[U-Boot] [PATCH v2] tegra: fdt: remove clocks nodes
These nodes are unused.
Signed-off-by: Allen Martin amartin@nvidia.com --- v2: remove "clock" as well as "clocks" nodes remove from non nvidia tegra boards as well v1: original submission --- arch/arm/dts/tegra20.dtsi | 10 ---------- arch/arm/dts/tegra30.dtsi | 10 ---------- board/avionic-design/dts/tegra20-medcom-wide.dts | 14 -------------- board/avionic-design/dts/tegra20-plutux.dts | 14 -------------- board/avionic-design/dts/tegra20-tec.dts | 14 -------------- board/compal/dts/tegra20-paz00.dts | 13 ------------- board/compulab/dts/tegra20-trimslice.dts | 13 ------------- board/nvidia/dts/tegra20-harmony.dts | 13 ------------- board/nvidia/dts/tegra20-seaboard.dts | 10 ---------- board/nvidia/dts/tegra20-ventana.dts | 13 ------------- board/nvidia/dts/tegra20-whistler.dts | 10 ---------- board/nvidia/dts/tegra30-cardhu.dts | 13 ------------- 12 files changed, 147 deletions(-)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 636ec2c..cc086b1 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -10,16 +10,6 @@ #clock-cells = <1>; };
- clocks { - #address-cells = <1>; - #size-cells = <0>; - - osc: clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - }; - }; - intc: interrupt-controller@50041000 { compatible = "nvidia,tegra20-gic"; interrupt-controller; diff --git a/arch/arm/dts/tegra30.dtsi b/arch/arm/dts/tegra30.dtsi index 664c397..09bdb36 100644 --- a/arch/arm/dts/tegra30.dtsi +++ b/arch/arm/dts/tegra30.dtsi @@ -9,16 +9,6 @@ #clock-cells = <1>; };
- clocks { - #address-cells = <1>; - #size-cells = <0>; - - osc: clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - }; - }; - i2c@7000c000 { #address-cells = <1>; #size-cells = <0>; diff --git a/board/avionic-design/dts/tegra20-medcom-wide.dts b/board/avionic-design/dts/tegra20-medcom-wide.dts index 70587a6..e46afbe 100644 --- a/board/avionic-design/dts/tegra20-medcom-wide.dts +++ b/board/avionic-design/dts/tegra20-medcom-wide.dts @@ -14,16 +14,6 @@ reg = <0x00000000 0x20000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - - osc { - clock-frequency = <12000000>; - }; - }; - host1x { status = "okay";
@@ -37,10 +27,6 @@ }; };
- clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = <216000000>; }; diff --git a/board/avionic-design/dts/tegra20-plutux.dts b/board/avionic-design/dts/tegra20-plutux.dts index 78c394f..3e6cce0 100644 --- a/board/avionic-design/dts/tegra20-plutux.dts +++ b/board/avionic-design/dts/tegra20-plutux.dts @@ -14,20 +14,6 @@ reg = <0x00000000 0x20000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = <216000000>; }; diff --git a/board/avionic-design/dts/tegra20-tec.dts b/board/avionic-design/dts/tegra20-tec.dts index cdb7527..8135eeb 100644 --- a/board/avionic-design/dts/tegra20-tec.dts +++ b/board/avionic-design/dts/tegra20-tec.dts @@ -14,16 +14,6 @@ reg = <0x00000000 0x20000000>; };
- clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = <216000000>; }; diff --git a/board/compal/dts/tegra20-paz00.dts b/board/compal/dts/tegra20-paz00.dts index afebbe5..0fef713 100644 --- a/board/compal/dts/tegra20-paz00.dts +++ b/board/compal/dts/tegra20-paz00.dts @@ -14,19 +14,6 @@ reg = <0x00000000 0x20000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006000 { clock-frequency = < 216000000 >; }; diff --git a/board/compulab/dts/tegra20-trimslice.dts b/board/compulab/dts/tegra20-trimslice.dts index 4450674..c8a4dd4 100644 --- a/board/compulab/dts/tegra20-trimslice.dts +++ b/board/compulab/dts/tegra20-trimslice.dts @@ -15,19 +15,6 @@ reg = <0x00000000 0x40000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006000 { clock-frequency = <216000000>; }; diff --git a/board/nvidia/dts/tegra20-harmony.dts b/board/nvidia/dts/tegra20-harmony.dts index 5645a8d..b456406 100644 --- a/board/nvidia/dts/tegra20-harmony.dts +++ b/board/nvidia/dts/tegra20-harmony.dts @@ -15,19 +15,6 @@ reg = <0x00000000 0x40000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = < 216000000 >; }; diff --git a/board/nvidia/dts/tegra20-seaboard.dts b/board/nvidia/dts/tegra20-seaboard.dts index dd98ca4..5fd8ae2 100644 --- a/board/nvidia/dts/tegra20-seaboard.dts +++ b/board/nvidia/dts/tegra20-seaboard.dts @@ -45,16 +45,6 @@ }; };
- clocks { - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = < 216000000 >; }; diff --git a/board/nvidia/dts/tegra20-ventana.dts b/board/nvidia/dts/tegra20-ventana.dts index 38b7b13..3e5e39d 100644 --- a/board/nvidia/dts/tegra20-ventana.dts +++ b/board/nvidia/dts/tegra20-ventana.dts @@ -14,19 +14,6 @@ reg = <0x00000000 0x40000000>; };
- clocks { - clk_32k: clk_32k { - clock-frequency = <32000>; - }; - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006300 { clock-frequency = < 216000000 >; }; diff --git a/board/nvidia/dts/tegra20-whistler.dts b/board/nvidia/dts/tegra20-whistler.dts index f830cf3..4579557 100644 --- a/board/nvidia/dts/tegra20-whistler.dts +++ b/board/nvidia/dts/tegra20-whistler.dts @@ -16,16 +16,6 @@ reg = < 0x00000000 0x20000000 >; };
- clocks { - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - serial@70006000 { clock-frequency = < 216000000 >; }; diff --git a/board/nvidia/dts/tegra30-cardhu.dts b/board/nvidia/dts/tegra30-cardhu.dts index 60b91b4..3223ed4 100644 --- a/board/nvidia/dts/tegra30-cardhu.dts +++ b/board/nvidia/dts/tegra30-cardhu.dts @@ -20,19 +20,6 @@ reg = <0x80000000 0x40000000>; };
- clocks { - clk_32k: clk_32K { - clock-frequency = <32768>; - }; - osc { - clock-frequency = <12000000>; - }; - }; - - clock@60006000 { - clocks = <&clk_32k &osc>; - }; - i2c@7000c000 { clock-frequency = <100000>; };
I can't remember the code that used this - maybe it never went upstream? Obviously we don't need it.
clocks {
#size-cells = <0>;
osc: clock {
#clock-cells = <0>;
clocks {
#size-cells = <0>;
osc: clock {
#clock-cells = <0>;
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32k {
osc {
clock@60006000 {
clocks {
osc {
clock@60006000 {
clocks {
clk_32k: clk_32K {
osc {
clock@60006000 {
-- 1.7.10.4
Allen Martin
