 19 -#define VF610_CLK_PLL2_PFD4 20 -#define VF610_CLK_PLL3_USB_OTG 21 -#define VF610_CLK_PLL3_PFD1 22 -#define VF610_CLK_PLL3_PFD2 23 -#define VF610_CLK_PLL3_PFD3 24 -#define VF610_CLK_PLL3_PFD4 25 -#define VF610_CLK_PLL4_AUDIO 26 -#define VF610_CLK_PLL5_ENET 27 -#define VF610_CLK_PLL6_VIDEO 28 -#define VF610_CLK_PLL3_MAIN_DIV 29 -#define VF610_CLK_PLL4_MAIN_DIV 30 -#define VF610_CLK_PLL6_MAIN_DIV 31 -#define VF610_CLK_PLL1_PFD_SEL 32 -#define VF610_CLK_PLL2_PFD_SEL 33 -#define VF610_CLK_SYS_SEL 34 -#define VF610_CLK_DDR_SEL 35 -#define VF610_CLK_SYS_BUS 36 -#define VF610_CLK_PLATFORM_BUS 37 -#define VF610_CLK_IPG_BUS 38 -#define VF610_CLK_UART0 39 -#define VF610_CLK_UART1 40 -#define VF610_CLK_UART2 41 -#define VF610_CLK_UART3 42 -#define VF610_CLK_UART4 43 -#define VF610_CLK_UART5 44 -#define VF610_CLK_PIT 45 -#define VF610_CLK_I2C0 46 -#define VF610_CLK_I2C1 47 -#define VF610_CLK_I2C2 48 -#define VF610_CLK_I2C3 49 -#define VF610_CLK_FTM0_EXT_SEL 50 -#define VF610_CLK_FTM0_FIX_SEL 51 -#define VF610_CLK_FTM0_EXT_FIX_EN 52 -#define VF610_CLK_FTM1_EXT_SEL 53 -#define VF610_CLK_FTM1_FIX_SEL 54 -#define VF610_CLK_FTM1_EXT_FIX_EN 55 -#define VF610_CLK_FTM2_EXT_SEL 56 -#define VF610_CLK_FTM2_FIX_SEL 57 -#define VF610_CLK_FTM2_EXT_FIX_EN 58 -#define VF610_CLK_FTM3_EXT_SEL 59 -#define VF610_CLK_FTM3_FIX_SEL 60 -#define VF610_CLK_FTM3_EXT_FIX_EN 61 -#define VF610_CLK_FTM0 62 -#define VF610_CLK_FTM1 63 -#define VF610_CLK_FTM2 64 -#define VF610_CLK_FTM3 65 -#define VF610_CLK_ENET_50M 66 -#define VF610_CLK_ENET_25M 67 -#define VF610_CLK_ENET_SEL 68 -#define VF610_CLK_ENET 69 -#define VF610_CLK_ENET_TS_SEL 70 -#define VF610_CLK_ENET_TS 71 -#define VF610_CLK_DSPI0 72 -#define VF610_CLK_DSPI1 73 -#define VF610_CLK_DSPI2 74 -#define VF610_CLK_DSPI3 75 -#define VF610_CLK_WDT 76 -#define VF610_CLK_ESDHC0_SEL 77 -#define VF610_CLK_ESDHC0_EN 78 -#define VF610_CLK_ESDHC0_DIV 79 -#define VF610_CLK_ESDHC0 80 -#define VF610_CLK_ESDHC1_SEL 81 -#define VF610_CLK_ESDHC1_EN 82 -#define VF610_CLK_ESDHC1_DIV 83 -#define VF610_CLK_ESDHC1 84 -#define VF610_CLK_DCU0_SEL 85 -#define VF610_CLK_DCU0_EN 86 -#define VF610_CLK_DCU0_DIV 87 -#define VF610_CLK_DCU0 88 -#define VF610_CLK_DCU1_SEL 89 -#define VF610_CLK_DCU1_EN 90 -#define VF610_CLK_DCU1_DIV 91 -#define VF610_CLK_DCU1 92 -#define VF610_CLK_ESAI_SEL 93 -#define VF610_CLK_ESAI_EN 94 -#define VF610_CLK_ESAI_DIV 95 -#define VF610_CLK_ESAI 96 -#define VF610_CLK_SAI0_SEL 97 -#define VF610_CLK_SAI0_EN 98 -#define VF610_CLK_SAI0_DIV 99 -#define VF610_CLK_SAI0 100 -#define VF610_CLK_SAI1_SEL 101 -#define VF610_CLK_SAI1_EN 102 -#define VF610_CLK_SAI1_DIV 103 -#define VF610_CLK_SAI1 104 -#define VF610_CLK_SAI2_SEL 105 -#define VF610_CLK_SAI2_EN 106 -#define VF610_CLK_SAI2_DIV 107 -#define VF610_CLK_SAI2 108 -#define VF610_CLK_SAI3_SEL 109 -#define VF610_CLK_SAI3_EN 110 -#define VF610_CLK_SAI3_DIV 111 -#define VF610_CLK_SAI3 112 -#define VF610_CLK_USBC0 113 -#define VF610_CLK_USBC1 114 -#define VF610_CLK_QSPI0_SEL 115 -#define VF610_CLK_QSPI0_EN 116 -#define VF610_CLK_QSPI0_X4_DIV 117 -#define VF610_CLK_QSPI0_X2_DIV 118 -#define VF610_CLK_QSPI0_X1_DIV 119 -#define VF610_CLK_QSPI1_SEL 120 -#define VF610_CLK_QSPI1_EN 121 -#define VF610_CLK_QSPI1_X4_DIV 122 -#define VF610_CLK_QSPI1_X2_DIV 123 -#define VF610_CLK_QSPI1_X1_DIV 124 -#define VF610_CLK_QSPI0 125 -#define VF610_CLK_QSPI1 126 -#define VF610_CLK_NFC_SEL 127 -#define VF610_CLK_NFC_EN 128 -#define VF610_CLK_NFC_PRE_DIV 129 -#define VF610_CLK_NFC_FRAC_DIV 130 -#define VF610_CLK_NFC_INV 131 -#define VF610_CLK_NFC 132 -#define VF610_CLK_VADC_SEL 133 -#define VF610_CLK_VADC_EN 134 -#define VF610_CLK_VADC_DIV 135 -#define VF610_CLK_VADC_DIV_HALF 136 -#define VF610_CLK_VADC 137 -#define VF610_CLK_ADC0 138 -#define VF610_CLK_ADC1 139 -#define VF610_CLK_DAC0 140 -#define VF610_CLK_DAC1 141 -#define VF610_CLK_FLEXCAN0 142 -#define VF610_CLK_FLEXCAN1 143 -#define VF610_CLK_ASRC 144 -#define VF610_CLK_GPU_SEL 145 -#define VF610_CLK_GPU_EN 146 -#define VF610_CLK_GPU2D 147 -#define VF610_CLK_ENET0 148 -#define VF610_CLK_ENET1 149 -#define VF610_CLK_DMAMUX0 150 -#define VF610_CLK_DMAMUX1 151 -#define VF610_CLK_DMAMUX2 152 -#define VF610_CLK_DMAMUX3 153 -#define VF610_CLK_FLEXCAN0_EN 154 -#define VF610_CLK_FLEXCAN1_EN 155 -#define VF610_CLK_PLL7_USB_HOST 156 -#define VF610_CLK_USBPHY0 157 -#define VF610_CLK_USBPHY1 158 -#define VF610_CLK_LVDS1_IN 159 -#define VF610_CLK_ANACLK1 160 -#define VF610_CLK_PLL1_BYPASS_SRC 161 -#define VF610_CLK_PLL2_BYPASS_SRC 162 -#define VF610_CLK_PLL3_BYPASS_SRC 163 -#define VF610_CLK_PLL4_BYPASS_SRC 164 -#define VF610_CLK_PLL5_BYPASS_SRC 165 -#define VF610_CLK_PLL6_BYPASS_SRC 166 -#define VF610_CLK_PLL7_BYPASS_SRC 167 -#define VF610_CLK_PLL1 168 -#define VF610_CLK_PLL2 169 -#define VF610_CLK_PLL3 170 -#define VF610_CLK_PLL4 171 -#define VF610_CLK_PLL5 172 -#define VF610_CLK_PLL6 173 -#define VF610_CLK_PLL7 174 -#define VF610_PLL1_BYPASS 175 -#define VF610_PLL2_BYPASS 176 -#define VF610_PLL3_BYPASS 177 -#define VF610_PLL4_BYPASS 178 -#define VF610_PLL5_BYPASS 179 -#define VF610_PLL6_BYPASS 180 -#define VF610_PLL7_BYPASS 181 -#define VF610_CLK_SNVS 182 -#define VF610_CLK_DAP 183 -#define VF610_CLK_OCOTP 184 -#define VF610_CLK_DDRMC 185 -#define VF610_CLK_WKPU 186 -#define VF610_CLK_TCON0 187 -#define VF610_CLK_TCON1 188 -#define VF610_CLK_CAAM 189 -#define VF610_CLK_CRC 190 -#define VF610_CLK_END 191 - -#endif /* __DT_BINDINGS_CLOCK_VF610_H */
Remaining device headers for small vendors
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/arm/coresight-cti-dt.h | 37 ----- include/dt-bindings/arm/ux500_pm_domains.h | 15 -- include/dt-bindings/bus/moxtet.h | 16 -- include/dt-bindings/display/tda998x.h | 8 - include/dt-bindings/gpio/aspeed-gpio.h | 51 ------ include/dt-bindings/gpio/uniphier-gpio.h | 18 -- .../dt-bindings/interrupt-controller/apple-aic.h | 15 -- include/dt-bindings/interrupt-controller/arm-gic.h | 23 --- include/dt-bindings/interrupt-controller/irq-st.h | 30 ---- .../dt-bindings/interrupt-controller/irqc-rzg2l.h | 25 --- .../dt-bindings/interrupt-controller/mips-gic.h | 9 - include/dt-bindings/leds/leds-netxbig.h | 18 -- include/dt-bindings/leds/leds-ns2.h | 9 - include/dt-bindings/leds/leds-pca9532.h | 18 -- include/dt-bindings/media/tda1997x.h | 74 --------- include/dt-bindings/media/video-interfaces.h | 16 -- include/dt-bindings/mfd/atmel-flexcom.h | 15 -- include/dt-bindings/mfd/dbx500-prcmu.h | 84 ---------- include/dt-bindings/net/mscc-phy-vsc8531.h | 31 ---- include/dt-bindings/net/qca-ar803x.h | 13 -- include/dt-bindings/phy/phy-am654-serdes.h | 13 -- include/dt-bindings/phy/phy-cadence.h | 24 --- include/dt-bindings/pinctrl/apple.h | 13 -- include/dt-bindings/pinctrl/dra.h | 79 --------- include/dt-bindings/power/owl-s700-powergate.h | 19 --- include/dt-bindings/power/raspberrypi-power.h | 41 ----- .../dt-bindings/regulator/dlg,da9063-regulator.h | 16 -- include/dt-bindings/regulator/maxim,max77802.h | 18 -- include/dt-bindings/reset/actions,s700-reset.h | 34 ---- include/dt-bindings/reset/actions,s900-reset.h | 65 -------- include/dt-bindings/reset/altr,rst-mgr-a10.h | 110 ------------- include/dt-bindings/reset/altr,rst-mgr-s10.h | 96 ----------- include/dt-bindings/reset/altr,rst-mgr.h | 82 --------- include/dt-bindings/reset/nuvoton,npcm7xx-reset.h | 91 ---------- .../dt-bindings/reset/raspberrypi,firmware-reset.h | 13 -- include/dt-bindings/reset/sama7g5-reset.h | 10 -- include/dt-bindings/reset/snps,hsdk-reset.h | 17 -- include/dt-bindings/reset/starfive,jh7110-crg.h | 183 --------------------- include/dt-bindings/sound/apq8016-lpass.h | 9 - include/dt-bindings/sound/tlv320aic31xx.h | 14 -- 40 files changed, 1472 deletions(-)
diff --git a/include/dt-bindings/arm/coresight-cti-dt.h b/include/dt-bindings/arm/coresight-cti-dt.h deleted file mode 100644 index 61e7bdf8ea6e..000000000000 --- a/include/dt-bindings/arm/coresight-cti-dt.h +++ /dev/null @@ -1,37 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the defined trigger signal - * types on CoreSight CTI. - */ - -#ifndef _DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H -#define _DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H - -#define GEN_IO 0 -#define GEN_INTREQ 1 -#define GEN_INTACK 2 -#define GEN_HALTREQ 3 -#define GEN_RESTARTREQ 4 -#define PE_EDBGREQ 5 -#define PE_DBGRESTART 6 -#define PE_CTIIRQ 7 -#define PE_PMUIRQ 8 -#define PE_DBGTRIGGER 9 -#define ETM_EXTOUT 10 -#define ETM_EXTIN 11 -#define SNK_FULL 12 -#define SNK_ACQCOMP 13 -#define SNK_FLUSHCOMP 14 -#define SNK_FLUSHIN 15 -#define SNK_TRIGIN 16 -#define STM_ASYNCOUT 17 -#define STM_TOUT_SPTE 18 -#define STM_TOUT_SW 19 -#define STM_TOUT_HETE 20 -#define STM_HWEVENT 21 -#define ELA_TSTART 22 -#define ELA_TSTOP 23 -#define ELA_DBGREQ 24 -#define CTI_TRIG_MAX 25 - -#endif /*_DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H */ diff --git a/include/dt-bindings/arm/ux500_pm_domains.h b/include/dt-bindings/arm/ux500_pm_domains.h deleted file mode 100644 index 9bd764f0c9e6..000000000000 --- a/include/dt-bindings/arm/ux500_pm_domains.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Copyright (C) 2014 Linaro Ltd. - * - * Author: Ulf Hansson ulf.hansson@linaro.org - */ -#ifndef _DT_BINDINGS_ARM_UX500_PM_DOMAINS_H -#define _DT_BINDINGS_ARM_UX500_PM_DOMAINS_H - -#define DOMAIN_VAPE 0 - -/* Number of PM domains. */ -#define NR_DOMAINS (DOMAIN_VAPE + 1) - -#endif diff --git a/include/dt-bindings/bus/moxtet.h b/include/dt-bindings/bus/moxtet.h deleted file mode 100644 index 10528de7b3ef..000000000000 --- a/include/dt-bindings/bus/moxtet.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Constant for device tree bindings for Turris Mox module configuration bus - * - * Copyright (C) 2019 Marek Behún kabel@kernel.org - */ - -#ifndef _DT_BINDINGS_BUS_MOXTET_H -#define _DT_BINDINGS_BUS_MOXTET_H - -#define MOXTET_IRQ_PCI 0 -#define MOXTET_IRQ_USB3 4 -#define MOXTET_IRQ_PERIDOT(n) (8 + (n)) -#define MOXTET_IRQ_TOPAZ 12 - -#endif /* _DT_BINDINGS_BUS_MOXTET_H */ diff --git a/include/dt-bindings/display/tda998x.h b/include/dt-bindings/display/tda998x.h deleted file mode 100644 index 746831ff396c..000000000000 --- a/include/dt-bindings/display/tda998x.h +++ /dev/null @@ -1,8 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef _DT_BINDINGS_TDA998X_H -#define _DT_BINDINGS_TDA998X_H - -#define TDA998x_SPDIF 1 -#define TDA998x_I2S 2 - -#endif /*_DT_BINDINGS_TDA998X_H */ diff --git a/include/dt-bindings/gpio/aspeed-gpio.h b/include/dt-bindings/gpio/aspeed-gpio.h deleted file mode 100644 index a49f5d5b5af0..000000000000 --- a/include/dt-bindings/gpio/aspeed-gpio.h +++ /dev/null @@ -1,51 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2022 IBM Corp. - * - * This header provides constants for binding aspeed,*-gpio. - * - * The first cell in Aspeed's GPIO specifier is the GPIO ID. The macros below - * provide names for this. - * - * The second cell contains standard flag values specified in gpio.h. - */ - -#ifndef _DT_BINDINGS_GPIO_ASPEED_GPIO_H -#define _DT_BINDINGS_GPIO_ASPEED_GPIO_H - -#include <dt-bindings/gpio/gpio.h> - -#define ASPEED_GPIO_PORT_A 0 -#define ASPEED_GPIO_PORT_B 1 -#define ASPEED_GPIO_PORT_C 2 -#define ASPEED_GPIO_PORT_D 3 -#define ASPEED_GPIO_PORT_E 4 -#define ASPEED_GPIO_PORT_F 5 -#define ASPEED_GPIO_PORT_G 6 -#define ASPEED_GPIO_PORT_H 7 -#define ASPEED_GPIO_PORT_I 8 -#define ASPEED_GPIO_PORT_J 9 -#define ASPEED_GPIO_PORT_K 10 -#define ASPEED_GPIO_PORT_L 11 -#define ASPEED_GPIO_PORT_M 12 -#define ASPEED_GPIO_PORT_N 13 -#define ASPEED_GPIO_PORT_O 14 -#define ASPEED_GPIO_PORT_P 15 -#define ASPEED_GPIO_PORT_Q 16 -#define ASPEED_GPIO_PORT_R 17 -#define ASPEED_GPIO_PORT_S 18 -#define ASPEED_GPIO_PORT_T 19 -#define ASPEED_GPIO_PORT_U 20 -#define ASPEED_GPIO_PORT_V 21 -#define ASPEED_GPIO_PORT_W 22 -#define ASPEED_GPIO_PORT_X 23 -#define ASPEED_GPIO_PORT_Y 24 -#define ASPEED_GPIO_PORT_Z 25 -#define ASPEED_GPIO_PORT_AA 26 -#define ASPEED_GPIO_PORT_AB 27 -#define ASPEED_GPIO_PORT_AC 28 - -#define ASPEED_GPIO(port, offset) \ - ((ASPEED_GPIO_PORT_##port * 8) + (offset)) - -#endif diff --git a/include/dt-bindings/gpio/uniphier-gpio.h b/include/dt-bindings/gpio/uniphier-gpio.h deleted file mode 100644 index 9f0ad174f61c..000000000000 --- a/include/dt-bindings/gpio/uniphier-gpio.h +++ /dev/null @@ -1,18 +0,0 @@ -/* - * Copyright (C) 2017 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - */ - -#ifndef _DT_BINDINGS_GPIO_UNIPHIER_H -#define _DT_BINDINGS_GPIO_UNIPHIER_H - -#define UNIPHIER_GPIO_LINES_PER_BANK 8 - -#define UNIPHIER_GPIO_IRQ_OFFSET ((UNIPHIER_GPIO_LINES_PER_BANK) * 15) - -#define UNIPHIER_GPIO_PORT(bank, line) \ - ((UNIPHIER_GPIO_LINES_PER_BANK) * (bank) + (line)) - -#define UNIPHIER_GPIO_IRQ(n) ((UNIPHIER_GPIO_IRQ_OFFSET) + (n)) - -#endif /* _DT_BINDINGS_GPIO_UNIPHIER_H */ diff --git a/include/dt-bindings/interrupt-controller/apple-aic.h b/include/dt-bindings/interrupt-controller/apple-aic.h deleted file mode 100644 index 9ac56a7e6d3f..000000000000 --- a/include/dt-bindings/interrupt-controller/apple-aic.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_APPLE_AIC_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_APPLE_AIC_H - -#include <dt-bindings/interrupt-controller/irq.h> - -#define AIC_IRQ 0 -#define AIC_FIQ 1 - -#define AIC_TMR_HV_PHYS 0 -#define AIC_TMR_HV_VIRT 1 -#define AIC_TMR_GUEST_PHYS 2 -#define AIC_TMR_GUEST_VIRT 3 - -#endif diff --git a/include/dt-bindings/interrupt-controller/arm-gic.h b/include/dt-bindings/interrupt-controller/arm-gic.h deleted file mode 100644 index 35b6f69b7db6..000000000000 --- a/include/dt-bindings/interrupt-controller/arm-gic.h +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 OR MIT */ -/* - * This header provides constants for the ARM GIC. - */ - -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H - -#include <dt-bindings/interrupt-controller/irq.h> - -/* interrupt specifier cell 0 */ - -#define GIC_SPI 0 -#define GIC_PPI 1 - -/* - * Interrupt specifier cell 2. - * The flags in irq.h are valid, plus those below. - */ -#define GIC_CPU_MASK_RAW(x) ((x) << 8) -#define GIC_CPU_MASK_SIMPLE(num) GIC_CPU_MASK_RAW((1 << (num)) - 1) - -#endif diff --git a/include/dt-bindings/interrupt-controller/irq-st.h b/include/dt-bindings/interrupt-controller/irq-st.h deleted file mode 100644 index 6baa9ad2644c..000000000000 --- a/include/dt-bindings/interrupt-controller/irq-st.h +++ /dev/null @@ -1,30 +0,0 @@ -/* - * include/linux/irqchip/irq-st.h - * - * Copyright (C) 2014 STMicroelectronics All Rights Reserved - * - * Author: Lee Jones lee.jones@linaro.org - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_ST_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_ST_H - -#define ST_IRQ_SYSCFG_EXT_0 0 -#define ST_IRQ_SYSCFG_EXT_1 1 -#define ST_IRQ_SYSCFG_EXT_2 2 -#define ST_IRQ_SYSCFG_CTI_0 3 -#define ST_IRQ_SYSCFG_CTI_1 4 -#define ST_IRQ_SYSCFG_PMU_0 5 -#define ST_IRQ_SYSCFG_PMU_1 6 -#define ST_IRQ_SYSCFG_pl310_L2 7 -#define ST_IRQ_SYSCFG_DISABLED 0xFFFFFFFF - -#define ST_IRQ_SYSCFG_EXT_1_INV 0x1 -#define ST_IRQ_SYSCFG_EXT_2_INV 0x2 -#define ST_IRQ_SYSCFG_EXT_3_INV 0x4 - -#endif diff --git a/include/dt-bindings/interrupt-controller/irqc-rzg2l.h b/include/dt-bindings/interrupt-controller/irqc-rzg2l.h deleted file mode 100644 index 34ce778885a1..000000000000 --- a/include/dt-bindings/interrupt-controller/irqc-rzg2l.h +++ /dev/null @@ -1,25 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * This header provides constants for Renesas RZ/G2L family IRQC bindings. - * - * Copyright (C) 2022 Renesas Electronics Corp. - * - */ - -#ifndef __DT_BINDINGS_IRQC_RZG2L_H -#define __DT_BINDINGS_IRQC_RZG2L_H - -/* NMI maps to SPI0 */ -#define RZG2L_NMI 0 - -/* IRQ0-7 map to SPI1-8 */ -#define RZG2L_IRQ0 1 -#define RZG2L_IRQ1 2 -#define RZG2L_IRQ2 3 -#define RZG2L_IRQ3 4 -#define RZG2L_IRQ4 5 -#define RZG2L_IRQ5 6 -#define RZG2L_IRQ6 7 -#define RZG2L_IRQ7 8 - -#endif /* __DT_BINDINGS_IRQC_RZG2L_H */ diff --git a/include/dt-bindings/interrupt-controller/mips-gic.h b/include/dt-bindings/interrupt-controller/mips-gic.h deleted file mode 100644 index cf35a577e371..000000000000 --- a/include/dt-bindings/interrupt-controller/mips-gic.h +++ /dev/null @@ -1,9 +0,0 @@ -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_MIPS_GIC_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_MIPS_GIC_H - -#include <dt-bindings/interrupt-controller/irq.h> - -#define GIC_SHARED 0 -#define GIC_LOCAL 1 - -#endif diff --git a/include/dt-bindings/leds/leds-netxbig.h b/include/dt-bindings/leds/leds-netxbig.h deleted file mode 100644 index 92658b0310b2..000000000000 --- a/include/dt-bindings/leds/leds-netxbig.h +++ /dev/null @@ -1,18 +0,0 @@ -/* - * This header provides constants for netxbig LED bindings. - * - * This file is licensed under the terms of the GNU General Public - * License version 2. This program is licensed "as is" without any - * warranty of any kind, whether express or implied. - */ - -#ifndef _DT_BINDINGS_LEDS_NETXBIG_H -#define _DT_BINDINGS_LEDS_NETXBIG_H - -#define NETXBIG_LED_OFF 0 -#define NETXBIG_LED_ON 1 -#define NETXBIG_LED_SATA 2 -#define NETXBIG_LED_TIMER1 3 -#define NETXBIG_LED_TIMER2 4 - -#endif /* _DT_BINDINGS_LEDS_NETXBIG_H */ diff --git a/include/dt-bindings/leds/leds-ns2.h b/include/dt-bindings/leds/leds-ns2.h deleted file mode 100644 index fd615749e703..000000000000 --- a/include/dt-bindings/leds/leds-ns2.h +++ /dev/null @@ -1,9 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef _DT_BINDINGS_LEDS_NS2_H -#define _DT_BINDINGS_LEDS_NS2_H - -#define NS_V2_LED_OFF 0 -#define NS_V2_LED_ON 1 -#define NS_V2_LED_SATA 2 - -#endif diff --git a/include/dt-bindings/leds/leds-pca9532.h b/include/dt-bindings/leds/leds-pca9532.h deleted file mode 100644 index 4d917aab7e1e..000000000000 --- a/include/dt-bindings/leds/leds-pca9532.h +++ /dev/null @@ -1,18 +0,0 @@ -/* - * This header provides constants for pca9532 LED bindings. - * - * This file is licensed under the terms of the GNU General Public - * License version 2. This program is licensed "as is" without any - * warranty of any kind, whether express or implied. - */ - -#ifndef _DT_BINDINGS_LEDS_PCA9532_H -#define _DT_BINDINGS_LEDS_PCA9532_H - -#define PCA9532_TYPE_NONE 0 -#define PCA9532_TYPE_LED 1 -#define PCA9532_TYPE_N2100_BEEP 2 -#define PCA9532_TYPE_GPIO 3 -#define PCA9532_LED_TIMER2 4 - -#endif /* _DT_BINDINGS_LEDS_PCA9532_H */ diff --git a/include/dt-bindings/media/tda1997x.h b/include/dt-bindings/media/tda1997x.h deleted file mode 100644 index bd9fbd718ec9..000000000000 --- a/include/dt-bindings/media/tda1997x.h +++ /dev/null @@ -1,74 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2017 Gateworks Corporation - */ -#ifndef _DT_BINDINGS_MEDIA_TDA1997X_H -#define _DT_BINDINGS_MEDIA_TDA1997X_H - -/* TDA19973 36bit Video Port control registers */ -#define TDA1997X_VP36_35_32 0 -#define TDA1997X_VP36_31_28 1 -#define TDA1997X_VP36_27_24 2 -#define TDA1997X_VP36_23_20 3 -#define TDA1997X_VP36_19_16 4 -#define TDA1997X_VP36_15_12 5 -#define TDA1997X_VP36_11_08 6 -#define TDA1997X_VP36_07_04 7 -#define TDA1997X_VP36_03_00 8 - -/* TDA19971 24bit Video Port control registers */ -#define TDA1997X_VP24_V23_20 0 -#define TDA1997X_VP24_V19_16 1 -#define TDA1997X_VP24_V15_12 3 -#define TDA1997X_VP24_V11_08 4 -#define TDA1997X_VP24_V07_04 6 -#define TDA1997X_VP24_V03_00 7 - -/* Pin groups */ -#define TDA1997X_VP_OUT_EN 0x80 /* enable output group */ -#define TDA1997X_VP_HIZ 0x40 /* hi-Z output group when not used */ -#define TDA1997X_VP_SWP 0x10 /* pin-swap output group */ -#define TDA1997X_R_CR_CBCR_3_0 (0 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_R_CR_CBCR_7_4 (1 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_R_CR_CBCR_11_8 (2 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_B_CB_3_0 (3 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_B_CB_7_4 (4 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_B_CB_11_8 (5 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_G_Y_3_0 (6 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_G_Y_7_4 (7 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -#define TDA1997X_G_Y_11_8 (8 | TDA1997X_VP_OUT_EN | TDA1997X_VP_HIZ) -/* pinswapped groups */ -#define TDA1997X_R_CR_CBCR_3_0_S (TDA1997X_R_CR_CBCR_3_0 | TDA1997X_VP_SWAP) -#define TDA1997X_R_CR_CBCR_7_4_S (TDA1997X_R_CR_CBCR_7_4 | TDA1997X_VP_SWAP) -#define TDA1997X_R_CR_CBCR_11_8_S (TDA1997X_R_CR_CBCR_11_8 | TDA1997X_VP_SWAP) -#define TDA1997X_B_CB_3_0_S (TDA1997X_B_CB_3_0 | TDA1997X_VP_SWAP) -#define TDA1997X_B_CB_7_4_S (TDA1997X_B_CB_7_4 | TDA1997X_VP_SWAP) -#define TDA1997X_B_CB_11_8_S (TDA1997X_B_CB_11_8 | TDA1997X_VP_SWAP) -#define TDA1997X_G_Y_3_0_S (TDA1997X_G_Y_3_0 | TDA1997X_VP_SWAP) -#define TDA1997X_G_Y_7_4_S (TDA1997X_G_Y_7_4 | TDA1997X_VP_SWAP) -#define TDA1997X_G_Y_11_8_S (TDA1997X_G_Y_11_8 | TDA1997X_VP_SWAP) - -/* Audio bus DAI format */ -#define TDA1997X_I2S16 1 /* I2S 16bit */ -#define TDA1997X_I2S32 2 /* I2S 32bit */ -#define TDA1997X_SPDIF 3 /* SPDIF */ -#define TDA1997X_OBA 4 /* One Bit Audio */ -#define TDA1997X_DST 5 /* Direct Stream Transfer */ -#define TDA1997X_I2S16_HBR 6 /* HBR straight in I2S 16bit mode */ -#define TDA1997X_I2S16_HBR_DEMUX 7 /* HBR demux in I2S 16bit mode */ -#define TDA1997X_I2S32_HBR_DEMUX 8 /* HBR demux in I2S 32bit mode */ -#define TDA1997X_SPDIF_HBR_DEMUX 9 /* HBR demux in SPDIF mode */ - -/* Audio bus channel layout */ -#define TDA1997X_LAYOUT0 0 /* 2-channel */ -#define TDA1997X_LAYOUT1 1 /* 8-channel */ - -/* Audio bus clock */ -#define TDA1997X_ACLK_16FS 0 -#define TDA1997X_ACLK_32FS 1 -#define TDA1997X_ACLK_64FS 2 -#define TDA1997X_ACLK_128FS 3 -#define TDA1997X_ACLK_256FS 4 -#define TDA1997X_ACLK_512FS 5 - -#endif /* _DT_BINDINGS_MEDIA_TDA1997X_H */ diff --git a/include/dt-bindings/media/video-interfaces.h b/include/dt-bindings/media/video-interfaces.h deleted file mode 100644 index 68ac4e05e37f..000000000000 --- a/include/dt-bindings/media/video-interfaces.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR MIT) */ -/* - * Copyright (C) 2022 Laurent Pinchart laurent.pinchart@ideasonboard.com - */ - -#ifndef __DT_BINDINGS_MEDIA_VIDEO_INTERFACES_H__ -#define __DT_BINDINGS_MEDIA_VIDEO_INTERFACES_H__ - -#define MEDIA_BUS_TYPE_CSI2_CPHY 1 -#define MEDIA_BUS_TYPE_CSI1 2 -#define MEDIA_BUS_TYPE_CCP2 3 -#define MEDIA_BUS_TYPE_CSI2_DPHY 4 -#define MEDIA_BUS_TYPE_PARALLEL 5 -#define MEDIA_BUS_TYPE_BT656 6 - -#endif /* __DT_BINDINGS_MEDIA_VIDEO_INTERFACES_H__ */ diff --git a/include/dt-bindings/mfd/atmel-flexcom.h b/include/dt-bindings/mfd/atmel-flexcom.h deleted file mode 100644 index 4e2fc3236394..000000000000 --- a/include/dt-bindings/mfd/atmel-flexcom.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * This header provides macros for Atmel Flexcom DT bindings. - * - * Copyright (C) 2015 Cyrille Pitchen cyrille.pitchen@atmel.com - */ - -#ifndef __DT_BINDINGS_ATMEL_FLEXCOM_H__ -#define __DT_BINDINGS_ATMEL_FLEXCOM_H__ - -#define ATMEL_FLEXCOM_MODE_USART 1 -#define ATMEL_FLEXCOM_MODE_SPI 2 -#define ATMEL_FLEXCOM_MODE_TWI 3 - -#endif /* __DT_BINDINGS_ATMEL_FLEXCOM_H__ */ diff --git a/include/dt-bindings/mfd/dbx500-prcmu.h b/include/dt-bindings/mfd/dbx500-prcmu.h deleted file mode 100644 index 7266ae67b03a..000000000000 --- a/include/dt-bindings/mfd/dbx500-prcmu.h +++ /dev/null @@ -1,84 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for the PRCMU bindings. - * - */ - -#ifndef _DT_BINDINGS_MFD_PRCMU_H -#define _DT_BINDINGS_MFD_PRCMU_H - -/* - * Clock identifiers. - */ -#define ARMCLK 0 -#define PRCMU_ACLK 1 -#define PRCMU_SVAMMCSPCLK 2 -#define PRCMU_SDMMCHCLK 2 /* DBx540 only. */ -#define PRCMU_SIACLK 3 -#define PRCMU_SIAMMDSPCLK 3 /* DBx540 only. */ -#define PRCMU_SGACLK 4 -#define PRCMU_UARTCLK 5 -#define PRCMU_MSP02CLK 6 -#define PRCMU_MSP1CLK 7 -#define PRCMU_I2CCLK 8 -#define PRCMU_SDMMCCLK 9 -#define PRCMU_SLIMCLK 10 -#define PRCMU_CAMCLK 10 /* DBx540 only. */ -#define PRCMU_PER1CLK 11 -#define PRCMU_PER2CLK 12 -#define PRCMU_PER3CLK 13 -#define PRCMU_PER5CLK 14 -#define PRCMU_PER6CLK 15 -#define PRCMU_PER7CLK 16 -#define PRCMU_LCDCLK 17 -#define PRCMU_BMLCLK 18 -#define PRCMU_HSITXCLK 19 -#define PRCMU_HSIRXCLK 20 -#define PRCMU_HDMICLK 21 -#define PRCMU_APEATCLK 22 -#define PRCMU_APETRACECLK 23 -#define PRCMU_MCDECLK 24 -#define PRCMU_IPI2CCLK 25 -#define PRCMU_DSIALTCLK 26 -#define PRCMU_DMACLK 27 -#define PRCMU_B2R2CLK 28 -#define PRCMU_TVCLK 29 -#define SPARE_UNIPROCLK 30 -#define PRCMU_SSPCLK 31 -#define PRCMU_RNGCLK 32 -#define PRCMU_UICCCLK 33 -#define PRCMU_G1CLK 34 /* DBx540 only. */ -#define PRCMU_HVACLK 35 /* DBx540 only. */ -#define PRCMU_SPARE1CLK 36 -#define PRCMU_SPARE2CLK 37 - -#define PRCMU_NUM_REG_CLOCKS 38 - -#define PRCMU_RTCCLK PRCMU_NUM_REG_CLOCKS -#define PRCMU_SYSCLK 39 -#define PRCMU_CDCLK 40 -#define PRCMU_TIMCLK 41 -#define PRCMU_PLLSOC0 42 -#define PRCMU_PLLSOC1 43 -#define PRCMU_ARMSS 44 -#define PRCMU_PLLDDR 45 - -/* DSI Clocks */ -#define PRCMU_PLLDSI 46 -#define PRCMU_DSI0CLK 47 -#define PRCMU_DSI1CLK 48 -#define PRCMU_DSI0ESCCLK 49 -#define PRCMU_DSI1ESCCLK 50 -#define PRCMU_DSI2ESCCLK 51 - -/* LCD DSI PLL - Ux540 only */ -#define PRCMU_PLLDSI_LCD 52 -#define PRCMU_DSI0CLK_LCD 53 -#define PRCMU_DSI1CLK_LCD 54 -#define PRCMU_DSI0ESCCLK_LCD 55 -#define PRCMU_DSI1ESCCLK_LCD 56 -#define PRCMU_DSI2ESCCLK_LCD 57 - -#define PRCMU_NUM_CLKS 58 - -#endif diff --git a/include/dt-bindings/net/mscc-phy-vsc8531.h b/include/dt-bindings/net/mscc-phy-vsc8531.h deleted file mode 100644 index c340437414fb..000000000000 --- a/include/dt-bindings/net/mscc-phy-vsc8531.h +++ /dev/null @@ -1,31 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Device Tree constants for Microsemi VSC8531 PHY - * - * Author: Nagaraju Lakkaraju - * - * Copyright (c) 2017 Microsemi Corporation - */ - -#ifndef _DT_BINDINGS_MSCC_VSC8531_H -#define _DT_BINDINGS_MSCC_VSC8531_H - -/* PHY LED Modes */ -#define VSC8531_LINK_ACTIVITY 0 -#define VSC8531_LINK_1000_ACTIVITY 1 -#define VSC8531_LINK_100_ACTIVITY 2 -#define VSC8531_LINK_10_ACTIVITY 3 -#define VSC8531_LINK_100_1000_ACTIVITY 4 -#define VSC8531_LINK_10_1000_ACTIVITY 5 -#define VSC8531_LINK_10_100_ACTIVITY 6 -#define VSC8584_LINK_100FX_1000X_ACTIVITY 7 -#define VSC8531_DUPLEX_COLLISION 8 -#define VSC8531_COLLISION 9 -#define VSC8531_ACTIVITY 10 -#define VSC8584_100FX_1000X_ACTIVITY 11 -#define VSC8531_AUTONEG_FAULT 12 -#define VSC8531_SERIAL_MODE 13 -#define VSC8531_FORCE_LED_OFF 14 -#define VSC8531_FORCE_LED_ON 15 - -#endif diff --git a/include/dt-bindings/net/qca-ar803x.h b/include/dt-bindings/net/qca-ar803x.h deleted file mode 100644 index 9c046c7242ed..000000000000 --- a/include/dt-bindings/net/qca-ar803x.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * Device Tree constants for the Qualcomm Atheros AR803x PHYs - */ - -#ifndef _DT_BINDINGS_QCA_AR803X_H -#define _DT_BINDINGS_QCA_AR803X_H - -#define AR803X_STRENGTH_FULL 0 -#define AR803X_STRENGTH_HALF 1 -#define AR803X_STRENGTH_QUARTER 2 - -#endif diff --git a/include/dt-bindings/phy/phy-am654-serdes.h b/include/dt-bindings/phy/phy-am654-serdes.h deleted file mode 100644 index e8d901729ed9..000000000000 --- a/include/dt-bindings/phy/phy-am654-serdes.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for AM654 SERDES. - */ - -#ifndef _DT_BINDINGS_AM654_SERDES -#define _DT_BINDINGS_AM654_SERDES - -#define AM654_SERDES_CMU_REFCLK 0 -#define AM654_SERDES_LO_REFCLK 1 -#define AM654_SERDES_RO_REFCLK 2 - -#endif /* _DT_BINDINGS_AM654_SERDES */ diff --git a/include/dt-bindings/phy/phy-cadence.h b/include/dt-bindings/phy/phy-cadence.h deleted file mode 100644 index 0122c6067b17..000000000000 --- a/include/dt-bindings/phy/phy-cadence.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for Cadence SERDES. - */ - -#ifndef _DT_BINDINGS_CADENCE_SERDES_H -#define _DT_BINDINGS_CADENCE_SERDES_H - -/* Torrent */ -#define TORRENT_SERDES_NO_SSC 0 -#define TORRENT_SERDES_EXTERNAL_SSC 1 -#define TORRENT_SERDES_INTERNAL_SSC 2 - -#define CDNS_TORRENT_REFCLK_DRIVER 0 - -/* Sierra */ -#define CDNS_SIERRA_PLL_CMNLC 0 -#define CDNS_SIERRA_PLL_CMNLC1 1 - -#define SIERRA_SERDES_NO_SSC 0 -#define SIERRA_SERDES_EXTERNAL_SSC 1 -#define SIERRA_SERDES_INTERNAL_SSC 2 - -#endif /* _DT_BINDINGS_CADENCE_SERDES_H */ diff --git a/include/dt-bindings/pinctrl/apple.h b/include/dt-bindings/pinctrl/apple.h deleted file mode 100644 index ea0a6f466592..000000000000 --- a/include/dt-bindings/pinctrl/apple.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ -/* - * This header provides constants for Apple pinctrl bindings. - */ - -#ifndef _DT_BINDINGS_PINCTRL_APPLE_H -#define _DT_BINDINGS_PINCTRL_APPLE_H - -#define APPLE_PINMUX(pin, func) ((pin) | ((func) << 16)) -#define APPLE_PIN(pinmux) ((pinmux) & 0xffff) -#define APPLE_FUNC(pinmux) ((pinmux) >> 16) - -#endif /* _DT_BINDINGS_PINCTRL_APPLE_H */ diff --git a/include/dt-bindings/pinctrl/dra.h b/include/dt-bindings/pinctrl/dra.h deleted file mode 100644 index 765c385f7b2c..000000000000 --- a/include/dt-bindings/pinctrl/dra.h +++ /dev/null @@ -1,79 +0,0 @@ -/* - * This header provides constants for DRA pinctrl bindings. - * - * Copyright (C) 2013 Texas Instruments Incorporated - https://www.ti.com/ - * Author: Rajendra Nayak rnayak@ti.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#ifndef _DT_BINDINGS_PINCTRL_DRA_H -#define _DT_BINDINGS_PINCTRL_DRA_H - -/* DRA7 mux mode options for each pin. See TRM for options */ -#define MUX_MODE0 0x0 -#define MUX_MODE1 0x1 -#define MUX_MODE2 0x2 -#define MUX_MODE3 0x3 -#define MUX_MODE4 0x4 -#define MUX_MODE5 0x5 -#define MUX_MODE6 0x6 -#define MUX_MODE7 0x7 -#define MUX_MODE8 0x8 -#define MUX_MODE9 0x9 -#define MUX_MODE10 0xa -#define MUX_MODE11 0xb -#define MUX_MODE12 0xc -#define MUX_MODE13 0xd -#define MUX_MODE14 0xe -#define MUX_MODE15 0xf - -/* Certain pins need virtual mode, but note: they may glitch */ -#define MUX_VIRTUAL_MODE0 (MODE_SELECT | (0x0 << 4)) -#define MUX_VIRTUAL_MODE1 (MODE_SELECT | (0x1 << 4)) -#define MUX_VIRTUAL_MODE2 (MODE_SELECT | (0x2 << 4)) -#define MUX_VIRTUAL_MODE3 (MODE_SELECT | (0x3 << 4)) -#define MUX_VIRTUAL_MODE4 (MODE_SELECT | (0x4 << 4)) -#define MUX_VIRTUAL_MODE5 (MODE_SELECT | (0x5 << 4)) -#define MUX_VIRTUAL_MODE6 (MODE_SELECT | (0x6 << 4)) -#define MUX_VIRTUAL_MODE7 (MODE_SELECT | (0x7 << 4)) -#define MUX_VIRTUAL_MODE8 (MODE_SELECT | (0x8 << 4)) -#define MUX_VIRTUAL_MODE9 (MODE_SELECT | (0x9 << 4)) -#define MUX_VIRTUAL_MODE10 (MODE_SELECT | (0xa << 4)) -#define MUX_VIRTUAL_MODE11 (MODE_SELECT | (0xb << 4)) -#define MUX_VIRTUAL_MODE12 (MODE_SELECT | (0xc << 4)) -#define MUX_VIRTUAL_MODE13 (MODE_SELECT | (0xd << 4)) -#define MUX_VIRTUAL_MODE14 (MODE_SELECT | (0xe << 4)) -#define MUX_VIRTUAL_MODE15 (MODE_SELECT | (0xf << 4)) - -#define MODE_SELECT (1 << 8) - -#define PULL_ENA (0 << 16) -#define PULL_DIS (1 << 16) -#define PULL_UP (1 << 17) -#define INPUT_EN (1 << 18) -#define SLEWCONTROL (1 << 19) -#define WAKEUP_EN (1 << 24) -#define WAKEUP_EVENT (1 << 25) - -/* Active pin states */ -#define PIN_OUTPUT (0 | PULL_DIS) -#define PIN_OUTPUT_PULLUP (PULL_UP) -#define PIN_OUTPUT_PULLDOWN (0) -#define PIN_INPUT (INPUT_EN | PULL_DIS) -#define PIN_INPUT_SLEW (INPUT_EN | SLEWCONTROL) -#define PIN_INPUT_PULLUP (PULL_ENA | INPUT_EN | PULL_UP) -#define PIN_INPUT_PULLDOWN (PULL_ENA | INPUT_EN) - -/* - * Macro to allow using the absolute physical address instead of the - * padconf registers instead of the offset from padconf base. - */ -#define DRA7XX_CORE_IOPAD(pa, val) (((pa) & 0xffff) - 0x3400) (val) - -/* DRA7 IODELAY configuration parameters */ -#define A_DELAY_PS(val) ((val) & 0xffff) -#define G_DELAY_PS(val) ((val) & 0xffff) -#endif diff --git a/include/dt-bindings/power/owl-s700-powergate.h b/include/dt-bindings/power/owl-s700-powergate.h deleted file mode 100644 index 4cf1aefbf09c..000000000000 --- a/include/dt-bindings/power/owl-s700-powergate.h +++ /dev/null @@ -1,19 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Actions Semi S700 SPS - * - * Copyright (c) 2017 Andreas Färber - */ -#ifndef DT_BINDINGS_POWER_OWL_S700_POWERGATE_H -#define DT_BINDINGS_POWER_OWL_S700_POWERGATE_H - -#define S700_PD_VDE 0 -#define S700_PD_VCE_SI 1 -#define S700_PD_USB2_1 2 -#define S700_PD_HDE 3 -#define S700_PD_DMA 4 -#define S700_PD_DS 5 -#define S700_PD_USB3 6 -#define S700_PD_USB2_0 7 - -#endif diff --git a/include/dt-bindings/power/raspberrypi-power.h b/include/dt-bindings/power/raspberrypi-power.h deleted file mode 100644 index b3ff8e09a78f..000000000000 --- a/include/dt-bindings/power/raspberrypi-power.h +++ /dev/null @@ -1,41 +0,0 @@ -/* - * Copyright © 2015 Broadcom - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ - -#ifndef _DT_BINDINGS_ARM_BCM2835_RPI_POWER_H -#define _DT_BINDINGS_ARM_BCM2835_RPI_POWER_H - -/* These power domain indices are the firmware interface's indices - * minus one. - */ -#define RPI_POWER_DOMAIN_I2C0 0 -#define RPI_POWER_DOMAIN_I2C1 1 -#define RPI_POWER_DOMAIN_I2C2 2 -#define RPI_POWER_DOMAIN_VIDEO_SCALER 3 -#define RPI_POWER_DOMAIN_VPU1 4 -#define RPI_POWER_DOMAIN_HDMI 5 -#define RPI_POWER_DOMAIN_USB 6 -#define RPI_POWER_DOMAIN_VEC 7 -#define RPI_POWER_DOMAIN_JPEG 8 -#define RPI_POWER_DOMAIN_H264 9 -#define RPI_POWER_DOMAIN_V3D 10 -#define RPI_POWER_DOMAIN_ISP 11 -#define RPI_POWER_DOMAIN_UNICAM0 12 -#define RPI_POWER_DOMAIN_UNICAM1 13 -#define RPI_POWER_DOMAIN_CCP2RX 14 -#define RPI_POWER_DOMAIN_CSI2 15 -#define RPI_POWER_DOMAIN_CPI 16 -#define RPI_POWER_DOMAIN_DSI0 17 -#define RPI_POWER_DOMAIN_DSI1 18 -#define RPI_POWER_DOMAIN_TRANSPOSER 19 -#define RPI_POWER_DOMAIN_CCP2TX 20 -#define RPI_POWER_DOMAIN_CDP 21 -#define RPI_POWER_DOMAIN_ARM 22 - -#define RPI_POWER_DOMAIN_COUNT 23 - -#endif /* _DT_BINDINGS_ARM_BCM2835_RPI_POWER_H */ diff --git a/include/dt-bindings/regulator/dlg,da9063-regulator.h b/include/dt-bindings/regulator/dlg,da9063-regulator.h deleted file mode 100644 index 1de710dd0899..000000000000 --- a/include/dt-bindings/regulator/dlg,da9063-regulator.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ - -#ifndef _DT_BINDINGS_REGULATOR_DLG_DA9063_H -#define _DT_BINDINGS_REGULATOR_DLG_DA9063_H - -/* - * These buck mode constants may be used to specify values in device tree - * properties (e.g. regulator-initial-mode). - * A description of the following modes is in the manufacturers datasheet. - */ - -#define DA9063_BUCK_MODE_SLEEP 1 -#define DA9063_BUCK_MODE_SYNC 2 -#define DA9063_BUCK_MODE_AUTO 3 - -#endif diff --git a/include/dt-bindings/regulator/maxim,max77802.h b/include/dt-bindings/regulator/maxim,max77802.h deleted file mode 100644 index cf28631d7109..000000000000 --- a/include/dt-bindings/regulator/maxim,max77802.h +++ /dev/null @@ -1,18 +0,0 @@ -/* - * Copyright (C) 2014 Google, Inc - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * Device Tree binding constants for the Maxim 77802 PMIC regulators - */ - -#ifndef _DT_BINDINGS_REGULATOR_MAXIM_MAX77802_H -#define _DT_BINDINGS_REGULATOR_MAXIM_MAX77802_H - -/* Regulator operating modes */ -#define MAX77802_OPMODE_LP 1 -#define MAX77802_OPMODE_NORMAL 3 - -#endif /* _DT_BINDINGS_REGULATOR_MAXIM_MAX77802_H */ diff --git a/include/dt-bindings/reset/actions,s700-reset.h b/include/dt-bindings/reset/actions,s700-reset.h deleted file mode 100644 index 5e3b16b8ef53..000000000000 --- a/include/dt-bindings/reset/actions,s700-reset.h +++ /dev/null @@ -1,34 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-or-later OR MIT) -// -// Device Tree binding constants for Actions Semi S700 Reset Management Unit -// -// Copyright (c) 2018 Linaro Ltd. - -#ifndef __DT_BINDINGS_ACTIONS_S700_RESET_H -#define __DT_BINDINGS_ACTIONS_S700_RESET_H - -#define RESET_AUDIO 0 -#define RESET_CSI 1 -#define RESET_DE 2 -#define RESET_DSI 3 -#define RESET_GPIO 4 -#define RESET_I2C0 5 -#define RESET_I2C1 6 -#define RESET_I2C2 7 -#define RESET_I2C3 8 -#define RESET_KEY 9 -#define RESET_LCD0 10 -#define RESET_SI 11 -#define RESET_SPI0 12 -#define RESET_SPI1 13 -#define RESET_SPI2 14 -#define RESET_SPI3 15 -#define RESET_UART0 16 -#define RESET_UART1 17 -#define RESET_UART2 18 -#define RESET_UART3 19 -#define RESET_UART4 20 -#define RESET_UART5 21 -#define RESET_UART6 22 - -#endif /* __DT_BINDINGS_ACTIONS_S700_RESET_H */ diff --git a/include/dt-bindings/reset/actions,s900-reset.h b/include/dt-bindings/reset/actions,s900-reset.h deleted file mode 100644 index 42c19d02e43b..000000000000 --- a/include/dt-bindings/reset/actions,s900-reset.h +++ /dev/null @@ -1,65 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-or-later OR MIT) -// -// Device Tree binding constants for Actions Semi S900 Reset Management Unit -// -// Copyright (c) 2018 Linaro Ltd. - -#ifndef __DT_BINDINGS_ACTIONS_S900_RESET_H -#define __DT_BINDINGS_ACTIONS_S900_RESET_H - -#define RESET_CHIPID 0 -#define RESET_CPU_SCNT 1 -#define RESET_SRAMI 2 -#define RESET_DDR_CTL_PHY 3 -#define RESET_DMAC 4 -#define RESET_GPIO 5 -#define RESET_BISP_AXI 6 -#define RESET_CSI0 7 -#define RESET_CSI1 8 -#define RESET_DE 9 -#define RESET_DSI 10 -#define RESET_GPU3D_PA 11 -#define RESET_GPU3D_PB 12 -#define RESET_HDE 13 -#define RESET_I2C0 14 -#define RESET_I2C1 15 -#define RESET_I2C2 16 -#define RESET_I2C3 17 -#define RESET_I2C4 18 -#define RESET_I2C5 19 -#define RESET_IMX 20 -#define RESET_NANDC0 21 -#define RESET_NANDC1 22 -#define RESET_SD0 23 -#define RESET_SD1 24 -#define RESET_SD2 25 -#define RESET_SD3 26 -#define RESET_SPI0 27 -#define RESET_SPI1 28 -#define RESET_SPI2 29 -#define RESET_SPI3 30 -#define RESET_UART0 31 -#define RESET_UART1 32 -#define RESET_UART2 33 -#define RESET_UART3 34 -#define RESET_UART4 35 -#define RESET_UART5 36 -#define RESET_UART6 37 -#define RESET_HDMI 38 -#define RESET_LVDS 39 -#define RESET_EDP 40 -#define RESET_USB2HUB 41 -#define RESET_USB2HSIC 42 -#define RESET_USB3 43 -#define RESET_PCM1 44 -#define RESET_AUDIO 45 -#define RESET_PCM0 46 -#define RESET_SE 47 -#define RESET_GIC 48 -#define RESET_DDR_CTL_PHY_AXI 49 -#define RESET_CMU_DDR 50 -#define RESET_DMM 51 -#define RESET_HDCP2TX 52 -#define RESET_ETHERNET 53 - -#endif /* __DT_BINDINGS_ACTIONS_S900_RESET_H */ diff --git a/include/dt-bindings/reset/altr,rst-mgr-a10.h b/include/dt-bindings/reset/altr,rst-mgr-a10.h deleted file mode 100644 index acb0bbf4f9f5..000000000000 --- a/include/dt-bindings/reset/altr,rst-mgr-a10.h +++ /dev/null @@ -1,110 +0,0 @@ -/* - * Copyright (c) 2014, Steffen Trumtrar s.trumtrar@pengutronix.de - * - * This software is licensed under the terms of the GNU General Public - * License version 2, as published by the Free Software Foundation, and - * may be copied, distributed, and modified under those terms. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H -#define _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H - -/* MPUMODRST */ -#define CPU0_RESET 0 -#define CPU1_RESET 1 -#define WDS_RESET 2 -#define SCUPER_RESET 3 - -/* PER0MODRST */ -#define EMAC0_RESET 32 -#define EMAC1_RESET 33 -#define EMAC2_RESET 34 -#define USB0_RESET 35 -#define USB1_RESET 36 -#define NAND_RESET 37 -#define QSPI_RESET 38 -#define SDMMC_RESET 39 -#define EMAC0_OCP_RESET 40 -#define EMAC1_OCP_RESET 41 -#define EMAC2_OCP_RESET 42 -#define USB0_OCP_RESET 43 -#define USB1_OCP_RESET 44 -#define NAND_OCP_RESET 45 -#define QSPI_OCP_RESET 46 -#define SDMMC_OCP_RESET 47 -#define DMA_RESET 48 -#define SPIM0_RESET 49 -#define SPIM1_RESET 50 -#define SPIS0_RESET 51 -#define SPIS1_RESET 52 -#define DMA_OCP_RESET 53 -#define EMAC_PTP_RESET 54 -/* 55 is empty*/ -#define DMAIF0_RESET 56 -#define DMAIF1_RESET 57 -#define DMAIF2_RESET 58 -#define DMAIF3_RESET 59 -#define DMAIF4_RESET 60 -#define DMAIF5_RESET 61 -#define DMAIF6_RESET 62 -#define DMAIF7_RESET 63 - -/* PER1MODRST */ -#define L4WD0_RESET 64 -#define L4WD1_RESET 65 -#define L4SYSTIMER0_RESET 66 -#define L4SYSTIMER1_RESET 67 -#define SPTIMER0_RESET 68 -#define SPTIMER1_RESET 69 -/* 70-71 is reserved */ -#define I2C0_RESET 72 -#define I2C1_RESET 73 -#define I2C2_RESET 74 -#define I2C3_RESET 75 -#define I2C4_RESET 76 -/* 77-79 is reserved */ -#define UART0_RESET 80 -#define UART1_RESET 81 -/* 82-87 is reserved */ -#define GPIO0_RESET 88 -#define GPIO1_RESET 89 -#define GPIO2_RESET 90 - -/* BRGMODRST */ -#define HPS2FPGA_RESET 96 -#define LWHPS2FPGA_RESET 97 -#define FPGA2HPS_RESET 98 -#define F2SSDRAM0_RESET 99 -#define F2SSDRAM1_RESET 100 -#define F2SSDRAM2_RESET 101 -#define DDRSCH_RESET 102 - -/* SYSMODRST*/ -#define ROM_RESET 128 -#define OCRAM_RESET 129 -/* 130 is reserved */ -#define FPGAMGR_RESET 131 -#define S2F_RESET 132 -#define SYSDBG_RESET 133 -#define OCRAM_OCP_RESET 134 - -/* COLDMODRST */ -#define CLKMGRCOLD_RESET 160 -/* 161-162 is reserved */ -#define S2FCOLD_RESET 163 -#define TIMESTAMPCOLD_RESET 164 -#define TAPCOLD_RESET 165 -#define HMCCOLD_RESET 166 -#define IOMGRCOLD_RESET 167 - -/* NRSTMODRST */ -#define NRSTPINOE_RESET 192 - -/* DBGMODRST */ -#define DBG_RESET 224 -#endif diff --git a/include/dt-bindings/reset/altr,rst-mgr-s10.h b/include/dt-bindings/reset/altr,rst-mgr-s10.h deleted file mode 100644 index 1fdcf8ae1531..000000000000 --- a/include/dt-bindings/reset/altr,rst-mgr-s10.h +++ /dev/null @@ -1,96 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2016-2018 Intel Corporation. All rights reserved - * Copyright (C) 2016 Altera Corporation. All rights reserved - * derived from Steffen Trumtrar's "altr,rst-mgr-a10.h" - */ - -#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_S10_H -#define _DT_BINDINGS_RESET_ALTR_RST_MGR_S10_H - -/* MPUMODRST */ -#define CPU0_RESET 0 -#define CPU1_RESET 1 -#define CPU2_RESET 2 -#define CPU3_RESET 3 - -/* PER0MODRST */ -#define EMAC0_RESET 32 -#define EMAC1_RESET 33 -#define EMAC2_RESET 34 -#define USB0_RESET 35 -#define USB1_RESET 36 -#define NAND_RESET 37 -/* 38 is empty */ -#define SDMMC_RESET 39 -#define EMAC0_OCP_RESET 40 -#define EMAC1_OCP_RESET 41 -#define EMAC2_OCP_RESET 42 -#define USB0_OCP_RESET 43 -#define USB1_OCP_RESET 44 -#define NAND_OCP_RESET 45 -/* 46 is empty */ -#define SDMMC_OCP_RESET 47 -#define DMA_RESET 48 -#define SPIM0_RESET 49 -#define SPIM1_RESET 50 -#define SPIS0_RESET 51 -#define SPIS1_RESET 52 -#define DMA_OCP_RESET 53 -#define EMAC_PTP_RESET 54 -/* 55 is empty*/ -#define DMAIF0_RESET 56 -#define DMAIF1_RESET 57 -#define DMAIF2_RESET 58 -#define DMAIF3_RESET 59 -#define DMAIF4_RESET 60 -#define DMAIF5_RESET 61 -#define DMAIF6_RESET 62 -#define DMAIF7_RESET 63 - -/* PER1MODRST */ -#define WATCHDOG0_RESET 64 -#define WATCHDOG1_RESET 65 -#define WATCHDOG2_RESET 66 -#define WATCHDOG3_RESET 67 -#define L4SYSTIMER0_RESET 68 -#define L4SYSTIMER1_RESET 69 -#define SPTIMER0_RESET 70 -#define SPTIMER1_RESET 71 -#define I2C0_RESET 72 -#define I2C1_RESET 73 -#define I2C2_RESET 74 -#define I2C3_RESET 75 -#define I2C4_RESET 76 -/* 77-79 is empty */ -#define UART0_RESET 80 -#define UART1_RESET 81 -/* 82-87 is empty */ -#define GPIO0_RESET 88 -#define GPIO1_RESET 89 - -/* BRGMODRST */ -#define SOC2FPGA_RESET 96 -#define LWHPS2FPGA_RESET 97 -#define FPGA2SOC_RESET 98 -#define F2SSDRAM0_RESET 99 -#define F2SSDRAM1_RESET 100 -#define F2SSDRAM2_RESET 101 -#define DDRSCH_RESET 102 - -/* COLDMODRST */ -#define CPUPO0_RESET 160 -#define CPUPO1_RESET 161 -#define CPUPO2_RESET 162 -#define CPUPO3_RESET 163 -/* 164-167 is empty */ -#define L2_RESET 168 - -/* DBGMODRST */ -#define DBG_RESET 224 -#define CSDAP_RESET 225 - -/* TAPMODRST */ -#define TAP_RESET 256 - -#endif diff --git a/include/dt-bindings/reset/altr,rst-mgr.h b/include/dt-bindings/reset/altr,rst-mgr.h deleted file mode 100644 index 5b7ad7396524..000000000000 --- a/include/dt-bindings/reset/altr,rst-mgr.h +++ /dev/null @@ -1,82 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2014, Steffen Trumtrar s.trumtrar@pengutronix.de - */ - -#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_H -#define _DT_BINDINGS_RESET_ALTR_RST_MGR_H - -/* MPUMODRST */ -#define CPU0_RESET 0 -#define CPU1_RESET 1 -#define WDS_RESET 2 -#define SCUPER_RESET 3 -#define L2_RESET 4 - -/* PERMODRST */ -#define EMAC0_RESET 32 -#define EMAC1_RESET 33 -#define USB0_RESET 34 -#define USB1_RESET 35 -#define NAND_RESET 36 -#define QSPI_RESET 37 -#define L4WD0_RESET 38 -#define L4WD1_RESET 39 -#define OSC1TIMER0_RESET 40 -#define OSC1TIMER1_RESET 41 -#define SPTIMER0_RESET 42 -#define SPTIMER1_RESET 43 -#define I2C0_RESET 44 -#define I2C1_RESET 45 -#define I2C2_RESET 46 -#define I2C3_RESET 47 -#define UART0_RESET 48 -#define UART1_RESET 49 -#define SPIM0_RESET 50 -#define SPIM1_RESET 51 -#define SPIS0_RESET 52 -#define SPIS1_RESET 53 -#define SDMMC_RESET 54 -#define CAN0_RESET 55 -#define CAN1_RESET 56 -#define GPIO0_RESET 57 -#define GPIO1_RESET 58 -#define GPIO2_RESET 59 -#define DMA_RESET 60 -#define SDR_RESET 61 - -/* PER2MODRST */ -#define DMAIF0_RESET 64 -#define DMAIF1_RESET 65 -#define DMAIF2_RESET 66 -#define DMAIF3_RESET 67 -#define DMAIF4_RESET 68 -#define DMAIF5_RESET 69 -#define DMAIF6_RESET 70 -#define DMAIF7_RESET 71 - -/* BRGMODRST */ -#define HPS2FPGA_RESET 96 -#define LWHPS2FPGA_RESET 97 -#define FPGA2HPS_RESET 98 - -/* MISCMODRST*/ -#define ROM_RESET 128 -#define OCRAM_RESET 129 -#define SYSMGR_RESET 130 -#define SYSMGRCOLD_RESET 131 -#define FPGAMGR_RESET 132 -#define ACPIDMAP_RESET 133 -#define S2F_RESET 134 -#define S2FCOLD_RESET 135 -#define NRSTPIN_RESET 136 -#define TIMESTAMPCOLD_RESET 137 -#define CLKMGRCOLD_RESET 138 -#define SCANMGR_RESET 139 -#define FRZCTRLCOLD_RESET 140 -#define SYSDBG_RESET 141 -#define DBG_RESET 142 -#define TAPCOLD_RESET 143 -#define SDRCOLD_RESET 144 - -#endif diff --git a/include/dt-bindings/reset/nuvoton,npcm7xx-reset.h b/include/dt-bindings/reset/nuvoton,npcm7xx-reset.h deleted file mode 100644 index 757f5e34c814..000000000000 --- a/include/dt-bindings/reset/nuvoton,npcm7xx-reset.h +++ /dev/null @@ -1,91 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -// Copyright (c) 2020 Nuvoton Technology corporation. - -#ifndef _DT_BINDINGS_NPCM7XX_RESET_H -#define _DT_BINDINGS_NPCM7XX_RESET_H - -#define NPCM7XX_RESET_IPSRST1 0x20 -#define NPCM7XX_RESET_IPSRST2 0x24 -#define NPCM7XX_RESET_IPSRST3 0x34 - -/* Reset lines on IP1 reset module (NPCM7XX_RESET_IPSRST1) */ -#define NPCM7XX_RESET_FIU3 1 -#define NPCM7XX_RESET_UDC1 5 -#define NPCM7XX_RESET_EMC1 6 -#define NPCM7XX_RESET_UART_2_3 7 -#define NPCM7XX_RESET_UDC2 8 -#define NPCM7XX_RESET_PECI 9 -#define NPCM7XX_RESET_AES 10 -#define NPCM7XX_RESET_UART_0_1 11 -#define NPCM7XX_RESET_MC 12 -#define NPCM7XX_RESET_SMB2 13 -#define NPCM7XX_RESET_SMB3 14 -#define NPCM7XX_RESET_SMB4 15 -#define NPCM7XX_RESET_SMB5 16 -#define NPCM7XX_RESET_PWM_M0 18 -#define NPCM7XX_RESET_TIMER_0_4 19 -#define NPCM7XX_RESET_TIMER_5_9 20 -#define NPCM7XX_RESET_EMC2 21 -#define NPCM7XX_RESET_UDC4 22 -#define NPCM7XX_RESET_UDC5 23 -#define NPCM7XX_RESET_UDC6 24 -#define NPCM7XX_RESET_UDC3 25 -#define NPCM7XX_RESET_ADC 27 -#define NPCM7XX_RESET_SMB6 28 -#define NPCM7XX_RESET_SMB7 29 -#define NPCM7XX_RESET_SMB0 30 -#define NPCM7XX_RESET_SMB1 31 - -/* Reset lines on IP2 reset module (NPCM7XX_RESET_IPSRST2) */ -#define NPCM7XX_RESET_MFT0 0 -#define NPCM7XX_RESET_MFT1 1 -#define NPCM7XX_RESET_MFT2 2 -#define NPCM7XX_RESET_MFT3 3 -#define NPCM7XX_RESET_MFT4 4 -#define NPCM7XX_RESET_MFT5 5 -#define NPCM7XX_RESET_MFT6 6 -#define NPCM7XX_RESET_MFT7 7 -#define NPCM7XX_RESET_MMC 8 -#define NPCM7XX_RESET_SDHC 9 -#define NPCM7XX_RESET_GFX_SYS 10 -#define NPCM7XX_RESET_AHB_PCIBRG 11 -#define NPCM7XX_RESET_VDMA 12 -#define NPCM7XX_RESET_ECE 13 -#define NPCM7XX_RESET_VCD 14 -#define NPCM7XX_RESET_OTP 16 -#define NPCM7XX_RESET_SIOX1 18 -#define NPCM7XX_RESET_SIOX2 19 -#define NPCM7XX_RESET_3DES 21 -#define NPCM7XX_RESET_PSPI1 22 -#define NPCM7XX_RESET_PSPI2 23 -#define NPCM7XX_RESET_GMAC2 25 -#define NPCM7XX_RESET_USB_HOST 26 -#define NPCM7XX_RESET_GMAC1 28 -#define NPCM7XX_RESET_CP 31 - -/* Reset lines on IP3 reset module (NPCM7XX_RESET_IPSRST3) */ -#define NPCM7XX_RESET_PWM_M1 0 -#define NPCM7XX_RESET_SMB12 1 -#define NPCM7XX_RESET_SPIX 2 -#define NPCM7XX_RESET_SMB13 3 -#define NPCM7XX_RESET_UDC0 4 -#define NPCM7XX_RESET_UDC7 5 -#define NPCM7XX_RESET_UDC8 6 -#define NPCM7XX_RESET_UDC9 7 -#define NPCM7XX_RESET_PCI_MAILBOX 9 -#define NPCM7XX_RESET_SMB14 12 -#define NPCM7XX_RESET_SHA 13 -#define NPCM7XX_RESET_SEC_ECC 14 -#define NPCM7XX_RESET_PCIE_RC 15 -#define NPCM7XX_RESET_TIMER_10_14 16 -#define NPCM7XX_RESET_RNG 17 -#define NPCM7XX_RESET_SMB15 18 -#define NPCM7XX_RESET_SMB8 19 -#define NPCM7XX_RESET_SMB9 20 -#define NPCM7XX_RESET_SMB10 21 -#define NPCM7XX_RESET_SMB11 22 -#define NPCM7XX_RESET_ESPI 23 -#define NPCM7XX_RESET_USB_PHY_1 24 -#define NPCM7XX_RESET_USB_PHY_2 25 - -#endif diff --git a/include/dt-bindings/reset/raspberrypi,firmware-reset.h b/include/dt-bindings/reset/raspberrypi,firmware-reset.h deleted file mode 100644 index 1a4f4c792723..000000000000 --- a/include/dt-bindings/reset/raspberrypi,firmware-reset.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2020 Nicolas Saenz Julienne - * Author: Nicolas Saenz Julienne nsaenzjulienne@suse.com - */ - -#ifndef _DT_BINDINGS_RASPBERRYPI_FIRMWARE_RESET_H -#define _DT_BINDINGS_RASPBERRYPI_FIRMWARE_RESET_H - -#define RASPBERRYPI_FIRMWARE_RESET_ID_USB 0 -#define RASPBERRYPI_FIRMWARE_RESET_NUM_IDS 1 - -#endif diff --git a/include/dt-bindings/reset/sama7g5-reset.h b/include/dt-bindings/reset/sama7g5-reset.h deleted file mode 100644 index 2116f41d04e0..000000000000 --- a/include/dt-bindings/reset/sama7g5-reset.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ - -#ifndef __DT_BINDINGS_RESET_SAMA7G5_H -#define __DT_BINDINGS_RESET_SAMA7G5_H - -#define SAMA7G5_RESET_USB_PHY1 4 -#define SAMA7G5_RESET_USB_PHY2 5 -#define SAMA7G5_RESET_USB_PHY3 6 - -#endif /* __DT_BINDINGS_RESET_SAMA7G5_H */ diff --git a/include/dt-bindings/reset/snps,hsdk-reset.h b/include/dt-bindings/reset/snps,hsdk-reset.h deleted file mode 100644 index e1a643e4bc91..000000000000 --- a/include/dt-bindings/reset/snps,hsdk-reset.h +++ /dev/null @@ -1,17 +0,0 @@ -/** - * This header provides index for the HSDK reset controller. - */ -#ifndef _DT_BINDINGS_RESET_CONTROLLER_SNPS_HSDK -#define _DT_BINDINGS_RESET_CONTROLLER_SNPS_HSDK - -#define HSDK_APB_RESET 0 -#define HSDK_AXI_RESET 1 -#define HSDK_ETH_RESET 2 -#define HSDK_USB_RESET 3 -#define HSDK_SDIO_RESET 4 -#define HSDK_HDMI_RESET 5 -#define HSDK_GFX_RESET 6 -#define HSDK_DMAC_RESET 7 -#define HSDK_EBI_RESET 8 - -#endif /*_DT_BINDINGS_RESET_CONTROLLER_SNPS_HSDK*/ diff --git a/include/dt-bindings/reset/starfive,jh7110-crg.h b/include/dt-bindings/reset/starfive,jh7110-crg.h deleted file mode 100644 index 1d596581da7b..000000000000 --- a/include/dt-bindings/reset/starfive,jh7110-crg.h +++ /dev/null @@ -1,183 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2022 StarFive Technology Co., Ltd. - * - * Author: Yanhong Wang yanhong.wang@starfivetech.com - */ - -#ifndef __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ -#define __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ - -/* SYSCRG resets */ -#define JH7110_SYSRST_JTAG2APB 0 -#define JH7110_SYSRST_SYSCON 1 -#define JH7110_SYSRST_IOMUX_APB 2 -#define JH7110_SYSRST_BUS 3 -#define JH7110_SYSRST_DEBUG 4 -#define JH7110_SYSRST_CORE0 5 -#define JH7110_SYSRST_CORE1 6 -#define JH7110_SYSRST_CORE2 7 -#define JH7110_SYSRST_CORE3 8 -#define JH7110_SYSRST_CORE4 9 -#define JH7110_SYSRST_CORE0_ST 10 -#define JH7110_SYSRST_CORE1_ST 11 -#define JH7110_SYSRST_CORE2_ST 12 -#define JH7110_SYSRST_CORE3_ST 13 -#define JH7110_SYSRST_CORE4_ST 14 -#define JH7110_SYSRST_TRACE0 15 -#define JH7110_SYSRST_TRACE1 16 -#define JH7110_SYSRST_TRACE2 17 -#define JH7110_SYSRST_TRACE3 18 -#define JH7110_SYSRST_TRACE4 19 -#define JH7110_SYSRST_TRACE_COM 20 -#define JH7110_SYSRST_GPU_APB 21 -#define JH7110_SYSRST_GPU_DOMA 22 -#define JH7110_SYSRST_NOC_BUS_APB_BUS 23 -#define JH7110_SYSRST_NOC_BUS_AXICFG0_AXI 24 -#define JH7110_SYSRST_NOC_BUS_CPU_AXI 25 -#define JH7110_SYSRST_NOC_BUS_DISP_AXI 26 -#define JH7110_SYSRST_NOC_BUS_GPU_AXI 27 -#define JH7110_SYSRST_NOC_BUS_ISP_AXI 28 -#define JH7110_SYSRST_NOC_BUS_DDRC 29 -#define JH7110_SYSRST_NOC_BUS_STG_AXI 30 -#define JH7110_SYSRST_NOC_BUS_VDEC_AXI 31 - -#define JH7110_SYSRST_NOC_BUS_VENC_AXI 32 -#define JH7110_SYSRST_AXI_CFG1_DEC_AHB 33 -#define JH7110_SYSRST_AXI_CFG1_DEC_MAIN 34 -#define JH7110_SYSRST_AXI_CFG0_DEC_MAIN 35 -#define JH7110_SYSRST_AXI_CFG0_DEC_MAIN_DIV 36 -#define JH7110_SYSRST_AXI_CFG0_DEC_HIFI4 37 -#define JH7110_SYSRST_DDR_AXI 38 -#define JH7110_SYSRST_DDR_OSC 39 -#define JH7110_SYSRST_DDR_APB 40 -#define JH7110_SYSRST_DOM_ISP_TOP_N 41 -#define JH7110_SYSRST_DOM_ISP_TOP_AXI 42 -#define JH7110_SYSRST_DOM_VOUT_TOP_SRC 43 -#define JH7110_SYSRST_CODAJ12_AXI 44 -#define JH7110_SYSRST_CODAJ12_CORE 45 -#define JH7110_SYSRST_CODAJ12_APB 46 -#define JH7110_SYSRST_WAVE511_AXI 47 -#define JH7110_SYSRST_WAVE511_BPU 48 -#define JH7110_SYSRST_WAVE511_VCE 49 -#define JH7110_SYSRST_WAVE511_APB 50 -#define JH7110_SYSRST_VDEC_JPG_ARB_JPG 51 -#define JH7110_SYSRST_VDEC_JPG_ARB_MAIN 52 -#define JH7110_SYSRST_AXIMEM0_AXI 53 -#define JH7110_SYSRST_WAVE420L_AXI 54 -#define JH7110_SYSRST_WAVE420L_BPU 55 -#define JH7110_SYSRST_WAVE420L_VCE 56 -#define JH7110_SYSRST_WAVE420L_APB 57 -#define JH7110_SYSRST_AXIMEM1_AXI 58 -#define JH7110_SYSRST_AXIMEM2_AXI 59 -#define JH7110_SYSRST_INTMEM 60 -#define JH7110_SYSRST_QSPI_AHB 61 -#define JH7110_SYSRST_QSPI_APB 62 -#define JH7110_SYSRST_QSPI_REF 63 - -#define JH7110_SYSRST_SDIO0_AHB 64 -#define JH7110_SYSRST_SDIO1_AHB 65 -#define JH7110_SYSRST_GMAC1_AXI 66 -#define JH7110_SYSRST_GMAC1_AHB 67 -#define JH7110_SYSRST_MAILBOX 68 -#define JH7110_SYSRST_SPI0_APB 69 -#define JH7110_SYSRST_SPI1_APB 70 -#define JH7110_SYSRST_SPI2_APB 71 -#define JH7110_SYSRST_SPI3_APB 72 -#define JH7110_SYSRST_SPI4_APB 73 -#define JH7110_SYSRST_SPI5_APB 74 -#define JH7110_SYSRST_SPI6_APB 75 -#define JH7110_SYSRST_I2C0_APB 76 -#define JH7110_SYSRST_I2C1_APB 77 -#define JH7110_SYSRST_I2C2_APB 78 -#define JH7110_SYSRST_I2C3_APB 79 -#define JH7110_SYSRST_I2C4_APB 80 -#define JH7110_SYSRST_I2C5_APB 81 -#define JH7110_SYSRST_I2C6_APB 82 -#define JH7110_SYSRST_UART0_APB 83 -#define JH7110_SYSRST_UART0_CORE 84 -#define JH7110_SYSRST_UART1_APB 85 -#define JH7110_SYSRST_UART1_CORE 86 -#define JH7110_SYSRST_UART2_APB 87 -#define JH7110_SYSRST_UART2_CORE 88 -#define JH7110_SYSRST_UART3_APB 89 -#define JH7110_SYSRST_UART3_CORE 90 -#define JH7110_SYSRST_UART4_APB 91 -#define JH7110_SYSRST_UART4_CORE 92 -#define JH7110_SYSRST_UART5_APB 93 -#define JH7110_SYSRST_UART5_CORE 94 -#define JH7110_SYSRST_SPDIF_APB 95 - -#define JH7110_SYSRST_PWMDAC_APB 96 -#define JH7110_SYSRST_PDM_DMIC 97 -#define JH7110_SYSRST_PDM_APB 98 -#define JH7110_SYSRST_I2SRX_APB 99 -#define JH7110_SYSRST_I2SRX_BCLK 100 -#define JH7110_SYSRST_I2STX0_APB 101 -#define JH7110_SYSRST_I2STX0_BCLK 102 -#define JH7110_SYSRST_I2STX1_APB 103 -#define JH7110_SYSRST_I2STX1_BCLK 104 -#define JH7110_SYSRST_TDM_AHB 105 -#define JH7110_SYSRST_TDM_CORE 106 -#define JH7110_SYSRST_TDM_APB 107 -#define JH7110_SYSRST_PWM_APB 108 -#define JH7110_SYSRST_WDT_APB 109 -#define JH7110_SYSRST_WDT_CORE 110 -#define JH7110_SYSRST_CAN0_APB 111 -#define JH7110_SYSRST_CAN0_CORE 112 -#define JH7110_SYSRST_CAN0_TIMER 113 -#define JH7110_SYSRST_CAN1_APB 114 -#define JH7110_SYSRST_CAN1_CORE 115 -#define JH7110_SYSRST_CAN1_TIMER 116 -#define JH7110_SYSRST_TIMER_APB 117 -#define JH7110_SYSRST_TIMER0 118 -#define JH7110_SYSRST_TIMER1 119 -#define JH7110_SYSRST_TIMER2 120 -#define JH7110_SYSRST_TIMER3 121 -#define JH7110_SYSRST_INT_CTRL_APB 122 -#define JH7110_SYSRST_TEMP_APB 123 -#define JH7110_SYSRST_TEMP_CORE 124 -#define JH7110_SYSRST_JTAG_CERTIFICATION 125 - -#define JH7110_SYSRST_END 126 - -/* AONCRG resets */ -#define JH7110_AONRST_GMAC0_AXI 0 -#define JH7110_AONRST_GMAC0_AHB 1 -#define JH7110_AONRST_IOMUX 2 -#define JH7110_AONRST_PMU_APB 3 -#define JH7110_AONRST_PMU_WKUP 4 -#define JH7110_AONRST_RTC_APB 5 -#define JH7110_AONRST_RTC_CAL 6 -#define JH7110_AONRST_RTC_32K 7 - -#define JH7110_AONRST_END 8 - -/* STGCRG resets */ -#define JH7110_STGRST_SYSCON_PRESETN 0 -#define JH7110_STGRST_HIFI4_CORE 1 -#define JH7110_STGRST_HIFI4_AXI 2 -#define JH7110_STGRST_SEC_TOP_HRESETN 3 -#define JH7110_STGRST_E24_CORE 4 -#define JH7110_STGRST_DMA1P_AXI 5 -#define JH7110_STGRST_DMA1P_AHB 6 -#define JH7110_STGRST_USB_AXI 7 -#define JH7110_STGRST_USB_APB 8 -#define JH7110_STGRST_USB_UTMI_APB 9 -#define JH7110_STGRST_USB_PWRUP 10 -#define JH7110_STGRST_PCIE0_MST0 11 -#define JH7110_STGRST_PCIE0_SLV0 12 -#define JH7110_STGRST_PCIE0_SLV 13 -#define JH7110_STGRST_PCIE0_BRG 14 -#define JH7110_STGRST_PCIE0_CORE 15 -#define JH7110_STGRST_PCIE0_APB 16 -#define JH7110_STGRST_PCIE1_MST0 17 -#define JH7110_STGRST_PCIE1_SLV0 18 -#define JH7110_STGRST_PCIE1_SLV 19 -#define JH7110_STGRST_PCIE1_BRG 20 -#define JH7110_STGRST_PCIE1_CORE 21 -#define JH7110_STGRST_PCIE1_APB 22 - -#define JH7110_STGRST_END 23 - -#endif /* __DT_BINDINGS_RESET_STARFIVE_JH7110_H__ */ diff --git a/include/dt-bindings/sound/apq8016-lpass.h b/include/dt-bindings/sound/apq8016-lpass.h deleted file mode 100644 index dc605c4bc224..000000000000 --- a/include/dt-bindings/sound/apq8016-lpass.h +++ /dev/null @@ -1,9 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_APQ8016_LPASS_H -#define __DT_APQ8016_LPASS_H - -#include <dt-bindings/sound/qcom,lpass.h> - -/* NOTE: Use qcom,lpass.h to define any AIF ID's for LPASS */ - -#endif /* __DT_APQ8016_LPASS_H */ diff --git a/include/dt-bindings/sound/tlv320aic31xx.h b/include/dt-bindings/sound/tlv320aic31xx.h deleted file mode 100644 index 4a80238ab250..000000000000 --- a/include/dt-bindings/sound/tlv320aic31xx.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_TLV320AIC31XX_H -#define __DT_TLV320AIC31XX_H - -#define MICBIAS_2_0V 1 -#define MICBIAS_2_5V 2 -#define MICBIAS_AVDDV 3 - -#define PLL_CLKIN_MCLK 0x00 -#define PLL_CLKIN_BCLK 0x01 -#define PLL_CLKIN_GPIO1 0x02 -#define PLL_CLKIN_DIN 0x03 - -#endif /* __DT_TLV320AIC31XX_H */
Drop all the subsystem headers that are compatible with the headers in dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org Tested-by: Neil Armstrong neil.armstrong@linaro.org # on AML-S805X-AC Tested-by: Neil Armstrong neil.armstrong@linaro.org # on AML-S905X-CC Tested-by: Neil Armstrong neil.armstrong@linaro.org # on BPI-M2S Tested-by: Neil Armstrong neil.armstrong@linaro.org # on BPI-M5 --- include/dt-bindings/ata/ahci.h | 20 - include/dt-bindings/gpio/gpio.h | 42 -- include/dt-bindings/input/gpio-keys.h | 13 - include/dt-bindings/input/input.h | 17 - include/dt-bindings/input/linux-event-codes.h | 806 ------------------------- include/dt-bindings/interrupt-controller/irq.h | 19 - include/dt-bindings/leds/common.h | 106 ---- include/dt-bindings/mux/mux.h | 17 - include/dt-bindings/phy/phy.h | 26 - include/dt-bindings/pwm/pwm.h | 14 - include/dt-bindings/spmi/spmi.h | 10 - include/dt-bindings/thermal/thermal.h | 15 - include/dt-bindings/usb/pd.h | 88 --- 13 files changed, 1193 deletions(-)
diff --git a/include/dt-bindings/ata/ahci.h b/include/dt-bindings/ata/ahci.h deleted file mode 100644 index b3f3b7cf9af8..000000000000 --- a/include/dt-bindings/ata/ahci.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -/* - * This header provides constants for most AHCI bindings. - */ - -#ifndef _DT_BINDINGS_ATA_AHCI_H -#define _DT_BINDINGS_ATA_AHCI_H - -/* Host Bus Adapter generic platform capabilities */ -#define HBA_SSS (1 << 27) -#define HBA_SMPS (1 << 28) - -/* Host Bus Adapter port-specific platform capabilities */ -#define HBA_PORT_HPCP (1 << 18) -#define HBA_PORT_MPSP (1 << 19) -#define HBA_PORT_CPD (1 << 20) -#define HBA_PORT_ESP (1 << 21) -#define HBA_PORT_FBSCP (1 << 22) - -#endif diff --git a/include/dt-bindings/gpio/gpio.h b/include/dt-bindings/gpio/gpio.h deleted file mode 100644 index c029467e828b..000000000000 --- a/include/dt-bindings/gpio/gpio.h +++ /dev/null @@ -1,42 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for most GPIO bindings. - * - * Most GPIO bindings include a flags cell as part of the GPIO specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_GPIO_GPIO_H -#define _DT_BINDINGS_GPIO_GPIO_H - -/* Bit 0 express polarity */ -#define GPIO_ACTIVE_HIGH 0 -#define GPIO_ACTIVE_LOW 1 - -/* Bit 1 express single-endedness */ -#define GPIO_PUSH_PULL 0 -#define GPIO_SINGLE_ENDED 2 - -/* Bit 2 express Open drain or open source */ -#define GPIO_LINE_OPEN_SOURCE 0 -#define GPIO_LINE_OPEN_DRAIN 4 - -/* - * Open Drain/Collector is the combination of single-ended open drain interface. - * Open Source/Emitter is the combination of single-ended open source interface. - */ -#define GPIO_OPEN_DRAIN (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_DRAIN) -#define GPIO_OPEN_SOURCE (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_SOURCE) - -/* Bit 3 express GPIO suspend/resume and reset persistence */ -#define GPIO_PERSISTENT 0 -#define GPIO_TRANSITORY 8 - -/* Bit 4 express pull up */ -#define GPIO_PULL_UP 16 - -/* Bit 5 express pull down */ -#define GPIO_PULL_DOWN 32 - -#endif diff --git a/include/dt-bindings/input/gpio-keys.h b/include/dt-bindings/input/gpio-keys.h deleted file mode 100644 index 8962df79e753..000000000000 --- a/include/dt-bindings/input/gpio-keys.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for gpio keys bindings. - */ - -#ifndef _DT_BINDINGS_GPIO_KEYS_H -#define _DT_BINDINGS_GPIO_KEYS_H - -#define EV_ACT_ANY 0x00 /* asserted or deasserted */ -#define EV_ACT_ASSERTED 0x01 /* asserted */ -#define EV_ACT_DEASSERTED 0x02 /* deasserted */ - -#endif /* _DT_BINDINGS_GPIO_KEYS_H */ diff --git a/include/dt-bindings/input/input.h b/include/dt-bindings/input/input.h deleted file mode 100644 index a21413324a3f..000000000000 --- a/include/dt-bindings/input/input.h +++ /dev/null @@ -1,17 +0,0 @@ -/* - * This header provides constants for most input bindings. - * - * Most input bindings include key code, matrix key code format. - * In most cases, key code and matrix key code format uses - * the standard values/macro defined in this header. - */ - -#ifndef _DT_BINDINGS_INPUT_INPUT_H -#define _DT_BINDINGS_INPUT_INPUT_H - -#include "linux-event-codes.h" - -#define MATRIX_KEY(row, col, code) \ - ((((row) & 0xFF) << 24) | (((col) & 0xFF) << 16) | ((code) & 0xFFFF)) - -#endif /* _DT_BINDINGS_INPUT_INPUT_H */ diff --git a/include/dt-bindings/input/linux-event-codes.h b/include/dt-bindings/input/linux-event-codes.h deleted file mode 100644 index 331458c0e710..000000000000 --- a/include/dt-bindings/input/linux-event-codes.h +++ /dev/null @@ -1,806 +0,0 @@ -/* - * Input event codes - * - * *** IMPORTANT *** - * This file is not only included from C-code but also from devicetree source - * files. As such this file MUST only contain comments and defines. - * - * Copyright (c) 1999-2002 Vojtech Pavlik - * Copyright (c) 2015 Hans de Goede hdegoede@redhat.com - * - * This program is free software; you can redistribute it and/or modify it - * under the terms of the GNU General Public License version 2 as published by - * the Free Software Foundation. - */ -#ifndef _UAPI_INPUT_EVENT_CODES_H -#define _UAPI_INPUT_EVENT_CODES_H - -/* - * Device properties and quirks - */ - -#define INPUT_PROP_POINTER 0x00 /* needs a pointer */ -#define INPUT_PROP_DIRECT 0x01 /* direct input devices */ -#define INPUT_PROP_BUTTONPAD 0x02 /* has button(s) under pad */ -#define INPUT_PROP_SEMI_MT 0x03 /* touch rectangle only */ -#define INPUT_PROP_TOPBUTTONPAD 0x04 /* softbuttons at top of pad */ -#define INPUT_PROP_POINTING_STICK 0x05 /* is a pointing stick */ -#define INPUT_PROP_ACCELEROMETER 0x06 /* has accelerometer */ - -#define INPUT_PROP_MAX 0x1f -#define INPUT_PROP_CNT (INPUT_PROP_MAX + 1) - -/* - * Event types - */ - -#define EV_SYN 0x00 -#define EV_KEY 0x01 -#define EV_REL 0x02 -#define EV_ABS 0x03 -#define EV_MSC 0x04 -#define EV_SW 0x05 -#define EV_LED 0x11 -#define EV_SND 0x12 -#define EV_REP 0x14 -#define EV_FF 0x15 -#define EV_PWR 0x16 -#define EV_FF_STATUS 0x17 -#define EV_MAX 0x1f -#define EV_CNT (EV_MAX+1) - -/* - * Synchronization events. - */ - -#define SYN_REPORT 0 -#define SYN_CONFIG 1 -#define SYN_MT_REPORT 2 -#define SYN_DROPPED 3 -#define SYN_MAX 0xf -#define SYN_CNT (SYN_MAX+1) - -/* - * Keys and buttons - * - * Most of the keys/buttons are modeled after USB HUT 1.12 - * (see http://www.usb.org/developers/hidpage). - * Abbreviations in the comments: - * AC - Application Control - * AL - Application Launch Button - * SC - System Control - */ - -#define KEY_RESERVED 0 -#define KEY_ESC 1 -#define KEY_1 2 -#define KEY_2 3 -#define KEY_3 4 -#define KEY_4 5 -#define KEY_5 6 -#define KEY_6 7 -#define KEY_7 8 -#define KEY_8 9 -#define KEY_9 10 -#define KEY_0 11 -#define KEY_MINUS 12 -#define KEY_EQUAL 13 -#define KEY_BACKSPACE 14 -#define KEY_TAB 15 -#define KEY_Q 16 -#define KEY_W 17 -#define KEY_E 18 -#define KEY_R 19 -#define KEY_T 20 -#define KEY_Y 21 -#define KEY_U 22 -#define KEY_I 23 -#define KEY_O 24 -#define KEY_P 25 -#define KEY_LEFTBRACE 26 -#define KEY_RIGHTBRACE 27 -#define KEY_ENTER 28 -#define KEY_LEFTCTRL 29 -#define KEY_A 30 -#define KEY_S 31 -#define KEY_D 32 -#define KEY_F 33 -#define KEY_G 34 -#define KEY_H 35 -#define KEY_J 36 -#define KEY_K 37 -#define KEY_L 38 -#define KEY_SEMICOLON 39 -#define KEY_APOSTROPHE 40 -#define KEY_GRAVE 41 -#define KEY_LEFTSHIFT 42 -#define KEY_BACKSLASH 43 -#define KEY_Z 44 -#define KEY_X 45 -#define KEY_C 46 -#define KEY_V 47 -#define KEY_B 48 -#define KEY_N 49 -#define KEY_M 50 -#define KEY_COMMA 51 -#define KEY_DOT 52 -#define KEY_SLASH 53 -#define KEY_RIGHTSHIFT 54 -#define KEY_KPASTERISK 55 -#define KEY_LEFTALT 56 -#define KEY_SPACE 57 -#define KEY_CAPSLOCK 58 -#define KEY_F1 59 -#define KEY_F2 60 -#define KEY_F3 61 -#define KEY_F4 62 -#define KEY_F5 63 -#define KEY_F6 64 -#define KEY_F7 65 -#define KEY_F8 66 -#define KEY_F9 67 -#define KEY_F10 68 -#define KEY_NUMLOCK 69 -#define KEY_SCROLLLOCK 70 -#define KEY_KP7 71 -#define KEY_KP8 72 -#define KEY_KP9 73 -#define KEY_KPMINUS 74 -#define KEY_KP4 75 -#define KEY_KP5 76 -#define KEY_KP6 77 -#define KEY_KPPLUS 78 -#define KEY_KP1 79 -#define KEY_KP2 80 -#define KEY_KP3 81 -#define KEY_KP0 82 -#define KEY_KPDOT 83 - -#define KEY_ZENKAKUHANKAKU 85 -#define KEY_102ND 86 -#define KEY_F11 87 -#define KEY_F12 88 -#define KEY_RO 89 -#define KEY_KATAKANA 90 -#define KEY_HIRAGANA 91 -#define KEY_HENKAN 92 -#define KEY_KATAKANAHIRAGANA 93 -#define KEY_MUHENKAN 94 -#define KEY_KPJPCOMMA 95 -#define KEY_KPENTER 96 -#define KEY_RIGHTCTRL 97 -#define KEY_KPSLASH 98 -#define KEY_SYSRQ 99 -#define KEY_RIGHTALT 100 -#define KEY_LINEFEED 101 -#define KEY_HOME 102 -#define KEY_UP 103 -#define KEY_PAGEUP 104 -#define KEY_LEFT 105 -#define KEY_RIGHT 106 -#define KEY_END 107 -#define KEY_DOWN 108 -#define KEY_PAGEDOWN 109 -#define KEY_INSERT 110 -#define KEY_DELETE 111 -#define KEY_MACRO 112 -#define KEY_MUTE 113 -#define KEY_VOLUMEDOWN 114 -#define KEY_VOLUMEUP 115 -#define KEY_POWER 116 /* SC System Power Down */ -#define KEY_KPEQUAL 117 -#define KEY_KPPLUSMINUS 118 -#define KEY_PAUSE 119 -#define KEY_SCALE 120 /* AL Compiz Scale (Expose) */ - -#define KEY_KPCOMMA 121 -#define KEY_HANGEUL 122 -#define KEY_HANGUEL KEY_HANGEUL -#define KEY_HANJA 123 -#define KEY_YEN 124 -#define KEY_LEFTMETA 125 -#define KEY_RIGHTMETA 126 -#define KEY_COMPOSE 127 - -#define KEY_STOP 128 /* AC Stop */ -#define KEY_AGAIN 129 -#define KEY_PROPS 130 /* AC Properties */ -#define KEY_UNDO 131 /* AC Undo */ -#define KEY_FRONT 132 -#define KEY_COPY 133 /* AC Copy */ -#define KEY_OPEN 134 /* AC Open */ -#define KEY_PASTE 135 /* AC Paste */ -#define KEY_FIND 136 /* AC Search */ -#define KEY_CUT 137 /* AC Cut */ -#define KEY_HELP 138 /* AL Integrated Help Center */ -#define KEY_MENU 139 /* Menu (show menu) */ -#define KEY_CALC 140 /* AL Calculator */ -#define KEY_SETUP 141 -#define KEY_SLEEP 142 /* SC System Sleep */ -#define KEY_WAKEUP 143 /* System Wake Up */ -#define KEY_FILE 144 /* AL Local Machine Browser */ -#define KEY_SENDFILE 145 -#define KEY_DELETEFILE 146 -#define KEY_XFER 147 -#define KEY_PROG1 148 -#define KEY_PROG2 149 -#define KEY_WWW 150 /* AL Internet Browser */ -#define KEY_MSDOS 151 -#define KEY_COFFEE 152 /* AL Terminal Lock/Screensaver */ -#define KEY_SCREENLOCK KEY_COFFEE -#define KEY_ROTATE_DISPLAY 153 /* Display orientation for e.g. tablets */ -#define KEY_DIRECTION KEY_ROTATE_DISPLAY -#define KEY_CYCLEWINDOWS 154 -#define KEY_MAIL 155 -#define KEY_BOOKMARKS 156 /* AC Bookmarks */ -#define KEY_COMPUTER 157 -#define KEY_BACK 158 /* AC Back */ -#define KEY_FORWARD 159 /* AC Forward */ -#define KEY_CLOSECD 160 -#define KEY_EJECTCD 161 -#define KEY_EJECTCLOSECD 162 -#define KEY_NEXTSONG 163 -#define KEY_PLAYPAUSE 164 -#define KEY_PREVIOUSSONG 165 -#define KEY_STOPCD 166 -#define KEY_RECORD 167 -#define KEY_REWIND 168 -#define KEY_PHONE 169 /* Media Select Telephone */ -#define KEY_ISO 170 -#define KEY_CONFIG 171 /* AL Consumer Control Configuration */ -#define KEY_HOMEPAGE 172 /* AC Home */ -#define KEY_REFRESH 173 /* AC Refresh */ -#define KEY_EXIT 174 /* AC Exit */ -#define KEY_MOVE 175 -#define KEY_EDIT 176 -#define KEY_SCROLLUP 177 -#define KEY_SCROLLDOWN 178 -#define KEY_KPLEFTPAREN 179 -#define KEY_KPRIGHTPAREN 180 -#define KEY_NEW 181 /* AC New */ -#define KEY_REDO 182 /* AC Redo/Repeat */ - -#define KEY_F13 183 -#define KEY_F14 184 -#define KEY_F15 185 -#define KEY_F16 186 -#define KEY_F17 187 -#define KEY_F18 188 -#define KEY_F19 189 -#define KEY_F20 190 -#define KEY_F21 191 -#define KEY_F22 192 -#define KEY_F23 193 -#define KEY_F24 194 - -#define KEY_PLAYCD 200 -#define KEY_PAUSECD 201 -#define KEY_PROG3 202 -#define KEY_PROG4 203 -#define KEY_DASHBOARD 204 /* AL Dashboard */ -#define KEY_SUSPEND 205 -#define KEY_CLOSE 206 /* AC Close */ -#define KEY_PLAY 207 -#define KEY_FASTFORWARD 208 -#define KEY_BASSBOOST 209 -#define KEY_PRINT 210 /* AC Print */ -#define KEY_HP 211 -#define KEY_CAMERA 212 -#define KEY_SOUND 213 -#define KEY_QUESTION 214 -#define KEY_EMAIL 215 -#define KEY_CHAT 216 -#define KEY_SEARCH 217 -#define KEY_CONNECT 218 -#define KEY_FINANCE 219 /* AL Checkbook/Finance */ -#define KEY_SPORT 220 -#define KEY_SHOP 221 -#define KEY_ALTERASE 222 -#define KEY_CANCEL 223 /* AC Cancel */ -#define KEY_BRIGHTNESSDOWN 224 -#define KEY_BRIGHTNESSUP 225 -#define KEY_MEDIA 226 - -#define KEY_SWITCHVIDEOMODE 227 /* Cycle between available video - outputs (Monitor/LCD/TV-out/etc) */ -#define KEY_KBDILLUMTOGGLE 228 -#define KEY_KBDILLUMDOWN 229 -#define KEY_KBDILLUMUP 230 - -#define KEY_SEND 231 /* AC Send */ -#define KEY_REPLY 232 /* AC Reply */ -#define KEY_FORWARDMAIL 233 /* AC Forward Msg */ -#define KEY_SAVE 234 /* AC Save */ -#define KEY_DOCUMENTS 235 - -#define KEY_BATTERY 236 - -#define KEY_BLUETOOTH 237 -#define KEY_WLAN 238 -#define KEY_UWB 239 - -#define KEY_UNKNOWN 240 - -#define KEY_VIDEO_NEXT 241 /* drive next video source */ -#define KEY_VIDEO_PREV 242 /* drive previous video source */ -#define KEY_BRIGHTNESS_CYCLE 243 /* brightness up, after max is min */ -#define KEY_BRIGHTNESS_AUTO 244 /* Set Auto Brightness: manual - brightness control is off, - rely on ambient */ -#define KEY_BRIGHTNESS_ZERO KEY_BRIGHTNESS_AUTO -#define KEY_DISPLAY_OFF 245 /* display device to off state */ - -#define KEY_WWAN 246 /* Wireless WAN (LTE, UMTS, GSM, etc.) */ -#define KEY_WIMAX KEY_WWAN -#define KEY_RFKILL 247 /* Key that controls all radios */ - -#define KEY_MICMUTE 248 /* Mute / unmute the microphone */ - -/* Code 255 is reserved for special needs of AT keyboard driver */ - -#define BTN_MISC 0x100 -#define BTN_0 0x100 -#define BTN_1 0x101 -#define BTN_2 0x102 -#define BTN_3 0x103 -#define BTN_4 0x104 -#define BTN_5 0x105 -#define BTN_6 0x106 -#define BTN_7 0x107 -#define BTN_8 0x108 -#define BTN_9 0x109 - -#define BTN_MOUSE 0x110 -#define BTN_LEFT 0x110 -#define BTN_RIGHT 0x111 -#define BTN_MIDDLE 0x112 -#define BTN_SIDE 0x113 -#define BTN_EXTRA 0x114 -#define BTN_FORWARD 0x115 -#define BTN_BACK 0x116 -#define BTN_TASK 0x117 - -#define BTN_JOYSTICK 0x120 -#define BTN_TRIGGER 0x120 -#define BTN_THUMB 0x121 -#define BTN_THUMB2 0x122 -#define BTN_TOP 0x123 -#define BTN_TOP2 0x124 -#define BTN_PINKIE 0x125 -#define BTN_BASE 0x126 -#define BTN_BASE2 0x127 -#define BTN_BASE3 0x128 -#define BTN_BASE4 0x129 -#define BTN_BASE5 0x12a -#define BTN_BASE6 0x12b -#define BTN_DEAD 0x12f - -#define BTN_GAMEPAD 0x130 -#define BTN_SOUTH 0x130 -#define BTN_A BTN_SOUTH -#define BTN_EAST 0x131 -#define BTN_B BTN_EAST -#define BTN_C 0x132 -#define BTN_NORTH 0x133 -#define BTN_X BTN_NORTH -#define BTN_WEST 0x134 -#define BTN_Y BTN_WEST -#define BTN_Z 0x135 -#define BTN_TL 0x136 -#define BTN_TR 0x137 -#define BTN_TL2 0x138 -#define BTN_TR2 0x139 -#define BTN_SELECT 0x13a -#define BTN_START 0x13b -#define BTN_MODE 0x13c -#define BTN_THUMBL 0x13d -#define BTN_THUMBR 0x13e - -#define BTN_DIGI 0x140 -#define BTN_TOOL_PEN 0x140 -#define BTN_TOOL_RUBBER 0x141 -#define BTN_TOOL_BRUSH 0x142 -#define BTN_TOOL_PENCIL 0x143 -#define BTN_TOOL_AIRBRUSH 0x144 -#define BTN_TOOL_FINGER 0x145 -#define BTN_TOOL_MOUSE 0x146 -#define BTN_TOOL_LENS 0x147 -#define BTN_TOOL_QUINTTAP 0x148 /* Five fingers on trackpad */ -#define BTN_TOUCH 0x14a -#define BTN_STYLUS 0x14b -#define BTN_STYLUS2 0x14c -#define BTN_TOOL_DOUBLETAP 0x14d -#define BTN_TOOL_TRIPLETAP 0x14e -#define BTN_TOOL_QUADTAP 0x14f /* Four fingers on trackpad */ - -#define BTN_WHEEL 0x150 -#define BTN_GEAR_DOWN 0x150 -#define BTN_GEAR_UP 0x151 - -#define KEY_OK 0x160 -#define KEY_SELECT 0x161 -#define KEY_GOTO 0x162 -#define KEY_CLEAR 0x163 -#define KEY_POWER2 0x164 -#define KEY_OPTION 0x165 -#define KEY_INFO 0x166 /* AL OEM Features/Tips/Tutorial */ -#define KEY_TIME 0x167 -#define KEY_VENDOR 0x168 -#define KEY_ARCHIVE 0x169 -#define KEY_PROGRAM 0x16a /* Media Select Program Guide */ -#define KEY_CHANNEL 0x16b -#define KEY_FAVORITES 0x16c -#define KEY_EPG 0x16d -#define KEY_PVR 0x16e /* Media Select Home */ -#define KEY_MHP 0x16f -#define KEY_LANGUAGE 0x170 -#define KEY_TITLE 0x171 -#define KEY_SUBTITLE 0x172 -#define KEY_ANGLE 0x173 -#define KEY_ZOOM 0x174 -#define KEY_MODE 0x175 -#define KEY_KEYBOARD 0x176 -#define KEY_SCREEN 0x177 -#define KEY_PC 0x178 /* Media Select Computer */ -#define KEY_TV 0x179 /* Media Select TV */ -#define KEY_TV2 0x17a /* Media Select Cable */ -#define KEY_VCR 0x17b /* Media Select VCR */ -#define KEY_VCR2 0x17c /* VCR Plus */ -#define KEY_SAT 0x17d /* Media Select Satellite */ -#define KEY_SAT2 0x17e -#define KEY_CD 0x17f /* Media Select CD */ -#define KEY_TAPE 0x180 /* Media Select Tape */ -#define KEY_RADIO 0x181 -#define KEY_TUNER 0x182 /* Media Select Tuner */ -#define KEY_PLAYER 0x183 -#define KEY_TEXT 0x184 -#define KEY_DVD 0x185 /* Media Select DVD */ -#define KEY_AUX 0x186 -#define KEY_MP3 0x187 -#define KEY_AUDIO 0x188 /* AL Audio Browser */ -#define KEY_VIDEO 0x189 /* AL Movie Browser */ -#define KEY_DIRECTORY 0x18a -#define KEY_LIST 0x18b -#define KEY_MEMO 0x18c /* Media Select Messages */ -#define KEY_CALENDAR 0x18d -#define KEY_RED 0x18e -#define KEY_GREEN 0x18f -#define KEY_YELLOW 0x190 -#define KEY_BLUE 0x191 -#define KEY_CHANNELUP 0x192 /* Channel Increment */ -#define KEY_CHANNELDOWN 0x193 /* Channel Decrement */ -#define KEY_FIRST 0x194 -#define KEY_LAST 0x195 /* Recall Last */ -#define KEY_AB 0x196 -#define KEY_NEXT 0x197 -#define KEY_RESTART 0x198 -#define KEY_SLOW 0x199 -#define KEY_SHUFFLE 0x19a -#define KEY_BREAK 0x19b -#define KEY_PREVIOUS 0x19c -#define KEY_DIGITS 0x19d -#define KEY_TEEN 0x19e -#define KEY_TWEN 0x19f -#define KEY_VIDEOPHONE 0x1a0 /* Media Select Video Phone */ -#define KEY_GAMES 0x1a1 /* Media Select Games */ -#define KEY_ZOOMIN 0x1a2 /* AC Zoom In */ -#define KEY_ZOOMOUT 0x1a3 /* AC Zoom Out */ -#define KEY_ZOOMRESET 0x1a4 /* AC Zoom */ -#define KEY_WORDPROCESSOR 0x1a5 /* AL Word Processor */ -#define KEY_EDITOR 0x1a6 /* AL Text Editor */ -#define KEY_SPREADSHEET 0x1a7 /* AL Spreadsheet */ -#define KEY_GRAPHICSEDITOR 0x1a8 /* AL Graphics Editor */ -#define KEY_PRESENTATION 0x1a9 /* AL Presentation App */ -#define KEY_DATABASE 0x1aa /* AL Database App */ -#define KEY_NEWS 0x1ab /* AL Newsreader */ -#define KEY_VOICEMAIL 0x1ac /* AL Voicemail */ -#define KEY_ADDRESSBOOK 0x1ad /* AL Contacts/Address Book */ -#define KEY_MESSENGER 0x1ae /* AL Instant Messaging */ -#define KEY_DISPLAYTOGGLE 0x1af /* Turn display (LCD) on and off */ -#define KEY_BRIGHTNESS_TOGGLE KEY_DISPLAYTOGGLE -#define KEY_SPELLCHECK 0x1b0 /* AL Spell Check */ -#define KEY_LOGOFF 0x1b1 /* AL Logoff */ - -#define KEY_DOLLAR 0x1b2 -#define KEY_EURO 0x1b3 - -#define KEY_FRAMEBACK 0x1b4 /* Consumer - transport controls */ -#define KEY_FRAMEFORWARD 0x1b5 -#define KEY_CONTEXT_MENU 0x1b6 /* GenDesc - system context menu */ -#define KEY_MEDIA_REPEAT 0x1b7 /* Consumer - transport control */ -#define KEY_10CHANNELSUP 0x1b8 /* 10 channels up (10+) */ -#define KEY_10CHANNELSDOWN 0x1b9 /* 10 channels down (10-) */ -#define KEY_IMAGES 0x1ba /* AL Image Browser */ - -#define KEY_DEL_EOL 0x1c0 -#define KEY_DEL_EOS 0x1c1 -#define KEY_INS_LINE 0x1c2 -#define KEY_DEL_LINE 0x1c3 - -#define KEY_FN 0x1d0 -#define KEY_FN_ESC 0x1d1 -#define KEY_FN_F1 0x1d2 -#define KEY_FN_F2 0x1d3 -#define KEY_FN_F3 0x1d4 -#define KEY_FN_F4 0x1d5 -#define KEY_FN_F5 0x1d6 -#define KEY_FN_F6 0x1d7 -#define KEY_FN_F7 0x1d8 -#define KEY_FN_F8 0x1d9 -#define KEY_FN_F9 0x1da -#define KEY_FN_F10 0x1db -#define KEY_FN_F11 0x1dc -#define KEY_FN_F12 0x1dd -#define KEY_FN_1 0x1de -#define KEY_FN_2 0x1df -#define KEY_FN_D 0x1e0 -#define KEY_FN_E 0x1e1 -#define KEY_FN_F 0x1e2 -#define KEY_FN_S 0x1e3 -#define KEY_FN_B 0x1e4 - -#define KEY_BRL_DOT1 0x1f1 -#define KEY_BRL_DOT2 0x1f2 -#define KEY_BRL_DOT3 0x1f3 -#define KEY_BRL_DOT4 0x1f4 -#define KEY_BRL_DOT5 0x1f5 -#define KEY_BRL_DOT6 0x1f6 -#define KEY_BRL_DOT7 0x1f7 -#define KEY_BRL_DOT8 0x1f8 -#define KEY_BRL_DOT9 0x1f9 -#define KEY_BRL_DOT10 0x1fa - -#define KEY_NUMERIC_0 0x200 /* used by phones, remote controls, */ -#define KEY_NUMERIC_1 0x201 /* and other keypads */ -#define KEY_NUMERIC_2 0x202 -#define KEY_NUMERIC_3 0x203 -#define KEY_NUMERIC_4 0x204 -#define KEY_NUMERIC_5 0x205 -#define KEY_NUMERIC_6 0x206 -#define KEY_NUMERIC_7 0x207 -#define KEY_NUMERIC_8 0x208 -#define KEY_NUMERIC_9 0x209 -#define KEY_NUMERIC_STAR 0x20a -#define KEY_NUMERIC_POUND 0x20b -#define KEY_NUMERIC_A 0x20c /* Phone key A - HUT Telephony 0xb9 */ -#define KEY_NUMERIC_B 0x20d -#define KEY_NUMERIC_C 0x20e -#define KEY_NUMERIC_D 0x20f - -#define KEY_CAMERA_FOCUS 0x210 -#define KEY_WPS_BUTTON 0x211 /* WiFi Protected Setup key */ - -#define KEY_TOUCHPAD_TOGGLE 0x212 /* Request switch touchpad on or off */ -#define KEY_TOUCHPAD_ON 0x213 -#define KEY_TOUCHPAD_OFF 0x214 - -#define KEY_CAMERA_ZOOMIN 0x215 -#define KEY_CAMERA_ZOOMOUT 0x216 -#define KEY_CAMERA_UP 0x217 -#define KEY_CAMERA_DOWN 0x218 -#define KEY_CAMERA_LEFT 0x219 -#define KEY_CAMERA_RIGHT 0x21a - -#define KEY_ATTENDANT_ON 0x21b -#define KEY_ATTENDANT_OFF 0x21c -#define KEY_ATTENDANT_TOGGLE 0x21d /* Attendant call on or off */ -#define KEY_LIGHTS_TOGGLE 0x21e /* Reading light on or off */ - -#define BTN_DPAD_UP 0x220 -#define BTN_DPAD_DOWN 0x221 -#define BTN_DPAD_LEFT 0x222 -#define BTN_DPAD_RIGHT 0x223 - -#define KEY_ALS_TOGGLE 0x230 /* Ambient light sensor */ - -#define KEY_BUTTONCONFIG 0x240 /* AL Button Configuration */ -#define KEY_TASKMANAGER 0x241 /* AL Task/Project Manager */ -#define KEY_JOURNAL 0x242 /* AL Log/Journal/Timecard */ -#define KEY_CONTROLPANEL 0x243 /* AL Control Panel */ -#define KEY_APPSELECT 0x244 /* AL Select Task/Application */ -#define KEY_SCREENSAVER 0x245 /* AL Screen Saver */ -#define KEY_VOICECOMMAND 0x246 /* Listening Voice Command */ - -#define KEY_BRIGHTNESS_MIN 0x250 /* Set Brightness to Minimum */ -#define KEY_BRIGHTNESS_MAX 0x251 /* Set Brightness to Maximum */ - -#define KEY_KBDINPUTASSIST_PREV 0x260 -#define KEY_KBDINPUTASSIST_NEXT 0x261 -#define KEY_KBDINPUTASSIST_PREVGROUP 0x262 -#define KEY_KBDINPUTASSIST_NEXTGROUP 0x263 -#define KEY_KBDINPUTASSIST_ACCEPT 0x264 -#define KEY_KBDINPUTASSIST_CANCEL 0x265 - -#define BTN_TRIGGER_HAPPY 0x2c0 -#define BTN_TRIGGER_HAPPY1 0x2c0 -#define BTN_TRIGGER_HAPPY2 0x2c1 -#define BTN_TRIGGER_HAPPY3 0x2c2 -#define BTN_TRIGGER_HAPPY4 0x2c3 -#define BTN_TRIGGER_HAPPY5 0x2c4 -#define BTN_TRIGGER_HAPPY6 0x2c5 -#define BTN_TRIGGER_HAPPY7 0x2c6 -#define BTN_TRIGGER_HAPPY8 0x2c7 -#define BTN_TRIGGER_HAPPY9 0x2c8 -#define BTN_TRIGGER_HAPPY10 0x2c9 -#define BTN_TRIGGER_HAPPY11 0x2ca -#define BTN_TRIGGER_HAPPY12 0x2cb -#define BTN_TRIGGER_HAPPY13 0x2cc -#define BTN_TRIGGER_HAPPY14 0x2cd -#define BTN_TRIGGER_HAPPY15 0x2ce -#define BTN_TRIGGER_HAPPY16 0x2cf -#define BTN_TRIGGER_HAPPY17 0x2d0 -#define BTN_TRIGGER_HAPPY18 0x2d1 -#define BTN_TRIGGER_HAPPY19 0x2d2 -#define BTN_TRIGGER_HAPPY20 0x2d3 -#define BTN_TRIGGER_HAPPY21 0x2d4 -#define BTN_TRIGGER_HAPPY22 0x2d5 -#define BTN_TRIGGER_HAPPY23 0x2d6 -#define BTN_TRIGGER_HAPPY24 0x2d7 -#define BTN_TRIGGER_HAPPY25 0x2d8 -#define BTN_TRIGGER_HAPPY26 0x2d9 -#define BTN_TRIGGER_HAPPY27 0x2da -#define BTN_TRIGGER_HAPPY28 0x2db -#define BTN_TRIGGER_HAPPY29 0x2dc -#define BTN_TRIGGER_HAPPY30 0x2dd -#define BTN_TRIGGER_HAPPY31 0x2de -#define BTN_TRIGGER_HAPPY32 0x2df -#define BTN_TRIGGER_HAPPY33 0x2e0 -#define BTN_TRIGGER_HAPPY34 0x2e1 -#define BTN_TRIGGER_HAPPY35 0x2e2 -#define BTN_TRIGGER_HAPPY36 0x2e3 -#define BTN_TRIGGER_HAPPY37 0x2e4 -#define BTN_TRIGGER_HAPPY38 0x2e5 -#define BTN_TRIGGER_HAPPY39 0x2e6 -#define BTN_TRIGGER_HAPPY40 0x2e7 - -/* We avoid low common keys in module aliases so they don't get huge. */ -#define KEY_MIN_INTERESTING KEY_MUTE -#define KEY_MAX 0x2ff -#define KEY_CNT (KEY_MAX+1) - -/* - * Relative axes - */ - -#define REL_X 0x00 -#define REL_Y 0x01 -#define REL_Z 0x02 -#define REL_RX 0x03 -#define REL_RY 0x04 -#define REL_RZ 0x05 -#define REL_HWHEEL 0x06 -#define REL_DIAL 0x07 -#define REL_WHEEL 0x08 -#define REL_MISC 0x09 -#define REL_MAX 0x0f -#define REL_CNT (REL_MAX+1) - -/* - * Absolute axes - */ - -#define ABS_X 0x00 -#define ABS_Y 0x01 -#define ABS_Z 0x02 -#define ABS_RX 0x03 -#define ABS_RY 0x04 -#define ABS_RZ 0x05 -#define ABS_THROTTLE 0x06 -#define ABS_RUDDER 0x07 -#define ABS_WHEEL 0x08 -#define ABS_GAS 0x09 -#define ABS_BRAKE 0x0a -#define ABS_HAT0X 0x10 -#define ABS_HAT0Y 0x11 -#define ABS_HAT1X 0x12 -#define ABS_HAT1Y 0x13 -#define ABS_HAT2X 0x14 -#define ABS_HAT2Y 0x15 -#define ABS_HAT3X 0x16 -#define ABS_HAT3Y 0x17 -#define ABS_PRESSURE 0x18 -#define ABS_DISTANCE 0x19 -#define ABS_TILT_X 0x1a -#define ABS_TILT_Y 0x1b -#define ABS_TOOL_WIDTH 0x1c - -#define ABS_VOLUME 0x20 - -#define ABS_MISC 0x28 - -#define ABS_MT_SLOT 0x2f /* MT slot being modified */ -#define ABS_MT_TOUCH_MAJOR 0x30 /* Major axis of touching ellipse */ -#define ABS_MT_TOUCH_MINOR 0x31 /* Minor axis (omit if circular) */ -#define ABS_MT_WIDTH_MAJOR 0x32 /* Major axis of approaching ellipse */ -#define ABS_MT_WIDTH_MINOR 0x33 /* Minor axis (omit if circular) */ -#define ABS_MT_ORIENTATION 0x34 /* Ellipse orientation */ -#define ABS_MT_POSITION_X 0x35 /* Center X touch position */ -#define ABS_MT_POSITION_Y 0x36 /* Center Y touch position */ -#define ABS_MT_TOOL_TYPE 0x37 /* Type of touching device */ -#define ABS_MT_BLOB_ID 0x38 /* Group a set of packets as a blob */ -#define ABS_MT_TRACKING_ID 0x39 /* Unique ID of initiated contact */ -#define ABS_MT_PRESSURE 0x3a /* Pressure on contact area */ -#define ABS_MT_DISTANCE 0x3b /* Contact hover distance */ -#define ABS_MT_TOOL_X 0x3c /* Center X tool position */ -#define ABS_MT_TOOL_Y 0x3d /* Center Y tool position */ - - -#define ABS_MAX 0x3f -#define ABS_CNT (ABS_MAX+1) - -/* - * Switch events - */ - -#define SW_LID 0x00 /* set = lid shut */ -#define SW_TABLET_MODE 0x01 /* set = tablet mode */ -#define SW_HEADPHONE_INSERT 0x02 /* set = inserted */ -#define SW_RFKILL_ALL 0x03 /* rfkill master switch, type "any" - set = radio enabled */ -#define SW_RADIO SW_RFKILL_ALL /* deprecated */ -#define SW_MICROPHONE_INSERT 0x04 /* set = inserted */ -#define SW_DOCK 0x05 /* set = plugged into dock */ -#define SW_LINEOUT_INSERT 0x06 /* set = inserted */ -#define SW_JACK_PHYSICAL_INSERT 0x07 /* set = mechanical switch set */ -#define SW_VIDEOOUT_INSERT 0x08 /* set = inserted */ -#define SW_CAMERA_LENS_COVER 0x09 /* set = lens covered */ -#define SW_KEYPAD_SLIDE 0x0a /* set = keypad slide out */ -#define SW_FRONT_PROXIMITY 0x0b /* set = front proximity sensor active */ -#define SW_ROTATE_LOCK 0x0c /* set = rotate locked/disabled */ -#define SW_LINEIN_INSERT 0x0d /* set = inserted */ -#define SW_MUTE_DEVICE 0x0e /* set = device disabled */ -#define SW_PEN_INSERTED 0x0f /* set = pen inserted */ -#define SW_MAX 0x10 -#define SW_CNT (SW_MAX+1) - -/* - * Misc events - */ - -#define MSC_SERIAL 0x00 -#define MSC_PULSELED 0x01 -#define MSC_GESTURE 0x02 -#define MSC_RAW 0x03 -#define MSC_SCAN 0x04 -#define MSC_TIMESTAMP 0x05 -#define MSC_MAX 0x07 -#define MSC_CNT (MSC_MAX+1) - -/* - * LEDs - */ - -#define LED_NUML 0x00 -#define LED_CAPSL 0x01 -#define LED_SCROLLL 0x02 -#define LED_COMPOSE 0x03 -#define LED_KANA 0x04 -#define LED_SLEEP 0x05 -#define LED_SUSPEND 0x06 -#define LED_MUTE 0x07 -#define LED_MISC 0x08 -#define LED_MAIL 0x09 -#define LED_CHARGING 0x0a -#define LED_MAX 0x0f -#define LED_CNT (LED_MAX+1) - -/* - * Autorepeat values - */ - -#define REP_DELAY 0x00 -#define REP_PERIOD 0x01 -#define REP_MAX 0x01 -#define REP_CNT (REP_MAX+1) - -/* - * Sounds - */ - -#define SND_CLICK 0x00 -#define SND_BELL 0x01 -#define SND_TONE 0x02 -#define SND_MAX 0x07 -#define SND_CNT (SND_MAX+1) - -#endif diff --git a/include/dt-bindings/interrupt-controller/irq.h b/include/dt-bindings/interrupt-controller/irq.h deleted file mode 100644 index 33a1003c55aa..000000000000 --- a/include/dt-bindings/interrupt-controller/irq.h +++ /dev/null @@ -1,19 +0,0 @@ -/* - * This header provides constants for most IRQ bindings. - * - * Most IRQ bindings include a flags cell as part of the IRQ specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H - -#define IRQ_TYPE_NONE 0 -#define IRQ_TYPE_EDGE_RISING 1 -#define IRQ_TYPE_EDGE_FALLING 2 -#define IRQ_TYPE_EDGE_BOTH (IRQ_TYPE_EDGE_FALLING | IRQ_TYPE_EDGE_RISING) -#define IRQ_TYPE_LEVEL_HIGH 4 -#define IRQ_TYPE_LEVEL_LOW 8 - -#endif diff --git a/include/dt-bindings/leds/common.h b/include/dt-bindings/leds/common.h deleted file mode 100644 index 9a0d33d027ff..000000000000 --- a/include/dt-bindings/leds/common.h +++ /dev/null @@ -1,106 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides macros for the common LEDs device tree bindings. - * - * Copyright (C) 2015, Samsung Electronics Co., Ltd. - * Author: Jacek Anaszewski j.anaszewski@samsung.com - * - * Copyright (C) 2019 Jacek Anaszewski jacek.anaszewski@gmail.com - * Copyright (C) 2020 Pavel Machek pavel@ucw.cz - */ - -#ifndef __DT_BINDINGS_LEDS_H -#define __DT_BINDINGS_LEDS_H - -/* External trigger type */ -#define LEDS_TRIG_TYPE_EDGE 0 -#define LEDS_TRIG_TYPE_LEVEL 1 - -/* Boost modes */ -#define LEDS_BOOST_OFF 0 -#define LEDS_BOOST_ADAPTIVE 1 -#define LEDS_BOOST_FIXED 2 - -/* Standard LED colors */ -#define LED_COLOR_ID_WHITE 0 -#define LED_COLOR_ID_RED 1 -#define LED_COLOR_ID_GREEN 2 -#define LED_COLOR_ID_BLUE 3 -#define LED_COLOR_ID_AMBER 4 -#define LED_COLOR_ID_VIOLET 5 -#define LED_COLOR_ID_YELLOW 6 -#define LED_COLOR_ID_IR 7 -#define LED_COLOR_ID_MULTI 8 /* For multicolor LEDs */ -#define LED_COLOR_ID_RGB 9 /* For multicolor LEDs that can do arbitrary color, - so this would include RGBW and similar */ -#define LED_COLOR_ID_PURPLE 10 -#define LED_COLOR_ID_ORANGE 11 -#define LED_COLOR_ID_PINK 12 -#define LED_COLOR_ID_CYAN 13 -#define LED_COLOR_ID_LIME 14 -#define LED_COLOR_ID_MAX 15 - -/* Standard LED functions */ -/* Keyboard LEDs, usually it would be input4::capslock etc. */ -/* Obsolete equivalent: "shift-key-light" */ -#define LED_FUNCTION_CAPSLOCK "capslock" -#define LED_FUNCTION_SCROLLLOCK "scrolllock" -#define LED_FUNCTION_NUMLOCK "numlock" -/* Obsolete equivalents: "tpacpi::thinklight" (IBM/Lenovo Thinkpads), - "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ -#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" - -/* System LEDs, usually found on system body. - platform::mute (etc) is sometimes seen, :mute would be better */ -#define LED_FUNCTION_POWER "power" -#define LED_FUNCTION_DISK "disk" - -/* Obsolete: "platform:*:charging" (allwinner sun50i) */ -#define LED_FUNCTION_CHARGING "charging" -/* Used RGB notification LEDs common on phones. - Obsolete equivalents: "status-led:{red,green,blue}" (Motorola Droid 4), - "lp5523:{r,g,b}" (Nokia N900) */ -#define LED_FUNCTION_STATUS "status" - -#define LED_FUNCTION_MICMUTE "micmute" -#define LED_FUNCTION_MUTE "mute" - -/* Used for player LEDs as found on game controllers from e.g. Nintendo, Sony. */ -#define LED_FUNCTION_PLAYER1 "player-1" -#define LED_FUNCTION_PLAYER2 "player-2" -#define LED_FUNCTION_PLAYER3 "player-3" -#define LED_FUNCTION_PLAYER4 "player-4" -#define LED_FUNCTION_PLAYER5 "player-5" - -/* Miscelleaus functions. Use functions above if you can. */ -#define LED_FUNCTION_ACTIVITY "activity" -#define LED_FUNCTION_ALARM "alarm" -#define LED_FUNCTION_BACKLIGHT "backlight" -#define LED_FUNCTION_BLUETOOTH "bluetooth" -#define LED_FUNCTION_BOOT "boot" -#define LED_FUNCTION_CPU "cpu" -#define LED_FUNCTION_DEBUG "debug" -#define LED_FUNCTION_DISK_ACTIVITY "disk-activity" -#define LED_FUNCTION_DISK_ERR "disk-err" -#define LED_FUNCTION_DISK_READ "disk-read" -#define LED_FUNCTION_DISK_WRITE "disk-write" -#define LED_FUNCTION_FAULT "fault" -#define LED_FUNCTION_FLASH "flash" -#define LED_FUNCTION_HEARTBEAT "heartbeat" -#define LED_FUNCTION_INDICATOR "indicator" -#define LED_FUNCTION_LAN "lan" -#define LED_FUNCTION_MAIL "mail" -#define LED_FUNCTION_MTD "mtd" -#define LED_FUNCTION_PANIC "panic" -#define LED_FUNCTION_PROGRAMMING "programming" -#define LED_FUNCTION_RX "rx" -#define LED_FUNCTION_SD "sd" -#define LED_FUNCTION_STANDBY "standby" -#define LED_FUNCTION_TORCH "torch" -#define LED_FUNCTION_TX "tx" -#define LED_FUNCTION_USB "usb" -#define LED_FUNCTION_WAN "wan" -#define LED_FUNCTION_WLAN "wlan" -#define LED_FUNCTION_WPS "wps" - -#endif /* __DT_BINDINGS_LEDS_H */ diff --git a/include/dt-bindings/mux/mux.h b/include/dt-bindings/mux/mux.h deleted file mode 100644 index 042719218dbf..000000000000 --- a/include/dt-bindings/mux/mux.h +++ /dev/null @@ -1,17 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for most Multiplexer bindings. - * - * Most Multiplexer bindings specify an idle state. In most cases, the - * the multiplexer can be left as is when idle, and in some cases it can - * disconnect the input/output and leave the multiplexer in a high - * impedance state. - */ - -#ifndef _DT_BINDINGS_MUX_MUX_H -#define _DT_BINDINGS_MUX_MUX_H - -#define MUX_IDLE_AS_IS (-1) -#define MUX_IDLE_DISCONNECT (-2) - -#endif diff --git a/include/dt-bindings/phy/phy.h b/include/dt-bindings/phy/phy.h deleted file mode 100644 index f48c9acf251e..000000000000 --- a/include/dt-bindings/phy/phy.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * - * This header provides constants for the phy framework - * - * Copyright (C) 2014 STMicroelectronics - * Author: Gabriel Fernandez gabriel.fernandez@st.com - */ - -#ifndef _DT_BINDINGS_PHY -#define _DT_BINDINGS_PHY - -#define PHY_NONE 0 -#define PHY_TYPE_SATA 1 -#define PHY_TYPE_PCIE 2 -#define PHY_TYPE_USB2 3 -#define PHY_TYPE_USB3 4 -#define PHY_TYPE_UFS 5 -#define PHY_TYPE_DP 6 -#define PHY_TYPE_XPCS 7 -#define PHY_TYPE_SGMII 8 -#define PHY_TYPE_QSGMII 9 -#define PHY_TYPE_DPHY 10 -#define PHY_TYPE_CPHY 11 - -#endif /* _DT_BINDINGS_PHY */ diff --git a/include/dt-bindings/pwm/pwm.h b/include/dt-bindings/pwm/pwm.h deleted file mode 100644 index 96f49e82253e..000000000000 --- a/include/dt-bindings/pwm/pwm.h +++ /dev/null @@ -1,14 +0,0 @@ -/* - * This header provides constants for most PWM bindings. - * - * Most PWM bindings can include a flags cell as part of the PWM specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_PWM_PWM_H -#define _DT_BINDINGS_PWM_PWM_H - -#define PWM_POLARITY_INVERTED (1 << 0) - -#endif diff --git a/include/dt-bindings/spmi/spmi.h b/include/dt-bindings/spmi/spmi.h deleted file mode 100644 index ad4a43481de4..000000000000 --- a/include/dt-bindings/spmi/spmi.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* Copyright (c) 2013, The Linux Foundation. All rights reserved. - */ -#ifndef __DT_BINDINGS_SPMI_H -#define __DT_BINDINGS_SPMI_H - -#define SPMI_USID 0 -#define SPMI_GSID 1 - -#endif diff --git a/include/dt-bindings/thermal/thermal.h b/include/dt-bindings/thermal/thermal.h deleted file mode 100644 index 7871e5f52b1c..000000000000 --- a/include/dt-bindings/thermal/thermal.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * This header provides constants for most thermal bindings. - * - * Copyright (C) 2013 Texas Instruments - * Eduardo Valentin eduardo.valentin@ti.com - */ - -#ifndef _DT_BINDINGS_THERMAL_THERMAL_H -#define _DT_BINDINGS_THERMAL_THERMAL_H - -/* On cooling devices upper and lower limits */ -#define THERMAL_NO_LIMIT (~0) - -#endif diff --git a/include/dt-bindings/usb/pd.h b/include/dt-bindings/usb/pd.h deleted file mode 100644 index 985f2bbd4d24..000000000000 --- a/include/dt-bindings/usb/pd.h +++ /dev/null @@ -1,88 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_POWER_DELIVERY_H -#define __DT_POWER_DELIVERY_H - -/* Power delivery Power Data Object definitions */ -#define PDO_TYPE_FIXED 0 -#define PDO_TYPE_BATT 1 -#define PDO_TYPE_VAR 2 -#define PDO_TYPE_APDO 3 - -#define PDO_TYPE_SHIFT 30 -#define PDO_TYPE_MASK 0x3 - -#define PDO_TYPE(t) ((t) << PDO_TYPE_SHIFT) - -#define PDO_VOLT_MASK 0x3ff -#define PDO_CURR_MASK 0x3ff -#define PDO_PWR_MASK 0x3ff - -#define PDO_FIXED_DUAL_ROLE (1 << 29) /* Power role swap supported */ -#define PDO_FIXED_SUSPEND (1 << 28) /* USB Suspend supported (Source) */ -#define PDO_FIXED_HIGHER_CAP (1 << 28) /* Requires more than vSafe5V (Sink) */ -#define PDO_FIXED_EXTPOWER (1 << 27) /* Externally powered */ -#define PDO_FIXED_USB_COMM (1 << 26) /* USB communications capable */ -#define PDO_FIXED_DATA_SWAP (1 << 25) /* Data role swap supported */ -#define PDO_FIXED_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_FIXED_CURR_SHIFT 0 /* 10mA units */ - -#define PDO_FIXED_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_FIXED_VOLT_SHIFT) -#define PDO_FIXED_CURR(ma) ((((ma) / 10) & PDO_CURR_MASK) << PDO_FIXED_CURR_SHIFT) - -#define PDO_FIXED(mv, ma, flags) \ - (PDO_TYPE(PDO_TYPE_FIXED) | (flags) | \ - PDO_FIXED_VOLT(mv) | PDO_FIXED_CURR(ma)) - -#define VSAFE5V 5000 /* mv units */ - -#define PDO_BATT_MAX_VOLT_SHIFT 20 /* 50mV units */ -#define PDO_BATT_MIN_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_BATT_MAX_PWR_SHIFT 0 /* 250mW units */ - -#define PDO_BATT_MIN_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_BATT_MIN_VOLT_SHIFT) -#define PDO_BATT_MAX_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_BATT_MAX_VOLT_SHIFT) -#define PDO_BATT_MAX_POWER(mw) ((((mw) / 250) & PDO_PWR_MASK) << PDO_BATT_MAX_PWR_SHIFT) - -#define PDO_BATT(min_mv, max_mv, max_mw) \ - (PDO_TYPE(PDO_TYPE_BATT) | PDO_BATT_MIN_VOLT(min_mv) | \ - PDO_BATT_MAX_VOLT(max_mv) | PDO_BATT_MAX_POWER(max_mw)) - -#define PDO_VAR_MAX_VOLT_SHIFT 20 /* 50mV units */ -#define PDO_VAR_MIN_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_VAR_MAX_CURR_SHIFT 0 /* 10mA units */ - -#define PDO_VAR_MIN_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_VAR_MIN_VOLT_SHIFT) -#define PDO_VAR_MAX_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_VAR_MAX_VOLT_SHIFT) -#define PDO_VAR_MAX_CURR(ma) ((((ma) / 10) & PDO_CURR_MASK) << PDO_VAR_MAX_CURR_SHIFT) - -#define PDO_VAR(min_mv, max_mv, max_ma) \ - (PDO_TYPE(PDO_TYPE_VAR) | PDO_VAR_MIN_VOLT(min_mv) | \ - PDO_VAR_MAX_VOLT(max_mv) | PDO_VAR_MAX_CURR(max_ma)) - -#define APDO_TYPE_PPS 0 - -#define PDO_APDO_TYPE_SHIFT 28 /* Only valid value currently is 0x0 - PPS */ -#define PDO_APDO_TYPE_MASK 0x3 - -#define PDO_APDO_TYPE(t) ((t) << PDO_APDO_TYPE_SHIFT) - -#define PDO_PPS_APDO_MAX_VOLT_SHIFT 17 /* 100mV units */ -#define PDO_PPS_APDO_MIN_VOLT_SHIFT 8 /* 100mV units */ -#define PDO_PPS_APDO_MAX_CURR_SHIFT 0 /* 50mA units */ - -#define PDO_PPS_APDO_VOLT_MASK 0xff -#define PDO_PPS_APDO_CURR_MASK 0x7f - -#define PDO_PPS_APDO_MIN_VOLT(mv) \ - ((((mv) / 100) & PDO_PPS_APDO_VOLT_MASK) << PDO_PPS_APDO_MIN_VOLT_SHIFT) -#define PDO_PPS_APDO_MAX_VOLT(mv) \ - ((((mv) / 100) & PDO_PPS_APDO_VOLT_MASK) << PDO_PPS_APDO_MAX_VOLT_SHIFT) -#define PDO_PPS_APDO_MAX_CURR(ma) \ - ((((ma) / 50) & PDO_PPS_APDO_CURR_MASK) << PDO_PPS_APDO_MAX_CURR_SHIFT) - -#define PDO_PPS_APDO(min_mv, max_mv, max_ma) \ - (PDO_TYPE(PDO_TYPE_APDO) | PDO_APDO_TYPE(APDO_TYPE_PPS) | \ - PDO_PPS_APDO_MIN_VOLT(min_mv) | PDO_PPS_APDO_MAX_VOLT(max_mv) | \ - PDO_PPS_APDO_MAX_CURR(max_ma)) - - #endif /* __DT_POWER_DELIVERY_H */
This adjusts OF_UPSTREAM to behave more like the kernel by allowing for all the devicetree files for a given vendor to be compiled. This is useful for Qualcomm in particular as most boards are supported by a single U-Boot build just provided with a different DT.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- dts/Kconfig | 24 ++++++++++++++++++++++++ scripts/Makefile.dts | 13 +++++++++++++ 2 files changed, 37 insertions(+)
diff --git a/dts/Kconfig b/dts/Kconfig index b9b6367154ef..6883a000a052 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -100,8 +100,32 @@ config OF_UPSTREAM However, newer boards whose devicetree source files haven't landed in the dts/upstream subtree, they can override this option to have the DT build from existing U-Boot tree location instead.
+config OF_UPSTREAM_BUILD_VENDOR + bool "Build all devicetree files for a particular vendor" + depends on OF_UPSTREAM + help + Enable building all devicetree files for a particular vendor. This + is useful for generic U-Boot configurations where many boards can + be supported with a single binary. + + This is only available for platforms using upstream devicetree. + +config OF_UPSTREAM_VENDOR + string "Vendor to build all upstream devicetree files for" + depends on OF_UPSTREAM_BUILD_VENDOR + default "qcom" if ARCH_SNAPDRAGON + default "rockchip" if ARCH_ROCKCHIP + default "amlogic" if ARCH_MESON + default "allwinner" if ARCH_SUNXI + default "mediatek" if ARCH_MEDIATEK + default "marvell" if ARCH_MVEBU || ARCH_KIRKWOOD + default "xilinx" if ARCH_VERSAL || ARCH_ZYNQ + default "nvidia" if ARCH_TEGRA + help + Select the vendor to build all devicetree files for. + choice prompt "Provider of DTB for DT control" depends on OF_CONTROL
diff --git a/scripts/Makefile.dts b/scripts/Makefile.dts index 5e2429c6170c..790f3c508f19 100644 --- a/scripts/Makefile.dts +++ b/scripts/Makefile.dts @@ -1,3 +1,16 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-y += $(patsubst %,%.dtb,$(subst ",,$(CONFIG_DEFAULT_DEVICE_TREE) $(CONFIG_OF_LIST) $(CONFIG_SPL_OF_LIST))) + +ifeq ($(CONFIG_OF_UPSTREAM_BUILD_VENDOR),y) +ifeq ($(CONFIG_ARM64),y) +dt_dir := $(srctree)/dts/upstream/src/arm64 +else +dt_dir := $(srctree)/dts/upstream/src/$(ARCH) +endif + +dtb-vendor_dts := $(patsubst %.dts,%.dtb,$(wildcard $(dt_dir)/$(subst ",,$(CONFIG_OF_UPSTREAM_VENDOR))/*.dts)) + +dtb-y += $(subst $(dt_dir)/,,$(dtb-vendor_dts)) + +endif
- bool "Build all devicetree files for a particular vendor"
- depends on OF_UPSTREAM
- help
- string "Vendor to build all upstream devicetree files for"
- depends on OF_UPSTREAM_BUILD_VENDOR
- default "qcom" if ARCH_SNAPDRAGON
- default "rockchip" if ARCH_ROCKCHIP
- default "amlogic" if ARCH_MESON
- default "allwinner" if ARCH_SUNXI
- default "mediatek" if ARCH_MEDIATEK
- default "marvell" if ARCH_MVEBU || ARCH_KIRKWOOD
- default "xilinx" if ARCH_VERSAL || ARCH_ZYNQ
This is not enough it should be
ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARCH_VERSAL_NET
Thanks, Michal
Caleb Connolly
Michal Simek
